[fusion-commits] r2145 - branches/fusion-2.0/lib
svn_fusion at osgeo.org
Fri Apr 16 09:35:05 EDT 2010
Author: madair
Date: 2010-04-16 09:35:05 -0400 (Fri, 16 Apr 2010)
New Revision: 2145
branches/fusion-2.0/lib/proj4js-compressed.js
re #392: update to latest proj4js v1.0.1 applied to 2.0 branch
Modified: branches/fusion-2.0/lib/proj4js-compressed.js
--- branches/fusion-2.0/lib/proj4js-compressed.js 2010-04-16 13:33:20 UTC (rev 2144)
+++ branches/fusion-2.0/lib/proj4js-compressed.js 2010-04-16 13:35:05 UTC (rev 2145)
@@ -3,7 +3,7 @@
Authors: Mike Adair madairATdmsolutions.ca
Richard Greenwood richATgreenwoodmap.com
- Didier Richard
+ Didier Richard didier.richardATign.fr
Stephen Irons
License: LGPL as per: http://www.gnu.org/copyleft/lesser.html
Note: This program is an almost direct port of the C library
@@ -33,13 +33,13 @@
Proj4js.extend(extended,parent);}
Class.prototype=extended;return Class;},bind:function(func,object){var args=Array.prototype.slice.apply(arguments,[2]);return function(){var newArgs=args.concat(Array.prototype.slice.apply(arguments,[0]));return func.apply(object,newArgs);};},scriptName:"proj4js-compressed.js",defsLookupService:'http://spatialreference.org/ref',libPath:null,getScriptLocation:function(){if(this.libPath)return this.libPath;var scriptName=this.scriptName;var scriptNameLen=scriptName.length;var scripts=document.getElementsByTagName('script');for(var i=0;i<scripts.length;i++){var src=scripts[i].getAttribute('src');if(src){var index=src.lastIndexOf(scriptName);if((index>-1)&&(index+scriptNameLen==src.length)){this.libPath=src.slice(0,-scriptNameLen);break;}}}
return this.libPath||"";},loadScript:function(url,onload,onfail,loadCheck){var script=document.createElement('script');script.defer=false;script.type="text/javascript";script.id=url;script.src=url;script.onload=onload;script.onerror=onfail;script.loadCheck=loadCheck;if(/MSIE/.test(navigator.userAgent)){script.onreadystatechange=this.checkReadyState;}
-document.getElementsByTagName('head')[0].appendChild(script);},checkReadyState:function(){if(this.readyState=='loaded'){if(!this.loadCheck()){this.onerror();}else{this.onload();}}}};Proj4js.Proj=Proj4js.Class({readyToUse:false,title:null,projName:null,units:null,datum:null,initialize:function(srsCode){this.srsCodeInput=srsCode;if(srsCode.indexOf('urn:')==0){var urn=srsCode.split(':');if((urn[1]=='ogc'||urn[1]=='x-ogc')&&(urn[2]=='def')&&(urn[3]=='crs')&&urn.length==7){srsCode=urn[4]+':'+urn[6];}}else if(srsCode.indexOf('http://')==0){var url=srsCode.split('#');if(url[0].match(/epsg.org/)){srsCode='EPSG:'+url[1];}else if(url[0].match(/RIG.xml/)){srsCode='IGNF:'+url[1];}}
+document.getElementsByTagName('head')[0].appendChild(script);},checkReadyState:function(){if(this.readyState=='loaded'){if(!this.loadCheck()){this.onerror();}else{this.onload();}}}};Proj4js.Proj=Proj4js.Class({readyToUse:false,title:null,projName:null,units:null,datum:null,x0:0,y0:0,initialize:function(srsCode){this.srsCodeInput=srsCode;if(srsCode.indexOf('urn:')==0){var urn=srsCode.split(':');if((urn[1]=='ogc'||urn[1]=='x-ogc')&&(urn[2]=='def')&&(urn[3]=='crs')){srsCode=urn[4]+':'+urn[urn.length-1];}}else if(srsCode.indexOf('http://')==0){var url=srsCode.split('#');if(url[0].match(/epsg.org/)){srsCode='EPSG:'+url[1];}else if(url[0].match(/RIG.xml/)){srsCode='IGNF:'+url[1];}}
