[fusion-commits] r1907 - in trunk: layers layers/MapGuide
layers/MapServer layers/MapServer/php lib
templates/mapserver/standard widgets
svn_fusion at osgeo.org
Thu Sep 24 11:32:42 EDT 2009
Author: madair
Date: 2009-09-24 11:32:41 -0400 (Thu, 24 Sep 2009)
New Revision: 1907
Added:
trunk/lib/proj4js-compressed.js
trunk/templates/mapserver/standard/EPSG42304.js
trunk/layers/Layers.js
trunk/layers/MapGuide/MapGuide.js
trunk/layers/MapServer/MapServer.js
trunk/layers/MapServer/php/LoadMap.php
trunk/lib/Map.js
trunk/lib/fusion.js
trunk/templates/mapserver/standard/ApplicationDefinition.xml
trunk/templates/mapserver/standard/index.html
trunk/widgets/Measure.js
re #247: add projection support so the measure widget can work with maps in any projection; this adds the Proj4js library
Modified: trunk/layers/Layers.js
--- trunk/layers/Layers.js 2009-09-23 22:07:49 UTC (rev 1906)
+++ trunk/layers/Layers.js 2009-09-24 15:32:41 UTC (rev 1907)
@@ -76,6 +76,16 @@
this.mapInfo = mapTag.mapInfo;
this.layerType = mapTag.type;
+ //projection info from the extension
+ if (mapTag.extension.ProjectionCode) {
+ this.projCode = mapTag.extension.ProjectionCode[0];
+ if (mapTag.extension.ProjectionDef) {
+ var projDef = mapTag.extension.ProjectionDef[0];
+ this.projCode = "APP-DEF-PROJ";
+ Proj4js.defs[this.projCode] = projDef;
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2009-09-23 22:07:49 UTC (rev 1906)
+++ trunk/layers/MapGuide/MapGuide.js 2009-09-24 15:32:41 UTC (rev 1907)
@@ -603,11 +603,6 @@
layerOptions.alpha = true;
- //Fix for IE6 PNG transparency
- if (params.format && params.format.toLowerCase().indexOf('png') >= 0) {
- layerOptions.alpha = true;
var url;
if ( !bSingleTile && layerOptions.useHttpTile) {
url = Fusion.getConfigurationItem('mapguide', 'tileCacheUrl');
Modified: trunk/layers/MapServer/MapServer.js
--- trunk/layers/MapServer/MapServer.js 2009-09-23 22:07:49 UTC (rev 1906)
+++ trunk/layers/MapServer/MapServer.js 2009-09-24 15:32:41 UTC (rev 1907)
@@ -184,9 +184,23 @@
this._sMapFile = o.mapId;
this._sMapname = o.mapName;
this._sMapTitle = o.mapTitle;
- this.mapWidget.setMetersPerUnit(o.metersPerUnit);
this._sImageType = o.imagetype;
this.metadata = o.metadata;
+ //setup the projection in the map widget
+ if (o.projString.length > 0) {
+ var epsg = o.projString.indexOf("init=");
+ if (epsg >= 0) {
+ this.projCode = o.projString.substring(epsg+5).toUpperCase();
+ } else {
+ this.projCode = o.mapName.toUpperCase();
+ Proj4js.defs[this.projCode] = o.projString;
+ if (this.projCode) {
+ this.mapWidget.setProjection(this.projCode);
+ this.mapWidget.setMetersPerUnit(o.metersPerUnit);
this.mapTag.layerOptions.maxExtent = OpenLayers.Bounds.fromArray(o.extent);
Modified: trunk/layers/MapServer/php/LoadMap.php
--- trunk/layers/MapServer/php/LoadMap.php 2009-09-23 22:07:49 UTC (rev 1906)
+++ trunk/layers/MapServer/php/LoadMap.php 2009-09-24 15:32:41 UTC (rev 1907)
@@ -152,6 +152,7 @@
+ $mapObj->projString = $oMap->getProjection();
$mapObj->metersPerUnit = GetMetersPerUnit($oMap->units);
$mapObj->dpi = $oMap->resolution;
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js 2009-09-23 22:07:49 UTC (rev 1906)
+++ trunk/lib/Map.js 2009-09-24 15:32:41 UTC (rev 1907)
@@ -781,6 +781,20 @@
+ * initializes the OpenLayers projection object on the Map object
+ * @param projCode projection code
+ setProjection: function(projCode) {
+ if (!Proj4js.defs[projCode]) {
+ Fusion.reportError( new Fusion.Error(Fusion.Error.WARNING,
+ 'Projection definition not found for:'+projCode));
+ this.oMapOL.projection = projCode;
* initializes the meters per unit values when a new map is loaded. Some systems make different
* assumptions for the conversion of degrees to meters so this makes sure both Fusion and
* OpenLayers are using the same value.
Modified: trunk/lib/fusion.js
--- trunk/lib/fusion.js 2009-09-23 22:07:49 UTC (rev 1906)
+++ trunk/lib/fusion.js 2009-09-24 15:32:41 UTC (rev 1907)
@@ -1079,6 +1079,7 @@
if (!Fusion._singleFile) {
var coreScripts = ['lib/OpenLayers/OpenLayers.js',
'lib/jxlib.uncompressed.js',
+ 'lib/proj4js-compressed.js',
'lib/EventMgr.js',
'lib/Error.js',
'lib/ApplicationDefinition.js',
Added: trunk/lib/proj4js-compressed.js
--- trunk/lib/proj4js-compressed.js (rev 0)
+++ trunk/lib/proj4js-compressed.js 2009-09-24 15:32:41 UTC (rev 1907)
@@ -0,0 +1,208 @@
+ proj4js.js -- Javascript reprojection library.
+ Authors: Mike Adair madairATdmsolutions.ca
+ Richard Greenwood richATgreenwoodmap.com
+ Didier Richard
+ Stephen Irons
+ License: LGPL as per: http://www.gnu.org/copyleft/lesser.html
+ Note: This program is an almost direct port of the C library
+ Proj4.
+Proj4js={defaultDatum:'WGS84',transform:function(source,dest,point){if(!source.readyToUse||!dest.readyToUse){this.reportError("Proj4js initialization for "+source.srsCode+" not yet complete");return point;}
+if((source.srsProjNumber=="900913"&&dest.datumCode!="WGS84")||(dest.srsProjNumber=="900913"&&source.datumCode!="WGS84")){var wgs84=Proj4js.WGS84;this.transform(source,wgs84,point);source=wgs84;}
+if(source.projName=="longlat"){point.x*=Proj4js.common.D2R;point.y*=Proj4js.common.D2R;}else{if(source.to_meter){point.x*=source.to_meter;point.y*=source.to_meter;}
+source.inverse(point);}
+if(source.from_greenwich){point.x+=source.from_greenwich;}
+point=this.datum_transform(source.datum,dest.datum,point);if(dest.from_greenwich){point.x-=dest.from_greenwich;}
+if(dest.projName=="longlat"){point.x*=Proj4js.common.R2D;point.y*=Proj4js.common.R2D;}else{dest.forward(point);if(dest.to_meter){point.x/=dest.to_meter;point.y/=dest.to_meter;}}
+return point;},datum_transform:function(source,dest,point){if(source.compare_datums(dest)){return point;}
+if(source.datum_type==Proj4js.common.PJD_NODATUM||dest.datum_type==Proj4js.common.PJD_NODATUM){return point;}
+if(source.datum_type==Proj4js.common.PJD_GRIDSHIFT)
+{alert("ERROR: Grid shift transformations are not implemented yet.");}
+if(dest.datum_type==Proj4js.common.PJD_GRIDSHIFT)
+if(source.es!=dest.es||source.a!=dest.a||source.datum_type==Proj4js.common.PJD_3PARAM||source.datum_type==Proj4js.common.PJD_7PARAM||dest.datum_type==Proj4js.common.PJD_3PARAM||dest.datum_type==Proj4js.common.PJD_7PARAM)
+{source.geodetic_to_geocentric(point);if(source.datum_type==Proj4js.common.PJD_3PARAM||source.datum_type==Proj4js.common.PJD_7PARAM){source.geocentric_to_wgs84(point);}
+if(dest.datum_type==Proj4js.common.PJD_3PARAM||dest.datum_type==Proj4js.common.PJD_7PARAM){dest.geocentric_from_wgs84(point);}
+dest.geocentric_to_geodetic(point);}
+return point;},reportError:function(msg){},extend:function(destination,source){destination=destination||{};if(source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}}
+return destination;},Class:function(){var Class=function(){this.initialize.apply(this,arguments);};var extended={};var parent;for(var i=0;i<arguments.length;++i){if(typeof arguments[i]=="function"){parent=arguments[i].prototype;}else{parent=arguments[i];}
+Proj4js.extend(extended,parent);}
+Class.prototype=extended;return Class;},bind:function(func,object){var args=Array.prototype.slice.apply(arguments,[2]);return function(){var newArgs=args.concat(Array.prototype.slice.apply(arguments,[0]));return func.apply(object,newArgs);};},scriptName:"proj4js-compressed.js",defsLookupService:'http://spatialreference.org/ref',libPath:null,getScriptLocation:function(){if(this.libPath)return this.libPath;var scriptName=this.scriptName;var scriptNameLen=scriptName.length;var scripts=document.getElementsByTagName('script');for(var i=0;i<scripts.length;i++){var src=scripts[i].getAttribute('src');if(src){var index=src.lastIndexOf(scriptName);if((index>-1)&&(index+scriptNameLen==src.length)){this.libPath=src.slice(0,-scriptNameLen);break;}}}
+return this.libPath||"";},loadScript:function(url,onload,onfail,loadCheck){var script=document.createElement('script');script.defer=false;script.type="text/javascript";script.id=url;script.src=url;script.onload=onload;script.onerror=onfail;script.loadCheck=loadCheck;if(/MSIE/.test(navigator.userAgent)){script.onreadystatechange=this.checkReadyState;}
+document.getElementsByTagName('head')[0].appendChild(script);},checkReadyState:function(){if(this.readyState=='loaded'){if(!this.loadCheck()){this.onerror();}else{this.onload();}}}};Proj4js.Proj=Proj4js.Class({readyToUse:false,title:null,projName:null,units:null,datum:null,initialize:function(srsCode){this.srsCodeInput=srsCode;if(srsCode.indexOf('urn:')==0){var urn=srsCode.split(':');if((urn[1]=='ogc'||urn[1]=='x-ogc')&&(urn[2]=='def')&&(urn[3]=='crs')&&urn.length==7){srsCode=urn[4]+':'+urn[6];}}else if(srsCode.indexOf('http://')==0){var url=srsCode.split('#');if(url[0].match(/epsg.org/)){srsCode='EPSG:'+url[1];}else if(url[0].match(/RIG.xml/)){srsCode='IGNF:'+url[1];}}
+this.srsCode=srsCode.toUpperCase();if(this.srsCode.indexOf("EPSG")==0){this.srsCode=this.srsCode;this.srsAuth='epsg';this.srsProjNumber=this.srsCode.substring(5);}else if(this.srsCode.indexOf("IGNF")==0){this.srsCode=this.srsCode;this.srsAuth='IGNF';this.srsProjNumber=this.srsCode.substring(5);}else if(this.srsCode.indexOf("CRS")==0){this.srsCode=this.srsCode;this.srsAuth='CRS';this.srsProjNumber=this.srsCode.substring(4);}else{this.srsAuth='';this.srsProjNumber=this.srsCode;}
+this.loadProjDefinition();},loadProjDefinition:function(){if(Proj4js.defs[this.srsCode]){this.defsLoaded();return;}
+var url=Proj4js.getScriptLocation()+'defs/'+this.srsAuth.toUpperCase()+this.srsProjNumber+'.js';Proj4js.loadScript(url,Proj4js.bind(this.defsLoaded,this),Proj4js.bind(this.loadFromService,this),Proj4js.bind(this.checkDefsLoaded,this));},loadFromService:function(){var url=Proj4js.defsLookupService+'/'+this.srsAuth+'/'+this.srsProjNumber+'/proj4js/';Proj4js.loadScript(url,Proj4js.bind(this.defsLoaded,this),Proj4js.bind(this.defsFailed,this),Proj4js.bind(this.checkDefsLoaded,this));},defsLoaded:function(){this.parseDefs();this.loadProjCode(this.projName);},checkDefsLoaded:function(){if(Proj4js.defs[this.srsCode]){return true;}else{return false;}},defsFailed:function(){Proj4js.reportError('failed to load projection definition for: '+this.srsCode);Proj4js.defs[this.srsCode]=Proj4js.defs['WGS84'];this.defsLoaded();},loadProjCode:function(projName){if(Proj4js.Proj[projName]){this.initTransforms();return;}
