[fusion-commits] r2306 - in trunk/lib: . OpenLayers
svn_fusion at osgeo.org
Thu Dec 16 14:20:49 EST 2010
Author: pagameba
Date: 2010-12-16 11:20:48 -0800 (Thu, 16 Dec 2010)
New Revision: 2306
trunk/lib/OpenLayers/OpenLayers.js
trunk/lib/jxlib.uncompressed.js
updating jxlib with bug fix, update OpenLayers with check for NaN
Modified: trunk/lib/OpenLayers/OpenLayers.js
--- trunk/lib/OpenLayers/OpenLayers.js 2010-12-16 15:42:00 UTC (rev 2305)
+++ trunk/lib/OpenLayers/OpenLayers.js 2010-12-16 19:20:48 UTC (rev 2306)
@@ -1,95 +1,95 @@
- OpenLayers.js -- OpenLayers Map Viewer Library
- Copyright 2005-2010 OpenLayers Contributors, released under the Clear BSD
- license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
- for the full text of the license.
- Includes compressed code under the following licenses:
- (For uncompressed versions of the code used please see the
- OpenLayers SVN repository: <http://openlayers.org/>)
-/* Contains portions of Prototype.js:
- * Prototype JavaScript framework, version 1.4.0
- * (c) 2005 Sam Stephenson <sam at conio.net>
- * Prototype is freely distributable under the terms of an MIT-style license.
- * For details, see the Prototype web site: http://prototype.conio.net/
-* Contains portions of Rico <http://openrico.org/>
-* Copyright 2005 Sabre Airline Solutions
-* Licensed under the Apache License, Version 2.0 (the "License"); you
-* may not use this file except in compliance with the License. You
-* may obtain a copy of the License at
-* http://www.apache.org/licenses/LICENSE-2.0
-* Unless required by applicable law or agreed to in writing, software
-* distributed under the License is distributed on an "AS IS" BASIS,
-* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
-* implied. See the License for the specific language governing
-* permissions and limitations under the License.
- * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
- * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Contains portions of Gears <http://code.google.com/apis/gears/>
- * Copyright 2007, Google Inc.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions are met:
- * 1. Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright notice,
- * this list of conditions and the following disclaimer in the documentation
- * and/or other materials provided with the distribution.
- * 3. Neither the name of Google Inc. nor the names of its contributors may be
- * used to endorse or promote products derived from this software without
- * specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
- * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
- * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
- * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
- * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
- * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
- * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
- * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- * Sets up google.gears.*, which is *the only* supported way to access Gears.
- * Circumvent this file at your own risk!
- * In the future, Gears may automatically define google.gears.* without this
- * file. Gears may use these objects to transparently fix bugs and compatibility
- * issues. Applications that use the code below will continue to work seamlessly
- * when that happens.
+ OpenLayers.js -- OpenLayers Map Viewer Library
+ Copyright 2005-2010 OpenLayers Contributors, released under the Clear BSD
+ license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
+ for the full text of the license.
+ Includes compressed code under the following licenses:
+ (For uncompressed versions of the code used please see the
+ OpenLayers SVN repository: <http://openlayers.org/>)
+/* Contains portions of Prototype.js:
+ * Prototype JavaScript framework, version 1.4.0
+ * (c) 2005 Sam Stephenson <sam at conio.net>
+ * Prototype is freely distributable under the terms of an MIT-style license.
+ * For details, see the Prototype web site: http://prototype.conio.net/
+* Contains portions of Rico <http://openrico.org/>
+* Copyright 2005 Sabre Airline Solutions
+* Licensed under the Apache License, Version 2.0 (the "License"); you
+* may not use this file except in compliance with the License. You
+* may obtain a copy of the License at
+* http://www.apache.org/licenses/LICENSE-2.0
+* Unless required by applicable law or agreed to in writing, software
+* distributed under the License is distributed on an "AS IS" BASIS,
+* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+* implied. See the License for the specific language governing
+* permissions and limitations under the License.
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Contains portions of Gears <http://code.google.com/apis/gears/>
+ * Copyright 2007, Google Inc.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * 3. Neither the name of Google Inc. nor the names of its contributors may be
+ * used to endorse or promote products derived from this software without
+ * specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
+ * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Sets up google.gears.*, which is *the only* supported way to access Gears.
+ * Circumvent this file at your own risk!
+ * In the future, Gears may automatically define google.gears.* without this
+ * file. Gears may use these objects to transparently fix bugs and compatibility
+ * issues. Applications that use the code below will continue to work seamlessly
+ * when that happens.
OpenLayers/SingleFile.js
@@ -25425,7 +25425,7 @@
* sz - {<OpenLayers.Size>}
* Returns:
- * {DOMElement} A new DOM Image with this marker´s icon set at the
+ * {DOMElement} A new DOM Image with this marker´s icon set at the
* location passed-in
draw: function(px, sz) {
@@ -27433,8 +27433,8 @@
var newBoxModel = OpenLayers.Util.getBrowserName() == "msie" ?
document.compatMode != "BackCompat" : true;
this.boxCharacteristics = {
- xOffset: xOffset,
- yOffset: yOffset,
+ xOffset: !isNaN(xOffset) ? xOffset: 0,
+ yOffset: !isNaN(yOffset) ? yOffset: 0,
newBoxModel: newBoxModel
Modified: trunk/lib/jxlib.uncompressed.js
--- trunk/lib/jxlib.uncompressed.js 2010-12-16 15:42:00 UTC (rev 2305)
+++ trunk/lib/jxlib.uncompressed.js 2010-12-16 19:20:48 UTC (rev 2306)
@@ -33956,8 +33956,10 @@
selected.set('cells',[]);
} else if (opt === 'row') {
this.getSelectedRows().each(function(row){
+ idx = row.retrieve('jxRowData').row;
row.removeClass('jxGridRowSelected');
+ this.setCheckField(idx,false);
+ }, this);
selected.set('rows',[]);
selected.get('rowHeads').each(function(rowHead){
rowHead.removeClass('jxGridRowHeaderSelected');
More information about the fusion-commits