this.srsCode=srsCode.toUpperCase();if(this.srsCode.indexOf("EPSG")==0){this.srsCode=this.srsCode;this.srsAuth='epsg';this.srsProjNumber=this.srsCode.substring(5);}else if(this.srsCode.indexOf("IGNF")==0){this.srsCode=this.srsCode;this.srsAuth='IGNF';this.srsProjNumber=this.srsCode.substring(5);}else if(this.srsCode.indexOf("CRS")==0){this.srsCode=this.srsCode;this.srsAuth='CRS';this.srsProjNumber=this.srsCode.substring(4);}else{this.srsAuth='';this.srsProjNumber=this.srsCode;}
this.loadProjDefinition();},loadProjDefinition:function(){if(Proj4js.defs[this.srsCode]){this.defsLoaded();return;}
var url=Proj4js.getScriptLocation()+'defs/'+this.srsAuth.toUpperCase()+this.srsProjNumber+'.js';Proj4js.loadScript(url,Proj4js.bind(this.defsLoaded,this),Proj4js.bind(this.loadFromService,this),Proj4js.bind(this.checkDefsLoaded,this));},loadFromService:function(){var url=Proj4js.defsLookupService+'/'+this.srsAuth+'/'+this.srsProjNumber+'/proj4js/';Proj4js.loadScript(url,Proj4js.bind(this.defsLoaded,this),Proj4js.bind(this.defsFailed,this),Proj4js.bind(this.checkDefsLoaded,this));},defsLoaded:function(){this.parseDefs();this.loadProjCode(this.projName);},checkDefsLoaded:function(){if(Proj4js.defs[this.srsCode]){return true;}else{return false;}},defsFailed:function(){Proj4js.reportError('failed to load projection definition for: '+this.srsCode);Proj4js.defs[this.srsCode]=Proj4js.defs['WGS84'];this.defsLoaded();},loadProjCode:function(projName){if(Proj4js.Proj[projName]){this.initTransforms();return;}
var url=Proj4js.getScriptLocation()+'projCode/'+projName+'.js';Proj4js.loadScript(url,Proj4js.bind(this.loadProjCodeSuccess,this,projName),Proj4js.bind(this.loadProjCodeFailure,this,projName),Proj4js.bind(this.checkCodeLoaded,this,projName));},loadProjCodeSuccess:function(projName){if(Proj4js.Proj[projName].dependsOn){this.loadProjCode(Proj4js.Proj[projName].dependsOn);}else{this.initTransforms();}},loadProjCodeFailure:function(projName){Proj4js.reportError("failed to find projection file for: "+projName);},checkCodeLoaded:function(projName){if(Proj4js.Proj[projName]){return true;}else{return false;}},initTransforms:function(){Proj4js.extend(this,Proj4js.Proj[this.projName]);this.init();this.readyToUse=true;},parseDefs:function(){this.defData=Proj4js.defs[this.srsCode];var paramName,paramVal;if(!this.defData){return;}
var paramArray=this.defData.split("+");for(var prop=0;prop<paramArray.length;prop++){var property=paramArray[prop].split("=");paramName=property[0].toLowerCase();paramVal=property[1];switch(paramName.replace(/\s/gi,"")){case"":break;case"title":this.title=paramVal;break;case"proj":this.projName=paramVal.replace(/\s/gi,"");break;case"units":this.units=paramVal.replace(/\s/gi,"");break;case"datum":this.datumCode=paramVal.replace(/\s/gi,"");break;case"nadgrids":this.nagrids=paramVal.replace(/\s/gi,"");break;case"ellps":this.ellps=paramVal.replace(/\s/gi,"");break;case"a":this.a=parseFloat(paramVal);break;case"b":this.b=parseFloat(paramVal);break;case"rf":this.rf=parseFloat(paramVal);break;case"lat_0":this.lat0=paramVal*Proj4js.common.D2R;break;case"lat_1":this.lat1=paramVal*Proj4js.common.D2R;break;case"lat_2":this.lat2=paramVal*Proj4js.common.D2R;break;case"lat_ts":this.lat_ts=paramVal*Proj4js.common.D2R;break;case"lon_0":this.long0=paramVal*Proj4js.common.D2R;break;case"alpha":this.alpha=parseFloat(paramVal)*Proj4js.common.D2R;break;case"lonc":this.longc=paramVal*Proj4js.common.D2R;break;case"x_0":this.x0=parseFloat(paramVal);break;case"y_0":this.y0=parseFloat(paramVal);break;case"k_0":this.k0=parseFloat(paramVal);break;case"k":this.k0=parseFloat(paramVal);break;case"r_a":this.R_A=true;break;case"zone":this.zone=parseInt(paramVal);break;case"south":this.utmSouth=true;break;case"towgs84":this.datum_params=paramVal.split(",");break;case"to_meter":this.to_meter=parseFloat(paramVal);break;case"from_greenwich":this.from_greenwich=paramVal*Proj4js.common.D2R;break;case"pm":paramVal=paramVal.replace(/\s/gi,"");this.from_greenwich=Proj4js.PrimeMeridian[paramVal]?Proj4js.PrimeMeridian[paramVal]:parseFloat(paramVal);this.from_greenwich*=Proj4js.common.D2R;break;case"no_defs":break;default:}}
