[fusion-commits] r2070 - trunk/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Feb 11 16:13:00 EST 2010
Author: madair
Date: 2010-02-11 16:12:59 -0500 (Thu, 11 Feb 2010)
New Revision: 2070
   trunk/widgets/Legend.js
re MG #940: keep track of sibling node to re-insert the new tree item
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js	2010-02-10 21:17:23 UTC (rev 2069)
+++ trunk/widgets/Legend.js	2010-02-11 21:12:59 UTC (rev 2070)
@@ -584,21 +584,20 @@
                     layer.parentGroup.legend.treeItem.append(layer.legend.treeItem);
                 } else if (layer.legend.treeItem instanceof Jx.TreeItem) {
-                    this.clearTreeItem(layer);
+                    var insertAt = this.clearTreeItem(layer);
                     layer.legend.treeItem = this.createFolderItem(layer, checkbox);
                     if(layer.legend.treeItem.checkBox)
                         OpenLayers.Event.observe(layer.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, layer));
-                    layer.parentGroup.legend.treeItem.append(layer.legend.treeItem);
+                    layer.parentGroup.legend.treeItem.insert(layer.legend.treeItem, insertAt);
                 } else {
                     while(layer.legend.treeItem.nodes.length > 0) {
                         layer.legend.treeItem.remove(layer.legend.treeItem.nodes[0]);
                 for (var i=0; i<range.styles.length; i++) {
-                    var item = this.createTreeItem(layer,
-                                               range.styles[i], fScale, false);
+                    var item = this.createTreeItem(layer, range.styles[i], fScale, false);
                     layer.legend.treeItem.append(item);
             } else {
@@ -615,13 +614,13 @@
                 } else if (layer.legend.treeItem instanceof Jx.TreeFolder) {
                     layer.legend.treeItem = this.createTreeItem(layer, style, fScale, checkbox);
                     if (checkbox) {
                 } else {
                     if (range.styles.length > 0) {
                         layer.legend.treeItem.domImg.style.backgroundImage = 'url('+layer.oMap.getLegendImageURL(fScale, layer, range.styles[0])+')';
@@ -740,7 +739,7 @@
         opt.contextMenu = this.getContextMenu();
         var item = new Jx.TreeItem(opt);
-        if (style && style.iconX >= 0 && style.iconY >= 0) {
+        if (style && style.iconOpt && style.iconX >= 0 && style.iconY >= 0) {
             item.domImg;
             item.domImg.style.backgroundImage = 'url('+opt.image+')';
             item.domImg.src = Jx.aPixel.src;
@@ -776,12 +775,15 @@
         return item;
     clearTreeItem: function(layer) {
+        var prevSibling = null;
         if (layer.legend.treeItem && layer.legend.treeItem.owner) {
+            prevSibling = layer.legend.treeItem.domObj.previousSibling;
             layer.legend.treeItem.domObj.store('data', null);
             layer.legend.treeItem.owner.remove(layer.legend.treeItem);
             layer.legend.treeItem.finalize();
             layer.legend.treeItem = null;
+        return prevSibling;
     stateChanged: function(obj, event) {
         if (obj.legend && obj.legend.treeItem.checkBox) {
More information about the fusion-commits mailing list
