[fusion-commits] r2094 - trunk/lib
svn_fusion at osgeo.org
Wed Mar 10 15:47:26 EST 2010
Author: madair
Date: 2010-03-10 15:47:25 -0500 (Wed, 10 Mar 2010)
New Revision: 2094
trunk/lib/ApplicationDefinition.js
re #315, #367: make sure that all <Map> objects end up with a valid EPSG code
Modified: trunk/lib/ApplicationDefinition.js
--- trunk/lib/ApplicationDefinition.js 2010-03-09 18:41:24 UTC (rev 2093)
+++ trunk/lib/ApplicationDefinition.js 2010-03-10 20:47:25 UTC (rev 2094)
@@ -526,7 +526,7 @@
//projection info from the extension
- this.projCode = "EPSG:4326"; //default to WGS84 lat long
+ //this.projCode = "EPSG:4326"; //default to WGS84 lat long
if (this.extension.ProjectionCode) {
this.projCode = this.extension.ProjectionCode[0];
@@ -537,6 +537,9 @@
Proj4js.defs[this.projCode] = projDef;
+ if (!this.projCode) {
+ this.projCode = "EPSG:4326";
switch (this.type) {
case 'MapGuide':
@@ -545,6 +548,12 @@
Fusion.require('layers/' + this.type + '/' + this.type + '.js');
break;
+ case "Google":
+ case "Yahoo":
+ case "VirtualEarth":
+ this.layerOptions.sphericalMercator = true;
+ this.layerOptions.displayProjection = "EPSG:4326";
+ //no break here continue below to set EPSG:3785 as projCode
default:
if (this.layerOptions.sphericalMercator) {
this.projCode = "EPSG:3785"; //commercial map layer projection spherical mercator
More information about the fusion-commits
