[fusion-commits] r1899 - trunk/lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Sep 17 23:49:58 EDT 2009
Author: zjames
Date: 2009-09-17 23:49:57 -0400 (Thu, 17 Sep 2009)
New Revision: 1899
   trunk/lib/fusion.js
re #289: only attempt to load apis from AppDef if it's in the repository
Modified: trunk/lib/fusion.js
--- trunk/lib/fusion.js	2009-09-17 17:36:19 UTC (rev 1898)
+++ trunk/lib/fusion.js	2009-09-18 03:49:57 UTC (rev 1899)
@@ -1115,5 +1115,97 @@
             document.write(allScriptTags.join(""));
+    /* Load commercial layer API scripts */
+    /*This function is extracted from Fusion to get the MapAgentUrl */
+    var getAgentUrl = function() {
+        * if the application has been loaded from the same host as
+        * fusion is installed in, then technically we don't need to
+        * use the redirect script because we conform to the
+        * Same Origin Policy for XmlHttpRequest to work.
+        var fusionURL = Fusion._getScriptLocation();
+        var testUrl = window.location.protocol + '//' + window.location.host;
+        var configUrl = 'config.json';
+        if (((Fusion.fusionURL.indexOf("http://") < 0) || (Fusion.fusionURL.indexOf(testUrl, 0) == 0)) && !(Fusion.bForceRedirect)) {
+            Fusion.sRedirectScript = '';
+        else {
+            Fusion.sRedirectScript = 'redirect.php';
+            configUrl += '&method=get';
+        var r = Fusion.getRedirectScript();
+        if (r != '') {
+            r = r + '?s=';
+        var fusionURL = r + Fusion.getFusionURL() + configUrl;
+        var xhr = new XMLHttpRequest();
+        xhr.open("GET", fusionURL, false);
+        xhr.send(null);
+        eval("Fusion.configuration=" + xhr.responseText);
+        var s = Fusion.configuration.mapguide.webTierUrl;
+        /* if it is set, use it ... otherwise assume fusion is installed in
+        * the default location and compute the web tier url from that
+        if (s) {
+            var nLength = s.length;
+            var slastChar = s.charAt((nLength - 1));
+            if (slastChar != '/') {
+                s = s + "/";
+        else {
+            var idx = Fusion.fusionURL.lastIndexOf('fusion');
+            if (idx == -1) {
+                s = Fusion.fusionURL + "../";   //loaded relatively from within fusion directory
+            else {
+                s = Fusion.fusionURL.substring(0, idx);
+        Fusion.configuration.mapguide.mapAgentUrl = s + 'mapagent/mapagent.fcgi';
+        return Fusion.configuration.mapguide.mapAgentUrl;
+    var addElement = function(element) {
+        if (!element) {
+            return;
+        var src = element.textContent;
+        // For IE Browser
+        if (!src) {
+            src = element.text;
+        document.writeln('<script src="' + src + '"><\/script>');
+    var appDefUrl = Fusion.getQueryParam('ApplicationDefinition');
+    if(appDefUrl){
+        var mapAgentUrl = getAgentUrl();
+        xhr.open("GET", mapAgentUrl + "?OPERATION=GETRESOURCECONTENT&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=" + appDefUrl + "&FORMAT=text%2Fxml", false);
+        xhr.send(null);
+        var appDefXML = xhr.responseXML.documentElement;
+        if(appDefXML){
+            var googleElement = appDefXML.getElementsByTagName("GoogleScript")[0];
+            var yahooElement = appDefXML.getElementsByTagName("YahooScript")[0];
+            var veElement = appDefXML.getElementsByTagName("VirtualEarthScript")[0];
+            addElement(googleElement);
+            addElement(yahooElement);
+            addElement(veElement);
More information about the fusion-commits mailing list