-this.deriveConstants();},deriveConstants:function(){if(this.nagrids=='@null')this.datumCode='none';if(this.datumCode&&this.datumCode!='none'){var datumDef=Proj4js.Datum[this.datumCode];if(datumDef){this.datum_params=datumDef.towgs84.split(',');this.ellps=datumDef.ellipse;this.datumName=datumDef.datumName?datumDef.datumName:this.datumCode;}}
+this.deriveConstants();},deriveConstants:function(){if(this.nagrids=='@null')this.datumCode='none';if(this.datumCode&&this.datumCode!='none'){var datumDef=Proj4js.Datum[this.datumCode];if(datumDef){this.datum_params=datumDef.towgs84?datumDef.towgs84.split(','):null;this.ellps=datumDef.ellipse;this.datumName=datumDef.datumName?datumDef.datumName:this.datumCode;}}
if(!this.a){var ellipse=Proj4js.Ellipsoid[this.ellps]?Proj4js.Ellipsoid[this.ellps]:Proj4js.Ellipsoid['WGS84'];Proj4js.extend(this,ellipse);}
if(this.rf&&!this.b)this.b=(1.0-1.0/this.rf)*this.a;if(Math.abs(this.a-this.b)<Proj4js.common.EPSLN){this.sphere=true;this.b=this.a;}
this.a2=this.a*this.a;this.b2=this.b*this.b;this.es=(this.a2-this.b2)/this.a2;this.e=Math.sqrt(this.es);if(this.R_A){this.a*=1.-this.es*(Proj4js.common.SIXTH+this.es*(Proj4js.common.RA4+this.es*Proj4js.common.RA6));this.a2=this.a*this.a;this.b2=this.b*this.b;this.es=0.;}
@@ -116,8 +116,8 @@
if(Math.abs(phi)<Proj4js.common.HALF_PI){var sin_phi=Math.sin(phi);var cos_phi=Math.cos(phi);var tan_phi=Math.tan(phi);var c=this.ep2*Math.pow(cos_phi,2);var cs=Math.pow(c,2);var t=Math.pow(tan_phi,2);var ts=Math.pow(t,2);con=1.0-this.es*Math.pow(sin_phi,2);var n=this.a/Math.sqrt(con);var r=n*(1.0-this.es)/con;var d=x/(n*this.k0);var ds=Math.pow(d,2);lat=phi-(n*tan_phi*ds/r)*(0.5-ds/24.0*(5.0+3.0*t+10.0*c-4.0*cs-9.0*this.ep2-ds/30.0*(61.0+90.0*t+298.0*c+45.0*ts-252.0*this.ep2-3.0*cs)));lon=Proj4js.common.adjust_lon(this.long0+(d*(1.0-ds/6.0*(1.0+2.0*t+c-ds/20.0*(5.0-2.0*c+28.0*t-3.0*cs+8.0*this.ep2+24.0*ts)))/cos_phi));}else{lat=Proj4js.common.HALF_PI*Proj4js.common.sign(y);lon=this.long0;}}
p.x=lon;p.y=lat;return p;}};Proj4js.defs["GOOGLE"]="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs";Proj4js.defs["EPSG:900913"]=Proj4js.defs["GOOGLE"];Proj4js.Proj.gstmerc={init:function(){var temp=this.b/this.a;this.e=Math.sqrt(1.0-temp*temp);this.lc=this.long0;this.rs=Math.sqrt(1.0+this.e*this.e*Math.pow(Math.cos(this.lat0),4.0)/(1.0-this.e*this.e));var sinz=Math.sin(this.lat0);var pc=Math.asin(sinz/this.rs);var sinzpc=Math.sin(pc);this.cp=Proj4js.common.latiso(0.0,pc,sinzpc)-this.rs*Proj4js.common.latiso(this.e,this.lat0,sinz);this.n2=this.k0*this.a*Math.sqrt(1.0-this.e*this.e)/(1.0-this.e*this.e*sinz*sinz);this.xs=this.x0;this.ys=this.y0-this.n2*pc;if(!this.title)this.title="Gauss Schreiber transverse mercator";},forward:function(p){var lon=p.x;var lat=p.y;var L=this.rs*(lon-this.lc);var Ls=this.cp+(this.rs*Proj4js.common.latiso(this.e,lat,Math.sin(lat)));var lat1=Math.asin(Math.sin(L)/Proj4js.common.cosh(Ls));var Ls1=Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));p.x=this.xs+(this.n2*Ls1);p.y=this.ys+(this.n2*Math.atan(Proj4js.common.sinh(Ls)/Math.cos(L)));return p;},inverse:function(p){var x=p.x;var