+var url=Proj4js.getScriptLocation()+'projCode/'+projName+'.js';Proj4js.loadScript(url,Proj4js.bind(this.loadProjCodeSuccess,this,projName),Proj4js.bind(this.loadProjCodeFailure,this,projName),Proj4js.bind(this.checkCodeLoaded,this,projName));},loadProjCodeSuccess:function(projName){if(Proj4js.Proj[projName].dependsOn){this.loadProjCode(Proj4js.Proj[projName].dependsOn);}else{this.initTransforms();}},loadProjCodeFailure:function(projName){Proj4js.reportError("failed to find projection file for: "+projName);},checkCodeLoaded:function(projName){if(Proj4js.Proj[projName]){return true;}else{return false;}},initTransforms:function(){Proj4js.extend(this,Proj4js.Proj[this.projName]);this.init();this.readyToUse=true;},parseDefs:function(){this.defData=Proj4js.defs[this.srsCode];var paramName,paramVal;if(!this.defData){return;}
+var paramArray=this.defData.split("+");for(var prop=0;prop<paramArray.length;prop++){var property=paramArray[prop].split("=");paramName=property[0].toLowerCase();paramVal=property[1];switch(paramName.replace(/\s/gi,"")){case"":break;case"title":this.title=paramVal;break;case"proj":this.projName=paramVal.replace(/\s/gi,"");break;case"units":this.units=paramVal.replace(/\s/gi,"");break;case"datum":this.datumCode=paramVal.replace(/\s/gi,"");break;case"nadgrids":this.nagrids=paramVal.replace(/\s/gi,"");break;case"ellps":this.ellps=paramVal.replace(/\s/gi,"");break;case"a":this.a=parseFloat(paramVal);break;case"b":this.b=parseFloat(paramVal);break;case"rf":this.rf=parseFloat(paramVal);break;case"lat_0":this.lat0=paramVal*Proj4js.common.D2R;break;case"lat_1":this.lat1=paramVal*Proj4js.common.D2R;break;case"lat_2":this.lat2=paramVal*Proj4js.common.D2R;break;case"lat_ts":this.lat_ts=paramVal*Proj4js.common.D2R;break;case"lon_0":this.long0=paramVal*Proj4js.common.D2R;break;case"alpha":this.alpha=parseFloat(paramVal)*Proj4js.common.D2R;break;case"lonc":this.longc=paramVal*Proj4js.common.D2R;break;case"x_0":this.x0=parseFloat(paramVal);break;case"y_0":this.y0=parseFloat(paramVal);break;case"k_0":this.k0=parseFloat(paramVal);break;case"k":this.k0=parseFloat(paramVal);break;case"r_a":this.R_A=true;break;case"zone":this.zone=parseInt(paramVal);break;case"south":this.utmSouth=true;break;case"towgs84":this.datum_params=paramVal.split(",");break;case"to_meter":this.to_meter=parseFloat(paramVal);break;case"from_greenwich":this.from_greenwich=paramVal*Proj4js.common.D2R;break;case"pm":paramVal=paramVal.replace(/\s/gi,"");this.from_greenwich=Proj4js.PrimeMeridian[paramVal]?Proj4js.PrimeMeridian[paramVal]:parseFloat(paramVal);this.from_greenwich*=Proj4js.common.D2R;break;case"no_defs":break;default:}}
+this.deriveConstants();},deriveConstants:function(){if(this.nagrids=='@null')this.datumCode='none';if(this.datumCode&&this.datumCode!='none'){var datumDef=Proj4js.Datum[this.datumCode];if(datumDef){this.datum_params=datumDef.towgs84.split(',');this.ellps=datumDef.ellipse;this.datumName=datumDef.datumName?datumDef.datumName:this.datumCode;}}
+if(!this.a){var ellipse=Proj4js.Ellipsoid[this.ellps]?Proj4js.Ellipsoid[this.ellps]:Proj4js.Ellipsoid['WGS84'];Proj4js.extend(this,ellipse);}
+if(this.rf&&!this.b)this.b=(1.0-1.0/this.rf)*this.a;if(Math.abs(this.a-this.b)<Proj4js.common.EPSLN){this.sphere=true;this.b=this.a;}
+this.a2=this.a*this.a;this.b2=this.b*this.b;this.es=(this.a2-this.b2)/this.a2;this.e=Math.sqrt(this.es);if(this.R_A){this.a*=1.-this.es*(Proj4js.common.SIXTH+this.es*(Proj4js.common.RA4+this.es*Proj4js.common.RA6));this.a2=this.a*this.a;this.b2=this.b*this.b;this.es=0.;}
+this.ep2=(this.a2-this.b2)/this.b2;if(!this.k0)this.k0=1.0;this.datum=new Proj4js.datum(this);}});Proj4js.Proj.longlat={init:function(){},forward:function(pt){return pt;},inverse:function(pt){return pt;}};Proj4js.defs={'WGS84':"+title=long/lat:WGS84 +proj=longlat +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4326':"+title=long/lat:WGS84 +proj=longlat +a=6378137.0 +b=6356752.31424518 +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4269':"+title=long/lat:NAD83 +proj=longlat +a=6378137.0 +b=6356752.31414036 +ellps=GRS80 +datum=NAD83 +units=degrees",'EPSG:3785':"+title= Google Mercator +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs"};Proj4js.defs['GOOGLE']=Proj4js.defs['EPSG:3785'];Proj4js.defs['EPSG:900913']=Proj4js.defs['EPSG:3785'];Proj4js.defs['EPSG:102113']=Proj4js.defs['EPSG:3785'];Proj4js.common={PI:3.141592653589793238,HALF_PI:1.570796326794896619,TWO_PI:6.283185307179586477,FORTPI:0.78539816339744833,R2D:57.29577951308232088,D2R:0.01745329251994329577,SEC_TO_RAD:4.84813681109535993589914102357e-6,EPSLN:1.0e-10,MAX_ITER:20,COS_67P5:0.38268343236508977,AD_C:1.0026000,PJD_UNKNOWN:0,PJD_3PARAM:1,PJD_7PARAM:2,PJD_GRIDSHIFT:3,PJD_WGS84:4,PJD_NODATUM:5,SRS_WGS84_SEMIMAJOR:6378137.0,SIXTH:.1666666666666666667,RA4:.04722222222222222222,RA6:.02215608465608465608,RV4:.06944444444444444444,RV6:.04243827160493827160,msfnz:function(eccent,sinphi,cosphi){var con=eccent*sinphi;return cosphi/(Math.sqrt(1.0-con*con));},tsfnz:function(eccent,phi,sinphi){var con=eccent*sinphi;var com=.5*eccent;con=Math.pow(((1.0-con)/(1.0+con)),com);return(Math.tan(.5*(this.HALF_PI-phi))/con);},phi2z:function(eccent,ts){var eccnth=.5*eccent;var con,dphi;var phi=this.HALF_PI-2*Math.atan(ts);for(i=0;i<=15;i++){con=eccent*Math.sin(phi);dphi=this.HALF_PI-2*Math.atan(ts*(Math.pow(((1.0-con)/(1.0+con)),eccnth)))-phi;phi+=dphi;if(Math.abs(dphi)<=.0000000001)return phi;}
+alert("phi2z has NoConvergence");return(-9999);},qsfnz:function(eccent,sinphi){var con;if(eccent>1.0e-7){con=eccent*sinphi;return((1.0-eccent*eccent)*(sinphi/(1.0-con*con)-(.5/eccent)*Math.log((1.0-con)/(1.0+con))));}else{return(2.0*sinphi);}},asinz:function(x){if(Math.abs(x)>1.0){x=(x>1.0)?1.0:-1.0;}
+return Math.asin(x);},e0fn:function(x){return(1.0-0.25*x*(1.0+x/16.0*(3.0+1.25*x)));},e1fn:function(x){return(0.375*x*(1.0+0.25*x*(1.0+0.46875*x)));},e2fn:function(x){return(0.05859375*x*x*(1.0+0.75*x));},e3fn:function(x){return(x*x*x*(35.0/3072.0));},mlfn:function(e0,e1,e2,e3,phi){return(e0*phi-e1*Math.sin(2.0*phi)+e2*Math.sin(4.0*phi)-e3*Math.sin(6.0*phi));},srat:function(esinp,exp){return(Math.pow((1.0-esinp)/(1.0+esinp),exp));},sign:function(x){if(x<0.0)return(-1);else return(1);},adjust_lon:function(x){x=(Math.abs(x)<this.PI)?x:(x-(this.sign(x)*this.TWO_PI));return x;},adjust_lat:function(x){x=(Math.abs(x)<this.HALF_PI)?x:(x-(this.sign(x)*this.PI));return x;},latiso:function(eccent,phi,sinphi){if(Math.abs(phi)>this.HALF_PI)return+Number.NaN;if(phi==this.HALF_PI)return Number.POSITIVE_INFINITY;if(phi==-1.0*this.HALF_PI)return-1.0*Number.POSITIVE_INFINITY;var con=eccent*sinphi;return Math.log(Math.tan((this.HALF_PI+phi)/2.0))+eccent*Math.log((1.0-con)/(1.0+con))/2.0;},fL:function(x,L){return 2.0*Math.atan(x*Math.exp(L))-this.HALF_PI;},invlatiso:function(eccent,ts){var phi=this.fL(1.0,ts);var Iphi=0.0;var con=0.0;do{Iphi=phi;con=eccent*Math.sin(Iphi);phi=this.fL(Math.exp(eccent*Math.log((1.0+con)/(1.0-con))/2.0),ts)}while(Math.abs(phi-Iphi)>1.0e-12);return phi;},sinh:function(x)
+{var r=Math.exp(x);r=(r-1.0/r)/2.0;return r;},cosh:function(x)
+{var r=Math.exp(x);r=(r+1.0/r)/2.0;return r;},tanh:function(x)
+{var r=Math.exp(x);r=(r-1.0/r)/(r+1.0/r);return r;},asinh:function(x)
+{var s=(x>=0?1.0:-1.0);return s*(Math.log(Math.abs(x)+Math.sqrt(x*x+1.0)));},acosh:function(x)
+{return 2.0*Math.log(Math.sqrt((x+1.0)/2.0)+Math.sqrt((x-1.0)/2.0));},atanh:function(x)
+{return Math.log((x-1.0)/(x+1.0))/2.0;},gN:function(a,e,sinphi)
+{var temp=e*sinphi;return a/Math.sqrt(1.0-temp*temp);}};Proj4js.datum=Proj4js.Class({initialize:function(proj){this.datum_type=Proj4js.common.PJD_WGS84;if(proj.datumCode&&proj.datumCode=='none'){this.datum_type=Proj4js.common.PJD_NODATUM;}
+if(proj&&proj.datum_params){for(var i=0;i<proj.datum_params.length;i++){proj.datum_params[i]=parseFloat(proj.datum_params[i]);}
+if(proj.datum_params[0]!=0||proj.datum_params[1]!=0||proj.datum_params[2]!=0){this.datum_type=Proj4js.common.PJD_3PARAM;}
+if(proj.datum_params.length>3){if(proj.datum_params[3]!=0||proj.datum_params[4]!=0||proj.datum_params[5]!=0||proj.datum_params[6]!=0){this.datum_type=Proj4js.common.PJD_7PARAM;proj.datum_params[3]*=Proj4js.common.SEC_TO_RAD;proj.datum_params[4]*=Proj4js.common.SEC_TO_RAD;proj.datum_params[5]*=Proj4js.common.SEC_TO_RAD;proj.datum_params[6]=(proj.datum_params[6]/1000000.0)+1.0;}}}
+if(proj){this.a=proj.a;this.b=proj.b;this.es=proj.es;this.ep2=proj.ep2;this.datum_params=proj.datum_params;}},compare_datums:function(dest){if(this.datum_type!=dest.datum_type){return false;}else if(this.a!=dest.a||Math.abs(this.es-dest.es)>0.000000000050){return false;}else if(this.datum_type==Proj4js.common.PJD_3PARAM){return(this.datum_params[0]==dest.datum_params[0]&&this.datum_params[1]==dest.datum_params[1]&&this.datum_params[2]==dest.datum_params[2]);}else if(this.datum_type==Proj4js.common.PJD_7PARAM){return(this.datum_params[0]==dest.datum_params[0]&&this.datum_params[1]==dest.datum_params[1]&&this.datum_params[2]==dest.datum_params[2]&&this.datum_params[3]==dest.datum_params[3]&&this.datum_params[4]==dest.datum_params[4]&&this.datum_params[5]==dest.datum_params[5]&&this.datum_params[6]==dest.datum_params[6]);}else if(this.datum_type==Proj4js.common.PJD_GRIDSHIFT){return strcmp(pj_param(this.params,"snadgrids").s,pj_param(dest.params,"snadgrids").s)==0;}else{return true;}},geodetic_to_geocentric:function(p){var Longitude=p.x;var Latitude=p.y;var Height=p.z?p.z:0;var X;var Y;var Z;var Error_Code=0;var Rn;var Sin_Lat;var Sin2_Lat;var Cos_Lat;if(Latitude<-Proj4js.common.HALF_PI&&Latitude>-1.001*Proj4js.common.HALF_PI){Latitude=-Proj4js.common.HALF_PI;}else if(Latitude>Proj4js.common.HALF_PI&&Latitude<1.001*Proj4js.common.HALF_PI){Latitude=Proj4js.common.HALF_PI;}else if((Latitude<-Proj4js.common.HALF_PI)||(Latitude>Proj4js.common.HALF_PI)){Proj4js.reportError('geocent:lat out of range:'+Latitude);return null;}
