[fusion-commits] r2098 - in trunk: layers layers/Generic
	layers/MapGuide layers/MapServer lib widgets
    svn_fusion at osgeo.org
    Mon Mar 15 15:51:14 EDT 2010
Author: madair
Date: 2010-03-15 15:51:13 -0400 (Mon, 15 Mar 2010)
New Revision: 2098
   trunk/layers/Generic/Generic.js
   trunk/layers/Layers.js
   trunk/layers/MapGuide/MapGuide.js
   trunk/layers/MapServer/MapServer.js
   trunk/lib/ApplicationDefinition.js
   trunk/lib/Map.js
   trunk/widgets/MapMenu.js
re #315: use consistent handling of projection and units - set a reasonable default value in AppDef.js when parsing the AppDef, but values may be overridden by LoadMap response.  Let OL handle setting up it's units/projection via addLayer().
Modified: trunk/layers/Generic/Generic.js
--- trunk/layers/Generic/Generic.js	2010-03-11 05:38:18 UTC (rev 2097)
+++ trunk/layers/Generic/Generic.js	2010-03-15 19:51:13 UTC (rev 2098)
@@ -174,7 +174,7 @@
                   this.mapTag.layerOptions.maxExtent = new OpenLayers.Bounds(-20037508.3427892, -20037508.3427892, 20037508.3427892, 20037508.3427892);
               this.mapTag.layerOptions.units = "m";
-              this.mapTag.layerOptions.projection = "EPSG:900913";
+              this.mapTag.layerOptions.projection = "EPSG:3785";
             } else {
               if (!this.mapTag.layerOptions.maxExtent) {
                   this.mapTag.layerOptions.maxExtent = new OpenLayers.Bounds(-180,-90,180,90);
Modified: trunk/layers/Layers.js
--- trunk/layers/Layers.js	2010-03-11 05:38:18 UTC (rev 2097)
+++ trunk/layers/Layers.js	2010-03-15 19:51:13 UTC (rev 2098)
@@ -48,7 +48,6 @@
     noCache: false,
     _sMapTitle: null,
     _sMapname: null,
-    projCode: null,
     initialize: function(map, mapTag, isMapWidgetLayer) {
         // console.log('Fusion.Layers.initialize');
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js	2010-03-11 05:38:18 UTC (rev 2097)
+++ trunk/layers/MapGuide/MapGuide.js	2010-03-15 19:51:13 UTC (rev 2098)
@@ -86,9 +86,6 @@
-        //copy over projection info from maptag
-        this.projCode = mapTag.projCode;
         rootOpts = {
           displayInLegend: this.bDisplayInLegend,
           expandInLegend: this.bExpandInLegend,
@@ -304,14 +301,11 @@
             //set projection units and code if supplied
             if (o.epsg != 0) {
-              this.projCode = "EPSG:" + o.epsg;
+              this.mapTag.layerOptions.projection = "EPSG:" + o.epsg;
             //TODO: consider passing the metersPerUnit value into the framework
             //to allow for scaling that doesn't match any of the pre-canned units
-            this.units = Fusion.getClosestUnits(o.metersPerUnit);
-            if (this.projCode) {
-              this.mapWidget.setProjection(this.projCode, this.units);
+            this.mapTag.layerOptions.units = Fusion.getClosestUnits(o.metersPerUnit);
             //add in scales array if supplied
             if (o.FiniteDisplayScales && o.FiniteDisplayScales.length>0) {
@@ -579,8 +573,6 @@
       var layerOptions = {
-        units: this.units,
-        projection: this.projCode,
         maxResolution: 'auto',
         useOverlay: this.selectionAsOverlay,
         useAsyncOverlay: this.useAsyncOverlay,
Modified: trunk/layers/MapServer/MapServer.js
--- trunk/layers/MapServer/MapServer.js	2010-03-11 05:38:18 UTC (rev 2097)
+++ trunk/layers/MapServer/MapServer.js	2010-03-15 19:51:13 UTC (rev 2098)
@@ -254,16 +254,12 @@
             if (o.projString.length > 0) {
               var epsg = o.projString.indexOf("init=");
               if (epsg >= 0) {
-                this.projCode = o.projString.substring(epsg+5).toUpperCase();