y=p.y;var L=Math.atan(Proj4js.common.sinh((x-this.xs)/this.n2)/Math.cos((y-this.ys)/this.n2));var lat1=Math.asin(Math.sin((y-this.ys)/this.n2)/Proj4js.common.cosh((x-this.xs)/this.n2));var LC=Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));p.x=this.lc+L/this.rs;p.y=Proj4js.common.invlatiso(this.e,(LC-this.cp)/this.rs);return p;}};Proj4js.Proj.ortho={init:function(def){;this.sin_p14=Math.sin(this.lat0);this.cos_p14=Math.cos(this.lat0);},forward:function(p){var sinphi,cosphi;var dlon;var coslon;var ksp;var g;var lon=p.x;var lat=p.y;dlon=Proj4js.common.adjust_lon(lon-this.long0);sinphi=Math.sin(lat);cosphi=Math.cos(lat);coslon=Math.cos(dlon);g=this.sin_p14*sinphi+this.cos_p14*cosphi*coslon;ksp=1.0;if((g>0)||(Math.abs(g)<=Proj4js.common.EPSLN)){var x=this.a*ksp*cosphi*Math.sin(dlon);var y=this.y0+this.a*ksp*(this.cos_p14*sinphi-this.sin_p14*cosphi*coslon);}else{Proj4js.reportError("orthoFwdPointError");}
p.x=x;p.y=y;return p;},inverse:function(p){var rh;var z;var sinz,cosz;var temp;var con;var lon,lat;p.x-=this.x0;p.y-=this.y0;rh=Math.sqrt(p.x*p.x+p.y*p.y);if(rh>this.a+.0000001){Proj4js.reportError("orthoInvDataError");}
-z=Proj4js.common.asinz(rh/this.a);sinz=Math.sin(z);cosi=Math.cos(z);lon=this.long0;if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=this.lat0;}
-lat=Proj4js.common.asinz(cosz*this.sin_p14+(y*sinz*this.cos_p14)/rh);con=Math.abs(lat0)-Proj4js.common.HALF_PI;if(Math.abs(con)<=Proj4js.common.EPSLN){if(this.lat0>=0){lon=Proj4js.common.adjust_lon(this.long0+Math.atan2(p.x,-p.y));}else{lon=Proj4js.common.adjust_lon(this.long0-Math.atan2(-p.x,p.y));}}
+z=Proj4js.common.asinz(rh/this.a);sinz=Math.sin(z);cosz=Math.cos(z);lon=this.long0;if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=this.lat0;}
+lat=Proj4js.common.asinz(cosz*this.sin_p14+(p.y*sinz*this.cos_p14)/rh);con=Math.abs(lat0)-Proj4js.common.HALF_PI;if(Math.abs(con)<=Proj4js.common.EPSLN){if(this.lat0>=0){lon=Proj4js.common.adjust_lon(this.long0+Math.atan2(p.x,-p.y));}else{lon=Proj4js.common.adjust_lon(this.long0-Math.atan2(-p.x,p.y));}}
con=cosz-this.sin_p14*Math.sin(lat);if((Math.abs(con)>=Proj4js.common.EPSLN)||(Math.abs(x)>=Proj4js.common.EPSLN)){lon=Proj4js.common.adjust_lon(this.long0+Math.atan2((p.x*sinz*this.cos_p14),(con*rh)));}
p.x=lon;p.y=lat;return p;}};Proj4js.Proj.somerc={init:function(){var phy0=this.lat0;this.lambda0=this.long0;var sinPhy0=Math.sin(phy0);var semiMajorAxis=this.a;var invF=this.rf;var flattening=1/invF;var e2=2*flattening-Math.pow(flattening,2);var e=this.e=Math.sqrt(e2);this.R=semiMajorAxis*Math.sqrt(1-e2)/(1-e2*Math.pow(sinPhy0,2.0));this.alpha=Math.sqrt(1+e2/(1-e2)*Math.pow(Math.cos(phy0),4.0));this.b0=Math.asin(sinPhy0/this.alpha);this.K=Math.log(Math.tan(Math.PI/4.0+this.b0/2.0))
-this.alpha*Math.log(Math.tan(Math.PI/4.0+phy0/2.0))
@@ -152,7 +152,9 @@
th_n_re=1;th_n_im=0;var den_re=this.B_re[1];var den_im=this.B_im[1];for(n=2;n<=6;n++){th_n_re1=th_n_re*th_re-th_n_im*th_im;th_n_im1=th_n_im*th_re+th_n_re*th_im;th_n_re=th_n_re1;th_n_im=th_n_im1;den_re=den_re+n*(this.B_re[n]*th_n_re-this.B_im[n]*th_n_im);den_im=den_im+n*(this.B_im[n]*th_n_re+this.B_re[n]*th_n_im);}
var den2=den_re*den_re+den_im*den_im;th_re=(num_re*den_re+num_im*den_im)/den2;th_im=(num_im*den_re-num_re*den_im)/den2;}
var d_psi=th_re;var d_lambda=th_im;var d_psi_n=1;var d_phi=0;for(n=1;n<=9;n++){d_psi_n=d_psi_n*d_psi;d_phi=d_phi+this.D[n]*d_psi_n;}
