[fusion-commits] r2199 - in trunk: layers/MapGuide lib widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Aug 11 14:51:20 EDT 2010
Author: madair
Date: 2010-08-11 18:51:20 +0000 (Wed, 11 Aug 2010)
New Revision: 2199
Added:
   trunk/lib/proj4js-combined.js
   trunk/layers/MapGuide/MapGuide.js
   trunk/lib/Map.js
   trunk/lib/proj4js-compressed.js
   trunk/widgets/Measure.js
closes #395: uses the new WKT parsing capabilities in Proj4js to determine MapGuide projection definitions
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js	2010-08-10 19:38:28 UTC (rev 2198)
+++ trunk/layers/MapGuide/MapGuide.js	2010-08-11 18:51:20 UTC (rev 2199)
@@ -301,19 +301,15 @@
             //set projection units and code if supplied
+            var wktProj;
             if (o.epsg != 0) {
               this.mapTag.layerOptions.projection = "EPSG:" + o.epsg;
             } else {
+              //default to the local non-projected system if not otherwise specified
               if (!o.wkt || o.wkt.length == 0){
                 o.wkt = "LOCAL_CS[\"Non-Earth (Meter)\",LOCAL_DATUM[\"Local Datum\",0],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
-              var wkt = o.wkt;
-              var wktContentRE = /(\w+)\[(.*)\]/;
-              var wktContent = wkt.match(wktContentRE);
-              var wktName = wktContent[2].split(",")[0];
-              wktName = wktName.toUpperCase();
-              this.mapTag.layerOptions.projection = wktName;
-              Proj4js.defs[wktName] = "+proj=identity +"+wkt;
+              wktProj = new OpenLayers.Projection(o.wkt);
             //TODO: consider passing the metersPerUnit value into the framework
             //to allow for scaling that doesn't match any of the pre-canned units
@@ -335,6 +331,9 @@
             this.oLayerOL = this.createOLLayer(this._sMapname, this.bSingleTile,2,false);
+            if (wktProj) {
+              this.oLayerOL.projection = wktProj;
             this.oLayerOL.events.register("loadstart", this, this.loadStart);
             this.oLayerOL.events.register("loadend", this, this.loadEnd);
             this.oLayerOL.events.register("loadcancel", this, this.loadEnd);
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js	2010-08-10 19:38:28 UTC (rev 2198)
+++ trunk/lib/Map.js	2010-08-11 18:51:20 UTC (rev 2199)
@@ -533,10 +533,10 @@
         this.oMapOL.addLayer(map.oLayerOL);
         if (map.oLayerOL.isBaseLayer) {
-          this.projection = map.projection;
-          this.units = map.units;
+          this.projection = this.oMapOL.baseLayer.projection;
+          this.units = this.oMapOL.baseLayer.units;
           this.oMapOL.setOptions({
-                  units: map.units,
+                  units: this.units,
                   projection: this.projection
Added: trunk/lib/proj4js-combined.js
--- trunk/lib/proj4js-combined.js	                        (rev 0)
+++ trunk/lib/proj4js-combined.js	2010-08-11 18:51:20 UTC (rev 2199)
@@ -0,0 +1,5142 @@
+  proj4js.js -- Javascript reprojection library.
+  Authors:      Mike Adair madairATdmsolutions.ca
+                Richard Greenwood richATgreenwoodmap.com
+                Didier Richard didier.richardATign.fr
+                Stephen Irons
+  License:      LGPL as per: http://www.gnu.org/copyleft/lesser.html
+                Note: This program is an almost direct port of the C library
+                Proj4.
+    proj4js.js
+Author:       Mike Adair madairATdmsolutions.ca
+              Richard Greenwood rich at greenwoodmap.com
+License:      LGPL as per: http://www.gnu.org/copyleft/lesser.html
+$Id: Proj.js 2956 2007-07-09 12:17:52Z steven $
+ * Namespace: Proj4js
+ * Proj4js is a JavaScript library to transform point coordinates from one
+ * coordinate system to another, including datum transformations.
+ * This library is a port of both the Proj.4 and GCTCP C libraries to JavaScript.
+ * Enabling these transformations in the browser allows geographic data stored
+ * in different projections to be combined in browser-based web mapping
+ * applications.
+ * Proj4js must have access to coordinate system initialization strings (which
+ * are the same as for PROJ.4 command line).  Thes can be included in your
+ * application using a <script> tag or Proj4js can load CS initialization
+ * strings from a local directory or a web service such as spatialreference.org.
+ * Similarly, Proj4js must have access to projection transform code.  These can
+ * be included individually using a <script> tag in your page, built into a
+ * custom build of Proj4js or loaded dynamically at run-time.  Using the
+ * -combined and -compressed versions of Proj4js includes all projection class
+ * code by default.
+ * Note that dynamic loading of defs and code happens ascynchrously, check the
+ * Proj.readyToUse flag before using the Proj object.  If the defs and code
+ * required by your application are loaded through script tags, dynamic loading
+ * is not required and the Proj object will be readyToUse on return from the
+ * constructor.
+ * All coordinates are handled as points which have a .x and a .y property
+ * which will be modified in place.
+ * Override Proj4js.reportError for output of alerts and warnings.
+ * See http://trac.osgeo.org/proj4js/wiki/UserGuide for full details.
+ * Global namespace object for Proj4js library
+Proj4js = {
+     * Property: defaultDatum
+     * The datum to use when no others a specified
+    defaultDatum: 'WGS84',                  //default datum
+    * Method: transform(source, dest, point)
+    * Transform a point coordinate from one map projection to another.  This is
+    * really the only public method you should need to use.
+    * Parameters:
+    * source - {Proj4js.Proj} source map projection for the transformation
+    * dest - {Proj4js.Proj} destination map projection for the transformation
+    * point - {Object} point to transform, may be geodetic (long, lat) or
+    *     projected Cartesian (x,y), but should always have x,y properties.
+    transform: function(source, dest, point) {
+        if (!source.readyToUse) {
+            this.reportError("Proj4js initialization for:"+source.srsCode+" not yet complete");
+            return point;
+        if (!dest.readyToUse) {
+            this.reportError("Proj4js initialization for:"+dest.srsCode+" not yet complete");
+            return point;
+        // Workaround for Spherical Mercator
+        if ((source.srsProjNumber =="900913" && dest.datumCode != "WGS84") ||
+            (dest.srsProjNumber == "900913" && source.datumCode != "WGS84")) {
+            var wgs84 = Proj4js.WGS84;
+            this.transform(source, wgs84, point);
+            source = wgs84;
+        // Transform source points to long/lat, if they aren't already.
+        if ( source.projName=="longlat") {
+            point.x *= Proj4js.common.D2R;  // convert degrees to radians
+            point.y *= Proj4js.common.D2R;
+        } else {
+            if (source.to_meter) {
+                point.x *= source.to_meter;
+                point.y *= source.to_meter;
+            source.inverse(point); // Convert Cartesian to longlat
+        // Adjust for the prime meridian if necessary
+        if (source.from_greenwich) {
+            point.x += source.from_greenwich;
+        // Convert datums if needed, and if possible.
+        point = this.datum_transform( source.datum, dest.datum, point );
+        if (dest.from_greenwich) {
+            point.x -= dest.from_greenwich;
+        if( dest.projName=="longlat" ) {
+            // convert radians to decimal degrees
+            point.x *= Proj4js.common.R2D;
+            point.y *= Proj4js.common.R2D;
+        } else  {               // else project
+            dest.forward(point);
+            if (dest.to_meter) {
+                point.x /= dest.to_meter;
+                point.y /= dest.to_meter;
+        return point;
+    }, // transform()
+    /** datum_transform()
+      source coordinate system definition,
+      destination coordinate system definition,
+      point to transform in geodetic coordinates (long, lat, height)
+    datum_transform : function( source, dest, point ) {
+      // Short cut if the datums are identical.
+      if( source.compare_datums( dest ) ) {
+          return point; // in this case, zero is sucess,
+                    // whereas cs_compare_datums returns 1 to indicate TRUE
+                    // confusing, should fix this
+      // Explicitly skip datum transform by setting 'datum=none' as parameter for either source or dest
+      if( source.datum_type == Proj4js.common.PJD_NODATUM
+          || dest.datum_type == Proj4js.common.PJD_NODATUM) {
+          return point;
+      // If this datum requires grid shifts, then apply it to geodetic coordinates.
+      if( source.datum_type == Proj4js.common.PJD_GRIDSHIFT )
+        alert("ERROR: Grid shift transformations are not implemented yet.");
+          pj_apply_gridshift( pj_param(source.params,"snadgrids").s, 0,
+                              point_count, point_offset, x, y, z );
+          CHECK_RETURN;
+          src_a = SRS_WGS84_SEMIMAJOR;
+          src_es = 0.006694379990;
+      if( dest.datum_type == Proj4js.common.PJD_GRIDSHIFT )
+          dst_a = ;
+          dst_es = 0.006694379990;
+      // Do we need to go through geocentric coordinates?
+      if( source.es != dest.es || source.a != dest.a
+          || source.datum_type == Proj4js.common.PJD_3PARAM
+          || source.datum_type == Proj4js.common.PJD_7PARAM
+          || dest.datum_type == Proj4js.common.PJD_3PARAM
+          || dest.datum_type == Proj4js.common.PJD_7PARAM)
+        // Convert to geocentric coordinates.
+        source.geodetic_to_geocentric( point );
+        // CHECK_RETURN;
+        // Convert between datums
+        if( source.datum_type == Proj4js.common.PJD_3PARAM || source.datum_type == Proj4js.common.PJD_7PARAM ) {
+          source.geocentric_to_wgs84(point);
+          // CHECK_RETURN;
+        if( dest.datum_type == Proj4js.common.PJD_3PARAM || dest.datum_type == Proj4js.common.PJD_7PARAM ) {
+          dest.geocentric_from_wgs84(point);
+          // CHECK_RETURN;
+        // Convert back to geodetic coordinates
+        dest.geocentric_to_geodetic( point );
+          // CHECK_RETURN;
+      // Apply grid shift to destination if required
+        // pj_apply_gridshift( pj_param(dest.params,"snadgrids").s, 1, point);
+        // CHECK_RETURN;
+      return point;
+    }, // cs_datum_transform
+     * Function: reportError
+     * An internal method to report errors back to user.
+     * Override this in applications to report error messages or throw exceptions.
+    reportError: function(msg) {
+      //console.log(msg);
+ * Title: Private Methods
+ * The following properties and methods are intended for internal use only.
+ * This is a minimal implementation of JavaScript inheritance methods so that
+ * Proj4js can be used as a stand-alone library.
+ * These are copies of the equivalent OpenLayers methods at v2.7
+ * Function: extend
+ * Copy all properties of a source object to a destination object.  Modifies
+ *     the passed in destination object.  Any properties on the source object
+ *     that are set to undefined will not be (re)set on the destination object.
+ * Parameters:
+ * destination - {Object} The object that will be modified
+ * source - {Object} The object with properties to be set on the destination
+ * Returns:
+ * {Object} The destination object.
+    extend: function(destination, source) {
+      destination = destination || {};
+      if(source) {
+          for(var property in source) {
+              var value = source[property];
+              if(value !== undefined) {
+                  destination[property] = value;
+      return destination;
+ * Constructor: Class
+ * Base class used to construct all other classes. Includes support for
+ *     multiple inheritance.
+    Class: function() {
+      var Class = function() {
+          this.initialize.apply(this, arguments);
+      var extended = {};
+      var parent;
+      for(var i=0; i<arguments.length; ++i) {
+          if(typeof arguments[i] == "function") {
+              // get the prototype of the superclass
+              parent = arguments[i].prototype;
+          } else {
+              // in this case we're extending with the prototype
+              parent = arguments[i];
+          Proj4js.extend(extended, parent);
+      Class.prototype = extended;
+      return Class;
+     * Function: bind
+     * Bind a function to an object.  Method to easily create closures with
+     *     'this' altered.
+     * Parameters:
+     * func - {Function} Input function.
+     * object - {Object} The object to bind to the input function (as this).
+     * Returns:
+     * {Function} A closure with 'this' set to the passed in object.
+    bind: function(func, object) {
+        // create a reference to all arguments past the second one
+        var args = Array.prototype.slice.apply(arguments, [2]);
+        return function() {
+            // Push on any additional arguments from the actual function call.
+            // These will come after those sent to the bind call.
+            var newArgs = args.concat(
+                Array.prototype.slice.apply(arguments, [0])
+            return func.apply(object, newArgs);
+ * The following properties and methods handle dynamic loading of JSON objects.
+     * Property: scriptName
+     * {String} The filename of this script without any path.
+    scriptName: "proj4js-combined.js",
+     * Property: defsLookupService
+     * AJAX service to retreive projection definition parameters from
+    defsLookupService: 'http://spatialreference.org/ref',
+     * Property: libPath
+     * internal: http server path to library code.
+    libPath: null,
+     * Function: getScriptLocation
+     * Return the path to this script.
+     * Returns:
+     * Path to this script
+    getScriptLocation: function () {
+        if (this.libPath) return this.libPath;
+        var scriptName = this.scriptName;
+        var scriptNameLen = scriptName.length;
+        var scripts = document.getElementsByTagName('script');
+        for (var i = 0; i < scripts.length; i++) {
+            var src = scripts[i].getAttribute('src');
+            if (src) {
+                var index = src.lastIndexOf(scriptName);
+                // is it found, at the end of the URL?
+                if ((index > -1) && (index + scriptNameLen == src.length)) {
+                    this.libPath = src.slice(0, -scriptNameLen);
+                    break;
+        return this.libPath||"";
+     * Function: loadScript
+     * Load a JS file from a URL into a <script> tag in the page.
+     * Parameters:
+     * url - {String} The URL containing the script to load
+     * onload - {Function} A method to be executed when the script loads successfully
+     * onfail - {Function} A method to be executed when there is an error loading the script
+     * loadCheck - {Function} A boolean method that checks to see if the script
+     *            has loaded.  Typically this just checks for the existance of
+     *            an object in the file just loaded.
+    loadScript: function(url, onload, onfail, loadCheck) {
+      var script = document.createElement('script');
+      script.defer = false;
+      script.type = "text/javascript";
+      script.id = url;
+      script.src = url;
+      script.onload = onload;
+      script.onerror = onfail;
+      script.loadCheck = loadCheck;
+      if (/MSIE/.test(navigator.userAgent)) {
+        script.onreadystatechange = this.checkReadyState;
+      document.getElementsByTagName('head')[0].appendChild(script);
+     * Function: checkReadyState
+     * IE workaround since there is no onerror handler.  Calls the user defined
+     * loadCheck method to determine if the script is loaded.
+    checkReadyState: function() {
+      if (this.readyState == 'loaded') {
+        if (!this.loadCheck()) {
+          this.onerror();
+        } else {
+          this.onload();
+ * Class: Proj4js.Proj
+ * Proj objects provide transformation methods for point coordinates
+ * between geodetic latitude/longitude and a projected coordinate system.
+ * once they have been initialized with a projection code.
+ * Initialization of Proj objects is with a projection code, usually EPSG codes,
+ * which is the key that will be used with the Proj4js.defs array.
+ * The code passed in will be stripped of colons and converted to uppercase
+ * to locate projection definition files.
+ * A projection object has properties for units and title strings.
+Proj4js.Proj = Proj4js.Class({
+   * Property: readyToUse
+   * Flag to indicate if initialization is complete for this Proj object
+  readyToUse: false,
+   * Property: title
+   * The title to describe the projection
+  title: null,
+   * Property: projName
+   * The projection class for this projection, e.g. lcc (lambert conformal conic,
+   * or merc for mercator).  These are exactly equivalent to their Proj4
+   * counterparts.
+  projName: null,
+   * Property: units
+   * The units of the projection.  Values include 'm' and 'degrees'
+  units: null,
+   * Property: datum
+   * The datum specified for the projection
+  datum: null,
+   * Property: x0
+   * The x coordinate origin
+  x0: 0,
+   * Property: y0
+   * The y coordinate origin
+  y0: 0,
+   * Property: localCS
+   * Flag to indicate if the projection is a local one in which no transforms
+   * are required.
+  localCS: false,
+   * Constructor: initialize
+   * Constructor for Proj4js.Proj objects
+  * Parameters:
+  * srsCode - a code for map projection definition parameters.  These are usually
+  * (but not always) EPSG codes.
+  initialize: function(srsCode) {
+      this.srsCodeInput = srsCode;
+      //check to see if this is a WKT string
+      if ((srsCode.indexOf('GEOGCS') >= 0) ||
+          (srsCode.indexOf('GEOCCS') >= 0) ||
+          (srsCode.indexOf('PROJCS') >= 0) ||
+          (srsCode.indexOf('LOCAL_CS') >= 0)) {
+            this.parseWKT(srsCode);
+            this.datum = new Proj4js.datum(this);
+            this.loadProjCode(this.projName);
+            return;
+      // DGR 2008-08-03 : support urn and url
+      if (srsCode.indexOf('urn:') == 0) {
+          //urn:ORIGINATOR:def:crs:CODESPACE:VERSION:ID
+          var urn = srsCode.split(':');
+          if ((urn[1] == 'ogc' || urn[1] =='x-ogc') &&
+              (urn[2] =='def') &&
+              (urn[3] =='crs')) {
+              srsCode = urn[4]+':'+urn[urn.length-1];
+      } else if (srsCode.indexOf('http://') == 0) {
+          //url#ID
+          var url = srsCode.split('#');
+          if (url[0].match(/epsg.org/)) {
+            // http://www.epsg.org/#
+            srsCode = 'EPSG:'+url[1];
+          } else if (url[0].match(/RIG.xml/)) {
+            //http://librairies.ign.fr/geoportail/resources/RIG.xml#
+            //http://interop.ign.fr/registers/ign/RIG.xml#
+            srsCode = 'IGNF:'+url[1];
+      this.srsCode = srsCode.toUpperCase();
+      if (this.srsCode.indexOf("EPSG") == 0) {
+          this.srsCode = this.srsCode;
+          this.srsAuth = 'epsg';
+          this.srsProjNumber = this.srsCode.substring(5);
+      // DGR 2007-11-20 : authority IGNF
+      } else if (this.srsCode.indexOf("IGNF") == 0) {
+          this.srsAuth = 'IGNF';
+      // DGR 2008-06-19 : pseudo-authority CRS for WMS
+      } else if (this.srsCode.indexOf("CRS") == 0) {
+          this.srsAuth = 'CRS';
+          this.srsProjNumber = this.srsCode.substring(4);
+      } else {
+          this.srsAuth = '';
+          this.srsProjNumber = this.srsCode;
+      this.loadProjDefinition();
+ * Function: loadProjDefinition
+ *    Loads the coordinate system initialization string if required.
+ *    Note that dynamic loading happens asynchronously so an application must
+ *    wait for the readyToUse property is set to true.
+ *    To prevent dynamic loading, include the defs through a script tag in
+ *    your application.
+    loadProjDefinition: function() {
+      //check in memory
+      if (Proj4js.defs[this.srsCode]) {
+        this.defsLoaded();
+        return;
+      //else check for def on the server
+      var url = Proj4js.getScriptLocation() + 'defs/' + this.srsAuth.toUpperCase() + this.srsProjNumber + '.js';
+      Proj4js.loadScript(url,
+                Proj4js.bind(this.defsLoaded, this),
+                Proj4js.bind(this.loadFromService, this),
+                Proj4js.bind(this.checkDefsLoaded, this) );
+ * Function: loadFromService
+ *    Creates the REST URL for loading the definition from a web service and
+ *    loads it.
+    loadFromService: function() {
+      //else load from web service
+      var url = Proj4js.defsLookupService +'/' + this.srsAuth +'/'+ this.srsProjNumber + '/proj4js/';
+            Proj4js.bind(this.defsFailed, this),
+ * Function: defsLoaded
+ * Continues the Proj object initilization once the def file is loaded
+    defsLoaded: function() {
+      this.parseDefs();
+ * Function: checkDefsLoaded
+ *    This is the loadCheck method to see if the def object exists
+    checkDefsLoaded: function() {
+        return true;
+      } else {
+        return false;
+ * Function: defsFailed
+ *    Report an error in loading the defs file, but continue on using WGS84
+   defsFailed: function() {
+      Proj4js.reportError('failed to load projection definition for: '+this.srsCode);
+      Proj4js.defs[this.srsCode] = Proj4js.defs['WGS84'];  //set it to something so it can at least continue
+ * Function: loadProjCode
+ *    Loads projection class code dynamically if required.
+ *     Projection code may be included either through a script tag or in
+ *     a built version of proj4js
+    loadProjCode: function(projName) {
+      if (Proj4js.Proj[projName]) {
+        this.initTransforms();
+        return;
+      //the URL for the projection code
+      var url = Proj4js.getScriptLocation() + 'projCode/' + projName + '.js';
+              Proj4js.bind(this.loadProjCodeSuccess, this, projName),
+              Proj4js.bind(this.loadProjCodeFailure, this, projName),
+              Proj4js.bind(this.checkCodeLoaded, this, projName) );
+ * Function: loadProjCodeSuccess
+ *    Loads any proj dependencies or continue on to final initialization.
+    loadProjCodeSuccess: function(projName) {
+      if (Proj4js.Proj[projName].dependsOn){
+        this.loadProjCode(Proj4js.Proj[projName].dependsOn);
+      } else {
+ *    Report an error in loading the proj file.  Initialization of the Proj
+ *    object has failed and the readyToUse flag will never be set.
+    loadProjCodeFailure: function(projName) {
+      Proj4js.reportError("failed to find projection file for: " + projName);
+      //TBD initialize with identity transforms so proj will still work?
+ * Function: checkCodeLoaded
+ *    This is the loadCheck method to see if the projection code is loaded
+    checkCodeLoaded: function(projName) {
+        return true;
+      } else {
+        return false;
+ * Function: initTransforms
+ *    Finalize the initialization of the Proj object
+    initTransforms: function() {
+      Proj4js.extend(this, Proj4js.Proj[this.projName]);
+      this.init();
+      this.readyToUse = true;
+ * Function: parseWKT
+ * Parses a WKT string to get initialization parameters
+ wktRE: /^(\w+)\[(.*)\]$/,
+ parseWKT: function(wkt) {
+    var wktMatch = wkt.match(this.wktRE);
+    if (!wktMatch) return;
+    var wktObject = wktMatch[1];
+    var wktContent = wktMatch[2];
+    var wktTemp = wktContent.split(",");
+    var wktName = wktTemp.shift();
+    wktName = wktName.replace(/^\"/,"");
+    wktName = wktName.replace(/\"$/,"");
+    wktContent = wktTemp.join(",");
+    var wktArray = wktContent.split("],");
+    for (var i=0; i<wktArray.length-1; ++i) {
+      wktArray[i] += "]";
+    var wktArray = new Array();
+    var bkCount = 0;
+    var obj = "";
+    for (var i=0; i<wktTemp.length; ++i) {
+      var token = wktTemp[i];
+      for (var j=0; j<token.length; ++j) {
+        if (token.charAt(j) == "[") ++bkCount;
+        if (token.charAt(j) == "]") --bkCount;
+      obj += token;
+      if (bkCount === 0) {
+        wktArray.push(obj);
+        obj = "";
+      } else {
+        obj += ",";
+    //do something based on the type of the wktObject being parsed
+    //add in variations in the spelling as required
+    switch (wktObject) {
+      case 'LOCAL_CS':
+        this.projName = 'identity'
+        this.localCS = true;
+        this.srsCode = wktName;
+        break;
+      case 'GEOGCS':
+        this.projName = 'longlat'
+        this.geocsCode = wktName;
+        if (!this.srsCode) this.srsCode = wktName;
+        break;
+      case 'PROJCS':
+        break;
+      case 'GEOCCS':
+        break;
+      case 'PROJECTION':
+        this.projName = Proj4js.wktProjections[wktName]
+        break;
+      case 'DATUM':
+        this.datumName = wktName;
+        break;
+      case 'LOCAL_DATUM':
+        this.datumCode = 'none';
+        break;
+      case 'SPHEROID':
+        this.ellps = wktName;
+        this.a = parseFloat(wktArray.shift());
+        this.rf = parseFloat(wktArray.shift());
+        break;
+      case 'PRIMEM':
+        this.from_greenwich = parseFloat(wktArray.shift()); //to radians?
+        break;
+      case 'UNIT':
+        this.units = wktName;
+        this.unitsPerMeter = parseFloat(wktArray.shift());
+        break;
+      case 'PARAMETER':
+        var name = wktName;
+        var value = parseFloat(parseFloat(wktArray.shift()));
+        //there amy be many variations on the wktName values, add in case
+        //statements as required
+        switch (name) {
+          case 'false_easting':
+            this.x0 = value;
+            break;
+          case 'false_northing':
+            this.y0 = value;
+            break;
+          case 'scale_factor':
+            this.k0 = value;
+            break;
+          case 'central_meridian':
+            this.long0 = value;
+            break;
+          case 'latitude_of_origin':
+            this.lat0 = value;
+            break;
+          case 'more_here':
+            break;
+          default:
+            break;
+        break;
+      case 'TOWGS84':
+        this.datum_params = wktArray;
+        break;
+      case 'MORE_HERE':
+        break;
+      default:
+        break;
+    for (var i=0; i<wktArray.length; ++i) {
+      this.parseWKT(wktArray[i]);
+ * Function: parseDefs
+ * Parses the PROJ.4 initialization string and sets the associated properties.
+  parseDefs: function() {
+      this.defData = Proj4js.defs[this.srsCode];
+      var paramName, paramVal;
+      if (!this.defData) {
+        return;
+      var paramArray=this.defData.split("+");
+      for (var prop=0; prop<paramArray.length; prop++) {
+          var property = paramArray[prop].split("=");
+          paramName = property[0].toLowerCase();
+          paramVal = property[1];
+          switch (paramName.replace(/\s/gi,"")) {  // trim out spaces
+              case "": break;   // throw away nameless parameter
+              case "title":  this.title = paramVal; break;
+              case "proj":   this.projName =  paramVal.replace(/\s/gi,""); break;
+              case "units":  this.units = paramVal.replace(/\s/gi,""); break;
+              case "datum":  this.datumCode = paramVal.replace(/\s/gi,""); break;
+              case "nadgrids": this.nagrids = paramVal.replace(/\s/gi,""); break;
+              case "ellps":  this.ellps = paramVal.replace(/\s/gi,""); break;
+              case "a":      this.a =  parseFloat(paramVal); break;  // semi-major radius
+              case "b":      this.b =  parseFloat(paramVal); break;  // semi-minor radius
+              // DGR 2007-11-20
+              case "rf":     this.rf = parseFloat(paramVal); break; // inverse flattening rf= a/(a-b)
+              case "lat_0":  this.lat0 = paramVal*Proj4js.common.D2R; break;        // phi0, central latitude
+              case "lat_1":  this.lat1 = paramVal*Proj4js.common.D2R; break;        //standard parallel 1
+              case "lat_2":  this.lat2 = paramVal*Proj4js.common.D2R; break;        //standard parallel 2
+              case "lat_ts": this.lat_ts = paramVal*Proj4js.common.D2R; break;      // used in merc and eqc
+              case "lon_0":  this.long0 = paramVal*Proj4js.common.D2R; break;       // lam0, central longitude
+              case "alpha":  this.alpha =  parseFloat(paramVal)*Proj4js.common.D2R; break;  //for somerc projection
+              case "lonc":   this.longc = paramVal*Proj4js.common.D2R; break;       //for somerc projection
+              case "x_0":    this.x0 = parseFloat(paramVal); break;  // false easting
+              case "y_0":    this.y0 = parseFloat(paramVal); break;  // false northing
+              case "k_0":    this.k0 = parseFloat(paramVal); break;  // projection scale factor
+              case "k":      this.k0 = parseFloat(paramVal); break;  // both forms returned
+              case "r_a":    this.R_A = true; break;                 // sphere--area of ellipsoid
+              case "zone":   this.zone = parseInt(paramVal); break;  // UTM Zone
+              case "south":   this.utmSouth = true; break;  // UTM north/south
+              case "towgs84":this.datum_params = paramVal.split(","); break;
+              case "to_meter": this.to_meter = parseFloat(paramVal); break; // cartesian scaling
+              case "from_greenwich": this.from_greenwich = paramVal*Proj4js.common.D2R; break;
+              // DGR 2008-07-09 : if pm is not a well-known prime meridian take
+              // the value instead of 0.0, then convert to radians
+              case "pm":     paramVal = paramVal.replace(/\s/gi,"");
+                             this.from_greenwich = Proj4js.PrimeMeridian[paramVal] ?
+                                Proj4js.PrimeMeridian[paramVal] : parseFloat(paramVal);
+                             this.from_greenwich *= Proj4js.common.D2R;
+                             break;
+              case "no_defs": break;
+              default: //alert("Unrecognized parameter: " + paramName);
+          } // switch()
+      } // for paramArray
+      this.deriveConstants();
+ * Function: deriveConstants
+ * Sets several derived constant values and initialization of datum and ellipse
+ *     parameters.
+  deriveConstants: function() {
+      if (this.nagrids == '@null') this.datumCode = 'none';
+      if (this.datumCode && this.datumCode != 'none') {
+        var datumDef = Proj4js.Datum[this.datumCode];
+        if (datumDef) {
+          this.datum_params = datumDef.towgs84 ? datumDef.towgs84.split(',') : null;
+          this.ellps = datumDef.ellipse;
+          this.datumName = datumDef.datumName ? datumDef.datumName : this.datumCode;
+      if (!this.a) {    // do we have an ellipsoid?
