[fusion-commits] r2160 - sandbox/jxlib-3.0/lib
svn_fusion at osgeo.org
Thu May 20 13:45:39 EDT 2010
Author: madair
Date: 2010-05-20 13:45:38 -0400 (Thu, 20 May 2010)
New Revision: 2160
sandbox/jxlib-3.0/lib/jxlib.uncompressed.js
only update treefolders if they have been changed
Modified: sandbox/jxlib-3.0/lib/jxlib.uncompressed.js
--- sandbox/jxlib-3.0/lib/jxlib.uncompressed.js 2010-05-17 19:01:40 UTC (rev 2159)
+++ sandbox/jxlib-3.0/lib/jxlib.uncompressed.js 2010-05-20 17:45:38 UTC (rev 2160)
@@ -27,14558 +27,14576 @@
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
-script: Core.js
-description: The core of MooTools, contains all the base functions and the Native and Hash implementations. Required by all the other scripts.
-license: MIT-style license.
-copyright: Copyright (c) 2006-2008 [Valerio Proietti](http://mad4milk.net/).
-authors: The MooTools production team (http://mootools.net/developers/)
-inspiration:
-- Class implementation inspired by [Base.js](http://dean.edwards.name/weblog/2006/03/base/) Copyright (c) 2006 Dean Edwards, [GNU Lesser General Public License](http://opensource.org/licenses/lgpl-license.php)
-- Some functionality inspired by [Prototype.js](http://prototypejs.org) Copyright (c) 2005-2007 Sam Stephenson, [MIT License](http://opensource.org/licenses/mit-license.php)
-provides: [MooTools, Native, Hash.base, Array.each, $util]
-var MooTools = {
- 'version': '1.2.5dev',
- 'build': '%build%'
-var Native = function(options){
- options = options || {};
- var name = options.name;
- var legacy = options.legacy;
- var protect = options.protect;
- var methods = options.implement;
- var generics = options.generics;
- var initialize = options.initialize;
- var afterImplement = options.afterImplement || function(){};
- var object = initialize || legacy;
- generics = generics !== false;
- object.constructor = Native;
- object.$family = {name: 'native'};
- if (legacy && initialize) object.prototype = legacy.prototype;
- object.prototype.constructor = object;
- if (name){
- var family = name.toLowerCase();
- object.prototype.$family = {name: family};
- Native.typize(object, family);
- var add = function(obj, name, method, force){
- if (!protect || force || !obj.prototype[name]) obj.prototype[name] = method;
- if (generics) Native.genericize(obj, name, protect);
- afterImplement.call(obj, name, method);
- return obj;
- object.alias = function(a1, a2, a3){
- if (typeof a1 == 'string'){
- var pa1 = this.prototype[a1];
- if ((a1 = pa1)) return add(this, a2, a1, a3);
- for (var a in a1) this.alias(a, a1[a], a2);
- return this;
- object.implement = function(a1, a2, a3){
- if (typeof a1 == 'string') return add(this, a1, a2, a3);
- for (var p in a1) add(this, p, a1[p], a2);
- return this;
- if (methods) object.implement(methods);
- return object;
-Native.genericize = function(object, property, check){
- if ((!check || !object[property]) && typeof object.prototype[property] == 'function') object[property] = function(){
- var args = Array.prototype.slice.call(arguments);
- return object.prototype[property].apply(args.shift(), args);
-Native.implement = function(objects, properties){
- for (var i = 0, l = objects.length; i < l; i++) objects[i].implement(properties);
-Native.typize = function(object, family){
- if (!object.type) object.type = function(item){
- return ($type(item) === family);
-(function(){
- var natives = {'Array': Array, 'Date': Date, 'Function': Function, 'Number': Number, 'RegExp': RegExp, 'String': String};
- for (var n in natives) new Native({name: n, initialize: natives[n], protect: true});
- var types = {'boolean': Boolean, 'native': Native, 'object': Object};
- for (var t in types) Native.typize(types[t], t);
- var generics = {
- 'Array': ["concat", "indexOf", "join", "lastIndexOf", "pop", "push", "reverse", "shift", "slice", "sort", "splice", "toString", "unshift", "valueOf"],
- 'String': ["charAt", "charCodeAt", "concat", "indexOf", "lastIndexOf", "match", "replace", "search", "slice", "split", "substr", "substring", "toLowerCase", "toUpperCase", "valueOf"]
- for (var g in generics){
- for (var i = generics[g].length; i--;) Native.genericize(natives[g], generics[g][i], true);
-var Hash = new Native({
- name: 'Hash',
- initialize: function(object){
- if ($type(object) == 'hash') object = $unlink(object.getClean());
- for (var key in object) this[key] = object[key];
- return this;
-Hash.implement({
- forEach: function(fn, bind){
- for (var key in this){
- if (this.hasOwnProperty(key)) fn.call(bind, this[key], key, this);
- getClean: function(){
- var clean = {};
- if (this.hasOwnProperty(key)) clean[key] = this[key];
- return clean;
- getLength: function(){
- var length = 0;
- if (this.hasOwnProperty(key)) length++;
- return length;
-Hash.alias('forEach', 'each');
-Array.implement({
- for (var i = 0, l = this.length; i < l; i++) fn.call(bind, this[i], i, this);
-Array.alias('forEach', 'each');
-function $A(iterable){
- if (iterable.item){
- var l = iterable.length, array = new Array(l);
- while (l--) array[l] = iterable[l];
- return array;
- return Array.prototype.slice.call(iterable);
-function $arguments(i){
- return function(){
- return arguments[i];
-function $chk(obj){
- return !!(obj || obj === 0);
-function $clear(timer){
- clearTimeout(timer);
- clearInterval(timer);
- return null;
-function $defined(obj){
- return (obj != undefined);
-function $each(iterable, fn, bind){
- var type = $type(iterable);
- ((type == 'arguments' || type == 'collection' || type == 'array') ? Array : Hash).each(iterable, fn, bind);
-function $empty(){};
-function $extend(original, extended){
- for (var key in (extended || {})) original[key] = extended[key];
- return original;
-function $H(object){
- return new Hash(object);
-function $lambda(value){
- return ($type(value) == 'function') ? value : function(){
- return value;
-function $merge(){
- var args = Array.slice(arguments);
- args.unshift({});
- return $mixin.apply(null, args);
-function $mixin(mix){
- for (var i = 1, l = arguments.length; i < l; i++){
- var object = arguments[i];
- if ($type(object) != 'object') continue;
- for (var key in object){
- var op = object[key], mp = mix[key];
- mix[key] = (mp && $type(op) == 'object' && $type(mp) == 'object') ? $mixin(mp, op) : $unlink(op);
- return mix;
-function $pick(){
- for (var i = 0, l = arguments.length; i < l; i++){
- if (arguments[i] != undefined) return arguments[i];
- return null;
-function $random(min, max){
- return Math.floor(Math.random() * (max - min + 1) + min);
-function $splat(obj){
- var type = $type(obj);
- return (type) ? ((type != 'array' && type != 'arguments') ? [obj] : obj) : [];
-var $time = Date.now || function(){
- return +new Date;
-function $try(){
- try {
- return arguments[i]();
- } catch(e){}
- return null;
-function $type(obj){
- if (obj == undefined) return false;
- if (obj.$family) return (obj.$family.name == 'number' && !isFinite(obj)) ? false : obj.$family.name;
- if (obj.nodeName){
- switch (obj.nodeType){
- case 1: return 'element';
- case 3: return (/\S/).test(obj.nodeValue) ? 'textnode' : 'whitespace';
- } else if (typeof obj.length == 'number'){
- if (obj.callee) return 'arguments';
- else if (obj.item) return 'collection';
- return typeof obj;
-function $unlink(object){
- var unlinked;
- switch ($type(object)){
- case 'object':
- unlinked = {};
- for (var p in object) unlinked[p] = $unlink(object[p]);
- break;
- case 'hash':
- unlinked = new Hash(object);
- break;
- case 'array':
- unlinked = [];
- for (var i = 0, l = object.length; i < l; i++) unlinked[i] = $unlink(object[i]);
- break;
- default: return object;
- return unlinked;
-script: Browser.js
-description: The Browser Core. Contains Browser initialization, Window and Document, and the Browser Hash.
-requires:
-- /Native
-- /$util
-provides: [Browser, Window, Document, $exec]
-var Browser = $merge({
- Engine: {name: 'unknown', version: 0},
- Platform: {name: (window.orientation != undefined) ? 'ipod' : (navigator.platform.match(/mac|win|linux/i) || ['other'])[0].toLowerCase()},
- Features: {xpath: !!(document.evaluate), air: !!(window.runtime), query: !!(document.querySelector)},
- Plugins: {},
- Engines: {
- presto: function(){
- return (!window.opera) ? false : ((arguments.callee.caller) ? 960 : ((document.getElementsByClassName) ? 950 : 925));
- trident: function(){
- return (!window.ActiveXObject) ? false : ((window.XMLHttpRequest) ? ((document.querySelectorAll) ? 6 : 5) : 4);
- webkit: function(){
- return (navigator.taintEnabled) ? false : ((Browser.Features.xpath) ? ((Browser.Features.query) ? 525 : 420) : 419);
- gecko: function(){
- return (!document.getBoxObjectFor && window.mozInnerScreenX == null) ? false : ((document.getElementsByClassName) ? 19 : 18);
-}, Browser || {});
-Browser.Platform[Browser.Platform.name] = true;
-Browser.detect = function(){
- for (var engine in this.Engines){
- var version = this.Engines[engine]();
- if (version){
- this.Engine = {name: engine, version: version};
- this.Engine[engine] = this.Engine[engine + version] = true;
- break;
- return {name: engine, version: version};
-Browser.detect();
-Browser.Request = function(){
- return $try(function(){
- return new XMLHttpRequest();
- }, function(){
- return new ActiveXObject('MSXML2.XMLHTTP');
- }, function(){
- return new ActiveXObject('Microsoft.XMLHTTP');
-Browser.Features.xhr = !!(Browser.Request());
-Browser.Plugins.Flash = (function(){
- var version = ($try(function(){
- return navigator.plugins['Shockwave Flash'].description;
- }, function(){
- return new ActiveXObject('ShockwaveFlash.ShockwaveFlash').GetVariable('$version');
- }) || '0 r0').match(/\d+/g);
- return {version: parseInt(version[0] || 0 + '.' + version[1], 10) || 0, build: parseInt(version[2], 10) || 0};
-function $exec(text){
- if (!text) return text;
- if (window.execScript){
- window.execScript(text);
- } else {
- var script = document.createElement('script');
- script.setAttribute('type', 'text/javascript');
- script[(Browser.Engine.webkit && Browser.Engine.version < 420) ? 'innerText' : 'text'] = text;
- document.head.appendChild(script);
- document.head.removeChild(script);
- return text;
-Native.UID = 1;
-var $uid = (Browser.Engine.trident) ? function(item){
- return (item.uid || (item.uid = [Native.UID++]))[0];
-} : function(item){
- return item.uid || (item.uid = Native.UID++);
-var Window = new Native({
- name: 'Window',
- legacy: (Browser.Engine.trident) ? null: window.Window,
- initialize: function(win){
- $uid(win);
- if (!win.Element){
- win.Element = $empty;
- if (Browser.Engine.webkit) win.document.createElement("iframe"); //fixes safari 2
- win.Element.prototype = (Browser.Engine.webkit) ? window["[[DOMElement.prototype]]"] : {};
- win.document.window = win;
- return $extend(win, Window.Prototype);
- afterImplement: function(property, value){
- window[property] = Window.Prototype[property] = value;
-Window.Prototype = {$family: {name: 'window'}};
-new Window(window);
-var Document = new Native({
- name: 'Document',
- legacy: (Browser.Engine.trident) ? null: window.Document,
- initialize: function(doc){
- $uid(doc);
- doc.head = doc.getElementsByTagName('head')[0];
- doc.html = doc.getElementsByTagName('html')[0];
- if (Browser.Engine.trident && Browser.Engine.version <= 4) $try(function(){
- doc.execCommand("BackgroundImageCache", false, true);
- if (Browser.Engine.trident) doc.window.attachEvent('onunload', function(){
- doc.window.detachEvent('onunload', arguments.callee);
- doc.head = doc.html = doc.window = null;
- return $extend(doc, Document.Prototype);
- document[property] = Document.Prototype[property] = value;
-Document.Prototype = {$family: {name: 'document'}};
-new Document(document);
-script: Array.js
-description: Contains Array Prototypes like each, contains, and erase.
-requires:
-- /$util
-- /Array.each
-provides: [Array]
-Array.implement({
- every: function(fn, bind){
- for (var i = 0, l = this.length; i < l; i++){
- if (!fn.call(bind, this[i], i, this)) return false;
- return true;
- filter: function(fn, bind){
- var results = [];
- if (fn.call(bind, this[i], i, this)) results.push(this[i]);
- return results;
- clean: function(){
- return this.filter($defined);
- indexOf: function(item, from){
- var len = this.length;
- for (var i = (from < 0) ? Math.max(0, len + from) : from || 0; i < len; i++){
- if (this[i] === item) return i;
- return -1;
- map: function(fn, bind){
- var results = [];
- for (var i = 0, l = this.length; i < l; i++) results[i] = fn.call(bind, this[i], i, this);
- return results;
- some: function(fn, bind){
- if (fn.call(bind, this[i], i, this)) return true;
- return false;
- associate: function(keys){
- var obj = {}, length = Math.min(this.length, keys.length);
- for (var i = 0; i < length; i++) obj[keys[i]] = this[i];
- return obj;
- link: function(object){
- var result = {};
- if (object[key](this[i])){
- result[key] = this[i];
- delete object[key];
- break;
- return result;
- contains: function(item, from){
- return this.indexOf(item, from) != -1;
- extend: function(array){
- for (var i = 0, j = array.length; i < j; i++) this.push(array[i]);
- return this;
- getLast: function(){
- return (this.length) ? this[this.length - 1] : null;
- getRandom: function(){
- return (this.length) ? this[$random(0, this.length - 1)] : null;
- include: function(item){
- if (!this.contains(item)) this.push(item);
- return this;
- combine: function(array){
- for (var i = 0, l = array.length; i < l; i++) this.include(array[i]);
- return this;
- erase: function(item){
- for (var i = this.length; i--; i){
- if (this[i] === item) this.splice(i, 1);
- return this;
- empty: function(){
- this.length = 0;
- return this;
- flatten: function(){
- var array = [];
- var type = $type(this[i]);
- if (!type) continue;
- array = array.concat((type == 'array' || type == 'collection' || type == 'arguments') ? Array.flatten(this[i]) : this[i]);
- return array;
- hexToRgb: function(array){
- if (this.length != 3) return null;
- var rgb = this.map(function(value){
- if (value.length == 1) value += value;
- return value.toInt(16);
- return (array) ? rgb : 'rgb(' + rgb + ')';
- rgbToHex: function(array){
- if (this.length < 3) return null;
- if (this.length == 4 && this[3] == 0 && !array) return 'transparent';
- var hex = [];
- for (var i = 0; i < 3; i++){
- var bit = (this[i] - 0).toString(16);
- hex.push((bit.length == 1) ? '0' + bit : bit);
- return (array) ? hex : '#' + hex.join('');
-script: Function.js
-description: Contains Function Prototypes like create, bind, pass, and delay.
-requires:
-- /Native
-- /$util
-provides: [Function]
-Function.implement({
- extend: function(properties){
- for (var property in properties) this[property] = properties[property];
- return this;
- create: function(options){
- var self = this;
- return function(event){
- var args = options.arguments;
- args = (args != undefined) ? $splat(args) : Array.slice(arguments, (options.event) ? 1 : 0);
- if (options.event) args = [event || window.event].extend(args);
- var returns = function(){
- return self.apply(options.bind || null, args);
- if (options.delay) return setTimeout(returns, options.delay);
- if (options.periodical) return setInterval(returns, options.periodical);
- if (options.attempt) return $try(returns);
- return returns();
- run: function(args, bind){
- return this.apply(bind, $splat(args));
- pass: function(args, bind){
- return this.create({bind: bind, arguments: args});
- bind: function(bind, args){
- bindWithEvent: function(bind, args){
- return this.create({bind: bind, arguments: args, event: true});
- attempt: function(args, bind){
- return this.create({bind: bind, arguments: args, attempt: true})();
- delay: function(delay, bind, args){
- return this.create({bind: bind, arguments: args, delay: delay})();
- periodical: function(periodical, bind, args){
- return this.create({bind: bind, arguments: args, periodical: periodical})();
-script: Number.js
-description: Contains Number Prototypes like limit, round, times, and ceil.
-requires:
-- /Native
-- /$util
-provides: [Number]
-Number.implement({
- limit: function(min, max){
- return Math.min(max, Math.max(min, this));
- round: function(precision){
- precision = Math.pow(10, precision || 0);
- return Math.round(this * precision) / precision;
- times: function(fn, bind){
- for (var i = 0; i < this; i++) fn.call(bind, i, this);
- toFloat: function(){
- return parseFloat(this);
- toInt: function(base){
- return parseInt(this, base || 10);
-Number.alias('times', 'each');
-(function(math){
- var methods = {};
- math.each(function(name){
- if (!Number[name]) methods[name] = function(){
- return Math[name].apply(null, [this].concat($A(arguments)));
- Number.implement(methods);
-})(['abs', 'acos', 'asin', 'atan', 'atan2', 'ceil', 'cos', 'exp', 'floor', 'log', 'max', 'min', 'pow', 'sin', 'sqrt', 'tan']);
-script: String.js
-description: Contains String Prototypes like camelCase, capitalize, test, and toInt.
-requires:
-- /Native
-provides: [String]
-String.implement({
- test: function(regex, params){
- return ((typeof regex == 'string') ? new RegExp(regex, params) : regex).test(this);
- contains: function(string, separator){
- return (separator) ? (separator + this + separator).indexOf(separator + string + separator) > -1 : this.indexOf(string) > -1;
- trim: function(){
- return this.replace(/^\s+|\s+$/g, '');
- return this.replace(/\s+/g, ' ').trim();
- camelCase: function(){
- return this.replace(/-\D/g, function(match){
- return match.charAt(1).toUpperCase();
- hyphenate: function(){
- return this.replace(/[A-Z]/g, function(match){
- return ('-' + match.charAt(0).toLowerCase());
- capitalize: function(){
- return this.replace(/\b[a-z]/g, function(match){
- return match.toUpperCase();
- escapeRegExp: function(){
- return this.replace(/([-.*+?^${}()|[\]\/\\])/g, '\\$1');
- var hex = this.match(/^#?(\w{1,2})(\w{1,2})(\w{1,2})$/);
- return (hex) ? hex.slice(1).hexToRgb(array) : null;
- var rgb = this.match(/\d{1,3}/g);
- return (rgb) ? rgb.rgbToHex(array) : null;
- stripScripts: function(option){
- var scripts = '';
- var text = this.replace(/<script[^>]*>([\s\S]*?)<\/script>/gi, function(){
- scripts += arguments[1] + '\n';
- return '';
- if (option === true) $exec(scripts);
- else if ($type(option) == 'function') option(scripts, text);
- return text;
- substitute: function(object, regexp){
- return this.replace(regexp || (/\\?\{([^{}]+)\}/g), function(match, name){
- if (match.charAt(0) == '\\') return match.slice(1);
- return (object[name] != undefined) ? object[name] : '';
-script: Hash.js
-description: Contains Hash Prototypes. Provides a means for overcoming the JavaScript practical impossibility of extending native Objects.
-requires:
-- /Hash.base
-provides: [Hash]
-Hash.implement({
- has: Object.prototype.hasOwnProperty,
- keyOf: function(value){
- if (this.hasOwnProperty(key) && this[key] === value) return key;
- return null;
- hasValue: function(value){
- return (Hash.keyOf(this, value) !== null);
- Hash.each(properties || {}, function(value, key){
- Hash.set(this, key, value);
- }, this);
- return this;
- combine: function(properties){
- Hash.include(this, key, value);
- }, this);
- return this;
- erase: function(key){
- if (this.hasOwnProperty(key)) delete this[key];
- return this;
- get: function(key){
- return (this.hasOwnProperty(key)) ? this[key] : null;
- set: function(key, value){
- if (!this[key] || this.hasOwnProperty(key)) this[key] = value;
- return this;
- Hash.each(this, function(value, key){
- delete this[key];
- }, this);
- return this;
- include: function(key, value){
- if (this[key] == undefined) this[key] = value;
- return this;
- var results = new Hash;
- results.set(key, fn.call(bind, value, key, this));
- }, this);
- return results;
- if (fn.call(bind, value, key, this)) results.set(key, value);
- }, this);
- return results;
- if (this.hasOwnProperty(key) && !fn.call(bind, this[key], key)) return false;
- return true;
- if (this.hasOwnProperty(key) && fn.call(bind, this[key], key)) return true;
- return false;
- getKeys: function(){
- var keys = [];
- keys.push(key);
- return keys;
- getValues: function(){
- var values = [];
- Hash.each(this, function(value){
- values.push(value);
- return values;
- toQueryString: function(base){
- var queryString = [];
- if (base) key = base + '[' + key + ']';
- var result;
- switch ($type(value)){
- case 'object': result = Hash.toQueryString(value, key); break;
- case 'array':
- var qs = {};
- value.each(function(val, i){
- qs[i] = val;
- result = Hash.toQueryString(qs, key);
- break;
- default: result = key + '=' + encodeURIComponent(value);
- if (value != undefined) queryString.push(result);
- return queryString.join('&');
-Hash.alias({keyOf: 'indexOf', hasValue: 'contains'});
-script: Event.js
-description: Contains the Event Class, to make the event object cross-browser.
-requires:
-- /Window
-- /Document
-- /Hash
-- /Array
-- /Function
-- /String
-provides: [Event]
-var Event = new Native({
- name: 'Event',
- initialize: function(event, win){
- win = win || window;
- var doc = win.document;
- event = event || win.event;
- if (event.$extended) return event;
- this.$extended = true;
- var type = event.type;
- var target = event.target || event.srcElement;
- while (target && target.nodeType == 3) target = target.parentNode;
- if (type.test(/key/)){
- var code = event.which || event.keyCode;
- var key = Event.Keys.keyOf(code);
- if (type == 'keydown'){
- var fKey = code - 111;
- if (fKey > 0 && fKey < 13) key = 'f' + fKey;
- key = key || String.fromCharCode(code).toLowerCase();
- } else if (type.match(/(click|mouse|menu)/i)){
- doc = (!doc.compatMode || doc.compatMode == 'CSS1Compat') ? doc.html : doc.body;
- var page = {
- x: event.pageX || event.clientX + doc.scrollLeft,
- y: event.pageY || event.clientY + doc.scrollTop
- var client = {
- x: (event.pageX) ? event.pageX - win.pageXOffset : event.clientX,
- y: (event.pageY) ? event.pageY - win.pageYOffset : event.clientY
- if (type.match(/DOMMouseScroll|mousewheel/)){
- var wheel = (event.wheelDelta) ? event.wheelDelta / 120 : -(event.detail || 0) / 3;
- var rightClick = (event.which == 3) || (event.button == 2);
- var related = null;
- if (type.match(/over|out/)){
- switch (type){
- case 'mouseover': related = event.relatedTarget || event.fromElement; break;
- case 'mouseout': related = event.relatedTarget || event.toElement;
- if (!(function(){
- while (related && related.nodeType == 3) related = related.parentNode;
- return true;
- }).create({attempt: Browser.Engine.gecko})()) related = false;
- return $extend(this, {
- event: event,
- type: type,
- page: page,
- client: client,
- rightClick: rightClick,
- wheel: wheel,
- relatedTarget: related,
- target: target,
- code: code,
- key: key,
- shift: event.shiftKey,
- control: event.ctrlKey,
- alt: event.altKey,
- meta: event.metaKey
-Event.Keys = new Hash({
- 'enter': 13,
- 'up': 38,
- 'down': 40,
- 'left': 37,
- 'right': 39,
- 'esc': 27,
- 'space': 32,
- 'backspace': 8,
- 'tab': 9,
- 'delete': 46
-Event.implement({
- stop: function(){
- return this.stopPropagation().preventDefault();
- stopPropagation: function(){
- if (this.event.stopPropagation) this.event.stopPropagation();
- else this.event.cancelBubble = true;
- return this;
- preventDefault: function(){
- if (this.event.preventDefault) this.event.preventDefault();
- else this.event.returnValue = false;
- return this;
-script: Class.js
-description: Contains the Class Function for easily creating, extending, and implementing reusable Classes.
-requires:
-- /$util
-- /Native
-- /Array
-- /String
-- /Function
-- /Number
-- /Hash
-provides: [Class]
-function Class(params){
- if (params instanceof Function) params = {initialize: params};
- var newClass = function(){
- Object.reset(this);
- if (newClass._prototyping) return this;
- this._current = $empty;
- var value = (this.initialize) ? this.initialize.apply(this, arguments) : this;
- delete this._current; delete this.caller;
- return value;
- }.extend(this);
- newClass.implement(params);
- newClass.constructor = Class;
- newClass.prototype.constructor = newClass;
- return newClass;
-Function.prototype.protect = function(){
- this._protected = true;
- return this;
-Object.reset = function(object, key){
- if (key == null){
- for (var p in object) Object.reset(object, p);
- return object;
- switch ($type(object[key])){
- case 'object':
- var F = function(){};
- F.prototype = object[key];
- var i = new F;
- object[key] = Object.reset(i);
- break;
- case 'array': object[key] = $unlink(object[key]); break;
- return object;
-new Native({name: 'Class', initialize: Class}).extend({
- instantiate: function(F){
- F._prototyping = true;
- var proto = new F;
- delete F._prototyping;
- return proto;
- wrap: function(self, key, method){
- if (method._origin) method = method._origin;
- if (method._protected && this._current == null) throw new Error('The method "' + key + '" cannot be called.');
- var caller = this.caller, current = this._current;
- this.caller = current; this._current = arguments.callee;
- var result = method.apply(this, arguments);
- this._current = current; this.caller = caller;
- return result;
- }.extend({_owner: self, _origin: method, _name: key});
-Class.implement({
- implement: function(key, value){
- if ($type(key) == 'object'){
- for (var p in key) this.implement(p, key[p]);
- return this;
- var mutator = Class.Mutators[key];
- if (mutator){
- value = mutator.call(this, value);
- if (value == null) return this;
- var proto = this.prototype;
- case 'function':
- if (value._hidden) return this;
- proto[key] = Class.wrap(this, key, value);
- break;
- case 'object':
- var previous = proto[key];
- if ($type(previous) == 'object') $mixin(previous, value);
- else proto[key] = $unlink(value);
- break;
- case 'array':
- proto[key] = $unlink(value);
- break;
- default: proto[key] = value;
- return this;
-Class.Mutators = {
- Extends: function(parent){
- this.parent = parent;
- this.prototype = Class.instantiate(parent);
- this.implement('parent', function(){
- var name = this.caller._name, previous = this.caller._owner.parent.prototype[name];
- if (!previous) throw new Error('The method "' + name + '" has no parent.');
- return previous.apply(this, arguments);
- }.protect());
- Implements: function(items){
- $splat(items).each(function(item){
- if (item instanceof Function) item = Class.instantiate(item);
- this.implement(item);
- }, this);
-script: Class.Extras.js
-description: Contains Utility Classes that can be implemented into your own Classes to ease the execution of many common tasks.
-requires:
-- /Class
-provides: [Chain, Events, Options]
-var Chain = new Class({
- $chain: [],
- chain: function(){
- this.$chain.extend(Array.flatten(arguments));
- return this;
- callChain: function(){
- return (this.$chain.length) ? this.$chain.shift().apply(this, arguments) : false;
- clearChain: function(){
- this.$chain.empty();
- return this;
-var Events = new Class({
- $events: {},
- addEvent: function(type, fn, internal){
- type = Events.removeOn(type);
- if (fn != $empty){
- this.$events[type] = this.$events[type] || [];
- this.$events[type].include(fn);
- if (internal) fn.internal = true;
- return this;
- addEvents: function(events){
- for (var type in events) this.addEvent(type, events[type]);
- return this;
- fireEvent: function(type, args, delay){
- if (!this.$events || !this.$events[type]) return this;
- this.$events[type].each(function(fn){
- fn.create({'bind': this, 'delay': delay, 'arguments': args})();
- }, this);
- return this;
- removeEvent: function(type, fn){
- if (!this.$events[type]) return this;
- if (!fn.internal) this.$events[type].erase(fn);
- return this;
- removeEvents: function(events){
- var type;
- if ($type(events) == 'object'){
- for (type in events) this.removeEvent(type, events[type]);
- return this;
- if (events) events = Events.removeOn(events);
- for (type in this.$events){
- if (events && events != type) continue;
- var fns = this.$events[type];
- for (var i = fns.length; i--; i) this.removeEvent(type, fns[i]);
- return this;
-Events.removeOn = function(string){
- return string.replace(/^on([A-Z])/, function(full, first){
- return first.toLowerCase();
-var Options = new Class({
- setOptions: function(){
- this.options = $merge.run([this.options].extend(arguments));
- if (!this.addEvent) return this;
- for (var option in this.options){
- if ($type(this.options[option]) != 'function' || !(/^on[A-Z]/).test(option)) continue;
- this.addEvent(option, this.options[option]);
- delete this.options[option];
- return this;
-script: Element.js
-description: One of the most important items in MooTools. Contains the dollar function, the dollars function, and an handful of cross-browser, time-saver methods to let you easily work with HTML Elements.
-requires:
-- /Window
-- /Document
-- /Array
-- /String
-- /Function
-- /Number
-- /Hash
-provides: [Element, Elements, $, $$, Iframe]
-var Element = new Native({
- name: 'Element',
- legacy: window.Element,
- initialize: function(tag, props){
- var konstructor = Element.Constructors.get(tag);
- if (konstructor) return konstructor(props);
- if (typeof tag == 'string') return document.newElement(tag, props);
- return document.id(tag).set(props);
- afterImplement: function(key, value){
- Element.Prototype[key] = value;
- if (Array[key]) return;
- Elements.implement(key, function(){
- var items = [], elements = true;
- for (var i = 0, j = this.length; i < j; i++){
- var returns = this[i][key].apply(this[i], arguments);
- items.push(returns);
- if (elements) elements = ($type(returns) == 'element');
- return (elements) ? new Elements(items) : items;
-Element.Prototype = {$family: {name: 'element'}};
-Element.Constructors = new Hash;
-var IFrame = new Native({
- name: 'IFrame',
- generics: false,
- initialize: function(){
- var params = Array.link(arguments, {properties: Object.type, iframe: $defined});
- var props = params.properties || {};
- var iframe = document.id(params.iframe);
- var onload = props.onload || $empty;
- delete props.onload;
- props.id = props.name = $pick(props.id, props.name, iframe ? (iframe.id || iframe.name) : 'IFrame_' + $time());
- iframe = new Element(iframe || 'iframe', props);
- var onFrameLoad = function(){
- var host = $try(function(){
- return iframe.contentWindow.location.host;
- if (!host || host == window.location.host){
- var win = new Window(iframe.contentWindow);
- new Document(iframe.contentWindow.document);
- $extend(win.Element.prototype, Element.Prototype);
- onload.call(iframe.contentWindow, iframe.contentWindow.document);
- var contentWindow = $try(function(){
- return iframe.contentWindow;
- ((contentWindow && contentWindow.document.body) || window.frames[props.id]) ? onFrameLoad() : iframe.addListener('load', onFrameLoad);
- return iframe;
-var Elements = new Native({
- initialize: function(elements, options){
- options = $extend({ddup: true, cash: true}, options);
- elements = elements || [];
- if (options.ddup || options.cash){
- var uniques = {}, returned = [];
- for (var i = 0, l = elements.length; i < l; i++){
- var el = document.id(elements[i], !options.cash);
- if (options.ddup){
- if (uniques[el.uid]) continue;
- uniques[el.uid] = true;
- if (el) returned.push(el);
- elements = returned;
- return (options.cash) ? $extend(elements, this) : elements;
-Elements.implement({
- filter: function(filter, bind){
- if (!filter) return this;
- return new Elements(Array.filter(this, (typeof filter == 'string') ? function(item){
- return item.match(filter);
- } : filter, bind));
-Document.implement({
- newElement: function(tag, props){
- if (Browser.Engine.trident && props){
- ['name', 'type', 'checked'].each(function(attribute){
- if (!props[attribute]) return;
- tag += ' ' + attribute + '="' + props[attribute] + '"';
- if (attribute != 'checked') delete props[attribute];
- tag = '<' + tag + '>';
- return document.id(this.createElement(tag)).set(props);
- newTextNode: function(text){
- return this.createTextNode(text);
- getDocument: function(){
- return this;
- getWindow: function(){
- return this.window;
- id: (function(){
- var types = {
- string: function(id, nocash, doc){
- id = doc.getElementById(id);
- return (id) ? types.element(id, nocash) : null;
- element: function(el, nocash){
- $uid(el);
- if (!nocash && !el.$family && !(/^object|embed$/i).test(el.tagName)){
- var proto = Element.Prototype;
- for (var p in proto) el[p] = proto[p];
- return el;
- object: function(obj, nocash, doc){
- if (obj.toElement) return types.element(obj.toElement(doc), nocash);
- return null;
- types.textnode = types.whitespace = types.window = types.document = $arguments(0);
- return function(el, nocash, doc){
- if (el && el.$family && el.uid) return el;
- var type = $type(el);
- return (types[type]) ? types[type](el, nocash, doc || document) : null;
-if (window.$ == null) Window.implement({
- $: function(el, nc){
- return document.id(el, nc, this.document);
-Window.implement({
- $$: function(selector){
- if (arguments.length == 1 && typeof selector == 'string') return this.document.getElements(selector);
- var elements = [];
- var args = Array.flatten(arguments);
- for (var i = 0, l = args.length; i < l; i++){
- var item = args[i];
- switch ($type(item)){
- case 'element': elements.push(item); break;
- case 'string': elements.extend(this.document.getElements(item, true));
- return new Elements(elements);
- return this.document;
- return this;
-Native.implement([Element, Document], {
- getElement: function(selector, nocash){
- return document.id(this.getElements(selector, true)[0] || null, nocash);
- getElements: function(tags, nocash){
- tags = tags.split(',');
- var ddup = (tags.length > 1);
- tags.each(function(tag){
- var partial = this.getElementsByTagName(tag.trim());
- (ddup) ? elements.extend(partial) : elements = partial;
- }, this);
- return new Elements(elements, {ddup: ddup, cash: !nocash});
-(function(){
-var collected = {}, storage = {};
-var props = {input: 'checked', option: 'selected', textarea: (Browser.Engine.webkit && Browser.Engine.version < 420) ? 'innerHTML' : 'value'};
-var get = function(uid){
- return (storage[uid] || (storage[uid] = {}));
-var clean = function(item, retain){
- if (!item) return;
- var uid = item.uid;
- if (retain !== true) retain = false;
- if (Browser.Engine.trident){
- if (item.clearAttributes){
- var clone = retain && item.cloneNode(false);
- item.clearAttributes();
- if (clone) item.mergeAttributes(clone);
- } else if (item.removeEvents){
- item.removeEvents();
- if ((/object/i).test(item.tagName)){
- for (var p in item){
- if (typeof item[p] == 'function') item[p] = $empty;
- Element.dispose(item);
- if (!uid) return;
- collected[uid] = storage[uid] = null;
-var purge = function(){
- Hash.each(collected, clean);
- if (Browser.Engine.trident) $A(document.getElementsByTagName('object')).each(clean);
- if (window.CollectGarbage) CollectGarbage();
- collected = storage = null;
-var walk = function(element, walk, start, match, all, nocash){
- var el = element[start || walk];
- while (el){
- if (el.nodeType == 1 && (!match || Element.match(el, match))){
- if (!all) return document.id(el, nocash);
- elements.push(el);
- el = el[walk];
- return (all) ? new Elements(elements, {ddup: false, cash: !nocash}) : null;
-var attributes = {
- 'html': 'innerHTML',
- 'class': 'className',
- 'for': 'htmlFor',
- 'defaultValue': 'defaultValue',
- 'text': (Browser.Engine.trident || (Browser.Engine.webkit && Browser.Engine.version < 420)) ? 'innerText' : 'textContent'
-var bools = ['compact', 'nowrap', 'ismap', 'declare', 'noshade', 'checked', 'disabled', 'readonly', 'multiple', 'selected', 'noresize', 'defer'];
-var camels = ['value', 'type', 'defaultValue', 'accessKey', 'cellPadding', 'cellSpacing', 'colSpan', 'frameBorder', 'maxLength', 'readOnly', 'rowSpan', 'tabIndex', 'useMap'];
-bools = bools.associate(bools);
-Hash.extend(attributes, bools);
-Hash.extend(attributes, camels.associate(camels.map(String.toLowerCase)));
-var inserters = {
- before: function(context, element){
- if (element.parentNode) element.parentNode.insertBefore(context, element);
- after: function(context, element){
- if (!element.parentNode) return;
- var next = element.nextSibling;
- (next) ? element.parentNode.insertBefore(context, next) : element.parentNode.appendChild(context);
- bottom: function(context, element){
- element.appendChild(context);
- top: function(context, element){
- var first = element.firstChild;
- (first) ? element.insertBefore(context, first) : element.appendChild(context);
-inserters.inside = inserters.bottom;
-Hash.each(inserters, function(inserter, where){
- where = where.capitalize();
- Element.implement('inject' + where, function(el){
- inserter(this, document.id(el, true));
- return this;
- Element.implement('grab' + where, function(el){
- inserter(document.id(el, true), this);
- return this;
-Element.implement({
- set: function(prop, value){
- switch ($type(prop)){
- case 'object':
- for (var p in prop) this.set(p, prop[p]);
- break;
- case 'string':
- var property = Element.Properties.get(prop);
- (property && property.set) ? property.set.apply(this, Array.slice(arguments, 1)) : this.setProperty(prop, value);
- return this;
- get: function(prop){
- return (property && property.get) ? property.get.apply(this, Array.slice(arguments, 1)) : this.getProperty(prop);
- erase: function(prop){
- (property && property.erase) ? property.erase.apply(this) : this.removeProperty(prop);
- return this;
- setProperty: function(attribute, value){
- var key = attributes[attribute];
- if (value == undefined) return this.removeProperty(attribute);
- if (key && bools[attribute]) value = !!value;
- (key) ? this[key] = value : this.setAttribute(attribute, '' + value);
- return this;
- setProperties: function(attributes){
- for (var attribute in attributes) this.setProperty(attribute, attributes[attribute]);
- return this;
- getProperty: function(attribute){
- var value = (key) ? this[key] : this.getAttribute(attribute, 2);
- return (bools[attribute]) ? !!value : (key) ? value : value || null;
- getProperties: function(){
- var args = $A(arguments);
- return args.map(this.getProperty, this).associate(args);
- removeProperty: function(attribute){
- (key) ? this[key] = (key && bools[attribute]) ? false : '' : this.removeAttribute(attribute);
- return this;
- removeProperties: function(){
- Array.each(arguments, this.removeProperty, this);
- return this;
- hasClass: function(className){
- return this.className.contains(className, ' ');
- addClass: function(className){
- if (!this.hasClass(className)) this.className = (this.className + ' ' + className).clean();
- return this;
- removeClass: function(className){
- this.className = this.className.replace(new RegExp('(^|\\s)' + className + '(?:\\s|$)'), '$1');
- return this;
- toggleClass: function(className){
- return this.hasClass(className) ? this.removeClass(className) : this.addClass(className);
- adopt: function(){
- Array.flatten(arguments).each(function(element){
- element = document.id(element, true);
- if (element) this.appendChild(element);
- }, this);
- return this;
- appendText: function(text, where){
- return this.grab(this.getDocument().newTextNode(text), where);
- grab: function(el, where){
- inserters[where || 'bottom'](document.id(el, true), this);
- return this;
- inject: function(el, where){
- inserters[where || 'bottom'](this, document.id(el, true));
- return this;
- replaces: function(el){
- el = document.id(el, true);
- el.parentNode.replaceChild(this, el);
- return this;
- wraps: function(el, where){
- return this.replaces(el).grab(el, where);
- getPrevious: function(match, nocash){
- return walk(this, 'previousSibling', null, match, false, nocash);
- getAllPrevious: function(match, nocash){
- return walk(this, 'previousSibling', null, match, true, nocash);
- getNext: function(match, nocash){
- return walk(this, 'nextSibling', null, match, false, nocash);
- getAllNext: function(match, nocash){
- return walk(this, 'nextSibling', null, match, true, nocash);
- getFirst: function(match, nocash){
- return walk(this, 'nextSibling', 'firstChild', match, false, nocash);
- getLast: function(match, nocash){
- return walk(this, 'previousSibling', 'lastChild', match, false, nocash);
- getParent: function(match, nocash){
- return walk(this, 'parentNode', null, match, false, nocash);
- getParents: function(match, nocash){
- return walk(this, 'parentNode', null, match, true, nocash);
- getSiblings: function(match, nocash){
- return this.getParent().getChildren(match, nocash).erase(this);
- getChildren: function(match, nocash){
- return walk(this, 'nextSibling', 'firstChild', match, true, nocash);
- return this.ownerDocument.window;
- return this.ownerDocument;
- getElementById: function(id, nocash){
- var el = this.ownerDocument.getElementById(id);
- if (!el) return null;
- for (var parent = el.parentNode; parent != this; parent = parent.parentNode){
- if (!parent) return null;
- return document.id(el, nocash);
- getSelected: function(){
- return new Elements($A(this.options).filter(function(option){
- return option.selected;
- getComputedStyle: function(property){
- if (this.currentStyle) return this.currentStyle[property.camelCase()];
- var computed = this.getDocument().defaultView.getComputedStyle(this, null);
- return (computed) ? computed.getPropertyValue([property.hyphenate()]) : null;
- toQueryString: function(){
- this.getElements('input, select, textarea', true).each(function(el){
- if (!el.name || el.disabled || el.type == 'submit' || el.type == 'reset' || el.type == 'file') return;
- var value = (el.tagName.toLowerCase() == 'select') ? Element.getSelected(el).map(function(opt){
- return opt.value;
- }) : ((el.type == 'radio' || el.type == 'checkbox') && !el.checked) ? null : el.value;
- $splat(value).each(function(val){
- if (typeof val != 'undefined') queryString.push(el.name + '=' + encodeURIComponent(val));
- clone: function(contents, keepid){
- contents = contents !== false;
- var clone = this.cloneNode(contents);
- var clean = function(node, element){
- if (!keepid) node.removeAttribute('id');
- node.clearAttributes();
- node.mergeAttributes(element);
- node.removeAttribute('uid');
- if (node.options){
- var no = node.options, eo = element.options;
- for (var j = no.length; j--;) no[j].selected = eo[j].selected;
- var prop = props[element.tagName.toLowerCase()];
- if (prop && element[prop]) node[prop] = element[prop];
- if (contents){
- var ce = clone.getElementsByTagName('*'), te = this.getElementsByTagName('*');
- for (var i = ce.length; i--;) clean(ce[i], te[i]);
- clean(clone, this);
- return document.id(clone);
- destroy: function(){
- Element.empty(this);
- Element.dispose(this);
- clean(this, true);
- return null;
- $A(this.childNodes).each(function(node){
- Element.destroy(node);
- return this;
- dispose: function(){
- return (this.parentNode) ? this.parentNode.removeChild(this) : this;
- hasChild: function(el){
- if (!el) return false;
- if (Browser.Engine.webkit && Browser.Engine.version < 420) return $A(this.getElementsByTagName(el.tagName)).contains(el);
- return (this.contains) ? (this != el && this.contains(el)) : !!(this.compareDocumentPosition(el) & 16);
- match: function(tag){
- return (!tag || (tag == this) || (Element.get(this, 'tag') == tag));
-Native.implement([Element, Window, Document], {
- addListener: function(type, fn){
- if (type == 'unload'){
- var old = fn, self = this;
- fn = function(){
- self.removeListener('unload', fn);
- old();
- } else {
- collected[this.uid] = this;
- if (this.addEventListener) this.addEventListener(type, fn, false);
- else this.attachEvent('on' + type, fn);
- return this;
- removeListener: function(type, fn){
- if (this.removeEventListener) this.removeEventListener(type, fn, false);
- else this.detachEvent('on' + type, fn);
- return this;
- retrieve: function(property, dflt){
- var storage = get(this.uid), prop = storage[property];
- if (dflt != undefined && prop == undefined) prop = storage[property] = dflt;
- return $pick(prop);
- store: function(property, value){
- var storage = get(this.uid);
- storage[property] = value;
- return this;
- eliminate: function(property){
- delete storage[property];
- return this;
-window.addListener('unload', purge);
-Element.Properties = new Hash;
-Element.Properties.style = {
- set: function(style){
- this.style.cssText = style;
- get: function(){
- return this.style.cssText;
- erase: function(){
- this.style.cssText = '';
-Element.Properties.tag = {
- get: function(){
- return this.tagName.toLowerCase();
-Element.Properties.html = (function(){
- var wrapper = document.createElement('div');
- var translations = {
- table: [1, '<table>', '</table>'],
- select: [1, '<select>', '</select>'],
- tbody: [2, '<table><tbody>', '</tbody></table>'],
- tr: [3, '<table><tbody><tr>', '</tr></tbody></table>']
- translations.thead = translations.tfoot = translations.tbody;
- var html = {
- set: function(){
- var html = Array.flatten(arguments).join('');
- var wrap = Browser.Engine.trident && translations[this.get('tag')];
- if (wrap){
- var first = wrapper;
- first.innerHTML = wrap[1] + html + wrap[2];
- for (var i = wrap[0]; i--;) first = first.firstChild;
- this.empty().adopt(first.childNodes);
- } else {
- this.innerHTML = html;
- html.erase = html.set;
- return html;
-if (Browser.Engine.webkit && Browser.Engine.version < 420) Element.Properties.text = {
- get: function(){
- if (this.innerText) return this.innerText;
- var temp = this.ownerDocument.newElement('div', {html: this.innerHTML}).inject(this.ownerDocument.body);
- var text = temp.innerText;
- temp.destroy();
- return text;
-script: Element.Event.js
-description: Contains Element methods for dealing with events. This file also includes mouseenter and mouseleave custom Element Events.
-requires:
-- /Element
-- /Event
-provides: [Element.Event]
-Element.Properties.events = {set: function(events){
- this.addEvents(events);
- addEvent: function(type, fn){
- var events = this.retrieve('events', {});
- events[type] = events[type] || {'keys': [], 'values': []};
- if (events[type].keys.contains(fn)) return this;
- events[type].keys.push(fn);
- var realType = type, custom = Element.Events.get(type), condition = fn, self = this;
- if (custom){
- if (custom.onAdd) custom.onAdd.call(this, fn);
- if (custom.condition){
- condition = function(event){
- if (custom.condition.call(this, event)) return fn.call(this, event);
- return true;
- realType = custom.base || realType;
- var defn = function(){
- return fn.call(self);
- var nativeEvent = Element.NativeEvents[realType];
- if (nativeEvent){
- if (nativeEvent == 2){
- defn = function(event){
- event = new Event(event, self.getWindow());
- if (condition.call(self, event) === false) event.stop();
- this.addListener(realType, defn);
- events[type].values.push(defn);
- return this;
- var events = this.retrieve('events');
- if (!events || !events[type]) return this;
- var pos = events[type].keys.indexOf(fn);
- if (pos == -1) return this;
- events[type].keys.splice(pos, 1);
- var value = events[type].values.splice(pos, 1)[0];
- var custom = Element.Events.get(type);
- if (custom){
- if (custom.onRemove) custom.onRemove.call(this, fn);
- type = custom.base || type;
- return (Element.NativeEvents[type]) ? this.removeListener(type, value) : this;
- for (var event in events) this.addEvent(event, events[event]);
- return this;
- var type;
- return this;
- var attached = this.retrieve('events');
- if (!attached) return this;
- if (!events){
- for (type in attached) this.removeEvents(type);
- this.eliminate('events');
- } else if (attached[events]){
- while (attached[events].keys[0]) this.removeEvent(events, attached[events].keys[0]);
- attached[events] = null;
- return this;
- events[type].keys.each(function(fn){
- }, this);
- return this;
- cloneEvents: function(from, type){
- from = document.id(from);
- var fevents = from.retrieve('events');
- if (!fevents) return this;
- if (!type){
- for (var evType in fevents) this.cloneEvents(from, evType);
- } else if (fevents[type]){
- fevents[type].keys.each(function(fn){
- this.addEvent(type, fn);
- }, this);
- return this;
-Element.NativeEvents = {
- click: 2, dblclick: 2, mouseup: 2, mousedown: 2, contextmenu: 2, //mouse buttons
- mousewheel: 2, DOMMouseScroll: 2, //mouse wheel
- mouseover: 2, mouseout: 2, mousemove: 2, selectstart: 2, selectend: 2, //mouse movement
- keydown: 2, keypress: 2, keyup: 2, //keyboard
- focus: 2, blur: 2, change: 2, reset: 2, select: 2, submit: 2, //form elements
- load: 1, unload: 1, beforeunload: 2, resize: 1, move: 1, DOMContentLoaded: 1, readystatechange: 1, //window
- error: 1, abort: 1, scroll: 1 //misc
-(function(){
-var $check = function(event){
- var related = event.relatedTarget;
- if (related == undefined) return true;
- if (related === false) return false;
- return ($type(this) != 'document' && related != this && related.prefix != 'xul' && !this.hasChild(related));
-Element.Events = new Hash({
- mouseenter: {
- base: 'mouseover',
- condition: $check
- mouseleave: {
- base: 'mouseout',
- condition: $check
- mousewheel: {
- base: (Browser.Engine.gecko) ? 'DOMMouseScroll' : 'mousewheel'
-script: Element.Style.js
-description: Contains methods for interacting with the styles of Elements in a fashionable way.
-requires:
-- /Element
-provides: [Element.Style]
-Element.Properties.styles = {set: function(styles){
- this.setStyles(styles);
-Element.Properties.opacity = {
- set: function(opacity, novisibility){
- if (!novisibility){
- if (opacity == 0){
- if (this.style.visibility != 'hidden') this.style.visibility = 'hidden';
- } else {
- if (this.style.visibility != 'visible') this.style.visibility = 'visible';
- if (!this.currentStyle || !this.currentStyle.hasLayout) this.style.zoom = 1;
- if (Browser.Engine.trident) this.style.filter = (opacity == 1) ? '' : 'alpha(opacity=' + opacity * 100 + ')';
- this.style.opacity = opacity;
- this.store('opacity', opacity);
- get: function(){
- return this.retrieve('opacity', 1);
- setOpacity: function(value){
- return this.set('opacity', value, true);
- getOpacity: function(){
- return this.get('opacity');
- setStyle: function(property, value){
- switch (property){
- case 'opacity': return this.set('opacity', parseFloat(value));
- case 'float': property = (Browser.Engine.trident) ? 'styleFloat' : 'cssFloat';
- property = property.camelCase();
- if ($type(value) != 'string'){
- var map = (Element.Styles.get(property) || '@').split(' ');
- value = $splat(value).map(function(val, i){
- if (!map[i]) return '';
- return ($type(val) == 'number') ? map[i].replace('@', Math.round(val)) : val;
- }).join(' ');
- } else if (value == String(Number(value))){
- value = Math.round(value);
- this.style[property] = value;
- return this;
- getStyle: function(property){
- case 'opacity': return this.get('opacity');
- var result = this.style[property];
- if (!$chk(result)){
- result = [];
- for (var style in Element.ShortStyles){
- if (property != style) continue;
- for (var s in Element.ShortStyles[style]) result.push(this.getStyle(s));
- return result.join(' ');
- result = this.getComputedStyle(property);
- if (result){
- result = String(result);
- var color = result.match(/rgba?\([\d\s,]+\)/);
- if (color) result = result.replace(color[0], color[0].rgbToHex());
- if (Browser.Engine.presto || (Browser.Engine.trident && !$chk(parseInt(result, 10)))){
- if (property.test(/^(height|width)$/)){
- var values = (property == 'width') ? ['left', 'right'] : ['top', 'bottom'], size = 0;
- values.each(function(value){
- size += this.getStyle('border-' + value + '-width').toInt() + this.getStyle('padding-' + value).toInt();
- }, this);
- return this['offset' + property.capitalize()] - size + 'px';
- if ((Browser.Engine.presto) && String(result).test('px')) return result;
- if (property.test(/(border(.+)Width|margin|padding)/)) return '0px';
- return result;
- setStyles: function(styles){
- for (var style in styles) this.setStyle(style, styles[style]);
- return this;
- getStyles: function(){
- var result = {};
- Array.flatten(arguments).each(function(key){
- result[key] = this.getStyle(key);
- }, this);
- return result;
-Element.Styles = new Hash({
- left: '@px', top: '@px', bottom: '@px', right: '@px',
- width: '@px', height: '@px', maxWidth: '@px', maxHeight: '@px', minWidth: '@px', minHeight: '@px',
- backgroundColor: 'rgb(@, @, @)', backgroundPosition: '@px @px', color: 'rgb(@, @, @)',
- fontSize: '@px', letterSpacing: '@px', lineHeight: '@px', clip: 'rect(@px @px @px @px)',
- margin: '@px @px @px @px', padding: '@px @px @px @px', border: '@px @ rgb(@, @, @) @px @ rgb(@, @, @) @px @ rgb(@, @, @)',
- borderWidth: '@px @px @px @px', borderStyle: '@ @ @ @', borderColor: 'rgb(@, @, @) rgb(@, @, @) rgb(@, @, @) rgb(@, @, @)',
- zIndex: '@', 'zoom': '@', fontWeight: '@', textIndent: '@px', opacity: '@'
-Element.ShortStyles = {margin: {}, padding: {}, border: {}, borderWidth: {}, borderStyle: {}, borderColor: {}};
-['Top', 'Right', 'Bottom', 'Left'].each(function(direction){
- var Short = Element.ShortStyles;
- var All = Element.Styles;
- ['margin', 'padding'].each(function(style){
- var sd = style + direction;
- Short[style][sd] = All[sd] = '@px';
- var bd = 'border' + direction;
- Short.border[bd] = All[bd] = '@px @ rgb(@, @, @)';
- var bdw = bd + 'Width', bds = bd + 'Style', bdc = bd + 'Color';
- Short[bd] = {};
- Short.borderWidth[bdw] = Short[bd][bdw] = All[bdw] = '@px';
- Short.borderStyle[bds] = Short[bd][bds] = All[bds] = '@';
- Short.borderColor[bdc] = Short[bd][bdc] = All[bdc] = 'rgb(@, @, @)';
-script: Element.Dimensions.js
-description: Contains methods to work with size, scroll, or positioning of Elements and the window object.
-credits:
-- Element positioning based on the [qooxdoo](http://qooxdoo.org/) code and smart browser fixes, [LGPL License](http://www.gnu.org/licenses/lgpl.html).
-- Viewport dimensions based on [YUI](http://developer.yahoo.com/yui/) code, [BSD License](http://developer.yahoo.com/yui/license.html).
-requires:
-- /Element
-provides: [Element.Dimensions]
-(function(){
- scrollTo: function(x, y){
- if (isBody(this)){
- this.getWindow().scrollTo(x, y);
- } else {
- this.scrollLeft = x;
- this.scrollTop = y;
- return this;
- getSize: function(){
- if (isBody(this)) return this.getWindow().getSize();
- return {x: this.offsetWidth, y: this.offsetHeight};
- getScrollSize: function(){
- if (isBody(this)) return this.getWindow().getScrollSize();
- return {x: this.scrollWidth, y: this.scrollHeight};
- getScroll: function(){
- if (isBody(this)) return this.getWindow().getScroll();
- return {x: this.scrollLeft, y: this.scrollTop};
- getScrolls: function(){
- var element = this, position = {x: 0, y: 0};
- while (element && !isBody(element)){
- position.x += element.scrollLeft;
- position.y += element.scrollTop;
- element = element.parentNode;
- return position;
- getOffsetParent: function(){
- var element = this;
- if (isBody(element)) return null;
- if (!Browser.Engine.trident) return element.offsetParent;
- while ((element = element.parentNode) && !isBody(element)){
- if (styleString(element, 'position') != 'static') return element;
- return null;
- getOffsets: function(){
- if (this.getBoundingClientRect){
- var bound = this.getBoundingClientRect(),
- html = document.id(this.getDocument().documentElement),
- htmlScroll = html.getScroll(),
- elemScrolls = this.getScrolls(),
- elemScroll = this.getScroll(),
- isFixed = (styleString(this, 'position') == 'fixed');
- return {
- x: bound.left.toInt() + elemScrolls.x - elemScroll.x + ((isFixed) ? 0 : htmlScroll.x) - html.clientLeft,
- y: bound.top.toInt() + elemScrolls.y - elemScroll.y + ((isFixed) ? 0 : htmlScroll.y) - html.clientTop
- if (isBody(this)) return position;
- position.x += element.offsetLeft;
- position.y += element.offsetTop;
- if (Browser.Engine.gecko){
- if (!borderBox(element)){
- position.x += leftBorder(element);
- position.y += topBorder(element);
- var parent = element.parentNode;
- if (parent && styleString(parent, 'overflow') != 'visible'){
- position.x += leftBorder(parent);
- position.y += topBorder(parent);
- } else if (element != this && Browser.Engine.webkit){
- element = element.offsetParent;
- if (Browser.Engine.gecko && !borderBox(this)){
- position.x -= leftBorder(this);
- position.y -= topBorder(this);
- return position;
- getPosition: function(relative){
- if (isBody(this)) return {x: 0, y: 0};
- var offset = this.getOffsets(),
- scroll = this.getScrolls();
- var position = {
- x: offset.x - scroll.x,
- y: offset.y - scroll.y
- var relativePosition = (relative && (relative = document.id(relative))) ? relative.getPosition() : {x: 0, y: 0};
- return {x: position.x - relativePosition.x, y: position.y - relativePosition.y};
- getCoordinates: function(element){
- if (isBody(this)) return this.getWindow().getCoordinates();
- var position = this.getPosition(element),
- size = this.getSize();
- var obj = {
- left: position.x,
- top: position.y,
- width: size.x,
- height: size.y
- obj.right = obj.left + obj.width;
- obj.bottom = obj.top + obj.height;
- return obj;
- computePosition: function(obj){
- return {
- left: obj.x - styleNumber(this, 'margin-left'),
- top: obj.y - styleNumber(this, 'margin-top')
- setPosition: function(obj){
- return this.setStyles(this.computePosition(obj));
-Native.implement([Document, Window], {
- if (Browser.Engine.presto || Browser.Engine.webkit){
- var win = this.getWindow();
- return {x: win.innerWidth, y: win.innerHeight};
- var doc = getCompatElement(this);
- return {x: doc.clientWidth, y: doc.clientHeight};
- var win = this.getWindow(), doc = getCompatElement(this);
- return {x: win.pageXOffset || doc.scrollLeft, y: win.pageYOffset || doc.scrollTop};
- var doc = getCompatElement(this), min = this.getSize();
- return {x: Math.max(doc.scrollWidth, min.x), y: Math.max(doc.scrollHeight, min.y)};
- getPosition: function(){
- return {x: 0, y: 0};
- getCoordinates: function(){
- var size = this.getSize();
- return {top: 0, left: 0, bottom: size.y, right: size.x, height: size.y, width: size.x};
-// private methods
-var styleString = Element.getComputedStyle;
-function styleNumber(element, style){
- return styleString(element, style).toInt() || 0;
-function borderBox(element){
- return styleString(element, '-moz-box-sizing') == 'border-box';
-function topBorder(element){
- return styleNumber(element, 'border-top-width');
-function leftBorder(element){
- return styleNumber(element, 'border-left-width');
-function isBody(element){
- return (/^(?:body|html)$/i).test(element.tagName);
-function getCompatElement(element){
- var doc = element.getDocument();
- return (!doc.compatMode || doc.compatMode == 'CSS1Compat') ? doc.html : doc.body;
-//aliases
-Element.alias('setPosition', 'position'); //compatability
-Native.implement([Window, Document, Element], {
- getHeight: function(){
- return this.getSize().y;
- getWidth: function(){
- return this.getSize().x;
- getScrollTop: function(){
- return this.getScroll().y;
- getScrollLeft: function(){
- return this.getScroll().x;
- getScrollHeight: function(){
- return this.getScrollSize().y;
- getScrollWidth: function(){
- return this.getScrollSize().x;
- getTop: function(){
- return this.getPosition().y;
- getLeft: function(){
- return this.getPosition().x;
-script: Selectors.js
-description: Adds advanced CSS-style querying capabilities for targeting HTML Elements. Includes pseudo selectors.
-requires:
-- /Element
-provides: [Selectors]
-Native.implement([Document, Element], {
- getElements: function(expression, nocash){
- expression = expression.split(',');
- var items, local = {};
- for (var i = 0, l = expression.length; i < l; i++){
- var selector = expression[i], elements = Selectors.Utils.search(this, selector, local);
- if (i != 0 && elements.item) elements = $A(elements);
- items = (i == 0) ? elements : (items.item) ? $A(items).concat(elements) : items.concat(elements);
- return new Elements(items, {ddup: (expression.length > 1), cash: !nocash});
- match: function(selector){
- if (!selector || (selector == this)) return true;
- var tagid = Selectors.Utils.parseTagAndID(selector);
- var tag = tagid[0], id = tagid[1];
- if (!Selectors.Filters.byID(this, id) || !Selectors.Filters.byTag(this, tag)) return false;
- var parsed = Selectors.Utils.parseSelector(selector);
- return (parsed) ? Selectors.Utils.filter(this, parsed, {}) : true;
-var Selectors = {Cache: {nth: {}, parsed: {}}};
-Selectors.RegExps = {
- id: (/#([\w-]+)/),
- tag: (/^(\w+|\*)/),
- quick: (/^(\w+|\*)$/),
- splitter: (/\s*([+>~\s])\s*([a-zA-Z#.*:\[])/g),
- combined: (/\.([\w-]+)|\[(\w+)(?:([!*^$~|]?=)(["']?)([^\4]*?)\4)?\]|:([\w-]+)(?:\(["']?(.*?)?["']?\)|$)/g)
-Selectors.Utils = {
- chk: function(item, uniques){
- if (!uniques) return true;
- var uid = $uid(item);
- if (!uniques[uid]) return uniques[uid] = true;
- return false;
- parseNthArgument: function(argument){
- if (Selectors.Cache.nth[argument]) return Selectors.Cache.nth[argument];
- var parsed = argument.match(/^([+-]?\d*)?([a-z]+)?([+-]?\d*)?$/);
- if (!parsed) return false;
- var inta = parseInt(parsed[1], 10);
- var a = (inta || inta === 0) ? inta : 1;
- var special = parsed[2] || false;
- var b = parseInt(parsed[3], 10) || 0;
- if (a != 0){
- b--;
- while (b < 1) b += a;
- while (b >= a) b -= a;
- } else {
- a = b;
- special = 'index';
- switch (special){
- case 'n': parsed = {a: a, b: b, special: 'n'}; break;
- case 'odd': parsed = {a: 2, b: 0, special: 'n'}; break;
- case 'even': parsed = {a: 2, b: 1, special: 'n'}; break;
- case 'first': parsed = {a: 0, special: 'index'}; break;
- case 'last': parsed = {special: 'last-child'}; break;
- case 'only': parsed = {special: 'only-child'}; break;
- default: parsed = {a: (a - 1), special: 'index'};
- return Selectors.Cache.nth[argument] = parsed;
- parseSelector: function(selector){
- if (Selectors.Cache.parsed[selector]) return Selectors.Cache.parsed[selector];
- var m, parsed = {classes: [], pseudos: [], attributes: []};
- while ((m = Selectors.RegExps.combined.exec(selector))){
- var cn = m[1], an = m[2], ao = m[3], av = m[5], pn = m[6], pa = m[7];
- if (cn){
- parsed.classes.push(cn);
- } else if (pn){
- var parser = Selectors.Pseudo.get(pn);
- if (parser) parsed.pseudos.push({parser: parser, argument: pa});
- else parsed.attributes.push({name: pn, operator: '=', value: pa});
- } else if (an){
- parsed.attributes.push({name: an, operator: ao, value: av});
- if (!parsed.classes.length) delete parsed.classes;
- if (!parsed.attributes.length) delete parsed.attributes;
- if (!parsed.pseudos.length) delete parsed.pseudos;
- if (!parsed.classes && !parsed.attributes && !parsed.pseudos) parsed = null;
- return Selectors.Cache.parsed[selector] = parsed;
- parseTagAndID: function(selector){
- var tag = selector.match(Selectors.RegExps.tag);
- var id = selector.match(Selectors.RegExps.id);
- return [(tag) ? tag[1] : '*', (id) ? id[1] : false];
- filter: function(item, parsed, local){
- var i;
- if (parsed.classes){
- for (i = parsed.classes.length; i--; i){
- var cn = parsed.classes[i];
- if (!Selectors.Filters.byClass(item, cn)) return false;
- if (parsed.attributes){
- for (i = parsed.attributes.length; i--; i){
- var att = parsed.attributes[i];
- if (!Selectors.Filters.byAttribute(item, att.name, att.operator, att.value)) return false;
- if (parsed.pseudos){
- for (i = parsed.pseudos.length; i--; i){
- var psd = parsed.pseudos[i];
- if (!Selectors.Filters.byPseudo(item, psd.parser, psd.argument, local)) return false;
- return true;
- getByTagAndID: function(ctx, tag, id){
- if (id){
- var item = (ctx.getElementById) ? ctx.getElementById(id, true) : Element.getElementById(ctx, id, true);
- return (item && Selectors.Filters.byTag(item, tag)) ? [item] : [];
- } else {
- return ctx.getElementsByTagName(tag);
- search: function(self, expression, local){
- var splitters = [];
- var selectors = expression.trim().replace(Selectors.RegExps.splitter, function(m0, m1, m2){
- splitters.push(m1);
- return ':)' + m2;
- }).split(':)');
- var items, filtered, item;
- for (var i = 0, l = selectors.length; i < l; i++){
- var selector = selectors[i];
- if (i == 0 && Selectors.RegExps.quick.test(selector)){
- items = self.getElementsByTagName(selector);
- continue;
- var splitter = splitters[i - 1];
- if (i == 0){
- items = Selectors.Utils.getByTagAndID(self, tag, id);
- } else {
- var uniques = {}, found = [];
- for (var j = 0, k = items.length; j < k; j++) found = Selectors.Getters[splitter](found, items[j], tag, id, uniques);
- items = found;
- if (parsed){
- filtered = [];
- for (var m = 0, n = items.length; m < n; m++){
- item = items[m];
- if (Selectors.Utils.filter(item, parsed, local)) filtered.push(item);
- items = filtered;
- return items;
-Selectors.Getters = {
- ' ': function(found, self, tag, id, uniques){
- var items = Selectors.Utils.getByTagAndID(self, tag, id);
- for (var i = 0, l = items.length; i < l; i++){
- var item = items[i];
- if (Selectors.Utils.chk(item, uniques)) found.push(item);
- return found;
- '>': function(found, self, tag, id, uniques){
- var children = Selectors.Utils.getByTagAndID(self, tag, id);
- for (var i = 0, l = children.length; i < l; i++){
- var child = children[i];
- if (child.parentNode == self && Selectors.Utils.chk(child, uniques)) found.push(child);
- return found;
- '+': function(found, self, tag, id, uniques){
- while ((self = self.nextSibling)){
- if (self.nodeType == 1){
- if (Selectors.Utils.chk(self, uniques) && Selectors.Filters.byTag(self, tag) && Selectors.Filters.byID(self, id)) found.push(self);
- break;
- return found;
- '~': function(found, self, tag, id, uniques){
- if (!Selectors.Utils.chk(self, uniques)) break;
- if (Selectors.Filters.byTag(self, tag) && Selectors.Filters.byID(self, id)) found.push(self);
- return found;
-Selectors.Filters = {
- byTag: function(self, tag){
- return (tag == '*' || (self.tagName && self.tagName.toLowerCase() == tag));
- byID: function(self, id){
- return (!id || (self.id && self.id == id));
- byClass: function(self, klass){
- return (self.className && self.className.contains && self.className.contains(klass, ' '));
- byPseudo: function(self, parser, argument, local){
- return parser.call(self, argument, local);
- byAttribute: function(self, name, operator, value){
- var result = Element.prototype.getProperty.call(self, name);
- if (!result) return (operator == '!=');
- if (!operator || value == undefined) return true;
- switch (operator){
- case '=': return (result == value);
- case '*=': return (result.contains(value));
- case '^=': return (result.substr(0, value.length) == value);
- case '$=': return (result.substr(result.length - value.length) == value);
- case '!=': return (result != value);
- case '~=': return result.contains(value, ' ');
- case '|=': return result.contains(value, '-');
- return false;
-Selectors.Pseudo = new Hash({
- // w3c pseudo selectors
- checked: function(){
- return this.checked;
- return !(this.innerText || this.textContent || '').length;
- not: function(selector){
- return !Element.match(this, selector);
- contains: function(text){
- return (this.innerText || this.textContent || '').contains(text);
- 'first-child': function(){
- return Selectors.Pseudo.index.call(this, 0);
- 'last-child': function(){
- while ((element = element.nextSibling)){
- if (element.nodeType == 1) return false;
- return true;
- 'only-child': function(){
- var prev = this;
- while ((prev = prev.previousSibling)){
- if (prev.nodeType == 1) return false;
- var next = this;
- while ((next = next.nextSibling)){
- if (next.nodeType == 1) return false;
- return true;
- 'nth-child': function(argument, local){
- argument = (argument == undefined) ? 'n' : argument;
- var parsed = Selectors.Utils.parseNthArgument(argument);
- if (parsed.special != 'n') return Selectors.Pseudo[parsed.special].call(this, parsed.a, local);
- var count = 0;
- local.positions = local.positions || {};
- var uid = $uid(this);
- if (!local.positions[uid]){
- var self = this;
- while ((self = self.previousSibling)){
- if (self.nodeType != 1) continue;
- count ++;
- var position = local.positions[$uid(self)];
- if (position != undefined){
- count = position + count;
- break;
- local.positions[uid] = count;
- return (local.positions[uid] % parsed.a == parsed.b);
- // custom pseudo selectors
- index: function(index){
- var element = this, count = 0;
- while ((element = element.previousSibling)){
- if (element.nodeType == 1 && ++count > index) return false;
- return (count == index);
- even: function(argument, local){
- return Selectors.Pseudo['nth-child'].call(this, '2n+1', local);
- odd: function(argument, local){
- return Selectors.Pseudo['nth-child'].call(this, '2n', local);
- selected: function(){
- return this.selected;
- enabled: function(){
- return (this.disabled === false);
-script: DomReady.js
-description: Contains the custom event domready.
-license: MIT-style license.
-requires:
-- /Element.Event
-provides: [DomReady]
-Element.Events.domready = {
- onAdd: function(fn){
- if (Browser.loaded) fn.call(this);
-(function(){
- var domready = function(){
- if (Browser.loaded) return;
- Browser.loaded = true;
- window.fireEvent('domready');
- document.fireEvent('domready');
- window.addEvent('load', domready);
- var temp = document.createElement('div');
- (function(){
- ($try(function(){
- temp.doScroll(); // Technique by Diego Perini
- return document.id(temp).inject(document.body).set('html', 'temp').dispose();
- })) ? domready() : arguments.callee.delay(50);
- } else if (Browser.Engine.webkit && Browser.Engine.version < 525){
- (function(){
- (['loaded', 'complete'].contains(document.readyState)) ? domready() : arguments.callee.delay(50);
- } else {
- document.addEvent('DOMContentLoaded', domready);
-script: JSON.js
-description: JSON encoder and decoder.
-See Also: <http://www.json.org/>
-requires:
-- /Array
-- /String
-- /Number
-- /Function
-- /Hash
-provides: [JSON]
-var JSON = new Hash(this.JSON && {
- stringify: JSON.stringify,
- parse: JSON.parse
-}).extend({
- $specialChars: {'\b': '\\b', '\t': '\\t', '\n': '\\n', '\f': '\\f', '\r': '\\r', '"' : '\\"', '\\': '\\\\'},
- $replaceChars: function(chr){
- return JSON.$specialChars[chr] || '\\u00' + Math.floor(chr.charCodeAt() / 16).toString(16) + (chr.charCodeAt() % 16).toString(16);
- encode: function(obj){
- switch ($type(obj)){
- case 'string':
- return '"' + obj.replace(/[\x00-\x1f\\"]/g, JSON.$replaceChars) + '"';
- case 'array':
- return '[' + String(obj.map(JSON.encode).clean()) + ']';
- case 'object': case 'hash':
- var string = [];
- Hash.each(obj, function(value, key){
- var json = JSON.encode(value);
- if (json) string.push(JSON.encode(key) + ':' + json);
- return '{' + string + '}';
- case 'number': case 'boolean': return String(obj);
- case false: return 'null';
- return null;
- decode: function(string, secure){
- if ($type(string) != 'string' || !string.length) return null;
- if (secure && !(/^[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t]*$/).test(string.replace(/\\./g, '@').replace(/"[^"\\\n\r]*"/g, ''))) return null;
- return eval('(' + string + ')');
-Native.implement([Hash, Array, String, Number], {
- toJSON: function(){
- return JSON.encode(this);
-script: Cookie.js
-description: Class for creating, reading, and deleting browser Cookies.
-credits:
-- Based on the functions by Peter-Paul Koch (http://quirksmode.org).
-requires:
-- /Options
-provides: [Cookie]
-var Cookie = new Class({
- Implements: Options,
- options: {
- path: false,
- domain: false,
- duration: false,
- secure: false,
- document: document
- initialize: function(key, options){
- this.key = key;
- this.setOptions(options);
- write: function(value){
- value = encodeURIComponent(value);
- if (this.options.domain) value += '; domain=' + this.options.domain;
- if (this.options.path) value += '; path=' + this.options.path;
- if (this.options.duration){
- var date = new Date();
- date.setTime(date.getTime() + this.options.duration * 24 * 60 * 60 * 1000);
- value += '; expires=' + date.toGMTString();
- if (this.options.secure) value += '; secure';
- this.options.document.cookie = this.key + '=' + value;
- return this;
- read: function(){
- var value = this.options.document.cookie.match('(?:^|;)\\s*' + this.key.escapeRegExp() + '=([^;]*)');
- return (value) ? decodeURIComponent(value[1]) : null;
- new Cookie(this.key, $merge(this.options, {duration: -1})).write('');
- return this;
-Cookie.write = function(key, value, options){
- return new Cookie(key, options).write(value);
-Cookie.read = function(key){
- return new Cookie(key).read();
-Cookie.dispose = function(key, options){
- return new Cookie(key, options).dispose();
-script: Swiff.js
-description: Wrapper for embedding SWF movies. Supports External Interface Communication.
-credits:
-- Flash detection & Internet Explorer + Flash Player 9 fix inspired by SWFObject.
-requires:
-- /Options
-- /$util
-provides: [Swiff]
-var Swiff = new Class({
- Implements: [Options],
- options: {
- id: null,
- height: 1,
- width: 1,
- container: null,
- properties: {},
- params: {
- quality: 'high',
- allowScriptAccess: 'always',
- wMode: 'transparent',
- swLiveConnect: true
- callBacks: {},
- vars: {}
- toElement: function(){
- return this.object;
- initialize: function(path, options){
- this.instance = 'Swiff_' + $time();
- options = this.options;
- var id = this.id = options.id || this.instance;
- var container = document.id(options.container);
- Swiff.CallBacks[this.instance] = {};
- var params = options.params, vars = options.vars, callBacks = options.callBacks;
- var properties = $extend({height: options.height, width: options.width}, options.properties);
- var self = this;
- for (var callBack in callBacks){
- Swiff.CallBacks[this.instance][callBack] = (function(option){
- return function(){
- return option.apply(self.object, arguments);
- })(callBacks[callBack]);
- vars[callBack] = 'Swiff.CallBacks.' + this.instance + '.' + callBack;
- params.flashVars = Hash.toQueryString(vars);
- properties.classid = 'clsid:D27CDB6E-AE6D-11cf-96B8-444553540000';
- params.movie = path;
- } else {
- properties.type = 'application/x-shockwave-flash';
- properties.data = path;
- var build = '<object id="' + id + '"';
- for (var property in properties) build += ' ' + property + '="' + properties[property] + '"';
- build += '>';
- for (var param in params){
- if (params[param]) build += '<param name="' + param + '" value="' + params[param] + '" />';
- build += '</object>';
- this.object = ((container) ? container.empty() : new Element('div')).set('html', build).firstChild;
- replaces: function(element){
- element.parentNode.replaceChild(this.toElement(), element);
- return this;
- inject: function(element){
- document.id(element, true).appendChild(this.toElement());
- return this;
- remote: function(){
- return Swiff.remote.apply(Swiff, [this.toElement()].extend(arguments));
-Swiff.CallBacks = {};
-Swiff.remote = function(obj, fn){
- var rs = obj.CallFunction('<invoke name="' + fn + '" returntype="javascript">' + __flash__argumentsToXML(arguments, 2) + '</invoke>');
- return eval(rs);
-script: Fx.js
-description: Contains the basic animation logic to be extended by all other Fx Classes.
-requires:
-- /Chain
-- /Events
-- /Options
-provides: [Fx]
-var Fx = new Class({
- Implements: [Chain, Events, Options],
- options: {
- onStart: $empty,
- onCancel: $empty,
- onComplete: $empty,
- fps: 50,
- unit: false,
- duration: 500,
- link: 'ignore'
- initialize: function(options){
- this.subject = this.subject || this;
- this.options.duration = Fx.Durations[this.options.duration] || this.options.duration.toInt();
- var wait = this.options.wait;
- if (wait === false) this.options.link = 'cancel';
- getTransition: function(){
- return function(p){
- return -(Math.cos(Math.PI * p) - 1) / 2;
- step: function(){
- var time = $time();
- if (time < this.time + this.options.duration){
- var delta = this.transition((time - this.time) / this.options.duration);
- this.set(this.compute(this.from, this.to, delta));
- } else {
- this.set(this.compute(this.from, this.to, 1));
- this.complete();
- set: function(now){
- return now;
- compute: function(from, to, delta){
- return Fx.compute(from, to, delta);
- check: function(){
- if (!this.timer) return true;
- switch (this.options.link){
- case 'cancel': this.cancel(); return true;
- case 'chain': this.chain(this.caller.bind(this, arguments)); return false;
- return false;
- start: function(from, to){
- if (!this.check(from, to)) return this;
- this.from = from;
- this.to = to;
- this.time = 0;
- this.transition = this.getTransition();
- this.startTimer();
- this.onStart();
- return this;
- complete: function(){
- if (this.stopTimer()) this.onComplete();
- return this;
- cancel: function(){
- if (this.stopTimer()) this.onCancel();
- return this;
- onStart: function(){
- this.fireEvent('start', this.subject);
- onComplete: function(){
- this.fireEvent('complete', this.subject);
- if (!this.callChain()) this.fireEvent('chainComplete', this.subject);
- onCancel: function(){
- this.fireEvent('cancel', this.subject).clearChain();
- pause: function(){
- this.stopTimer();
- return this;
- resume: function(){
- return this;
- stopTimer: function(){
- if (!this.timer) return false;
- this.time = $time() - this.time;
- this.timer = $clear(this.timer);
- return true;
- startTimer: function(){
- if (this.timer) return false;
- this.timer = this.step.periodical(Math.round(1000 / this.options.fps), this);
- return true;
-Fx.compute = function(from, to, delta){
- return (to - from) * delta + from;
-Fx.Durations = {'short': 250, 'normal': 500, 'long': 1000};
-script: Fx.CSS.js
-description: Contains the CSS animation logic. Used by Fx.Tween, Fx.Morph, Fx.Elements.
-requires:
-- /Fx
-- /Element.Style
-provides: [Fx.CSS]
-Fx.CSS = new Class({
- Extends: Fx,
- //prepares the base from/to object
- prepare: function(element, property, values){
- values = $splat(values);
- var values1 = values[1];
- if (!$chk(values1)){
- values[1] = values[0];
- values[0] = element.getStyle(property);
- var parsed = values.map(this.parse);
- return {from: parsed[0], to: parsed[1]};
- //parses a value into an array
- parse: function(value){
- value = $lambda(value)();
- value = (typeof value == 'string') ? value.split(' ') : $splat(value);
- return value.map(function(val){
- val = String(val);
- var found = false;
- Fx.CSS.Parsers.each(function(parser, key){
- if (found) return;
- var parsed = parser.parse(val);
- if ($chk(parsed)) found = {value: parsed, parser: parser};
- found = found || {value: val, parser: Fx.CSS.Parsers.String};
- return found;
- //computes by a from and to prepared objects, using their parsers.
- var computed = [];
- (Math.min(from.length, to.length)).times(function(i){
- computed.push({value: from[i].parser.compute(from[i].value, to[i].value, delta), parser: from[i].parser});
- computed.$family = {name: 'fx:css:value'};
- return computed;
- //serves the value as settable
- serve: function(value, unit){
- if ($type(value) != 'fx:css:value') value = this.parse(value);
- var returned = [];
- value.each(function(bit){
- returned = returned.concat(bit.parser.serve(bit.value, unit));
- return returned;
- //renders the change to an element
- render: function(element, property, value, unit){
- element.setStyle(property, this.serve(value, unit));
- //searches inside the page css to find the values for a selector
- search: function(selector){
- if (Fx.CSS.Cache[selector]) return Fx.CSS.Cache[selector];
- var to = {};
- Array.each(document.styleSheets, function(sheet, j){
- var href = sheet.href;
- if (href && href.contains('://') && !href.contains(document.domain)) return;
- var rules = sheet.rules || sheet.cssRules;
- Array.each(rules, function(rule, i){
- if (!rule.style) return;
- var selectorText = (rule.selectorText) ? rule.selectorText.replace(/^\w+/, function(m){
- return m.toLowerCase();
- }) : null;
- if (!selectorText || !selectorText.test('^' + selector + '$')) return;
- Element.Styles.each(function(value, style){
- if (!rule.style[style] || Element.ShortStyles[style]) return;
- value = String(rule.style[style]);
- to[style] = (value.test(/^rgb/)) ? value.rgbToHex() : value;
- return Fx.CSS.Cache[selector] = to;
-Fx.CSS.Cache = {};
-Fx.CSS.Parsers = new Hash({
- Color: {
- if (value.match(/^#[0-9a-f]{3,6}$/i)) return value.hexToRgb(true);
- return ((value = value.match(/(\d+),\s*(\d+),\s*(\d+)/))) ? [value[1], value[2], value[3]] : false;
- return from.map(function(value, i){
- return Math.round(Fx.compute(from[i], to[i], delta));
- serve: function(value){
- return value.map(Number);
- Number: {
- parse: parseFloat,
- compute: Fx.compute,
- return (unit) ? value + unit : value;
- String: {
- parse: $lambda(false),
- compute: $arguments(1),
- serve: $arguments(0)
-script: Fx.Tween.js
-description: Formerly Fx.Style, effect to transition any CSS property for an element.
-requires:
-- /Fx.CSS
-provides: [Fx.Tween, Element.fade, Element.highlight]
-Fx.Tween = new Class({
- Extends: Fx.CSS,
- initialize: function(element, options){
- this.element = this.subject = document.id(element);
- this.parent(options);
- set: function(property, now){
- if (arguments.length == 1){
- now = property;
- property = this.property || this.options.property;
- this.render(this.element, property, now, this.options.unit);
- return this;
- start: function(property, from, to){
- if (!this.check(property, from, to)) return this;
- this.property = this.options.property || args.shift();
- var parsed = this.prepare(this.element, this.property, args);
- return this.parent(parsed.from, parsed.to);
-Element.Properties.tween = {
- set: function(options){
- var tween = this.retrieve('tween');
- if (tween) tween.cancel();
- return this.eliminate('tween').store('tween:options', $extend({link: 'cancel'}, options));
- get: function(options){
- if (options || !this.retrieve('tween')){
- if (options || !this.retrieve('tween:options')) this.set('tween', options);
- this.store('tween', new Fx.Tween(this, this.retrieve('tween:options')));
- return this.retrieve('tween');
- tween: function(property, from, to){
- this.get('tween').start(arguments);
- return this;
- fade: function(how){
- var fade = this.get('tween'), o = 'opacity', toggle;
- how = $pick(how, 'toggle');
- switch (how){
- case 'in': fade.start(o, 1); break;
- case 'out': fade.start(o, 0); break;
- case 'show': fade.set(o, 1); break;
- case 'hide': fade.set(o, 0); break;
- case 'toggle':
- var flag = this.retrieve('fade:flag', this.get('opacity') == 1);
- fade.start(o, (flag) ? 0 : 1);
- this.store('fade:flag', !flag);
- toggle = true;
- break;
- default: fade.start(o, arguments);
- if (!toggle) this.eliminate('fade:flag');
- return this;
- highlight: function(start, end){
- if (!end){
- end = this.retrieve('highlight:original', this.getStyle('background-color'));
- end = (end == 'transparent') ? '#fff' : end;
- var tween = this.get('tween');
- tween.start('background-color', start || '#ffff88', end).chain(function(){
- this.setStyle('background-color', this.retrieve('highlight:original'));
- tween.callChain();
- }.bind(this));
- return this;
-script: Fx.Morph.js
-description: Formerly Fx.Styles, effect to transition any number of CSS properties for an element using an object of rules, or CSS based selector rules.
-requires:
-- /Fx.CSS
-provides: [Fx.Morph]
-Fx.Morph = new Class({
- Extends: Fx.CSS,
- if (typeof now == 'string') now = this.search(now);
- for (var p in now) this.render(this.element, p, now[p], this.options.unit);
- return this;
- var now = {};
- for (var p in from) now[p] = this.parent(from[p], to[p], delta);
- return now;
- start: function(properties){
- if (!this.check(properties)) return this;
- if (typeof properties == 'string') properties = this.search(properties);
- var from = {}, to = {};
- for (var p in properties){
- var parsed = this.prepare(this.element, p, properties[p]);
- from[p] = parsed.from;
- to[p] = parsed.to;
- return this.parent(from, to);
-Element.Properties.morph = {
- var morph = this.retrieve('morph');
- if (morph) morph.cancel();
- return this.eliminate('morph').store('morph:options', $extend({link: 'cancel'}, options));
- if (options || !this.retrieve('morph')){
- if (options || !this.retrieve('morph:options')) this.set('morph', options);
- this.store('morph', new Fx.Morph(this, this.retrieve('morph:options')));
- return this.retrieve('morph');
- morph: function(props){
- this.get('morph').start(props);
- return this;
-script: Fx.Transitions.js
-description: Contains a set of advanced transitions to be used with any of the Fx Classes.
-credits:
-- Easing Equations by Robert Penner, <http://www.robertpenner.com/easing/>, modified and optimized to be used with MooTools.
-requires:
-- /Fx
-provides: [Fx.Transitions]
-Fx.implement({
- var trans = this.options.transition || Fx.Transitions.Sine.easeInOut;
- if (typeof trans == 'string'){
- var data = trans.split(':');
- trans = Fx.Transitions;
- trans = trans[data[0]] || trans[data[0].capitalize()];
- if (data[1]) trans = trans['ease' + data[1].capitalize() + (data[2] ? data[2].capitalize() : '')];
- return trans;
-Fx.Transition = function(transition, params){
- params = $splat(params);
- return $extend(transition, {
- easeIn: function(pos){
- return transition(pos, params);
- easeOut: function(pos){
- return 1 - transition(1 - pos, params);
- easeInOut: function(pos){
- return (pos <= 0.5) ? transition(2 * pos, params) / 2 : (2 - transition(2 * (1 - pos), params)) / 2;
-Fx.Transitions = new Hash({
- linear: $arguments(0)
-Fx.Transitions.extend = function(transitions){
- for (var transition in transitions) Fx.Transitions[transition] = new Fx.Transition(transitions[transition]);
-Fx.Transitions.extend({
- Pow: function(p, x){
- return Math.pow(p, x[0] || 6);
- Expo: function(p){
- return Math.pow(2, 8 * (p - 1));
- Circ: function(p){
- return 1 - Math.sin(Math.acos(p));
- Sine: function(p){
- return 1 - Math.sin((1 - p) * Math.PI / 2);
- Back: function(p, x){
- x = x[0] || 1.618;
- return Math.pow(p, 2) * ((x + 1) * p - x);
- Bounce: function(p){
- var value;
- for (var a = 0, b = 1; 1; a += b, b /= 2){
- if (p >= (7 - 4 * a) / 11){
- value = b * b - Math.pow((11 - 6 * a - 11 * p) / 4, 2);
- break;
- return value;
- Elastic: function(p, x){
- return Math.pow(2, 10 * --p) * Math.cos(20 * p * Math.PI * (x[0] || 1) / 3);
-['Quad', 'Cubic', 'Quart', 'Quint'].each(function(transition, i){
- Fx.Transitions[transition] = new Fx.Transition(function(p){
- return Math.pow(p, [i + 2]);
-script: Request.js
-description: Powerful all purpose Request Class. Uses XMLHTTPRequest.
-requires:
-- /Element
-- /Chain
-- /Events
-- /Options
-- /Browser
-provides: [Request]
-var Request = new Class({
- options: {/*
- onRequest: $empty,
- onCancel: $empty,
- onSuccess: $empty,
- onFailure: $empty,
- onException: $empty,*/
- url: '',
- data: '',
- headers: {
- 'X-Requested-With': 'XMLHttpRequest',
- 'Accept': 'text/javascript, text/html, application/xml, text/xml, */*'
- async: true,
- format: false,
- method: 'post',
- link: 'ignore',
- isSuccess: null,
- emulation: true,
- urlEncoded: true,
- encoding: 'utf-8',
- evalScripts: false,
- evalResponse: false,
- noCache: false
- this.xhr = new Browser.Request();
- this.options.isSuccess = this.options.isSuccess || this.isSuccess;
- this.headers = new Hash(this.options.headers);
- onStateChange: function(){
- if (this.xhr.readyState != 4 || !this.running) return;
- this.running = false;
- this.status = 0;
- $try(function(){
- this.status = this.xhr.status;
- }.bind(this));
- this.xhr.onreadystatechange = $empty;
- if (this.options.isSuccess.call(this, this.status)){
- this.response = {text: this.xhr.responseText, xml: this.xhr.responseXML};
- this.success(this.response.text, this.response.xml);
- } else {
- this.response = {text: null, xml: null};
- this.failure();
- isSuccess: function(){
- return ((this.status >= 200) && (this.status < 300));
- processScripts: function(text){
- if (this.options.evalResponse || (/(ecma|java)script/).test(this.getHeader('Content-type'))) return $exec(text);
- return text.stripScripts(this.options.evalScripts);
- success: function(text, xml){
- this.onSuccess(this.processScripts(text), xml);
- onSuccess: function(){
- this.fireEvent('complete', arguments).fireEvent('success', arguments).callChain();
- failure: function(){
- this.onFailure();
- onFailure: function(){
- this.fireEvent('complete').fireEvent('failure', this.xhr);
- setHeader: function(name, value){
- this.headers.set(name, value);
- return this;
- getHeader: function(name){
- return $try(function(){
- return this.xhr.getResponseHeader(name);
- }.bind(this));
- if (!this.running) return true;
- return false;
- send: function(options){
- if (!this.check(options)) return this;
- this.running = true;
- var type = $type(options);
- if (type == 'string' || type == 'element') options = {data: options};
- var old = this.options;
- options = $extend({data: old.data, url: old.url, method: old.method}, options);
- var data = options.data, url = String(options.url), method = options.method.toLowerCase();
- switch ($type(data)){
- case 'element': data = document.id(data).toQueryString(); break;
- case 'object': case 'hash': data = Hash.toQueryString(data);
- if (this.options.format){
- var format = 'format=' + this.options.format;
- data = (data) ? format + '&' + data : format;
- if (this.options.emulation && !['get', 'post'].contains(method)){
- var _method = '_method=' + method;
- data = (data) ? _method + '&' + data : _method;
- method = 'post';
- if (this.options.urlEncoded && method == 'post'){
- var encoding = (this.options.encoding) ? '; charset=' + this.options.encoding : '';
- this.headers.set('Content-type', 'application/x-www-form-urlencoded' + encoding);
- if (this.options.noCache){
- var noCache = 'noCache=' + new Date().getTime();
- data = (data) ? noCache + '&' + data : noCache;
- var trimPosition = url.lastIndexOf('/');
- if (trimPosition > -1 && (trimPosition = url.indexOf('#')) > -1) url = url.substr(0, trimPosition);
- if (data && method == 'get'){
- url = url + (url.contains('?') ? '&' : '?') + data;
- data = null;
- this.xhr.open(method.toUpperCase(), url, this.options.async);
- this.xhr.onreadystatechange = this.onStateChange.bind(this);
- this.headers.each(function(value, key){
- try {
- this.xhr.setRequestHeader(key, value);
- } catch (e){
- this.fireEvent('exception', [key, value]);
- }, this);
- this.fireEvent('request');
- this.xhr.send(data);
- if (!this.options.async) this.onStateChange();
- return this;
- if (!this.running) return this;
- this.xhr.abort();
- this.fireEvent('cancel');
- return this;
-(function(){
-var methods = {};
-['get', 'post', 'put', 'delete', 'GET', 'POST', 'PUT', 'DELETE'].each(function(method){
- methods[method] = function(){
- var params = Array.link(arguments, {url: String.type, data: $defined});
- return this.send($extend(params, {method: method}));
-Request.implement(methods);
-Element.Properties.send = {
- var send = this.retrieve('send');
- if (send) send.cancel();
- return this.eliminate('send').store('send:options', $extend({
- data: this, link: 'cancel', method: this.get('method') || 'post', url: this.get('action')
- }, options));
- if (options || !this.retrieve('send')){
- if (options || !this.retrieve('send:options')) this.set('send', options);
- this.store('send', new Request(this.retrieve('send:options')));
- return this.retrieve('send');
- send: function(url){
- var sender = this.get('send');
- sender.send({data: this, url: url || sender.options.url});
- return this;
-script: Request.HTML.js
-description: Extends the basic Request Class with additional methods for interacting with HTML responses.
-requires:
-- /Request
-- /Element
-provides: [Request.HTML]
-Request.HTML = new Class({
- Extends: Request,
- options: {
- update: false,
- append: false,
- evalScripts: true,
- filter: false
- processHTML: function(text){
- var match = text.match(/<body[^>]*>([\s\S]*?)<\/body>/i);
- text = (match) ? match[1] : text;
- var container = new Element('div');
- var root = '<root>' + text + '</root>', doc;
- doc = new ActiveXObject('Microsoft.XMLDOM');
- doc.async = false;
- doc.loadXML(root);
- } else {
- doc = new DOMParser().parseFromString(root, 'text/xml');
- root = doc.getElementsByTagName('root')[0];
- if (!root) return null;
- for (var i = 0, k = root.childNodes.length; i < k; i++){
- var child = Element.clone(root.childNodes[i], true, true);
- if (child) container.grab(child);
- return container;
- }) || container.set('html', text);
- success: function(text){
- var options = this.options, response = this.response;
- response.html = text.stripScripts(function(script){
- response.javascript = script;
- var temp = this.processHTML(response.html);
- response.tree = temp.childNodes;
- response.elements = temp.getElements('*');
- if (options.filter) response.tree = response.elements.filter(options.filter);
- if (options.update) document.id(options.update).empty().set('html', response.html);
- else if (options.append) document.id(options.append).adopt(temp.getChildren());
- if (options.evalScripts) $exec(response.javascript);
- this.onSuccess(response.tree, response.elements, response.html, response.javascript);
-Element.Properties.load = {
- var load = this.retrieve('load');
- if (load) load.cancel();
- return this.eliminate('load').store('load:options', $extend({data: this, link: 'cancel', update: this, method: 'get'}, options));
- if (options || ! this.retrieve('load')){
- if (options || !this.retrieve('load:options')) this.set('load', options);
- this.store('load', new Request.HTML(this.retrieve('load:options')));
- return this.retrieve('load');
- load: function(){
- this.get('load').send(Array.link(arguments, {data: Object.type, url: String.type}));
- return this;
-script: Request.JSON.js
-description: Extends the basic Request Class with additional methods for sending and receiving JSON data.
-requires:
-- /Request JSON
-Request.JSON = new Class({
- Extends: Request,
- options: {
- secure: true
- this.headers.extend({'Accept': 'application/json', 'X-Request': 'JSON'});
- this.response.json = JSON.decode(text, this.options.secure);
- this.onSuccess(this.response.json, text);
-script: More.js
-description: MooTools More
-authors:
-- Guillermo Rauch
-- Thomas Aylott
-- Scott Kyle
-requires:
-- core:1.2.4/MooTools
-provides: [MooTools.More]
-MooTools.More = {
- 'version': '1.2.4.4',
- 'build': '6f6057dc645fdb7547689183b2311063bd653ddf'
-script: MooTools.Lang.js
-description: Provides methods for localization.