-var lat=this.lat0+(d_phi*Proj4js.common.SEC_TO_RAD*1E5);var lon=this.long0+d_lambda;p.x=lon;p.y=lat;return p;}};Proj4js.Proj.mill={init:function(){},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+this.a*dlon;var y=this.y0+this.a*Math.log(Math.tan((Proj4js.common.PI/4.0)+(lat/2.5)))*1.25;p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var lon=Proj4js.common.adjust_lon(this.long0+p.x/this.a);var lat=2.5*(Math.atan(Math.exp(0.8*p.y/this.a))-Proj4js.common.PI/4.0);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.sinu={init:function(){this.R=6370997.0;},forward:function(p){var x,y,delta_lon;var lon=p.x;var lat=p.y;delta_lon=Proj4js.common.adjust_lon(lon-this.long0);x=this.R*delta_lon*Math.cos(lat)+this.x0;y=this.R*lat+this.y0;p.x=x;p.y=y;return p;},inverse:function(p){var lat,temp,lon;p.x-=this.x0;p.y-=this.y0;lat=p.y/this.R;if(Math.abs(lat)>Proj4js.common.HALF_PI){Proj4js.reportError("sinu:Inv:DataError");}
+var lat=this.lat0+(d_phi*Proj4js.common.SEC_TO_RAD*1E5);var lon=this.long0+d_lambda;p.x=lon;p.y=lat;return p;}};Proj4js.Proj.mill={init:function(){},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+this.a*dlon;var y=this.y0+this.a*Math.log(Math.tan((Proj4js.common.PI/4.0)+(lat/2.5)))*1.25;p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var lon=Proj4js.common.adjust_lon(this.long0+p.x/this.a);var lat=2.5*(Math.atan(Math.exp(0.8*p.y/this.a))-Proj4js.common.PI/4.0);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.gnom={init:function(def){this.sin_p14=Math.sin(this.lat0);this.cos_p14=Math.cos(this.lat0);this.infinity_dist=1000*this.a;},forward:function(p){var sinphi,cosphi;var dlon;var coslon;var ksp;var g;var lon=p.x;var lat=p.y;dlon=Proj4js.common.adjust_lon(lon-this.long0);sinphi=Math.sin(lat);cosphi=Math.cos(lat);coslon=Math.cos(dlon);g=this.sin_p14*sinphi+this.cos_p14*cosphi*coslon;ksp=1.0;if((g>0)||(Math.abs(g)<=Proj4js.common.EPSLN)){x=this.x0+this.a*ksp*cosphi*Math.sin(dlon)/g;y=this.y0+this.a*ksp*(this.cos_p14*sinphi-this.sin_p14*cosphi*coslon)/g;}else{Proj4js.reportError("orthoFwdPointError");x=this.x0+this.infinity_dist*cosphi*Math.sin(dlon);y=this.y0+this.infinity_dist*(this.cos_p14*sinphi-this.sin_p14*cosphi*coslon);}
+p.x=x;p.y=y;return p;},inverse:function(p){var rh;var z;var sinc,cosc;var c;var lon,lat;p.x=(p.x-this.x0)/this.a;p.y=(p.y-this.y0)/this.a;p.x/=this.k0;p.y/=this.k0;if((rh=Math.sqrt(p.x*p.x+p.y*p.y))){c=Math.atan2(rh,this.rc);sinc=Math.sin(c);cosc=Math.cos(c);lat=Proj4js.common.asinz(cosc*this.sin_p14+(p.y*sinc*this.cos_p14)/rh);lon=Math.atan2(p.x*sinc,rh*this.cos_p14*cosc-p.y*this.sin_p14*sinc);lon=Proj4js.common.adjust_lon(this.long0+lon);}else{lat=this.phic0;lon=0.0;}
+p.x=lon;p.y=lat;return p;}};Proj4js.Proj.sinu={init:function(){this.R=6370997.0;},forward:function(p){var x,y,delta_lon;var lon=p.x;var lat=p.y;delta_lon=Proj4js.common.adjust_lon(lon-this.long0);x=this.R*delta_lon*Math.cos(lat)+this.x0;y=this.R*lat+this.y0;p.x=x;p.y=y;return p;},inverse:function(p){var lat,temp,lon;p.x-=this.x0;p.y-=this.y0;lat=p.y/this.R;if(Math.abs(lat)>Proj4js.common.HALF_PI){Proj4js.reportError("sinu:Inv:DataError");}
temp=Math.abs(lat)-Proj4js.common.HALF_PI;if(Math.abs(temp)>Proj4js.common.EPSLN){temp=this.long0+p.x/(this.R*Math.cos(lat));lon=Proj4js.common.adjust_lon(temp);}else{lon=this.long0;}
p.x=lon;p.y=lat;return p;}};Proj4js.Proj.vandg={init:function(){this.R=6370997.0;},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var x,y;if(Math.abs(lat)<=Proj4js.common.EPSLN){x=this.x0+this.R*dlon;y=this.y0;}
var theta=Proj4js.common.asinz(2.0*Math.abs(lat/Proj4js.common.PI));if((Math.abs(dlon)<=Proj4js.common.EPSLN)||(Math.abs(Math.abs(lat)-Proj4js.common.HALF_PI)<=Proj4js.common.EPSLN)){x=this.x0;if(lat>=0){y=this.y0+Proj4js.common.PI*this.R*Math.tan(.5*theta);}else{y=this.y0+Proj4js.common.PI*this.R*-Math.tan(.5*theta);}}