+if(Longitude>Proj4js.common.PI)Longitude-=(2*Proj4js.common.PI);Sin_Lat=Math.sin(Latitude);Cos_Lat=Math.cos(Latitude);Sin2_Lat=Sin_Lat*Sin_Lat;Rn=this.a/(Math.sqrt(1.0e0-this.es*Sin2_Lat));X=(Rn+Height)*Cos_Lat*Math.cos(Longitude);Y=(Rn+Height)*Cos_Lat*Math.sin(Longitude);Z=((Rn*(1-this.es))+Height)*Sin_Lat;p.x=X;p.y=Y;p.z=Z;return Error_Code;},geocentric_to_geodetic:function(p){var genau=1.E-12;var genau2=(genau*genau);var maxiter=30;var P;var RR;var CT;var ST;var RX;var RK;var RN;var CPHI0;var SPHI0;var CPHI;var SPHI;var SDPHI;var At_Pole;var iter;var X=p.x;var Y=p.y;var Z=p.z?p.z:0.0;var Longitude;var Latitude;var Height;At_Pole=false;P=Math.sqrt(X*X+Y*Y);RR=Math.sqrt(X*X+Y*Y+Z*Z);if(P/this.a<genau){At_Pole=true;Longitude=0.0;if(RR/this.a<genau){Latitude=Proj4js.common.HALF_PI;Height=-this.b;return;}}else{Longitude=Math.atan2(Y,X);}
+CT=Z/RR;ST=P/RR;RX=1.0/Math.sqrt(1.0-this.es*(2.0-this.es)*ST*ST);CPHI0=ST*(1.0-this.es)*RX;SPHI0=CT*RX;iter=0;do
+{iter++;RN=this.a/Math.sqrt(1.0-this.es*SPHI0*SPHI0);Height=P*CPHI0+Z*SPHI0-RN*(1.0-this.es*SPHI0*SPHI0);RK=this.es*RN/(RN+Height);RX=1.0/Math.sqrt(1.0-RK*(2.0-RK)*ST*ST);CPHI=ST*(1.0-RK)*RX;SPHI=CT*RX;SDPHI=SPHI*CPHI0-CPHI*SPHI0;CPHI0=CPHI;SPHI0=SPHI;}
+while(SDPHI*SDPHI>genau2&&iter<maxiter);Latitude=Math.atan(SPHI/Math.abs(CPHI));p.x=Longitude;p.y=Latitude;p.z=Height;return p;},geocentric_to_geodetic_noniter:function(p){var X=p.x;var Y=p.y;var Z=p.z?p.z:0;var Longitude;var Latitude;var Height;var W;var W2;var T0;var T1;var S0;var S1;var Sin_B0;var Sin3_B0;var Cos_B0;var Sin_p1;var Cos_p1;var Rn;var Sum;var At_Pole;X=parseFloat(X);Y=parseFloat(Y);Z=parseFloat(Z);At_Pole=false;if(X!=0.0)
+{Longitude=Math.atan2(Y,X);}
+else
+{if(Y>0)
+{Longitude=Proj4js.common.HALF_PI;}
+else if(Y<0)
+{Longitude=-Proj4js.common.HALF_PI;}
+else
+{At_Pole=true;Longitude=0.0;if(Z>0.0)
+{Latitude=Proj4js.common.HALF_PI;}
+else if(Z<0.0)
+{Latitude=-Proj4js.common.HALF_PI;}
+else
+{Latitude=Proj4js.common.HALF_PI;Height=-this.b;return;}}}
+W2=X*X+Y*Y;W=Math.sqrt(W2);T0=Z*Proj4js.common.AD_C;S0=Math.sqrt(T0*T0+W2);Sin_B0=T0/S0;Cos_B0=W/S0;Sin3_B0=Sin_B0*Sin_B0*Sin_B0;T1=Z+this.b*this.ep2*Sin3_B0;Sum=W-this.a*this.es*Cos_B0*Cos_B0*Cos_B0;S1=Math.sqrt(T1*T1+Sum*Sum);Sin_p1=T1/S1;Cos_p1=Sum/S1;Rn=this.a/Math.sqrt(1.0-this.es*Sin_p1*Sin_p1);if(Cos_p1>=Proj4js.common.COS_67P5)
+{Height=W/Cos_p1-Rn;}
+else if(Cos_p1<=-Proj4js.common.COS_67P5)
+{Height=W/-Cos_p1-Rn;}
+else
+{Height=Z/Sin_p1+Rn*(this.es-1.0);}
+if(At_Pole==false)
+{Latitude=Math.atan(Sin_p1/Cos_p1);}
+p.x=Longitude;p.y=Latitude;p.z=Height;return p;},geocentric_to_wgs84:function(p){if(this.datum_type==Proj4js.common.PJD_3PARAM)
+{p.x+=this.datum_params[0];p.y+=this.datum_params[1];p.z+=this.datum_params[2];}
+else if(this.datum_type==Proj4js.common.PJD_7PARAM)
+{var Dx_BF=this.datum_params[0];var Dy_BF=this.datum_params[1];var Dz_BF=this.datum_params[2];var Rx_BF=this.datum_params[3];var Ry_BF=this.datum_params[4];var Rz_BF=this.datum_params[5];var M_BF=this.datum_params[6];var x_out=M_BF*(p.x-Rz_BF*p.y+Ry_BF*p.z)+Dx_BF;var y_out=M_BF*(Rz_BF*p.x+p.y-Rx_BF*p.z)+Dy_BF;var z_out=M_BF*(-Ry_BF*p.x+Rx_BF*p.y+p.z)+Dz_BF;p.x=x_out;p.y=y_out;p.z=z_out;}},geocentric_from_wgs84:function(p){if(this.datum_type==Proj4js.common.PJD_3PARAM)
+{p.x-=this.datum_params[0];p.y-=this.datum_params[1];p.z-=this.datum_params[2];}
+{var Dx_BF=this.datum_params[0];var Dy_BF=this.datum_params[1];var Dz_BF=this.datum_params[2];var Rx_BF=this.datum_params[3];var Ry_BF=this.datum_params[4];var Rz_BF=this.datum_params[5];var M_BF=this.datum_params[6];var x_tmp=(p.x-Dx_BF)/M_BF;var y_tmp=(p.y-Dy_BF)/M_BF;var z_tmp=(p.z-Dz_BF)/M_BF;p.x=x_tmp+Rz_BF*y_tmp-Ry_BF*z_tmp;p.y=-Rz_BF*x_tmp+y_tmp+Rx_BF*z_tmp;p.z=Ry_BF*x_tmp-Rx_BF*y_tmp+z_tmp;}}});Proj4js.Point=Proj4js.Class({initialize:function(x,y,z){if(typeof x=='object'){this.x=x[0];this.y=x[1];this.z=x[2]||0.0;}else if(typeof x=='string'){var coords=x.split(',');this.x=parseFloat(coords[0]);this.y=parseFloat(coords[1]);this.z=parseFloat(coords[2])||0.0;}else{this.x=x;this.y=y;this.z=z||0.0;}},clone:function(){return new Proj4js.Point(this.x,this.y,this.z);},toString:function(){return("x="+this.x+",y="+this.y);},toShortString:function(){return(this.x+", "+this.y);}});Proj4js.PrimeMeridian={"greenwich":0.0,"lisbon":-9.131906111111,"paris":2.337229166667,"bogota":-74.080916666667,"madrid":-3.687938888889,"rome":12.452333333333,"bern":7.439583333333,"jakarta":106.807719444444,"ferro":-17.666666666667,"brussels":4.367975,"stockholm":18.058277777778,"athens":23.7163375,"oslo":10.722916666667};Proj4js.Ellipsoid={"MERIT":{a:6378137.0,rf:298.257,ellipseName:"MERIT 1983"},"SGS85":{a:6378136.0,rf:298.257,ellipseName:"Soviet Geodetic System 85"},"GRS80":{a:6378137.0,rf:298.257222101,ellipseName:"GRS 1980(IUGG, 1980)"},"IAU76":{a:6378140.0,rf:298.257,ellipseName:"IAU 1976"},"airy":{a:6377563.396,b:6356256.910,ellipseName:"Airy 1830"},"APL4.":{a:6378137,rf:298.25,ellipseName:"Appl. Physics. 1965"},"NWL9D":{a:6378145.0,rf:298.25,ellipseName:"Naval Weapons Lab., 1965"},"mod_airy":{a:6377340.189,b:6356034.446,ellipseName:"Modified Airy"},"andrae":{a:6377104.43,rf:300.0,ellipseName:"Andrae 1876 (Den., Iclnd.)"},"aust_SA":{a:6378160.0,rf:298.25,ellipseName:"Australian Natl & S. Amer. 1969"},"GRS67":{a:6378160.0,rf:298.2471674270,ellipseName:"GRS 67(IUGG 1967)"},"bessel":{a:6377397.155,rf:299.1528128,ellipseName:"Bessel 1841"},"bess_nam":{a:6377483.865,rf:299.1528128,ellipseName:"Bessel 1841 (Namibia)"},"clrk66":{a:6378206.4,b:6356583.8,ellipseName:"Clarke 1866"},"clrk80":{a:6378249.145,rf:293.4663,ellipseName:"Clarke 1880 mod."},"CPM":{a:6375738.7,rf:334.29,ellipseName:"Comm. des Poids et Mesures 1799"},"delmbr":{a:6376428.0,rf:311.5,ellipseName:"Delambre 1810 (Belgium)"},"engelis":{a:6378136.05,rf:298.2566,ellipseName:"Engelis 1985"},"evrst30":{a:6377276.345,rf:300.8017,ellipseName:"Everest 1830"},"evrst48":{a:6377304.063,rf:300.8017,ellipseName:"Everest 1948"},"evrst56":{a:6377301.243,rf:300.8017,ellipseName:"Everest 1956"},"evrst69":{a:6377295.664,rf:300.8017,ellipseName:"Everest 1969"},"evrstSS":{a:6377298.556,rf:300.8017,ellipseName:"Everest (Sabah & Sarawak)"},"fschr60":{a:6378166.0,rf:298.3,ellipseName:"Fischer (Mercury Datum) 1960"},"fschr60m":{a:6378155.0,rf:298.3,ellipseName:"Fischer 1960"},"fschr68":{a:6378150.0,rf:298.3,ellipseName:"Fischer 1968"},"helmert":{a:6378200.0,rf:298.3,ellipseName:"Helmert 1906"},"hough":{a:6378270.0,rf:297.0,ellipseName:"Hough"},"intl":{a:6378388.0,rf:297.0,ellipseName:"International 1909 (Hayford)"},"kaula":{a:6378163.0,rf:298.24,ellipseName:"Kaula 1961"},"lerch":{a:6378139.0,rf:298.257,ellipseName:"Lerch 1979"},"mprts":{a:6397300.0,rf:191.0,ellipseName:"Maupertius 1738"},"new_intl":{a:6378157.5,b:6356772.2,ellipseName:"New International 1967"},"plessis":{a:6376523.0,rf:6355863.0,ellipseName:"Plessis 1817 (France)"},"krass":{a:6378245.0,rf:298.3,ellipseName:"Krassovsky, 1942"},"SEasia":{a:6378155.0,b:6356773.3205,ellipseName:"Southeast Asia"},"walbeck":{a:6376896.0,b:6355834.8467,ellipseName:"Walbeck"},"WGS60":{a:6378165.0,rf:298.3,ellipseName:"WGS 60"},"WGS66":{a:6378145.0,rf:298.25,ellipseName:"WGS 66"},"WGS72":{a:6378135.0,rf:298.26,ellipseName:"WGS 72"},"WGS84":{a:6378137.0,rf:298.257223563,ellipseName:"WGS 84"},"sphere":{a:6370997.0,b:6370997.0,ellipseName:"Normal Sphere (r=6370997)"}};Proj4js.Datum={"WGS84":{towgs84:"0,0,0",ellipse:"WGS84",datumName:"WGS84"},"GGRS87":{towgs84:"-199.87,74.79,246.62",ellipse:"GRS80",datumName:"Greek_Geodetic_Reference_System_1987"},"NAD83":{towgs84:"0,0,0",ellipse:"GRS80",datumName:"North_American_Datum_1983"},"NAD27":{nadgrids:"@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat",ellipse:"clrk66",datumName:"North_American_Datum_1927"},"potsdam":{towgs84:"606.0,23.0,413.0",ellipse:"bessel",datumName:"Potsdam Rauenberg 1950 DHDN"},"carthage":{towgs84:"-263.0,6.0,431.0",ellipse:"clark80",datumName:"Carthage 1934 Tunisia"},"hermannskogel":{towgs84:"653.0,-212.0,449.0",ellipse:"bessel",datumName:"Hermannskogel"},"ire65":{towgs84:"482.530,-130.596,564.557,-1.042,-0.214,-0.631,8.15",ellipse:"mod_airy",datumName:"Ireland 1965"},"nzgd49":{towgs84:"59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993",ellipse:"intl",datumName:"New Zealand Geodetic Datum 1949"},"OSGB36":{towgs84:"446.448,-125.157,542.060,0.1502,0.2470,0.8421,-20.4894",ellipse:"airy",datumName:"Airy 1830"}};Proj4js.WGS84=new Proj4js.Proj('WGS84');Proj4js.Datum['OSB36']=Proj4js.Datum['OSGB36'];Proj4js.Proj.aea={init:function(){if(Math.abs(this.lat1+this.lat2)<Proj4js.common.EPSLN){Proj4js.reportError("aeaInitEqualLatitudes");return;}
+this.temp=this.b/this.a;this.es=1.0-Math.pow(this.temp,2);this.e3=Math.sqrt(this.es);this.sin_po=Math.sin(this.lat1);this.cos_po=Math.cos(this.lat1);this.t1=this.sin_po;this.con=this.sin_po;this.ms1=Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);this.qs1=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);this.sin_po=Math.sin(this.lat2);this.cos_po=Math.cos(this.lat2);this.t2=this.sin_po;this.ms2=Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);this.qs2=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);this.sin_po=Math.sin(this.lat0);this.cos_po=Math.cos(this.lat0);this.t3=this.sin_po;this.qs0=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);if(Math.abs(this.lat1-this.lat2)>Proj4js.common.EPSLN){this.ns0=(this.ms1*this.ms1-this.ms2*this.ms2)/(this.qs2-this.qs1);}else{this.ns0=this.con;}
+this.c=this.ms1*this.ms1+this.ns0*this.qs1;this.rh=this.a*Math.sqrt(this.c-this.ns0*this.qs0)/this.ns0;},forward:function(p){var lon=p.x;var lat=p.y;this.sin_phi=Math.sin(lat);this.cos_phi=Math.cos(lat);var qs=Proj4js.common.qsfnz(this.e3,this.sin_phi,this.cos_phi);var rh1=this.a*Math.sqrt(this.c-this.ns0*qs)/this.ns0;var theta=this.ns0*Proj4js.common.adjust_lon(lon-this.long0);var x=rh1*Math.sin(theta)+this.x0;var y=this.rh-rh1*Math.cos(theta)+this.y0;p.x=x;p.y=y;return p;},inverse:function(p){var rh1,qs,con,theta,lon,lat;p.x-=this.x0;p.y=this.rh-p.y+this.y0;if(this.ns0>=0){rh1=Math.sqrt(p.x*p.x+p.y*p.y);con=1.0;}else{rh1=-Math.sqrt(p.x*p.x+p.y*p.y);con=-1.0;}
+theta=0.0;if(rh1!=0.0){theta=Math.atan2(con*p.x,con*p.y);}