+          var ellipse = Proj4js.Ellipsoid[this.ellps] ? Proj4js.Ellipsoid[this.ellps] : Proj4js.Ellipsoid['WGS84'];
+          Proj4js.extend(this, ellipse);
+      if (this.rf && !this.b) this.b = (1.0 - 1.0/this.rf) * this.a;
+      if (Math.abs(this.a - this.b)<Proj4js.common.EPSLN) {
+        this.sphere = true;
+        this.b= this.a;
+      this.a2 = this.a * this.a;          // used in geocentric
+      this.b2 = this.b * this.b;          // used in geocentric
+      this.es = (this.a2-this.b2)/this.a2;  // e ^ 2
+      this.e = Math.sqrt(this.es);        // eccentricity
+      if (this.R_A) {
+        this.a *= 1. - this.es * (Proj4js.common.SIXTH + this.es * (Proj4js.common.RA4 + this.es * Proj4js.common.RA6));
+        this.es = 0.;
+      this.ep2=(this.a2-this.b2)/this.b2; // used in geocentric
+      if (!this.k0) this.k0 = 1.0;    //default value
+Proj4js.Proj.longlat = {
+  init: function() {
+    //no-op for longlat
+  forward: function(pt) {
+    //identity transform
+    return pt;
+  inverse: function(pt) {
+    return pt;
+Proj4js.Proj.identity = Proj4js.Proj.longlat;
+  Proj4js.defs is a collection of coordinate system definition objects in the
+  PROJ.4 command line format.
+  Generally a def is added by means of a separate .js file for example:
+    <SCRIPT type="text/javascript" src="defs/EPSG26912.js"></SCRIPT>
+  def is a CS definition in PROJ.4 WKT format, for example:
+    +proj="tmerc"   //longlat, etc.
+    +a=majorRadius
+    +b=minorRadius
+    +lat0=somenumber
+    +long=somenumber
+Proj4js.defs = {
+  // These are so widely used, we'll go ahead and throw them in
+  // without requiring a separate .js file
+  'WGS84': "+title=long/lat:WGS84 +proj=longlat +ellps=WGS84 +datum=WGS84 +units=degrees",
+  'EPSG:4326': "+title=long/lat:WGS84 +proj=longlat +a=6378137.0 +b=6356752.31424518 +ellps=WGS84 +datum=WGS84 +units=degrees",
+  'EPSG:4269': "+title=long/lat:NAD83 +proj=longlat +a=6378137.0 +b=6356752.31414036 +ellps=GRS80 +datum=NAD83 +units=degrees",
+  'EPSG:3785': "+title= Google Mercator +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs"
+Proj4js.defs['GOOGLE'] = Proj4js.defs['EPSG:3785'];
+Proj4js.defs['EPSG:900913'] = Proj4js.defs['EPSG:3785'];
+Proj4js.defs['EPSG:102113'] = Proj4js.defs['EPSG:3785'];
+Proj4js.common = {
+  PI : 3.141592653589793238, //Math.PI,
+  HALF_PI : 1.570796326794896619, //Math.PI*0.5,
+  TWO_PI : 6.283185307179586477, //Math.PI*2,
+  FORTPI : 0.78539816339744833,
+  R2D : 57.29577951308232088,
+  D2R : 0.01745329251994329577,
+  SEC_TO_RAD : 4.84813681109535993589914102357e-6, /* SEC_TO_RAD = Pi/180/3600 */
+  EPSLN : 1.0e-10,
+  MAX_ITER : 20,
+  // following constants from geocent.c
+  COS_67P5 : 0.38268343236508977,  /* cosine of 67.5 degrees */
+  AD_C : 1.0026000,                /* Toms region 1 constant */
+  /* datum_type values */
+  PJD_UNKNOWN  : 0,
+  PJD_3PARAM   : 1,
+  PJD_7PARAM   : 2,
+  PJD_GRIDSHIFT: 3,
+  PJD_WGS84    : 4,   // WGS84 or equivalent
+  PJD_NODATUM  : 5,   // WGS84 or equivalent
+  SRS_WGS84_SEMIMAJOR : 6378137.0,  // only used in grid shift transforms
+  // ellipoid pj_set_ell.c
+  SIXTH : .1666666666666666667, /* 1/6 */
+  RA4   : .04722222222222222222, /* 17/360 */
+  RA6   : .02215608465608465608, /* 67/3024 */
+  RV4   : .06944444444444444444, /* 5/72 */
+  RV6   : .04243827160493827160, /* 55/1296 */
+// Function to compute the constant small m which is the radius of
+//   a parallel of latitude, phi, divided by the semimajor axis.
+  msfnz : function(eccent, sinphi, cosphi) {
+      var con = eccent * sinphi;
+      return cosphi/(Math.sqrt(1.0 - con * con));
+// Function to compute the constant small t for use in the forward
+//   computations in the Lambert Conformal Conic and the Polar
+//   Stereographic projections.
+  tsfnz : function(eccent, phi, sinphi) {
+    var com = .5 * eccent;
+    con = Math.pow(((1.0 - con) / (1.0 + con)), com);
+    return (Math.tan(.5 * (this.HALF_PI - phi))/con);
+// Function to compute the latitude angle, phi2, for the inverse of the
+//   Lambert Conformal Conic and Polar Stereographic projections.
+  phi2z : function(eccent, ts) {
+    var eccnth = .5 * eccent;
+    var con, dphi;
+    var phi = this.HALF_PI - 2 * Math.atan(ts);
+    for (var i = 0; i <= 15; i++) {
+      con = eccent * Math.sin(phi);
+      dphi = this.HALF_PI - 2 * Math.atan(ts *(Math.pow(((1.0 - con)/(1.0 + con)),eccnth))) - phi;
+      phi += dphi;
+      if (Math.abs(dphi) <= .0000000001) return phi;
+    alert("phi2z has NoConvergence");
+    return (-9999);
+/* Function to compute constant small q which is the radius of a
+   parallel of latitude, phi, divided by the semimajor axis.
+  qsfnz : function(eccent,sinphi) {
+    var con;
+    if (eccent > 1.0e-7) {
+      con = eccent * sinphi;
+      return (( 1.0- eccent * eccent) * (sinphi /(1.0 - con * con) - (.5/eccent)*Math.log((1.0 - con)/(1.0 + con))));
+    } else {
+      return(2.0 * sinphi);
+/* Function to eliminate roundoff errors in asin
+  asinz : function(x) {
+    if (Math.abs(x)>1.0) {
+      x=(x>1.0)?1.0:-1.0;
+    return Math.asin(x);
+// following functions from gctpc cproj.c for transverse mercator projections
+  e0fn : function(x) {return(1.0-0.25*x*(1.0+x/16.0*(3.0+1.25*x)));},
+  e1fn : function(x) {return(0.375*x*(1.0+0.25*x*(1.0+0.46875*x)));},
+  e2fn : function(x) {return(0.05859375*x*x*(1.0+0.75*x));},
+  e3fn : function(x) {return(x*x*x*(35.0/3072.0));},
+  mlfn : function(e0,e1,e2,e3,phi) {return(e0*phi-e1*Math.sin(2.0*phi)+e2*Math.sin(4.0*phi)-e3*Math.sin(6.0*phi));},
+  srat : function(esinp, exp) {
+    return(Math.pow((1.0-esinp)/(1.0+esinp), exp));
+// Function to return the sign of an argument
+  sign : function(x) { if (x < 0.0) return(-1); else return(1);},
+// Function to adjust longitude to -180 to 180; input in radians
+  adjust_lon : function(x) {
+    x = (Math.abs(x) < this.PI) ? x: (x - (this.sign(x)*this.TWO_PI) );
+    return x;
+// IGNF - DGR : algorithms used by IGN France
+// Function to adjust latitude to -90 to 90; input in radians
+  adjust_lat : function(x) {
+    x= (Math.abs(x) < this.HALF_PI) ? x: (x - (this.sign(x)*this.PI) );
+    return x;
+// Latitude Isometrique - close to tsfnz ...
+  latiso : function(eccent, phi, sinphi) {
+    if (Math.abs(phi) > this.HALF_PI) return +Number.NaN;
+    if (phi==this.HALF_PI) return Number.POSITIVE_INFINITY;
+    if (phi==-1.0*this.HALF_PI) return -1.0*Number.POSITIVE_INFINITY;
+    var con= eccent*sinphi;
+    return Math.log(Math.tan((this.HALF_PI+phi)/2.0))+eccent*Math.log((1.0-con)/(1.0+con))/2.0;
+  fL : function(x,L) {
+    return 2.0*Math.atan(x*Math.exp(L)) - this.HALF_PI;
+// Inverse Latitude Isometrique - close to ph2z
+  invlatiso : function(eccent, ts) {
+    var phi= this.fL(1.0,ts);
+    var Iphi= 0.0;
+    var con= 0.0;
+    do {
+      Iphi= phi;
+      con= eccent*Math.sin(Iphi);
+      phi= this.fL(Math.exp(eccent*Math.log((1.0+con)/(1.0-con))/2.0),ts)
+    } while (Math.abs(phi-Iphi)>1.0e-12);
+    return phi;
+// Needed for Gauss Schreiber
+// Original:  Denis Makarov (info at binarythings.com)
+// Web Site:  http://www.binarythings.com
+  sinh : function(x)
+    var r= Math.exp(x);
+    r= (r-1.0/r)/2.0;
+    return r;
+  cosh : function(x)
+    r= (r+1.0/r)/2.0;
+    return r;
+  tanh : function(x)
+    r= (r-1.0/r)/(r+1.0/r);
+    return r;
+  asinh : function(x)
+    var s= (x>= 0? 1.0:-1.0);
+    return s*(Math.log( Math.abs(x) + Math.sqrt(x*x+1.0) ));
+  acosh : function(x)
+    return 2.0*Math.log(Math.sqrt((x+1.0)/2.0) + Math.sqrt((x-1.0)/2.0));
+  atanh : function(x)
+    return Math.log((x-1.0)/(x+1.0))/2.0;
+// Grande Normale
+  gN : function(a,e,sinphi)
+    var temp= e*sinphi;
+    return a/Math.sqrt(1.0 - temp*temp);
+/** datum object
+Proj4js.datum = Proj4js.Class({
+  initialize : function(proj) {
+    this.datum_type = Proj4js.common.PJD_WGS84;   //default setting
+    if (proj.datumCode && proj.datumCode == 'none') {
+      this.datum_type = Proj4js.common.PJD_NODATUM;
+    if (proj && proj.datum_params) {
+      for (var i=0; i<proj.datum_params.length; i++) {
+        proj.datum_params[i]=parseFloat(proj.datum_params[i]);
+      if (proj.datum_params[0] != 0 || proj.datum_params[1] != 0 || proj.datum_params[2] != 0 ) {
+        this.datum_type = Proj4js.common.PJD_3PARAM;
+      if (proj.datum_params.length > 3) {
+        if (proj.datum_params[3] != 0 || proj.datum_params[4] != 0 ||
+            proj.datum_params[5] != 0 || proj.datum_params[6] != 0 ) {
+          this.datum_type = Proj4js.common.PJD_7PARAM;
+          proj.datum_params[3] *= Proj4js.common.SEC_TO_RAD;
+          proj.datum_params[4] *= Proj4js.common.SEC_TO_RAD;
+          proj.datum_params[5] *= Proj4js.common.SEC_TO_RAD;
+          proj.datum_params[6] = (proj.datum_params[6]/1000000.0) + 1.0;
+    if (proj) {
+      this.a = proj.a;    //datum object also uses these values
+      this.b = proj.b;
+      this.es = proj.es;
+      this.ep2 = proj.ep2;
+      this.datum_params = proj.datum_params;
+  // cs_compare_datums()
+  //   Returns 1 (TRUE) if the two datums match, otherwise 0 (FALSE).
+  compare_datums : function( dest ) {
+    if( this.datum_type != dest.datum_type ) {
+      return false; // false, datums are not equal
+    } else if( this.a != dest.a || Math.abs(this.es-dest.es) > 0.000000000050 ) {
+      // the tolerence for es is to ensure that GRS80 and WGS84
+      // are considered identical
+      return false;
+    } else if( this.datum_type == Proj4js.common.PJD_3PARAM ) {
+      return (this.datum_params[0] == dest.datum_params[0]
+              && this.datum_params[1] == dest.datum_params[1]
+              && this.datum_params[2] == dest.datum_params[2]);
+    } else if( this.datum_type == Proj4js.common.PJD_7PARAM ) {
+              && this.datum_params[3] == dest.datum_params[3]
+              && this.datum_params[4] == dest.datum_params[4]
+              && this.datum_params[5] == dest.datum_params[5]
+              && this.datum_params[6] == dest.datum_params[6]);
+    } else if( this.datum_type == Proj4js.common.PJD_GRIDSHIFT ) {
+      return strcmp( pj_param(this.params,"snadgrids").s,
+                     pj_param(dest.params,"snadgrids").s ) == 0;
+    } else {
+      return true; // datums are equal
+  }, // cs_compare_datums()
+   * The function Convert_Geodetic_To_Geocentric converts geodetic coordinates
+   * (latitude, longitude, and height) to geocentric coordinates (X, Y, Z),
+   * according to the current ellipsoid parameters.
+   *    Latitude  : Geodetic latitude in radians                     (input)
+   *    Longitude : Geodetic longitude in radians                    (input)
+   *    Height    : Geodetic height, in meters                       (input)
+   *    X         : Calculated Geocentric X coordinate, in meters    (output)
+   *    Y         : Calculated Geocentric Y coordinate, in meters    (output)
+   *    Z         : Calculated Geocentric Z coordinate, in meters    (output)
+  geodetic_to_geocentric : function(p) {
+    var Longitude = p.x;
+    var Latitude = p.y;
+    var Height = p.z ? p.z : 0;   //Z value not always supplied
+    var X;  // output
+    var Y;
+    var Z;
+    var Error_Code=0;  //  GEOCENT_NO_ERROR;
+    var Rn;            /*  Earth radius at location  */
+    var Sin_Lat;       /*  Math.sin(Latitude)  */
+    var Sin2_Lat;      /*  Square of Math.sin(Latitude)  */
+    var Cos_Lat;       /*  Math.cos(Latitude)  */
+    ** Don't blow up if Latitude is just a little out of the value
+    ** range as it may just be a rounding issue.  Also removed longitude
+    ** test, it should be wrapped by Math.cos() and Math.sin().  NFW for PROJ.4, Sep/2001.
+    if( Latitude < -Proj4js.common.HALF_PI && Latitude > -1.001 * Proj4js.common.HALF_PI ) {
+        Latitude = -Proj4js.common.HALF_PI;
+    } else if( Latitude > Proj4js.common.HALF_PI && Latitude < 1.001 * Proj4js.common.HALF_PI ) {
+        Latitude = Proj4js.common.HALF_PI;
+    } else if ((Latitude < -Proj4js.common.HALF_PI) || (Latitude > Proj4js.common.HALF_PI)) {
+      /* Latitude out of range */
+      Proj4js.reportError('geocent:lat out of range:'+Latitude);
+      return null;
+    if (Longitude > Proj4js.common.PI) Longitude -= (2*Proj4js.common.PI);
+    Sin_Lat = Math.sin(Latitude);
+    Cos_Lat = Math.cos(Latitude);
+    Sin2_Lat = Sin_Lat * Sin_Lat;
+    Rn = this.a / (Math.sqrt(1.0e0 - this.es * Sin2_Lat));
+    X = (Rn + Height) * Cos_Lat * Math.cos(Longitude);
+    Y = (Rn + Height) * Cos_Lat * Math.sin(Longitude);
+    Z = ((Rn * (1 - this.es)) + Height) * Sin_Lat;
+    p.x = X;
+    p.y = Y;
+    p.z = Z;
+    return Error_Code;
+  }, // cs_geodetic_to_geocentric()
+  geocentric_to_geodetic : function (p) {
+/* local defintions and variables */
+/* end-criterium of loop, accuracy of sin(Latitude) */
+var genau = 1.E-12;
+var genau2 = (genau*genau);
+var maxiter = 30;
+    var P;        /* distance between semi-minor axis and location */
+    var RR;       /* distance between center and location */
+    var CT;       /* sin of geocentric latitude */
+    var ST;       /* cos of geocentric latitude */
+    var RX;
+    var RK;
+    var RN;       /* Earth radius at location */
+    var CPHI0;    /* cos of start or old geodetic latitude in iterations */
+    var SPHI0;    /* sin of start or old geodetic latitude in iterations */
+    var CPHI;     /* cos of searched geodetic latitude */
+    var SPHI;     /* sin of searched geodetic latitude */
+    var SDPHI;    /* end-criterium: addition-theorem of sin(Latitude(iter)-Latitude(iter-1)) */
+    var At_Pole;     /* indicates location is in polar region */
+    var iter;        /* # of continous iteration, max. 30 is always enough (s.a.) */
+    var X = p.x;
+    var Y = p.y;
+    var Z = p.z ? p.z : 0.0;   //Z value not always supplied
+    var Longitude;
+    var Latitude;
+    var Height;
+    At_Pole = false;
+    P = Math.sqrt(X*X+Y*Y);
+    RR = Math.sqrt(X*X+Y*Y+Z*Z);
+/*      special cases for latitude and longitude */
+    if (P/this.a < genau) {
+/*  special case, if P=0. (X=0., Y=0.) */
+        At_Pole = true;
+        Longitude = 0.0;
+/*  if (X,Y,Z)=(0.,0.,0.) then Height becomes semi-minor axis
+ *  of ellipsoid (=center of mass), Latitude becomes PI/2 */
+        if (RR/this.a < genau) {
+            Height   = -this.b;
+            return;
+    } else {
+/*  ellipsoidal (geodetic) longitude
+ *  interval: -PI < Longitude <= +PI */
+        Longitude=Math.atan2(Y,X);
+ * Following iterative algorithm was developped by
+ * "Institut für Erdmessung", University of Hannover, July 1988.
+ * Internet: www.ife.uni-hannover.de
+ * Iterative computation of CPHI,SPHI and Height.
+ * Iteration of CPHI and SPHI to 10**-12 radian resp.
+ * 2*10**-7 arcsec.
+    CT = Z/RR;
+    ST = P/RR;
+    RX = 1.0/Math.sqrt(1.0-this.es*(2.0-this.es)*ST*ST);
+    CPHI0 = ST*(1.0-this.es)*RX;
+    SPHI0 = CT*RX;
+    iter = 0;
+/* loop to find sin(Latitude) resp. Latitude
+ * until |sin(Latitude(iter)-Latitude(iter-1))| < genau */
+    do
+        iter++;
+        RN = this.a/Math.sqrt(1.0-this.es*SPHI0*SPHI0);
+/*  ellipsoidal (geodetic) height */
+        Height = P*CPHI0+Z*SPHI0-RN*(1.0-this.es*SPHI0*SPHI0);
+        RK = this.es*RN/(RN+Height);
+        RX = 1.0/Math.sqrt(1.0-RK*(2.0-RK)*ST*ST);
+        CPHI = ST*(1.0-RK)*RX;
+        SPHI = CT*RX;
+        SDPHI = SPHI*CPHI0-CPHI*SPHI0;
+        CPHI0 = CPHI;
+        SPHI0 = SPHI;
+    while (SDPHI*SDPHI > genau2 && iter < maxiter);
+/*      ellipsoidal (geodetic) latitude */
+    Latitude=Math.atan(SPHI/Math.abs(CPHI));
+    p.x = Longitude;
+    p.y = Latitude;
+    p.z = Height;
+    return p;
+  }, // cs_geocentric_to_geodetic()
+  /** Convert_Geocentric_To_Geodetic
+   * The method used here is derived from 'An Improved Algorithm for
+   * Geocentric to Geodetic Coordinate Conversion', by Ralph Toms, Feb 1996
+  geocentric_to_geodetic_noniter : function (p) {
+    var X = p.x;
+    var Y = p.y;
+    var Z = p.z ? p.z : 0;   //Z value not always supplied
+    var Longitude;
+    var Latitude;
+    var Height;
+    var W;        /* distance from Z axis */
+    var W2;       /* square of distance from Z axis */
+    var T0;       /* initial estimate of vertical component */
+    var T1;       /* corrected estimate of vertical component */
+    var S0;       /* initial estimate of horizontal component */
+    var S1;       /* corrected estimate of horizontal component */
+    var Sin_B0;   /* Math.sin(B0), B0 is estimate of Bowring aux variable */
+    var Sin3_B0;  /* cube of Math.sin(B0) */
+    var Cos_B0;   /* Math.cos(B0) */
+    var Sin_p1;   /* Math.sin(phi1), phi1 is estimated latitude */
+    var Cos_p1;   /* Math.cos(phi1) */
+    var Sum;      /* numerator of Math.cos(phi1) */
+    X = parseFloat(X);  // cast from string to float
+    Y = parseFloat(Y);
+    Z = parseFloat(Z);
+    At_Pole = false;
+    if (X != 0.0)
+        Longitude = Math.atan2(Y,X);
+    else
+        if (Y > 0)
+            Longitude = Proj4js.common.HALF_PI;
+        else if (Y < 0)
+            Longitude = -Proj4js.common.HALF_PI;
+        else
+            At_Pole = true;
+            Longitude = 0.0;
+            if (Z > 0.0)
+            {  /* north pole */
+            else if (Z < 0.0)
+            {  /* south pole */
+            else
+            {  /* center of earth */
+                Height = -this.b;
+                return;
+    W2 = X*X + Y*Y;
+    W = Math.sqrt(W2);
+    T0 = Z * Proj4js.common.AD_C;
+    S0 = Math.sqrt(T0 * T0 + W2);
+    Sin_B0 = T0 / S0;
+    Cos_B0 = W / S0;
+    Sin3_B0 = Sin_B0 * Sin_B0 * Sin_B0;
+    T1 = Z + this.b * this.ep2 * Sin3_B0;
+    Sum = W - this.a * this.es * Cos_B0 * Cos_B0 * Cos_B0;
+    S1 = Math.sqrt(T1*T1 + Sum * Sum);
+    Sin_p1 = T1 / S1;
+    Cos_p1 = Sum / S1;
+    Rn = this.a / Math.sqrt(1.0 - this.es * Sin_p1 * Sin_p1);
+    if (Cos_p1 >= Proj4js.common.COS_67P5)
+        Height = W / Cos_p1 - Rn;
+    else if (Cos_p1 <= -Proj4js.common.COS_67P5)
+        Height = W / -Cos_p1 - Rn;
+    else
+        Height = Z / Sin_p1 + Rn * (this.es - 1.0);
+    if (At_Pole == false)
+        Latitude = Math.atan(Sin_p1 / Cos_p1);
+    p.x = Longitude;
+    p.y = Latitude;
+    p.z = Height;
+    return p;
+  }, // geocentric_to_geodetic_noniter()
+  // pj_geocentic_to_wgs84( p )
+  //  p = point to transform in geocentric coordinates (x,y,z)
+  geocentric_to_wgs84 : function ( p ) {
+    if( this.datum_type == Proj4js.common.PJD_3PARAM )
+      // if( x[io] == HUGE_VAL )
+      //    continue;
+      p.x += this.datum_params[0];
+      p.y += this.datum_params[1];
+      p.z += this.datum_params[2];
+    else if (this.datum_type == Proj4js.common.PJD_7PARAM)
+      var Dx_BF =this.datum_params[0];
+      var Dy_BF =this.datum_params[1];
+      var Dz_BF =this.datum_params[2];
+      var Rx_BF =this.datum_params[3];
+      var Ry_BF =this.datum_params[4];
+      var Rz_BF =this.datum_params[5];
+      var M_BF  =this.datum_params[6];
+      //    continue;
+      var x_out = M_BF*(       p.x - Rz_BF*p.y + Ry_BF*p.z) + Dx_BF;
+      var y_out = M_BF*( Rz_BF*p.x +       p.y - Rx_BF*p.z) + Dy_BF;
+      var z_out = M_BF*(-Ry_BF*p.x + Rx_BF*p.y +       p.z) + Dz_BF;
+      p.x = x_out;
+      p.y = y_out;
+      p.z = z_out;
+  }, // cs_geocentric_to_wgs84
+  // pj_geocentic_from_wgs84()
+  //  coordinate system definition,
+  //  point to transform in geocentric coordinates (x,y,z)
+  geocentric_from_wgs84 : function( p ) {
+      //if( x[io] == HUGE_VAL )
+      //    continue;
+      p.x -= this.datum_params[0];
+      p.y -= this.datum_params[1];
+      p.z -= this.datum_params[2];
+      var x_tmp = (p.x - Dx_BF) / M_BF;
+      var y_tmp = (p.y - Dy_BF) / M_BF;
+      var z_tmp = (p.z - Dz_BF) / M_BF;
+      //    continue;
+      p.x =        x_tmp + Rz_BF*y_tmp - Ry_BF*z_tmp;
+      p.y = -Rz_BF*x_tmp +       y_tmp + Rx_BF*z_tmp;
+      p.z =  Ry_BF*x_tmp - Rx_BF*y_tmp +       z_tmp;
+    } //cs_geocentric_from_wgs84()
+/** point object, nothing fancy, just allows values to be
+    passed back and forth by reference rather than by value.
+    Other point classes may be used as long as they have
+    x and y properties, which will get modified in the transform method.
+Proj4js.Point = Proj4js.Class({
+     * Constructor: Proj4js.Point
+     * Parameters:
+     * - x {float} or {Array} either the first coordinates component or
+     *     the full coordinates
+     * - y {float} the second component
+     * - z {float} the third component, optional.
+    initialize : function(x,y,z) {
+      if (typeof x == 'object') {
+        this.x = x[0];
+        this.y = x[1];
+        this.z = x[2] || 0.0;
+      } else if (typeof x == 'string') {
+        var coords = x.split(',');
+        this.x = parseFloat(coords[0]);
+        this.y = parseFloat(coords[1]);
+        this.z = parseFloat(coords[2]) || 0.0;
+      } else {
+        this.x = x;
+        this.y = y;
+        this.z = z || 0.0;
+     * APIMethod: clone
+     * Build a copy of a Proj4js.Point object.
+     * Return:
+     * {Proj4js}.Point the cloned point.
+    clone : function() {
+      return new Proj4js.Point(this.x, this.y, this.z);
+     * APIMethod: toString
+     * Return a readable string version of the point
+     * Return:
+     * {String} String representation of Proj4js.Point object.
+     *           (ex. <i>"x=5,y=42"</i>)
+    toString : function() {
+        return ("x=" + this.x + ",y=" + this.y);
+     * APIMethod: toShortString
+     * Return a short string version of the point.
+     * Return:
+     * {String} Shortened String representation of Proj4js.Point object.