+                this.mapTag.layerOptions.projection = o.projString.substring(epsg+5).toUpperCase();
               } else {
-                this.projCode = o.mapName.toUpperCase();
-                Proj4js.defs[this.projCode] = o.projString;
+                this.mapTag.layerOptions.projection = o.mapName.toUpperCase();
+                Proj4js.defs[this.mapTag.layerOptions.projection] = o.projString;
-              this.mapWidget.setProjection(this.projCode);
-            this.mapWidget.setMetersPerUnit(o.metersPerUnit);
             this.mapTag.layerOptions.maxExtent = OpenLayers.Bounds.fromArray(o.extent);
@@ -293,12 +289,11 @@
       				singleTile: true,
       				ratio: this.ratio,
       				minScale: maxScale,	//OL interpretation of min/max scale is reversed from Fusion
       				maxScale: minScale
@@ -330,7 +325,6 @@
             if (this.bIsMapWidgetLayer) {
               this.mapWidget.addMap(this);
-              this.mapWidget.oMapOL.units = this.oLayerOL.units;
             this.bMapLoaded = true;
Modified: trunk/lib/ApplicationDefinition.js
--- trunk/lib/ApplicationDefinition.js	2010-03-11 05:38:18 UTC (rev 2097)
+++ trunk/lib/ApplicationDefinition.js	2010-03-15 19:51:13 UTC (rev 2098)
@@ -486,7 +486,6 @@
     type: null,
     singleTile: false,
     extension: null,
-    projCode: null,
     initialize: function(jsonNode) {
         /* TODO: type can be any supported OpenLayers type */
@@ -526,19 +525,19 @@
         //projection info from the extension
-        //this.projCode = "EPSG:4326";  //default to WGS84 lat long
+        //this.layerOptions.projection = "EPSG:4326";  //default to WGS84 lat long
         if (this.extension.ProjectionCode) {
-          this.projCode = this.extension.ProjectionCode[0];
+          this.layerOptions.projection = this.extension.ProjectionCode[0];
         if (this.extension.ProjectionDef) {
           var projDef = this.extension.ProjectionDef[0];
-          if (!this.projCode) {
-            this.projCode = "APP-DEF-PROJ";
+          if (!this.layerOptions.projection) {
+            this.layerOptions.projection = "APP-DEF-PROJ";
-          Proj4js.defs[this.projCode] = projDef;
+          Proj4js.defs[this.layerOptions.projection] = projDef;
-          this.projCode = "EPSG:4326";
+          this.layerOptions.projection = "EPSG:4326";
         switch (this.type) {
@@ -551,14 +550,15 @@
           case "Google":
           case "Yahoo":
           case "VirtualEarth":
+              this.layerOptions.isBaseLayer = true;
               this.layerOptions.sphericalMercator = true;
               this.layerOptions.displayProjection = "EPSG:4326";
               //no break here continue below to set EPSG:3785 as projCode
           default:
             if (this.layerOptions.sphericalMercator) {
-              this.projCode = "EPSG:3785";  //commercial map layer projection spherical mercator
+              this.layerOptions.projection = "EPSG:3785";  //commercial map layer projection spherical mercator
             } else {
-              this.projCode = "EPSG:4326";  //WGS84 lat long
+              this.layerOptions.projection = "EPSG:4326";  //WGS84 lat long
             if ( !Fusion.Layers.Generic ) {
               Fusion.require('layers/Generic/Generic.js');
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js	2010-03-11 05:38:18 UTC (rev 2097)
+++ trunk/lib/Map.js	2010-03-15 19:51:13 UTC (rev 2098)
@@ -27,6 +27,7 @@
  * Class: Fusion.Widget.Map
  * generic class for map widgets. Provides common utility classes.
+ * This class provides a wrapper around the OpenLayers Map object.
