[fusion-commits] r2131 - trunk/widgets/Theme/classes
svn_fusion at osgeo.org
Mon Apr 5 21:59:48 EDT 2010
Author: liuar
Date: 2010-04-05 21:59:47 -0400 (Mon, 05 Apr 2010)
New Revision: 2131
trunk/widgets/Theme/classes/theme.php
Fixed ticket #386 Theme: The layer only geometric type = MgFeatureGeometricType::Surface is listed for Theme
Modified: trunk/widgets/Theme/classes/theme.php
--- trunk/widgets/Theme/classes/theme.php 2010-04-05 15:21:24 UTC (rev 2130)
+++ trunk/widgets/Theme/classes/theme.php 2010-04-06 01:59:47 UTC (rev 2131)
@@ -63,7 +63,14 @@
if($propDef->GetPropertyType() == MgFeaturePropertyType::GeometricProperty)
- if ($propDef->GetGeometryTypes() == MgFeatureGeometricType::Surface)
+ if ($propDef->GetGeometryTypes() == MgFeatureGeometricType::Surface ||
+ $propDef->GetGeometryTypes() == (MgFeatureGeometricType::Point | MgFeatureGeometricType::Surface) ||
+ $propDef->GetGeometryTypes() == (MgFeatureGeometricType::Curve | MgFeatureGeometricType::Surface) ||
+ $propDef->GetGeometryTypes() == (MgFeatureGeometricType::Solid | MgFeatureGeometricType::Surface) ||
+ $propDef->GetGeometryTypes() == (MgFeatureGeometricType::Point | MgFeatureGeometricType::Curve | MgFeatureGeometricType::Surface) ||
+ $propDef->GetGeometryTypes() == (MgFeatureGeometricType::Point | MgFeatureGeometricType::Solid | MgFeatureGeometricType::Surface) ||
+ $propDef->GetGeometryTypes() == (MgFeatureGeometricType::Curve | MgFeatureGeometricType::Solid | MgFeatureGeometricType::Surface) ||
+ $propDef->GetGeometryTypes() == (MgFeatureGeometricType::Point | MgFeatureGeometricType::Curve | MgFeatureGeometricType::Solid | MgFeatureGeometricType::Surface))
$layerNames[$layer->GetName()] = $layer->GetLegendLabel();
More information about the fusion-commits