+     *         (ex. <i>"5, 42"</i>)
+    toShortString : function() {
+        return (this.x + ", " + this.y);
+Proj4js.PrimeMeridian = {
+    "greenwich": 0.0,               //"0dE",
+    "lisbon":     -9.131906111111,   //"9d07'54.862\"W",
+    "paris":       2.337229166667,   //"2d20'14.025\"E",
+    "bogota":    -74.080916666667,  //"74d04'51.3\"W",
+    "madrid":     -3.687938888889,  //"3d41'16.58\"W",
+    "rome":       12.452333333333,  //"12d27'8.4\"E",
+    "bern":        7.439583333333,  //"7d26'22.5\"E",
+    "jakarta":   106.807719444444,  //"106d48'27.79\"E",
+    "ferro":     -17.666666666667,  //"17d40'W",
+    "brussels":    4.367975,        //"4d22'4.71\"E",
+    "stockholm":  18.058277777778,  //"18d3'29.8\"E",
+    "athens":     23.7163375,       //"23d42'58.815\"E",
+    "oslo":       10.722916666667   //"10d43'22.5\"E"
+Proj4js.Ellipsoid = {
+  "MERIT": {a:6378137.0, rf:298.257, ellipseName:"MERIT 1983"},
+  "SGS85": {a:6378136.0, rf:298.257, ellipseName:"Soviet Geodetic System 85"},
+  "GRS80": {a:6378137.0, rf:298.257222101, ellipseName:"GRS 1980(IUGG, 1980)"},
+  "IAU76": {a:6378140.0, rf:298.257, ellipseName:"IAU 1976"},
+  "airy": {a:6377563.396, b:6356256.910, ellipseName:"Airy 1830"},
+  "APL4.": {a:6378137, rf:298.25, ellipseName:"Appl. Physics. 1965"},
+  "NWL9D": {a:6378145.0, rf:298.25, ellipseName:"Naval Weapons Lab., 1965"},
+  "mod_airy": {a:6377340.189, b:6356034.446, ellipseName:"Modified Airy"},
+  "andrae": {a:6377104.43, rf:300.0, ellipseName:"Andrae 1876 (Den., Iclnd.)"},
+  "aust_SA": {a:6378160.0, rf:298.25, ellipseName:"Australian Natl & S. Amer. 1969"},
+  "GRS67": {a:6378160.0, rf:298.2471674270, ellipseName:"GRS 67(IUGG 1967)"},
+  "bessel": {a:6377397.155, rf:299.1528128, ellipseName:"Bessel 1841"},
+  "bess_nam": {a:6377483.865, rf:299.1528128, ellipseName:"Bessel 1841 (Namibia)"},
+  "clrk66": {a:6378206.4, b:6356583.8, ellipseName:"Clarke 1866"},
+  "clrk80": {a:6378249.145, rf:293.4663, ellipseName:"Clarke 1880 mod."},
+  "CPM": {a:6375738.7, rf:334.29, ellipseName:"Comm. des Poids et Mesures 1799"},
+  "delmbr": {a:6376428.0, rf:311.5, ellipseName:"Delambre 1810 (Belgium)"},
+  "engelis": {a:6378136.05, rf:298.2566, ellipseName:"Engelis 1985"},
+  "evrst30": {a:6377276.345, rf:300.8017, ellipseName:"Everest 1830"},
+  "evrst48": {a:6377304.063, rf:300.8017, ellipseName:"Everest 1948"},
+  "evrst56": {a:6377301.243, rf:300.8017, ellipseName:"Everest 1956"},
+  "evrst69": {a:6377295.664, rf:300.8017, ellipseName:"Everest 1969"},
+  "evrstSS": {a:6377298.556, rf:300.8017, ellipseName:"Everest (Sabah & Sarawak)"},
+  "fschr60": {a:6378166.0, rf:298.3, ellipseName:"Fischer (Mercury Datum) 1960"},
+  "fschr60m": {a:6378155.0, rf:298.3, ellipseName:"Fischer 1960"},
+  "fschr68": {a:6378150.0, rf:298.3, ellipseName:"Fischer 1968"},
+  "helmert": {a:6378200.0, rf:298.3, ellipseName:"Helmert 1906"},
+  "hough": {a:6378270.0, rf:297.0, ellipseName:"Hough"},
+  "intl": {a:6378388.0, rf:297.0, ellipseName:"International 1909 (Hayford)"},
+  "kaula": {a:6378163.0, rf:298.24, ellipseName:"Kaula 1961"},
+  "lerch": {a:6378139.0, rf:298.257, ellipseName:"Lerch 1979"},
+  "mprts": {a:6397300.0, rf:191.0, ellipseName:"Maupertius 1738"},
+  "new_intl": {a:6378157.5, b:6356772.2, ellipseName:"New International 1967"},
+  "plessis": {a:6376523.0, rf:6355863.0, ellipseName:"Plessis 1817 (France)"},
+  "krass": {a:6378245.0, rf:298.3, ellipseName:"Krassovsky, 1942"},
+  "SEasia": {a:6378155.0, b:6356773.3205, ellipseName:"Southeast Asia"},
+  "walbeck": {a:6376896.0, b:6355834.8467, ellipseName:"Walbeck"},
+  "WGS60": {a:6378165.0, rf:298.3, ellipseName:"WGS 60"},
+  "WGS66": {a:6378145.0, rf:298.25, ellipseName:"WGS 66"},
+  "WGS72": {a:6378135.0, rf:298.26, ellipseName:"WGS 72"},
+  "WGS84": {a:6378137.0, rf:298.257223563, ellipseName:"WGS 84"},
+  "sphere": {a:6370997.0, b:6370997.0, ellipseName:"Normal Sphere (r=6370997)"}
+Proj4js.Datum = {
+  "WGS84": {towgs84: "0,0,0", ellipse: "WGS84", datumName: "WGS84"},
+  "GGRS87": {towgs84: "-199.87,74.79,246.62", ellipse: "GRS80", datumName: "Greek_Geodetic_Reference_System_1987"},
+  "NAD83": {towgs84: "0,0,0", ellipse: "GRS80", datumName: "North_American_Datum_1983"},
+  "NAD27": {nadgrids: "@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat", ellipse: "clrk66", datumName: "North_American_Datum_1927"},
+  "potsdam": {towgs84: "606.0,23.0,413.0", ellipse: "bessel", datumName: "Potsdam Rauenberg 1950 DHDN"},
+  "carthage": {towgs84: "-263.0,6.0,431.0", ellipse: "clark80", datumName: "Carthage 1934 Tunisia"},
+  "hermannskogel": {towgs84: "653.0,-212.0,449.0", ellipse: "bessel", datumName: "Hermannskogel"},
+  "ire65": {towgs84: "482.530,-130.596,564.557,-1.042,-0.214,-0.631,8.15", ellipse: "mod_airy", datumName: "Ireland 1965"},
+  "nzgd49": {towgs84: "59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993", ellipse: "intl", datumName: "New Zealand Geodetic Datum 1949"},
+  "OSGB36": {towgs84: "446.448,-125.157,542.060,0.1502,0.2470,0.8421,-20.4894", ellipse: "airy", datumName: "Airy 1830"}
+Proj4js.WGS84 = new Proj4js.Proj('WGS84');
+Proj4js.Datum['OSB36'] = Proj4js.Datum['OSGB36']; //as returned from spatialreference.org
+//lookup table to go from the projection name in WKT to the Proj4js projection name
+//build this out as required
+Proj4js.wktProjections = {
+  "Lambert Tangential Conformal Conic Projection": "lcc",
+  "Mercator": "merc",
+  "Transverse_Mercator": "tmerc",
+  "Transverse Mercator": "tmerc",
+  "Lambert Azimuthal Equal Area": "laea",
+  "Universal Transverse Mercator System": "utm"
+    projCode/aea.js
+NAME                     ALBERS CONICAL EQUAL AREA
+PURPOSE:	Transforms input longitude and latitude to Easting and Northing
+		for the Albers Conical Equal Area projection.  The longitude
+		and latitude must be in radians.  The Easting and Northing
+		values will be returned in meters.
+PROGRAMMER              DATE
+T. Mittan,       	Feb, 1992
+ALGORITHM REFERENCES
+1.  Snyder, John P., "Map Projections--A Working Manual", U.S. Geological
+    Survey Professional Paper 1395 (Supersedes USGS Bulletin 1532), United
+    State Government Printing Office, Washington D.C., 1987.
+2.  Snyder, John P. and Voxland, Philip M., "An Album of Map Projections",
+    U.S. Geological Survey Professional Paper 1453 , United State Government
+    Printing Office, Washington D.C., 1989.
+Proj4js.Proj.aea = {
+  init : function() {
+    if (Math.abs(this.lat1 + this.lat2) < Proj4js.common.EPSLN) {
+       Proj4js.reportError("aeaInitEqualLatitudes");
+       return;
+    this.temp = this.b / this.a;
+    this.es = 1.0 - Math.pow(this.temp,2);
+    this.e3 = Math.sqrt(this.es);
+    this.sin_po=Math.sin(this.lat1);
+    this.cos_po=Math.cos(this.lat1);
+    this.t1=this.sin_po;
+    this.con = this.sin_po;
+    this.ms1 = Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);
+    this.qs1 = Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);
+    this.sin_po=Math.sin(this.lat2);
+    this.cos_po=Math.cos(this.lat2);
+    this.t2=this.sin_po;
+    this.ms2 = Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);
+    this.qs2 = Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);
+    this.sin_po=Math.sin(this.lat0);
+    this.cos_po=Math.cos(this.lat0);
+    this.t3=this.sin_po;
+    this.qs0 = Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);
+    if (Math.abs(this.lat1 - this.lat2) > Proj4js.common.EPSLN) {
+      this.ns0 = (this.ms1 * this.ms1 - this.ms2 *this.ms2)/ (this.qs2 - this.qs1);
+    } else {
+      this.ns0 = this.con;
+    this.c = this.ms1 * this.ms1 + this.ns0 * this.qs1;
+    this.rh = this.a * Math.sqrt(this.c - this.ns0 * this.qs0)/this.ns0;
+/* Albers Conical Equal Area forward equations--mapping lat,long to x,y
+  forward: function(p){
+    var lon=p.x;
+    var lat=p.y;
+    this.sin_phi=Math.sin(lat);
+    this.cos_phi=Math.cos(lat);
+    var qs = Proj4js.common.qsfnz(this.e3,this.sin_phi,this.cos_phi);
+    var rh1 =this.a * Math.sqrt(this.c - this.ns0 * qs)/this.ns0;
+    var theta = this.ns0 * Proj4js.common.adjust_lon(lon - this.long0);
+    var x = rh1 * Math.sin(theta) + this.x0;
+    var y = this.rh - rh1 * Math.cos(theta) + this.y0;
+    p.x = x;
+    p.y = y;
+    return p;
+  inverse: function(p) {
+    var rh1,qs,con,theta,lon,lat;
+    p.x -= this.x0;
+    p.y = this.rh - p.y + this.y0;
+    if (this.ns0 >= 0) {
+      rh1 = Math.sqrt(p.x *p.x + p.y * p.y);
+      con = 1.0;
+    } else {
+      rh1 = -Math.sqrt(p.x * p.x + p.y *p.y);
+      con = -1.0;
+    theta = 0.0;
+    if (rh1 != 0.0) {
+      theta = Math.atan2(con * p.x, con * p.y);
+    con = rh1 * this.ns0 / this.a;
+    qs = (this.c - con * con) / this.ns0;
+    if (this.e3 >= 1e-10) {
+      con = 1 - .5 * (1.0 -this.es) * Math.log((1.0 - this.e3) / (1.0 + this.e3))/this.e3;
+      if (Math.abs(Math.abs(con) - Math.abs(qs)) > .0000000001 ) {
+          lat = this.phi1z(this.e3,qs);
+      } else {
+          if (qs >= 0) {
+             lat = .5 * PI;
+          } else {
+             lat = -.5 * PI;
+    } else {
+      lat = this.phi1z(e3,qs);
+    lon = Proj4js.common.adjust_lon(theta/this.ns0 + this.long0);
+    p.x = lon;
+    p.y = lat;
+    return p;
+/* Function to compute phi1, the latitude for the inverse of the
+   Albers Conical Equal-Area projection.
+  phi1z: function (eccent,qs) {
+    var con, com, dphi;
+    var phi = Proj4js.common.asinz(.5 * qs);
+    if (eccent < Proj4js.common.EPSLN) return phi;
+    var eccnts = eccent * eccent;
+    for (var i = 1; i <= 25; i++) {
+        sinphi = Math.sin(phi);
+        cosphi = Math.cos(phi);
+        com = 1.0 - con * con;
+        dphi = .5 * com * com / cosphi * (qs / (1.0 - eccnts) - sinphi / com + .5 / eccent * Math.log((1.0 - con) / (1.0 + con)));
+        phi = phi + dphi;
+        if (Math.abs(dphi) <= 1e-7) return phi;
+    Proj4js.reportError("aea:phi1z:Convergence error");
+    return null;
+    projCode/sterea.js
+Proj4js.Proj.sterea = {
+  dependsOn : 'gauss',
+    Proj4js.Proj['gauss'].init.apply(this);
+    if (!this.rc) {
+      Proj4js.reportError("sterea:init:E_ERROR_0");
+      return;
+    this.sinc0 = Math.sin(this.phic0);
+    this.cosc0 = Math.cos(this.phic0);
+    this.R2 = 2.0 * this.rc;
+    if (!this.title) this.title = "Oblique Stereographic Alternative";
+  forward : function(p) {
+    p.x = Proj4js.common.adjust_lon(p.x-this.long0); /* adjust del longitude */
+    Proj4js.Proj['gauss'].forward.apply(this, [p]);
+    sinc = Math.sin(p.y);
+    cosc = Math.cos(p.y);
+    cosl = Math.cos(p.x);
+    k = this.k0 * this.R2 / (1.0 + this.sinc0 * sinc + this.cosc0 * cosc * cosl);
+    p.x = k * cosc * Math.sin(p.x);
+    p.y = k * (this.cosc0 * sinc - this.sinc0 * cosc * cosl);
+    p.x = this.a * p.x + this.x0;
+    p.y = this.a * p.y + this.y0;
+    return p;
+  inverse : function(p) {
+    var lon,lat;
+    p.x = (p.x - this.x0) / this.a; /* descale and de-offset */
+    p.y = (p.y - this.y0) / this.a;
+    p.x /= this.k0;
+    p.y /= this.k0;
+    if ( (rho = Math.sqrt(p.x*p.x + p.y*p.y)) ) {
+      c = 2.0 * Math.atan2(rho, this.R2);
+      sinc = Math.sin(c);
+      cosc = Math.cos(c);
+      lat = Math.asin(cosc * this.sinc0 + p.y * sinc * this.cosc0 / rho);
+      lon = Math.atan2(p.x * sinc, rho * this.cosc0 * cosc - p.y * this.sinc0 * sinc);
+    } else {
+      lat = this.phic0;
+      lon = 0.;
+    p.x = lon;
+    p.y = lat;
+    Proj4js.Proj['gauss'].inverse.apply(this,[p]);
+    p.x = Proj4js.common.adjust_lon(p.x + this.long0); /* adjust longitude to CM */
+    return p;
+    projCode/poly.js
+/* Function to compute, phi4, the latitude for the inverse of the
+   Polyconic projection.
+function phi4z (eccent,e0,e1,e2,e3,a,b,c,phi) {
+	var sinphi, sin2ph, tanph, ml, mlp, con1, con2, con3, dphi, i;
+	phi = a;
+	for (i = 1; i <= 15; i++) {
+		tanphi = Math.tan(phi);
+		c = tanphi * Math.sqrt (1.0 - eccent * sinphi * sinphi);
+		sin2ph = Math.sin (2.0 * phi);
+		ml = e0 * *phi - e1 * sin2ph + e2 * sin (4.0 *  *phi);
+		mlp = e0 - 2.0 * e1 * cos (2.0 *  *phi) + 4.0 * e2 *  cos (4.0 *  *phi);
+		ml = e0 * phi - e1 * sin2ph + e2 * Math.sin (4.0 *  phi) - e3 * Math.sin (6.0 * phi);
+		mlp = e0 - 2.0 * e1 * Math.cos (2.0 *  phi) + 4.0 * e2 * Math.cos (4.0 *  phi) - 6.0 * e3 * Math.cos (6.0 *  phi);
+		con1 = 2.0 * ml + c * (ml * ml + b) - 2.0 * a *  (c * ml + 1.0);
+		con2 = eccent * sin2ph * (ml * ml + b - 2.0 * a * ml) / (2.0 *c);
+		con3 = 2.0 * (a - ml) * (c * mlp - 2.0 / sin2ph) - 2.0 * mlp;
+		dphi = con1 / (con2 + con3);
+		phi += dphi;
+		if (Math.abs(dphi) <= .0000000001 ) return(phi);
+	Proj4js.reportError("phi4z: No convergence");
+	return null;
+/* Function to compute the constant e4 from the input of the eccentricity
+   of the spheroid, x.  This constant is used in the Polar Stereographic
+   projection.
+function e4fn(x) {
+	var con, com;
+	con = 1.0 + x;
+	com = 1.0 - x;
+	return (Math.sqrt((Math.pow(con,con))*(Math.pow(com,com))));
+NAME                             POLYCONIC
+		Northing for the Polyconic projection.  The
+		longitude and latitude must be in radians.  The Easting
+		and Northing values will be returned in meters.
+PROGRAMMER              DATE
+T. Mittan		Mar, 1993
+Proj4js.Proj.poly = {
+	/* Initialize the POLYCONIC projection
+		var temp;			/* temporary variable		*/
+		if (this.lat0=0) this.lat0=90;//this.lat0 ca
+		/* Place parameters in static storage for common use
+		this.es = 1.0 - Math.pow(this.temp,2);// devait etre dans tmerc.js mais n y est pas donc je commente sinon retour de valeurs nulles
+		this.e0 = Proj4js.common.e0fn(this.es);
+		this.e1 = Proj4js.common.e1fn(this.es);
+		this.e2 = Proj4js.common.e2fn(this.es);
+		this.e3 = Proj4js.common.e3fn(this.es);
+		this.ml0 = Proj4js.common.mlfn(this.e0, this.e1,this.e2, this.e3, this.lat0);//si que des zeros le calcul ne se fait pas
+		//if (!this.ml0) {this.ml0=0;}
+	/* Polyconic forward equations--mapping lat,long to x,y
+	forward: function(p) {
+		var sinphi, cosphi;	/* sin and cos value				*/
+		var al;				/* temporary values				*/
+		var c;				/* temporary values				*/
+		var con, ml;		/* cone constant, small m			*/
+		var ms;				/* small m					*/
+		var x,y;
+		var lon=p.x;
+		var lat=p.y;
+		con = Proj4js.common.adjust_lon(lon - this.long0);
+		if (Math.abs(lat) <= .0000001) {
+			x = this.x0 + this.a * con;
+			y = this.y0 - this.a * this.ml0;
+		} else {
+			sinphi = Math.sin(lat);
+			cosphi = Math.cos(lat);
+			ml = Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, lat);
+			ms = Proj4js.common.msfnz(this.e,sinphi,cosphi);
+			con = sinphi;
+			x = this.x0 + this.a * ms * Math.sin(con)/sinphi;
+			y = this.y0 + this.a * (ml - this.ml0 + ms * (1.0 - Math.cos(con))/sinphi);
+		p.x=x;
+		p.y=y;
+		return p;
+	/* Inverse equations
+		var sin_phi, cos_phi;	/* sin and cos value				*/
+		var b;					/* temporary values				*/
+		var iflg;				/* error flag					*/
+		var lon,lat;
+		p.x -= this.x0;
+		p.y -= this.y0;
+		al = this.ml0 + p.y/this.a;
+		iflg = 0;
+		if (Math.abs(al) <= .0000001) {
+			lon = p.x/this.a + this.long0;
+			lat = 0.0;
+		} else {
+			b = al * al + (p.x/this.a) * (p.x/this.a);
+			iflg = phi4z(this.es,this.e0,this.e1,this.e2,this.e3,this.al,b,c,lat);
+			if (iflg != 1) return(iflg);
+			lon = Proj4js.common.adjust_lon((Proj4js.common.asinz(p.x * c / this.a) / Math.sin(lat)) + this.long0);
+		p.x=lon;
+		p.y=lat;
+		return p;
+    projCode/equi.js
+NAME                             EQUIRECTANGULAR
+		Northing for the Equirectangular projection.  The
+PROGRAMMER              DATE
+Proj4js.Proj.equi = {
+    if(!this.x0) this.x0=0;
+    if(!this.y0) this.y0=0;
+    if(!this.lat0) this.lat0=0;
+    if(!this.long0) this.long0=0;
+    ///this.t2;
+/* Equirectangular forward equations--mapping lat,long to x,y
+    var lon=p.x;
+    var lat=p.y;
+    var dlon = Proj4js.common.adjust_lon(lon - this.long0);
+    var x = this.x0 +this. a * dlon *Math.cos(this.lat0);
+    var y = this.y0 + this.a * lat;
+    this.t1=x;
+    this.t2=Math.cos(this.lat0);
+    p.x=x;
+    p.y=y;
+    return p;
+  },  //equiFwd()
+/* Equirectangular inverse equations--mapping x,y to lat/long
+    p.x -= this.x0;
+    p.y -= this.y0;
+    var lat = p.y /this. a;
+    if ( Math.abs(lat) > Proj4js.common.HALF_PI) {
+        Proj4js.reportError("equi:Inv:DataError");
+    var lon = Proj4js.common.adjust_lon(this.long0 + p.x / (this.a * Math.cos(this.lat0)));
+    p.x=lon;
+    p.y=lat;
+  }//equiInv()
+    projCode/merc.js
+NAME                            MERCATOR
+		Northing for the Mercator projection.  The
+PROGRAMMER              DATE
+D. Steinwand, EROS      Nov, 1991
+//static double r_major = a;		   /* major axis 				*/
+//static double r_minor = b;		   /* minor axis 				*/
+//static double lon_center = long0;	   /* Center longitude (projection center) */
+//static double lat_origin =  lat0;	   /* center latitude			*/
+//static double e,es;		           /* eccentricity constants		*/
+//static double m1;		               /* small value m			*/
+//static double false_northing = y0;   /* y offset in meters			*/
+//static double false_easting = x0;	   /* x offset in meters			*/
+//scale_fact = k0
+Proj4js.Proj.merc = {
+	//?this.temp = this.r_minor / this.r_major;
+	//this.temp = this.b / this.a;
+	//this.es = 1.0 - Math.sqrt(this.temp);
+	//this.e = Math.sqrt( this.es );
+	//?this.m1 = Math.cos(this.lat_origin) / (Math.sqrt( 1.0 - this.es * Math.sin(this.lat_origin) * Math.sin(this.lat_origin)));
+	//this.m1 = Math.cos(0.0) / (Math.sqrt( 1.0 - this.es * Math.sin(0.0) * Math.sin(0.0)));
+    if (this.lat_ts) {
+      if (this.sphere) {
+        this.k0 = Math.cos(this.lat_ts);
+      } else {
+        this.k0 = Proj4js.common.msfnz(this.es, Math.sin(this.lat_ts), Math.cos(this.lat_ts));
+/* Mercator forward equations--mapping lat,long to x,y
+    //alert("ll2m coords : "+coords);
+    var lon = p.x;
+    var lat = p.y;
+    // convert to radians
+    if ( lat*Proj4js.common.R2D > 90.0 &&
+          lat*Proj4js.common.R2D < -90.0 &&
+          lon*Proj4js.common.R2D > 180.0 &&
+          lon*Proj4js.common.R2D < -180.0) {
+      Proj4js.reportError("merc:forward: llInputOutOfRange: "+ lon +" : " + lat);
+      return null;
+    var x,y;
+    if(Math.abs( Math.abs(lat) - Proj4js.common.HALF_PI)  <= Proj4js.common.EPSLN) {
+      Proj4js.reportError("merc:forward: ll2mAtPoles");
+      return null;
+    } else {
+        x = this.x0 + this.a * this.k0 * Proj4js.common.adjust_lon(lon - this.long0);
+        y = this.y0 + this.a * this.k0 * Math.log(Math.tan(Proj4js.common.FORTPI + 0.5*lat));
+      } else {
+        var sinphi = Math.sin(lat);
+        var ts = Proj4js.common.tsfnz(this.e,lat,sinphi);
+        y = this.y0 - this.a * this.k0 * Math.log(ts);
+      p.x = x;
+      p.y = y;
+      return p;
+  /* Mercator inverse equations--mapping x,y to lat/long
+    var x = p.x - this.x0;
+    var y = p.y - this.y0;
+    var lon,lat;
+      lat = Proj4js.common.HALF_PI - 2.0 * Math.atan(Math.exp(-y / this.a * this.k0));
+    } else {
+      var ts = Math.exp(-y / (this.a * this.k0));
+      lat = Proj4js.common.phi2z(this.e,ts);
+      if(lat == -9999) {
+        Proj4js.reportError("merc:inverse: lat = -9999");
+        return null;
+    lon = Proj4js.common.adjust_lon(this.long0+ x / (this.a * this.k0));
+    p.x = lon;
+    p.y = lat;
+    return p;
+    projCode/utm.js
+NAME                            TRANSVERSE MERCATOR
+		Northing for the Transverse Mercator projection.  The
+  Initialize Transverse Mercator projection
+Proj4js.Proj.utm = {
+  dependsOn : 'tmerc',
+    if (!this.zone) {
+      Proj4js.reportError("utm:init: zone must be specified for UTM");
+      return;
+    this.lat0 = 0.0;
+    this.long0 = ((6 * Math.abs(this.zone)) - 183) * Proj4js.common.D2R;
+    this.x0 = 500000.0;
+    this.y0 = this.utmSouth ? 10000000.0 : 0.0;
+    this.k0 = 0.9996;
+    Proj4js.Proj['tmerc'].init.apply(this);
+    this.forward = Proj4js.Proj['tmerc'].forward;
+    this.inverse = Proj4js.Proj['tmerc'].inverse;
+    projCode/eqdc.js
+NAME                            EQUIDISTANT CONIC
+		for the Equidistant Conic projection.  The longitude and
+		latitude must be in radians.  The Easting and Northing values
+		will be returned in meters.
+PROGRAMMER              DATE
+/* Variables common to all subroutines in this code file
+Proj4js.Proj.eqdc = {
+/* Initialize the Equidistant Conic projection
+    if(!this.mode) this.mode=0;//chosen default mode
+    this.sinphi=Math.sin(this.lat1);
+    this.cosphi=Math.cos(this.lat1);
+    this.ms1 = Proj4js.common.msfnz(this.e,this.sinphi,this.cosphi);
+    this.ml1 = Proj4js.common.mlfn(this.e0, this.e1, this.e2,this.e3, this.lat1);
+    /* format B
+    if (this.mode != 0) {
+            Proj4js.reportError("eqdc:Init:EqualLatitudes");
+            //return(81);
+       this.sinphi=Math.sin(this.lat2);
+       this.cosphi=Math.cos(this.lat2);
+       this.ms2 = Proj4js.common.msfnz(this.e,this.sinphi,this.cosphi);
+       this.ml2 = Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, this.lat2);
+       if (Math.abs(this.lat1 - this.lat2) >= Proj4js.common.EPSLN) {
+         this.ns = (this.ms1 - this.ms2) / (this.ml2 - this.ml1);
+       } else {
+          this.ns = this.sinphi;
+    } else {
+    this.g = this.ml1 + this.ms1/this.ns;
+    this.ml0 = Proj4js.common.mlfn(this.e0, this.e1,this. e2, this.e3, this.lat0);
+    this.rh = this.a * (this.g - this.ml0);
+/* Equidistant Conic forward equations--mapping lat,long to x,y
+    var lon=p.x;
+    var lat=p.y;
+    /* Forward equations
+    var ml = Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, lat);
+    var rh1 = this.a * (this.g - ml);
+    var theta = this.ns * Proj4js.common.adjust_lon(lon - this.long0);
+    var x = this.x0  + rh1 * Math.sin(theta);
+    var y = this.y0 + this.rh - rh1 * Math.cos(theta);
+    p.x=x;
+    p.y=y;
+    return p;
+/* Inverse equations
+    p.x -= this.x0;
+    var con, rh1;
+    if (this.ns >= 0) {
+       var rh1 = Math.sqrt(p.x *p.x + p.y * p.y);
+       var con = 1.0;
+    } else {
+       rh1 = -Math.sqrt(p.x *p. x +p. y * p.y);
+       con = -1.0;
+    var theta = 0.0;
+    if (rh1 != 0.0) theta = Math.atan2(con *p.x, con *p.y);
+    var ml = this.g - rh1 /this.a;
+    var lat = this.phi3z(ml,this.e0,this.e1,this.e2,this.e3);
+    var lon = Proj4js.common.adjust_lon(this.long0 + theta / this.ns);
+     p.x=lon;
+     p.y=lat;
+     return p;
+/* Function to compute latitude, phi3, for the inverse of the Equidistant
+   Conic projection.
