[fusion-commits] r2301 - trunk/layers/Generic
svn_fusion at osgeo.org
Thu Dec 9 16:18:13 EST 2010
Author: madair
Date: 2010-12-09 13:18:13 -0800 (Thu, 09 Dec 2010)
New Revision: 2301
trunk/layers/Generic/Generic.js
re #423: move setting of layer options to before the case statement so it applies for all cases; if a layer is tiled, set fractionalZoom to false for any type of layer
Modified: trunk/layers/Generic/Generic.js
--- trunk/layers/Generic/Generic.js 2010-12-09 08:23:31 UTC (rev 2300)
+++ trunk/layers/Generic/Generic.js 2010-12-09 21:18:13 UTC (rev 2301)
@@ -46,6 +46,8 @@
this._sMapname = mapTag.layerOptions['name'] ? mapTag.layerOptions['name'] : 'generic layer';
+ this.bSingleTile = mapTag.singleTile;
this.minScale = mapTag.layerOptions.minScale ? mapTag.layerOptions.minScale : 1;
this.maxScale = mapTag.layerOptions.maxScale ? mapTag.layerOptions.maxScale : 'auto';
var scaleRange = new Fusion.Layers.ScaleRange({
@@ -94,6 +96,27 @@
this.oLayerOL.destroy();
this.oLayerOL = null;
+ if (typeof this.mapTag.layerOptions.sphericalMercator == 'undefined') {
+ this.mapTag.layerOptions.sphericalMercator = true;
+ if (this.mapTag.layerOptions.sphericalMercator) {
+ if (!this.mapTag.layerOptions.maxExtent) {
+ this.mapTag.layerOptions.maxExtent = new OpenLayers.Bounds(-20037508.3427892, -20037508.3427892, 20037508.3427892, 20037508.3427892);
+ this.mapTag.layerOptions.units = "m";
+ this.mapTag.layerOptions.projection = "EPSG:900913";
+ } else {
+ this.mapTag.layerOptions.maxExtent = new OpenLayers.Bounds(-180,-90,180,90);
+ this.mapTag.layerOptions.units = "dd";
+ this.mapTag.layerOptions.projection = "EPSG:4326";
+ if (typeof this.mapTag.layerOptions.numZoomLevels == 'undefined') {
+ this.mapTag.layerOptions.numZoomLevels = 20;
switch (this.layerType) {
case 'Google':
@@ -171,6 +194,12 @@
this.mapTag.layerOptions.type = 'Mapnik';
break;
+ case 'XYZ':
+ this.oLayerOL = new OpenLayers.Layer[this.layerType](
+ this.getMapName(),
+ this.sMapResourceId,
+ this.mapTag.layerOptions );
+ break;
default:
this.getMapName(),
@@ -180,38 +209,22 @@
break;
if (!this.oLayerOL) {
- if (typeof this.mapTag.layerOptions.sphericalMercator == 'undefined') {
- this.mapTag.layerOptions.sphericalMercator = true;
- if (this.mapTag.layerOptions.sphericalMercator) {
- if (!this.mapTag.layerOptions.maxExtent) {
- this.mapTag.layerOptions.maxExtent = new OpenLayers.Bounds(-20037508.3427892, -20037508.3427892, 20037508.3427892, 20037508.3427892);
- this.mapTag.layerOptions.units = "m";
- this.mapTag.layerOptions.projection = "EPSG:3785";
- } else {
- this.mapTag.layerOptions.maxExtent = new OpenLayers.Bounds(-180,-90,180,90);
- this.mapTag.layerOptions.units = "dd";
- this.mapTag.layerOptions.projection = "EPSG:4326";
- if (typeof this.mapTag.layerOptions.numZoomLevels == 'undefined') {
- this.mapTag.layerOptions.numZoomLevels = 20;
if(this.layerType == 'OpenStreetMap') {
this.oLayerOL = new OpenLayers.Layer.OSM[this.mapTag.layerOptions.type](this.getMapName(), this.mapTag.layerOptions );
else {
this.oLayerOL = new OpenLayers.Layer[this.layerType](this.getMapName(), this.mapTag.layerOptions );
- this.mapWidget.fractionalZoom = false; //fractionalZoom not permitted with Google layers
+ //fractionalZoom not permitted with tiled base layers
+ if (!this.bSingleTile) {
+ this.mapWidget.fractionalZoom = false;
this.mapWidget.oMapOL.setOptions({fractionalZoom: false});
this.oLayerOL.events.register("loadstart", this, this.loadStart);
this.oLayerOL.events.register("loadend", this, this.loadEnd);
this.oLayerOL.events.register("loadcancel", this, this.loadEnd);
More information about the fusion-commits
