[fusion-commits] r2046 - sandbox/jxlib-3.0/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Jan 28 14:13:58 EST 2010
Author: madair
Date: 2010-01-28 14:13:58 -0500 (Thu, 28 Jan 2010)
New Revision: 2046
   sandbox/jxlib-3.0/widgets/MapMenu.js
add platform support for MapServer to the MapMenu
Modified: sandbox/jxlib-3.0/widgets/MapMenu.js
--- sandbox/jxlib-3.0/widgets/MapMenu.js	2010-01-28 19:13:21 UTC (rev 2045)
+++ sandbox/jxlib-3.0/widgets/MapMenu.js	2010-01-28 19:13:58 UTC (rev 2046)
@@ -80,9 +80,70 @@
             var params =  {parameters: {'folder': this.rootFolder},
                           onComplete: OpenLayers.Function.bind(this.processMapMenu, this)};
             Fusion.ajaxRequest(s, params);
+        } else if (this.arch == 'MapServer' && json.Folder) {
+            this.rootFolder = json.Folder ? json.Folder[0] : '/';
+            //var s = 'layers/' + this.arch + '/' + Fusion.getScriptLanguage() + '/MapMenu.' + Fusion.getScriptLanguage();
+            var s = '/platform/api/mapsherpa.php';
+            var options =  {
+                  parameters: {
+                    request: 'listresources',
+                    depth: -1,
+                    resourceType: 'map',
+                    folder: this.rootFolder
+                  method: 'GET',
+                  onComplete: OpenLayers.Function.bind(this.processMSMapMenu, this)
+            var temp = new OpenLayers.Ajax.Request( s, options);
+    processMSMapMenu: function(r) {
+        if (r.status == 200) {
+            var o;
+            eval("o="+r.responseText);
+            //var testData = '{"success":true,"errorMessages":[],"values":{"resources":[{"sResourceId":"/topLevel","sType":"Map"},{"sResourceId":"/Premium","sType":"Folder"},{"sResourceId":"/Premium/San Francisco","sType":"Map"},{"sResourceId":"/Premium/secondo","sType":"Folder"},{"sResourceId":"/Premium/secondo/deep","sType":"Map"}]}}';
+            //eval("o="+testData);
+            this.menus = {};
+            var list = o.values.resources;
+            for (var i=0; i<list.length; i++) {
+                var resource = list[i];
+                var mapId = resource.sResourceId;
+                mapId = mapId.replace(this.rootFolder, '');
+                if (resource.sType == "Folder") {
+                    this.createFolders(mapId);
+                } else {
+                  var folders = mapId.split('/');
+                  var label = folders.pop();
+                  var path = folders.join('/');
+                  // check for mapgroup data and if there is none,
+                  // create a maptag that will be passed to the map
+                  // widget constructor
+                  data = {maps:[{'resourceId': label,
+                          'singleTile':true,
+                          'type': this.arch,
+                          'extension':{'ResourceId': [label]}
+                  //set up needed accessor
+                  data.getInitialView = function() {
+                      return this.initialView;
+                  var menuItem = new Jx.Menu.Item({
+                      label: label,
+                      onClick: OpenLayers.Function.bind(this.switchMap, this, data)
+                  if (path == '') {
+                      this.uiObj.add(menuItem);
+                  }else {
+                      this.menus[path].add(menuItem);
     processMapMenu: function(r) {
             var o;
More information about the fusion-commits mailing list
