[fusion-commits] r2067 - in sandbox/adsk/2.2gp: layers
layers/MapGuide lib
svn_fusion at osgeo.org
Wed Feb 10 16:12:28 EST 2010
Author: madair
Date: 2010-02-10 16:12:27 -0500 (Wed, 10 Feb 2010)
New Revision: 2067
sandbox/adsk/2.2gp/layers/Layers.js
sandbox/adsk/2.2gp/layers/MapGuide/MapGuide.js
sandbox/adsk/2.2gp/lib/ApplicationDefinition.js
sandbox/adsk/2.2gp/lib/Map.js
re #310: carry through projection code and definitions to the map and layer objects, patch applied to adsk branch
Modified: sandbox/adsk/2.2gp/layers/Layers.js
--- sandbox/adsk/2.2gp/layers/Layers.js 2010-02-10 21:11:53 UTC (rev 2066)
+++ sandbox/adsk/2.2gp/layers/Layers.js 2010-02-10 21:12:27 UTC (rev 2067)
@@ -48,6 +48,7 @@
noCache: false,
_sMapTitle: null,
_sMapname: null,
+ projCode: null,
initialize: function(map, mapTag, isMapWidgetLayer) {
// console.log('Fusion.Layers.initialize');
@@ -76,17 +77,6 @@
this.sMapResourceId = mapTag.resourceId ? mapTag.resourceId : '';
this.mapInfo = mapTag.mapInfo;
this.layerType = mapTag.type;
- //projection info from the extension
- if (mapTag.extension.ProjectionCode) {
- this.projCode = mapTag.extension.ProjectionCode[0];
- if (mapTag.extension.ProjectionDef) {
- var projDef = mapTag.extension.ProjectionDef[0];
- this.projCode = "APP-DEF-PROJ";
- Proj4js.defs[this.projCode] = projDef;
Modified: sandbox/adsk/2.2gp/layers/MapGuide/MapGuide.js
--- sandbox/adsk/2.2gp/layers/MapGuide/MapGuide.js 2010-02-10 21:11:53 UTC (rev 2066)
+++ sandbox/adsk/2.2gp/layers/MapGuide/MapGuide.js 2010-02-10 21:12:27 UTC (rev 2067)
@@ -85,6 +85,9 @@
this.nTolerance = 2; //pixels, default pixel tolernace for a point click; TBD make this configurable
+ //copy over projection info from maptag
+ this.projCode = mapTag.projCode;
rootOpts = {
displayInLegend: this.bDisplayInLegend,
@@ -304,7 +307,7 @@
//to allow for scaling that doesn't match any of the pre-canned units
this.units = Fusion.getClosestUnits(o.metersPerUnit);
if (this.projCode) {
- this.mapWidget.setProjection(this.projCode);
+ this.mapWidget.setProjection(this.projCode, this.units);
//add in scales array if supplied
@@ -574,6 +577,7 @@
var layerOptions = {
units: this.units,
+ projection: this.projCode,
maxResolution: 'auto',
useOverlay: this.selectionAsOverlay,
useAsyncOverlay: this.useAsyncOverlay,
Modified: sandbox/adsk/2.2gp/lib/ApplicationDefinition.js
--- sandbox/adsk/2.2gp/lib/ApplicationDefinition.js 2010-02-10 21:11:53 UTC (rev 2066)
+++ sandbox/adsk/2.2gp/lib/ApplicationDefinition.js 2010-02-10 21:12:27 UTC (rev 2067)
@@ -486,6 +486,8 @@
type: null,
singleTile: false,
extension: null,
+ projCode: null,
initialize: function(jsonNode) {
/* TODO: type can be any supported OpenLayers type */
this.type = jsonNode.Type[0];
@@ -522,6 +524,18 @@
this.layerParams[key] = tagParams[0][key][0];
+ //projection info from the extension
+ if (this.extension.ProjectionCode) {
+ this.projCode = this.extension.ProjectionCode[0];
+ if (this.extension.ProjectionDef) {
+ var projDef = this.extension.ProjectionDef[0];
+ if (!this.projCode) {
+ this.projCode = "APP-DEF-PROJ";
+ Proj4js.defs[this.projCode] = projDef;
switch (this.type) {
case 'MapGuide':
@@ -531,6 +545,11 @@
break;
default:
+ if (this.layerOptions.sphericalMercator) {
+ this.projCode = "EPSG:3785"; //commercial map layer projection spherical mercator
+ } else {
+ this.projCode = "EPSG:4326"; //WGS84 lat long
if ( !Fusion.Layers.Generic ) {
Fusion.require('layers/Generic/Generic.js');
Modified: sandbox/adsk/2.2gp/lib/Map.js
--- sandbox/adsk/2.2gp/lib/Map.js 2010-02-10 21:11:53 UTC (rev 2066)
+++ sandbox/adsk/2.2gp/lib/Map.js 2010-02-10 21:12:27 UTC (rev 2067)
@@ -169,7 +169,7 @@
this.registerEventID(Fusion.Event.MAP_SELECTION_ON);
this.registerEventID(Fusion.Event.MAP_SELECTION_OFF);
this.registerEventID(Fusion.Event.MAP_MAPTIP_REQ_FINISHED);
- this.registerEventID(Fusion.Event.MAP_MAP_GROUP_LOADED);
+ this.registerEventID(Fusion.Event.MAP_MAP_GROUP_LOADED);
this.registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.mapLoaded,this));
@@ -215,7 +215,10 @@
this.aMaps[i].oLayerOL.destroy();
+ this._fMetersperunit = -1;
+ this.oMapOL.center = null;
+ this.maxExtent = new OpenLayers.Bounds();
this.aMaps = [];
this.layerRoot.clear();
@@ -232,7 +235,7 @@
this.aMaps[i].registerForEvent(Fusion.Event.LAYER_LOADED, OpenLayers.Function.bind(this.layerLoaded,this));
- this.triggerEvent(Fusion.Event.MAP_MAP_GROUP_LOADED);
+ this.triggerEvent(Fusion.Event.MAP_MAP_GROUP_LOADED);
layerLoaded: function() {
@@ -807,12 +810,14 @@
* @param projCode projection code
- setProjection: function(projCode) {
+ setProjection: function(projCode, units) {
if (!Proj4js.defs[projCode]) {
Fusion.reportError( new Fusion.Error(Fusion.Error.WARNING,
'Projection definition not found for:'+projCode));
+ this.projection = projCode;
this.oMapOL.projection = projCode;
+ this.oMapOL.units = units;
More information about the fusion-commits