 Fusion.Event.MAP_EXTENTS_CHANGED = Fusion.Event.lastEventId++;
@@ -52,37 +53,69 @@
 Fusion.Constant.LAYER_DWF_TYPE = 5;
 Fusion.Widget.Map = OpenLayers.Class(Fusion.Lib.EventMgr, {
+    /** The DOM object that holds the map */
     _oDomObj: null,
+    /** The id of DOM object */
     _sDomObj: '',
+    /** The internal name used for the map, usually assigned by the server */
     _sMapname: '',
-    _nWidth: -1,
-    _nHeight: -1,
+    /** conversion factor to convert from map units to meters */
     _fMetersperunit: -1,
+    /** scale denominator value */
     _fScale: -1,
+    /** Dots per inch setting for the server */
     _nDpi: 96,
+    /** The current bounds of the map, this is updated on every map draw */
     _oCurrentExtents: null,
+    /** The maximum extent of the map */
     maxExtent: new OpenLayers.Bounds(),
+    /** counter of worker threads for the ActivityIndicator widget  */
     _nWorkers: 0,
+    /** The context menu object for right click */
     oContextMenu: null,
+    /** flag to disable the map context menu, set this in the Map extension  */
     bSupressContextMenu: false,
+    /** an array to hold all the individual map layer objects */
     aMaps: null,
+    /** flag to indicate if all the map layers are loaded */
     mapsLoaded: false,
+    /** the root of the layer structure for the Legend */
     layerRoot: null,
+    /** flag to indicate if the map is tiled or not, set in the Map extension */
     singleTile: true,
+    /** flag to indicate if fractional zoom is supported, ie. allow any scale
+    *   value rather than a fixed set of scales
     fractionalZoom: true,
     maxScale: null, //set this to a large number in AppDef to zoom out beyond maxExtent, e.g. 1 billion
      * construct a new view Fusion.Widget.Map class.
-    initialize : function(widgetTag, mapGroup, widgetSet) {
+    initialize: function(widgetTag, mapGroup, widgetSet) {
         this.widgetTag = widgetTag;
         var name = widgetTag.name;
         this.aMaps = [];
         this.buttonSet = new Jx.ButtonSet();
         this.widgetSet = widgetSet;
-        this._nCellSize = -1;
         this._sDomObj = name;
         this._oDomObj = $(this._sDomObj);
         this.layerRoot = new Fusion.Layers.Group({
@@ -101,6 +134,7 @@
           this.fractionalZoom = widgetTag.extension.FractionalZoom[0]=='false'?false:true;
+        //if there is a scales array specified, use that set and turn off fraczoom
         var scalesArray = null;
         if (widgetTag.extension.Scales) {
           scalesArray = widgetTag.extension.Scales[0].split(',');
@@ -113,11 +147,13 @@
           this.maxScale = parseInt(widgetTag.extension.MaxExtent[0]);
+        //set the maxExtent
         var maxExtent = null;
         if (widgetTag.extension.MaxExtent) {
           maxExtent = OpenLayers.Bounds.fromString(widgetTag.extension.MaxExtent[0]);
+        //create the OpenLayers Map object
         OpenLayers.DOTS_PER_INCH = this._nDpi;
         if (!this.oMapOL) {
             var options = {
@@ -136,6 +172,7 @@
             this.oMapOL = new OpenLayers.Map(this._sDomObj, options );
+        //Fusion specific modifications to the OL map window style
         this.oMapOL.viewPortDiv.style.position = 'absolute';  //not the top level container so set it to absolute
         this.oMapOL.viewPortDiv.style.zIndex = 0;   //must explicitly set the z-index for FF3
@@ -188,10 +225,28 @@
         this.loadMapGroup(mapGroup);
+     * Function: mapLoaded
+     * Callback for when all maps have been loaded
+     * Parameter: none.