-authors:
-- Aaron Newton
-requires:
-- core:1.2.4/Events
-- /MooTools.More
-provides: [MooTools.Lang]
-(function(){
- var data = {
- language: 'en-US',
- languages: {
- 'en-US': {}
- cascades: ['en-US']
- var cascaded;
- MooTools.lang = new Events();
- $extend(MooTools.lang, {
- setLanguage: function(lang){
- if (!data.languages[lang]) return this;
- data.language = lang;
- this.load();
- this.fireEvent('langChange', lang);
- return this;
- load: function() {
- var langs = this.cascade(this.getCurrentLanguage());
- cascaded = {};
- $each(langs, function(set, setName){
- cascaded[setName] = this.lambda(set);
- }, this);
- getCurrentLanguage: function(){
- return data.language;
- addLanguage: function(lang){
- data.languages[lang] = data.languages[lang] || {};
- return this;
- cascade: function(lang){
- var cascades = (data.languages[lang] || {}).cascades || [];
- cascades.combine(data.cascades);
- cascades.erase(lang).push(lang);
- var langs = cascades.map(function(lng){
- return data.languages[lng];
- }, this);
- return $merge.apply(this, langs);
- lambda: function(set) {
- (set || {}).get = function(key, args){
- return $lambda(set[key]).apply(this, $splat(args));
- return set;
- get: function(set, key, args){
- if (cascaded && cascaded[set]) return (key ? cascaded[set].get(key, args) : cascaded[set]);
- set: function(lang, set, members){
- this.addLanguage(lang);
- langData = data.languages[lang];
- if (!langData[set]) langData[set] = {};
- $extend(langData[set], members);
- if (lang == this.getCurrentLanguage()){
- this.load();
- return this;
- list: function(){
- return Hash.getKeys(data.languages);
-script: Log.js
-description: Provides basic logging functionality for plugins to implement.
-authors:
-- Guillermo Rauch
-- Thomas Aylott
-- Scott Kyle
-requires:
-- core:1.2.4/Class
-- /MooTools.More
-provides: [Log]
-(function(){
-var global = this;
-var log = function(){
- if (global.console && console.log){
- try {
- console.log.apply(console, arguments);
- } catch(e) {
- console.log(Array.slice(arguments));
- } else {
- Log.logged.push(arguments);
- return this;
-var disabled = function(){
- this.logged.push(arguments);
- return this;
-this.Log = new Class({
- logged: [],
- log: disabled,
- resetLog: function(){
- this.logged.empty();
- return this;
- enableLog: function(){
- this.log = log;
- this.logged.each(function(args){
- this.log.apply(this, args);
- }, this);
- return this.resetLog();
- disableLog: function(){
- this.log = disabled;
- return this;
-Log.extend(new Log).enableLog();
-// legacy
-Log.logger = function(){
- return this.log.apply(this, arguments);
-script: Depender.js
-description: A stand alone dependency loader for the MooTools library.
-authors:
-- Aaron Newton
-requires:
-- core:1.2.4/Element.Events
-- core:1.2.4/Request.JSON
-- /MooTools.More
-- /Log
-provides: Depender
-var Depender = {
- options: {
- onRequire: $empty(options),
- onRequirementLoaded: $empty([scripts, options]),
- onScriptLoaded: $empty({
- script: script,
- totalLoaded: percentOfTotalLoaded,
- loaded: scriptsState
- serial: false,
- target: null,
- noCache: false,
- log: false,*/
- loadedSources: [],
- loadedScripts: ['Core', 'Browser', 'Array', 'String', 'Function', 'Number', 'Hash', 'Element', 'Event', 'Element.Event', 'Class', 'DomReady', 'Class.Extras', 'Request', 'JSON', 'Request.JSON', 'More', 'Depender', 'Log'],
- useScriptInjection: true
- loaded: [],
- sources: {},
- libs: {},
- include: function(libs){
- this.log('include: ', libs);
- this.mapLoaded = false;
- var loader = function(data){
- this.libs = $merge(this.libs, data);
- $each(this.libs, function(data, lib){
- if (data.scripts) this.loadSource(lib, data.scripts);
- }, this);
- }.bind(this);
- if ($type(libs) == 'string'){
- this.log('fetching libs ', libs);
- this.request(libs, loader);
- } else {
- loader(libs);
- return this;
- required: [],
- require: function(options){
- var loaded = function(){
- var scripts = this.calculateDependencies(options.scripts);
- if (options.sources){
- options.sources.each(function(source){
- scripts.combine(this.libs[source].files);
- }, this);
- if (options.serial) scripts.combine(this.getLoadedScripts());
- options.scripts = scripts;
- this.required.push(options);
- this.fireEvent('require', options);
- this.loadScripts(options.scripts);
- if (this.mapLoaded) loaded.call(this);
- else this.addEvent('mapLoaded', loaded.bind(this));
- return this;
- cleanDoubleSlash: function(str){
- if (!str) return str;
- var prefix = '';
- if (str.test(/^http:\/\//)){
- prefix = 'http://';
- str = str.substring(7, str.length);
- str = str.replace(/\/\//g, '/');
- return prefix + str;
- request: function(url, callback){
- new Request.JSON({
- url: url,
- secure: false,
- onSuccess: callback
- }).send();
- loadSource: function(lib, source){
- if (this.libs[lib].files){
- this.dataLoaded();
- return;
- this.log('loading source: ', source);
- this.request(this.cleanDoubleSlash(source + '/scripts.json'), function(result){
- this.log('loaded source: ', source);
- this.libs[lib].files = result;
- }.bind(this));
- dataLoaded: function(){
- var loaded = true;
- $each(this.libs, function(v, k){
- if (!this.libs[k].files) loaded = false;
- }, this);
- if (loaded){
- this.mapTree();
- this.mapLoaded = true;
- this.calculateLoaded();
- this.lastLoaded = this.getLoadedScripts().getLength();
- this.fireEvent('mapLoaded');
- this.removeEvents('mapLoaded');
- calculateLoaded: function(){
- var set = function(script){
- this.scriptsState[script] = true;
- }.bind(this);
- if (this.options.loadedScripts) this.options.loadedScripts.each(set);
- if (this.options.loadedSources){
- this.options.loadedSources.each(function(lib){
- $each(this.libs[lib].files, function(dir){
- $each(dir, function(data, file){
- set(file);
- }, this);
- }, this);
- }, this);
- deps: {},
- pathMap: {},
- mapTree: function(){
- $each(this.libs, function(data, source){
- $each(data.files, function(scripts, folder){
- $each(scripts, function(details, script){
- var path = source + ':' + folder + ':' + script;
- if (this.deps[path]) return;
- this.deps[path] = details.deps;
- this.pathMap[script] = path;
- }, this);
- }, this);
- }, this);
- getDepsForScript: function(script){
- return this.deps[this.pathMap[script]] || [];
- calculateDependencies: function(scripts){
- var reqs = [];
- $splat(scripts).each(function(script){
- if (script == 'None' || !script) return;
- var deps = this.getDepsForScript(script);
- if (!deps){
- if (window.console && console.warn) console.warn('dependencies not mapped: script: %o, map: %o, :deps: %o', script, this.pathMap, this.deps);
- } else {
- deps.each(function(scr){
- if (scr == script || scr == 'None' || !scr) return;
- if (!reqs.contains(scr)) reqs.combine(this.calculateDependencies(scr));
- reqs.include(scr);
- }, this);
- reqs.include(script);
- }, this);
- return reqs;
- getPath: function(script){
- try {
- var chunks = this.pathMap[script].split(':');
- var lib = this.libs[chunks[0]];
- var dir = (lib.path || lib.scripts) + '/';
- chunks.shift();
- return this.cleanDoubleSlash(dir + chunks.join('/') + '.js');
- } catch(e){
- return script;
- loadScripts: function(scripts){
- scripts = scripts.filter(function(s){
- if (!this.scriptsState[s] && s != 'None'){
- this.scriptsState[s] = false;
- return true;
- }, this);
- if (scripts.length){
- scripts.each(function(scr){
- this.loadScript(scr);
- }, this);
- } else {
- this.check();
- toLoad: [],
- loadScript: function(script){
- if (this.scriptsState[script] && this.toLoad.length){
- this.loadScript(this.toLoad.shift());
- return;
- } else if (this.loading){
- this.toLoad.push(script);
- return;
- var finish = function(){
- this.loading = false;
- this.scriptLoaded(script);
- if (this.toLoad.length) this.loadScript(this.toLoad.shift());
- }.bind(this);
- var error = function(){
- this.log('could not load: ', scriptPath);
- }.bind(this);
- this.loading = true;
- var scriptPath = this.getPath(script);
- if (this.options.useScriptInjection){
- this.log('injecting script: ', scriptPath);
- this.log('loaded script: ', scriptPath);
- finish();
- }.bind(this);
- new Element('script', {
- src: scriptPath + (this.options.noCache ? '?noCache=' + new Date().getTime() : ''),
- events: {
- load: loaded,
- readystatechange: function(){
- if (['loaded', 'complete'].contains(this.readyState)) loaded();
- error: error
- }).inject(this.options.target || document.head);
- } else {
- this.log('requesting script: ', scriptPath);
- new Request({
- url: scriptPath,
- noCache: this.options.noCache,
- onComplete: function(js){
- $exec(js);
- finish();
- }.bind(this),
- onFailure: error,
- onException: error
- }).send();
- scriptsState: $H(),
- getLoadedScripts: function(){
- return this.scriptsState.filter(function(state){
- return state;
- scriptLoaded: function(script){
- this.log('loaded script: ', script);
- this.check();
- var loaded = this.getLoadedScripts();
- var loadedLength = loaded.getLength();
- var toLoad = this.scriptsState.getLength();
- this.fireEvent('scriptLoaded', {
- script: script,
- totalLoaded: (loadedLength / toLoad * 100).round(),
- currentLoaded: ((loadedLength - this.lastLoaded) / (toLoad - this.lastLoaded) * 100).round(),
- loaded: loaded
- if (loadedLength == toLoad) this.lastLoaded = loadedLength;
- lastLoaded: 0,
- var incomplete = [];
- this.required.each(function(required){
- var loaded = [];
- required.scripts.each(function(script){
- if (this.scriptsState[script]) loaded.push(script);
- }, this);
- if (required.onStep){
- required.onStep({
- percent: loaded.length / required.scripts.length * 100,
- scripts: loaded
- if (required.scripts.length != loaded.length) return;
- required.callback();
- this.required.erase(required);
- this.fireEvent('requirementLoaded', [loaded, required]);
- }, this);
-$extend(Depender, new Events);
-$extend(Depender, new Options);
-$extend(Depender, new Log);
-Depender._setOptions = Depender.setOptions;
-Depender.setOptions = function(){
- Depender._setOptions.apply(Depender, arguments);
- if (this.options.log) Depender.enableLog();
- return this;
-script: Class.Refactor.js
-description: Extends a class onto itself with new property, preserving any items attached to the class's namespace.
-authors:
-- Aaron Newton
-requires:
-- core:1.2.4/Class
-- /MooTools.More
-provides: [Class.refactor]
-Class.refactor = function(original, refactors){
- $each(refactors, function(item, name){
- var origin = original.prototype[name];
- if (origin && (origin = origin._origin) && typeof item == 'function') original.implement(name, function(){
- var old = this.previous;
- this.previous = origin;
- var value = item.apply(this, arguments);
- this.previous = old;
- return value;
- }); else original.implement(name, item);
- return original;
-script: Class.Binds.js
-description: Automagically binds specified methods in a class to the instance of the class.
-authors:
-- Aaron Newton
-requires:
-- core:1.2.4/Class
-- /MooTools.More
-provides: [Class.Binds]
-Class.Mutators.Binds = function(binds){
- return binds;
-Class.Mutators.initialize = function(initialize){
- $splat(this.Binds).each(function(name){
- var original = this[name];
- if (original) this[name] = original.bind(this);
- }, this);
- return initialize.apply(this, arguments);
-script: Class.Occlude.js
-description: Prevents a class from being applied to a DOM element twice.
-authors:
-- Aaron Newton
-requires:
-- core/1.2.4/Class
-- /MooTools.More
-provides: [Class.Occlude]
-Class.Occlude = new Class({
- occlude: function(property, element){
- element = document.id(element || this.element);
- var instance = element.retrieve(property || this.property);
- if (instance && !$defined(this.occluded))
- return this.occluded = instance;
- this.occluded = false;
- element.store(property || this.property, this);
- return this.occluded;
-script: Chain.Wait.js
-description: value, Adds a method to inject pauses between chained events.
-authors:
-- Aaron Newton
-requires:
-- core:1.2.4/Chain
-- core:1.2.4/Fx
-- /MooTools.More
-provides: [Chain.Wait]
-(function(){
- var wait = {
- wait: function(duration){
- return this.chain(function(){
- this.callChain.delay($pick(duration, 500), this);
- }.bind(this));
- Chain.implement(wait);
- if (window.Fx){
- Fx.implement(wait);
- ['Css', 'Tween', 'Elements'].each(function(cls){
- if (Fx[cls]) Fx[cls].implement(wait);
- Element.implement({
- chains: function(effects){
- $splat($pick(effects, ['tween', 'morph', 'reveal'])).each(function(effect){
- effect = this.get(effect);
- if (!effect) return;
- effect.setOptions({
- link:'chain'
- }, this);
- return this;
- pauseFx: function(duration, effect){
- this.chains(effect).get($pick(effect, 'tween')).wait(duration);
- return this;
-script: Array.Extras.js
-description: Extends the Array native object to include useful methods to work with arrays.
-authors:
-- Christoph Pojer
-requires:
-- core:1.2.4/Array
-provides: [Array.Extras]
-Array.implement({
- min: function(){
- return Math.min.apply(null, this);
- max: function(){
- return Math.max.apply(null, this);
- average: function(){
- return this.length ? this.sum() / this.length : 0;
- sum: function(){
- var result = 0, l = this.length;
- if (l){
- do {
- result += this[--l];
- } while (l);
- return result;
- unique: function(){
- return [].combine(this);
- shuffle: function(){
- for (var i = this.length; i && --i;){
- var temp = this[i], r = Math.floor(Math.random() * ( i + 1 ));
- this[i] = this[r];
- this[r] = temp;
- return this;
-script: Date.English.US.js
-description: Date messages for US English.
-authors:
-- Aaron Newton
-requires:
-- /Lang
-- /Date
-provides: [Date.English.US]
-MooTools.lang.set('en-US', 'Date', {
- months: ['January', 'February', 'March', 'April', 'May', 'June', 'July', 'August', 'September', 'October', 'November', 'December'],
- days: ['Sunday', 'Monday', 'Tuesday', 'Wednesday', 'Thursday', 'Friday', 'Saturday'],
- //culture's date order: MM/DD/YYYY
- dateOrder: ['month', 'date', 'year'],
- shortDate: '%m/%d/%Y',
- shortTime: '%I:%M%p',
- AM: 'AM',
- PM: 'PM',
- /* Date.Extras */
- ordinal: function(dayOfMonth){
- //1st, 2nd, 3rd, etc.
- return (dayOfMonth > 3 && dayOfMonth < 21) ? 'th' : ['th', 'st', 'nd', 'rd', 'th'][Math.min(dayOfMonth % 10, 4)];
- lessThanMinuteAgo: 'less than a minute ago',
- minuteAgo: 'about a minute ago',
- minutesAgo: '{delta} minutes ago',
- hourAgo: 'about an hour ago',
- hoursAgo: 'about {delta} hours ago',
- dayAgo: '1 day ago',
- daysAgo: '{delta} days ago',
- weekAgo: '1 week ago',
- weeksAgo: '{delta} weeks ago',
- monthAgo: '1 month ago',
- monthsAgo: '{delta} months ago',
- yearAgo: '1 year ago',
- yearsAgo: '{delta} years ago',
- lessThanMinuteUntil: 'less than a minute from now',
- minuteUntil: 'about a minute from now',
- minutesUntil: '{delta} minutes from now',
- hourUntil: 'about an hour from now',
- hoursUntil: 'about {delta} hours from now',
- dayUntil: '1 day from now',
- daysUntil: '{delta} days from now',
- weekUntil: '1 week from now',
- weeksUntil: '{delta} weeks from now',
- monthUntil: '1 month from now',
- monthsUntil: '{delta} months from now',
- yearUntil: '1 year from now',
- yearsUntil: '{delta} years from now'
-script: Date.js
-description: Extends the Date native object to include methods useful in managing dates.
-authors:
-- Aaron Newton
-- Nicholas Barthelemy - https://svn.nbarthelemy.com/date-js/
-- Harald Kirshner - mail [at] digitarald.de; http://digitarald.de
-- Scott Kyle - scott [at] appden.com; http://appden.com
-requires:
-- core:1.2.4/Array
-- core:1.2.4/String
-- core:1.2.4/Number
-- core:1.2.4/Lang
-- core:1.2.4/Date.English.US
-- /MooTools.More
-provides: [Date]
-(function(){
-var Date = this.Date;
-if (!Date.now) Date.now = $time;
-Date.Methods = {
- ms: 'Milliseconds',
- year: 'FullYear',
- min: 'Minutes',
- mo: 'Month',
- sec: 'Seconds',
- hr: 'Hours'
-['Date', 'Day', 'FullYear', 'Hours', 'Milliseconds', 'Minutes', 'Month', 'Seconds', 'Time', 'TimezoneOffset',
- 'Week', 'Timezone', 'GMTOffset', 'DayOfYear', 'LastMonth', 'LastDayOfMonth', 'UTCDate', 'UTCDay', 'UTCFullYear',
- 'AMPM', 'Ordinal', 'UTCHours', 'UTCMilliseconds', 'UTCMinutes', 'UTCMonth', 'UTCSeconds'].each(function(method){
- Date.Methods[method.toLowerCase()] = method;
-var pad = function(what, length){
- return new Array(length - String(what).length + 1).join('0') + what;
-Date.implement({
- set: function(prop, value){
- switch ($type(prop)){
- case 'object':
- for (var p in prop) this.set(p, prop[p]);
- break;
- case 'string':
- prop = prop.toLowerCase();
- var m = Date.Methods;
- if (m[prop]) this['set' + m[prop]](value);
- return this;
- get: function(prop){
- if (m[prop]) return this['get' + m[prop]]();
- return null;
- clone: function(){
- return new Date(this.get('time'));
- increment: function(interval, times){
- interval = interval || 'day';
- times = $pick(times, 1);
- switch (interval){
- case 'year':
- return this.increment('month', times * 12);
- case 'month':
- var d = this.get('date');
- this.set('date', 1).set('mo', this.get('mo') + times);
- return this.set('date', d.min(this.get('lastdayofmonth')));
- case 'week':
- return this.increment('day', times * 7);
- case 'day':
- return this.set('date', this.get('date') + times);
- if (!Date.units[interval]) throw new Error(interval + ' is not a supported interval');
- return this.set('time', this.get('time') + times * Date.units[interval]());
- decrement: function(interval, times){
- return this.increment(interval, -1 * $pick(times, 1));
- isLeapYear: function(){
- return Date.isLeapYear(this.get('year'));
- clearTime: function(){
- return this.set({hr: 0, min: 0, sec: 0, ms: 0});
- diff: function(date, resolution){
- if ($type(date) == 'string') date = Date.parse(date);
- return ((date - this) / Date.units[resolution || 'day'](3, 3)).toInt(); // non-leap year, 30-day month
- getLastDayOfMonth: function(){
- return Date.daysInMonth(this.get('mo'), this.get('year'));
- getDayOfYear: function(){
- return (Date.UTC(this.get('year'), this.get('mo'), this.get('date') + 1)
- - Date.UTC(this.get('year'), 0, 1)) / Date.units.day();
- getWeek: function(){
- return (this.get('dayofyear') / 7).ceil();
- getOrdinal: function(day){
- return Date.getMsg('ordinal', day || this.get('date'));
- getTimezone: function(){
- return this.toString()
- .replace(/^.*? ([A-Z]{3}).[0-9]{4}.*$/, '$1')
- .replace(/^.*?\(([A-Z])[a-z]+ ([A-Z])[a-z]+ ([A-Z])[a-z]+\)$/, '$1$2$3');
- getGMTOffset: function(){
- var off = this.get('timezoneOffset');
- return ((off > 0) ? '-' : '+') + pad((off.abs() / 60).floor(), 2) + pad(off % 60, 2);
- setAMPM: function(ampm){
- ampm = ampm.toUpperCase();
- var hr = this.get('hr');
- if (hr > 11 && ampm == 'AM') return this.decrement('hour', 12);
- else if (hr < 12 && ampm == 'PM') return this.increment('hour', 12);
- return this;
- getAMPM: function(){
- return (this.get('hr') < 12) ? 'AM' : 'PM';
- parse: function(str){
- this.set('time', Date.parse(str));
- return this;
- isValid: function(date) {
- return !!(date || this).valueOf();
- format: function(f){
- if (!this.isValid()) return 'invalid date';
- f = f || '%x %X';
- f = formats[f.toLowerCase()] || f; // replace short-hand with actual format
- var d = this;
- return f.replace(/%([a-z%])/gi,
- function($0, $1){
- switch ($1){
- case 'a': return Date.getMsg('days')[d.get('day')].substr(0, 3);
- case 'A': return Date.getMsg('days')[d.get('day')];
- case 'b': return Date.getMsg('months')[d.get('month')].substr(0, 3);
- case 'B': return Date.getMsg('months')[d.get('month')];
- case 'c': return d.toString();
- case 'd': return pad(d.get('date'), 2);
- case 'H': return pad(d.get('hr'), 2);
- case 'I': return ((d.get('hr') % 12) || 12);
- case 'j': return pad(d.get('dayofyear'), 3);
- case 'm': return pad((d.get('mo') + 1), 2);
- case 'M': return pad(d.get('min'), 2);
- case 'o': return d.get('ordinal');
- case 'p': return Date.getMsg(d.get('ampm'));
- case 'S': return pad(d.get('seconds'), 2);
- case 'U': return pad(d.get('week'), 2);
- case 'w': return d.get('day');
- case 'x': return d.format(Date.getMsg('shortDate'));
- case 'X': return d.format(Date.getMsg('shortTime'));
- case 'y': return d.get('year').toString().substr(2);
- case 'Y': return d.get('year');
- case 'T': return d.get('GMTOffset');
- case 'Z': return d.get('Timezone');
- return $1;
- toISOString: function(){
- return this.format('iso8601');
-Date.alias('toISOString', 'toJSON');
-Date.alias('diff', 'compare');
-Date.alias('format', 'strftime');
-var formats = {
- db: '%Y-%m-%d %H:%M:%S',
- compact: '%Y%m%dT%H%M%S',
- iso8601: '%Y-%m-%dT%H:%M:%S%T',
- rfc822: '%a, %d %b %Y %H:%M:%S %Z',
- 'short': '%d %b %H:%M',
- 'long': '%B %d, %Y %H:%M'
-var parsePatterns = [];
-var nativeParse = Date.parse;
-var parseWord = function(type, word, num){
- var ret = -1;
- var translated = Date.getMsg(type + 's');
- switch ($type(word)){
- case 'object':
- ret = translated[word.get(type)];
- break;
- case 'number':
- ret = translated[month - 1];
- if (!ret) throw new Error('Invalid ' + type + ' index: ' + index);
- break;
- case 'string':
- var match = translated.filter(function(name){
- return this.test(name);
- }, new RegExp('^' + word, 'i'));
- if (!match.length) throw new Error('Invalid ' + type + ' string');
- if (match.length > 1) throw new Error('Ambiguous ' + type);
- ret = match[0];
- return (num) ? translated.indexOf(ret) : ret;
-Date.extend({
- getMsg: function(key, args) {
- return MooTools.lang.get('Date', key, args);
- units: {
- ms: $lambda(1),
- second: $lambda(1000),
- minute: $lambda(60000),
- hour: $lambda(3600000),
- day: $lambda(86400000),
- week: $lambda(608400000),
- month: function(month, year){
- var d = new Date;
- return Date.daysInMonth($pick(month, d.get('mo')), $pick(year, d.get('year'))) * 86400000;
- year: function(year){
- year = year || new Date().get('year');
- return Date.isLeapYear(year) ? 31622400000 : 31536000000;
- daysInMonth: function(month, year){
- return [31, Date.isLeapYear(year) ? 29 : 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31][month];
- isLeapYear: function(year){
- return ((year % 4 === 0) && (year % 100 !== 0)) || (year % 400 === 0);
- parse: function(from){
- var t = $type(from);
- if (t == 'number') return new Date(from);
- if (t != 'string') return from;
- from = from.clean();
- if (!from.length) return null;
- var parsed;
- parsePatterns.some(function(pattern){
- var bits = pattern.re.exec(from);
- return (bits) ? (parsed = pattern.handler(bits)) : false;
- return parsed || new Date(nativeParse(from));
- parseDay: function(day, num){
- return parseWord('day', day, num);
- parseMonth: function(month, num){
- return parseWord('month', month, num);
- parseUTC: function(value){
- var localDate = new Date(value);
- var utcSeconds = Date.UTC(
- localDate.get('year'),
- localDate.get('mo'),
- localDate.get('date'),
- localDate.get('hr'),
- localDate.get('min'),
- localDate.get('sec')
- return new Date(utcSeconds);
- orderIndex: function(unit){
- return Date.getMsg('dateOrder').indexOf(unit) + 1;
- defineFormat: function(name, format){
- formats[name] = format;
- defineFormats: function(formats){
- for (var name in formats) Date.defineFormat(name, formats[name]);
- parsePatterns: parsePatterns, // this is deprecated
- defineParser: function(pattern){
- parsePatterns.push((pattern.re && pattern.handler) ? pattern : build(pattern));
- defineParsers: function(){
- Array.flatten(arguments).each(Date.defineParser);
- define2DigitYearStart: function(year){
- startYear = year % 100;
- startCentury = year - startYear;
-var startCentury = 1900;
-var startYear = 70;
-var regexOf = function(type){
- return new RegExp('(?:' + Date.getMsg(type).map(function(name){
- return name.substr(0, 3);
- }).join('|') + ')[a-z]*');
-var replacers = function(key){
- switch(key){
- case 'x': // iso8601 covers yyyy-mm-dd, so just check if month is first
- return ((Date.orderIndex('month') == 1) ? '%m[.-/]%d' : '%d[.-/]%m') + '([.-/]%y)?';
- case 'X':
- return '%H([.:]%M)?([.:]%S([.:]%s)?)? ?%p? ?%T?';
- return null;
-var keys = {
- d: /[0-2]?[0-9]|3[01]/,
- H: /[01]?[0-9]|2[0-3]/,
- I: /0?[1-9]|1[0-2]/,
- M: /[0-5]?\d/,
- s: /\d+/,
- o: /[a-z]*/,
- p: /[ap]\.?m\.?/,
- y: /\d{2}|\d{4}/,
- Y: /\d{4}/,
- T: /Z|[+-]\d{2}(?::?\d{2})?/
-keys.m = keys.I;
-keys.S = keys.M;
-var currentLanguage;
-var recompile = function(language){
- currentLanguage = language;
- keys.a = keys.A = regexOf('days');
- keys.b = keys.B = regexOf('months');
- parsePatterns.each(function(pattern, i){
- if (pattern.format) parsePatterns[i] = build(pattern.format);
-var build = function(format){
- if (!currentLanguage) return {format: format};
- var parsed = [];
- var re = (format.source || format) // allow format to be regex
- .replace(/%([a-z])/gi,
- function($0, $1){
- return replacers($1) || $0;
- ).replace(/\((?!\?)/g, '(?:') // make all groups non-capturing
- .replace(/ (?!\?|\*)/g, ',? ') // be forgiving with spaces and commas
- .replace(/%([a-z%])/gi,
- function($0, $1){
- var p = keys[$1];
- if (!p) return $1;
- parsed.push($1);
- return '(' + p.source + ')';
- ).replace(/\[a-z\]/gi, '[a-z\\u00c0-\\uffff]'); // handle unicode words
- return {
- format: format,
- re: new RegExp('^' + re + '$', 'i'),
- handler: function(bits){
- bits = bits.slice(1).associate(parsed);
- var date = new Date().clearTime();
- if ('d' in bits) handle.call(date, 'd', 1);
- if ('m' in bits || 'b' in bits || 'B' in bits) handle.call(date, 'm', 1);
- for (var key in bits) handle.call(date, key, bits[key]);
- return date;
-var handle = function(key, value){
- if (!value) return this;
- switch(key){
- case 'a': case 'A': return this.set('day', Date.parseDay(value, true));
- case 'b': case 'B': return this.set('mo', Date.parseMonth(value, true));
- case 'd': return this.set('date', value);
- case 'H': case 'I': return this.set('hr', value);
- case 'm': return this.set('mo', value - 1);
- case 'M': return this.set('min', value);
- case 'p': return this.set('ampm', value.replace(/\./g, ''));
- case 'S': return this.set('sec', value);
- case 's': return this.set('ms', ('0.' + value) * 1000);
- case 'w': return this.set('day', value);
- case 'Y': return this.set('year', value);
- case 'y':
- value = +value;
- if (value < 100) value += startCentury + (value < startYear ? 100 : 0);
- return this.set('year', value);
- case 'T':
- if (value == 'Z') value = '+00';
- var offset = value.match(/([+-])(\d{2}):?(\d{2})?/);
- offset = (offset[1] + '1') * (offset[2] * 60 + (+offset[3] || 0)) + this.getTimezoneOffset();
- return this.set('time', this - offset * 60000);
- return this;
-Date.defineParsers(
- '%Y([-./]%m([-./]%d((T| )%X)?)?)?', // "1999-12-31", "1999-12-31 11:59pm", "1999-12-31 23:59:59", ISO8601
- '%Y%m%d(T%H(%M%S?)?)?', // "19991231", "19991231T1159", compact
- '%x( %X)?', // "12/31", "12.31.99", "12-31-1999", "12/31/2008 11:59 PM"
- '%d%o( %b( %Y)?)?( %X)?', // "31st", "31st December", "31 Dec 1999", "31 Dec 1999 11:59pm"
- '%b( %d%o)?( %Y)?( %X)?', // Same as above with month and day switched
- '%Y %b( %d%o( %X)?)?', // Same as above with year coming first
- '%o %b %d %X %T %Y' // "Thu Oct 22 08:11:23 +0000 2009"
-MooTools.lang.addEvent('langChange', function(language){
- if (MooTools.lang.get('Date')) recompile(language);
-}).fireEvent('langChange', MooTools.lang.getCurrentLanguage());
-script: Date.Extras.js
-description: Extends the Date native object to include extra methods (on top of those in Date.js).
-authors:
-- Aaron Newton
-- Scott Kyle
-requires:
-- /Date
-provides: [Date.Extras]
-Date.implement({
- timeDiffInWords: function(relative_to){
- return Date.distanceOfTimeInWords(this, relative_to || new Date);
- timeDiff: function(to, joiner){
- if (to == null) to = new Date;
- var delta = ((to - this) / 1000).toInt();
- if (!delta) return '0s';
- var durations = {s: 60, m: 60, h: 24, d: 365, y: 0};
- var duration, vals = [];
- for (var step in durations){
- if (!delta) break;
- if ((duration = durations[step])){
- vals.unshift((delta % duration) + step);
- delta = (delta / duration).toInt();
- } else {
- vals.unshift(delta + step);
- return vals.join(joiner || ':');
-Date.alias('timeDiffInWords', 'timeAgoInWords');
-Date.extend({
- distanceOfTimeInWords: function(from, to){
- return Date.getTimePhrase(((to - from) / 1000).toInt());
- getTimePhrase: function(delta){
- var suffix = (delta < 0) ? 'Until' : 'Ago';
- if (delta < 0) delta *= -1;
- var units = {
- minute: 60,
- hour: 60,
- day: 24,
- week: 7,
- month: 52 / 12,
- year: 12,
- eon: Infinity
- var msg = 'lessThanMinute';
- for (var unit in units){
- var interval = units[unit];
- if (delta < 1.5 * interval){
- if (delta > 0.75 * interval) msg = unit;
- break;
- delta /= interval;
- msg = unit + 's';
- return Date.getMsg(msg + suffix).substitute({delta: delta.round()});
- // "today", "tomorrow", "yesterday"
- re: /^(?:tod|tom|yes)/i,
- var d = new Date().clearTime();
- switch(bits[0]){
- case 'tom': return d.increment();
- case 'yes': return d.decrement();
- default: return d;
- // "next Wednesday", "last Thursday"
- re: /^(next|last) ([a-z]+)$/i,
- var day = d.getDay();
- var newDay = Date.parseDay(bits[2], true);
- var addDays = newDay - day;
- if (newDay <= day) addDays += 7;
- if (bits[1] == 'last') addDays -= 7;
- return d.set('date', d.getDate() + addDays);
-script: Hash.Extras.js
-description: Extends the Hash native object to include getFromPath which allows a path notation to child elements.
-authors:
-- Aaron Newton
-requires:
-- core:1.2.4/Hash.base
-- /MooTools.More
-provides: [Hash.Extras]
-Hash.implement({
- getFromPath: function(notation){
- var source = this.getClean();
- notation.replace(/\[([^\]]+)\]|\.([^.[]+)|[^[.]+/g, function(match){
- if (!source) return null;
- var prop = arguments[2] || arguments[1] || arguments[0];
- source = (prop in source) ? source[prop] : null;
- return match;
- return source;
- cleanValues: function(method){
- method = method || $defined;
- this.each(function(v, k){
- if (!method(v)) this.erase(k);
- }, this);
- return this;
- run: function(){
- var args = arguments;
- if ($type(v) == 'function') v.run(args);
-script: String.Extras.js
-description: Extends the String native object to include methods useful in managing various kinds of strings (query strings, urls, html, etc).
-authors:
-- Aaron Newton
-- Guillermo Rauch
-requires:
-- core:1.2.4/$util
-- core:1.2.4/Array
-provides: [String.Extras]
-(function(){
-var special = ['Ã','à ','Ã?','á','Ã','â','Ã','ã','Ã','ä','Ã
','Ã¥','Ä','Ä','Ä','Ä
','Ä','Ä','Ä','Ä?','Ã','ç', 'Ä','Ä?','Ä?','Ä', 'Ã','è','Ã','é','Ã','ê','Ã','ë','Ä','Ä','Ä','Ä', 'Ä','Ä','Ã','ì','Ã?','Ã','Ã','î','Ã?','ï', 'Ĺ','ĺ','Ľ','ľ','Å?','Å', 'Ã','ñ','Å','Å','Å','Å','Ã','ò','Ã','ó','Ã','ô','Ã','õ','Ã','ö','Ã','ø','Å','Å','Å','Å','Å','Å ','Å¡','Å','Å','Å','Å', 'Ť','Å¥','Ť','Å¥','Å¢','Å£','Ã','ù','Ã','ú','Ã','û','Ã','ü','Å®','ů', 'Ÿ','ÿ','ý','Ã?','Ž','ž','Ź','ź','Å»','ż', 'Ã','þ','Ã?','ð','Ã','Å','Å','Ã','æ','µ'];
-var standard = ['A','a','A','a','A','a','A','a','Ae','ae','A','a','A','a','A','a','C','c','C','c','C','c','D','d','D','d', 'E','e','E','e','E','e','E','e','E','e','E','e','G','g','I','i','I','i','I','i','I','i','L','l','L','l','L','l', 'N','n','N','n','N','n', 'O','o','O','o','O','o','O','o','Oe','oe','O','o','o', 'R','r','R','r', 'S','s','S','s','S','s','T','t','T','t','T','t', 'U','u','U','u','U','u','Ue','ue','U','u','Y','y','Y','y','Z','z','Z','z','Z','z','TH','th','DH','dh','ss','OE','oe','AE','ae','u'];
-var tidymap = {
- "[\xa0\u2002\u2003\u2009]": " ",
- "\xb7": "*",
- "[\u2018\u2019]": "'",
- "[\u201c\u201d]": '"',
- "\u2026": "...",
- "\u2013": "-",
- "\u2014": "--",
- "\uFFFD": "»"
-var getRegForTag = function(tag, contents) {
- tag = tag || '';
- var regstr = contents ? "<" + tag + "[^>]*>([\\s\\S]*?)<\/" + tag + ">" : "<\/?" + tag + "([^>]+)?>";
- reg = new RegExp(regstr, "gi");
- return reg;
-String.implement({
- standardize: function(){
- var text = this;
- special.each(function(ch, i){
- text = text.replace(new RegExp(ch, 'g'), standard[i]);
- return text;
- repeat: function(times){
- return new Array(times + 1).join(this);
- pad: function(length, str, dir){
- if (this.length >= length) return this;
- var pad = (str == null ? ' ' : '' + str).repeat(length - this.length).substr(0, length - this.length);
- if (!dir || dir == 'right') return this + pad;
- if (dir == 'left') return pad + this;
- return pad.substr(0, (pad.length / 2).floor()) + this + pad.substr(0, (pad.length / 2).ceil());
- getTags: function(tag, contents){
- return this.match(getRegForTag(tag, contents)) || [];
- stripTags: function(tag, contents){
- return this.replace(getRegForTag(tag, contents), '');
- tidy: function(){
- var txt = this.toString();
- $each(tidymap, function(value, key){
- txt = txt.replace(new RegExp(key, 'g'), value);
- return txt;
-script: String.QueryString.js
-description: Methods for dealing with URI query strings.
-authors:
-- Sebastian Markbåge, Aaron Newton, Lennart Pilon, Valerio Proietti
-requires:
-- core:1.2.4/Array
-- /MooTools.More
-provides: [String.QueryString]
-String.implement({
- parseQueryString: function(){
- var vars = this.split(/[&;]/), res = {};
- if (vars.length) vars.each(function(val){
- var index = val.indexOf('='),
- keys = index < 0 ? [''] : val.substr(0, index).match(/[^\]\[]+/g),
- value = decodeURIComponent(val.substr(index + 1)),
- obj = res;
- keys.each(function(key, i){
- var current = obj[key];
- if(i < keys.length - 1)
- obj = obj[key] = current || {};
- else if($type(current) == 'array')
- current.push(value);
- else
- obj[key] = $defined(current) ? [current, value] : value;
- return res;
- cleanQueryString: function(method){
- return this.split('&').filter(function(val){
- key = index < 0 ? '' : val.substr(0, index),
- value = val.substr(index + 1);
- return method ? method.run([key, value]) : $chk(value);
- }).join('&');
-script: URI.js
-description: Provides methods useful in managing the window location and uris.
-authors:
-- Aaron Newton
-requires:
-- core:1.2.4/Selectors
-- /String.QueryString
-provides: URI
-var URI = new Class({
- options: {
- /*base: false*/
- regex: /^(?:(\w+):)?(?:\/\/(?:(?:([^:@\/]*):?([^:@\/]*))?@)?([^:\/?#]*)(?::(\d*))?)?(\.\.?$|(?:[^?#\/]*\/)*)([^?#]*)(?:\?([^#]*))?(?:#(.*))?/,
- parts: ['scheme', 'user', 'password', 'host', 'port', 'directory', 'file', 'query', 'fragment'],
- schemes: {http: 80, https: 443, ftp: 21, rtsp: 554, mms: 1755, file: 0},
- initialize: function(uri, options){
- var base = this.options.base || URI.base;
- if(!uri) uri = base;
- if (uri && uri.parsed) this.parsed = $unlink(uri.parsed);
- else this.set('value', uri.href || uri.toString(), base ? new URI(base) : false);
- parse: function(value, base){
- var bits = value.match(this.regex);
- if (!bits) return false;
- bits.shift();
- return this.merge(bits.associate(this.parts), base);
- merge: function(bits, base){
- if ((!bits || !bits.scheme) && (!base || !base.scheme)) return false;
- if (base){
- this.parts.every(function(part){
- if (bits[part]) return false;
- bits[part] = base[part] || '';
- return true;
- bits.port = bits.port || this.schemes[bits.scheme.toLowerCase()];
- bits.directory = bits.directory ? this.parseDirectory(bits.directory, base ? base.directory : '') : '/';
- return bits;
- parseDirectory: function(directory, baseDirectory) {
- directory = (directory.substr(0, 1) == '/' ? '' : (baseDirectory || '/')) + directory;
- if (!directory.test(URI.regs.directoryDot)) return directory;
- var result = [];
- directory.replace(URI.regs.endSlash, '').split('/').each(function(dir){
- if (dir == '..' && result.length > 0) result.pop();
- else if (dir != '.') result.push(dir);
- return result.join('/') + '/';
- combine: function(bits){
- return bits.value || bits.scheme + '://' +
- (bits.user ? bits.user + (bits.password ? ':' + bits.password : '') + '@' : '') +
- (bits.host || '') + (bits.port && bits.port != this.schemes[bits.scheme] ? ':' + bits.port : '') +
- (bits.directory || '/') + (bits.file || '') +
- (bits.query ? '?' + bits.query : '') +
- (bits.fragment ? '#' + bits.fragment : '');
- set: function(part, value, base){
- if (part == 'value'){
- var scheme = value.match(URI.regs.scheme);
- if (scheme) scheme = scheme[1];
- if (scheme && !$defined(this.schemes[scheme.toLowerCase()])) this.parsed = { scheme: scheme, value: value };
- else this.parsed = this.parse(value, (base || this).parsed) || (scheme ? { scheme: scheme, value: value } : { value: value });
- } else if (part == 'data') {
- this.setData(value);
- } else {
- this.parsed[part] = value;
- return this;
- get: function(part, base){
- switch(part){
- case 'value': return this.combine(this.parsed, base ? base.parsed : false);
- case 'data' : return this.getData();
- return this.parsed[part] || '';
- go: function(){
- document.location.href = this.toString();
- toURI: function(){
- return this;
- getData: function(key, part){
- var qs = this.get(part || 'query');
- if (!$chk(qs)) return key ? null : {};
- var obj = qs.parseQueryString();
- return key ? obj[key] : obj;
- setData: function(values, merge, part){
- if (typeof values == 'string'){
- data = this.getData();
- data[arguments[0]] = arguments[1];
- values = data;
- } else if (merge) {
- values = $merge(this.getData(), values);
- return this.set(part || 'query', Hash.toQueryString(values));
- clearData: function(part){
- return this.set(part || 'query', '');
-URI.prototype.toString = URI.prototype.valueOf = function(){
- return this.get('value');
-URI.regs = {
- endSlash: /\/$/,
- scheme: /^(\w+):/,
- directoryDot: /\.\/|\.$/
-URI.base = new URI(document.getElements('base[href]', true).getLast(), {base: document.location});
-String.implement({
- toURI: function(options){
- return new URI(this, options);
-script: URI.Relative.js
-description: Extends the URI class to add methods for computing relative and absolute urls.
-license: MIT-style license
-authors:
-requires:
-- /Class.refactor
-- /URI
-provides: [URI.Relative]
-URI = Class.refactor(URI, {
- combine: function(bits, base){
- if (!base || bits.scheme != base.scheme || bits.host != base.host || bits.port != base.port)
- return this.previous.apply(this, arguments);
- var end = bits.file + (bits.query ? '?' + bits.query : '') + (bits.fragment ? '#' + bits.fragment : '');
- if (!base.directory) return (bits.directory || (bits.file ? '' : './')) + end;
- var baseDir = base.directory.split('/'),
- relDir = bits.directory.split('/'),
- path = '',
- offset;
- var i = 0;
- for(offset = 0; offset < baseDir.length && offset < relDir.length && baseDir[offset] == relDir[offset]; offset++);
- for(i = 0; i < baseDir.length - offset - 1; i++) path += '../';
- for(i = offset; i < relDir.length - 1; i++) path += relDir[i] + '/';
- return (path || (bits.file ? '' : './')) + end;
- toAbsolute: function(base){
- base = new URI(base);
- if (base) base.set('directory', '').set('file', '');
- return this.toRelative(base);
- toRelative: function(base){
- return this.get('value', new URI(base));
-script: Element.Forms.js
-description: Extends the Element native object to include methods useful in managing inputs.
-authors:
-- Aaron Newton
-requires:
-- /MooTools.More
-provides: [Element.Forms]
-Element.implement({
- tidy: function(){
- this.set('value', this.get('value').tidy());
- getTextInRange: function(start, end){
- return this.get('value').substring(start, end);
- getSelectedText: function(){
- if (this.setSelectionRange) return this.getTextInRange(this.getSelectionStart(), this.getSelectionEnd());
- return document.selection.createRange().text;
- getSelectedRange: function() {
- if ($defined(this.selectionStart)) return {start: this.selectionStart, end: this.selectionEnd};
- var pos = {start: 0, end: 0};
- var range = this.getDocument().selection.createRange();
- if (!range || range.parentElement() != this) return pos;
- var dup = range.duplicate();
- if (this.type == 'text') {
- pos.start = 0 - dup.moveStart('character', -100000);
- pos.end = pos.start + range.text.length;
- } else {
- var value = this.get('value');
- var offset = value.length;
- dup.moveToElementText(this);
- dup.setEndPoint('StartToEnd', range);
- if(dup.text.length) offset -= value.match(/[\n\r]*$/)[0].length;
- pos.end = offset - dup.text.length;
- dup.setEndPoint('StartToStart', range);
- pos.start = offset - dup.text.length;
- return pos;
- getSelectionStart: function(){
- return this.getSelectedRange().start;
- getSelectionEnd: function(){
- return this.getSelectedRange().end;
- setCaretPosition: function(pos){
- if (pos == 'end') pos = this.get('value').length;
- this.selectRange(pos, pos);
- return this;
- getCaretPosition: function(){
- selectRange: function(start, end){
- if (this.setSelectionRange) {
- this.focus();
- this.setSelectionRange(start, end);
- } else {
- var diff = value.substr(start, end - start).replace(/\r/g, '').length;
- start = value.substr(0, start).replace(/\r/g, '').length;
- var range = this.createTextRange();
- range.collapse(true);
- range.moveEnd('character', start + diff);
- range.moveStart('character', start);
- range.select();
- return this;
- insertAtCursor: function(value, select){
- var pos = this.getSelectedRange();
- var text = this.get('value');
- this.set('value', text.substring(0, pos.start) + value + text.substring(pos.end, text.length));
- if ($pick(select, true)) this.selectRange(pos.start, pos.start + value.length);
- else this.setCaretPosition(pos.start + value.length);
- return this;
- insertAroundCursor: function(options, select){
- before: '',
- defaultMiddle: '',
- after: ''
- }, options);
- var value = this.getSelectedText() || options.defaultMiddle;
- if (pos.start == pos.end){
- this.set('value', text.substring(0, pos.start) + options.before + value + options.after + text.substring(pos.end, text.length));
- this.selectRange(pos.start + options.before.length, pos.end + options.before.length + value.length);
- } else {
- var current = text.substring(pos.start, pos.end);
- this.set('value', text.substring(0, pos.start) + options.before + current + options.after + text.substring(pos.end, text.length));
- var selStart = pos.start + options.before.length;
- if ($pick(select, true)) this.selectRange(selStart, selStart + current.length);
- else this.setCaretPosition(selStart + text.length);
- return this;
-script: Elements.From.js
-description: Returns a collection of elements from a string of html.
-authors:
-- Aaron Newton
-requires:
-- /MooTools.More
-provides: [Elements.from]
-Elements.from = function(text, excludeScripts){
- if ($pick(excludeScripts, true)) text = text.stripScripts();
- var container, match = text.match(/^\s*<(t[dhr]|tbody|tfoot|thead)/i);
- if (match){
- container = new Element('table');
- var tag = match[1].toLowerCase();
- if (['td', 'th', 'tr'].contains(tag)){
- container = new Element('tbody').inject(container);
- if (tag != 'tr') container = new Element('tr').inject(container);
- return (container || new Element('div')).set('html', text).getChildren();
-script: Element.Delegation.js
-description: Extends the Element native object to include the delegate method for more efficient event management.
-credits:
-- "Event checking based on the work of Daniel Steigerwald. License: MIT-style license. Copyright: Copyright (c) 2008 Daniel Steigerwald, daniel.steigerwald.cz"
-authors:
-- Aaron Newton
-- Daniel Steigerwald
-requires:
-- /MooTools.More
-provides: [Element.Delegation]
-(function(addEvent, removeEvent){
- var match = /(.*?):relay\(([^)]+)\)$/,
- combinators = /[+>~\s]/,
- splitType = function(type){
- var bits = type.match(match);
- return !bits ? {event: type} : {
- event: bits[1],
- selector: bits[2]
- check = function(e, selector){
- var t = e.target;
- if (combinators.test(selector = selector.trim())){
- var els = this.getElements(selector);
- for (var i = els.length; i--; ){
- var el = els[i];
- if (t == el || el.hasChild(t)) return el;
- } else {
- for ( ; t && t != this; t = t.parentNode){
- if (Element.match(t, selector)) return document.id(t);
- return null;
- addEvent: function(type, fn){
- var splitted = splitType(type);
- if (splitted.selector){
- var monitors = this.retrieve('$moo:delegateMonitors', {});
- if (!monitors[type]){
- var monitor = function(e){
- var el = check.call(this, e, splitted.selector);
- if (el) this.fireEvent(type, [e, el], 0, el);
- }.bind(this);
- monitors[type] = monitor;
- addEvent.call(this, splitted.event, monitor);
- return addEvent.apply(this, arguments);
- removeEvent: function(type, fn){
- var events = this.retrieve('events');
- if (!events || !events[type] || (fn && !events[type].keys.contains(fn))) return this;
- if (fn) removeEvent.apply(this, [type, fn]);
- else removeEvent.apply(this, type);
- events = this.retrieve('events');
- if (events && events[type] && events[type].keys.length == 0){
- removeEvent.apply(this, [splitted.event, monitors[type]]);
- delete monitors[type];
- return this;
- return removeEvent.apply(this, arguments);
- fireEvent: function(type, args, delay, bind){
- if (!events || !events[type]) return this;
- events[type].keys.each(function(fn){
- fn.create({bind: bind || this, delay: delay, arguments: args})();
- }, this);
- return this;
-})(Element.prototype.addEvent, Element.prototype.removeEvent);/*
-script: Element.Measure.js
-description: Extends the Element native object to include methods useful in measuring dimensions.
-credits: "Element.measure / .expose methods by Daniel Steigerwald License: MIT-style license. Copyright: Copyright (c) 2008 Daniel Steigerwald, daniel.steigerwald.cz"
-authors:
-- Aaron Newton
-requires:
-- core:1.2.4/Element.Style
-- core:1.2.4/Element.Dimensions
-- /MooTools.More
-provides: [Element.Measure]
- measure: function(fn){
- var vis = function(el) {
- return !!(!el || el.offsetHeight || el.offsetWidth);
- if (vis(this)) return fn.apply(this);
- var parent = this.getParent(),
- restorers = [],
- toMeasure = [];
- while (!vis(parent) && parent != document.body) {
- toMeasure.push(parent.expose());
- parent = parent.getParent();
- var restore = this.expose();
- var result = fn.apply(this);
- restore();
- toMeasure.each(function(restore){
- restore();
- return result;
- expose: function(){
- if (this.getStyle('display') != 'none') return $empty;
- var before = this.style.cssText;
- this.setStyles({
- display: 'block',
- position: 'absolute',
- visibility: 'hidden'
- return function(){
- this.style.cssText = before;
- }.bind(this);
- getDimensions: function(options){
- options = $merge({computeSize: false},options);
- var dim = {};
- var getSize = function(el, options){
- return (options.computeSize)?el.getComputedSize(options):el.getSize();
- var parent = this.getParent('body');
- if (parent && this.getStyle('display') == 'none'){
- dim = this.measure(function(){
- return getSize(this, options);
- } else if (parent){
- try { //safari sometimes crashes here, so catch it
- dim = getSize(this, options);
- }catch(e){}
- } else {
- dim = {x: 0, y: 0};
- return $chk(dim.x) ? $extend(dim, {width: dim.x, height: dim.y}) : $extend(dim, {x: dim.width, y: dim.height});
- getComputedSize: function(options){
- styles: ['padding','border'],
- plains: {
- height: ['top','bottom'],
- width: ['left','right']
- mode: 'both'
- }, options);
- var size = {width: 0,height: 0};
- switch (options.mode){
- case 'vertical':
- delete size.width;
- delete options.plains.width;
- break;
- case 'horizontal':
- delete size.height;
- delete options.plains.height;
- break;
- var getStyles = [];
- //this function might be useful in other places; perhaps it should be outside this function?
- $each(options.plains, function(plain, key){
- plain.each(function(edge){
- options.styles.each(function(style){
- getStyles.push((style == 'border') ? style + '-' + edge + '-' + 'width' : style + '-' + edge);
- var styles = {};
- getStyles.each(function(style){ styles[style] = this.getComputedStyle(style); }, this);
- var subtracted = [];
- $each(options.plains, function(plain, key){ //keys: width, height, plains: ['left', 'right'], ['top','bottom']
- var capitalized = key.capitalize();
- size['total' + capitalized] = size['computed' + capitalized] = 0;
- plain.each(function(edge){ //top, left, right, bottom
- size['computed' + edge.capitalize()] = 0;
- getStyles.each(function(style, i){ //padding, border, etc.
- //'padding-left'.test('left') size['totalWidth'] = size['width'] + [padding-left]
- if (style.test(edge)){
- styles[style] = styles[style].toInt() || 0; //styles['padding-left'] = 5;
- size['total' + capitalized] = size['total' + capitalized] + styles[style];
- size['computed' + edge.capitalize()] = size['computed' + edge.capitalize()] + styles[style];
- //if width != width (so, padding-left, for instance), then subtract that from the total
- if (style.test(edge) && key != style &&
- (style.test('border') || style.test('padding')) && !subtracted.contains(style)){
- subtracted.push(style);
- size['computed' + capitalized] = size['computed' + capitalized]-styles[style];
- ['Width', 'Height'].each(function(value){
- var lower = value.toLowerCase();
- if(!$chk(size[lower])) return;
- size[lower] = size[lower] + this['offset' + value] + size['computed' + value];
- size['total' + value] = size[lower] + size['total' + value];
- delete size['computed' + value];
- }, this);
- return $extend(styles, size);
-script: Element.Pin.js
-description: Extends the Element native object to include the pin method useful for fixed positioning for elements.
-authors:
-- Aaron Newton
-requires:
-- /MooTools.More
-provides: [Element.Pin]
-(function(){
- var supportsPositionFixed = false;
- window.addEvent('domready', function(){
- var test = new Element('div').setStyles({
- position: 'fixed',
- top: 0,
- right: 0
- }).inject(document.body);
- supportsPositionFixed = (test.offsetTop === 0);
- test.dispose();
- pin: function(enable){
- if (this.getStyle('display') == 'none') return null;
- var p,
- scroll = window.getScroll();
- if (enable !== false){
- p = this.getPosition();
- if (!this.retrieve('pinned')){
- var pos = {
- top: p.y - scroll.y,
- left: p.x - scroll.x
- if (supportsPositionFixed){
- this.setStyle('position', 'fixed').setStyles(pos);
- } else {
- this.store('pinnedByJS', true);
- this.setStyles({
- top: p.y,
- left: p.x
- }).addClass('isPinned');
- this.store('scrollFixer', (function(){
- if (this.retrieve('pinned'))
- var scroll = window.getScroll();
- this.setStyles({
- top: pos.top.toInt() + scroll.y,
- left: pos.left.toInt() + scroll.x
- }).bind(this));
- window.addEvent('scroll', this.retrieve('scrollFixer'));
- this.store('pinned', true);
- } else {
- var op;
- if (!Browser.Engine.trident){
- var parent = this.getParent();
- op = (parent.getComputedStyle('position') != 'static' ? parent : parent.getOffsetParent());
- p = this.getPosition(op);
- this.store('pinned', false);
- var reposition;
- if (supportsPositionFixed && !this.retrieve('pinnedByJS')){
- reposition = {
- top: p.y + scroll.y,
- left: p.x + scroll.x
- } else {
- this.store('pinnedByJS', false);
- window.removeEvent('scroll', this.retrieve('scrollFixer'));
- reposition = {
- top: p.y,
- left: p.x
- this.setStyles($merge(reposition, {position: 'absolute'})).removeClass('isPinned');
- return this;
- unpin: function(){
- return this.pin(false);
- togglepin: function(){
- this.pin(!this.retrieve('pinned'));
-script: Element.Position.js
-description: Extends the Element native object to include methods useful positioning elements relative to others.
-authors:
-- Aaron Newton
-requires:
-- /Element.Measure
-provides: [Elements.Position]
-(function(){
-var original = Element.prototype.position;
- position: function(options){
- //call original position if the options are x/y values
- if (options && ($defined(options.x) || $defined(options.y))) return original ? original.apply(this, arguments) : this;
- $each(options||{}, function(v, k){ if (!$defined(v)) delete options[k]; });
- // minimum: { x: 0, y: 0 },
- // maximum: { x: 0, y: 0},
- relativeTo: document.body,
- position: {
- x: 'center', //left, center, right
- y: 'center' //top, center, bottom
- edge: false,
- offset: {x: 0, y: 0},
- returnPos: false,
- relFixedPosition: false,
- ignoreMargins: false,
- ignoreScroll: false,
- allowNegative: false
- }, options);
- //compute the offset of the parent positioned element if this element is in one
- var parentOffset = {x: 0, y: 0},
- parentPositioned = false;
- /* dollar around getOffsetParent should not be necessary, but as it does not return
- * a mootools extended element in IE, an error occurs on the call to expose. See:
- * http://mootools.lighthouseapp.com/projects/2706/tickets/333-element-getoffsetparent-inconsistency-between-ie-and-other-browsers */
- var offsetParent = this.measure(function(){
- return document.id(this.getOffsetParent());
- if (offsetParent && offsetParent != this.getDocument().body){
- parentOffset = offsetParent.measure(function(){
- return this.getPosition();
- parentPositioned = offsetParent != document.id(options.relativeTo);
- options.offset.x = options.offset.x - parentOffset.x;
- options.offset.y = options.offset.y - parentOffset.y;
- //upperRight, bottomRight, centerRight, upperLeft, bottomLeft, centerLeft
- //topRight, topLeft, centerTop, centerBottom, center
- var fixValue = function(option){
- if ($type(option) != 'string') return option;
- option = option.toLowerCase();
- var val = {};
- if (option.test('left')) val.x = 'left';
- else if (option.test('right')) val.x = 'right';
- else val.x = 'center';
- if (option.test('upper') || option.test('top')) val.y = 'top';
- else if (option.test('bottom')) val.y = 'bottom';
- else val.y = 'center';
- return val;
- options.edge = fixValue(options.edge);
- options.position = fixValue(options.position);
- if (!options.edge){
- if (options.position.x == 'center' && options.position.y == 'center') options.edge = {x:'center', y:'center'};
- else options.edge = {x:'left', y:'top'};
- this.setStyle('position', 'absolute');
- var rel = document.id(options.relativeTo) || document.body,
- calc = rel == document.body ? window.getScroll() : rel.getPosition(),
- top = calc.y, left = calc.x;
- var dim = this.getDimensions({computeSize: true, styles:['padding', 'border','margin']});
- var pos = {},
- prefY = options.offset.y,
- prefX = options.offset.x,
- winSize = window.getSize();
- switch(options.position.x){
- case 'left':
- pos.x = left + prefX;
- break;
- case 'right':
- pos.x = left + prefX + rel.offsetWidth;
- break;
- default: //center
- pos.x = left + ((rel == document.body ? winSize.x : rel.offsetWidth)/2) + prefX;
- break;
- switch(options.position.y){
- case 'top':
- pos.y = top + prefY;
- break;
- case 'bottom':
- pos.y = top + prefY + rel.offsetHeight;
- break;
- default: //center
- pos.y = top + ((rel == document.body ? winSize.y : rel.offsetHeight)/2) + prefY;
- break;
- if (options.edge){
- var edgeOffset = {};
- switch(options.edge.x){
- case 'left':
- edgeOffset.x = 0;
- break;
- case 'right':
- edgeOffset.x = -dim.x-dim.computedRight-dim.computedLeft;
- break;
- default: //center
- edgeOffset.x = -(dim.totalWidth/2);
- break;
- switch(options.edge.y){
- case 'top':
- edgeOffset.y = 0;
- break;
- case 'bottom':
- edgeOffset.y = -dim.y-dim.computedTop-dim.computedBottom;
- break;
- default: //center
- edgeOffset.y = -(dim.totalHeight/2);
- break;
- pos.x += edgeOffset.x;
- pos.y += edgeOffset.y;
- pos = {
- left: ((pos.x >= 0 || parentPositioned || options.allowNegative) ? pos.x : 0).toInt(),
- top: ((pos.y >= 0 || parentPositioned || options.allowNegative) ? pos.y : 0).toInt()
- var xy = {left: 'x', top: 'y'};
- ['minimum', 'maximum'].each(function(minmax) {
- ['left', 'top'].each(function(lr) {
- var val = options[minmax] ? options[minmax][xy[lr]] : null;
- if (val != null && pos[lr] < val) pos[lr] = val;
- if (rel.getStyle('position') == 'fixed' || options.relFixedPosition){
- var winScroll = window.getScroll();
- pos.top+= winScroll.y;
- pos.left+= winScroll.x;
- if (options.ignoreScroll) {
- var relScroll = rel.getScroll();
- pos.top-= relScroll.y;
- pos.left-= relScroll.x;
- if (options.ignoreMargins) {
- pos.left += (
- options.edge.x == 'right' ? dim['margin-right'] :
- options.edge.x == 'center' ? -dim['margin-left'] + ((dim['margin-right'] + dim['margin-left'])/2) :
- - dim['margin-left']
- pos.top += (
- options.edge.y == 'bottom' ? dim['margin-bottom'] :
- options.edge.y == 'center' ? -dim['margin-top'] + ((dim['margin-bottom'] + dim['margin-top'])/2) :
- - dim['margin-top']
- pos.left = Math.ceil(pos.left);
- pos.top = Math.ceil(pos.top);
- if (options.returnPos) return pos;
- else this.setStyles(pos);
- return this;
-script: Element.Shortcuts.js
-description: Extends the Element native object to include some shortcut methods.
-authors:
-- Aaron Newton
-requires:
-- /MooTools.More
-provides: [Element.Shortcuts]
- isDisplayed: function(){
- return this.getStyle('display') != 'none';
- isVisible: function(){
- var w = this.offsetWidth,
- h = this.offsetHeight;
- return (w == 0 && h == 0) ? false : (w > 0 && h > 0) ? true : this.isDisplayed();
- toggle: function(){
- return this[this.isDisplayed() ? 'hide' : 'show']();
- hide: function(){
- var d;
- try {
- //IE fails here if the element is not in the dom
- d = this.getStyle('display');
- } catch(e){}
- return this.store('originalDisplay', d || '').setStyle('display', 'none');
- show: function(display){
- display = display || this.retrieve('originalDisplay') || 'block';
- return this.setStyle('display', (display == 'none') ? 'block' : display);
- swapClass: function(remove, add){
- return this.removeClass(remove).addClass(add);
-script: IframeShim.js
-description: Defines IframeShim, a class for obscuring select lists and flash objects in IE.
-authors:
-- Aaron Newton
-requires:
-- core:1.2.4/Options Events
-- /Element.Position
-- /Class.Occlude
-provides: [IframeShim]
-var IframeShim = new Class({
- Implements: [Options, Events, Class.Occlude],
- options: {
- className: 'iframeShim',
- src: 'javascript:false;document.write("");',
- display: false,
- zIndex: null,
- margin: 0,
- browsers: (Browser.Engine.trident4 || (Browser.Engine.gecko && !Browser.Engine.gecko19 && Browser.Platform.mac))
- property: 'IframeShim',
- initialize: function(element, options){
- this.element = document.id(element);
- if (this.occlude()) return this.occluded;
- this.setOptions(options);
- this.makeShim();
- return this;
- makeShim: function(){
- if(this.options.browsers){
- var zIndex = this.element.getStyle('zIndex').toInt();
- if (!zIndex){
- zIndex = 1;
- var pos = this.element.getStyle('position');
- if (pos == 'static' || !pos) this.element.setStyle('position', 'relative');
- this.element.setStyle('zIndex', zIndex);
- zIndex = ($chk(this.options.zIndex) && zIndex > this.options.zIndex) ? this.options.zIndex : zIndex - 1;
- if (zIndex < 0) zIndex = 1;
- this.shim = new Element('iframe', {
- src: this.options.src,
- scrolling: 'no',
- frameborder: 0,
- styles: {
- zIndex: zIndex,
- border: 'none',
- filter: 'progid:DXImageTransform.Microsoft.Alpha(style=0,opacity=0)'
- 'class': this.options.className
- }).store('IframeShim', this);
- var inject = (function(){
- this.shim.inject(this.element, 'after');
- this[this.options.display ? 'show' : 'hide']();
- this.fireEvent('inject');
- }).bind(this);
- if (!IframeShim.ready) window.addEvent('load', inject);
- else inject();
- } else {
- this.position = this.hide = this.show = this.dispose = $lambda(this);
- position: function(){
- if (!IframeShim.ready || !this.shim) return this;
- var size = this.element.measure(function(){
- return this.getSize();
- if (this.options.margin != undefined){
- size.x = size.x - (this.options.margin * 2);
- size.y = size.y - (this.options.margin * 2);
- this.options.offset.x += this.options.margin;
- this.options.offset.y += this.options.margin;
- this.shim.set({width: size.x, height: size.y}).position({
- relativeTo: this.element,
- offset: this.options.offset
- return this;
- hide: function(){
- if (this.shim) this.shim.setStyle('display', 'none');
- return this;
- show: function(){
- if (this.shim) this.shim.setStyle('display', 'block');
- return this.position();
- dispose: function(){
- if (this.shim) this.shim.dispose();
- return this;
- destroy: function(){
- if (this.shim) this.shim.destroy();
- return this;
-window.addEvent('load', function(){
- IframeShim.ready = true;
-script: Mask.js
-description: Creates a mask element to cover another.
-authors:
-- Aaron Newton
-requires:
-- core:1.2.4/Events
-- /Class.Binds
-- /IframeShim
-provides: [Mask]
-var Mask = new Class({
- Implements: [Options, Events],
- Binds: ['position'],
- options: {
- // onShow: $empty,
- // onHide: $empty,
- // onDestroy: $empty,
- // onClick: $empty,
- //inject: {
- // where: 'after',
- // target: null,
- // hideOnClick: false,
- // id: null,
- // destroyOnHide: false,
- style: {},
- 'class': 'mask',
- maskMargins: false,
- useIframeShim: true,
- iframeShimOptions: {}
- initialize: function(target, options){
- this.target = document.id(target) || document.id(document.body);
- this.target.store('Mask', this);
- this.render();
- this.inject();
- render: function() {
- this.element = new Element('div', {
- 'class': this.options['class'],
- id: this.options.id || 'mask-' + $time(),
- styles: $merge(this.options.style, {
- display: 'none'
- events: {
- click: function(){
- this.fireEvent('click');
- if (this.options.hideOnClick) this.hide();
- }.bind(this)
- this.hidden = true;
- toElement: function(){
- return this.element;
- inject: function(target, where){
- where = where || this.options.inject ? this.options.inject.where : '' || this.target == document.body ? 'inside' : 'after';
- target = target || this.options.inject ? this.options.inject.target : '' || this.target;
- this.element.inject(target, where);
- if (this.options.useIframeShim) {
- this.shim = new IframeShim(this.element, this.options.iframeShimOptions);
- this.addEvents({
- show: this.shim.show.bind(this.shim),
- hide: this.shim.hide.bind(this.shim),
- destroy: this.shim.destroy.bind(this.shim)
- this.resize(this.options.width, this.options.height);
- this.element.position({
- relativeTo: this.target,
- position: 'topLeft',
- ignoreMargins: !this.options.maskMargins,
- ignoreScroll: this.target == document.body
- return this;
- resize: function(x, y){
- var opt = {
- styles: ['padding', 'border']
- if (this.options.maskMargins) opt.styles.push('margin');
- var dim = this.target.getComputedSize(opt);
- if (this.target == document.body) {
- var win = window.getSize();
- if (dim.totalHeight < win.y) dim.totalHeight = win.y;
- if (dim.totalWidth < win.x) dim.totalWidth = win.x;
- this.element.setStyles({
- width: $pick(x, dim.totalWidth, dim.x),
- height: $pick(y, dim.totalHeight, dim.y)
- return this;
- show: function(){
- if (!this.hidden) return this;
- window.addEvent('resize', this.position);
- this.position();
- this.showMask.apply(this, arguments);
- return this;
- showMask: function(){
- this.element.setStyle('display', 'block');
- this.hidden = false;
- this.fireEvent('show');
- hide: function(){
- if (this.hidden) return this;
- window.removeEvent('resize', this.position);
- this.hideMask.apply(this, arguments);
- if (this.options.destroyOnHide) return this.destroy();
- return this;
- hideMask: function(){
- this.element.setStyle('display', 'none');
- this.fireEvent('hide');
- this[this.hidden ? 'show' : 'hide']();
- this.hide();
- this.element.destroy();
- this.fireEvent('destroy');
- this.target.eliminate('mask');
-Element.Properties.mask = {
- set: function(options){
- var mask = this.retrieve('mask');
- return this.eliminate('mask').store('mask:options', options);
- get: function(options){
- if (options || !this.retrieve('mask')){
- if (this.retrieve('mask')) this.retrieve('mask').destroy();
- if (options || !this.retrieve('mask:options')) this.set('mask', options);
- this.store('mask', new Mask(this, this.retrieve('mask:options')));
- return this.retrieve('mask');
- mask: function(options){
- this.get('mask', options).show();
- return this;
- unmask: function(){
- this.get('mask').hide();
- return this;
-script: Spinner.js
-description: Adds a semi-transparent overlay over a dom element with a spinnin ajax icon.
-authors:
-- Aaron Newton
-requires:
-- core:1.2.4/Fx.Tween
-- /Class.refactor
-- /Mask
-provides: [Spinner]
-var Spinner = new Class({
- Extends: Mask,
- options: {
- /*message: false,*/
- 'class':'spinner',
- containerPosition: {},
- content: {
- 'class':'spinner-content'
- messageContainer: {
- 'class':'spinner-msg'
- img: {
- 'class':'spinner-img'
- fxOptions: {
- link: 'chain'
- initialize: function(){
- this.parent.apply(this, arguments);
- this.target.store('spinner', this);
- //add this to events for when noFx is true; parent methods handle hide/show
- var deactivate = function(){ this.active = false; }.bind(this);
- this.addEvents({
- hide: deactivate,
- show: deactivate
- render: function(){
- this.parent();
- this.element.set('id', this.options.id || 'spinner-'+$time());
- this.content = document.id(this.options.content) || new Element('div', this.options.content);
- this.content.inject(this.element);
- if (this.options.message) {
- this.msg = document.id(this.options.message) || new Element('p', this.options.messageContainer).appendText(this.options.message);
- this.msg.inject(this.content);
- if (this.options.img) {
- this.img = document.id(this.options.img) || new Element('div', this.options.img);
- this.img.inject(this.content);
- this.element.set('tween', this.options.fxOptions);
- show: function(noFx){
- if (this.active) return this.chain(this.show.bind(this));
- if (!this.hidden) {
- this.callChain.delay(20, this);
- return this;
- this.active = true;
- return this.parent(noFx);
- showMask: function(noFx){
- var pos = function(){
- this.content.position($merge({
- }, this.options.containerPosition));
- }.bind(this);
- if (noFx) {
- this.parent();
- pos();
- } else {
- display: 'block',
- opacity: 0
- }).tween('opacity', this.options.style.opacity || 0.9);
- pos();
- this.callChain();
- hide: function(noFx){
- if (this.active) return this.chain(this.hide.bind(this));
- if (this.hidden) {
- return this;
- hideMask: function(noFx){
- if (noFx) return this.parent();
- this.element.tween('opacity', 0).get('tween').chain(function(){
- this.callChain();
- }.bind(this));
- this.content.destroy();
- this.parent();
- this.target.eliminate('spinner');
-Spinner.implement(new Chain);
-if (window.Request) {
- Request = Class.refactor(Request, {
- options: {
- useSpinner: false,
- spinnerOptions: {},
- spinnerTarget: false
- initialize: function(options){
- this._send = this.send;
- this.send = function(options){
- if (this.spinner) this.spinner.chain(this._send.bind(this, options)).show();
- else this._send(options);
- return this;
- this.previous(options);
- var update = document.id(this.options.spinnerTarget) || document.id(this.options.update);
- if (this.options.useSpinner && update) {
- this.spinner = update.get('spinner', this.options.spinnerOptions);
- ['onComplete', 'onException', 'onCancel'].each(function(event){
- this.addEvent(event, this.spinner.hide.bind(this.spinner));
- }, this);
- getSpinner: function(){
- return this.spinner;
-Element.Properties.spinner = {
- var spinner = this.retrieve('spinner');
- return this.eliminate('spinner').store('spinner:options', options);
- if (options || !this.retrieve('spinner')){
- if (this.retrieve('spinner')) this.retrieve('spinner').destroy();
- if (options || !this.retrieve('spinner:options')) this.set('spinner', options);
- new Spinner(this, this.retrieve('spinner:options'));
- return this.retrieve('spinner');
- spin: function(options){
- this.get('spinner', options).show();
- return this;
- unspin: function(){
- var opt = Array.link(arguments, {options: Object.type, callback: Function.type});
- this.get('spinner', opt.options).hide(opt.callback);
- return this;
-script: Form.Request.js
-description: Handles the basic functionality of submitting a form and updating a dom element with the result.
-authors:
-- Aaron Newton
-requires:
-- core:1.2.4/Element.Event
-- core:1.2.4/Request.HTML
-- /Class.Binds
-- /Class.Occlude
-- /Spinner
-provides: [Form.Request]
-if (!window.Form) window.Form = {};
-(function(){
- Form.Request = new Class({
- Binds: ['onSubmit', 'onFormValidate'],
- options: {
- //onFailure: $empty,
- //onSuccess: #empty, //aliased to onComplete,
- //onSend: $empty
- requestOptions: {
- evalScripts: true,
- useSpinner: true,
- emulation: false,
- link: 'ignore'
- extraData: {},
- resetForm: true
- property: 'form.request',
- initialize: function(form, update, options) {
- this.element = document.id(form);
- this.update = document.id(update);
- this.makeRequest();
- if (this.options.resetForm) {
- this.request.addEvent('success', function(){
- $try(function(){ this.element.reset(); }.bind(this));
- if (window.OverText) OverText.update();
- }.bind(this));
- this.attach();
- toElement: function() {
- makeRequest: function(){
- this.request = new Request.HTML($merge({
- update: this.update,
- emulation: false,
- spinnerTarget: this.element,
- method: this.element.get('method') || 'post'
- }, this.options.requestOptions)).addEvents({
- success: function(text, xml){
- ['complete', 'success'].each(function(evt){
- this.fireEvent(evt, [this.update, text, xml]);
- }, this);
- }.bind(this),
- failure: function(xhr){
- this.fireEvent('complete').fireEvent('failure', xhr);
- }.bind(this),
- exception: function(){
- this.fireEvent('failure', xhr);
- }.bind(this)
- attach: function(attach){
- attach = $pick(attach, true);
- method = attach ? 'addEvent' : 'removeEvent';
- var fv = this.element.retrieve('validator');
- if (fv) fv[method]('onFormValidate', this.onFormValidate);
- if (!fv || !attach) this.element[method]('submit', this.onSubmit);
- detach: function(){
- this.attach(false);
- //public method
- enable: function(){
- this.attach();
- //public method
- disable: function(){
- this.detach();
- onFormValidate: function(valid, form, e) {
- if (valid || (fv && !fv.options.stopOnFailure)) {
- if (e && e.stop) e.stop();
- this.send();
- onSubmit: function(e){
- if (this.element.retrieve('validator')) {
- //form validator was created after Form.Request
- this.detach();
- return;
- e.stop();
- this.send();
- send: function(){
- var str = this.element.toQueryString().trim();
- var data = $H(this.options.extraData).toQueryString();
- if (str) str += "&" + data;
- else str = data;
- this.fireEvent('send', [this.element, str.parseQueryString()]);
- this.request.send({data: str, url: this.element.get("action")});
- return this;
- Element.Properties.formRequest = {
- set: function(){
- var opt = Array.link(arguments, {options: Object.type, update: Element.type, updateId: String.type});
- var update = opt.update || opt.updateId;
- var updater = this.retrieve('form.request');
- if (update) {
- if (updater) updater.update = document.id(update);
- this.store('form.request:update', update);
- if (opt.options) {
- if (updater) updater.setOptions(opt.options);
- this.store('form.request:options', opt.options);
- return this;
- get: function(){
- if (opt.options || update || !this.retrieve('form.request')){
- if (opt.options || !this.retrieve('form.request:options')) this.set('form.request', opt.options);
- if (update) this.set('form.request', update);
- this.store('form.request', new Form.Request(this, this.retrieve('form.request:update'), this.retrieve('form.request:options')));
- return this.retrieve('form.request');
- formUpdate: function(update, options){
- this.get('form.request', update, options).send();
- return this;
-script: Fx.Reveal.js
-description: Defines Fx.Reveal, a class that shows and hides elements with a transition.
-authors:
-- Aaron Newton
-requires:
-- core:1.2.4/Fx.Morph
-- /Element.Shortcuts
-- /Element.Measure
-provides: [Fx.Reveal]
-Fx.Reveal = new Class({
- Extends: Fx.Morph,
- options: {/*
- onShow: $empty(thisElement),
- onHide: $empty(thisElement),
- onComplete: $empty(thisElement),
- heightOverride: null,
- widthOverride: null, */
- link: 'cancel',
- styles: ['padding', 'border', 'margin'],
- transitionOpacity: !Browser.Engine.trident4,
- mode: 'vertical',
- display: 'block',
- hideInputs: Browser.Engine.trident ? 'select, input, textarea, object, embed' : false
- dissolve: function(){
- try {
- if (!this.hiding && !this.showing){
- if (this.element.getStyle('display') != 'none'){
- this.hiding = true;
- this.showing = false;
- this.cssText = this.element.style.cssText;
- var startStyles = this.element.getComputedSize({
- styles: this.options.styles,
- mode: this.options.mode
- this.element.setStyle('display', this.options.display);
- if (this.options.transitionOpacity) startStyles.opacity = 1;
- var zero = {};
- $each(startStyles, function(style, name){
- zero[name] = [style, 0];
- }, this);
- this.element.setStyle('overflow', 'hidden');
- var hideThese = this.options.hideInputs ? this.element.getElements(this.options.hideInputs) : null;
- this.$chain.unshift(function(){
- if (this.hidden){
- this.hiding = false;
- startStyles[name] = style;
- }, this);
- this.element.style.cssText = this.cssText;
- if (hideThese) hideThese.setStyle('visibility', 'visible');
- this.fireEvent('hide', this.element);
- this.callChain();
- }.bind(this));
- if (hideThese) hideThese.setStyle('visibility', 'hidden');
- this.start(zero);
- } else {
- this.callChain.delay(10, this);
- this.fireEvent('complete', this.element);
- } else if (this.options.link == 'chain'){
- this.chain(this.dissolve.bind(this));
- } else if (this.options.link == 'cancel' && !this.hiding){
- this.cancel();
- this.dissolve();
- } catch(e){
- return this;
- reveal: function(){
- try {
- if (!this.showing && !this.hiding){
- if (this.element.getStyle('display') == 'none' ||
- this.element.getStyle('visiblity') == 'hidden' ||
- this.element.getStyle('opacity') == 0){
- this.showing = true;
- this.hiding = this.hidden = false;
- var startStyles;
- //toggle display, but hide it
- this.element.measure(function(){
- //create the styles for the opened/visible state
- startStyles = this.element.getComputedSize({
- }.bind(this));
- //if we're overridding height/width
- if ($chk(this.options.heightOverride)) startStyles.height = this.options.heightOverride.toInt();
- if ($chk(this.options.widthOverride)) startStyles.width = this.options.widthOverride.toInt();
- if (this.options.transitionOpacity) {
- this.element.setStyle('opacity', 0);
- startStyles.opacity = 1;
- //create the zero state for the beginning of the transition
- var zero = {
- height: 0,
- display: this.options.display
- $each(startStyles, function(style, name){ zero[name] = 0; });
- //set to zero
- this.element.setStyles($merge(zero, {overflow: 'hidden'}));
- //hide inputs
- //start the effect
- this.start(startStyles);
- if (!this.hidden) this.showing = false;
- this.callChain();
- this.fireEvent('show', this.element);
- }.bind(this));
- } else {
- this.callChain();
- this.chain(this.reveal.bind(this));
- } else if (this.options.link == 'cancel' && !this.showing){
- this.cancel();
- this.reveal();
- } catch(e){
- display: this.options.display,
- visiblity: 'visible',
- opacity: 1
- return this;
- this.reveal();
- } else {
- this.dissolve();
- return this;
- cancel: function(){
- this.hidding = false;
-Element.Properties.reveal = {
- var reveal = this.retrieve('reveal');
- if (reveal) reveal.cancel();
- return this.eliminate('reveal').store('reveal:options', options);
- if (options || !this.retrieve('reveal')){
- if (options || !this.retrieve('reveal:options')) this.set('reveal', options);
- this.store('reveal', new Fx.Reveal(this, this.retrieve('reveal:options')));
- return this.retrieve('reveal');
-Element.Properties.dissolve = Element.Properties.reveal;
- reveal: function(options){
- this.get('reveal', options).reveal();
- return this;
- dissolve: function(options){
- this.get('reveal', options).dissolve();
- return this;
- nix: function(){
- var params = Array.link(arguments, {destroy: Boolean.type, options: Object.type});
- this.get('reveal', params.options).dissolve().chain(function(){
- this[params.destroy ? 'destroy' : 'dispose']();
- }.bind(this));
- return this;
- wink: function(){
- var params = Array.link(arguments, {duration: Number.type, options: Object.type});
- var reveal = this.get('reveal', params.options);
- reveal.reveal().chain(function(){
- (function(){
- reveal.dissolve();
- }).delay(params.duration || 2000);
-script: Form.Request.Append.js
-description: Handles the basic functionality of submitting a form and updating a dom element with the result. The result is appended to the DOM element instead of replacing its contents.
-authors:
-- Aaron Newton
-requires:
-- /Form.Request
-- /Fx.Reveal
-- /Elements.from
-provides: [Form.Request.Append]
-Form.Request.Append = new Class({
- Extends: Form.Request,
- options: {
- //onBeforeEffect: $empty,
- useReveal: true,
- revealOptions: {},
- inject: 'bottom'
- url: this.element.get('action'),
- method: this.element.get('method') || 'post',
- }, this.options.requestOptions, {
- evalScripts: false
- ).addEvents({
- success: function(tree, elements, html, javascript){
- var container;
- var kids = Elements.from(html);
- if (kids.length == 1) {
- container = kids[0];
- } else {
- container = new Element('div', {
- styles: {
- display: 'none'
- }).adopt(kids);
- container.inject(this.update, this.options.inject);
- if (this.options.requestOptions.evalScripts) $exec(javascript);
- this.fireEvent('beforeEffect', container);
- var finish = function(){
- this.fireEvent('success', [container, this.update, tree, elements, html, javascript]);
- }.bind(this);
- if (this.options.useReveal) {
- container.get('reveal', this.options.revealOptions).chain(finish);
- container.reveal();
- } else {
- finish();
- }.bind(this),
- }.bind(this)
-script: Form.Validator.English.js
-description: Form Validator messages for English.
-authors:
-- Aaron Newton
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.English]
-MooTools.lang.set('en-US', 'Form.Validator', {
- required:'This field is required.',
- minLength:'Please enter at least {minLength} characters (you entered {length} characters).',
- maxLength:'Please enter no more than {maxLength} characters (you entered {length} characters).',
- integer:'Please enter an integer in this field. Numbers with decimals (e.g. 1.25) are not permitted.',
- numeric:'Please enter only numeric values in this field (i.e. "1" or "1.1" or "-1" or "-1.1").',
- digits:'Please use numbers and punctuation only in this field (for example, a phone number with dashes or dots is permitted).',
- alpha:'Please use letters only (a-z) with in this field. No spaces or other characters are allowed.',
- alphanum:'Please use only letters (a-z) or numbers (0-9) only in this field. No spaces or other characters are allowed.',
- dateSuchAs:'Please enter a valid date such as {date}',
- dateInFormatMDY:'Please enter a valid date such as MM/DD/YYYY (i.e. "12/31/1999")',
- email:'Please enter a valid email address. For example "fred at domain.com".',
- url:'Please enter a valid URL such as http://www.google.com.',
- currencyDollar:'Please enter a valid $ amount. For example $100.00 .',
- oneRequired:'Please enter something for at least one of these inputs.',
- errorPrefix: 'Error: ',
- warningPrefix: 'Warning: ',
- //Form.Validator.Extras
- noSpace: 'There can be no spaces in this input.',
- reqChkByNode: 'No items are selected.',
- requiredChk: 'This field is required.',
- reqChkByName: 'Please select a {label}.',
- match: 'This field needs to match the {matchName} field',
- startDate: 'the start date',
- endDate: 'the end date',
- currendDate: 'the current date',
- afterDate: 'The date should be the same or after {label}.',
- beforeDate: 'The date should be the same or before {label}.',
- startMonth: 'Please select a start month',
- sameMonth: 'These two dates must be in the same month - you must change one or the other.',
- creditcard: 'The credit card number entered is invalid. Please check the number and try again. {length} digits entered.'
-script: Form.Validator.js
-description: A css-class based form validation system.
-authors:
-- Aaron Newton
-requires:
-- core:1.2.4/JSON
-- /Lang- /Class.Binds
-- /Date Element.Forms
-- /Form.Validator.English
-provides: [Form.Validator, InputValidator, FormValidator.BaseValidators]
-var InputValidator = new Class({
- Implements: [Options],
- options: {
- errorMsg: 'Validation failed.',
- test: function(field){return true;}
- initialize: function(className, options){
- this.className = className;
- test: function(field, props){
- if (document.id(field)) return this.options.test(document.id(field), props||this.getProps(field));
- else return false;
- getError: function(field, props){
- var err = this.options.errorMsg;
- if ($type(err) == 'function') err = err(document.id(field), props||this.getProps(field));
- return err;
- getProps: function(field){
- if (!document.id(field)) return {};
- return field.get('validatorProps');
-Element.Properties.validatorProps = {
- set: function(props){
- return this.eliminate('validatorProps').store('validatorProps', props);
- get: function(props){
- if (props) this.set(props);
- if (this.retrieve('validatorProps')) return this.retrieve('validatorProps');
- if (this.getProperty('validatorProps')){
- try {
- this.store('validatorProps', JSON.decode(this.getProperty('validatorProps')));
- }catch(e){
- return {};
- } else {
- var vals = this.get('class').split(' ').filter(function(cls){
- return cls.test(':');
- if (!vals.length){
- this.store('validatorProps', {});
- } else {
- props = {};
- vals.each(function(cls){
- var split = cls.split(':');
- if (split[1]) {
- try {
- props[split[0]] = JSON.decode(split[1]);
- } catch(e) {}
- this.store('validatorProps', props);
- return this.retrieve('validatorProps');
-Form.Validator = new Class({
- Implements:[Options, Events],
- Binds: ['onSubmit'],
- options: {/*
- onFormValidate: $empty(isValid, form, event),
- onElementValidate: $empty(isValid, field, className, warn),
- onElementPass: $empty(field),
- onElementFail: $empty(field, validatorsFailed) */
- fieldSelectors: 'input, select, textarea',
- ignoreHidden: true,
- ignoreDisabled: true,
- useTitles: false,
- evaluateOnSubmit: true,
- evaluateFieldsOnBlur: true,
- evaluateFieldsOnChange: true,
- serial: true,
- stopOnFailure: true,
- warningPrefix: function(){
- return Form.Validator.getMsg('warningPrefix') || 'Warning: ';
- errorPrefix: function(){
- return Form.Validator.getMsg('errorPrefix') || 'Error: ';
- initialize: function(form, options){
- this.element.store('validator', this);
- this.warningPrefix = $lambda(this.options.warningPrefix)();
- this.errorPrefix = $lambda(this.options.errorPrefix)();
- if (this.options.evaluateOnSubmit) this.element.addEvent('submit', this.onSubmit);
- if (this.options.evaluateFieldsOnBlur || this.options.evaluateFieldsOnChange) this.watchFields(this.getFields());
- getFields: function(){
- return (this.fields = this.element.getElements(this.options.fieldSelectors));
- watchFields: function(fields){
- fields.each(function(el){
- if (this.options.evaluateFieldsOnBlur)
- el.addEvent('blur', this.validationMonitor.pass([el, false], this));
- if (this.options.evaluateFieldsOnChange)
- el.addEvent('change', this.validationMonitor.pass([el, true], this));
- }, this);
- validationMonitor: function(){
- $clear(this.timer);
- this.timer = this.validateField.delay(50, this, arguments);
- onSubmit: function(event){
- if (!this.validate(event) && event) event.preventDefault();
- else this.reset();
- reset: function(){
- this.getFields().each(this.resetField, this);
- return this;
- validate: function(event){
- var result = this.getFields().map(function(field){
- return this.validateField(field, true);
- }, this).every(function(v){ return v;});
- this.fireEvent('formValidate', [result, this.element, event]);
- if (this.options.stopOnFailure && !result && event) event.preventDefault();
- return result;
- validateField: function(field, force){
- if (this.paused) return true;
- field = document.id(field);
- var passed = !field.hasClass('validation-failed');
- var failed, warned;
- if (this.options.serial && !force){
- failed = this.element.getElement('.validation-failed');
- warned = this.element.getElement('.warning');
- if (field && (!failed || force || field.hasClass('validation-failed') || (failed && !this.options.serial))){
- var validators = field.className.split(' ').some(function(cn){
- return this.getValidator(cn);
- }, this);
- var validatorsFailed = [];
- field.className.split(' ').each(function(className){
- if (className && !this.test(className, field)) validatorsFailed.include(className);
- }, this);
- passed = validatorsFailed.length === 0;
- if (validators && !field.hasClass('warnOnly')){
- if (passed){
- field.addClass('validation-passed').removeClass('validation-failed');
- this.fireEvent('elementPass', field);
- } else {
- field.addClass('validation-failed').removeClass('validation-passed');
- this.fireEvent('elementFail', [field, validatorsFailed]);
- if (!warned){
- var warnings = field.className.split(' ').some(function(cn){
- if (cn.test('^warn-') || field.hasClass('warnOnly'))
- return this.getValidator(cn.replace(/^warn-/,''));
- else return null;
- }, this);
- field.removeClass('warning');
- var warnResult = field.className.split(' ').map(function(cn){
- return this.test(cn.replace(/^warn-/,''), field, true);
- else return null;
- }, this);
- return passed;
- test: function(className, field, warn){
- if((this.options.ignoreHidden && !field.isVisible()) || (this.options.ignoreDisabled && field.get('disabled'))) return true;
- var validator = this.getValidator(className);
- if (field.hasClass('ignoreValidation')) return true;
- warn = $pick(warn, false);
- if (field.hasClass('warnOnly')) warn = true;
- var isValid = validator ? validator.test(field) : true;
- if (validator && field.isVisible()) this.fireEvent('elementValidate', [isValid, field, className, warn]);
- if (warn) return true;
- return isValid;
- resetField: function(field){
- if (field){
- if (className.test('^warn-')) className = className.replace(/^warn-/, '');
- field.removeClass('validation-failed');
- field.removeClass('validation-passed');
- }, this);
- return this;
- stop: function(){
- this.paused = true;
- return this;
- start: function(){
- this.paused = false;
- return this;
- ignoreField: function(field, warn){
- if (field){
- this.enforceField(field);
- if (warn) field.addClass('warnOnly');
- else field.addClass('ignoreValidation');
- return this;
- enforceField: function(field){
- if (field) field.removeClass('warnOnly').removeClass('ignoreValidation');
- return this;
-Form.Validator.getMsg = function(key){
- return MooTools.lang.get('Form.Validator', key);
-Form.Validator.adders = {
- validators:{},
- add : function(className, options){
- this.validators[className] = new InputValidator(className, options);
- //if this is a class (this method is used by instances of Form.Validator and the Form.Validator namespace)
- //extend these validators into it
- //this allows validators to be global and/or per instance
- if (!this.initialize){
- this.implement({
- validators: this.validators
- addAllThese : function(validators){
- $A(validators).each(function(validator){
- this.add(validator[0], validator[1]);
- }, this);
- getValidator: function(className){
- return this.validators[className.split(':')[0]];
-$extend(Form.Validator, Form.Validator.adders);
-Form.Validator.implement(Form.Validator.adders);
-Form.Validator.add('IsEmpty', {
- errorMsg: false,
- test: function(element){
- if (element.type == 'select-one' || element.type == 'select')
- return !(element.selectedIndex >= 0 && element.options[element.selectedIndex].value != '');
- else
- return ((element.get('value') == null) || (element.get('value').length == 0));
-Form.Validator.addAllThese([
- ['required', {
- errorMsg: function(){
- return Form.Validator.getMsg('required');
- return !Form.Validator.getValidator('IsEmpty').test(element);
- ['minLength', {
- errorMsg: function(element, props){
- if ($type(props.minLength))
- return Form.Validator.getMsg('minLength').substitute({minLength:props.minLength,length:element.get('value').length });
- else return '';
- test: function(element, props){
- if ($type(props.minLength)) return (element.get('value').length >= $pick(props.minLength, 0));
- else return true;
- ['maxLength', {
- //props is {maxLength:10}
- if ($type(props.maxLength))
- return Form.Validator.getMsg('maxLength').substitute({maxLength:props.maxLength,length:element.get('value').length });
- else return '';
- //if the value is <= than the maxLength value, element passes test
- return (element.get('value').length <= $pick(props.maxLength, 10000));
- ['validate-integer', {
- errorMsg: Form.Validator.getMsg.pass('integer'),
- return Form.Validator.getValidator('IsEmpty').test(element) || (/^(-?[1-9]\d*|0)$/).test(element.get('value'));
- ['validate-numeric', {
- errorMsg: Form.Validator.getMsg.pass('numeric'),
- (/^-?(?:0$0(?=\d*\.)|[1-9]|0)\d*(\.\d+)?$/).test(element.get('value'));
- ['validate-digits', {
- errorMsg: Form.Validator.getMsg.pass('digits'),
- return Form.Validator.getValidator('IsEmpty').test(element) || (/^[\d() .:\-\+#]+$/.test(element.get('value')));
- ['validate-alpha', {
- errorMsg: Form.Validator.getMsg.pass('alpha'),
- return Form.Validator.getValidator('IsEmpty').test(element) || (/^[a-zA-Z]+$/).test(element.get('value'));
- ['validate-alphanum', {
- errorMsg: Form.Validator.getMsg.pass('alphanum'),
- return Form.Validator.getValidator('IsEmpty').test(element) || !(/\W/).test(element.get('value'));
- ['validate-date', {
- if (Date.parse){
- var format = props.dateFormat || '%x';
- return Form.Validator.getMsg('dateSuchAs').substitute({date: new Date().format(format)});
- } else {
- return Form.Validator.getMsg('dateInFormatMDY');
- if (Form.Validator.getValidator('IsEmpty').test(element)) return true;
- var d;
- if (Date.parse){
- d = Date.parse(element.get('value'));
- var formatted = d.format(format);
- if (formatted != 'invalid date') element.set('value', formatted);
- return !isNaN(d);
- } else {
- var regex = /^(\d{2})\/(\d{2})\/(\d{4})$/;
- if (!regex.test(element.get('value'))) return false;
- d = new Date(element.get('value').replace(regex, '$1/$2/$3'));
- return (parseInt(RegExp.$1, 10) == (1 + d.getMonth())) &&
- (parseInt(RegExp.$2, 10) == d.getDate()) &&
- (parseInt(RegExp.$3, 10) == d.getFullYear());
- ['validate-email', {
- errorMsg: Form.Validator.getMsg.pass('email'),
- return Form.Validator.getValidator('IsEmpty').test(element) || (/^[A-Z0-9._%+-]+@[A-Z0-9.-]+\.[A-Z]{2,4}$/i).test(element.get('value'));
- ['validate-url', {
- errorMsg: Form.Validator.getMsg.pass('url'),
- return Form.Validator.getValidator('IsEmpty').test(element) || (/^(https?|ftp|rmtp|mms):\/\/(([A-Z0-9][A-Z0-9_-]*)(\.[A-Z0-9][A-Z0-9_-]*)+)(:(\d+))?\/?/i).test(element.get('value'));
- ['validate-currency-dollar', {
- errorMsg: Form.Validator.getMsg.pass('currencyDollar'),
- // [$]1[##][,###]+[.##]
- // [$]1###+[.##]
- // [$]0.##
- return Form.Validator.getValidator('IsEmpty').test(element) || (/^\$?\-?([1-9]{1}[0-9]{0,2}(\,[0-9]{3})*(\.[0-9]{0,2})?|[1-9]{1}\d*(\.[0-9]{0,2})?|0(\.[0-9]{0,2})?|(\.[0-9]{1,2})?)$/).test(element.get('value'));
- ['validate-one-required', {
- errorMsg: Form.Validator.getMsg.pass('oneRequired'),
- var p = document.id(props['validate-one-required']) || element.getParent();
- return p.getElements('input').some(function(el){
- if (['checkbox', 'radio'].contains(el.get('type'))) return el.get('checked');
- return el.get('value');
-Element.Properties.validator = {
- var validator = this.retrieve('validator');
- if (validator) validator.setOptions(options);
- return this.store('validator:options');
- if (options || !this.retrieve('validator')){
- if (options || !this.retrieve('validator:options')) this.set('validator', options);
- this.store('validator', new Form.Validator(this, this.retrieve('validator:options')));
- return this.retrieve('validator');
- validate: function(options){
- this.set('validator', options);
- return this.get('validator', options).validate();
-//legacy
-var FormValidator = Form.Validator;/*
-script: Form.Validator.Inline.js
-description: Extends Form.Validator to add inline messages.