+  phi3z: function(ml,e0,e1,e2,e3) {
+    var phi;
+    var dphi;
+    phi = ml;
+    for (var i = 0; i < 15; i++) {
+      dphi = (ml + e1 * Math.sin(2.0 * phi) - e2 * Math.sin(4.0 * phi) + e3 * Math.sin(6.0 * phi))/ e0 - phi;
+      phi += dphi;
+      if (Math.abs(dphi) <= .0000000001) {
+        return phi;
+    Proj4js.reportError("PHI3Z-CONV:Latitude failed to converge after 15 iterations");
+    return null;
+    projCode/tmerc.js
+Proj4js.Proj.tmerc = {
+    this.ml0 = this.a * Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, this.lat0);
+    Transverse Mercator Forward  - long/lat to x/y
+    long/lat in radians
+    var lon = p.x;
+    var lat = p.y;
+    var delta_lon = Proj4js.common.adjust_lon(lon - this.long0); // Delta longitude
+    var con;    // cone constant
+    var x, y;
+    var sin_phi=Math.sin(lat);
+    var cos_phi=Math.cos(lat);
+    if (this.sphere) {  /* spherical form */
+      var b = cos_phi * Math.sin(delta_lon);
+      if ((Math.abs(Math.abs(b) - 1.0)) < .0000000001)  {
+        Proj4js.reportError("tmerc:forward: Point projects into infinity");
+        return(93);
+      } else {
+        x = .5 * this.a * this.k0 * Math.log((1.0 + b)/(1.0 - b));
+        con = Math.acos(cos_phi * Math.cos(delta_lon)/Math.sqrt(1.0 - b*b));
+        if (lat < 0) con = - con;
+        y = this.a * this.k0 * (con - this.lat0);
+    } else {
+      var al  = cos_phi * delta_lon;
+      var als = Math.pow(al,2);
+      var c   = this.ep2 * Math.pow(cos_phi,2);
+      var tq  = Math.tan(lat);
+      var t   = Math.pow(tq,2);
+      con = 1.0 - this.es * Math.pow(sin_phi,2);
+      var n   = this.a / Math.sqrt(con);
+      var ml  = this.a * Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, lat);
+      x = this.k0 * n * al * (1.0 + als / 6.0 * (1.0 - t + c + als / 20.0 * (5.0 - 18.0 * t + Math.pow(t,2) + 72.0 * c - 58.0 * this.ep2))) + this.x0;
+      y = this.k0 * (ml - this.ml0 + n * tq * (als * (0.5 + als / 24.0 * (5.0 - t + 9.0 * c + 4.0 * Math.pow(c,2) + als / 30.0 * (61.0 - 58.0 * t + Math.pow(t,2) + 600.0 * c - 330.0 * this.ep2))))) + this.y0;
+    p.x = x; p.y = y;
+    return p;
+  }, // tmercFwd()
+    Transverse Mercator Inverse  -  x/y to long/lat
+    var con, phi;  /* temporary angles       */
+    var delta_phi; /* difference between longitudes    */
+    var i;
+    var max_iter = 6;      /* maximun number of iterations */
+    var lat, lon;
+      var f = Math.exp(p.x/(this.a * this.k0));
+      var g = .5 * (f - 1/f);
+      var temp = this.lat0 + p.y/(this.a * this.k0);
+      var h = Math.cos(temp);
+      con = Math.sqrt((1.0 - h * h)/(1.0 + g * g));
+      lat = Proj4js.common.asinz(con);
+      if (temp < 0)
+        lat = -lat;
+      if ((g == 0) && (h == 0)) {
+        lon = this.long0;
+      } else {
+        lon = Proj4js.common.adjust_lon(Math.atan2(g,h) + this.long0);
+    } else {    // ellipsoidal form
+      con = (this.ml0 + y / this.k0) / this.a;
+      phi = con;
+      for (i=0;true;i++) {
+        delta_phi=((con + this.e1 * Math.sin(2.0*phi) - this.e2 * Math.sin(4.0*phi) + this.e3 * Math.sin(6.0*phi)) / this.e0) - phi;
+        phi += delta_phi;
+        if (Math.abs(delta_phi) <= Proj4js.common.EPSLN) break;
+        if (i >= max_iter) {
+          Proj4js.reportError("tmerc:inverse: Latitude failed to converge");
+          return(95);
+      } // for()
+      if (Math.abs(phi) < Proj4js.common.HALF_PI) {
+        // sincos(phi, &sin_phi, &cos_phi);
+        var sin_phi=Math.sin(phi);
+        var cos_phi=Math.cos(phi);
+        var tan_phi = Math.tan(phi);
+        var cs = Math.pow(c,2);
+        var t = Math.pow(tan_phi,2);
+        var ts = Math.pow(t,2);
+        var r = n * (1.0 - this.es) / con;
+        var d = x / (n * this.k0);
+        var ds = Math.pow(d,2);
+        lat = phi - (n * tan_phi * ds / r) * (0.5 - ds / 24.0 * (5.0 + 3.0 * t + 10.0 * c - 4.0 * cs - 9.0 * this.ep2 - ds / 30.0 * (61.0 + 90.0 * t + 298.0 * c + 45.0 * ts - 252.0 * this.ep2 - 3.0 * cs)));
+        lon = Proj4js.common.adjust_lon(this.long0 + (d * (1.0 - ds / 6.0 * (1.0 + 2.0 * t + c - ds / 20.0 * (5.0 - 2.0 * c + 28.0 * t - 3.0 * cs + 8.0 * this.ep2 + 24.0 * ts))) / cos_phi));
+      } else {
+        lat = Proj4js.common.HALF_PI * Proj4js.common.sign(y);
+        lon = this.long0;
+    p.x = lon;
+    p.y = lat;
+    return p;
+  } // tmercInv()
+    defs/GOOGLE.js
+Proj4js.defs["GOOGLE"]="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs";
+Proj4js.defs["EPSG:900913"]=Proj4js.defs["GOOGLE"];
+    projCode/gstmerc.js
+Proj4js.Proj.gstmerc = {
+    // array of:  a, b, lon0, lat0, k0, x0, y0
+      var temp= this.b / this.a;
+      this.e= Math.sqrt(1.0 - temp*temp);
+      this.lc= this.long0;
+      this.rs= Math.sqrt(1.0+this.e*this.e*Math.pow(Math.cos(this.lat0),4.0)/(1.0-this.e*this.e));
+      var sinz= Math.sin(this.lat0);
+      var pc= Math.asin(sinz/this.rs);
+      var sinzpc= Math.sin(pc);
+      this.cp= Proj4js.common.latiso(0.0,pc,sinzpc)-this.rs*Proj4js.common.latiso(this.e,this.lat0,sinz);
+      this.n2= this.k0*this.a*Math.sqrt(1.0-this.e*this.e)/(1.0-this.e*this.e*sinz*sinz);
+      this.xs= this.x0;
+      this.ys= this.y0-this.n2*pc;
+      if (!this.title) this.title = "Gauss Schreiber transverse mercator";
+    // forward equations--mapping lat,long to x,y
+      var lon= p.x;
+      var lat= p.y;
+      var L= this.rs*(lon-this.lc);
+      var Ls= this.cp+(this.rs*Proj4js.common.latiso(this.e,lat,Math.sin(lat)));
+      var lat1= Math.asin(Math.sin(L)/Proj4js.common.cosh(Ls));
+      var Ls1= Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));
+      p.x= this.xs+(this.n2*Ls1);
+      p.y= this.ys+(this.n2*Math.atan(Proj4js.common.sinh(Ls)/Math.cos(L)));
+      return p;
+  // inverse equations--mapping x,y to lat/long
+    var x= p.x;
+    var y= p.y;
+    var L= Math.atan(Proj4js.common.sinh((x-this.xs)/this.n2)/Math.cos((y-this.ys)/this.n2));
+    var lat1= Math.asin(Math.sin((y-this.ys)/this.n2)/Proj4js.common.cosh((x-this.xs)/this.n2));
+    var LC= Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));
+    p.x= this.lc+L/this.rs;
+    p.y= Proj4js.common.invlatiso(this.e,(LC-this.cp)/this.rs);
+    return p;
+    projCode/ortho.js
+NAME                             ORTHOGRAPHIC
+		Northing for the Orthographic projection.  The
+PROGRAMMER              DATE
+Proj4js.Proj.ortho = {
+  /* Initialize the Orthographic projection
+  init: function(def) {
+    //double temp;			/* temporary variable		*/
+    this.sin_p14=Math.sin(this.lat0);
+    this.cos_p14=Math.cos(this.lat0);
+  /* Orthographic forward equations--mapping lat,long to x,y
+    var dlon;		/* delta longitude value			*/
+    var coslon;		/* cos of longitude				*/
+    var ksp;		/* scale factor					*/
+    var g;
+    var lon=p.x;
+    var lat=p.y;
+    dlon = Proj4js.common.adjust_lon(lon - this.long0);
+    sinphi=Math.sin(lat);
+    cosphi=Math.cos(lat);
+    coslon = Math.cos(dlon);
+    g = this.sin_p14 * sinphi + this.cos_p14 * cosphi * coslon;
+    ksp = 1.0;
+    if ((g > 0) || (Math.abs(g) <= Proj4js.common.EPSLN)) {
+      var x = this.a * ksp * cosphi * Math.sin(dlon);
+      var y = this.y0 + this.a * ksp * (this.cos_p14 * sinphi - this.sin_p14 * cosphi * coslon);
+    } else {
+      Proj4js.reportError("orthoFwdPointError");
+    p.x=x;
+    p.y=y;
+    return p;
+    var rh;		/* height above ellipsoid			*/
+    var z;		/* angle					*/
+    var sinz,cosz;	/* sin of z and cos of z			*/
+    var temp;
+    var con;
+    var lon , lat;
+    p.x -= this.x0;
+    p.y -= this.y0;
+    rh = Math.sqrt(p.x * p.x + p.y * p.y);
+    if (rh > this.a + .0000001) {
+      Proj4js.reportError("orthoInvDataError");
+    z = Proj4js.common.asinz(rh / this.a);
+    sinz=Math.sin(z);
+    cosz=Math.cos(z);
+    lon = this.long0;
+    if (Math.abs(rh) <= Proj4js.common.EPSLN) {
+      lat = this.lat0;
+    lat = Proj4js.common.asinz(cosz * this.sin_p14 + (p.y * sinz * this.cos_p14)/rh);
+    con = Math.abs(this.lat0) - Proj4js.common.HALF_PI;
+    if (Math.abs(con) <= Proj4js.common.EPSLN) {
+       if (this.lat0 >= 0) {
+          lon = Proj4js.common.adjust_lon(this.long0 + Math.atan2(p.x, -p.y));
+       } else {
+          lon = Proj4js.common.adjust_lon(this.long0 -Math.atan2(-p.x, p.y));
+    con = cosz - this.sin_p14 * Math.sin(lat);
+    p.x=lon;
+    p.y=lat;
+    return p;
+    projCode/somerc.js
+NAME                       SWISS OBLIQUE MERCATOR
+PURPOSE:	Swiss projection.
+WARNING:  X and Y are inverted (weird) in the swiss coordinate system. Not
+   here, since we want X to be horizontal and Y vertical.
+1. "Formules et constantes pour le Calcul pour la
+ projection cylindrique conforme à axe oblique et pour la transformation entre
+ des systèmes de référence".
+ http://www.swisstopo.admin.ch/internet/swisstopo/fr/home/topics/survey/sys/refsys/switzerland.parsysrelated1.31216.downloadList.77004.DownloadFile.tmp/swissprojectionfr.pdf
+Proj4js.Proj.somerc = {
+    var phy0 = this.lat0;
+    this.lambda0 = this.long0;
+    var sinPhy0 = Math.sin(phy0);
+    var semiMajorAxis = this.a;
+    var invF = this.rf;
+    var flattening = 1 / invF;
+    var e2 = 2 * flattening - Math.pow(flattening, 2);
+    var e = this.e = Math.sqrt(e2);
+    this.R = this.k0 * semiMajorAxis * Math.sqrt(1 - e2) / (1 - e2 * Math.pow(sinPhy0, 2.0));
+    this.alpha = Math.sqrt(1 + e2 / (1 - e2) * Math.pow(Math.cos(phy0), 4.0));
+    this.b0 = Math.asin(sinPhy0 / this.alpha);
+    this.K = Math.log(Math.tan(Math.PI / 4.0 + this.b0 / 2.0))
+            - this.alpha
+            * Math.log(Math.tan(Math.PI / 4.0 + phy0 / 2.0))
+            + this.alpha
+            * e / 2
+            * Math.log((1 + e * sinPhy0)
+            / (1 - e * sinPhy0));
+    var Sa1 = Math.log(Math.tan(Math.PI / 4.0 - p.y / 2.0));
+    var Sa2 = this.e / 2.0
+            * Math.log((1 + this.e * Math.sin(p.y))
+            / (1 - this.e * Math.sin(p.y)));
+    var S = -this.alpha * (Sa1 + Sa2) + this.K;
+        // spheric latitude
+    var b = 2.0 * (Math.atan(Math.exp(S)) - Math.PI / 4.0);
+        // spheric longitude
+    var I = this.alpha * (p.x - this.lambda0);
+        // psoeudo equatorial rotation
+    var rotI = Math.atan(Math.sin(I)
+            / (Math.sin(this.b0) * Math.tan(b) +
+               Math.cos(this.b0) * Math.cos(I)));
+    var rotB = Math.asin(Math.cos(this.b0) * Math.sin(b) -
+                         Math.sin(this.b0) * Math.cos(b) * Math.cos(I));
+    p.y = this.R / 2.0
+            * Math.log((1 + Math.sin(rotB)) / (1 - Math.sin(rotB)))
+            + this.y0;
+    p.x = this.R * rotI + this.x0;
+    return p;
+    var Y = p.x - this.x0;
+    var X = p.y - this.y0;
+    var rotI = Y / this.R;
+    var rotB = 2 * (Math.atan(Math.exp(X / this.R)) - Math.PI / 4.0);
+    var b = Math.asin(Math.cos(this.b0) * Math.sin(rotB)
+            + Math.sin(this.b0) * Math.cos(rotB) * Math.cos(rotI));
+    var I = Math.atan(Math.sin(rotI)
+            / (Math.cos(this.b0) * Math.cos(rotI) - Math.sin(this.b0)
+            * Math.tan(rotB)));
+    var lambda = this.lambda0 + I / this.alpha;
+    var S = 0.0;
+    var phy = b;
+    var prevPhy = -1000.0;
+    var iteration = 0;
+    while (Math.abs(phy - prevPhy) > 0.0000001)
+      if (++iteration > 20)
+        Proj4js.reportError("omercFwdInfinity");
+        return;
+      //S = Math.log(Math.tan(Math.PI / 4.0 + phy / 2.0));
+      S = 1.0
+              / this.alpha
+              * (Math.log(Math.tan(Math.PI / 4.0 + b / 2.0)) - this.K)
+              + this.e
+              + Math.asin(this.e * Math.sin(phy))
+              / 2.0));
+      prevPhy = phy;
+      phy = 2.0 * Math.atan(Math.exp(S)) - Math.PI / 2.0;
+    p.x = lambda;
+    p.y = phy;
+    return p;
+    projCode/stere.js
+// Initialize the Stereographic projection
+Proj4js.Proj.stere = {
+  ssfn_: function(phit, sinphi, eccen) {
+  	sinphi *= eccen;
+  	return (Math.tan (.5 * (Proj4js.common.HALF_PI + phit)) * Math.pow((1. - sinphi) / (1. + sinphi), .5 * eccen));
+  TOL:	1.e-8,
+  NITER:	8,
+  CONV:	1.e-10,
+  S_POLE:	0,
+  N_POLE:	1,
+  OBLIQ:	2,
+  EQUIT:	3,
+  	this.phits = this.lat_ts ? this.lat_ts : Proj4js.common.HALF_PI;
+    var t = Math.abs(this.lat0);
+  	if ((Math.abs(t) - Proj4js.common.HALF_PI) < Proj4js.common.EPSLN) {
+  		this.mode = this.lat0 < 0. ? this.S_POLE : this.N_POLE;
+  	} else {
+  		this.mode = t > Proj4js.common.EPSLN ? this.OBLIQ : this.EQUIT;
+  	this.phits = Math.abs(this.phits);
+  	if (this.es) {
+  		var X;
+  		switch (this.mode) {
+  		case this.N_POLE:
+  		case this.S_POLE:
+  			if (Math.abs(this.phits - Proj4js.common.HALF_PI) < Proj4js.common.EPSLN) {
+  				this.akm1 = 2. * this.k0 / Math.sqrt(Math.pow(1+this.e,1+this.e)*Math.pow(1-this.e,1-this.e));
+  			} else {
+          t = Math.sin(this.phits);
+  				this.akm1 = Math.cos(this.phits) / Proj4js.common.tsfnz(this.e, this.phits, t);
+  				t *= this.e;
+  				this.akm1 /= Math.sqrt(1. - t * t);
+  			break;
+  		case this.EQUIT:
+  			this.akm1 = 2. * this.k0;
+  			break;
+  		case this.OBLIQ:
+  			t = Math.sin(this.lat0);
+  			X = 2. * Math.atan(this.ssfn_(this.lat0, t, this.e)) - Proj4js.common.HALF_PI;
+  			t *= this.e;
+  			this.akm1 = 2. * this.k0 * Math.cos(this.lat0) / Math.sqrt(1. - t * t);
+  			this.sinX1 = Math.sin(X);
+  			this.cosX1 = Math.cos(X);
+  			break;
+  	} else {
+  		case this.OBLIQ:
+  			this.sinph0 = Math.sin(this.lat0);
+  			this.cosph0 = Math.cos(this.lat0);
+  		case this.EQUIT:
+  			break;
+  		case this.S_POLE:
+  		case this.N_POLE:
+  			this.akm1 = Math.abs(this.phits - Proj4js.common.HALF_PI) >= Proj4js.common.EPSLN ?
+  			   Math.cos(this.phits) / Math.tan(Proj4js.common.FORTPI - .5 * this.phits) :
+  			   2. * this.k0 ;
+  			break;
+// Stereographic forward equations--mapping lat,long to x,y
+    var lon = p.x;
+    lon = Proj4js.common.adjust_lon(lon - this.long0);
+    var lat = p.y;
+    var x, y;
+    	var  sinphi, cosphi, coslam, sinlam;
+    	coslam = Math.cos(lon);
+    	sinlam = Math.sin(lon);
+    	case this.EQUIT:
+    		y = 1. + cosphi * coslam;
+    		if (y <= Proj4js.common.EPSLN) {
+          F_ERROR;
+        y = this.akm1 / y;
+    		x = y * cosphi * sinlam;
+        y *= sinphi;
+    		break;
+    	case this.OBLIQ:
+    		y = 1. + this.sinph0 * sinphi + this.cosph0 * cosphi * coslam;
+          F_ERROR;
+    		y *= this.cosph0 * sinphi - this.sinph0 * cosphi * coslam;
+    		break;
+    	case this.N_POLE:
+    		coslam = -coslam;
+    		lat = -lat;
+        //Note  no break here so it conitnues through S_POLE
+    	case this.S_POLE:
+    		if (Math.abs(lat - Proj4js.common.HALF_PI) < this.TOL) {
+          F_ERROR;
+        y = this.akm1 * Math.tan(Proj4js.common.FORTPI + .5 * lat);
+    		x = sinlam * y;
+    		y *= coslam;
+    		break;
+    } else {
+    	if (this.mode == this.OBLIQ || this.mode == this.EQUIT) {
+        X = 2. * Math.atan(this.ssfn_(lat, sinphi, this.e));
+    		sinX = Math.sin(X - Proj4js.common.HALF_PI);
+    		cosX = Math.cos(X);
+    	case this.OBLIQ:
+    		A = this.akm1 / (this.cosX1 * (1. + this.sinX1 * sinX + this.cosX1 * cosX * coslam));
+    		y = A * (this.cosX1 * sinX - this.sinX1 * cosX * coslam);
+    		x = A * cosX;
+    		break;
+    	case this.EQUIT:
+    		A = 2. * this.akm1 / (1. + cosX * coslam);
+    		y = A * sinX;
+    		x = A * cosX;
+    		break;
+    	case this.S_POLE:
+    		lat = -lat;
+    		coslam = - coslam;
+    		sinphi = -sinphi;
+    	case this.N_POLE:
+    		x = this.akm1 * Proj4js.common.tsfnz(this.e, lat, sinphi);
+    		y = - x * coslam;
+    		break;
+    	x = x * sinlam;
+    p.x = x*this.a + this.x0;
+    p.y = y*this.a + this.y0;
+    return p;
+//* Stereographic inverse equations--mapping x,y to lat/long
+    var x = (p.x - this.x0)/this.a;   /* descale and de-offset */
+    var y = (p.y - this.y0)/this.a;
+    var lon, lat;
+    var cosphi, sinphi, tp=0.0, phi_l=0.0, rho, halfe=0.0, pi2=0.0;
+    var i;
+    	var  c, rh, sinc, cosc;
+      rh = Math.sqrt(x*x + y*y);
+      c = 2. * Math.atan(rh / this.akm1);
+    	lon = 0.;
+    	case this.EQUIT:
+    			lat = 0.;
+    		} else {
+    			lat = Math.asin(y * sinc / rh);
+    		if (cosc != 0. || x != 0.) lon = Math.atan2(x * sinc, cosc * rh);
+    		break;
+    	case this.OBLIQ:
+    			lat = this.phi0;
+    		} else {
+    			lat = Math.asin(cosc * sinph0 + y * sinc * cosph0 / rh);
+        c = cosc - sinph0 * Math.sin(lat);
+    		if (c != 0. || x != 0.) {
+    			lon = Math.atan2(x * sinc * cosph0, c * rh);
+    		break;
+    	case this.N_POLE:
+    		y = -y;
+    	case this.S_POLE:
+    			lat = this.phi0;
+    		} else {
+    			lat = Math.asin(this.mode == this.S_POLE ? -cosc : cosc);
+    		lon = (x == 0. && y == 0.) ? 0. : Math.atan2(x, y);
+    		break;
+    } else {
+    	rho = Math.sqrt(x*x + y*y);
+    	case this.OBLIQ:
+    	case this.EQUIT:
+        tp = 2. * Math.atan2(rho * this.cosX1 , this.akm1);
+    		cosphi = Math.cos(tp);
+    		sinphi = Math.sin(tp);
+        if( rho == 0.0 ) {
+    		  phi_l = Math.asin(cosphi * this.sinX1);
+        } else {
+    		  phi_l = Math.asin(cosphi * this.sinX1 + (y * sinphi * this.cosX1 / rho));
+    		tp = Math.tan(.5 * (Proj4js.common.HALF_PI + phi_l));
+    		x *= sinphi;
+    		y = rho * this.cosX1 * cosphi - y * this.sinX1* sinphi;
+    		pi2 = Proj4js.common.HALF_PI;
+    		halfe = .5 * this.e;
+    		break;
+    	case this.N_POLE:
+    		y = -y;
+    	case this.S_POLE:
+        tp = - rho / this.akm1;
+    		phi_l = Proj4js.common.HALF_PI - 2. * Math.atan(tp);
+    		pi2 = -Proj4js.common.HALF_PI;
+    		halfe = -.5 * this.e;
+    		break;
+    	for (i = this.NITER; i--; phi_l = lat) { //check this
+    		sinphi = this.e * Math.sin(phi_l);
+    		lat = 2. * Math.atan(tp * Math.pow((1.+sinphi)/(1.-sinphi), halfe)) - pi2;
+    		if (Math.abs(phi_l - lat) < this.CONV) {
+    			if (this.mode == this.S_POLE) lat = -lat;
+          p.x = Proj4js.common.adjust_lon(lon + this.long0);
+          p.y = lat;
+    			return p;
+    projCode/nzmg.js
+NAME                            NEW ZEALAND MAP GRID
+		Northing for the New Zealand Map Grid projection.  The
+1.  Department of Land and Survey Technical Circular 1973/32
+      http://www.linz.govt.nz/docs/miscellaneous/nz-map-definition.pdf
+2.  OSG Technical Report 4.1
+      http://www.linz.govt.nz/docs/miscellaneous/nzmg.pdf
+IMPLEMENTATION NOTES
+The two references use different symbols for the calculated values. This
+implementation uses the variable names similar to the symbols in reference [1].
+The alogrithm uses different units for delta latitude and delta longitude.
+The delta latitude is assumed to be in units of seconds of arc x 10^-5.
+The delta longitude is the usual radians. Look out for these conversions.
+The algorithm is described using complex arithmetic. There were three
+options:
+   * find and use a Javascript library for complex arithmetic
+   * write my own complex library
+   * expand the complex arithmetic by hand to simple arithmetic
+This implementation has expanded the complex multiplication operations
+into parallel simple arithmetic operations for the real and imaginary parts.
+The imaginary part is way over to the right of the display; this probably
+violates every coding standard in the world, but, to me, it makes it much
+more obvious what is going on.
+The following complex operations are used:
+   - addition
+   - multiplication
+   - division
+   - complex number raised to integer power
+   - summation
+A summary of complex arithmetic operations:
+   (from http://en.wikipedia.org/wiki/Complex_arithmetic)
+   addition:       (a + bi) + (c + di) = (a + c) + (b + d)i
+   subtraction:    (a + bi) - (c + di) = (a - c) + (b - d)i
+   multiplication: (a + bi) x (c + di) = (ac - bd) + (bc + ad)i
+   division:       (a + bi) / (c + di) = [(ac + bd)/(cc + dd)] + [(bc - ad)/(cc + dd)]i
+The algorithm needs to calculate summations of simple and complex numbers. This is
+implemented using a for-loop, pre-loading the summed value to zero.
+The algorithm needs to calculate theta^2, theta^3, etc while doing a summation.
+There are three possible implementations:
+   - use Math.pow in the summation loop - except for complex numbers
+   - precalculate the values before running the loop
+   - calculate theta^n = theta^(n-1) * theta during the loop
+This implementation uses the third option for both real and complex arithmetic.
+For example
+   psi_n = 1;
+   sum = 0;
+   for (n = 1; n <=6; n++) {
+      psi_n1 = psi_n * psi;       // calculate psi^(n+1)
+      psi_n = psi_n1;
+      sum = sum + A[n] * psi_n;
+TEST VECTORS
+NZMG E, N:         2487100.638      6751049.719     metres
+NZGD49 long, lat:      172.739194       -34.444066  degrees
+NZMG E, N:         2486533.395      6077263.661     metres
+NZGD49 long, lat:      172.723106       -40.512409  degrees
+NZMG E, N:         2216746.425      5388508.765     metres
+NZGD49 long, lat:      169.172062       -46.651295  degrees
+Note that these test vectors convert from NZMG metres to lat/long referenced
+to NZGD49, not the more usual WGS84. The difference is about 70m N/S and about
+10m E/W.
+These test vectors are provided in reference [1]. Many more test
+vectors are available in
+   http://www.linz.govt.nz/docs/topography/topographicdata/placenamesdatabase/nznamesmar08.zip
+which is a catalog of names on the 260-series maps.
+EPSG CODES
+NZMG     EPSG:27200
+NZGD49   EPSG:4272
+http://spatialreference.org/ defines these as
+  Proj4js.defs["EPSG:4272"] = "+proj=longlat +ellps=intl +datum=nzgd49 +no_defs ";
+  Proj4js.defs["EPSG:27200"] = "+proj=nzmg +lat_0=-41 +lon_0=173 +x_0=2510000 +y_0=6023150 +ellps=intl +datum=nzgd49 +units=m +no_defs ";
+LICENSE
+  Copyright: Stephen Irons 2008
+  Released under terms of the LGPL as per: http://www.gnu.org/copyleft/lesser.html
+  Initialize New Zealand Map Grip projection
+Proj4js.Proj.nzmg = {
+   * iterations: Number of iterations to refine inverse transform.
+   *     0 -> km accuracy
+   *     1 -> m accuracy -- suitable for most mapping applications
+   *     2 -> mm accuracy
+  iterations: 1,
+    this.A = new Array();
+    this.A[1]  = +0.6399175073;
+    this.A[2]  = -0.1358797613;
+    this.A[3]  = +0.063294409;
+    this.A[4]  = -0.02526853;
+    this.A[5]  = +0.0117879;
+    this.A[6]  = -0.0055161;
+    this.A[7]  = +0.0026906;
+    this.A[8]  = -0.001333;
+    this.A[9]  = +0.00067;
+    this.A[10] = -0.00034;
+    this.B_re = new Array();        this.B_im = new Array();
+    this.B_re[1] = +0.7557853228;   this.B_im[1] =  0.0;
+    this.B_re[2] = +0.249204646;    this.B_im[2] = +0.003371507;
+    this.B_re[3] = -0.001541739;    this.B_im[3] = +0.041058560;
+    this.B_re[4] = -0.10162907;     this.B_im[4] = +0.01727609;
+    this.B_re[5] = -0.26623489;     this.B_im[5] = -0.36249218;
+    this.B_re[6] = -0.6870983;      this.B_im[6] = -1.1651967;
+    this.C_re = new Array();        this.C_im = new Array();
+    this.C_re[1] = +1.3231270439;   this.C_im[1] =  0.0;
+    this.C_re[2] = -0.577245789;    this.C_im[2] = -0.007809598;
+    this.C_re[3] = +0.508307513;    this.C_im[3] = -0.112208952;
+    this.C_re[4] = -0.15094762;     this.C_im[4] = +0.18200602;
+    this.C_re[5] = +1.01418179;     this.C_im[5] = +1.64497696;
+    this.C_re[6] = +1.9660549;      this.C_im[6] = +2.5127645;
+    this.D = new Array();
+    this.D[1] = +1.5627014243;
+    this.D[2] = +0.5185406398;
+    this.D[3] = -0.03333098;
+    this.D[4] = -0.1052906;
+    this.D[5] = -0.0368594;
+    this.D[6] = +0.007317;
+    this.D[7] = +0.01220;
+    this.D[8] = +0.00394;
+    this.D[9] = -0.0013;
+    New Zealand Map Grid Forward  - long/lat to x/y
+    var lon = p.x;
+    var lat = p.y;
+    var delta_lat = lat - this.lat0;
+    var delta_lon = lon - this.long0;
+    // 1. Calculate d_phi and d_psi    ...                          // and d_lambda
+    // For this algorithm, delta_latitude is in seconds of arc x 10-5, so we need to scale to those units. Longitude is radians.
+    var d_phi = delta_lat / Proj4js.common.SEC_TO_RAD * 1E-5;       var d_lambda = delta_lon;
+    var d_phi_n = 1;  // d_phi^0
+    var d_psi = 0;
+    for (n = 1; n <= 10; n++) {
+      d_phi_n = d_phi_n * d_phi;
+      d_psi = d_psi + this.A[n] * d_phi_n;
+    // 2. Calculate theta
+    var th_re = d_psi;                                              var th_im = d_lambda;
+    // 3. Calculate z
+    var th_n_re = 1;                                                var th_n_im = 0;  // theta^0
+    var th_n_re1;                                                   var th_n_im1;
+    var z_re = 0;                                                   var z_im = 0;
+    for (n = 1; n <= 6; n++) {
+      th_n_re1 = th_n_re*th_re - th_n_im*th_im;                     th_n_im1 = th_n_im*th_re + th_n_re*th_im;
+      th_n_re = th_n_re1;                                           th_n_im = th_n_im1;
+      z_re = z_re + this.B_re[n]*th_n_re - this.B_im[n]*th_n_im;    z_im = z_im + this.B_im[n]*th_n_re + this.B_re[n]*th_n_im;
+    // 4. Calculate easting and northing
+    x = (z_im * this.a) + this.x0;
+    y = (z_re * this.a) + this.y0;
+    p.x = x; p.y = y;
+    return p;
+    New Zealand Map Grid Inverse  -  x/y to long/lat
+    var x = p.x;
+    var y = p.y;
+    var delta_x = x - this.x0;
+    var delta_y = y - this.y0;
+    // 1. Calculate z
+    var z_re = delta_y / this.a;                                              var z_im = delta_x / this.a;
+    // 2a. Calculate theta - first approximation gives km accuracy
+    var z_n_re = 1;                                                           var z_n_im = 0;  // z^0
+    var z_n_re1;                                                              var z_n_im1;
+    var th_re = 0;                                                            var th_im = 0;
+      z_n_re1 = z_n_re*z_re - z_n_im*z_im;                                    z_n_im1 = z_n_im*z_re + z_n_re*z_im;
+      z_n_re = z_n_re1;                                                       z_n_im = z_n_im1;
+      th_re = th_re + this.C_re[n]*z_n_re - this.C_im[n]*z_n_im;              th_im = th_im + this.C_im[n]*z_n_re + this.C_re[n]*z_n_im;
+    // 2b. Iterate to refine the accuracy of the calculation
+    //        0 iterations gives km accuracy
+    //        1 iteration gives m accuracy -- good enough for most mapping applications
+    //        2 iterations bives mm accuracy
+    for (i = 0; i < this.iterations; i++) {
+       var th_n_re = th_re;                                                      var th_n_im = th_im;
+       var num_re = z_re;                                                        var num_im = z_im;
+       for (n = 2; n <= 6; n++) {
+         num_re = num_re + (n-1)*(this.B_re[n]*th_n_re - this.B_im[n]*th_n_im);  num_im = num_im + (n-1)*(this.B_im[n]*th_n_re + this.B_re[n]*th_n_im);
+       th_n_re = 1;                                                              th_n_im = 0;
+       var den_re = this.B_re[1];                                                var den_im = this.B_im[1];
+         den_re = den_re + n * (this.B_re[n]*th_n_re - this.B_im[n]*th_n_im);    den_im = den_im + n * (this.B_im[n]*th_n_re + this.B_re[n]*th_n_im);
+       // Complex division
+       var den2 = den_re*den_re + den_im*den_im;
+       th_re = (num_re*den_re + num_im*den_im) / den2;                           th_im = (num_im*den_re - num_re*den_im) / den2;
+    // 3. Calculate d_phi              ...                                    // and d_lambda
+    var d_psi = th_re;                                                        var d_lambda = th_im;
+    var d_psi_n = 1;  // d_psi^0
+    var d_phi = 0;
+    for (n = 1; n <= 9; n++) {
+       d_psi_n = d_psi_n * d_psi;
+       d_phi = d_phi + this.D[n] * d_psi_n;
+    // 4. Calculate latitude and longitude
+    // d_phi is calcuated in second of arc * 10^-5, so we need to scale back to radians. d_lambda is in radians.