+con=rh1*this.ns0/this.a;qs=(this.c-con*con)/this.ns0;if(this.e3>=1e-10){con=1-.5*(1.0-this.es)*Math.log((1.0-this.e3)/(1.0+this.e3))/this.e3;if(Math.abs(Math.abs(con)-Math.abs(qs))>.0000000001){lat=this.phi1z(this.e3,qs);}else{if(qs>=0){lat=.5*PI;}else{lat=-.5*PI;}}}else{lat=this.phi1z(e3,qs);}
+lon=Proj4js.common.adjust_lon(theta/this.ns0+this.long0);p.x=lon;p.y=lat;return p;},phi1z:function(eccent,qs){var con,com,dphi;var phi=Proj4js.common.asinz(.5*qs);if(eccent<Proj4js.common.EPSLN)return phi;var eccnts=eccent*eccent;for(var i=1;i<=25;i++){sinphi=Math.sin(phi);cosphi=Math.cos(phi);con=eccent*sinphi;com=1.0-con*con;dphi=.5*com*com/cosphi*(qs/(1.0-eccnts)-sinphi/com+.5/eccent*Math.log((1.0-con)/(1.0+con)));phi=phi+dphi;if(Math.abs(dphi)<=1e-7)return phi;}
+Proj4js.reportError("aea:phi1z:Convergence error");return null;}};Proj4js.Proj.sterea={dependsOn:'gauss',init:function(){Proj4js.Proj['gauss'].init.apply(this);if(!this.rc){Proj4js.reportError("sterea:init:E_ERROR_0");return;}
+this.sinc0=Math.sin(this.phic0);this.cosc0=Math.cos(this.phic0);this.R2=2.0*this.rc;if(!this.title)this.title="Oblique Stereographic Alternative";},forward:function(p){p.x=Proj4js.common.adjust_lon(p.x-this.long0);Proj4js.Proj['gauss'].forward.apply(this,[p]);sinc=Math.sin(p.y);cosc=Math.cos(p.y);cosl=Math.cos(p.x);k=this.k0*this.R2/(1.0+this.sinc0*sinc+this.cosc0*cosc*cosl);p.x=k*cosc*Math.sin(p.x);p.y=k*(this.cosc0*sinc-this.sinc0*cosc*cosl);p.x=this.a*p.x+this.x0;p.y=this.a*p.y+this.y0;return p;},inverse:function(p){var lon,lat;p.x=(p.x-this.x0)/this.a;p.y=(p.y-this.y0)/this.a;p.x/=this.k0;p.y/=this.k0;if((rho=Math.sqrt(p.x*p.x+p.y*p.y))){c=2.0*Math.atan2(rho,this.R2);sinc=Math.sin(c);cosc=Math.cos(c);lat=Math.asin(cosc*this.sinc0+p.y*sinc*this.cosc0/rho);lon=Math.atan2(p.x*sinc,rho*this.cosc0*cosc-p.y*this.sinc0*sinc);}else{lat=this.phic0;lon=0.;}
+p.x=lon;p.y=lat;Proj4js.Proj['gauss'].inverse.apply(this,[p]);p.x=Proj4js.common.adjust_lon(p.x+this.long0);return p;}};function phi4z(eccent,e0,e1,e2,e3,a,b,c,phi){var sinphi,sin2ph,tanph,ml,mlp,con1,con2,con3,dphi,i;phi=a;for(i=1;i<=15;i++){sinphi=Math.sin(phi);tanphi=Math.tan(phi);c=tanphi*Math.sqrt(1.0-eccent*sinphi*sinphi);sin2ph=Math.sin(2.0*phi);ml=e0*phi-e1*sin2ph+e2*Math.sin(4.0*phi)-e3*Math.sin(6.0*phi);mlp=e0-2.0*e1*Math.cos(2.0*phi)+4.0*e2*Math.cos(4.0*phi)-6.0*e3*Math.cos(6.0*phi);con1=2.0*ml+c*(ml*ml+b)-2.0*a*(c*ml+1.0);con2=eccent*sin2ph*(ml*ml+b-2.0*a*ml)/(2.0*c);con3=2.0*(a-ml)*(c*mlp-2.0/sin2ph)-2.0*mlp;dphi=con1/(con2+con3);phi+=dphi;if(Math.abs(dphi)<=.0000000001)return(phi);}
+Proj4js.reportError("phi4z: No convergence");return null;}
+function e4fn(x){var con,com;con=1.0+x;com=1.0-x;return(Math.sqrt((Math.pow(con,con))*(Math.pow(com,com))));}
+Proj4js.Proj.poly={init:function(){var temp;if(this.lat0=0)this.lat0=90;this.temp=this.b/this.a;this.es=1.0-Math.pow(this.temp,2);this.e=Math.sqrt(this.es);this.e0=Proj4js.common.e0fn(this.es);this.e1=Proj4js.common.e1fn(this.es);this.e2=Proj4js.common.e2fn(this.es);this.e3=Proj4js.common.e3fn(this.es);this.ml0=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,this.lat0);},forward:function(p){var sinphi,cosphi;var al;var c;var con,ml;var ms;var x,y;var lon=p.x;var lat=p.y;con=Proj4js.common.adjust_lon(lon-this.long0);if(Math.abs(lat)<=.0000001){x=this.x0+this.a*con;y=this.y0-this.a*this.ml0;}else{sinphi=Math.sin(lat);cosphi=Math.cos(lat);ml=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,lat);ms=Proj4js.common.msfnz(this.e,sinphi,cosphi);con=sinphi;x=this.x0+this.a*ms*Math.sin(con)/sinphi;y=this.y0+this.a*(ml-this.ml0+ms*(1.0-Math.cos(con))/sinphi);}
+p.x=x;p.y=y;return p;},inverse:function(p){var sin_phi,cos_phi;var al;var b;var c;var con,ml;var iflg;var lon,lat;p.x-=this.x0;p.y-=this.y0;al=this.ml0+p.y/this.a;iflg=0;if(Math.abs(al)<=.0000001){lon=p.x/this.a+this.long0;lat=0.0;}else{b=al*al+(p.x/this.a)*(p.x/this.a);iflg=phi4z(this.es,this.e0,this.e1,this.e2,this.e3,this.al,b,c,lat);if(iflg!=1)return(iflg);lon=Proj4js.common.adjust_lon((Proj4js.common.asinz(p.x*c/this.a)/Math.sin(lat))+this.long0);}
+p.x=lon;p.y=lat;return p;}};Proj4js.Proj.equi={init:function(){if(!this.x0)this.x0=0;if(!this.y0)this.y0=0;if(!this.lat0)this.lat0=0;if(!this.long0)this.long0=0;},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+this.a*dlon*Math.cos(this.lat0);var y=this.y0+this.a*lat;this.t1=x;this.t2=Math.cos(this.lat0);p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var lat=p.y/this.a;if(Math.abs(lat)>Proj4js.common.HALF_PI){Proj4js.reportError("equi:Inv:DataError");}
+var lon=Proj4js.common.adjust_lon(this.long0+p.x/(this.a*Math.cos(this.lat0)));p.x=lon;p.y=lat;}};Proj4js.Proj.merc={init:function(){if(this.lat_ts){if(this.sphere){this.k0=Math.cos(this.lat_ts);}else{this.k0=Proj4js.common.msfnz(this.es,Math.sin(this.lat_ts),Math.cos(this.lat_ts));}}},forward:function(p){var lon=p.x;var lat=p.y;if(lat*Proj4js.common.R2D>90.0&&lat*Proj4js.common.R2D<-90.0&&lon*Proj4js.common.R2D>180.0&&lon*Proj4js.common.R2D<-180.0){Proj4js.reportError("merc:forward: llInputOutOfRange: "+lon+" : "+lat);return null;}
+var x,y;if(Math.abs(Math.abs(lat)-Proj4js.common.HALF_PI)<=Proj4js.common.EPSLN){Proj4js.reportError("merc:forward: ll2mAtPoles");return null;}else{if(this.sphere){x=this.x0+this.a*this.k0*Proj4js.common.adjust_lon(lon-this.long0);y=this.y0+this.a*this.k0*Math.log(Math.tan(Proj4js.common.FORTPI+0.5*lat));}else{var sinphi=Math.sin(lat);var ts=Proj4js.common.tsfnz(this.e,lat,sinphi);x=this.x0+this.a*this.k0*Proj4js.common.adjust_lon(lon-this.long0);y=this.y0-this.a*this.k0*Math.log(ts);}
+p.x=x;p.y=y;return p;}},inverse:function(p){var x=p.x-this.x0;var y=p.y-this.y0;var lon,lat;if(this.sphere){lat=Proj4js.common.HALF_PI-2.0*Math.atan(Math.exp(-y/this.a*this.k0));}else{var ts=Math.exp(-y/(this.a*this.k0));lat=Proj4js.common.phi2z(this.e,ts);if(lat==-9999){Proj4js.reportError("merc:inverse: lat = -9999");return null;}}
+lon=Proj4js.common.adjust_lon(this.long0+x/(this.a*this.k0));p.x=lon;p.y=lat;return p;}};Proj4js.Proj.utm={dependsOn:'tmerc',init:function(){if(!this.zone){Proj4js.reportError("utm:init: zone must be specified for UTM");return;}
+this.lat0=0.0;this.long0=((6*Math.abs(this.zone))-183)*Proj4js.common.D2R;this.x0=500000.0;this.y0=this.utmSouth?10000000.0:0.0;this.k0=0.9996;Proj4js.Proj['tmerc'].init.apply(this);this.forward=Proj4js.Proj['tmerc'].forward;this.inverse=Proj4js.Proj['tmerc'].inverse;}};Proj4js.Proj.eqdc={init:function(){if(!this.mode)this.mode=0;this.temp=this.b/this.a;this.es=1.0-Math.pow(this.temp,2);this.e=Math.sqrt(this.es);this.e0=Proj4js.common.e0fn(this.es);this.e1=Proj4js.common.e1fn(this.es);this.e2=Proj4js.common.e2fn(this.es);this.e3=Proj4js.common.e3fn(this.es);this.sinphi=Math.sin(this.lat1);this.cosphi=Math.cos(this.lat1);this.ms1=Proj4js.common.msfnz(this.e,this.sinphi,this.cosphi);this.ml1=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,this.lat1);if(this.mode!=0){if(Math.abs(this.lat1+this.lat2)<Proj4js.common.EPSLN){Proj4js.reportError("eqdc:Init:EqualLatitudes");}
+this.sinphi=Math.sin(this.lat2);this.cosphi=Math.cos(this.lat2);this.ms2=Proj4js.common.msfnz(this.e,this.sinphi,this.cosphi);this.ml2=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,this.lat2);if(Math.abs(this.lat1-this.lat2)>=Proj4js.common.EPSLN){this.ns=(this.ms1-this.ms2)/(this.ml2-this.ml1);}else{this.ns=this.sinphi;}}else{this.ns=this.sinphi;}
+this.g=this.ml1+this.ms1/this.ns;this.ml0=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,this.lat0);this.rh=this.a*(this.g-this.ml0);},forward:function(p){var lon=p.x;var lat=p.y;var ml=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,lat);var rh1=this.a*(this.g-ml);var theta=this.ns*Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+rh1*Math.sin(theta);var y=this.y0+this.rh-rh1*Math.cos(theta);p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y=this.rh-p.y+this.y0;var con,rh1;if(this.ns>=0){var rh1=Math.sqrt(p.x*p.x+p.y*p.y);var con=1.0;}else{rh1=-Math.sqrt(p.x*p.x+p.y*p.y);con=-1.0;}
+var theta=0.0;if(rh1!=0.0)theta=Math.atan2(con*p.x,con*p.y);var ml=this.g-rh1/this.a;var lat=this.phi3z(this.ml,this.e0,this.e1,this.e2,this.e3);var lon=Proj4js.common.adjust_lon(this.long0+theta/this.ns);p.x=lon;p.y=lat;return p;},phi3z:function(ml,e0,e1,e2,e3){var phi;var dphi;phi=ml;for(var i=0;i<15;i++){dphi=(ml+e1*Math.sin(2.0*phi)-e2*Math.sin(4.0*phi)+e3*Math.sin(6.0*phi))/e0-phi;phi+=dphi;if(Math.abs(dphi)<=.0000000001){return phi;}}
+Proj4js.reportError("PHI3Z-CONV:Latitude failed to converge after 15 iterations");return null;}};Proj4js.Proj.tmerc={init:function(){this.e0=Proj4js.common.e0fn(this.es);this.e1=Proj4js.common.e1fn(this.es);this.e2=Proj4js.common.e2fn(this.es);this.e3=Proj4js.common.e3fn(this.es);this.ml0=this.a*Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,this.lat0);},forward:function(p){var lon=p.x;var lat=p.y;var delta_lon=Proj4js.common.adjust_lon(lon-this.long0);var con;var x,y;var sin_phi=Math.sin(lat);var cos_phi=Math.cos(lat);if(this.sphere){var b=cos_phi*Math.sin(delta_lon);if((Math.abs(Math.abs(b)-1.0))<.0000000001){Proj4js.reportError("tmerc:forward: Point projects into infinity");return(93);}else{x=.5*this.a*this.k0*Math.log((1.0+b)/(1.0-b));con=Math.acos(cos_phi*Math.cos(delta_lon)/Math.sqrt(1.0-b*b));if(lat<0)con=-con;y=this.a*this.k0*(con-this.lat0);}}else{var al=cos_phi*delta_lon;var als=Math.pow(al,2);var c=this.ep2*Math.pow(cos_phi,2);var tq=Math.tan(lat);var t=Math.pow(tq,2);con=1.0-this.es*Math.pow(sin_phi,2);var n=this.a/Math.sqrt(con);var ml=this.a*Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,lat);x=this.k0*n*al*(1.0+als/6.0*(1.0-t+c+als/20.0*(5.0-18.0*t+Math.pow(t,2)+72.0*c-58.0*this.ep2)))+this.x0;y=this.k0*(ml-this.ml0+n*tq*(als*(0.5+als/24.0*(5.0-t+9.0*c+4.0*Math.pow(c,2)+als/30.0*(61.0-58.0*t+Math.pow(t,2)+600.0*c-330.0*this.ep2)))))+this.y0;}
+p.x=x;p.y=y;return p;},inverse:function(p){var con,phi;var delta_phi;var i;var max_iter=6;var lat,lon;if(this.sphere){var f=Math.exp(p.x/(this.a*this.k0));var g=.5*(f-1/f);var temp=this.lat0+p.y/(this.a*this.k0);var h=Math.cos(temp);con=Math.sqrt((1.0-h*h)/(1.0+g*g));lat=Proj4js.common.asinz(con);if(temp<0)