-authors:
-- Aaron Newton
-requires:
-- /Form.Validator
-provides: [Form.Validator.Inline]
-Form.Validator.Inline = new Class({
- Extends: Form.Validator,
- options: {
- scrollToErrorsOnSubmit: true,
- scrollFxOptions: {
- transition: 'quad:out',
- offset: {
- y: -20
- this.parent(form, options);
- this.addEvent('onElementValidate', function(isValid, field, className, warn){
- if (!isValid && validator.getError(field)){
- if (warn) field.addClass('warning');
- var advice = this.makeAdvice(className, field, validator.getError(field), warn);
- this.insertAdvice(advice, field);
- this.showAdvice(className, field);
- } else {
- this.hideAdvice(className, field);
- makeAdvice: function(className, field, error, warn){
- var errorMsg = (warn)?this.warningPrefix:this.errorPrefix;
- errorMsg += (this.options.useTitles) ? field.title || error:error;
- var cssClass = (warn) ? 'warning-advice' : 'validation-advice';
- var advice = this.getAdvice(className, field);
- if(advice) {
- advice = advice.set('html', errorMsg);
- } else {
- advice = new Element('div', {
- html: errorMsg,
- styles: { display: 'none' },
- id: 'advice-' + className + '-' + this.getFieldId(field)
- }).addClass(cssClass);
- field.store('advice-' + className, advice);
- return advice;
- getFieldId : function(field){
- return field.id ? field.id : field.id = 'input_' + field.name;
- showAdvice: function(className, field){
- if (advice && !field.retrieve(this.getPropName(className))
- && (advice.getStyle('display') == 'none'
- || advice.getStyle('visiblity') == 'hidden'
- || advice.getStyle('opacity') == 0)){
- field.store(this.getPropName(className), true);
- if (advice.reveal) advice.reveal();
- else advice.setStyle('display', 'block');
- hideAdvice: function(className, field){
- if (advice && field.retrieve(this.getPropName(className))){
- field.store(this.getPropName(className), false);
- //if Fx.Reveal.js is present, transition the advice out
- if (advice.dissolve) advice.dissolve();
- else advice.setStyle('display', 'none');
- getPropName: function(className){
- return 'advice' + className;
- if (!field) return this;
- this.parent(field);
- }, this);
- return this;
- getAllAdviceMessages: function(field, force){
- var advice = [];
- if (field.hasClass('ignoreValidation') && !force) return advice;
- var warner = cn.test('^warn-') || field.hasClass('warnOnly');
- if (warner) cn = cn.replace(/^warn-/, '');
- var validator = this.getValidator(cn);
- if (!validator) return;
- advice.push({
- message: validator.getError(field),
- warnOnly: warner,
- passed: validator.test(),
- validator: validator
- }, this);
- return advice;
- getAdvice: function(className, field){
- return field.retrieve('advice-' + className);
- insertAdvice: function(advice, field){
- //Check for error position prop
- var props = field.get('validatorProps');
- //Build advice
- if (!props.msgPos || !document.id(props.msgPos)){
- if(field.type.toLowerCase() == 'radio') field.getParent().adopt(advice);
- else advice.inject(document.id(field), 'after');
- } else {
- document.id(props.msgPos).grab(advice);
- var result = this.parent(field, force);
- if (this.options.scrollToErrorsOnSubmit && !result){
- var failed = document.id(this).getElement('.validation-failed');
- var par = document.id(this).getParent();
- while (par != document.body && par.getScrollSize().y == par.getSize().y){
- par = par.getParent();
- var fx = par.retrieve('fvScroller');
- if (!fx && window.Fx && Fx.Scroll){
- fx = new Fx.Scroll(par, this.options.scrollFxOptions);
- par.store('fvScroller', fx);
- if (failed){
- if (fx) fx.toElement(failed);
- else par.scrollTo(par.getScroll().x, failed.getPosition(par).y - 20);
- return result;
-script: Form.Validator.Extras.js
-description: Additional validators for the Form.Validator class.
-authors:
-- Aaron Newton
-requires:
-- /Form.Validator
-provides: [Form.Validator.Extras]
- ['validate-enforce-oncheck', {
- if (element.checked){
- var fv = element.getParent('form').retrieve('validator');
- if (!fv) return true;
- (props.toEnforce || document.id(props.enforceChildrenOf).getElements('input, select, textarea')).map(function(item){
- fv.enforceField(item);
- return true;
- ['validate-ignore-oncheck', {
- (props.toIgnore || document.id(props.ignoreChildrenOf).getElements('input, select, textarea')).each(function(item){
- fv.ignoreField(item);
- fv.resetField(item);
- return true;
- ['validate-nospace', {
- return Form.Validator.getMsg('noSpace');
- return !element.get('value').test(/\s/);
- ['validate-toggle-oncheck', {
- var eleArr = props.toToggle || document.id(props.toToggleChildrenOf).getElements('input, select, textarea');
- if (!element.checked){
- eleArr.each(function(item){
- } else {
- return true;
- ['validate-reqchk-bynode', {
- return Form.Validator.getMsg('reqChkByNode');
- return (document.id(props.nodeId).getElements(props.selector || 'input[type=checkbox], input[type=radio]')).some(function(item){
- return item.checked;
- ['validate-required-check', {
- return props.useTitle ? element.get('title') : Form.Validator.getMsg('requiredChk');
- return !!element.checked;
- ['validate-reqchk-byname', {
- return Form.Validator.getMsg('reqChkByName').substitute({label: props.label || element.get('type')});
- var grpName = props.groupName || element.get('name');
- var oneCheckedItem = $$(document.getElementsByName(grpName)).some(function(item, index){
- if (oneCheckedItem && fv) fv.resetField(element);
- return oneCheckedItem;
- ['validate-match', {
- return Form.Validator.getMsg('match').substitute({matchName: props.matchName || document.id(props.matchInput).get('name')});
- var eleVal = element.get('value');
- var matchVal = document.id(props.matchInput) && document.id(props.matchInput).get('value');
- return eleVal && matchVal ? eleVal == matchVal : true;
- ['validate-after-date', {
- return Form.Validator.getMsg('afterDate').substitute({
- label: props.afterLabel || (props.afterElement ? Form.Validator.getMsg('startDate') : Form.Validator.getMsg('currentDate'))
- var start = document.id(props.afterElement) ? Date.parse(document.id(props.afterElement).get('value')) : new Date();
- var end = Date.parse(element.get('value'));
- return end && start ? end >= start : true;
- ['validate-before-date', {
- return Form.Validator.getMsg('beforeDate').substitute({
- label: props.beforeLabel || (props.beforeElement ? Form.Validator.getMsg('endDate') : Form.Validator.getMsg('currentDate'))
- var start = Date.parse(element.get('value'));
- var end = document.id(props.beforeElement) ? Date.parse(document.id(props.beforeElement).get('value')) : new Date();
- ['validate-custom-required', {
- return element.get('value') != props.emptyValue;
- ['validate-same-month', {
- var startMo = document.id(props.sameMonthAs) && document.id(props.sameMonthAs).get('value');
- if (eleVal != '') return Form.Validator.getMsg(startMo ? 'sameMonth' : 'startMonth');
- var d1 = Date.parse(element.get('value'));
- var d2 = Date.parse(document.id(props.sameMonthAs) && document.id(props.sameMonthAs).get('value'));
- return d1 && d2 ? d1.format('%B') == d2.format('%B') : true;
- ['validate-cc-num', {
- errorMsg: function(element){
- var ccNum = element.get('value').replace(/[^0-9]/g, '');
- return Form.Validator.getMsg('creditcard').substitute({length: ccNum.length});
- // required is a different test
- if (Form.Validator.getValidator('IsEmpty').test(element)) { return true; }
- // Clean number value
- var ccNum = element.get('value');
- ccNum = ccNum.replace(/[^0-9]/g, '');
- var valid_type = false;
- if (ccNum.test(/^4[0-9]{12}([0-9]{3})?$/)) valid_type = 'Visa';
- else if (ccNum.test(/^5[1-5]([0-9]{14})$/)) valid_type = 'Master Card';
- else if (ccNum.test(/^3[47][0-9]{13}$/)) valid_type = 'American Express';
- else if (ccNum.test(/^6011[0-9]{12}$/)) valid_type = 'Discover';
- if (valid_type) {
- var sum = 0;
- var cur = 0;
- for(var i=ccNum.length-1; i>=0; --i) {
- cur = ccNum.charAt(i).toInt();
- if (cur == 0) { continue; }
- if ((ccNum.length-i) % 2 == 0) { cur += cur; }
- if (cur > 9) { cur = cur.toString().charAt(0).toInt() + cur.toString().charAt(1).toInt(); }
- sum += cur;
- if ((sum % 10) == 0) { return true; }
- var chunks = '';
- while (ccNum != '') {
- chunks += ' ' + ccNum.substr(0,4);
- ccNum = ccNum.substr(4);
- element.getParent('form').retrieve('validator').ignoreField(element);
- element.set('value', chunks.clean());
- element.getParent('form').retrieve('validator').enforceField(element);
- return false;
-script: OverText.js
-description: Shows text over an input that disappears when the user clicks into it. The text remains hidden if the user adds a value.
-license: MIT-style license
-authors:
-- Aaron Newton
-requires:
-- /Class.Binds
-- /Class.Occlude
-provides: [OverText]
-var OverText = new Class({
- Binds: ['reposition', 'assert', 'focus', 'hide'],
- options: {/*
- textOverride: null,
- onFocus: $empty()
- onTextHide: $empty(textEl, inputEl),
- onTextShow: $empty(textEl, inputEl), */
- element: 'label',
- positionOptions: {
- position: 'upperLeft',
- edge: 'upperLeft',
- offset: {
- x: 4,
- y: 2
- poll: false,
- pollInterval: 250,
- wrap: false
- property: 'OverText',
- this.attach(this.element);
- OverText.instances.push(this);
- if (this.options.poll) this.poll();
- return this;
- attach: function(){
- var val = this.options.textOverride || this.element.get('alt') || this.element.get('title');
- if (!val) return;
- this.text = new Element(this.options.element, {
- 'class': 'overTxtLabel',
- styles: {
- lineHeight: 'normal',
- cursor: 'text'
- html: val,
- events: {
- click: this.hide.pass(this.options.element == 'label', this)
- }).inject(this.element, 'after');
- if (this.options.element == 'label') {
- if (!this.element.get('id')) this.element.set('id', 'input_' + new Date().getTime());
- this.text.set('for', this.element.get('id'));
- if (this.options.wrap) {
- this.textHolder = new Element('div', {
- styles: {
- position: 'relative'
- 'class':'overTxtWrapper'
- }).adopt(this.text).inject(this.element, 'before');
- this.element.addEvents({
- focus: this.focus,
- blur: this.assert,
- change: this.assert
- }).store('OverTextDiv', this.text);
- window.addEvent('resize', this.reposition.bind(this));
- this.assert(true);
- this.reposition();
- wrap: function(){
- startPolling: function(){
- this.pollingPaused = false;
- return this.poll();
- poll: function(stop){
- //start immediately
- //pause on focus
- //resumeon blur
- if (this.poller && !stop) return this;
- var test = function(){
- if (!this.pollingPaused) this.assert(true);
- }.bind(this);
- if (stop) $clear(this.poller);
- else this.poller = test.periodical(this.options.pollInterval, this);
- return this;
- stopPolling: function(){
- this.pollingPaused = true;
- return this.poll(true);
- focus: function(){
- if (this.text && (!this.text.isDisplayed() || this.element.get('disabled'))) return;
- this.hide();
- hide: function(suppressFocus, force){
- if (this.text && (this.text.isDisplayed() && (!this.element.get('disabled') || force))){
- this.text.hide();
- this.fireEvent('textHide', [this.text, this.element]);
- if (!suppressFocus){
- try {
- this.element.fireEvent('focus');
- this.element.focus();
- } catch(e){} //IE barfs if you call focus on hidden elements
- return this;
- show: function(){
- if (this.text && !this.text.isDisplayed()){
- this.text.show();
- this.fireEvent('textShow', [this.text, this.element]);
- return this;
- assert: function(suppressFocus){
- this[this.test() ? 'show' : 'hide'](suppressFocus);
- test: function(){
- var v = this.element.get('value');
- return !v;
- reposition: function(){
- if (!this.element.isVisible()) return this.stopPolling().hide();
- if (this.text && this.test()) this.text.position($merge(this.options.positionOptions, {relativeTo: this.element}));
- return this;
-OverText.instances = [];
-$extend(OverText, {
- each: function(fn) {
- return OverText.instances.map(function(ot, i){
- if (ot.element && ot.text) return fn.apply(OverText, [ot, i]);
- return null; //the input or the text was destroyed
- update: function(){
- return OverText.each(function(ot){
- return ot.reposition();
- hideAll: function(){
- return ot.hide(true, true);
- showAll: function(){
- return OverText.each(function(ot) {
- return ot.show();
-if (window.Fx && Fx.Reveal) {
- Fx.Reveal.implement({
- hideInputs: Browser.Engine.trident ? 'select, input, textarea, object, embed, .overTxtLabel' : false
-script: Fx.Elements.js
-description: Effect to change any number of CSS properties of any number of Elements.
-authors:
-- Valerio Proietti
-requires:
-- core:1.2.4/Fx.CSS
-- /MooTools.More
-provides: [Fx.Elements]
-Fx.Elements = new Class({
- Extends: Fx.CSS,
- initialize: function(elements, options){
- this.elements = this.subject = $$(elements);
- this.parent(options);
- compute: function(from, to, delta){
- var now = {};
- for (var i in from){
- var iFrom = from[i], iTo = to[i], iNow = now[i] = {};
- for (var p in iFrom) iNow[p] = this.parent(iFrom[p], iTo[p], delta);
- return now;
- set: function(now){
- for (var i in now){
- var iNow = now[i];
- for (var p in iNow) this.render(this.elements[i], p, iNow[p], this.options.unit);
- return this;
- start: function(obj){
- if (!this.check(obj)) return this;
- var from = {}, to = {};
- for (var i in obj){
- var iProps = obj[i], iFrom = from[i] = {}, iTo = to[i] = {};
- for (var p in iProps){
- var parsed = this.prepare(this.elements[i], p, iProps[p]);
- iFrom[p] = parsed.from;
- iTo[p] = parsed.to;
- return this.parent(from, to);
-script: Fx.Accordion.js
-description: An Fx.Elements extension which allows you to easily create accordion type controls.
-authors:
-- Valerio Proietti
-requires:
-- /Fx.Elements
-provides: [Fx.Accordion]
-Fx.Accordion = new Class({
- Extends: Fx.Elements,
- options: {/*
- onActive: $empty(toggler, section),
- onBackground: $empty(toggler, section),
- fixedHeight: false,
- fixedWidth: false,
- display: 0,
- show: false,
- height: true,
- width: false,
- opacity: true,
- alwaysHide: false,
- trigger: 'click',
- initialDisplayFx: true,
- returnHeightToAuto: true
- 'container': Element.type, //deprecated
- 'options': Object.type,
- 'togglers': $defined,
- 'elements': $defined
- this.parent(params.elements, params.options);
- this.togglers = $$(params.togglers);
- this.previous = -1;
- this.internalChain = new Chain();
- if (this.options.alwaysHide) this.options.wait = true;
- if ($chk(this.options.show)){
- this.options.display = false;
- this.previous = this.options.show;
- if (this.options.start){
- this.options.show = false;
- this.effects = {};
- if (this.options.opacity) this.effects.opacity = 'fullOpacity';
- if (this.options.width) this.effects.width = this.options.fixedWidth ? 'fullWidth' : 'offsetWidth';
- if (this.options.height) this.effects.height = this.options.fixedHeight ? 'fullHeight' : 'scrollHeight';
- for (var i = 0, l = this.togglers.length; i < l; i++) this.addSection(this.togglers[i], this.elements[i]);
- this.elements.each(function(el, i){
- if (this.options.show === i){
- this.fireEvent('active', [this.togglers[i], el]);
- } else {
- for (var fx in this.effects) el.setStyle(fx, 0);
- }, this);
- if ($chk(this.options.display) || this.options.initialDisplayFx === false) this.display(this.options.display, this.options.initialDisplayFx);
- if (this.options.fixedHeight !== false) this.options.returnHeightToAuto = false;
- this.addEvent('complete', this.internalChain.callChain.bind(this.internalChain));
- addSection: function(toggler, element){
- toggler = document.id(toggler);
- element = document.id(element);
- var test = this.togglers.contains(toggler);
- this.togglers.include(toggler);
- this.elements.include(element);
- var idx = this.togglers.indexOf(toggler);
- var displayer = this.display.bind(this, idx);
- toggler.store('accordion:display', displayer);
- toggler.addEvent(this.options.trigger, displayer);
- if (this.options.height) element.setStyles({'padding-top': 0, 'border-top': 'none', 'padding-bottom': 0, 'border-bottom': 'none'});
- if (this.options.width) element.setStyles({'padding-left': 0, 'border-left': 'none', 'padding-right': 0, 'border-right': 'none'});
- element.fullOpacity = 1;
- if (this.options.fixedWidth) element.fullWidth = this.options.fixedWidth;
- if (this.options.fixedHeight) element.fullHeight = this.options.fixedHeight;
- element.setStyle('overflow', 'hidden');
- if (!test){
- for (var fx in this.effects) element.setStyle(fx, 0);
- return this;
- this.togglers.each(function(toggler) {
- toggler.removeEvent(this.options.trigger, toggler.retrieve('accordion:display'));
- }, this);
- display: function(index, useFx){
- if (!this.check(index, useFx)) return this;
- useFx = $pick(useFx, true);
- if (this.options.returnHeightToAuto){
- var prev = this.elements[this.previous];
- if (prev && !this.selfHidden){
- for (var fx in this.effects){
- prev.setStyle(fx, prev[this.effects[fx]]);
- index = ($type(index) == 'element') ? this.elements.indexOf(index) : index;
- if ((this.timer && this.options.wait) || (index === this.previous && !this.options.alwaysHide)) return this;
- this.previous = index;
- var obj = {};
- obj[i] = {};
- var hide;
- if (i != index){
- hide = true;
- } else if (this.options.alwaysHide && ((el.offsetHeight > 0 && this.options.height) || el.offsetWidth > 0 && this.options.width)){
- hide = true;
- this.selfHidden = true;
- this.fireEvent(hide ? 'background' : 'active', [this.togglers[i], el]);
- for (var fx in this.effects) obj[i][fx] = hide ? 0 : el[this.effects[fx]];
- }, this);
- this.internalChain.chain(function(){
- if (this.options.returnHeightToAuto && !this.selfHidden){
- var el = this.elements[index];
- if (el) el.setStyle('height', 'auto');
- }.bind(this));
- return useFx ? this.start(obj) : this.set(obj);
- Compatibility with 1.2.0
-var Accordion = new Class({
- Extends: Fx.Accordion,
- var params = Array.link(arguments, {'container': Element.type});
- this.container = params.container;
- addSection: function(toggler, element, pos){
- var len = this.togglers.length;
- if (len && (!test || pos)){
- pos = $pick(pos, len - 1);
- toggler.inject(this.togglers[pos], 'before');
- element.inject(toggler, 'after');
- } else if (this.container && !test){
- toggler.inject(this.container);
- element.inject(this.container);
- return this.parent.apply(this, arguments);
-script: Fx.Move.js
-description: Defines Fx.Move, a class that works with Element.Position.js to transition an element from one location to another.
-authors:
-- Aaron Newton
-requires:
-provides: [Fx.Move]
-Fx.Move = new Class({
- options: {
- position: 'center',
- edge: false,
- start: function(destination){
- return this.parent(this.element.position($merge(this.options, destination, {returnPos: true})));
-Element.Properties.move = {
- var morph = this.retrieve('move');
- if (morph) morph.cancel();
- return this.eliminate('move').store('move:options', $extend({link: 'cancel'}, options));
- if (options || !this.retrieve('move')){
- if (options || !this.retrieve('move:options')) this.set('move', options);
- this.store('move', new Fx.Move(this, this.retrieve('move:options')));
- return this.retrieve('move');
-Element.implement({
- move: function(options){
- this.get('move').start(options);
- return this;
-script: Fx.Scroll.js
-description: Effect to smoothly scroll any element, including the window.
-authors:
-- Valerio Proietti
-requires:
-- core:1.2.4/Fx
-- core:1.2.4/Element.Dimensions
-- /MooTools.More
-provides: [Fx.Scroll]
-Fx.Scroll = new Class({
- Extends: Fx,
- options: {
- wheelStops: true
- this.element = this.subject = document.id(element);
- var cancel = this.cancel.bind(this, false);
- if ($type(this.element) != 'element') this.element = document.id(this.element.getDocument().body);
- var stopper = this.element;
- if (this.options.wheelStops){
- this.addEvent('start', function(){
- stopper.addEvent('mousewheel', cancel);
- }, true);
- this.addEvent('complete', function(){
- stopper.removeEvent('mousewheel', cancel);
- }, true);
- set: function(){
- var now = Array.flatten(arguments);
- if (Browser.Engine.gecko) now = [Math.round(now[0]), Math.round(now[1])];
- this.element.scrollTo(now[0], now[1]);
- return [0, 1].map(function(i){
- return Fx.compute(from[i], to[i], delta);
- start: function(x, y){
- if (!this.check(x, y)) return this;
- var scrollSize = this.element.getScrollSize(),
- scroll = this.element.getScroll(),
- values = {x: x, y: y};
- for (var z in values){
- var max = scrollSize[z];
- if ($chk(values[z])) values[z] = ($type(values[z]) == 'number') ? values[z] : max;
- else values[z] = scroll[z];
- values[z] += this.options.offset[z];
- return this.parent([scroll.x, scroll.y], [values.x, values.y]);
- toTop: function(){
- return this.start(false, 0);
- toLeft: function(){
- return this.start(0, false);
- toRight: function(){
- return this.start('right', false);
- toBottom: function(){
- return this.start(false, 'bottom');
- toElement: function(el){
- var position = document.id(el).getPosition(this.element);
- return this.start(position.x, position.y);
- scrollIntoView: function(el, axes, offset){
- axes = axes ? $splat(axes) : ['x','y'];
- var to = {};
- el = document.id(el);
- var pos = el.getPosition(this.element);
- var size = el.getSize();
- var scroll = this.element.getScroll();
- var containerSize = this.element.getSize();
- var edge = {
- x: pos.x + size.x,
- y: pos.y + size.y
- ['x','y'].each(function(axis) {
- if (axes.contains(axis)) {
- if (edge[axis] > scroll[axis] + containerSize[axis]) to[axis] = edge[axis] - containerSize[axis];
- if (pos[axis] < scroll[axis]) to[axis] = pos[axis];
- if (to[axis] == null) to[axis] = scroll[axis];
- if (offset && offset[axis]) to[axis] = to[axis] + offset[axis];
- }, this);
- if (to.x != scroll.x || to.y != scroll.y) this.start(to.x, to.y);
- return this;
- scrollToCenter: function(el, axes, offset){
- axes = axes ? $splat(axes) : ['x', 'y'];
- el = $(el);
- var to = {},
- pos = el.getPosition(this.element),
- size = el.getSize(),
- containerSize = this.element.getSize(),
- edge = {
- y: pos.y + size.y
- ['x','y'].each(function(axis){
- if(axes.contains(axis)){
- to[axis] = pos[axis] - (containerSize[axis] - size[axis])/2;
- if(to[axis] == null) to[axis] = scroll[axis];
- if(offset && offset[axis]) to[axis] = to[axis] + offset[axis];
- }, this);
- return this;
-script: Fx.Slide.js
-description: Effect to slide an element in and out of view.
-authors:
-- Valerio Proietti
-requires:
-- core:1.2.4/Fx Element.Style
-- /MooTools.More
-provides: [Fx.Slide]
-Fx.Slide = new Class({
- Extends: Fx,
- options: {
- mode: 'vertical',
- wrapper: false,
- hideOverflow: true
- this.open = (this.wrapper['offset' + this.layout.capitalize()] != 0);
- if (this.open) this.wrapper.setStyle('height', '');
- if (this.open && Browser.Engine.webkit419) this.element.dispose().inject(this.wrapper);
- }, true);
- var wrapper = this.element.retrieve('wrapper');
- var styles = this.element.getStyles('margin', 'position', 'overflow');
- if (this.options.hideOverflow) styles = $extend(styles, {overflow: 'hidden'});
- if (this.options.wrapper) wrapper = document.id(this.options.wrapper).setStyles(styles);
- this.wrapper = wrapper || new Element('div', {
- styles: styles
- }).wraps(this.element);
- this.element.store('wrapper', this.wrapper).setStyle('margin', 0);
- this.now = [];
- this.open = true;
- vertical: function(){
- this.margin = 'margin-top';
- this.layout = 'height';
- this.offset = this.element.offsetHeight;
- horizontal: function(){
- this.margin = 'margin-left';
- this.layout = 'width';
- this.offset = this.element.offsetWidth;
- this.element.setStyle(this.margin, now[0]);
- this.wrapper.setStyle(this.layout, now[1]);
- return this;
- start: function(how, mode){
- if (!this.check(how, mode)) return this;
- this[mode || this.options.mode]();
- var margin = this.element.getStyle(this.margin).toInt();
- var layout = this.wrapper.getStyle(this.layout).toInt();
- var caseIn = [[margin, layout], [0, this.offset]];
- var caseOut = [[margin, layout], [-this.offset, 0]];
- var start;
- switch (how){
- case 'in': start = caseIn; break;
- case 'out': start = caseOut; break;
- case 'toggle': start = (layout == 0) ? caseIn : caseOut;
- return this.parent(start[0], start[1]);
- slideIn: function(mode){
- return this.start('in', mode);
- slideOut: function(mode){
- return this.start('out', mode);
- hide: function(mode){
- this.open = false;
- return this.set([-this.offset, 0]);
- show: function(mode){
- this.open = true;
- return this.set([0, this.offset]);
- toggle: function(mode){
- return this.start('toggle', mode);
-Element.Properties.slide = {
- var slide = this.retrieve('slide');
- if (slide) slide.cancel();
- return this.eliminate('slide').store('slide:options', $extend({link: 'cancel'}, options));
- if (options || !this.retrieve('slide')){
- if (options || !this.retrieve('slide:options')) this.set('slide', options);
- this.store('slide', new Fx.Slide(this, this.retrieve('slide:options')));
- return this.retrieve('slide');
- slide: function(how, mode){
- how = how || 'toggle';
- var slide = this.get('slide'), toggle;
- switch (how){
- case 'hide': slide.hide(mode); break;
- case 'show': slide.show(mode); break;
- case 'toggle':
- var flag = this.retrieve('slide:flag', slide.open);
- slide[flag ? 'slideOut' : 'slideIn'](mode);
- this.store('slide:flag', !flag);
- toggle = true;
- break;
- default: slide.start(how, mode);
- if (!toggle) this.eliminate('slide:flag');
- return this;
-script: Fx.SmoothScroll.js
-description: Class for creating a smooth scrolling effect to all internal links on the page.
-authors:
-- Valerio Proietti
-requires:
-- core:1.2.4/Selectors
-- /Fx.Scroll
-provides: [Fx.SmoothScroll]
-var SmoothScroll = Fx.SmoothScroll = new Class({
- Extends: Fx.Scroll,
- initialize: function(options, context){
- context = context || document;
- this.doc = context.getDocument();
- var win = context.getWindow();
- this.parent(this.doc, options);
- this.links = $$(this.options.links || this.doc.links);
- var location = win.location.href.match(/^[^#]*/)[0] + '#';
- this.links.each(function(link){
- if (link.href.indexOf(location) != 0) {return;}
- var anchor = link.href.substr(location.length);
- if (anchor) this.useLink(link, anchor);
- }, this);
- if (!Browser.Engine.webkit419) {
- win.location.hash = this.anchor;
- }, true);
- useLink: function(link, anchor){
- var el;
- link.addEvent('click', function(event){
- if (el !== false && !el) el = document.id(anchor) || this.doc.getElement('a[name=' + anchor + ']');
- if (el) {
- event.preventDefault();
- this.anchor = anchor;
- this.toElement(el).chain(function(){
- this.fireEvent('scrolledTo', [link, el]);
- }.bind(this));
- link.blur();
- }.bind(this));
-script: Fx.Sort.js
-description: Defines Fx.Sort, a class that reorders lists with a transition.
-authors:
-- Aaron Newton
-requires:
-- /Fx.Elements
-- /Element.Measure
-provides: [Fx.Sort]
-Fx.Sort = new Class({
- options: {
- mode: 'vertical'
- this.parent(elements, options);
- this.elements.each(function(el){
- if (el.getStyle('position') == 'static') el.setStyle('position', 'relative');
- this.setDefaultOrder();
- setDefaultOrder: function(){
- this.currentOrder = this.elements.map(function(el, index){
- return index;
- sort: function(newOrder){
- if ($type(newOrder) != 'array') return false;
- var top = 0,
- left = 0,
- next = {},
- zero = {},
- vert = this.options.mode == 'vertical';
- var current = this.elements.map(function(el, index){
- var size = el.getComputedSize({styles: ['border', 'padding', 'margin']});
- var val;
- if (vert){
- val = {
- top: top,
- margin: size['margin-top'],
- height: size.totalHeight
- top += val.height - size['margin-top'];
- } else {
- val = {
- left: left,
- margin: size['margin-left'],
- width: size.totalWidth
- left += val.width;
- var plain = vert ? 'top' : 'left';
- zero[index] = {};
- var start = el.getStyle(plain).toInt();
- zero[index][plain] = start || 0;
- return val;
- }, this);
- this.set(zero);
- newOrder = newOrder.map(function(i){ return i.toInt(); });
- if (newOrder.length != this.elements.length){
- this.currentOrder.each(function(index){
- if (!newOrder.contains(index)) newOrder.push(index);
- if (newOrder.length > this.elements.length)
- newOrder.splice(this.elements.length-1, newOrder.length - this.elements.length);
- var margin = top = left = 0;
- newOrder.each(function(item, index){
- var newPos = {};
- if (vert){
- newPos.top = top - current[item].top - margin;
- top += current[item].height;
- } else {
- newPos.left = left - current[item].left;
- left += current[item].width;
- margin = margin + current[item].margin;
- next[item]=newPos;
- }, this);
- var mapped = {};
- $A(newOrder).sort().each(function(index){
- mapped[index] = next[index];
- this.start(mapped);
- this.currentOrder = newOrder;
- return this;
- rearrangeDOM: function(newOrder){
- newOrder = newOrder || this.currentOrder;
- var parent = this.elements[0].getParent();
- var rearranged = [];
- this.elements.setStyle('opacity', 0);
- //move each element and store the new default order
- newOrder.each(function(index){
- rearranged.push(this.elements[index].inject(parent).setStyles({
- top: 0,
- left: 0
- }, this);
- this.elements.setStyle('opacity', 1);
- this.elements = $$(rearranged);
- return this;
- getDefaultOrder: function(){
- return this.elements.map(function(el, index){
- return index;
- forward: function(){
- return this.sort(this.getDefaultOrder());
- backward: function(){
- return this.sort(this.getDefaultOrder().reverse());
- reverse: function(){
- return this.sort(this.currentOrder.reverse());
- sortByElements: function(elements){
- return this.sort(elements.map(function(el){
- return this.elements.indexOf(el);
- }, this));
- swap: function(one, two){
- if ($type(one) == 'element') one = this.elements.indexOf(one);
- if ($type(two) == 'element') two = this.elements.indexOf(two);
- var newOrder = $A(this.currentOrder);
- newOrder[this.currentOrder.indexOf(one)] = two;
- newOrder[this.currentOrder.indexOf(two)] = one;
- return this.sort(newOrder);
-script: Drag.js
-description: The base Drag Class. Can be used to drag and resize Elements using mouse events.
-authors:
-- Valerio Proietti
-- Tom Occhinno
-- Jan Kassens
-requires:
-- core:1.2.4/Events
-- core:1.2.4/Options
-- core:1.2.4/Element.Style
-- /MooTools.More
-provides: [Drag]
-var Drag = new Class({
- Implements: [Events, Options],
- options: {/*
- onBeforeStart: $empty(thisElement),
- onStart: $empty(thisElement, event),
- onSnap: $empty(thisElement)
- onDrag: $empty(thisElement, event),
- onCancel: $empty(thisElement),
- onComplete: $empty(thisElement, event),*/
- snap: 6,
- unit: 'px',
- grid: false,
- style: true,
- limit: false,
- handle: false,
- invert: false,
- preventDefault: false,
- stopPropagation: false,
- modifiers: {x: 'left', y: 'top'}
- var params = Array.link(arguments, {'options': Object.type, 'element': $defined});
- this.element = document.id(params.element);
- this.document = this.element.getDocument();
- this.setOptions(params.options || {});
- var htype = $type(this.options.handle);
- this.handles = ((htype == 'array' || htype == 'collection') ? $$(this.options.handle) : document.id(this.options.handle)) || this.element;
- this.mouse = {'now': {}, 'pos': {}};
- this.value = {'start': {}, 'now': {}};
- this.selection = (Browser.Engine.trident) ? 'selectstart' : 'mousedown';
- this.bound = {
- start: this.start.bind(this),
- check: this.check.bind(this),
- drag: this.drag.bind(this),
- stop: this.stop.bind(this),
- cancel: this.cancel.bind(this),
- eventStop: $lambda(false)
- this.attach();
- this.handles.addEvent('mousedown', this.bound.start);
- return this;
- this.handles.removeEvent('mousedown', this.bound.start);
- return this;
- start: function(event){
- if (event.rightClick) return;
- if (this.options.preventDefault) event.preventDefault();
- if (this.options.stopPropagation) event.stopPropagation();
- this.mouse.start = event.page;
- this.fireEvent('beforeStart', this.element);
- var limit = this.options.limit;
- this.limit = {x: [], y: []};
- for (var z in this.options.modifiers){
- if (!this.options.modifiers[z]) continue;
- if (this.options.style) this.value.now[z] = this.element.getStyle(this.options.modifiers[z]).toInt();
- else this.value.now[z] = this.element[this.options.modifiers[z]];
- if (this.options.invert) this.value.now[z] *= -1;
- this.mouse.pos[z] = event.page[z] - this.value.now[z];
- if (limit && limit[z]){
- for (var i = 2; i--; i){
- if ($chk(limit[z][i])) this.limit[z][i] = $lambda(limit[z][i])();
- if ($type(this.options.grid) == 'number') this.options.grid = {x: this.options.grid, y: this.options.grid};
- this.document.addEvents({mousemove: this.bound.check, mouseup: this.bound.cancel});
- this.document.addEvent(this.selection, this.bound.eventStop);
- check: function(event){
- var distance = Math.round(Math.sqrt(Math.pow(event.page.x - this.mouse.start.x, 2) + Math.pow(event.page.y - this.mouse.start.y, 2)));
- if (distance > this.options.snap){
- this.cancel();
- mousemove: this.bound.drag,
- mouseup: this.bound.stop
- this.fireEvent('start', [this.element, event]).fireEvent('snap', this.element);
- drag: function(event){
- this.mouse.now = event.page;
- this.value.now[z] = this.mouse.now[z] - this.mouse.pos[z];
- if (this.options.limit && this.limit[z]){
- if ($chk(this.limit[z][1]) && (this.value.now[z] > this.limit[z][1])){
- this.value.now[z] = this.limit[z][1];
- } else if ($chk(this.limit[z][0]) && (this.value.now[z] < this.limit[z][0])){
- this.value.now[z] = this.limit[z][0];
- if (this.options.grid[z]) this.value.now[z] -= ((this.value.now[z] - (this.limit[z][0]||0)) % this.options.grid[z]);
- if (this.options.style) {
- this.element.setStyle(this.options.modifiers[z], this.value.now[z] + this.options.unit);
- } else {
- this.element[this.options.modifiers[z]] = this.value.now[z];
- this.fireEvent('drag', [this.element, event]);
- cancel: function(event){
- this.document.removeEvent('mousemove', this.bound.check);
- this.document.removeEvent('mouseup', this.bound.cancel);
- if (event){
- this.document.removeEvent(this.selection, this.bound.eventStop);
- this.fireEvent('cancel', this.element);
- stop: function(event){
- this.document.removeEvent('mousemove', this.bound.drag);
- this.document.removeEvent('mouseup', this.bound.stop);
- if (event) this.fireEvent('complete', [this.element, event]);
- makeResizable: function(options){
- var drag = new Drag(this, $merge({modifiers: {x: 'width', y: 'height'}}, options));
- this.store('resizer', drag);
- return drag.addEvent('drag', function(){
- this.fireEvent('resize', drag);
- }.bind(this));
-script: Drag.Move.js
-description: A Drag extension that provides support for the constraining of draggables to containers and droppables.
-authors:
-- Valerio Proietti
-- Tom Occhinno
-- Jan Kassens
-- Aaron Newton
-- Scott Kyle
-requires:
-- /Drag
-provides: [Drag.Move]
-Drag.Move = new Class({
- Extends: Drag,
- options: {/*
- onEnter: $empty(thisElement, overed),
- onLeave: $empty(thisElement, overed),
- onDrop: $empty(thisElement, overed, event),*/
- droppables: [],
- container: false,
- precalculate: false,
- includeMargins: true,
- checkDroppables: true
- initialize: function(element, options){
- this.parent(element, options);
- element = this.element;
- this.droppables = $$(this.options.droppables);
- this.container = document.id(this.options.container);
- if (this.container && $type(this.container) != 'element')
- this.container = document.id(this.container.getDocument().body);
- var styles = element.getStyles('left', 'top', 'position');
- if (styles.left == 'auto' || styles.top == 'auto')
- element.setPosition(element.getPosition(element.getOffsetParent()));
- if (styles.position == 'static')
- element.setStyle('position', 'absolute');
- this.addEvent('start', this.checkDroppables, true);
- this.overed = null;
- if (this.container) this.options.limit = this.calculateLimit();
- if (this.options.precalculate){
- this.positions = this.droppables.map(function(el){
- return el.getCoordinates();
- this.parent(event);
- calculateLimit: function(){
- var offsetParent = this.element.getOffsetParent(),
- containerCoordinates = this.container.getCoordinates(offsetParent),
- containerBorder = {},
- elementMargin = {},
- elementBorder = {},
- containerMargin = {},
- offsetParentPadding = {};
- ['top', 'right', 'bottom', 'left'].each(function(pad){
- containerBorder[pad] = this.container.getStyle('border-' + pad).toInt();
- elementBorder[pad] = this.element.getStyle('border-' + pad).toInt();
- elementMargin[pad] = this.element.getStyle('margin-' + pad).toInt();
- containerMargin[pad] = this.container.getStyle('margin-' + pad).toInt();
- offsetParentPadding[pad] = offsetParent.getStyle('padding-' + pad).toInt();
- }, this);
- var width = this.element.offsetWidth + elementMargin.left + elementMargin.right,
- height = this.element.offsetHeight + elementMargin.top + elementMargin.bottom,
- left = 0,
- top = 0,
- right = containerCoordinates.right - containerBorder.right - width,
- bottom = containerCoordinates.bottom - containerBorder.bottom - height;
- if (this.options.includeMargins){
- left += elementMargin.left;
- top += elementMargin.top;
- } else {
- right += elementMargin.right;
- bottom += elementMargin.bottom;
- if (this.element.getStyle('position') == 'relative'){
- var coords = this.element.getCoordinates(offsetParent);
- coords.left -= this.element.getStyle('left').toInt();
- coords.top -= this.element.getStyle('top').toInt();
- left += containerBorder.left - coords.left;
- top += containerBorder.top - coords.top;
- right += elementMargin.left - coords.left;
- bottom += elementMargin.top - coords.top;
- if (this.container != offsetParent){
- left += containerMargin.left + offsetParentPadding.left;
- top += (Browser.Engine.trident4 ? 0 : containerMargin.top) + offsetParentPadding.top;
- } else {
- left -= elementMargin.left;
- top -= elementMargin.top;
- if (this.container == offsetParent){
- right -= containerBorder.left;
- bottom -= containerBorder.top;
- } else {
- left += containerCoordinates.left + containerBorder.left;
- top += containerCoordinates.top + containerBorder.top;
- return {
- x: [left, right],
- y: [top, bottom]
- checkAgainst: function(el, i){
- el = (this.positions) ? this.positions[i] : el.getCoordinates();
- var now = this.mouse.now;
- return (now.x > el.left && now.x < el.right && now.y < el.bottom && now.y > el.top);
- checkDroppables: function(){
- var overed = this.droppables.filter(this.checkAgainst, this).getLast();
- if (this.overed != overed){
- if (this.overed) this.fireEvent('leave', [this.element, this.overed]);
- if (overed) this.fireEvent('enter', [this.element, overed]);
- this.overed = overed;
- if (this.options.checkDroppables && this.droppables.length) this.checkDroppables();
- this.checkDroppables();
- this.fireEvent('drop', [this.element, this.overed, event]);
- return this.parent(event);
- makeDraggable: function(options){
- var drag = new Drag.Move(this, options);
- this.store('dragger', drag);
- return drag;
-script: Slider.js
-description: Class for creating horizontal and vertical slider controls.
-authors:
-- Valerio Proietti
-requires:
-- /Class.Binds
-- /Drag
-- /Element.Dimensions
-- /Element.Measure
-provides: [Slider]
-var Slider = new Class({
- Binds: ['clickedElement', 'draggedKnob', 'scrolledElement'],
- options: {/*
- onTick: $empty(intPosition),
- onChange: $empty(intStep),
- onComplete: $empty(strStep),*/
- onTick: function(position){
- if (this.options.snap) position = this.toPosition(this.step);
- this.knob.setStyle(this.property, position);
- initialStep: 0,
- snap: false,
- offset: 0,
- range: false,
- wheel: false,
- steps: 100,
- mode: 'horizontal'
- initialize: function(element, knob, options){
- this.setOptions(options);
- this.element = document.id(element);
- this.knob = document.id(knob);
- this.previousChange = this.previousEnd = this.step = -1;
- var offset, limit = {}, modifiers = {'x': false, 'y': false};
- switch (this.options.mode){
- case 'vertical':
- this.axis = 'y';
- this.property = 'top';
- offset = 'offsetHeight';
- break;
- case 'horizontal':
- this.axis = 'x';
- this.property = 'left';
- offset = 'offsetWidth';
- this.full = this.element.measure(function(){
- this.half = this.knob[offset] / 2;
- return this.element[offset] - this.knob[offset] + (this.options.offset * 2);
- }.bind(this));
- this.min = $chk(this.options.range[0]) ? this.options.range[0] : 0;
- this.max = $chk(this.options.range[1]) ? this.options.range[1] : this.options.steps;
- this.range = this.max - this.min;
- this.steps = this.options.steps || this.full;
- this.stepSize = Math.abs(this.range) / this.steps;
- this.stepWidth = this.stepSize * this.full / Math.abs(this.range) ;
- this.knob.setStyle('position', 'relative').setStyle(this.property, this.options.initialStep ? this.toPosition(this.options.initialStep) : - this.options.offset);
- modifiers[this.axis] = this.property;
- limit[this.axis] = [- this.options.offset, this.full - this.options.offset];
- var dragOptions = {
- snap: 0,
- limit: limit,
- modifiers: modifiers,
- onDrag: this.draggedKnob,
- onStart: this.draggedKnob,
- onBeforeStart: (function(){
- this.isDragging = true;
- }).bind(this),
- onCancel: function() {
- this.isDragging = false;
- }.bind(this),
- onComplete: function(){
- this.draggedKnob();
- this.end();
- }.bind(this)
- if (this.options.snap){
- dragOptions.grid = Math.ceil(this.stepWidth);
- dragOptions.limit[this.axis][1] = this.full;
- this.drag = new Drag(this.knob, dragOptions);
- this.attach();
- this.element.addEvent('mousedown', this.clickedElement);
- if (this.options.wheel) this.element.addEvent('mousewheel', this.scrolledElement);
- this.drag.attach();
- return this;
- detach: function(){
- this.element.removeEvent('mousedown', this.clickedElement);
- this.element.removeEvent('mousewheel', this.scrolledElement);
- this.drag.detach();
- return this;
- set: function(step){
- if (!((this.range > 0) ^ (step < this.min))) step = this.min;
- if (!((this.range > 0) ^ (step > this.max))) step = this.max;
- this.step = Math.round(step);
- this.checkStep();
- this.fireEvent('tick', this.toPosition(this.step));
- this.end();
- return this;
- clickedElement: function(event){
- if (this.isDragging || event.target == this.knob) return;
- var dir = this.range < 0 ? -1 : 1;
- var position = event.page[this.axis] - this.element.getPosition()[this.axis] - this.half;
- position = position.limit(-this.options.offset, this.full -this.options.offset);
- this.step = Math.round(this.min + dir * this.toStep(position));
- this.checkStep();
- this.fireEvent('tick', position);
- this.end();
- scrolledElement: function(event){
- var mode = (this.options.mode == 'horizontal') ? (event.wheel < 0) : (event.wheel > 0);
- this.set(mode ? this.step - this.stepSize : this.step + this.stepSize);
- event.stop();
- draggedKnob: function(){
- var position = this.drag.value.now[this.axis];
- this.checkStep();
- checkStep: function(){
- if (this.previousChange != this.step){
- this.previousChange = this.step;
- this.fireEvent('change', this.step);
- end: function(){
- if (this.previousEnd !== this.step){
- this.previousEnd = this.step;
- this.fireEvent('complete', this.step + '');
- toStep: function(position){
- var step = (position + this.options.offset) * this.stepSize / this.full * this.steps;
- return this.options.steps ? Math.round(step -= step % this.stepSize) : step;
- toPosition: function(step){
- return (this.full * Math.abs(this.min - step)) / (this.steps * this.stepSize) - this.options.offset;
-script: Sortables.js
-description: Class for creating a drag and drop sorting interface for lists of items.
-authors:
-- Tom Occhino
-requires:
-- /Drag.Move
-provides: [Slider]
-var Sortables = new Class({
- options: {/*
- onSort: $empty(element, clone),
- onStart: $empty(element, clone),
- onComplete: $empty(element),*/
- snap: 4,
- opacity: 1,
- clone: false,
- revert: false,
- handle: false,
- constrain: false
- initialize: function(lists, options){
- this.elements = [];
- this.lists = [];
- this.idle = true;
- this.addLists($$(document.id(lists) || lists));
- if (!this.options.clone) this.options.revert = false;
- if (this.options.revert) this.effect = new Fx.Morph(null, $merge({duration: 250, link: 'cancel'}, this.options.revert));
- this.addLists(this.lists);
- return this;
- this.lists = this.removeLists(this.lists);
- return this;
- addItems: function(){
- Array.flatten(arguments).each(function(element){
- this.elements.push(element);
- var start = element.retrieve('sortables:start', this.start.bindWithEvent(this, element));
- (this.options.handle ? element.getElement(this.options.handle) || element : element).addEvent('mousedown', start);
- }, this);
- return this;
- addLists: function(){
- Array.flatten(arguments).each(function(list){
- this.lists.push(list);
- this.addItems(list.getChildren());
- }, this);
- return this;
- removeItems: function(){
- return $$(Array.flatten(arguments).map(function(element){
- this.elements.erase(element);
- var start = element.retrieve('sortables:start');
- (this.options.handle ? element.getElement(this.options.handle) || element : element).removeEvent('mousedown', start);
- return element;
- }, this));
- removeLists: function(){
- return $$(Array.flatten(arguments).map(function(list){
- this.lists.erase(list);
- this.removeItems(list.getChildren());
- return list;
- }, this));
- getClone: function(event, element){
- if (!this.options.clone) return new Element('div').inject(document.body);
- if ($type(this.options.clone) == 'function') return this.options.clone.call(this, event, element, this.list);
- var clone = element.clone(true).setStyles({
- margin: '0px',
- position: 'absolute',
- visibility: 'hidden',
- 'width': element.getStyle('width')
- //prevent the duplicated radio inputs from unchecking the real one
- if (clone.get('html').test('radio')) {
- clone.getElements('input[type=radio]').each(function(input, i) {
- input.set('name', 'clone_' + i);
- return clone.inject(this.list).setPosition(element.getPosition(element.getOffsetParent()));
- getDroppables: function(){
- var droppables = this.list.getChildren();
- if (!this.options.constrain) droppables = this.lists.concat(droppables).erase(this.list);
- return droppables.erase(this.clone).erase(this.element);
- insert: function(dragging, element){
- var where = 'inside';
- if (this.lists.contains(element)){
- this.list = element;
- this.drag.droppables = this.getDroppables();
- } else {
- where = this.element.getAllPrevious().contains(element) ? 'before' : 'after';
- this.element.inject(element, where);
- this.fireEvent('sort', [this.element, this.clone]);
- start: function(event, element){
- if (!this.idle) return;
- this.idle = false;
- this.element = element;
- this.opacity = element.get('opacity');
- this.list = element.getParent();
- this.clone = this.getClone(event, element);
- this.drag = new Drag.Move(this.clone, {
- snap: this.options.snap,
- container: this.options.constrain && this.element.getParent(),
- droppables: this.getDroppables(),
- onSnap: function(){
- event.stop();
- this.clone.setStyle('visibility', 'visible');
- this.element.set('opacity', this.options.opacity || 0);
- this.fireEvent('start', [this.element, this.clone]);
- }.bind(this),
- onEnter: this.insert.bind(this),
- onCancel: this.reset.bind(this),
- onComplete: this.end.bind(this)
- this.clone.inject(this.element, 'before');
- this.drag.start(event);
- end: function(){
- this.element.set('opacity', this.opacity);
- if (this.effect){
- var dim = this.element.getStyles('width', 'height');
- var pos = this.clone.computePosition(this.element.getPosition(this.clone.offsetParent));
- this.effect.element = this.clone;
- this.effect.start({
- top: pos.top,
- left: pos.left,
- width: dim.width,
- height: dim.height,
- opacity: 0.25
- }).chain(this.reset.bind(this));
- } else {
- this.reset();
- this.idle = true;
- this.clone.destroy();
- this.fireEvent('complete', this.element);
- serialize: function(){
- var params = Array.link(arguments, {modifier: Function.type, index: $defined});
- var serial = this.lists.map(function(list){
- return list.getChildren().map(params.modifier || function(element){
- return element.get('id');
- }, this);
- }, this);
- var index = params.index;
- if (this.lists.length == 1) index = 0;
- return $chk(index) && index >= 0 && index < this.lists.length ? serial[index] : serial;
-script: Request.JSONP.js
-description: Defines Request.JSONP, a class for cross domain javascript via script injection.
-authors:
-- Aaron Newton
-- Guillermo Rauch
-requires:
-- core:1.2.4/Request
-- /Log
-provides: [Request.JSONP]
-Request.JSONP = new Class({
- Implements: [Chain, Events, Options, Log],
- options: {/*
- onRetry: $empty(intRetries),
- onRequest: $empty(scriptElement),
- onComplete: $empty(data),
- onSuccess: $empty(data),
- onCancel: $empty(),
- log: false,
- url: '',
- data: {},
- retries: 0,
- timeout: 0,
- link: 'ignore',
- callbackKey: 'callback',
- injectScript: document.head
- initialize: function(options){
- if (this.options.log) this.enableLog();
- this.running = false;
- this.requests = 0;
- this.triesRemaining = [];
- check: function(){
- if (!this.running) return true;
- switch (this.options.link){
- case 'cancel': this.cancel(); return true;
- case 'chain': this.chain(this.caller.bind(this, arguments)); return false;
- return false;
- send: function(options){
- if (!$chk(arguments[1]) && !this.check(options)) return this;
- var type = $type(options),
- old = this.options,
- index = $chk(arguments[1]) ? arguments[1] : this.requests++;
- if (type == 'string' || type == 'element') options = {data: options};
- options = $extend({data: old.data, url: old.url}, options);
- if (!$chk(this.triesRemaining[index])) this.triesRemaining[index] = this.options.retries;
- var remaining = this.triesRemaining[index];
- (function(){
- var script = this.getScript(options);
- this.log('JSONP retrieving script with url: ' + script.get('src'));
- this.fireEvent('request', script);
- this.running = true;
- (function(){
- if (remaining){
- this.triesRemaining[index] = remaining - 1;
- if (script){
- script.destroy();
- this.send(options, index).fireEvent('retry', this.triesRemaining[index]);
- } else if(script && this.options.timeout){
- script.destroy();
- this.cancel().fireEvent('failure');
- }).delay(this.options.timeout, this);
- }).delay(Browser.Engine.trident ? 50 : 0, this);
- return this;
- cancel: function(){
- if (!this.running) return this;
- this.fireEvent('cancel');
- return this;
- getScript: function(options){
- var index = Request.JSONP.counter,
- data;
- Request.JSONP.counter++;
- switch ($type(options.data)){
- case 'element': data = document.id(options.data).toQueryString(); break;
- case 'object': case 'hash': data = Hash.toQueryString(options.data);
- var src = options.url +
- (options.url.test('\\?') ? '&' :'?') +
- (options.callbackKey || this.options.callbackKey) +
- '=Request.JSONP.request_map.request_'+ index +
- (data ? '&' + data : '');
- if (src.length > 2083) this.log('JSONP '+ src +' will fail in Internet Explorer, which enforces a 2083 bytes length limit on URIs');
- var script = new Element('script', {type: 'text/javascript', src: src});
- Request.JSONP.request_map['request_' + index] = function(){ this.success(arguments, script); }.bind(this);
- return script.inject(this.options.injectScript);
- success: function(args, script){
- if (script) script.destroy();
- this.log('JSONP successfully retrieved: ', args);
- this.fireEvent('complete', args).fireEvent('success', args).callChain();
-Request.JSONP.counter = 0;
-Request.JSONP.request_map = {};/*
-script: Request.Queue.js
-description: Controls several instances of Request and its variants to run only one request at a time.
-authors:
-- Aaron Newton
-requires:
-- /Log
-provides: [Request.Queue]
-Request.Queue = new Class({
- Implements: [Options, Events],
- Binds: ['attach', 'request', 'complete', 'cancel', 'success', 'failure', 'exception'],
- options: {/*
- onRequest: $empty(argsPassedToOnRequest),
- onSuccess: $empty(argsPassedToOnSuccess),
- onComplete: $empty(argsPassedToOnComplete),
- onCancel: $empty(argsPassedToOnCancel),
- onException: $empty(argsPassedToOnException),
- onFailure: $empty(argsPassedToOnFailure),
- onEnd: $empty,
- stopOnFailure: true,
- autoAdvance: true,
- concurrent: 1,
- requests: {}
- if(options){
- var requests = options.requests;
- delete options.requests;
- this.requests = new Hash;
- this.queue = [];
- this.reqBinders = {};
- if(requests) this.addRequests(requests);
- addRequest: function(name, request){
- this.requests.set(name, request);
- this.attach(name, request);
- return this;
- addRequests: function(obj){
- $each(obj, function(req, name){
- this.addRequest(name, req);
- }, this);
- return this;
- getName: function(req){
- return this.requests.keyOf(req);
- attach: function(name, req){
- if (req._groupSend) return this;
- ['request', 'complete', 'cancel', 'success', 'failure', 'exception'].each(function(evt){
- if(!this.reqBinders[name]) this.reqBinders[name] = {};
- this.reqBinders[name][evt] = function(){
- this['on' + evt.capitalize()].apply(this, [name, req].extend(arguments));
- }.bind(this);
- req.addEvent(evt, this.reqBinders[name][evt]);
- }, this);
- req._groupSend = req.send;
- req.send = function(options){
- this.send(name, options);
- return req;
- }.bind(this);
- return this;
- removeRequest: function(req){
- var name = $type(req) == 'object' ? this.getName(req) : req;
- if (!name && $type(name) != 'string') return this;
- req = this.requests.get(name);
- if (!req) return this;
- req.removeEvent(evt, this.reqBinders[name][evt]);
- }, this);
- req.send = req._groupSend;
- delete req._groupSend;
- return this;
- getRunning: function(){
- return this.requests.filter(function(r){
- return r.running;
- isRunning: function(){
- return !!(this.getRunning().getKeys().length);
- send: function(name, options){
- var q = function(){
- this.requests.get(name)._groupSend(options);
- this.queue.erase(q);
- }.bind(this);
- q.name = name;
- if (this.getRunning().getKeys().length >= this.options.concurrent || (this.error && this.options.stopOnFailure)) this.queue.push(q);
- else q();
- return this;
- hasNext: function(name){
- return (!name) ? !!this.queue.length : !!this.queue.filter(function(q){ return q.name == name; }).length;
- resume: function(){
- this.error = false;
- (this.options.concurrent - this.getRunning().getKeys().length).times(this.runNext, this);
- return this;
- runNext: function(name){
- if (!this.queue.length) return this;
- if (!name){
- this.queue[0]();
- } else {
- var found;
- this.queue.each(function(q){
- if (!found && q.name == name){
- found = true;
- q();
- return this;
- runAll: function() {
- this.queue.each(function(q) {
- q();
- return this;
- clear: function(name){
- if (!name){
- this.queue.empty();
- } else {
- this.queue = this.queue.map(function(q){
- if (q.name != name) return q;
- else return false;
- }).filter(function(q){ return q; });
- return this;
- cancel: function(name){
- this.requests.get(name).cancel();
- return this;
- onRequest: function(){
- this.fireEvent('request', arguments);
- this.fireEvent('complete', arguments);
- if (!this.queue.length) this.fireEvent('end');
- onCancel: function(){
- if (this.options.autoAdvance && !this.error) this.runNext();
- this.fireEvent('cancel', arguments);
- onSuccess: function(){
- this.fireEvent('success', arguments);
- onFailure: function(){
- this.error = true;
- if (!this.options.stopOnFailure && this.options.autoAdvance) this.runNext();
- this.fireEvent('failure', arguments);
- onException: function(){
- this.fireEvent('exception', arguments);
-script: Request.Periodical.js
-description: Requests the same URL to pull data from a server but increases the intervals if no data is returned to reduce the load
-authors:
-- Christoph Pojer
-requires:
-- /MooTools.More
-provides: [Request.Periodical]
-Request.implement({
- options: {
- initialDelay: 5000,
- delay: 5000,
- limit: 60000
- startTimer: function(data){
- var fn = function(){
- if (!this.running) this.send({data: data});
- this.timer = fn.delay(this.options.initialDelay, this);
- this.lastDelay = this.options.initialDelay;
- this.completeCheck = function(response){
- $clear(this.timer);
- this.lastDelay = (response) ? this.options.delay : (this.lastDelay + this.options.delay).min(this.options.limit);
- this.timer = fn.delay(this.lastDelay, this);
- return this.addEvent('complete', this.completeCheck);
- stopTimer: function(){
- return this.removeEvent('complete', this.completeCheck);
-script: Assets.js
-description: Provides methods to dynamically load JavaScript, CSS, and Image files into the document.
-authors:
-- Valerio Proietti
-requires:
-- core:1.2.4/Element.Event
-- /MooTools.More
-provides: [Assets]
-var Asset = {
- javascript: function(source, properties){
- properties = $extend({
- onload: $empty,
- document: document,
- check: $lambda(true)
- }, properties);
- if (properties.onLoad) properties.onload = properties.onLoad;
- var script = new Element('script', {src: source, type: 'text/javascript'});
- var load = properties.onload.bind(script),
- check = properties.check,
- doc = properties.document;
- delete properties.onload;
- delete properties.check;
- delete properties.document;
- script.addEvents({
- load: load,
- readystatechange: function(){
- if (['loaded', 'complete'].contains(this.readyState)) load();
- }).set(properties);
- if (Browser.Engine.webkit419) var checker = (function(){
- if (!$try(check)) return;
- $clear(checker);
- load();
- }).periodical(50);
- return script.inject(doc.head);
- css: function(source, properties){
- return new Element('link', $merge({
- rel: 'stylesheet',
- media: 'screen',
- type: 'text/css',
- href: source
- }, properties)).inject(document.head);
- image: function(source, properties){
- properties = $merge({
- onload: $empty,
- onabort: $empty,
- onerror: $empty
- }, properties);
- var image = new Image();
- var element = document.id(image) || new Element('img');
- ['load', 'abort', 'error'].each(function(name){
- var type = 'on' + name;
- var cap = name.capitalize();
- if (properties['on' + cap]) properties[type] = properties['on' + cap];
- var event = properties[type];
- delete properties[type];
- image[type] = function(){
- if (!image) return;
- if (!element.parentNode){
- element.width = image.width;
- element.height = image.height;
- image = image.onload = image.onabort = image.onerror = null;
- event.delay(1, element, element);
- element.fireEvent(name, element, 1);
- image.src = element.src = source;
- if (image && image.complete) image.onload.delay(1);
- return element.set(properties);
- images: function(sources, options){
- options = $merge({
- onComplete: $empty,
- onProgress: $empty,
- onError: $empty,
- properties: {}
- }, options);
- sources = $splat(sources);
- var images = [];
- var counter = 0;
- return new Elements(sources.map(function(source){
- return Asset.image(source, $extend(options.properties, {
- onload: function(){
- options.onProgress.call(this, counter, sources.indexOf(source));
- counter++;
- if (counter == sources.length) options.onComplete();
- onerror: function(){
- options.onError.call(this, counter, sources.indexOf(source));
- counter++;
-script: Color.js
-description: Class for creating and manipulating colors in JavaScript. Supports HSB -> RGB Conversions and vice versa.
-authors:
-- Valerio Proietti
-requires:
-- core:1.2.4/Array
-- core:1.2.4/String
-- core:1.2.4/Number
-- core:1.2.4/Hash
-- core:1.2.4/Function
-- core:1.2.4/$util
-provides: [Color]
-var Color = new Native({
- initialize: function(color, type){
- if (arguments.length >= 3){
- type = 'rgb'; color = Array.slice(arguments, 0, 3);
- } else if (typeof color == 'string'){
- if (color.match(/rgb/)) color = color.rgbToHex().hexToRgb(true);
- else if (color.match(/hsb/)) color = color.hsbToRgb();
- else color = color.hexToRgb(true);
- type = type || 'rgb';
- switch (type){
- case 'hsb':
- var old = color;
- color = color.hsbToRgb();
- color.hsb = old;
- break;
- case 'hex': color = color.hexToRgb(true); break;
- color.rgb = color.slice(0, 3);
- color.hsb = color.hsb || color.rgbToHsb();
- color.hex = color.rgbToHex();
- return $extend(color, this);
-Color.implement({
- mix: function(){
- var colors = Array.slice(arguments);
- var alpha = ($type(colors.getLast()) == 'number') ? colors.pop() : 50;
- var rgb = this.slice();
- colors.each(function(color){
- color = new Color(color);
- for (var i = 0; i < 3; i++) rgb[i] = Math.round((rgb[i] / 100 * (100 - alpha)) + (color[i] / 100 * alpha));
- return new Color(rgb, 'rgb');
- invert: function(){
- return new Color(this.map(function(value){
- return 255 - value;
- setHue: function(value){
- return new Color([value, this.hsb[1], this.hsb[2]], 'hsb');
- setSaturation: function(percent){
- return new Color([this.hsb[0], percent, this.hsb[2]], 'hsb');
- setBrightness: function(percent){
- return new Color([this.hsb[0], this.hsb[1], percent], 'hsb');
-var $RGB = function(r, g, b){
- return new Color([r, g, b], 'rgb');
-var $HSB = function(h, s, b){
- return new Color([h, s, b], 'hsb');
-var $HEX = function(hex){
- return new Color(hex, 'hex');
-Array.implement({
- rgbToHsb: function(){
- var red = this[0],
- green = this[1],
- blue = this[2],
- hue = 0;
- var max = Math.max(red, green, blue),
- min = Math.min(red, green, blue);
- var delta = max - min;
- var brightness = max / 255,
- saturation = (max != 0) ? delta / max : 0;
- if(saturation != 0) {
- var rr = (max - red) / delta;
- var gr = (max - green) / delta;
- var br = (max - blue) / delta;
- if (red == max) hue = br - gr;
- else if (green == max) hue = 2 + rr - br;
- else hue = 4 + gr - rr;
- hue /= 6;
- if (hue < 0) hue++;
- return [Math.round(hue * 360), Math.round(saturation * 100), Math.round(brightness * 100)];
- hsbToRgb: function(){
- var br = Math.round(this[2] / 100 * 255);
- if (this[1] == 0){
- return [br, br, br];
- } else {
- var hue = this[0] % 360;
- var f = hue % 60;
- var p = Math.round((this[2] * (100 - this[1])) / 10000 * 255);
- var q = Math.round((this[2] * (6000 - this[1] * f)) / 600000 * 255);
- var t = Math.round((this[2] * (6000 - this[1] * (60 - f))) / 600000 * 255);
- switch (Math.floor(hue / 60)){
- case 0: return [br, t, p];
- case 1: return [q, br, p];
- case 2: return [p, br, t];
- case 3: return [p, q, br];
- case 4: return [t, p, br];
- case 5: return [br, p, q];
- return false;
-String.implement({
- var rgb = this.match(/\d{1,3}/g);
- return (rgb) ? rgb.rgbToHsb() : null;
- var hsb = this.match(/\d{1,3}/g);
- return (hsb) ? hsb.hsbToRgb() : null;
-script: Group.js
-description: Class for monitoring collections of events
-authors:
-- Valerio Proietti
-requires:
-- /MooTools.More
-provides: [Group]
-var Group = new Class({
- initialize: function(){
- this.instances = Array.flatten(arguments);
- this.events = {};
- this.checker = {};
- addEvent: function(type, fn){
- this.checker[type] = this.checker[type] || {};
- this.events[type] = this.events[type] || [];
- if (this.events[type].contains(fn)) return false;
- else this.events[type].push(fn);
- this.instances.each(function(instance, i){
- instance.addEvent(type, this.check.bind(this, [type, instance, i]));
- }, this);
- return this;
- check: function(type, instance, i){
- this.checker[type][i] = true;
- var every = this.instances.every(function(current, j){
- return this.checker[type][j] || false;
- }, this);
- if (!every) return;
- this.checker[type] = {};
- this.events[type].each(function(event){
- event.call(this, this.instances, instance);
- }, this);
-script: Hash.Cookie.js
-description: Class for creating, reading, and deleting Cookies in JSON format.
-authors:
-- Valerio Proietti
-- Aaron Newton
-requires:
-- core:1.2.4/Cookie
-- core:1.2.4/JSON
-- /MooTools.More
-provides: [Hash.Cookie]
-Hash.Cookie = new Class({
- Extends: Cookie,
- options: {
- autoSave: true
- initialize: function(name, options){
- this.parent(name, options);
- this.load();
- save: function(){
- var value = JSON.encode(this.hash);
- if (!value || value.length > 4096) return false; //cookie would be truncated!
- if (value == '{}') this.dispose();
- else this.write(value);
- return true;
- load: function(){
- this.hash = new Hash(JSON.decode(this.read(), true));
- return this;
-Hash.each(Hash.prototype, function(method, name){
- if (typeof method == 'function') Hash.Cookie.implement(name, function(){
- var value = method.apply(this.hash, arguments);
- if (this.options.autoSave) this.save();
- return value;
-script: HtmlTable.js
-description: Builds table elements with methods to add rows.
-authors:
-- Aaron Newton
-requires:
-- /Class.Occlude
-provides: [HtmlTable]
-var HtmlTable = new Class({
- Implements: [Options, Events, Class.Occlude],
- options: {
- properties: {
- cellpadding: 0,
- cellspacing: 0,
- border: 0
- rows: [],
- headers: [],
- footers: []
- property: 'HtmlTable',
- var params = Array.link(arguments, {options: Object.type, table: Element.type});
- this.setOptions(params.options);
- this.element = params.table || new Element('table', this.options.properties);
- if (this.occlude()) return this.occluded;
- this.build();
- build: function(){
- this.element.store('HtmlTable', this);
- this.body = document.id(this.element.tBodies[0]) || new Element('tbody').inject(this.element);
- $$(this.body.rows);
- if (this.options.headers.length) this.setHeaders(this.options.headers);
- else this.thead = document.id(this.element.tHead);
- if (this.thead) this.head = document.id(this.thead.rows[0]);
- if (this.options.footers.length) this.setFooters(this.options.footers);
- this.tfoot = document.id(this.element.tFoot);
- if (this.tfoot) this.foot = document.id(this.thead.rows[0]);
- this.options.rows.each(function(row){
- this.push(row);
- }, this);
- ['adopt', 'inject', 'wraps', 'grab', 'replaces', 'dispose'].each(function(method){
- this[method] = this.element[method].bind(this.element);
- }, this);
- toElement: function(){
- return this.element;
- empty: function(){
- this.body.empty();
- return this;
- set: function(what, items) {
- var target = (what == 'headers') ? 'tHead' : 'tFoot';
- this[target.toLowerCase()] = (document.id(this.element[target]) || new Element(target.toLowerCase()).inject(this.element, 'top')).empty();
- var data = this.push(items, {}, this[target.toLowerCase()], what == 'headers' ? 'th' : 'td');
- if (what == 'headers') this.head = document.id(this.thead.rows[0]);
- else this.foot = document.id(this.thead.rows[0]);
- return data;
- setHeaders: function(headers){
- this.set('headers', headers);
- return this;
- setFooters: function(footers){
- this.set('footers', footers);
- return this;
- push: function(row, rowProperties, target, tag){
- var tds = row.map(function(data){
- var td = new Element(tag || 'td', data.properties),
- type = data.content || data || '',
- element = document.id(type);
- if($type(type) != 'string' && element) td.adopt(element);
- else td.set('html', type);
- return td;
- return {
- tr: new Element('tr', rowProperties).inject(target || this.body).adopt(tds),
- tds: tds
-script: HtmlTable.Zebra.js
-description: Builds a stripy table with methods to add rows.
-authors:
-- Harald Kirschner
-- Aaron Newton
-requires:
-- /HtmlTable
-- /Class.refactor
-provides: [HtmlTable.Zebra]
-HtmlTable = Class.refactor(HtmlTable, {
- options: {
- classZebra: 'table-tr-odd',
- zebra: true
- this.previous.apply(this, arguments);
- if (this.occluded) return this.occluded;
- if (this.options.zebra) this.updateZebras();
- updateZebras: function(){
- Array.each(this.body.rows, this.zebra, this);
- zebra: function(row, i){
- return row[((i % 2) ? 'remove' : 'add')+'Class'](this.options.classZebra);
- push: function(){
- var pushed = this.previous.apply(this, arguments);
- return pushed;
-script: HtmlTable.Sort.js
-description: Builds a stripy, sortable table with methods to add rows.
-authors:
-- Harald Kirschner
-- Aaron Newton
-requires:
-- core:1.2.4/Hash
-- /HtmlTable
-- /Class.refactor
-- /Element.Delegation
-- /Date
-provides: [HtmlTable.Sort]
- options: {/*
- onSort: $empty, */
- sortIndex: 0,
- sortReverse: false,
- parsers: [],
- defaultParser: 'string',
- classSortable: 'table-sortable',
- classHeadSort: 'table-th-sort',
- classHeadSortRev: 'table-th-sort-rev',
- classNoSort: 'table-th-nosort',
- classGroupHead: 'table-tr-group-head',
- classGroup: 'table-tr-group',
- classCellSort: 'table-td-sort',
- classSortSpan: 'table-th-sort-span',
- sortable: false
- initialize: function () {
- this.sorted = {index: null, dir: 1};
- this.bound = {
- headClick: this.headClick.bind(this)
- this.sortSpans = new Elements();
- if (this.options.sortable) {
- this.enableSort();
- if (this.options.sortIndex != null) this.sort(this.options.sortIndex, this.options.sortReverse);
- attachSorts: function(attach){
- this.element.removeEvents('click:relay(th)');
- this.element[$pick(attach, true) ? 'addEvent' : 'removeEvent']('click:relay(th)', this.bound.headClick);
- setHeaders: function(){
- if (this.sortEnabled) this.detectParsers();
- detectParsers: function(force){
- if (!this.head) return;
- var parsers = this.options.parsers,
- rows = this.body.rows;
- // auto-detect
- this.parsers = $$(this.head.cells).map(function(cell, index) {
- if (!force && (cell.hasClass(this.options.classNoSort) || cell.retrieve('htmltable-parser'))) return cell.retrieve('htmltable-parser');
- var thDiv = new Element('div');
- $each(cell.childNodes, function(node) {
- thDiv.adopt(node);
- thDiv.inject(cell);
- var sortSpan = new Element('span', {'html': ' ', 'class': this.options.classSortSpan}).inject(thDiv, 'top');
- this.sortSpans.push(sortSpan);
- var parser = parsers[index],
- cancel;
- switch ($type(parser)) {
- case 'function': parser = {convert: parser}; cancel = true; break;
- case 'string': parser = parser; cancel = true; break;
- if (!cancel) {
- HtmlTable.Parsers.some(function(current) {
- var match = current.match;
- if (!match) return false;
- for (var i = 0, j = rows.length; i < j; i++) {
- var text = $(rows[i].cells[index]).get('html').clean();
- if (text && match.test(text)) {
- parser = current;
- return true;
- if (!parser) parser = this.options.defaultParser;
- cell.store('htmltable-parser', parser);
- return parser;
- }, this);
- headClick: function(event, el) {
- console.log(el);
- if (!this.head || el.hasClass(this.options.classNoSort)) return;
- var index = Array.indexOf(this.head.cells, el);
- this.sort(index);
- return false;
- sort: function(index, reverse, pre) {
- pre = !!(pre);
- var classCellSort = this.options.classCellSort;
- var classGroup = this.options.classGroup,
- classGroupHead = this.options.classGroupHead;
- if (!pre) {
- if (index != null) {
- if (this.sorted.index == index) {
- this.sorted.reverse = !(this.sorted.reverse);
- } else {
- if (this.sorted.index != null) {
- this.sorted.reverse = false;
- this.head.cells[this.sorted.index].removeClass(this.options.classHeadSort).removeClass(this.options.classHeadSortRev);
- } else {
- this.sorted.reverse = true;
- this.sorted.index = index;
- } else {
- index = this.sorted.index;
- if (reverse != null) this.sorted.reverse = reverse;
- var head = document.id(this.head.cells[index]);
- if (head) {
- head.addClass(this.options.classHeadSort);
- if (this.sorted.reverse) head.addClass(this.options.classHeadSortRev);
- else head.removeClass(this.options.classHeadSortRev);
- this.body.getElements('td').removeClass(this.options.classCellSort);
- var parser = this.parsers[index];
- if ($type(parser) == 'string') parser = HtmlTable.Parsers.get(parser);
- if (!parser) return;
- if (!Browser.Engine.trident) {
- var rel = this.body.getParent();
- this.body.dispose();
- var data = Array.map(this.body.rows, function(row, i) {
- var value = parser.convert.call(document.id(row.cells[index]));
- return {
- position: i,
- value: value,
- toString: function() {
- return value.toString();
- }, this);
- data.reverse(true);
- data.sort(function(a, b){
- if (a.value === b.value) return 0;
- return a.value > b.value ? 1 : -1;
- if (!this.sorted.reverse) data.reverse(true);
- var i = data.length, body = this.body;
- var j, position, entry, group;
- while (i) {
- var item = data[--i];
- position = item.position;
- var row = body.rows[position];
- if (row.disabled) continue;
- if (!pre) {
- if (group === item.value) {
- row.removeClass(classGroupHead).addClass(classGroup);
- } else {
- group = item.value;
- row.removeClass(classGroup).addClass(classGroupHead);
- if (this.zebra) this.zebra(row, i);
- row.cells[index].addClass(classCellSort);
- body.appendChild(row);
- for (j = 0; j < i; j++) {
- if (data[j].position > position) data[j].position--;
- data = null;
- if (rel) rel.grab(body);
- return this.fireEvent('sort', [body, index]);
- reSort: function(){
- if (this.sortEnabled) this.sort.call(this, this.sorted.index, this.sorted.reverse);
- return this;
- enableSort: function(){
- this.element.addClass(this.options.classSortable);
- this.attachSorts(true);
- this.detectParsers();
- this.sortEnabled = true;
- return this;
- disableSort: function(){
- this.element.removeClass(this.options.classSortable);
- this.attachSorts(false);
- this.sortSpans.each(function(span) { span.destroy(); });
- this.sortSpans.empty();
- this.sortEnabled = false;
- return this;
-HtmlTable.Parsers = new Hash({
- 'date': {
- match: /^\d{2}[-\/ ]\d{2}[-\/ ]\d{2,4}$/,
- convert: function() {
- return Date.parse(this.get('text')).format('db');
- type: 'date'
- 'input-checked': {
- match: / type="(radio|checkbox)" /,
- return this.getElement('input').checked;
- 'input-value': {
- match: /<input/,
- return this.getElement('input').value;
- 'number': {
- match: /^\d+[^\d.,]*$/,
- return this.get('text').toInt();
- number: true
- 'numberLax': {
- match: /^[^\d]+\d+$/,
- return this.get('text').replace(/[^-?^0-9]/, '').toInt();
- number: true
- 'float': {
- match: /^[\d]+\.[\d]+/,
- return this.get('text').replace(/[^-?^\d.]/, '').toFloat();
- number: true
- 'floatLax': {
- match: /^[^\d]+[\d]+\.[\d]+$/,
- return this.get('text').replace(/[^-?^\d.]/, '');
- number: true
- 'string': {
- match: null,
- return this.get('text');
- 'title': {
- match: null,
- return this.title;
-script: Keyboard.js
-description: KeyboardEvents used to intercept events on a class for keyboard and format modifiers in a specific order so as to make alt+shift+c the same as shift+alt+c.
-license: MIT-style license
-authors:
-- Perrin Westrich
-- Aaron Newton
-- Scott Kyle
-requires:
-- /Log
-provides: [Keyboard]
-(function(){
- var Keyboard = this.Keyboard = new Class({
- Extends: Events,
- Implements: [Options, Log],
- options: {
- onActivate: $empty,
- onDeactivate: $empty,
- defaultEventType: 'keydown',
- active: false,
- events: {},
- nonParsedEvents: ['activate', 'deactivate', 'onactivate', 'ondeactivate', 'changed', 'onchanged']
- this.setup();
- setup: function(){
- this.addEvents(this.options.events);
- //if this is the root manager, nothing manages it
- if (Keyboard.manager && !this.manager) Keyboard.manager.manage(this);
- if (this.options.active) this.activate();
- handle: function(event, type){
- //Keyboard.stop(event) prevents key propagation
- if (event.preventKeyboardPropagation) return;
- var bubbles = !!this.manager;
- if (bubbles && this.activeKB){
- this.activeKB.handle(event, type);
- this.fireEvent(type, event);
- if (!bubbles && this.activeKB) this.activeKB.handle(event, type);
- addEvent: function(type, fn, internal){
- return this.parent(Keyboard.parse(type, this.options.defaultEventType, this.options.nonParsedEvents), fn, internal);
- removeEvent: function(type, fn){
- return this.parent(Keyboard.parse(type, this.options.defaultEventType, this.options.nonParsedEvents), fn);
- toggleActive: function(){
- return this[this.active ? 'deactivate' : 'activate']();
- activate: function(instance){
- if (instance) {
- //if we're stealing focus, store the last keyboard to have it so the relenquish command works
- if (instance != this.activeKB) this.previous = this.activeKB;
- //if we're enabling a child, assign it so that events are now passed to it
- this.activeKB = instance.fireEvent('activate');
- Keyboard.manager.fireEvent('changed');
- } else if (this.manager) {
- //else we're enabling ourselves, we must ask our parent to do it for us
- this.manager.activate(this);
- return this;
- deactivate: function(instance){
- if (instance) {
- if(instance === this.activeKB) {
- this.activeKB = null;
- instance.fireEvent('deactivate');
- else if (this.manager) {
- this.manager.deactivate(this);
- return this;
- relenquish: function(){
- if (this.previous) this.activate(this.previous);
- //management logic
- manage: function(instance){
- if (instance.manager) instance.manager.drop(instance);
- this.instances.push(instance);
- instance.manager = this;
- if (!this.activeKB) this.activate(instance);
- else this._disable(instance);
- _disable: function(instance){
- if (this.activeKB == instance) this.activeKB = null;
- drop: function(instance){
- this._disable(instance);
- this.instances.erase(instance);
- instances: [],
- trace: function(){
- Keyboard.trace(this);
- each: function(fn){
- Keyboard.each(this, fn);
- var parsed = {};
- var modifiers = ['shift', 'control', 'alt', 'meta'];
- var regex = /^(?:shift|control|ctrl|alt|meta)$/;
- Keyboard.parse = function(type, eventType, ignore){
- if (ignore && ignore.contains(type.toLowerCase())) return type;
- type = type.toLowerCase().replace(/^(keyup|keydown):/, function($0, $1){
- eventType = $1;
- return '';
- if (!parsed[type]){
- var key, mods = {};
- type.split('+').each(function(part){
- if (regex.test(part)) mods[part] = true;
- else key = part;
- mods.control = mods.control || mods.ctrl; // allow both control and ctrl
- var keys = [];
- modifiers.each(function(mod){
- if (mods[mod]) keys.push(mod);
- if (key) keys.push(key);
- parsed[type] = keys.join('+');
- return eventType + ':' + parsed[type];
- Keyboard.each = function(keyboard, fn){
- var current = keyboard || Keyboard.manager;
- while (current){
- fn.run(current);
- current = current.activeKB;
- Keyboard.stop = function(event){
- event.preventKeyboardPropagation = true;
- Keyboard.manager = new Keyboard({
- active: true
- Keyboard.trace = function(keyboard){
- keyboard = keyboard || Keyboard.manager;
- keyboard.enableLog();
- keyboard.log('the following items have focus: ');
- Keyboard.each(keyboard, function(current){
- keyboard.log(document.id(current.widget) || current.wiget || current);
- var handler = function(event){
- var keys = [];
- if (event[mod]) keys.push(mod);
- if (!regex.test(event.key)) keys.push(event.key);
- Keyboard.manager.handle(event, event.type + ':' + keys.join('+'));
- document.addEvents({
- 'keyup': handler,
- 'keydown': handler
- Event.Keys.extend({
- 'shift': 16,
- 'control': 17,
- 'alt': 18,
- 'capslock': 20,
- 'pageup': 33,
- 'pagedown': 34,
- 'end': 35,
- 'home': 36,
- 'numlock': 144,
- 'scrolllock': 145,
- ';': 186,
- '=': 187,
- ',': 188,
- '-': Browser.Engine.Gecko ? 109 : 189,
- '.': 190,
- '/': 191,
- '`': 192,
- '[': 219,
- '\\': 220,
- ']': 221,
- "'": 222
-script: HtmlTable.Select.js
-description: Builds a stripy, sortable table with methods to add rows. Rows can be selected with the mouse or keyboard navigation.
-authors:
-- Harald Kirschner
-- Aaron Newton
-requires:
-- /Keyboard
-- /HtmlTable
-- /Class.refactor
-provides: [HtmlTable.Select]
- options: {
- /*onRowFocus: $empty,
- onRowUnfocus: $empty,*/
- useKeyboard: true,
- classRowSelected: 'table-tr-selected',
- classRowHovered: 'table-tr-hovered',
- classSelectable: 'table-selectable',
- allowMultiSelect: true,
- selectable: false
- this.selectedRows = new Elements();
- this.bound = {
- mouseleave: this.mouseleave.bind(this),
- focusRow: this.focusRow.bind(this)
- if (this.options.selectable) this.enableSelect();
- enableSelect: function(){
- this.selectEnabled = true;
- this.attachSelects();
- this.element.addClass(this.options.classSelectable);
- disableSelect: function(){
- this.selectEnabled = false;
- this.attach(false);
- this.element.removeClass(this.options.classSelectable);
- attachSelects: function(attach){
- attach = $pick(attach, true);
- var method = attach ? 'addEvents' : 'removeEvents';
- this.element[method]({
- mouseleave: this.bound.mouseleave
- this.body[method]({
- 'click:relay(tr)': this.bound.focusRow
- if (this.options.useKeyboard || this.keyboard){
- if (!this.keyboard) this.keyboard = new Keyboard({
- events: {
- down: function(e) {
- e.preventDefault();
- this.shiftFocus(1);
- }.bind(this),
- up: function(e) {
- this.shiftFocus(-1);
- }.bind(this),
- enter: function(e) {
- if (this.hover) this.focusRow(this.hover);
- }.bind(this)
- active: true
- this.keyboard[attach ? 'activate' : 'deactivate']();
- this.updateSelects();
- mouseleave: function(){
- if (this.hover) this.leaveRow(this.hover);
- focus: function(){
- if (this.keyboard) this.keyboard.activate();
- blur: function(){
- if (this.keyboard) this.keyboard.deactivate();
- push: function(){
- var ret = this.previous.apply(this, arguments);
- return ret;
- updateSelects: function(){
- Array.each(this.body.rows, function(row){
- var binders = row.retrieve('binders');
- if ((binders && this.selectEnabled) || (!binders && !this.selectEnabled)) return;
- if (!binders){
- binders = {
- mouseenter: this.enterRow.bind(this, [row]),
- mouseleave: this.leaveRow.bind(this, [row])
- row.store('binders', binders).addEvents(binders);
- } else {
- row.removeEvents(binders);
- }, this);
- enterRow: function(row){
- if (this.hover) this.hover = this.leaveRow(this.hover);
- this.hover = row.addClass(this.options.classRowHovered);
- shiftFocus: function(offset){
- if (!this.hover) return this.enterRow(this.body.rows[0]);
- var to = Array.indexOf(this.body.rows, this.hover) + offset;
- if (to < 0) to = 0;
- if (to >= this.body.rows.length) to = this.body.rows.length - 1;
- if (this.hover == this.body.rows[to]) return this;
- this.enterRow(this.body.rows[to]);
- leaveRow: function(row){
- row.removeClass(this.options.classRowHovered);
- focusRow: function(){
- var row = arguments[1] || arguments[0]; //delegation passes the event first
- if (!this.body.getChildren().contains(row)) return;
- var unfocus = function(row){
- this.selectedRows.erase(row);
- row.removeClass(this.options.classRowSelected);
- this.fireEvent('rowUnfocus', [row, this.selectedRows]);
- }.bind(this);
- if (!this.options.allowMultiSelect) this.selectedRows.each(unfocus);
- if (!this.selectedRows.contains(row)) {
- this.selectedRows.push(row);
- row.addClass(this.options.classRowSelected);
- this.fireEvent('rowFocus', [row, this.selectedRows]);
- } else {
- unfocus(row);
- return false;
- selectAll: function(status){
- status = $pick(status, true);
- if (!this.options.allowMultiSelect && status) return;
- if (!status) this.selectedRows.removeClass(this.options.classRowSelected).empty();
- else this.selectedRows.combine(this.body.rows).addClass(this.options.classRowSelected);
- return this;
- selectNone: function(){
- return this.selectAll(false);
-description: Enhances Keyboard by adding the ability to name and describe keyboard shortcuts, and the ability to grab shortcuts by name and bind the shortcut to different keys.
-authors:
-- Perrin Westrich
-requires:
-- /Keyboard.Extras
-provides: [Keyboard.Extras]
-Keyboard.prototype.options.nonParsedEvents.combine(['rebound', 'onrebound']);
-Keyboard.implement({
- shortcut should be in the format of:
- 'keys': 'shift+s', // the default to add as an event.
- 'description': 'blah blah blah', // a brief description of the functionality.
- 'handler': function(){} // the event handler to run when keys are pressed.
- addShortcut: function(name, shortcut) {
- this.shortcuts = this.shortcuts || [];
- this.shortcutIndex = this.shortcutIndex || {};
- shortcut.getKeyboard = $lambda(this);
- shortcut.name = name;
- this.shortcutIndex[name] = shortcut;
- this.shortcuts.push(shortcut);
- if(shortcut.keys) this.addEvent(shortcut.keys, shortcut.handler);
- return this;
- addShortcuts: function(obj){
- for(var name in obj) this.addShortcut(name, obj[name]);
- return this;
- getShortcuts: function(){
- return this.shortcuts || [];
- getShortcut: function(name){
- return (this.shortcutIndex || {})[name];
-Keyboard.rebind = function(newKeys, shortcuts){
- $splat(shortcuts).each(function(shortcut){
- shortcut.getKeyboard().removeEvent(shortcut.keys, shortcut.handler);
- shortcut.getKeyboard().addEvent(newKeys, shortcut.handler);
- shortcut.keys = newKeys;
- shortcut.getKeyboard().fireEvent('rebound');
-Keyboard.getActiveShortcuts = function(keyboard) {
- var activeKBS = [], activeSCS = [];
- Keyboard.each(keyboard, [].push.bind(activeKBS));
- activeKBS.each(function(kb){ activeSCS.extend(kb.getShortcuts()); });
- return activeSCS;
-Keyboard.getShortcut = function(name, keyboard, opts){
- opts = opts || {};
- var shortcuts = opts.many ? [] : null,
- set = opts.many ? function(kb){
- var shortcut = kb.getShortcut(name);
- if(shortcut) shortcuts.push(shortcut);
- } : function(kb) {
- if(!shortcuts) shortcuts = kb.getShortcut(name);
- Keyboard.each(keyboard, set);
- return shortcuts;
-Keyboard.getShortcuts = function(name, keyboard) {
- return Keyboard.getShortcut(name, keyboard, { many: true });
-script: Scroller.js
-description: Class which scrolls the contents of any Element (including the window) when the mouse reaches the Element's boundaries.
-authors:
-- Valerio Proietti
-requires:
-- core:1.2.4/Element.Dimensions
-provides: [Scroller]
-var Scroller = new Class({
- options: {
- area: 20,
- velocity: 1,
- onChange: function(x, y){
- this.element.scrollTo(x, y);
- fps: 50
- this.docBody = document.id(this.element.getDocument().body);
- this.listener = ($type(this.element) != 'element') ? this.docBody : this.element;
- this.timer = null;
- this.bound = {
- attach: this.attach.bind(this),
- detach: this.detach.bind(this),
- getCoords: this.getCoords.bind(this)
- start: function(){
- this.listener.addEvents({
- mouseover: this.bound.attach,
- mouseout: this.bound.detach
- stop: function(){
- this.listener.removeEvents({
- this.detach();
- this.timer = $clear(this.timer);
- attach: function(){
- this.listener.addEvent('mousemove', this.bound.getCoords);
- this.listener.removeEvent('mousemove', this.bound.getCoords);
- getCoords: function(event){
- this.page = (this.listener.get('tag') == 'body') ? event.client : event.page;
- if (!this.timer) this.timer = this.scroll.periodical(Math.round(1000 / this.options.fps), this);
- scroll: function(){
- var size = this.element.getSize(),
- scroll = this.element.getScroll(),
- pos = this.element != this.docBody ? this.element.getOffsets() : {x: 0, y:0},
- scrollSize = this.element.getScrollSize(),
- change = {x: 0, y: 0};
- for (var z in this.page){
- if (this.page[z] < (this.options.area + pos[z]) && scroll[z] != 0) {
- change[z] = (this.page[z] - this.options.area - pos[z]) * this.options.velocity;
- } else if (this.page[z] + this.options.area > (size[z] + pos[z]) && scroll[z] + size[z] != scrollSize[z]) {
- change[z] = (this.page[z] - size[z] + this.options.area - pos[z]) * this.options.velocity;
- if (change.y || change.x) this.fireEvent('change', [scroll.x + change.x, scroll.y + change.y]);
-script: Tips.js
-description: Class for creating nice tips that follow the mouse cursor when hovering an element.
-authors:
-- Valerio Proietti
-- Christoph Pojer
-requires:
-- /MooTools.More
-provides: [Tips]
-(function(){
-var read = function(option, element){
- return (option) ? ($type(option) == 'function' ? option(element) : element.get(option)) : '';
-this.Tips = new Class({
- options: {
- onAttach: $empty(element),
- onDetach: $empty(element),
- onShow: function(){
- this.tip.setStyle('display', 'block');
- onHide: function(){
- this.tip.setStyle('display', 'none');
- title: 'title',
- text: function(element){
- return element.get('rel') || element.get('href');
- showDelay: 100,
- hideDelay: 100,
- className: 'tip-wrap',
- offset: {x: 16, y: 16},
- windowPadding: {x:0, y:0},
- fixed: false
- var params = Array.link(arguments, {options: Object.type, elements: $defined});
- if (params.elements) this.attach(params.elements);
- this.container = new Element('div', {'class': 'tip'});
- if (this.tip) return this.tip;
- return this.tip = new Element('div', {
- 'class': this.options.className,
- styles: {
- top: 0,
- left: 0
- }).adopt(
- new Element('div', {'class': 'tip-top'}),
- this.container,
- new Element('div', {'class': 'tip-bottom'})
- ).inject(document.body);
- attach: function(elements){
- $$(elements).each(function(element){
- var title = read(this.options.title, element),
- text = read(this.options.text, element);
- element.erase('title').store('tip:native', title).retrieve('tip:title', title);
- element.retrieve('tip:text', text);
- this.fireEvent('attach', [element]);
- var events = ['enter', 'leave'];
- if (!this.options.fixed) events.push('move');
- events.each(function(value){
- var event = element.retrieve('tip:' + value);
- if (!event) event = this['element' + value.capitalize()].bindWithEvent(this, element);
- element.store('tip:' + value, event).addEvent('mouse' + value, event);
- }, this);
- }, this);
- return this;
- detach: function(elements){
- ['enter', 'leave', 'move'].each(function(value){
- element.removeEvent('mouse' + value, element.retrieve('tip:' + value)).eliminate('tip:' + value);
- this.fireEvent('detach', [element]);
- if (this.options.title == 'title'){ // This is necessary to check if we can revert the title
- var original = element.retrieve('tip:native');
- if (original) element.set('title', original);
- }, this);
- return this;
- elementEnter: function(event, element){
- this.container.empty();
- ['title', 'text'].each(function(value){
- var content = element.retrieve('tip:' + value);
- if (content) this.fill(new Element('div', {'class': 'tip-' + value}).inject(this.container), content);
- }, this);
- this.timer = (function(){
- this.show(this, element);
- this.position((this.options.fixed) ? {page: element.getPosition()} : event);
- }).delay(this.options.showDelay, this);
- elementLeave: function(event, element){
- this.timer = this.hide.delay(this.options.hideDelay, this, element);
- this.fireForParent(event, element);
- fireForParent: function(event, element){
- element = element.getParent();
- if (!element || element == document.body) return;
- if (element.retrieve('tip:enter')) element.fireEvent('mouseenter', event);
- else this.fireForParent(event, element);
- elementMove: function(event, element){
- this.position(event);
- position: function(event){
- if (!this.tip) document.id(this);
- var size = window.getSize(), scroll = window.getScroll(),
- tip = {x: this.tip.offsetWidth, y: this.tip.offsetHeight},
- props = {x: 'left', y: 'top'},
- obj = {};
- for (var z in props){
- obj[props[z]] = event.page[z] + this.options.offset[z];
- if ((obj[props[z]] + tip[z] - scroll[z]) > size[z] - this.options.windowPadding[z]) obj[props[z]] = event.page[z] - this.options.offset[z] - tip[z];
- this.tip.setStyles(obj);
- fill: function(element, contents){
- if(typeof contents == 'string') element.set('html', contents);
- else element.adopt(contents);
- show: function(element){
- this.fireEvent('show', [this.tip, element]);
- hide: function(element){
- this.fireEvent('hide', [this.tip, element]);
-script: Date.Catalan.js
-description: Date messages for Catalan.
-authors:
-- Alfons Sanchez
-requires:
-- /Lang
-- /Date
-provides: [Date.Catalan]
-MooTools.lang.set('ca-CA', 'Date', {
- months: ['Gener', 'Febrer', 'Març', 'Abril', 'Maig', 'Juny', 'Juli', 'Agost', 'Setembre', 'Octubre', 'Novembre', 'Desembre'],
- days: ['Diumenge', 'Dilluns', 'Dimarts', 'Dimecres', 'Dijous', 'Divendres', 'Dissabte'],
- //culture's date order: MM/DD/YYYY
- dateOrder: ['date', 'month', 'year'],
- shortDate: '%d/%m/%Y',
- shortTime: '%H:%M',
- AM: 'AM',
- PM: 'PM',
- /* Date.Extras */
- ordinal: '',
- lessThanMinuteAgo: 'fa menys d`un minut',
- minuteAgo: 'fa un minut',
- minutesAgo: 'fa {delta} minuts',
- hourAgo: 'fa un hora',
- hoursAgo: 'fa unes {delta} hores',
- dayAgo: 'fa un dia',
- daysAgo: 'fa {delta} dies',
- lessThanMinuteUntil: 'menys d`un minut des d`ara',
- minuteUntil: 'un minut des d`ara',
- minutesUntil: '{delta} minuts des d`ara',
- hourUntil: 'un hora des d`ara',
- hoursUntil: 'unes {delta} hores des d`ara',
- dayUntil: '1 dia des d`ara',
- daysUntil: '{delta} dies des d`ara'
-script: Date.Czech.js
-description: Date messages for Czech.