+     * Return: none
     mapLoaded: function() {
       this.setViewOptions(this.getUnits());
+     * Function: setMenu
+     * Attaches a context menu as defined in the AppDef to the map
+     * Return: none
     setMenu: function() {
         if (this.widgetTag.extension.MenuContainer) {
             var contextMenu = new Jx.Menu.Context();
@@ -203,6 +258,15 @@
+     * Function: loadMapGroup
+     * Controls the creation of Layers based on the MapGroup object passed in
+     * Parameter: {Object} mapGroup - a representation of the MapGroup object
+     * Return: none
     loadMapGroup: function(mapGroup) {
         //clear any existing selection
         this.mapsLoaded = false;
@@ -238,6 +302,17 @@
         this.triggerEvent(Fusion.Event.MAP_MAP_GROUP_LOADED);
+     * Function: layerLoaded
+     * Called after each layer is loaded in the OL viewport.  Nothing happens
+     * here until the last layer is laoded, then it sets the OL baselayer and
+     * zooms to the initial extent.
+     * Parameter: none
+     * Return: none
     layerLoaded: function() {
       for (var i=0; i<this.aMaps.length; ++i) {
         if (!this.aMaps[i].isMapLoaded()) {
@@ -269,10 +344,14 @@
-     * Method: wheelChange
+     * Function: wheelChange
+     * handles mouse wheel events by accummulating the events and setting a timer
+     * to do the actual zoom in/out
      * Parameters:
-     * evt - {Event}
+     * evt - {Event} the mouse wheel event object
+     * deltaZ - {Integer} the number of ticks wheeled
     wheelChange: function(evt, deltaZ) {
         if (this.wheelTimer) {
@@ -285,6 +364,17 @@
         this.wheelTimer = setTimeout(OpenLayers.Function.bind(function(){this.doWheelChange(evt, deltaZ);}, this), 200);
+     * Function: doWheelChange
+     * Carries out the actual map zoom based on the wheel movement
+     * Parameters:
+     * Return: none
     doWheelChange: function(evt, deltaZ) {
         this.wheelTimer = null;
         if (this.cumulativeDelta == 0) {
@@ -331,50 +421,104 @@
-     * returns the dom element
+     * Function: getDomObj
+     * returns the dom element for this widget
+     * Parameters: none
+     * Return: none
     getDomObj: function() {
         return this._oDomObj;
+     * Function: getMapName
+     * returns the name of the baselayer map
+     * Return: {String} the name of the baselayer map
     getMapName: function() {
         //TODO: what is the mapname in the case of multiple map layer objects?
         //just return baselayer mapname for now
         return this.aMaps[0].getMapName();
+     * Function: getMapTitle
+     * returns the Title of the baselayer map.  This is a human-readable title
+     * Return: {String} the Title of the baselayer map
     getMapTitle: function() {
         //TODO: what is the map title in the case of multiple map layer objects?
         //just return baselayer mapTitle for now
         return this.aMaps[0]._sMapTitle;
+     * Function: getSessionID
+     * returns the server session ID
+     * Return: {String} the session ID
     getSessionID: function() {
         //just return baselayer session ID for now
         return this.aMaps[0].getSessionID();
+     * Function: getDomId
+     * returns the ID of dom element for this widget
+     * Return: {String} the id of the DOM element
     getDomId: function() {
         return this._sDomObj;
+     * Function: setMapOptions
+     * sets options on the OpenLayers map object, a wrapper for the OL function
+     * Parameters: {Object} options - has of option key/value pairs
+     * Return: none
     setMapOptions: function(options) {
         this.oMapOL.setOptions(options);
+     * Function: addMap
+     * adds a map/Layer to the map and registers some event handlers on the map
+     * Parameters: {Object} map - the map object to tbe added (really a layer object)
+     * Return: none
     addMap: function(map) {
         if (map.mapTag.layerOptions.maxExtent) {
-          this.projection = map.projection;
-          this.units = map.units;
           this.maxExtent.extend(map.mapTag.layerOptions.maxExtent);
-          this.oMapOL.setOptions({
-                  maxExtent: this.maxExtent,
-                  units: map.units,
-                  projection: this.projection
+          this.oMapOL.setOptions({maxExtent: this.maxExtent});
         //if bRestrictExtent is null, use the default OL behaviour with somewhat restricted map navigation
@@ -388,19 +532,44 @@
         this.oMapOL.addLayer(map.oLayerOL);
-        map.registerForEvent(Fusion.Event.MAP_LOADED,
-                OpenLayers.Function.bind(this.mapLoadHandler, this));
+        if (map.oLayerOL.isBaseLayer) {
+          this.projection = map.projection;
+          this.units = map.units;
+                  units: map.units,
+                  projection: this.projection
         map.registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
                 OpenLayers.Function.bind(this.selectionHandler, this));
         map.registerForEvent(Fusion.Event.MAP_SELECTION_ON,
+     * Function: getAllMaps
+     * returns the array of map objects
+     * Return: {Array} the array of map Objects
     getAllMaps: function() {
         return this.aMaps;
-    //this uses setTimeout so this method can be called from an IFRAME
+     * Function: reloadMap
+     * Called to reload all the map objects.