+    var lat = this.lat0 + (d_phi * Proj4js.common.SEC_TO_RAD * 1E5);
+    var lon = this.long0 +  d_lambda;
+    p.x = lon;
+    p.y = lat;
+    return p;
+    projCode/mill.js
+NAME                    MILLER CYLINDRICAL
+		Northing for the Miller Cylindrical projection.  The
+PROGRAMMER              DATE
+T. Mittan		March, 1993
+This function was adapted from the Lambert Azimuthal Equal Area projection
+code (FORTRAN) in the General Cartographic Transformation Package software
+which is available from the U.S. Geological Survey National Mapping Division.
+1.  "New Equal-Area Map Projections for Noncircular Regions", John P. Snyder,
+    The American Cartographer, Vol 15, No. 4, October 1988, pp. 341-355.
+2.  Snyder, John P., "Map Projections--A Working Manual", U.S. Geological
+3.  "Software Documentation for GCTP General Cartographic Transformation
+    Package", U.S. Geological Survey National Mapping Division, May 1982.
+Proj4js.Proj.mill = {
+/* Initialize the Miller Cylindrical projection
+  init: function() {
+    //no-op
+  /* Miller Cylindrical forward equations--mapping lat,long to x,y
+    var lon=p.x;
+    var lat=p.y;
+    var dlon = Proj4js.common.adjust_lon(lon -this.long0);
+    var x = this.x0 + this.a * dlon;
+    var y = this.y0 + this.a * Math.log(Math.tan((Proj4js.common.PI / 4.0) + (lat / 2.5))) * 1.25;
+    p.x=x;
+    p.y=y;
+    return p;
+  },//millFwd()
+  /* Miller Cylindrical inverse equations--mapping x,y to lat/long
+    p.x -= this.x0;
+    p.y -= this.y0;
+    var lon = Proj4js.common.adjust_lon(this.long0 + p.x /this.a);
+    var lat = 2.5 * (Math.atan(Math.exp(0.8*p.y/this.a)) - Proj4js.common.PI / 4.0);
+    p.x=lon;
+    p.y=lat;
+    return p;
+  }//millInv()
+    projCode/gnom.js
+NAME                             GNOMONIC
+		Northing for the Gnomonic Projection.
+                Implementation based on the existing sterea and ortho
+                implementations.
+PROGRAMMER              DATE
+Richard Marsden         November 2009
+1.  Snyder, John P., "Flattening the Earth - Two Thousand Years of Map
+    Projections", University of Chicago Press 1993
+2.  Wolfram Mathworld "Gnomonic Projection"
+    http://mathworld.wolfram.com/GnomonicProjection.html
+    Accessed: 12th November 2009
+Proj4js.Proj.gnom = {
+  /* Initialize the Gnomonic projection
+    // Approximation for projecting points to the horizon (infinity)
+    this.infinity_dist = 1000 * this.a;
+    this.rc = 1;
+  /* Gnomonic forward equations--mapping lat,long to x,y
+    var g;
+    var lon=p.x;
+    var lat=p.y;
+    ksp = 1.0;
+      x = this.x0 + this.a * ksp * cosphi * Math.sin(dlon) / g;
+      y = this.y0 + this.a * ksp * (this.cos_p14 * sinphi - this.sin_p14 * cosphi * coslon) / g;
+    } else {
+      // Point is in the opposing hemisphere and is unprojectable
+      // We still need to return a reasonable point, so we project
+      // to infinity, on a bearing
+      // equivalent to the northern hemisphere equivalent
+      // This is a reasonable approximation for short shapes and lines that
+      // straddle the horizon.
+      x = this.x0 + this.infinity_dist * cosphi * Math.sin(dlon);
+      y = this.y0 + this.infinity_dist * (this.cos_p14 * sinphi - this.sin_p14 * cosphi * coslon);
+    p.x=x;
+    p.y=y;
+    return p;
+    var rh;		/* Rho */
+    var sinc, cosc;
+    var c;
+    var lon , lat;
+    p.x /= this.k0;
+    p.y /= this.k0;
+    if ( (rh = Math.sqrt(p.x * p.x + p.y * p.y)) ) {
+      c = Math.atan2(rh, this.rc);
+      lat = Proj4js.common.asinz(cosc*this.sin_p14 + (p.y*sinc*this.cos_p14) / rh);
+      lon = Math.atan2(p.x*sinc, rh*this.cos_p14*cosc - p.y*this.sin_p14*sinc);
+      lon = Proj4js.common.adjust_lon(this.long0+lon);
+    } else {
+      lat = this.phic0;
+      lon = 0.0;
+    p.x=lon;
+    p.y=lat;
+    return p;
+    projCode/sinu.js
+NAME                  		SINUSOIDAL
+		Northing for the Sinusoidal projection.  The
+PROGRAMMER              DATE
+D. Steinwand, EROS      May, 1991
+This function was adapted from the Sinusoidal projection code (FORTRAN) in the
+General Cartographic Transformation Package software which is available from
+the U.S. Geological Survey National Mapping Division.
+2.  "Software Documentation for GCTP General Cartographic Transformation
+Proj4js.Proj.sinu = {
+	/* Initialize the Sinusoidal projection
+		this.R = 6370997.0; //Radius of earth
+	/* Sinusoidal forward equations--mapping lat,long to x,y
+		var x,y,delta_lon;
+		var lon=p.x;
+		var lat=p.y;
+		delta_lon = Proj4js.common.adjust_lon(lon - this.long0);
+		x = this.R * delta_lon * Math.cos(lat) + this.x0;
+		y = this.R * lat + this.y0;
+		p.x=x;
+		p.y=y;
+		return p;
+		var lat,temp,lon;
+		p.x -= this.x0;
+		p.y -= this.y0;
+		lat = p.y / this.R;
+		if (Math.abs(lat) > Proj4js.common.HALF_PI) {
+		    Proj4js.reportError("sinu:Inv:DataError");
+		temp = Math.abs(lat) - Proj4js.common.HALF_PI;
+		if (Math.abs(temp) > Proj4js.common.EPSLN) {
+			temp = this.long0+ p.x / (this.R *Math.cos(lat));
+			lon = Proj4js.common.adjust_lon(temp);
+		} else {
+			lon = this.long0;
+		p.x=lon;
+		p.y=lat;
+		return p;
+    projCode/vandg.js
+NAME                    VAN DER GRINTEN
+PURPOSE:	Transforms input Easting and Northing to longitude and
+		latitude for the Van der Grinten projection.  The
+		Easting and Northing must be in meters.  The longitude
+		and latitude values will be returned in radians.
+PROGRAMMER              DATE
+This function was adapted from the Van Der Grinten projection code
+(FORTRAN) in the General Cartographic Transformation Package software
+Proj4js.Proj.vandg = {
+/* Initialize the Van Der Grinten projection
+		var lon=p.x;
+		var lat=p.y;
+		var x,y;
+		if (Math.abs(lat) <= Proj4js.common.EPSLN) {
+			x = this.x0  + this.R * dlon;
+			y = this.y0;
+		var theta = Proj4js.common.asinz(2.0 * Math.abs(lat / Proj4js.common.PI));
+		if ((Math.abs(dlon) <= Proj4js.common.EPSLN) || (Math.abs(Math.abs(lat) - Proj4js.common.HALF_PI) <= Proj4js.common.EPSLN)) {
+			x = this.x0;
+			if (lat >= 0) {
+				y = this.y0 + Proj4js.common.PI * this.R * Math.tan(.5 * theta);
+			} else {
+				y = this.y0 + Proj4js.common.PI * this.R * - Math.tan(.5 * theta);
+			//  return(OK);
+		var al = .5 * Math.abs((Proj4js.common.PI / dlon) - (dlon / Proj4js.common.PI));
+		var asq = al * al;
+		var sinth = Math.sin(theta);
+		var costh = Math.cos(theta);
+		var g = costh / (sinth + costh - 1.0);
+		var gsq = g * g;
+		var m = g * (2.0 / sinth - 1.0);
+		var msq = m * m;
+		var con = Proj4js.common.PI * this.R * (al * (g - msq) + Math.sqrt(asq * (g - msq) * (g - msq) - (msq + asq) * (gsq - msq))) / (msq + asq);
+		if (dlon < 0) {
+		 con = -con;
+		x = this.x0 + con;
+		con = Math.abs(con / (Proj4js.common.PI * this.R));
+		if (lat >= 0) {
+		 y = this.y0 + Proj4js.common.PI * this.R * Math.sqrt(1.0 - con * con - 2.0 * al * con);
+		} else {
+		 y = this.y0 - Proj4js.common.PI * this.R * Math.sqrt(1.0 - con * con - 2.0 * al * con);
+		p.x = x;
+		p.y = y;
+		return p;
+/* Van Der Grinten inverse equations--mapping x,y to lat/long
+		var dlon;
+		var xx,yy,xys,c1,c2,c3;
+		var al,asq;
+		var a1;
+		var m1;
+		var con;
+		var th1;
+		var d;
+		/* inverse equations
+		p.x -= this.x0;
+		p.y -= this.y0;
+		con = Proj4js.common.PI * this.R;
+		xx = p.x / con;
+		yy =p.y / con;
+		xys = xx * xx + yy * yy;
+		c1 = -Math.abs(yy) * (1.0 + xys);
+		c2 = c1 - 2.0 * yy * yy + xx * xx;
+		c3 = -2.0 * c1 + 1.0 + 2.0 * yy * yy + xys * xys;
+		d = yy * yy / c3 + (2.0 * c2 * c2 * c2 / c3 / c3 / c3 - 9.0 * c1 * c2 / c3 /c3) / 27.0;
+		a1 = (c1 - c2 * c2 / 3.0 / c3) / c3;
+		m1 = 2.0 * Math.sqrt( -a1 / 3.0);
+		con = ((3.0 * d) / a1) / m1;
+		if (Math.abs(con) > 1.0) {
+			if (con >= 0.0) {
+				con = 1.0;
+			} else {
+				con = -1.0;
+		th1 = Math.acos(con) / 3.0;
+		if (p.y >= 0) {
+			lat = (-m1 *Math.cos(th1 + Proj4js.common.PI / 3.0) - c2 / 3.0 / c3) * Proj4js.common.PI;
+		} else {
+			lat = -(-m1 * Math.cos(th1 + Proj4js.common.PI / 3.0) - c2 / 3.0 / c3) * Proj4js.common.PI;
+		if (Math.abs(xx) < Proj4js.common.EPSLN) {
+			lon = this.long0;
+		lon = Proj4js.common.adjust_lon(this.long0 + Proj4js.common.PI * (xys - 1.0 + Math.sqrt(1.0 + 2.0 * (xx * xx - yy * yy) + xys * xys)) / 2.0 / xx);
+		p.x=lon;
+		p.y=lat;
+		return p;
+    projCode/cea.js
+NAME                    LAMBERT CYLINDRICAL EQUAL AREA
+		Northing for the Lambert Cylindrical Equal Area projection.
+                This class of projection includes the Behrmann and
+                Gall-Peters Projections.  The
+PROGRAMMER              DATE
+R. Marsden              August 2009
+Winwaed Software Tech LLC, http://www.winwaed.com
+This function was adapted from the Miller Cylindrical Projection in the Proj4JS
+library.
+Note: This implementation assumes a Spherical Earth. The (commented) code
+has been included for the ellipsoidal forward transform, but derivation of
+the ellispoidal inverse transform is beyond me. Note that most of the
+Proj4JS implementations do NOT currently support ellipsoidal figures.
+Therefore this is not seen as a problem - especially this lack of support
+is explicitly stated here.
+1.  "Cartographic Projection Procedures for the UNIX Environment -
+     A User's Manual" by Gerald I. Evenden, USGS Open File Report 90-284
+    and Release 4 Interim Reports (2003)
+2.  Snyder, John P., "Flattening the Earth - Two Thousand Years of Map
+    Projections", Univ. Chicago Press, 1993
+Proj4js.Proj.cea = {
+/* Initialize the Cylindrical Equal Area projection
+    //no-op
+  /* Cylindrical Equal Area forward equations--mapping lat,long to x,y
+    var lon=p.x;
+    var lat=p.y;
+    dlon = Proj4js.common.adjust_lon(lon -this.long0);
+    var x = this.x0 + this.a * dlon * Math.cos(this.lat_ts);
+    var y = this.y0 + this.a * Math.sin(lat) / Math.cos(this.lat_ts);
+   /* Elliptical Forward Transform
+      Not implemented due to a lack of a matchign inverse function
+      var Sin_Lat = Math.sin(lat);
+      var Rn = this.a * (Math.sqrt(1.0e0 - this.es * Sin_Lat * Sin_Lat ));
+      x = this.x0 + this.a * dlon * Math.cos(this.lat_ts);
+      y = this.y0 + Rn * Math.sin(lat) / Math.cos(this.lat_ts);
+    p.x=x;
+    p.y=y;
+    return p;
+  },//ceaFwd()
+  /* Cylindrical Equal Area inverse equations--mapping x,y to lat/long
+    p.x -= this.x0;
+    p.y -= this.y0;
+    var lon = Proj4js.common.adjust_lon( this.long0 + (p.x / this.a) / Math.cos(this.lat_ts) );
+    var lat = Math.asin( (p.y/this.a) * Math.cos(this.lat_ts) );
+    p.x=lon;
+    p.y=lat;
+    return p;
+  }//ceaInv()
+    projCode/eqc.js
+/* similar to equi.js FIXME proj4 uses eqc */
+Proj4js.Proj.eqc = {
+      if(!this.lat_ts) this.lat_ts=0;
+      if (!this.title) this.title = "Equidistant Cylindrical (Plate Carre)";
+      this.rc= Math.cos(this.lat_ts);
+      var lon= p.x;
+      var lat= p.y;
+      var dlat = Proj4js.common.adjust_lat(lat - this.lat0 );
+      p.x= this.x0 + (this.a*dlon*this.rc);
+      p.y= this.y0 + (this.a*dlat        );
+      return p;
+    var x= p.x;
+    var y= p.y;
+    p.x= Proj4js.common.adjust_lon(this.long0 + ((x - this.x0)/(this.a*this.rc)));
+    p.y= Proj4js.common.adjust_lat(this.lat0  + ((y - this.y0)/(this.a        )));
+    return p;
+    projCode/cass.js
+NAME                            CASSINI
+		Northing for the Cassini projection.  The
+    Ported from PROJ.4.
+//Proj4js.defs["EPSG:28191"] = "+proj=cass +lat_0=31.73409694444445 +lon_0=35.21208055555556 +x_0=170251.555 +y_0=126867.909 +a=6378300.789 +b=6356566.435 +towgs84=-275.722,94.7824,340.894,-8.001,-4.42,-11.821,1 +units=m +no_defs";
+// Initialize the Cassini projection
+Proj4js.Proj.cass = {
+    if (!this.sphere) {
+      this.en = this.pj_enfn(this.es)
+      this.m0 = this.pj_mlfn(this.lat0, Math.sin(this.lat0), Math.cos(this.lat0), this.en);
+  C1:	.16666666666666666666,
+  C2:	.00833333333333333333,
+  C3:	.04166666666666666666,
+  C4:	.33333333333333333333,
+  C5:	.06666666666666666666,
+/* Cassini forward equations--mapping lat,long to x,y
+    var x,y;
+    var lam=p.x;
+    var phi=p.y;
+    lam = Proj4js.common.adjust_lon(lam - this.long0);
+      x = Math.asin(Math.cos(phi) * Math.sin(lam));
+      y = Math.atan2(Math.tan(phi) , Math.cos(lam)) - this.phi0;
+    } else {
+        //ellipsoid
+      this.n = Math.sin(phi);
+      this.c = Math.cos(phi);
+      y = this.pj_mlfn(phi, this.n, this.c, this.en);
+      this.n = 1./Math.sqrt(1. - this.es * this.n * this.n);
+      this.tn = Math.tan(phi);
+      this.t = this.tn * this.tn;
+      this.a1 = lam * this.c;
+      this.c *= this.es * this.c / (1 - this.es);
+      this.a2 = this.a1 * this.a1;
+      x = this.n * this.a1 * (1. - this.a2 * this.t * (this.C1 - (8. - this.t + 8. * this.c) * this.a2 * this.C2));
+      y -= this.m0 - this.n * this.tn * this.a2 * (.5 + (5. - this.t + 6. * this.c) * this.a2 * this.C3);
+    p.x = this.a*x + this.x0;
+    p.y = this.a*y + this.y0;
+    return p;
+  },//cassFwd()
+    p.x -= this.x0;
+    p.y -= this.y0;
+    var x = p.x/this.a;
+    var y = p.y/this.a;
+      this.dd = y + this.lat0;
+      phi = Math.asin(Math.sin(this.dd) * Math.cos(x));
+      lam = Math.atan2(Math.tan(x), Math.cos(this.dd));
+    } else {
+      /* ellipsoid */
+      ph1 = this.pj_inv_mlfn(this.m0 + y, this.es, this.en);
+      this.tn = Math.tan(ph1);
+      this.n = Math.sin(ph1);
+      this.r = 1. / (1. - this.es * this.n * this.n);
+      this.n = Math.sqrt(this.r);
+      this.r *= (1. - this.es) * this.n;
+      this.dd = x / this.n;
+      this.d2 = this.dd * this.dd;
+      phi = ph1 - (this.n * this.tn / this.r) * this.d2 * (.5 - (1. + 3. * this.t) * this.d2 * this.C3);
+      lam = this.dd * (1. + this.t * this.d2 * (-this.C4 + (1. + 3. * this.t) * this.d2 * this.C5)) / Math.cos(ph1);
+    p.x = Proj4js.common.adjust_lon(this.long0+lam);
+    p.y = phi;
+    return p;
+  },//lamazInv()
+  //code from the PROJ.4 pj_mlfn.c file;  this may be useful for other projections
+  pj_enfn: function(es) {
+    en = new Array();
+    en[0] = this.C00 - es * (this.C02 + es * (this.C04 + es * (this.C06 + es * this.C08)));
+    en[1] = es * (this.C22 - es * (this.C04 + es * (this.C06 + es * this.C08)));
+    var t = es * es;
+    en[2] = t * (this.C44 - es * (this.C46 + es * this.C48));
+    t *= es;
+    en[3] = t * (this.C66 - es * this.C68);
+    en[4] = t * es * this.C88;
+    return en;
+  pj_mlfn: function(phi, sphi, cphi, en) {
+    cphi *= sphi;
+    sphi *= sphi;
+    return(en[0] * phi - cphi * (en[1] + sphi*(en[2]+ sphi*(en[3] + sphi*en[4]))));
+  pj_inv_mlfn: function(arg, es, en) {
+    k = 1./(1.-es);
+    phi = arg;
+    for (i = Proj4js.common.MAX_ITER; i ; --i) { /* rarely goes over 2 iterations */
+      s = Math.sin(phi);
+      t = 1. - es * s * s;
+      //t = this.pj_mlfn(phi, s, Math.cos(phi), en) - arg;
+      //phi -= t * (t * Math.sqrt(t)) * k;
+      t = (this.pj_mlfn(phi, s, Math.cos(phi), en) - arg) * (t * Math.sqrt(t)) * k;
+      phi -= t;
+      if (Math.abs(t) < Proj4js.common.EPSLN)
+        return phi;
+    Proj4js.reportError("cass:pj_inv_mlfn: Convergence error");
+    return phi;
+/* meridinal distance for ellipsoid and inverse
+**	8th degree - accurate to < 1e-5 meters when used in conjuction
+**		with typical major axis values.
+**	Inverse determines phi to EPS (1e-11) radians, about 1e-6 seconds.
+  C00: 1.0,
+  C02: .25,
+  C04: .046875,
+  C06: .01953125,
+  C08: .01068115234375,
+  C22: .75,
+  C44: .46875,
+  C46: .01302083333333333333,
+  C48: .00712076822916666666,
+  C66: .36458333333333333333,
+  C68: .00569661458333333333,
+  C88: .3076171875
+    projCode/gauss.js
+Proj4js.Proj.gauss = {
+    sphi = Math.sin(this.lat0);
+    cphi = Math.cos(this.lat0);
+    cphi *= cphi;
+    this.rc = Math.sqrt(1.0 - this.es) / (1.0 - this.es * sphi * sphi);
+    this.C = Math.sqrt(1.0 + this.es * cphi * cphi / (1.0 - this.es));
+    this.phic0 = Math.asin(sphi / this.C);
+    this.ratexp = 0.5 * this.C * this.e;
+    this.K = Math.tan(0.5 * this.phic0 + Proj4js.common.FORTPI) / (Math.pow(Math.tan(0.5*this.lat0 + Proj4js.common.FORTPI), this.C) * Proj4js.common.srat(this.e*sphi, this.ratexp));
+    var lon = p.x;
+    var lat = p.y;
+    p.y = 2.0 * Math.atan( this.K * Math.pow(Math.tan(0.5 * lat + Proj4js.common.FORTPI), this.C) * Proj4js.common.srat(this.e * Math.sin(lat), this.ratexp) ) - Proj4js.common.HALF_PI;
+    p.x = this.C * lon;
+    return p;
+    var DEL_TOL = 1e-14;
+    var lon = p.x / this.C;
+    var lat = p.y;
+    num = Math.pow(Math.tan(0.5 * lat + Proj4js.common.FORTPI)/this.K, 1./this.C);
+    for (var i = Proj4js.common.MAX_ITER; i>0; --i) {
+      lat = 2.0 * Math.atan(num * Proj4js.common.srat(this.e * Math.sin(p.y), -0.5 * this.e)) - Proj4js.common.HALF_PI;
+      if (Math.abs(lat - p.y) < DEL_TOL) break;
+      p.y = lat;
+    /* convergence failed */
+    if (!i) {
+      Proj4js.reportError("gauss:inverse:convergence failed");
+      return null;
+    p.x = lon;
+    p.y = lat;
+    return p;
+    projCode/omerc.js
+NAME                       OBLIQUE MERCATOR (HOTINE)
+		Northing for the Oblique Mercator projection.  The
+PROGRAMMER              DATE
+Proj4js.Proj.omerc = {
+  /* Initialize the Oblique Mercator  projection
+    if (!this.mode) this.mode=0;
+    if (!this.lon1)   {this.lon1=0;this.mode=1;}
+    if (!this.lon2)   this.lon2=0;
+    if (!this.lat2)    this.lat2=0;
+    var temp = this.b/ this.a;
+    var es = 1.0 - Math.pow(temp,2);
+    var e = Math.sqrt(es);
+    this.sin_p20=Math.sin(this.lat0);
+    this.cos_p20=Math.cos(this.lat0);
+    this.con = 1.0 - this.es * this.sin_p20 * this.sin_p20;
+    this.com = Math.sqrt(1.0 - es);
+    this.bl = Math.sqrt(1.0 + this.es * Math.pow(this.cos_p20,4.0)/(1.0 - es));
+    this.al = this.a * this.bl * this.k0 * this.com / this.con;
+    if (Math.abs(this.lat0) < Proj4js.common.EPSLN) {
+       this.ts = 1.0;
+       this.d = 1.0;
+       this.el = 1.0;
+    } else {
+       this.ts = Proj4js.common.tsfnz(this.e,this.lat0,this.sin_p20);
+       this.con = Math.sqrt(this.con);
+       this.d = this.bl * this.com / (this.cos_p20 * this.con);
+       if ((this.d * this.d - 1.0) > 0.0) {
+          if (this.lat0 >= 0.0) {
+             this.f = this.d + Math.sqrt(this.d * this.d - 1.0);
+          } else {
+             this.f = this.d - Math.sqrt(this.d * this.d - 1.0);
+       } else {
+         this.f = this.d;
+       this.el = this.f * Math.pow(this.ts,this.bl);
+    //this.longc=52.60353916666667;
+       this.g = .5 * (this.f - 1.0/this.f);
+       this.gama = Proj4js.common.asinz(Math.sin(this.alpha) / this.d);
+       this.longc= this.longc - Proj4js.common.asinz(this.g * Math.tan(this.gama))/this.bl;
+       /* Report parameters common to format B
+       //genrpt(azimuth * R2D,"Azimuth of Central Line:    ");
+       //cenlon(lon_origin);
+      // cenlat(lat_origin);
+       this.con = Math.abs(this.lat0);
+       if ((this.con > Proj4js.common.EPSLN) && (Math.abs(this.con - Proj4js.common.HALF_PI) > Proj4js.common.EPSLN)) {
+            this.singam=Math.sin(this.gama);
+            this.cosgam=Math.cos(this.gama);
+            this.sinaz=Math.sin(this.alpha);
+            this.cosaz=Math.cos(this.alpha);
+            if (this.lat0>= 0) {
+               this.u =  (this.al / this.bl) * Math.atan(Math.sqrt(this.d*this.d - 1.0)/this.cosaz);
+            } else {
+               this.u =  -(this.al / this.bl) *Math.atan(Math.sqrt(this.d*this.d - 1.0)/this.cosaz);
+          } else {
+            Proj4js.reportError("omerc:Init:DataError");
+       } else {
+       this.sinphi =Math. sin(this.at1);
+       this.ts1 = Proj4js.common.tsfnz(this.e,this.lat1,this.sinphi);
+       this.sinphi = Math.sin(this.lat2);
+       this.ts2 = Proj4js.common.tsfnz(this.e,this.lat2,this.sinphi);
+       this.h = Math.pow(this.ts1,this.bl);
+       this.l = Math.pow(this.ts2,this.bl);
+       this.f = this.el/this.h;
+       this.j = (this.el * this.el - this.l * this.h)/(this.el * this.el + this.l * this.h);
+       this.p = (this.l - this.h) / (this.l + this.h);
+       this.dlon = this.lon1 - this.lon2;
+       if (this.dlon < -Proj4js.common.PI) this.lon2 = this.lon2 - 2.0 * Proj4js.common.PI;
+       if (this.dlon > Proj4js.common.PI) this.lon2 = this.lon2 + 2.0 * Proj4js.common.PI;
+       this.longc = .5 * (this.lon1 + this.lon2) -Math.atan(this.j * Math.tan(.5 * this.bl * this.dlon)/this.p)/this.bl;
+       this.dlon  = Proj4js.common.adjust_lon(this.lon1 - this.longc);
+       this.gama = Math.atan(Math.sin(this.bl * this.dlon)/this.g);
+       this.alpha = Proj4js.common.asinz(this.d * Math.sin(this.gama));
+       /* Report parameters common to format A
+       if (Math.abs(this.lat1 - this.lat2) <= Proj4js.common.EPSLN) {
+          Proj4js.reportError("omercInitDataError");
+          //return(202);
+       } else {
+          this.con = Math.abs(this.lat1);
+       if ((this.con <= Proj4js.common.EPSLN) || (Math.abs(this.con - HALF_PI) <= Proj4js.common.EPSLN)) {
+                //return(202);
+       } else {
+         if (Math.abs(Math.abs(this.lat0) - Proj4js.common.HALF_PI) <= Proj4js.common.EPSLN) {
+            //return(202);
+       this.singam=Math.sin(this.gam);
+       this.cosgam=Math.cos(this.gam);
+          this.u =  (this.al/this.bl) * Math.atan(Math.sqrt(this.d * this.d - 1.0)/this.cosaz);
+       } else {
+          this.u = -(this.al/this.bl) * Math.atan(Math.sqrt(this.d * this.d - 1.0)/this.cosaz);
+  /* Oblique Mercator forward equations--mapping lat,long to x,y
+    var theta;		/* angle					*/
+    var sin_phi, cos_phi;/* sin and cos value				*/
+    var c, t, tq;	/* temporary values				*/
+    var con, n, ml;	/* cone constant, small m			*/
+    var q,us,vl;
+    var ul,vs;
+    var s;
+    var dlon;
+    var ts1;
+    var lon=p.x;
+    var lat=p.y;
+    sin_phi = Math.sin(lat);
+    dlon = Proj4js.common.adjust_lon(lon - this.longc);
+    vl = Math.sin(this.bl * dlon);
+    if (Math.abs(Math.abs(lat) - Proj4js.common.HALF_PI) > Proj4js.common.EPSLN) {
+       ts1 = Proj4js.common.tsfnz(this.e,lat,sin_phi);
+       q = this.el / (Math.pow(ts1,this.bl));
+       s = .5 * (q - 1.0 / q);
+       t = .5 * (q + 1.0/ q);
+       ul = (s * this.singam - vl * this.cosgam) / t;
+       con = Math.cos(this.bl * dlon);
+       if (Math.abs(con) < .0000001) {
+          us = this.al * this.bl * dlon;
+       } else {
+          us = this.al * Math.atan((s * this.cosgam + vl * this.singam) / con)/this.bl;
+          if (con < 0) us = us + Proj4js.common.PI * this.al / this.bl;
+    } else {
+       if (lat >= 0) {
+          ul = this.singam;
+       } else {
+          ul = -this.singam;
+       us = this.al * lat / this.bl;
+    if (Math.abs(Math.abs(ul) - 1.0) <= Proj4js.common.EPSLN) {
+       //alert("Point projects into infinity","omer-for");
+       //return(205);
+    vs = .5 * this.al * Math.log((1.0 - ul)/(1.0 + ul)) / this.bl;
+    us = us - this.u;
+    var x = this.x0 + vs * this.cosaz + us * this.sinaz;
+    var y = this.y0 + us * this.cosaz - vs * this.sinaz;
+    p.x=x;
+    p.y=y;
+    return p;
+    var delta_lon;	/* Delta longitude (Given longitude - center 	*/
+    var delta_theta;	/* adjusted longitude				*/
+    var vs,us,q,s,ts1;
+    var vl,ul,bs;
+    var dlon;
+    var  flag;
+    p.x -= this.x0;
+    p.y -= this.y0;
+    flag = 0;
+    vs = p.x * this.cosaz - p.y * this.sinaz;
+    us = p.y * this.cosaz + p.x * this.sinaz;
+    us = us + this.u;
+    q = Math.exp(-this.bl * vs / this.al);
+    s = .5 * (q - 1.0/q);
+    t = .5 * (q + 1.0/q);
+    vl = Math.sin(this.bl * us / this.al);
+    ul = (vl * this.cosgam + s * this.singam)/t;
+       lon = this.longc;
+       if (ul >= 0.0) {
+          lat = Proj4js.common.HALF_PI;
+       } else {
+         lat = -Proj4js.common.HALF_PI;
+    } else {
+       con = 1.0 / this.bl;
+       ts1 =Math.pow((this.el / Math.sqrt((1.0 + ul) / (1.0 - ul))),con);
+       lat = Proj4js.common.phi2z(this.e,ts1);
+       //if (flag != 0)
+          //return(flag);
+       //~ con = Math.cos(this.bl * us /al);
+       theta = this.longc - Math.atan2((s * this.cosgam - vl * this.singam) , con)/this.bl;
+       lon = Proj4js.common.adjust_lon(theta);
+    p.x=lon;
+    p.y=lat;
+    return p;
+    projCode/lcc.js
+NAME                            LAMBERT CONFORMAL CONIC
+PURPOSE:	Transforms input longitude and latitude to Easting and
+		Northing for the Lambert Conformal Conic projection.  The
+ALGORITHM REFERENCES
+1.  Snyder, John P., "Map Projections--A Working Manual", U.S. Geological
+    Survey Professional Paper 1395 (Supersedes USGS Bulletin 1532), United
+    State Government Printing Office, Washington D.C., 1987.