@@ -161,7 +163,13 @@
p.x=x;p.y=y;return p;},inverse:function(p){var dlon;var xx,yy,xys,c1,c2,c3;var al,asq;var a1;var m1;var con;var th1;var d;p.x-=this.x0;p.y-=this.y0;con=Proj4js.common.PI*this.R;xx=p.x/con;yy=p.y/con;xys=xx*xx+yy*yy;c1=-Math.abs(yy)*(1.0+xys);c2=c1-2.0*yy*yy+xx*xx;c3=-2.0*c1+1.0+2.0*yy*yy+xys*xys;d=yy*yy/c3+(2.0*c2*c2*c2/c3/c3/c3-9.0*c1*c2/c3/c3)/27.0;a1=(c1-c2*c2/3.0/c3)/c3;m1=2.0*Math.sqrt(-a1/3.0);con=((3.0*d)/a1)/m1;if(Math.abs(con)>1.0){if(con>=0.0){con=1.0;}else{con=-1.0;}}
th1=Math.acos(con)/3.0;if(p.y>=0){lat=(-m1*Math.cos(th1+Proj4js.common.PI/3.0)-c2/3.0/c3)*Proj4js.common.PI;}else{lat=-(-m1*Math.cos(th1+PI/3.0)-c2/3.0/c3)*Proj4js.common.PI;}
if(Math.abs(xx)<Proj4js.common.EPSLN){lon=this.long0;}
-lon=Proj4js.common.adjust_lon(this.long0+Proj4js.common.PI*(xys-1.0+Math.sqrt(1.0+2.0*(xx*xx-yy*yy)+xys*xys))/2.0/xx);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.cea={init:function(){},forward:function(p){var lon=p.x;var lat=p.y;dlon=Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+this.a*dlon*Math.cos(this.lat_ts);var y=this.y0+this.a*Math.sin(lat)/Math.cos(this.lat_ts);p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var lon=Proj4js.common.adjust_lon(this.long0+(p.x/this.a)/Math.cos(this.lat_ts));var lat=Math.asin((p.y/this.a)*Math.cos(this.lat_ts));p.x=lon;p.y=lat;return p;}};Proj4js.Proj.eqc={init:function(){if(!this.x0)this.x0=0;if(!this.y0)this.y0=0;if(!this.lat0)this.lat0=0;if(!this.long0)this.long0=0;if(!this.lat_ts)this.lat_ts=0;if(!this.title)this.title="Equidistant Cylindrical (Plate Carre)";this.rc=Math.cos(this.lat_ts);},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var dlat=Proj4js.common.adjust_lat(lat-this.lat0);p.x=this.x0+(this.a*dlon*this.rc);p.y=this.y0+(this.a*dlat);return p;},inverse:function(p){var x=p.x;var y=p.y;p.x=Proj4js.common.adjust_lon(this.long0+((x-this.x0)/(this.a*this.rc)));p.y=Proj4js.common.adjust_lat(this.lat0+((y-this.y0)/(this.a)));return p;}};Proj4js.Proj.gauss={init:function(){sphi=Math.sin(this.lat0);cphi=Math.cos(this.lat0);cphi*=cphi;this.rc=Math.sqrt(1.0-this.es)/(1.0-this.es*sphi*sphi);this.C=Math.sqrt(1.0+this.es*cphi*cphi/(1.0-this.es));this.phic0=Math.asin(sphi/this.C);this.ratexp=0.5*this.C*this.e;this.K=Math.tan(0.5*this.phic0+Proj4js.common.FORTPI)/(Math.pow(Math.tan(0.5*this.lat0+Proj4js.common.FORTPI),this.C)*Proj4js.common.srat(this.e*sphi,this.ratexp));},forward:function(p){var lon=p.x;var lat=p.y;p.y=2.0*Math.atan(this.K*Math.pow(Math.tan(0.5*lat+Proj4js.common.FORTPI),this.C)*Proj4js.common.srat(this.e*Math.sin(lat),this.ratexp))-Proj4js.common.HALF_PI;p.x=this.C*lon;return p;},inverse:function(p){var DEL_TOL=1e-14;var lon=p.x/this.C;var lat=p.y;num=Math.pow(Math.tan(0.5*lat+Proj4js.common.FORTPI)/this.K,1./this.C);for(var i=Proj4js.common.MAX_ITER;i>0;--i){lat=2.0*Math.atan(num*Proj4js.common.srat(this.e*Math.sin(p.y),-0.5*this.e))-Proj4js.common.HALF_PI;if(Math.abs(lat-p.y)<DEL_TOL)break;p.y=lat;}