-authors:
-- Jan Äerný chemiX
-requires:
-- /Lang
-- /Date
-provides: [Date.Czech]
-MooTools.lang.set('cs-CZ', 'Date', {
- months: ['Leden', 'Ãnor', 'BÅezen', 'Duben', 'KvÄten', 'Äerven', 'Äervenec', 'Srpen', 'ZáÅÃ', 'ÅÃjen', 'Listopad', 'Prosinec'],
- days: ['NedÄle', 'PondÄlÃ', 'Ãterý', 'StÅeda', 'Ätvrtek', 'Pátek', 'Sobota'],
- AM: 'dop.',
- PM: 'odp.',
- /* Date.Extras */
- ordinal: function(dayOfMonth){
- return '.';
- // TODO : in examples use and fix it
- lessThanMinuteAgo: 'ménÄ než minutou',
- minuteAgo: 'pÅibližnÄ pÅed minutou',
- minutesAgo: 'pÅed {delta} minutami',
- hourAgo: 'pÅibližnÄ pÅed hodinou',
- hoursAgo: 'pÅed {delta} hodinami',
- dayAgo: 'pÅed dnem',
- daysAgo: 'pÅed {delta} dni',
- lessThanMinuteUntil: 'pÅed ménÄ než minutou',
- minuteUntil: 'asi pÅed minutou',
- minutesUntil: ' asi pÅed {delta} minutami',
- hourUntil: 'asi pÅed hodinou',
- hoursUntil: 'pÅed {delta} hodinami',
- dayUntil: 'pÅed dnem',
- daysUntil: 'pÅed {delta} dni',
- weekUntil: 'pÅed týdnem',
- weeksUntil: 'pÅed {delta} týdny',
- monthUntil: 'pÅed mÄsÃcem',
- monthsUntil: 'pÅed {delta} mÄsÃci',
- yearUntil: 'pÅed rokem',
- yearsUntil: 'pÅed {delta} lety'
-script: Date.Danish.js
-description: Date messages for Danish.
-authors:
-- Martin Overgaard
-- Henrik Hansen
-requires:
-- /Lang
-- /Date
-provides: [Date.Danish]
-MooTools.lang.set('da-DK', 'Date', {
- months: ['Januar', 'Februa', 'Marts', 'April', 'Maj', 'Juni', 'Juli', 'August', 'September', 'Oktober', 'November', 'December'],
- days: ['Søndag', 'Mandag', 'Tirsdag', 'Onsdag', 'Torsdag', 'Fredag', 'Lørdag'],
- //culture's date order: DD/MM/YYYY
- AM: 'AM',
- PM: 'PM',
- shortDate: '%d-%m-%Y',
- /* Date.Extras */
- //1st, 2nd, 3rd, etc.
- return (dayOfMonth > 3 && dayOfMonth < 21) ? 'th' : ['th', 'st', 'nd', 'rd', 'th'][Math.min(dayOfMonth % 10, 4)];
- lessThanMinuteAgo: 'mindre end et minut siden',
- minuteAgo: 'omkring et minut siden',
- minutesAgo: '{delta} minutter siden',
- hourAgo: 'omkring en time siden',
- hoursAgo: 'omkring {delta} timer siden',
- dayAgo: '1 dag siden',
- daysAgo: '{delta} dage siden',
- weekAgo: '1 uge siden',
- weeksAgo: '{delta} uger siden',
- monthAgo: '1 måned siden',
- monthsAgo: '{delta} måneder siden',
- yearthAgo: '1 år siden',
- yearsAgo: '{delta} år siden',
- lessThanMinuteUntil: 'mindre end et minut fra nu',
- minuteUntil: 'omkring et minut fra nu',
- minutesUntil: '{delta} minutter fra nu',
- hourUntil: 'omkring en time fra nu',
- hoursUntil: 'omkring {delta} timer fra nu',
- dayUntil: '1 dag fra nu',
- daysUntil: '{delta} dage fra nu',
- weekUntil: '1 uge fra nu',
- weeksUntil: '{delta} uger fra nu',
- monthUntil: '1 måned fra nu',
- monthsUntil: '{delta} måneder fra nu',
- yearUntil: '1 år fra nu',
- yearsUntil: '{delta} år fra nu'
-script: Date.Dutch.js
-description: Date messages in Dutch.
-authors:
-- Lennart Pilon
-requires:
-- /Lang
-- /Date
-provides: [Date.Dutch]
-MooTools.lang.set('nl-NL', 'Date', {
- months: ['Januari', 'Februari', 'Maart', 'April', 'Mei', 'Juni', 'Juli', 'Augustus', 'September', 'Oktober', 'November', 'December'],
- days: ['Zondag', 'Maandag', 'Dinsdag', 'Woensdag', 'Donderdag', 'Vrijdag', 'Zaterdag'],
- AM: 'AM',
- PM: 'PM',
- /* Date.Extras */
- ordinal: 'e',
- lessThanMinuteAgo: 'minder dan een minuut geleden',
- minuteAgo: 'ongeveer een minuut geleden',
- minutesAgo: 'minuten geleden',
- hourAgo: 'ongeveer een uur geleden',
- hoursAgo: 'ongeveer {delta} uur geleden',
- dayAgo: '{delta} dag geleden',
- daysAgo: 'dagen geleden',
- weekAgo: 'een week geleden',
- weeksAgo: '{delta} weken geleden',
- monthAgo: 'een maand geleden',
- monthsAgo: '{delta} maanden geleden',
- yearAgo: 'een jaar geleden',
- yearsAgo: '{delta} jaar geleden',
- lessThanMinuteUntil: 'minder dan een minuut vanaf nu',
- minuteUntil: 'ongeveer een minuut vanaf nu',
- minutesUntil: '{delta} minuten vanaf nu',
- hourUntil: 'ongeveer een uur vanaf nu',
- hoursUntil: 'ongeveer {delta} uur vanaf nu',
- dayUntil: '1 dag vanaf nu',
- daysUntil: '{delta} dagen vanaf nu',
- yearthAgo: 'een jaar geleden',
- weekUntil: 'over een week',
- weeksUntil: 'over {delta} weken',
- monthUntil: 'over een maand',
- monthsUntil: 'over {delta} maanden',
- yearUntil: 'over een jaar',
- yearsUntil: 'over {delta} jaar'
-script: Date.English.GB.js
-description: Date messages for British English.
-authors:
-- Aaron Newton
-requires:
-- /Lang
-- /Date
-provides: [Date.English.GB]
-MooTools.lang.set('en-GB', 'Date', {
-}).set('cascade', ['en-US']);/*
-script: Date.Estonian.js
-description: Date messages for Estonian.
-authors:
-- Kevin Valdek
-requires:
-- /Lang
-- /Date
-provides: [Date.Estonian]
-MooTools.lang.set('et-EE', 'Date', {
- months: ['jaanuar', 'veebruar', 'märts', 'aprill', 'mai', 'juuni', 'juuli', 'august', 'september', 'oktoober', 'november', 'detsember'],
- days: ['pühapäev', 'esmaspäev', 'teisipäev', 'kolmapäev', 'neljapäev', 'reede', 'laupäev'],
- //culture's date order: MM.DD.YYYY
- dateOrder: ['month', 'date', 'year'],
- AM: 'AM',
- PM: 'PM',
- shortDate: '%m.%d.%Y',
- /* Date.Extras */
- ordinal: '',
- lessThanMinuteAgo: 'vähem kui minut aega tagasi',
- minuteAgo: 'umbes minut aega tagasi',
- minutesAgo: '{delta} minutit tagasi',
- hourAgo: 'umbes tund aega tagasi',
- hoursAgo: 'umbes {delta} tundi tagasi',
- dayAgo: '1 päev tagasi',
- daysAgo: '{delta} päeva tagasi',
- weekAgo: '1 nädal tagasi',
- weeksAgo: '{delta} nädalat tagasi',
- monthAgo: '1 kuu tagasi',
- monthsAgo: '{delta} kuud tagasi',
- yearAgo: '1 aasta tagasi',
- yearsAgo: '{delta} aastat tagasi',
- lessThanMinuteUntil: 'vähem kui minuti aja pärast',
- minuteUntil: 'umbes minuti aja pärast',
- minutesUntil: '{delta} minuti pärast',
- hourUntil: 'umbes tunni aja pärast',
- hoursUntil: 'umbes {delta} tunni pärast',
- dayUntil: '1 päeva pärast',
- daysUntil: '{delta} päeva pärast',
- weekUntil: '1 nädala pärast',
- weeksUntil: '{delta} nädala pärast',
- monthUntil: '1 kuu pärast',
- monthsUntil: '{delta} kuu pärast',
- yearUntil: '1 aasta pärast',
- yearsUntil: '{delta} aasta pärast'
-script: Date.German.js
-description: Date messages for German.
-authors:
-- Christoph Pojer
-- Frank Rossi
-- Ulrich Petri
-- Fabian Beiner
-requires:
-- /Lang
-- /Date
-provides: [Date.German]
-MooTools.lang.set('de-DE', 'Date', {
- months: ['Januar', 'Februar', 'März', 'April', 'Mai', 'Juni', 'Juli', 'August', 'September', 'Oktober', 'November', 'Dezember'],
- days: ['Sonntag', 'Montag', 'Dienstag', 'Mittwoch', 'Donnerstag', 'Freitag', 'Samstag'],
- dateOrder: [ 'date', 'month', 'year', '.'],
- AM: 'vormittags',
- PM: 'nachmittags',
- shortDate: '%d.%m.%Y',
- /* Date.Extras */
- ordinal: '.',
- lessThanMinuteAgo: 'Vor weniger als einer Minute',
- minuteAgo: 'Vor einer Minute',
- minutesAgo: 'Vor {delta} Minuten',
- hourAgo: 'Vor einer Stunde',
- hoursAgo: 'Vor {delta} Stunden',
- dayAgo: 'Vor einem Tag',
- daysAgo: 'Vor {delta} Tagen',
- weekAgo: 'Vor einer Woche',
- weeksAgo: 'Vor {delta} Wochen',
- monthAgo: 'Vor einem Monat',
- monthsAgo: 'Vor {delta} Monaten',
- yearAgo: 'Vor einem Jahr',
- yearsAgo: 'Vor {delta} Jahren',
- lessThanMinuteUntil: 'In weniger als einer Minute',
- minuteUntil: 'In einer Minute',
- minutesUntil: 'In {delta} Minuten',
- hourUntil: 'In ca. einer Stunde',
- hoursUntil: 'In ca. {delta} Stunden',
- dayUntil: 'In einem Tag',
- daysUntil: 'In {delta} Tagen',
- weekUntil: 'In einer Woche',
- weeksUntil: 'In {delta} Wochen',
- monthUntil: 'In einem Monat',
- monthsUntil: 'In {delta} Monaten',
- yearUntil: 'In einem Jahr',
- yearsUntil: 'In {delta} Jahren'
-script: Date.German.CH.js
-description: Date messages for German (Switzerland).
-authors:
-- Michael van der Weg
-requires:
-- /Lang
-- /Date.German
-provides: [Date.German.CH]
-MooTools.lang.set('de-CH', 'cascade', ['de-DE']);/*
-script: Date.French.js
-description: Date messages in French.
-authors:
-- Nicolas Sorosac
-- Antoine Abt
-requires:
-- /Lang
-- /Date
-provides: [Date.French]
-MooTools.lang.set('fr-FR', 'Date', {
- months: ['janvier', 'février', 'mars', 'avril', 'mai', 'juin', 'juillet', 'août', 'septembre', 'octobre', 'novembre', 'décembre'],
- days: ['dimanche', 'lundi', 'mardi', 'mercredi', 'jeudi', 'vendredi', 'samedi'],
- AM: 'AM',
- PM: 'PM',
- /* Date.Extras */
- getOrdinal: function(dayOfMonth){
- return (dayOfMonth > 1) ? '' : 'er';
- lessThanMinuteAgo: 'il y a moins d\'une minute',
- minuteAgo: 'il y a une minute',
- minutesAgo: 'il y a {delta} minutes',
- hourAgo: 'il y a une heure',
- hoursAgo: 'il y a {delta} heures',
- dayAgo: 'il y a un jour',
- daysAgo: 'il y a {delta} jours',
- weekAgo: 'il y a une semaine',
- weeksAgo: 'il y a {delta} semaines',
- monthAgo: 'il y a 1 mois',
- monthsAgo: 'il y a {delta} mois',
- yearthAgo: 'il y a 1 an',
- yearsAgo: 'il y a {delta} ans',
- lessThanMinuteUntil: 'dans moins d\'une minute',
- minuteUntil: 'dans une minute',
- minutesUntil: 'dans {delta} minutes',
- hourUntil: 'dans une heure',
- hoursUntil: 'dans {delta} heures',
- dayUntil: 'dans un jour',
- daysUntil: 'dans {delta} jours',
- weekUntil: 'dans 1 semaine',
- weeksUntil: 'dans {delta} semaines',
- monthUntil: 'dans 1 mois',
- monthsUntil: 'dans {delta} mois',
- yearUntil: 'dans 1 an',
- yearsUntil: 'dans {delta} ans'
-script: Date.Italian.js
-description: Date messages for Italian.
-license: MIT-style license.
-authors:
-- Andrea Novero
-- Valerio Proietti
-requires:
-- /Lang
-- /Date
-provides: [Date.Italian]
-MooTools.lang.set('it-IT', 'Date', {
- months: ['Gennaio', 'Febbraio', 'Marzo', 'Aprile', 'Maggio', 'Giugno', 'Luglio', 'Agosto', 'Settembre', 'Ottobre', 'Novembre', 'Dicembre'],
- days: ['Domenica', 'Lunedì', 'Martedì', 'Mercoledì', 'Giovedì', 'Venerdì', 'Sabato'],
- AM: 'AM',
- PM: 'PM',
- shortTime: '%H.%M',
- /* Date.Extras */
- ordinal: 'º',
- lessThanMinuteAgo: 'meno di un minuto fa',
- minuteAgo: 'circa un minuto fa',
- minutesAgo: 'circa {delta} minuti fa',
- hourAgo: 'circa un\'ora fa',
- hoursAgo: 'circa {delta} ore fa',
- dayAgo: 'circa 1 giorno fa',
- daysAgo: 'circa {delta} giorni fa',
- lessThanMinuteUntil: 'tra meno di un minuto',
- minuteUntil: 'tra circa un minuto',
- minutesUntil: 'tra circa {delta} minuti',
- hourUntil: 'tra circa un\'ora',
- hoursUntil: 'tra circa {delta} ore',
- dayUntil: 'tra circa un giorno',
- daysUntil: 'tra circa {delta} giorni'
-script: Date.Norwegian.js
-description: Date messages in Norwegian.
-authors:
-- Espen 'Rexxars' Hovlandsdal
-requires:
-- /Lang
-- /Date
-provides: [Date.Norwegian]
-MooTools.lang.set('no-NO', 'Date', {
- lessThanMinuteAgo: 'kortere enn et minutt siden',
- minuteAgo: 'omtrent et minutt siden',
- hourAgo: 'omtrent en time siden',
- hoursAgo: 'omtrent {delta} timer siden',
- dayAgo: '{delta} dag siden',
- daysAgo: '{delta} dager siden'
-script: Date.Polish.js
-description: Date messages for Polish.
-authors:
-- Oskar Krawczyk
-requires:
-- /Lang
-- /Date
-provides: [Date.Polish]
-MooTools.lang.set('pl-PL', 'Date', {
- months: ['StyczeÅ', 'Luty', 'Marzec', 'KwiecieÅ', 'Maj', 'Czerwiec', 'Lipiec', 'SierpieÅ', 'WrzesieÅ', 'Październik', 'Listopad', 'GrudzieÅ'],
- days: ['Niedziela', 'PoniedziaÅek', 'Wtorek', 'Åroda', 'Czwartek', 'PiÄ
tek', 'Sobota'],
- dateOrder: ['year', 'month', 'date'],
- AM: 'nad ranem',
- PM: 'po poÅudniu',
- shortDate: '%Y-%m-%d',
- /* Date.Extras */
- return (dayOfMonth > 3 && dayOfMonth < 21) ? 'ty' : ['ty', 'szy', 'gi', 'ci', 'ty'][Math.min(dayOfMonth % 10, 4)];
- lessThanMinuteAgo: 'mniej niż minute temu',
- minuteAgo: 'okoÅo minutÄ temu',
- minutesAgo: '{delta} minut temu',
- hourAgo: 'okoÅo godzinÄ temu',
- hoursAgo: 'okoÅo {delta} godzin temu',
- dayAgo: 'Wczoraj',
- daysAgo: '{delta} dni temu',
- lessThanMinuteUntil: 'za niecaÅÄ
minutÄ',
- minuteUntil: 'za okoÅo minutÄ',
- minutesUntil: 'za {delta} minut',
- hourUntil: 'za okoÅo godzinÄ',
- hoursUntil: 'za okoÅo {delta} godzin',
- dayUntil: 'za 1 dzieÅ',
- daysUntil: 'za {delta} dni'
-script: Date.Portuguese.BR.js
-description: Date messages in Portuguese-BR (Brazil).
-authors:
-- Fabio Miranda Costa
-requires:
-- /Lang
-- /Date
-provides: [Date.Portuguese.BR]
-MooTools.lang.set('pt-BR', 'Date', {
- months: ['Janeiro', 'Fevereiro', 'Março', 'Abril', 'Maio', 'Junho', 'Julho', 'Agosto', 'Setembro', 'Outubro', 'Novembro', 'Dezembro'],
- days: ['Domingo', 'Segunda-feira', 'Terça-feira', 'Quarta-feira', 'Quinta-feira', 'Sexta-feira', 'Sábado'],
- /* Date.Extras */
- //1º, 2º, 3º, etc.
- return 'º';
- lessThanMinuteAgo: 'há menos de um minuto',
- minuteAgo: 'há cerca de um minuto',
- minutesAgo: 'há {delta} minutos',
- hourAgo: 'há cerca de uma hora',
- hoursAgo: 'há cerca de {delta} horas',
- dayAgo: 'há um dia',
- daysAgo: 'há {delta} dias',
- weekAgo: 'há uma semana',
- weeksAgo: 'há {delta} semanas',
- monthAgo: 'há um mês',
- monthsAgo: 'há {delta} meses',
- yearAgo: 'há um ano',
- yearsAgo: 'há {delta} anos',
- lessThanMinuteUntil: 'em menos de um minuto',
- minuteUntil: 'em um minuto',
- minutesUntil: 'em {delta} minutos',
- hourUntil: 'em uma hora',
- hoursUntil: 'em {delta} horas',
- dayUntil: 'em um dia',
- daysUntil: 'em {delta} dias',
- weekUntil: 'em uma semana',
- weeksUntil: 'em {delta} semanas',
- monthUntil: 'em um mês',
- monthsUntil: 'em {delta} meses',
- yearUntil: 'em um ano',
- yearsUntil: 'em {delta} anos'
-Script: Date.Russian.js
- Date messages for Russian.
- License:
- MIT-style license.
- Authors:
- Evstigneev Pavel
-MooTools.lang.set('ru-RU-unicode', 'Date', {
- months: ['ЯнваÑÑ', 'ФевÑалÑ', 'ÐаÑÑ', 'Ð?пÑелÑ', 'Ðай', 'ÐÑнÑ', 'ÐÑлÑ', 'Ð?вгÑÑ?Ñ', 'СенÑÑ?бÑÑ', 'ÐкÑÑ?бÑÑ', 'Ð?оÑ?бÑÑ', 'ÐекабÑÑ'],
- days: ['ÐоÑ?кÑеÑ?енÑе', 'ÐонеделÑник', 'ÐÑоÑник', 'СÑеда', 'ЧеÑвеÑг', 'ÐÑ?ÑниÑа', 'СÑббоÑа'],
- AM: 'AM',
- PM: 'PM',
- * Russian language pluralization rules, taken from CLDR project, http://unicode.org/cldr/
- * one -> n mod 10 is 1 and n mod 100 is not 11;
- * few -> n mod 10 in 2..4 and n mod 100 not in 12..14;
- * many -> n mod 10 is 0 or n mod 10 in 5..9 or n mod 100 in 11..14;
- * other -> everything else (example 3.14)
- pluralize: function (n, one, few, many, other) {
- var modulo10 = n % 10
- var modulo100 = n % 100
- if (modulo10 == 1 && modulo100 != 11) {
- return one;
- } else if ((modulo10 == 2 || modulo10 == 3 || modulo10 == 4) && !(modulo100 == 12 || modulo100 == 13 || modulo100 == 14)) {
- return few;
- } else if (modulo10 == 0 || (modulo10 == 5 || modulo10 == 6 || modulo10 == 7 || modulo10 == 8 || modulo10 == 9) || (modulo100 == 11 || modulo100 == 12 || modulo100 == 13 || modulo100 == 14)) {
- return many;
- } else {
- return other;
- /* Date.Extras */
- ordinal: '',
- lessThanMinuteAgo: 'менÑÑе минÑÑÑ Ð½Ð°Ð·Ð°Ð´',
- minuteAgo: 'минÑÑа назад',
- minutesAgo: function (delta) { return '{delta} ' + this.pluralize(delta, 'минÑÑа', 'минÑÑÑ', 'минÑÑ') + ' назад'},
- hourAgo: 'ÑаÑ? назад',
- hoursAgo: function (delta) { return '{delta} ' + this.pluralize(delta, 'ÑаÑ?', 'ÑаÑ?а', 'ÑаÑ?ов') + ' назад'},
- dayAgo: 'вÑеÑа',
- daysAgo: function (delta) { return '{delta} ' + this.pluralize(delta, 'денÑ', 'днÑ?', 'дней') + ' назад' },
- lessThanMinuteUntil: 'менÑÑе минÑÑÑ Ð½Ð°Ð·Ð°Ð´',
- minuteUntil: 'ÑеÑез минÑÑÑ',
- minutesUntil: function (delta) { return 'ÑеÑез {delta} ' + this.pluralize(delta, 'ÑаÑ?', 'ÑаÑ?а', 'ÑаÑ?ов') + ''},
- hourUntil: 'ÑеÑез ÑаÑ?',
- hoursUntil: function (delta) { return 'ÑеÑез {delta} ' + this.pluralize(delta, 'ÑаÑ?', 'ÑаÑ?а', 'ÑаÑ?ов') + ''},
- dayUntil: 'завÑÑа',
- daysUntil: function (delta) { return 'ÑеÑез {delta} ' + this.pluralize(delta, 'денÑ', 'днÑ?', 'дней') + '' }
-script: Date.Spanish.US.js
-description: Date messages for Spanish.
-authors:
-- Ãlfons Sanchez
-requires:
-- /Lang
-- /Date
-provides: [Date.Spanish]
-MooTools.lang.set('es-ES', 'Date', {
- months: ['Enero', 'Febrero', 'Marzo', 'Abril', 'Mayo', 'Junio', 'Julio', 'Agosto', 'Septiembre', 'Octubre', 'Noviembre', 'Diciembre'],
- days: ['Domingo', 'Lunes', 'Martes', 'Miércoles', 'Jueves', 'Viernes', 'Sábado'],
- AM: 'AM',
- PM: 'PM',
- /* Date.Extras */
- ordinal: '',
- lessThanMinuteAgo: 'hace menos de un minuto',
- minuteAgo: 'hace un minuto',
- minutesAgo: 'hace {delta} minutos',
- hourAgo: 'hace una hora',
- hoursAgo: 'hace unas {delta} horas',
- dayAgo: 'hace un dÃa',
- daysAgo: 'hace {delta} dÃas',
- weekAgo: 'hace una semana',
- weeksAgo: 'hace unas {delta} semanas',
- monthAgo: 'hace un mes',
- monthsAgo: 'hace {delta} meses',
- yearAgo: 'hace un año',
- yearsAgo: 'hace {delta} años',
- lessThanMinuteUntil: 'menos de un minuto desde ahora',
- minuteUntil: 'un minuto desde ahora',
- minutesUntil: '{delta} minutos desde ahora',
- hourUntil: 'una hora desde ahora',
- hoursUntil: 'unas {delta} horas desde ahora',
- dayUntil: 'un dÃa desde ahora',
- daysUntil: '{delta} dÃas desde ahora',
- weekUntil: 'una semana desde ahora',
- weeksUntil: 'unas {delta} semanas desde ahora',
- monthUntil: 'un mes desde ahora',
- monthsUntil: '{delta} meses desde ahora',
- yearUntil: 'un año desde ahora',
- yearsUntil: '{delta} años desde ahora'
-script: Date.Swedish.js
-description: Date messages for Swedish (SE).
-authors:
-- Martin Lundgren
-requires:
-- /Lang
-- /Date
-provides: [Date.Swedish]
-MooTools.lang.set('sv-SE', 'Date', {
- months: ['januari', 'februari', 'mars', 'april', 'maj', 'juni', 'juli', 'augusti', 'september', 'oktober', 'november', 'december'],
- days: ['söndag', 'måndag', 'tisdag', 'onsdag', 'torsdag', 'fredag', 'lördag'],
- // culture's date order: YYYY-MM-DD
- AM: '',
- PM: '',
- /* Date.Extras */
- // Not used in Swedish
- return '';
- lessThanMinuteAgo: 'mindre än en minut sedan',
- minuteAgo: 'ungefär en minut sedan',
- minutesAgo: '{delta} minuter sedan',
- hourAgo: 'ungefär en timme sedan',
- hoursAgo: 'ungefär {delta} timmar sedan',
- dayAgo: '1 dag sedan',
- daysAgo: '{delta} dagar sedan',
- lessThanMinuteUntil: 'mindre än en minut sedan',
- minuteUntil: 'ungefär en minut sedan',
- minutesUntil: '{delta} minuter sedan',
- hourUntil: 'ungefär en timme sedan',
- hoursUntil: 'ungefär {delta} timmar sedan',
- dayUntil: '1 dag sedan',
- daysUntil: '{delta} dagar sedan'
-script: Date.Ukrainian.js
-description: Date messages for Ukrainian.
-authors:
-- Slik
-requires:
-- /Lang
-- /Date
-provides: [Date.Ukrainian]
-(function(){
- var pluralize = function(n, one, few, many, other){
- var d = (n / 10).toInt();
- var z = n % 10;
- var s = (n / 100).toInt();
- if(d == 1 && n > 10) return many;
- if(z == 1) return one;
- if(z > 0 && z < 5) return few;
- return many;
- MooTools.lang.set('uk-UA', 'Date', {
- months: ['СÑÑенÑ', 'ÐÑÑий', 'ÐеÑезенÑ', 'ÐвÑÑенÑ', 'ТÑавенÑ', 'ЧеÑвенÑ', 'ÐипенÑ', 'СеÑпенÑ', 'ÐеÑеÑ?енÑ', 'ÐовÑенÑ', 'ÐиÑ?Ñопад', 'ÐÑÑденÑ'],
- days: ['Ð?едÑлÑ?', 'ÐонедÑлок', 'ÐÑвÑоÑок', 'СеÑеда', 'ЧеÑвеÑ', 'Ð\'Ñ?ÑниÑÑ?', 'СÑбоÑа'],
- AM: 'до полÑднÑ?',
- PM: 'по полÑднÑ',
- /* Date.Extras */
- ordinal: '',
- lessThanMinuteAgo: 'менÑÑе Ñ
вилини ÑомÑ',
- minuteAgo: 'Ñ
Ð²Ð¸Ð»Ð¸Ð½Ñ ÑомÑ',
- minutesAgo: function (delta){
- return '{delta} ' + pluralize(delta, 'Ñ
вилинÑ', 'Ñ
вилини', 'Ñ
вилин') + ' ÑомÑ';
- hourAgo: 'Ð³Ð¾Ð´Ð¸Ð½Ñ ÑомÑ',
- hoursAgo: function (delta){
- return '{delta} ' + pluralize(delta, 'годинÑ', 'години', 'годин') + ' ÑомÑ';
- dayAgo: 'вÑоÑа',
- daysAgo: function (delta){
- return '{delta} ' + pluralize(delta, 'денÑ', 'днÑ?', 'днÑв') + ' ÑомÑ';
- weekAgo: 'ÑÐ¸Ð¶Ð´ÐµÐ½Ñ ÑомÑ',
- weeksAgo: function (delta){
- return '{delta} ' + pluralize(delta, 'ÑижденÑ', 'ÑижнÑ', 'ÑижнÑв') + ' ÑомÑ';
- monthAgo: 'мÑÑ?Ñ?ÑÑ ÑомÑ',
- monthsAgo: function (delta){
- return '{delta} ' + pluralize(delta, 'мÑÑ?Ñ?ÑÑ', 'мÑÑ?Ñ?ÑÑ', 'мÑÑ?Ñ?ÑÑв') + ' ÑомÑ';
- yearAgo: 'ÑÑк ÑомÑ',
- yearsAgo: function (delta){
- return '{delta} ' + pluralize(delta, 'ÑÑк', 'Ñоки', 'ÑокÑв') + ' ÑомÑ';
- lessThanMinuteUntil: 'за миÑÑ',
- minuteUntil: 'ÑеÑез Ñ
вилинÑ',
- minutesUntil: function (delta){
- return 'ÑеÑез {delta} ' + pluralize(delta, 'Ñ
вилинÑ', 'Ñ
вилини', 'Ñ
вилин');
- hourUntil: 'ÑеÑез годинÑ',
- hoursUntil: function (delta){
- return 'ÑеÑез {delta} ' + pluralize(delta, 'годинÑ', 'години', 'годин');
- daysUntil: function (delta){
- return 'ÑеÑез {delta} ' + pluralize(delta, 'денÑ', 'днÑ?', 'днÑв');
- weekUntil: 'ÑеÑез ÑижденÑ',
- weeksUntil: function (delta){
- return 'ÑеÑез {delta} ' + pluralize(delta, 'ÑижденÑ', 'ÑижнÑ', 'ÑижнÑв');
- monthUntil: 'ÑеÑез мÑÑ?Ñ?ÑÑ',
- monthesUntil: function (delta){
- return 'ÑеÑез {delta} ' + pluralize(delta, 'мÑÑ?Ñ?ÑÑ', 'мÑÑ?Ñ?ÑÑ', 'мÑÑ?Ñ?ÑÑв');
- yearUntil: 'ÑеÑез ÑÑк',
- yearsUntil: function (delta){
- return 'ÑеÑез {delta} ' + pluralize(delta, 'ÑÑк', 'Ñоки', 'ÑокÑв');
-script: Form.Validator.Arabic.js
-description: Form.Validator messages in Arabic.
-authors:
-- Chafik Barbar
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.Arabic]
-MooTools.lang.set('ar', 'Form.Validator', {
- required:'ÙØ°Ø§ Ø§ÙØÙÙ Ù
Ø·ÙÙØ¨.',
- minLength:'رجاء٠إدخا٠{minLength} Ø£ØØ±Ù? عÙÙ Ø§ÙØ£ÙÙ (تÙ
إدخا٠{length} Ø£ØØ±Ù?).',
- maxLength:'Ø§ÙØ±Ø¬Ø§Ø¡ عدÙ
Ø¥Ø¯Ø®Ø§Ù Ø£ÙØ«Ø± Ù
Ù {maxLength} Ø£ØØ±Ù? (تÙ
- integer:'Ø§ÙØ±Ø¬Ø§Ø¡ إدخا٠عدد صØÙØ Ù?Ù ÙØ°Ø§ Ø§ÙØÙÙ. أ٠رÙÙ
Ø°Ù ÙØ³Ø± عشر٠أ٠Ù
ئÙÙ (Ù
ثا٠1.25 ) ØºÙØ± Ù
سÙ
ÙØ.',
- numeric:'Ø§ÙØ±Ø¬Ø§Ø¡ إدخا٠ÙÙÙ
رÙÙ
ÙØ© Ù?Ù ÙØ°Ø§ Ø§ÙØÙÙ (Ù
ثا٠"1" أ٠"1.1" أ٠"-1" أ٠"-1.1").',
- digits:'Ø§ÙØ±Ø¬Ø§Ø¡ أستخداÙ
ÙÙÙ
رÙÙ
ÙØ© ÙØ¹ÙاÙ
ات ترÙÙÙ
ÙØ© Ù?ÙØ· Ù?Ù ÙØ°Ø§ Ø§ÙØÙÙ (Ù
ثاÙ, رÙÙ
ÙØ§ØªÙ? Ù
ع ÙÙØ·Ø© Ø£Ù Ø´ØØ·Ø©)',
- alpha:'Ø§ÙØ±Ø¬Ø§Ø¡ أستخداÙ
Ø£ØØ±Ù? Ù?ÙØ· (ا-Ù) Ù?Ù ÙØ°Ø§ Ø§ÙØÙÙ. Ø£Ù Ù?راغات Ø£Ù Ø¹ÙØ§Ù
ات ØºÙØ± Ù
سÙ
ÙØØ©.',
- alphanum:'Ø§ÙØ±Ø¬Ø§Ø¡ أستخداÙ
Ø£ØØ±Ù? Ù?ÙØ· (ا-Ù) Ø£Ù Ø£Ø±ÙØ§Ù
(0-9) Ù?ÙØ· Ù?Ù ÙØ°Ø§ Ø§ÙØÙÙ. Ø£Ù Ù?راغات Ø£Ù Ø¹ÙØ§Ù
ات ØºÙØ± Ù
سÙ
ÙØØ©.',
- dateSuchAs:'Ø§ÙØ±Ø¬Ø§Ø¡ Ø¥Ø¯Ø®Ø§Ù ØªØ§Ø±ÙØ® صØÙØ ÙØ§ÙتاÙÙ {date}',
- dateInFormatMDY:'Ø§ÙØ±Ø¬Ø§Ø¡ Ø¥Ø¯Ø®Ø§Ù ØªØ§Ø±ÙØ® صØÙØ (Ù
ثاÙ, 31-12-1999)',
- email:'Ø§ÙØ±Ø¬Ø§Ø¡ Ø¥Ø¯Ø®Ø§Ù Ø¨Ø±ÙØ¯ Ø¥ÙÙØªØ±ÙÙ٠صØÙØ.',
- url:'Ø§ÙØ±Ø¬Ø§Ø¡ إدخا٠عÙÙØ§Ù Ø¥ÙÙØªØ±ÙÙ٠صØÙØ Ù
ث٠http://www.google.com',
- currencyDollar:'Ø§ÙØ±Ø¬Ø§Ø¡ إدخا٠ÙÙÙ
Ø© $ صØÙØØ©. Ù
ثاÙ, 100.00$',
- oneRequired:'Ø§ÙØ±Ø¬Ø§Ø¡ إدخا٠ÙÙÙ
Ø© Ù?Ù Ø£ØØ¯ ÙØ°Ù Ø§ÙØÙÙ٠عÙÙ Ø§ÙØ£ÙÙ.',
- errorPrefix: 'خطأ: ',
- warningPrefix: 'ØªØØ°Ùر: '
-}).set('ar', 'Date', {
- dateOrder: ['date', 'month', 'year', '/']
-script: Form.Validator.Catalan.js
-authors:
-- Miquel Hudin
-- Alfons Sanchez
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.Catalan]
-MooTools.lang.set('ca-CA', 'Form.Validator', {
- required:'Aquest camp es obligatori.',
- minLength:'Per favor introdueix al menys {minLength} caracters (has introduit {length} caracters).',
- maxLength:'Per favor introdueix no mes de {maxLength} caracters (has introduit {length} caracters).',
- integer:'Per favor introdueix un nombre enter en aquest camp. Nombres amb decimals (p.e. 1,25) no estan permesos.',
- numeric:'Per favor introdueix sols valors numerics en aquest camp (p.e. "1" o "1,1" o "-1" o "-1,1").',
- digits:'Per favor usa sols numeros i puntuacio en aquest camp (per exemple, un nombre de telefon amb guions i punts no esta permes).',
- alpha:'Per favor utilitza lletres nomes (a-z) en aquest camp. No s´admiteixen espais ni altres caracters.',
- alphanum:'Per favor, utilitza nomes lletres (a-z) o numeros (0-9) en aquest camp. No s´admiteixen espais ni altres caracters.',
- dateSuchAs:'Per favor introdueix una data valida com {date}',
- dateInFormatMDY:'Per favor introdueix una data valida com DD/MM/YYYY (p.e. "31/12/1999")',
- email:'Per favor, introdueix una adreça de correu electronic valida. Per exemple, "fred at domain.com".',
- url:'Per favor introdueix una URL valida com http://www.google.com.',
- currencyDollar:'Per favor introdueix una quantitat valida de â¬. Per exemple â¬100,00 .',
- oneRequired:'Per favor introdueix alguna cosa per al menys una d´aquestes entrades.',
- errorPrefix: 'Error: ',
- warningPrefix: 'Avis: ',
- //Form.Validator.Extras
- noSpace: 'No poden haver espais en aquesta entrada.',
- reqChkByNode: 'No hi han elements seleccionats.',
- requiredChk: 'Aquest camp es obligatori.',
- reqChkByName: 'Per favor selecciona una {label}.',
- match: 'Aquest camp necessita coincidir amb el camp {matchName}',
- startDate: 'la data de inici',
- endDate: 'la data de fi',
- currendDate: 'la data actual',
- afterDate: 'La data deu ser igual o posterior a {label}.',
- beforeDate: 'La data deu ser igual o anterior a {label}.',
- startMonth: 'Per favor selecciona un mes d´orige',
- sameMonth: 'Aquestes dos dates deuen estar dins del mateix mes - deus canviar una o altra.'
-script: Form.Validator.Czech.js
-description: Form Validator messages for Czech.
-authors:
-- Jan Äerný chemiX
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.Czech]
-MooTools.lang.set('cs-CZ', 'Form.Validator', {
- required:'Tato položka je povinná.',
- minLength:'Zadejte prosÃm alespoÅ {minLength} znaků (napsáno {length} znaků).',
- maxLength:'Zadejte prosÃm ménÄ než {maxLength} znaků (nápsáno {length} znaků).',
- integer:'Zadejte prosÃm celé Ä?Ãslo. Desetinná Ä?Ãsla (napÅ. 1.25) nejsou povolena.',
- numeric:'Zadejte jen Ä?Ãselné hodnoty (tj. "1" nebo "1.1" nebo "-1" nebo "-1.1").',
- digits:'Zadejte prosÃm pouze Ä?Ãsla a interpunkÄ?nà znaménka(napÅÃklad telefonnà Ä?Ãslo s pomlÄ?kami nebo teÄ?kami je povoleno).',
- alpha:'Zadejte prosÃm pouze pÃsmena (a-z). Mezery nebo jiné znaky nejsou povoleny.',
- alphanum:'Zadejte prosÃm pouze pÃsmena (a-z) nebo Ä?Ãslice (0-9). Mezery nebo jiné znaky nejsou povoleny.',
- dateSuchAs:'Zadejte prosÃm platné datum jako {date}',
- dateInFormatMDY:'Zadejte prosÃm platné datum jako MM / DD / RRRR (tj. "12/31/1999")',
- email:'Zadejte prosÃm platnou e-mailovou adresu. NapÅÃklad "fred at domain.com".',
- url:'Zadejte prosÃm platnou URL adresu jako http://www.google.com.',
- currencyDollar:'Zadejte prosÃm platnou Ä?ástku. NapÅÃklad $100.00.',
- oneRequired:'Zadejte prosÃm alespoÅ jednu hodnotu pro tyto položky.',
- errorPrefix: 'Chyba: ',
- warningPrefix: 'UpozornÄnÃ: ',
- noSpace: 'V této položce nejsou povoleny mezery',
- reqChkByNode: 'Nejsou vybrány žádné položky.',
- requiredChk: 'Tato položka je vyžadována.',
- reqChkByName: 'ProsÃm vyberte {label}.',
- match: 'Tato položka se musà shodovat s položkou {matchName}',
- startDate: 'datum zahájenÃ',
- endDate: 'datum ukonÄ?enÃ',
- currendDate: 'aktuálnà datum',
- afterDate: 'Datum by mÄlo být stejné nebo vÄtšà než {label}.',
- beforeDate: 'Datum by mÄlo být stejné nebo menšà než {label}.',
- startMonth: 'Vyberte poÄ?áteÄ?nà mÄsÃc.',
- sameMonth: 'Tyto dva datumy musà být ve stejném mÄsÃci - zmÄÅte jeden z nich.',
- creditcard: 'Zadané Ä?Ãslo kreditnà karty je neplatné. ProsÃm opravte ho. Bylo zadáno {length} Ä?Ãsel.'
-script: Form.Validator.Chinese.js
-description: Form.Validator messages in chinese (both simplified and traditional).
-authors:
-- éæ¡å - guidy <at> ixuer [dot] net
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.Chinese]
-In Chinese:
-éè¦?æåºçæ¯ï¼
-ç®ä½ä¸æéç¨äºä¸å½å¤§éï¼
-ç¹?ä½ä¸æéç¨äºé¦æ¸¯ã?æ¾³é¨åå?°æ¹¾ç?ã
-ç®ä½ä¸æåç¹?ä½ä¸æå¨åä½åè¯æ³ä¸æå¾å¤çä¸?å?ä¹å¤ã
-æå?¯ä»¥ç¡®ä¿?ç®ä½ä¸æè¯è¨å
çåç¡®æ§ï¼
-ä½å¯¹äºç¹?ä½ä¸æï¼æå?¯ä»¥ä¿?è¯?ç¨æ·å?¯ä»¥åç¡®çç?è§£ï¼ä½æ æ³ä¿?è¯?è¯å?¥ç¬¦å?ä»ä»¬çé
è¯»ä¹ æ¯ã
-妿æ¨ä¸?è½ç¡®è®¤çè¯?ï¼å?¯ä»¥å?ªä½¿ç¨ç®ä½ä¸æè¯è¨å
ï¼å ä¸ºå®æ¯æéç¨çã
-In English:
-It should be noted that:
-Simplified Chinese apply to mainland Chinese,
-Traditional Chinese apply to Hong Kong, Macao and Taiwan Province.
-There are a lot of different from Simplified Chinese and Traditional Chinese , Contains font and syntax .
-I can assure Simplified Chinese language pack accuracy .
-For Traditional Chinese, I can only guarantee that users can understand, but not necessarily in line with their reading habits.
-If you are unsure, you can only use the simplified Chinese language pack, as it is the most common.
-// Simplified Chinese
-MooTools.lang.set('zhs-CN', 'Form.Validator', {
- required:'è¿æ¯å¿
填项ã',
- minLength:'请è³å°è¾å
¥ {minLength} 个å符 (å·²è¾å
¥ {length} 个)ã',
- maxLength:'æå¤å?ªè½è¾å
¥ {maxLength} 个å符 (å·²è¾å
¥ {length} 个)ã',
- integer:'请è¾å
¥ä¸ä¸ªæ´æ°ï¼ä¸?è½å
å?«å°?æ°ç¹ãä¾å¦ï¼"1", "200"ã',
- numeric:'请è¾å
¥ä¸ä¸ªæ°åï¼ä¾å¦ï¼"1", "1.1", "-1", "-1.1"ã',
- digits:'è¿éå?ªè½æ¥å?æ°ååæ ç¹çè¾å
¥ï¼æ ç¹å?¯ä»¥æ¯ï¼"(", ")", ".", ":", "-", "+", "#"åç©ºæ ¼ã',
- alpha:'请è¾å
¥ A-Z ç 26 ä¸ªåæ¯?ï¼ä¸?è½å
å?«ç©ºæ ¼æä»»ä½å
¶ä»å符ã',
- alphanum:'请è¾å
¥ A-Z ç 26 ä¸ªåæ¯?æ 0-9 ç 10 个æ°åï¼ä¸?è½å
å?«ç©ºæ ¼æä»»ä½å
¶ä»å符ã',
- dateSuchAs:'请è¾å
¥å?æ³çæ¥ææ ¼å¼?ï¼å¦ï¼{date}ã',
- dateInFormatMDY:'请è¾å
¥å?æ³çæ¥ææ ¼å¼?ï¼ä¾å¦ï¼MM/DD/YYYY ("12/31/1999")ã',
- email:'请è¾å
¥å?æ³ççµå?ä¿¡ç®±å°å?ï¼ä¾å¦ï¼"fred at domain.com"ã',
- url:'请è¾å
¥å?æ³ç Url å°å?ï¼ä¾å¦ï¼http://www.google.comã',
- currencyDollar:'请è¾å
¥å?æ³çè´§å¸?符å?·ï¼ä¾å¦ï¼ï¿¥',
- oneRequired:'请è³å°éæ©ä¸é¡¹ã',
- errorPrefix: 'é误ï¼',
- warningPrefix: 'è¦åï¼'
-// Traditional Chinese
-MooTools.lang.set('zht-CN', 'Form.Validator', {
- required:'鿝å¿
å¡«é
ã',
- minLength:'è«è³å°é?µå
¥ {minLength} åå符(å·²é?µå
¥ {length} å)ã',
- maxLength:'æå¤å?ªè½é?µå
¥ {maxLength} åå符(å·²é?µå
¥ {length} å)ã',
- integer:'è«é?µå
¥ä¸åæ´æ¸ï¼ä¸?è½å
å?«å°?æ¸é»ãä¾å¦ï¼"1", "200"ã',
- numeric:'è«é?µå
¥ä¸åæ¸åï¼ä¾å¦ï¼"1", "1.1", "-1", "-1.1"ã',
- digits:'é裡å?ªè½æ¥å?æ¸å忍é»çé?µå
¥ï¼æ¨é»å?¯ä»¥æ¯ï¼"(", ")", ".", ":", "-", "+", "#"åç©ºæ ¼ã',
- alpha:'è«é?µå
¥ A-Z ç 26 å忝?ï¼ä¸?è½å
å?«ç©ºæ ¼æä»»ä½å
¶ä»å符ã',
- alphanum:'è«é?µå
¥ A-Z ç 26 å忝?æ 0-9 ç 10 忏åï¼ä¸?è½å
å?«ç©ºæ ¼æä»»ä½å
¶ä»å符ã',
- dateSuchAs:'è«é?µå
- dateInFormatMDY:'è«é?µå
- email:'è«é?µå
¥å?æ³çé»å?ä¿¡ç®±å°å?ï¼ä¾å¦ï¼"fred at domain.com"ã',
- url:'è«é?µå
- currencyYuan:'è«é?µå
¥å?æ³ç貨幣符èï¼ä¾å¦ï¼ï¿¥',
- oneRequired:'è«è³å°é?¸æä¸é
ã',
- errorPrefix: 'é¯èª¤ï¼',
-Form.Validator.add('validate-currency-yuan', {
- errorMsg: function(){
- return Form.Validator.getMsg('currencyYuan');
- test: function(element) {
- // [ï¿¥]1[##][,###]+[.##]
- // [ï¿¥]1###+[.##]
- // [ï¿¥]0.##
- // [ï¿¥].##
- return Form.Validator.getValidator('IsEmpty').test(element) || (/^ï¿¥?\-?([1-9]{1}[0-9]{0,2}(\,[0-9]{3})*(\.[0-9]{0,2})?|[1-9]{1}\d*(\.[0-9]{0,2})?|0(\.[0-9]{0,2})?|(\.[0-9]{1,2})?)$/).test(element.get('value'));
-script: Form.Validator.Dutch.js
-description: Form.Validator messages in Dutch.
-authors:
-- Lennart Pilon
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.Dutch]
-MooTools.lang.set('nl-NL', 'Form.Validator', {
- required:'Dit veld is verplicht.',
- minLength:'Vul minimaal {minLength} karakters in (je hebt {length} karakters ingevoerd).',
- maxLength:'Vul niet meer dan {maxLength} karakters in (je hebt {length} karakters ingevoerd).',
- integer:'Vul een getal in. Getallen met decimalen (bijvoorbeeld 1,25) zijn niet toegestaan.',
- numeric:'Vul alleen numerieke waarden in (bijvoorbeeld. "1" of "1.1" of "-1" of "-1.1").',
- digits:'Vul alleen nummers en leestekens in (bijvoorbeeld een telefoonnummer met een streepje).',
- alpha:'Vul alleen letters in (a-z). Spaties en andere karakters zijn niet toegestaan.',
- alphanum:'Vul alleen letters in (a-z) of nummers (0-9). Spaties en andere karakters zijn niet toegestaan.',
- dateSuchAs:'Vul een geldige datum in, zoals {date}',
- dateInFormatMDY:'Vul een geldige datum, in het formaat MM/DD/YYYY (bijvoorbeeld "12/31/1999")',
- email:'Vul een geldig e-mailadres in. Bijvoorbeeld "fred at domein.nl".',
- url:'Vul een geldige URL in, zoals http://www.google.nl.',
- currencyDollar:'Vul een geldig $ bedrag in. Bijvoorbeeld $100.00 .',
- oneRequired:'Vul iets in bij minimaal een van de invoervelden.',
- warningPrefix: 'Waarschuwing: ',
- errorPrefix: 'Fout: '
-script: Form.Validator.Estonian.js
-authors:
-- Kevin Valdek
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.Estonian]
-MooTools.lang.set('et-EE', 'Form.Validator', {
- required:'Väli peab olema täidetud.',
- minLength:'Palun sisestage vähemalt {minLength} tähte (te sisestasite {length} tähte).',
- maxLength:'Palun ärge sisestage rohkem kui {maxLength} tähte (te sisestasite {length} tähte).',
- integer:'Palun sisestage väljale täisarv. Kümnendarvud (näiteks 1.25) ei ole lubatud.',
- numeric:'Palun sisestage ainult numbreid väljale (näiteks "1", "1.1", "-1" või "-1.1").',
- digits:'Palun kasutage ainult numbreid ja kirjavahemärke (telefoninumbri sisestamisel on lubatud kasutada kriipse ja punkte).',
- alpha:'Palun kasutage ainult tähti (a-z). Tühikud ja teised sümbolid on keelatud.',
- alphanum:'Palun kasutage ainult tähti (a-z) või numbreid (0-9). Tühikud ja teised sümbolid on keelatud.',
- dateSuchAs:'Palun sisestage kehtiv kuupäev kujul {date}',
- dateInFormatMDY:'Palun sisestage kehtiv kuupäev kujul MM.DD.YYYY (näiteks: "12.31.1999").',
- email:'Palun sisestage kehtiv e-maili aadress (näiteks: "fred at domain.com").',
- url:'Palun sisestage kehtiv URL (näiteks: http://www.google.com).',
- currencyDollar:'Palun sisestage kehtiv $ summa (näiteks: $100.00).',
- oneRequired:'Palun sisestage midagi vähemalt ühele antud väljadest.',
- errorPrefix: 'Viga: ',
- warningPrefix: 'Hoiatus: ',
- noSpace: 'Väli ei tohi sisaldada tühikuid.',
- reqChkByNode: 'Ãkski väljadest pole valitud.',
- requiredChk: 'Välja täitmine on vajalik.',
- reqChkByName: 'Palun valige üks {label}.',
- match: 'Väli peab sobima {matchName} väljaga',
- startDate: 'algkuupäev',
- endDate: 'lõppkuupäev',
- currendDate: 'praegune kuupäev',
- afterDate: 'Kuupäev peab olema võrdne või pärast {label}.',
- beforeDate: 'Kuupäev peab olema võrdne või enne {label}.',
- startMonth: 'Palun valige algkuupäev.',
- sameMonth: 'Antud kaks kuupäeva peavad olema samas kuus - peate muutma ühte kuupäeva.'
-script: Form.Validator.German.js
-authors:
-- Frank Rossi
-- Ulrich Petri
-- Fabian Beiner
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.German]
-MooTools.lang.set('de-DE', 'Form.Validator', {
- required: 'Dieses Eingabefeld muss ausgefüllt werden.',
- minLength: 'Geben Sie bitte mindestens {minLength} Zeichen ein (Sie haben nur {length} Zeichen eingegeben).',
- maxLength: 'Geben Sie bitte nicht mehr als {maxLength} Zeichen ein (Sie haben {length} Zeichen eingegeben).',
- integer: 'Geben Sie in diesem Eingabefeld bitte eine ganze Zahl ein. Dezimalzahlen (z.B. "1.25") sind nicht erlaubt.',
- numeric: 'Geben Sie in diesem Eingabefeld bitte nur Zahlenwerte (z.B. "1", "1.1", "-1" oder "-1.1") ein.',
- digits: 'Geben Sie in diesem Eingabefeld bitte nur Zahlen und Satzzeichen ein (z.B. eine Telefonnummer mit Bindestrichen und Punkten ist erlaubt).',
- alpha: 'Geben Sie in diesem Eingabefeld bitte nur Buchstaben (a-z) ein. Leerzeichen und andere Zeichen sind nicht erlaubt.',
- alphanum: 'Geben Sie in diesem Eingabefeld bitte nur Buchstaben (a-z) und Zahlen (0-9) ein. Leerzeichen oder andere Zeichen sind nicht erlaubt.',
- dateSuchAs: 'Geben Sie bitte ein gültiges Datum ein (z.B. "{date}").',
- dateInFormatMDY: 'Geben Sie bitte ein gültiges Datum im Format TT.MM.JJJJ ein (z.B. "31.12.1999").',
- email: 'Geben Sie bitte eine gültige E-Mail-Adresse ein (z.B. "max at mustermann.de").',
- url: 'Geben Sie bitte eine gültige URL ein (z.B. "http://www.google.de").',
- currencyDollar: 'Geben Sie bitte einen gültigen Betrag in EURO ein (z.B. 100.00€).',
- oneRequired: 'Bitte füllen Sie mindestens ein Eingabefeld aus.',
- errorPrefix: 'Fehler: ',
- warningPrefix: 'Warnung: ',
- noSpace: 'Es darf kein Leerzeichen in diesem Eingabefeld sein.',
- reqChkByNode: 'Es wurden keine Elemente gewählt.',
- requiredChk: 'Dieses Feld muss ausgefüllt werden.',
- reqChkByName: 'Bitte wählen Sie ein {label}.',
- match: 'Dieses Eingabefeld muss mit dem {matchName} Eingabefeld übereinstimmen.',
- startDate: 'Das Anfangsdatum',
- endDate: 'Das Enddatum',
- currendDate: 'Das aktuelle Datum',
- afterDate: 'Das Datum sollte zur gleichen Zeit oder später sein als {label}.',
- beforeDate: 'Das Datum sollte zur gleichen Zeit oder früher sein als {label}.',
- startMonth: 'Wählen Sie bitte einen Anfangsmonat',
- sameMonth: 'Diese zwei Datumsangaben müssen im selben Monat sein - Sie müssen eines von beiden verändern.',
- creditcard: 'Die eingegebene Kreditkartennummer ist ungültig. Bitte überprüfen Sie diese und versuchen Sie es erneut. {length} Zahlen eingegeben.'
-script: Form.Validator.German.CH.js
-authors:
-requires:
-- /Lang
-- /Form.Validator.German
-provides: [Form.Validator.German.CH]
-MooTools.lang.set('de-CH', 'Form.Validator', {
- required:'Dieses Feld ist obligatorisch.',
- minLength:'Geben Sie bitte mindestens {minLength} Zeichen ein (Sie haben {length} Zeichen eingegeben).',
- maxLength:'Bitte geben Sie nicht mehr als {maxLength} Zeichen ein (Sie haben {length} Zeichen eingegeben).',
- integer:'Geben Sie bitte eine ganze Zahl ein. Dezimalzahlen (z.B. 1.25) sind nicht erlaubt.',
- numeric:'Geben Sie bitte nur Zahlenwerte in dieses Eingabefeld ein (z.B. "1", "1.1", "-1" oder "-1.1").',
- digits:'Benutzen Sie bitte nur Zahlen und Satzzeichen in diesem Eingabefeld (erlaubt ist z.B. eine Telefonnummer mit Bindestrichen und Punkten).',
- alpha:'Benutzen Sie bitte nur Buchstaben (a-z) in diesem Feld. Leerzeichen und andere Zeichen sind nicht erlaubt.',
- alphanum:'Benutzen Sie bitte nur Buchstaben (a-z) und Zahlen (0-9) in diesem Eingabefeld. Leerzeichen und andere Zeichen sind nicht erlaubt.',
- dateSuchAs:'Geben Sie bitte ein gültiges Datum ein. Wie zum Beispiel {date}',
- dateInFormatMDY:'Geben Sie bitte ein gültiges Datum ein. Wie zum Beispiel TT.MM.JJJJ (z.B. "31.12.1999")',
- email:'Geben Sie bitte eine gültige E-Mail Adresse ein. Wie zum Beispiel "maria at bernasconi.ch".',
- url:'Geben Sie bitte eine gültige URL ein. Wie zum Beispiel http://www.google.ch.',
- currencyDollar:'Geben Sie bitte einen gültigen Betrag in Schweizer Franken ein. Wie zum Beispiel 100.00 CHF .',
- oneRequired:'Machen Sie für mindestens eines der Eingabefelder einen Eintrag.',
- noSpace: 'In diesem Eingabefeld darf kein Leerzeichen sein.',
- requiredChk: 'Dieses Feld ist obligatorisch.',
- match: 'Dieses Eingabefeld muss mit dem Feld {matchName} übereinstimmen.',
- afterDate: 'Das Datum sollte zur gleichen Zeit oder später sein {label}.',
- beforeDate: 'Das Datum sollte zur gleichen Zeit oder früher sein {label}.',
- sameMonth: 'Diese zwei Datumsangaben müssen im selben Monat sein - Sie müssen eine von beiden verändern.'
-script: Form.Validator.French.js
-description: Form.Validator messages in French.
-authors:
-- Miquel Hudin
-- Nicolas Sorosac <nicolas <dot> sorosac <at> gmail <dot> com>
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.French]
-MooTools.lang.set('fr-FR', 'Form.Validator', {
- required:'Ce champ est obligatoire.',
- minLength:'Veuillez saisir un minimum de {minLength} caractère(s) (vous avez saisi {length} caractère(s)).',
- maxLength:'Veuillez saisir un maximum de {maxLength} caractère(s) (vous avez saisi {length} caractère(s)).',
- integer:'Veuillez saisir un nombre entier dans ce champ. Les nombres décimaux (ex : "1,25") ne sont pas autorisés.',
- numeric:'Veuillez saisir uniquement des chiffres dans ce champ (ex : "1" ou "1,1" ou "-1" ou "-1,1").',
- digits:'Veuillez saisir uniquement des chiffres et des signes de ponctuation dans ce champ (ex : un numéro de téléphone avec des traits d\'union est autorisé).',
- alpha:'Veuillez saisir uniquement des lettres (a-z) dans ce champ. Les espaces ou autres caractères ne sont pas autorisés.',
- alphanum:'Veuillez saisir uniquement des lettres (a-z) ou des chiffres (0-9) dans ce champ. Les espaces ou autres caractères ne sont pas autorisés.',
- dateSuchAs:'Veuillez saisir une date correcte comme {date}',
- dateInFormatMDY:'Veuillez saisir une date correcte, au format JJ/MM/AAAA (ex : "31/11/1999").',
- email:'Veuillez saisir une adresse de courrier électronique. Par example "fred at domaine.com".',
- url:'Veuillez saisir une URL, comme http://www.google.com.',
- currencyDollar:'Veuillez saisir une quantité correcte. Par example 100,00€.',
- oneRequired:'Veuillez sélectionner au moins une de ces options.',
- errorPrefix: 'Erreur : ',
- warningPrefix: 'Attention : ',
- noSpace: 'Ce champ n\'accepte pas les espaces.',
- reqChkByNode: 'Aucun élément n\'est sélectionné.',
- requiredChk: 'Ce champ est obligatoire.',
- reqChkByName: 'Veuillez sélectionner un(e) {label}.',
- match: 'Ce champ doit correspondre avec le champ {matchName}.',
- startDate: 'date de début',
- endDate: 'date de fin',
- currendDate: 'date actuelle',
- afterDate: 'La date doit être identique ou postérieure à {label}.',
- beforeDate: 'La date doit être identique ou antérieure à {label}.',
- startMonth: 'Veuillez sélectionner un mois de début.',
- sameMonth: 'Ces deux dates doivent être dans le même mois - vous devez en modifier une.'
-script: Form.Validator.Italian.js
-description: Form.Validator messages in Italian.
-authors:
-- Leonardo Laureti
-- Andrea Novero
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.Italian]
-MooTools.lang.set('it-IT', 'Form.Validator', {
- required:'Il campo è obbligatorio.',
- minLength:'Inserire almeno {minLength} caratteri (ne sono stati inseriti {length}).',
- maxLength:'Inserire al massimo {maxLength} caratteri (ne sono stati inseriti {length}).',
- integer:'Inserire un numero intero. Non sono consentiti decimali (es.: 1.25).',
- numeric:'Inserire solo valori numerici (es.: "1" oppure "1.1" oppure "-1" oppure "-1.1").',
- digits:'Inserire solo numeri e caratteri di punteggiatura. Per esempio è consentito un numero telefonico con trattini o punti.',
- alpha:'Inserire solo lettere (a-z). Non sono consentiti spazi o altri caratteri.',
- alphanum:'Inserire solo lettere (a-z) o numeri (0-9). Non sono consentiti spazi o altri caratteri.',
- dateSuchAs:'Inserire una data valida del tipo {date}',
- dateInFormatMDY:'Inserire una data valida nel formato MM/GG/AAAA (es.: "12/31/1999")',
- email:'Inserire un indirizzo email valido. Per esempio "nome at dominio.com".',
- url:'Inserire un indirizzo valido. Per esempio "http://www.dominio.com".',
- currencyDollar:'Inserire un importo valido. Per esempio "$100.00".',
- oneRequired:'Completare almeno uno dei campi richiesti.',
- errorPrefix: 'Errore: ',
- warningPrefix: 'Attenzione: ',
- noSpace: 'Non sono consentiti spazi.',
- reqChkByNode: 'Nessuna voce selezionata.',
- requiredChk: 'Il campo è obbligatorio.',
- reqChkByName: 'Selezionare un(a) {label}.',
- match: 'Il valore deve corrispondere al campo {matchName}',
- startDate: 'data d\'inizio',
- endDate: 'data di fine',
- currendDate: 'data attuale',
- afterDate: 'La data deve corrispondere o essere successiva al {label}.',
- beforeDate: 'La data deve corrispondere o essere precedente al {label}.',
- startMonth: 'Selezionare un mese d\'inizio',
- sameMonth: 'Le due date devono essere dello stesso mese - occorre modificarne una.'
-script: Form.Validator.Norwegian.js
-description: Form.Validator messages in Norwegian.
-authors:
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.Norwegian]
-MooTools.lang.set('no-NO', 'Form.Validator', {
- required:'Dette feltet er pÃÂ¥krevd.',
- minLength:'Vennligst skriv inn minst {minLength} tegn (du skrev {length} tegn).',
- maxLength:'Vennligst skriv inn maksimalt {maxLength} tegn (du skrev {length} tegn).',
- integer:'Vennligst skriv inn et tall i dette feltet. Tall med desimaler (for eksempel 1,25) er ikke tillat.',
- numeric:'Vennligst skriv inn kun numeriske verdier i dette feltet (for eksempel "1", "1.1", "-1" eller "-1.1").',
- digits:'Vennligst bruk kun nummer og skilletegn i dette feltet.',
- alpha:'Vennligst bruk kun bokstaver (a-z) i dette feltet. Ingen mellomrom eller andre tegn er tillat.',
- alphanum:'Vennligst bruk kun bokstaver (a-z) eller nummer (0-9) i dette feltet. Ingen mellomrom eller andre tegn er tillat.',
- dateSuchAs:'Vennligst skriv inn en gyldig dato, som {date}',
- dateInFormatMDY:'Vennligst skriv inn en gyldig dato, i formatet MM/DD/YYYY (for eksempel "12/31/1999")',
- email:'Vennligst skriv inn en gyldig epost-adresse. For eksempel "espen at domene.no".',
- url:'Vennligst skriv inn en gyldig URL, for eksempel http://www.google.no.',
- currencyDollar:'Vennligst fyll ut et gyldig $ beløp. For eksempel $100.00 .',
- oneRequired:'Vennligst fyll ut noe i minst ett av disse feltene.',
- errorPrefix: 'Feil: ',
- warningPrefix: 'Advarsel: '
-script: Form.Validator.Polish.js
-authors:
-- Oskar Krawczyk
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.Polish]
-MooTools.lang.set('pl-PL', 'Form.Validator', {
- required:'To pole jest wymagane.',
- minLength:'Wymagane jest przynajmniej {minLength} znaków (wpisanych zostaÅo tylko {length}).',
- maxLength:'Dozwolone jest nie wiÄcej niż {maxLength} znaków (wpisanych zostaÅo {length})',
- integer:'To pole wymaga liczb caÅych. Liczby dziesiÄtne (np. 1.25) sÄ
niedozwolone.',
- numeric:'Prosimy używaÄ tylko numerycznych wartoÅci w tym polu (np. "1", "1.1", "-1" lub "-1.1").',
- digits:'Prosimy używaÄ liczb oraz zankow punktuacyjnych w typ polu (dla przykÅadu, przy numerze telefonu myÅlniki i kropki sÄ
dozwolone).',
- alpha:'Prosimy używaÄ tylko liter (a-z) w tym polu. Spacje oraz inne znaki sÄ
niedozwolone.',
- alphanum:'Prosimy używaÄ tylko liter (a-z) lub liczb (0-9) w tym polu. Spacje oraz inne znaki sÄ
niedozwolone.',
- dateSuchAs:'Prosimy podaÄ prawidÅowÄ
datÄ w formacie: {date}',
- dateInFormatMDY:'Prosimy podaÄ poprawnÄ
date w formacie DD.MM.RRRR (i.e. "12.01.2009")',
- email:'Prosimy podaÄ prawidÅowy adres e-mail, np. "jan at domena.pl".',
- url:'Prosimy podaÄ prawidÅowy adres URL, np. http://www.google.pl.',
- currencyDollar:'Prosimy podaÄ prawidÅowÄ
sumÄ w PLN. Dla przykÅadu: 100.00 PLN.',
- oneRequired:'Prosimy wypeÅniÄ chociaż jedno z pól.',
- errorPrefix: 'BÅÄ
d: ',
- warningPrefix: 'Uwaga: ',
- noSpace: 'W tym polu nie mogÄ
znajdowaÄ siÄ spacje.',
- reqChkByNode: 'Brak zaznaczonych elementów.',
- requiredChk: 'To pole jest wymagane.',
- reqChkByName: 'Prosimy wybraÄ z {label}.',
- match: 'To pole musi byÄ takie samo jak {matchName}',
- startDate: 'data poczÄ
tkowa',
- endDate: 'data koÅcowa',
- currendDate: 'aktualna data',
- afterDate: 'Podana data poinna byÄ taka sama lub po {label}.',
- beforeDate: 'Podana data poinna byÄ taka sama lub przed {label}.',
- startMonth: 'Prosimy wybraÄ poczÄ
tkowy miesiÄ
c.',
- sameMonth: 'Te dwie daty muszÄ
byÄ w zakresie tego samego miesiÄ
ca - wymagana jest zmiana któregoŠz pól.'
-script: Form.Validator.Portuguese.js
-description: Form.Validator messages in Portuguese.
-authors:
-- Miquel Hudin
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.Portuguese]
-MooTools.lang.set('pt-PT', 'Form.Validator', {
- required:'Este campo é necessário.',
- minLength:'Digite pelo menos{minLength} caracteres (comprimento {length} caracteres).',
- maxLength:'Não insira mais de {maxLength} caracteres (comprimento {length} caracteres).',
- integer:'Digite um número inteiro neste domÃnio. Com números decimais (por exemplo, 1,25), não são permitidas.',
- numeric:'Digite apenas valores numéricos neste domÃnio (p.ex., "1" ou "1.1" ou "-1" ou "-1,1").',
- digits:'Por favor, use números e pontuação apenas neste campo (p.ex., um número de telefone com traços ou pontos é permitida).',
- alpha:'Por favor use somente letras (a-z), com nesta área. Não utilize espaços nem outros caracteres são permitidos.',
- alphanum:'Use somente letras (a-z) ou números (0-9) neste campo. Não utilize espaços nem outros caracteres são permitidos.',
- dateSuchAs:'Digite uma data válida, como {date}',
- dateInFormatMDY:'Digite uma data válida, como DD/MM/YYYY (p.ex. "31/12/1999")',
- email:'Digite um endereço de email válido. Por exemplo "fred at domain.com".',
- url:'Digite uma URL válida, como http://www.google.com.',
- currencyDollar:'Digite um valor válido $. Por exemplo $ 100,00. ',
- oneRequired:'Digite algo para pelo menos um desses insumos.',
- errorPrefix: 'Erro: ',
- warningPrefix: 'Aviso: '
-}).set('pt-PT', 'Date', {
-script: Form.Validator.Portuguese.BR.js
-description: Form.Validator messages in Portuguese-BR.
-authors:
-- Fábio Miranda Costa
-requires:
-- /Lang
-- /Form.Validator.Portuguese
-provides: [Form.Validator.Portuguese.BR]
-MooTools.lang.set('pt-BR', 'Form.Validator', {
- required: 'Este campo é obrigatório.',
- minLength: 'Digite pelo menos {minLength} caracteres (tamanho atual: {length}).',
- maxLength: 'Não digite mais de {maxLength} caracteres (tamanho atual: {length}).',
- integer: 'Por favor digite apenas um número inteiro neste campo. Não são permitidos números decimais (por exemplo, 1,25).',
- numeric: 'Por favor digite apenas valores numéricos neste campo (por exemplo, "1" ou "1.1" ou "-1" ou "-1,1").',
- digits: 'Por favor use apenas números e pontuação neste campo (por exemplo, um número de telefone com traços ou pontos é permitido).',
- alpha: 'Por favor use somente letras (a-z). Espaço e outros caracteres não são permitidos.',
- alphanum: 'Use somente letras (a-z) ou números (0-9) neste campo. Espaço e outros caracteres não são permitidos.',
- dateSuchAs: 'Digite uma data válida, como {date}',
- dateInFormatMDY: 'Digite uma data válida, como DD/MM/YYYY (por exemplo, "31/12/1999")',
- email: 'Digite um endereço de email válido. Por exemplo "nome at dominio.com".',
- url: 'Digite uma URL válida. Exemplo: http://www.google.com.',
- currencyDollar: 'Digite um valor em dinheiro válido. Exemplo: R$100,00 .',
- oneRequired: 'Digite algo para pelo menos um desses campos.',
- warningPrefix: 'Aviso: ',
- noSpace: 'Não é possÃvel digitar espaços neste campo.',
- reqChkByNode: 'Não foi selecionado nenhum item.',
- requiredChk: 'Este campo é obrigatório.',
- reqChkByName: 'Por favor digite um {label}.',
- match: 'Este campo deve ser igual ao campo {matchName}.',
- startDate: 'a data inicial',
- endDate: 'a data final',
- currendDate: 'a data atual',
- afterDate: 'A data deve ser igual ou posterior a {label}.',
- beforeDate: 'A data deve ser igual ou anterior a {label}.',
- startMonth: 'Por favor selecione uma data inicial.',
- sameMonth: 'Estas duas datas devem ter o mesmo mês - você deve modificar uma das duas.',
- creditcard: 'O número do cartão de crédito informado é inválido. Por favor verifique o valor e tente novamente. {length} números informados.'
-script: Form.Validator.Russian.js
-description: Form.Validator messages in Russian (utf-8 and cp1251).
-authors:
-- Chernodarov Egor
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.Russian]
-MooTools.lang.set('ru-RU-unicode', 'Form.Validator', {
- required:'ÐÑо поле обÑ?заÑелÑно к заполнениÑ.',
- minLength:'ÐожалÑйÑ?Ñа, введиÑе Ñ
оÑÑ? Ð±Ñ {minLength} Ñ?имволов (ÐÑ Ð²Ð²ÐµÐ»Ð¸ {length}).',
- maxLength:'ÐожалÑйÑ?Ñа, введиÑе не болÑÑе {maxLength} Ñ?имволов (ÐÑ Ð²Ð²ÐµÐ»Ð¸ {length}).',
- integer:'ÐожалÑйÑ?Ñа, введиÑе в Ñ?Ñо поле ÑиÑ?ло. ÐÑобнÑе ÑиÑ?ла (напÑÐ¸Ð¼ÐµÑ 1.25) ÑÑÑ Ð½Ðµ ÑазÑеÑенÑ.',
- numeric:'ÐожалÑйÑ?Ñа, введиÑе в Ñ?Ñо поле ÑиÑ?ло (напÑÐ¸Ð¼ÐµÑ "1" или "1.1", или "-1", или "-1.1").',
- digits:'Ð Ñ?Ñом поле ÐÑ Ð¼Ð¾Ð¶ÐµÑе иÑ?полÑзоваÑÑ ÑолÑко ÑиÑÑÑ Ð¸ знаки пÑнкÑÑаÑии (напÑимеÑ, ÑелеÑоннÑй Ð½Ð¾Ð¼ÐµÑ Ñ?о знаками деÑиÑ?а или Ñ? ÑоÑками).',
- alpha:'Ð Ñ?Ñом поле можно иÑ?полÑзоваÑÑ ÑолÑко лаÑинÑ?кие бÑÐºÐ²Ñ (a-z). ÐÑÐ¾Ð±ÐµÐ»Ñ Ð¸ дÑÑгие Ñ?Ð¸Ð¼Ð²Ð¾Ð»Ñ Ð·Ð°Ð¿ÑеÑенÑ.',
- alphanum:'Ð Ñ?Ñом поле можно иÑ?полÑзоваÑÑ ÑолÑко лаÑинÑ?кие бÑÐºÐ²Ñ (a-z) и ÑиÑÑÑ (0-9). ÐÑÐ¾Ð±ÐµÐ»Ñ Ð¸ дÑÑгие Ñ?Ð¸Ð¼Ð²Ð¾Ð»Ñ Ð·Ð°Ð¿ÑеÑенÑ.',
- dateSuchAs:'ÐожалÑйÑ?Ñа, введиÑе коÑÑекÑнÑÑ Ð´Ð°ÑÑ {date}',
- dateInFormatMDY:'ÐожалÑйÑ?Ñа, введиÑе даÑÑ Ð² ÑоÑмаÑе ÐÐ/ÐÐ/ÐÐÐÐ (напÑÐ¸Ð¼ÐµÑ "12/31/1999")',
- email:'ÐожалÑйÑ?Ñа, введиÑе коÑÑекÑнÑй емейл-адÑеÑ?. ÐлÑ? пÑимеÑа "fred at domain.com".',
- url:'ÐожалÑйÑ?Ñа, введиÑе пÑавилÑнÑÑ Ñ?Ñ?ÑÐ»ÐºÑ Ð²Ð¸Ð´Ð° http://www.google.com.',
- currencyDollar:'ÐожалÑйÑ?Ñа, введиÑе Ñ?ÑÐ¼Ð¼Ñ Ð² доллаÑаÑ
. Ð?апÑимеÑ: $100.00 .',
- oneRequired:'ÐожалÑйÑ?Ñа, вÑбеÑиÑе Ñ
оÑÑ ÑÑо-нибÑÐ´Ñ Ð² одном из Ñ?ÑиÑ
полей.',
- errorPrefix: 'ÐÑибка: ',
- warningPrefix: 'Ðнимание: '
-//translation in windows-1251 codepage
-MooTools.lang.set('ru-RU', 'Form.Validator', {
- required:'Ã?òî ïîëå îáÿçà òåëüÃî ê çà ïîëÃÃ¥Ãèþ.',
- minLength:'Ã?îæà ëóéñòà , ââåäèòå õîòÿ áû {minLength} ñèìâîëîâ (Ãû ââåëè {length}).',
- maxLength:'Ã?îæà ëóéñòà , ââåäèòå ÃÃ¥ áîëüøå {maxLength} ñèìâîëîâ (Ãû ââåëè {length}).',
- integer:'Ã?îæà ëóéñòà , ââåäèòå â ýòî ïîëå ÷èñëî. ÃðîáÃûå ÷èñëà (Ãà ïðèìåð 1.25) òóò ÃÃ¥ ðà çðåøåÃû.',
- numeric:'Ã?îæà ëóéñòà , ââåäèòå â ýòî ïîëå ÷èñëî (Ãà ïðèìåð "1" èëè "1.1", èëè "-1", èëè "-1.1").',
- digits:'à ýòîì ïîëå Ãû ìîæåòå èñïîëüçîâà òü òîëüêî öèôðû è çÃà êè ïóÃêòóà öèè (Ãà ïðèìåð, òåëåôîÃÃûé Ãîìåð ñî çÃà êà ìè äåôèñà èëè ñ òî÷êà ìè).',
- alpha:'à ýòîì ïîëå ìîæÃî èñïîëüçîâà òü òîëüêî ëà òèÃñêèå áóêâû (a-z). Ã?ðîáåëû è äðóãèå ñèìâîëû çà ïðåùåÃû.',
- alphanum:'à ýòîì ïîëå ìîæÃî èñïîëüçîâà òü òîëüêî ëà òèÃñêèå áóêâû (a-z) è öèôðû (0-9). Ã?ðîáåëû è äðóãèå ñèìâîëû çà ïðåùåÃû.',
- dateSuchAs:'Ã?îæà ëóéñòà , ââåäèòå êîððåêòÃóþ äà òó {date}',
- dateInFormatMDY:'Ã?îæà ëóéñòà , ââåäèòå äà òó â ôîðìà òå ÃÃ/ÃÃ/ÃÃÃà (Ãà ïðèìåð "12/31/1999")',
- email:'Ã?îæà ëóéñòà , ââåäèòå êîððåêòÃûé åìåéë-à äðåñ. Ãëÿ ïðèìåðà "fred at domain.com".',
- url:'Ã?îæà ëóéñòà , ââåäèòå ïðà âèëüÃóþ ññûëêó âèäà http://www.google.com.',
- currencyDollar:'�îæà ëóéñòà , ââåäèòå ñóììó â äîëëà ðà õ. �à ïðèìåð: $100.00 .',
- oneRequired:'Ã?îæà ëóéñòà , âûáåðèòå õîòü ÷òî-Ãèáóäü â îäÃîì èç ýòèõ ïîëåé.',
- errorPrefix: 'Ãøèáêà : ',
- warningPrefix: 'ÃÃèìà Ãèå: '
-script: Form.Validator.Spanish.js
-authors:
-- Ãlfons Sanchez
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.Spanish]
-MooTools.lang.set('es-ES', 'Form.Validator', {
- required:'Este campo es obligatorio.',
- minLength:'Por favor introduce al menos {minLength} caracteres (has introducido {length} caracteres).',
- maxLength:'Por favor introduce no más de {maxLength} caracteres (has introducido {length} caracteres).',
- integer:'Por favor introduce un número entero en este campo. Números con decimales (p.e. 1,25) no se permiten.',
- numeric:'Por favor introduce solo valores numéricos en este campo (p.e. "1" o "1,1" o "-1" o "-1,1").',
- digits:'Por favor usa solo números y puntuación en este campo (por ejemplo, un número de teléfono con guiones y puntos no esta permitido).',
- alpha:'Por favor usa letras solo (a-z) en este campo. No se admiten espacios ni otros caracteres.',
- alphanum:'Por favor, usa solo letras (a-z) o números (0-9) en este campo. No se admiten espacios ni otros caracteres.',
- dateSuchAs:'Por favor introduce una fecha válida como {date}',
- dateInFormatMDY:'Por favor introduce una fecha válida como DD/MM/YYYY (p.e. "31/12/1999")',
- email:'Por favor, introduce una dirección de email válida. Por ejemplo, "fred at domain.com".',
- url:'Por favor introduce una URL válida como http://www.google.com.',
- currencyDollar:'Por favor introduce una cantidad válida de â¬. Por ejemplo â¬100,00 .',
- oneRequired:'Por favor introduce algo para por lo menos una de estas entradas.',
- noSpace: 'No pueden haber espacios en esta entrada.',
- reqChkByNode: 'No hay elementos seleccionados.',
- requiredChk: 'Este campo es obligatorio.',
- reqChkByName: 'Por favor selecciona una {label}.',
- match: 'Este campo necesita coincidir con el campo {matchName}',
- startDate: 'la fecha de inicio',
- endDate: 'la fecha de fin',
- currendDate: 'la fecha actual',
- afterDate: 'La fecha debe ser igual o posterior a {label}.',
- beforeDate: 'La fecha debe ser igual o anterior a {label}.',
- startMonth: 'Por favor selecciona un mes de origen',
- sameMonth: 'Estas dos fechas deben estar en el mismo mes - debes cambiar una u otra.'
-script: Form.Validator.Swedish.js
-description: Date messages for Swedish.
-authors:
-- Martin Lundgren
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.Swedish]
-MooTools.lang.set('sv-SE', 'Form.Validator', {
- required:'Fältet är obligatoriskt.',
- minLength:'Ange minst {minLength} tecken (du angav {length} tecken).',
- maxLength:'Ange högst {maxLength} tecken (du angav {length} tecken). ',
- integer:'Ange ett heltal i fältet. Tal med decimaler (t.ex. 1,25) är inte tillåtna.',
- numeric:'Ange endast numeriska värden i detta fält (t.ex. "1" eller "1.1" eller "-1" eller "-1,1").',
- digits:'Använd endast siffror och skiljetecken i detta fält (till exempel ett telefonnummer med bindestreck tillåtet).',
- alpha:'Använd endast bokstäver (a-ö) i detta fält. Inga mellanslag eller andra tecken är tillåtna.',
- alphanum:'Använd endast bokstäver (a-ö) och siffror (0-9) i detta fält. Inga mellanslag eller andra tecken är tillåtna.',
- dateSuchAs:'Ange ett giltigt datum som t.ex. {date}',
- dateInFormatMDY:'Ange ett giltigt datum som t.ex. YYYY-MM-DD (i.e. "1999-12-31")',
- email:'Ange en giltig e-postadress. Till exempel "erik at domain.com".',
- url:'Ange en giltig webbadress som http://www.google.com.',
- currencyDollar:'Ange en giltig belopp. Exempelvis 100,00.',
- oneRequired:'Vänligen ange minst ett av dessa alternativ.',
- errorPrefix: 'Fel: ',
- warningPrefix: 'Varning: ',
- noSpace: 'Det får inte finnas några mellanslag i detta fält.',
- reqChkByNode: 'Inga objekt är valda.',
- requiredChk: 'Detta är ett obligatoriskt fält.',
- reqChkByName: 'Välj en {label}.',
- match: 'Detta fält måste matcha {matchName}',
- startDate: 'startdatumet',
- endDate: 'slutdatum',
- currendDate: 'dagens datum',
- afterDate: 'Datumet bör vara samma eller senare än {label}.',
- beforeDate: 'Datumet bör vara samma eller tidigare än {label}.',
- startMonth: 'Välj en start månad',
- sameMonth: 'Dessa två datum måste vara i samma månad - du måste ändra det ena eller det andra.'
-script: Form.Validator.Ukrainian.js
-description: Form.Validator messages in Ukrainian (utf-8).
-authors:
-- Slik
-requires:
-- /Lang
-- /Form.Validator
-provides: [Form.Validator.Ukrainian]
-MooTools.lang.set('uk-UA', 'Form.Validator', {
- required:'Це поле повинне бÑÑи заповненим.',
- minLength:'ÐведÑÑÑ Ñ
оÑа б {minLength} Ñ?имволÑв (Ðи ввели {length}).',
- maxLength:'ÐÑлÑкÑÑ?ÑÑ Ñ?имволÑв не може бÑÑи бÑлÑÑе {maxLength} (Ðи ввели {length}).',
- integer:'ÐведÑÑÑ Ð² Ñе поле ÑиÑ?ло. ÐÑÐ¾Ð±Ð¾Ð²Ñ ÑиÑ?ла (напÑиклад 1.25) не дозволенÑ.',
- numeric:'ÐведÑÑÑ Ð² Ñе поле ÑиÑ?ло (напÑиклад "1" або "1.1", або "-1", або "-1.1").',
- digits:'Ð ÑÑÐ¾Ð¼Ñ Ð¿Ð¾Ð»Ñ Ð²Ð¸ можеÑе викоÑиÑ?ÑовÑваÑи лиÑе ÑиÑÑи Ñ Ð·Ð½Ð°ÐºÐ¸ пÑнкÑÑаÑÑÑ (напÑиклад, ÑелеÑонний Ð½Ð¾Ð¼ÐµÑ Ð· знаками деÑÑÐ·Ñ Ð°Ð±Ð¾ з кÑапками).',
- alpha:'Ð ÑÑÐ¾Ð¼Ñ Ð¿Ð¾Ð»Ñ Ð¼Ð¾Ð¶Ð½Ð° викоÑиÑ?ÑовÑваÑи лиÑе лаÑинÑ?ÑÐºÑ Ð»ÑÑеÑи (a-z). ÐÑобÑли Ñ ÑнÑÑ Ñ?имволи забоÑоненÑ.',
- alphanum:'Ð ÑÑÐ¾Ð¼Ñ Ð¿Ð¾Ð»Ñ Ð¼Ð¾Ð¶Ð½Ð° викоÑиÑ?ÑовÑваÑи лиÑе лаÑинÑ?ÑÐºÑ Ð»ÑÑеÑи (a-z) Ñ ÑиÑÑи (0-9). ÐÑобÑли Ñ ÑнÑÑ Ñ?имволи забоÑоненÑ.',
- dateSuchAs:'ÐведÑÑÑ ÐºÐ¾ÑекÑÐ½Ñ Ð´Ð°ÑÑ {date}.',
- dateInFormatMDY:'ÐведÑÑÑ Ð´Ð°ÑÑ Ð² ÑоÑмаÑÑ ÐÐ/ÐÐ/Ð Ð Ð Ð (напÑиклад "12/31/2009").',
- email:'ÐведÑÑÑ ÐºÐ¾ÑекÑÐ½Ñ Ð°Ð´ÑеÑ?Ñ ÐµÐ»ÐµÐºÑÑÐ¾Ð½Ð½Ð¾Ñ Ð¿Ð¾ÑÑи (напÑиклад "name at domain.com").',
- url:'ÐведÑÑÑ ÐºÐ¾ÑекÑне ÑнÑеÑнеÑ-поÑ?иланнÑ? (напÑиклад http://www.google.com).',
- currencyDollar:'ÐведÑÑÑ Ñ?ÑÐ¼Ñ Ð² долаÑаÑ
(напÑиклад "$100.00").',
- oneRequired:'ÐаповнÑÑÑ Ð¾Ð´Ð½Ðµ з полÑв.',
- errorPrefix: 'Ðомилка: ',
- warningPrefix: 'Увага: '
-// $Id: common.js 746 2010-03-12 12:57:45Z pagameba $
+script: Core.js
+description: The core of MooTools, contains all the base functions and the Native and Hash implementations. Required by all the other scripts.
+license: MIT-style license.
+copyright: Copyright (c) 2006-2008 [Valerio Proietti](http://mad4milk.net/).
+authors: The MooTools production team (http://mootools.net/developers/)
+inspiration:
+- Class implementation inspired by [Base.js](http://dean.edwards.name/weblog/2006/03/base/) Copyright (c) 2006 Dean Edwards, [GNU Lesser General Public License](http://opensource.org/licenses/lgpl-license.php)
+- Some functionality inspired by [Prototype.js](http://prototypejs.org) Copyright (c) 2005-2007 Sam Stephenson, [MIT License](http://opensource.org/licenses/mit-license.php)
+provides: [MooTools, Native, Hash.base, Array.each, $util]
+var MooTools = {
+ 'version': '1.2.5dev',
+ 'build': '%build%'
+var Native = function(options){
+ options = options || {};
+ var name = options.name;
+ var legacy = options.legacy;
+ var protect = options.protect;
+ var methods = options.implement;
+ var generics = options.generics;
+ var initialize = options.initialize;
+ var afterImplement = options.afterImplement || function(){};
+ var object = initialize || legacy;
+ generics = generics !== false;
+ object.constructor = Native;
+ object.$family = {name: 'native'};
+ if (legacy && initialize) object.prototype = legacy.prototype;
+ object.prototype.constructor = object;
+ if (name){
+ var family = name.toLowerCase();
+ object.prototype.$family = {name: family};
+ Native.typize(object, family);
+ var add = function(obj, name, method, force){
+ if (!protect || force || !obj.prototype[name]) obj.prototype[name] = method;
+ if (generics) Native.genericize(obj, name, protect);
+ afterImplement.call(obj, name, method);
+ return obj;
+ object.alias = function(a1, a2, a3){
+ if (typeof a1 == 'string'){
+ var pa1 = this.prototype[a1];
+ if ((a1 = pa1)) return add(this, a2, a1, a3);
+ for (var a in a1) this.alias(a, a1[a], a2);
+ return this;
+ object.implement = function(a1, a2, a3){
+ if (typeof a1 == 'string') return add(this, a1, a2, a3);
+ for (var p in a1) add(this, p, a1[p], a2);
+ return this;
+ if (methods) object.implement(methods);
+ return object;
+Native.genericize = function(object, property, check){
+ if ((!check || !object[property]) && typeof object.prototype[property] == 'function') object[property] = function(){
+ var args = Array.prototype.slice.call(arguments);
+ return object.prototype[property].apply(args.shift(), args);
+Native.implement = function(objects, properties){
+ for (var i = 0, l = objects.length; i < l; i++) objects[i].implement(properties);
+Native.typize = function(object, family){
+ if (!object.type) object.type = function(item){
+ return ($type(item) === family);
+(function(){
+ var natives = {'Array': Array, 'Date': Date, 'Function': Function, 'Number': Number, 'RegExp': RegExp, 'String': String};
+ for (var n in natives) new Native({name: n, initialize: natives[n], protect: true});
+ var types = {'boolean': Boolean, 'native': Native, 'object': Object};
+ for (var t in types) Native.typize(types[t], t);
+ var generics = {
+ 'Array': ["concat", "indexOf", "join", "lastIndexOf", "pop", "push", "reverse", "shift", "slice", "sort", "splice", "toString", "unshift", "valueOf"],
+ 'String': ["charAt", "charCodeAt", "concat", "indexOf", "lastIndexOf", "match", "replace", "search", "slice", "split", "substr", "substring", "toLowerCase", "toUpperCase", "valueOf"]
+ for (var g in generics){
+ for (var i = generics[g].length; i--;) Native.genericize(natives[g], generics[g][i], true);
+var Hash = new Native({
+ name: 'Hash',
+ initialize: function(object){
+ if ($type(object) == 'hash') object = $unlink(object.getClean());
+ for (var key in object) this[key] = object[key];
+ return this;
+Hash.implement({
+ forEach: function(fn, bind){
+ for (var key in this){
+ if (this.hasOwnProperty(key)) fn.call(bind, this[key], key, this);
+ getClean: function(){
+ var clean = {};
+ if (this.hasOwnProperty(key)) clean[key] = this[key];
+ return clean;
+ getLength: function(){
+ var length = 0;
+ if (this.hasOwnProperty(key)) length++;
+ return length;
+Hash.alias('forEach', 'each');
+Array.implement({
+ for (var i = 0, l = this.length; i < l; i++) fn.call(bind, this[i], i, this);
+Array.alias('forEach', 'each');
+function $A(iterable){
+ if (iterable.item){
+ var l = iterable.length, array = new Array(l);
+ while (l--) array[l] = iterable[l];
+ return array;
+ return Array.prototype.slice.call(iterable);
+function $arguments(i){
+ return function(){
+ return arguments[i];
+function $chk(obj){
+ return !!(obj || obj === 0);
+function $clear(timer){
+ clearTimeout(timer);
+ clearInterval(timer);
+ return null;
+function $defined(obj){
+ return (obj != undefined);
+function $each(iterable, fn, bind){
+ var type = $type(iterable);
+ ((type == 'arguments' || type == 'collection' || type == 'array') ? Array : Hash).each(iterable, fn, bind);
+function $empty(){};
+function $extend(original, extended){
+ for (var key in (extended || {})) original[key] = extended[key];
+ return original;
+function $H(object){
+ return new Hash(object);
+function $lambda(value){
+ return ($type(value) == 'function') ? value : function(){
+ return value;
+function $merge(){
+ var args = Array.slice(arguments);
+ args.unshift({});
+ return $mixin.apply(null, args);
+function $mixin(mix){
+ for (var i = 1, l = arguments.length; i < l; i++){
+ var object = arguments[i];
+ if ($type(object) != 'object') continue;
+ for (var key in object){
+ var op = object[key], mp = mix[key];
+ mix[key] = (mp && $type(op) == 'object' && $type(mp) == 'object') ? $mixin(mp, op) : $unlink(op);
+ return mix;
+function $pick(){
+ for (var i = 0, l = arguments.length; i < l; i++){
+ if (arguments[i] != undefined) return arguments[i];
+ return null;
+function $random(min, max){
+ return Math.floor(Math.random() * (max - min + 1) + min);
+function $splat(obj){
+ var type = $type(obj);
+ return (type) ? ((type != 'array' && type != 'arguments') ? [obj] : obj) : [];
+var $time = Date.now || function(){
+ return +new Date;
+function $try(){
+ try {
+ return arguments[i]();
+ } catch(e){}
+ return null;
+function $type(obj){
+ if (obj == undefined) return false;
+ if (obj.$family) return (obj.$family.name == 'number' && !isFinite(obj)) ? false : obj.$family.name;
+ if (obj.nodeName){
+ switch (obj.nodeType){
+ case 1: return 'element';
+ case 3: return (/\S/).test(obj.nodeValue) ? 'textnode' : 'whitespace';
+ } else if (typeof obj.length == 'number'){
+ if (obj.callee) return 'arguments';
+ else if (obj.item) return 'collection';
+ return typeof obj;
+function $unlink(object){
+ var unlinked;
+ switch ($type(object)){
+ case 'object':
+ unlinked = {};
+ for (var p in object) unlinked[p] = $unlink(object[p]);
+ break;
+ case 'hash':
+ unlinked = new Hash(object);
+ break;
+ case 'array':
+ unlinked = [];
+ for (var i = 0, l = object.length; i < l; i++) unlinked[i] = $unlink(object[i]);
+ break;
+ default: return object;
+ return unlinked;
+script: Browser.js
+description: The Browser Core. Contains Browser initialization, Window and Document, and the Browser Hash.
+requires:
+- /Native
+- /$util
+provides: [Browser, Window, Document, $exec]
+var Browser = $merge({
+ Engine: {name: 'unknown', version: 0},
+ Platform: {name: (window.orientation != undefined) ? 'ipod' : (navigator.platform.match(/mac|win|linux/i) || ['other'])[0].toLowerCase()},
+ Features: {xpath: !!(document.evaluate), air: !!(window.runtime), query: !!(document.querySelector)},
+ Plugins: {},
+ Engines: {
+ presto: function(){
+ return (!window.opera) ? false : ((arguments.callee.caller) ? 960 : ((document.getElementsByClassName) ? 950 : 925));
+ trident: function(){
+ return (!window.ActiveXObject) ? false : ((window.XMLHttpRequest) ? ((document.querySelectorAll) ? 6 : 5) : 4);
+ webkit: function(){
+ return (navigator.taintEnabled) ? false : ((Browser.Features.xpath) ? ((Browser.Features.query) ? 525 : 420) : 419);
+ gecko: function(){
+ return (!document.getBoxObjectFor && window.mozInnerScreenX == null) ? false : ((document.getElementsByClassName) ? 19 : 18);
+}, Browser || {});
+Browser.Platform[Browser.Platform.name] = true;
+Browser.detect = function(){
+ for (var engine in this.Engines){
+ var version = this.Engines[engine]();
+ if (version){
+ this.Engine = {name: engine, version: version};
+ this.Engine[engine] = this.Engine[engine + version] = true;
+ break;
+ return {name: engine, version: version};
+Browser.detect();
+Browser.Request = function(){
+ return $try(function(){
+ return new XMLHttpRequest();
+ }, function(){
+ return new ActiveXObject('MSXML2.XMLHTTP');
+ }, function(){
+ return new ActiveXObject('Microsoft.XMLHTTP');
+Browser.Features.xhr = !!(Browser.Request());
+Browser.Plugins.Flash = (function(){
+ var version = ($try(function(){
+ return navigator.plugins['Shockwave Flash'].description;
+ }, function(){
+ return new ActiveXObject('ShockwaveFlash.ShockwaveFlash').GetVariable('$version');
+ }) || '0 r0').match(/\d+/g);
+ return {version: parseInt(version[0] || 0 + '.' + version[1], 10) || 0, build: parseInt(version[2], 10) || 0};
+function $exec(text){
+ if (!text) return text;
+ if (window.execScript){
+ window.execScript(text);
+ } else {
+ var script = document.createElement('script');
+ script.setAttribute('type', 'text/javascript');
+ script[(Browser.Engine.webkit && Browser.Engine.version < 420) ? 'innerText' : 'text'] = text;
+ document.head.appendChild(script);
+ document.head.removeChild(script);
+ return text;
+Native.UID = 1;
+var $uid = (Browser.Engine.trident) ? function(item){
+ return (item.uid || (item.uid = [Native.UID++]))[0];
+} : function(item){
+ return item.uid || (item.uid = Native.UID++);
+var Window = new Native({
+ name: 'Window',
+ legacy: (Browser.Engine.trident) ? null: window.Window,
+ initialize: function(win){
+ $uid(win);
+ if (!win.Element){
+ win.Element = $empty;
+ if (Browser.Engine.webkit) win.document.createElement("iframe"); //fixes safari 2
+ win.Element.prototype = (Browser.Engine.webkit) ? window["[[DOMElement.prototype]]"] : {};
+ win.document.window = win;
+ return $extend(win, Window.Prototype);
+ afterImplement: function(property, value){
+ window[property] = Window.Prototype[property] = value;
+Window.Prototype = {$family: {name: 'window'}};
+new Window(window);
+var Document = new Native({
+ name: 'Document',
+ legacy: (Browser.Engine.trident) ? null: window.Document,
+ initialize: function(doc){
+ $uid(doc);
+ doc.head = doc.getElementsByTagName('head')[0];
+ doc.html = doc.getElementsByTagName('html')[0];
+ if (Browser.Engine.trident && Browser.Engine.version <= 4) $try(function(){
+ doc.execCommand("BackgroundImageCache", false, true);
+ if (Browser.Engine.trident) doc.window.attachEvent('onunload', function(){
+ doc.window.detachEvent('onunload', arguments.callee);
+ doc.head = doc.html = doc.window = null;
+ return $extend(doc, Document.Prototype);
+ document[property] = Document.Prototype[property] = value;
+Document.Prototype = {$family: {name: 'document'}};
+new Document(document);
+script: Array.js
+description: Contains Array Prototypes like each, contains, and erase.