+2.  Snyder, John P. and Voxland, Philip M., "An Album of Map Projections",
+    U.S. Geological Survey Professional Paper 1453 , United State Government
+//<2104> +proj=lcc +lat_1=10.16666666666667 +lat_0=10.16666666666667 +lon_0=-71.60561777777777 +k_0=1 +x0=-17044 +x0=-23139.97 +ellps=intl +units=m +no_defs  no_defs
+// Initialize the Lambert Conformal conic projection
+//Proj4js.Proj.lcc = Class.create();
+Proj4js.Proj.lcc = {
+  init : function() {
+    // array of:  r_maj,r_min,lat1,lat2,c_lon,c_lat,false_east,false_north
+    //double c_lat;                   /* center latitude                      */
+    //double c_lon;                   /* center longitude                     */
+    //double lat1;                    /* first standard parallel              */
+    //double lat2;                    /* second standard parallel             */
+    //double r_maj;                   /* major axis                           */
+    //double r_min;                   /* minor axis                           */
+    //double false_east;              /* x offset in meters                   */
+    //double false_north;             /* y offset in meters                   */
+      if (!this.lat2){this.lat2=this.lat0;}//if lat2 is not defined
+      if (!this.k0) this.k0 = 1.0;
+    // Standard Parallels cannot be equal and on opposite sides of the equator
+      if (Math.abs(this.lat1+this.lat2) < Proj4js.common.EPSLN) {
+        Proj4js.reportError("lcc:init: Equal Latitudes");
+        return;
+      var temp = this.b / this.a;
+      this.e = Math.sqrt(1.0 - temp*temp);
+      var sin1 = Math.sin(this.lat1);
+      var cos1 = Math.cos(this.lat1);
+      var ms1 = Proj4js.common.msfnz(this.e, sin1, cos1);
+      var ts1 = Proj4js.common.tsfnz(this.e, this.lat1, sin1);
+      var sin2 = Math.sin(this.lat2);
+      var cos2 = Math.cos(this.lat2);
+      var ms2 = Proj4js.common.msfnz(this.e, sin2, cos2);
+      var ts2 = Proj4js.common.tsfnz(this.e, this.lat2, sin2);
+      var ts0 = Proj4js.common.tsfnz(this.e, this.lat0, Math.sin(this.lat0));
+      if (Math.abs(this.lat1 - this.lat2) > Proj4js.common.EPSLN) {
+        this.ns = Math.log(ms1/ms2)/Math.log(ts1/ts2);
+      } else {
+        this.ns = sin1;
+      this.f0 = ms1 / (this.ns * Math.pow(ts1, this.ns));
+      this.rh = this.a * this.f0 * Math.pow(ts0, this.ns);
+      if (!this.title) this.title = "Lambert Conformal Conic";
+    // Lambert Conformal conic forward equations--mapping lat,long to x,y
+      var lon = p.x;
+      var lat = p.y;
+      if ( lat <= 90.0 && lat >= -90.0 && lon <= 180.0 && lon >= -180.0) {
+        //lon = lon * Proj4js.common.D2R;
+        //lat = lat * Proj4js.common.D2R;
+      } else {
+        Proj4js.reportError("lcc:forward: llInputOutOfRange: "+ lon +" : " + lat);
+        return null;
+      var con  = Math.abs( Math.abs(lat) - Proj4js.common.HALF_PI);
+      var ts, rh1;
+      if (con > Proj4js.common.EPSLN) {
+        ts = Proj4js.common.tsfnz(this.e, lat, Math.sin(lat) );
+        rh1 = this.a * this.f0 * Math.pow(ts, this.ns);
+      } else {
+        con = lat * this.ns;
+        if (con <= 0) {
+          Proj4js.reportError("lcc:forward: No Projection");
+          return null;
+        rh1 = 0;
+      p.x = this.k0 * (rh1 * Math.sin(theta)) + this.x0;
+      p.y = this.k0 * (this.rh - rh1 * Math.cos(theta)) + this.y0;
+      return p;
+  // Lambert Conformal Conic inverse equations--mapping x,y to lat/long
+  inverse : function(p) {
+    var rh1, con, ts;
+    var lat, lon;
+    var x = (p.x - this.x0)/this.k0;
+    var y = (this.rh - (p.y - this.y0)/this.k0);
+    if (this.ns > 0) {
+      rh1 = Math.sqrt (x * x + y * y);
+      con = 1.0;
+    } else {
+      rh1 = -Math.sqrt (x * x + y * y);
+      con = -1.0;
+    var theta = 0.0;
+    if (rh1 != 0) {
+      theta = Math.atan2((con * x),(con * y));
+    if ((rh1 != 0) || (this.ns > 0.0)) {
+      con = 1.0/this.ns;
+      ts = Math.pow((rh1/(this.a * this.f0)), con);
+      lat = Proj4js.common.phi2z(this.e, ts);
+      if (lat == -9999) return null;
+    } else {
+    lon = Proj4js.common.adjust_lon(theta/this.ns + this.long0);
+    p.x = lon;
+    p.y = lat;
+    return p;
+    projCode/laea.js
+NAME                  LAMBERT AZIMUTHAL EQUAL-AREA
+		Northing for the Lambert Azimuthal Equal-Area projection.  The
+PROGRAMMER              DATE
+D. Steinwand, EROS      March, 1991
+Proj4js.Proj.laea = {
+  S_POLE: 1,
+  N_POLE: 2,
+  EQUIT: 3,
+  OBLIQ: 4,
+/* Initialize the Lambert Azimuthal Equal Area projection
+    if (Math.abs(t - Proj4js.common.HALF_PI) < Proj4js.common.EPSLN) {
+    } else if (Math.abs(t) < Proj4js.common.EPSLN) {
+      this.mode = this.EQUIT;
+    } else {
+      this.mode = this.OBLIQ;
+    if (this.es > 0) {
+      var sinphi;
+      this.qp = Proj4js.common.qsfnz(this.e, 1.0);
+      this.mmf = .5 / (1. - this.es);
+      this.apa = this.authset(this.es);
+        case this.N_POLE:
+        case this.S_POLE:
+          this.dd = 1.;
+          break;
+        case this.EQUIT:
+          this.rq = Math.sqrt(.5 * this.qp);
+          this.dd = 1. / this.rq;
+          this.xmf = 1.;
+          this.ymf = .5 * this.qp;
+          break;
+        case this.OBLIQ:
+          sinphi = Math.sin(this.lat0);
+          this.sinb1 = Proj4js.common.qsfnz(this.e, sinphi) / this.qp;
+          this.cosb1 = Math.sqrt(1. - this.sinb1 * this.sinb1);
+          this.dd = Math.cos(this.lat0) / (Math.sqrt(1. - this.es * sinphi * sinphi) * this.rq * this.cosb1);
+          this.ymf = (this.xmf = this.rq) / this.dd;
+          this.xmf *= this.dd;
+          break;
+    } else {
+      if (this.mode == this.OBLIQ) {
+/* Lambert Azimuthal Equal Area forward equations--mapping lat,long to x,y
+    var x,y;
+    var lam=p.x;
+    var phi=p.y;
+        var coslam, cosphi, sinphi;
+        sinphi = Math.sin(phi);
+        cosphi = Math.cos(phi);
+        coslam = Math.cos(lam);
+          case this.EQUIT:
+            y = (this.mode == this.EQUIT) ? 1. + cosphi * coslam : 1. + this.sinph0 * sinphi + this.cosph0 * cosphi * coslam;
+              Proj4js.reportError("laea:fwd:y less than eps");
+              return null;
+            y = Math.sqrt(2. / y);
+            x = y * cosphi * Math.sin(lam);
+            y *= (this.mode == this.EQUIT) ? sinphi : this.cosph0 * sinphi - this.sinph0 * cosphi * coslam;
+            break;
+          case this.N_POLE:
+            coslam = -coslam;
+          case this.S_POLE:
+            if (Math.abs(phi + this.phi0) < Proj4js.common.EPSLN) {
+              Proj4js.reportError("laea:fwd:phi < eps");
+              return null;
+            y = Proj4js.common.FORTPI - phi * .5;
+            y = 2. * ((this.mode == this.S_POLE) ? Math.cos(y) : Math.sin(y));
+            x = y * Math.sin(lam);
+            y *= coslam;
+            break;
+    } else {
+        var coslam, sinlam, sinphi, q, sinb=0.0, cosb=0.0, b=0.0;
+        sinlam = Math.sin(lam);
+        q = Proj4js.common.qsfnz(this.e, sinphi);
+          sinb = q / this.qp;
+          cosb = Math.sqrt(1. - sinb * sinb);
+          case this.OBLIQ:
+            b = 1. + this.sinb1 * sinb + this.cosb1 * cosb * coslam;
+            break;
+          case this.EQUIT:
+            b = 1. + cosb * coslam;
+            break;
+          case this.N_POLE:
+            b = Proj4js.common.HALF_PI + phi;
+            q = this.qp - q;
+            break;
+          case this.S_POLE:
+            b = phi - Proj4js.common.HALF_PI;
+            q = this.qp + q;
+            break;
+        if (Math.abs(b) < Proj4js.common.EPSLN) {
+            Proj4js.reportError("laea:fwd:b < eps");
+            return null;
+          case this.OBLIQ:
+          case this.EQUIT:
+            b = Math.sqrt(2. / b);
+              y = this.ymf * b * (this.cosb1 * sinb - this.sinb1 * cosb * coslam);
+            } else {
+              y = (b = Math.sqrt(2. / (1. + cosb * coslam))) * sinb * this.ymf;
+            x = this.xmf * b * cosb * sinlam;
+            break;
+          case this.N_POLE:
+          case this.S_POLE:
+            if (q >= 0.) {
+              x = (b = Math.sqrt(q)) * sinlam;
+              y = coslam * ((this.mode == this.S_POLE) ? b : -b);
+            } else {
+              x = y = 0.;
+            break;
+    //v 1.0
+    var sin_lat=Math.sin(lat);
+    var cos_lat=Math.cos(lat);
+    var sin_delta_lon=Math.sin(delta_lon);
+    var cos_delta_lon=Math.cos(delta_lon);
+    var g =this.sin_lat_o * sin_lat +this.cos_lat_o * cos_lat * cos_delta_lon;
+    if (g == -1.0) {
+      Proj4js.reportError("laea:fwd:Point projects to a circle of radius "+ 2.0 * R);
+      return null;
+    var ksp = this.a * Math.sqrt(2.0 / (1.0 + g));
+    var x = ksp * cos_lat * sin_delta_lon + this.x0;
+    var y = ksp * (this.cos_lat_o * sin_lat - this.sin_lat_o * cos_lat * cos_delta_lon) + this.y0;
+    return p;
+  },//lamazFwd()
+  inverse: function(p) {
+    p.x -= this.x0;
+    p.y -= this.y0;
+        var  cosz=0.0, rh, sinz=0.0;
+        var phi = rh * .5;
+        if (phi > 1.) {
+          Proj4js.reportError("laea:Inv:DataError");
+          return null;
+        phi = 2. * Math.asin(phi);
+          sinz = Math.sin(phi);
+          cosz = Math.cos(phi);
+        case this.EQUIT:
+          phi = (Math.abs(rh) <= Proj4js.common.EPSLN) ? 0. : Math.asin(y * sinz / rh);
+          x *= sinz;
+          y = cosz * rh;
+          break;
+        case this.OBLIQ:
+          phi = (Math.abs(rh) <= Proj4js.common.EPSLN) ? this.phi0 : Math.asin(cosz * sinph0 + y * sinz * cosph0 / rh);
+          x *= sinz * cosph0;
+          y = (cosz - Math.sin(phi) * sinph0) * rh;
+          break;
+        case this.N_POLE:
+          y = -y;
+          phi = Proj4js.common.HALF_PI - phi;
+          break;
+        case this.S_POLE:
+          phi -= Proj4js.common.HALF_PI;
+          break;
+        lam = (y == 0. && (this.mode == this.EQUIT || this.mode == this.OBLIQ)) ? 0. : Math.atan2(x, y);
+    } else {
+        var cCe, sCe, q, rho, ab=0.0;
+          case this.EQUIT:
+          case this.OBLIQ:
+            x /= this.dd;
+            y *=  this.dd;
+            if (rho < Proj4js.common.EPSLN) {
+              p.x = 0.;
+              p.y = this.phi0;
+              return p;
+            sCe = 2. * Math.asin(.5 * rho / this.rq);
+            cCe = Math.cos(sCe);
+            x *= (sCe = Math.sin(sCe));
+              ab = cCe * this.sinb1 + y * sCe * this.cosb1 / rho
+              q = this.qp * ab;
+              y = rho * this.cosb1 * cCe - y * this.sinb1 * sCe;
+            } else {
+              ab = y * sCe / rho;
+              q = this.qp * ab;
+              y = rho * cCe;
+            break;
+          case this.N_POLE:
+            y = -y;
+          case this.S_POLE:
+            q = (x * x + y * y);
+            if (!q ) {
+              p.x = 0.;
+              p.y = this.phi0;
+              return p;
+            q = this.qp - q;
+            ab = 1. - q / this.qp;
+            if (this.mode == this.S_POLE) {
+              ab = - ab;
+            break;
+        lam = Math.atan2(x, y);
+        phi = this.authlat(Math.asin(ab), this.apa);
+    var Rh = Math.Math.sqrt(p.x *p.x +p.y * p.y);
+    var temp = Rh / (2.0 * this.a);
+    if (temp > 1) {
+      return null;
+    var z = 2.0 * Proj4js.common.asinz(temp);
+    var sin_z=Math.sin(z);
+    var cos_z=Math.cos(z);
+    var lon =this.long0;
+    if (Math.abs(Rh) > Proj4js.common.EPSLN) {
+       var lat = Proj4js.common.asinz(this.sin_lat_o * cos_z +this. cos_lat_o * sin_z *p.y / Rh);
+       var temp =Math.abs(this.lat0) - Proj4js.common.HALF_PI;
+          temp = cos_z -this.sin_lat_o * Math.sin(lat);
+          if(temp!=0.0) lon=Proj4js.common.adjust_lon(this.long0+Math.atan2(p.x*sin_z*this.cos_lat_o,temp*Rh));
+       } else if (this.lat0 < 0.0) {
+          lon = Proj4js.common.adjust_lon(this.long0 - Math.atan2(-p.x,p.y));
+       } else {
+    } else {
+      lat = this.lat0;
+    //return(OK);
+    p.y = phi;
+    return p;
+  },//lamazInv()
+/* determine latitude from authalic latitude */
+  P00: .33333333333333333333,
+  P01: .17222222222222222222,
+  P02: .10257936507936507936,
+  P10: .06388888888888888888,
+  P11: .06640211640211640211,
+  P20: .01641501294219154443,
+  authset: function(es) {
+    var t;
+    var APA = new Array();
+    APA[0] = es * this.P00;
+    t = es * es;
+    APA[0] += t * this.P01;
+    APA[1] = t * this.P10;
+    t *= es;
+    APA[0] += t * this.P02;
+    APA[1] += t * this.P11;
+    APA[2] = t * this.P20;
+    return APA;
+  authlat: function(beta, APA) {
+    var t = beta+beta;
+    return(beta + APA[0] * Math.sin(t) + APA[1] * Math.sin(t+t) + APA[2] * Math.sin(t+t+t));
+    projCode/aeqd.js
+Proj4js.Proj.aeqd = {
+    this.sin_p12=Math.sin(this.lat0);
+    this.cos_p12=Math.cos(this.lat0);
+  forward: function(p) {
+    var lon=p.x;
+    var lat=p.y;
+    var ksp;
+    var sinphi=Math.sin(p.y);
+    var cosphi=Math.cos(p.y);
+    var dlon = Proj4js.common.adjust_lon(lon - this.long0);
+    var coslon = Math.cos(dlon);
+    var g = this.sin_p12 * sinphi + this.cos_p12 * cosphi * coslon;
+    if (Math.abs(Math.abs(g) - 1.0) < Proj4js.common.EPSLN) {
+       ksp = 1.0;
+       if (g < 0.0) {
+         Proj4js.reportError("aeqd:Fwd:PointError");
+         return;
+    } else {
+       var z = Math.acos(g);
+       ksp = z/Math.sin(z);
+    p.x = this.x0 + this.a * ksp * cosphi * Math.sin(dlon);
+    p.y = this.y0 + this.a * ksp * (this.cos_p12 * sinphi - this.sin_p12 * cosphi * coslon);
+    return p;
+  inverse: function(p){
+    p.x -= this.x0;
+    p.y -= this.y0;
+    var rh = Math.sqrt(p.x * p.x + p.y *p.y);
+    if (rh > (2.0 * Proj4js.common.HALF_PI * this.a)) {
+       Proj4js.reportError("aeqdInvDataError");
+       return;
+    var z = rh / this.a;
+    var sinz=Math.sin(z);
+    var cosz=Math.cos(z);
+    var lon = this.long0;
+    var lat;
+      lat = this.lat0;
+    } else {
+      lat = Proj4js.common.asinz(cosz * this.sin_p12 + (p.y * sinz * this.cos_p12) / rh);
+      var con = Math.abs(this.lat0) - Proj4js.common.HALF_PI;
+        if (lat0 >= 0.0) {
+          lon = Proj4js.common.adjust_lon(this.long0 + Math.atan2(p.x , -p.y));
+        } else {
+          lon = Proj4js.common.adjust_lon(this.long0 - Math.atan2(-p.x , p.y));
+      } else {
+        con = cosz - this.sin_p12 * Math.sin(lat);
+        if ((Math.abs(con) < Proj4js.common.EPSLN) && (Math.abs(p.x) < Proj4js.common.EPSLN)) {
+           //no-op, just keep the lon value as is
+        } else {
+          var temp = Math.atan2((p.x * sinz * this.cos_p12), (con * rh));
+          lon = Proj4js.common.adjust_lon(this.long0 + Math.atan2((p.x * sinz * this.cos_p12), (con * rh)));
+    p.x = lon;
+    p.y = lat;
+    return p;
+    projCode/moll.js
+NAME                            MOLLWEIDE
+		Northing for the MOllweide projection.  The
+		longitude and latitude must be in radians.  The Easting
+		and Northing values will be returned in meters.
+PROGRAMMER              DATE
+D. Steinwand, EROS      May, 1991;  Updated Sept, 1992; Updated Feb, 1993
+S. Nelson, EDC		Jun, 2993;	Made corrections in precision and
+					number of iterations.
+1.  Snyder, John P. and Voxland, Philip M., "An Album of Map Projections",
+    Printing Office, Washington D.C., 1989.
+Proj4js.Proj.moll = {
+  /* Initialize the Mollweide projection
+  init: function(){
+    //no-op
+  /* Mollweide forward equations--mapping lat,long to x,y
+    /* Forward equations
+    var lon=p.x;
+    var lat=p.y;
+    var theta = lat;
+    var con = Proj4js.common.PI * Math.sin(lat);
+    /* Iterate using the Newton-Raphson method to find theta
+    for (var i=0;true;i++) {
+       var delta_theta = -(theta + Math.sin(theta) - con)/ (1.0 + Math.cos(theta));
+       theta += delta_theta;
+       if (Math.abs(delta_theta) < Proj4js.common.EPSLN) break;
+       if (i >= 50) {
+          Proj4js.reportError("moll:Fwd:IterationError");
+         //return(241);
+    theta /= 2.0;
+    /* If the latitude is 90 deg, force the x coordinate to be "0 + false easting"
+       this is done here because of precision problems with "cos(theta)"
+    if (Proj4js.common.PI/2 - Math.abs(lat) < Proj4js.common.EPSLN) delta_lon =0;
+    var x = 0.900316316158 * this.a * delta_lon * Math.cos(theta) + this.x0;
+    var y = 1.4142135623731 * this.a * Math.sin(theta) + this.y0;
+    p.x=x;
+    p.y=y;
+    return p;
+    var theta;
+    var arg;
+    /* Inverse equations
+    p.x-= this.x0;
+    //~ p.y -= this.y0;
+    var arg = p.y /  (1.4142135623731 * this.a);
+    /* Because of division by zero problems, 'arg' can not be 1.0.  Therefore
+       a number very close to one is used instead.
+    if(Math.abs(arg) > 0.999999999999) arg=0.999999999999;
+    var theta =Math.asin(arg);
+    var lon = Proj4js.common.adjust_lon(this.long0 + (p.x / (0.900316316158 * this.a * Math.cos(theta))));
+    if(lon < (-Proj4js.common.PI)) lon= -Proj4js.common.PI;
+    if(lon > Proj4js.common.PI) lon= Proj4js.common.PI;
+    arg = (2.0 * theta + Math.sin(2.0 * theta)) / Proj4js.common.PI;
+    if(Math.abs(arg) > 1.0)arg=1.0;
+    var lat = Math.asin(arg);
+    //return(OK);
+    p.x=lon;
+    p.y=lat;
+    return p;
Modified: trunk/lib/proj4js-compressed.js
--- trunk/lib/proj4js-compressed.js	2010-08-10 19:38:28 UTC (rev 2198)
+++ trunk/lib/proj4js-compressed.js	2010-08-11 18:51:20 UTC (rev 2199)
@@ -9,7 +9,8 @@
                 Note: This program is an almost direct port of the C library
                 Proj4.