+lat=-lat;if((g==0)&&(h==0)){lon=this.long0;}else{lon=Proj4js.common.adjust_lon(Math.atan2(g,h)+this.long0);}}else{var x=p.x-this.x0;var y=p.y-this.y0;con=(this.ml0+y/this.k0)/this.a;phi=con;for(i=0;true;i++){delta_phi=((con+this.e1*Math.sin(2.0*phi)-this.e2*Math.sin(4.0*phi)+this.e3*Math.sin(6.0*phi))/this.e0)-phi;phi+=delta_phi;if(Math.abs(delta_phi)<=Proj4js.common.EPSLN)break;if(i>=max_iter){Proj4js.reportError("tmerc:inverse: Latitude failed to converge");return(95);}}
+if(Math.abs(phi)<Proj4js.common.HALF_PI){var sin_phi=Math.sin(phi);var cos_phi=Math.cos(phi);var tan_phi=Math.tan(phi);var c=this.ep2*Math.pow(cos_phi,2);var cs=Math.pow(c,2);var t=Math.pow(tan_phi,2);var ts=Math.pow(t,2);con=1.0-this.es*Math.pow(sin_phi,2);var n=this.a/Math.sqrt(con);var r=n*(1.0-this.es)/con;var d=x/(n*this.k0);var ds=Math.pow(d,2);lat=phi-(n*tan_phi*ds/r)*(0.5-ds/24.0*(5.0+3.0*t+10.0*c-4.0*cs-9.0*this.ep2-ds/30.0*(61.0+90.0*t+298.0*c+45.0*ts-252.0*this.ep2-3.0*cs)));lon=Proj4js.common.adjust_lon(this.long0+(d*(1.0-ds/6.0*(1.0+2.0*t+c-ds/20.0*(5.0-2.0*c+28.0*t-3.0*cs+8.0*this.ep2+24.0*ts)))/cos_phi));}else{lat=Proj4js.common.HALF_PI*Proj4js.common.sign(y);lon=this.long0;}}
+p.x=lon;p.y=lat;return p;}};Proj4js.defs["GOOGLE"]="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs";Proj4js.defs["EPSG:900913"]=Proj4js.defs["GOOGLE"];Proj4js.Proj.gstmerc={init:function(){var temp=this.b/this.a;this.e=Math.sqrt(1.0-temp*temp);this.lc=this.long0;this.rs=Math.sqrt(1.0+this.e*this.e*Math.pow(Math.cos(this.lat0),4.0)/(1.0-this.e*this.e));var sinz=Math.sin(this.lat0);var pc=Math.asin(sinz/this.rs);var sinzpc=Math.sin(pc);this.cp=Proj4js.common.latiso(0.0,pc,sinzpc)-this.rs*Proj4js.common.latiso(this.e,this.lat0,sinz);this.n2=this.k0*this.a*Math.sqrt(1.0-this.e*this.e)/(1.0-this.e*this.e*sinz*sinz);this.xs=this.x0;this.ys=this.y0-this.n2*pc;if(!this.title)this.title="Gauss Schreiber transverse mercator";},forward:function(p){var lon=p.x;var lat=p.y;var L=this.rs*(lon-this.lc);var Ls=this.cp+(this.rs*Proj4js.common.latiso(this.e,lat,Math.sin(lat)));var lat1=Math.asin(Math.sin(L)/Proj4js.common.cosh(Ls));var Ls1=Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));p.x=this.xs+(this.n2*Ls1);p.y=this.ys+(this.n2*Math.atan(Proj4js.common.sinh(Ls)/Math.cos(L)));return p;},inverse:function(p){var x=p.x;var y=p.y;var L=Math.atan(Proj4js.common.sinh((x-this.xs)/this.n2)/Math.cos((y-this.ys)/this.n2));var lat1=Math.asin(Math.sin((y-this.ys)/this.n2)/Proj4js.common.cosh((x-this.xs)/this.n2));var LC=Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));p.x=this.lc+L/this.rs;p.y=Proj4js.common.invlatiso(this.e,(LC-this.cp)/this.rs);return p;}};Proj4js.Proj.ortho={init:function(def){;this.sin_p14=Math.sin(this.lat0);this.cos_p14=Math.cos(this.lat0);},forward:function(p){var sinphi,cosphi;var dlon;var coslon;var ksp;var g;var lon=p.x;var lat=p.y;dlon=Proj4js.common.adjust_lon(lon-this.long0);sinphi=Math.sin(lat);cosphi=Math.cos(lat);coslon=Math.cos(dlon);g=this.sin_p14*sinphi+this.cos_p14*cosphi*coslon;ksp=1.0;if((g>0)||(Math.abs(g)<=Proj4js.common.EPSLN)){var x=this.a*ksp*cosphi*Math.sin(dlon);var y=this.y0+this.a*ksp*(this.cos_p14*sinphi-this.sin_p14*cosphi*coslon);}else{Proj4js.reportError("orthoFwdPointError");}
+p.x=x;p.y=y;return p;},inverse:function(p){var rh;var z;var sinz,cosz;var temp;var con;var lon,lat;p.x-=this.x0;p.y-=this.y0;rh=Math.sqrt(p.x*p.x+p.y*p.y);if(rh>this.a+.0000001){Proj4js.reportError("orthoInvDataError");}
+z=Proj4js.common.asinz(rh/this.a);sinz=Math.sin(z);cosi=Math.cos(z);lon=this.long0;if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=this.lat0;}
+lat=Proj4js.common.asinz(cosz*this.sin_p14+(y*sinz*this.cos_p14)/rh);con=Math.abs(lat0)-Proj4js.common.HALF_PI;if(Math.abs(con)<=Proj4js.common.EPSLN){if(this.lat0>=0){lon=Proj4js.common.adjust_lon(this.long0+Math.atan2(p.x,-p.y));}else{lon=Proj4js.common.adjust_lon(this.long0-Math.atan2(-p.x,p.y));}}
+con=cosz-this.sin_p14*Math.sin(lat);if((Math.abs(con)>=Proj4js.common.EPSLN)||(Math.abs(x)>=Proj4js.common.EPSLN)){lon=Proj4js.common.adjust_lon(this.long0+Math.atan2((p.x*sinz*this.cos_p14),(con*rh)));}
+p.x=lon;p.y=lat;return p;}};Proj4js.Proj.somerc={init:function(){var phy0=this.lat0;this.lambda0=this.long0;var sinPhy0=Math.sin(phy0);var semiMajorAxis=this.a;var invF=this.rf;var flattening=1/invF;var e2=2*flattening-Math.pow(flattening,2);var e=this.e=Math.sqrt(e2);this.R=semiMajorAxis*Math.sqrt(1-e2)/(1-e2*Math.pow(sinPhy0,2.0));this.alpha=Math.sqrt(1+e2/(1-e2)*Math.pow(Math.cos(phy0),4.0));this.b0=Math.asin(sinPhy0/this.alpha);this.K=Math.log(Math.tan(Math.PI/4.0+this.b0/2.0))
+-this.alpha*Math.log(Math.tan(Math.PI/4.0+phy0/2.0))
++this.alpha*e/2*Math.log((1+e*sinPhy0)/(1-e*sinPhy0));},forward:function(p){var Sa1=Math.log(Math.tan(Math.PI/4.0-p.y/2.0));var Sa2=this.e/2.0*Math.log((1+this.e*Math.sin(p.y))/(1-this.e*Math.sin(p.y)));var S=-this.alpha*(Sa1+Sa2)+this.K;var b=2.0*(Math.atan(Math.exp(S))-Math.PI/4.0);var I=this.alpha*(p.x-this.lambda0);var rotI=Math.atan(Math.sin(I)/(Math.sin(this.b0)*Math.tan(b)+
+Math.cos(this.b0)*Math.cos(I)));var rotB=Math.asin(Math.cos(this.b0)*Math.sin(b)-
+Math.sin(this.b0)*Math.cos(b)*Math.cos(I));p.y=this.R/2.0*Math.log((1+Math.sin(rotB))/(1-Math.sin(rotB)))
++this.y0;p.x=this.R*rotI+this.x0;return p;},inverse:function(p){var Y=p.x-this.x0;var X=p.y-this.y0;var rotI=Y/this.R;var rotB=2*(Math.atan(Math.exp(X/this.R))-Math.PI/4.0);var b=Math.asin(Math.cos(this.b0)*Math.sin(rotB)
++Math.sin(this.b0)*Math.cos(rotB)*Math.cos(rotI));var I=Math.atan(Math.sin(rotI)/(Math.cos(this.b0)*Math.cos(rotI)-Math.sin(this.b0)*Math.tan(rotB)));var lambda=this.lambda0+I/this.alpha;var S=0.0;var phy=b;var prevPhy=-1000.0;var iteration=0;while(Math.abs(phy-prevPhy)>0.0000001)
+{if(++iteration>20)
+{Proj4js.reportError("omercFwdInfinity");return;}
+S=1.0/this.alpha*(Math.log(Math.tan(Math.PI/4.0+b/2.0))-this.K)
++this.e*Math.log(Math.tan(Math.PI/4.0
++Math.asin(this.e*Math.sin(phy))/2.0));prevPhy=phy;phy=2.0*Math.atan(Math.exp(S))-Math.PI/2.0;}
+p.x=lambda;p.y=phy;return p;}};Proj4js.Proj.stere={ssfn_:function(phit,sinphi,eccen){sinphi*=eccen;return(Math.tan(.5*(Proj4js.common.HALF_PI+phit))*Math.pow((1.-sinphi)/(1.+sinphi),.5*eccen));},TOL:1.e-8,NITER:8,CONV:1.e-10,S_POLE:0,N_POLE:1,OBLIQ:2,EQUIT:3,init:function(){this.phits=this.lat_ts?this.lat_ts:Proj4js.common.HALF_PI;var t=Math.abs(this.lat0);if((Math.abs(t)-Proj4js.common.HALF_PI)<Proj4js.common.EPSLN){this.mode=this.lat0<0.?this.S_POLE:this.N_POLE;}else{this.mode=t>Proj4js.common.EPSLN?this.OBLIQ:this.EQUIT;}
+this.phits=Math.abs(this.phits);if(this.es){var X;switch(this.mode){case this.N_POLE:case this.S_POLE:if(Math.abs(this.phits-Proj4js.common.HALF_PI)<Proj4js.common.EPSLN){this.akm1=2.*this.k0/Math.sqrt(Math.pow(1+this.e,1+this.e)*Math.pow(1-this.e,1-this.e));}else{t=Math.sin(this.phits);this.akm1=Math.cos(this.phits)/Proj4js.common.tsfnz(this.e,this.phits,t);t*=this.e;this.akm1/=Math.sqrt(1.-t*t);}
+break;case this.EQUIT:this.akm1=2.*this.k0;break;case this.OBLIQ:t=Math.sin(this.lat0);X=2.*Math.atan(this.ssfn_(this.lat0,t,this.e))-Proj4js.common.HALF_PI;t*=this.e;this.akm1=2.*this.k0*Math.cos(this.lat0)/Math.sqrt(1.-t*t);this.sinX1=Math.sin(X);this.cosX1=Math.cos(X);break;}}else{switch(this.mode){case this.OBLIQ:this.sinph0=Math.sin(this.lat0);this.cosph0=Math.cos(this.lat0);case this.EQUIT:this.akm1=2.*this.k0;break;case this.S_POLE:case this.N_POLE:this.akm1=Math.abs(this.phits-Proj4js.common.HALF_PI)>=Proj4js.common.EPSLN?Math.cos(this.phits)/Math.tan(Proj4js.common.FORTPI-.5*this.phits):2.*this.k0;break;}}},forward:function(p){var lon=p.x;lon=Proj4js.common.adjust_lon(lon-this.long0);var lat=p.y;var x,y;if(this.sphere){var sinphi,cosphi,coslam,sinlam;sinphi=Math.sin(lat);cosphi=Math.cos(lat);coslam=Math.cos(lon);sinlam=Math.sin(lon);switch(this.mode){case this.EQUIT:y=1.+cosphi*coslam;if(y<=Proj4js.common.EPSLN){F_ERROR;}
+y=this.akm1/y;x=y*cosphi*sinlam;y*=sinphi;break;case this.OBLIQ:y=1.+this.sinph0*sinphi+this.cosph0*cosphi*coslam;if(y<=Proj4js.common.EPSLN){F_ERROR;}
+y=this.akm1/y;x=y*cosphi*sinlam;y*=this.cosph0*sinphi-this.sinph0*cosphi*coslam;break;case this.N_POLE:coslam=-coslam;lat=-lat;case this.S_POLE:if(Math.abs(lat-Proj4js.common.HALF_PI)<this.TOL){F_ERROR;}
+y=this.akm1*Math.tan(Proj4js.common.FORTPI+.5*lat);x=sinlam*y;y*=coslam;break;}}else{coslam=Math.cos(lon);sinlam=Math.sin(lon);sinphi=Math.sin(lat);if(this.mode==this.OBLIQ||this.mode==this.EQUIT){X=2.*Math.atan(this.ssfn_(lat,sinphi,this.e));sinX=Math.sin(X-Proj4js.common.HALF_PI);cosX=Math.cos(X);}
+switch(this.mode){case this.OBLIQ:A=this.akm1/(this.cosX1*(1.+this.sinX1*sinX+this.cosX1*cosX*coslam));y=A*(this.cosX1*sinX-this.sinX1*cosX*coslam);x=A*cosX;break;case this.EQUIT:A=2.*this.akm1/(1.+cosX*coslam);y=A*sinX;x=A*cosX;break;case this.S_POLE:lat=-lat;coslam=-coslam;sinphi=-sinphi;case this.N_POLE:x=this.akm1*Proj4js.common.tsfnz(this.e,lat,sinphi);y=-x*coslam;break;}
+x=x*sinlam;}
+p.x=x*this.a+this.x0;p.y=y*this.a+this.y0;return p;},inverse:function(p){var x=(p.x-this.x0)/this.a;var y=(p.y-this.y0)/this.a;var lon,lat;var cosphi,sinphi,tp=0.0,phi_l=0.0,rho,halfe=0.0,pi2=0.0;var i;if(this.sphere){var c,rh,sinc,cosc;rh=Math.sqrt(x*x+y*y);c=2.*Math.atan(rh/this.akm1);sinc=Math.sin(c);cosc=Math.cos(c);lon=0.;switch(this.mode){case this.EQUIT:if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=0.;}else{lat=Math.asin(y*sinc/rh);}
+if(cosc!=0.||x!=0.)lon=Math.atan2(x*sinc,cosc*rh);break;case this.OBLIQ:if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=this.phi0;}else{lat=Math.asin(cosc*sinph0+y*sinc*cosph0/rh);}
+c=cosc-sinph0*Math.sin(lat);if(c!=0.||x!=0.){lon=Math.atan2(x*sinc*cosph0,c*rh);}
+break;case this.N_POLE:y=-y;case this.S_POLE:if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=this.phi0;}else{lat=Math.asin(this.mode==this.S_POLE?-cosc:cosc);}
+lon=(x==0.&&y==0.)?0.:Math.atan2(x,y);break;}}else{rho=Math.sqrt(x*x+y*y);switch(this.mode){case this.OBLIQ:case this.EQUIT:tp=2.*Math.atan2(rho*this.cosX1,this.akm1);cosphi=Math.cos(tp);sinphi=Math.sin(tp);if(rho==0.0){phi_l=Math.asin(cosphi*this.sinX1);}else{phi_l=Math.asin(cosphi*this.sinX1+(y*sinphi*this.cosX1/rho));}