+requires:
+- /$util
+- /Array.each
+provides: [Array]
+Array.implement({
+ every: function(fn, bind){
+ for (var i = 0, l = this.length; i < l; i++){
+ if (!fn.call(bind, this[i], i, this)) return false;
+ return true;
+ filter: function(fn, bind){
+ var results = [];
+ if (fn.call(bind, this[i], i, this)) results.push(this[i]);
+ return results;
+ clean: function(){
+ return this.filter($defined);
+ indexOf: function(item, from){
+ var len = this.length;
+ for (var i = (from < 0) ? Math.max(0, len + from) : from || 0; i < len; i++){
+ if (this[i] === item) return i;
+ return -1;
+ map: function(fn, bind){
+ var results = [];
+ for (var i = 0, l = this.length; i < l; i++) results[i] = fn.call(bind, this[i], i, this);
+ return results;
+ some: function(fn, bind){
+ if (fn.call(bind, this[i], i, this)) return true;
+ return false;
+ associate: function(keys){
+ var obj = {}, length = Math.min(this.length, keys.length);
+ for (var i = 0; i < length; i++) obj[keys[i]] = this[i];
+ return obj;
+ link: function(object){
+ var result = {};
+ if (object[key](this[i])){
+ result[key] = this[i];
+ delete object[key];
+ break;
+ return result;
+ contains: function(item, from){
+ return this.indexOf(item, from) != -1;
+ extend: function(array){
+ for (var i = 0, j = array.length; i < j; i++) this.push(array[i]);
+ return this;
+ getLast: function(){
+ return (this.length) ? this[this.length - 1] : null;
+ getRandom: function(){
+ return (this.length) ? this[$random(0, this.length - 1)] : null;
+ include: function(item){
+ if (!this.contains(item)) this.push(item);
+ return this;
+ combine: function(array){
+ for (var i = 0, l = array.length; i < l; i++) this.include(array[i]);
+ return this;
+ erase: function(item){
+ for (var i = this.length; i--; i){
+ if (this[i] === item) this.splice(i, 1);
+ return this;
+ empty: function(){
+ this.length = 0;
+ return this;
+ flatten: function(){
+ var array = [];
+ var type = $type(this[i]);
+ if (!type) continue;
+ array = array.concat((type == 'array' || type == 'collection' || type == 'arguments') ? Array.flatten(this[i]) : this[i]);
+ return array;
+ hexToRgb: function(array){
+ if (this.length != 3) return null;
+ var rgb = this.map(function(value){
+ if (value.length == 1) value += value;
+ return value.toInt(16);
+ return (array) ? rgb : 'rgb(' + rgb + ')';
+ rgbToHex: function(array){
+ if (this.length < 3) return null;
+ if (this.length == 4 && this[3] == 0 && !array) return 'transparent';
+ var hex = [];
+ for (var i = 0; i < 3; i++){
+ var bit = (this[i] - 0).toString(16);
+ hex.push((bit.length == 1) ? '0' + bit : bit);
+ return (array) ? hex : '#' + hex.join('');
+script: Function.js
+description: Contains Function Prototypes like create, bind, pass, and delay.
+requires:
+- /Native
+- /$util
+provides: [Function]
+Function.implement({
+ extend: function(properties){
+ for (var property in properties) this[property] = properties[property];
+ return this;
+ create: function(options){
+ var self = this;
+ return function(event){
+ var args = options.arguments;
+ args = (args != undefined) ? $splat(args) : Array.slice(arguments, (options.event) ? 1 : 0);
+ if (options.event) args = [event || window.event].extend(args);
+ var returns = function(){
+ return self.apply(options.bind || null, args);
+ if (options.delay) return setTimeout(returns, options.delay);
+ if (options.periodical) return setInterval(returns, options.periodical);
+ if (options.attempt) return $try(returns);
+ return returns();
+ run: function(args, bind){
+ return this.apply(bind, $splat(args));
+ pass: function(args, bind){
+ return this.create({bind: bind, arguments: args});
+ bind: function(bind, args){
+ bindWithEvent: function(bind, args){
+ return this.create({bind: bind, arguments: args, event: true});
+ attempt: function(args, bind){
+ return this.create({bind: bind, arguments: args, attempt: true})();
+ delay: function(delay, bind, args){
+ return this.create({bind: bind, arguments: args, delay: delay})();
+ periodical: function(periodical, bind, args){
+ return this.create({bind: bind, arguments: args, periodical: periodical})();
+script: Number.js
+description: Contains Number Prototypes like limit, round, times, and ceil.
+requires:
+- /Native
+- /$util
+provides: [Number]
+Number.implement({
+ limit: function(min, max){
+ return Math.min(max, Math.max(min, this));
+ round: function(precision){
+ precision = Math.pow(10, precision || 0);
+ return Math.round(this * precision) / precision;
+ times: function(fn, bind){
+ for (var i = 0; i < this; i++) fn.call(bind, i, this);
+ toFloat: function(){
+ return parseFloat(this);
+ toInt: function(base){
+ return parseInt(this, base || 10);
+Number.alias('times', 'each');
+(function(math){
+ var methods = {};
+ math.each(function(name){
+ if (!Number[name]) methods[name] = function(){
+ return Math[name].apply(null, [this].concat($A(arguments)));
+ Number.implement(methods);
+})(['abs', 'acos', 'asin', 'atan', 'atan2', 'ceil', 'cos', 'exp', 'floor', 'log', 'max', 'min', 'pow', 'sin', 'sqrt', 'tan']);
+script: String.js
+description: Contains String Prototypes like camelCase, capitalize, test, and toInt.
+requires:
+- /Native
+provides: [String]
+String.implement({
+ test: function(regex, params){
+ return ((typeof regex == 'string') ? new RegExp(regex, params) : regex).test(this);
+ contains: function(string, separator){
+ return (separator) ? (separator + this + separator).indexOf(separator + string + separator) > -1 : this.indexOf(string) > -1;
+ trim: function(){
+ return this.replace(/^\s+|\s+$/g, '');
+ return this.replace(/\s+/g, ' ').trim();
+ camelCase: function(){
+ return this.replace(/-\D/g, function(match){
+ return match.charAt(1).toUpperCase();
+ hyphenate: function(){
+ return this.replace(/[A-Z]/g, function(match){
+ return ('-' + match.charAt(0).toLowerCase());
+ capitalize: function(){
+ return this.replace(/\b[a-z]/g, function(match){
+ return match.toUpperCase();
+ escapeRegExp: function(){
+ return this.replace(/([-.*+?^${}()|[\]\/\\])/g, '\\$1');
+ var hex = this.match(/^#?(\w{1,2})(\w{1,2})(\w{1,2})$/);
+ return (hex) ? hex.slice(1).hexToRgb(array) : null;
+ var rgb = this.match(/\d{1,3}/g);
+ return (rgb) ? rgb.rgbToHex(array) : null;
+ stripScripts: function(option){
+ var scripts = '';
+ var text = this.replace(/<script[^>]*>([\s\S]*?)<\/script>/gi, function(){
+ scripts += arguments[1] + '\n';
+ return '';
+ if (option === true) $exec(scripts);
+ else if ($type(option) == 'function') option(scripts, text);
+ return text;
+ substitute: function(object, regexp){
+ return this.replace(regexp || (/\\?\{([^{}]+)\}/g), function(match, name){
+ if (match.charAt(0) == '\\') return match.slice(1);
+ return (object[name] != undefined) ? object[name] : '';
+script: Hash.js
+description: Contains Hash Prototypes. Provides a means for overcoming the JavaScript practical impossibility of extending native Objects.
+requires:
+- /Hash.base
+provides: [Hash]
+Hash.implement({
+ has: Object.prototype.hasOwnProperty,
+ keyOf: function(value){
+ if (this.hasOwnProperty(key) && this[key] === value) return key;
+ return null;
+ hasValue: function(value){
+ return (Hash.keyOf(this, value) !== null);
+ Hash.each(properties || {}, function(value, key){
+ Hash.set(this, key, value);
+ }, this);
+ return this;
+ combine: function(properties){
+ Hash.include(this, key, value);
+ }, this);
+ return this;
+ erase: function(key){
+ if (this.hasOwnProperty(key)) delete this[key];
+ return this;
+ get: function(key){
+ return (this.hasOwnProperty(key)) ? this[key] : null;
+ set: function(key, value){
+ if (!this[key] || this.hasOwnProperty(key)) this[key] = value;
+ return this;
+ Hash.each(this, function(value, key){
+ delete this[key];
+ }, this);
+ return this;
+ include: function(key, value){
+ if (this[key] == undefined) this[key] = value;
+ return this;
+ var results = new Hash;
+ results.set(key, fn.call(bind, value, key, this));
+ }, this);
+ return results;
+ if (fn.call(bind, value, key, this)) results.set(key, value);
+ }, this);
+ return results;
+ if (this.hasOwnProperty(key) && !fn.call(bind, this[key], key)) return false;
+ return true;
+ if (this.hasOwnProperty(key) && fn.call(bind, this[key], key)) return true;
+ return false;
+ getKeys: function(){
+ var keys = [];
+ keys.push(key);
+ return keys;
+ getValues: function(){
+ var values = [];
+ Hash.each(this, function(value){
+ values.push(value);
+ return values;
+ toQueryString: function(base){
+ var queryString = [];
+ if (base) key = base + '[' + key + ']';
+ var result;
+ switch ($type(value)){
+ case 'object': result = Hash.toQueryString(value, key); break;
+ case 'array':
+ var qs = {};
+ value.each(function(val, i){
+ qs[i] = val;
+ result = Hash.toQueryString(qs, key);
+ break;
+ default: result = key + '=' + encodeURIComponent(value);
+ if (value != undefined) queryString.push(result);
+ return queryString.join('&');
+Hash.alias({keyOf: 'indexOf', hasValue: 'contains'});
+script: Event.js
+description: Contains the Event Class, to make the event object cross-browser.
+requires:
+- /Window
+- /Document
+- /Hash
+- /Array
+- /Function
+- /String
+provides: [Event]
+var Event = new Native({
+ name: 'Event',
+ initialize: function(event, win){
+ win = win || window;
+ var doc = win.document;
+ event = event || win.event;
+ if (event.$extended) return event;
+ this.$extended = true;
+ var type = event.type;
+ var target = event.target || event.srcElement;
+ while (target && target.nodeType == 3) target = target.parentNode;
+ if (type.test(/key/)){
+ var code = event.which || event.keyCode;
+ var key = Event.Keys.keyOf(code);
+ if (type == 'keydown'){
+ var fKey = code - 111;
+ if (fKey > 0 && fKey < 13) key = 'f' + fKey;
+ key = key || String.fromCharCode(code).toLowerCase();
+ } else if (type.match(/(click|mouse|menu)/i)){
+ doc = (!doc.compatMode || doc.compatMode == 'CSS1Compat') ? doc.html : doc.body;
+ var page = {
+ x: event.pageX || event.clientX + doc.scrollLeft,
+ y: event.pageY || event.clientY + doc.scrollTop
+ var client = {
+ x: (event.pageX) ? event.pageX - win.pageXOffset : event.clientX,
+ y: (event.pageY) ? event.pageY - win.pageYOffset : event.clientY
+ if (type.match(/DOMMouseScroll|mousewheel/)){
+ var wheel = (event.wheelDelta) ? event.wheelDelta / 120 : -(event.detail || 0) / 3;
+ var rightClick = (event.which == 3) || (event.button == 2);
+ var related = null;
+ if (type.match(/over|out/)){
+ switch (type){
+ case 'mouseover': related = event.relatedTarget || event.fromElement; break;
+ case 'mouseout': related = event.relatedTarget || event.toElement;
+ if (!(function(){
+ while (related && related.nodeType == 3) related = related.parentNode;
+ return true;
+ }).create({attempt: Browser.Engine.gecko})()) related = false;
+ return $extend(this, {
+ event: event,
+ type: type,
+ page: page,
+ client: client,
+ rightClick: rightClick,
+ wheel: wheel,
+ relatedTarget: related,
+ target: target,
+ code: code,
+ key: key,
+ shift: event.shiftKey,
+ control: event.ctrlKey,
+ alt: event.altKey,
+ meta: event.metaKey
+Event.Keys = new Hash({
+ 'enter': 13,
+ 'up': 38,
+ 'down': 40,
+ 'left': 37,
+ 'right': 39,
+ 'esc': 27,
+ 'space': 32,
+ 'backspace': 8,
+ 'tab': 9,
+ 'delete': 46
+Event.implement({
+ stop: function(){
+ return this.stopPropagation().preventDefault();
+ stopPropagation: function(){
+ if (this.event.stopPropagation) this.event.stopPropagation();
+ else this.event.cancelBubble = true;
+ return this;
+ preventDefault: function(){
+ if (this.event.preventDefault) this.event.preventDefault();
+ else this.event.returnValue = false;
+ return this;
+script: Class.js
+description: Contains the Class Function for easily creating, extending, and implementing reusable Classes.
+requires:
+- /$util
+- /Native
+- /Array
+- /String
+- /Function
+- /Number
+- /Hash
+provides: [Class]
+function Class(params){
+ if (params instanceof Function) params = {initialize: params};
+ var newClass = function(){
+ Object.reset(this);
+ if (newClass._prototyping) return this;
+ this._current = $empty;
+ var value = (this.initialize) ? this.initialize.apply(this, arguments) : this;
+ delete this._current; delete this.caller;
+ return value;
+ }.extend(this);
+ newClass.implement(params);
+ newClass.constructor = Class;
+ newClass.prototype.constructor = newClass;
+ return newClass;
+Function.prototype.protect = function(){
+ this._protected = true;
+ return this;
+Object.reset = function(object, key){
+ if (key == null){
+ for (var p in object) Object.reset(object, p);
+ return object;
+ switch ($type(object[key])){
+ case 'object':
+ var F = function(){};
+ F.prototype = object[key];
+ var i = new F;
+ object[key] = Object.reset(i);
+ break;
+ case 'array': object[key] = $unlink(object[key]); break;
+ return object;
+new Native({name: 'Class', initialize: Class}).extend({
+ instantiate: function(F){
+ F._prototyping = true;
+ var proto = new F;
+ delete F._prototyping;
+ return proto;
+ wrap: function(self, key, method){
+ if (method._origin) method = method._origin;
+ if (method._protected && this._current == null) throw new Error('The method "' + key + '" cannot be called.');
+ var caller = this.caller, current = this._current;
+ this.caller = current; this._current = arguments.callee;
+ var result = method.apply(this, arguments);
+ this._current = current; this.caller = caller;
+ return result;
+ }.extend({_owner: self, _origin: method, _name: key});
+Class.implement({
+ implement: function(key, value){
+ if ($type(key) == 'object'){
+ for (var p in key) this.implement(p, key[p]);
+ return this;
+ var mutator = Class.Mutators[key];
+ if (mutator){
+ value = mutator.call(this, value);
+ if (value == null) return this;
+ var proto = this.prototype;
+ case 'function':
+ if (value._hidden) return this;
+ proto[key] = Class.wrap(this, key, value);
+ break;
+ case 'object':
+ var previous = proto[key];
+ if ($type(previous) == 'object') $mixin(previous, value);
+ else proto[key] = $unlink(value);
+ break;
+ case 'array':
+ proto[key] = $unlink(value);
+ break;
+ default: proto[key] = value;
+ return this;
+Class.Mutators = {
+ Extends: function(parent){
+ this.parent = parent;
+ this.prototype = Class.instantiate(parent);
+ this.implement('parent', function(){
+ var name = this.caller._name, previous = this.caller._owner.parent.prototype[name];
+ if (!previous) throw new Error('The method "' + name + '" has no parent.');
+ return previous.apply(this, arguments);
+ }.protect());
+ Implements: function(items){
+ $splat(items).each(function(item){
+ if (item instanceof Function) item = Class.instantiate(item);
+ this.implement(item);
+ }, this);
+script: Class.Extras.js
+description: Contains Utility Classes that can be implemented into your own Classes to ease the execution of many common tasks.
+requires:
+- /Class
+provides: [Chain, Events, Options]
+var Chain = new Class({
+ $chain: [],
+ chain: function(){
+ this.$chain.extend(Array.flatten(arguments));
+ return this;
+ callChain: function(){
+ return (this.$chain.length) ? this.$chain.shift().apply(this, arguments) : false;
+ clearChain: function(){
+ this.$chain.empty();
+ return this;
+var Events = new Class({
+ $events: {},
+ addEvent: function(type, fn, internal){
+ type = Events.removeOn(type);
+ if (fn != $empty){
+ this.$events[type] = this.$events[type] || [];
+ this.$events[type].include(fn);
+ if (internal) fn.internal = true;
+ return this;
+ addEvents: function(events){
+ for (var type in events) this.addEvent(type, events[type]);
+ return this;
+ fireEvent: function(type, args, delay){
+ if (!this.$events || !this.$events[type]) return this;
+ this.$events[type].each(function(fn){
+ fn.create({'bind': this, 'delay': delay, 'arguments': args})();
+ }, this);
+ return this;
+ removeEvent: function(type, fn){
+ if (!this.$events[type]) return this;
+ if (!fn.internal) this.$events[type].erase(fn);
+ return this;
+ removeEvents: function(events){
+ var type;
+ if ($type(events) == 'object'){
+ for (type in events) this.removeEvent(type, events[type]);
+ return this;
+ if (events) events = Events.removeOn(events);
+ for (type in this.$events){
+ if (events && events != type) continue;
+ var fns = this.$events[type];
+ for (var i = fns.length; i--; i) this.removeEvent(type, fns[i]);
+ return this;
+Events.removeOn = function(string){
+ return string.replace(/^on([A-Z])/, function(full, first){
+ return first.toLowerCase();
+var Options = new Class({
+ setOptions: function(){
+ this.options = $merge.run([this.options].extend(arguments));
+ if (!this.addEvent) return this;
+ for (var option in this.options){
+ if ($type(this.options[option]) != 'function' || !(/^on[A-Z]/).test(option)) continue;
+ this.addEvent(option, this.options[option]);
+ delete this.options[option];
+ return this;
+script: Element.js
+description: One of the most important items in MooTools. Contains the dollar function, the dollars function, and an handful of cross-browser, time-saver methods to let you easily work with HTML Elements.
+requires:
+- /Window
+- /Document
+- /Array
+- /String
+- /Function
+- /Number
+- /Hash
+provides: [Element, Elements, $, $$, Iframe]
+var Element = new Native({
+ name: 'Element',
+ legacy: window.Element,
+ initialize: function(tag, props){
+ var konstructor = Element.Constructors.get(tag);
+ if (konstructor) return konstructor(props);
+ if (typeof tag == 'string') return document.newElement(tag, props);
+ return document.id(tag).set(props);
+ afterImplement: function(key, value){
+ Element.Prototype[key] = value;
+ if (Array[key]) return;
+ Elements.implement(key, function(){
+ var items = [], elements = true;
+ for (var i = 0, j = this.length; i < j; i++){
+ var returns = this[i][key].apply(this[i], arguments);
+ items.push(returns);
+ if (elements) elements = ($type(returns) == 'element');
+ return (elements) ? new Elements(items) : items;
+Element.Prototype = {$family: {name: 'element'}};
+Element.Constructors = new Hash;
+var IFrame = new Native({
+ name: 'IFrame',
+ generics: false,
+ initialize: function(){
+ var params = Array.link(arguments, {properties: Object.type, iframe: $defined});
+ var props = params.properties || {};
+ var iframe = document.id(params.iframe);
+ var onload = props.onload || $empty;
+ delete props.onload;
+ props.id = props.name = $pick(props.id, props.name, iframe ? (iframe.id || iframe.name) : 'IFrame_' + $time());
+ iframe = new Element(iframe || 'iframe', props);
+ var onFrameLoad = function(){
+ var host = $try(function(){
+ return iframe.contentWindow.location.host;
+ if (!host || host == window.location.host){
+ var win = new Window(iframe.contentWindow);
+ new Document(iframe.contentWindow.document);
+ $extend(win.Element.prototype, Element.Prototype);
+ onload.call(iframe.contentWindow, iframe.contentWindow.document);
+ var contentWindow = $try(function(){
+ return iframe.contentWindow;
+ ((contentWindow && contentWindow.document.body) || window.frames[props.id]) ? onFrameLoad() : iframe.addListener('load', onFrameLoad);
+ return iframe;
+var Elements = new Native({
+ initialize: function(elements, options){
+ options = $extend({ddup: true, cash: true}, options);
+ elements = elements || [];
+ if (options.ddup || options.cash){
+ var uniques = {}, returned = [];
+ for (var i = 0, l = elements.length; i < l; i++){
+ var el = document.id(elements[i], !options.cash);
+ if (options.ddup){
+ if (uniques[el.uid]) continue;
+ uniques[el.uid] = true;
+ if (el) returned.push(el);
+ elements = returned;
+ return (options.cash) ? $extend(elements, this) : elements;
+Elements.implement({
+ filter: function(filter, bind){
+ if (!filter) return this;
+ return new Elements(Array.filter(this, (typeof filter == 'string') ? function(item){
+ return item.match(filter);
+ } : filter, bind));
+Document.implement({
+ newElement: function(tag, props){
+ if (Browser.Engine.trident && props){
+ ['name', 'type', 'checked'].each(function(attribute){
+ if (!props[attribute]) return;
+ tag += ' ' + attribute + '="' + props[attribute] + '"';
+ if (attribute != 'checked') delete props[attribute];
+ tag = '<' + tag + '>';
+ return document.id(this.createElement(tag)).set(props);
+ newTextNode: function(text){
+ return this.createTextNode(text);
+ getDocument: function(){
+ return this;
+ getWindow: function(){
+ return this.window;
+ id: (function(){
+ var types = {
+ string: function(id, nocash, doc){
+ id = doc.getElementById(id);
+ return (id) ? types.element(id, nocash) : null;
+ element: function(el, nocash){
+ $uid(el);
+ if (!nocash && !el.$family && !(/^object|embed$/i).test(el.tagName)){
+ var proto = Element.Prototype;
+ for (var p in proto) el[p] = proto[p];
+ return el;
+ object: function(obj, nocash, doc){
+ if (obj.toElement) return types.element(obj.toElement(doc), nocash);
+ return null;
+ types.textnode = types.whitespace = types.window = types.document = $arguments(0);
+ return function(el, nocash, doc){
+ if (el && el.$family && el.uid) return el;
+ var type = $type(el);
+ return (types[type]) ? types[type](el, nocash, doc || document) : null;
+if (window.$ == null) Window.implement({
+ $: function(el, nc){
+ return document.id(el, nc, this.document);
+Window.implement({
+ $$: function(selector){
+ if (arguments.length == 1 && typeof selector == 'string') return this.document.getElements(selector);
+ var elements = [];
+ var args = Array.flatten(arguments);
+ for (var i = 0, l = args.length; i < l; i++){
+ var item = args[i];
+ switch ($type(item)){
+ case 'element': elements.push(item); break;
+ case 'string': elements.extend(this.document.getElements(item, true));
+ return new Elements(elements);
+ return this.document;
+ return this;
+Native.implement([Element, Document], {
+ getElement: function(selector, nocash){
+ return document.id(this.getElements(selector, true)[0] || null, nocash);
+ getElements: function(tags, nocash){
+ tags = tags.split(',');
+ var ddup = (tags.length > 1);
+ tags.each(function(tag){
+ var partial = this.getElementsByTagName(tag.trim());
+ (ddup) ? elements.extend(partial) : elements = partial;
+ }, this);
+ return new Elements(elements, {ddup: ddup, cash: !nocash});
+(function(){
+var collected = {}, storage = {};
+var props = {input: 'checked', option: 'selected', textarea: (Browser.Engine.webkit && Browser.Engine.version < 420) ? 'innerHTML' : 'value'};
+var get = function(uid){
+ return (storage[uid] || (storage[uid] = {}));
+var clean = function(item, retain){
+ if (!item) return;
+ var uid = item.uid;
+ if (retain !== true) retain = false;
+ if (Browser.Engine.trident){
+ if (item.clearAttributes){
+ var clone = retain && item.cloneNode(false);
+ item.clearAttributes();
+ if (clone) item.mergeAttributes(clone);
+ } else if (item.removeEvents){
+ item.removeEvents();
+ if ((/object/i).test(item.tagName)){
+ for (var p in item){
+ if (typeof item[p] == 'function') item[p] = $empty;
+ Element.dispose(item);
+ if (!uid) return;
+ collected[uid] = storage[uid] = null;
+var purge = function(){
+ Hash.each(collected, clean);
+ if (Browser.Engine.trident) $A(document.getElementsByTagName('object')).each(clean);
+ if (window.CollectGarbage) CollectGarbage();
+ collected = storage = null;
+var walk = function(element, walk, start, match, all, nocash){
+ var el = element[start || walk];
+ while (el){
+ if (el.nodeType == 1 && (!match || Element.match(el, match))){
+ if (!all) return document.id(el, nocash);
+ elements.push(el);
+ el = el[walk];
+ return (all) ? new Elements(elements, {ddup: false, cash: !nocash}) : null;
+var attributes = {
+ 'html': 'innerHTML',
+ 'class': 'className',
+ 'for': 'htmlFor',
+ 'defaultValue': 'defaultValue',
+ 'text': (Browser.Engine.trident || (Browser.Engine.webkit && Browser.Engine.version < 420)) ? 'innerText' : 'textContent'
+var bools = ['compact', 'nowrap', 'ismap', 'declare', 'noshade', 'checked', 'disabled', 'readonly', 'multiple', 'selected', 'noresize', 'defer'];
+var camels = ['value', 'type', 'defaultValue', 'accessKey', 'cellPadding', 'cellSpacing', 'colSpan', 'frameBorder', 'maxLength', 'readOnly', 'rowSpan', 'tabIndex', 'useMap'];
+bools = bools.associate(bools);
+Hash.extend(attributes, bools);
+Hash.extend(attributes, camels.associate(camels.map(String.toLowerCase)));
+var inserters = {
+ before: function(context, element){
+ if (element.parentNode) element.parentNode.insertBefore(context, element);
+ after: function(context, element){
+ if (!element.parentNode) return;
+ var next = element.nextSibling;
+ (next) ? element.parentNode.insertBefore(context, next) : element.parentNode.appendChild(context);
+ bottom: function(context, element){
+ element.appendChild(context);
+ top: function(context, element){
+ var first = element.firstChild;
+ (first) ? element.insertBefore(context, first) : element.appendChild(context);
+inserters.inside = inserters.bottom;
+Hash.each(inserters, function(inserter, where){
+ where = where.capitalize();
+ Element.implement('inject' + where, function(el){
+ inserter(this, document.id(el, true));
+ return this;
+ Element.implement('grab' + where, function(el){
+ inserter(document.id(el, true), this);
+ return this;
+Element.implement({
+ set: function(prop, value){
+ switch ($type(prop)){
+ case 'object':
+ for (var p in prop) this.set(p, prop[p]);
+ break;
+ case 'string':
+ var property = Element.Properties.get(prop);
+ (property && property.set) ? property.set.apply(this, Array.slice(arguments, 1)) : this.setProperty(prop, value);
+ return this;
+ get: function(prop){
+ return (property && property.get) ? property.get.apply(this, Array.slice(arguments, 1)) : this.getProperty(prop);
+ erase: function(prop){
+ (property && property.erase) ? property.erase.apply(this) : this.removeProperty(prop);
+ return this;
+ setProperty: function(attribute, value){
+ var key = attributes[attribute];
+ if (value == undefined) return this.removeProperty(attribute);
+ if (key && bools[attribute]) value = !!value;
+ (key) ? this[key] = value : this.setAttribute(attribute, '' + value);
+ return this;
+ setProperties: function(attributes){
+ for (var attribute in attributes) this.setProperty(attribute, attributes[attribute]);
+ return this;
+ getProperty: function(attribute){
+ var value = (key) ? this[key] : this.getAttribute(attribute, 2);
+ return (bools[attribute]) ? !!value : (key) ? value : value || null;
+ getProperties: function(){
+ var args = $A(arguments);
+ return args.map(this.getProperty, this).associate(args);
+ removeProperty: function(attribute){
+ (key) ? this[key] = (key && bools[attribute]) ? false : '' : this.removeAttribute(attribute);
+ return this;
+ removeProperties: function(){
+ Array.each(arguments, this.removeProperty, this);
+ return this;
+ hasClass: function(className){
+ return this.className.contains(className, ' ');
+ addClass: function(className){
+ if (!this.hasClass(className)) this.className = (this.className + ' ' + className).clean();
+ return this;
+ removeClass: function(className){
+ this.className = this.className.replace(new RegExp('(^|\\s)' + className + '(?:\\s|$)'), '$1');
+ return this;
+ toggleClass: function(className){
+ return this.hasClass(className) ? this.removeClass(className) : this.addClass(className);
+ adopt: function(){
+ Array.flatten(arguments).each(function(element){
+ element = document.id(element, true);
+ if (element) this.appendChild(element);
+ }, this);
+ return this;
+ appendText: function(text, where){
+ return this.grab(this.getDocument().newTextNode(text), where);
+ grab: function(el, where){
+ inserters[where || 'bottom'](document.id(el, true), this);
+ return this;
+ inject: function(el, where){
+ inserters[where || 'bottom'](this, document.id(el, true));
+ return this;
+ replaces: function(el){
+ el = document.id(el, true);
+ el.parentNode.replaceChild(this, el);
+ return this;
+ wraps: function(el, where){
+ return this.replaces(el).grab(el, where);
+ getPrevious: function(match, nocash){
+ return walk(this, 'previousSibling', null, match, false, nocash);
+ getAllPrevious: function(match, nocash){
+ return walk(this, 'previousSibling', null, match, true, nocash);
+ getNext: function(match, nocash){
+ return walk(this, 'nextSibling', null, match, false, nocash);
+ getAllNext: function(match, nocash){
+ return walk(this, 'nextSibling', null, match, true, nocash);
+ getFirst: function(match, nocash){
+ return walk(this, 'nextSibling', 'firstChild', match, false, nocash);
+ getLast: function(match, nocash){
+ return walk(this, 'previousSibling', 'lastChild', match, false, nocash);
+ getParent: function(match, nocash){
+ return walk(this, 'parentNode', null, match, false, nocash);
+ getParents: function(match, nocash){
+ return walk(this, 'parentNode', null, match, true, nocash);
+ getSiblings: function(match, nocash){
+ return this.getParent().getChildren(match, nocash).erase(this);
+ getChildren: function(match, nocash){
+ return walk(this, 'nextSibling', 'firstChild', match, true, nocash);
+ return this.ownerDocument.window;
+ return this.ownerDocument;
+ getElementById: function(id, nocash){
+ var el = this.ownerDocument.getElementById(id);
+ if (!el) return null;
+ for (var parent = el.parentNode; parent != this; parent = parent.parentNode){
+ if (!parent) return null;
+ return document.id(el, nocash);
+ getSelected: function(){
+ return new Elements($A(this.options).filter(function(option){
+ return option.selected;
+ getComputedStyle: function(property){
+ if (this.currentStyle) return this.currentStyle[property.camelCase()];
+ var computed = this.getDocument().defaultView.getComputedStyle(this, null);
+ return (computed) ? computed.getPropertyValue([property.hyphenate()]) : null;
+ toQueryString: function(){
+ this.getElements('input, select, textarea', true).each(function(el){
+ if (!el.name || el.disabled || el.type == 'submit' || el.type == 'reset' || el.type == 'file') return;
+ var value = (el.tagName.toLowerCase() == 'select') ? Element.getSelected(el).map(function(opt){
+ return opt.value;
+ }) : ((el.type == 'radio' || el.type == 'checkbox') && !el.checked) ? null : el.value;
+ $splat(value).each(function(val){
+ if (typeof val != 'undefined') queryString.push(el.name + '=' + encodeURIComponent(val));
+ clone: function(contents, keepid){
+ contents = contents !== false;
+ var clone = this.cloneNode(contents);
+ var clean = function(node, element){
+ if (!keepid) node.removeAttribute('id');
+ node.clearAttributes();
+ node.mergeAttributes(element);
+ node.removeAttribute('uid');
+ if (node.options){
+ var no = node.options, eo = element.options;
+ for (var j = no.length; j--;) no[j].selected = eo[j].selected;
+ var prop = props[element.tagName.toLowerCase()];
+ if (prop && element[prop]) node[prop] = element[prop];
+ if (contents){
+ var ce = clone.getElementsByTagName('*'), te = this.getElementsByTagName('*');
+ for (var i = ce.length; i--;) clean(ce[i], te[i]);
+ clean(clone, this);
+ return document.id(clone);
+ destroy: function(){
+ Element.empty(this);
+ Element.dispose(this);
+ clean(this, true);
+ return null;
+ $A(this.childNodes).each(function(node){
+ Element.destroy(node);
+ return this;
+ dispose: function(){
+ return (this.parentNode) ? this.parentNode.removeChild(this) : this;
+ hasChild: function(el){
+ if (!el) return false;
+ if (Browser.Engine.webkit && Browser.Engine.version < 420) return $A(this.getElementsByTagName(el.tagName)).contains(el);
+ return (this.contains) ? (this != el && this.contains(el)) : !!(this.compareDocumentPosition(el) & 16);
+ match: function(tag){
+ return (!tag || (tag == this) || (Element.get(this, 'tag') == tag));
+Native.implement([Element, Window, Document], {
+ addListener: function(type, fn){
+ if (type == 'unload'){
+ var old = fn, self = this;
+ fn = function(){
+ self.removeListener('unload', fn);
+ old();
+ } else {
+ collected[this.uid] = this;
+ if (this.addEventListener) this.addEventListener(type, fn, false);
+ else this.attachEvent('on' + type, fn);
+ return this;
+ removeListener: function(type, fn){
+ if (this.removeEventListener) this.removeEventListener(type, fn, false);
+ else this.detachEvent('on' + type, fn);
+ return this;
+ retrieve: function(property, dflt){
+ var storage = get(this.uid), prop = storage[property];
+ if (dflt != undefined && prop == undefined) prop = storage[property] = dflt;
+ return $pick(prop);
+ store: function(property, value){
+ var storage = get(this.uid);
+ storage[property] = value;
+ return this;
+ eliminate: function(property){
+ delete storage[property];
+ return this;
+window.addListener('unload', purge);
+Element.Properties = new Hash;
+Element.Properties.style = {
+ set: function(style){
+ this.style.cssText = style;
+ get: function(){
+ return this.style.cssText;
+ erase: function(){
+ this.style.cssText = '';
+Element.Properties.tag = {
+ get: function(){
+ return this.tagName.toLowerCase();
+Element.Properties.html = (function(){
+ var wrapper = document.createElement('div');
+ var translations = {
+ table: [1, '<table>', '</table>'],
+ select: [1, '<select>', '</select>'],
+ tbody: [2, '<table><tbody>', '</tbody></table>'],
+ tr: [3, '<table><tbody><tr>', '</tr></tbody></table>']
+ translations.thead = translations.tfoot = translations.tbody;
+ var html = {
+ set: function(){
+ var html = Array.flatten(arguments).join('');
+ var wrap = Browser.Engine.trident && translations[this.get('tag')];
+ if (wrap){
+ var first = wrapper;
+ first.innerHTML = wrap[1] + html + wrap[2];
+ for (var i = wrap[0]; i--;) first = first.firstChild;
+ this.empty().adopt(first.childNodes);
+ } else {
+ this.innerHTML = html;
+ html.erase = html.set;
+ return html;
+if (Browser.Engine.webkit && Browser.Engine.version < 420) Element.Properties.text = {
+ get: function(){
+ if (this.innerText) return this.innerText;
+ var temp = this.ownerDocument.newElement('div', {html: this.innerHTML}).inject(this.ownerDocument.body);
+ var text = temp.innerText;
+ temp.destroy();
+ return text;
+script: Element.Event.js
+description: Contains Element methods for dealing with events. This file also includes mouseenter and mouseleave custom Element Events.
+requires:
+- /Element
+- /Event
+provides: [Element.Event]
+Element.Properties.events = {set: function(events){
+ this.addEvents(events);
+ addEvent: function(type, fn){
+ var events = this.retrieve('events', {});
+ events[type] = events[type] || {'keys': [], 'values': []};
+ if (events[type].keys.contains(fn)) return this;
+ events[type].keys.push(fn);
+ var realType = type, custom = Element.Events.get(type), condition = fn, self = this;
+ if (custom){
+ if (custom.onAdd) custom.onAdd.call(this, fn);
+ if (custom.condition){
+ condition = function(event){
+ if (custom.condition.call(this, event)) return fn.call(this, event);
+ return true;
+ realType = custom.base || realType;
+ var defn = function(){
+ return fn.call(self);
+ var nativeEvent = Element.NativeEvents[realType];
+ if (nativeEvent){
+ if (nativeEvent == 2){
+ defn = function(event){
+ event = new Event(event, self.getWindow());
+ if (condition.call(self, event) === false) event.stop();
+ this.addListener(realType, defn);
+ events[type].values.push(defn);
+ return this;
+ var events = this.retrieve('events');
+ if (!events || !events[type]) return this;
+ var pos = events[type].keys.indexOf(fn);
+ if (pos == -1) return this;
+ events[type].keys.splice(pos, 1);
+ var value = events[type].values.splice(pos, 1)[0];
+ var custom = Element.Events.get(type);
+ if (custom){
+ if (custom.onRemove) custom.onRemove.call(this, fn);
+ type = custom.base || type;
+ return (Element.NativeEvents[type]) ? this.removeListener(type, value) : this;
+ for (var event in events) this.addEvent(event, events[event]);
+ return this;
+ var type;
+ return this;
+ var attached = this.retrieve('events');
+ if (!attached) return this;
+ if (!events){
+ for (type in attached) this.removeEvents(type);
+ this.eliminate('events');
+ } else if (attached[events]){
+ while (attached[events].keys[0]) this.removeEvent(events, attached[events].keys[0]);
+ attached[events] = null;
+ return this;
+ events[type].keys.each(function(fn){
+ }, this);
+ return this;
+ cloneEvents: function(from, type){
+ from = document.id(from);
+ var fevents = from.retrieve('events');
+ if (!fevents) return this;
+ if (!type){
+ for (var evType in fevents) this.cloneEvents(from, evType);
+ } else if (fevents[type]){
+ fevents[type].keys.each(function(fn){
+ this.addEvent(type, fn);
+ }, this);
+ return this;
+Element.NativeEvents = {
+ click: 2, dblclick: 2, mouseup: 2, mousedown: 2, contextmenu: 2, //mouse buttons
+ mousewheel: 2, DOMMouseScroll: 2, //mouse wheel
+ mouseover: 2, mouseout: 2, mousemove: 2, selectstart: 2, selectend: 2, //mouse movement
+ keydown: 2, keypress: 2, keyup: 2, //keyboard
+ focus: 2, blur: 2, change: 2, reset: 2, select: 2, submit: 2, //form elements
+ load: 1, unload: 1, beforeunload: 2, resize: 1, move: 1, DOMContentLoaded: 1, readystatechange: 1, //window
+ error: 1, abort: 1, scroll: 1 //misc
+(function(){
+var $check = function(event){
+ var related = event.relatedTarget;
+ if (related == undefined) return true;
+ if (related === false) return false;
+ return ($type(this) != 'document' && related != this && related.prefix != 'xul' && !this.hasChild(related));
+Element.Events = new Hash({
+ mouseenter: {
+ base: 'mouseover',
+ condition: $check
+ mouseleave: {
+ base: 'mouseout',
+ condition: $check
+ mousewheel: {
+ base: (Browser.Engine.gecko) ? 'DOMMouseScroll' : 'mousewheel'
+script: Element.Style.js
+description: Contains methods for interacting with the styles of Elements in a fashionable way.
+requires:
+- /Element
+provides: [Element.Style]
+Element.Properties.styles = {set: function(styles){
+ this.setStyles(styles);
+Element.Properties.opacity = {
+ set: function(opacity, novisibility){
+ if (!novisibility){
+ if (opacity == 0){
+ if (this.style.visibility != 'hidden') this.style.visibility = 'hidden';
+ } else {
+ if (this.style.visibility != 'visible') this.style.visibility = 'visible';
+ if (!this.currentStyle || !this.currentStyle.hasLayout) this.style.zoom = 1;
+ if (Browser.Engine.trident) this.style.filter = (opacity == 1) ? '' : 'alpha(opacity=' + opacity * 100 + ')';
+ this.style.opacity = opacity;
+ this.store('opacity', opacity);
+ get: function(){
+ return this.retrieve('opacity', 1);
+ setOpacity: function(value){
+ return this.set('opacity', value, true);
+ getOpacity: function(){
+ return this.get('opacity');
+ setStyle: function(property, value){
+ switch (property){
+ case 'opacity': return this.set('opacity', parseFloat(value));
+ case 'float': property = (Browser.Engine.trident) ? 'styleFloat' : 'cssFloat';
+ property = property.camelCase();
+ if ($type(value) != 'string'){
+ var map = (Element.Styles.get(property) || '@').split(' ');
+ value = $splat(value).map(function(val, i){
+ if (!map[i]) return '';
+ return ($type(val) == 'number') ? map[i].replace('@', Math.round(val)) : val;
+ }).join(' ');
+ } else if (value == String(Number(value))){
+ value = Math.round(value);
+ this.style[property] = value;
+ return this;
+ getStyle: function(property){
+ case 'opacity': return this.get('opacity');
+ var result = this.style[property];
+ if (!$chk(result)){
+ result = [];
+ for (var style in Element.ShortStyles){
+ if (property != style) continue;
+ for (var s in Element.ShortStyles[style]) result.push(this.getStyle(s));
+ return result.join(' ');
+ result = this.getComputedStyle(property);
+ if (result){
+ result = String(result);
+ var color = result.match(/rgba?\([\d\s,]+\)/);
+ if (color) result = result.replace(color[0], color[0].rgbToHex());
+ if (Browser.Engine.presto || (Browser.Engine.trident && !$chk(parseInt(result, 10)))){
+ if (property.test(/^(height|width)$/)){
+ var values = (property == 'width') ? ['left', 'right'] : ['top', 'bottom'], size = 0;
+ values.each(function(value){
+ size += this.getStyle('border-' + value + '-width').toInt() + this.getStyle('padding-' + value).toInt();
+ }, this);
+ return this['offset' + property.capitalize()] - size + 'px';
+ if ((Browser.Engine.presto) && String(result).test('px')) return result;
+ if (property.test(/(border(.+)Width|margin|padding)/)) return '0px';
+ return result;
+ setStyles: function(styles){
+ for (var style in styles) this.setStyle(style, styles[style]);
+ return this;
+ getStyles: function(){
+ var result = {};
+ Array.flatten(arguments).each(function(key){
+ result[key] = this.getStyle(key);
+ }, this);
+ return result;
+Element.Styles = new Hash({
+ left: '@px', top: '@px', bottom: '@px', right: '@px',
+ width: '@px', height: '@px', maxWidth: '@px', maxHeight: '@px', minWidth: '@px', minHeight: '@px',
+ backgroundColor: 'rgb(@, @, @)', backgroundPosition: '@px @px', color: 'rgb(@, @, @)',
+ fontSize: '@px', letterSpacing: '@px', lineHeight: '@px', clip: 'rect(@px @px @px @px)',
+ margin: '@px @px @px @px', padding: '@px @px @px @px', border: '@px @ rgb(@, @, @) @px @ rgb(@, @, @) @px @ rgb(@, @, @)',
+ borderWidth: '@px @px @px @px', borderStyle: '@ @ @ @', borderColor: 'rgb(@, @, @) rgb(@, @, @) rgb(@, @, @) rgb(@, @, @)',
+ zIndex: '@', 'zoom': '@', fontWeight: '@', textIndent: '@px', opacity: '@'
+Element.ShortStyles = {margin: {}, padding: {}, border: {}, borderWidth: {}, borderStyle: {}, borderColor: {}};
+['Top', 'Right', 'Bottom', 'Left'].each(function(direction){
+ var Short = Element.ShortStyles;
+ var All = Element.Styles;
+ ['margin', 'padding'].each(function(style){
+ var sd = style + direction;
+ Short[style][sd] = All[sd] = '@px';
+ var bd = 'border' + direction;
+ Short.border[bd] = All[bd] = '@px @ rgb(@, @, @)';
+ var bdw = bd + 'Width', bds = bd + 'Style', bdc = bd + 'Color';
+ Short[bd] = {};
+ Short.borderWidth[bdw] = Short[bd][bdw] = All[bdw] = '@px';
+ Short.borderStyle[bds] = Short[bd][bds] = All[bds] = '@';
+ Short.borderColor[bdc] = Short[bd][bdc] = All[bdc] = 'rgb(@, @, @)';
+script: Element.Dimensions.js
+description: Contains methods to work with size, scroll, or positioning of Elements and the window object.
+credits:
+- Element positioning based on the [qooxdoo](http://qooxdoo.org/) code and smart browser fixes, [LGPL License](http://www.gnu.org/licenses/lgpl.html).
+- Viewport dimensions based on [YUI](http://developer.yahoo.com/yui/) code, [BSD License](http://developer.yahoo.com/yui/license.html).
+requires:
+- /Element
+provides: [Element.Dimensions]
+(function(){
+ scrollTo: function(x, y){
+ if (isBody(this)){
+ this.getWindow().scrollTo(x, y);
+ } else {
+ this.scrollLeft = x;
+ this.scrollTop = y;
+ return this;
+ getSize: function(){
+ if (isBody(this)) return this.getWindow().getSize();
+ return {x: this.offsetWidth, y: this.offsetHeight};
+ getScrollSize: function(){
+ if (isBody(this)) return this.getWindow().getScrollSize();
+ return {x: this.scrollWidth, y: this.scrollHeight};
+ getScroll: function(){
+ if (isBody(this)) return this.getWindow().getScroll();
+ return {x: this.scrollLeft, y: this.scrollTop};
+ getScrolls: function(){
+ var element = this, position = {x: 0, y: 0};
+ while (element && !isBody(element)){
+ position.x += element.scrollLeft;
+ position.y += element.scrollTop;
+ element = element.parentNode;
+ return position;
+ getOffsetParent: function(){
+ var element = this;
+ if (isBody(element)) return null;
+ if (!Browser.Engine.trident) return element.offsetParent;
+ while ((element = element.parentNode) && !isBody(element)){
+ if (styleString(element, 'position') != 'static') return element;
+ return null;
+ getOffsets: function(){
+ if (this.getBoundingClientRect){
+ var bound = this.getBoundingClientRect(),
+ html = document.id(this.getDocument().documentElement),
+ htmlScroll = html.getScroll(),
+ elemScrolls = this.getScrolls(),
+ elemScroll = this.getScroll(),
+ isFixed = (styleString(this, 'position') == 'fixed');
+ return {
+ x: bound.left.toInt() + elemScrolls.x - elemScroll.x + ((isFixed) ? 0 : htmlScroll.x) - html.clientLeft,
+ y: bound.top.toInt() + elemScrolls.y - elemScroll.y + ((isFixed) ? 0 : htmlScroll.y) - html.clientTop
+ if (isBody(this)) return position;
+ position.x += element.offsetLeft;
+ position.y += element.offsetTop;
+ if (Browser.Engine.gecko){
+ if (!borderBox(element)){
+ position.x += leftBorder(element);
+ position.y += topBorder(element);
+ var parent = element.parentNode;
+ if (parent && styleString(parent, 'overflow') != 'visible'){
+ position.x += leftBorder(parent);
+ position.y += topBorder(parent);
+ } else if (element != this && Browser.Engine.webkit){
+ element = element.offsetParent;
+ if (Browser.Engine.gecko && !borderBox(this)){
+ position.x -= leftBorder(this);
+ position.y -= topBorder(this);
+ return position;
+ getPosition: function(relative){
+ if (isBody(this)) return {x: 0, y: 0};
+ var offset = this.getOffsets(),
+ scroll = this.getScrolls();
+ var position = {
+ x: offset.x - scroll.x,
+ y: offset.y - scroll.y
+ var relativePosition = (relative && (relative = document.id(relative))) ? relative.getPosition() : {x: 0, y: 0};
+ return {x: position.x - relativePosition.x, y: position.y - relativePosition.y};
+ getCoordinates: function(element){
+ if (isBody(this)) return this.getWindow().getCoordinates();
+ var position = this.getPosition(element),
+ size = this.getSize();
+ var obj = {
+ left: position.x,
+ top: position.y,
+ width: size.x,
+ height: size.y
+ obj.right = obj.left + obj.width;
+ obj.bottom = obj.top + obj.height;
+ return obj;
+ computePosition: function(obj){
+ return {
+ left: obj.x - styleNumber(this, 'margin-left'),
+ top: obj.y - styleNumber(this, 'margin-top')
+ setPosition: function(obj){
+ return this.setStyles(this.computePosition(obj));
+Native.implement([Document, Window], {
+ if (Browser.Engine.presto || Browser.Engine.webkit){
+ var win = this.getWindow();
+ return {x: win.innerWidth, y: win.innerHeight};
+ var doc = getCompatElement(this);
+ return {x: doc.clientWidth, y: doc.clientHeight};
+ var win = this.getWindow(), doc = getCompatElement(this);
+ return {x: win.pageXOffset || doc.scrollLeft, y: win.pageYOffset || doc.scrollTop};
+ var doc = getCompatElement(this), min = this.getSize();
+ return {x: Math.max(doc.scrollWidth, min.x), y: Math.max(doc.scrollHeight, min.y)};
+ getPosition: function(){
+ return {x: 0, y: 0};
+ getCoordinates: function(){
+ var size = this.getSize();
+ return {top: 0, left: 0, bottom: size.y, right: size.x, height: size.y, width: size.x};
+// private methods
+var styleString = Element.getComputedStyle;
+function styleNumber(element, style){
+ return styleString(element, style).toInt() || 0;
+function borderBox(element){
+ return styleString(element, '-moz-box-sizing') == 'border-box';
+function topBorder(element){
+ return styleNumber(element, 'border-top-width');
+function leftBorder(element){
+ return styleNumber(element, 'border-left-width');
+function isBody(element){
+ return (/^(?:body|html)$/i).test(element.tagName);
+function getCompatElement(element){
+ var doc = element.getDocument();
+ return (!doc.compatMode || doc.compatMode == 'CSS1Compat') ? doc.html : doc.body;
+//aliases
+Element.alias('setPosition', 'position'); //compatability
+Native.implement([Window, Document, Element], {
+ getHeight: function(){
+ return this.getSize().y;
+ getWidth: function(){
+ return this.getSize().x;
+ getScrollTop: function(){
+ return this.getScroll().y;
+ getScrollLeft: function(){
+ return this.getScroll().x;
+ getScrollHeight: function(){
+ return this.getScrollSize().y;
+ getScrollWidth: function(){
+ return this.getScrollSize().x;
+ getTop: function(){
+ return this.getPosition().y;
+ getLeft: function(){
+ return this.getPosition().x;
+script: Selectors.js
+description: Adds advanced CSS-style querying capabilities for targeting HTML Elements. Includes pseudo selectors.
+requires:
+- /Element
+provides: [Selectors]
+Native.implement([Document, Element], {
+ getElements: function(expression, nocash){
+ expression = expression.split(',');
+ var items, local = {};
+ for (var i = 0, l = expression.length; i < l; i++){
+ var selector = expression[i], elements = Selectors.Utils.search(this, selector, local);
+ if (i != 0 && elements.item) elements = $A(elements);
+ items = (i == 0) ? elements : (items.item) ? $A(items).concat(elements) : items.concat(elements);
+ return new Elements(items, {ddup: (expression.length > 1), cash: !nocash});
+ match: function(selector){
+ if (!selector || (selector == this)) return true;
+ var tagid = Selectors.Utils.parseTagAndID(selector);
+ var tag = tagid[0], id = tagid[1];
+ if (!Selectors.Filters.byID(this, id) || !Selectors.Filters.byTag(this, tag)) return false;
+ var parsed = Selectors.Utils.parseSelector(selector);
+ return (parsed) ? Selectors.Utils.filter(this, parsed, {}) : true;
+var Selectors = {Cache: {nth: {}, parsed: {}}};
+Selectors.RegExps = {
+ id: (/#([\w-]+)/),
+ tag: (/^(\w+|\*)/),
+ quick: (/^(\w+|\*)$/),
+ splitter: (/\s*([+>~\s])\s*([a-zA-Z#.*:\[])/g),
+ combined: (/\.([\w-]+)|\[(\w+)(?:([!*^$~|]?=)(["']?)([^\4]*?)\4)?\]|:([\w-]+)(?:\(["']?(.*?)?["']?\)|$)/g)
+Selectors.Utils = {
+ chk: function(item, uniques){
+ if (!uniques) return true;
+ var uid = $uid(item);
+ if (!uniques[uid]) return uniques[uid] = true;
+ return false;
+ parseNthArgument: function(argument){
+ if (Selectors.Cache.nth[argument]) return Selectors.Cache.nth[argument];
+ var parsed = argument.match(/^([+-]?\d*)?([a-z]+)?([+-]?\d*)?$/);
+ if (!parsed) return false;
+ var inta = parseInt(parsed[1], 10);
+ var a = (inta || inta === 0) ? inta : 1;
+ var special = parsed[2] || false;
+ var b = parseInt(parsed[3], 10) || 0;
+ if (a != 0){
+ b--;
+ while (b < 1) b += a;
+ while (b >= a) b -= a;
+ } else {
+ a = b;
+ special = 'index';
+ switch (special){
+ case 'n': parsed = {a: a, b: b, special: 'n'}; break;
+ case 'odd': parsed = {a: 2, b: 0, special: 'n'}; break;
+ case 'even': parsed = {a: 2, b: 1, special: 'n'}; break;
+ case 'first': parsed = {a: 0, special: 'index'}; break;
+ case 'last': parsed = {special: 'last-child'}; break;
+ case 'only': parsed = {special: 'only-child'}; break;
+ default: parsed = {a: (a - 1), special: 'index'};
+ return Selectors.Cache.nth[argument] = parsed;
+ parseSelector: function(selector){
+ if (Selectors.Cache.parsed[selector]) return Selectors.Cache.parsed[selector];
+ var m, parsed = {classes: [], pseudos: [], attributes: []};
+ while ((m = Selectors.RegExps.combined.exec(selector))){
+ var cn = m[1], an = m[2], ao = m[3], av = m[5], pn = m[6], pa = m[7];
+ if (cn){
+ parsed.classes.push(cn);
+ } else if (pn){
+ var parser = Selectors.Pseudo.get(pn);
+ if (parser) parsed.pseudos.push({parser: parser, argument: pa});
+ else parsed.attributes.push({name: pn, operator: '=', value: pa});
+ } else if (an){
+ parsed.attributes.push({name: an, operator: ao, value: av});
+ if (!parsed.classes.length) delete parsed.classes;
+ if (!parsed.attributes.length) delete parsed.attributes;
+ if (!parsed.pseudos.length) delete parsed.pseudos;
+ if (!parsed.classes && !parsed.attributes && !parsed.pseudos) parsed = null;
+ return Selectors.Cache.parsed[selector] = parsed;
+ parseTagAndID: function(selector){
+ var tag = selector.match(Selectors.RegExps.tag);
+ var id = selector.match(Selectors.RegExps.id);
+ return [(tag) ? tag[1] : '*', (id) ? id[1] : false];
+ filter: function(item, parsed, local){
+ var i;
+ if (parsed.classes){
+ for (i = parsed.classes.length; i--; i){
+ var cn = parsed.classes[i];
+ if (!Selectors.Filters.byClass(item, cn)) return false;
+ if (parsed.attributes){
+ for (i = parsed.attributes.length; i--; i){
+ var att = parsed.attributes[i];
+ if (!Selectors.Filters.byAttribute(item, att.name, att.operator, att.value)) return false;
+ if (parsed.pseudos){
+ for (i = parsed.pseudos.length; i--; i){
+ var psd = parsed.pseudos[i];
+ if (!Selectors.Filters.byPseudo(item, psd.parser, psd.argument, local)) return false;
+ return true;
+ getByTagAndID: function(ctx, tag, id){
+ if (id){
+ var item = (ctx.getElementById) ? ctx.getElementById(id, true) : Element.getElementById(ctx, id, true);
+ return (item && Selectors.Filters.byTag(item, tag)) ? [item] : [];
+ } else {
+ return ctx.getElementsByTagName(tag);
+ search: function(self, expression, local){
+ var splitters = [];
+ var selectors = expression.trim().replace(Selectors.RegExps.splitter, function(m0, m1, m2){
+ splitters.push(m1);
+ return ':)' + m2;
+ }).split(':)');
+ var items, filtered, item;
+ for (var i = 0, l = selectors.length; i < l; i++){
+ var selector = selectors[i];
+ if (i == 0 && Selectors.RegExps.quick.test(selector)){
+ items = self.getElementsByTagName(selector);
+ continue;
+ var splitter = splitters[i - 1];
+ if (i == 0){
+ items = Selectors.Utils.getByTagAndID(self, tag, id);
+ } else {
+ var uniques = {}, found = [];
+ for (var j = 0, k = items.length; j < k; j++) found = Selectors.Getters[splitter](found, items[j], tag, id, uniques);
+ items = found;
+ if (parsed){
+ filtered = [];
+ for (var m = 0, n = items.length; m < n; m++){
+ item = items[m];
+ if (Selectors.Utils.filter(item, parsed, local)) filtered.push(item);
+ items = filtered;
+ return items;
+Selectors.Getters = {
+ ' ': function(found, self, tag, id, uniques){
+ var items = Selectors.Utils.getByTagAndID(self, tag, id);
+ for (var i = 0, l = items.length; i < l; i++){
+ var item = items[i];
+ if (Selectors.Utils.chk(item, uniques)) found.push(item);
+ return found;
+ '>': function(found, self, tag, id, uniques){
+ var children = Selectors.Utils.getByTagAndID(self, tag, id);
+ for (var i = 0, l = children.length; i < l; i++){
+ var child = children[i];
+ if (child.parentNode == self && Selectors.Utils.chk(child, uniques)) found.push(child);
+ return found;
+ '+': function(found, self, tag, id, uniques){
+ while ((self = self.nextSibling)){
+ if (self.nodeType == 1){
+ if (Selectors.Utils.chk(self, uniques) && Selectors.Filters.byTag(self, tag) && Selectors.Filters.byID(self, id)) found.push(self);
+ break;
+ return found;
+ '~': function(found, self, tag, id, uniques){
+ if (!Selectors.Utils.chk(self, uniques)) break;
+ if (Selectors.Filters.byTag(self, tag) && Selectors.Filters.byID(self, id)) found.push(self);
+ return found;
+Selectors.Filters = {
+ byTag: function(self, tag){
+ return (tag == '*' || (self.tagName && self.tagName.toLowerCase() == tag));
+ byID: function(self, id){
+ return (!id || (self.id && self.id == id));
+ byClass: function(self, klass){
+ return (self.className && self.className.contains && self.className.contains(klass, ' '));
+ byPseudo: function(self, parser, argument, local){
+ return parser.call(self, argument, local);
+ byAttribute: function(self, name, operator, value){
+ var result = Element.prototype.getProperty.call(self, name);
+ if (!result) return (operator == '!=');
+ if (!operator || value == undefined) return true;
+ switch (operator){
+ case '=': return (result == value);
+ case '*=': return (result.contains(value));
+ case '^=': return (result.substr(0, value.length) == value);
+ case '$=': return (result.substr(result.length - value.length) == value);
+ case '!=': return (result != value);
+ case '~=': return result.contains(value, ' ');
+ case '|=': return result.contains(value, '-');
+ return false;
+Selectors.Pseudo = new Hash({
+ // w3c pseudo selectors
+ checked: function(){
+ return this.checked;
+ return !(this.innerText || this.textContent || '').length;
+ not: function(selector){
+ return !Element.match(this, selector);
+ contains: function(text){
+ return (this.innerText || this.textContent || '').contains(text);
+ 'first-child': function(){
+ return Selectors.Pseudo.index.call(this, 0);
+ 'last-child': function(){
+ while ((element = element.nextSibling)){
+ if (element.nodeType == 1) return false;
+ return true;
+ 'only-child': function(){
+ var prev = this;
+ while ((prev = prev.previousSibling)){
+ if (prev.nodeType == 1) return false;
+ var next = this;
+ while ((next = next.nextSibling)){
+ if (next.nodeType == 1) return false;
+ return true;
+ 'nth-child': function(argument, local){
+ argument = (argument == undefined) ? 'n' : argument;
+ var parsed = Selectors.Utils.parseNthArgument(argument);
+ if (parsed.special != 'n') return Selectors.Pseudo[parsed.special].call(this, parsed.a, local);
+ var count = 0;
+ local.positions = local.positions || {};
+ var uid = $uid(this);
+ if (!local.positions[uid]){
+ var self = this;
+ while ((self = self.previousSibling)){
+ if (self.nodeType != 1) continue;
+ count ++;
+ var position = local.positions[$uid(self)];
+ if (position != undefined){
+ count = position + count;
+ break;
+ local.positions[uid] = count;
+ return (local.positions[uid] % parsed.a == parsed.b);
+ // custom pseudo selectors
+ index: function(index){
+ var element = this, count = 0;
+ while ((element = element.previousSibling)){
+ if (element.nodeType == 1 && ++count > index) return false;
+ return (count == index);
+ even: function(argument, local){
+ return Selectors.Pseudo['nth-child'].call(this, '2n+1', local);
+ odd: function(argument, local){
+ return Selectors.Pseudo['nth-child'].call(this, '2n', local);
+ selected: function(){
+ return this.selected;
+ enabled: function(){
+ return (this.disabled === false);
+script: DomReady.js
+description: Contains the custom event domready.
+license: MIT-style license.
+requires:
+- /Element.Event
+provides: [DomReady]
+Element.Events.domready = {
+ onAdd: function(fn){
+ if (Browser.loaded) fn.call(this);
+(function(){
+ var domready = function(){
+ if (Browser.loaded) return;
+ Browser.loaded = true;
+ window.fireEvent('domready');
+ document.fireEvent('domready');
+ window.addEvent('load', domready);
+ var temp = document.createElement('div');
+ (function(){
+ ($try(function(){
+ temp.doScroll(); // Technique by Diego Perini
+ return document.id(temp).inject(document.body).set('html', 'temp').dispose();
+ })) ? domready() : arguments.callee.delay(50);
+ } else if (Browser.Engine.webkit && Browser.Engine.version < 525){
+ (function(){
+ (['loaded', 'complete'].contains(document.readyState)) ? domready() : arguments.callee.delay(50);
+ } else {
+ document.addEvent('DOMContentLoaded', domready);
+script: JSON.js
+description: JSON encoder and decoder.
+See Also: <http://www.json.org/>
+requires:
+- /Array
+- /String
+- /Number
+- /Function
+- /Hash
+provides: [JSON]
+var JSON = new Hash(this.JSON && {
+ stringify: JSON.stringify,
+ parse: JSON.parse
+}).extend({
+ $specialChars: {'\b': '\\b', '\t': '\\t', '\n': '\\n', '\f': '\\f', '\r': '\\r', '"' : '\\"', '\\': '\\\\'},
+ $replaceChars: function(chr){
+ return JSON.$specialChars[chr] || '\\u00' + Math.floor(chr.charCodeAt() / 16).toString(16) + (chr.charCodeAt() % 16).toString(16);
+ encode: function(obj){
+ switch ($type(obj)){
+ case 'string':
+ return '"' + obj.replace(/[\x00-\x1f\\"]/g, JSON.$replaceChars) + '"';
+ case 'array':
+ return '[' + String(obj.map(JSON.encode).clean()) + ']';
+ case 'object': case 'hash':
+ var string = [];
+ Hash.each(obj, function(value, key){
+ var json = JSON.encode(value);
+ if (json) string.push(JSON.encode(key) + ':' + json);
+ return '{' + string + '}';
+ case 'number': case 'boolean': return String(obj);
+ case false: return 'null';
+ return null;
+ decode: function(string, secure){
+ if ($type(string) != 'string' || !string.length) return null;
+ if (secure && !(/^[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t]*$/).test(string.replace(/\\./g, '@').replace(/"[^"\\\n\r]*"/g, ''))) return null;
+ return eval('(' + string + ')');
+Native.implement([Hash, Array, String, Number], {
+ toJSON: function(){
+ return JSON.encode(this);
+script: Cookie.js
+description: Class for creating, reading, and deleting browser Cookies.
+credits:
+- Based on the functions by Peter-Paul Koch (http://quirksmode.org).
+requires:
+- /Options
+provides: [Cookie]
+var Cookie = new Class({
+ Implements: Options,
+ options: {
+ path: false,
+ domain: false,
+ duration: false,
+ secure: false,
+ document: document
+ initialize: function(key, options){
+ this.key = key;
+ this.setOptions(options);
+ write: function(value){
+ value = encodeURIComponent(value);
+ if (this.options.domain) value += '; domain=' + this.options.domain;
+ if (this.options.path) value += '; path=' + this.options.path;
+ if (this.options.duration){
+ var date = new Date();
+ date.setTime(date.getTime() + this.options.duration * 24 * 60 * 60 * 1000);
+ value += '; expires=' + date.toGMTString();
+ if (this.options.secure) value += '; secure';
+ this.options.document.cookie = this.key + '=' + value;
+ return this;
+ read: function(){
+ var value = this.options.document.cookie.match('(?:^|;)\\s*' + this.key.escapeRegExp() + '=([^;]*)');
+ return (value) ? decodeURIComponent(value[1]) : null;
+ new Cookie(this.key, $merge(this.options, {duration: -1})).write('');
+ return this;
+Cookie.write = function(key, value, options){
+ return new Cookie(key, options).write(value);
+Cookie.read = function(key){
+ return new Cookie(key).read();
+Cookie.dispose = function(key, options){
+ return new Cookie(key, options).dispose();
+script: Swiff.js
+description: Wrapper for embedding SWF movies. Supports External Interface Communication.
+credits:
+- Flash detection & Internet Explorer + Flash Player 9 fix inspired by SWFObject.
+requires:
+- /Options
+- /$util
+provides: [Swiff]
+var Swiff = new Class({
+ Implements: [Options],
+ options: {
+ id: null,
+ height: 1,
+ width: 1,
+ container: null,
+ properties: {},
+ params: {
+ quality: 'high',
+ allowScriptAccess: 'always',
+ wMode: 'transparent',
+ swLiveConnect: true
+ callBacks: {},
+ vars: {}
+ toElement: function(){
+ return this.object;
+ initialize: function(path, options){
+ this.instance = 'Swiff_' + $time();
+ options = this.options;
+ var id = this.id = options.id || this.instance;
+ var container = document.id(options.container);
+ Swiff.CallBacks[this.instance] = {};
+ var params = options.params, vars = options.vars, callBacks = options.callBacks;
+ var properties = $extend({height: options.height, width: options.width}, options.properties);
+ var self = this;
+ for (var callBack in callBacks){
+ Swiff.CallBacks[this.instance][callBack] = (function(option){
+ return function(){
+ return option.apply(self.object, arguments);
+ })(callBacks[callBack]);
+ vars[callBack] = 'Swiff.CallBacks.' + this.instance + '.' + callBack;
+ params.flashVars = Hash.toQueryString(vars);
+ properties.classid = 'clsid:D27CDB6E-AE6D-11cf-96B8-444553540000';
+ params.movie = path;
+ } else {
+ properties.type = 'application/x-shockwave-flash';
+ properties.data = path;
+ var build = '<object id="' + id + '"';
+ for (var property in properties) build += ' ' + property + '="' + properties[property] + '"';
+ build += '>';
+ for (var param in params){
+ if (params[param]) build += '<param name="' + param + '" value="' + params[param] + '" />';
+ build += '</object>';
+ this.object = ((container) ? container.empty() : new Element('div')).set('html', build).firstChild;
+ replaces: function(element){
+ element.parentNode.replaceChild(this.toElement(), element);
+ return this;
+ inject: function(element){
+ document.id(element, true).appendChild(this.toElement());
+ return this;
+ remote: function(){
+ return Swiff.remote.apply(Swiff, [this.toElement()].extend(arguments));
+Swiff.CallBacks = {};
+Swiff.remote = function(obj, fn){
+ var rs = obj.CallFunction('<invoke name="' + fn + '" returntype="javascript">' + __flash__argumentsToXML(arguments, 2) + '</invoke>');
+ return eval(rs);
+script: Fx.js
+description: Contains the basic animation logic to be extended by all other Fx Classes.
+requires:
+- /Chain
+- /Events
+- /Options
+provides: [Fx]
+var Fx = new Class({
+ Implements: [Chain, Events, Options],
+ options: {
+ onStart: $empty,
+ onCancel: $empty,
+ onComplete: $empty,
+ fps: 50,
+ unit: false,
+ duration: 500,
+ link: 'ignore'
+ initialize: function(options){
+ this.subject = this.subject || this;
+ this.options.duration = Fx.Durations[this.options.duration] || this.options.duration.toInt();
+ var wait = this.options.wait;
+ if (wait === false) this.options.link = 'cancel';
+ getTransition: function(){
+ return function(p){
+ return -(Math.cos(Math.PI * p) - 1) / 2;
+ step: function(){
+ var time = $time();
+ if (time < this.time + this.options.duration){
+ var delta = this.transition((time - this.time) / this.options.duration);
+ this.set(this.compute(this.from, this.to, delta));
+ } else {
+ this.set(this.compute(this.from, this.to, 1));
+ this.complete();
+ set: function(now){
+ return now;
+ compute: function(from, to, delta){
+ return Fx.compute(from, to, delta);
+ check: function(){
+ if (!this.timer) return true;
+ switch (this.options.link){
+ case 'cancel': this.cancel(); return true;
+ case 'chain': this.chain(this.caller.bind(this, arguments)); return false;
+ return false;
+ start: function(from, to){
+ if (!this.check(from, to)) return this;
+ this.from = from;
+ this.to = to;
+ this.time = 0;
+ this.transition = this.getTransition();
+ this.startTimer();
+ this.onStart();
+ return this;
+ complete: function(){
+ if (this.stopTimer()) this.onComplete();
+ return this;
+ cancel: function(){
+ if (this.stopTimer()) this.onCancel();
+ return this;
+ onStart: function(){
+ this.fireEvent('start', this.subject);
+ onComplete: function(){
+ this.fireEvent('complete', this.subject);
+ if (!this.callChain()) this.fireEvent('chainComplete', this.subject);
+ onCancel: function(){
+ this.fireEvent('cancel', this.subject).clearChain();
+ pause: function(){
+ this.stopTimer();
+ return this;
+ resume: function(){
+ return this;
+ stopTimer: function(){
+ if (!this.timer) return false;
+ this.time = $time() - this.time;
+ this.timer = $clear(this.timer);
+ return true;
+ startTimer: function(){
+ if (this.timer) return false;
+ this.timer = this.step.periodical(Math.round(1000 / this.options.fps), this);
+ return true;
+Fx.compute = function(from, to, delta){
+ return (to - from) * delta + from;
+Fx.Durations = {'short': 250, 'normal': 500, 'long': 1000};
+script: Fx.CSS.js
+description: Contains the CSS animation logic. Used by Fx.Tween, Fx.Morph, Fx.Elements.
+requires:
+- /Fx
+- /Element.Style
+provides: [Fx.CSS]
+Fx.CSS = new Class({
+ Extends: Fx,
+ //prepares the base from/to object
+ prepare: function(element, property, values){
+ values = $splat(values);
+ var values1 = values[1];
+ if (!$chk(values1)){
+ values[1] = values[0];
+ values[0] = element.getStyle(property);
+ var parsed = values.map(this.parse);
+ return {from: parsed[0], to: parsed[1]};
+ //parses a value into an array
+ parse: function(value){
+ value = $lambda(value)();
+ value = (typeof value == 'string') ? value.split(' ') : $splat(value);
+ return value.map(function(val){
+ val = String(val);
+ var found = false;
+ Fx.CSS.Parsers.each(function(parser, key){
+ if (found) return;
+ var parsed = parser.parse(val);
+ if ($chk(parsed)) found = {value: parsed, parser: parser};
+ found = found || {value: val, parser: Fx.CSS.Parsers.String};
+ return found;
+ //computes by a from and to prepared objects, using their parsers.
+ var computed = [];
+ (Math.min(from.length, to.length)).times(function(i){
+ computed.push({value: from[i].parser.compute(from[i].value, to[i].value, delta), parser: from[i].parser});
+ computed.$family = {name: 'fx:css:value'};
+ return computed;
+ //serves the value as settable
+ serve: function(value, unit){
+ if ($type(value) != 'fx:css:value') value = this.parse(value);
+ var returned = [];
+ value.each(function(bit){
+ returned = returned.concat(bit.parser.serve(bit.value, unit));
+ return returned;
+ //renders the change to an element
+ render: function(element, property, value, unit){
+ element.setStyle(property, this.serve(value, unit));
+ //searches inside the page css to find the values for a selector
+ search: function(selector){
+ if (Fx.CSS.Cache[selector]) return Fx.CSS.Cache[selector];
+ var to = {};
+ Array.each(document.styleSheets, function(sheet, j){
+ var href = sheet.href;
+ if (href && href.contains('://') && !href.contains(document.domain)) return;
+ var rules = sheet.rules || sheet.cssRules;
+ Array.each(rules, function(rule, i){
+ if (!rule.style) return;
+ var selectorText = (rule.selectorText) ? rule.selectorText.replace(/^\w+/, function(m){
+ return m.toLowerCase();
+ }) : null;
+ if (!selectorText || !selectorText.test('^' + selector + '$')) return;
+ Element.Styles.each(function(value, style){
+ if (!rule.style[style] || Element.ShortStyles[style]) return;
+ value = String(rule.style[style]);
+ to[style] = (value.test(/^rgb/)) ? value.rgbToHex() : value;
+ return Fx.CSS.Cache[selector] = to;
+Fx.CSS.Cache = {};
+Fx.CSS.Parsers = new Hash({
+ Color: {
+ if (value.match(/^#[0-9a-f]{3,6}$/i)) return value.hexToRgb(true);
+ return ((value = value.match(/(\d+),\s*(\d+),\s*(\d+)/))) ? [value[1], value[2], value[3]] : false;
+ return from.map(function(value, i){
+ return Math.round(Fx.compute(from[i], to[i], delta));
+ serve: function(value){
+ return value.map(Number);
+ Number: {
+ parse: parseFloat,
+ compute: Fx.compute,
+ return (unit) ? value + unit : value;
+ String: {
+ parse: $lambda(false),
+ compute: $arguments(1),
+ serve: $arguments(0)
+script: Fx.Tween.js
+description: Formerly Fx.Style, effect to transition any CSS property for an element.
+requires:
+- /Fx.CSS
+provides: [Fx.Tween, Element.fade, Element.highlight]
+Fx.Tween = new Class({
+ Extends: Fx.CSS,
+ initialize: function(element, options){
+ this.element = this.subject = document.id(element);
+ this.parent(options);
+ set: function(property, now){
+ if (arguments.length == 1){
+ now = property;
+ property = this.property || this.options.property;
+ this.render(this.element, property, now, this.options.unit);
+ return this;
+ start: function(property, from, to){
+ if (!this.check(property, from, to)) return this;
+ this.property = this.options.property || args.shift();
+ var parsed = this.prepare(this.element, this.property, args);
+ return this.parent(parsed.from, parsed.to);
+Element.Properties.tween = {
+ set: function(options){
+ var tween = this.retrieve('tween');
+ if (tween) tween.cancel();
+ return this.eliminate('tween').store('tween:options', $extend({link: 'cancel'}, options));
+ get: function(options){
+ if (options || !this.retrieve('tween')){
+ if (options || !this.retrieve('tween:options')) this.set('tween', options);
+ this.store('tween', new Fx.Tween(this, this.retrieve('tween:options')));
+ return this.retrieve('tween');
+ tween: function(property, from, to){
+ this.get('tween').start(arguments);
+ return this;
+ fade: function(how){
+ var fade = this.get('tween'), o = 'opacity', toggle;
+ how = $pick(how, 'toggle');
+ switch (how){
+ case 'in': fade.start(o, 1); break;
+ case 'out': fade.start(o, 0); break;
+ case 'show': fade.set(o, 1); break;
+ case 'hide': fade.set(o, 0); break;
+ case 'toggle':
+ var flag = this.retrieve('fade:flag', this.get('opacity') == 1);
+ fade.start(o, (flag) ? 0 : 1);
+ this.store('fade:flag', !flag);
+ toggle = true;
+ break;
+ default: fade.start(o, arguments);
+ if (!toggle) this.eliminate('fade:flag');
+ return this;
+ highlight: function(start, end){
+ if (!end){
+ end = this.retrieve('highlight:original', this.getStyle('background-color'));
+ end = (end == 'transparent') ? '#fff' : end;
+ var tween = this.get('tween');
+ tween.start('background-color', start || '#ffff88', end).chain(function(){
+ this.setStyle('background-color', this.retrieve('highlight:original'));
+ tween.callChain();
+ }.bind(this));
+ return this;
+script: Fx.Morph.js
+description: Formerly Fx.Styles, effect to transition any number of CSS properties for an element using an object of rules, or CSS based selector rules.
+requires:
+- /Fx.CSS
+provides: [Fx.Morph]
+Fx.Morph = new Class({
+ Extends: Fx.CSS,
+ if (typeof now == 'string') now = this.search(now);
+ for (var p in now) this.render(this.element, p, now[p], this.options.unit);
+ return this;
+ var now = {};
+ for (var p in from) now[p] = this.parent(from[p], to[p], delta);
+ return now;
+ start: function(properties){
+ if (!this.check(properties)) return this;
+ if (typeof properties == 'string') properties = this.search(properties);
+ var from = {}, to = {};
+ for (var p in properties){
+ var parsed = this.prepare(this.element, p, properties[p]);
+ from[p] = parsed.from;
+ to[p] = parsed.to;
+ return this.parent(from, to);
+Element.Properties.morph = {
+ var morph = this.retrieve('morph');
+ if (morph) morph.cancel();
+ return this.eliminate('morph').store('morph:options', $extend({link: 'cancel'}, options));
+ if (options || !this.retrieve('morph')){
+ if (options || !this.retrieve('morph:options')) this.set('morph', options);
+ this.store('morph', new Fx.Morph(this, this.retrieve('morph:options')));
+ return this.retrieve('morph');
+ morph: function(props){
+ this.get('morph').start(props);
+ return this;
+script: Fx.Transitions.js
+description: Contains a set of advanced transitions to be used with any of the Fx Classes.
+credits:
+- Easing Equations by Robert Penner, <http://www.robertpenner.com/easing/>, modified and optimized to be used with MooTools.
+requires:
+- /Fx
+provides: [Fx.Transitions]
+Fx.implement({
+ var trans = this.options.transition || Fx.Transitions.Sine.easeInOut;
+ if (typeof trans == 'string'){
+ var data = trans.split(':');
+ trans = Fx.Transitions;
+ trans = trans[data[0]] || trans[data[0].capitalize()];
+ if (data[1]) trans = trans['ease' + data[1].capitalize() + (data[2] ? data[2].capitalize() : '')];
+ return trans;
+Fx.Transition = function(transition, params){
+ params = $splat(params);
+ return $extend(transition, {
+ easeIn: function(pos){
+ return transition(pos, params);
+ easeOut: function(pos){
+ return 1 - transition(1 - pos, params);
+ easeInOut: function(pos){
+ return (pos <= 0.5) ? transition(2 * pos, params) / 2 : (2 - transition(2 * (1 - pos), params)) / 2;
+Fx.Transitions = new Hash({
+ linear: $arguments(0)
+Fx.Transitions.extend = function(transitions){
+ for (var transition in transitions) Fx.Transitions[transition] = new Fx.Transition(transitions[transition]);
+Fx.Transitions.extend({
+ Pow: function(p, x){
+ return Math.pow(p, x[0] || 6);
+ Expo: function(p){
+ return Math.pow(2, 8 * (p - 1));
+ Circ: function(p){
+ return 1 - Math.sin(Math.acos(p));
+ Sine: function(p){
+ return 1 - Math.sin((1 - p) * Math.PI / 2);
+ Back: function(p, x){
+ x = x[0] || 1.618;
+ return Math.pow(p, 2) * ((x + 1) * p - x);
+ Bounce: function(p){
+ var value;
+ for (var a = 0, b = 1; 1; a += b, b /= 2){
+ if (p >= (7 - 4 * a) / 11){
+ value = b * b - Math.pow((11 - 6 * a - 11 * p) / 4, 2);
+ break;
+ return value;
+ Elastic: function(p, x){
+ return Math.pow(2, 10 * --p) * Math.cos(20 * p * Math.PI * (x[0] || 1) / 3);
+['Quad', 'Cubic', 'Quart', 'Quint'].each(function(transition, i){
+ Fx.Transitions[transition] = new Fx.Transition(function(p){
+ return Math.pow(p, [i + 2]);
+script: Request.js
+description: Powerful all purpose Request Class. Uses XMLHTTPRequest.
+requires:
+- /Element
+- /Chain
+- /Events
+- /Options
+- /Browser
+provides: [Request]
+var Request = new Class({
+ options: {/*
+ onRequest: $empty,
+ onCancel: $empty,
+ onSuccess: $empty,
+ onFailure: $empty,
+ onException: $empty,*/
+ url: '',
+ data: '',
+ headers: {
+ 'X-Requested-With': 'XMLHttpRequest',
+ 'Accept': 'text/javascript, text/html, application/xml, text/xml, */*'
+ async: true,
+ format: false,
+ method: 'post',
+ link: 'ignore',
+ isSuccess: null,
+ emulation: true,
+ urlEncoded: true,
+ encoding: 'utf-8',
+ evalScripts: false,
+ evalResponse: false,
+ noCache: false
+ this.xhr = new Browser.Request();
+ this.options.isSuccess = this.options.isSuccess || this.isSuccess;
+ this.headers = new Hash(this.options.headers);
+ onStateChange: function(){
+ if (this.xhr.readyState != 4 || !this.running) return;
+ this.running = false;
+ this.status = 0;
+ $try(function(){
+ this.status = this.xhr.status;
+ }.bind(this));
+ this.xhr.onreadystatechange = $empty;
+ if (this.options.isSuccess.call(this, this.status)){
+ this.response = {text: this.xhr.responseText, xml: this.xhr.responseXML};
+ this.success(this.response.text, this.response.xml);
+ } else {
+ this.response = {text: null, xml: null};
+ this.failure();
+ isSuccess: function(){
+ return ((this.status >= 200) && (this.status < 300));
+ processScripts: function(text){
+ if (this.options.evalResponse || (/(ecma|java)script/).test(this.getHeader('Content-type'))) return $exec(text);
+ return text.stripScripts(this.options.evalScripts);
+ success: function(text, xml){
+ this.onSuccess(this.processScripts(text), xml);
+ onSuccess: function(){
+ this.fireEvent('complete', arguments).fireEvent('success', arguments).callChain();
+ failure: function(){
+ this.onFailure();
+ onFailure: function(){
+ this.fireEvent('complete').fireEvent('failure', this.xhr);
+ setHeader: function(name, value){
+ this.headers.set(name, value);
+ return this;
+ getHeader: function(name){
+ return $try(function(){
+ return this.xhr.getResponseHeader(name);
+ }.bind(this));
+ if (!this.running) return true;
+ return false;
+ send: function(options){
+ if (!this.check(options)) return this;
+ this.running = true;
+ var type = $type(options);
+ if (type == 'string' || type == 'element') options = {data: options};
+ var old = this.options;
+ options = $extend({data: old.data, url: old.url, method: old.method}, options);
+ var data = options.data, url = String(options.url), method = options.method.toLowerCase();
+ switch ($type(data)){
+ case 'element': data = document.id(data).toQueryString(); break;
+ case 'object': case 'hash': data = Hash.toQueryString(data);
+ if (this.options.format){
+ var format = 'format=' + this.options.format;
+ data = (data) ? format + '&' + data : format;
+ if (this.options.emulation && !['get', 'post'].contains(method)){
+ var _method = '_method=' + method;
+ data = (data) ? _method + '&' + data : _method;
+ method = 'post';
+ if (this.options.urlEncoded && method == 'post'){
+ var encoding = (this.options.encoding) ? '; charset=' + this.options.encoding : '';
+ this.headers.set('Content-type', 'application/x-www-form-urlencoded' + encoding);
+ if (this.options.noCache){
+ var noCache = 'noCache=' + new Date().getTime();
+ data = (data) ? noCache + '&' + data : noCache;
+ var trimPosition = url.lastIndexOf('/');
+ if (trimPosition > -1 && (trimPosition = url.indexOf('#')) > -1) url = url.substr(0, trimPosition);
+ if (data && method == 'get'){
+ url = url + (url.contains('?') ? '&' : '?') + data;
+ data = null;
+ this.xhr.open(method.toUpperCase(), url, this.options.async);
+ this.xhr.onreadystatechange = this.onStateChange.bind(this);
+ this.headers.each(function(value, key){
+ try {
+ this.xhr.setRequestHeader(key, value);
+ } catch (e){
+ this.fireEvent('exception', [key, value]);
+ }, this);
+ this.fireEvent('request');
+ this.xhr.send(data);
+ if (!this.options.async) this.onStateChange();
+ return this;
+ if (!this.running) return this;
+ this.xhr.abort();
+ this.fireEvent('cancel');
+ return this;
+(function(){
+var methods = {};
+['get', 'post', 'put', 'delete', 'GET', 'POST', 'PUT', 'DELETE'].each(function(method){
+ methods[method] = function(){
+ var params = Array.link(arguments, {url: String.type, data: $defined});
+ return this.send($extend(params, {method: method}));
+Request.implement(methods);
+Element.Properties.send = {
+ var send = this.retrieve('send');
+ if (send) send.cancel();
+ return this.eliminate('send').store('send:options', $extend({
+ data: this, link: 'cancel', method: this.get('method') || 'post', url: this.get('action')
+ }, options));
+ if (options || !this.retrieve('send')){
+ if (options || !this.retrieve('send:options')) this.set('send', options);
+ this.store('send', new Request(this.retrieve('send:options')));
+ return this.retrieve('send');
+ send: function(url){
+ var sender = this.get('send');
+ sender.send({data: this, url: url || sender.options.url});
+ return this;
+script: Request.HTML.js
+description: Extends the basic Request Class with additional methods for interacting with HTML responses.
+requires:
+- /Request
+- /Element
+provides: [Request.HTML]
+Request.HTML = new Class({
+ Extends: Request,
+ options: {
+ update: false,
+ append: false,
+ evalScripts: true,
+ filter: false
+ processHTML: function(text){
+ var match = text.match(/<body[^>]*>([\s\S]*?)<\/body>/i);
+ text = (match) ? match[1] : text;
+ var container = new Element('div');
+ var root = '<root>' + text + '</root>', doc;
+ doc = new ActiveXObject('Microsoft.XMLDOM');
+ doc.async = false;
+ doc.loadXML(root);
+ } else {
+ doc = new DOMParser().parseFromString(root, 'text/xml');
+ root = doc.getElementsByTagName('root')[0];
+ if (!root) return null;
+ for (var i = 0, k = root.childNodes.length; i < k; i++){
+ var child = Element.clone(root.childNodes[i], true, true);
+ if (child) container.grab(child);
+ return container;
+ }) || container.set('html', text);
+ success: function(text){
+ var options = this.options, response = this.response;
+ response.html = text.stripScripts(function(script){
+ response.javascript = script;
+ var temp = this.processHTML(response.html);
+ response.tree = temp.childNodes;
+ response.elements = temp.getElements('*');
+ if (options.filter) response.tree = response.elements.filter(options.filter);
+ if (options.update) document.id(options.update).empty().set('html', response.html);
+ else if (options.append) document.id(options.append).adopt(temp.getChildren());
+ if (options.evalScripts) $exec(response.javascript);
+ this.onSuccess(response.tree, response.elements, response.html, response.javascript);
+Element.Properties.load = {
+ var load = this.retrieve('load');
+ if (load) load.cancel();
+ return this.eliminate('load').store('load:options', $extend({data: this, link: 'cancel', update: this, method: 'get'}, options));
+ if (options || ! this.retrieve('load')){
+ if (options || !this.retrieve('load:options')) this.set('load', options);
+ this.store('load', new Request.HTML(this.retrieve('load:options')));
+ return this.retrieve('load');
+ load: function(){
+ this.get('load').send(Array.link(arguments, {data: Object.type, url: String.type}));
+ return this;
+script: Request.JSON.js
+description: Extends the basic Request Class with additional methods for sending and receiving JSON data.
+requires:
+- /Request JSON
+Request.JSON = new Class({
+ Extends: Request,
+ options: {
+ secure: true
+ this.headers.extend({'Accept': 'application/json', 'X-Request': 'JSON'});
+ this.response.json = JSON.decode(text, this.options.secure);
+ this.onSuccess(this.response.json, text);
+script: More.js
+description: MooTools More
+authors:
+- Guillermo Rauch
+- Thomas Aylott
+- Scott Kyle
+requires:
+- core:1.2.4/MooTools
+provides: [MooTools.More]
+MooTools.More = {
+ 'version': '1.2.4.4',
+ 'build': '6f6057dc645fdb7547689183b2311063bd653ddf'
+script: MooTools.Lang.js
+description: Provides methods for localization.
+authors:
+- Aaron Newton
+requires:
+- core:1.2.4/Events
+- /MooTools.More
+provides: [MooTools.Lang]
+(function(){
+ var data = {
+ language: 'en-US',
+ languages: {
+ 'en-US': {}
+ cascades: ['en-US']
+ var cascaded;
+ MooTools.lang = new Events();
+ $extend(MooTools.lang, {
+ setLanguage: function(lang){
+ if (!data.languages[lang]) return this;
+ data.language = lang;
+ this.load();
+ this.fireEvent('langChange', lang);
+ return this;
+ load: function() {
+ var langs = this.cascade(this.getCurrentLanguage());
+ cascaded = {};
+ $each(langs, function(set, setName){
+ cascaded[setName] = this.lambda(set);
+ }, this);
+ getCurrentLanguage: function(){
+ return data.language;
+ addLanguage: function(lang){
+ data.languages[lang] = data.languages[lang] || {};
+ return this;
+ cascade: function(lang){
+ var cascades = (data.languages[lang] || {}).cascades || [];
+ cascades.combine(data.cascades);
+ cascades.erase(lang).push(lang);
+ var langs = cascades.map(function(lng){
+ return data.languages[lng];
+ }, this);
+ return $merge.apply(this, langs);
+ lambda: function(set) {
+ (set || {}).get = function(key, args){
+ return $lambda(set[key]).apply(this, $splat(args));
+ return set;
+ get: function(set, key, args){
+ if (cascaded && cascaded[set]) return (key ? cascaded[set].get(key, args) : cascaded[set]);
+ set: function(lang, set, members){
+ this.addLanguage(lang);
+ langData = data.languages[lang];
+ if (!langData[set]) langData[set] = {};
+ $extend(langData[set], members);
+ if (lang == this.getCurrentLanguage()){
+ this.load();
+ return this;
+ list: function(){
+ return Hash.getKeys(data.languages);
+script: Log.js
+description: Provides basic logging functionality for plugins to implement.
+authors:
+- Guillermo Rauch
+- Thomas Aylott
+- Scott Kyle
+requires:
+- core:1.2.4/Class
+- /MooTools.More
+provides: [Log]
+(function(){
+var global = this;
+var log = function(){
+ if (global.console && console.log){
+ try {
+ console.log.apply(console, arguments);
+ } catch(e) {
+ console.log(Array.slice(arguments));
+ } else {
+ Log.logged.push(arguments);
+ return this;
+var disabled = function(){
+ this.logged.push(arguments);
+ return this;
+this.Log = new Class({
+ logged: [],
+ log: disabled,
+ resetLog: function(){
+ this.logged.empty();
+ return this;
+ enableLog: function(){
+ this.log = log;
+ this.logged.each(function(args){
+ this.log.apply(this, args);
+ }, this);
+ return this.resetLog();
+ disableLog: function(){
+ this.log = disabled;
+ return this;
+Log.extend(new Log).enableLog();
+// legacy
+Log.logger = function(){
+ return this.log.apply(this, arguments);
+script: Depender.js
+description: A stand alone dependency loader for the MooTools library.
+authors:
+- Aaron Newton
+requires:
+- core:1.2.4/Element.Events
+- core:1.2.4/Request.JSON
+- /MooTools.More
+- /Log
+provides: Depender
+var Depender = {
+ options: {
+ onRequire: $empty(options),
+ onRequirementLoaded: $empty([scripts, options]),
+ onScriptLoaded: $empty({
+ script: script,
+ totalLoaded: percentOfTotalLoaded,
+ loaded: scriptsState
+ serial: false,
+ target: null,
+ noCache: false,
+ log: false,*/
+ loadedSources: [],
+ loadedScripts: ['Core', 'Browser', 'Array', 'String', 'Function', 'Number', 'Hash', 'Element', 'Event', 'Element.Event', 'Class', 'DomReady', 'Class.Extras', 'Request', 'JSON', 'Request.JSON', 'More', 'Depender', 'Log'],
+ useScriptInjection: true
+ loaded: [],
+ sources: {},
+ libs: {},
+ include: function(libs){
+ this.log('include: ', libs);
+ this.mapLoaded = false;
+ var loader = function(data){
+ this.libs = $merge(this.libs, data);
+ $each(this.libs, function(data, lib){
+ if (data.scripts) this.loadSource(lib, data.scripts);
+ }, this);
+ }.bind(this);
+ if ($type(libs) == 'string'){
+ this.log('fetching libs ', libs);
+ this.request(libs, loader);
+ } else {
+ loader(libs);
+ return this;
+ required: [],
+ require: function(options){
+ var loaded = function(){
+ var scripts = this.calculateDependencies(options.scripts);
+ if (options.sources){
+ options.sources.each(function(source){
+ scripts.combine(this.libs[source].files);
+ }, this);
+ if (options.serial) scripts.combine(this.getLoadedScripts());
+ options.scripts = scripts;
+ this.required.push(options);
+ this.fireEvent('require', options);
+ this.loadScripts(options.scripts);
+ if (this.mapLoaded) loaded.call(this);
+ else this.addEvent('mapLoaded', loaded.bind(this));
+ return this;
+ cleanDoubleSlash: function(str){
+ if (!str) return str;
+ var prefix = '';
+ if (str.test(/^http:\/\//)){
+ prefix = 'http://';
+ str = str.substring(7, str.length);
+ str = str.replace(/\/\//g, '/');
+ return prefix + str;
+ request: function(url, callback){
+ new Request.JSON({
+ url: url,
+ secure: false,
+ onSuccess: callback
+ }).send();
+ loadSource: function(lib, source){
+ if (this.libs[lib].files){
+ this.dataLoaded();
+ return;
+ this.log('loading source: ', source);
+ this.request(this.cleanDoubleSlash(source + '/scripts.json'), function(result){
+ this.log('loaded source: ', source);
+ this.libs[lib].files = result;
+ }.bind(this));
+ dataLoaded: function(){
+ var loaded = true;
+ $each(this.libs, function(v, k){
+ if (!this.libs[k].files) loaded = false;
+ }, this);
+ if (loaded){
+ this.mapTree();
+ this.mapLoaded = true;
+ this.calculateLoaded();
+ this.lastLoaded = this.getLoadedScripts().getLength();
+ this.fireEvent('mapLoaded');
+ this.removeEvents('mapLoaded');
+ calculateLoaded: function(){
+ var set = function(script){
+ this.scriptsState[script] = true;
+ }.bind(this);
+ if (this.options.loadedScripts) this.options.loadedScripts.each(set);
+ if (this.options.loadedSources){
+ this.options.loadedSources.each(function(lib){
+ $each(this.libs[lib].files, function(dir){
+ $each(dir, function(data, file){
+ set(file);
+ }, this);
+ }, this);
+ }, this);
+ deps: {},
+ pathMap: {},
+ mapTree: function(){
+ $each(this.libs, function(data, source){
+ $each(data.files, function(scripts, folder){
+ $each(scripts, function(details, script){
+ var path = source + ':' + folder + ':' + script;
+ if (this.deps[path]) return;
+ this.deps[path] = details.deps;
+ this.pathMap[script] = path;
+ }, this);
+ }, this);
+ }, this);
+ getDepsForScript: function(script){
+ return this.deps[this.pathMap[script]] || [];
+ calculateDependencies: function(scripts){
+ var reqs = [];
+ $splat(scripts).each(function(script){
+ if (script == 'None' || !script) return;
+ var deps = this.getDepsForScript(script);
+ if (!deps){
+ if (window.console && console.warn) console.warn('dependencies not mapped: script: %o, map: %o, :deps: %o', script, this.pathMap, this.deps);
+ } else {
+ deps.each(function(scr){
+ if (scr == script || scr == 'None' || !scr) return;
+ if (!reqs.contains(scr)) reqs.combine(this.calculateDependencies(scr));
+ reqs.include(scr);
+ }, this);
+ reqs.include(script);
+ }, this);
+ return reqs;
+ getPath: function(script){
+ try {
+ var chunks = this.pathMap[script].split(':');
+ var lib = this.libs[chunks[0]];
+ var dir = (lib.path || lib.scripts) + '/';
+ chunks.shift();
+ return this.cleanDoubleSlash(dir + chunks.join('/') + '.js');
+ } catch(e){
+ return script;
+ loadScripts: function(scripts){
+ scripts = scripts.filter(function(s){
+ if (!this.scriptsState[s] && s != 'None'){
+ this.scriptsState[s] = false;
+ return true;
+ }, this);
+ if (scripts.length){
+ scripts.each(function(scr){
+ this.loadScript(scr);
+ }, this);
+ } else {
+ this.check();
+ toLoad: [],
+ loadScript: function(script){
+ if (this.scriptsState[script] && this.toLoad.length){
+ this.loadScript(this.toLoad.shift());
+ return;
+ } else if (this.loading){
+ this.toLoad.push(script);
+ return;
+ var finish = function(){
+ this.loading = false;
+ this.scriptLoaded(script);
+ if (this.toLoad.length) this.loadScript(this.toLoad.shift());
+ }.bind(this);
+ var error = function(){
+ this.log('could not load: ', scriptPath);
+ }.bind(this);
+ this.loading = true;
+ var scriptPath = this.getPath(script);
+ if (this.options.useScriptInjection){
+ this.log('injecting script: ', scriptPath);
+ this.log('loaded script: ', scriptPath);
+ finish();
+ }.bind(this);
+ new Element('script', {
+ src: scriptPath + (this.options.noCache ? '?noCache=' + new Date().getTime() : ''),
+ events: {
+ load: loaded,
+ readystatechange: function(){
+ if (['loaded', 'complete'].contains(this.readyState)) loaded();
+ error: error
+ }).inject(this.options.target || document.head);
+ } else {
+ this.log('requesting script: ', scriptPath);
+ new Request({
+ url: scriptPath,
+ noCache: this.options.noCache,
+ onComplete: function(js){
+ $exec(js);
+ finish();
+ }.bind(this),
+ onFailure: error,
+ onException: error
+ }).send();
+ scriptsState: $H(),
+ getLoadedScripts: function(){
+ return this.scriptsState.filter(function(state){
+ return state;
+ scriptLoaded: function(script){
+ this.log('loaded script: ', script);
+ this.check();
+ var loaded = this.getLoadedScripts();
+ var loadedLength = loaded.getLength();
+ var toLoad = this.scriptsState.getLength();
+ this.fireEvent('scriptLoaded', {
+ script: script,
+ totalLoaded: (loadedLength / toLoad * 100).round(),
+ currentLoaded: ((loadedLength - this.lastLoaded) / (toLoad - this.lastLoaded) * 100).round(),
+ loaded: loaded
+ if (loadedLength == toLoad) this.lastLoaded = loadedLength;
+ lastLoaded: 0,
+ var incomplete = [];
+ this.required.each(function(required){
+ var loaded = [];
+ required.scripts.each(function(script){
+ if (this.scriptsState[script]) loaded.push(script);
+ }, this);
+ if (required.onStep){
+ required.onStep({
+ percent: loaded.length / required.scripts.length * 100,
+ scripts: loaded
+ if (required.scripts.length != loaded.length) return;
+ required.callback();
+ this.required.erase(required);
+ this.fireEvent('requirementLoaded', [loaded, required]);
+ }, this);
+$extend(Depender, new Events);
+$extend(Depender, new Options);
+$extend(Depender, new Log);
+Depender._setOptions = Depender.setOptions;
+Depender.setOptions = function(){
+ Depender._setOptions.apply(Depender, arguments);
+ if (this.options.log) Depender.enableLog();
+ return this;
+script: Class.Refactor.js
+description: Extends a class onto itself with new property, preserving any items attached to the class's namespace.