+     * this uses setTimeout so this method can be called from an IFRAME
+     * Return: none
     reloadMap: function() {
         var map = this.aMaps[i];
@@ -408,6 +577,17 @@
+     * Function: loadScaleRanges
+     * Loads the ScaleRange objects separate from the LoadMap sequence since
+     * this also generates sprites and is a relatively expensive operation.
+     * Parameters: {Function} userFunc - a user defined function to be called as a
+     *                                  callback
+     * Return: none
     loadScaleRanges: function(userFunc) {
@@ -418,7 +598,9 @@
      * Function: query
-     * dispatch query requests to maps
+     * dispatch query requests to the maps
+     * Parameters: {object} options - query options to be passed to each map
     query: function(options) {
         this.lastQueryOptions = options;
@@ -429,25 +611,14 @@
-     * Function: mapLoadHandler
+     * Function: selectionHandler
      * handle selection events from maps and republish for
      * widgets as appropriate
-    mapLoadHandler: function() {
-        ++this.mapLoadCounter;
-        if (this.mapLoadCounter == this.aMaps.length) {
-            this._oInitialExtents = null;
-            this.fullExtents();
-            this.triggerEvent(Fusion.Event.MAP_LOADED);
-     * Function: selectionHandler
-     * handle selection events from maps and republish for
-     * widgets as appropriate
+     * Return: none
     selectionHandler: function() {
         if (this.hasSelection()) {
@@ -460,7 +631,9 @@
      * Function: hasSelection
-     * returns true if any map has a selection
+     * cehck to see if any of the maps have an active selection
+     * Returns: {Boolean} - true if any map has a selection
      hasSelection: function() {
          for (var i=0; i<this.aMaps.length; i++ ) {
@@ -487,7 +660,7 @@
       * Function: getSelection
-      * returns the current selection asynchronously in case we
+      * initiates a call to get the current selection asynchronously in case we
       * need to retrieve the details from the server
      getSelection: function(callback, layers, startcount) {
@@ -515,7 +688,11 @@
       * Function: setSelection
-      * sets a Selection XML back to the server
+      * sets a Selection XML back to the server for each of the maps
+      * Parameters:
+      * {String} selText - the selection string
+      * {Boolean} zoomTo - if set, will zoom to the selection on completion
       setSelection: function(selText, zoomTo) {
@@ -528,6 +705,10 @@
       * accumulate the selection results from each map and when all have
       * reported in, pass the results to the callback function
+      * Parameters:
+      * {Object} map - the map object that has the selection
+      * {Object} oSelection - the Fusion selection object
      accumulateSelection: function(map, oSelection) {
          this.oSelection[map._sMapname] = oSelection;
@@ -545,25 +726,33 @@
       * Function: setActiveLayer
       * sets the active layer for selection/manipulation
+      * Parameters:
+      * {Object} oLayer - the layer to be set as active
-    setActiveLayer: function( oLayer ) {
-        this.oActiveLayer = oLayer;
-        if (oLayer) {
-            this.oActiveMap = oLayer.map;
-        this.triggerEvent(Fusion.Event.MAP_ACTIVE_LAYER_CHANGED, oLayer);
+      setActiveLayer: function( oLayer ) {
+          this.oActiveLayer = oLayer;
+          if (oLayer) {
+              this.oActiveMap = oLayer.map;
+          this.triggerEvent(Fusion.Event.MAP_ACTIVE_LAYER_CHANGED, oLayer);
       * Function: getActiveLayer
       * returns the active layer for selection/manipulation
+      * Returns:
+      * {Object} the active layer
     getActiveLayer: function() {
         return this.oActiveLayer;
+     * Function: _addWorker
      * indicate that a new asynchronous process has started and make sure the
      * visual indicator is visible for the user.  This is intended to be used
      * internally by gMap but could be used by external tools if appropriate.