+lon=Proj4js.common.adjust_lon(this.long0+Proj4js.common.PI*(xys-1.0+Math.sqrt(1.0+2.0*(xx*xx-yy*yy)+xys*xys))/2.0/xx);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.cea={init:function(){},forward:function(p){var lon=p.x;var lat=p.y;dlon=Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+this.a*dlon*Math.cos(this.lat_ts);var y=this.y0+this.a*Math.sin(lat)/Math.cos(this.lat_ts);p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var lon=Proj4js.common.adjust_lon(this.long0+(p.x/this.a)/Math.cos(this.lat_ts));var lat=Math.asin((p.y/this.a)*Math.cos(this.lat_ts));p.x=lon;p.y=lat;return p;}};Proj4js.Proj.eqc={init:function(){if(!this.x0)this.x0=0;if(!this.y0)this.y0=0;if(!this.lat0)this.lat0=0;if(!this.long0)this.long0=0;if(!this.lat_ts)this.lat_ts=0;if(!this.title)this.title="Equidistant Cylindrical (Plate Carre)";this.rc=Math.cos(this.lat_ts);},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var dlat=Proj4js.common.adjust_lat(lat-this.lat0);p.x=this.x0+(this.a*dlon*this.rc);p.y=this.y0+(this.a*dlat);return p;},inverse:function(p){var x=p.x;var y=p.y;p.x=Proj4js.common.adjust_lon(this.long0+((x-this.x0)/(this.a*this.rc)));p.y=Proj4js.common.adjust_lat(this.lat0+((y-this.y0)/(this.a)));return p;}};Proj4js.Proj.cass={init:function(){if(!this.sphere){this.en=this.pj_enfn(this.es)
+this.m0=this.pj_mlfn(this.lat0,Math.sin(this.lat0),Math.cos(this.lat0),this.en);}},C1:.16666666666666666666,C2:.00833333333333333333,C3:.04166666666666666666,C4:.33333333333333333333,C5:.06666666666666666666,forward:function(p){var x,y;var lam=p.x;var phi=p.y;lam=Proj4js.common.adjust_lon(lam-this.long0);if(this.sphere){x=Math.asin(Math.cos(phi)*Math.sin(lam));y=Math.atan2(Math.tan(phi),Math.cos(lam))-this.phi0;}else{this.n=Math.sin(phi);this.c=Math.cos(phi);y=this.pj_mlfn(phi,this.n,this.c,this.en);this.n=1./Math.sqrt(1.-this.es*this.n*this.n);this.tn=Math.tan(phi);this.t=this.tn*this.tn;this.a1=lam*this.c;this.c*=this.es*this.c/(1-this.es);this.a2=this.a1*this.a1;x=this.n*this.a1*(1.-this.a2*this.t*(this.C1-(8.-this.t+8.*this.c)*this.a2*this.C2));y-=this.m0-this.n*this.tn*this.a2*(.5+(5.-this.t+6.*this.c)*this.a2*this.C3);}
+p.x=this.a*x+this.x0;p.y=this.a*y+this.y0;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var x=p.x/this.a;var y=p.y/this.a;if(this.sphere){this.dd=y+this.lat0;phi=Math.asin(Math.sin(this.dd)*Math.cos(x));lam=Math.atan2(Math.tan(x),Math.cos(this.dd));}else{ph1=this.pj_inv_mlfn(this.m0+y,this.es,this.en);this.tn=Math.tan(ph1);this.t=this.tn*this.tn;this.n=Math.sin(ph1);this.r=1./(1.-this.es*this.n*this.n);this.n=Math.sqrt(this.r);this.r*=(1.-this.es)*this.n;this.dd=x/this.n;this.d2=this.dd*this.dd;phi=ph1-(this.n*this.tn/this.r)*this.d2*(.5-(1.+3.*this.t)*this.d2*this.C3);lam=this.dd*(1.+this.t*this.d2*(-this.C4+(1.+3.*this.t)*this.d2*this.C5))/Math.cos(ph1);}
+p.x=Proj4js.common.adjust_lon(this.long0+lam);p.y=phi;return p;},pj_enfn:function(es){en=new Array();en[0]=this.C00-es*(this.C02+es*(this.C04+es*(this.C06+es*this.C08)));en[1]=es*(this.C22-es*(this.C04+es*(this.C06+es*this.C08)));var t=es*es;en[2]=t*(this.C44-es*(this.C46+es*this.C48));t*=es;en[3]=t*(this.C66-es*this.C68);en[4]=t*es*this.C88;return en;},pj_mlfn:function(phi,sphi,cphi,en){cphi*=sphi;sphi*=sphi;return(en[0]*phi-cphi*(en[1]+sphi*(en[2]+sphi*(en[3]+sphi*en[4]))));},pj_inv_mlfn:function(arg,es,en){k=1./(1.-es);phi=arg;for(i=Proj4js.common.MAX_ITER;i;--i){s=Math.sin(phi);t=1.-es*s*s;t=(this.pj_mlfn(phi,s,Math.cos(phi),en)-arg)*(t*Math.sqrt(t))*k;phi-=t;if(Math.abs(t)<Proj4js.common.EPSLN)
+return phi;}
+Proj4js.reportError("cass:pj_inv_mlfn: Convergence error");return phi;},C00:1.0,C02:.25,C04:.046875,C06:.01953125,C08:.01068115234375,C22:.75,C44:.46875,C46:.01302083333333333333,C48:.00712076822916666666,C66:.36458333333333333333,C68:.00569661458333333333,C88:.3076171875}