+authors:
+- Aaron Newton
+requires:
+- core:1.2.4/Class
+- /MooTools.More
+provides: [Class.refactor]
+Class.refactor = function(original, refactors){
+ $each(refactors, function(item, name){
+ var origin = original.prototype[name];
+ if (origin && (origin = origin._origin) && typeof item == 'function') original.implement(name, function(){
+ var old = this.previous;
+ this.previous = origin;
+ var value = item.apply(this, arguments);
+ this.previous = old;
+ return value;
+ }); else original.implement(name, item);
+ return original;
+script: Class.Binds.js
+description: Automagically binds specified methods in a class to the instance of the class.
+authors:
+- Aaron Newton
+requires:
+- core:1.2.4/Class
+- /MooTools.More
+provides: [Class.Binds]
+Class.Mutators.Binds = function(binds){
+ return binds;
+Class.Mutators.initialize = function(initialize){
+ $splat(this.Binds).each(function(name){
+ var original = this[name];
+ if (original) this[name] = original.bind(this);
+ }, this);
+ return initialize.apply(this, arguments);
+script: Class.Occlude.js
+description: Prevents a class from being applied to a DOM element twice.
+authors:
+- Aaron Newton
+requires:
+- core/1.2.4/Class
+- /MooTools.More
+provides: [Class.Occlude]
+Class.Occlude = new Class({
+ occlude: function(property, element){
+ element = document.id(element || this.element);
+ var instance = element.retrieve(property || this.property);
+ if (instance && !$defined(this.occluded))
+ return this.occluded = instance;
+ this.occluded = false;
+ element.store(property || this.property, this);
+ return this.occluded;
+script: Chain.Wait.js
+description: value, Adds a method to inject pauses between chained events.
+authors:
+- Aaron Newton
+requires:
+- core:1.2.4/Chain
+- core:1.2.4/Fx
+- /MooTools.More
+provides: [Chain.Wait]
+(function(){
+ var wait = {
+ wait: function(duration){
+ return this.chain(function(){
+ this.callChain.delay($pick(duration, 500), this);
+ }.bind(this));
+ Chain.implement(wait);
+ if (window.Fx){
+ Fx.implement(wait);
+ ['Css', 'Tween', 'Elements'].each(function(cls){
+ if (Fx[cls]) Fx[cls].implement(wait);
+ Element.implement({
+ chains: function(effects){
+ $splat($pick(effects, ['tween', 'morph', 'reveal'])).each(function(effect){
+ effect = this.get(effect);
+ if (!effect) return;
+ effect.setOptions({
+ link:'chain'
+ }, this);
+ return this;
+ pauseFx: function(duration, effect){
+ this.chains(effect).get($pick(effect, 'tween')).wait(duration);
+ return this;
+script: Array.Extras.js
+description: Extends the Array native object to include useful methods to work with arrays.
+authors:
+- Christoph Pojer
+requires:
+- core:1.2.4/Array
+provides: [Array.Extras]
+Array.implement({
+ min: function(){
+ return Math.min.apply(null, this);
+ max: function(){
+ return Math.max.apply(null, this);
+ average: function(){
+ return this.length ? this.sum() / this.length : 0;
+ sum: function(){
+ var result = 0, l = this.length;
+ if (l){
+ do {
+ result += this[--l];
+ } while (l);
+ return result;
+ unique: function(){
+ return [].combine(this);
+ shuffle: function(){
+ for (var i = this.length; i && --i;){
+ var temp = this[i], r = Math.floor(Math.random() * ( i + 1 ));
+ this[i] = this[r];
+ this[r] = temp;
+ return this;
+script: Date.English.US.js
+description: Date messages for US English.
+authors:
+- Aaron Newton
+requires:
+- /Lang
+- /Date
+provides: [Date.English.US]
+MooTools.lang.set('en-US', 'Date', {
+ months: ['January', 'February', 'March', 'April', 'May', 'June', 'July', 'August', 'September', 'October', 'November', 'December'],
+ days: ['Sunday', 'Monday', 'Tuesday', 'Wednesday', 'Thursday', 'Friday', 'Saturday'],
+ //culture's date order: MM/DD/YYYY
+ dateOrder: ['month', 'date', 'year'],
+ shortDate: '%m/%d/%Y',
+ shortTime: '%I:%M%p',
+ AM: 'AM',
+ PM: 'PM',
+ /* Date.Extras */
+ ordinal: function(dayOfMonth){
+ //1st, 2nd, 3rd, etc.
+ return (dayOfMonth > 3 && dayOfMonth < 21) ? 'th' : ['th', 'st', 'nd', 'rd', 'th'][Math.min(dayOfMonth % 10, 4)];
+ lessThanMinuteAgo: 'less than a minute ago',
+ minuteAgo: 'about a minute ago',
+ minutesAgo: '{delta} minutes ago',
+ hourAgo: 'about an hour ago',
+ hoursAgo: 'about {delta} hours ago',
+ dayAgo: '1 day ago',
+ daysAgo: '{delta} days ago',
+ weekAgo: '1 week ago',
+ weeksAgo: '{delta} weeks ago',
+ monthAgo: '1 month ago',
+ monthsAgo: '{delta} months ago',
+ yearAgo: '1 year ago',
+ yearsAgo: '{delta} years ago',
+ lessThanMinuteUntil: 'less than a minute from now',
+ minuteUntil: 'about a minute from now',
+ minutesUntil: '{delta} minutes from now',
+ hourUntil: 'about an hour from now',
+ hoursUntil: 'about {delta} hours from now',
+ dayUntil: '1 day from now',
+ daysUntil: '{delta} days from now',
+ weekUntil: '1 week from now',
+ weeksUntil: '{delta} weeks from now',
+ monthUntil: '1 month from now',
+ monthsUntil: '{delta} months from now',
+ yearUntil: '1 year from now',
+ yearsUntil: '{delta} years from now'
+script: Date.js
+description: Extends the Date native object to include methods useful in managing dates.
+authors:
+- Aaron Newton
+- Nicholas Barthelemy - https://svn.nbarthelemy.com/date-js/
+- Harald Kirshner - mail [at] digitarald.de; http://digitarald.de
+- Scott Kyle - scott [at] appden.com; http://appden.com
+requires:
+- core:1.2.4/Array
+- core:1.2.4/String
+- core:1.2.4/Number
+- core:1.2.4/Lang
+- core:1.2.4/Date.English.US
+- /MooTools.More
+provides: [Date]
+(function(){
+var Date = this.Date;
+if (!Date.now) Date.now = $time;
+Date.Methods = {
+ ms: 'Milliseconds',
+ year: 'FullYear',
+ min: 'Minutes',
+ mo: 'Month',
+ sec: 'Seconds',
+ hr: 'Hours'
+['Date', 'Day', 'FullYear', 'Hours', 'Milliseconds', 'Minutes', 'Month', 'Seconds', 'Time', 'TimezoneOffset',
+ 'Week', 'Timezone', 'GMTOffset', 'DayOfYear', 'LastMonth', 'LastDayOfMonth', 'UTCDate', 'UTCDay', 'UTCFullYear',
+ 'AMPM', 'Ordinal', 'UTCHours', 'UTCMilliseconds', 'UTCMinutes', 'UTCMonth', 'UTCSeconds'].each(function(method){
+ Date.Methods[method.toLowerCase()] = method;
+var pad = function(what, length){
+ return new Array(length - String(what).length + 1).join('0') + what;
+Date.implement({
+ set: function(prop, value){
+ switch ($type(prop)){
+ case 'object':
+ for (var p in prop) this.set(p, prop[p]);
+ break;
+ case 'string':
+ prop = prop.toLowerCase();
+ var m = Date.Methods;
+ if (m[prop]) this['set' + m[prop]](value);
+ return this;
+ get: function(prop){
+ if (m[prop]) return this['get' + m[prop]]();
+ return null;
+ clone: function(){
+ return new Date(this.get('time'));
+ increment: function(interval, times){
+ interval = interval || 'day';
+ times = $pick(times, 1);
+ switch (interval){
+ case 'year':
+ return this.increment('month', times * 12);
+ case 'month':
+ var d = this.get('date');
+ this.set('date', 1).set('mo', this.get('mo') + times);
+ return this.set('date', d.min(this.get('lastdayofmonth')));
+ case 'week':
+ return this.increment('day', times * 7);
+ case 'day':
+ return this.set('date', this.get('date') + times);
+ if (!Date.units[interval]) throw new Error(interval + ' is not a supported interval');
+ return this.set('time', this.get('time') + times * Date.units[interval]());
+ decrement: function(interval, times){
+ return this.increment(interval, -1 * $pick(times, 1));
+ isLeapYear: function(){
+ return Date.isLeapYear(this.get('year'));
+ clearTime: function(){
+ return this.set({hr: 0, min: 0, sec: 0, ms: 0});
+ diff: function(date, resolution){
+ if ($type(date) == 'string') date = Date.parse(date);
+ return ((date - this) / Date.units[resolution || 'day'](3, 3)).toInt(); // non-leap year, 30-day month
+ getLastDayOfMonth: function(){
+ return Date.daysInMonth(this.get('mo'), this.get('year'));
+ getDayOfYear: function(){
+ return (Date.UTC(this.get('year'), this.get('mo'), this.get('date') + 1)
+ - Date.UTC(this.get('year'), 0, 1)) / Date.units.day();
+ getWeek: function(){
+ return (this.get('dayofyear') / 7).ceil();
+ getOrdinal: function(day){
+ return Date.getMsg('ordinal', day || this.get('date'));
+ getTimezone: function(){
+ return this.toString()
+ .replace(/^.*? ([A-Z]{3}).[0-9]{4}.*$/, '$1')
+ .replace(/^.*?\(([A-Z])[a-z]+ ([A-Z])[a-z]+ ([A-Z])[a-z]+\)$/, '$1$2$3');
+ getGMTOffset: function(){
+ var off = this.get('timezoneOffset');
+ return ((off > 0) ? '-' : '+') + pad((off.abs() / 60).floor(), 2) + pad(off % 60, 2);
+ setAMPM: function(ampm){
+ ampm = ampm.toUpperCase();
+ var hr = this.get('hr');
+ if (hr > 11 && ampm == 'AM') return this.decrement('hour', 12);
+ else if (hr < 12 && ampm == 'PM') return this.increment('hour', 12);
+ return this;
+ getAMPM: function(){
+ return (this.get('hr') < 12) ? 'AM' : 'PM';
+ parse: function(str){
+ this.set('time', Date.parse(str));
+ return this;
+ isValid: function(date) {
+ return !!(date || this).valueOf();
+ format: function(f){
+ if (!this.isValid()) return 'invalid date';
+ f = f || '%x %X';
+ f = formats[f.toLowerCase()] || f; // replace short-hand with actual format
+ var d = this;
+ return f.replace(/%([a-z%])/gi,
+ function($0, $1){
+ switch ($1){
+ case 'a': return Date.getMsg('days')[d.get('day')].substr(0, 3);
+ case 'A': return Date.getMsg('days')[d.get('day')];
+ case 'b': return Date.getMsg('months')[d.get('month')].substr(0, 3);
+ case 'B': return Date.getMsg('months')[d.get('month')];
+ case 'c': return d.toString();
+ case 'd': return pad(d.get('date'), 2);
+ case 'H': return pad(d.get('hr'), 2);
+ case 'I': return ((d.get('hr') % 12) || 12);
+ case 'j': return pad(d.get('dayofyear'), 3);
+ case 'm': return pad((d.get('mo') + 1), 2);
+ case 'M': return pad(d.get('min'), 2);
+ case 'o': return d.get('ordinal');
+ case 'p': return Date.getMsg(d.get('ampm'));
+ case 'S': return pad(d.get('seconds'), 2);
+ case 'U': return pad(d.get('week'), 2);
+ case 'w': return d.get('day');
+ case 'x': return d.format(Date.getMsg('shortDate'));
+ case 'X': return d.format(Date.getMsg('shortTime'));
+ case 'y': return d.get('year').toString().substr(2);
+ case 'Y': return d.get('year');
+ case 'T': return d.get('GMTOffset');
+ case 'Z': return d.get('Timezone');
+ return $1;
+ toISOString: function(){
+ return this.format('iso8601');
+Date.alias('toISOString', 'toJSON');
+Date.alias('diff', 'compare');
+Date.alias('format', 'strftime');
+var formats = {
+ db: '%Y-%m-%d %H:%M:%S',
+ compact: '%Y%m%dT%H%M%S',
+ iso8601: '%Y-%m-%dT%H:%M:%S%T',
+ rfc822: '%a, %d %b %Y %H:%M:%S %Z',
+ 'short': '%d %b %H:%M',
+ 'long': '%B %d, %Y %H:%M'
+var parsePatterns = [];
+var nativeParse = Date.parse;
+var parseWord = function(type, word, num){
+ var ret = -1;
+ var translated = Date.getMsg(type + 's');
+ switch ($type(word)){
+ case 'object':
+ ret = translated[word.get(type)];
+ break;
+ case 'number':
+ ret = translated[month - 1];
+ if (!ret) throw new Error('Invalid ' + type + ' index: ' + index);
+ break;
+ case 'string':
+ var match = translated.filter(function(name){
+ return this.test(name);
+ }, new RegExp('^' + word, 'i'));
+ if (!match.length) throw new Error('Invalid ' + type + ' string');
+ if (match.length > 1) throw new Error('Ambiguous ' + type);
+ ret = match[0];
+ return (num) ? translated.indexOf(ret) : ret;
+Date.extend({
+ getMsg: function(key, args) {
+ return MooTools.lang.get('Date', key, args);
+ units: {
+ ms: $lambda(1),
+ second: $lambda(1000),
+ minute: $lambda(60000),
+ hour: $lambda(3600000),
+ day: $lambda(86400000),
+ week: $lambda(608400000),
+ month: function(month, year){
+ var d = new Date;
+ return Date.daysInMonth($pick(month, d.get('mo')), $pick(year, d.get('year'))) * 86400000;
+ year: function(year){
+ year = year || new Date().get('year');
+ return Date.isLeapYear(year) ? 31622400000 : 31536000000;
+ daysInMonth: function(month, year){
+ return [31, Date.isLeapYear(year) ? 29 : 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31][month];
+ isLeapYear: function(year){
+ return ((year % 4 === 0) && (year % 100 !== 0)) || (year % 400 === 0);
+ parse: function(from){
+ var t = $type(from);
+ if (t == 'number') return new Date(from);
+ if (t != 'string') return from;
+ from = from.clean();
+ if (!from.length) return null;
+ var parsed;
+ parsePatterns.some(function(pattern){
+ var bits = pattern.re.exec(from);
+ return (bits) ? (parsed = pattern.handler(bits)) : false;
+ return parsed || new Date(nativeParse(from));
+ parseDay: function(day, num){
+ return parseWord('day', day, num);
+ parseMonth: function(month, num){
+ return parseWord('month', month, num);
+ parseUTC: function(value){
+ var localDate = new Date(value);
+ var utcSeconds = Date.UTC(
+ localDate.get('year'),
+ localDate.get('mo'),
+ localDate.get('date'),
+ localDate.get('hr'),
+ localDate.get('min'),
+ localDate.get('sec')
+ return new Date(utcSeconds);
+ orderIndex: function(unit){
+ return Date.getMsg('dateOrder').indexOf(unit) + 1;
+ defineFormat: function(name, format){
+ formats[name] = format;
+ defineFormats: function(formats){
+ for (var name in formats) Date.defineFormat(name, formats[name]);
+ parsePatterns: parsePatterns, // this is deprecated
+ defineParser: function(pattern){
+ parsePatterns.push((pattern.re && pattern.handler) ? pattern : build(pattern));
+ defineParsers: function(){
+ Array.flatten(arguments).each(Date.defineParser);
+ define2DigitYearStart: function(year){
+ startYear = year % 100;
+ startCentury = year - startYear;
+var startCentury = 1900;
+var startYear = 70;
+var regexOf = function(type){
+ return new RegExp('(?:' + Date.getMsg(type).map(function(name){
+ return name.substr(0, 3);
+ }).join('|') + ')[a-z]*');
+var replacers = function(key){
+ switch(key){
+ case 'x': // iso8601 covers yyyy-mm-dd, so just check if month is first
+ return ((Date.orderIndex('month') == 1) ? '%m[.-/]%d' : '%d[.-/]%m') + '([.-/]%y)?';
+ case 'X':
+ return '%H([.:]%M)?([.:]%S([.:]%s)?)? ?%p? ?%T?';
+ return null;
+var keys = {
+ d: /[0-2]?[0-9]|3[01]/,
+ H: /[01]?[0-9]|2[0-3]/,
+ I: /0?[1-9]|1[0-2]/,
+ M: /[0-5]?\d/,
+ s: /\d+/,
+ o: /[a-z]*/,
+ p: /[ap]\.?m\.?/,
+ y: /\d{2}|\d{4}/,
+ Y: /\d{4}/,
+ T: /Z|[+-]\d{2}(?::?\d{2})?/
+keys.m = keys.I;
+keys.S = keys.M;
+var currentLanguage;
+var recompile = function(language){
+ currentLanguage = language;
+ keys.a = keys.A = regexOf('days');
+ keys.b = keys.B = regexOf('months');
+ parsePatterns.each(function(pattern, i){
+ if (pattern.format) parsePatterns[i] = build(pattern.format);
+var build = function(format){
+ if (!currentLanguage) return {format: format};
+ var parsed = [];
+ var re = (format.source || format) // allow format to be regex
+ .replace(/%([a-z])/gi,
+ function($0, $1){
+ return replacers($1) || $0;
+ ).replace(/\((?!\?)/g, '(?:') // make all groups non-capturing
+ .replace(/ (?!\?|\*)/g, ',? ') // be forgiving with spaces and commas
+ .replace(/%([a-z%])/gi,
+ function($0, $1){
+ var p = keys[$1];
+ if (!p) return $1;
+ parsed.push($1);
+ return '(' + p.source + ')';
+ ).replace(/\[a-z\]/gi, '[a-z\\u00c0-\\uffff]'); // handle unicode words
+ return {
+ format: format,
+ re: new RegExp('^' + re + '$', 'i'),
+ handler: function(bits){
+ bits = bits.slice(1).associate(parsed);
+ var date = new Date().clearTime();
+ if ('d' in bits) handle.call(date, 'd', 1);
+ if ('m' in bits || 'b' in bits || 'B' in bits) handle.call(date, 'm', 1);
+ for (var key in bits) handle.call(date, key, bits[key]);
+ return date;
+var handle = function(key, value){
+ if (!value) return this;
+ switch(key){
+ case 'a': case 'A': return this.set('day', Date.parseDay(value, true));
+ case 'b': case 'B': return this.set('mo', Date.parseMonth(value, true));
+ case 'd': return this.set('date', value);
+ case 'H': case 'I': return this.set('hr', value);
+ case 'm': return this.set('mo', value - 1);
+ case 'M': return this.set('min', value);
+ case 'p': return this.set('ampm', value.replace(/\./g, ''));
+ case 'S': return this.set('sec', value);
+ case 's': return this.set('ms', ('0.' + value) * 1000);
+ case 'w': return this.set('day', value);
+ case 'Y': return this.set('year', value);
+ case 'y':
+ value = +value;
+ if (value < 100) value += startCentury + (value < startYear ? 100 : 0);
+ return this.set('year', value);
+ case 'T':
+ if (value == 'Z') value = '+00';
+ var offset = value.match(/([+-])(\d{2}):?(\d{2})?/);
+ offset = (offset[1] + '1') * (offset[2] * 60 + (+offset[3] || 0)) + this.getTimezoneOffset();
+ return this.set('time', this - offset * 60000);
+ return this;
+Date.defineParsers(
+ '%Y([-./]%m([-./]%d((T| )%X)?)?)?', // "1999-12-31", "1999-12-31 11:59pm", "1999-12-31 23:59:59", ISO8601
+ '%Y%m%d(T%H(%M%S?)?)?', // "19991231", "19991231T1159", compact
+ '%x( %X)?', // "12/31", "12.31.99", "12-31-1999", "12/31/2008 11:59 PM"
+ '%d%o( %b( %Y)?)?( %X)?', // "31st", "31st December", "31 Dec 1999", "31 Dec 1999 11:59pm"
+ '%b( %d%o)?( %Y)?( %X)?', // Same as above with month and day switched
+ '%Y %b( %d%o( %X)?)?', // Same as above with year coming first
+ '%o %b %d %X %T %Y' // "Thu Oct 22 08:11:23 +0000 2009"
+MooTools.lang.addEvent('langChange', function(language){
+ if (MooTools.lang.get('Date')) recompile(language);
+}).fireEvent('langChange', MooTools.lang.getCurrentLanguage());
+script: Date.Extras.js
+description: Extends the Date native object to include extra methods (on top of those in Date.js).
+authors:
+- Aaron Newton
+- Scott Kyle
+requires:
+- /Date
+provides: [Date.Extras]
+Date.implement({
+ timeDiffInWords: function(relative_to){
+ return Date.distanceOfTimeInWords(this, relative_to || new Date);
+ timeDiff: function(to, joiner){
+ if (to == null) to = new Date;
+ var delta = ((to - this) / 1000).toInt();
+ if (!delta) return '0s';
+ var durations = {s: 60, m: 60, h: 24, d: 365, y: 0};
+ var duration, vals = [];
+ for (var step in durations){
+ if (!delta) break;
+ if ((duration = durations[step])){
+ vals.unshift((delta % duration) + step);
+ delta = (delta / duration).toInt();
+ } else {
+ vals.unshift(delta + step);
+ return vals.join(joiner || ':');
+Date.alias('timeDiffInWords', 'timeAgoInWords');
+Date.extend({
+ distanceOfTimeInWords: function(from, to){
+ return Date.getTimePhrase(((to - from) / 1000).toInt());
+ getTimePhrase: function(delta){
+ var suffix = (delta < 0) ? 'Until' : 'Ago';
+ if (delta < 0) delta *= -1;
+ var units = {
+ minute: 60,
+ hour: 60,
+ day: 24,
+ week: 7,
+ month: 52 / 12,
+ year: 12,
+ eon: Infinity
+ var msg = 'lessThanMinute';
+ for (var unit in units){
+ var interval = units[unit];
+ if (delta < 1.5 * interval){
+ if (delta > 0.75 * interval) msg = unit;
+ break;
+ delta /= interval;
+ msg = unit + 's';
+ return Date.getMsg(msg + suffix).substitute({delta: delta.round()});
+ // "today", "tomorrow", "yesterday"
+ re: /^(?:tod|tom|yes)/i,
+ var d = new Date().clearTime();
+ switch(bits[0]){
+ case 'tom': return d.increment();
+ case 'yes': return d.decrement();
+ default: return d;
+ // "next Wednesday", "last Thursday"
+ re: /^(next|last) ([a-z]+)$/i,
+ var day = d.getDay();
+ var newDay = Date.parseDay(bits[2], true);
+ var addDays = newDay - day;
+ if (newDay <= day) addDays += 7;
+ if (bits[1] == 'last') addDays -= 7;
+ return d.set('date', d.getDate() + addDays);
+script: Hash.Extras.js
+description: Extends the Hash native object to include getFromPath which allows a path notation to child elements.
+authors:
+- Aaron Newton
+requires:
+- core:1.2.4/Hash.base
+- /MooTools.More
+provides: [Hash.Extras]
+Hash.implement({
+ getFromPath: function(notation){
+ var source = this.getClean();
+ notation.replace(/\[([^\]]+)\]|\.([^.[]+)|[^[.]+/g, function(match){
+ if (!source) return null;
+ var prop = arguments[2] || arguments[1] || arguments[0];
+ source = (prop in source) ? source[prop] : null;
+ return match;
+ return source;
+ cleanValues: function(method){
+ method = method || $defined;
+ this.each(function(v, k){
+ if (!method(v)) this.erase(k);
+ }, this);
+ return this;
+ run: function(){
+ var args = arguments;
+ if ($type(v) == 'function') v.run(args);
+script: String.Extras.js
+description: Extends the String native object to include methods useful in managing various kinds of strings (query strings, urls, html, etc).
+authors:
+- Aaron Newton
+- Guillermo Rauch
+requires:
+- core:1.2.4/$util
+- core:1.2.4/Array
+provides: [String.Extras]
+(function(){
+var special = ['Ã','à ','Ã?','á','Ã','â','Ã','ã','Ã','ä','Ã
','Ã¥','Ä','Ä','Ä','Ä
','Ä','Ä','Ä','Ä?','Ã','ç', 'Ä','Ä?','Ä?','Ä', 'Ã','è','Ã','é','Ã','ê','Ã','ë','Ä','Ä','Ä','Ä', 'Ä','Ä','Ã','ì','Ã?','Ã','Ã','î','Ã?','ï', 'Ĺ','ĺ','Ľ','ľ','Å?','Å', 'Ã','ñ','Å','Å','Å','Å','Ã','ò','Ã','ó','Ã','ô','Ã','õ','Ã','ö','Ã','ø','Å','Å','Å','Å','Å','Å ','Å¡','Å','Å','Å','Å', 'Ť','Å¥','Ť','Å¥','Å¢','Å£','Ã','ù','Ã','ú','Ã','û','Ã','ü','Å®','ů', 'Ÿ','ÿ','ý','Ã?','Ž','ž','Ź','ź','Å»','ż', 'Ã','þ','Ã?','ð','Ã','Å','Å','Ã','æ','µ'];
+var standard = ['A','a','A','a','A','a','A','a','Ae','ae','A','a','A','a','A','a','C','c','C','c','C','c','D','d','D','d', 'E','e','E','e','E','e','E','e','E','e','E','e','G','g','I','i','I','i','I','i','I','i','L','l','L','l','L','l', 'N','n','N','n','N','n', 'O','o','O','o','O','o','O','o','Oe','oe','O','o','o', 'R','r','R','r', 'S','s','S','s','S','s','T','t','T','t','T','t', 'U','u','U','u','U','u','Ue','ue','U','u','Y','y','Y','y','Z','z','Z','z','Z','z','TH','th','DH','dh','ss','OE','oe','AE','ae','u'];
+var tidymap = {
+ "[\xa0\u2002\u2003\u2009]": " ",
+ "\xb7": "*",
+ "[\u2018\u2019]": "'",
+ "[\u201c\u201d]": '"',
+ "\u2026": "...",
+ "\u2013": "-",
+ "\u2014": "--",
+ "\uFFFD": "»"
+var getRegForTag = function(tag, contents) {
+ tag = tag || '';
+ var regstr = contents ? "<" + tag + "[^>]*>([\\s\\S]*?)<\/" + tag + ">" : "<\/?" + tag + "([^>]+)?>";
+ reg = new RegExp(regstr, "gi");
+ return reg;
+String.implement({
+ standardize: function(){
+ var text = this;
+ special.each(function(ch, i){
+ text = text.replace(new RegExp(ch, 'g'), standard[i]);
+ return text;
+ repeat: function(times){
+ return new Array(times + 1).join(this);
+ pad: function(length, str, dir){
+ if (this.length >= length) return this;
+ var pad = (str == null ? ' ' : '' + str).repeat(length - this.length).substr(0, length - this.length);
+ if (!dir || dir == 'right') return this + pad;
+ if (dir == 'left') return pad + this;
+ return pad.substr(0, (pad.length / 2).floor()) + this + pad.substr(0, (pad.length / 2).ceil());
+ getTags: function(tag, contents){
+ return this.match(getRegForTag(tag, contents)) || [];
+ stripTags: function(tag, contents){
+ return this.replace(getRegForTag(tag, contents), '');
+ tidy: function(){
+ var txt = this.toString();
+ $each(tidymap, function(value, key){
+ txt = txt.replace(new RegExp(key, 'g'), value);
+ return txt;
+script: String.QueryString.js
+description: Methods for dealing with URI query strings.
+authors:
+- Sebastian Markbåge, Aaron Newton, Lennart Pilon, Valerio Proietti
+requires:
+- core:1.2.4/Array
+- /MooTools.More
+provides: [String.QueryString]
+String.implement({
+ parseQueryString: function(){
+ var vars = this.split(/[&;]/), res = {};
+ if (vars.length) vars.each(function(val){
+ var index = val.indexOf('='),
+ keys = index < 0 ? [''] : val.substr(0, index).match(/[^\]\[]+/g),
+ value = decodeURIComponent(val.substr(index + 1)),
+ obj = res;
+ keys.each(function(key, i){
+ var current = obj[key];
+ if(i < keys.length - 1)
+ obj = obj[key] = current || {};
+ else if($type(current) == 'array')
+ current.push(value);
+ else
+ obj[key] = $defined(current) ? [current, value] : value;
+ return res;
+ cleanQueryString: function(method){
+ return this.split('&').filter(function(val){
+ key = index < 0 ? '' : val.substr(0, index),
+ value = val.substr(index + 1);
+ return method ? method.run([key, value]) : $chk(value);
+ }).join('&');
+script: URI.js
+description: Provides methods useful in managing the window location and uris.
+authors:
+- Aaron Newton
+requires:
+- core:1.2.4/Selectors
+- /String.QueryString
+provides: URI
+var URI = new Class({
+ options: {
+ /*base: false*/
+ regex: /^(?:(\w+):)?(?:\/\/(?:(?:([^:@\/]*):?([^:@\/]*))?@)?([^:\/?#]*)(?::(\d*))?)?(\.\.?$|(?:[^?#\/]*\/)*)([^?#]*)(?:\?([^#]*))?(?:#(.*))?/,
+ parts: ['scheme', 'user', 'password', 'host', 'port', 'directory', 'file', 'query', 'fragment'],
+ schemes: {http: 80, https: 443, ftp: 21, rtsp: 554, mms: 1755, file: 0},
+ initialize: function(uri, options){
+ var base = this.options.base || URI.base;
+ if(!uri) uri = base;
+ if (uri && uri.parsed) this.parsed = $unlink(uri.parsed);
+ else this.set('value', uri.href || uri.toString(), base ? new URI(base) : false);
+ parse: function(value, base){
+ var bits = value.match(this.regex);
+ if (!bits) return false;
+ bits.shift();
+ return this.merge(bits.associate(this.parts), base);
+ merge: function(bits, base){
+ if ((!bits || !bits.scheme) && (!base || !base.scheme)) return false;
+ if (base){
+ this.parts.every(function(part){
+ if (bits[part]) return false;
+ bits[part] = base[part] || '';
+ return true;
+ bits.port = bits.port || this.schemes[bits.scheme.toLowerCase()];
+ bits.directory = bits.directory ? this.parseDirectory(bits.directory, base ? base.directory : '') : '/';
+ return bits;
+ parseDirectory: function(directory, baseDirectory) {
+ directory = (directory.substr(0, 1) == '/' ? '' : (baseDirectory || '/')) + directory;
+ if (!directory.test(URI.regs.directoryDot)) return directory;
+ var result = [];
+ directory.replace(URI.regs.endSlash, '').split('/').each(function(dir){
+ if (dir == '..' && result.length > 0) result.pop();
+ else if (dir != '.') result.push(dir);
+ return result.join('/') + '/';
+ combine: function(bits){
+ return bits.value || bits.scheme + '://' +
+ (bits.user ? bits.user + (bits.password ? ':' + bits.password : '') + '@' : '') +
+ (bits.host || '') + (bits.port && bits.port != this.schemes[bits.scheme] ? ':' + bits.port : '') +
+ (bits.directory || '/') + (bits.file || '') +
+ (bits.query ? '?' + bits.query : '') +
+ (bits.fragment ? '#' + bits.fragment : '');
+ set: function(part, value, base){
+ if (part == 'value'){
+ var scheme = value.match(URI.regs.scheme);
+ if (scheme) scheme = scheme[1];
+ if (scheme && !$defined(this.schemes[scheme.toLowerCase()])) this.parsed = { scheme: scheme, value: value };
+ else this.parsed = this.parse(value, (base || this).parsed) || (scheme ? { scheme: scheme, value: value } : { value: value });
+ } else if (part == 'data') {
+ this.setData(value);
+ } else {
+ this.parsed[part] = value;
+ return this;
+ get: function(part, base){
+ switch(part){
+ case 'value': return this.combine(this.parsed, base ? base.parsed : false);
+ case 'data' : return this.getData();
+ return this.parsed[part] || '';
+ go: function(){
+ document.location.href = this.toString();
+ toURI: function(){
+ return this;
+ getData: function(key, part){
+ var qs = this.get(part || 'query');
+ if (!$chk(qs)) return key ? null : {};
+ var obj = qs.parseQueryString();
+ return key ? obj[key] : obj;
+ setData: function(values, merge, part){
+ if (typeof values == 'string'){
+ data = this.getData();
+ data[arguments[0]] = arguments[1];
+ values = data;
+ } else if (merge) {
+ values = $merge(this.getData(), values);
+ return this.set(part || 'query', Hash.toQueryString(values));
+ clearData: function(part){
+ return this.set(part || 'query', '');
+URI.prototype.toString = URI.prototype.valueOf = function(){
+ return this.get('value');
+URI.regs = {
+ endSlash: /\/$/,
+ scheme: /^(\w+):/,
+ directoryDot: /\.\/|\.$/
+URI.base = new URI(document.getElements('base[href]', true).getLast(), {base: document.location});
+String.implement({
+ toURI: function(options){
+ return new URI(this, options);
+script: URI.Relative.js
+description: Extends the URI class to add methods for computing relative and absolute urls.
+license: MIT-style license
+authors:
+requires:
+- /Class.refactor
+- /URI
+provides: [URI.Relative]
+URI = Class.refactor(URI, {
+ combine: function(bits, base){
+ if (!base || bits.scheme != base.scheme || bits.host != base.host || bits.port != base.port)
+ return this.previous.apply(this, arguments);
+ var end = bits.file + (bits.query ? '?' + bits.query : '') + (bits.fragment ? '#' + bits.fragment : '');
+ if (!base.directory) return (bits.directory || (bits.file ? '' : './')) + end;
+ var baseDir = base.directory.split('/'),
+ relDir = bits.directory.split('/'),
+ path = '',
+ offset;
+ var i = 0;
+ for(offset = 0; offset < baseDir.length && offset < relDir.length && baseDir[offset] == relDir[offset]; offset++);
+ for(i = 0; i < baseDir.length - offset - 1; i++) path += '../';
+ for(i = offset; i < relDir.length - 1; i++) path += relDir[i] + '/';
+ return (path || (bits.file ? '' : './')) + end;
+ toAbsolute: function(base){
+ base = new URI(base);
+ if (base) base.set('directory', '').set('file', '');
+ return this.toRelative(base);
+ toRelative: function(base){
+ return this.get('value', new URI(base));
+script: Element.Forms.js
+description: Extends the Element native object to include methods useful in managing inputs.
+authors:
+- Aaron Newton
+requires:
+- /MooTools.More
+provides: [Element.Forms]
+Element.implement({
+ tidy: function(){
+ this.set('value', this.get('value').tidy());
+ getTextInRange: function(start, end){
+ return this.get('value').substring(start, end);
+ getSelectedText: function(){
+ if (this.setSelectionRange) return this.getTextInRange(this.getSelectionStart(), this.getSelectionEnd());
+ return document.selection.createRange().text;
+ getSelectedRange: function() {
+ if ($defined(this.selectionStart)) return {start: this.selectionStart, end: this.selectionEnd};
+ var pos = {start: 0, end: 0};
+ var range = this.getDocument().selection.createRange();
+ if (!range || range.parentElement() != this) return pos;
+ var dup = range.duplicate();
+ if (this.type == 'text') {
+ pos.start = 0 - dup.moveStart('character', -100000);
+ pos.end = pos.start + range.text.length;
+ } else {
+ var value = this.get('value');
+ var offset = value.length;
+ dup.moveToElementText(this);
+ dup.setEndPoint('StartToEnd', range);
+ if(dup.text.length) offset -= value.match(/[\n\r]*$/)[0].length;
+ pos.end = offset - dup.text.length;
+ dup.setEndPoint('StartToStart', range);
+ pos.start = offset - dup.text.length;
+ return pos;
+ getSelectionStart: function(){
+ return this.getSelectedRange().start;
+ getSelectionEnd: function(){
+ return this.getSelectedRange().end;
+ setCaretPosition: function(pos){
+ if (pos == 'end') pos = this.get('value').length;
+ this.selectRange(pos, pos);
+ return this;
+ getCaretPosition: function(){
+ selectRange: function(start, end){
+ if (this.setSelectionRange) {
+ this.focus();
+ this.setSelectionRange(start, end);
+ } else {
+ var diff = value.substr(start, end - start).replace(/\r/g, '').length;
+ start = value.substr(0, start).replace(/\r/g, '').length;
+ var range = this.createTextRange();
+ range.collapse(true);
+ range.moveEnd('character', start + diff);
+ range.moveStart('character', start);
+ range.select();
+ return this;
+ insertAtCursor: function(value, select){
+ var pos = this.getSelectedRange();
+ var text = this.get('value');
+ this.set('value', text.substring(0, pos.start) + value + text.substring(pos.end, text.length));
+ if ($pick(select, true)) this.selectRange(pos.start, pos.start + value.length);
+ else this.setCaretPosition(pos.start + value.length);
+ return this;
+ insertAroundCursor: function(options, select){
+ before: '',
+ defaultMiddle: '',
+ after: ''
+ }, options);
+ var value = this.getSelectedText() || options.defaultMiddle;
+ if (pos.start == pos.end){
+ this.set('value', text.substring(0, pos.start) + options.before + value + options.after + text.substring(pos.end, text.length));
+ this.selectRange(pos.start + options.before.length, pos.end + options.before.length + value.length);
+ } else {
+ var current = text.substring(pos.start, pos.end);
+ this.set('value', text.substring(0, pos.start) + options.before + current + options.after + text.substring(pos.end, text.length));
+ var selStart = pos.start + options.before.length;
+ if ($pick(select, true)) this.selectRange(selStart, selStart + current.length);
+ else this.setCaretPosition(selStart + text.length);
+ return this;
+script: Elements.From.js
+description: Returns a collection of elements from a string of html.
+authors:
+- Aaron Newton
+requires:
+- /MooTools.More
+provides: [Elements.from]
+Elements.from = function(text, excludeScripts){
+ if ($pick(excludeScripts, true)) text = text.stripScripts();
+ var container, match = text.match(/^\s*<(t[dhr]|tbody|tfoot|thead)/i);
+ if (match){
+ container = new Element('table');
+ var tag = match[1].toLowerCase();
+ if (['td', 'th', 'tr'].contains(tag)){
+ container = new Element('tbody').inject(container);
+ if (tag != 'tr') container = new Element('tr').inject(container);
+ return (container || new Element('div')).set('html', text).getChildren();
+script: Element.Delegation.js
+description: Extends the Element native object to include the delegate method for more efficient event management.
+credits:
+- "Event checking based on the work of Daniel Steigerwald. License: MIT-style license. Copyright: Copyright (c) 2008 Daniel Steigerwald, daniel.steigerwald.cz"
+authors:
+- Aaron Newton
+- Daniel Steigerwald
+requires:
+- /MooTools.More
+provides: [Element.Delegation]
+(function(addEvent, removeEvent){
+ var match = /(.*?):relay\(([^)]+)\)$/,
+ combinators = /[+>~\s]/,
+ splitType = function(type){
+ var bits = type.match(match);
+ return !bits ? {event: type} : {
+ event: bits[1],
+ selector: bits[2]
+ check = function(e, selector){
+ var t = e.target;
+ if (combinators.test(selector = selector.trim())){
+ var els = this.getElements(selector);
+ for (var i = els.length; i--; ){
+ var el = els[i];
+ if (t == el || el.hasChild(t)) return el;
+ } else {
+ for ( ; t && t != this; t = t.parentNode){
+ if (Element.match(t, selector)) return document.id(t);
+ return null;
+ addEvent: function(type, fn){
+ var splitted = splitType(type);
+ if (splitted.selector){
+ var monitors = this.retrieve('$moo:delegateMonitors', {});
+ if (!monitors[type]){
+ var monitor = function(e){
+ var el = check.call(this, e, splitted.selector);
+ if (el) this.fireEvent(type, [e, el], 0, el);
+ }.bind(this);
+ monitors[type] = monitor;
+ addEvent.call(this, splitted.event, monitor);
+ return addEvent.apply(this, arguments);
+ removeEvent: function(type, fn){
+ var events = this.retrieve('events');
+ if (!events || !events[type] || (fn && !events[type].keys.contains(fn))) return this;
+ if (fn) removeEvent.apply(this, [type, fn]);
+ else removeEvent.apply(this, type);
+ events = this.retrieve('events');
+ if (events && events[type] && events[type].keys.length == 0){
+ removeEvent.apply(this, [splitted.event, monitors[type]]);
+ delete monitors[type];
+ return this;
+ return removeEvent.apply(this, arguments);
+ fireEvent: function(type, args, delay, bind){
+ if (!events || !events[type]) return this;
+ events[type].keys.each(function(fn){
+ fn.create({bind: bind || this, delay: delay, arguments: args})();
+ }, this);
+ return this;
+})(Element.prototype.addEvent, Element.prototype.removeEvent);/*
+script: Element.Measure.js
+description: Extends the Element native object to include methods useful in measuring dimensions.
+credits: "Element.measure / .expose methods by Daniel Steigerwald License: MIT-style license. Copyright: Copyright (c) 2008 Daniel Steigerwald, daniel.steigerwald.cz"
+authors:
+- Aaron Newton
+requires:
+- core:1.2.4/Element.Style
+- core:1.2.4/Element.Dimensions
+- /MooTools.More
+provides: [Element.Measure]
+ measure: function(fn){
+ var vis = function(el) {
+ return !!(!el || el.offsetHeight || el.offsetWidth);
+ if (vis(this)) return fn.apply(this);
+ var parent = this.getParent(),
+ restorers = [],
+ toMeasure = [];
+ while (!vis(parent) && parent != document.body) {
+ toMeasure.push(parent.expose());
+ parent = parent.getParent();
+ var restore = this.expose();
+ var result = fn.apply(this);
+ restore();
+ toMeasure.each(function(restore){
+ restore();
+ return result;
+ expose: function(){
+ if (this.getStyle('display') != 'none') return $empty;
+ var before = this.style.cssText;
+ this.setStyles({
+ display: 'block',
+ position: 'absolute',
+ visibility: 'hidden'
+ return function(){
+ this.style.cssText = before;
+ }.bind(this);
+ getDimensions: function(options){
+ options = $merge({computeSize: false},options);
+ var dim = {};
+ var getSize = function(el, options){
+ return (options.computeSize)?el.getComputedSize(options):el.getSize();
+ var parent = this.getParent('body');
+ if (parent && this.getStyle('display') == 'none'){
+ dim = this.measure(function(){
+ return getSize(this, options);
+ } else if (parent){
+ try { //safari sometimes crashes here, so catch it
+ dim = getSize(this, options);
+ }catch(e){}
+ } else {
+ dim = {x: 0, y: 0};
+ return $chk(dim.x) ? $extend(dim, {width: dim.x, height: dim.y}) : $extend(dim, {x: dim.width, y: dim.height});
+ getComputedSize: function(options){
+ styles: ['padding','border'],
+ plains: {
+ height: ['top','bottom'],
+ width: ['left','right']
+ mode: 'both'
+ }, options);
+ var size = {width: 0,height: 0};
+ switch (options.mode){
+ case 'vertical':
+ delete size.width;
+ delete options.plains.width;
+ break;
+ case 'horizontal':
+ delete size.height;
+ delete options.plains.height;
+ break;
+ var getStyles = [];
+ //this function might be useful in other places; perhaps it should be outside this function?
+ $each(options.plains, function(plain, key){
+ plain.each(function(edge){
+ options.styles.each(function(style){
+ getStyles.push((style == 'border') ? style + '-' + edge + '-' + 'width' : style + '-' + edge);
+ var styles = {};
+ getStyles.each(function(style){ styles[style] = this.getComputedStyle(style); }, this);
+ var subtracted = [];
+ $each(options.plains, function(plain, key){ //keys: width, height, plains: ['left', 'right'], ['top','bottom']
+ var capitalized = key.capitalize();
+ size['total' + capitalized] = size['computed' + capitalized] = 0;
+ plain.each(function(edge){ //top, left, right, bottom
+ size['computed' + edge.capitalize()] = 0;
+ getStyles.each(function(style, i){ //padding, border, etc.
+ //'padding-left'.test('left') size['totalWidth'] = size['width'] + [padding-left]
+ if (style.test(edge)){
+ styles[style] = styles[style].toInt() || 0; //styles['padding-left'] = 5;
+ size['total' + capitalized] = size['total' + capitalized] + styles[style];
+ size['computed' + edge.capitalize()] = size['computed' + edge.capitalize()] + styles[style];
+ //if width != width (so, padding-left, for instance), then subtract that from the total
+ if (style.test(edge) && key != style &&
+ (style.test('border') || style.test('padding')) && !subtracted.contains(style)){
+ subtracted.push(style);
+ size['computed' + capitalized] = size['computed' + capitalized]-styles[style];
+ ['Width', 'Height'].each(function(value){
+ var lower = value.toLowerCase();
+ if(!$chk(size[lower])) return;
+ size[lower] = size[lower] + this['offset' + value] + size['computed' + value];
+ size['total' + value] = size[lower] + size['total' + value];
+ delete size['computed' + value];
+ }, this);
+ return $extend(styles, size);
+script: Element.Pin.js
+description: Extends the Element native object to include the pin method useful for fixed positioning for elements.
+authors:
+- Aaron Newton
+requires:
+- /MooTools.More
+provides: [Element.Pin]
+(function(){
+ var supportsPositionFixed = false;
+ window.addEvent('domready', function(){
+ var test = new Element('div').setStyles({
+ position: 'fixed',
+ top: 0,
+ right: 0
+ }).inject(document.body);
+ supportsPositionFixed = (test.offsetTop === 0);
+ test.dispose();
+ pin: function(enable){
+ if (this.getStyle('display') == 'none') return null;
+ var p,
+ scroll = window.getScroll();
+ if (enable !== false){
+ p = this.getPosition();
+ if (!this.retrieve('pinned')){
+ var pos = {
+ top: p.y - scroll.y,
+ left: p.x - scroll.x
+ if (supportsPositionFixed){
+ this.setStyle('position', 'fixed').setStyles(pos);
+ } else {
+ this.store('pinnedByJS', true);
+ this.setStyles({
+ top: p.y,
+ left: p.x
+ }).addClass('isPinned');
+ this.store('scrollFixer', (function(){
+ if (this.retrieve('pinned'))
+ var scroll = window.getScroll();
+ this.setStyles({
+ top: pos.top.toInt() + scroll.y,
+ left: pos.left.toInt() + scroll.x
+ }).bind(this));
+ window.addEvent('scroll', this.retrieve('scrollFixer'));
+ this.store('pinned', true);
+ } else {
+ var op;
+ if (!Browser.Engine.trident){
+ var parent = this.getParent();
+ op = (parent.getComputedStyle('position') != 'static' ? parent : parent.getOffsetParent());
+ p = this.getPosition(op);
+ this.store('pinned', false);
+ var reposition;
+ if (supportsPositionFixed && !this.retrieve('pinnedByJS')){
+ reposition = {
+ top: p.y + scroll.y,
+ left: p.x + scroll.x
+ } else {
+ this.store('pinnedByJS', false);
+ window.removeEvent('scroll', this.retrieve('scrollFixer'));
+ reposition = {
+ top: p.y,
+ left: p.x
+ this.setStyles($merge(reposition, {position: 'absolute'})).removeClass('isPinned');
+ return this;
+ unpin: function(){
+ return this.pin(false);
+ togglepin: function(){
+ this.pin(!this.retrieve('pinned'));
+script: Element.Position.js
+description: Extends the Element native object to include methods useful positioning elements relative to others.
+authors:
+- Aaron Newton
+requires:
+- /Element.Measure
+provides: [Elements.Position]
+(function(){
+var original = Element.prototype.position;
+ position: function(options){
+ //call original position if the options are x/y values
+ if (options && ($defined(options.x) || $defined(options.y))) return original ? original.apply(this, arguments) : this;
+ $each(options||{}, function(v, k){ if (!$defined(v)) delete options[k]; });
+ // minimum: { x: 0, y: 0 },
+ // maximum: { x: 0, y: 0},
+ relativeTo: document.body,
+ position: {
+ x: 'center', //left, center, right
+ y: 'center' //top, center, bottom
+ edge: false,
+ offset: {x: 0, y: 0},
+ returnPos: false,
+ relFixedPosition: false,
+ ignoreMargins: false,
+ ignoreScroll: false,
+ allowNegative: false
+ }, options);
+ //compute the offset of the parent positioned element if this element is in one
+ var parentOffset = {x: 0, y: 0},
+ parentPositioned = false;
+ /* dollar around getOffsetParent should not be necessary, but as it does not return
+ * a mootools extended element in IE, an error occurs on the call to expose. See:
+ * http://mootools.lighthouseapp.com/projects/2706/tickets/333-element-getoffsetparent-inconsistency-between-ie-and-other-browsers */
+ var offsetParent = this.measure(function(){
+ return document.id(this.getOffsetParent());
+ if (offsetParent && offsetParent != this.getDocument().body){
+ parentOffset = offsetParent.measure(function(){
+ return this.getPosition();
+ parentPositioned = offsetParent != document.id(options.relativeTo);
+ options.offset.x = options.offset.x - parentOffset.x;
+ options.offset.y = options.offset.y - parentOffset.y;
+ //upperRight, bottomRight, centerRight, upperLeft, bottomLeft, centerLeft
+ //topRight, topLeft, centerTop, centerBottom, center
+ var fixValue = function(option){
+ if ($type(option) != 'string') return option;
+ option = option.toLowerCase();
+ var val = {};
+ if (option.test('left')) val.x = 'left';
+ else if (option.test('right')) val.x = 'right';
+ else val.x = 'center';
+ if (option.test('upper') || option.test('top')) val.y = 'top';
+ else if (option.test('bottom')) val.y = 'bottom';
+ else val.y = 'center';
+ return val;
+ options.edge = fixValue(options.edge);
+ options.position = fixValue(options.position);
+ if (!options.edge){
+ if (options.position.x == 'center' && options.position.y == 'center') options.edge = {x:'center', y:'center'};
+ else options.edge = {x:'left', y:'top'};
+ this.setStyle('position', 'absolute');
+ var rel = document.id(options.relativeTo) || document.body,
+ calc = rel == document.body ? window.getScroll() : rel.getPosition(),
+ top = calc.y, left = calc.x;
+ var dim = this.getDimensions({computeSize: true, styles:['padding', 'border','margin']});
+ var pos = {},
+ prefY = options.offset.y,
+ prefX = options.offset.x,
+ winSize = window.getSize();
+ switch(options.position.x){
+ case 'left':
+ pos.x = left + prefX;
+ break;
+ case 'right':
+ pos.x = left + prefX + rel.offsetWidth;
+ break;
+ default: //center
+ pos.x = left + ((rel == document.body ? winSize.x : rel.offsetWidth)/2) + prefX;
+ break;
+ switch(options.position.y){
+ case 'top':
+ pos.y = top + prefY;
+ break;
+ case 'bottom':
+ pos.y = top + prefY + rel.offsetHeight;
+ break;
+ default: //center
+ pos.y = top + ((rel == document.body ? winSize.y : rel.offsetHeight)/2) + prefY;
+ break;
+ if (options.edge){
+ var edgeOffset = {};
+ switch(options.edge.x){
+ case 'left':
+ edgeOffset.x = 0;
+ break;
+ case 'right':
+ edgeOffset.x = -dim.x-dim.computedRight-dim.computedLeft;
+ break;
+ default: //center
+ edgeOffset.x = -(dim.totalWidth/2);
+ break;
+ switch(options.edge.y){
+ case 'top':
+ edgeOffset.y = 0;
+ break;
+ case 'bottom':
+ edgeOffset.y = -dim.y-dim.computedTop-dim.computedBottom;
+ break;
+ default: //center
+ edgeOffset.y = -(dim.totalHeight/2);
+ break;
+ pos.x += edgeOffset.x;
+ pos.y += edgeOffset.y;
+ pos = {
+ left: ((pos.x >= 0 || parentPositioned || options.allowNegative) ? pos.x : 0).toInt(),
+ top: ((pos.y >= 0 || parentPositioned || options.allowNegative) ? pos.y : 0).toInt()
+ var xy = {left: 'x', top: 'y'};
+ ['minimum', 'maximum'].each(function(minmax) {
+ ['left', 'top'].each(function(lr) {
+ var val = options[minmax] ? options[minmax][xy[lr]] : null;
+ if (val != null && pos[lr] < val) pos[lr] = val;
+ if (rel.getStyle('position') == 'fixed' || options.relFixedPosition){
+ var winScroll = window.getScroll();
+ pos.top+= winScroll.y;
+ pos.left+= winScroll.x;
+ if (options.ignoreScroll) {
+ var relScroll = rel.getScroll();
+ pos.top-= relScroll.y;
+ pos.left-= relScroll.x;
+ if (options.ignoreMargins) {
+ pos.left += (
+ options.edge.x == 'right' ? dim['margin-right'] :
+ options.edge.x == 'center' ? -dim['margin-left'] + ((dim['margin-right'] + dim['margin-left'])/2) :
+ - dim['margin-left']
+ pos.top += (
+ options.edge.y == 'bottom' ? dim['margin-bottom'] :
+ options.edge.y == 'center' ? -dim['margin-top'] + ((dim['margin-bottom'] + dim['margin-top'])/2) :
+ - dim['margin-top']
+ pos.left = Math.ceil(pos.left);
+ pos.top = Math.ceil(pos.top);
+ if (options.returnPos) return pos;
+ else this.setStyles(pos);
+ return this;
+script: Element.Shortcuts.js
+description: Extends the Element native object to include some shortcut methods.
+authors:
+- Aaron Newton
+requires:
+- /MooTools.More
+provides: [Element.Shortcuts]
+ isDisplayed: function(){
+ return this.getStyle('display') != 'none';
+ isVisible: function(){
+ var w = this.offsetWidth,
+ h = this.offsetHeight;
+ return (w == 0 && h == 0) ? false : (w > 0 && h > 0) ? true : this.isDisplayed();
+ toggle: function(){
+ return this[this.isDisplayed() ? 'hide' : 'show']();
+ hide: function(){
+ var d;
+ try {
+ //IE fails here if the element is not in the dom
+ d = this.getStyle('display');
+ } catch(e){}
+ return this.store('originalDisplay', d || '').setStyle('display', 'none');
+ show: function(display){
+ display = display || this.retrieve('originalDisplay') || 'block';
+ return this.setStyle('display', (display == 'none') ? 'block' : display);
+ swapClass: function(remove, add){
+ return this.removeClass(remove).addClass(add);
+script: IframeShim.js
+description: Defines IframeShim, a class for obscuring select lists and flash objects in IE.
+authors:
+- Aaron Newton
+requires:
+- core:1.2.4/Options Events
+- /Element.Position
+- /Class.Occlude
+provides: [IframeShim]
+var IframeShim = new Class({
+ Implements: [Options, Events, Class.Occlude],
+ options: {
+ className: 'iframeShim',
+ src: 'javascript:false;document.write("");',
+ display: false,
+ zIndex: null,
+ margin: 0,
+ browsers: (Browser.Engine.trident4 || (Browser.Engine.gecko && !Browser.Engine.gecko19 && Browser.Platform.mac))
+ property: 'IframeShim',
+ initialize: function(element, options){
+ this.element = document.id(element);
+ if (this.occlude()) return this.occluded;
+ this.setOptions(options);
+ this.makeShim();
+ return this;
+ makeShim: function(){
+ if(this.options.browsers){
+ var zIndex = this.element.getStyle('zIndex').toInt();
+ if (!zIndex){
+ zIndex = 1;
+ var pos = this.element.getStyle('position');
+ if (pos == 'static' || !pos) this.element.setStyle('position', 'relative');
+ this.element.setStyle('zIndex', zIndex);
+ zIndex = ($chk(this.options.zIndex) && zIndex > this.options.zIndex) ? this.options.zIndex : zIndex - 1;
+ if (zIndex < 0) zIndex = 1;
+ this.shim = new Element('iframe', {
+ src: this.options.src,
+ scrolling: 'no',
+ frameborder: 0,
+ styles: {
+ zIndex: zIndex,
+ border: 'none',
+ filter: 'progid:DXImageTransform.Microsoft.Alpha(style=0,opacity=0)'
+ 'class': this.options.className
+ }).store('IframeShim', this);
+ var inject = (function(){
+ this.shim.inject(this.element, 'after');
+ this[this.options.display ? 'show' : 'hide']();
+ this.fireEvent('inject');
+ }).bind(this);
+ if (!IframeShim.ready) window.addEvent('load', inject);
+ else inject();
+ } else {
+ this.position = this.hide = this.show = this.dispose = $lambda(this);
+ position: function(){
+ if (!IframeShim.ready || !this.shim) return this;
+ var size = this.element.measure(function(){
+ return this.getSize();
+ if (this.options.margin != undefined){
+ size.x = size.x - (this.options.margin * 2);
+ size.y = size.y - (this.options.margin * 2);
+ this.options.offset.x += this.options.margin;
+ this.options.offset.y += this.options.margin;
+ this.shim.set({width: size.x, height: size.y}).position({
+ relativeTo: this.element,
+ offset: this.options.offset
+ return this;
+ hide: function(){
+ if (this.shim) this.shim.setStyle('display', 'none');
+ return this;
+ show: function(){
+ if (this.shim) this.shim.setStyle('display', 'block');
+ return this.position();
+ dispose: function(){
+ if (this.shim) this.shim.dispose();
+ return this;
+ destroy: function(){
+ if (this.shim) this.shim.destroy();
+ return this;
+window.addEvent('load', function(){
+ IframeShim.ready = true;
+script: Mask.js
+description: Creates a mask element to cover another.
+authors:
+- Aaron Newton
+requires:
+- core:1.2.4/Events
+- /Class.Binds
+- /IframeShim
+provides: [Mask]
+var Mask = new Class({
+ Implements: [Options, Events],
+ Binds: ['position'],
+ options: {
+ // onShow: $empty,
+ // onHide: $empty,
+ // onDestroy: $empty,
+ // onClick: $empty,
+ //inject: {
+ // where: 'after',
+ // target: null,
+ // hideOnClick: false,
+ // id: null,
+ // destroyOnHide: false,
+ style: {},
+ 'class': 'mask',
+ maskMargins: false,
+ useIframeShim: true,
+ iframeShimOptions: {}
+ initialize: function(target, options){
+ this.target = document.id(target) || document.id(document.body);
+ this.target.store('Mask', this);
+ this.render();
+ this.inject();
+ render: function() {
+ this.element = new Element('div', {
+ 'class': this.options['class'],
+ id: this.options.id || 'mask-' + $time(),
+ styles: $merge(this.options.style, {
+ display: 'none'
+ events: {
+ click: function(){
+ this.fireEvent('click');
+ if (this.options.hideOnClick) this.hide();
+ }.bind(this)
+ this.hidden = true;
+ toElement: function(){
+ return this.element;
+ inject: function(target, where){
+ where = where || this.options.inject ? this.options.inject.where : '' || this.target == document.body ? 'inside' : 'after';
+ target = target || this.options.inject ? this.options.inject.target : '' || this.target;
+ this.element.inject(target, where);
+ if (this.options.useIframeShim) {
+ this.shim = new IframeShim(this.element, this.options.iframeShimOptions);
+ this.addEvents({
+ show: this.shim.show.bind(this.shim),
+ hide: this.shim.hide.bind(this.shim),
+ destroy: this.shim.destroy.bind(this.shim)
+ this.resize(this.options.width, this.options.height);
+ this.element.position({
+ relativeTo: this.target,
+ position: 'topLeft',
+ ignoreMargins: !this.options.maskMargins,
+ ignoreScroll: this.target == document.body
+ return this;
+ resize: function(x, y){
+ var opt = {
+ styles: ['padding', 'border']
+ if (this.options.maskMargins) opt.styles.push('margin');
+ var dim = this.target.getComputedSize(opt);
+ if (this.target == document.body) {
+ var win = window.getSize();
+ if (dim.totalHeight < win.y) dim.totalHeight = win.y;
+ if (dim.totalWidth < win.x) dim.totalWidth = win.x;
+ this.element.setStyles({
+ width: $pick(x, dim.totalWidth, dim.x),
+ height: $pick(y, dim.totalHeight, dim.y)
+ return this;
+ show: function(){
+ if (!this.hidden) return this;
+ window.addEvent('resize', this.position);
+ this.position();
+ this.showMask.apply(this, arguments);
+ return this;
+ showMask: function(){
+ this.element.setStyle('display', 'block');
+ this.hidden = false;
+ this.fireEvent('show');
+ hide: function(){
+ if (this.hidden) return this;
+ window.removeEvent('resize', this.position);
+ this.hideMask.apply(this, arguments);
+ if (this.options.destroyOnHide) return this.destroy();
+ return this;
+ hideMask: function(){
+ this.element.setStyle('display', 'none');
+ this.fireEvent('hide');
+ this[this.hidden ? 'show' : 'hide']();
+ this.hide();
+ this.element.destroy();
+ this.fireEvent('destroy');
+ this.target.eliminate('mask');
+Element.Properties.mask = {
+ set: function(options){
+ var mask = this.retrieve('mask');
+ return this.eliminate('mask').store('mask:options', options);
+ get: function(options){
+ if (options || !this.retrieve('mask')){
+ if (this.retrieve('mask')) this.retrieve('mask').destroy();
+ if (options || !this.retrieve('mask:options')) this.set('mask', options);
+ this.store('mask', new Mask(this, this.retrieve('mask:options')));
+ return this.retrieve('mask');
+ mask: function(options){
+ this.get('mask', options).show();
+ return this;
+ unmask: function(){
+ this.get('mask').hide();
+ return this;
+script: Spinner.js
+description: Adds a semi-transparent overlay over a dom element with a spinnin ajax icon.
+authors:
+- Aaron Newton
+requires:
+- core:1.2.4/Fx.Tween
+- /Class.refactor
+- /Mask
+provides: [Spinner]
+var Spinner = new Class({
+ Extends: Mask,
+ options: {
+ /*message: false,*/
+ 'class':'spinner',
+ containerPosition: {},
+ content: {
+ 'class':'spinner-content'
+ messageContainer: {
+ 'class':'spinner-msg'
+ img: {
+ 'class':'spinner-img'
+ fxOptions: {
+ link: 'chain'
+ initialize: function(){
+ this.parent.apply(this, arguments);
+ this.target.store('spinner', this);
+ //add this to events for when noFx is true; parent methods handle hide/show
+ var deactivate = function(){ this.active = false; }.bind(this);
+ this.addEvents({
+ hide: deactivate,
+ show: deactivate
+ render: function(){
+ this.parent();
+ this.element.set('id', this.options.id || 'spinner-'+$time());
+ this.content = document.id(this.options.content) || new Element('div', this.options.content);
+ this.content.inject(this.element);
+ if (this.options.message) {
+ this.msg = document.id(this.options.message) || new Element('p', this.options.messageContainer).appendText(this.options.message);
+ this.msg.inject(this.content);
+ if (this.options.img) {
+ this.img = document.id(this.options.img) || new Element('div', this.options.img);
+ this.img.inject(this.content);
+ this.element.set('tween', this.options.fxOptions);
+ show: function(noFx){
+ if (this.active) return this.chain(this.show.bind(this));
+ if (!this.hidden) {
+ this.callChain.delay(20, this);
+ return this;
+ this.active = true;
+ return this.parent(noFx);
+ showMask: function(noFx){
+ var pos = function(){
+ this.content.position($merge({
+ }, this.options.containerPosition));
+ }.bind(this);
+ if (noFx) {
+ this.parent();
+ pos();
+ } else {
+ display: 'block',
+ opacity: 0
+ }).tween('opacity', this.options.style.opacity || 0.9);
+ pos();
+ this.callChain();
+ hide: function(noFx){
+ if (this.active) return this.chain(this.hide.bind(this));
+ if (this.hidden) {
+ return this;
+ hideMask: function(noFx){
+ if (noFx) return this.parent();
+ this.element.tween('opacity', 0).get('tween').chain(function(){
+ this.callChain();
+ }.bind(this));
+ this.content.destroy();
+ this.parent();
+ this.target.eliminate('spinner');
+Spinner.implement(new Chain);
+if (window.Request) {
+ Request = Class.refactor(Request, {
+ options: {
+ useSpinner: false,
+ spinnerOptions: {},
+ spinnerTarget: false
+ initialize: function(options){
+ this._send = this.send;
+ this.send = function(options){
+ if (this.spinner) this.spinner.chain(this._send.bind(this, options)).show();
+ else this._send(options);
+ return this;
+ this.previous(options);
+ var update = document.id(this.options.spinnerTarget) || document.id(this.options.update);
+ if (this.options.useSpinner && update) {
+ this.spinner = update.get('spinner', this.options.spinnerOptions);
+ ['onComplete', 'onException', 'onCancel'].each(function(event){
+ this.addEvent(event, this.spinner.hide.bind(this.spinner));
+ }, this);
+ getSpinner: function(){
+ return this.spinner;
+Element.Properties.spinner = {
+ var spinner = this.retrieve('spinner');
+ return this.eliminate('spinner').store('spinner:options', options);
+ if (options || !this.retrieve('spinner')){
+ if (this.retrieve('spinner')) this.retrieve('spinner').destroy();
+ if (options || !this.retrieve('spinner:options')) this.set('spinner', options);
+ new Spinner(this, this.retrieve('spinner:options'));
+ return this.retrieve('spinner');
+ spin: function(options){
+ this.get('spinner', options).show();
+ return this;
+ unspin: function(){
+ var opt = Array.link(arguments, {options: Object.type, callback: Function.type});
+ this.get('spinner', opt.options).hide(opt.callback);
+ return this;
+script: Form.Request.js
+description: Handles the basic functionality of submitting a form and updating a dom element with the result.
+authors:
+- Aaron Newton
+requires:
+- core:1.2.4/Element.Event
+- core:1.2.4/Request.HTML
+- /Class.Binds
+- /Class.Occlude
+- /Spinner
+provides: [Form.Request]
+if (!window.Form) window.Form = {};
+(function(){
+ Form.Request = new Class({
+ Binds: ['onSubmit', 'onFormValidate'],
+ options: {
+ //onFailure: $empty,
+ //onSuccess: #empty, //aliased to onComplete,
+ //onSend: $empty
+ requestOptions: {
+ evalScripts: true,
+ useSpinner: true,
+ emulation: false,
+ link: 'ignore'
+ extraData: {},
+ resetForm: true
+ property: 'form.request',
+ initialize: function(form, update, options) {
+ this.element = document.id(form);
+ this.update = document.id(update);
+ this.makeRequest();
+ if (this.options.resetForm) {
+ this.request.addEvent('success', function(){
+ $try(function(){ this.element.reset(); }.bind(this));
+ if (window.OverText) OverText.update();
+ }.bind(this));
+ this.attach();
+ toElement: function() {
+ makeRequest: function(){
+ this.request = new Request.HTML($merge({
+ update: this.update,
+ emulation: false,
+ spinnerTarget: this.element,
+ method: this.element.get('method') || 'post'
+ }, this.options.requestOptions)).addEvents({
+ success: function(text, xml){
+ ['complete', 'success'].each(function(evt){
+ this.fireEvent(evt, [this.update, text, xml]);
+ }, this);
+ }.bind(this),
+ failure: function(xhr){
+ this.fireEvent('complete').fireEvent('failure', xhr);
+ }.bind(this),
+ exception: function(){
+ this.fireEvent('failure', xhr);
+ }.bind(this)
+ attach: function(attach){
+ attach = $pick(attach, true);
+ method = attach ? 'addEvent' : 'removeEvent';
+ var fv = this.element.retrieve('validator');
+ if (fv) fv[method]('onFormValidate', this.onFormValidate);
+ if (!fv || !attach) this.element[method]('submit', this.onSubmit);
+ detach: function(){
+ this.attach(false);
+ //public method
+ enable: function(){
+ this.attach();
+ //public method
+ disable: function(){
+ this.detach();
+ onFormValidate: function(valid, form, e) {
+ if (valid || (fv && !fv.options.stopOnFailure)) {
+ if (e && e.stop) e.stop();
+ this.send();
+ onSubmit: function(e){
+ if (this.element.retrieve('validator')) {
+ //form validator was created after Form.Request
+ this.detach();
+ return;
+ e.stop();
+ this.send();
+ send: function(){
+ var str = this.element.toQueryString().trim();
+ var data = $H(this.options.extraData).toQueryString();
+ if (str) str += "&" + data;
+ else str = data;
+ this.fireEvent('send', [this.element, str.parseQueryString()]);
+ this.request.send({data: str, url: this.element.get("action")});
+ return this;
+ Element.Properties.formRequest = {
+ set: function(){
+ var opt = Array.link(arguments, {options: Object.type, update: Element.type, updateId: String.type});
+ var update = opt.update || opt.updateId;
+ var updater = this.retrieve('form.request');
+ if (update) {
+ if (updater) updater.update = document.id(update);
+ this.store('form.request:update', update);
+ if (opt.options) {
+ if (updater) updater.setOptions(opt.options);
+ this.store('form.request:options', opt.options);
+ return this;
+ get: function(){
+ if (opt.options || update || !this.retrieve('form.request')){
+ if (opt.options || !this.retrieve('form.request:options')) this.set('form.request', opt.options);
+ if (update) this.set('form.request', update);
+ this.store('form.request', new Form.Request(this, this.retrieve('form.request:update'), this.retrieve('form.request:options')));
+ return this.retrieve('form.request');
+ formUpdate: function(update, options){
+ this.get('form.request', update, options).send();
+ return this;
+script: Fx.Reveal.js
+description: Defines Fx.Reveal, a class that shows and hides elements with a transition.
+authors:
+- Aaron Newton
+requires:
+- core:1.2.4/Fx.Morph
+- /Element.Shortcuts
+- /Element.Measure
+provides: [Fx.Reveal]
+Fx.Reveal = new Class({
+ Extends: Fx.Morph,
+ options: {/*
+ onShow: $empty(thisElement),
+ onHide: $empty(thisElement),
+ onComplete: $empty(thisElement),
+ heightOverride: null,
+ widthOverride: null, */
+ link: 'cancel',
+ styles: ['padding', 'border', 'margin'],
+ transitionOpacity: !Browser.Engine.trident4,
+ mode: 'vertical',
+ display: 'block',
+ hideInputs: Browser.Engine.trident ? 'select, input, textarea, object, embed' : false
+ dissolve: function(){
+ try {
+ if (!this.hiding && !this.showing){
+ if (this.element.getStyle('display') != 'none'){
+ this.hiding = true;
+ this.showing = false;
+ this.cssText = this.element.style.cssText;
+ var startStyles = this.element.getComputedSize({
+ styles: this.options.styles,
+ mode: this.options.mode
+ this.element.setStyle('display', this.options.display);
+ if (this.options.transitionOpacity) startStyles.opacity = 1;
+ var zero = {};
+ $each(startStyles, function(style, name){
+ zero[name] = [style, 0];
+ }, this);
+ this.element.setStyle('overflow', 'hidden');
+ var hideThese = this.options.hideInputs ? this.element.getElements(this.options.hideInputs) : null;
+ this.$chain.unshift(function(){
+ if (this.hidden){
+ this.hiding = false;
+ startStyles[name] = style;
+ }, this);
+ this.element.style.cssText = this.cssText;
+ if (hideThese) hideThese.setStyle('visibility', 'visible');
+ this.fireEvent('hide', this.element);
+ this.callChain();
+ }.bind(this));
+ if (hideThese) hideThese.setStyle('visibility', 'hidden');
+ this.start(zero);
+ } else {
+ this.callChain.delay(10, this);
+ this.fireEvent('complete', this.element);
+ } else if (this.options.link == 'chain'){
+ this.chain(this.dissolve.bind(this));
+ } else if (this.options.link == 'cancel' && !this.hiding){
+ this.cancel();
+ this.dissolve();
+ } catch(e){
+ return this;
+ reveal: function(){
+ try {
+ if (!this.showing && !this.hiding){
+ if (this.element.getStyle('display') == 'none' ||
+ this.element.getStyle('visiblity') == 'hidden' ||
+ this.element.getStyle('opacity') == 0){
+ this.showing = true;
+ this.hiding = this.hidden = false;
+ var startStyles;
+ //toggle display, but hide it
+ this.element.measure(function(){
+ //create the styles for the opened/visible state
+ startStyles = this.element.getComputedSize({
+ }.bind(this));
+ //if we're overridding height/width
+ if ($chk(this.options.heightOverride)) startStyles.height = this.options.heightOverride.toInt();
+ if ($chk(this.options.widthOverride)) startStyles.width = this.options.widthOverride.toInt();
+ if (this.options.transitionOpacity) {
+ this.element.setStyle('opacity', 0);
+ startStyles.opacity = 1;
+ //create the zero state for the beginning of the transition
+ var zero = {
+ height: 0,
+ display: this.options.display
+ $each(startStyles, function(style, name){ zero[name] = 0; });
+ //set to zero
+ this.element.setStyles($merge(zero, {overflow: 'hidden'}));
+ //hide inputs
+ //start the effect
+ this.start(startStyles);
+ if (!this.hidden) this.showing = false;
+ this.callChain();
+ this.fireEvent('show', this.element);
+ }.bind(this));
+ } else {
+ this.callChain();
+ this.chain(this.reveal.bind(this));
+ } else if (this.options.link == 'cancel' && !this.showing){
+ this.cancel();
+ this.reveal();
+ } catch(e){
+ display: this.options.display,
+ visiblity: 'visible',
+ opacity: 1
+ return this;
+ this.reveal();
+ } else {
+ this.dissolve();
+ return this;
+ cancel: function(){
+ this.hidding = false;
+Element.Properties.reveal = {
+ var reveal = this.retrieve('reveal');
+ if (reveal) reveal.cancel();
+ return this.eliminate('reveal').store('reveal:options', options);
+ if (options || !this.retrieve('reveal')){
+ if (options || !this.retrieve('reveal:options')) this.set('reveal', options);
+ this.store('reveal', new Fx.Reveal(this, this.retrieve('reveal:options')));
+ return this.retrieve('reveal');
+Element.Properties.dissolve = Element.Properties.reveal;
+ reveal: function(options){
+ this.get('reveal', options).reveal();
+ return this;
+ dissolve: function(options){
+ this.get('reveal', options).dissolve();
+ return this;
+ nix: function(){
+ var params = Array.link(arguments, {destroy: Boolean.type, options: Object.type});
+ this.get('reveal', params.options).dissolve().chain(function(){
+ this[params.destroy ? 'destroy' : 'dispose']();
+ }.bind(this));
+ return this;
+ wink: function(){
+ var params = Array.link(arguments, {duration: Number.type, options: Object.type});
+ var reveal = this.get('reveal', params.options);
+ reveal.reveal().chain(function(){
+ (function(){
+ reveal.dissolve();
+ }).delay(params.duration || 2000);
+script: Form.Request.Append.js
+description: Handles the basic functionality of submitting a form and updating a dom element with the result. The result is appended to the DOM element instead of replacing its contents.
+authors:
+- Aaron Newton
+requires:
+- /Form.Request
+- /Fx.Reveal
+- /Elements.from
+provides: [Form.Request.Append]
+Form.Request.Append = new Class({
+ Extends: Form.Request,
+ options: {
+ //onBeforeEffect: $empty,
+ useReveal: true,
+ revealOptions: {},
+ inject: 'bottom'
+ url: this.element.get('action'),
+ method: this.element.get('method') || 'post',
+ }, this.options.requestOptions, {
+ evalScripts: false
+ ).addEvents({
+ success: function(tree, elements, html, javascript){
+ var container;
+ var kids = Elements.from(html);
+ if (kids.length == 1) {
+ container = kids[0];
+ } else {
+ container = new Element('div', {
+ styles: {
+ display: 'none'
+ }).adopt(kids);
+ container.inject(this.update, this.options.inject);
+ if (this.options.requestOptions.evalScripts) $exec(javascript);
+ this.fireEvent('beforeEffect', container);
+ var finish = function(){
+ this.fireEvent('success', [container, this.update, tree, elements, html, javascript]);
+ }.bind(this);
+ if (this.options.useReveal) {
+ container.get('reveal', this.options.revealOptions).chain(finish);
+ container.reveal();
+ } else {
+ finish();
+ }.bind(this),
+ }.bind(this)
+script: Form.Validator.English.js
+description: Form Validator messages for English.
+authors:
+- Aaron Newton
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.English]
+MooTools.lang.set('en-US', 'Form.Validator', {
+ required:'This field is required.',
+ minLength:'Please enter at least {minLength} characters (you entered {length} characters).',
+ maxLength:'Please enter no more than {maxLength} characters (you entered {length} characters).',
+ integer:'Please enter an integer in this field. Numbers with decimals (e.g. 1.25) are not permitted.',
+ numeric:'Please enter only numeric values in this field (i.e. "1" or "1.1" or "-1" or "-1.1").',
+ digits:'Please use numbers and punctuation only in this field (for example, a phone number with dashes or dots is permitted).',
+ alpha:'Please use letters only (a-z) with in this field. No spaces or other characters are allowed.',
+ alphanum:'Please use only letters (a-z) or numbers (0-9) only in this field. No spaces or other characters are allowed.',
+ dateSuchAs:'Please enter a valid date such as {date}',
+ dateInFormatMDY:'Please enter a valid date such as MM/DD/YYYY (i.e. "12/31/1999")',
+ email:'Please enter a valid email address. For example "fred at domain.com".',
+ url:'Please enter a valid URL such as http://www.google.com.',
+ currencyDollar:'Please enter a valid $ amount. For example $100.00 .',
+ oneRequired:'Please enter something for at least one of these inputs.',
+ errorPrefix: 'Error: ',
+ warningPrefix: 'Warning: ',
+ //Form.Validator.Extras
+ noSpace: 'There can be no spaces in this input.',
+ reqChkByNode: 'No items are selected.',
+ requiredChk: 'This field is required.',
+ reqChkByName: 'Please select a {label}.',
+ match: 'This field needs to match the {matchName} field',
+ startDate: 'the start date',
+ endDate: 'the end date',
+ currendDate: 'the current date',
+ afterDate: 'The date should be the same or after {label}.',
+ beforeDate: 'The date should be the same or before {label}.',
+ startMonth: 'Please select a start month',
+ sameMonth: 'These two dates must be in the same month - you must change one or the other.',
+ creditcard: 'The credit card number entered is invalid. Please check the number and try again. {length} digits entered.'
+script: Form.Validator.js
+description: A css-class based form validation system.
+authors:
+- Aaron Newton
+requires:
+- core:1.2.4/JSON
+- /Lang- /Class.Binds
+- /Date Element.Forms
+- /Form.Validator.English
+provides: [Form.Validator, InputValidator, FormValidator.BaseValidators]
+var InputValidator = new Class({
+ Implements: [Options],
+ options: {
+ errorMsg: 'Validation failed.',
+ test: function(field){return true;}
+ initialize: function(className, options){
+ this.className = className;
+ test: function(field, props){
+ if (document.id(field)) return this.options.test(document.id(field), props||this.getProps(field));
+ else return false;
+ getError: function(field, props){
+ var err = this.options.errorMsg;
+ if ($type(err) == 'function') err = err(document.id(field), props||this.getProps(field));
+ return err;
+ getProps: function(field){
+ if (!document.id(field)) return {};
+ return field.get('validatorProps');
+Element.Properties.validatorProps = {
+ set: function(props){
+ return this.eliminate('validatorProps').store('validatorProps', props);
+ get: function(props){
+ if (props) this.set(props);
+ if (this.retrieve('validatorProps')) return this.retrieve('validatorProps');
+ if (this.getProperty('validatorProps')){
+ try {
+ this.store('validatorProps', JSON.decode(this.getProperty('validatorProps')));
+ }catch(e){
+ return {};
+ } else {
+ var vals = this.get('class').split(' ').filter(function(cls){
+ return cls.test(':');
+ if (!vals.length){
+ this.store('validatorProps', {});
+ } else {
+ props = {};
+ vals.each(function(cls){
+ var split = cls.split(':');
+ if (split[1]) {
+ try {
+ props[split[0]] = JSON.decode(split[1]);
+ } catch(e) {}
+ this.store('validatorProps', props);
+ return this.retrieve('validatorProps');
+Form.Validator = new Class({
+ Implements:[Options, Events],
+ Binds: ['onSubmit'],
+ options: {/*
+ onFormValidate: $empty(isValid, form, event),
+ onElementValidate: $empty(isValid, field, className, warn),
+ onElementPass: $empty(field),
+ onElementFail: $empty(field, validatorsFailed) */
+ fieldSelectors: 'input, select, textarea',
+ ignoreHidden: true,
+ ignoreDisabled: true,
+ useTitles: false,
+ evaluateOnSubmit: true,
+ evaluateFieldsOnBlur: true,
+ evaluateFieldsOnChange: true,
+ serial: true,
+ stopOnFailure: true,
+ warningPrefix: function(){
+ return Form.Validator.getMsg('warningPrefix') || 'Warning: ';
+ errorPrefix: function(){
+ return Form.Validator.getMsg('errorPrefix') || 'Error: ';
+ initialize: function(form, options){
+ this.element.store('validator', this);
+ this.warningPrefix = $lambda(this.options.warningPrefix)();
+ this.errorPrefix = $lambda(this.options.errorPrefix)();
+ if (this.options.evaluateOnSubmit) this.element.addEvent('submit', this.onSubmit);
+ if (this.options.evaluateFieldsOnBlur || this.options.evaluateFieldsOnChange) this.watchFields(this.getFields());
+ getFields: function(){
+ return (this.fields = this.element.getElements(this.options.fieldSelectors));
+ watchFields: function(fields){
+ fields.each(function(el){
+ if (this.options.evaluateFieldsOnBlur)
+ el.addEvent('blur', this.validationMonitor.pass([el, false], this));
+ if (this.options.evaluateFieldsOnChange)
+ el.addEvent('change', this.validationMonitor.pass([el, true], this));
+ }, this);
+ validationMonitor: function(){
+ $clear(this.timer);
+ this.timer = this.validateField.delay(50, this, arguments);
+ onSubmit: function(event){
+ if (!this.validate(event) && event) event.preventDefault();
+ else this.reset();
+ reset: function(){
+ this.getFields().each(this.resetField, this);
+ return this;
+ validate: function(event){
+ var result = this.getFields().map(function(field){
+ return this.validateField(field, true);
+ }, this).every(function(v){ return v;});
+ this.fireEvent('formValidate', [result, this.element, event]);
+ if (this.options.stopOnFailure && !result && event) event.preventDefault();
+ return result;
+ validateField: function(field, force){
+ if (this.paused) return true;
+ field = document.id(field);
+ var passed = !field.hasClass('validation-failed');
+ var failed, warned;
+ if (this.options.serial && !force){
+ failed = this.element.getElement('.validation-failed');
+ warned = this.element.getElement('.warning');
+ if (field && (!failed || force || field.hasClass('validation-failed') || (failed && !this.options.serial))){
+ var validators = field.className.split(' ').some(function(cn){
+ return this.getValidator(cn);
+ }, this);
+ var validatorsFailed = [];
+ field.className.split(' ').each(function(className){
+ if (className && !this.test(className, field)) validatorsFailed.include(className);
+ }, this);
+ passed = validatorsFailed.length === 0;
+ if (validators && !field.hasClass('warnOnly')){
+ if (passed){
+ field.addClass('validation-passed').removeClass('validation-failed');
+ this.fireEvent('elementPass', field);
+ } else {
+ field.addClass('validation-failed').removeClass('validation-passed');
+ this.fireEvent('elementFail', [field, validatorsFailed]);
+ if (!warned){
+ var warnings = field.className.split(' ').some(function(cn){
+ if (cn.test('^warn-') || field.hasClass('warnOnly'))
+ return this.getValidator(cn.replace(/^warn-/,''));
+ else return null;
+ }, this);
+ field.removeClass('warning');
+ var warnResult = field.className.split(' ').map(function(cn){
+ return this.test(cn.replace(/^warn-/,''), field, true);
+ else return null;
+ }, this);
+ return passed;
+ test: function(className, field, warn){
+ if((this.options.ignoreHidden && !field.isVisible()) || (this.options.ignoreDisabled && field.get('disabled'))) return true;
+ var validator = this.getValidator(className);
+ if (field.hasClass('ignoreValidation')) return true;
+ warn = $pick(warn, false);
+ if (field.hasClass('warnOnly')) warn = true;
+ var isValid = validator ? validator.test(field) : true;
+ if (validator && field.isVisible()) this.fireEvent('elementValidate', [isValid, field, className, warn]);
+ if (warn) return true;
+ return isValid;
+ resetField: function(field){
+ if (field){
+ if (className.test('^warn-')) className = className.replace(/^warn-/, '');
+ field.removeClass('validation-failed');
+ field.removeClass('validation-passed');
+ }, this);
+ return this;
+ stop: function(){
+ this.paused = true;
+ return this;
+ start: function(){
+ this.paused = false;
+ return this;
+ ignoreField: function(field, warn){
+ if (field){
+ this.enforceField(field);
+ if (warn) field.addClass('warnOnly');
+ else field.addClass('ignoreValidation');
+ return this;
+ enforceField: function(field){
+ if (field) field.removeClass('warnOnly').removeClass('ignoreValidation');
+ return this;
+Form.Validator.getMsg = function(key){
+ return MooTools.lang.get('Form.Validator', key);
+Form.Validator.adders = {
+ validators:{},
+ add : function(className, options){
+ this.validators[className] = new InputValidator(className, options);
+ //if this is a class (this method is used by instances of Form.Validator and the Form.Validator namespace)
+ //extend these validators into it
+ //this allows validators to be global and/or per instance
+ if (!this.initialize){
+ this.implement({
+ validators: this.validators
+ addAllThese : function(validators){
+ $A(validators).each(function(validator){
+ this.add(validator[0], validator[1]);
+ }, this);
+ getValidator: function(className){
+ return this.validators[className.split(':')[0]];
+$extend(Form.Validator, Form.Validator.adders);
+Form.Validator.implement(Form.Validator.adders);
+Form.Validator.add('IsEmpty', {
+ errorMsg: false,
+ test: function(element){
+ if (element.type == 'select-one' || element.type == 'select')
+ return !(element.selectedIndex >= 0 && element.options[element.selectedIndex].value != '');
+ else
+ return ((element.get('value') == null) || (element.get('value').length == 0));
+Form.Validator.addAllThese([
+ ['required', {
+ errorMsg: function(){
+ return Form.Validator.getMsg('required');
+ return !Form.Validator.getValidator('IsEmpty').test(element);
+ ['minLength', {
+ errorMsg: function(element, props){
+ if ($type(props.minLength))
+ return Form.Validator.getMsg('minLength').substitute({minLength:props.minLength,length:element.get('value').length });
+ else return '';
+ test: function(element, props){
+ if ($type(props.minLength)) return (element.get('value').length >= $pick(props.minLength, 0));
+ else return true;
+ ['maxLength', {
+ //props is {maxLength:10}
+ if ($type(props.maxLength))
+ return Form.Validator.getMsg('maxLength').substitute({maxLength:props.maxLength,length:element.get('value').length });
+ else return '';
+ //if the value is <= than the maxLength value, element passes test
+ return (element.get('value').length <= $pick(props.maxLength, 10000));
+ ['validate-integer', {
+ errorMsg: Form.Validator.getMsg.pass('integer'),
+ return Form.Validator.getValidator('IsEmpty').test(element) || (/^(-?[1-9]\d*|0)$/).test(element.get('value'));
+ ['validate-numeric', {
+ errorMsg: Form.Validator.getMsg.pass('numeric'),
+ (/^-?(?:0$0(?=\d*\.)|[1-9]|0)\d*(\.\d+)?$/).test(element.get('value'));
+ ['validate-digits', {
+ errorMsg: Form.Validator.getMsg.pass('digits'),
+ return Form.Validator.getValidator('IsEmpty').test(element) || (/^[\d() .:\-\+#]+$/.test(element.get('value')));
+ ['validate-alpha', {
+ errorMsg: Form.Validator.getMsg.pass('alpha'),
+ return Form.Validator.getValidator('IsEmpty').test(element) || (/^[a-zA-Z]+$/).test(element.get('value'));
+ ['validate-alphanum', {
+ errorMsg: Form.Validator.getMsg.pass('alphanum'),
+ return Form.Validator.getValidator('IsEmpty').test(element) || !(/\W/).test(element.get('value'));
+ ['validate-date', {
+ if (Date.parse){
+ var format = props.dateFormat || '%x';
+ return Form.Validator.getMsg('dateSuchAs').substitute({date: new Date().format(format)});
+ } else {
+ return Form.Validator.getMsg('dateInFormatMDY');
+ if (Form.Validator.getValidator('IsEmpty').test(element)) return true;
+ var d;
+ if (Date.parse){
+ d = Date.parse(element.get('value'));
+ var formatted = d.format(format);
+ if (formatted != 'invalid date') element.set('value', formatted);
+ return !isNaN(d);
+ } else {
+ var regex = /^(\d{2})\/(\d{2})\/(\d{4})$/;
+ if (!regex.test(element.get('value'))) return false;
+ d = new Date(element.get('value').replace(regex, '$1/$2/$3'));
+ return (parseInt(RegExp.$1, 10) == (1 + d.getMonth())) &&
+ (parseInt(RegExp.$2, 10) == d.getDate()) &&
+ (parseInt(RegExp.$3, 10) == d.getFullYear());
+ ['validate-email', {
+ errorMsg: Form.Validator.getMsg.pass('email'),
+ return Form.Validator.getValidator('IsEmpty').test(element) || (/^[A-Z0-9._%+-]+@[A-Z0-9.-]+\.[A-Z]{2,4}$/i).test(element.get('value'));
+ ['validate-url', {
+ errorMsg: Form.Validator.getMsg.pass('url'),
+ return Form.Validator.getValidator('IsEmpty').test(element) || (/^(https?|ftp|rmtp|mms):\/\/(([A-Z0-9][A-Z0-9_-]*)(\.[A-Z0-9][A-Z0-9_-]*)+)(:(\d+))?\/?/i).test(element.get('value'));
+ ['validate-currency-dollar', {
+ errorMsg: Form.Validator.getMsg.pass('currencyDollar'),
+ // [$]1[##][,###]+[.##]
+ // [$]1###+[.##]
+ // [$]0.##
+ return Form.Validator.getValidator('IsEmpty').test(element) || (/^\$?\-?([1-9]{1}[0-9]{0,2}(\,[0-9]{3})*(\.[0-9]{0,2})?|[1-9]{1}\d*(\.[0-9]{0,2})?|0(\.[0-9]{0,2})?|(\.[0-9]{1,2})?)$/).test(element.get('value'));
+ ['validate-one-required', {
+ errorMsg: Form.Validator.getMsg.pass('oneRequired'),
+ var p = document.id(props['validate-one-required']) || element.getParent();
+ return p.getElements('input').some(function(el){
+ if (['checkbox', 'radio'].contains(el.get('type'))) return el.get('checked');
+ return el.get('value');
+Element.Properties.validator = {
+ var validator = this.retrieve('validator');
+ if (validator) validator.setOptions(options);
+ return this.store('validator:options');
+ if (options || !this.retrieve('validator')){
+ if (options || !this.retrieve('validator:options')) this.set('validator', options);
+ this.store('validator', new Form.Validator(this, this.retrieve('validator:options')));
+ return this.retrieve('validator');
+ validate: function(options){
+ this.set('validator', options);
+ return this.get('validator', options).validate();
+//legacy
+var FormValidator = Form.Validator;/*
+script: Form.Validator.Inline.js
+description: Extends Form.Validator to add inline messages.
