[fusion-commits] r2031 - sandbox/jxlib-3.0/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Jan 5 10:49:40 EST 2010
Author: madair
Date: 2010-01-05 10:49:39 -0500 (Tue, 05 Jan 2010)
New Revision: 2031
   sandbox/jxlib-3.0/widgets/Measure.js
fix error in area calculation
Modified: sandbox/jxlib-3.0/widgets/Measure.js
--- sandbox/jxlib-3.0/widgets/Measure.js	2010-01-05 15:47:33 UTC (rev 2030)
+++ sandbox/jxlib-3.0/widgets/Measure.js	2010-01-05 15:49:39 UTC (rev 2031)
@@ -68,12 +68,16 @@
     /* Style for the polygon line used for area draw */
     areaStyle: null,
+    /* optional DOM obj ID for button to clear the result */
+    clearButton: null,
     initializeWidget: function(widgetTag) {
         this.asCursor = ['crosshair'];
         var json = widgetTag.extension;
         this.units = (json.Units && (json.Units[0] != '')) ?  Fusion.unitFromName(json.Units[0]): this.units;
         this.distPrecision = json.DistancePrecision ? parseInt(json.DistancePrecision[0]) : 4;
         this.areaPrecision = json.AreaPrecision ? parseInt(json.AreaPrecision[0]) : 4;
+        this.clearButton = json.clearButton ? json.clearButton[0] : null;
         this.sTarget = json.Target ? json.Target[0] : "";
         this.sBaseUrl = Fusion.getFusionURL() + 'widgets/Measure/Measure.php';
@@ -115,6 +119,9 @@
         mapWidget.registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.setUnits, this, this.units));
         this.registerParameter('Units');
+        if (this.clearButton) {
             // style the sketch fancy
         this.sketchSymbolizers = {
                 "Point": {
@@ -296,7 +303,7 @@
             at = this.getMap().geoToPix(cg.x, cg.y);
             quantity = geom.getGeodesicArea(proj);
             //TODO: result is in square meters - convert to other units?
-            var q = Math.pow(Fusion.convert(measureUnits, this.units, q));
+            var q = Fusion.convert(measureUnits, this.units, quantity);
             this.totalArea = q.toPrecision(this.areaPrecision);
         if (quantity > 1) {
More information about the fusion-commits mailing list
