[fusion-commits] r1920 - trunk
svn_fusion at osgeo.org
Thu Sep 24 17:37:31 EDT 2009
Author: pagameba
Date: 2009-09-24 17:37:31 -0400 (Thu, 24 Sep 2009)
New Revision: 1920
trunk/build.xml
move static path to PHP into a parameter so it can be configured more easily per system or using -DPHP=/path/to/php when invoking ant
Modified: trunk/build.xml
--- trunk/build.xml 2009-09-24 20:58:07 UTC (rev 1919)
+++ trunk/build.xml 2009-09-24 21:37:31 UTC (rev 1920)
@@ -93,6 +93,7 @@
<property name="buildOutput" value="${build.home}/lib/${sfName}"/>
<property name="cssOutput" value="${build.home}/lib/${sfName}"/>
<property name="cssFiles" value=""/>
+ <property name="PHP" value="/usr/local/php5cgi/bin/php"/>
<!-- ==================== Prepare Target ================================== -->
@@ -185,9 +186,9 @@
<xmlproperty file="${build.home}/appDefFileset.xml"/>
<!-- convert the application definition file to JSON -->
- <exec executable="C:\ms4w\Apache\cgi-bin\php.exe" os="Windows Vista, Windows XP"
+ <exec executable="${PHP}" dir="${build.home}"
output="${build.home}/appDef.json">
- <arg line="common\php\Xml2JSON.php --file='${appDef}'"/>
+ <arg line="${build.home}\common\php\Xml2JSON.php --file='${appDef}'"/>
</exec>
</target>
More information about the fusion-commits