@@ -575,6 +764,8 @@
+     * Function: _removeWorker
      * indicate that an asynchronous process has completed and hide the
      * visual indicator if no remaining processes are active.  This is
      * intended to be used internally by gMap but could be used by
@@ -589,19 +780,57 @@
         this.triggerEvent(Fusion.Event.MAP_BUSY_CHANGED, this);
+     * Function: mapExtentsChanged
+     * OpenLayers event handler for whenever the map changes either zoom level
+     * of the center has changed.  This in turn triggers the Fusion event.
+     * Return: none
     mapExtentsChanged: function() {
         this._oCurrentExtents = this.oMapOL.getExtent();
         this.triggerEvent(Fusion.Event.MAP_EXTENTS_CHANGED);
+     * Function: isBusy
+     * check to see if there are any outstanding requests to the server
+     * Return: {Boolean} true if there are active requests
     isBusy: function() {
         return this._nWorkers > 0;
+     * Function: sizeChanged
+     * callback for when the browser window size changes, simply calls resize
+     * on the map viewport layout object
+     * Return: none
     sizeChanged: function() {
         this.resize();
+     * Function: resize
+     * handles the resizing of the maps and triggers a Fusion event
+     * Return: none
     resize: function() {
       if (!this.mapsLoaded) {
         return;
@@ -609,29 +838,57 @@
       //console.log('Fusion.Widget.Map.resize');
         this.oMapOL.updateSize();
         var d = $(this.getDomObj()).getContentBoxSize();
-        this._nWidth = d.width;
-        this._nHeight = d.height;
         if (this._oCurrentExtents) {
           this.setExtents(this._oCurrentExtents);
         this.triggerEvent(Fusion.Event.MAP_RESIZED, this);
+     * Function: redraw
+     * redraws the map using current extents and zoom level.  A dummy parameter
+     * is added to the map request to ensure the map request is not cached.
+     * Return: none
     redraw: function() {
-	    if(this.aMaps[i].oLayerOL.params){
+        if(this.aMaps[i].oLayerOL.params){
             this.aMaps[i].oLayerOL.params.ts = (new Date()).getTime();
             //mergeNewParams calls redraw on the layer, which will get called below anyway
             //this.aMaps[i].oLayerOL.mergeNewParams({ts : (new Date()).getTime()});
       this.oMapOL.setCenter(this.oMapOL.getCenter(), this.oMapOL.getZoom(), false, true);
+     * Function: setBackgroundColor
+     * sets the background color for the map
+     * Parameters: {String} color - the CSS color value to set as background
+     * Return: none
     setBackgroundColor: function(color) {
         this._oDomObj.style.backgroundColor = color;
+     * Function: setExtents
+     * handle selection events from maps and republish for
+     * widgets as appropriate
+     * Parameters: {Object} oExtents - an OpenLayers.Bounds object or an array
+     *                            of 4 values that will be converted to Bounds
+     * Return: none
     setExtents: function(oExtents) {
         if (!oExtents) {
             Fusion.reportError(new Fusion.Error(Fusion.Error.WARNING,
@@ -652,10 +909,14 @@
+     * Function: setInitialExtents
      * determine the initialExtents of the map from (in order of precedence):
      * 1. a URL query parameter called 'extent'
      * 2. an <InitialView> specified in the MapGroup in AppDef
      * 3. the maxExtent as specified by the LoadMap call (default)
+     * Returns: {Object} an OpenLayers.Bounds object which is the initial extent
     setInitialExtents: function() {
       var initialExtents;
@@ -684,7 +945,12 @@
-     * sets the extent by examining all mapgroup map extents
+     * Function: getMapGroupExtent
+     * gets the intitial extents from all maps with or without including the
+     * extent of any Generic/commercial layers
+     * Return: {Object} an OpenLayers.Bounds object which is the initial extent
     getMapGroupExtent: function(includeGenericLayers) {
       var initialExtent;
@@ -698,6 +964,8 @@
+     * Function: fullExtents
      * sets the extent of the map to the max as returned by loadMap
     fullExtents: function() {
@@ -705,10 +973,34 @@
       this.setExtents(extents);
+     * Function: isMapLoaded
+     * returns if the map has finished loading (based on setting the
+     * _oCurrentExtent value)
+     * Returns {Boolean} true if the map is loaded and extent has been set
     isMapLoaded: function() {
         return (this._oCurrentExtents) ? true : false;
+     * Function: zoom
+     * sets the map zoom and extent.