-Proj4js={defaultDatum:'WGS84',transform:function(source,dest,point){if(!source.readyToUse||!dest.readyToUse){this.reportError("Proj4js initialization for "+source.srsCode+" not yet complete");return point;}
+Proj4js={defaultDatum:'WGS84',transform:function(source,dest,point){if(!source.readyToUse){this.reportError("Proj4js initialization for:"+source.srsCode+" not yet complete");return point;}
+if(!dest.readyToUse){this.reportError("Proj4js initialization for:"+dest.srsCode+" not yet complete");return point;}
 if((source.srsProjNumber=="900913"&&dest.datumCode!="WGS84")||(dest.srsProjNumber=="900913"&&source.datumCode!="WGS84")){var wgs84=Proj4js.WGS84;this.transform(source,wgs84,point);source=wgs84;}
 if(source.projName=="longlat"){point.x*=Proj4js.common.D2R;point.y*=Proj4js.common.D2R;}else{if(source.to_meter){point.x*=source.to_meter;point.y*=source.to_meter;}
 source.inverse(point);}
@@ -33,17 +34,25 @@
 Proj4js.extend(extended,parent);}
 Class.prototype=extended;return Class;},bind:function(func,object){var args=Array.prototype.slice.apply(arguments,[2]);return function(){var newArgs=args.concat(Array.prototype.slice.apply(arguments,[0]));return func.apply(object,newArgs);};},scriptName:"proj4js-compressed.js",defsLookupService:'http://spatialreference.org/ref',libPath:null,getScriptLocation:function(){if(this.libPath)return this.libPath;var scriptName=this.scriptName;var scriptNameLen=scriptName.length;var scripts=document.getElementsByTagName('script');for(var i=0;i<scripts.length;i++){var src=scripts[i].getAttribute('src');if(src){var index=src.lastIndexOf(scriptName);if((index>-1)&&(index+scriptNameLen==src.length)){this.libPath=src.slice(0,-scriptNameLen);break;}}}
 return this.libPath||"";},loadScript:function(url,onload,onfail,loadCheck){var script=document.createElement('script');script.defer=false;script.type="text/javascript";script.id=url;script.src=url;script.onload=onload;script.onerror=onfail;script.loadCheck=loadCheck;if(/MSIE/.test(navigator.userAgent)){script.onreadystatechange=this.checkReadyState;}
-document.getElementsByTagName('head')[0].appendChild(script);},checkReadyState:function(){if(this.readyState=='loaded'){if(!this.loadCheck()){this.onerror();}else{this.onload();}}}};Proj4js.Proj=Proj4js.Class({readyToUse:false,title:null,projName:null,units:null,datum:null,x0:0,y0:0,initialize:function(srsCode){this.srsCodeInput=srsCode;if(srsCode.indexOf('urn:')==0){var urn=srsCode.split(':');if((urn[1]=='ogc'||urn[1]=='x-ogc')&&(urn[2]=='def')&&(urn[3]=='crs')){srsCode=urn[4]+':'+urn[urn.length-1];}}else if(srsCode.indexOf('http://')==0){var url=srsCode.split('#');if(url[0].match(/epsg.org/)){srsCode='EPSG:'+url[1];}else if(url[0].match(/RIG.xml/)){srsCode='IGNF:'+url[1];}}
+document.getElementsByTagName('head')[0].appendChild(script);},checkReadyState:function(){if(this.readyState=='loaded'){if(!this.loadCheck()){this.onerror();}else{this.onload();}}}};Proj4js.Proj=Proj4js.Class({readyToUse:false,title:null,projName:null,units:null,datum:null,x0:0,y0:0,localCS:false,initialize:function(srsCode){this.srsCodeInput=srsCode;if((srsCode.indexOf('GEOGCS')>=0)||(srsCode.indexOf('GEOCCS')>=0)||(srsCode.indexOf('PROJCS')>=0)||(srsCode.indexOf('LOCAL_CS')>=0)){this.parseWKT(srsCode);this.datum=new Proj4js.datum(this);this.loadProjCode(this.projName);return;}
+if(srsCode.indexOf('urn:')==0){var urn=srsCode.split(':');if((urn[1]=='ogc'||urn[1]=='x-ogc')&&(urn[2]=='def')&&(urn[3]=='crs')){srsCode=urn[4]+':'+urn[urn.length-1];}}else if(srsCode.indexOf('http://')==0){var url=srsCode.split('#');if(url[0].match(/epsg.org/)){srsCode='EPSG:'+url[1];}else if(url[0].match(/RIG.xml/)){srsCode='IGNF:'+url[1];}}
 this.srsCode=srsCode.toUpperCase();if(this.srsCode.indexOf("EPSG")==0){this.srsCode=this.srsCode;this.srsAuth='epsg';this.srsProjNumber=this.srsCode.substring(5);}else if(this.srsCode.indexOf("IGNF")==0){this.srsCode=this.srsCode;this.srsAuth='IGNF';this.srsProjNumber=this.srsCode.substring(5);}else if(this.srsCode.indexOf("CRS")==0){this.srsCode=this.srsCode;this.srsAuth='CRS';this.srsProjNumber=this.srsCode.substring(4);}else{this.srsAuth='';this.srsProjNumber=this.srsCode;}
 this.loadProjDefinition();},loadProjDefinition:function(){if(Proj4js.defs[this.srsCode]){this.defsLoaded();return;}
 var url=Proj4js.getScriptLocation()+'defs/'+this.srsAuth.toUpperCase()+this.srsProjNumber+'.js';Proj4js.loadScript(url,Proj4js.bind(this.defsLoaded,this),Proj4js.bind(this.loadFromService,this),Proj4js.bind(this.checkDefsLoaded,this));},loadFromService:function(){var url=Proj4js.defsLookupService+'/'+this.srsAuth+'/'+this.srsProjNumber+'/proj4js/';Proj4js.loadScript(url,Proj4js.bind(this.defsLoaded,this),Proj4js.bind(this.defsFailed,this),Proj4js.bind(this.checkDefsLoaded,this));},defsLoaded:function(){this.parseDefs();this.loadProjCode(this.projName);},checkDefsLoaded:function(){if(Proj4js.defs[this.srsCode]){return true;}else{return false;}},defsFailed:function(){Proj4js.reportError('failed to load projection definition for: '+this.srsCode);Proj4js.defs[this.srsCode]=Proj4js.defs['WGS84'];this.defsLoaded();},loadProjCode:function(projName){if(Proj4js.Proj[projName]){this.initTransforms();return;}
-var url=Proj4js.getScriptLocation()+'projCode/'+projName+'.js';Proj4js.loadScript(url,Proj4js.bind(this.loadProjCodeSuccess,this,projName),Proj4js.bind(this.loadProjCodeFailure,this,projName),Proj4js.bind(this.checkCodeLoaded,this,projName));},loadProjCodeSuccess:function(projName){if(Proj4js.Proj[projName].dependsOn){this.loadProjCode(Proj4js.Proj[projName].dependsOn);}else{this.initTransforms();}},loadProjCodeFailure:function(projName){Proj4js.reportError("failed to find projection file for: "+projName);},checkCodeLoaded:function(projName){if(Proj4js.Proj[projName]){return true;}else{return false;}},initTransforms:function(){Proj4js.extend(this,Proj4js.Proj[this.projName]);this.init();this.readyToUse=true;},parseDefs:function(){this.defData=Proj4js.defs[this.srsCode];var paramName,paramVal;if(!this.defData){return;}
+var url=Proj4js.getScriptLocation()+'projCode/'+projName+'.js';Proj4js.loadScript(url,Proj4js.bind(this.loadProjCodeSuccess,this,projName),Proj4js.bind(this.loadProjCodeFailure,this,projName),Proj4js.bind(this.checkCodeLoaded,this,projName));},loadProjCodeSuccess:function(projName){if(Proj4js.Proj[projName].dependsOn){this.loadProjCode(Proj4js.Proj[projName].dependsOn);}else{this.initTransforms();}},loadProjCodeFailure:function(projName){Proj4js.reportError("failed to find projection file for: "+projName);},checkCodeLoaded:function(projName){if(Proj4js.Proj[projName]){return true;}else{return false;}},initTransforms:function(){Proj4js.extend(this,Proj4js.Proj[this.projName]);this.init();this.readyToUse=true;},wktRE:/^(\w+)\[(.*)\]$/,parseWKT:function(wkt){var wktMatch=wkt.match(this.wktRE);if(!wktMatch)return;var wktObject=wktMatch[1];var wktContent=wktMatch[2];var wktTemp=wktContent.split(",");var wktName=wktTemp.shift();wktName=wktName.replace(/^\"/,"");wktName=wktName.rep
 lace(/\"$/,"");var wktArray=new Array();var bkCount=0;var obj="";for(var i=0;i<wktTemp.length;++i){var token=wktTemp[i];for(var j=0;j<token.length;++j){if(token.charAt(j)=="[")++bkCount;if(token.charAt(j)=="]")--bkCount;}
+obj+=token;if(bkCount===0){wktArray.push(obj);obj="";}else{obj+=",";}}
+switch(wktObject){case'LOCAL_CS':this.projName='identity'
+this.localCS=true;this.srsCode=wktName;break;case'GEOGCS':this.projName='longlat'
+this.geocsCode=wktName;if(!this.srsCode)this.srsCode=wktName;break;case'PROJCS':this.srsCode=wktName;break;case'GEOCCS':break;case'PROJECTION':this.projName=Proj4js.wktProjections[wktName]
+break;case'DATUM':this.datumName=wktName;break;case'LOCAL_DATUM':this.datumCode='none';break;case'SPHEROID':this.ellps=wktName;this.a=parseFloat(wktArray.shift());this.rf=parseFloat(wktArray.shift());break;case'PRIMEM':this.from_greenwich=parseFloat(wktArray.shift());break;case'UNIT':this.units=wktName;this.unitsPerMeter=parseFloat(wktArray.shift());break;case'PARAMETER':var name=wktName;var value=parseFloat(parseFloat(wktArray.shift()));switch(name){case'false_easting':this.x0=value;break;case'false_northing':this.y0=value;break;case'scale_factor':this.k0=value;break;case'central_meridian':this.long0=value;break;case'latitude_of_origin':this.lat0=value;break;case'more_here':break;default:break;}
+break;case'TOWGS84':this.datum_params=wktArray;break;case'MORE_HERE':break;default:break;}
+for(var i=0;i<wktArray.length;++i){this.parseWKT(wktArray[i]);}},parseDefs:function(){this.defData=Proj4js.defs[this.srsCode];var paramName,paramVal;if(!this.defData){return;}
 var paramArray=this.defData.split("+");for(var prop=0;prop<paramArray.length;prop++){var property=paramArray[prop].split("=");paramName=property[0].toLowerCase();paramVal=property[1];switch(paramName.replace(/\s/gi,"")){case"":break;case"title":this.title=paramVal;break;case"proj":this.projName=paramVal.replace(/\s/gi,"");break;case"units":this.units=paramVal.replace(/\s/gi,"");break;case"datum":this.datumCode=paramVal.replace(/\s/gi,"");break;case"nadgrids":this.nagrids=paramVal.replace(/\s/gi,"");break;case"ellps":this.ellps=paramVal.replace(/\s/gi,"");break;case"a":this.a=parseFloat(paramVal);break;case"b":this.b=parseFloat(paramVal);break;case"rf":this.rf=parseFloat(paramVal);break;case"lat_0":this.lat0=paramVal*Proj4js.common.D2R;break;case"lat_1":this.lat1=paramVal*Proj4js.common.D2R;break;case"lat_2":this.lat2=paramVal*Proj4js.common.D2R;break;case"lat_ts":this.lat_ts=paramVal*Proj4js.common.D2R;break;case"lon_0":this.long0=paramVal*Proj4js.common.D2R;break;case"alpha
 ":this.alpha=parseFloat(paramVal)*Proj4js.common.D2R;break;case"lonc":this.longc=paramVal*Proj4js.common.D2R;break;case"x_0":this.x0=parseFloat(paramVal);break;case"y_0":this.y0=parseFloat(paramVal);break;case"k_0":this.k0=parseFloat(paramVal);break;case"k":this.k0=parseFloat(paramVal);break;case"r_a":this.R_A=true;break;case"zone":this.zone=parseInt(paramVal);break;case"south":this.utmSouth=true;break;case"towgs84":this.datum_params=paramVal.split(",");break;case"to_meter":this.to_meter=parseFloat(paramVal);break;case"from_greenwich":this.from_greenwich=paramVal*Proj4js.common.D2R;break;case"pm":paramVal=paramVal.replace(/\s/gi,"");this.from_greenwich=Proj4js.PrimeMeridian[paramVal]?Proj4js.PrimeMeridian[paramVal]:parseFloat(paramVal);this.from_greenwich*=Proj4js.common.D2R;break;case"no_defs":break;default:}}
 this.deriveConstants();},deriveConstants:function(){if(this.nagrids=='@null')this.datumCode='none';if(this.datumCode&&this.datumCode!='none'){var datumDef=Proj4js.Datum[this.datumCode];if(datumDef){this.datum_params=datumDef.towgs84?datumDef.towgs84.split(','):null;this.ellps=datumDef.ellipse;this.datumName=datumDef.datumName?datumDef.datumName:this.datumCode;}}
 if(!this.a){var ellipse=Proj4js.Ellipsoid[this.ellps]?Proj4js.Ellipsoid[this.ellps]:Proj4js.Ellipsoid['WGS84'];Proj4js.extend(this,ellipse);}
 if(this.rf&&!this.b)this.b=(1.0-1.0/this.rf)*this.a;if(Math.abs(this.a-this.b)<Proj4js.common.EPSLN){this.sphere=true;this.b=this.a;}
 this.a2=this.a*this.a;this.b2=this.b*this.b;this.es=(this.a2-this.b2)/this.a2;this.e=Math.sqrt(this.es);if(this.R_A){this.a*=1.-this.es*(Proj4js.common.SIXTH+this.es*(Proj4js.common.RA4+this.es*Proj4js.common.RA6));this.a2=this.a*this.a;this.b2=this.b*this.b;this.es=0.;}
-this.ep2=(this.a2-this.b2)/this.b2;if(!this.k0)this.k0=1.0;this.datum=new Proj4js.datum(this);}});Proj4js.Proj.longlat={init:function(){},forward:function(pt){return pt;},inverse:function(pt){return pt;}};Proj4js.Proj.identity=Proj4js.Proj.longlat;Proj4js.defs={'WGS84':"+title=long/lat:WGS84 +proj=longlat +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4326':"+title=long/lat:WGS84 +proj=longlat +a=6378137.0 +b=6356752.31424518 +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4269':"+title=long/lat:NAD83 +proj=longlat +a=6378137.0 +b=6356752.31414036 +ellps=GRS80 +datum=NAD83 +units=degrees",'EPSG:3785':"+title= Google Mercator +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs"};Proj4js.defs['GOOGLE']=Proj4js.defs['EPSG:3785'];Proj4js.defs['EPSG:900913']=Proj4js.defs['EPSG:3785'];Proj4js.defs['EPSG:102113']=Proj4js.defs['EPSG:3785'];Proj4js.common={PI:3.141592653589793238,HALF_PI:1.570796326794896619,TWO_PI:6.28318
 5307179586477,FORTPI:0.78539816339744833,R2D:57.29577951308232088,D2R:0.01745329251994329577,SEC_TO_RAD:4.84813681109535993589914102357e-6,EPSLN:1.0e-10,MAX_ITER:20,COS_67P5:0.38268343236508977,AD_C:1.0026000,PJD_UNKNOWN:0,PJD_3PARAM:1,PJD_7PARAM:2,PJD_GRIDSHIFT:3,PJD_WGS84:4,PJD_NODATUM:5,SRS_WGS84_SEMIMAJOR:6378137.0,SIXTH:.1666666666666666667,RA4:.04722222222222222222,RA6:.02215608465608465608,RV4:.06944444444444444444,RV6:.04243827160493827160,msfnz:function(eccent,sinphi,cosphi){var con=eccent*sinphi;return cosphi/(Math.sqrt(1.0-con*con));},tsfnz:function(eccent,phi,sinphi){var con=eccent*sinphi;var com=.5*eccent;con=Math.pow(((1.0-con)/(1.0+con)),com);return(Math.tan(.5*(this.HALF_PI-phi))/con);},phi2z:function(eccent,ts){var eccnth=.5*eccent;var con,dphi;var phi=this.HALF_PI-2*Math.atan(ts);for(i=0;i<=15;i++){con=eccent*Math.sin(phi);dphi=this.HALF_PI-2*Math.atan(ts*(Math.pow(((1.0-con)/(1.0+con)),eccnth)))-phi;phi+=dphi;if(Math.abs(dphi)<=.0000000001)return phi;}
+this.ep2=(this.a2-this.b2)/this.b2;if(!this.k0)this.k0=1.0;this.datum=new Proj4js.datum(this);}});Proj4js.Proj.longlat={init:function(){},forward:function(pt){return pt;},inverse:function(pt){return pt;}};Proj4js.Proj.identity=Proj4js.Proj.longlat;Proj4js.defs={'WGS84':"+title=long/lat:WGS84 +proj=longlat +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4326':"+title=long/lat:WGS84 +proj=longlat +a=6378137.0 +b=6356752.31424518 +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4269':"+title=long/lat:NAD83 +proj=longlat +a=6378137.0 +b=6356752.31414036 +ellps=GRS80 +datum=NAD83 +units=degrees",'EPSG:3785':"+title= Google Mercator +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs"};Proj4js.defs['GOOGLE']=Proj4js.defs['EPSG:3785'];Proj4js.defs['EPSG:900913']=Proj4js.defs['EPSG:3785'];Proj4js.defs['EPSG:102113']=Proj4js.defs['EPSG:3785'];Proj4js.common={PI:3.141592653589793238,HALF_PI:1.570796326794896619,TWO_PI:6.28318
 5307179586477,FORTPI:0.78539816339744833,R2D:57.29577951308232088,D2R:0.01745329251994329577,SEC_TO_RAD:4.84813681109535993589914102357e-6,EPSLN:1.0e-10,MAX_ITER:20,COS_67P5:0.38268343236508977,AD_C:1.0026000,PJD_UNKNOWN:0,PJD_3PARAM:1,PJD_7PARAM:2,PJD_GRIDSHIFT:3,PJD_WGS84:4,PJD_NODATUM:5,SRS_WGS84_SEMIMAJOR:6378137.0,SIXTH:.1666666666666666667,RA4:.04722222222222222222,RA6:.02215608465608465608,RV4:.06944444444444444444,RV6:.04243827160493827160,msfnz:function(eccent,sinphi,cosphi){var con=eccent*sinphi;return cosphi/(Math.sqrt(1.0-con*con));},tsfnz:function(eccent,phi,sinphi){var con=eccent*sinphi;var com=.5*eccent;con=Math.pow(((1.0-con)/(1.0+con)),com);return(Math.tan(.5*(this.HALF_PI-phi))/con);},phi2z:function(eccent,ts){var eccnth=.5*eccent;var con,dphi;var phi=this.HALF_PI-2*Math.atan(ts);for(var i=0;i<=15;i++){con=eccent*Math.sin(phi);dphi=this.HALF_PI-2*Math.atan(ts*(Math.pow(((1.0-con)/(1.0+con)),eccnth)))-phi;phi+=dphi;if(Math.abs(dphi)<=.0000000001)return phi;}
 alert("phi2z has NoConvergence");return(-9999);},qsfnz:function(eccent,sinphi){var con;if(eccent>1.0e-7){con=eccent*sinphi;return((1.0-eccent*eccent)*(sinphi/(1.0-con*con)-(.5/eccent)*Math.log((1.0-con)/(1.0+con))));}else{return(2.0*sinphi);}},asinz:function(x){if(Math.abs(x)>1.0){x=(x>1.0)?1.0:-1.0;}
 return Math.asin(x);},e0fn:function(x){return(1.0-0.25*x*(1.0+x/16.0*(3.0+1.25*x)));},e1fn:function(x){return(0.375*x*(1.0+0.25*x*(1.0+0.46875*x)));},e2fn:function(x){return(0.05859375*x*x*(1.0+0.75*x));},e3fn:function(x){return(x*x*x*(35.0/3072.0));},mlfn:function(e0,e1,e2,e3,phi){return(e0*phi-e1*Math.sin(2.0*phi)+e2*Math.sin(4.0*phi)-e3*Math.sin(6.0*phi));},srat:function(esinp,exp){return(Math.pow((1.0-esinp)/(1.0+esinp),exp));},sign:function(x){if(x<0.0)return(-1);else return(1);},adjust_lon:function(x){x=(Math.abs(x)<this.PI)?x:(x-(this.sign(x)*this.TWO_PI));return x;},adjust_lat:function(x){x=(Math.abs(x)<this.HALF_PI)?x:(x-(this.sign(x)*this.PI));return x;},latiso:function(eccent,phi,sinphi){if(Math.abs(phi)>this.HALF_PI)return+Number.NaN;if(phi==this.HALF_PI)return Number.POSITIVE_INFINITY;if(phi==-1.0*this.HALF_PI)return-1.0*Number.POSITIVE_INFINITY;var con=eccent*sinphi;return Math.log(Math.tan((this.HALF_PI+phi)/2.0))+eccent*Math.log((1.0-con)/(1.0+con))/2.0;},fL:
 function(x,L){return 2.0*Math.atan(x*Math.exp(L))-this.HALF_PI;},invlatiso:function(eccent,ts){var phi=this.fL(1.0,ts);var Iphi=0.0;var con=0.0;do{Iphi=phi;con=eccent*Math.sin(Iphi);phi=this.fL(Math.exp(eccent*Math.log((1.0+con)/(1.0-con))/2.0),ts)}while(Math.abs(phi-Iphi)>1.0e-12);return phi;},sinh:function(x)
 {var r=Math.exp(x);r=(r-1.0/r)/2.0;return r;},cosh:function(x)
@@ -88,7 +97,7 @@
 {var Dx_BF=this.datum_params[0];var Dy_BF=this.datum_params[1];var Dz_BF=this.datum_params[2];var Rx_BF=this.datum_params[3];var Ry_BF=this.datum_params[4];var Rz_BF=this.datum_params[5];var M_BF=this.datum_params[6];var x_out=M_BF*(p.x-Rz_BF*p.y+Ry_BF*p.z)+Dx_BF;var y_out=M_BF*(Rz_BF*p.x+p.y-Rx_BF*p.z)+Dy_BF;var z_out=M_BF*(-Ry_BF*p.x+Rx_BF*p.y+p.z)+Dz_BF;p.x=x_out;p.y=y_out;p.z=z_out;}},geocentric_from_wgs84:function(p){if(this.datum_type==Proj4js.common.PJD_3PARAM)
 {p.x-=this.datum_params[0];p.y-=this.datum_params[1];p.z-=this.datum_params[2];}
 else if(this.datum_type==Proj4js.common.PJD_7PARAM)
-{var Dx_BF=this.datum_params[0];var Dy_BF=this.datum_params[1];var Dz_BF=this.datum_params[2];var Rx_BF=this.datum_params[3];var Ry_BF=this.datum_params[4];var Rz_BF=this.datum_params[5];var M_BF=this.datum_params[6];var x_tmp=(p.x-Dx_BF)/M_BF;var y_tmp=(p.y-Dy_BF)/M_BF;var z_tmp=(p.z-Dz_BF)/M_BF;p.x=x_tmp+Rz_BF*y_tmp-Ry_BF*z_tmp;p.y=-Rz_BF*x_tmp+y_tmp+Rx_BF*z_tmp;p.z=Ry_BF*x_tmp-Rx_BF*y_tmp+z_tmp;}}});Proj4js.Point=Proj4js.Class({initialize:function(x,y,z){if(typeof x=='object'){this.x=x[0];this.y=x[1];this.z=x[2]||0.0;}else if(typeof x=='string'){var coords=x.split(',');this.x=parseFloat(coords[0]);this.y=parseFloat(coords[1]);this.z=parseFloat(coords[2])||0.0;}else{this.x=x;this.y=y;this.z=z||0.0;}},clone:function(){return new Proj4js.Point(this.x,this.y,this.z);},toString:function(){return("x="+this.x+",y="+this.y);},toShortString:function(){return(this.x+", "+this.y);}});Proj4js.PrimeMeridian={"greenwich":0.0,"lisbon":-9.131906111111,"paris":2.337229166667,"bogota":-74.
 080916666667,"madrid":-3.687938888889,"rome":12.452333333333,"bern":7.439583333333,"jakarta":106.807719444444,"ferro":-17.666666666667,"brussels":4.367975,"stockholm":18.058277777778,"athens":23.7163375,"oslo":10.722916666667};Proj4js.Ellipsoid={"MERIT":{a:6378137.0,rf:298.257,ellipseName:"MERIT 1983"},"SGS85":{a:6378136.0,rf:298.257,ellipseName:"Soviet Geodetic System 85"},"GRS80":{a:6378137.0,rf:298.257222101,ellipseName:"GRS 1980(IUGG, 1980)"},"IAU76":{a:6378140.0,rf:298.257,ellipseName:"IAU 1976"},"airy":{a:6377563.396,b:6356256.910,ellipseName:"Airy 1830"},"APL4.":{a:6378137,rf:298.25,ellipseName:"Appl. Physics. 1965"},"NWL9D":{a:6378145.0,rf:298.25,ellipseName:"Naval Weapons Lab., 1965"},"mod_airy":{a:6377340.189,b:6356034.446,ellipseName:"Modified Airy"},"andrae":{a:6377104.43,rf:300.0,ellipseName:"Andrae 1876 (Den., Iclnd.)"},"aust_SA":{a:6378160.0,rf:298.25,ellipseName:"Australian Natl & S. Amer. 1969"},"GRS67":{a:6378160.0,rf:298.2471674270,ellipseName:"GRS 67(IUGG
  1967)"},"bessel":{a:6377397.155,rf:299.1528128,ellipseName:"Bessel 1841"},"bess_nam":{a:6377483.865,rf:299.1528128,ellipseName:"Bessel 1841 (Namibia)"},"clrk66":{a:6378206.4,b:6356583.8,ellipseName:"Clarke 1866"},"clrk80":{a:6378249.145,rf:293.4663,ellipseName:"Clarke 1880 mod."},"CPM":{a:6375738.7,rf:334.29,ellipseName:"Comm. des Poids et Mesures 1799"},"delmbr":{a:6376428.0,rf:311.5,ellipseName:"Delambre 1810 (Belgium)"},"engelis":{a:6378136.05,rf:298.2566,ellipseName:"Engelis 1985"},"evrst30":{a:6377276.345,rf:300.8017,ellipseName:"Everest 1830"},"evrst48":{a:6377304.063,rf:300.8017,ellipseName:"Everest 1948"},"evrst56":{a:6377301.243,rf:300.8017,ellipseName:"Everest 1956"},"evrst69":{a:6377295.664,rf:300.8017,ellipseName:"Everest 1969"},"evrstSS":{a:6377298.556,rf:300.8017,ellipseName:"Everest (Sabah & Sarawak)"},"fschr60":{a:6378166.0,rf:298.3,ellipseName:"Fischer (Mercury Datum) 1960"},"fschr60m":{a:6378155.0,rf:298.3,ellipseName:"Fischer 1960"},"fschr68":{a:6378150.0
 ,rf:298.3,ellipseName:"Fischer 1968"},"helmert":{a:6378200.0,rf:298.3,ellipseName:"Helmert 1906"},"hough":{a:6378270.0,rf:297.0,ellipseName:"Hough"},"intl":{a:6378388.0,rf:297.0,ellipseName:"International 1909 (Hayford)"},"kaula":{a:6378163.0,rf:298.24,ellipseName:"Kaula 1961"},"lerch":{a:6378139.0,rf:298.257,ellipseName:"Lerch 1979"},"mprts":{a:6397300.0,rf:191.0,ellipseName:"Maupertius 1738"},"new_intl":{a:6378157.5,b:6356772.2,ellipseName:"New International 1967"},"plessis":{a:6376523.0,rf:6355863.0,ellipseName:"Plessis 1817 (France)"},"krass":{a:6378245.0,rf:298.3,ellipseName:"Krassovsky, 1942"},"SEasia":{a:6378155.0,b:6356773.3205,ellipseName:"Southeast Asia"},"walbeck":{a:6376896.0,b:6355834.8467,ellipseName:"Walbeck"},"WGS60":{a:6378165.0,rf:298.3,ellipseName:"WGS 60"},"WGS66":{a:6378145.0,rf:298.25,ellipseName:"WGS 66"},"WGS72":{a:6378135.0,rf:298.26,ellipseName:"WGS 72"},"WGS84":{a:6378137.0,rf:298.257223563,ellipseName:"WGS 84"},"sphere":{a:6370997.0,b:6370997.0,el
 lipseName:"Normal Sphere (r=6370997)"}};Proj4js.Datum={"WGS84":{towgs84:"0,0,0",ellipse:"WGS84",datumName:"WGS84"},"GGRS87":{towgs84:"-199.87,74.79,246.62",ellipse:"GRS80",datumName:"Greek_Geodetic_Reference_System_1987"},"NAD83":{towgs84:"0,0,0",ellipse:"GRS80",datumName:"North_American_Datum_1983"},"NAD27":{nadgrids:"@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat",ellipse:"clrk66",datumName:"North_American_Datum_1927"},"potsdam":{towgs84:"606.0,23.0,413.0",ellipse:"bessel",datumName:"Potsdam Rauenberg 1950 DHDN"},"carthage":{towgs84:"-263.0,6.0,431.0",ellipse:"clark80",datumName:"Carthage 1934 Tunisia"},"hermannskogel":{towgs84:"653.0,-212.0,449.0",ellipse:"bessel",datumName:"Hermannskogel"},"ire65":{towgs84:"482.530,-130.596,564.557,-1.042,-0.214,-0.631,8.15",ellipse:"mod_airy",datumName:"Ireland 1965"},"nzgd49":{towgs84:"59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993",ellipse:"intl",datumName:"New Zealand Geodetic Datum 1949"},"OSGB36":{towgs84:"446.448,-125.157,542.060,0.1502,0.2
 470,0.8421,-20.4894",ellipse:"airy",datumName:"Airy 1830"}};Proj4js.WGS84=new Proj4js.Proj('WGS84');Proj4js.Datum['OSB36']=Proj4js.Datum['OSGB36'];Proj4js.Proj.aea={init:function(){if(Math.abs(this.lat1+this.lat2)<Proj4js.common.EPSLN){Proj4js.reportError("aeaInitEqualLatitudes");return;}
+{var Dx_BF=this.datum_params[0];var Dy_BF=this.datum_params[1];var Dz_BF=this.datum_params[2];var Rx_BF=this.datum_params[3];var Ry_BF=this.datum_params[4];var Rz_BF=this.datum_params[5];var M_BF=this.datum_params[6];var x_tmp=(p.x-Dx_BF)/M_BF;var y_tmp=(p.y-Dy_BF)/M_BF;var z_tmp=(p.z-Dz_BF)/M_BF;p.x=x_tmp+Rz_BF*y_tmp-Ry_BF*z_tmp;p.y=-Rz_BF*x_tmp+y_tmp+Rx_BF*z_tmp;p.z=Ry_BF*x_tmp-Rx_BF*y_tmp+z_tmp;}}});Proj4js.Point=Proj4js.Class({initialize:function(x,y,z){if(typeof x=='object'){this.x=x[0];this.y=x[1];this.z=x[2]||0.0;}else if(typeof x=='string'){var coords=x.split(',');this.x=parseFloat(coords[0]);this.y=parseFloat(coords[1]);this.z=parseFloat(coords[2])||0.0;}else{this.x=x;this.y=y;this.z=z||0.0;}},clone:function(){return new Proj4js.Point(this.x,this.y,this.z);},toString:function(){return("x="+this.x+",y="+this.y);},toShortString:function(){return(this.x+", "+this.y);}});Proj4js.PrimeMeridian={"greenwich":0.0,"lisbon":-9.131906111111,"paris":2.337229166667,"bogota":-74.