+tp=Math.tan(.5*(Proj4js.common.HALF_PI+phi_l));x*=sinphi;y=rho*this.cosX1*cosphi-y*this.sinX1*sinphi;pi2=Proj4js.common.HALF_PI;halfe=.5*this.e;break;case this.N_POLE:y=-y;case this.S_POLE:tp=-rho/this.akm1;phi_l=Proj4js.common.HALF_PI-2.*Math.atan(tp);pi2=-Proj4js.common.HALF_PI;halfe=-.5*this.e;break;}
+for(i=this.NITER;i--;phi_l=lat){sinphi=this.e*Math.sin(phi_l);lat=2.*Math.atan(tp*Math.pow((1.+sinphi)/(1.-sinphi),halfe))-pi2;if(Math.abs(phi_l-lat)<this.CONV){if(this.mode==this.S_POLE)lat=-lat;lon=(x==0.&&y==0.)?0.:Math.atan2(x,y);p.x=Proj4js.common.adjust_lon(lon+this.long0);p.y=lat;return p;}}}}};Proj4js.Proj.nzmg={iterations:1,init:function(){this.A=new Array();this.A[1]=+0.6399175073;this.A[2]=-0.1358797613;this.A[3]=+0.063294409;this.A[4]=-0.02526853;this.A[5]=+0.0117879;this.A[6]=-0.0055161;this.A[7]=+0.0026906;this.A[8]=-0.001333;this.A[9]=+0.00067;this.A[10]=-0.00034;this.B_re=new Array();this.B_im=new Array();this.B_re[1]=+0.7557853228;this.B_im[1]=0.0;this.B_re[2]=+0.249204646;this.B_im[2]=+0.003371507;this.B_re[3]=-0.001541739;this.B_im[3]=+0.041058560;this.B_re[4]=-0.10162907;this.B_im[4]=+0.01727609;this.B_re[5]=-0.26623489;this.B_im[5]=-0.36249218;this.B_re[6]=-0.6870983;this.B_im[6]=-1.1651967;this.C_re=new Array();this.C_im=new Array();this.C_re[1]=+1.3231270439;this.C_im[1]=0.0;this.C_re[2]=-0.577245789;this.C_im[2]=-0.007809598;this.C_re[3]=+0.508307513;this.C_im[3]=-0.112208952;this.C_re[4]=-0.15094762;this.C_im[4]=+0.18200602;this.C_re[5]=+1.01418179;this.C_im[5]=+1.64497696;this.C_re[6]=+1.9660549;this.C_im[6]=+2.5127645;this.D=new Array();this.D[1]=+1.5627014243;this.D[2]=+0.5185406398;this.D[3]=-0.03333098;this.D[4]=-0.1052906;this.D[5]=-0.0368594;this.D[6]=+0.007317;this.D[7]=+0.01220;this.D[8]=+0.00394;this.D[9]=-0.0013;},forward:function(p){var lon=p.x;var lat=p.y;var delta_lat=lat-this.lat0;var delta_lon=lon-this.long0;var d_phi=delta_lat/Proj4js.common.SEC_TO_RAD*1E-5;var d_lambda=delta_lon;var d_phi_n=1;var d_psi=0;for(n=1;n<=10;n++){d_phi_n=d_phi_n*d_phi;d_psi=d_psi+this.A[n]*d_phi_n;}
+var th_re=d_psi;var th_im=d_lambda;var th_n_re=1;var th_n_im=0;var th_n_re1;var th_n_im1;var z_re=0;var z_im=0;for(n=1;n<=6;n++){th_n_re1=th_n_re*th_re-th_n_im*th_im;th_n_im1=th_n_im*th_re+th_n_re*th_im;th_n_re=th_n_re1;th_n_im=th_n_im1;z_re=z_re+this.B_re[n]*th_n_re-this.B_im[n]*th_n_im;z_im=z_im+this.B_im[n]*th_n_re+this.B_re[n]*th_n_im;}
+x=(z_im*this.a)+this.x0;y=(z_re*this.a)+this.y0;p.x=x;p.y=y;return p;},inverse:function(p){var x=p.x;var y=p.y;var delta_x=x-this.x0;var delta_y=y-this.y0;var z_re=delta_y/this.a;var z_im=delta_x/this.a;var z_n_re=1;var z_n_im=0;var z_n_re1;var z_n_im1;var th_re=0;var th_im=0;for(n=1;n<=6;n++){z_n_re1=z_n_re*z_re-z_n_im*z_im;z_n_im1=z_n_im*z_re+z_n_re*z_im;z_n_re=z_n_re1;z_n_im=z_n_im1;th_re=th_re+this.C_re[n]*z_n_re-this.C_im[n]*z_n_im;th_im=th_im+this.C_im[n]*z_n_re+this.C_re[n]*z_n_im;}
+for(i=0;i<this.iterations;i++){var th_n_re=th_re;var th_n_im=th_im;var th_n_re1;var th_n_im1;var num_re=z_re;var num_im=z_im;for(n=2;n<=6;n++){th_n_re1=th_n_re*th_re-th_n_im*th_im;th_n_im1=th_n_im*th_re+th_n_re*th_im;th_n_re=th_n_re1;th_n_im=th_n_im1;num_re=num_re+(n-1)*(this.B_re[n]*th_n_re-this.B_im[n]*th_n_im);num_im=num_im+(n-1)*(this.B_im[n]*th_n_re+this.B_re[n]*th_n_im);}
+th_n_re=1;th_n_im=0;var den_re=this.B_re[1];var den_im=this.B_im[1];for(n=2;n<=6;n++){th_n_re1=th_n_re*th_re-th_n_im*th_im;th_n_im1=th_n_im*th_re+th_n_re*th_im;th_n_re=th_n_re1;th_n_im=th_n_im1;den_re=den_re+n*(this.B_re[n]*th_n_re-this.B_im[n]*th_n_im);den_im=den_im+n*(this.B_im[n]*th_n_re+this.B_re[n]*th_n_im);}
+var den2=den_re*den_re+den_im*den_im;th_re=(num_re*den_re+num_im*den_im)/den2;th_im=(num_im*den_re-num_re*den_im)/den2;}
+var d_psi=th_re;var d_lambda=th_im;var d_psi_n=1;var d_phi=0;for(n=1;n<=9;n++){d_psi_n=d_psi_n*d_psi;d_phi=d_phi+this.D[n]*d_psi_n;}
+var lat=this.lat0+(d_phi*Proj4js.common.SEC_TO_RAD*1E5);var lon=this.long0+d_lambda;p.x=lon;p.y=lat;return p;}};Proj4js.Proj.mill={init:function(){},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+this.a*dlon;var y=this.y0+this.a*Math.log(Math.tan((Proj4js.common.PI/4.0)+(lat/2.5)))*1.25;p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var lon=Proj4js.common.adjust_lon(this.long0+p.x/this.a);var lat=2.5*(Math.atan(Math.exp(0.8*p.y/this.a))-Proj4js.common.PI/4.0);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.sinu={init:function(){this.R=6370997.0;},forward:function(p){var x,y,delta_lon;var lon=p.x;var lat=p.y;delta_lon=Proj4js.common.adjust_lon(lon-this.long0);x=this.R*delta_lon*Math.cos(lat)+this.x0;y=this.R*lat+this.y0;p.x=x;p.y=y;return p;},inverse:function(p){var lat,temp,lon;p.x-=this.x0;p.y-=this.y0;lat=p.y/this.R;if(Math.abs(lat)>Proj4js.common.HALF_PI){Proj4js.reportError("sinu:Inv:DataError");}
+temp=Math.abs(lat)-Proj4js.common.HALF_PI;if(Math.abs(temp)>Proj4js.common.EPSLN){temp=this.long0+p.x/(this.R*Math.cos(lat));lon=Proj4js.common.adjust_lon(temp);}else{lon=this.long0;}
+p.x=lon;p.y=lat;return p;}};Proj4js.Proj.vandg={init:function(){this.R=6370997.0;},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var x,y;if(Math.abs(lat)<=Proj4js.common.EPSLN){x=this.x0+this.R*dlon;y=this.y0;}
+var theta=Proj4js.common.asinz(2.0*Math.abs(lat/Proj4js.common.PI));if((Math.abs(dlon)<=Proj4js.common.EPSLN)||(Math.abs(Math.abs(lat)-Proj4js.common.HALF_PI)<=Proj4js.common.EPSLN)){x=this.x0;if(lat>=0){y=this.y0+Proj4js.common.PI*this.R*Math.tan(.5*theta);}else{y=this.y0+Proj4js.common.PI*this.R*-Math.tan(.5*theta);}}
+var al=.5*Math.abs((Proj4js.common.PI/dlon)-(dlon/Proj4js.common.PI));var asq=al*al;var sinth=Math.sin(theta);var costh=Math.cos(theta);var g=costh/(sinth+costh-1.0);var gsq=g*g;var m=g*(2.0/sinth-1.0);var msq=m*m;var con=Proj4js.common.PI*this.R*(al*(g-msq)+Math.sqrt(asq*(g-msq)*(g-msq)-(msq+asq)*(gsq-msq)))/(msq+asq);if(dlon<0){con=-con;}
+x=this.x0+con;con=Math.abs(con/(Proj4js.common.PI*this.R));if(lat>=0){y=this.y0+Proj4js.common.PI*this.R*Math.sqrt(1.0-con*con-2.0*al*con);}else{y=this.y0-Proj4js.common.PI*this.R*Math.sqrt(1.0-con*con-2.0*al*con);}
+p.x=x;p.y=y;return p;},inverse:function(p){var dlon;var xx,yy,xys,c1,c2,c3;var al,asq;var a1;var m1;var con;var th1;var d;p.x-=this.x0;p.y-=this.y0;con=Proj4js.common.PI*this.R;xx=p.x/con;yy=p.y/con;xys=xx*xx+yy*yy;c1=-Math.abs(yy)*(1.0+xys);c2=c1-2.0*yy*yy+xx*xx;c3=-2.0*c1+1.0+2.0*yy*yy+xys*xys;d=yy*yy/c3+(2.0*c2*c2*c2/c3/c3/c3-9.0*c1*c2/c3/c3)/27.0;a1=(c1-c2*c2/3.0/c3)/c3;m1=2.0*Math.sqrt(-a1/3.0);con=((3.0*d)/a1)/m1;if(Math.abs(con)>1.0){if(con>=0.0){con=1.0;}else{con=-1.0;}}
+th1=Math.acos(con)/3.0;if(p.y>=0){lat=(-m1*Math.cos(th1+Proj4js.common.PI/3.0)-c2/3.0/c3)*Proj4js.common.PI;}else{lat=-(-m1*Math.cos(th1+PI/3.0)-c2/3.0/c3)*Proj4js.common.PI;}
+if(Math.abs(xx)<Proj4js.common.EPSLN){lon=this.long0;}
+lon=Proj4js.common.adjust_lon(this.long0+Proj4js.common.PI*(xys-1.0+Math.sqrt(1.0+2.0*(xx*xx-yy*yy)+xys*xys))/2.0/xx);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.cea={init:function(){},forward:function(p){var lon=p.x;var lat=p.y;dlon=Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+this.a*dlon*Math.cos(this.lat_ts);var y=this.y0+this.a*Math.sin(lat)/Math.cos(this.lat_ts);p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var lon=Proj4js.common.adjust_lon(this.long0+(p.x/this.a)/Math.cos(this.lat_ts));var lat=Math.asin((p.y/this.a)*Math.cos(this.lat_ts));p.x=lon;p.y=lat;return p;}};Proj4js.Proj.eqc={init:function(){if(!this.x0)this.x0=0;if(!this.y0)this.y0=0;if(!this.lat0)this.lat0=0;if(!this.long0)this.long0=0;if(!this.lat_ts)this.lat_ts=0;if(!this.title)this.title="Equidistant Cylindrical (Plate Carre)";this.rc=Math.cos(this.lat_ts);},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var dlat=Proj4js.common.adjust_lat(lat-this.lat0);p.x=this.x0+(this.a*dlon*this.rc);p.y=this.y0+(this.a*dlat);return p;},inverse:function(p){var x=p.x;var y=p.y;p.x=Proj4js.common.adjust_lon(this.long0+((x-this.x0)/(this.a*this.rc)));p.y=Proj4js.common.adjust_lat(this.lat0+((y-this.y0)/(this.a)));return p;}};Proj4js.Proj.gauss={init:function(){sphi=Math.sin(this.lat0);cphi=Math.cos(this.lat0);cphi*=cphi;this.rc=Math.sqrt(1.0-this.es)/(1.0-this.es*sphi*sphi);this.C=Math.sqrt(1.0+this.es*cphi*cphi/(1.0-this.es));this.phic0=Math.asin(sphi/this.C);this.ratexp=0.5*this.C*this.e;this.K=Math.tan(0.5*this.phic0+Proj4js.common.FORTPI)/(Math.pow(Math.tan(0.5*this.lat0+Proj4js.common.FORTPI),this.C)*Proj4js.common.srat(this.e*sphi,this.ratexp));},forward:function(p){var lon=p.x;var lat=p.y;p.y=2.0*Math.atan(this.K*Math.pow(Math.tan(0.5*lat+Proj4js.common.FORTPI),this.C)*Proj4js.common.srat(this.e*Math.sin(lat),this.ratexp))-Proj4js.common.HALF_PI;p.x=this.C*lon;return p;},inverse:function(p){var DEL_TOL=1e-14;var lon=p.x/this.C;var lat=p.y;num=Math.pow(Math.tan(0.5*lat+Proj4js.common.FORTPI)/this.K,1./this.C);for(var i=Proj4js.common.MAX_ITER;i>0;--i){lat=2.0*Math.atan(num*Proj4js.common.srat(this.e*Math.sin(p.y),-0.5*this.e))-Proj4js.common.HALF_PI;if(Math.abs(lat-p.y)<DEL_TOL)break;p.y=lat;}
+if(!i){Proj4js.reportError("gauss:inverse:convergence failed");return null;}
+p.x=lon;p.y=lat;return p;}};Proj4js.Proj.omerc={init:function(){if(!this.mode)this.mode=0;if(!this.lon1){this.lon1=0;this.mode=1;}
+if(!this.lon2)this.lon2=0;if(!this.lat2)this.lat2=0;var temp=this.b/this.a;var es=1.0-Math.pow(temp,2);var e=Math.sqrt(es);this.sin_p20=Math.sin(this.lat0);this.cos_p20=Math.cos(this.lat0);this.con=1.0-this.es*this.sin_p20*this.sin_p20;this.com=Math.sqrt(1.0-es);this.bl=Math.sqrt(1.0+this.es*Math.pow(this.cos_p20,4.0)/(1.0-es));this.al=this.a*this.bl*this.k0*this.com/this.con;if(Math.abs(this.lat0)<Proj4js.common.EPSLN){this.ts=1.0;this.d=1.0;this.el=1.0;}else{this.ts=Proj4js.common.tsfnz(this.e,this.lat0,this.sin_p20);this.con=Math.sqrt(this.con);this.d=this.bl*this.com/(this.cos_p20*this.con);if((this.d*this.d-1.0)>0.0){if(this.lat0>=0.0){this.f=this.d+Math.sqrt(this.d*this.d-1.0);}else{this.f=this.d-Math.sqrt(this.d*this.d-1.0);}}else{this.f=this.d;}
+this.el=this.f*Math.pow(this.ts,this.bl);}
