[fusion-commits] r2033 - sandbox/jxlib-3.0/widgets
svn_fusion at osgeo.org
Thu Jan 7 10:44:55 EST 2010
Author: madair
Date: 2010-01-07 10:44:52 -0500 (Thu, 07 Jan 2010)
New Revision: 2033
Added:
sandbox/jxlib-3.0/widgets/MapMetadata.js
re #6: mapfile metadata widget
Added: sandbox/jxlib-3.0/widgets/MapMetadata.js
--- sandbox/jxlib-3.0/widgets/MapMetadata.js (rev 0)
+++ sandbox/jxlib-3.0/widgets/MapMetadata.js 2010-01-07 15:44:52 UTC (rev 2033)
@@ -0,0 +1,80 @@
+ * Fusion.Widget.About
+ * $Id: About.js 1656 2008-11-08 21:44:26Z madair $
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+* Class: Fusion.Widget.MapMetadata
+* MapMetadata widget to inject map metadata elements into the interface
+Fusion.Widget.MapMetadata = OpenLayers.Class(Fusion.Widget, {
+ content: 'text',
+ * Constructor: MapMetadata
+ * Parameters:
+ * widgetTag - JSON node for this widget from the Application definition
+ initializeWidget: function(widgetTag) {
+ var json = widgetTag.extension;
+ if (json.MetadataId) {
+ this.metadataId = json.MetadataId[0];
+ } else {
+ Fusion.reportError( new Fusion.Error(Fusion.Error.FATAL,"MetadataId is a required parameter for mapMetadata widget"));
+ if (json.Content) {
+ this.content = json.Content[0];
+ this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.showMetadata, this));
+ * Function: showMetadata
+ * puts a piece of map metadata into the interface
+ showMetadata: function() {
+ var metadata = this.getMap().getMetadata(this.metadataId);
+ if (metadata) {
+ //this.domObj.appendChild(metadata);
+ if (this.content == 'markup') {
+ //load in an HTML fragment
+ //this isn't working in IE
+ var domObj = $(this.domObj);
+ domObj.load(metadata);
+ } else if ((this.content == 'hyperlink') && this.domObj.tagName == 'A') {
+ this.domObj.href = metadata;
+ } else {
+ this.domObj.innerHTML = metadata;
More information about the fusion-commits
