[fusion-commits] r2044 - in sandbox/jxlib-3.0: layers/MapGuide
	layers/MapServer lib widgets
    svn_fusion at osgeo.org
    Tue Jan 26 15:35:46 EST 2010
Author: madair
Date: 2010-01-26 15:35:43 -0500 (Tue, 26 Jan 2010)
New Revision: 2044
   sandbox/jxlib-3.0/layers/MapGuide/MapGuide.js
   sandbox/jxlib-3.0/layers/MapServer/MapServer.js
   sandbox/jxlib-3.0/lib/Map.js
   sandbox/jxlib-3.0/widgets/LayerManager.js
   sandbox/jxlib-3.0/widgets/Legend.js
trigger an event after LoadScaleRanges so multiple widgets can listen for it
Modified: sandbox/jxlib-3.0/layers/MapGuide/MapGuide.js
--- sandbox/jxlib-3.0/layers/MapGuide/MapGuide.js	2010-01-25 16:34:33 UTC (rev 2043)
+++ sandbox/jxlib-3.0/layers/MapGuide/MapGuide.js	2010-01-26 20:35:43 UTC (rev 2044)
@@ -380,39 +380,34 @@
      * used by the legend widget.
-    loadScaleRanges: function(userFunc) {
+    loadScaleRanges: function() {
         var sl = Fusion.getScriptLanguage();
         var loadmapScript = 'layers/' + this.arch + '/' + sl  + '/LoadScaleRanges.' + sl;
         var sessionid = this.getSessionID();
         var params = {'mapname': this._sMapname, "session": sessionid};
-        var options = {onSuccess: OpenLayers.Function.bind(this.scaleRangesLoaded,this, userFunc),
+        var options = {onSuccess: OpenLayers.Function.bind(this.scaleRangesLoaded,this),
                        parameters:params};
         Fusion.ajaxRequest(loadmapScript, options);
-    scaleRangesLoaded: function(userFunc, r)
+    scaleRangesLoaded: function(r)
-        if (r.status == 200)
+        if (r.status == 200) {
             var o;
             eval('o='+r.responseText);
-            if (o.layers && o.layers.length > 0)
+            if (o.layers && o.layers.length > 0) {
                 var iconOpt = {
                     url: o.icons_url || null,
                     width: o.icons_width || 16,
                     height: o.icons_height || 16
-                for (var i=0; i<o.layers.length; i++)
+                for (var i=0; i<o.layers.length; i++)  {
                     var oLayer = this.getLayerById(o.layers[i].uniqueId);
-                    if (oLayer)
+                    if (oLayer) {
                         oLayer.scaleRanges = [];
-                        for (var j=0; j<o.layers[i].scaleRanges.length; j++)
+                        for (var j=0; j<o.layers[i].scaleRanges.length; j++) {
                             var scaleRange = new Fusion.Layers.ScaleRange(o.layers[i].scaleRanges[j],
        oLayer.layerType, iconOpt);
                             oLayer.scaleRanges.push(scaleRange);
@@ -420,10 +415,10 @@
-            userFunc();
+            this.mapWidget.triggerEvent(Fusion.Event.MAP_SCALE_RANGE_LOADED);
 //TBD: this function not yet converted for OL
     mapReloaded: function(r) {
Modified: sandbox/jxlib-3.0/layers/MapServer/MapServer.js
--- sandbox/jxlib-3.0/layers/MapServer/MapServer.js	2010-01-25 16:34:33 UTC (rev 2043)
+++ sandbox/jxlib-3.0/layers/MapServer/MapServer.js	2010-01-26 20:35:43 UTC (rev 2044)
@@ -323,19 +323,19 @@
         var params = {'mapname': this._sMapname, "session": this.getSessionID()};
+        var options = {onSuccess: OpenLayers.Function.bind(this.scaleRangesLoaded, this),
                        parameters:params};
-    scaleRangesLoaded: function(userFunc, r) {
+    scaleRangesLoaded: function(r) {
             var o;
@@ -358,8 +358,7 @@
-            userFunc();
@@ -410,13 +409,14 @@
           var nLayers = layerCopy.length -1;
           //Mapserver has list of layers reversed from MapGuide
-          aLayerIndex.reverse();
+          //aLayerIndex.reverse();
   				this.aLayers = [];