+if(this.mode!=0){this.g=.5*(this.f-1.0/this.f);this.gama=Proj4js.common.asinz(Math.sin(this.alpha)/this.d);this.longc=this.longc-Proj4js.common.asinz(this.g*Math.tan(this.gama))/this.bl;this.con=Math.abs(this.lat0);if((this.con>Proj4js.common.EPSLN)&&(Math.abs(this.con-Proj4js.common.HALF_PI)>Proj4js.common.EPSLN)){this.singam=Math.sin(this.gama);this.cosgam=Math.cos(this.gama);this.sinaz=Math.sin(this.alpha);this.cosaz=Math.cos(this.alpha);if(this.lat0>=0){this.u=(this.al/this.bl)*Math.atan(Math.sqrt(this.d*this.d-1.0)/this.cosaz);}else{this.u=-(this.al/this.bl)*Math.atan(Math.sqrt(this.d*this.d-1.0)/this.cosaz);}}else{Proj4js.reportError("omerc:Init:DataError");}}else{this.sinphi=Math.sin(this.at1);this.ts1=Proj4js.common.tsfnz(this.e,this.lat1,this.sinphi);this.sinphi=Math.sin(this.lat2);this.ts2=Proj4js.common.tsfnz(this.e,this.lat2,this.sinphi);this.h=Math.pow(this.ts1,this.bl);this.l=Math.pow(this.ts2,this.bl);this.f=this.el/this.h;this.g=.5*(this.f-1.0/this.f);this.j=(this.el*this.el-this.l*this.h)/(this.el*this.el+this.l*this.h);this.p=(this.l-this.h)/(this.l+this.h);this.dlon=this.lon1-this.lon2;if(this.dlon<-Proj4js.common.PI)this.lon2=this.lon2-2.0*Proj4js.common.PI;if(this.dlon>Proj4js.common.PI)this.lon2=this.lon2+2.0*Proj4js.common.PI;this.dlon=this.lon1-this.lon2;this.longc=.5*(this.lon1+this.lon2)-Math.atan(this.j*Math.tan(.5*this.bl*this.dlon)/this.p)/this.bl;this.dlon=Proj4js.common.adjust_lon(this.lon1-this.longc);this.gama=Math.atan(Math.sin(this.bl*this.dlon)/this.g);this.alpha=Proj4js.common.asinz(this.d*Math.sin(this.gama));if(Math.abs(this.lat1-this.lat2)<=Proj4js.common.EPSLN){Proj4js.reportError("omercInitDataError");}else{this.con=Math.abs(this.lat1);}
+if((this.con<=Proj4js.common.EPSLN)||(Math.abs(this.con-HALF_PI)<=Proj4js.common.EPSLN)){Proj4js.reportError("omercInitDataError");}else{if(Math.abs(Math.abs(this.lat0)-Proj4js.common.HALF_PI)<=Proj4js.common.EPSLN){Proj4js.reportError("omercInitDataError");}}
+this.singam=Math.sin(this.gam);this.cosgam=Math.cos(this.gam);this.sinaz=Math.sin(this.alpha);this.cosaz=Math.cos(this.alpha);if(this.lat0>=0){this.u=(this.al/this.bl)*Math.atan(Math.sqrt(this.d*this.d-1.0)/this.cosaz);}else{this.u=-(this.al/this.bl)*Math.atan(Math.sqrt(this.d*this.d-1.0)/this.cosaz);}}},forward:function(p){var theta;var sin_phi,cos_phi;var b;var c,t,tq;var con,n,ml;var q,us,vl;var ul,vs;var s;var dlon;var ts1;var lon=p.x;var lat=p.y;sin_phi=Math.sin(lat);dlon=Proj4js.common.adjust_lon(lon-this.longc);vl=Math.sin(this.bl*dlon);if(Math.abs(Math.abs(lat)-Proj4js.common.HALF_PI)>Proj4js.common.EPSLN){ts1=Proj4js.common.tsfnz(this.e,lat,sin_phi);q=this.el/(Math.pow(ts1,this.bl));s=.5*(q-1.0/q);t=.5*(q+1.0/q);ul=(s*this.singam-vl*this.cosgam)/t;con=Math.cos(this.bl*dlon);if(Math.abs(con)<.0000001){us=this.al*this.bl*dlon;}else{us=this.al*Math.atan((s*this.cosgam+vl*this.singam)/con)/this.bl;if(con<0)us=us+Proj4js.common.PI*this.al/this.bl;}}else{if(lat>=0){ul=this.singam;}else{ul=-this.singam;}
+us=this.al*lat/this.bl;}
+if(Math.abs(Math.abs(ul)-1.0)<=Proj4js.common.EPSLN){Proj4js.reportError("omercFwdInfinity");}
+vs=.5*this.al*Math.log((1.0-ul)/(1.0+ul))/this.bl;us=us-this.u;var x=this.x0+vs*this.cosaz+us*this.sinaz;var y=this.y0+us*this.cosaz-vs*this.sinaz;p.x=x;p.y=y;return p;},inverse:function(p){var delta_lon;var theta;var delta_theta;var sin_phi,cos_phi;var b;var c,t,tq;var con,n,ml;var vs,us,q,s,ts1;var vl,ul,bs;var dlon;var flag;p.x-=this.x0;p.y-=this.y0;flag=0;vs=p.x*this.cosaz-p.y*this.sinaz;us=p.y*this.cosaz+p.x*this.sinaz;us=us+this.u;q=Math.exp(-this.bl*vs/this.al);s=.5*(q-1.0/q);t=.5*(q+1.0/q);vl=Math.sin(this.bl*us/this.al);ul=(vl*this.cosgam+s*this.singam)/t;if(Math.abs(Math.abs(ul)-1.0)<=Proj4js.common.EPSLN)
+{lon=this.longc;if(ul>=0.0){lat=Proj4js.common.HALF_PI;}else{lat=-Proj4js.common.HALF_PI;}}else{con=1.0/this.bl;ts1=Math.pow((this.el/Math.sqrt((1.0+ul)/(1.0-ul))),con);lat=Proj4js.common.phi2z(this.e,ts1);theta=this.longc-Math.atan2((s*this.cosgam-vl*this.singam),con)/this.bl;lon=Proj4js.common.adjust_lon(theta);}
+p.x=lon;p.y=lat;return p;}};Proj4js.Proj.lcc={init:function(){if(!this.lat2){this.lat2=this.lat0;}
+if(!this.k0)this.k0=1.0;if(Math.abs(this.lat1+this.lat2)<Proj4js.common.EPSLN){Proj4js.reportError("lcc:init: Equal Latitudes");return;}
+var temp=this.b/this.a;this.e=Math.sqrt(1.0-temp*temp);var sin1=Math.sin(this.lat1);var cos1=Math.cos(this.lat1);var ms1=Proj4js.common.msfnz(this.e,sin1,cos1);var ts1=Proj4js.common.tsfnz(this.e,this.lat1,sin1);var sin2=Math.sin(this.lat2);var cos2=Math.cos(this.lat2);var ms2=Proj4js.common.msfnz(this.e,sin2,cos2);var ts2=Proj4js.common.tsfnz(this.e,this.lat2,sin2);var ts0=Proj4js.common.tsfnz(this.e,this.lat0,Math.sin(this.lat0));if(Math.abs(this.lat1-this.lat2)>Proj4js.common.EPSLN){this.ns=Math.log(ms1/ms2)/Math.log(ts1/ts2);}else{this.ns=sin1;}
+this.f0=ms1/(this.ns*Math.pow(ts1,this.ns));this.rh=this.a*this.f0*Math.pow(ts0,this.ns);if(!this.title)this.title="Lambert Conformal Conic";},forward:function(p){var lon=p.x;var lat=p.y;if(lat<=90.0&&lat>=-90.0&&lon<=180.0&&lon>=-180.0){}else{Proj4js.reportError("lcc:forward: llInputOutOfRange: "+lon+" : "+lat);return null;}
+var con=Math.abs(Math.abs(lat)-Proj4js.common.HALF_PI);var ts,rh1;if(con>Proj4js.common.EPSLN){ts=Proj4js.common.tsfnz(this.e,lat,Math.sin(lat));rh1=this.a*this.f0*Math.pow(ts,this.ns);}else{con=lat*this.ns;if(con<=0){Proj4js.reportError("lcc:forward: No Projection");return null;}
+rh1=0;}
+var theta=this.ns*Proj4js.common.adjust_lon(lon-this.long0);p.x=this.k0*(rh1*Math.sin(theta))+this.x0;p.y=this.k0*(this.rh-rh1*Math.cos(theta))+this.y0;return p;},inverse:function(p){var rh1,con,ts;var lat,lon;x=(p.x-this.x0)/this.k0;y=(this.rh-(p.y-this.y0)/this.k0);if(this.ns>0){rh1=Math.sqrt(x*x+y*y);con=1.0;}else{rh1=-Math.sqrt(x*x+y*y);con=-1.0;}
+var theta=0.0;if(rh1!=0){theta=Math.atan2((con*x),(con*y));}
+if((rh1!=0)||(this.ns>0.0)){con=1.0/this.ns;ts=Math.pow((rh1/(this.a*this.f0)),con);lat=Proj4js.common.phi2z(this.e,ts);if(lat==-9999)return null;}else{lat=-Proj4js.common.HALF_PI;}
+lon=Proj4js.common.adjust_lon(theta/this.ns+this.long0);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.laea={S_POLE:1,N_POLE:2,EQUIT:3,OBLIQ:4,init:function(){var t=Math.abs(this.lat0);if(Math.abs(t-Proj4js.common.HALF_PI)<Proj4js.common.EPSLN){this.mode=this.lat0<0.?this.S_POLE:this.N_POLE;}else if(Math.abs(t)<Proj4js.common.EPSLN){this.mode=this.EQUIT;}else{this.mode=this.OBLIQ;}
+if(this.es>0){var sinphi;this.qp=Proj4js.common.qsfnz(this.e,1.0);this.mmf=.5/(1.-this.es);this.apa=this.authset(this.es);switch(this.mode){case this.N_POLE:case this.S_POLE:this.dd=1.;break;case this.EQUIT:this.rq=Math.sqrt(.5*this.qp);this.dd=1./this.rq;this.xmf=1.;this.ymf=.5*this.qp;break;case this.OBLIQ:this.rq=Math.sqrt(.5*this.qp);sinphi=Math.sin(this.lat0);this.sinb1=Proj4js.common.qsfnz(this.e,sinphi)/this.qp;this.cosb1=Math.sqrt(1.-this.sinb1*this.sinb1);this.dd=Math.cos(this.lat0)/(Math.sqrt(1.-this.es*sinphi*sinphi)*this.rq*this.cosb1);this.ymf=(this.xmf=this.rq)/this.dd;this.xmf*=this.dd;break;}}else{if(this.mode==this.OBLIQ){this.sinph0=Math.sin(this.lat0);this.cosph0=Math.cos(this.lat0);}}},forward:function(p){var x,y;var lam=p.x;var phi=p.y;lam=Proj4js.common.adjust_lon(lam-this.long0);if(this.sphere){var coslam,cosphi,sinphi;sinphi=Math.sin(phi);cosphi=Math.cos(phi);coslam=Math.cos(lam);switch(this.mode){case this.EQUIT:y=(this.mode==this.EQUIT)?1.+cosphi*coslam:1.+this.sinph0*sinphi+this.cosph0*cosphi*coslam;if(y<=Proj4js.common.EPSLN){Proj4js.reportError("laea:fwd:y less than eps");return null;}
+y=Math.sqrt(2./y);x=y*cosphi*Math.sin(lam);y*=(this.mode==this.EQUIT)?sinphi:this.cosph0*sinphi-this.sinph0*cosphi*coslam;break;case this.N_POLE:coslam=-coslam;case this.S_POLE:if(Math.abs(phi+this.phi0)<Proj4js.common.EPSLN){Proj4js.reportError("laea:fwd:phi < eps");return null;}
+y=Proj4js.common.FORTPI-phi*.5;y=2.*((this.mode==this.S_POLE)?Math.cos(y):Math.sin(y));x=y*Math.sin(lam);y*=coslam;break;}}else{var coslam,sinlam,sinphi,q,sinb=0.0,cosb=0.0,b=0.0;coslam=Math.cos(lam);sinlam=Math.sin(lam);sinphi=Math.sin(phi);q=Proj4js.common.qsfnz(this.e,sinphi);if(this.mode==this.OBLIQ||this.mode==this.EQUIT){sinb=q/this.qp;cosb=Math.sqrt(1.-sinb*sinb);}
+switch(this.mode){case this.OBLIQ:b=1.+this.sinb1*sinb+this.cosb1*cosb*coslam;break;case this.EQUIT:b=1.+cosb*coslam;break;case this.N_POLE:b=Proj4js.common.HALF_PI+phi;q=this.qp-q;break;case this.S_POLE:b=phi-Proj4js.common.HALF_PI;q=this.qp+q;break;}
+if(Math.abs(b)<Proj4js.common.EPSLN){Proj4js.reportError("laea:fwd:b < eps");return null;}
+switch(this.mode){case this.OBLIQ:case this.EQUIT:b=Math.sqrt(2./b);if(this.mode==this.OBLIQ){y=this.ymf*b*(this.cosb1*sinb-this.sinb1*cosb*coslam);}else{y=(b=Math.sqrt(2./(1.+cosb*coslam)))*sinb*this.ymf;}
+x=this.xmf*b*cosb*sinlam;break;case this.N_POLE:case this.S_POLE:if(q>=0.){x=(b=Math.sqrt(q))*sinlam;y=coslam*((this.mode==this.S_POLE)?b:-b);}else{x=y=0.;}
+break;}}
+p.x=this.a*x+this.x0;p.y=this.a*y+this.y0;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var x=p.x/this.a;var y=p.y/this.a;if(this.sphere){var cosz=0.0,rh,sinz=0.0;rh=Math.sqrt(x*x+y*y);var phi=rh*.5;if(phi>1.){Proj4js.reportError("laea:Inv:DataError");return null;}
+phi=2.*Math.asin(phi);if(this.mode==this.OBLIQ||this.mode==this.EQUIT){sinz=Math.sin(phi);cosz=Math.cos(phi);}
+switch(this.mode){case this.EQUIT:phi=(Math.abs(rh)<=Proj4js.common.EPSLN)?0.:Math.asin(y*sinz/rh);x*=sinz;y=cosz*rh;break;case this.OBLIQ:phi=(Math.abs(rh)<=Proj4js.common.EPSLN)?this.phi0:Math.asin(cosz*sinph0+y*sinz*cosph0/rh);x*=sinz*cosph0;y=(cosz-Math.sin(phi)*sinph0)*rh;break;case this.N_POLE:y=-y;phi=Proj4js.common.HALF_PI-phi;break;case this.S_POLE:phi-=Proj4js.common.HALF_PI;break;}
+lam=(y==0.&&(this.mode==this.EQUIT||this.mode==this.OBLIQ))?0.:atan2(x,y);}else{var cCe,sCe,q,rho,ab=0.0;switch(this.mode){case this.EQUIT:case this.OBLIQ:x/=this.dd;y*=this.dd;rho=Math.sqrt(x*x+y*y);if(rho<Proj4js.common.EPSLN){p.x=0.;p.y=this.phi0;return p;}
+sCe=2.*Math.asin(.5*rho/this.rq);cCe=Math.cos(sCe);x*=(sCe=Math.sin(sCe));if(this.mode==this.OBLIQ){ab=cCe*this.sinb1+y*sCe*this.cosb1/rho