+authors:
+- Aaron Newton
+requires:
+- /Form.Validator
+provides: [Form.Validator.Inline]
+Form.Validator.Inline = new Class({
+ Extends: Form.Validator,
+ options: {
+ scrollToErrorsOnSubmit: true,
+ scrollFxOptions: {
+ transition: 'quad:out',
+ offset: {
+ y: -20
+ this.parent(form, options);
+ this.addEvent('onElementValidate', function(isValid, field, className, warn){
+ if (!isValid && validator.getError(field)){
+ if (warn) field.addClass('warning');
+ var advice = this.makeAdvice(className, field, validator.getError(field), warn);
+ this.insertAdvice(advice, field);
+ this.showAdvice(className, field);
+ } else {
+ this.hideAdvice(className, field);
+ makeAdvice: function(className, field, error, warn){
+ var errorMsg = (warn)?this.warningPrefix:this.errorPrefix;
+ errorMsg += (this.options.useTitles) ? field.title || error:error;
+ var cssClass = (warn) ? 'warning-advice' : 'validation-advice';
+ var advice = this.getAdvice(className, field);
+ if(advice) {
+ advice = advice.set('html', errorMsg);
+ } else {
+ advice = new Element('div', {
+ html: errorMsg,
+ styles: { display: 'none' },
+ id: 'advice-' + className + '-' + this.getFieldId(field)
+ }).addClass(cssClass);
+ field.store('advice-' + className, advice);
+ return advice;
+ getFieldId : function(field){
+ return field.id ? field.id : field.id = 'input_' + field.name;
+ showAdvice: function(className, field){
+ if (advice && !field.retrieve(this.getPropName(className))
+ && (advice.getStyle('display') == 'none'
+ || advice.getStyle('visiblity') == 'hidden'
+ || advice.getStyle('opacity') == 0)){
+ field.store(this.getPropName(className), true);
+ if (advice.reveal) advice.reveal();
+ else advice.setStyle('display', 'block');
+ hideAdvice: function(className, field){
+ if (advice && field.retrieve(this.getPropName(className))){
+ field.store(this.getPropName(className), false);
+ //if Fx.Reveal.js is present, transition the advice out
+ if (advice.dissolve) advice.dissolve();
+ else advice.setStyle('display', 'none');
+ getPropName: function(className){
+ return 'advice' + className;
+ if (!field) return this;
+ this.parent(field);
+ }, this);
+ return this;
+ getAllAdviceMessages: function(field, force){
+ var advice = [];
+ if (field.hasClass('ignoreValidation') && !force) return advice;
+ var warner = cn.test('^warn-') || field.hasClass('warnOnly');
+ if (warner) cn = cn.replace(/^warn-/, '');
+ var validator = this.getValidator(cn);
+ if (!validator) return;
+ advice.push({
+ message: validator.getError(field),
+ warnOnly: warner,
+ passed: validator.test(),
+ validator: validator
+ }, this);
+ return advice;
+ getAdvice: function(className, field){
+ return field.retrieve('advice-' + className);
+ insertAdvice: function(advice, field){
+ //Check for error position prop
+ var props = field.get('validatorProps');
+ //Build advice
+ if (!props.msgPos || !document.id(props.msgPos)){
+ if(field.type.toLowerCase() == 'radio') field.getParent().adopt(advice);
+ else advice.inject(document.id(field), 'after');
+ } else {
+ document.id(props.msgPos).grab(advice);
+ var result = this.parent(field, force);
+ if (this.options.scrollToErrorsOnSubmit && !result){
+ var failed = document.id(this).getElement('.validation-failed');
+ var par = document.id(this).getParent();
+ while (par != document.body && par.getScrollSize().y == par.getSize().y){
+ par = par.getParent();
+ var fx = par.retrieve('fvScroller');
+ if (!fx && window.Fx && Fx.Scroll){
+ fx = new Fx.Scroll(par, this.options.scrollFxOptions);
+ par.store('fvScroller', fx);
+ if (failed){
+ if (fx) fx.toElement(failed);
+ else par.scrollTo(par.getScroll().x, failed.getPosition(par).y - 20);
+ return result;
+script: Form.Validator.Extras.js
+description: Additional validators for the Form.Validator class.
+authors:
+- Aaron Newton
+requires:
+- /Form.Validator
+provides: [Form.Validator.Extras]
+ ['validate-enforce-oncheck', {
+ if (element.checked){
+ var fv = element.getParent('form').retrieve('validator');
+ if (!fv) return true;
+ (props.toEnforce || document.id(props.enforceChildrenOf).getElements('input, select, textarea')).map(function(item){
+ fv.enforceField(item);
+ return true;
+ ['validate-ignore-oncheck', {
+ (props.toIgnore || document.id(props.ignoreChildrenOf).getElements('input, select, textarea')).each(function(item){
+ fv.ignoreField(item);
+ fv.resetField(item);
+ return true;
+ ['validate-nospace', {
+ return Form.Validator.getMsg('noSpace');
+ return !element.get('value').test(/\s/);
+ ['validate-toggle-oncheck', {
+ var eleArr = props.toToggle || document.id(props.toToggleChildrenOf).getElements('input, select, textarea');
+ if (!element.checked){
+ eleArr.each(function(item){
+ } else {
+ return true;
+ ['validate-reqchk-bynode', {
+ return Form.Validator.getMsg('reqChkByNode');
+ return (document.id(props.nodeId).getElements(props.selector || 'input[type=checkbox], input[type=radio]')).some(function(item){
+ return item.checked;
+ ['validate-required-check', {
+ return props.useTitle ? element.get('title') : Form.Validator.getMsg('requiredChk');
+ return !!element.checked;
+ ['validate-reqchk-byname', {
+ return Form.Validator.getMsg('reqChkByName').substitute({label: props.label || element.get('type')});
+ var grpName = props.groupName || element.get('name');
+ var oneCheckedItem = $$(document.getElementsByName(grpName)).some(function(item, index){
+ if (oneCheckedItem && fv) fv.resetField(element);
+ return oneCheckedItem;
+ ['validate-match', {
+ return Form.Validator.getMsg('match').substitute({matchName: props.matchName || document.id(props.matchInput).get('name')});
+ var eleVal = element.get('value');
+ var matchVal = document.id(props.matchInput) && document.id(props.matchInput).get('value');
+ return eleVal && matchVal ? eleVal == matchVal : true;
+ ['validate-after-date', {
+ return Form.Validator.getMsg('afterDate').substitute({
+ label: props.afterLabel || (props.afterElement ? Form.Validator.getMsg('startDate') : Form.Validator.getMsg('currentDate'))
+ var start = document.id(props.afterElement) ? Date.parse(document.id(props.afterElement).get('value')) : new Date();
+ var end = Date.parse(element.get('value'));
+ return end && start ? end >= start : true;
+ ['validate-before-date', {
+ return Form.Validator.getMsg('beforeDate').substitute({
+ label: props.beforeLabel || (props.beforeElement ? Form.Validator.getMsg('endDate') : Form.Validator.getMsg('currentDate'))
+ var start = Date.parse(element.get('value'));
+ var end = document.id(props.beforeElement) ? Date.parse(document.id(props.beforeElement).get('value')) : new Date();
+ ['validate-custom-required', {
+ return element.get('value') != props.emptyValue;
+ ['validate-same-month', {
+ var startMo = document.id(props.sameMonthAs) && document.id(props.sameMonthAs).get('value');
+ if (eleVal != '') return Form.Validator.getMsg(startMo ? 'sameMonth' : 'startMonth');
+ var d1 = Date.parse(element.get('value'));
+ var d2 = Date.parse(document.id(props.sameMonthAs) && document.id(props.sameMonthAs).get('value'));
+ return d1 && d2 ? d1.format('%B') == d2.format('%B') : true;
+ ['validate-cc-num', {
+ errorMsg: function(element){
+ var ccNum = element.get('value').replace(/[^0-9]/g, '');
+ return Form.Validator.getMsg('creditcard').substitute({length: ccNum.length});
+ // required is a different test
+ if (Form.Validator.getValidator('IsEmpty').test(element)) { return true; }
+ // Clean number value
+ var ccNum = element.get('value');
+ ccNum = ccNum.replace(/[^0-9]/g, '');
+ var valid_type = false;
+ if (ccNum.test(/^4[0-9]{12}([0-9]{3})?$/)) valid_type = 'Visa';
+ else if (ccNum.test(/^5[1-5]([0-9]{14})$/)) valid_type = 'Master Card';
+ else if (ccNum.test(/^3[47][0-9]{13}$/)) valid_type = 'American Express';
+ else if (ccNum.test(/^6011[0-9]{12}$/)) valid_type = 'Discover';
+ if (valid_type) {
+ var sum = 0;
+ var cur = 0;
+ for(var i=ccNum.length-1; i>=0; --i) {
+ cur = ccNum.charAt(i).toInt();
+ if (cur == 0) { continue; }
+ if ((ccNum.length-i) % 2 == 0) { cur += cur; }
+ if (cur > 9) { cur = cur.toString().charAt(0).toInt() + cur.toString().charAt(1).toInt(); }
+ sum += cur;
+ if ((sum % 10) == 0) { return true; }
+ var chunks = '';
+ while (ccNum != '') {
+ chunks += ' ' + ccNum.substr(0,4);
+ ccNum = ccNum.substr(4);
+ element.getParent('form').retrieve('validator').ignoreField(element);
+ element.set('value', chunks.clean());
+ element.getParent('form').retrieve('validator').enforceField(element);
+ return false;
+script: OverText.js
+description: Shows text over an input that disappears when the user clicks into it. The text remains hidden if the user adds a value.
+license: MIT-style license
+authors:
+- Aaron Newton
+requires:
+- /Class.Binds
+- /Class.Occlude
+provides: [OverText]
+var OverText = new Class({
+ Binds: ['reposition', 'assert', 'focus', 'hide'],
+ options: {/*
+ textOverride: null,
+ onFocus: $empty()
+ onTextHide: $empty(textEl, inputEl),
+ onTextShow: $empty(textEl, inputEl), */
+ element: 'label',
+ positionOptions: {
+ position: 'upperLeft',
+ edge: 'upperLeft',
+ offset: {
+ x: 4,
+ y: 2
+ poll: false,
+ pollInterval: 250,
+ wrap: false
+ property: 'OverText',
+ this.attach(this.element);
+ OverText.instances.push(this);
+ if (this.options.poll) this.poll();
+ return this;
+ attach: function(){
+ var val = this.options.textOverride || this.element.get('alt') || this.element.get('title');
+ if (!val) return;
+ this.text = new Element(this.options.element, {
+ 'class': 'overTxtLabel',
+ styles: {
+ lineHeight: 'normal',
+ cursor: 'text'
+ html: val,
+ events: {
+ click: this.hide.pass(this.options.element == 'label', this)
+ }).inject(this.element, 'after');
+ if (this.options.element == 'label') {
+ if (!this.element.get('id')) this.element.set('id', 'input_' + new Date().getTime());
+ this.text.set('for', this.element.get('id'));
+ if (this.options.wrap) {
+ this.textHolder = new Element('div', {
+ styles: {
+ position: 'relative'
+ 'class':'overTxtWrapper'
+ }).adopt(this.text).inject(this.element, 'before');
+ this.element.addEvents({
+ focus: this.focus,
+ blur: this.assert,
+ change: this.assert
+ }).store('OverTextDiv', this.text);
+ window.addEvent('resize', this.reposition.bind(this));
+ this.assert(true);
+ this.reposition();
+ wrap: function(){
+ startPolling: function(){
+ this.pollingPaused = false;
+ return this.poll();
+ poll: function(stop){
+ //start immediately
+ //pause on focus
+ //resumeon blur
+ if (this.poller && !stop) return this;
+ var test = function(){
+ if (!this.pollingPaused) this.assert(true);
+ }.bind(this);
+ if (stop) $clear(this.poller);
+ else this.poller = test.periodical(this.options.pollInterval, this);
+ return this;
+ stopPolling: function(){
+ this.pollingPaused = true;
+ return this.poll(true);
+ focus: function(){
+ if (this.text && (!this.text.isDisplayed() || this.element.get('disabled'))) return;
+ this.hide();
+ hide: function(suppressFocus, force){
+ if (this.text && (this.text.isDisplayed() && (!this.element.get('disabled') || force))){
+ this.text.hide();
+ this.fireEvent('textHide', [this.text, this.element]);
+ if (!suppressFocus){
+ try {
+ this.element.fireEvent('focus');
+ this.element.focus();
+ } catch(e){} //IE barfs if you call focus on hidden elements
+ return this;
+ show: function(){
+ if (this.text && !this.text.isDisplayed()){
+ this.text.show();
+ this.fireEvent('textShow', [this.text, this.element]);
+ return this;
+ assert: function(suppressFocus){
+ this[this.test() ? 'show' : 'hide'](suppressFocus);
+ test: function(){
+ var v = this.element.get('value');
+ return !v;
+ reposition: function(){
+ if (!this.element.isVisible()) return this.stopPolling().hide();
+ if (this.text && this.test()) this.text.position($merge(this.options.positionOptions, {relativeTo: this.element}));
+ return this;
+OverText.instances = [];
+$extend(OverText, {
+ each: function(fn) {
+ return OverText.instances.map(function(ot, i){
+ if (ot.element && ot.text) return fn.apply(OverText, [ot, i]);
+ return null; //the input or the text was destroyed
+ update: function(){
+ return OverText.each(function(ot){
+ return ot.reposition();
+ hideAll: function(){
+ return ot.hide(true, true);
+ showAll: function(){
+ return OverText.each(function(ot) {
+ return ot.show();
+if (window.Fx && Fx.Reveal) {
+ Fx.Reveal.implement({
+ hideInputs: Browser.Engine.trident ? 'select, input, textarea, object, embed, .overTxtLabel' : false
+script: Fx.Elements.js
+description: Effect to change any number of CSS properties of any number of Elements.
+authors:
+- Valerio Proietti
+requires:
+- core:1.2.4/Fx.CSS
+- /MooTools.More
+provides: [Fx.Elements]
+Fx.Elements = new Class({
+ Extends: Fx.CSS,
+ initialize: function(elements, options){
+ this.elements = this.subject = $$(elements);
+ this.parent(options);
+ compute: function(from, to, delta){
+ var now = {};
+ for (var i in from){
+ var iFrom = from[i], iTo = to[i], iNow = now[i] = {};
+ for (var p in iFrom) iNow[p] = this.parent(iFrom[p], iTo[p], delta);
+ return now;
+ set: function(now){
+ for (var i in now){
+ var iNow = now[i];
+ for (var p in iNow) this.render(this.elements[i], p, iNow[p], this.options.unit);
+ return this;
+ start: function(obj){
+ if (!this.check(obj)) return this;
+ var from = {}, to = {};
+ for (var i in obj){
+ var iProps = obj[i], iFrom = from[i] = {}, iTo = to[i] = {};
+ for (var p in iProps){
+ var parsed = this.prepare(this.elements[i], p, iProps[p]);
+ iFrom[p] = parsed.from;
+ iTo[p] = parsed.to;
+ return this.parent(from, to);
+script: Fx.Accordion.js
+description: An Fx.Elements extension which allows you to easily create accordion type controls.
+authors:
+- Valerio Proietti
+requires:
+- /Fx.Elements
+provides: [Fx.Accordion]
+Fx.Accordion = new Class({
+ Extends: Fx.Elements,
+ options: {/*
+ onActive: $empty(toggler, section),
+ onBackground: $empty(toggler, section),
+ fixedHeight: false,
+ fixedWidth: false,
+ display: 0,
+ show: false,
+ height: true,
+ width: false,
+ opacity: true,
+ alwaysHide: false,
+ trigger: 'click',
+ initialDisplayFx: true,
+ returnHeightToAuto: true
+ 'container': Element.type, //deprecated
+ 'options': Object.type,
+ 'togglers': $defined,
+ 'elements': $defined
+ this.parent(params.elements, params.options);
+ this.togglers = $$(params.togglers);
+ this.previous = -1;
+ this.internalChain = new Chain();
+ if (this.options.alwaysHide) this.options.wait = true;
+ if ($chk(this.options.show)){
+ this.options.display = false;
+ this.previous = this.options.show;
+ if (this.options.start){
+ this.options.show = false;
+ this.effects = {};
+ if (this.options.opacity) this.effects.opacity = 'fullOpacity';
+ if (this.options.width) this.effects.width = this.options.fixedWidth ? 'fullWidth' : 'offsetWidth';
+ if (this.options.height) this.effects.height = this.options.fixedHeight ? 'fullHeight' : 'scrollHeight';
+ for (var i = 0, l = this.togglers.length; i < l; i++) this.addSection(this.togglers[i], this.elements[i]);
+ this.elements.each(function(el, i){
+ if (this.options.show === i){
+ this.fireEvent('active', [this.togglers[i], el]);
+ } else {
+ for (var fx in this.effects) el.setStyle(fx, 0);
+ }, this);
+ if ($chk(this.options.display) || this.options.initialDisplayFx === false) this.display(this.options.display, this.options.initialDisplayFx);
+ if (this.options.fixedHeight !== false) this.options.returnHeightToAuto = false;
+ this.addEvent('complete', this.internalChain.callChain.bind(this.internalChain));
+ addSection: function(toggler, element){
+ toggler = document.id(toggler);
+ element = document.id(element);
+ var test = this.togglers.contains(toggler);
+ this.togglers.include(toggler);
+ this.elements.include(element);
+ var idx = this.togglers.indexOf(toggler);
+ var displayer = this.display.bind(this, idx);
+ toggler.store('accordion:display', displayer);
+ toggler.addEvent(this.options.trigger, displayer);
+ if (this.options.height) element.setStyles({'padding-top': 0, 'border-top': 'none', 'padding-bottom': 0, 'border-bottom': 'none'});
+ if (this.options.width) element.setStyles({'padding-left': 0, 'border-left': 'none', 'padding-right': 0, 'border-right': 'none'});
+ element.fullOpacity = 1;
+ if (this.options.fixedWidth) element.fullWidth = this.options.fixedWidth;
+ if (this.options.fixedHeight) element.fullHeight = this.options.fixedHeight;
+ element.setStyle('overflow', 'hidden');
+ if (!test){
+ for (var fx in this.effects) element.setStyle(fx, 0);
+ return this;
+ this.togglers.each(function(toggler) {
+ toggler.removeEvent(this.options.trigger, toggler.retrieve('accordion:display'));
+ }, this);
+ display: function(index, useFx){
+ if (!this.check(index, useFx)) return this;
+ useFx = $pick(useFx, true);
+ if (this.options.returnHeightToAuto){
+ var prev = this.elements[this.previous];
+ if (prev && !this.selfHidden){
+ for (var fx in this.effects){
+ prev.setStyle(fx, prev[this.effects[fx]]);
+ index = ($type(index) == 'element') ? this.elements.indexOf(index) : index;
+ if ((this.timer && this.options.wait) || (index === this.previous && !this.options.alwaysHide)) return this;
+ this.previous = index;
+ var obj = {};
+ obj[i] = {};
+ var hide;
+ if (i != index){
+ hide = true;
+ } else if (this.options.alwaysHide && ((el.offsetHeight > 0 && this.options.height) || el.offsetWidth > 0 && this.options.width)){
+ hide = true;
+ this.selfHidden = true;
+ this.fireEvent(hide ? 'background' : 'active', [this.togglers[i], el]);
+ for (var fx in this.effects) obj[i][fx] = hide ? 0 : el[this.effects[fx]];
+ }, this);
+ this.internalChain.chain(function(){
+ if (this.options.returnHeightToAuto && !this.selfHidden){
+ var el = this.elements[index];
+ if (el) el.setStyle('height', 'auto');
+ }.bind(this));
+ return useFx ? this.start(obj) : this.set(obj);
+ Compatibility with 1.2.0
+var Accordion = new Class({
+ Extends: Fx.Accordion,
+ var params = Array.link(arguments, {'container': Element.type});
+ this.container = params.container;
+ addSection: function(toggler, element, pos){
+ var len = this.togglers.length;
+ if (len && (!test || pos)){
+ pos = $pick(pos, len - 1);
+ toggler.inject(this.togglers[pos], 'before');
+ element.inject(toggler, 'after');
+ } else if (this.container && !test){
+ toggler.inject(this.container);
+ element.inject(this.container);
+ return this.parent.apply(this, arguments);
+script: Fx.Move.js
+description: Defines Fx.Move, a class that works with Element.Position.js to transition an element from one location to another.
+authors:
+- Aaron Newton
+requires:
+provides: [Fx.Move]
+Fx.Move = new Class({
+ options: {
+ position: 'center',
+ edge: false,
+ start: function(destination){
+ return this.parent(this.element.position($merge(this.options, destination, {returnPos: true})));
+Element.Properties.move = {
+ var morph = this.retrieve('move');
+ if (morph) morph.cancel();
+ return this.eliminate('move').store('move:options', $extend({link: 'cancel'}, options));
+ if (options || !this.retrieve('move')){
+ if (options || !this.retrieve('move:options')) this.set('move', options);
+ this.store('move', new Fx.Move(this, this.retrieve('move:options')));
+ return this.retrieve('move');
+Element.implement({
+ move: function(options){
+ this.get('move').start(options);
+ return this;
+script: Fx.Scroll.js
+description: Effect to smoothly scroll any element, including the window.
+authors:
+- Valerio Proietti
+requires:
+- core:1.2.4/Fx
+- core:1.2.4/Element.Dimensions
+- /MooTools.More
+provides: [Fx.Scroll]
+Fx.Scroll = new Class({
+ Extends: Fx,
+ options: {
+ wheelStops: true
+ this.element = this.subject = document.id(element);
+ var cancel = this.cancel.bind(this, false);
+ if ($type(this.element) != 'element') this.element = document.id(this.element.getDocument().body);
+ var stopper = this.element;
+ if (this.options.wheelStops){
+ this.addEvent('start', function(){
+ stopper.addEvent('mousewheel', cancel);
+ }, true);
+ this.addEvent('complete', function(){
+ stopper.removeEvent('mousewheel', cancel);
+ }, true);
+ set: function(){
+ var now = Array.flatten(arguments);
+ if (Browser.Engine.gecko) now = [Math.round(now[0]), Math.round(now[1])];
+ this.element.scrollTo(now[0], now[1]);
+ return [0, 1].map(function(i){
+ return Fx.compute(from[i], to[i], delta);
+ start: function(x, y){
+ if (!this.check(x, y)) return this;
+ var scrollSize = this.element.getScrollSize(),
+ scroll = this.element.getScroll(),
+ values = {x: x, y: y};
+ for (var z in values){
+ var max = scrollSize[z];
+ if ($chk(values[z])) values[z] = ($type(values[z]) == 'number') ? values[z] : max;
+ else values[z] = scroll[z];
+ values[z] += this.options.offset[z];
+ return this.parent([scroll.x, scroll.y], [values.x, values.y]);
+ toTop: function(){
+ return this.start(false, 0);
+ toLeft: function(){
+ return this.start(0, false);
+ toRight: function(){
+ return this.start('right', false);
+ toBottom: function(){
+ return this.start(false, 'bottom');
+ toElement: function(el){
+ var position = document.id(el).getPosition(this.element);
+ return this.start(position.x, position.y);
+ scrollIntoView: function(el, axes, offset){
+ axes = axes ? $splat(axes) : ['x','y'];
+ var to = {};
+ el = document.id(el);
+ var pos = el.getPosition(this.element);
+ var size = el.getSize();
+ var scroll = this.element.getScroll();
+ var containerSize = this.element.getSize();
+ var edge = {
+ x: pos.x + size.x,
+ y: pos.y + size.y
+ ['x','y'].each(function(axis) {
+ if (axes.contains(axis)) {
+ if (edge[axis] > scroll[axis] + containerSize[axis]) to[axis] = edge[axis] - containerSize[axis];
+ if (pos[axis] < scroll[axis]) to[axis] = pos[axis];
+ if (to[axis] == null) to[axis] = scroll[axis];
+ if (offset && offset[axis]) to[axis] = to[axis] + offset[axis];
+ }, this);
+ if (to.x != scroll.x || to.y != scroll.y) this.start(to.x, to.y);
+ return this;
+ scrollToCenter: function(el, axes, offset){
+ axes = axes ? $splat(axes) : ['x', 'y'];
+ el = $(el);
+ var to = {},
+ pos = el.getPosition(this.element),
+ size = el.getSize(),
+ containerSize = this.element.getSize(),
+ edge = {
+ y: pos.y + size.y
+ ['x','y'].each(function(axis){
+ if(axes.contains(axis)){
+ to[axis] = pos[axis] - (containerSize[axis] - size[axis])/2;
+ if(to[axis] == null) to[axis] = scroll[axis];
+ if(offset && offset[axis]) to[axis] = to[axis] + offset[axis];
+ }, this);
+ return this;
+script: Fx.Slide.js
+description: Effect to slide an element in and out of view.
+authors:
+- Valerio Proietti
+requires:
+- core:1.2.4/Fx Element.Style
+- /MooTools.More
+provides: [Fx.Slide]
+Fx.Slide = new Class({
+ Extends: Fx,
+ options: {
+ mode: 'vertical',
+ wrapper: false,
+ hideOverflow: true
+ this.open = (this.wrapper['offset' + this.layout.capitalize()] != 0);
+ if (this.open) this.wrapper.setStyle('height', '');
+ if (this.open && Browser.Engine.webkit419) this.element.dispose().inject(this.wrapper);
+ }, true);
+ var wrapper = this.element.retrieve('wrapper');
+ var styles = this.element.getStyles('margin', 'position', 'overflow');
+ if (this.options.hideOverflow) styles = $extend(styles, {overflow: 'hidden'});
+ if (this.options.wrapper) wrapper = document.id(this.options.wrapper).setStyles(styles);
+ this.wrapper = wrapper || new Element('div', {
+ styles: styles
+ }).wraps(this.element);
+ this.element.store('wrapper', this.wrapper).setStyle('margin', 0);
+ this.now = [];
+ this.open = true;
+ vertical: function(){
+ this.margin = 'margin-top';
+ this.layout = 'height';
+ this.offset = this.element.offsetHeight;
+ horizontal: function(){
+ this.margin = 'margin-left';
+ this.layout = 'width';
+ this.offset = this.element.offsetWidth;
+ this.element.setStyle(this.margin, now[0]);
+ this.wrapper.setStyle(this.layout, now[1]);
+ return this;
+ start: function(how, mode){
+ if (!this.check(how, mode)) return this;
+ this[mode || this.options.mode]();
+ var margin = this.element.getStyle(this.margin).toInt();
+ var layout = this.wrapper.getStyle(this.layout).toInt();
+ var caseIn = [[margin, layout], [0, this.offset]];
+ var caseOut = [[margin, layout], [-this.offset, 0]];
+ var start;
+ switch (how){
+ case 'in': start = caseIn; break;
+ case 'out': start = caseOut; break;
+ case 'toggle': start = (layout == 0) ? caseIn : caseOut;
+ return this.parent(start[0], start[1]);
+ slideIn: function(mode){
+ return this.start('in', mode);
+ slideOut: function(mode){
+ return this.start('out', mode);
+ hide: function(mode){
+ this.open = false;
+ return this.set([-this.offset, 0]);
+ show: function(mode){
+ this.open = true;
+ return this.set([0, this.offset]);
+ toggle: function(mode){
+ return this.start('toggle', mode);
+Element.Properties.slide = {
+ var slide = this.retrieve('slide');
+ if (slide) slide.cancel();
+ return this.eliminate('slide').store('slide:options', $extend({link: 'cancel'}, options));
+ if (options || !this.retrieve('slide')){
+ if (options || !this.retrieve('slide:options')) this.set('slide', options);
+ this.store('slide', new Fx.Slide(this, this.retrieve('slide:options')));
+ return this.retrieve('slide');
+ slide: function(how, mode){
+ how = how || 'toggle';
+ var slide = this.get('slide'), toggle;
+ switch (how){
+ case 'hide': slide.hide(mode); break;
+ case 'show': slide.show(mode); break;
+ case 'toggle':
+ var flag = this.retrieve('slide:flag', slide.open);
+ slide[flag ? 'slideOut' : 'slideIn'](mode);
+ this.store('slide:flag', !flag);
+ toggle = true;
+ break;
+ default: slide.start(how, mode);
+ if (!toggle) this.eliminate('slide:flag');
+ return this;
+script: Fx.SmoothScroll.js
+description: Class for creating a smooth scrolling effect to all internal links on the page.
+authors:
+- Valerio Proietti
+requires:
+- core:1.2.4/Selectors
+- /Fx.Scroll
+provides: [Fx.SmoothScroll]
+var SmoothScroll = Fx.SmoothScroll = new Class({
+ Extends: Fx.Scroll,
+ initialize: function(options, context){
+ context = context || document;
+ this.doc = context.getDocument();
+ var win = context.getWindow();
+ this.parent(this.doc, options);
+ this.links = $$(this.options.links || this.doc.links);
+ var location = win.location.href.match(/^[^#]*/)[0] + '#';
+ this.links.each(function(link){
+ if (link.href.indexOf(location) != 0) {return;}
+ var anchor = link.href.substr(location.length);
+ if (anchor) this.useLink(link, anchor);
+ }, this);
+ if (!Browser.Engine.webkit419) {
+ win.location.hash = this.anchor;
+ }, true);
+ useLink: function(link, anchor){
+ var el;
+ link.addEvent('click', function(event){
+ if (el !== false && !el) el = document.id(anchor) || this.doc.getElement('a[name=' + anchor + ']');
+ if (el) {
+ event.preventDefault();
+ this.anchor = anchor;
+ this.toElement(el).chain(function(){
+ this.fireEvent('scrolledTo', [link, el]);
+ }.bind(this));
+ link.blur();
+ }.bind(this));
+script: Fx.Sort.js
+description: Defines Fx.Sort, a class that reorders lists with a transition.
+authors:
+- Aaron Newton
+requires:
+- /Fx.Elements
+- /Element.Measure
+provides: [Fx.Sort]
+Fx.Sort = new Class({
+ options: {
+ mode: 'vertical'
+ this.parent(elements, options);
+ this.elements.each(function(el){
+ if (el.getStyle('position') == 'static') el.setStyle('position', 'relative');
+ this.setDefaultOrder();
+ setDefaultOrder: function(){
+ this.currentOrder = this.elements.map(function(el, index){
+ return index;
+ sort: function(newOrder){
+ if ($type(newOrder) != 'array') return false;
+ var top = 0,
+ left = 0,
+ next = {},
+ zero = {},
+ vert = this.options.mode == 'vertical';
+ var current = this.elements.map(function(el, index){
+ var size = el.getComputedSize({styles: ['border', 'padding', 'margin']});
+ var val;
+ if (vert){
+ val = {
+ top: top,
+ margin: size['margin-top'],
+ height: size.totalHeight
+ top += val.height - size['margin-top'];
+ } else {
+ val = {
+ left: left,
+ margin: size['margin-left'],
+ width: size.totalWidth
+ left += val.width;
+ var plain = vert ? 'top' : 'left';
+ zero[index] = {};
+ var start = el.getStyle(plain).toInt();
+ zero[index][plain] = start || 0;
+ return val;
+ }, this);
+ this.set(zero);
+ newOrder = newOrder.map(function(i){ return i.toInt(); });
+ if (newOrder.length != this.elements.length){
+ this.currentOrder.each(function(index){
+ if (!newOrder.contains(index)) newOrder.push(index);
+ if (newOrder.length > this.elements.length)
+ newOrder.splice(this.elements.length-1, newOrder.length - this.elements.length);
+ var margin = top = left = 0;
+ newOrder.each(function(item, index){
+ var newPos = {};
+ if (vert){
+ newPos.top = top - current[item].top - margin;
+ top += current[item].height;
+ } else {
+ newPos.left = left - current[item].left;
+ left += current[item].width;
+ margin = margin + current[item].margin;
+ next[item]=newPos;
+ }, this);
+ var mapped = {};
+ $A(newOrder).sort().each(function(index){
+ mapped[index] = next[index];
+ this.start(mapped);
+ this.currentOrder = newOrder;
+ return this;
+ rearrangeDOM: function(newOrder){
+ newOrder = newOrder || this.currentOrder;
+ var parent = this.elements[0].getParent();
+ var rearranged = [];
+ this.elements.setStyle('opacity', 0);
+ //move each element and store the new default order
+ newOrder.each(function(index){
+ rearranged.push(this.elements[index].inject(parent).setStyles({
+ top: 0,
+ left: 0
+ }, this);
+ this.elements.setStyle('opacity', 1);
+ this.elements = $$(rearranged);
+ return this;
+ getDefaultOrder: function(){
+ return this.elements.map(function(el, index){
+ return index;
+ forward: function(){
+ return this.sort(this.getDefaultOrder());
+ backward: function(){
+ return this.sort(this.getDefaultOrder().reverse());
+ reverse: function(){
+ return this.sort(this.currentOrder.reverse());
+ sortByElements: function(elements){
+ return this.sort(elements.map(function(el){
+ return this.elements.indexOf(el);
+ }, this));
+ swap: function(one, two){
+ if ($type(one) == 'element') one = this.elements.indexOf(one);
+ if ($type(two) == 'element') two = this.elements.indexOf(two);
+ var newOrder = $A(this.currentOrder);
+ newOrder[this.currentOrder.indexOf(one)] = two;
+ newOrder[this.currentOrder.indexOf(two)] = one;
+ return this.sort(newOrder);
+script: Drag.js
+description: The base Drag Class. Can be used to drag and resize Elements using mouse events.
+authors:
+- Valerio Proietti
+- Tom Occhinno
+- Jan Kassens
+requires:
+- core:1.2.4/Events
+- core:1.2.4/Options
+- core:1.2.4/Element.Style
+- /MooTools.More
+provides: [Drag]
+var Drag = new Class({
+ Implements: [Events, Options],
+ options: {/*
+ onBeforeStart: $empty(thisElement),
+ onStart: $empty(thisElement, event),
+ onSnap: $empty(thisElement)
+ onDrag: $empty(thisElement, event),
+ onCancel: $empty(thisElement),
+ onComplete: $empty(thisElement, event),*/
+ snap: 6,
+ unit: 'px',
+ grid: false,
+ style: true,
+ limit: false,
+ handle: false,
+ invert: false,
+ preventDefault: false,
+ stopPropagation: false,
+ modifiers: {x: 'left', y: 'top'}
+ var params = Array.link(arguments, {'options': Object.type, 'element': $defined});
+ this.element = document.id(params.element);
+ this.document = this.element.getDocument();
+ this.setOptions(params.options || {});
+ var htype = $type(this.options.handle);
+ this.handles = ((htype == 'array' || htype == 'collection') ? $$(this.options.handle) : document.id(this.options.handle)) || this.element;
+ this.mouse = {'now': {}, 'pos': {}};
+ this.value = {'start': {}, 'now': {}};
+ this.selection = (Browser.Engine.trident) ? 'selectstart' : 'mousedown';
+ this.bound = {
+ start: this.start.bind(this),
+ check: this.check.bind(this),
+ drag: this.drag.bind(this),
+ stop: this.stop.bind(this),
+ cancel: this.cancel.bind(this),
+ eventStop: $lambda(false)
+ this.attach();
+ this.handles.addEvent('mousedown', this.bound.start);
+ return this;
+ this.handles.removeEvent('mousedown', this.bound.start);
+ return this;
+ start: function(event){
+ if (event.rightClick) return;
+ if (this.options.preventDefault) event.preventDefault();
+ if (this.options.stopPropagation) event.stopPropagation();
+ this.mouse.start = event.page;
+ this.fireEvent('beforeStart', this.element);
+ var limit = this.options.limit;
+ this.limit = {x: [], y: []};
+ for (var z in this.options.modifiers){
+ if (!this.options.modifiers[z]) continue;
+ if (this.options.style) this.value.now[z] = this.element.getStyle(this.options.modifiers[z]).toInt();
+ else this.value.now[z] = this.element[this.options.modifiers[z]];
+ if (this.options.invert) this.value.now[z] *= -1;
+ this.mouse.pos[z] = event.page[z] - this.value.now[z];
+ if (limit && limit[z]){
+ for (var i = 2; i--; i){
+ if ($chk(limit[z][i])) this.limit[z][i] = $lambda(limit[z][i])();
+ if ($type(this.options.grid) == 'number') this.options.grid = {x: this.options.grid, y: this.options.grid};
+ this.document.addEvents({mousemove: this.bound.check, mouseup: this.bound.cancel});
+ this.document.addEvent(this.selection, this.bound.eventStop);
+ check: function(event){
+ var distance = Math.round(Math.sqrt(Math.pow(event.page.x - this.mouse.start.x, 2) + Math.pow(event.page.y - this.mouse.start.y, 2)));
+ if (distance > this.options.snap){
+ this.cancel();
+ mousemove: this.bound.drag,
+ mouseup: this.bound.stop
+ this.fireEvent('start', [this.element, event]).fireEvent('snap', this.element);
+ drag: function(event){
+ this.mouse.now = event.page;
+ this.value.now[z] = this.mouse.now[z] - this.mouse.pos[z];
+ if (this.options.limit && this.limit[z]){
+ if ($chk(this.limit[z][1]) && (this.value.now[z] > this.limit[z][1])){
+ this.value.now[z] = this.limit[z][1];
+ } else if ($chk(this.limit[z][0]) && (this.value.now[z] < this.limit[z][0])){
+ this.value.now[z] = this.limit[z][0];
+ if (this.options.grid[z]) this.value.now[z] -= ((this.value.now[z] - (this.limit[z][0]||0)) % this.options.grid[z]);
+ if (this.options.style) {
+ this.element.setStyle(this.options.modifiers[z], this.value.now[z] + this.options.unit);
+ } else {
+ this.element[this.options.modifiers[z]] = this.value.now[z];
+ this.fireEvent('drag', [this.element, event]);
+ cancel: function(event){
+ this.document.removeEvent('mousemove', this.bound.check);
+ this.document.removeEvent('mouseup', this.bound.cancel);
+ if (event){
+ this.document.removeEvent(this.selection, this.bound.eventStop);
+ this.fireEvent('cancel', this.element);
+ stop: function(event){
+ this.document.removeEvent('mousemove', this.bound.drag);
+ this.document.removeEvent('mouseup', this.bound.stop);
+ if (event) this.fireEvent('complete', [this.element, event]);
+ makeResizable: function(options){
+ var drag = new Drag(this, $merge({modifiers: {x: 'width', y: 'height'}}, options));
+ this.store('resizer', drag);
+ return drag.addEvent('drag', function(){
+ this.fireEvent('resize', drag);
+ }.bind(this));
+script: Drag.Move.js
+description: A Drag extension that provides support for the constraining of draggables to containers and droppables.
+authors:
+- Valerio Proietti
+- Tom Occhinno
+- Jan Kassens
+- Aaron Newton
+- Scott Kyle
+requires:
+- /Drag
+provides: [Drag.Move]
+Drag.Move = new Class({
+ Extends: Drag,
+ options: {/*
+ onEnter: $empty(thisElement, overed),
+ onLeave: $empty(thisElement, overed),
+ onDrop: $empty(thisElement, overed, event),*/
+ droppables: [],
+ container: false,
+ precalculate: false,
+ includeMargins: true,
+ checkDroppables: true
+ initialize: function(element, options){
+ this.parent(element, options);
+ element = this.element;
+ this.droppables = $$(this.options.droppables);
+ this.container = document.id(this.options.container);
+ if (this.container && $type(this.container) != 'element')
+ this.container = document.id(this.container.getDocument().body);
+ var styles = element.getStyles('left', 'top', 'position');
+ if (styles.left == 'auto' || styles.top == 'auto')
+ element.setPosition(element.getPosition(element.getOffsetParent()));
+ if (styles.position == 'static')
+ element.setStyle('position', 'absolute');
+ this.addEvent('start', this.checkDroppables, true);
+ this.overed = null;
+ if (this.container) this.options.limit = this.calculateLimit();
+ if (this.options.precalculate){
+ this.positions = this.droppables.map(function(el){
+ return el.getCoordinates();
+ this.parent(event);
+ calculateLimit: function(){
+ var offsetParent = this.element.getOffsetParent(),
+ containerCoordinates = this.container.getCoordinates(offsetParent),
+ containerBorder = {},
+ elementMargin = {},
+ elementBorder = {},
+ containerMargin = {},
+ offsetParentPadding = {};
+ ['top', 'right', 'bottom', 'left'].each(function(pad){
+ containerBorder[pad] = this.container.getStyle('border-' + pad).toInt();
+ elementBorder[pad] = this.element.getStyle('border-' + pad).toInt();
+ elementMargin[pad] = this.element.getStyle('margin-' + pad).toInt();
+ containerMargin[pad] = this.container.getStyle('margin-' + pad).toInt();
+ offsetParentPadding[pad] = offsetParent.getStyle('padding-' + pad).toInt();
+ }, this);
+ var width = this.element.offsetWidth + elementMargin.left + elementMargin.right,
+ height = this.element.offsetHeight + elementMargin.top + elementMargin.bottom,
+ left = 0,
+ top = 0,
+ right = containerCoordinates.right - containerBorder.right - width,
+ bottom = containerCoordinates.bottom - containerBorder.bottom - height;
+ if (this.options.includeMargins){
+ left += elementMargin.left;
+ top += elementMargin.top;
+ } else {
+ right += elementMargin.right;
+ bottom += elementMargin.bottom;
+ if (this.element.getStyle('position') == 'relative'){
+ var coords = this.element.getCoordinates(offsetParent);
+ coords.left -= this.element.getStyle('left').toInt();
+ coords.top -= this.element.getStyle('top').toInt();
+ left += containerBorder.left - coords.left;
+ top += containerBorder.top - coords.top;
+ right += elementMargin.left - coords.left;
+ bottom += elementMargin.top - coords.top;
+ if (this.container != offsetParent){
+ left += containerMargin.left + offsetParentPadding.left;
+ top += (Browser.Engine.trident4 ? 0 : containerMargin.top) + offsetParentPadding.top;
+ } else {
+ left -= elementMargin.left;
+ top -= elementMargin.top;
+ if (this.container == offsetParent){
+ right -= containerBorder.left;
+ bottom -= containerBorder.top;
+ } else {
+ left += containerCoordinates.left + containerBorder.left;
+ top += containerCoordinates.top + containerBorder.top;
+ return {
+ x: [left, right],
+ y: [top, bottom]
+ checkAgainst: function(el, i){
+ el = (this.positions) ? this.positions[i] : el.getCoordinates();
+ var now = this.mouse.now;
+ return (now.x > el.left && now.x < el.right && now.y < el.bottom && now.y > el.top);
+ checkDroppables: function(){
+ var overed = this.droppables.filter(this.checkAgainst, this).getLast();
+ if (this.overed != overed){
+ if (this.overed) this.fireEvent('leave', [this.element, this.overed]);
+ if (overed) this.fireEvent('enter', [this.element, overed]);
+ this.overed = overed;
+ if (this.options.checkDroppables && this.droppables.length) this.checkDroppables();
+ this.checkDroppables();
+ this.fireEvent('drop', [this.element, this.overed, event]);
+ return this.parent(event);
+ makeDraggable: function(options){
+ var drag = new Drag.Move(this, options);
+ this.store('dragger', drag);
+ return drag;
+script: Slider.js
+description: Class for creating horizontal and vertical slider controls.
+authors:
+- Valerio Proietti
+requires:
+- /Class.Binds
+- /Drag
+- /Element.Dimensions
+- /Element.Measure
+provides: [Slider]
+var Slider = new Class({
+ Binds: ['clickedElement', 'draggedKnob', 'scrolledElement'],
+ options: {/*
+ onTick: $empty(intPosition),
+ onChange: $empty(intStep),
+ onComplete: $empty(strStep),*/
+ onTick: function(position){
+ if (this.options.snap) position = this.toPosition(this.step);
+ this.knob.setStyle(this.property, position);
+ initialStep: 0,
+ snap: false,
+ offset: 0,
+ range: false,
+ wheel: false,
+ steps: 100,
+ mode: 'horizontal'
+ initialize: function(element, knob, options){
+ this.setOptions(options);
+ this.element = document.id(element);
+ this.knob = document.id(knob);
+ this.previousChange = this.previousEnd = this.step = -1;
+ var offset, limit = {}, modifiers = {'x': false, 'y': false};
+ switch (this.options.mode){
+ case 'vertical':
+ this.axis = 'y';
+ this.property = 'top';
+ offset = 'offsetHeight';
+ break;
+ case 'horizontal':
+ this.axis = 'x';
+ this.property = 'left';
+ offset = 'offsetWidth';
+ this.full = this.element.measure(function(){
+ this.half = this.knob[offset] / 2;
+ return this.element[offset] - this.knob[offset] + (this.options.offset * 2);
+ }.bind(this));
+ this.min = $chk(this.options.range[0]) ? this.options.range[0] : 0;
+ this.max = $chk(this.options.range[1]) ? this.options.range[1] : this.options.steps;
+ this.range = this.max - this.min;
+ this.steps = this.options.steps || this.full;
+ this.stepSize = Math.abs(this.range) / this.steps;
+ this.stepWidth = this.stepSize * this.full / Math.abs(this.range) ;
+ this.knob.setStyle('position', 'relative').setStyle(this.property, this.options.initialStep ? this.toPosition(this.options.initialStep) : - this.options.offset);
+ modifiers[this.axis] = this.property;
+ limit[this.axis] = [- this.options.offset, this.full - this.options.offset];
+ var dragOptions = {
+ snap: 0,
+ limit: limit,
+ modifiers: modifiers,
+ onDrag: this.draggedKnob,
+ onStart: this.draggedKnob,
+ onBeforeStart: (function(){
+ this.isDragging = true;
+ }).bind(this),
+ onCancel: function() {
+ this.isDragging = false;
+ }.bind(this),
+ onComplete: function(){
+ this.draggedKnob();
+ this.end();
+ }.bind(this)
+ if (this.options.snap){
+ dragOptions.grid = Math.ceil(this.stepWidth);
+ dragOptions.limit[this.axis][1] = this.full;
+ this.drag = new Drag(this.knob, dragOptions);
+ this.attach();
+ this.element.addEvent('mousedown', this.clickedElement);
+ if (this.options.wheel) this.element.addEvent('mousewheel', this.scrolledElement);
+ this.drag.attach();
+ return this;
+ detach: function(){
+ this.element.removeEvent('mousedown', this.clickedElement);
+ this.element.removeEvent('mousewheel', this.scrolledElement);
+ this.drag.detach();
+ return this;
+ set: function(step){
+ if (!((this.range > 0) ^ (step < this.min))) step = this.min;
+ if (!((this.range > 0) ^ (step > this.max))) step = this.max;
+ this.step = Math.round(step);
+ this.checkStep();
+ this.fireEvent('tick', this.toPosition(this.step));
+ this.end();
+ return this;
+ clickedElement: function(event){
+ if (this.isDragging || event.target == this.knob) return;
+ var dir = this.range < 0 ? -1 : 1;
+ var position = event.page[this.axis] - this.element.getPosition()[this.axis] - this.half;
+ position = position.limit(-this.options.offset, this.full -this.options.offset);
+ this.step = Math.round(this.min + dir * this.toStep(position));
+ this.checkStep();
+ this.fireEvent('tick', position);
+ this.end();
+ scrolledElement: function(event){
+ var mode = (this.options.mode == 'horizontal') ? (event.wheel < 0) : (event.wheel > 0);
+ this.set(mode ? this.step - this.stepSize : this.step + this.stepSize);
+ event.stop();
+ draggedKnob: function(){
+ var position = this.drag.value.now[this.axis];
+ this.checkStep();
+ checkStep: function(){
+ if (this.previousChange != this.step){
+ this.previousChange = this.step;
+ this.fireEvent('change', this.step);
+ end: function(){
+ if (this.previousEnd !== this.step){
+ this.previousEnd = this.step;
+ this.fireEvent('complete', this.step + '');
+ toStep: function(position){
+ var step = (position + this.options.offset) * this.stepSize / this.full * this.steps;
+ return this.options.steps ? Math.round(step -= step % this.stepSize) : step;
+ toPosition: function(step){
+ return (this.full * Math.abs(this.min - step)) / (this.steps * this.stepSize) - this.options.offset;
+script: Sortables.js
+description: Class for creating a drag and drop sorting interface for lists of items.
+authors:
+- Tom Occhino
+requires:
+- /Drag.Move
+provides: [Slider]
+var Sortables = new Class({
+ options: {/*
+ onSort: $empty(element, clone),
+ onStart: $empty(element, clone),
+ onComplete: $empty(element),*/
+ snap: 4,
+ opacity: 1,
+ clone: false,
+ revert: false,
+ handle: false,
+ constrain: false
+ initialize: function(lists, options){
+ this.elements = [];
+ this.lists = [];
+ this.idle = true;
+ this.addLists($$(document.id(lists) || lists));
+ if (!this.options.clone) this.options.revert = false;
+ if (this.options.revert) this.effect = new Fx.Morph(null, $merge({duration: 250, link: 'cancel'}, this.options.revert));
+ this.addLists(this.lists);
+ return this;
+ this.lists = this.removeLists(this.lists);
+ return this;
+ addItems: function(){
+ Array.flatten(arguments).each(function(element){
+ this.elements.push(element);
+ var start = element.retrieve('sortables:start', this.start.bindWithEvent(this, element));
+ (this.options.handle ? element.getElement(this.options.handle) || element : element).addEvent('mousedown', start);
+ }, this);
+ return this;
+ addLists: function(){
+ Array.flatten(arguments).each(function(list){
+ this.lists.push(list);
+ this.addItems(list.getChildren());
+ }, this);
+ return this;
+ removeItems: function(){
+ return $$(Array.flatten(arguments).map(function(element){
+ this.elements.erase(element);
+ var start = element.retrieve('sortables:start');
+ (this.options.handle ? element.getElement(this.options.handle) || element : element).removeEvent('mousedown', start);
+ return element;
+ }, this));
+ removeLists: function(){
+ return $$(Array.flatten(arguments).map(function(list){
+ this.lists.erase(list);
+ this.removeItems(list.getChildren());
+ return list;
+ }, this));
+ getClone: function(event, element){
+ if (!this.options.clone) return new Element('div').inject(document.body);
+ if ($type(this.options.clone) == 'function') return this.options.clone.call(this, event, element, this.list);
+ var clone = element.clone(true).setStyles({
+ margin: '0px',
+ position: 'absolute',
+ visibility: 'hidden',
+ 'width': element.getStyle('width')
+ //prevent the duplicated radio inputs from unchecking the real one
+ if (clone.get('html').test('radio')) {
+ clone.getElements('input[type=radio]').each(function(input, i) {
+ input.set('name', 'clone_' + i);
+ return clone.inject(this.list).setPosition(element.getPosition(element.getOffsetParent()));
+ getDroppables: function(){
+ var droppables = this.list.getChildren();
+ if (!this.options.constrain) droppables = this.lists.concat(droppables).erase(this.list);
+ return droppables.erase(this.clone).erase(this.element);
+ insert: function(dragging, element){
+ var where = 'inside';
+ if (this.lists.contains(element)){
+ this.list = element;
+ this.drag.droppables = this.getDroppables();
+ } else {
+ where = this.element.getAllPrevious().contains(element) ? 'before' : 'after';
+ this.element.inject(element, where);
+ this.fireEvent('sort', [this.element, this.clone]);
+ start: function(event, element){
+ if (!this.idle) return;
+ this.idle = false;
+ this.element = element;
+ this.opacity = element.get('opacity');
+ this.list = element.getParent();
+ this.clone = this.getClone(event, element);
+ this.drag = new Drag.Move(this.clone, {
+ snap: this.options.snap,
+ container: this.options.constrain && this.element.getParent(),
+ droppables: this.getDroppables(),
+ onSnap: function(){
+ event.stop();
+ this.clone.setStyle('visibility', 'visible');
+ this.element.set('opacity', this.options.opacity || 0);
+ this.fireEvent('start', [this.element, this.clone]);
+ }.bind(this),
+ onEnter: this.insert.bind(this),
+ onCancel: this.reset.bind(this),
+ onComplete: this.end.bind(this)
+ this.clone.inject(this.element, 'before');
+ this.drag.start(event);
+ end: function(){
+ this.element.set('opacity', this.opacity);
+ if (this.effect){
+ var dim = this.element.getStyles('width', 'height');
+ var pos = this.clone.computePosition(this.element.getPosition(this.clone.offsetParent));
+ this.effect.element = this.clone;
+ this.effect.start({
+ top: pos.top,
+ left: pos.left,
+ width: dim.width,
+ height: dim.height,
+ opacity: 0.25
+ }).chain(this.reset.bind(this));
+ } else {
+ this.reset();
+ this.idle = true;
+ this.clone.destroy();
+ this.fireEvent('complete', this.element);
+ serialize: function(){
+ var params = Array.link(arguments, {modifier: Function.type, index: $defined});
+ var serial = this.lists.map(function(list){
+ return list.getChildren().map(params.modifier || function(element){
+ return element.get('id');
+ }, this);
+ }, this);
+ var index = params.index;
+ if (this.lists.length == 1) index = 0;
+ return $chk(index) && index >= 0 && index < this.lists.length ? serial[index] : serial;
+script: Request.JSONP.js
+description: Defines Request.JSONP, a class for cross domain javascript via script injection.
+authors:
+- Aaron Newton
+- Guillermo Rauch
+requires:
+- core:1.2.4/Request
+- /Log
+provides: [Request.JSONP]
+Request.JSONP = new Class({
+ Implements: [Chain, Events, Options, Log],
+ options: {/*
+ onRetry: $empty(intRetries),
+ onRequest: $empty(scriptElement),
+ onComplete: $empty(data),
+ onSuccess: $empty(data),
+ onCancel: $empty(),
+ log: false,
+ url: '',
+ data: {},
+ retries: 0,
+ timeout: 0,
+ link: 'ignore',
+ callbackKey: 'callback',
+ injectScript: document.head
+ initialize: function(options){
+ if (this.options.log) this.enableLog();
+ this.running = false;
+ this.requests = 0;
+ this.triesRemaining = [];
+ check: function(){
+ if (!this.running) return true;
+ switch (this.options.link){
+ case 'cancel': this.cancel(); return true;
+ case 'chain': this.chain(this.caller.bind(this, arguments)); return false;
+ return false;
+ send: function(options){
+ if (!$chk(arguments[1]) && !this.check(options)) return this;
+ var type = $type(options),
+ old = this.options,
+ index = $chk(arguments[1]) ? arguments[1] : this.requests++;
+ if (type == 'string' || type == 'element') options = {data: options};
+ options = $extend({data: old.data, url: old.url}, options);
+ if (!$chk(this.triesRemaining[index])) this.triesRemaining[index] = this.options.retries;
+ var remaining = this.triesRemaining[index];
+ (function(){
+ var script = this.getScript(options);
+ this.log('JSONP retrieving script with url: ' + script.get('src'));
+ this.fireEvent('request', script);
+ this.running = true;
+ (function(){
+ if (remaining){
+ this.triesRemaining[index] = remaining - 1;
+ if (script){
+ script.destroy();
+ this.send(options, index).fireEvent('retry', this.triesRemaining[index]);
+ } else if(script && this.options.timeout){
+ script.destroy();
+ this.cancel().fireEvent('failure');
+ }).delay(this.options.timeout, this);
+ }).delay(Browser.Engine.trident ? 50 : 0, this);
+ return this;
+ cancel: function(){
+ if (!this.running) return this;
+ this.fireEvent('cancel');
+ return this;
+ getScript: function(options){
+ var index = Request.JSONP.counter,
+ data;
+ Request.JSONP.counter++;
+ switch ($type(options.data)){
+ case 'element': data = document.id(options.data).toQueryString(); break;
+ case 'object': case 'hash': data = Hash.toQueryString(options.data);
+ var src = options.url +
+ (options.url.test('\\?') ? '&' :'?') +
+ (options.callbackKey || this.options.callbackKey) +
+ '=Request.JSONP.request_map.request_'+ index +
+ (data ? '&' + data : '');
+ if (src.length > 2083) this.log('JSONP '+ src +' will fail in Internet Explorer, which enforces a 2083 bytes length limit on URIs');
+ var script = new Element('script', {type: 'text/javascript', src: src});
+ Request.JSONP.request_map['request_' + index] = function(){ this.success(arguments, script); }.bind(this);
+ return script.inject(this.options.injectScript);
+ success: function(args, script){
+ if (script) script.destroy();
+ this.log('JSONP successfully retrieved: ', args);
+ this.fireEvent('complete', args).fireEvent('success', args).callChain();
+Request.JSONP.counter = 0;
+Request.JSONP.request_map = {};/*
+script: Request.Queue.js
+description: Controls several instances of Request and its variants to run only one request at a time.
+authors:
+- Aaron Newton
+requires:
+- /Log
+provides: [Request.Queue]
+Request.Queue = new Class({
+ Implements: [Options, Events],
+ Binds: ['attach', 'request', 'complete', 'cancel', 'success', 'failure', 'exception'],
+ options: {/*
+ onRequest: $empty(argsPassedToOnRequest),
+ onSuccess: $empty(argsPassedToOnSuccess),
+ onComplete: $empty(argsPassedToOnComplete),
+ onCancel: $empty(argsPassedToOnCancel),
+ onException: $empty(argsPassedToOnException),
+ onFailure: $empty(argsPassedToOnFailure),
+ onEnd: $empty,
+ stopOnFailure: true,
+ autoAdvance: true,
+ concurrent: 1,
+ requests: {}
+ if(options){
+ var requests = options.requests;
+ delete options.requests;
+ this.requests = new Hash;
+ this.queue = [];
+ this.reqBinders = {};
+ if(requests) this.addRequests(requests);
+ addRequest: function(name, request){
+ this.requests.set(name, request);
+ this.attach(name, request);
+ return this;
+ addRequests: function(obj){
+ $each(obj, function(req, name){
+ this.addRequest(name, req);
+ }, this);
+ return this;
+ getName: function(req){
+ return this.requests.keyOf(req);
+ attach: function(name, req){
+ if (req._groupSend) return this;
+ ['request', 'complete', 'cancel', 'success', 'failure', 'exception'].each(function(evt){
+ if(!this.reqBinders[name]) this.reqBinders[name] = {};
+ this.reqBinders[name][evt] = function(){
+ this['on' + evt.capitalize()].apply(this, [name, req].extend(arguments));
+ }.bind(this);
+ req.addEvent(evt, this.reqBinders[name][evt]);
+ }, this);
+ req._groupSend = req.send;
+ req.send = function(options){
+ this.send(name, options);
+ return req;
+ }.bind(this);
+ return this;
+ removeRequest: function(req){
+ var name = $type(req) == 'object' ? this.getName(req) : req;
+ if (!name && $type(name) != 'string') return this;
+ req = this.requests.get(name);
+ if (!req) return this;
+ req.removeEvent(evt, this.reqBinders[name][evt]);
+ }, this);
+ req.send = req._groupSend;
+ delete req._groupSend;
+ return this;
+ getRunning: function(){
+ return this.requests.filter(function(r){
+ return r.running;
+ isRunning: function(){
+ return !!(this.getRunning().getKeys().length);
+ send: function(name, options){
+ var q = function(){
+ this.requests.get(name)._groupSend(options);
+ this.queue.erase(q);
+ }.bind(this);
+ q.name = name;
+ if (this.getRunning().getKeys().length >= this.options.concurrent || (this.error && this.options.stopOnFailure)) this.queue.push(q);
+ else q();
+ return this;
+ hasNext: function(name){
+ return (!name) ? !!this.queue.length : !!this.queue.filter(function(q){ return q.name == name; }).length;
+ resume: function(){
+ this.error = false;
+ (this.options.concurrent - this.getRunning().getKeys().length).times(this.runNext, this);
+ return this;
+ runNext: function(name){
+ if (!this.queue.length) return this;
+ if (!name){
+ this.queue[0]();
+ } else {
+ var found;
+ this.queue.each(function(q){
+ if (!found && q.name == name){
+ found = true;
+ q();
+ return this;
+ runAll: function() {
+ this.queue.each(function(q) {
+ q();
+ return this;
+ clear: function(name){
+ if (!name){
+ this.queue.empty();
+ } else {
+ this.queue = this.queue.map(function(q){
+ if (q.name != name) return q;
+ else return false;
+ }).filter(function(q){ return q; });
+ return this;
+ cancel: function(name){
+ this.requests.get(name).cancel();
+ return this;
+ onRequest: function(){
+ this.fireEvent('request', arguments);
+ this.fireEvent('complete', arguments);
+ if (!this.queue.length) this.fireEvent('end');
+ onCancel: function(){
+ if (this.options.autoAdvance && !this.error) this.runNext();
+ this.fireEvent('cancel', arguments);
+ onSuccess: function(){
+ this.fireEvent('success', arguments);
+ onFailure: function(){
+ this.error = true;
+ if (!this.options.stopOnFailure && this.options.autoAdvance) this.runNext();
+ this.fireEvent('failure', arguments);
+ onException: function(){
+ this.fireEvent('exception', arguments);
+script: Request.Periodical.js
+description: Requests the same URL to pull data from a server but increases the intervals if no data is returned to reduce the load
+authors:
+- Christoph Pojer
+requires:
+- /MooTools.More
+provides: [Request.Periodical]
+Request.implement({
+ options: {
+ initialDelay: 5000,
+ delay: 5000,
+ limit: 60000
+ startTimer: function(data){
+ var fn = function(){
+ if (!this.running) this.send({data: data});
+ this.timer = fn.delay(this.options.initialDelay, this);
+ this.lastDelay = this.options.initialDelay;
+ this.completeCheck = function(response){
+ $clear(this.timer);
+ this.lastDelay = (response) ? this.options.delay : (this.lastDelay + this.options.delay).min(this.options.limit);
+ this.timer = fn.delay(this.lastDelay, this);
+ return this.addEvent('complete', this.completeCheck);
+ stopTimer: function(){
+ return this.removeEvent('complete', this.completeCheck);
+script: Assets.js
+description: Provides methods to dynamically load JavaScript, CSS, and Image files into the document.
+authors:
+- Valerio Proietti
+requires:
+- core:1.2.4/Element.Event
+- /MooTools.More
+provides: [Assets]
+var Asset = {
+ javascript: function(source, properties){
+ properties = $extend({
+ onload: $empty,
+ document: document,
+ check: $lambda(true)
+ }, properties);
+ if (properties.onLoad) properties.onload = properties.onLoad;
+ var script = new Element('script', {src: source, type: 'text/javascript'});
+ var load = properties.onload.bind(script),
+ check = properties.check,
+ doc = properties.document;
+ delete properties.onload;
+ delete properties.check;
+ delete properties.document;
+ script.addEvents({
+ load: load,
+ readystatechange: function(){
+ if (['loaded', 'complete'].contains(this.readyState)) load();
+ }).set(properties);
+ if (Browser.Engine.webkit419) var checker = (function(){
+ if (!$try(check)) return;
+ $clear(checker);
+ load();
+ }).periodical(50);
+ return script.inject(doc.head);
+ css: function(source, properties){
+ return new Element('link', $merge({
+ rel: 'stylesheet',
+ media: 'screen',
+ type: 'text/css',
+ href: source
+ }, properties)).inject(document.head);
+ image: function(source, properties){
+ properties = $merge({
+ onload: $empty,
+ onabort: $empty,
+ onerror: $empty
+ }, properties);
+ var image = new Image();
+ var element = document.id(image) || new Element('img');
+ ['load', 'abort', 'error'].each(function(name){
+ var type = 'on' + name;
+ var cap = name.capitalize();
+ if (properties['on' + cap]) properties[type] = properties['on' + cap];
+ var event = properties[type];
+ delete properties[type];
+ image[type] = function(){
+ if (!image) return;
+ if (!element.parentNode){
+ element.width = image.width;
+ element.height = image.height;
+ image = image.onload = image.onabort = image.onerror = null;
+ event.delay(1, element, element);
+ element.fireEvent(name, element, 1);
+ image.src = element.src = source;
+ if (image && image.complete) image.onload.delay(1);
+ return element.set(properties);
+ images: function(sources, options){
+ options = $merge({
+ onComplete: $empty,
+ onProgress: $empty,
+ onError: $empty,
+ properties: {}
+ }, options);
+ sources = $splat(sources);
+ var images = [];
+ var counter = 0;
+ return new Elements(sources.map(function(source){
+ return Asset.image(source, $extend(options.properties, {
+ onload: function(){
+ options.onProgress.call(this, counter, sources.indexOf(source));
+ counter++;
+ if (counter == sources.length) options.onComplete();
+ onerror: function(){
+ options.onError.call(this, counter, sources.indexOf(source));
+ counter++;
+script: Color.js
+description: Class for creating and manipulating colors in JavaScript. Supports HSB -> RGB Conversions and vice versa.
+authors:
+- Valerio Proietti
+requires:
+- core:1.2.4/Array
+- core:1.2.4/String
+- core:1.2.4/Number
+- core:1.2.4/Hash
+- core:1.2.4/Function
+- core:1.2.4/$util
+provides: [Color]
+var Color = new Native({
+ initialize: function(color, type){
+ if (arguments.length >= 3){
+ type = 'rgb'; color = Array.slice(arguments, 0, 3);
+ } else if (typeof color == 'string'){
+ if (color.match(/rgb/)) color = color.rgbToHex().hexToRgb(true);
+ else if (color.match(/hsb/)) color = color.hsbToRgb();
+ else color = color.hexToRgb(true);
+ type = type || 'rgb';
+ switch (type){
+ case 'hsb':
+ var old = color;
+ color = color.hsbToRgb();
+ color.hsb = old;
+ break;
+ case 'hex': color = color.hexToRgb(true); break;
+ color.rgb = color.slice(0, 3);
+ color.hsb = color.hsb || color.rgbToHsb();
+ color.hex = color.rgbToHex();
+ return $extend(color, this);
+Color.implement({
+ mix: function(){
+ var colors = Array.slice(arguments);
+ var alpha = ($type(colors.getLast()) == 'number') ? colors.pop() : 50;
+ var rgb = this.slice();
+ colors.each(function(color){
+ color = new Color(color);
+ for (var i = 0; i < 3; i++) rgb[i] = Math.round((rgb[i] / 100 * (100 - alpha)) + (color[i] / 100 * alpha));
+ return new Color(rgb, 'rgb');
+ invert: function(){
+ return new Color(this.map(function(value){
+ return 255 - value;
+ setHue: function(value){
+ return new Color([value, this.hsb[1], this.hsb[2]], 'hsb');
+ setSaturation: function(percent){
+ return new Color([this.hsb[0], percent, this.hsb[2]], 'hsb');
+ setBrightness: function(percent){
+ return new Color([this.hsb[0], this.hsb[1], percent], 'hsb');
+var $RGB = function(r, g, b){
+ return new Color([r, g, b], 'rgb');
+var $HSB = function(h, s, b){
+ return new Color([h, s, b], 'hsb');
+var $HEX = function(hex){
+ return new Color(hex, 'hex');
+Array.implement({
+ rgbToHsb: function(){
+ var red = this[0],
+ green = this[1],
+ blue = this[2],
+ hue = 0;
+ var max = Math.max(red, green, blue),
+ min = Math.min(red, green, blue);
+ var delta = max - min;
+ var brightness = max / 255,
+ saturation = (max != 0) ? delta / max : 0;
+ if(saturation != 0) {
+ var rr = (max - red) / delta;
+ var gr = (max - green) / delta;
+ var br = (max - blue) / delta;
+ if (red == max) hue = br - gr;
+ else if (green == max) hue = 2 + rr - br;
+ else hue = 4 + gr - rr;
+ hue /= 6;
+ if (hue < 0) hue++;
+ return [Math.round(hue * 360), Math.round(saturation * 100), Math.round(brightness * 100)];
+ hsbToRgb: function(){
+ var br = Math.round(this[2] / 100 * 255);
+ if (this[1] == 0){
+ return [br, br, br];
+ } else {
+ var hue = this[0] % 360;
+ var f = hue % 60;
+ var p = Math.round((this[2] * (100 - this[1])) / 10000 * 255);
+ var q = Math.round((this[2] * (6000 - this[1] * f)) / 600000 * 255);
+ var t = Math.round((this[2] * (6000 - this[1] * (60 - f))) / 600000 * 255);
+ switch (Math.floor(hue / 60)){
+ case 0: return [br, t, p];
+ case 1: return [q, br, p];
+ case 2: return [p, br, t];
+ case 3: return [p, q, br];
+ case 4: return [t, p, br];
+ case 5: return [br, p, q];
+ return false;
+String.implement({
+ var rgb = this.match(/\d{1,3}/g);
+ return (rgb) ? rgb.rgbToHsb() : null;
+ var hsb = this.match(/\d{1,3}/g);
+ return (hsb) ? hsb.hsbToRgb() : null;
+script: Group.js
+description: Class for monitoring collections of events
+authors:
+- Valerio Proietti
+requires:
+- /MooTools.More
+provides: [Group]
+var Group = new Class({
+ initialize: function(){
+ this.instances = Array.flatten(arguments);
+ this.events = {};
+ this.checker = {};
+ addEvent: function(type, fn){
+ this.checker[type] = this.checker[type] || {};
+ this.events[type] = this.events[type] || [];
+ if (this.events[type].contains(fn)) return false;
+ else this.events[type].push(fn);
+ this.instances.each(function(instance, i){
+ instance.addEvent(type, this.check.bind(this, [type, instance, i]));
+ }, this);
+ return this;
+ check: function(type, instance, i){
+ this.checker[type][i] = true;
+ var every = this.instances.every(function(current, j){
+ return this.checker[type][j] || false;
+ }, this);
+ if (!every) return;
+ this.checker[type] = {};
+ this.events[type].each(function(event){
+ event.call(this, this.instances, instance);
+ }, this);
+script: Hash.Cookie.js
+description: Class for creating, reading, and deleting Cookies in JSON format.
+authors:
+- Valerio Proietti
+- Aaron Newton
+requires:
+- core:1.2.4/Cookie
+- core:1.2.4/JSON
+- /MooTools.More
+provides: [Hash.Cookie]
+Hash.Cookie = new Class({
+ Extends: Cookie,
+ options: {
+ autoSave: true
+ initialize: function(name, options){
+ this.parent(name, options);
+ this.load();
+ save: function(){
+ var value = JSON.encode(this.hash);
+ if (!value || value.length > 4096) return false; //cookie would be truncated!
+ if (value == '{}') this.dispose();
+ else this.write(value);
+ return true;
+ load: function(){
+ this.hash = new Hash(JSON.decode(this.read(), true));
+ return this;
+Hash.each(Hash.prototype, function(method, name){
+ if (typeof method == 'function') Hash.Cookie.implement(name, function(){
+ var value = method.apply(this.hash, arguments);
+ if (this.options.autoSave) this.save();
+ return value;
+script: HtmlTable.js
+description: Builds table elements with methods to add rows.
+authors:
+- Aaron Newton
+requires:
+- /Class.Occlude
+provides: [HtmlTable]
+var HtmlTable = new Class({
+ Implements: [Options, Events, Class.Occlude],
+ options: {
+ properties: {
+ cellpadding: 0,
+ cellspacing: 0,
+ border: 0
+ rows: [],
+ headers: [],
+ footers: []
+ property: 'HtmlTable',
+ var params = Array.link(arguments, {options: Object.type, table: Element.type});
+ this.setOptions(params.options);
+ this.element = params.table || new Element('table', this.options.properties);
+ if (this.occlude()) return this.occluded;
+ this.build();
+ build: function(){
+ this.element.store('HtmlTable', this);
+ this.body = document.id(this.element.tBodies[0]) || new Element('tbody').inject(this.element);
+ $$(this.body.rows);
+ if (this.options.headers.length) this.setHeaders(this.options.headers);
+ else this.thead = document.id(this.element.tHead);
+ if (this.thead) this.head = document.id(this.thead.rows[0]);
+ if (this.options.footers.length) this.setFooters(this.options.footers);
+ this.tfoot = document.id(this.element.tFoot);
+ if (this.tfoot) this.foot = document.id(this.thead.rows[0]);
+ this.options.rows.each(function(row){
+ this.push(row);
+ }, this);
+ ['adopt', 'inject', 'wraps', 'grab', 'replaces', 'dispose'].each(function(method){
+ this[method] = this.element[method].bind(this.element);
+ }, this);
+ toElement: function(){
+ return this.element;
+ empty: function(){
+ this.body.empty();
+ return this;
+ set: function(what, items) {
+ var target = (what == 'headers') ? 'tHead' : 'tFoot';
+ this[target.toLowerCase()] = (document.id(this.element[target]) || new Element(target.toLowerCase()).inject(this.element, 'top')).empty();
+ var data = this.push(items, {}, this[target.toLowerCase()], what == 'headers' ? 'th' : 'td');
+ if (what == 'headers') this.head = document.id(this.thead.rows[0]);
+ else this.foot = document.id(this.thead.rows[0]);
+ return data;
+ setHeaders: function(headers){
+ this.set('headers', headers);
+ return this;
+ setFooters: function(footers){
+ this.set('footers', footers);
+ return this;
+ push: function(row, rowProperties, target, tag){
+ var tds = row.map(function(data){
+ var td = new Element(tag || 'td', data.properties),
+ type = data.content || data || '',
+ element = document.id(type);
+ if($type(type) != 'string' && element) td.adopt(element);
+ else td.set('html', type);
+ return td;
+ return {
+ tr: new Element('tr', rowProperties).inject(target || this.body).adopt(tds),
+ tds: tds
+script: HtmlTable.Zebra.js
+description: Builds a stripy table with methods to add rows.
+authors:
+- Harald Kirschner
+- Aaron Newton
+requires:
+- /HtmlTable
+- /Class.refactor
+provides: [HtmlTable.Zebra]
+HtmlTable = Class.refactor(HtmlTable, {
+ options: {
+ classZebra: 'table-tr-odd',
+ zebra: true
+ this.previous.apply(this, arguments);
+ if (this.occluded) return this.occluded;
+ if (this.options.zebra) this.updateZebras();
+ updateZebras: function(){
+ Array.each(this.body.rows, this.zebra, this);
+ zebra: function(row, i){
+ return row[((i % 2) ? 'remove' : 'add')+'Class'](this.options.classZebra);
+ push: function(){
+ var pushed = this.previous.apply(this, arguments);
+ return pushed;
+script: HtmlTable.Sort.js
+description: Builds a stripy, sortable table with methods to add rows.
+authors:
+- Harald Kirschner
+- Aaron Newton
+requires:
+- core:1.2.4/Hash
+- /HtmlTable
+- /Class.refactor
+- /Element.Delegation
+- /Date
+provides: [HtmlTable.Sort]
+ options: {/*
+ onSort: $empty, */
+ sortIndex: 0,
+ sortReverse: false,
+ parsers: [],
+ defaultParser: 'string',
+ classSortable: 'table-sortable',
+ classHeadSort: 'table-th-sort',
+ classHeadSortRev: 'table-th-sort-rev',
+ classNoSort: 'table-th-nosort',
+ classGroupHead: 'table-tr-group-head',
+ classGroup: 'table-tr-group',
+ classCellSort: 'table-td-sort',
+ classSortSpan: 'table-th-sort-span',
+ sortable: false
+ initialize: function () {
+ this.sorted = {index: null, dir: 1};
+ this.bound = {
+ headClick: this.headClick.bind(this)
+ this.sortSpans = new Elements();
+ if (this.options.sortable) {
+ this.enableSort();
+ if (this.options.sortIndex != null) this.sort(this.options.sortIndex, this.options.sortReverse);
+ attachSorts: function(attach){
+ this.element.removeEvents('click:relay(th)');
+ this.element[$pick(attach, true) ? 'addEvent' : 'removeEvent']('click:relay(th)', this.bound.headClick);
+ setHeaders: function(){
+ if (this.sortEnabled) this.detectParsers();
+ detectParsers: function(force){
+ if (!this.head) return;
+ var parsers = this.options.parsers,
+ rows = this.body.rows;
+ // auto-detect
+ this.parsers = $$(this.head.cells).map(function(cell, index) {
+ if (!force && (cell.hasClass(this.options.classNoSort) || cell.retrieve('htmltable-parser'))) return cell.retrieve('htmltable-parser');
+ var thDiv = new Element('div');
+ $each(cell.childNodes, function(node) {
+ thDiv.adopt(node);
+ thDiv.inject(cell);
+ var sortSpan = new Element('span', {'html': ' ', 'class': this.options.classSortSpan}).inject(thDiv, 'top');
+ this.sortSpans.push(sortSpan);
+ var parser = parsers[index],
+ cancel;
+ switch ($type(parser)) {
+ case 'function': parser = {convert: parser}; cancel = true; break;
+ case 'string': parser = parser; cancel = true; break;
+ if (!cancel) {
+ HtmlTable.Parsers.some(function(current) {
+ var match = current.match;
+ if (!match) return false;
+ for (var i = 0, j = rows.length; i < j; i++) {
+ var text = $(rows[i].cells[index]).get('html').clean();
+ if (text && match.test(text)) {
+ parser = current;
+ return true;
+ if (!parser) parser = this.options.defaultParser;
+ cell.store('htmltable-parser', parser);
+ return parser;
+ }, this);
+ headClick: function(event, el) {
+ console.log(el);
+ if (!this.head || el.hasClass(this.options.classNoSort)) return;
+ var index = Array.indexOf(this.head.cells, el);
+ this.sort(index);
+ return false;
+ sort: function(index, reverse, pre) {
+ pre = !!(pre);
+ var classCellSort = this.options.classCellSort;
+ var classGroup = this.options.classGroup,
+ classGroupHead = this.options.classGroupHead;
+ if (!pre) {
+ if (index != null) {
+ if (this.sorted.index == index) {
+ this.sorted.reverse = !(this.sorted.reverse);
+ } else {
+ if (this.sorted.index != null) {
+ this.sorted.reverse = false;
+ this.head.cells[this.sorted.index].removeClass(this.options.classHeadSort).removeClass(this.options.classHeadSortRev);
+ } else {
+ this.sorted.reverse = true;
+ this.sorted.index = index;
+ } else {
+ index = this.sorted.index;
+ if (reverse != null) this.sorted.reverse = reverse;
+ var head = document.id(this.head.cells[index]);
+ if (head) {
+ head.addClass(this.options.classHeadSort);
+ if (this.sorted.reverse) head.addClass(this.options.classHeadSortRev);
+ else head.removeClass(this.options.classHeadSortRev);
+ this.body.getElements('td').removeClass(this.options.classCellSort);
+ var parser = this.parsers[index];
+ if ($type(parser) == 'string') parser = HtmlTable.Parsers.get(parser);
+ if (!parser) return;
+ if (!Browser.Engine.trident) {
+ var rel = this.body.getParent();
+ this.body.dispose();
+ var data = Array.map(this.body.rows, function(row, i) {
+ var value = parser.convert.call(document.id(row.cells[index]));
+ return {
+ position: i,
+ value: value,
+ toString: function() {
+ return value.toString();
+ }, this);
+ data.reverse(true);
+ data.sort(function(a, b){
+ if (a.value === b.value) return 0;
+ return a.value > b.value ? 1 : -1;
+ if (!this.sorted.reverse) data.reverse(true);
+ var i = data.length, body = this.body;
+ var j, position, entry, group;
+ while (i) {
+ var item = data[--i];
+ position = item.position;
+ var row = body.rows[position];
+ if (row.disabled) continue;
+ if (!pre) {
+ if (group === item.value) {
+ row.removeClass(classGroupHead).addClass(classGroup);
+ } else {
+ group = item.value;
+ row.removeClass(classGroup).addClass(classGroupHead);
+ if (this.zebra) this.zebra(row, i);
+ row.cells[index].addClass(classCellSort);
+ body.appendChild(row);
+ for (j = 0; j < i; j++) {
+ if (data[j].position > position) data[j].position--;
+ data = null;
+ if (rel) rel.grab(body);
+ return this.fireEvent('sort', [body, index]);
+ reSort: function(){
+ if (this.sortEnabled) this.sort.call(this, this.sorted.index, this.sorted.reverse);
+ return this;
+ enableSort: function(){
+ this.element.addClass(this.options.classSortable);
+ this.attachSorts(true);
+ this.detectParsers();
+ this.sortEnabled = true;
+ return this;
+ disableSort: function(){
+ this.element.removeClass(this.options.classSortable);
+ this.attachSorts(false);
+ this.sortSpans.each(function(span) { span.destroy(); });
+ this.sortSpans.empty();
+ this.sortEnabled = false;
+ return this;
+HtmlTable.Parsers = new Hash({
+ 'date': {
+ match: /^\d{2}[-\/ ]\d{2}[-\/ ]\d{2,4}$/,
+ convert: function() {
+ return Date.parse(this.get('text')).format('db');
+ type: 'date'
+ 'input-checked': {
+ match: / type="(radio|checkbox)" /,
+ return this.getElement('input').checked;
+ 'input-value': {
+ match: /<input/,
+ return this.getElement('input').value;
+ 'number': {
+ match: /^\d+[^\d.,]*$/,
+ return this.get('text').toInt();
+ number: true
+ 'numberLax': {
+ match: /^[^\d]+\d+$/,
+ return this.get('text').replace(/[^-?^0-9]/, '').toInt();
+ number: true
+ 'float': {
+ match: /^[\d]+\.[\d]+/,
+ return this.get('text').replace(/[^-?^\d.]/, '').toFloat();
+ number: true
+ 'floatLax': {
+ match: /^[^\d]+[\d]+\.[\d]+$/,
+ return this.get('text').replace(/[^-?^\d.]/, '');
+ number: true
+ 'string': {
+ match: null,
+ return this.get('text');
+ 'title': {
+ match: null,
+ return this.title;
+script: Keyboard.js
+description: KeyboardEvents used to intercept events on a class for keyboard and format modifiers in a specific order so as to make alt+shift+c the same as shift+alt+c.
+license: MIT-style license
+authors:
+- Perrin Westrich
+- Aaron Newton
+- Scott Kyle
+requires:
+- /Log
+provides: [Keyboard]
+(function(){
+ var Keyboard = this.Keyboard = new Class({
+ Extends: Events,
+ Implements: [Options, Log],
+ options: {
+ onActivate: $empty,
+ onDeactivate: $empty,
+ defaultEventType: 'keydown',
+ active: false,
+ events: {},
+ nonParsedEvents: ['activate', 'deactivate', 'onactivate', 'ondeactivate', 'changed', 'onchanged']
+ this.setup();
+ setup: function(){
+ this.addEvents(this.options.events);
+ //if this is the root manager, nothing manages it
+ if (Keyboard.manager && !this.manager) Keyboard.manager.manage(this);
+ if (this.options.active) this.activate();
+ handle: function(event, type){
+ //Keyboard.stop(event) prevents key propagation
+ if (event.preventKeyboardPropagation) return;
+ var bubbles = !!this.manager;
+ if (bubbles && this.activeKB){
+ this.activeKB.handle(event, type);
+ this.fireEvent(type, event);
+ if (!bubbles && this.activeKB) this.activeKB.handle(event, type);
+ addEvent: function(type, fn, internal){
+ return this.parent(Keyboard.parse(type, this.options.defaultEventType, this.options.nonParsedEvents), fn, internal);
+ removeEvent: function(type, fn){
+ return this.parent(Keyboard.parse(type, this.options.defaultEventType, this.options.nonParsedEvents), fn);
+ toggleActive: function(){
+ return this[this.active ? 'deactivate' : 'activate']();
+ activate: function(instance){
+ if (instance) {
+ //if we're stealing focus, store the last keyboard to have it so the relenquish command works
+ if (instance != this.activeKB) this.previous = this.activeKB;
+ //if we're enabling a child, assign it so that events are now passed to it
+ this.activeKB = instance.fireEvent('activate');
+ Keyboard.manager.fireEvent('changed');
+ } else if (this.manager) {
+ //else we're enabling ourselves, we must ask our parent to do it for us
+ this.manager.activate(this);
+ return this;
+ deactivate: function(instance){
+ if (instance) {
+ if(instance === this.activeKB) {
+ this.activeKB = null;
+ instance.fireEvent('deactivate');
+ else if (this.manager) {
+ this.manager.deactivate(this);
+ return this;
+ relenquish: function(){
+ if (this.previous) this.activate(this.previous);
+ //management logic
+ manage: function(instance){
+ if (instance.manager) instance.manager.drop(instance);
+ this.instances.push(instance);
+ instance.manager = this;
+ if (!this.activeKB) this.activate(instance);
+ else this._disable(instance);
+ _disable: function(instance){
+ if (this.activeKB == instance) this.activeKB = null;
+ drop: function(instance){
+ this._disable(instance);
+ this.instances.erase(instance);
+ instances: [],
+ trace: function(){
+ Keyboard.trace(this);
+ each: function(fn){
+ Keyboard.each(this, fn);
+ var parsed = {};
+ var modifiers = ['shift', 'control', 'alt', 'meta'];
+ var regex = /^(?:shift|control|ctrl|alt|meta)$/;
+ Keyboard.parse = function(type, eventType, ignore){
+ if (ignore && ignore.contains(type.toLowerCase())) return type;
+ type = type.toLowerCase().replace(/^(keyup|keydown):/, function($0, $1){
+ eventType = $1;
+ return '';
+ if (!parsed[type]){
+ var key, mods = {};
+ type.split('+').each(function(part){
+ if (regex.test(part)) mods[part] = true;
+ else key = part;
+ mods.control = mods.control || mods.ctrl; // allow both control and ctrl
+ var keys = [];
+ modifiers.each(function(mod){
+ if (mods[mod]) keys.push(mod);
+ if (key) keys.push(key);
+ parsed[type] = keys.join('+');
+ return eventType + ':' + parsed[type];
+ Keyboard.each = function(keyboard, fn){
+ var current = keyboard || Keyboard.manager;
+ while (current){
+ fn.run(current);
+ current = current.activeKB;
+ Keyboard.stop = function(event){
+ event.preventKeyboardPropagation = true;
+ Keyboard.manager = new Keyboard({
+ active: true
+ Keyboard.trace = function(keyboard){
+ keyboard = keyboard || Keyboard.manager;
+ keyboard.enableLog();
+ keyboard.log('the following items have focus: ');
+ Keyboard.each(keyboard, function(current){
+ keyboard.log(document.id(current.widget) || current.wiget || current);
+ var handler = function(event){
+ var keys = [];
+ if (event[mod]) keys.push(mod);
+ if (!regex.test(event.key)) keys.push(event.key);
+ Keyboard.manager.handle(event, event.type + ':' + keys.join('+'));
+ document.addEvents({
+ 'keyup': handler,
+ 'keydown': handler
+ Event.Keys.extend({
+ 'shift': 16,
+ 'control': 17,
+ 'alt': 18,
+ 'capslock': 20,
+ 'pageup': 33,
+ 'pagedown': 34,
+ 'end': 35,
+ 'home': 36,
+ 'numlock': 144,
+ 'scrolllock': 145,
+ ';': 186,
+ '=': 187,
+ ',': 188,
+ '-': Browser.Engine.Gecko ? 109 : 189,
+ '.': 190,
+ '/': 191,
+ '`': 192,
+ '[': 219,
+ '\\': 220,
+ ']': 221,
+ "'": 222
+script: HtmlTable.Select.js
+description: Builds a stripy, sortable table with methods to add rows. Rows can be selected with the mouse or keyboard navigation.
+authors:
+- Harald Kirschner
+- Aaron Newton
+requires:
+- /Keyboard
+- /HtmlTable
+- /Class.refactor
+provides: [HtmlTable.Select]
+ options: {
+ /*onRowFocus: $empty,
+ onRowUnfocus: $empty,*/
+ useKeyboard: true,
+ classRowSelected: 'table-tr-selected',
+ classRowHovered: 'table-tr-hovered',
+ classSelectable: 'table-selectable',
+ allowMultiSelect: true,
+ selectable: false
+ this.selectedRows = new Elements();
+ this.bound = {
+ mouseleave: this.mouseleave.bind(this),
+ focusRow: this.focusRow.bind(this)
+ if (this.options.selectable) this.enableSelect();
+ enableSelect: function(){
+ this.selectEnabled = true;
+ this.attachSelects();
+ this.element.addClass(this.options.classSelectable);
+ disableSelect: function(){
+ this.selectEnabled = false;
+ this.attach(false);
+ this.element.removeClass(this.options.classSelectable);
+ attachSelects: function(attach){
+ attach = $pick(attach, true);
+ var method = attach ? 'addEvents' : 'removeEvents';
+ this.element[method]({
+ mouseleave: this.bound.mouseleave
+ this.body[method]({
+ 'click:relay(tr)': this.bound.focusRow
+ if (this.options.useKeyboard || this.keyboard){
+ if (!this.keyboard) this.keyboard = new Keyboard({
+ events: {
+ down: function(e) {
+ e.preventDefault();
+ this.shiftFocus(1);
+ }.bind(this),
+ up: function(e) {
+ this.shiftFocus(-1);
+ }.bind(this),
+ enter: function(e) {
+ if (this.hover) this.focusRow(this.hover);
+ }.bind(this)
+ active: true
+ this.keyboard[attach ? 'activate' : 'deactivate']();
+ this.updateSelects();
+ mouseleave: function(){
+ if (this.hover) this.leaveRow(this.hover);
+ focus: function(){
+ if (this.keyboard) this.keyboard.activate();
+ blur: function(){
+ if (this.keyboard) this.keyboard.deactivate();
+ push: function(){
+ var ret = this.previous.apply(this, arguments);
+ return ret;
+ updateSelects: function(){
+ Array.each(this.body.rows, function(row){
+ var binders = row.retrieve('binders');
+ if ((binders && this.selectEnabled) || (!binders && !this.selectEnabled)) return;
+ if (!binders){
+ binders = {
+ mouseenter: this.enterRow.bind(this, [row]),
+ mouseleave: this.leaveRow.bind(this, [row])
+ row.store('binders', binders).addEvents(binders);
+ } else {
+ row.removeEvents(binders);
+ }, this);
+ enterRow: function(row){
+ if (this.hover) this.hover = this.leaveRow(this.hover);
+ this.hover = row.addClass(this.options.classRowHovered);
+ shiftFocus: function(offset){
+ if (!this.hover) return this.enterRow(this.body.rows[0]);
+ var to = Array.indexOf(this.body.rows, this.hover) + offset;
+ if (to < 0) to = 0;
+ if (to >= this.body.rows.length) to = this.body.rows.length - 1;
+ if (this.hover == this.body.rows[to]) return this;
+ this.enterRow(this.body.rows[to]);
+ leaveRow: function(row){
+ row.removeClass(this.options.classRowHovered);
+ focusRow: function(){
+ var row = arguments[1] || arguments[0]; //delegation passes the event first
+ if (!this.body.getChildren().contains(row)) return;
+ var unfocus = function(row){
+ this.selectedRows.erase(row);
+ row.removeClass(this.options.classRowSelected);
+ this.fireEvent('rowUnfocus', [row, this.selectedRows]);
+ }.bind(this);
+ if (!this.options.allowMultiSelect) this.selectedRows.each(unfocus);
+ if (!this.selectedRows.contains(row)) {
+ this.selectedRows.push(row);
+ row.addClass(this.options.classRowSelected);
+ this.fireEvent('rowFocus', [row, this.selectedRows]);
+ } else {
+ unfocus(row);
+ return false;
+ selectAll: function(status){
+ status = $pick(status, true);
+ if (!this.options.allowMultiSelect && status) return;
+ if (!status) this.selectedRows.removeClass(this.options.classRowSelected).empty();
+ else this.selectedRows.combine(this.body.rows).addClass(this.options.classRowSelected);
+ return this;
+ selectNone: function(){
+ return this.selectAll(false);
+description: Enhances Keyboard by adding the ability to name and describe keyboard shortcuts, and the ability to grab shortcuts by name and bind the shortcut to different keys.
+authors:
+- Perrin Westrich
+requires:
+- /Keyboard.Extras
+provides: [Keyboard.Extras]
+Keyboard.prototype.options.nonParsedEvents.combine(['rebound', 'onrebound']);
+Keyboard.implement({
+ shortcut should be in the format of:
+ 'keys': 'shift+s', // the default to add as an event.
+ 'description': 'blah blah blah', // a brief description of the functionality.
+ 'handler': function(){} // the event handler to run when keys are pressed.
+ addShortcut: function(name, shortcut) {
+ this.shortcuts = this.shortcuts || [];
+ this.shortcutIndex = this.shortcutIndex || {};
+ shortcut.getKeyboard = $lambda(this);
+ shortcut.name = name;
+ this.shortcutIndex[name] = shortcut;
+ this.shortcuts.push(shortcut);
+ if(shortcut.keys) this.addEvent(shortcut.keys, shortcut.handler);
+ return this;
+ addShortcuts: function(obj){
+ for(var name in obj) this.addShortcut(name, obj[name]);
+ return this;
+ getShortcuts: function(){
+ return this.shortcuts || [];
+ getShortcut: function(name){
+ return (this.shortcutIndex || {})[name];
+Keyboard.rebind = function(newKeys, shortcuts){
+ $splat(shortcuts).each(function(shortcut){
+ shortcut.getKeyboard().removeEvent(shortcut.keys, shortcut.handler);
+ shortcut.getKeyboard().addEvent(newKeys, shortcut.handler);
+ shortcut.keys = newKeys;
+ shortcut.getKeyboard().fireEvent('rebound');
+Keyboard.getActiveShortcuts = function(keyboard) {
+ var activeKBS = [], activeSCS = [];
+ Keyboard.each(keyboard, [].push.bind(activeKBS));
+ activeKBS.each(function(kb){ activeSCS.extend(kb.getShortcuts()); });
+ return activeSCS;
+Keyboard.getShortcut = function(name, keyboard, opts){
+ opts = opts || {};
+ var shortcuts = opts.many ? [] : null,
+ set = opts.many ? function(kb){
+ var shortcut = kb.getShortcut(name);
+ if(shortcut) shortcuts.push(shortcut);
+ } : function(kb) {
+ if(!shortcuts) shortcuts = kb.getShortcut(name);
+ Keyboard.each(keyboard, set);
+ return shortcuts;
+Keyboard.getShortcuts = function(name, keyboard) {
+ return Keyboard.getShortcut(name, keyboard, { many: true });
+script: Scroller.js
+description: Class which scrolls the contents of any Element (including the window) when the mouse reaches the Element's boundaries.
+authors:
+- Valerio Proietti
+requires:
+- core:1.2.4/Element.Dimensions
+provides: [Scroller]
+var Scroller = new Class({
+ options: {
+ area: 20,
+ velocity: 1,
+ onChange: function(x, y){
+ this.element.scrollTo(x, y);
+ fps: 50
+ this.docBody = document.id(this.element.getDocument().body);
+ this.listener = ($type(this.element) != 'element') ? this.docBody : this.element;
+ this.timer = null;
+ this.bound = {
+ attach: this.attach.bind(this),
+ detach: this.detach.bind(this),
+ getCoords: this.getCoords.bind(this)
+ start: function(){
+ this.listener.addEvents({
+ mouseover: this.bound.attach,
+ mouseout: this.bound.detach
+ stop: function(){
+ this.listener.removeEvents({
+ this.detach();
+ this.timer = $clear(this.timer);
+ attach: function(){
+ this.listener.addEvent('mousemove', this.bound.getCoords);
+ this.listener.removeEvent('mousemove', this.bound.getCoords);
+ getCoords: function(event){
+ this.page = (this.listener.get('tag') == 'body') ? event.client : event.page;
+ if (!this.timer) this.timer = this.scroll.periodical(Math.round(1000 / this.options.fps), this);
+ scroll: function(){
+ var size = this.element.getSize(),
+ scroll = this.element.getScroll(),
+ pos = this.element != this.docBody ? this.element.getOffsets() : {x: 0, y:0},
+ scrollSize = this.element.getScrollSize(),
+ change = {x: 0, y: 0};
+ for (var z in this.page){
+ if (this.page[z] < (this.options.area + pos[z]) && scroll[z] != 0) {
+ change[z] = (this.page[z] - this.options.area - pos[z]) * this.options.velocity;
+ } else if (this.page[z] + this.options.area > (size[z] + pos[z]) && scroll[z] + size[z] != scrollSize[z]) {
+ change[z] = (this.page[z] - size[z] + this.options.area - pos[z]) * this.options.velocity;
+ if (change.y || change.x) this.fireEvent('change', [scroll.x + change.x, scroll.y + change.y]);
+script: Tips.js
+description: Class for creating nice tips that follow the mouse cursor when hovering an element.
+authors:
+- Valerio Proietti
+- Christoph Pojer
+requires:
+- /MooTools.More
+provides: [Tips]
+(function(){
+var read = function(option, element){
+ return (option) ? ($type(option) == 'function' ? option(element) : element.get(option)) : '';
+this.Tips = new Class({
+ options: {
+ onAttach: $empty(element),
+ onDetach: $empty(element),
+ onShow: function(){
+ this.tip.setStyle('display', 'block');
+ onHide: function(){
+ this.tip.setStyle('display', 'none');
+ title: 'title',
+ text: function(element){
+ return element.get('rel') || element.get('href');
+ showDelay: 100,
+ hideDelay: 100,
+ className: 'tip-wrap',
+ offset: {x: 16, y: 16},
+ windowPadding: {x:0, y:0},
+ fixed: false
+ var params = Array.link(arguments, {options: Object.type, elements: $defined});
+ if (params.elements) this.attach(params.elements);
+ this.container = new Element('div', {'class': 'tip'});
+ if (this.tip) return this.tip;
+ return this.tip = new Element('div', {
+ 'class': this.options.className,
+ styles: {
+ top: 0,
+ left: 0
+ }).adopt(
+ new Element('div', {'class': 'tip-top'}),
+ this.container,
+ new Element('div', {'class': 'tip-bottom'})
+ ).inject(document.body);
+ attach: function(elements){
+ $$(elements).each(function(element){
+ var title = read(this.options.title, element),
+ text = read(this.options.text, element);
+ element.erase('title').store('tip:native', title).retrieve('tip:title', title);
+ element.retrieve('tip:text', text);
+ this.fireEvent('attach', [element]);
+ var events = ['enter', 'leave'];
+ if (!this.options.fixed) events.push('move');
+ events.each(function(value){
+ var event = element.retrieve('tip:' + value);
+ if (!event) event = this['element' + value.capitalize()].bindWithEvent(this, element);
+ element.store('tip:' + value, event).addEvent('mouse' + value, event);
+ }, this);
+ }, this);
+ return this;
+ detach: function(elements){
+ ['enter', 'leave', 'move'].each(function(value){
+ element.removeEvent('mouse' + value, element.retrieve('tip:' + value)).eliminate('tip:' + value);
+ this.fireEvent('detach', [element]);
+ if (this.options.title == 'title'){ // This is necessary to check if we can revert the title
+ var original = element.retrieve('tip:native');
+ if (original) element.set('title', original);
+ }, this);
+ return this;
+ elementEnter: function(event, element){
+ this.container.empty();
+ ['title', 'text'].each(function(value){
+ var content = element.retrieve('tip:' + value);
+ if (content) this.fill(new Element('div', {'class': 'tip-' + value}).inject(this.container), content);
+ }, this);
+ this.timer = (function(){
+ this.show(this, element);
+ this.position((this.options.fixed) ? {page: element.getPosition()} : event);
+ }).delay(this.options.showDelay, this);
+ elementLeave: function(event, element){
+ this.timer = this.hide.delay(this.options.hideDelay, this, element);
+ this.fireForParent(event, element);
+ fireForParent: function(event, element){
+ element = element.getParent();
+ if (!element || element == document.body) return;
+ if (element.retrieve('tip:enter')) element.fireEvent('mouseenter', event);
+ else this.fireForParent(event, element);
+ elementMove: function(event, element){
+ this.position(event);
+ position: function(event){
+ if (!this.tip) document.id(this);
+ var size = window.getSize(), scroll = window.getScroll(),
+ tip = {x: this.tip.offsetWidth, y: this.tip.offsetHeight},
+ props = {x: 'left', y: 'top'},
+ obj = {};
+ for (var z in props){
+ obj[props[z]] = event.page[z] + this.options.offset[z];
+ if ((obj[props[z]] + tip[z] - scroll[z]) > size[z] - this.options.windowPadding[z]) obj[props[z]] = event.page[z] - this.options.offset[z] - tip[z];
+ this.tip.setStyles(obj);
+ fill: function(element, contents){
+ if(typeof contents == 'string') element.set('html', contents);
+ else element.adopt(contents);
+ show: function(element){
+ this.fireEvent('show', [this.tip, element]);
+ hide: function(element){
+ this.fireEvent('hide', [this.tip, element]);
+script: Date.Catalan.js
+description: Date messages for Catalan.
