[fusion-commits] r2092 - trunk
svn_fusion at osgeo.org
Mon Mar 8 15:17:07 EST 2010
Author: madair
Date: 2010-03-08 15:17:06 -0500 (Mon, 08 Mar 2010)
New Revision: 2092
trunk/BUILDING.TXT
trunk/COPYING.TXT
trunk/build.xml
closes #362: documentation updates
Modified: trunk/BUILDING.TXT
--- trunk/BUILDING.TXT 2010-03-05 05:15:16 UTC (rev 2091)
+++ trunk/BUILDING.TXT 2010-03-08 20:17:06 UTC (rev 2092)
@@ -16,10 +16,8 @@
For some tasks, external executable files are used and must be available for
execution on the PATH environment variable.
-This script requires an HTDOCS environment variable be set to point to the
-document root directory of your web server.
+Targets available include:
-targets available include:
prepare - creates a "build" subdirectory with all files required to be put on
the web server
deploy - places a copy of the build directory in the web server HTDOCS directory
@@ -42,11 +40,14 @@
Properties that can be set (and their defaults) include:
-<property name="sfName" value="${build.home}/lib/fusionSF"/>
-<property name="cssOutput" value="${sfName}"/>
-<property name="cssFiles" value=""/>
-<property name="appDef" value=""/>
+ <property name="YUIcompressor" value="${basedir}/utils/yuicompressor-2.3.6.jar"/>
+ <property name="sfName" value="fusionSF"/>
+ <property name="buildOutput" value="${build.home}/lib/${sfName}"/>
+ <property name="cssOutput" value="${build.home}/lib/${sfName}"/>
+ <property name="cssFiles" value=""/>
+ <property name="PHP" value="/usr/local/php5cgi/bin/php"/>
These properties can be assigned a value when ant is invoked by using the
-D command line option, e.g.:
Modified: trunk/COPYING.TXT
--- trunk/COPYING.TXT 2010-03-05 05:15:16 UTC (rev 2091)
+++ trunk/COPYING.TXT 2010-03-08 20:17:06 UTC (rev 2092)
@@ -1,14 +1,9 @@
Fusion License
-Scriptaculous and prototype are third party libraries included in the jx
-directory and are distributed under their own licenses. Please see
-MIT-LICENSE in the Scriptaculous directory for more information.
+Mootools is a third party library included in the jx distribution and is
+distributed under an MIT-style license. Please see the jxlib.uncompressed.js
+file for more information.
-ExplorerCanvas is Copyright 2006 Google Inc. and is distributed under
-the Apache License Version 2.0, January 2004.
-JavaScript Scalebar for MapServer (widgets/scalebar/) is Copyright (c) 2005 Tim Schaub of CommEn Space (http://www.commenspace.org) and is distributed under the LGPL license.
This license applies to all files obtained with the fusion source that are not
explicitly covered by a separate license.
Modified: trunk/build.xml
--- trunk/build.xml 2010-03-05 05:15:16 UTC (rev 2091)
+++ trunk/build.xml 2010-03-08 20:17:06 UTC (rev 2092)
@@ -74,7 +74,7 @@
<property environment="env"/>
<property name="app.name" value="fusion"/>
<property name="app.path" value="/${app.name}"/>
- <property name="app.version" value="1.1.x"/>
+ <property name="app.version" value="2.0.x"/>
<property name="build.home" value="${basedir}/build"/>
<property name="deploy.home" value="${basedir}/../${app.name}"/>
<property name="dist.home" value="${basedir}/dist"/>
@@ -155,8 +155,7 @@
<arg value="-i ./"/>
<arg value="-o html ./docs"/>
<arg value="-p ./docs/NaturalDocs"/>
- <arg value="-xi ./scriptaculous"/>
- <arg value="-xi ./lib"/>
+ <arg value="-xi ./lib"/>
<arg value="-r"/>
<arg line="/c perl C:\Progra~1\NaturalDocs\NaturalDocs -i ./lib -i ./widgets -o html ./docs/NaturalDocs -p ./docs/NaturalDocs -r"/>
More information about the fusion-commits