 470,0.8421,-20.4894",ellipse:"airy",datumName:"Airy 1830"}};Proj4js.WGS84=new Proj4js.Proj('WGS84');Proj4js.Datum['OSB36']=Proj4js.Datum['OSGB36'];Proj4js.wktProjections={"Lambert Tangential Conformal Conic Projection":"lcc","Mercator":"merc","Transverse_Mercator":"tmerc","Transverse Mercator":"tmerc","Lambert Azimuthal Equal Area":"laea","Universal Transverse Mercator System":"utm"};Proj4js.Proj.aea={init:function(){if(Math.abs(this.lat1+this.lat2)<Proj4js.common.EPSLN){Proj4js.reportError("aeaInitEqualLatitudes");return;}
 this.temp=this.b/this.a;this.es=1.0-Math.pow(this.temp,2);this.e3=Math.sqrt(this.es);this.sin_po=Math.sin(this.lat1);this.cos_po=Math.cos(this.lat1);this.t1=this.sin_po;this.con=this.sin_po;this.ms1=Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);this.qs1=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);this.sin_po=Math.sin(this.lat2);this.cos_po=Math.cos(this.lat2);this.t2=this.sin_po;this.ms2=Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);this.qs2=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);this.sin_po=Math.sin(this.lat0);this.cos_po=Math.cos(this.lat0);this.t3=this.sin_po;this.qs0=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);if(Math.abs(this.lat1-this.lat2)>Proj4js.common.EPSLN){this.ns0=(this.ms1*this.ms1-this.ms2*this.ms2)/(this.qs2-this.qs1);}else{this.ns0=this.con;}
 this.c=this.ms1*this.ms1+this.ns0*this.qs1;this.rh=this.a*Math.sqrt(this.c-this.ns0*this.qs0)/this.ns0;},forward:function(p){var lon=p.x;var lat=p.y;this.sin_phi=Math.sin(lat);this.cos_phi=Math.cos(lat);var qs=Proj4js.common.qsfnz(this.e3,this.sin_phi,this.cos_phi);var rh1=this.a*Math.sqrt(this.c-this.ns0*qs)/this.ns0;var theta=this.ns0*Proj4js.common.adjust_lon(lon-this.long0);var x=rh1*Math.sin(theta)+this.x0;var y=this.rh-rh1*Math.cos(theta)+this.y0;p.x=x;p.y=y;return p;},inverse:function(p){var rh1,qs,con,theta,lon,lat;p.x-=this.x0;p.y=this.rh-p.y+this.y0;if(this.ns0>=0){rh1=Math.sqrt(p.x*p.x+p.y*p.y);con=1.0;}else{rh1=-Math.sqrt(p.x*p.x+p.y*p.y);con=-1.0;}
 theta=0.0;if(rh1!=0.0){theta=Math.atan2(con*p.x,con*p.y);}
@@ -109,7 +118,7 @@
 this.lat0=0.0;this.long0=((6*Math.abs(this.zone))-183)*Proj4js.common.D2R;this.x0=500000.0;this.y0=this.utmSouth?10000000.0:0.0;this.k0=0.9996;Proj4js.Proj['tmerc'].init.apply(this);this.forward=Proj4js.Proj['tmerc'].forward;this.inverse=Proj4js.Proj['tmerc'].inverse;}};Proj4js.Proj.eqdc={init:function(){if(!this.mode)this.mode=0;this.temp=this.b/this.a;this.es=1.0-Math.pow(this.temp,2);this.e=Math.sqrt(this.es);this.e0=Proj4js.common.e0fn(this.es);this.e1=Proj4js.common.e1fn(this.es);this.e2=Proj4js.common.e2fn(this.es);this.e3=Proj4js.common.e3fn(this.es);this.sinphi=Math.sin(this.lat1);this.cosphi=Math.cos(this.lat1);this.ms1=Proj4js.common.msfnz(this.e,this.sinphi,this.cosphi);this.ml1=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,this.lat1);if(this.mode!=0){if(Math.abs(this.lat1+this.lat2)<Proj4js.common.EPSLN){Proj4js.reportError("eqdc:Init:EqualLatitudes");}
 this.sinphi=Math.sin(this.lat2);this.cosphi=Math.cos(this.lat2);this.ms2=Proj4js.common.msfnz(this.e,this.sinphi,this.cosphi);this.ml2=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,this.lat2);if(Math.abs(this.lat1-this.lat2)>=Proj4js.common.EPSLN){this.ns=(this.ms1-this.ms2)/(this.ml2-this.ml1);}else{this.ns=this.sinphi;}}else{this.ns=this.sinphi;}
 this.g=this.ml1+this.ms1/this.ns;this.ml0=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,this.lat0);this.rh=this.a*(this.g-this.ml0);},forward:function(p){var lon=p.x;var lat=p.y;var ml=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,lat);var rh1=this.a*(this.g-ml);var theta=this.ns*Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+rh1*Math.sin(theta);var y=this.y0+this.rh-rh1*Math.cos(theta);p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y=this.rh-p.y+this.y0;var con,rh1;if(this.ns>=0){var rh1=Math.sqrt(p.x*p.x+p.y*p.y);var con=1.0;}else{rh1=-Math.sqrt(p.x*p.x+p.y*p.y);con=-1.0;}
-var theta=0.0;if(rh1!=0.0)theta=Math.atan2(con*p.x,con*p.y);var ml=this.g-rh1/this.a;var lat=this.phi3z(this.ml,this.e0,this.e1,this.e2,this.e3);var lon=Proj4js.common.adjust_lon(this.long0+theta/this.ns);p.x=lon;p.y=lat;return p;},phi3z:function(ml,e0,e1,e2,e3){var phi;var dphi;phi=ml;for(var i=0;i<15;i++){dphi=(ml+e1*Math.sin(2.0*phi)-e2*Math.sin(4.0*phi)+e3*Math.sin(6.0*phi))/e0-phi;phi+=dphi;if(Math.abs(dphi)<=.0000000001){return phi;}}
+var theta=0.0;if(rh1!=0.0)theta=Math.atan2(con*p.x,con*p.y);var ml=this.g-rh1/this.a;var lat=this.phi3z(ml,this.e0,this.e1,this.e2,this.e3);var lon=Proj4js.common.adjust_lon(this.long0+theta/this.ns);p.x=lon;p.y=lat;return p;},phi3z:function(ml,e0,e1,e2,e3){var phi;var dphi;phi=ml;for(var i=0;i<15;i++){dphi=(ml+e1*Math.sin(2.0*phi)-e2*Math.sin(4.0*phi)+e3*Math.sin(6.0*phi))/e0-phi;phi+=dphi;if(Math.abs(dphi)<=.0000000001){return phi;}}
 Proj4js.reportError("PHI3Z-CONV:Latitude failed to converge after 15 iterations");return null;}};Proj4js.Proj.tmerc={init:function(){this.e0=Proj4js.common.e0fn(this.es);this.e1=Proj4js.common.e1fn(this.es);this.e2=Proj4js.common.e2fn(this.es);this.e3=Proj4js.common.e3fn(this.es);this.ml0=this.a*Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,this.lat0);},forward:function(p){var lon=p.x;var lat=p.y;var delta_lon=Proj4js.common.adjust_lon(lon-this.long0);var con;var x,y;var sin_phi=Math.sin(lat);var cos_phi=Math.cos(lat);if(this.sphere){var b=cos_phi*Math.sin(delta_lon);if((Math.abs(Math.abs(b)-1.0))<.0000000001){Proj4js.reportError("tmerc:forward: Point projects into infinity");return(93);}else{x=.5*this.a*this.k0*Math.log((1.0+b)/(1.0-b));con=Math.acos(cos_phi*Math.cos(delta_lon)/Math.sqrt(1.0-b*b));if(lat<0)con=-con;y=this.a*this.k0*(con-this.lat0);}}else{var al=cos_phi*delta_lon;var als=Math.pow(al,2);var c=this.ep2*Math.pow(cos_phi,2);var tq=Math.tan(lat);var t=Math.
 pow(tq,2);con=1.0-this.es*Math.pow(sin_phi,2);var n=this.a/Math.sqrt(con);var ml=this.a*Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,lat);x=this.k0*n*al*(1.0+als/6.0*(1.0-t+c+als/20.0*(5.0-18.0*t+Math.pow(t,2)+72.0*c-58.0*this.ep2)))+this.x0;y=this.k0*(ml-this.ml0+n*tq*(als*(0.5+als/24.0*(5.0-t+9.0*c+4.0*Math.pow(c,2)+als/30.0*(61.0-58.0*t+Math.pow(t,2)+600.0*c-330.0*this.ep2)))))+this.y0;}
 p.x=x;p.y=y;return p;},inverse:function(p){var con,phi;var delta_phi;var i;var max_iter=6;var lat,lon;if(this.sphere){var f=Math.exp(p.x/(this.a*this.k0));var g=.5*(f-1/f);var temp=this.lat0+p.y/(this.a*this.k0);var h=Math.cos(temp);con=Math.sqrt((1.0-h*h)/(1.0+g*g));lat=Proj4js.common.asinz(con);if(temp<0)
 lat=-lat;if((g==0)&&(h==0)){lon=this.long0;}else{lon=Proj4js.common.adjust_lon(Math.atan2(g,h)+this.long0);}}else{var x=p.x-this.x0;var y=p.y-this.y0;con=(this.ml0+y/this.k0)/this.a;phi=con;for(i=0;true;i++){delta_phi=((con+this.e1*Math.sin(2.0*phi)-this.e2*Math.sin(4.0*phi)+this.e3*Math.sin(6.0*phi))/this.e0)-phi;phi+=delta_phi;if(Math.abs(delta_phi)<=Proj4js.common.EPSLN)break;if(i>=max_iter){Proj4js.reportError("tmerc:inverse: Latitude failed to converge");return(95);}}
@@ -117,9 +126,8 @@
 p.x=lon;p.y=lat;return p;}};Proj4js.defs["GOOGLE"]="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs";Proj4js.defs["EPSG:900913"]=Proj4js.defs["GOOGLE"];Proj4js.Proj.gstmerc={init:function(){var temp=this.b/this.a;this.e=Math.sqrt(1.0-temp*temp);this.lc=this.long0;this.rs=Math.sqrt(1.0+this.e*this.e*Math.pow(Math.cos(this.lat0),4.0)/(1.0-this.e*this.e));var sinz=Math.sin(this.lat0);var pc=Math.asin(sinz/this.rs);var sinzpc=Math.sin(pc);this.cp=Proj4js.common.latiso(0.0,pc,sinzpc)-this.rs*Proj4js.common.latiso(this.e,this.lat0,sinz);this.n2=this.k0*this.a*Math.sqrt(1.0-this.e*this.e)/(1.0-this.e*this.e*sinz*sinz);this.xs=this.x0;this.ys=this.y0-this.n2*pc;if(!this.title)this.title="Gauss Schreiber transverse mercator";},forward:function(p){var lon=p.x;var lat=p.y;var L=this.rs*(lon-this.lc);var Ls=this.cp+(this.rs*Proj4js.common.latiso(this.e,lat,Math.sin(lat)));var lat1=Math.asin(Math.sin(L)/Proj4js.common.cosh(
 Ls));var Ls1=Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));p.x=this.xs+(this.n2*Ls1);p.y=this.ys+(this.n2*Math.atan(Proj4js.common.sinh(Ls)/Math.cos(L)));return p;},inverse:function(p){var x=p.x;var y=p.y;var L=Math.atan(Proj4js.common.sinh((x-this.xs)/this.n2)/Math.cos((y-this.ys)/this.n2));var lat1=Math.asin(Math.sin((y-this.ys)/this.n2)/Proj4js.common.cosh((x-this.xs)/this.n2));var LC=Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));p.x=this.lc+L/this.rs;p.y=Proj4js.common.invlatiso(this.e,(LC-this.cp)/this.rs);return p;}};Proj4js.Proj.ortho={init:function(def){;this.sin_p14=Math.sin(this.lat0);this.cos_p14=Math.cos(this.lat0);},forward:function(p){var sinphi,cosphi;var dlon;var coslon;var ksp;var g;var lon=p.x;var lat=p.y;dlon=Proj4js.common.adjust_lon(lon-this.long0);sinphi=Math.sin(lat);cosphi=Math.cos(lat);coslon=Math.cos(dlon);g=this.sin_p14*sinphi+this.cos_p14*cosphi*coslon;ksp=1.0;if((g>0)||(Math.abs(g)<=Proj4js.common.EPSLN)){var x=this.a*ksp*cosphi*Math.sin(dlon);
 var y=this.y0+this.a*ksp*(this.cos_p14*sinphi-this.sin_p14*cosphi*coslon);}else{Proj4js.reportError("orthoFwdPointError");}
 p.x=x;p.y=y;return p;},inverse:function(p){var rh;var z;var sinz,cosz;var temp;var con;var lon,lat;p.x-=this.x0;p.y-=this.y0;rh=Math.sqrt(p.x*p.x+p.y*p.y);if(rh>this.a+.0000001){Proj4js.reportError("orthoInvDataError");}
 z=Proj4js.common.asinz(rh/this.a);sinz=Math.sin(z);cosz=Math.cos(z);lon=this.long0;if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=this.lat0;}
-lat=Proj4js.common.asinz(cosz*this.sin_p14+(p.y*sinz*this.cos_p14)/rh);con=Math.abs(lat0)-Proj4js.common.HALF_PI;if(Math.abs(con)<=Proj4js.common.EPSLN){if(this.lat0>=0){lon=Proj4js.common.adjust_lon(this.long0+Math.atan2(p.x,-p.y));}else{lon=Proj4js.common.adjust_lon(this.long0-Math.atan2(-p.x,p.y));}}
-con=cosz-this.sin_p14*Math.sin(lat);if((Math.abs(con)>=Proj4js.common.EPSLN)||(Math.abs(x)>=Proj4js.common.EPSLN)){lon=Proj4js.common.adjust_lon(this.long0+Math.atan2((p.x*sinz*this.cos_p14),(con*rh)));}
-p.x=lon;p.y=lat;return p;}};Proj4js.Proj.somerc={init:function(){var phy0=this.lat0;this.lambda0=this.long0;var sinPhy0=Math.sin(phy0);var semiMajorAxis=this.a;var invF=this.rf;var flattening=1/invF;var e2=2*flattening-Math.pow(flattening,2);var e=this.e=Math.sqrt(e2);this.R=semiMajorAxis*Math.sqrt(1-e2)/(1-e2*Math.pow(sinPhy0,2.0));this.alpha=Math.sqrt(1+e2/(1-e2)*Math.pow(Math.cos(phy0),4.0));this.b0=Math.asin(sinPhy0/this.alpha);this.K=Math.log(Math.tan(Math.PI/4.0+this.b0/2.0))
+lat=Proj4js.common.asinz(cosz*this.sin_p14+(p.y*sinz*this.cos_p14)/rh);con=Math.abs(this.lat0)-Proj4js.common.HALF_PI;if(Math.abs(con)<=Proj4js.common.EPSLN){if(this.lat0>=0){lon=Proj4js.common.adjust_lon(this.long0+Math.atan2(p.x,-p.y));}else{lon=Proj4js.common.adjust_lon(this.long0-Math.atan2(-p.x,p.y));}}
+con=cosz-this.sin_p14*Math.sin(lat);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.somerc={init:function(){var phy0=this.lat0;this.lambda0=this.long0;var sinPhy0=Math.sin(phy0);var semiMajorAxis=this.a;var invF=this.rf;var flattening=1/invF;var e2=2*flattening-Math.pow(flattening,2);var e=this.e=Math.sqrt(e2);this.R=this.k0*semiMajorAxis*Math.sqrt(1-e2)/(1-e2*Math.pow(sinPhy0,2.0));this.alpha=Math.sqrt(1+e2/(1-e2)*Math.pow(Math.cos(phy0),4.0));this.b0=Math.asin(sinPhy0/this.alpha);this.K=Math.log(Math.tan(Math.PI/4.0+this.b0/2.0))
 -this.alpha*Math.log(Math.tan(Math.PI/4.0+phy0/2.0))
 +this.alpha*e/2*Math.log((1+e*sinPhy0)/(1-e*sinPhy0));},forward:function(p){var Sa1=Math.log(Math.tan(Math.PI/4.0-p.y/2.0));var Sa2=this.e/2.0*Math.log((1+this.e*Math.sin(p.y))/(1-this.e*Math.sin(p.y)));var S=-this.alpha*(Sa1+Sa2)+this.K;var b=2.0*(Math.atan(Math.exp(S))-Math.PI/4.0);var I=this.alpha*(p.x-this.lambda0);var rotI=Math.atan(Math.sin(I)/(Math.sin(this.b0)*Math.tan(b)+
 Math.cos(this.b0)*Math.cos(I)));var rotB=Math.asin(Math.cos(this.b0)*Math.sin(b)-
@@ -152,7 +160,7 @@
 th_n_re=1;th_n_im=0;var den_re=this.B_re[1];var den_im=this.B_im[1];for(n=2;n<=6;n++){th_n_re1=th_n_re*th_re-th_n_im*th_im;th_n_im1=th_n_im*th_re+th_n_re*th_im;th_n_re=th_n_re1;th_n_im=th_n_im1;den_re=den_re+n*(this.B_re[n]*th_n_re-this.B_im[n]*th_n_im);den_im=den_im+n*(this.B_im[n]*th_n_re+this.B_re[n]*th_n_im);}
 var den2=den_re*den_re+den_im*den_im;th_re=(num_re*den_re+num_im*den_im)/den2;th_im=(num_im*den_re-num_re*den_im)/den2;}
 var d_psi=th_re;var d_lambda=th_im;var d_psi_n=1;var d_phi=0;for(n=1;n<=9;n++){d_psi_n=d_psi_n*d_psi;d_phi=d_phi+this.D[n]*d_psi_n;}
-var lat=this.lat0+(d_phi*Proj4js.common.SEC_TO_RAD*1E5);var lon=this.long0+d_lambda;p.x=lon;p.y=lat;return p;}};Proj4js.Proj.mill={init:function(){},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+this.a*dlon;var y=this.y0+this.a*Math.log(Math.tan((Proj4js.common.PI/4.0)+(lat/2.5)))*1.25;p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var lon=Proj4js.common.adjust_lon(this.long0+p.x/this.a);var lat=2.5*(Math.atan(Math.exp(0.8*p.y/this.a))-Proj4js.common.PI/4.0);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.gnom={init:function(def){this.sin_p14=Math.sin(this.lat0);this.cos_p14=Math.cos(this.lat0);this.infinity_dist=1000*this.a;},forward:function(p){var sinphi,cosphi;var dlon;var coslon;var ksp;var g;var lon=p.x;var lat=p.y;dlon=Proj4js.common.adjust_lon(lon-this.long0);sinphi=Math.sin(lat);cosphi=Math.cos(lat);coslon=Math.cos(dlon);g=this.sin_p14*sinphi+this.cos_p14*cosphi*coslon;ksp=1.0;if((g>0)||(M
 ath.abs(g)<=Proj4js.common.EPSLN)){x=this.x0+this.a*ksp*cosphi*Math.sin(dlon)/g;y=this.y0+this.a*ksp*(this.cos_p14*sinphi-this.sin_p14*cosphi*coslon)/g;}else{Proj4js.reportError("orthoFwdPointError");x=this.x0+this.infinity_dist*cosphi*Math.sin(dlon);y=this.y0+this.infinity_dist*(this.cos_p14*sinphi-this.sin_p14*cosphi*coslon);}
+var lat=this.lat0+(d_phi*Proj4js.common.SEC_TO_RAD*1E5);var lon=this.long0+d_lambda;p.x=lon;p.y=lat;return p;}};Proj4js.Proj.mill={init:function(){},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+this.a*dlon;var y=this.y0+this.a*Math.log(Math.tan((Proj4js.common.PI/4.0)+(lat/2.5)))*1.25;p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var lon=Proj4js.common.adjust_lon(this.long0+p.x/this.a);var lat=2.5*(Math.atan(Math.exp(0.8*p.y/this.a))-Proj4js.common.PI/4.0);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.gnom={init:function(def){this.sin_p14=Math.sin(this.lat0);this.cos_p14=Math.cos(this.lat0);this.infinity_dist=1000*this.a;this.rc=1;},forward:function(p){var sinphi,cosphi;var dlon;var coslon;var ksp;var g;var lon=p.x;var lat=p.y;dlon=Proj4js.common.adjust_lon(lon-this.long0);sinphi=Math.sin(lat);cosphi=Math.cos(lat);coslon=Math.cos(dlon);g=this.sin_p14*sinphi+this.cos_p14*cosphi*coslon;ksp=1.0;if
 ((g>0)||(Math.abs(g)<=Proj4js.common.EPSLN)){x=this.x0+this.a*ksp*cosphi*Math.sin(dlon)/g;y=this.y0+this.a*ksp*(this.cos_p14*sinphi-this.sin_p14*cosphi*coslon)/g;}else{Proj4js.reportError("orthoFwdPointError");x=this.x0+this.infinity_dist*cosphi*Math.sin(dlon);y=this.y0+this.infinity_dist*(this.cos_p14*sinphi-this.sin_p14*cosphi*coslon);}
 p.x=x;p.y=y;return p;},inverse:function(p){var rh;var z;var sinc,cosc;var c;var lon,lat;p.x=(p.x-this.x0)/this.a;p.y=(p.y-this.y0)/this.a;p.x/=this.k0;p.y/=this.k0;if((rh=Math.sqrt(p.x*p.x+p.y*p.y))){c=Math.atan2(rh,this.rc);sinc=Math.sin(c);cosc=Math.cos(c);lat=Proj4js.common.asinz(cosc*this.sin_p14+(p.y*sinc*this.cos_p14)/rh);lon=Math.atan2(p.x*sinc,rh*this.cos_p14*cosc-p.y*this.sin_p14*sinc);lon=Proj4js.common.adjust_lon(this.long0+lon);}else{lat=this.phic0;lon=0.0;}
 p.x=lon;p.y=lat;return p;}};Proj4js.Proj.sinu={init:function(){this.R=6370997.0;},forward:function(p){var x,y,delta_lon;var lon=p.x;var lat=p.y;delta_lon=Proj4js.common.adjust_lon(lon-this.long0);x=this.R*delta_lon*Math.cos(lat)+this.x0;y=this.R*lat+this.y0;p.x=x;p.y=y;return p;},inverse:function(p){var lat,temp,lon;p.x-=this.x0;p.y-=this.y0;lat=p.y/this.R;if(Math.abs(lat)>Proj4js.common.HALF_PI){Proj4js.reportError("sinu:Inv:DataError");}
 temp=Math.abs(lat)-Proj4js.common.HALF_PI;if(Math.abs(temp)>Proj4js.common.EPSLN){temp=this.long0+p.x/(this.R*Math.cos(lat));lon=Proj4js.common.adjust_lon(temp);}else{lon=this.long0;}
@@ -161,7 +169,7 @@
 var al=.5*Math.abs((Proj4js.common.PI/dlon)-(dlon/Proj4js.common.PI));var asq=al*al;var sinth=Math.sin(theta);var costh=Math.cos(theta);var g=costh/(sinth+costh-1.0);var gsq=g*g;var m=g*(2.0/sinth-1.0);var msq=m*m;var con=Proj4js.common.PI*this.R*(al*(g-msq)+Math.sqrt(asq*(g-msq)*(g-msq)-(msq+asq)*(gsq-msq)))/(msq+asq);if(dlon<0){con=-con;}
 x=this.x0+con;con=Math.abs(con/(Proj4js.common.PI*this.R));if(lat>=0){y=this.y0+Proj4js.common.PI*this.R*Math.sqrt(1.0-con*con-2.0*al*con);}else{y=this.y0-Proj4js.common.PI*this.R*Math.sqrt(1.0-con*con-2.0*al*con);}
 p.x=x;p.y=y;return p;},inverse:function(p){var dlon;var xx,yy,xys,c1,c2,c3;var al,asq;var a1;var m1;var con;var th1;var d;p.x-=this.x0;p.y-=this.y0;con=Proj4js.common.PI*this.R;xx=p.x/con;yy=p.y/con;xys=xx*xx+yy*yy;c1=-Math.abs(yy)*(1.0+xys);c2=c1-2.0*yy*yy+xx*xx;c3=-2.0*c1+1.0+2.0*yy*yy+xys*xys;d=yy*yy/c3+(2.0*c2*c2*c2/c3/c3/c3-9.0*c1*c2/c3/c3)/27.0;a1=(c1-c2*c2/3.0/c3)/c3;m1=2.0*Math.sqrt(-a1/3.0);con=((3.0*d)/a1)/m1;if(Math.abs(con)>1.0){if(con>=0.0){con=1.0;}else{con=-1.0;}}
-th1=Math.acos(con)/3.0;if(p.y>=0){lat=(-m1*Math.cos(th1+Proj4js.common.PI/3.0)-c2/3.0/c3)*Proj4js.common.PI;}else{lat=-(-m1*Math.cos(th1+PI/3.0)-c2/3.0/c3)*Proj4js.common.PI;}
+th1=Math.acos(con)/3.0;if(p.y>=0){lat=(-m1*Math.cos(th1+Proj4js.common.PI/3.0)-c2/3.0/c3)*Proj4js.common.PI;}else{lat=-(-m1*Math.cos(th1+Proj4js.common.PI/3.0)-c2/3.0/c3)*Proj4js.common.PI;}
 if(Math.abs(xx)<Proj4js.common.EPSLN){lon=this.long0;}
 lon=Proj4js.common.adjust_lon(this.long0+Proj4js.common.PI*(xys-1.0+Math.sqrt(1.0+2.0*(xx*xx-yy*yy)+xys*xys))/2.0/xx);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.cea={init:function(){},forward:function(p){var lon=p.x;var lat=p.y;dlon=Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+this.a*dlon*Math.cos(this.lat_ts);var y=this.y0+this.a*Math.sin(lat)/Math.cos(this.lat_ts);p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var lon=Proj4js.common.adjust_lon(this.long0+(p.x/this.a)/Math.cos(this.lat_ts));var lat=Math.asin((p.y/this.a)*Math.cos(this.lat_ts));p.x=lon;p.y=lat;return p;}};Proj4js.Proj.eqc={init:function(){if(!this.x0)this.x0=0;if(!this.y0)this.y0=0;if(!this.lat0)this.lat0=0;if(!this.long0)this.long0=0;if(!this.lat_ts)this.lat_ts=0;if(!this.title)this.title="Equidistant Cylindrical (Plate Carre)";this.rc=Math.cos(this.lat_ts);},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var dlat=Proj4js.common.
 adjust_lat(lat-this.lat0);p.x=this.x0+(this.a*dlon*this.rc);p.y=this.y0+(this.a*dlat);return p;},inverse:function(p){var x=p.x;var y=p.y;p.x=Proj4js.common.adjust_lon(this.long0+((x-this.x0)/(this.a*this.rc)));p.y=Proj4js.common.adjust_lat(this.lat0+((y-this.y0)/(this.a)));return p;}};Proj4js.Proj.cass={init:function(){if(!this.sphere){this.en=this.pj_enfn(this.es)
 this.m0=this.pj_mlfn(this.lat0,Math.sin(this.lat0),Math.cos(this.lat0),this.en);}},C1:.16666666666666666666,C2:.00833333333333333333,C3:.04166666666666666666,C4:.33333333333333333333,C5:.06666666666666666666,forward:function(p){var x,y;var lam=p.x;var phi=p.y;lam=Proj4js.common.adjust_lon(lam-this.long0);if(this.sphere){x=Math.asin(Math.cos(phi)*Math.sin(lam));y=Math.atan2(Math.tan(phi),Math.cos(lam))-this.phi0;}else{this.n=Math.sin(phi);this.c=Math.cos(phi);y=this.pj_mlfn(phi,this.n,this.c,this.en);this.n=1./Math.sqrt(1.-this.es*this.n*this.n);this.tn=Math.tan(phi);this.t=this.tn*this.tn;this.a1=lam*this.c;this.c*=this.es*this.c/(1-this.es);this.a2=this.a1*this.a1;x=this.n*this.a1*(1.-this.a2*this.t*(this.C1-(8.-this.t+8.*this.c)*this.a2*this.C2));y-=this.m0-this.n*this.tn*this.a2*(.5+(5.-this.t+6.*this.c)*this.a2*this.C3);}
@@ -187,7 +195,7 @@
 this.f0=ms1/(this.ns*Math.pow(ts1,this.ns));this.rh=this.a*this.f0*Math.pow(ts0,this.ns);if(!this.title)this.title="Lambert Conformal Conic";},forward:function(p){var lon=p.x;var lat=p.y;if(lat<=90.0&&lat>=-90.0&&lon<=180.0&&lon>=-180.0){}else{Proj4js.reportError("lcc:forward: llInputOutOfRange: "+lon+" : "+lat);return null;}
 var con=Math.abs(Math.abs(lat)-Proj4js.common.HALF_PI);var ts,rh1;if(con>Proj4js.common.EPSLN){ts=Proj4js.common.tsfnz(this.e,lat,Math.sin(lat));rh1=this.a*this.f0*Math.pow(ts,this.ns);}else{con=lat*this.ns;if(con<=0){Proj4js.reportError("lcc:forward: No Projection");return null;}
 rh1=0;}
-var theta=this.ns*Proj4js.common.adjust_lon(lon-this.long0);p.x=this.k0*(rh1*Math.sin(theta))+this.x0;p.y=this.k0*(this.rh-rh1*Math.cos(theta))+this.y0;return p;},inverse:function(p){var rh1,con,ts;var lat,lon;x=(p.x-this.x0)/this.k0;y=(this.rh-(p.y-this.y0)/this.k0);if(this.ns>0){rh1=Math.sqrt(x*x+y*y);con=1.0;}else{rh1=-Math.sqrt(x*x+y*y);con=-1.0;}
+var theta=this.ns*Proj4js.common.adjust_lon(lon-this.long0);p.x=this.k0*(rh1*Math.sin(theta))+this.x0;p.y=this.k0*(this.rh-rh1*Math.cos(theta))+this.y0;return p;},inverse:function(p){var rh1,con,ts;var lat,lon;var x=(p.x-this.x0)/this.k0;var y=(this.rh-(p.y-this.y0)/this.k0);if(this.ns>0){rh1=Math.sqrt(x*x+y*y);con=1.0;}else{rh1=-Math.sqrt(x*x+y*y);con=-1.0;}
 var theta=0.0;if(rh1!=0){theta=Math.atan2((con*x),(con*y));}
 if((rh1!=0)||(this.ns>0.0)){con=1.0/this.ns;ts=Math.pow((rh1/(this.a*this.f0)),con);lat=Proj4js.common.phi2z(this.e,ts);if(lat==-9999)return null;}else{lat=-Proj4js.common.HALF_PI;}
 lon=Proj4js.common.adjust_lon(theta/this.ns+this.long0);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.laea={S_POLE:1,N_POLE:2,EQUIT:3,OBLIQ:4,init:function(){var t=Math.abs(this.lat0);if(Math.abs(t-Proj4js.common.HALF_PI)<Proj4js.common.EPSLN){this.mode=this.lat0<0.?this.S_POLE:this.N_POLE;}else if(Math.abs(t)<Proj4js.common.EPSLN){this.mode=this.EQUIT;}else{this.mode=this.OBLIQ;}
Modified: trunk/widgets/Measure.js
--- trunk/widgets/Measure.js	2010-08-10 19:38:28 UTC (rev 2198)
+++ trunk/widgets/Measure.js	2010-08-11 18:51:20 UTC (rev 2199)
@@ -80,6 +80,9 @@
         if(json.SegmentLabels){
             this.segmentLabels = (json.SegmentLabels[0].toLowerCase == "true" && json.SegmentLabels[0]) ? true : false;
+        if(json.Geodesic){
+            this.geodesic = (json.Geodesic[0].toLowerCase == "false") ? false : true;
         this.sTarget = json.Target ? json.Target[0] : "";
         this.sBaseUrl = Fusion.getFusionURL() + 'widgets/Measure/Measure.php';
@@ -636,8 +639,12 @@
      * Subsequent calls from a ViewOptions widget would override the value specified.
     setUnits: function(units) {
-      units = (units == Fusion.UNKNOWN)?Fusion.unitFromName(this.getMap().getUnits()):units;
+      var map = this.getMap();
+      units = (units == Fusion.UNKNOWN)?Fusion.unitFromName(map.getUnits()):units;
       this.setParameter('Units', Fusion.unitName(units));
+      if (map.oMapOL.baseLayer.projection.proj && map.oMapOL.baseLayer.projection.proj.localCS) {
+        this.geodesic = false;
     setParameter: function(param, value) {
More information about the fusion-commits mailing list
