[fusion-commits] r2050 - in sandbox/jxlib-3.0: layers/MapServer
widgets
svn_fusion at osgeo.org
Mon Feb 1 16:13:05 EST 2010
Author: madair
Date: 2010-02-01 16:13:04 -0500 (Mon, 01 Feb 2010)
New Revision: 2050
sandbox/jxlib-3.0/layers/MapServer/MapServer.js
sandbox/jxlib-3.0/widgets/LayerManager.js
sandbox/jxlib-3.0/widgets/Legend.js
update so that Legend and LayerManager both get updated when order/visibility changes
Modified: sandbox/jxlib-3.0/layers/MapServer/MapServer.js
--- sandbox/jxlib-3.0/layers/MapServer/MapServer.js 2010-02-01 19:56:37 UTC (rev 2049)
+++ sandbox/jxlib-3.0/layers/MapServer/MapServer.js 2010-02-01 21:13:04 UTC (rev 2050)
@@ -454,6 +454,20 @@
+ parseLayers: function() {
+ //this.layerRoot.clear();
+ for (var i=0; i<this.aLayers.length; i++) {
+ var layer = this.aLayers[i];
+ var parent;
+ if (layer.parentGroup != '') {
+ parent = this.layerRoot.findGroup(layer.parentGroup.name);
+ } else {
+ parent = this.layerRoot;
+ parent.addLayer(layer, this.bLayersReversed);
getScale: function() {
return this.mapWidget.getScale();
Modified: sandbox/jxlib-3.0/widgets/LayerManager.js
--- sandbox/jxlib-3.0/widgets/LayerManager.js 2010-02-01 19:56:37 UTC (rev 2049)
+++ sandbox/jxlib-3.0/widgets/LayerManager.js 2010-02-01 21:13:04 UTC (rev 2050)
@@ -79,7 +79,8 @@
//this.draw();
- layerChanged: function() {
+ layerChanged: function(eventId, layer) {
+ this.updateLayer(this.map.aMaps[0]);
this.updateSessionMapFile();
@@ -168,7 +169,7 @@
revert: true,
onComplete: OpenLayers.Function.bind(this.updateLayer, this, map)
- var mySortables = new Sortables(this.mapBlockList.id, sortableOptions);
+ var mySortables = new Sortables(this.mapBlockList.id, sortableOptions);
createItemHtml: function(parent, layer) {
@@ -260,7 +261,7 @@
- updateLayer: function(map, ul) {
+ updateLayer: function(map) {
//console.log("updateLayer");
//reorder the layers in the client as well as the session
var aLayerIndex = [];
@@ -278,7 +279,7 @@
var node = this.mapBlockList.childNodes[i];
aIds[i].push(i);
node.id = aIds[i].join('_');
- node.childNodes[1].checked = node.layer.isVisible()
+ node.childNodes[2].checked = node.layer.isVisible()
//check tos ee if the layer indexes have been modified
@@ -299,16 +300,15 @@
- updateMapBlock: function(map, ul) {
+ updateMapBlock: function(map) {
//reorder the OL layers
deleteLayer: function(layer, ev) {
// console.log("deleteLayer");
var targetLI = (new Event(ev)).target.parentNode;
- var ul = targetLI.parentNode;
$(targetLI).dispose();
- this.updateLayer(layer.oMap, ul);
+ this.updateLayer(layer.oMap);
showLayerInfo: function(layer, ev) {
Modified: sandbox/jxlib-3.0/widgets/Legend.js
--- sandbox/jxlib-3.0/widgets/Legend.js 2010-02-01 19:56:37 UTC (rev 2049)
+++ sandbox/jxlib-3.0/widgets/Legend.js 2010-02-01 21:13:04 UTC (rev 2050)
@@ -173,6 +173,14 @@
mapReloaded: function() {},
+ * Method: mapRefresh
+ * Abstract method that handle the event: Fusion.Event.MAP_LAYER_ORDER_CHANGED. This method
+ * should be implemented by all concrete class.
+ mapRefresh: function() {},
* Method: getMap
* Helper method to obtains the map.
@@ -366,22 +374,24 @@
mapLoaded: function() {
this.getMap().registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, this.extentsChangedWatcher);
+ var baseLayer = this.getMap().aMaps[0];
+ baseLayer.registerForEvent(Fusion.Event.MAP_LAYER_ORDER_CHANGED, OpenLayers.Function.bind(this.mapRefresh, this));
+ this.layerRoot = this.getMap().layerRoot;
+ this.renderLegend();
- * the map state has become invalid in some way (layer added, removed,
- * ect). For now, we just re-request the map state from the server
- * which calls draw which recreates the entire legend from scratch
- * TODO: more fine grained updating of the legend would be nice
- invalidate: function() {
- this.draw();
+ baseLayer.parseLayers();
* Callback for legend XML response. Creates a list of layers and sets up event
* handling. Create groups if applicable.
@@ -414,7 +424,7 @@
this.bIsDrawn = true;
this.update();
processMapGroup: function(group, folder) {
if (group.displayInLegend) {
/* make a 'namespace' on the group object to store legend-related info */
More information about the fusion-commits
