[fusion-commits] r2148 - sandbox/adsk/2.2gp/lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Apr 16 16:08:00 EDT 2010
Author: chrisclaydon
Date: 2010-04-16 16:08:00 -0400 (Fri, 16 Apr 2010)
New Revision: 2148
   sandbox/adsk/2.2gp/lib/proj4js-compressed.js
Re #392 - Warning 'towgs84' is null or not an object popup if the CS of the map is CA-I (NAD27 California State Planes, Zone I(401), US Foot)
Modified: sandbox/adsk/2.2gp/lib/proj4js-compressed.js
--- sandbox/adsk/2.2gp/lib/proj4js-compressed.js	2010-04-16 18:54:01 UTC (rev 2147)
+++ sandbox/adsk/2.2gp/lib/proj4js-compressed.js	2010-04-16 20:08:00 UTC (rev 2148)
@@ -39,7 +39,7 @@
 var url=Proj4js.getScriptLocation()+'defs/'+this.srsAuth.toUpperCase()+this.srsProjNumber+'.js';Proj4js.loadScript(url,Proj4js.bind(this.defsLoaded,this),Proj4js.bind(this.loadFromService,this),Proj4js.bind(this.checkDefsLoaded,this));},loadFromService:function(){var url=Proj4js.defsLookupService+'/'+this.srsAuth+'/'+this.srsProjNumber+'/proj4js/';Proj4js.loadScript(url,Proj4js.bind(this.defsLoaded,this),Proj4js.bind(this.defsFailed,this),Proj4js.bind(this.checkDefsLoaded,this));},defsLoaded:function(){this.parseDefs();this.loadProjCode(this.projName);},checkDefsLoaded:function(){if(Proj4js.defs[this.srsCode]){return true;}else{return false;}},defsFailed:function(){Proj4js.reportError('failed to load projection definition for: '+this.srsCode);Proj4js.defs[this.srsCode]=Proj4js.defs['WGS84'];this.defsLoaded();},loadProjCode:function(projName){if(Proj4js.Proj[projName]){this.initTransforms();return;}
 var url=Proj4js.getScriptLocation()+'projCode/'+projName+'.js';Proj4js.loadScript(url,Proj4js.bind(this.loadProjCodeSuccess,this,projName),Proj4js.bind(this.loadProjCodeFailure,this,projName),Proj4js.bind(this.checkCodeLoaded,this,projName));},loadProjCodeSuccess:function(projName){if(Proj4js.Proj[projName].dependsOn){this.loadProjCode(Proj4js.Proj[projName].dependsOn);}else{this.initTransforms();}},loadProjCodeFailure:function(projName){Proj4js.reportError("failed to find projection file for: "+projName);},checkCodeLoaded:function(projName){if(Proj4js.Proj[projName]){return true;}else{return false;}},initTransforms:function(){Proj4js.extend(this,Proj4js.Proj[this.projName]);this.init();this.readyToUse=true;},parseDefs:function(){this.defData=Proj4js.defs[this.srsCode];var paramName,paramVal;if(!this.defData){return;}
 var paramArray=this.defData.split("+");for(var prop=0;prop<paramArray.length;prop++){var property=paramArray[prop].split("=");paramName=property[0].toLowerCase();paramVal=property[1];switch(paramName.replace(/\s/gi,"")){case"":break;case"title":this.title=paramVal;break;case"proj":this.projName=paramVal.replace(/\s/gi,"");break;case"units":this.units=paramVal.replace(/\s/gi,"");break;case"datum":this.datumCode=paramVal.replace(/\s/gi,"");break;case"nadgrids":this.nagrids=paramVal.replace(/\s/gi,"");break;case"ellps":this.ellps=paramVal.replace(/\s/gi,"");break;case"a":this.a=parseFloat(paramVal);break;case"b":this.b=parseFloat(paramVal);break;case"rf":this.rf=parseFloat(paramVal);break;case"lat_0":this.lat0=paramVal*Proj4js.common.D2R;break;case"lat_1":this.lat1=paramVal*Proj4js.common.D2R;break;case"lat_2":this.lat2=paramVal*Proj4js.common.D2R;break;case"lat_ts":this.lat_ts=paramVal*Proj4js.common.D2R;break;case"lon_0":this.long0=paramVal*Proj4js.common.D2R;break;case"alpha":this.alpha=parseFloat(paramVal)*Proj4js.common.D2R;break;case"lonc":this.longc=paramVal*Proj4js.common.D2R;break;case"x_0":this.x0=parseFloat(paramVal);break;case"y_0":this.y0=parseFloat(paramVal);break;case"k_0":this.k0=parseFloat(paramVal);break;case"k":this.k0=parseFloat(paramVal);break;case"r_a":this.R_A=true;break;case"zone":this.zone=parseInt(paramVal);break;case"south":this.utmSouth=true;break;case"towgs84":this.datum_params=paramVal.split(",");break;case"to_meter":this.to_meter=parseFloat(paramVal);break;case"from_greenwich":this.from_greenwich=paramVal*Proj4js.common.D2R;break;case"pm":paramVal=paramVal.replace(/\s/gi,"");this.from_greenwich=Proj4js.PrimeMeridian[paramVal]?Proj4js.PrimeMeridian[paramVal]:parseFloat(paramVal);this.from_greenwich*=Proj4js.common.D2R;break;case"no_defs":break;default:}}
-this.deriveConstants();},deriveConstants:function(){if(this.nagrids=='@null')this.datumCode='none';if(this.datumCode&&this.datumCode!='none'){var datumDef=Proj4js.Datum[this.datumCode];if(datumDef){this.datum_params=datumDef.towgs84.split(',');this.ellps=datumDef.ellipse;this.datumName=datumDef.datumName?datumDef.datumName:this.datumCode;}}
+this.deriveConstants();},deriveConstants:function(){if(this.nagrids=='@null')this.datumCode='none';if(this.datumCode&&this.datumCode!='none'){var datumDef=Proj4js.Datum[this.datumCode];if(datumDef){this.datum_params=datumDef.towgs84?datumDef.towgs84.split(','):null;this.ellps=datumDef.ellipse;this.datumName=datumDef.datumName?datumDef.datumName:this.datumCode;}}
 if(!this.a){var ellipse=Proj4js.Ellipsoid[this.ellps]?Proj4js.Ellipsoid[this.ellps]:Proj4js.Ellipsoid['WGS84'];Proj4js.extend(this,ellipse);}
 if(this.rf&&!this.b)this.b=(1.0-1.0/this.rf)*this.a;if(Math.abs(this.a-this.b)<Proj4js.common.EPSLN){this.sphere=true;this.b=this.a;}
 this.a2=this.a*this.a;this.b2=this.b*this.b;this.es=(this.a2-this.b2)/this.a2;this.e=Math.sqrt(this.es);if(this.R_A){this.a*=1.-this.es*(Proj4js.common.SIXTH+this.es*(Proj4js.common.RA4+this.es*Proj4js.common.RA6));this.a2=this.a*this.a;this.b2=this.b*this.b;this.es=0.;}
More information about the fusion-commits mailing list