   				this.aVisibleLayers = [];
           for (var i=0; i<aLayerIndex.length; ++i) {
-            this.aLayers.push( layerCopy[ nLayers - aLayerIndex[i] ] );
+            //this.aLayers.push( layerCopy[ nLayers - aLayerIndex[i] ] );
+            this.aLayers.push( layerCopy[ aLayerIndex[i] ] );
             if (this.aLayers[i].visible) {
                 this.aVisibleLayers.push(this.aLayers[i].layerName);
@@ -819,7 +819,7 @@
         return oLayer;
-    getLegendImageURL: function(fScale, layer, style,defaultIcon) {
+    getLegendImageURL: function(fScale, layer, style) {
         var url = Fusion.getFusionURL() + '/layers/' + this.arch + '/' + sl  + '/LegendIcon.' + sl;
Modified: sandbox/jxlib-3.0/lib/Map.js
--- sandbox/jxlib-3.0/lib/Map.js	2010-01-25 16:34:33 UTC (rev 2043)
+++ sandbox/jxlib-3.0/lib/Map.js	2010-01-26 20:35:43 UTC (rev 2044)
@@ -42,6 +42,7 @@
 Fusion.Event.MAP_SESSION_CREATED = Fusion.Event.lastEventId++;
 Fusion.Event.MAP_MAPTIP_REQ_FINISHED = Fusion.Event.lastEventId++;
 Fusion.Event.WMS_LAYER_ADDED = Fusion.Event.lastEventId++;
+Fusion.Event.MAP_SCALE_RANGE_LOADED = Fusion.Event.lastEventId++;
 Fusion.Constant.LAYER_POINT_TYPE = 0;
 Fusion.Constant.LAYER_LINE_TYPE = 1;
@@ -169,6 +170,7 @@
         this.registerEventID(Fusion.Event.MAP_SELECTION_OFF);
         this.registerEventID(Fusion.Event.MAP_MAPTIP_REQ_FINISHED);
         this.registerEventID(Fusion.Event.WMS_LAYER_ADDED);
+        this.registerEventID(Fusion.Event.MAP_SCALE_RANGE_LOADED);
         this.registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.mapLoaded,this));
@@ -189,6 +191,7 @@
     mapLoaded: function() {
       this.setViewOptions(this.getUnits());
+      this.loadScaleRanges(OpenLayers.Function.bind(this.scaleRangesLoaded, this));
     setMenu: function() {
@@ -394,10 +397,10 @@
       for (var i=0; i<this.aMaps.length; ++i) {
         var map = this.aMaps[i];
-        OpenLayers.Function.bind(map.loadScaleRanges(userFunc), map);
+        map.loadScaleRanges();
Modified: sandbox/jxlib-3.0/widgets/LayerManager.js
--- sandbox/jxlib-3.0/widgets/LayerManager.js	2010-01-25 16:34:33 UTC (rev 2043)
+++ sandbox/jxlib-3.0/widgets/LayerManager.js	2010-01-26 20:35:43 UTC (rev 2044)
@@ -58,6 +58,7 @@
         //console.log("initializeWidget");
         var json = widgetTag.extension;
         this.delIconSrc = json.DeleteIcon ? json.DeleteIcon[0] : 'images/icons/select-delete.png';
+        this.infoIconSrc = json.LayerInfoIcon ? json.LayerInfoIcon[0] : 'images/icons/tree_layer_info.png';
         Fusion.addWidgetStyleSheet(widgetTag.location + 'LayerManager/LayerManager.css');
         this.cursorNormal = ["url('images/grab.cur'),move", 'grab', '-moz-grab', 'move'];
@@ -65,19 +66,27 @@
         this.map = this.getMap();
         this.map.registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.mapLoaded, this));
         this.map.registerForEvent(Fusion.Event.MAP_RELOADED, OpenLayers.Function.bind(this.mapReLoaded, this));
+        this.map.registerForEvent(Fusion.Event.MAP_SCALE_RANGE_LOADED, OpenLayers.Function.bind(this.scaleRangeLoaded, this));
         // update changes to the legend in this widget
         this.map.aMaps[0].registerForEvent(Fusion.Event.LAYER_PROPERTY_CHANGED, OpenLayers.Function.bind(this.layerChanged,this));
-    mapLoaded: function() {
+    scaleRangeLoaded: function() {
         this.draw();
+    mapLoaded: function() {
+        //this.draw();
     layerChanged: function() {
         this.updateSessionMapFile();
     mapReLoaded: function(){
         this.draw();
      * remove the dom objects representing the legend layers and groups
@@ -136,10 +145,10 @@
