[fusion-commits] r2192 - in trunk/widgets: BufferPanel Search
SelectWithin
svn_fusion at osgeo.org
Tue Jul 13 22:31:53 EDT 2010
Author: hubu
Date: 2010-07-14 02:31:53 +0000 (Wed, 14 Jul 2010)
New Revision: 2192
trunk/widgets/BufferPanel/Buffer.php
trunk/widgets/BufferPanel/BufferReport.templ
trunk/widgets/BufferPanel/ErrorPage.templ
trunk/widgets/Search/ErrorPage.templ
trunk/widgets/Search/Search.templ
trunk/widgets/Search/SearchPrompt.templ
trunk/widgets/SelectWithin/SelectWithinPanel.templ
Fix the ticket 399. Reviewed by Mike Adair.
And also change the Buffer.php, since the split() function has been deprecated by PHP5.3.1.
So I change the split() to explode().
Modified: trunk/widgets/BufferPanel/Buffer.php
--- trunk/widgets/BufferPanel/Buffer.php 2010-07-08 18:01:52 UTC (rev 2191)
+++ trunk/widgets/BufferPanel/Buffer.php 2010-07-14 02:31:53 UTC (rev 2192)
@@ -87,7 +87,7 @@
$layers = $map->GetLayers();
$layer = FindLayer($layers, $bufferName);
- $layerNames = split(",", $layersParam);
+ $layerNames = explode(",", $layersParam);
// convert distance to meters
if($units == "mi") //miles
Modified: trunk/widgets/BufferPanel/BufferReport.templ
--- trunk/widgets/BufferPanel/BufferReport.templ 2010-07-08 18:01:52 UTC (rev 2191)
+++ trunk/widgets/BufferPanel/BufferReport.templ 2010-07-14 02:31:53 UTC (rev 2192)
@@ -47,11 +47,16 @@
function GetParent()
- if(popup)
- return opener;
- else
- return parent.parent;
+{debugger;
+ if(popup)
+ return opener;
+ else
+ var node = parent;
+ while (!node.Fusion && node.parent)
+ node = node.parent;
+ return node;
</script>
Modified: trunk/widgets/BufferPanel/ErrorPage.templ
--- trunk/widgets/BufferPanel/ErrorPage.templ 2010-07-08 18:01:52 UTC (rev 2191)
+++ trunk/widgets/BufferPanel/ErrorPage.templ 2010-07-14 02:31:53 UTC (rev 2192)
@@ -49,10 +49,15 @@
- if(popup)
- return opener;
- else
+ if(popup)
+ return opener;
+ else
+ while (!node.fusion && node.parent)
+ return node;
</script>
Modified: trunk/widgets/Search/ErrorPage.templ
--- trunk/widgets/Search/ErrorPage.templ 2010-07-08 18:01:52 UTC (rev 2191)
+++ trunk/widgets/Search/ErrorPage.templ 2010-07-14 02:31:53 UTC (rev 2192)
@@ -51,10 +51,15 @@
- if(popup)
- return opener;
- else
+ if(popup)
+ return opener;
+ else
+ return node;
</script>
Modified: trunk/widgets/Search/Search.templ
--- trunk/widgets/Search/Search.templ 2010-07-08 18:01:52 UTC (rev 2191)
+++ trunk/widgets/Search/Search.templ 2010-07-14 02:31:53 UTC (rev 2192)
@@ -106,10 +106,15 @@
- if(popup)
- return opener;
- else
+ if(popup)
+ return opener;
+ else
+ return node;
</script>
Modified: trunk/widgets/Search/SearchPrompt.templ
--- trunk/widgets/Search/SearchPrompt.templ 2010-07-08 18:01:52 UTC (rev 2191)
+++ trunk/widgets/Search/SearchPrompt.templ 2010-07-14 02:31:53 UTC (rev 2192)
@@ -80,10 +80,15 @@
- if(popup)
- return opener;
- else
+ if(popup)
+ return opener;
+ else
+ return node;
function SetMatchLabel()
Modified: trunk/widgets/SelectWithin/SelectWithinPanel.templ
--- trunk/widgets/SelectWithin/SelectWithinPanel.templ 2010-07-08 18:01:52 UTC (rev 2191)
+++ trunk/widgets/SelectWithin/SelectWithinPanel.templ 2010-07-14 02:31:53 UTC (rev 2192)
@@ -146,12 +146,16 @@
- if(popup) {
- return opener;
- } else {
+{debugger;
+ if(popup)
+ return opener;
+ else
+ return node;
</script>
More information about the fusion-commits
