[fusion-commits] r2295 - in branches/fusion-2.2/widgets/Theme: classes templates
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Dec 6 04:17:57 EST 2010
Author: liuar
Date: 2010-12-06 01:17:57 -0800 (Mon, 06 Dec 2010)
New Revision: 2295
Added:
   branches/fusion-2.2/widgets/Theme/templates/arearuletemplate-2.3.0-Enhanced.xml
   branches/fusion-2.2/widgets/Theme/templates/arearuletemplate-2.3.0.xml
   branches/fusion-2.2/widgets/Theme/classes/theme.php
Port Ticket #421 to fusion 2.2 branch
MapGuide upgraded LayerDefinition schema from 1.3.0 to 2.3.0.
So, the theme widget need to be enhanced to support the latest version of layer definition.
The new layer definition could be found at  http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Common/Schema/LayerDefinition-2.3.0.xsd
Modified: branches/fusion-2.2/widgets/Theme/classes/theme.php
--- branches/fusion-2.2/widgets/Theme/classes/theme.php	2010-12-03 03:33:57 UTC (rev 2294)
+++ branches/fusion-2.2/widgets/Theme/classes/theme.php	2010-12-06 09:17:57 UTC (rev 2295)
@@ -257,22 +257,51 @@
         $areaTypeStyle = $vectorScaleRangecElement->getElementsByTagName('AreaTypeStyle')->item(0);
         // Remove any existing <AreaRule> elements.
+        if($areaTypeStyle != null)
+            $areaRuleList = $areaTypeStyle->getElementsByTagName('AreaRule');
+            $ruleCount = $areaRuleList->length;
+            for($index = 0; $index < $ruleCount; $index++)
+                $areaTypeStyle->removeChild($areaRuleList->item(0));
-        $areaRuleList = $areaTypeStyle->getElementsByTagName('AreaRule');
-        $ruleCount = $areaRuleList->length;
-        for($index = 0; $index < $ruleCount; $index++)
-            $areaTypeStyle->removeChild($areaRuleList->item(0));
+            $hasChild = $areaTypeStyle->hasChildNodes();
+            if($hasChild)
+              $element = $areaTypeStyle->childNodes->item(0);
-        $hasChild = $areaTypeStyle->hasChildNodes();
-        if($hasChild)
+        $CompositeTypeStyles = $vectorScaleRangecElement->getElementsByTagName('CompositeTypeStyle');
+        // Remove any existing <CompositeTypeStyle> elements with Polygon <GeometryContext>.
+        if($CompositeTypeStyles != null)
-          $element = $areaTypeStyle->childNodes->item(0);
+            $template = 'templates/arearuletemplate-'.$version.'-Enhanced.xml';
+            $styleCount = $CompositeTypeStyles->length;
+            for($index = 0; $index < $styleCount; $index++)
+                $CompositeTypeStyle = $CompositeTypeStyles->item($index);
+                $GeometryContexts = $CompositeTypeStyle->getElementsByTagName('GeometryContext');
+                $contextCount = $GeometryContexts->length;
+                for($i = 0; $i < $contextCount; $i++)
+                    $GeometryContext = $GeometryContexts->item($i);
+                    if($GeometryContext->nodeValue == 'Polygon')
+                        $vectorScaleRangecElement->removeChild($CompositeTypeStyle);
+                        $index--;
+                        $styleCount--;
+                        break;
-        // Now create the new <AreaRule> elements.
+        // Now create the new <AreaRule> or <CompositeTypeStyle> elements.