     processMapBlock: function(blockDom, map) {
       //console.log("processMapBlock");
-      var mapBlockList = document.createElement('ul');
-      mapBlockList.className = 'jxLmanSet';
-      mapBlockList.id = 'fusionLayerManager_'+map.getMapName();
-      blockDom.appendChild(mapBlockList);
+      this.mapBlockList = document.createElement('ul');
+      this.mapBlockList.className = 'jxLmanSet';
+      this.mapBlockList.id = 'fusionLayerManager_'+map.getMapName();
+      blockDom.appendChild(this.mapBlockList);
       map.layerPrefix = 'layer_';   //TODO make this unique for each block
       //this process all layers within an OL layer
       var processArray = map.aLayers;
@@ -148,7 +157,7 @@
         var blockItem = document.createElement('li');
         blockItem.className = 'jxLmanLayer';
         blockItem.id = map.layerPrefix+i;
-        mapBlockList.appendChild(blockItem);
+        this.mapBlockList.appendChild(blockItem);
         this.createItemHtml(blockItem, processArray[i]);
         blockItem.layer = processArray[i];
@@ -157,12 +166,18 @@
                 constrain: true,
                 clone: false,
                 revert: true,
-                onComplete: OpenLayers.Function.bind(this.updateLayer, $(mapBlockList.id), map)
+                onComplete: OpenLayers.Function.bind(this.updateLayer, this, map)
-    var mySortables = new Sortables(mapBlockList.id, sortableOptions);
+    var mySortables = new Sortables(this.mapBlockList.id, sortableOptions);
   createItemHtml: function(parent, layer) {
+    var infoIcon = document.createElement('img');
+    infoIcon.src = this.infoIconSrc;
+    OpenLayers.Event.observe(infoIcon, 'click', OpenLayers.Function.bind(this.showLayerInfo, this, layer));
+    infoIcon.style.visibility = 'hidden';
+    parent.appendChild(infoIcon);
     var delIcon = document.createElement('img');
     delIcon.src = this.delIconSrc;
     OpenLayers.Event.observe(delIcon, 'click', OpenLayers.Function.bind(this.deleteLayer, this, layer));
@@ -179,6 +194,23 @@
       visSelect.checked = false;
+    var img = document.createElement('img');
+    var scale = layer.oMap.getScale();
+    var range = layer.getScaleRange(scale);
+    if (range && range.styles.length>0) {
+        var style = range.styles[0];//TODO: handle multiple styles?
+        var iconX = 0;
+        var iconY = 0;
+        if (style && style.iconX >= 0 && style.iconY >= 0) {
+            iconX = -1 * (style.iconX);
+            iconY = -1 * (style.iconY);
+        img.src = Jx.aPixel.src;
+        img.style.backgroundImage = 'url('+style.iconOpt.url+')';
+        img.style.backgroundPosition = iconX + 'px ' + iconY + 'px';
+        parent.appendChild(img);
     var label = document.createElement('a');
     label.innerHTML = layer.legendLabel;
     OpenLayers.Event.observe(label, 'mouseover', OpenLayers.Function.bind(this.setGrabCursor, this));
@@ -186,16 +218,18 @@
     OpenLayers.Event.observe(label, 'mouseout', OpenLayers.Function.bind(this.setNormalCursor, this));
     parent.appendChild(label);
-    OpenLayers.Event.observe(parent, 'mouseover', OpenLayers.Function.bind(this.setHandleVis, this, delIcon));
-    OpenLayers.Event.observe(parent, 'mouseout', OpenLayers.Function.bind(this.setHandleHide, this, delIcon));
+    OpenLayers.Event.observe(parent, 'mouseover', OpenLayers.Function.bind(this.setHandleVis, this, delIcon, infoIcon));
+    OpenLayers.Event.observe(parent, 'mouseout', OpenLayers.Function.bind(this.setHandleHide, this, delIcon, infoIcon));
-  setHandleVis: function(delIcon) {
+  setHandleVis: function(delIcon, infoIcon) {
     delIcon.style.visibility = 'visible';