+Proj4js.Proj.gauss={init:function(){sphi=Math.sin(this.lat0);cphi=Math.cos(this.lat0);cphi*=cphi;this.rc=Math.sqrt(1.0-this.es)/(1.0-this.es*sphi*sphi);this.C=Math.sqrt(1.0+this.es*cphi*cphi/(1.0-this.es));this.phic0=Math.asin(sphi/this.C);this.ratexp=0.5*this.C*this.e;this.K=Math.tan(0.5*this.phic0+Proj4js.common.FORTPI)/(Math.pow(Math.tan(0.5*this.lat0+Proj4js.common.FORTPI),this.C)*Proj4js.common.srat(this.e*sphi,this.ratexp));},forward:function(p){var lon=p.x;var lat=p.y;p.y=2.0*Math.atan(this.K*Math.pow(Math.tan(0.5*lat+Proj4js.common.FORTPI),this.C)*Proj4js.common.srat(this.e*Math.sin(lat),this.ratexp))-Proj4js.common.HALF_PI;p.x=this.C*lon;return p;},inverse:function(p){var DEL_TOL=1e-14;var lon=p.x/this.C;var lat=p.y;num=Math.pow(Math.tan(0.5*lat+Proj4js.common.FORTPI)/this.K,1./this.C);for(var i=Proj4js.common.MAX_ITER;i>0;--i){lat=2.0*Math.atan(num*Proj4js.common.srat(this.e*Math.sin(p.y),-0.5*this.e))-Proj4js.common.HALF_PI;if(Math.abs(lat-p.y)<DEL_TOL)break;p.y=lat;}
if(!i){Proj4js.reportError("gauss:inverse:convergence failed");return null;}
p.x=lon;p.y=lat;return p;}};Proj4js.Proj.omerc={init:function(){if(!this.mode)this.mode=0;if(!this.lon1){this.lon1=0;this.mode=1;}
if(!this.lon2)this.lon2=0;if(!this.lat2)this.lat2=0;var temp=this.b/this.a;var es=1.0-Math.pow(temp,2);var e=Math.sqrt(es);this.sin_p20=Math.sin(this.lat0);this.cos_p20=Math.cos(this.lat0);this.con=1.0-this.es*this.sin_p20*this.sin_p20;this.com=Math.sqrt(1.0-es);this.bl=Math.sqrt(1.0+this.es*Math.pow(this.cos_p20,4.0)/(1.0-es));this.al=this.a*this.bl*this.k0*this.com/this.con;if(Math.abs(this.lat0)<Proj4js.common.EPSLN){this.ts=1.0;this.d=1.0;this.el=1.0;}else{this.ts=Proj4js.common.tsfnz(this.e,this.lat0,this.sin_p20);this.con=Math.sqrt(this.con);this.d=this.bl*this.com/(this.cos_p20*this.con);if((this.d*this.d-1.0)>0.0){if(this.lat0>=0.0){this.f=this.d+Math.sqrt(this.d*this.d-1.0);}else{this.f=this.d-Math.sqrt(this.d*this.d-1.0);}}else{this.f=this.d;}
@@ -194,7 +202,7 @@
p.x=this.a*x+this.x0;p.y=this.a*y+this.y0;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var x=p.x/this.a;var y=p.y/this.a;if(this.sphere){var cosz=0.0,rh,sinz=0.0;rh=Math.sqrt(x*x+y*y);var phi=rh*.5;if(phi>1.){Proj4js.reportError("laea:Inv:DataError");return null;}
phi=2.*Math.asin(phi);if(this.mode==this.OBLIQ||this.mode==this.EQUIT){sinz=Math.sin(phi);cosz=Math.cos(phi);}
switch(this.mode){case this.EQUIT:phi=(Math.abs(rh)<=Proj4js.common.EPSLN)?0.:Math.asin(y*sinz/rh);x*=sinz;y=cosz*rh;break;case this.OBLIQ:phi=(Math.abs(rh)<=Proj4js.common.EPSLN)?this.phi0:Math.asin(cosz*sinph0+y*sinz*cosph0/rh);x*=sinz*cosph0;y=(cosz-Math.sin(phi)*sinph0)*rh;break;case this.N_POLE:y=-y;phi=Proj4js.common.HALF_PI-phi;break;case this.S_POLE:phi-=Proj4js.common.HALF_PI;break;}
-lam=(y==0.&&(this.mode==this.EQUIT||this.mode==this.OBLIQ))?0.:atan2(x,y);}else{var cCe,sCe,q,rho,ab=0.0;switch(this.mode){case this.EQUIT:case this.OBLIQ:x/=this.dd;y*=this.dd;rho=Math.sqrt(x*x+y*y);if(rho<Proj4js.common.EPSLN){p.x=0.;p.y=this.phi0;return p;}
+lam=(y==0.&&(this.mode==this.EQUIT||this.mode==this.OBLIQ))?0.:Math.atan2(x,y);}else{var cCe,sCe,q,rho,ab=0.0;switch(this.mode){case this.EQUIT:case this.OBLIQ:x/=this.dd;y*=this.dd;rho=Math.sqrt(x*x+y*y);if(rho<Proj4js.common.EPSLN){p.x=0.;p.y=this.phi0;return p;}
sCe=2.*Math.asin(.5*rho/this.rq);cCe=Math.cos(sCe);x*=(sCe=Math.sin(sCe));if(this.mode==this.OBLIQ){ab=cCe*this.sinb1+y*sCe*this.cosb1/rho
q=this.qp*ab;y=rho*this.cosb1*cCe-y*this.sinb1*sCe;}else{ab=y*sCe/rho;q=this.qp*ab;y=rho*cCe;}
break;case this.N_POLE:y=-y;case this.S_POLE:q=(x*x+y*y);if(!q){p.x=0.;p.y=this.phi0;return p;}
More information about the fusion-commits