         $areaRuleTemplate = file_get_contents($template);
         $aggregateOptions = new MgFeatureAggregateOptions();
@@ -316,13 +345,22 @@
                 $areaDoc = DOMDocument::loadXML($areaRuleXML);
                 $areaNode = $doc->importNode($areaDoc->documentElement, true);
-                if($hasChild)
-                  $areaTypeStyle->insertBefore($areaNode, $element);
+                    if($hasChild)
+                      $areaTypeStyle->insertBefore($areaNode, $element);
+                    else
+                      $areaTypeStyle->appendChild($areaNode);
-                else
-                  $areaTypeStyle->appendChild($areaNode);
+                    $compositeTypeStyle = $doc->createElement('CompositeTypeStyle');
+                    $compositeTypeStyle->appendChild($areaNode);
+                    $vectorScaleRangecElement->appendChild($compositeTypeStyle);
                 $portion += $increment;
@@ -361,13 +399,22 @@
-                if($hasChild)
+                    if($hasChild)
+                    else
-                else
Added: branches/fusion-2.2/widgets/Theme/templates/arearuletemplate-2.3.0-Enhanced.xml
--- branches/fusion-2.2/widgets/Theme/templates/arearuletemplate-2.3.0-Enhanced.xml	                        (rev 0)
+++ branches/fusion-2.2/widgets/Theme/templates/arearuletemplate-2.3.0-Enhanced.xml	2010-12-06 09:17:57 UTC (rev 2295)
@@ -0,0 +1,85 @@
+<CompositeRule>
+  <LegendLabel>%s</LegendLabel>
+  <Filter>%s</Filter>
+  <CompositeSymbolization>
+    <SymbolInstance>
+      <SimpleSymbolDefinition>
+        <Name>Solid Fill</Name>
+        <Description>Default Area Symbol</Description>
+        <Graphics>
+          <Path>
+            <Geometry>M 0.0,0.0 h 100.0 v 100.0 h -100.0 z</Geometry>
+            <FillColor>%s</FillColor>
+          </Path>
+        </Graphics>
+        <AreaUsage>
+          <RepeatX>100.0</RepeatX>
+          <RepeatY>100.0</RepeatY>
+        </AreaUsage>
+        <ParameterDefinition>
+          <Parameter>
+            <Identifier>FILLCOLOR</Identifier>
+            <DefaultValue>0xffbfbfbf</DefaultValue>
+            <DisplayName>&amp;Fill Color</DisplayName>
+            <Description>Fill Color</Description>
+            <DataType>FillColor</DataType>
+          </Parameter>
+        </ParameterDefinition>
+      </SimpleSymbolDefinition>
+      <ParameterOverrides>
+        <Override>
+          <SymbolName>Solid Fill</SymbolName>
+          <ParameterIdentifier>FILLCOLOR</ParameterIdentifier>
+          <ParameterValue>0xffbfbfbf</ParameterValue>
+        </Override>
+      </ParameterOverrides>
+      <GeometryContext>Polygon</GeometryContext>
+    </SymbolInstance>
+    <SymbolInstance>
+        <Name>Solid Line</Name>
+        <Description>Default Line Symbol</Description>
+        <Graphics>
+          <Path>
+            <Geometry>M 0.0,0.0 L 1.0,0.0</Geometry>
+            <LineColor>%s</LineColor>
+            <LineWeight>0.0</LineWeight>
+            <LineWeightScalable>false</LineWeightScalable>
+          </Path>
+        </Graphics>
+        <LineUsage>
+          <Repeat>1.0</Repeat>
+        </LineUsage>
+          <Parameter>
+            <Identifier>LINECOLOR</Identifier>
+            <DefaultValue>0xff000000</DefaultValue>
+            <DisplayName>Line &amp;Color</DisplayName>
+            <Description>Line Color</Description>
+            <DataType>LineColor</DataType>
+          </Parameter>
+          <Parameter>
+            <Identifier>LINEWEIGHT</Identifier>
+            <DefaultValue>0.0</DefaultValue>
+            <DisplayName>Line &amp;Thickness</DisplayName>
+            <Description>Line Thickness</Description>
+            <DataType>LineWeight</DataType>
+          </Parameter>
+        <Override>
+          <SymbolName>Solid Line</SymbolName>
+          <ParameterIdentifier>LINECOLOR</ParameterIdentifier>
+          <ParameterValue>0xff000000</ParameterValue>
+        </Override>
+        <Override>
+          <ParameterIdentifier>LINEWEIGHT</ParameterIdentifier>
+          <ParameterValue>0.0</ParameterValue>
+        </Override>
+    </SymbolInstance>
+  </CompositeSymbolization>
+</CompositeRule>
\ No newline at end of file
Added: branches/fusion-2.2/widgets/Theme/templates/arearuletemplate-2.3.0.xml
--- branches/fusion-2.2/widgets/Theme/templates/arearuletemplate-2.3.0.xml	                        (rev 0)
+++ branches/fusion-2.2/widgets/Theme/templates/arearuletemplate-2.3.0.xml	2010-12-06 09:17:57 UTC (rev 2295)
@@ -0,0 +1,18 @@
+<AreaRule>
+ <AreaSymbolization2D>
+  <Fill>
+   <FillPattern>Solid</FillPattern>
+   <ForegroundColor>%s</ForegroundColor>
+   <BackgroundColor>FF000000</BackgroundColor>
+  </Fill>
+  <Stroke>
+   <LineStyle>Solid</LineStyle>
+   <Thickness>0</Thickness>
+   <Color>%s</Color>
+   <Unit>Inches</Unit>
+   <SizeContext>DeviceUnits</SizeContext>
+  </Stroke>
+ </AreaSymbolization2D>
+</AreaRule>
More information about the fusion-commits mailing list