+    infoIcon.style.visibility = 'visible';
-  setHandleHide: function(delIcon) {
+  setHandleHide: function(delIcon, infoIcon) {
     delIcon.style.visibility = 'hidden';
   setGrabCursor: function(ev) {
@@ -210,7 +244,7 @@
     this.setCursor('auto', ev.currentTarget.parentNode);
-  setCursor : function(cursor, domObj) {
+  setCursor: function(cursor, domObj) {
       this.cursor = cursor;
       if (cursor && cursor.length && typeof cursor == 'object') {
           for (var i = 0; i < cursor.length; i++) {
@@ -231,23 +265,38 @@
     //reorder the layers in the client as well as the session
     var aLayerIndex = [];
     var aIds = [];
-    var nLayers = this.childNodes.length;
+    var nLayers = this.mapBlockList.childNodes.length;
     for (var i=0; i<nLayers; ++i) {
-      aIds[i] = this.childNodes[i].id.split('_');
+      aIds[i] = this.mapBlockList.childNodes[i].id.split('_');
       var index = parseInt(aIds[i].pop());
       aLayerIndex.push(index);
-      this.childNodes[i].id = '';
+      this.mapBlockList.childNodes[i].id = '';
     //reset the ID's on the LI elements to be in order
-    for (var i=0; i<this.childNodes.length; ++i) {
-      var node = this.childNodes[i];
+    for (var i=0; i<this.mapBlockList.childNodes.length; ++i) {
+      var node = this.mapBlockList.childNodes[i];
       aIds[i].push(i);
       node.id = aIds[i].join('_');
       node.childNodes[1].checked = node.layer.isVisible()
+    //check tos ee if the layer indexes have been modified
+    var indexModified = false;
+    if (aLayerIndex.length == map.aLayers.length) {
+      for (var i=0; i<aLayerIndex.length; ++i) {
+        if (aLayerIndex[i] != i) {
+          indexModified = true;
+          break;
+    } else {
-    map.reorderLayers(aLayerIndex);
+    if (indexModified) {
+        map.reorderLayers(aLayerIndex);
   updateMapBlock: function(map, ul) {
@@ -262,6 +311,13 @@
     this.updateLayer(layer.oMap, ul);
+  showLayerInfo: function(layer, ev) {
+    var layerInfoUrl = layer.oMap.getLayerInfoUrl(layer.layerName);
+    if (layerInfoUrl) {
+      window.open(layerInfoUrl);
   visChanged: function(layer2, ev) {
     var target = (new Event(ev)).target;
     var layer = target.parentNode.layer;
Modified: sandbox/jxlib-3.0/widgets/Legend.js
--- sandbox/jxlib-3.0/widgets/Legend.js	2010-01-25 16:34:33 UTC (rev 2043)
+++ sandbox/jxlib-3.0/widgets/Legend.js	2010-01-26 20:35:43 UTC (rev 2044)
@@ -110,6 +110,9 @@
         if (this.renderer.mapLoaded)
             this.getMap().registerForEvent(Fusion.Event.MAP_LOADED,
                                            OpenLayers.Function.bind(this.renderer.mapLoaded, this.renderer));
+        if (this.renderer.scaleRangesLoaded)
+            this.getMap().registerForEvent(Fusion.Event.MAP_SCALE_RANGE_LOADED,
+                                           OpenLayers.Function.bind(this.renderer.scaleRangesLoaded, this.renderer));
@@ -355,6 +358,7 @@
         this.layerRoot = this.getMap().layerRoot;
         this.renderLegend();
     mapLoading: function() {
         this.getMap().deregisterForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, this.extentsChangedWatcher);
         this.clear();
@@ -362,12 +366,11 @@
         this.getMap().registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, this.extentsChangedWatcher);
-        this.getMap().loadScaleRanges(OpenLayers.Function.bind(this.scaleRangesLoaded, this));
     mapReloaded: function() {
      * the map state has become invalid in some way (layer added, removed,
      * ect).  For now, we just re-request the map state from the server
More information about the fusion-commits