+q=this.qp*ab;y=rho*this.cosb1*cCe-y*this.sinb1*sCe;}else{ab=y*sCe/rho;q=this.qp*ab;y=rho*cCe;}
+break;case this.N_POLE:y=-y;case this.S_POLE:q=(x*x+y*y);if(!q){p.x=0.;p.y=this.phi0;return p;}
+ab=1.-q/this.qp;if(this.mode==this.S_POLE){ab=-ab;}
+break;}
+lam=Math.atan2(x,y);phi=this.authlat(Math.asin(ab),this.apa);}
+p.x=Proj4js.common.adjust_lon(this.long0+lam);p.y=phi;return p;},P00:.33333333333333333333,P01:.17222222222222222222,P02:.10257936507936507936,P10:.06388888888888888888,P11:.06640211640211640211,P20:.01641501294219154443,authset:function(es){var t;var APA=new Array();APA[0]=es*this.P00;t=es*es;APA[0]+=t*this.P01;APA[1]=t*this.P10;t*=es;APA[0]+=t*this.P02;APA[1]+=t*this.P11;APA[2]=t*this.P20;return APA;},authlat:function(beta,APA){var t=beta+beta;return(beta+APA[0]*Math.sin(t)+APA[1]*Math.sin(t+t)+APA[2]*Math.sin(t+t+t));}};Proj4js.Proj.aeqd={init:function(){this.sin_p12=Math.sin(this.lat0);this.cos_p12=Math.cos(this.lat0);},forward:function(p){var lon=p.x;var lat=p.y;var ksp;var sinphi=Math.sin(p.y);var cosphi=Math.cos(p.y);var dlon=Proj4js.common.adjust_lon(lon-this.long0);var coslon=Math.cos(dlon);var g=this.sin_p12*sinphi+this.cos_p12*cosphi*coslon;if(Math.abs(Math.abs(g)-1.0)<Proj4js.common.EPSLN){ksp=1.0;if(g<0.0){Proj4js.reportError("aeqd:Fwd:PointError");return;}}else{var z=Math.acos(g);ksp=z/Math.sin(z);}
+p.x=this.x0+this.a*ksp*cosphi*Math.sin(dlon);p.y=this.y0+this.a*ksp*(this.cos_p12*sinphi-this.sin_p12*cosphi*coslon);return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var rh=Math.sqrt(p.x*p.x+p.y*p.y);if(rh>(2.0*Proj4js.common.HALF_PI*this.a)){Proj4js.reportError("aeqdInvDataError");return;}
+var z=rh/this.a;var sinz=Math.sin(z);var cosz=Math.cos(z);var lon=this.long0;var lat;if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=this.lat0;}else{lat=Proj4js.common.asinz(cosz*this.sin_p12+(p.y*sinz*this.cos_p12)/rh);var con=Math.abs(this.lat0)-Proj4js.common.HALF_PI;if(Math.abs(con)<=Proj4js.common.EPSLN){if(lat0>=0.0){lon=Proj4js.common.adjust_lon(this.long0+Math.atan2(p.x,-p.y));}else{lon=Proj4js.common.adjust_lon(this.long0-Math.atan2(-p.x,p.y));}}else{con=cosz-this.sin_p12*Math.sin(lat);if((Math.abs(con)<Proj4js.common.EPSLN)&&(Math.abs(p.x)<Proj4js.common.EPSLN)){}else{var temp=Math.atan2((p.x*sinz*this.cos_p12),(con*rh));lon=Proj4js.common.adjust_lon(this.long0+Math.atan2((p.x*sinz*this.cos_p12),(con*rh)));}}}
+p.x=lon;p.y=lat;return p;}};Proj4js.Proj.moll={init:function(){},forward:function(p){var lon=p.x;var lat=p.y;var delta_lon=Proj4js.common.adjust_lon(lon-this.long0);var theta=lat;var con=Proj4js.common.PI*Math.sin(lat);for(var i=0;true;i++){var delta_theta=-(theta+Math.sin(theta)-con)/(1.0+Math.cos(theta));theta+=delta_theta;if(Math.abs(delta_theta)<Proj4js.common.EPSLN)break;if(i>=50){Proj4js.reportError("moll:Fwd:IterationError");}}
+theta/=2.0;if(Proj4js.common.PI/2-Math.abs(lat)<Proj4js.common.EPSLN)delta_lon=0;var x=0.900316316158*this.a*delta_lon*Math.cos(theta)+this.x0;var y=1.4142135623731*this.a*Math.sin(theta)+this.y0;p.x=x;p.y=y;return p;},inverse:function(p){var theta;var arg;p.x-=this.x0;var arg=p.y/(1.4142135623731*this.a);if(Math.abs(arg)>0.999999999999)arg=0.999999999999;var theta=Math.asin(arg);var lon=Proj4js.common.adjust_lon(this.long0+(p.x/(0.900316316158*this.a*Math.cos(theta))));if(lon<(-Proj4js.common.PI))lon=-Proj4js.common.PI;if(lon>Proj4js.common.PI)lon=Proj4js.common.PI;arg=(2.0*theta+Math.sin(2.0*theta))/Proj4js.common.PI;if(Math.abs(arg)>1.0)arg=1.0;var lat=Math.asin(arg);p.x=lon;p.y=lat;return p;}};
\ No newline at end of file
Modified: trunk/templates/mapserver/standard/ApplicationDefinition.xml
--- trunk/templates/mapserver/standard/ApplicationDefinition.xml 2009-09-23 22:07:49 UTC (rev 1906)
+++ trunk/templates/mapserver/standard/ApplicationDefinition.xml 2009-09-24 15:32:41 UTC (rev 1907)
@@ -14,7 +14,7 @@
<Type>MapServer</Type>
<SingleTile>true</SingleTile>
<Extension>
- <MapFile>/home/pdeschamps/fgs/apps/gmap-orig/htdocs/gmap_groups.map</MapFile>
+ <MapFile>/ms4w/apps/gmap/htdocs/gmap_groups.map</MapFile>
</Extension>
</Map>
</MapGroup>
@@ -23,10 +23,21 @@
<Extension>
- <MapFile>/home/pdeschamps/fgs/apps/gmap-orig/htdocs/gmap75.map</MapFile>
+ <MapFile>/ms4w/apps/gmap/htdocs/gmap75.map</MapFile>
+ <!--ProjectionCode>EPSG:42304</ProjectionCode-->
+ <ProjectionDef>+title=LCC +proj=lcc +lat_1=49 +lat_2=77 +lat_0=49 +lon_0=-95 +x_0=0 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs</ProjectionDef>
</Extension>
</Map>
</MapGroup>
+ <MapGroup id="gmapLL" xsi:type="MapType">
+ <Map xsi:type="MapLayerType">
+ <Type>MapServer</Type>
+ <SingleTile>true</SingleTile>
+ <Extension>
+ <MapFile>/ms4w/apps/gmap/htdocs/gmapLonLat2.map</MapFile>
+ </Extension>
+ </Map>
+ </MapGroup>
<MapGroup id="mixed" xsi:type="MapType">
<Map xsi:type="WMSLayerType">
<Type>WMS</Type>
@@ -49,7 +60,7 @@
<Extension>
+ <MapFile>/ms4w/apps/gmap/htdocs/gmapLonLat.map</MapFile>
<Options>
<isBaseLayer>false</isBaseLayer>
<singleTile>true</singleTile>
@@ -665,12 +676,12 @@
<Type>Measure</Type>
<StatusText>Measure distances on the map.</StatusText>
<Extension xsi:type="CustomContentType">
- <Type>both</Type>
+ <Type>distance</Type>
<MeasureTooltipContainer>MeasureResult</MeasureTooltipContainer>
<MeasureTooltipType>dynamic</MeasureTooltipType>
<DistancePrecision>0</DistancePrecision>
<AreaPrecision>0</AreaPrecision>
- <Units>meters</Units>
+ <Units>km</Units>
</Extension>
<ImageUrl>images/icons.png</ImageUrl>
<ImageClass>measure</ImageClass>
@@ -1125,17 +1136,14 @@
</MapWidget>
<!-- OVERVIEW MAP
<Widget xsi:type="WidgetType">
<Name>OverviewMap</Name>
<Type>OverviewMap</Type>
<Description/>
- <Extension xsi:type="CustomContentType">
- <MapId>mapserverKeymap</MapId>
- </Extension>
</Widget>
<!-- PRINT -->
<Widget xsi:type="UiWidgetType">
@@ -1171,6 +1179,7 @@
</Widget>
<!-- MAPTIPS -->
<Name>Maptip</Name>
<Type>Maptip</Type>
@@ -1178,12 +1187,6 @@
<Delay>250</Delay>
<Tolerance>5</Tolerance>
<Maptip>
- <Layer>popplace </Layer>
- <Label>Populated Places</Label>
- <TextField>NAME</TextField>
- <CustomURL>http://localhost/populationInfo.php?cityname=[NAME]</CustomURL>
- </Maptip>
- <Maptip>
<Layer>park</Layer>
<TextField>NAME_E</TextField>
</Maptip>
@@ -1206,7 +1209,59 @@
</Maptip>
</Extension>
</Widget>
+ <Widget xsi:type="UiWidgetType">
+ <Name>NewPoint</Name>
+ <Type>Digitizer</Type>
+ <Location>ext/LWE</Location>
+ <Extension>
+ <Mode>redline</Mode>
+ <Type>polygon</Type>
+ <Symbolizer>
+ <SymbolInput>PointStyleShape</SymbolInput>
+ <SizeInput>PointStyleSize</SizeInput>
+ <OutlineColorInput>PointStyleBorderColor</OutlineColorInput>
+ <ColorInput>PointStyleFillColor</ColorInput>
+ </Symbolizer>
+ </Extension>
+ <ImageUrl>images/icons/edit-create-point.png</ImageUrl>
+ <Label>new point</Label>
+ <Tooltip>Click create a new point</Tooltip>
+ <StatusText/>
+ <Disabled>false</Disabled>
+ </Widget>
+ <Widget>
+ <Name>PointStyleFillColorButton</Name>
+ <Type>ColorPicker</Type>
+ <Description/>
+ <Extension>
+ <ColorInputId>PointStyleFillColor</ColorInputId>
+ </Extension>
+ <Label>Fill</Label>
+ <Tooltip>Click to change the fill color of the point symbol</Tooltip>
+ </Widget>
+ <!--Widget xsi:type="UiWidgetType">
+ <Name>ModifyPoint</Name>
+ <Type>Edit</Type>
+ <Extension>
+ <Type>point</Type>
+ <Symbolizer>
+ </Symbolizer>
+ </Extension>
+ <ImageUrl>images/icons/edit-modify-point.png</ImageUrl>
+ <Label/>
+ <Tooltip>Click to modify existing points</Tooltip>
+ <StatusText/>
+ </Widget-->
</WidgetSet>
<Extension/>
Added: trunk/templates/mapserver/standard/EPSG42304.js
--- trunk/templates/mapserver/standard/EPSG42304.js (rev 0)
+++ trunk/templates/mapserver/standard/EPSG42304.js 2009-09-24 15:32:41 UTC (rev 1907)
@@ -0,0 +1 @@
+Proj4js.defs["EPSG:42304"]="+title=Atlas of Canada, LCC +proj=lcc +lat_1=49 +lat_2=77 +lat_0=49 +lon_0=-95 +x_0=0 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs";
Modified: trunk/templates/mapserver/standard/index.html
--- trunk/templates/mapserver/standard/index.html 2009-09-23 22:07:49 UTC (rev 1906)
+++ trunk/templates/mapserver/standard/index.html 2009-09-24 15:32:41 UTC (rev 1907)
@@ -7,6 +7,7 @@
<script src='http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ'></script>
<script type="text/javascript" src="../../../lib/fusion.js" charset="utf-8"></script>
+<script type="text/javascript" src="EPSG42304.js"></script>
<link rel="stylesheet" href="themes/delicious/jxtheme.uncompressed.css" type="text/css" media="screen" charset="utf-8">
<link rel="stylesheet" href="icons.css" type="text/css" media="screen" charset="utf-8">
<style type="text/css">
@@ -97,8 +98,10 @@
<div id="SelectionPanel"></div>
<div id="OverviewMap"></div>
</div>
-<div id="Map"><div id="Navigator"></div>
-<div id="Maptip"></div></div>
+<div id="Map">
+ <div id="Navigator"></div>
+ <div id="Maptip"></div>
+</div>
<div id="Statusbar"></div>
<div id="TaskPane"></div>
<div id="PoweredBy" class="statusBarItem">
@@ -108,7 +111,6 @@
</div>
</div>
<div id="BusyIndicator" style="visibility: hidden;">
</div>
Modified: trunk/widgets/Measure.js
--- trunk/widgets/Measure.js 2009-09-23 22:07:49 UTC (rev 1906)
+++ trunk/widgets/Measure.js 2009-09-24 15:32:41 UTC (rev 1907)
@@ -144,7 +144,7 @@
new OpenLayers.Rule({symbolizer: this.sketchSymbolizers})
var styleMap = new OpenLayers.StyleMap({"default": style});
//add in the OL Polygon handler
this.map = mapWidget.oMapOL;
var handlerOptions = {
@@ -278,15 +278,17 @@
var quantity, from, to;
var v = geom.getVertices();
+ var map = this.getMap();
+ var proj = map.oMapOL.baseLayer.projection;
if (geom.CLASS_NAME.indexOf('LineString') != -1) {
from = this.getMap().geoToPix(v[0].x,v[0].y);
to = this.getMap().geoToPix(v[1].x,v[1].y);
at = {x: (from.x + to.x) / 2, y: (from.y + to.y) / 2};
- quantity = geom.getGeodesicLength();
+ quantity = geom.getGeodesicLength(proj);
} else {
var cg = geom.getCentroid();
at = this.getMap().geoToPix(cg.x, cg.y);
- quantity = geom.getGeodesicArea();
+ quantity = geom.getGeodesicArea(proj);
if (quantity > 1) {
marker.setQuantity(quantity);
More information about the fusion-commits