+     * Parameters:
+     *   fX {Float} - new x coordinate value in map units
+     *   fY {Float} - new y coordinate value in map units
+     *   nFactor {Float} - zoom factor; positive values zoom in, negative out
+     *                  - if set to 0 or 1, the map is just recentered
+     *                  - if the map has fractional zoom enabled, the map resolution
+     *                  will be modified by this factor
+     *                  - with fixed scales, zoom up or down one level, depending on the sign
+     * Returns: none
     zoom: function(fX, fY, nFactor) {
         //do this differntly with OL code??
         if (nFactor == 1 || nFactor == 0) {
@@ -745,15 +1037,63 @@
+     * Function: zoom
+     * Parameters:
+     * Returns: none
     zoomToScale: function(fScale) {
         var center = this.getCurrentCenter();
         var extent = this.getExtentFromPoint(center.x, center.y, fScale);
         this.setExtents(extent);
-    queryRect : function(fMinX, fMinY, fMaxX, fMaxY) { },
+     * Function: zoom
+     * Parameters:
+     * Returns: none
+    queryRect: function(fMinX, fMinY, fMaxX, fMaxY) { },
-    queryPoint : function(fX, fY) { },
+     * Function: zoom
+     * Parameters:
+     * Returns: none
+    queryPoint: function(fX, fY) { },
@@ -765,7 +1105,7 @@
      * @return an object with geographic coordinates in x and y properties of the
      *         object.
-    pixToGeo : function( pX, pY ) {
+    pixToGeo: function( pX, pY ) {
         var lonLat = this.oMapOL.getLonLatFromPixel( new OpenLayers.Pixel(pX,pY) );
         if (lonLat != null) {
           return {x:lonLat.lon, y:lonLat.lat};
@@ -783,7 +1123,7 @@
      * @return an object with pixel coordinates in x and y properties of the
      *         object.
-    geoToPix : function( gX, gY ) {
+    geoToPix: function( gX, gY ) {
         if (!(this._oCurrentExtents)) {
             return null;
@@ -799,7 +1139,7 @@
      * @return geographic measure
-    pixToGeoMeasure : function(nPixels) {
+    pixToGeoMeasure: function(nPixels) {
         var resolution = this.oMapOL.getResolution();
         return (nPixels*resolution);
Modified: trunk/widgets/MapMenu.js
--- trunk/widgets/MapMenu.js	2010-03-11 05:38:18 UTC (rev 2097)
+++ trunk/widgets/MapMenu.js	2010-03-15 19:51:13 UTC (rev 2098)
@@ -157,8 +157,17 @@
     //change the map, preserving current extents
     switchMap: function(data) {
         var ce = this.getMap().getCurrentExtents();
-        var dest = new OpenLayers.Projection(data.maps[0].projCode);
-        ce = ce.transform(this.oMap.oMapOL.baseLayer.projection, dest);
+        var dest = null;
+        for (var i=0; i<data.maps.length; ++i) {
+          if (data.maps[i].layerOptions.isBaseLayer) {
+            dest = new OpenLayers.Projection(data.maps[i].layerOptions.projection);
+            break;
+        if (!dest) {
+          dest = new OpenLayers.Projection("EPSG:4326");
+        ce = ce.transform(this.oMap.oMapOL.getProjectionObject(), dest);
         data.initialView = {minX:ce.left,
                             minY:ce.bottom,
                             maxX:ce.right,
More information about the fusion-commits