+authors:
+- Alfons Sanchez
+requires:
+- /Lang
+- /Date
+provides: [Date.Catalan]
+MooTools.lang.set('ca-CA', 'Date', {
+ months: ['Gener', 'Febrer', 'Març', 'Abril', 'Maig', 'Juny', 'Juli', 'Agost', 'Setembre', 'Octubre', 'Novembre', 'Desembre'],
+ days: ['Diumenge', 'Dilluns', 'Dimarts', 'Dimecres', 'Dijous', 'Divendres', 'Dissabte'],
+ //culture's date order: MM/DD/YYYY
+ dateOrder: ['date', 'month', 'year'],
+ shortDate: '%d/%m/%Y',
+ shortTime: '%H:%M',
+ AM: 'AM',
+ PM: 'PM',
+ /* Date.Extras */
+ ordinal: '',
+ lessThanMinuteAgo: 'fa menys d`un minut',
+ minuteAgo: 'fa un minut',
+ minutesAgo: 'fa {delta} minuts',
+ hourAgo: 'fa un hora',
+ hoursAgo: 'fa unes {delta} hores',
+ dayAgo: 'fa un dia',
+ daysAgo: 'fa {delta} dies',
+ lessThanMinuteUntil: 'menys d`un minut des d`ara',
+ minuteUntil: 'un minut des d`ara',
+ minutesUntil: '{delta} minuts des d`ara',
+ hourUntil: 'un hora des d`ara',
+ hoursUntil: 'unes {delta} hores des d`ara',
+ dayUntil: '1 dia des d`ara',
+ daysUntil: '{delta} dies des d`ara'
+script: Date.Czech.js
+description: Date messages for Czech.
+authors:
+- Jan Äerný chemiX
+requires:
+- /Lang
+- /Date
+provides: [Date.Czech]
+MooTools.lang.set('cs-CZ', 'Date', {
+ months: ['Leden', 'Ãnor', 'BÅezen', 'Duben', 'KvÄten', 'Äerven', 'Äervenec', 'Srpen', 'ZáÅÃ', 'ÅÃjen', 'Listopad', 'Prosinec'],
+ days: ['NedÄle', 'PondÄlÃ', 'Ãterý', 'StÅeda', 'Ätvrtek', 'Pátek', 'Sobota'],
+ AM: 'dop.',
+ PM: 'odp.',
+ /* Date.Extras */
+ ordinal: function(dayOfMonth){
+ return '.';
+ // TODO : in examples use and fix it
+ lessThanMinuteAgo: 'ménÄ než minutou',
+ minuteAgo: 'pÅibližnÄ pÅed minutou',
+ minutesAgo: 'pÅed {delta} minutami',
+ hourAgo: 'pÅibližnÄ pÅed hodinou',
+ hoursAgo: 'pÅed {delta} hodinami',
+ dayAgo: 'pÅed dnem',
+ daysAgo: 'pÅed {delta} dni',
+ lessThanMinuteUntil: 'pÅed ménÄ než minutou',
+ minuteUntil: 'asi pÅed minutou',
+ minutesUntil: ' asi pÅed {delta} minutami',
+ hourUntil: 'asi pÅed hodinou',
+ hoursUntil: 'pÅed {delta} hodinami',
+ dayUntil: 'pÅed dnem',
+ daysUntil: 'pÅed {delta} dni',
+ weekUntil: 'pÅed týdnem',
+ weeksUntil: 'pÅed {delta} týdny',
+ monthUntil: 'pÅed mÄsÃcem',
+ monthsUntil: 'pÅed {delta} mÄsÃci',
+ yearUntil: 'pÅed rokem',
+ yearsUntil: 'pÅed {delta} lety'
+script: Date.Danish.js
+description: Date messages for Danish.
+authors:
+- Martin Overgaard
+- Henrik Hansen
+requires:
+- /Lang
+- /Date
+provides: [Date.Danish]
+MooTools.lang.set('da-DK', 'Date', {
+ months: ['Januar', 'Februa', 'Marts', 'April', 'Maj', 'Juni', 'Juli', 'August', 'September', 'Oktober', 'November', 'December'],
+ days: ['Søndag', 'Mandag', 'Tirsdag', 'Onsdag', 'Torsdag', 'Fredag', 'Lørdag'],
+ //culture's date order: DD/MM/YYYY
+ AM: 'AM',
+ PM: 'PM',
+ shortDate: '%d-%m-%Y',
+ /* Date.Extras */
+ //1st, 2nd, 3rd, etc.
+ return (dayOfMonth > 3 && dayOfMonth < 21) ? 'th' : ['th', 'st', 'nd', 'rd', 'th'][Math.min(dayOfMonth % 10, 4)];
+ lessThanMinuteAgo: 'mindre end et minut siden',
+ minuteAgo: 'omkring et minut siden',
+ minutesAgo: '{delta} minutter siden',
+ hourAgo: 'omkring en time siden',
+ hoursAgo: 'omkring {delta} timer siden',
+ dayAgo: '1 dag siden',
+ daysAgo: '{delta} dage siden',
+ weekAgo: '1 uge siden',
+ weeksAgo: '{delta} uger siden',
+ monthAgo: '1 måned siden',
+ monthsAgo: '{delta} måneder siden',
+ yearthAgo: '1 år siden',
+ yearsAgo: '{delta} år siden',
+ lessThanMinuteUntil: 'mindre end et minut fra nu',
+ minuteUntil: 'omkring et minut fra nu',
+ minutesUntil: '{delta} minutter fra nu',
+ hourUntil: 'omkring en time fra nu',
+ hoursUntil: 'omkring {delta} timer fra nu',
+ dayUntil: '1 dag fra nu',
+ daysUntil: '{delta} dage fra nu',
+ weekUntil: '1 uge fra nu',
+ weeksUntil: '{delta} uger fra nu',
+ monthUntil: '1 måned fra nu',
+ monthsUntil: '{delta} måneder fra nu',
+ yearUntil: '1 år fra nu',
+ yearsUntil: '{delta} år fra nu'
+script: Date.Dutch.js
+description: Date messages in Dutch.
+authors:
+- Lennart Pilon
+requires:
+- /Lang
+- /Date
+provides: [Date.Dutch]
+MooTools.lang.set('nl-NL', 'Date', {
+ months: ['Januari', 'Februari', 'Maart', 'April', 'Mei', 'Juni', 'Juli', 'Augustus', 'September', 'Oktober', 'November', 'December'],
+ days: ['Zondag', 'Maandag', 'Dinsdag', 'Woensdag', 'Donderdag', 'Vrijdag', 'Zaterdag'],
+ AM: 'AM',
+ PM: 'PM',
+ /* Date.Extras */
+ ordinal: 'e',
+ lessThanMinuteAgo: 'minder dan een minuut geleden',
+ minuteAgo: 'ongeveer een minuut geleden',
+ minutesAgo: 'minuten geleden',
+ hourAgo: 'ongeveer een uur geleden',
+ hoursAgo: 'ongeveer {delta} uur geleden',
+ dayAgo: '{delta} dag geleden',
+ daysAgo: 'dagen geleden',
+ weekAgo: 'een week geleden',
+ weeksAgo: '{delta} weken geleden',
+ monthAgo: 'een maand geleden',
+ monthsAgo: '{delta} maanden geleden',
+ yearAgo: 'een jaar geleden',
+ yearsAgo: '{delta} jaar geleden',
+ lessThanMinuteUntil: 'minder dan een minuut vanaf nu',
+ minuteUntil: 'ongeveer een minuut vanaf nu',
+ minutesUntil: '{delta} minuten vanaf nu',
+ hourUntil: 'ongeveer een uur vanaf nu',
+ hoursUntil: 'ongeveer {delta} uur vanaf nu',
+ dayUntil: '1 dag vanaf nu',
+ daysUntil: '{delta} dagen vanaf nu',
+ yearthAgo: 'een jaar geleden',
+ weekUntil: 'over een week',
+ weeksUntil: 'over {delta} weken',
+ monthUntil: 'over een maand',
+ monthsUntil: 'over {delta} maanden',
+ yearUntil: 'over een jaar',
+ yearsUntil: 'over {delta} jaar'
+script: Date.English.GB.js
+description: Date messages for British English.
+authors:
+- Aaron Newton
+requires:
+- /Lang
+- /Date
+provides: [Date.English.GB]
+MooTools.lang.set('en-GB', 'Date', {
+}).set('cascade', ['en-US']);/*
+script: Date.Estonian.js
+description: Date messages for Estonian.
+authors:
+- Kevin Valdek
+requires:
+- /Lang
+- /Date
+provides: [Date.Estonian]
+MooTools.lang.set('et-EE', 'Date', {
+ months: ['jaanuar', 'veebruar', 'märts', 'aprill', 'mai', 'juuni', 'juuli', 'august', 'september', 'oktoober', 'november', 'detsember'],
+ days: ['pühapäev', 'esmaspäev', 'teisipäev', 'kolmapäev', 'neljapäev', 'reede', 'laupäev'],
+ //culture's date order: MM.DD.YYYY
+ dateOrder: ['month', 'date', 'year'],
+ AM: 'AM',
+ PM: 'PM',
+ shortDate: '%m.%d.%Y',
+ /* Date.Extras */
+ ordinal: '',
+ lessThanMinuteAgo: 'vähem kui minut aega tagasi',
+ minuteAgo: 'umbes minut aega tagasi',
+ minutesAgo: '{delta} minutit tagasi',
+ hourAgo: 'umbes tund aega tagasi',
+ hoursAgo: 'umbes {delta} tundi tagasi',
+ dayAgo: '1 päev tagasi',
+ daysAgo: '{delta} päeva tagasi',
+ weekAgo: '1 nädal tagasi',
+ weeksAgo: '{delta} nädalat tagasi',
+ monthAgo: '1 kuu tagasi',
+ monthsAgo: '{delta} kuud tagasi',
+ yearAgo: '1 aasta tagasi',
+ yearsAgo: '{delta} aastat tagasi',
+ lessThanMinuteUntil: 'vähem kui minuti aja pärast',
+ minuteUntil: 'umbes minuti aja pärast',
+ minutesUntil: '{delta} minuti pärast',
+ hourUntil: 'umbes tunni aja pärast',
+ hoursUntil: 'umbes {delta} tunni pärast',
+ dayUntil: '1 päeva pärast',
+ daysUntil: '{delta} päeva pärast',
+ weekUntil: '1 nädala pärast',
+ weeksUntil: '{delta} nädala pärast',
+ monthUntil: '1 kuu pärast',
+ monthsUntil: '{delta} kuu pärast',
+ yearUntil: '1 aasta pärast',
+ yearsUntil: '{delta} aasta pärast'
+script: Date.German.js
+description: Date messages for German.
+authors:
+- Christoph Pojer
+- Frank Rossi
+- Ulrich Petri
+- Fabian Beiner
+requires:
+- /Lang
+- /Date
+provides: [Date.German]
+MooTools.lang.set('de-DE', 'Date', {
+ months: ['Januar', 'Februar', 'März', 'April', 'Mai', 'Juni', 'Juli', 'August', 'September', 'Oktober', 'November', 'Dezember'],
+ days: ['Sonntag', 'Montag', 'Dienstag', 'Mittwoch', 'Donnerstag', 'Freitag', 'Samstag'],
+ dateOrder: [ 'date', 'month', 'year', '.'],
+ AM: 'vormittags',
+ PM: 'nachmittags',
+ shortDate: '%d.%m.%Y',
+ /* Date.Extras */
+ ordinal: '.',
+ lessThanMinuteAgo: 'Vor weniger als einer Minute',
+ minuteAgo: 'Vor einer Minute',
+ minutesAgo: 'Vor {delta} Minuten',
+ hourAgo: 'Vor einer Stunde',
+ hoursAgo: 'Vor {delta} Stunden',
+ dayAgo: 'Vor einem Tag',
+ daysAgo: 'Vor {delta} Tagen',
+ weekAgo: 'Vor einer Woche',
+ weeksAgo: 'Vor {delta} Wochen',
+ monthAgo: 'Vor einem Monat',
+ monthsAgo: 'Vor {delta} Monaten',
+ yearAgo: 'Vor einem Jahr',
+ yearsAgo: 'Vor {delta} Jahren',
+ lessThanMinuteUntil: 'In weniger als einer Minute',
+ minuteUntil: 'In einer Minute',
+ minutesUntil: 'In {delta} Minuten',
+ hourUntil: 'In ca. einer Stunde',
+ hoursUntil: 'In ca. {delta} Stunden',
+ dayUntil: 'In einem Tag',
+ daysUntil: 'In {delta} Tagen',
+ weekUntil: 'In einer Woche',
+ weeksUntil: 'In {delta} Wochen',
+ monthUntil: 'In einem Monat',
+ monthsUntil: 'In {delta} Monaten',
+ yearUntil: 'In einem Jahr',
+ yearsUntil: 'In {delta} Jahren'
+script: Date.German.CH.js
+description: Date messages for German (Switzerland).
+authors:
+- Michael van der Weg
+requires:
+- /Lang
+- /Date.German
+provides: [Date.German.CH]
+MooTools.lang.set('de-CH', 'cascade', ['de-DE']);/*
+script: Date.French.js
+description: Date messages in French.
+authors:
+- Nicolas Sorosac
+- Antoine Abt
+requires:
+- /Lang
+- /Date
+provides: [Date.French]
+MooTools.lang.set('fr-FR', 'Date', {
+ months: ['janvier', 'février', 'mars', 'avril', 'mai', 'juin', 'juillet', 'août', 'septembre', 'octobre', 'novembre', 'décembre'],
+ days: ['dimanche', 'lundi', 'mardi', 'mercredi', 'jeudi', 'vendredi', 'samedi'],
+ AM: 'AM',
+ PM: 'PM',
+ /* Date.Extras */
+ getOrdinal: function(dayOfMonth){
+ return (dayOfMonth > 1) ? '' : 'er';
+ lessThanMinuteAgo: 'il y a moins d\'une minute',
+ minuteAgo: 'il y a une minute',
+ minutesAgo: 'il y a {delta} minutes',
+ hourAgo: 'il y a une heure',
+ hoursAgo: 'il y a {delta} heures',
+ dayAgo: 'il y a un jour',
+ daysAgo: 'il y a {delta} jours',
+ weekAgo: 'il y a une semaine',
+ weeksAgo: 'il y a {delta} semaines',
+ monthAgo: 'il y a 1 mois',
+ monthsAgo: 'il y a {delta} mois',
+ yearthAgo: 'il y a 1 an',
+ yearsAgo: 'il y a {delta} ans',
+ lessThanMinuteUntil: 'dans moins d\'une minute',
+ minuteUntil: 'dans une minute',
+ minutesUntil: 'dans {delta} minutes',
+ hourUntil: 'dans une heure',
+ hoursUntil: 'dans {delta} heures',
+ dayUntil: 'dans un jour',
+ daysUntil: 'dans {delta} jours',
+ weekUntil: 'dans 1 semaine',
+ weeksUntil: 'dans {delta} semaines',
+ monthUntil: 'dans 1 mois',
+ monthsUntil: 'dans {delta} mois',
+ yearUntil: 'dans 1 an',
+ yearsUntil: 'dans {delta} ans'
+script: Date.Italian.js
+description: Date messages for Italian.
+license: MIT-style license.
+authors:
+- Andrea Novero
+- Valerio Proietti
+requires:
+- /Lang
+- /Date
+provides: [Date.Italian]
+MooTools.lang.set('it-IT', 'Date', {
+ months: ['Gennaio', 'Febbraio', 'Marzo', 'Aprile', 'Maggio', 'Giugno', 'Luglio', 'Agosto', 'Settembre', 'Ottobre', 'Novembre', 'Dicembre'],
+ days: ['Domenica', 'Lunedì', 'Martedì', 'Mercoledì', 'Giovedì', 'Venerdì', 'Sabato'],
+ AM: 'AM',
+ PM: 'PM',
+ shortTime: '%H.%M',
+ /* Date.Extras */
+ ordinal: 'º',
+ lessThanMinuteAgo: 'meno di un minuto fa',
+ minuteAgo: 'circa un minuto fa',
+ minutesAgo: 'circa {delta} minuti fa',
+ hourAgo: 'circa un\'ora fa',
+ hoursAgo: 'circa {delta} ore fa',
+ dayAgo: 'circa 1 giorno fa',
+ daysAgo: 'circa {delta} giorni fa',
+ lessThanMinuteUntil: 'tra meno di un minuto',
+ minuteUntil: 'tra circa un minuto',
+ minutesUntil: 'tra circa {delta} minuti',
+ hourUntil: 'tra circa un\'ora',
+ hoursUntil: 'tra circa {delta} ore',
+ dayUntil: 'tra circa un giorno',
+ daysUntil: 'tra circa {delta} giorni'
+script: Date.Norwegian.js
+description: Date messages in Norwegian.
+authors:
+- Espen 'Rexxars' Hovlandsdal
+requires:
+- /Lang
+- /Date
+provides: [Date.Norwegian]
+MooTools.lang.set('no-NO', 'Date', {
+ lessThanMinuteAgo: 'kortere enn et minutt siden',
+ minuteAgo: 'omtrent et minutt siden',
+ hourAgo: 'omtrent en time siden',
+ hoursAgo: 'omtrent {delta} timer siden',
+ dayAgo: '{delta} dag siden',
+ daysAgo: '{delta} dager siden'
+script: Date.Polish.js
+description: Date messages for Polish.
+authors:
+- Oskar Krawczyk
+requires:
+- /Lang
+- /Date
+provides: [Date.Polish]
+MooTools.lang.set('pl-PL', 'Date', {
+ months: ['StyczeÅ', 'Luty', 'Marzec', 'KwiecieÅ', 'Maj', 'Czerwiec', 'Lipiec', 'SierpieÅ', 'WrzesieÅ', 'Październik', 'Listopad', 'GrudzieÅ'],
+ days: ['Niedziela', 'PoniedziaÅek', 'Wtorek', 'Åroda', 'Czwartek', 'PiÄ
tek', 'Sobota'],
+ dateOrder: ['year', 'month', 'date'],
+ AM: 'nad ranem',
+ PM: 'po poÅudniu',
+ shortDate: '%Y-%m-%d',
+ /* Date.Extras */
+ return (dayOfMonth > 3 && dayOfMonth < 21) ? 'ty' : ['ty', 'szy', 'gi', 'ci', 'ty'][Math.min(dayOfMonth % 10, 4)];
+ lessThanMinuteAgo: 'mniej niż minute temu',
+ minuteAgo: 'okoÅo minutÄ temu',
+ minutesAgo: '{delta} minut temu',
+ hourAgo: 'okoÅo godzinÄ temu',
+ hoursAgo: 'okoÅo {delta} godzin temu',
+ dayAgo: 'Wczoraj',
+ daysAgo: '{delta} dni temu',
+ lessThanMinuteUntil: 'za niecaÅÄ
minutÄ',
+ minuteUntil: 'za okoÅo minutÄ',
+ minutesUntil: 'za {delta} minut',
+ hourUntil: 'za okoÅo godzinÄ',
+ hoursUntil: 'za okoÅo {delta} godzin',
+ dayUntil: 'za 1 dzieÅ',
+ daysUntil: 'za {delta} dni'
+script: Date.Portuguese.BR.js
+description: Date messages in Portuguese-BR (Brazil).
+authors:
+- Fabio Miranda Costa
+requires:
+- /Lang
+- /Date
+provides: [Date.Portuguese.BR]
+MooTools.lang.set('pt-BR', 'Date', {
+ months: ['Janeiro', 'Fevereiro', 'Março', 'Abril', 'Maio', 'Junho', 'Julho', 'Agosto', 'Setembro', 'Outubro', 'Novembro', 'Dezembro'],
+ days: ['Domingo', 'Segunda-feira', 'Terça-feira', 'Quarta-feira', 'Quinta-feira', 'Sexta-feira', 'Sábado'],
+ /* Date.Extras */
+ //1º, 2º, 3º, etc.
+ return 'º';
+ lessThanMinuteAgo: 'há menos de um minuto',
+ minuteAgo: 'há cerca de um minuto',
+ minutesAgo: 'há {delta} minutos',
+ hourAgo: 'há cerca de uma hora',
+ hoursAgo: 'há cerca de {delta} horas',
+ dayAgo: 'há um dia',
+ daysAgo: 'há {delta} dias',
+ weekAgo: 'há uma semana',
+ weeksAgo: 'há {delta} semanas',
+ monthAgo: 'há um mês',
+ monthsAgo: 'há {delta} meses',
+ yearAgo: 'há um ano',
+ yearsAgo: 'há {delta} anos',
+ lessThanMinuteUntil: 'em menos de um minuto',
+ minuteUntil: 'em um minuto',
+ minutesUntil: 'em {delta} minutos',
+ hourUntil: 'em uma hora',
+ hoursUntil: 'em {delta} horas',
+ dayUntil: 'em um dia',
+ daysUntil: 'em {delta} dias',
+ weekUntil: 'em uma semana',
+ weeksUntil: 'em {delta} semanas',
+ monthUntil: 'em um mês',
+ monthsUntil: 'em {delta} meses',
+ yearUntil: 'em um ano',
+ yearsUntil: 'em {delta} anos'
+Script: Date.Russian.js
+ Date messages for Russian.
+ License:
+ MIT-style license.
+ Authors:
+ Evstigneev Pavel
+MooTools.lang.set('ru-RU-unicode', 'Date', {
+ months: ['ЯнваÑÑ', 'ФевÑалÑ', 'ÐаÑÑ', 'Ð?пÑелÑ', 'Ðай', 'ÐÑнÑ', 'ÐÑлÑ', 'Ð?вгÑÑ?Ñ', 'СенÑÑ?бÑÑ', 'ÐкÑÑ?бÑÑ', 'Ð?оÑ?бÑÑ', 'ÐекабÑÑ'],
+ days: ['ÐоÑ?кÑеÑ?енÑе', 'ÐонеделÑник', 'ÐÑоÑник', 'СÑеда', 'ЧеÑвеÑг', 'ÐÑ?ÑниÑа', 'СÑббоÑа'],
+ AM: 'AM',
+ PM: 'PM',
+ * Russian language pluralization rules, taken from CLDR project, http://unicode.org/cldr/
+ * one -> n mod 10 is 1 and n mod 100 is not 11;
+ * few -> n mod 10 in 2..4 and n mod 100 not in 12..14;
+ * many -> n mod 10 is 0 or n mod 10 in 5..9 or n mod 100 in 11..14;
+ * other -> everything else (example 3.14)
+ pluralize: function (n, one, few, many, other) {
+ var modulo10 = n % 10
+ var modulo100 = n % 100
+ if (modulo10 == 1 && modulo100 != 11) {
+ return one;
+ } else if ((modulo10 == 2 || modulo10 == 3 || modulo10 == 4) && !(modulo100 == 12 || modulo100 == 13 || modulo100 == 14)) {
+ return few;
+ } else if (modulo10 == 0 || (modulo10 == 5 || modulo10 == 6 || modulo10 == 7 || modulo10 == 8 || modulo10 == 9) || (modulo100 == 11 || modulo100 == 12 || modulo100 == 13 || modulo100 == 14)) {
+ return many;
+ } else {
+ return other;
+ /* Date.Extras */
+ ordinal: '',
+ lessThanMinuteAgo: 'менÑÑе минÑÑÑ Ð½Ð°Ð·Ð°Ð´',
+ minuteAgo: 'минÑÑа назад',
+ minutesAgo: function (delta) { return '{delta} ' + this.pluralize(delta, 'минÑÑа', 'минÑÑÑ', 'минÑÑ') + ' назад'},
+ hourAgo: 'ÑаÑ? назад',
+ hoursAgo: function (delta) { return '{delta} ' + this.pluralize(delta, 'ÑаÑ?', 'ÑаÑ?а', 'ÑаÑ?ов') + ' назад'},
+ dayAgo: 'вÑеÑа',
+ daysAgo: function (delta) { return '{delta} ' + this.pluralize(delta, 'денÑ', 'днÑ?', 'дней') + ' назад' },
+ lessThanMinuteUntil: 'менÑÑе минÑÑÑ Ð½Ð°Ð·Ð°Ð´',
+ minuteUntil: 'ÑеÑез минÑÑÑ',
+ minutesUntil: function (delta) { return 'ÑеÑез {delta} ' + this.pluralize(delta, 'ÑаÑ?', 'ÑаÑ?а', 'ÑаÑ?ов') + ''},
+ hourUntil: 'ÑеÑез ÑаÑ?',
+ hoursUntil: function (delta) { return 'ÑеÑез {delta} ' + this.pluralize(delta, 'ÑаÑ?', 'ÑаÑ?а', 'ÑаÑ?ов') + ''},
+ dayUntil: 'завÑÑа',
+ daysUntil: function (delta) { return 'ÑеÑез {delta} ' + this.pluralize(delta, 'денÑ', 'днÑ?', 'дней') + '' }
+script: Date.Spanish.US.js
+description: Date messages for Spanish.
+authors:
+- Ãlfons Sanchez
+requires:
+- /Lang
+- /Date
+provides: [Date.Spanish]
+MooTools.lang.set('es-ES', 'Date', {
+ months: ['Enero', 'Febrero', 'Marzo', 'Abril', 'Mayo', 'Junio', 'Julio', 'Agosto', 'Septiembre', 'Octubre', 'Noviembre', 'Diciembre'],
+ days: ['Domingo', 'Lunes', 'Martes', 'Miércoles', 'Jueves', 'Viernes', 'Sábado'],
+ AM: 'AM',
+ PM: 'PM',
+ /* Date.Extras */
+ ordinal: '',
+ lessThanMinuteAgo: 'hace menos de un minuto',
+ minuteAgo: 'hace un minuto',
+ minutesAgo: 'hace {delta} minutos',
+ hourAgo: 'hace una hora',
+ hoursAgo: 'hace unas {delta} horas',
+ dayAgo: 'hace un dÃa',
+ daysAgo: 'hace {delta} dÃas',
+ weekAgo: 'hace una semana',
+ weeksAgo: 'hace unas {delta} semanas',
+ monthAgo: 'hace un mes',
+ monthsAgo: 'hace {delta} meses',
+ yearAgo: 'hace un año',
+ yearsAgo: 'hace {delta} años',
+ lessThanMinuteUntil: 'menos de un minuto desde ahora',
+ minuteUntil: 'un minuto desde ahora',
+ minutesUntil: '{delta} minutos desde ahora',
+ hourUntil: 'una hora desde ahora',
+ hoursUntil: 'unas {delta} horas desde ahora',
+ dayUntil: 'un dÃa desde ahora',
+ daysUntil: '{delta} dÃas desde ahora',
+ weekUntil: 'una semana desde ahora',
+ weeksUntil: 'unas {delta} semanas desde ahora',
+ monthUntil: 'un mes desde ahora',
+ monthsUntil: '{delta} meses desde ahora',
+ yearUntil: 'un año desde ahora',
+ yearsUntil: '{delta} años desde ahora'
+script: Date.Swedish.js
+description: Date messages for Swedish (SE).
+authors:
+- Martin Lundgren
+requires:
+- /Lang
+- /Date
+provides: [Date.Swedish]
+MooTools.lang.set('sv-SE', 'Date', {
+ months: ['januari', 'februari', 'mars', 'april', 'maj', 'juni', 'juli', 'augusti', 'september', 'oktober', 'november', 'december'],
+ days: ['söndag', 'måndag', 'tisdag', 'onsdag', 'torsdag', 'fredag', 'lördag'],
+ // culture's date order: YYYY-MM-DD
+ AM: '',
+ PM: '',
+ /* Date.Extras */
+ // Not used in Swedish
+ return '';
+ lessThanMinuteAgo: 'mindre än en minut sedan',
+ minuteAgo: 'ungefär en minut sedan',
+ minutesAgo: '{delta} minuter sedan',
+ hourAgo: 'ungefär en timme sedan',
+ hoursAgo: 'ungefär {delta} timmar sedan',
+ dayAgo: '1 dag sedan',
+ daysAgo: '{delta} dagar sedan',
+ lessThanMinuteUntil: 'mindre än en minut sedan',
+ minuteUntil: 'ungefär en minut sedan',
+ minutesUntil: '{delta} minuter sedan',
+ hourUntil: 'ungefär en timme sedan',
+ hoursUntil: 'ungefär {delta} timmar sedan',
+ dayUntil: '1 dag sedan',
+ daysUntil: '{delta} dagar sedan'
+script: Date.Ukrainian.js
+description: Date messages for Ukrainian.
+authors:
+- Slik
+requires:
+- /Lang
+- /Date
+provides: [Date.Ukrainian]
+(function(){
+ var pluralize = function(n, one, few, many, other){
+ var d = (n / 10).toInt();
+ var z = n % 10;
+ var s = (n / 100).toInt();
+ if(d == 1 && n > 10) return many;
+ if(z == 1) return one;
+ if(z > 0 && z < 5) return few;
+ return many;
+ MooTools.lang.set('uk-UA', 'Date', {
+ months: ['СÑÑенÑ', 'ÐÑÑий', 'ÐеÑезенÑ', 'ÐвÑÑенÑ', 'ТÑавенÑ', 'ЧеÑвенÑ', 'ÐипенÑ', 'СеÑпенÑ', 'ÐеÑеÑ?енÑ', 'ÐовÑенÑ', 'ÐиÑ?Ñопад', 'ÐÑÑденÑ'],
+ days: ['Ð?едÑлÑ?', 'ÐонедÑлок', 'ÐÑвÑоÑок', 'СеÑеда', 'ЧеÑвеÑ', 'Ð\'Ñ?ÑниÑÑ?', 'СÑбоÑа'],
+ AM: 'до полÑднÑ?',
+ PM: 'по полÑднÑ',
+ /* Date.Extras */
+ ordinal: '',
+ lessThanMinuteAgo: 'менÑÑе Ñ
вилини ÑомÑ',
+ minuteAgo: 'Ñ
Ð²Ð¸Ð»Ð¸Ð½Ñ ÑомÑ',
+ minutesAgo: function (delta){
+ return '{delta} ' + pluralize(delta, 'Ñ
вилинÑ', 'Ñ
вилини', 'Ñ
вилин') + ' ÑомÑ';
+ hourAgo: 'Ð³Ð¾Ð´Ð¸Ð½Ñ ÑомÑ',
+ hoursAgo: function (delta){
+ return '{delta} ' + pluralize(delta, 'годинÑ', 'години', 'годин') + ' ÑомÑ';
+ dayAgo: 'вÑоÑа',
+ daysAgo: function (delta){
+ return '{delta} ' + pluralize(delta, 'денÑ', 'днÑ?', 'днÑв') + ' ÑомÑ';
+ weekAgo: 'ÑÐ¸Ð¶Ð´ÐµÐ½Ñ ÑомÑ',
+ weeksAgo: function (delta){
+ return '{delta} ' + pluralize(delta, 'ÑижденÑ', 'ÑижнÑ', 'ÑижнÑв') + ' ÑомÑ';
+ monthAgo: 'мÑÑ?Ñ?ÑÑ ÑомÑ',
+ monthsAgo: function (delta){
+ return '{delta} ' + pluralize(delta, 'мÑÑ?Ñ?ÑÑ', 'мÑÑ?Ñ?ÑÑ', 'мÑÑ?Ñ?ÑÑв') + ' ÑомÑ';
+ yearAgo: 'ÑÑк ÑомÑ',
+ yearsAgo: function (delta){
+ return '{delta} ' + pluralize(delta, 'ÑÑк', 'Ñоки', 'ÑокÑв') + ' ÑомÑ';
+ lessThanMinuteUntil: 'за миÑÑ',
+ minuteUntil: 'ÑеÑез Ñ
вилинÑ',
+ minutesUntil: function (delta){
+ return 'ÑеÑез {delta} ' + pluralize(delta, 'Ñ
вилинÑ', 'Ñ
вилини', 'Ñ
вилин');
+ hourUntil: 'ÑеÑез годинÑ',
+ hoursUntil: function (delta){
+ return 'ÑеÑез {delta} ' + pluralize(delta, 'годинÑ', 'години', 'годин');
+ daysUntil: function (delta){
+ return 'ÑеÑез {delta} ' + pluralize(delta, 'денÑ', 'днÑ?', 'днÑв');
+ weekUntil: 'ÑеÑез ÑижденÑ',
+ weeksUntil: function (delta){
+ return 'ÑеÑез {delta} ' + pluralize(delta, 'ÑижденÑ', 'ÑижнÑ', 'ÑижнÑв');
+ monthUntil: 'ÑеÑез мÑÑ?Ñ?ÑÑ',
+ monthesUntil: function (delta){
+ return 'ÑеÑез {delta} ' + pluralize(delta, 'мÑÑ?Ñ?ÑÑ', 'мÑÑ?Ñ?ÑÑ', 'мÑÑ?Ñ?ÑÑв');
+ yearUntil: 'ÑеÑез ÑÑк',
+ yearsUntil: function (delta){
+ return 'ÑеÑез {delta} ' + pluralize(delta, 'ÑÑк', 'Ñоки', 'ÑокÑв');
+script: Form.Validator.Arabic.js
+description: Form.Validator messages in Arabic.
+authors:
+- Chafik Barbar
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.Arabic]
+MooTools.lang.set('ar', 'Form.Validator', {
+ required:'ÙØ°Ø§ Ø§ÙØÙÙ Ù
Ø·ÙÙØ¨.',
+ minLength:'رجاء٠إدخا٠{minLength} Ø£ØØ±Ù? عÙÙ Ø§ÙØ£ÙÙ (تÙ
إدخا٠{length} Ø£ØØ±Ù?).',
+ maxLength:'Ø§ÙØ±Ø¬Ø§Ø¡ عدÙ
Ø¥Ø¯Ø®Ø§Ù Ø£ÙØ«Ø± Ù
Ù {maxLength} Ø£ØØ±Ù? (تÙ
+ integer:'Ø§ÙØ±Ø¬Ø§Ø¡ إدخا٠عدد صØÙØ Ù?Ù ÙØ°Ø§ Ø§ÙØÙÙ. أ٠رÙÙ
Ø°Ù ÙØ³Ø± عشر٠أ٠Ù
ئÙÙ (Ù
ثا٠1.25 ) ØºÙØ± Ù
سÙ
ÙØ.',
+ numeric:'Ø§ÙØ±Ø¬Ø§Ø¡ إدخا٠ÙÙÙ
رÙÙ
ÙØ© Ù?Ù ÙØ°Ø§ Ø§ÙØÙÙ (Ù
ثا٠"1" أ٠"1.1" أ٠"-1" أ٠"-1.1").',
+ digits:'Ø§ÙØ±Ø¬Ø§Ø¡ أستخداÙ
ÙÙÙ
رÙÙ
ÙØ© ÙØ¹ÙاÙ
ات ترÙÙÙ
ÙØ© Ù?ÙØ· Ù?Ù ÙØ°Ø§ Ø§ÙØÙÙ (Ù
ثاÙ, رÙÙ
ÙØ§ØªÙ? Ù
ع ÙÙØ·Ø© Ø£Ù Ø´ØØ·Ø©)',
+ alpha:'Ø§ÙØ±Ø¬Ø§Ø¡ أستخداÙ
Ø£ØØ±Ù? Ù?ÙØ· (ا-Ù) Ù?Ù ÙØ°Ø§ Ø§ÙØÙÙ. Ø£Ù Ù?راغات Ø£Ù Ø¹ÙØ§Ù
ات ØºÙØ± Ù
سÙ
ÙØØ©.',
+ alphanum:'Ø§ÙØ±Ø¬Ø§Ø¡ أستخداÙ
Ø£ØØ±Ù? Ù?ÙØ· (ا-Ù) Ø£Ù Ø£Ø±ÙØ§Ù
(0-9) Ù?ÙØ· Ù?Ù ÙØ°Ø§ Ø§ÙØÙÙ. Ø£Ù Ù?راغات Ø£Ù Ø¹ÙØ§Ù
ات ØºÙØ± Ù
سÙ
ÙØØ©.',
+ dateSuchAs:'Ø§ÙØ±Ø¬Ø§Ø¡ Ø¥Ø¯Ø®Ø§Ù ØªØ§Ø±ÙØ® صØÙØ ÙØ§ÙتاÙÙ {date}',
+ dateInFormatMDY:'Ø§ÙØ±Ø¬Ø§Ø¡ Ø¥Ø¯Ø®Ø§Ù ØªØ§Ø±ÙØ® صØÙØ (Ù
ثاÙ, 31-12-1999)',
+ email:'Ø§ÙØ±Ø¬Ø§Ø¡ Ø¥Ø¯Ø®Ø§Ù Ø¨Ø±ÙØ¯ Ø¥ÙÙØªØ±ÙÙ٠صØÙØ.',
+ url:'Ø§ÙØ±Ø¬Ø§Ø¡ إدخا٠عÙÙØ§Ù Ø¥ÙÙØªØ±ÙÙ٠صØÙØ Ù
ث٠http://www.google.com',
+ currencyDollar:'Ø§ÙØ±Ø¬Ø§Ø¡ إدخا٠ÙÙÙ
Ø© $ صØÙØØ©. Ù
ثاÙ, 100.00$',
+ oneRequired:'Ø§ÙØ±Ø¬Ø§Ø¡ إدخا٠ÙÙÙ
Ø© Ù?Ù Ø£ØØ¯ ÙØ°Ù Ø§ÙØÙÙ٠عÙÙ Ø§ÙØ£ÙÙ.',
+ errorPrefix: 'خطأ: ',
+ warningPrefix: 'ØªØØ°Ùر: '
+}).set('ar', 'Date', {
+ dateOrder: ['date', 'month', 'year', '/']
+script: Form.Validator.Catalan.js
+authors:
+- Miquel Hudin
+- Alfons Sanchez
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.Catalan]
+MooTools.lang.set('ca-CA', 'Form.Validator', {
+ required:'Aquest camp es obligatori.',
+ minLength:'Per favor introdueix al menys {minLength} caracters (has introduit {length} caracters).',
+ maxLength:'Per favor introdueix no mes de {maxLength} caracters (has introduit {length} caracters).',
+ integer:'Per favor introdueix un nombre enter en aquest camp. Nombres amb decimals (p.e. 1,25) no estan permesos.',
+ numeric:'Per favor introdueix sols valors numerics en aquest camp (p.e. "1" o "1,1" o "-1" o "-1,1").',
+ digits:'Per favor usa sols numeros i puntuacio en aquest camp (per exemple, un nombre de telefon amb guions i punts no esta permes).',
+ alpha:'Per favor utilitza lletres nomes (a-z) en aquest camp. No s´admiteixen espais ni altres caracters.',
+ alphanum:'Per favor, utilitza nomes lletres (a-z) o numeros (0-9) en aquest camp. No s´admiteixen espais ni altres caracters.',
+ dateSuchAs:'Per favor introdueix una data valida com {date}',
+ dateInFormatMDY:'Per favor introdueix una data valida com DD/MM/YYYY (p.e. "31/12/1999")',
+ email:'Per favor, introdueix una adreça de correu electronic valida. Per exemple, "fred at domain.com".',
+ url:'Per favor introdueix una URL valida com http://www.google.com.',
+ currencyDollar:'Per favor introdueix una quantitat valida de â¬. Per exemple â¬100,00 .',
+ oneRequired:'Per favor introdueix alguna cosa per al menys una d´aquestes entrades.',
+ errorPrefix: 'Error: ',
+ warningPrefix: 'Avis: ',
+ //Form.Validator.Extras
+ noSpace: 'No poden haver espais en aquesta entrada.',
+ reqChkByNode: 'No hi han elements seleccionats.',
+ requiredChk: 'Aquest camp es obligatori.',
+ reqChkByName: 'Per favor selecciona una {label}.',
+ match: 'Aquest camp necessita coincidir amb el camp {matchName}',
+ startDate: 'la data de inici',
+ endDate: 'la data de fi',
+ currendDate: 'la data actual',
+ afterDate: 'La data deu ser igual o posterior a {label}.',
+ beforeDate: 'La data deu ser igual o anterior a {label}.',
+ startMonth: 'Per favor selecciona un mes d´orige',
+ sameMonth: 'Aquestes dos dates deuen estar dins del mateix mes - deus canviar una o altra.'
+script: Form.Validator.Czech.js
+description: Form Validator messages for Czech.
+authors:
+- Jan Äerný chemiX
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.Czech]
+MooTools.lang.set('cs-CZ', 'Form.Validator', {
+ required:'Tato položka je povinná.',
+ minLength:'Zadejte prosÃm alespoÅ {minLength} znaků (napsáno {length} znaků).',
+ maxLength:'Zadejte prosÃm ménÄ než {maxLength} znaků (nápsáno {length} znaků).',
+ integer:'Zadejte prosÃm celé Ä?Ãslo. Desetinná Ä?Ãsla (napÅ. 1.25) nejsou povolena.',
+ numeric:'Zadejte jen Ä?Ãselné hodnoty (tj. "1" nebo "1.1" nebo "-1" nebo "-1.1").',
+ digits:'Zadejte prosÃm pouze Ä?Ãsla a interpunkÄ?nà znaménka(napÅÃklad telefonnà Ä?Ãslo s pomlÄ?kami nebo teÄ?kami je povoleno).',
+ alpha:'Zadejte prosÃm pouze pÃsmena (a-z). Mezery nebo jiné znaky nejsou povoleny.',
+ alphanum:'Zadejte prosÃm pouze pÃsmena (a-z) nebo Ä?Ãslice (0-9). Mezery nebo jiné znaky nejsou povoleny.',
+ dateSuchAs:'Zadejte prosÃm platné datum jako {date}',
+ dateInFormatMDY:'Zadejte prosÃm platné datum jako MM / DD / RRRR (tj. "12/31/1999")',
+ email:'Zadejte prosÃm platnou e-mailovou adresu. NapÅÃklad "fred at domain.com".',
+ url:'Zadejte prosÃm platnou URL adresu jako http://www.google.com.',
+ currencyDollar:'Zadejte prosÃm platnou Ä?ástku. NapÅÃklad $100.00.',
+ oneRequired:'Zadejte prosÃm alespoÅ jednu hodnotu pro tyto položky.',
+ errorPrefix: 'Chyba: ',
+ warningPrefix: 'UpozornÄnÃ: ',
+ noSpace: 'V této položce nejsou povoleny mezery',
+ reqChkByNode: 'Nejsou vybrány žádné položky.',
+ requiredChk: 'Tato položka je vyžadována.',
+ reqChkByName: 'ProsÃm vyberte {label}.',
+ match: 'Tato položka se musà shodovat s položkou {matchName}',
+ startDate: 'datum zahájenÃ',
+ endDate: 'datum ukonÄ?enÃ',
+ currendDate: 'aktuálnà datum',
+ afterDate: 'Datum by mÄlo být stejné nebo vÄtšà než {label}.',
+ beforeDate: 'Datum by mÄlo být stejné nebo menšà než {label}.',
+ startMonth: 'Vyberte poÄ?áteÄ?nà mÄsÃc.',
+ sameMonth: 'Tyto dva datumy musà být ve stejném mÄsÃci - zmÄÅte jeden z nich.',
+ creditcard: 'Zadané Ä?Ãslo kreditnà karty je neplatné. ProsÃm opravte ho. Bylo zadáno {length} Ä?Ãsel.'
+script: Form.Validator.Chinese.js
+description: Form.Validator messages in chinese (both simplified and traditional).
+authors:
+- éæ¡å - guidy <at> ixuer [dot] net
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.Chinese]
+In Chinese:
+éè¦?æåºçæ¯ï¼
+ç®ä½ä¸æéç¨äºä¸å½å¤§éï¼
+ç¹?ä½ä¸æéç¨äºé¦æ¸¯ã?æ¾³é¨åå?°æ¹¾ç?ã
+ç®ä½ä¸æåç¹?ä½ä¸æå¨åä½åè¯æ³ä¸æå¾å¤çä¸?å?ä¹å¤ã
+æå?¯ä»¥ç¡®ä¿?ç®ä½ä¸æè¯è¨å
çåç¡®æ§ï¼
+ä½å¯¹äºç¹?ä½ä¸æï¼æå?¯ä»¥ä¿?è¯?ç¨æ·å?¯ä»¥åç¡®çç?è§£ï¼ä½æ æ³ä¿?è¯?è¯å?¥ç¬¦å?ä»ä»¬çé
è¯»ä¹ æ¯ã
+妿æ¨ä¸?è½ç¡®è®¤çè¯?ï¼å?¯ä»¥å?ªä½¿ç¨ç®ä½ä¸æè¯è¨å
ï¼å ä¸ºå®æ¯æéç¨çã
+In English:
+It should be noted that:
+Simplified Chinese apply to mainland Chinese,
+Traditional Chinese apply to Hong Kong, Macao and Taiwan Province.
+There are a lot of different from Simplified Chinese and Traditional Chinese , Contains font and syntax .
+I can assure Simplified Chinese language pack accuracy .
+For Traditional Chinese, I can only guarantee that users can understand, but not necessarily in line with their reading habits.
+If you are unsure, you can only use the simplified Chinese language pack, as it is the most common.
+// Simplified Chinese
+MooTools.lang.set('zhs-CN', 'Form.Validator', {
+ required:'è¿æ¯å¿
填项ã',
+ minLength:'请è³å°è¾å
¥ {minLength} 个å符 (å·²è¾å
¥ {length} 个)ã',
+ maxLength:'æå¤å?ªè½è¾å
¥ {maxLength} 个å符 (å·²è¾å
¥ {length} 个)ã',
+ integer:'请è¾å
¥ä¸ä¸ªæ´æ°ï¼ä¸?è½å
å?«å°?æ°ç¹ãä¾å¦ï¼"1", "200"ã',
+ numeric:'请è¾å
¥ä¸ä¸ªæ°åï¼ä¾å¦ï¼"1", "1.1", "-1", "-1.1"ã',
+ digits:'è¿éå?ªè½æ¥å?æ°ååæ ç¹çè¾å
¥ï¼æ ç¹å?¯ä»¥æ¯ï¼"(", ")", ".", ":", "-", "+", "#"åç©ºæ ¼ã',
+ alpha:'请è¾å
¥ A-Z ç 26 ä¸ªåæ¯?ï¼ä¸?è½å
å?«ç©ºæ ¼æä»»ä½å
¶ä»å符ã',
+ alphanum:'请è¾å
¥ A-Z ç 26 ä¸ªåæ¯?æ 0-9 ç 10 个æ°åï¼ä¸?è½å
å?«ç©ºæ ¼æä»»ä½å
¶ä»å符ã',
+ dateSuchAs:'请è¾å
¥å?æ³çæ¥ææ ¼å¼?ï¼å¦ï¼{date}ã',
+ dateInFormatMDY:'请è¾å
¥å?æ³çæ¥ææ ¼å¼?ï¼ä¾å¦ï¼MM/DD/YYYY ("12/31/1999")ã',
+ email:'请è¾å
¥å?æ³ççµå?ä¿¡ç®±å°å?ï¼ä¾å¦ï¼"fred at domain.com"ã',
+ url:'请è¾å
¥å?æ³ç Url å°å?ï¼ä¾å¦ï¼http://www.google.comã',
+ currencyDollar:'请è¾å
¥å?æ³çè´§å¸?符å?·ï¼ä¾å¦ï¼ï¿¥',
+ oneRequired:'请è³å°éæ©ä¸é¡¹ã',
+ errorPrefix: 'é误ï¼',
+ warningPrefix: 'è¦åï¼'
+// Traditional Chinese
+MooTools.lang.set('zht-CN', 'Form.Validator', {
+ required:'鿝å¿
å¡«é
ã',
+ minLength:'è«è³å°é?µå
¥ {minLength} åå符(å·²é?µå
¥ {length} å)ã',
+ maxLength:'æå¤å?ªè½é?µå
¥ {maxLength} åå符(å·²é?µå
¥ {length} å)ã',
+ integer:'è«é?µå
¥ä¸åæ´æ¸ï¼ä¸?è½å
å?«å°?æ¸é»ãä¾å¦ï¼"1", "200"ã',
+ numeric:'è«é?µå
¥ä¸åæ¸åï¼ä¾å¦ï¼"1", "1.1", "-1", "-1.1"ã',
+ digits:'é裡å?ªè½æ¥å?æ¸å忍é»çé?µå
¥ï¼æ¨é»å?¯ä»¥æ¯ï¼"(", ")", ".", ":", "-", "+", "#"åç©ºæ ¼ã',
+ alpha:'è«é?µå
¥ A-Z ç 26 å忝?ï¼ä¸?è½å
å?«ç©ºæ ¼æä»»ä½å
¶ä»å符ã',
+ alphanum:'è«é?µå
¥ A-Z ç 26 å忝?æ 0-9 ç 10 忏åï¼ä¸?è½å
å?«ç©ºæ ¼æä»»ä½å
¶ä»å符ã',
+ dateSuchAs:'è«é?µå
+ dateInFormatMDY:'è«é?µå
+ email:'è«é?µå
¥å?æ³çé»å?ä¿¡ç®±å°å?ï¼ä¾å¦ï¼"fred at domain.com"ã',
+ url:'è«é?µå
+ currencyYuan:'è«é?µå
¥å?æ³ç貨幣符èï¼ä¾å¦ï¼ï¿¥',
+ oneRequired:'è«è³å°é?¸æä¸é
ã',
+ errorPrefix: 'é¯èª¤ï¼',
+Form.Validator.add('validate-currency-yuan', {
+ errorMsg: function(){
+ return Form.Validator.getMsg('currencyYuan');
+ test: function(element) {
+ // [ï¿¥]1[##][,###]+[.##]
+ // [ï¿¥]1###+[.##]
+ // [ï¿¥]0.##
+ // [ï¿¥].##
+ return Form.Validator.getValidator('IsEmpty').test(element) || (/^ï¿¥?\-?([1-9]{1}[0-9]{0,2}(\,[0-9]{3})*(\.[0-9]{0,2})?|[1-9]{1}\d*(\.[0-9]{0,2})?|0(\.[0-9]{0,2})?|(\.[0-9]{1,2})?)$/).test(element.get('value'));
+script: Form.Validator.Dutch.js
+description: Form.Validator messages in Dutch.
+authors:
+- Lennart Pilon
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.Dutch]
+MooTools.lang.set('nl-NL', 'Form.Validator', {
+ required:'Dit veld is verplicht.',
+ minLength:'Vul minimaal {minLength} karakters in (je hebt {length} karakters ingevoerd).',
+ maxLength:'Vul niet meer dan {maxLength} karakters in (je hebt {length} karakters ingevoerd).',
+ integer:'Vul een getal in. Getallen met decimalen (bijvoorbeeld 1,25) zijn niet toegestaan.',
+ numeric:'Vul alleen numerieke waarden in (bijvoorbeeld. "1" of "1.1" of "-1" of "-1.1").',
+ digits:'Vul alleen nummers en leestekens in (bijvoorbeeld een telefoonnummer met een streepje).',
+ alpha:'Vul alleen letters in (a-z). Spaties en andere karakters zijn niet toegestaan.',
+ alphanum:'Vul alleen letters in (a-z) of nummers (0-9). Spaties en andere karakters zijn niet toegestaan.',
+ dateSuchAs:'Vul een geldige datum in, zoals {date}',
+ dateInFormatMDY:'Vul een geldige datum, in het formaat MM/DD/YYYY (bijvoorbeeld "12/31/1999")',
+ email:'Vul een geldig e-mailadres in. Bijvoorbeeld "fred at domein.nl".',
+ url:'Vul een geldige URL in, zoals http://www.google.nl.',
+ currencyDollar:'Vul een geldig $ bedrag in. Bijvoorbeeld $100.00 .',
+ oneRequired:'Vul iets in bij minimaal een van de invoervelden.',
+ warningPrefix: 'Waarschuwing: ',
+ errorPrefix: 'Fout: '
+script: Form.Validator.Estonian.js
+authors:
+- Kevin Valdek
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.Estonian]
+MooTools.lang.set('et-EE', 'Form.Validator', {
+ required:'Väli peab olema täidetud.',
+ minLength:'Palun sisestage vähemalt {minLength} tähte (te sisestasite {length} tähte).',
+ maxLength:'Palun ärge sisestage rohkem kui {maxLength} tähte (te sisestasite {length} tähte).',
+ integer:'Palun sisestage väljale täisarv. Kümnendarvud (näiteks 1.25) ei ole lubatud.',
+ numeric:'Palun sisestage ainult numbreid väljale (näiteks "1", "1.1", "-1" või "-1.1").',
+ digits:'Palun kasutage ainult numbreid ja kirjavahemärke (telefoninumbri sisestamisel on lubatud kasutada kriipse ja punkte).',
+ alpha:'Palun kasutage ainult tähti (a-z). Tühikud ja teised sümbolid on keelatud.',
+ alphanum:'Palun kasutage ainult tähti (a-z) või numbreid (0-9). Tühikud ja teised sümbolid on keelatud.',
+ dateSuchAs:'Palun sisestage kehtiv kuupäev kujul {date}',
+ dateInFormatMDY:'Palun sisestage kehtiv kuupäev kujul MM.DD.YYYY (näiteks: "12.31.1999").',
+ email:'Palun sisestage kehtiv e-maili aadress (näiteks: "fred at domain.com").',
+ url:'Palun sisestage kehtiv URL (näiteks: http://www.google.com).',
+ currencyDollar:'Palun sisestage kehtiv $ summa (näiteks: $100.00).',
+ oneRequired:'Palun sisestage midagi vähemalt ühele antud väljadest.',
+ errorPrefix: 'Viga: ',
+ warningPrefix: 'Hoiatus: ',
+ noSpace: 'Väli ei tohi sisaldada tühikuid.',
+ reqChkByNode: 'Ãkski väljadest pole valitud.',
+ requiredChk: 'Välja täitmine on vajalik.',
+ reqChkByName: 'Palun valige üks {label}.',
+ match: 'Väli peab sobima {matchName} väljaga',
+ startDate: 'algkuupäev',
+ endDate: 'lõppkuupäev',
+ currendDate: 'praegune kuupäev',
+ afterDate: 'Kuupäev peab olema võrdne või pärast {label}.',
+ beforeDate: 'Kuupäev peab olema võrdne või enne {label}.',
+ startMonth: 'Palun valige algkuupäev.',
+ sameMonth: 'Antud kaks kuupäeva peavad olema samas kuus - peate muutma ühte kuupäeva.'
+script: Form.Validator.German.js
+authors:
+- Frank Rossi
+- Ulrich Petri
+- Fabian Beiner
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.German]
+MooTools.lang.set('de-DE', 'Form.Validator', {
+ required: 'Dieses Eingabefeld muss ausgefüllt werden.',
+ minLength: 'Geben Sie bitte mindestens {minLength} Zeichen ein (Sie haben nur {length} Zeichen eingegeben).',
+ maxLength: 'Geben Sie bitte nicht mehr als {maxLength} Zeichen ein (Sie haben {length} Zeichen eingegeben).',
+ integer: 'Geben Sie in diesem Eingabefeld bitte eine ganze Zahl ein. Dezimalzahlen (z.B. "1.25") sind nicht erlaubt.',
+ numeric: 'Geben Sie in diesem Eingabefeld bitte nur Zahlenwerte (z.B. "1", "1.1", "-1" oder "-1.1") ein.',
+ digits: 'Geben Sie in diesem Eingabefeld bitte nur Zahlen und Satzzeichen ein (z.B. eine Telefonnummer mit Bindestrichen und Punkten ist erlaubt).',
+ alpha: 'Geben Sie in diesem Eingabefeld bitte nur Buchstaben (a-z) ein. Leerzeichen und andere Zeichen sind nicht erlaubt.',
+ alphanum: 'Geben Sie in diesem Eingabefeld bitte nur Buchstaben (a-z) und Zahlen (0-9) ein. Leerzeichen oder andere Zeichen sind nicht erlaubt.',
+ dateSuchAs: 'Geben Sie bitte ein gültiges Datum ein (z.B. "{date}").',
+ dateInFormatMDY: 'Geben Sie bitte ein gültiges Datum im Format TT.MM.JJJJ ein (z.B. "31.12.1999").',
+ email: 'Geben Sie bitte eine gültige E-Mail-Adresse ein (z.B. "max at mustermann.de").',
+ url: 'Geben Sie bitte eine gültige URL ein (z.B. "http://www.google.de").',
+ currencyDollar: 'Geben Sie bitte einen gültigen Betrag in EURO ein (z.B. 100.00€).',
+ oneRequired: 'Bitte füllen Sie mindestens ein Eingabefeld aus.',
+ errorPrefix: 'Fehler: ',
+ warningPrefix: 'Warnung: ',
+ noSpace: 'Es darf kein Leerzeichen in diesem Eingabefeld sein.',
+ reqChkByNode: 'Es wurden keine Elemente gewählt.',
+ requiredChk: 'Dieses Feld muss ausgefüllt werden.',
+ reqChkByName: 'Bitte wählen Sie ein {label}.',
+ match: 'Dieses Eingabefeld muss mit dem {matchName} Eingabefeld übereinstimmen.',
+ startDate: 'Das Anfangsdatum',
+ endDate: 'Das Enddatum',
+ currendDate: 'Das aktuelle Datum',
+ afterDate: 'Das Datum sollte zur gleichen Zeit oder später sein als {label}.',
+ beforeDate: 'Das Datum sollte zur gleichen Zeit oder früher sein als {label}.',
+ startMonth: 'Wählen Sie bitte einen Anfangsmonat',
+ sameMonth: 'Diese zwei Datumsangaben müssen im selben Monat sein - Sie müssen eines von beiden verändern.',
+ creditcard: 'Die eingegebene Kreditkartennummer ist ungültig. Bitte überprüfen Sie diese und versuchen Sie es erneut. {length} Zahlen eingegeben.'
+script: Form.Validator.German.CH.js
+authors:
+requires:
+- /Lang
+- /Form.Validator.German
+provides: [Form.Validator.German.CH]
+MooTools.lang.set('de-CH', 'Form.Validator', {
+ required:'Dieses Feld ist obligatorisch.',
+ minLength:'Geben Sie bitte mindestens {minLength} Zeichen ein (Sie haben {length} Zeichen eingegeben).',
+ maxLength:'Bitte geben Sie nicht mehr als {maxLength} Zeichen ein (Sie haben {length} Zeichen eingegeben).',
+ integer:'Geben Sie bitte eine ganze Zahl ein. Dezimalzahlen (z.B. 1.25) sind nicht erlaubt.',
+ numeric:'Geben Sie bitte nur Zahlenwerte in dieses Eingabefeld ein (z.B. "1", "1.1", "-1" oder "-1.1").',
+ digits:'Benutzen Sie bitte nur Zahlen und Satzzeichen in diesem Eingabefeld (erlaubt ist z.B. eine Telefonnummer mit Bindestrichen und Punkten).',
+ alpha:'Benutzen Sie bitte nur Buchstaben (a-z) in diesem Feld. Leerzeichen und andere Zeichen sind nicht erlaubt.',
+ alphanum:'Benutzen Sie bitte nur Buchstaben (a-z) und Zahlen (0-9) in diesem Eingabefeld. Leerzeichen und andere Zeichen sind nicht erlaubt.',
+ dateSuchAs:'Geben Sie bitte ein gültiges Datum ein. Wie zum Beispiel {date}',
+ dateInFormatMDY:'Geben Sie bitte ein gültiges Datum ein. Wie zum Beispiel TT.MM.JJJJ (z.B. "31.12.1999")',
+ email:'Geben Sie bitte eine gültige E-Mail Adresse ein. Wie zum Beispiel "maria at bernasconi.ch".',
+ url:'Geben Sie bitte eine gültige URL ein. Wie zum Beispiel http://www.google.ch.',
+ currencyDollar:'Geben Sie bitte einen gültigen Betrag in Schweizer Franken ein. Wie zum Beispiel 100.00 CHF .',
+ oneRequired:'Machen Sie für mindestens eines der Eingabefelder einen Eintrag.',
+ noSpace: 'In diesem Eingabefeld darf kein Leerzeichen sein.',
+ requiredChk: 'Dieses Feld ist obligatorisch.',
+ match: 'Dieses Eingabefeld muss mit dem Feld {matchName} übereinstimmen.',
+ afterDate: 'Das Datum sollte zur gleichen Zeit oder später sein {label}.',
+ beforeDate: 'Das Datum sollte zur gleichen Zeit oder früher sein {label}.',
+ sameMonth: 'Diese zwei Datumsangaben müssen im selben Monat sein - Sie müssen eine von beiden verändern.'
+script: Form.Validator.French.js
+description: Form.Validator messages in French.
+authors:
+- Miquel Hudin
+- Nicolas Sorosac <nicolas <dot> sorosac <at> gmail <dot> com>
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.French]
+MooTools.lang.set('fr-FR', 'Form.Validator', {
+ required:'Ce champ est obligatoire.',
+ minLength:'Veuillez saisir un minimum de {minLength} caractère(s) (vous avez saisi {length} caractère(s)).',
+ maxLength:'Veuillez saisir un maximum de {maxLength} caractère(s) (vous avez saisi {length} caractère(s)).',
+ integer:'Veuillez saisir un nombre entier dans ce champ. Les nombres décimaux (ex : "1,25") ne sont pas autorisés.',
+ numeric:'Veuillez saisir uniquement des chiffres dans ce champ (ex : "1" ou "1,1" ou "-1" ou "-1,1").',
+ digits:'Veuillez saisir uniquement des chiffres et des signes de ponctuation dans ce champ (ex : un numéro de téléphone avec des traits d\'union est autorisé).',
+ alpha:'Veuillez saisir uniquement des lettres (a-z) dans ce champ. Les espaces ou autres caractères ne sont pas autorisés.',
+ alphanum:'Veuillez saisir uniquement des lettres (a-z) ou des chiffres (0-9) dans ce champ. Les espaces ou autres caractères ne sont pas autorisés.',
+ dateSuchAs:'Veuillez saisir une date correcte comme {date}',
+ dateInFormatMDY:'Veuillez saisir une date correcte, au format JJ/MM/AAAA (ex : "31/11/1999").',
+ email:'Veuillez saisir une adresse de courrier électronique. Par example "fred at domaine.com".',
+ url:'Veuillez saisir une URL, comme http://www.google.com.',
+ currencyDollar:'Veuillez saisir une quantité correcte. Par example 100,00€.',
+ oneRequired:'Veuillez sélectionner au moins une de ces options.',
+ errorPrefix: 'Erreur : ',
+ warningPrefix: 'Attention : ',
+ noSpace: 'Ce champ n\'accepte pas les espaces.',
+ reqChkByNode: 'Aucun élément n\'est sélectionné.',
+ requiredChk: 'Ce champ est obligatoire.',
+ reqChkByName: 'Veuillez sélectionner un(e) {label}.',
+ match: 'Ce champ doit correspondre avec le champ {matchName}.',
+ startDate: 'date de début',
+ endDate: 'date de fin',
+ currendDate: 'date actuelle',
+ afterDate: 'La date doit être identique ou postérieure à {label}.',
+ beforeDate: 'La date doit être identique ou antérieure à {label}.',
+ startMonth: 'Veuillez sélectionner un mois de début.',
+ sameMonth: 'Ces deux dates doivent être dans le même mois - vous devez en modifier une.'
+script: Form.Validator.Italian.js
+description: Form.Validator messages in Italian.
+authors:
+- Leonardo Laureti
+- Andrea Novero
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.Italian]
+MooTools.lang.set('it-IT', 'Form.Validator', {
+ required:'Il campo è obbligatorio.',
+ minLength:'Inserire almeno {minLength} caratteri (ne sono stati inseriti {length}).',
+ maxLength:'Inserire al massimo {maxLength} caratteri (ne sono stati inseriti {length}).',
+ integer:'Inserire un numero intero. Non sono consentiti decimali (es.: 1.25).',
+ numeric:'Inserire solo valori numerici (es.: "1" oppure "1.1" oppure "-1" oppure "-1.1").',
+ digits:'Inserire solo numeri e caratteri di punteggiatura. Per esempio è consentito un numero telefonico con trattini o punti.',
+ alpha:'Inserire solo lettere (a-z). Non sono consentiti spazi o altri caratteri.',
+ alphanum:'Inserire solo lettere (a-z) o numeri (0-9). Non sono consentiti spazi o altri caratteri.',
+ dateSuchAs:'Inserire una data valida del tipo {date}',
+ dateInFormatMDY:'Inserire una data valida nel formato MM/GG/AAAA (es.: "12/31/1999")',
+ email:'Inserire un indirizzo email valido. Per esempio "nome at dominio.com".',
+ url:'Inserire un indirizzo valido. Per esempio "http://www.dominio.com".',
+ currencyDollar:'Inserire un importo valido. Per esempio "$100.00".',
+ oneRequired:'Completare almeno uno dei campi richiesti.',
+ errorPrefix: 'Errore: ',
+ warningPrefix: 'Attenzione: ',
+ noSpace: 'Non sono consentiti spazi.',
+ reqChkByNode: 'Nessuna voce selezionata.',
+ requiredChk: 'Il campo è obbligatorio.',
+ reqChkByName: 'Selezionare un(a) {label}.',
+ match: 'Il valore deve corrispondere al campo {matchName}',
+ startDate: 'data d\'inizio',
+ endDate: 'data di fine',
+ currendDate: 'data attuale',
+ afterDate: 'La data deve corrispondere o essere successiva al {label}.',
+ beforeDate: 'La data deve corrispondere o essere precedente al {label}.',
+ startMonth: 'Selezionare un mese d\'inizio',
+ sameMonth: 'Le due date devono essere dello stesso mese - occorre modificarne una.'
+script: Form.Validator.Norwegian.js
+description: Form.Validator messages in Norwegian.
+authors:
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.Norwegian]
+MooTools.lang.set('no-NO', 'Form.Validator', {
+ required:'Dette feltet er pÃÂ¥krevd.',
+ minLength:'Vennligst skriv inn minst {minLength} tegn (du skrev {length} tegn).',
+ maxLength:'Vennligst skriv inn maksimalt {maxLength} tegn (du skrev {length} tegn).',
+ integer:'Vennligst skriv inn et tall i dette feltet. Tall med desimaler (for eksempel 1,25) er ikke tillat.',
+ numeric:'Vennligst skriv inn kun numeriske verdier i dette feltet (for eksempel "1", "1.1", "-1" eller "-1.1").',
+ digits:'Vennligst bruk kun nummer og skilletegn i dette feltet.',
+ alpha:'Vennligst bruk kun bokstaver (a-z) i dette feltet. Ingen mellomrom eller andre tegn er tillat.',
+ alphanum:'Vennligst bruk kun bokstaver (a-z) eller nummer (0-9) i dette feltet. Ingen mellomrom eller andre tegn er tillat.',
+ dateSuchAs:'Vennligst skriv inn en gyldig dato, som {date}',
+ dateInFormatMDY:'Vennligst skriv inn en gyldig dato, i formatet MM/DD/YYYY (for eksempel "12/31/1999")',
+ email:'Vennligst skriv inn en gyldig epost-adresse. For eksempel "espen at domene.no".',
+ url:'Vennligst skriv inn en gyldig URL, for eksempel http://www.google.no.',
+ currencyDollar:'Vennligst fyll ut et gyldig $ beløp. For eksempel $100.00 .',
+ oneRequired:'Vennligst fyll ut noe i minst ett av disse feltene.',
+ errorPrefix: 'Feil: ',
+ warningPrefix: 'Advarsel: '
+script: Form.Validator.Polish.js
+authors:
+- Oskar Krawczyk
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.Polish]
+MooTools.lang.set('pl-PL', 'Form.Validator', {
+ required:'To pole jest wymagane.',
+ minLength:'Wymagane jest przynajmniej {minLength} znaków (wpisanych zostaÅo tylko {length}).',
+ maxLength:'Dozwolone jest nie wiÄcej niż {maxLength} znaków (wpisanych zostaÅo {length})',
+ integer:'To pole wymaga liczb caÅych. Liczby dziesiÄtne (np. 1.25) sÄ
niedozwolone.',
+ numeric:'Prosimy używaÄ tylko numerycznych wartoÅci w tym polu (np. "1", "1.1", "-1" lub "-1.1").',
+ digits:'Prosimy używaÄ liczb oraz zankow punktuacyjnych w typ polu (dla przykÅadu, przy numerze telefonu myÅlniki i kropki sÄ
dozwolone).',
+ alpha:'Prosimy używaÄ tylko liter (a-z) w tym polu. Spacje oraz inne znaki sÄ
niedozwolone.',
+ alphanum:'Prosimy używaÄ tylko liter (a-z) lub liczb (0-9) w tym polu. Spacje oraz inne znaki sÄ
niedozwolone.',
+ dateSuchAs:'Prosimy podaÄ prawidÅowÄ
datÄ w formacie: {date}',
+ dateInFormatMDY:'Prosimy podaÄ poprawnÄ
date w formacie DD.MM.RRRR (i.e. "12.01.2009")',
+ email:'Prosimy podaÄ prawidÅowy adres e-mail, np. "jan at domena.pl".',
+ url:'Prosimy podaÄ prawidÅowy adres URL, np. http://www.google.pl.',
+ currencyDollar:'Prosimy podaÄ prawidÅowÄ
sumÄ w PLN. Dla przykÅadu: 100.00 PLN.',
+ oneRequired:'Prosimy wypeÅniÄ chociaż jedno z pól.',
+ errorPrefix: 'BÅÄ
d: ',
+ warningPrefix: 'Uwaga: ',
+ noSpace: 'W tym polu nie mogÄ
znajdowaÄ siÄ spacje.',
+ reqChkByNode: 'Brak zaznaczonych elementów.',
+ requiredChk: 'To pole jest wymagane.',
+ reqChkByName: 'Prosimy wybraÄ z {label}.',
+ match: 'To pole musi byÄ takie samo jak {matchName}',
+ startDate: 'data poczÄ
tkowa',
+ endDate: 'data koÅcowa',
+ currendDate: 'aktualna data',
+ afterDate: 'Podana data poinna byÄ taka sama lub po {label}.',
+ beforeDate: 'Podana data poinna byÄ taka sama lub przed {label}.',
+ startMonth: 'Prosimy wybraÄ poczÄ
tkowy miesiÄ
c.',
+ sameMonth: 'Te dwie daty muszÄ
byÄ w zakresie tego samego miesiÄ
ca - wymagana jest zmiana któregoŠz pól.'
+script: Form.Validator.Portuguese.js
+description: Form.Validator messages in Portuguese.
+authors:
+- Miquel Hudin
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.Portuguese]
+MooTools.lang.set('pt-PT', 'Form.Validator', {
+ required:'Este campo é necessário.',
+ minLength:'Digite pelo menos{minLength} caracteres (comprimento {length} caracteres).',
+ maxLength:'Não insira mais de {maxLength} caracteres (comprimento {length} caracteres).',
+ integer:'Digite um número inteiro neste domÃnio. Com números decimais (por exemplo, 1,25), não são permitidas.',
+ numeric:'Digite apenas valores numéricos neste domÃnio (p.ex., "1" ou "1.1" ou "-1" ou "-1,1").',
+ digits:'Por favor, use números e pontuação apenas neste campo (p.ex., um número de telefone com traços ou pontos é permitida).',
+ alpha:'Por favor use somente letras (a-z), com nesta área. Não utilize espaços nem outros caracteres são permitidos.',
+ alphanum:'Use somente letras (a-z) ou números (0-9) neste campo. Não utilize espaços nem outros caracteres são permitidos.',
+ dateSuchAs:'Digite uma data válida, como {date}',
+ dateInFormatMDY:'Digite uma data válida, como DD/MM/YYYY (p.ex. "31/12/1999")',
+ email:'Digite um endereço de email válido. Por exemplo "fred at domain.com".',
+ url:'Digite uma URL válida, como http://www.google.com.',
+ currencyDollar:'Digite um valor válido $. Por exemplo $ 100,00. ',
+ oneRequired:'Digite algo para pelo menos um desses insumos.',
+ errorPrefix: 'Erro: ',
+ warningPrefix: 'Aviso: '
+}).set('pt-PT', 'Date', {
+script: Form.Validator.Portuguese.BR.js
+description: Form.Validator messages in Portuguese-BR.
+authors:
+- Fábio Miranda Costa
+requires:
+- /Lang
+- /Form.Validator.Portuguese
+provides: [Form.Validator.Portuguese.BR]
+MooTools.lang.set('pt-BR', 'Form.Validator', {
+ required: 'Este campo é obrigatório.',
+ minLength: 'Digite pelo menos {minLength} caracteres (tamanho atual: {length}).',
+ maxLength: 'Não digite mais de {maxLength} caracteres (tamanho atual: {length}).',
+ integer: 'Por favor digite apenas um número inteiro neste campo. Não são permitidos números decimais (por exemplo, 1,25).',
+ numeric: 'Por favor digite apenas valores numéricos neste campo (por exemplo, "1" ou "1.1" ou "-1" ou "-1,1").',
+ digits: 'Por favor use apenas números e pontuação neste campo (por exemplo, um número de telefone com traços ou pontos é permitido).',
+ alpha: 'Por favor use somente letras (a-z). Espaço e outros caracteres não são permitidos.',
+ alphanum: 'Use somente letras (a-z) ou números (0-9) neste campo. Espaço e outros caracteres não são permitidos.',
+ dateSuchAs: 'Digite uma data válida, como {date}',
+ dateInFormatMDY: 'Digite uma data válida, como DD/MM/YYYY (por exemplo, "31/12/1999")',
+ email: 'Digite um endereço de email válido. Por exemplo "nome at dominio.com".',
+ url: 'Digite uma URL válida. Exemplo: http://www.google.com.',
+ currencyDollar: 'Digite um valor em dinheiro válido. Exemplo: R$100,00 .',
+ oneRequired: 'Digite algo para pelo menos um desses campos.',
+ warningPrefix: 'Aviso: ',
+ noSpace: 'Não é possÃvel digitar espaços neste campo.',
+ reqChkByNode: 'Não foi selecionado nenhum item.',
+ requiredChk: 'Este campo é obrigatório.',
+ reqChkByName: 'Por favor digite um {label}.',
+ match: 'Este campo deve ser igual ao campo {matchName}.',
+ startDate: 'a data inicial',
+ endDate: 'a data final',
+ currendDate: 'a data atual',
+ afterDate: 'A data deve ser igual ou posterior a {label}.',
+ beforeDate: 'A data deve ser igual ou anterior a {label}.',
+ startMonth: 'Por favor selecione uma data inicial.',
+ sameMonth: 'Estas duas datas devem ter o mesmo mês - você deve modificar uma das duas.',
+ creditcard: 'O número do cartão de crédito informado é inválido. Por favor verifique o valor e tente novamente. {length} números informados.'
+script: Form.Validator.Russian.js
+description: Form.Validator messages in Russian (utf-8 and cp1251).
+authors:
+- Chernodarov Egor
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.Russian]
+MooTools.lang.set('ru-RU-unicode', 'Form.Validator', {
+ required:'ÐÑо поле обÑ?заÑелÑно к заполнениÑ.',
+ minLength:'ÐожалÑйÑ?Ñа, введиÑе Ñ
оÑÑ? Ð±Ñ {minLength} Ñ?имволов (ÐÑ Ð²Ð²ÐµÐ»Ð¸ {length}).',
+ maxLength:'ÐожалÑйÑ?Ñа, введиÑе не болÑÑе {maxLength} Ñ?имволов (ÐÑ Ð²Ð²ÐµÐ»Ð¸ {length}).',
+ integer:'ÐожалÑйÑ?Ñа, введиÑе в Ñ?Ñо поле ÑиÑ?ло. ÐÑобнÑе ÑиÑ?ла (напÑÐ¸Ð¼ÐµÑ 1.25) ÑÑÑ Ð½Ðµ ÑазÑеÑенÑ.',
+ numeric:'ÐожалÑйÑ?Ñа, введиÑе в Ñ?Ñо поле ÑиÑ?ло (напÑÐ¸Ð¼ÐµÑ "1" или "1.1", или "-1", или "-1.1").',
+ digits:'Ð Ñ?Ñом поле ÐÑ Ð¼Ð¾Ð¶ÐµÑе иÑ?полÑзоваÑÑ ÑолÑко ÑиÑÑÑ Ð¸ знаки пÑнкÑÑаÑии (напÑимеÑ, ÑелеÑоннÑй Ð½Ð¾Ð¼ÐµÑ Ñ?о знаками деÑиÑ?а или Ñ? ÑоÑками).',
+ alpha:'Ð Ñ?Ñом поле можно иÑ?полÑзоваÑÑ ÑолÑко лаÑинÑ?кие бÑÐºÐ²Ñ (a-z). ÐÑÐ¾Ð±ÐµÐ»Ñ Ð¸ дÑÑгие Ñ?Ð¸Ð¼Ð²Ð¾Ð»Ñ Ð·Ð°Ð¿ÑеÑенÑ.',
+ alphanum:'Ð Ñ?Ñом поле можно иÑ?полÑзоваÑÑ ÑолÑко лаÑинÑ?кие бÑÐºÐ²Ñ (a-z) и ÑиÑÑÑ (0-9). ÐÑÐ¾Ð±ÐµÐ»Ñ Ð¸ дÑÑгие Ñ?Ð¸Ð¼Ð²Ð¾Ð»Ñ Ð·Ð°Ð¿ÑеÑенÑ.',
+ dateSuchAs:'ÐожалÑйÑ?Ñа, введиÑе коÑÑекÑнÑÑ Ð´Ð°ÑÑ {date}',
+ dateInFormatMDY:'ÐожалÑйÑ?Ñа, введиÑе даÑÑ Ð² ÑоÑмаÑе ÐÐ/ÐÐ/ÐÐÐÐ (напÑÐ¸Ð¼ÐµÑ "12/31/1999")',
+ email:'ÐожалÑйÑ?Ñа, введиÑе коÑÑекÑнÑй емейл-адÑеÑ?. ÐлÑ? пÑимеÑа "fred at domain.com".',
+ url:'ÐожалÑйÑ?Ñа, введиÑе пÑавилÑнÑÑ Ñ?Ñ?ÑÐ»ÐºÑ Ð²Ð¸Ð´Ð° http://www.google.com.',
+ currencyDollar:'ÐожалÑйÑ?Ñа, введиÑе Ñ?ÑÐ¼Ð¼Ñ Ð² доллаÑаÑ
. Ð?апÑимеÑ: $100.00 .',
+ oneRequired:'ÐожалÑйÑ?Ñа, вÑбеÑиÑе Ñ
оÑÑ ÑÑо-нибÑÐ´Ñ Ð² одном из Ñ?ÑиÑ
полей.',
+ errorPrefix: 'ÐÑибка: ',
+ warningPrefix: 'Ðнимание: '
+//translation in windows-1251 codepage
+MooTools.lang.set('ru-RU', 'Form.Validator', {
+ required:'Ã?òî ïîëå îáÿçà òåëüÃî ê çà ïîëÃÃ¥Ãèþ.',
+ minLength:'Ã?îæà ëóéñòà , ââåäèòå õîòÿ áû {minLength} ñèìâîëîâ (Ãû ââåëè {length}).',
+ maxLength:'Ã?îæà ëóéñòà , ââåäèòå ÃÃ¥ áîëüøå {maxLength} ñèìâîëîâ (Ãû ââåëè {length}).',
+ integer:'Ã?îæà ëóéñòà , ââåäèòå â ýòî ïîëå ÷èñëî. ÃðîáÃûå ÷èñëà (Ãà ïðèìåð 1.25) òóò ÃÃ¥ ðà çðåøåÃû.',
+ numeric:'Ã?îæà ëóéñòà , ââåäèòå â ýòî ïîëå ÷èñëî (Ãà ïðèìåð "1" èëè "1.1", èëè "-1", èëè "-1.1").',
+ digits:'à ýòîì ïîëå Ãû ìîæåòå èñïîëüçîâà òü òîëüêî öèôðû è çÃà êè ïóÃêòóà öèè (Ãà ïðèìåð, òåëåôîÃÃûé Ãîìåð ñî çÃà êà ìè äåôèñà èëè ñ òî÷êà ìè).',
+ alpha:'à ýòîì ïîëå ìîæÃî èñïîëüçîâà òü òîëüêî ëà òèÃñêèå áóêâû (a-z). Ã?ðîáåëû è äðóãèå ñèìâîëû çà ïðåùåÃû.',
+ alphanum:'à ýòîì ïîëå ìîæÃî èñïîëüçîâà òü òîëüêî ëà òèÃñêèå áóêâû (a-z) è öèôðû (0-9). Ã?ðîáåëû è äðóãèå ñèìâîëû çà ïðåùåÃû.',
+ dateSuchAs:'Ã?îæà ëóéñòà , ââåäèòå êîððåêòÃóþ äà òó {date}',
+ dateInFormatMDY:'Ã?îæà ëóéñòà , ââåäèòå äà òó â ôîðìà òå ÃÃ/ÃÃ/ÃÃÃà (Ãà ïðèìåð "12/31/1999")',
+ email:'Ã?îæà ëóéñòà , ââåäèòå êîððåêòÃûé åìåéë-à äðåñ. Ãëÿ ïðèìåðà "fred at domain.com".',
+ url:'Ã?îæà ëóéñòà , ââåäèòå ïðà âèëüÃóþ ññûëêó âèäà http://www.google.com.',
+ currencyDollar:'�îæà ëóéñòà , ââåäèòå ñóììó â äîëëà ðà õ. �à ïðèìåð: $100.00 .',
+ oneRequired:'Ã?îæà ëóéñòà , âûáåðèòå õîòü ÷òî-Ãèáóäü â îäÃîì èç ýòèõ ïîëåé.',
+ errorPrefix: 'Ãøèáêà : ',
+ warningPrefix: 'ÃÃèìà Ãèå: '
+script: Form.Validator.Spanish.js
+authors:
+- Ãlfons Sanchez
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.Spanish]
+MooTools.lang.set('es-ES', 'Form.Validator', {
+ required:'Este campo es obligatorio.',
+ minLength:'Por favor introduce al menos {minLength} caracteres (has introducido {length} caracteres).',
+ maxLength:'Por favor introduce no más de {maxLength} caracteres (has introducido {length} caracteres).',
+ integer:'Por favor introduce un número entero en este campo. Números con decimales (p.e. 1,25) no se permiten.',
+ numeric:'Por favor introduce solo valores numéricos en este campo (p.e. "1" o "1,1" o "-1" o "-1,1").',
+ digits:'Por favor usa solo números y puntuación en este campo (por ejemplo, un número de teléfono con guiones y puntos no esta permitido).',
+ alpha:'Por favor usa letras solo (a-z) en este campo. No se admiten espacios ni otros caracteres.',
+ alphanum:'Por favor, usa solo letras (a-z) o números (0-9) en este campo. No se admiten espacios ni otros caracteres.',
+ dateSuchAs:'Por favor introduce una fecha válida como {date}',
+ dateInFormatMDY:'Por favor introduce una fecha válida como DD/MM/YYYY (p.e. "31/12/1999")',
+ email:'Por favor, introduce una dirección de email válida. Por ejemplo, "fred at domain.com".',
+ url:'Por favor introduce una URL válida como http://www.google.com.',
+ currencyDollar:'Por favor introduce una cantidad válida de â¬. Por ejemplo â¬100,00 .',
+ oneRequired:'Por favor introduce algo para por lo menos una de estas entradas.',
+ noSpace: 'No pueden haber espacios en esta entrada.',
+ reqChkByNode: 'No hay elementos seleccionados.',
+ requiredChk: 'Este campo es obligatorio.',
+ reqChkByName: 'Por favor selecciona una {label}.',
+ match: 'Este campo necesita coincidir con el campo {matchName}',
+ startDate: 'la fecha de inicio',
+ endDate: 'la fecha de fin',
+ currendDate: 'la fecha actual',
+ afterDate: 'La fecha debe ser igual o posterior a {label}.',
+ beforeDate: 'La fecha debe ser igual o anterior a {label}.',
+ startMonth: 'Por favor selecciona un mes de origen',
+ sameMonth: 'Estas dos fechas deben estar en el mismo mes - debes cambiar una u otra.'
+script: Form.Validator.Swedish.js
+description: Date messages for Swedish.
+authors:
+- Martin Lundgren
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.Swedish]
+MooTools.lang.set('sv-SE', 'Form.Validator', {
+ required:'Fältet är obligatoriskt.',
+ minLength:'Ange minst {minLength} tecken (du angav {length} tecken).',
+ maxLength:'Ange högst {maxLength} tecken (du angav {length} tecken). ',
+ integer:'Ange ett heltal i fältet. Tal med decimaler (t.ex. 1,25) är inte tillåtna.',
+ numeric:'Ange endast numeriska värden i detta fält (t.ex. "1" eller "1.1" eller "-1" eller "-1,1").',
+ digits:'Använd endast siffror och skiljetecken i detta fält (till exempel ett telefonnummer med bindestreck tillåtet).',
+ alpha:'Använd endast bokstäver (a-ö) i detta fält. Inga mellanslag eller andra tecken är tillåtna.',
+ alphanum:'Använd endast bokstäver (a-ö) och siffror (0-9) i detta fält. Inga mellanslag eller andra tecken är tillåtna.',
+ dateSuchAs:'Ange ett giltigt datum som t.ex. {date}',
+ dateInFormatMDY:'Ange ett giltigt datum som t.ex. YYYY-MM-DD (i.e. "1999-12-31")',
+ email:'Ange en giltig e-postadress. Till exempel "erik at domain.com".',
+ url:'Ange en giltig webbadress som http://www.google.com.',
+ currencyDollar:'Ange en giltig belopp. Exempelvis 100,00.',
+ oneRequired:'Vänligen ange minst ett av dessa alternativ.',
+ errorPrefix: 'Fel: ',
+ warningPrefix: 'Varning: ',
+ noSpace: 'Det får inte finnas några mellanslag i detta fält.',
+ reqChkByNode: 'Inga objekt är valda.',
+ requiredChk: 'Detta är ett obligatoriskt fält.',
+ reqChkByName: 'Välj en {label}.',
+ match: 'Detta fält måste matcha {matchName}',
+ startDate: 'startdatumet',
+ endDate: 'slutdatum',
+ currendDate: 'dagens datum',
+ afterDate: 'Datumet bör vara samma eller senare än {label}.',
+ beforeDate: 'Datumet bör vara samma eller tidigare än {label}.',
+ startMonth: 'Välj en start månad',
+ sameMonth: 'Dessa två datum måste vara i samma månad - du måste ändra det ena eller det andra.'
+script: Form.Validator.Ukrainian.js
+description: Form.Validator messages in Ukrainian (utf-8).
+authors:
+- Slik
+requires:
+- /Lang
+- /Form.Validator
+provides: [Form.Validator.Ukrainian]
+MooTools.lang.set('uk-UA', 'Form.Validator', {
+ required:'Це поле повинне бÑÑи заповненим.',
+ minLength:'ÐведÑÑÑ Ñ
оÑа б {minLength} Ñ?имволÑв (Ðи ввели {length}).',
+ maxLength:'ÐÑлÑкÑÑ?ÑÑ Ñ?имволÑв не може бÑÑи бÑлÑÑе {maxLength} (Ðи ввели {length}).',
+ integer:'ÐведÑÑÑ Ð² Ñе поле ÑиÑ?ло. ÐÑÐ¾Ð±Ð¾Ð²Ñ ÑиÑ?ла (напÑиклад 1.25) не дозволенÑ.',
+ numeric:'ÐведÑÑÑ Ð² Ñе поле ÑиÑ?ло (напÑиклад "1" або "1.1", або "-1", або "-1.1").',
+ digits:'Ð ÑÑÐ¾Ð¼Ñ Ð¿Ð¾Ð»Ñ Ð²Ð¸ можеÑе викоÑиÑ?ÑовÑваÑи лиÑе ÑиÑÑи Ñ Ð·Ð½Ð°ÐºÐ¸ пÑнкÑÑаÑÑÑ (напÑиклад, ÑелеÑонний Ð½Ð¾Ð¼ÐµÑ Ð· знаками деÑÑÐ·Ñ Ð°Ð±Ð¾ з кÑапками).',
+ alpha:'Ð ÑÑÐ¾Ð¼Ñ Ð¿Ð¾Ð»Ñ Ð¼Ð¾Ð¶Ð½Ð° викоÑиÑ?ÑовÑваÑи лиÑе лаÑинÑ?ÑÐºÑ Ð»ÑÑеÑи (a-z). ÐÑобÑли Ñ ÑнÑÑ Ñ?имволи забоÑоненÑ.',
+ alphanum:'Ð ÑÑÐ¾Ð¼Ñ Ð¿Ð¾Ð»Ñ Ð¼Ð¾Ð¶Ð½Ð° викоÑиÑ?ÑовÑваÑи лиÑе лаÑинÑ?ÑÐºÑ Ð»ÑÑеÑи (a-z) Ñ ÑиÑÑи (0-9). ÐÑобÑли Ñ ÑнÑÑ Ñ?имволи забоÑоненÑ.',
+ dateSuchAs:'ÐведÑÑÑ ÐºÐ¾ÑекÑÐ½Ñ Ð´Ð°ÑÑ {date}.',
+ dateInFormatMDY:'ÐведÑÑÑ Ð´Ð°ÑÑ Ð² ÑоÑмаÑÑ ÐÐ/ÐÐ/Ð Ð Ð Ð (напÑиклад "12/31/2009").',
+ email:'ÐведÑÑÑ ÐºÐ¾ÑекÑÐ½Ñ Ð°Ð´ÑеÑ?Ñ ÐµÐ»ÐµÐºÑÑÐ¾Ð½Ð½Ð¾Ñ Ð¿Ð¾ÑÑи (напÑиклад "name at domain.com").',
+ url:'ÐведÑÑÑ ÐºÐ¾ÑекÑне ÑнÑеÑнеÑ-поÑ?иланнÑ? (напÑиклад http://www.google.com).',
+ currencyDollar:'ÐведÑÑÑ Ñ?ÑÐ¼Ñ Ð² долаÑаÑ
(напÑиклад "$100.00").',
+ oneRequired:'ÐаповнÑÑÑ Ð¾Ð´Ð½Ðµ з полÑв.',
+ errorPrefix: 'Ðомилка: ',
+ warningPrefix: 'Увага: '
+// $Id: common.js 845 2010-04-15 18:47:08Z pagameba $
+ * Function: $jx
+ * dereferences a DOM Element to a JxLib object if possible and returns
+ * a reference to the object, or null if not defined.
+function $jx(id) {
+ id = document.id(id);
+ if (id) {
+ var widget = id.retrieve('jxWidget');
+ if (!widget && id != document.body) {
+ return $jx(id.getParent());
+ } else {
+ return widget;
+ return null;
* Class: Jx
* Jx is a global singleton object that contains the entire Jx library
* within it. All Jx functions, attributes and classes are accessed
@@ -14733,8 +14751,7 @@
if (!$defined(Jx.isAir)) {
(function() {
- * Determine if we're running in Adobe AIR. Run this regardless of whether
- * the above runs or not.
+ * Determine if we're running in Adobe AIR.
var aScripts = document.getElementsByTagName('SCRIPT');
var src = aScripts[0].src;
@@ -15294,11 +15311,17 @@
insertCssRule: function (selector, declaration, styleSheetName) {
var ss = this.getDynamicStyleSheet(styleSheetName);
var rule;
var text = selector + " {" + declaration + "}";
if (Browser.Engine.name === 'trident') {
- ss.styleSheet.cssText += text;
- rule = ss.sheet.rules[ss.insertRule.length];
+ if (declaration == '') {
+ //IE requires SOME text for the declaration. Passing '{}' will
+ //create an empty rule.
+ declaration = '{}';
+ var index = ss.styleSheet.addRule(selector,declaration);
+ rule = ss.styleSheet.rules[index];
} else {
ss.sheet.insertRule(text, ss.indicies.length);
rule = ss.sheet.cssRules[ss.indicies.length];
@@ -15393,7 +15416,7 @@
isStyleSheetDefined: function (name) {
return this.dynamicStyleMap.has(name);
-}))();// $Id: object.js 777 2010-03-24 06:00:30Z jonlb at comcast.net $
+}))();// $Id: object.js 837 2010-04-12 18:45:17Z conrad.barthelmes $
* Class: Jx.Object
* Base class for all other object in the JxLib framework. This class
@@ -15640,7 +15663,11 @@
this.setOptions(options);
if (this.options.useLang) {
- MooTools.lang.addEvent('langChange', this.changeText)
+ //MooTools.lang.addEvent('langChange', this.changeText)
+ var self = this;
+ MooTools.lang.addEvent('langChange', function(ev) {
+ self.changeText();
this.fireEvent('preInit');
this.init();
@@ -15768,18 +15795,42 @@
return this.plugins.get(name);
+ * APIMethod: getText
+ * returns the text for a jx.widget used in a label.
+ * Parameters:
+ * val - <String> || <Function> || <Object> = { set: '', key: ''[, value: ''] } for a MooTools.lang object
+ getText: function(val) {
+ if (Jx.type(val) == 'string') {
+ return val;
+ } else if (Jx.type(val) == 'function') {
+ return val();
+ } else if (Jx.type(val) == 'object' && $defined(val.set) && $defined(val.key)) {
+ // COMMENT: just an idea how a localization object could be stored to the instance if needed somewhere else and options change?
+ this.i18n = val;
+ if($defined(val.value)) {
+ return MooTools.lang.get(val.set, val.key)[val.value];
+ }else{
+ return MooTools.lang.get(val.set, val.key);
+ return '';
* APIMethod: changeText
* This method should be overridden by subclasses. It should be used
* to change any language specific default text that is used by the widget.
* Parameters:
- * lang - the language being changed to or that had it's data set of
+ * lang - the language being changed to or that had it's data set of
* translations changed.
- changeText: $empty
+ changeText : $empty
MooTools.lang.set('en-US', 'Jx', {
@@ -15817,6 +15868,9 @@
splitter: {
barToolTip: 'drag this bar to resize'
+ panelset: {
+ barToolTip: 'drag this bar to resize'
panel: {
collapseTooltip: 'Collapse/Expand Panel',
collapseLabel: 'Collapse',
@@ -15829,7 +15883,7 @@
closeLabel: 'Close'
confirm: {
- affirmitiveLabel: 'Yes',
+ affirmativeLabel: 'Yes',
negativeLabel: 'No'
dialog: {
@@ -15838,9 +15892,6 @@
message: {
okButton: 'Ok'
- panelset: {
- barTooltip: 'drag this bar to resize'
prompt: {
okButton: 'Ok',
cancelButton: 'Cancel'
@@ -15855,7 +15906,7 @@
submitButton: 'Save',
-});// $Id: widget.js 781 2010-03-25 13:24:27Z zak4ms $
+});// $Id: widget.js 901 2010-05-10 19:33:28Z jonlb at comcast.net $
* Class: Jx.Widget
* Base class for all widgets (visual classes) in the JxLib Framework. This
@@ -15910,6 +15961,20 @@
* The mask and spinner functionality is provided by the MooTools Spinner
* class. You can use any options documented for Spinner or Mask by setting
* the maskOptions option when creating a widget.
+ * Events:
+ * Jx.Widget has several events called during it's lifetime (in addition to
+ * the ones for its base class <Jx.Object>).
+ * preRender - called before rendering begins
+ * postRender - called after rendering is done
+ * deferRender - called when the deferRender option is set to true. The first
+ * two events (pre- and post- render will NOT be called if deferRender is
+ * set to true).
+ * contentLoaded - called after content has been loaded successfully
+ * contentLoadFailed - called if content can not be loaded for some reason
+ * addTo - called when a widget is added to another element or widget
+ * busy - called just before the busy mask is rendered/removed
* MooTools.Lang Keys:
* widget.busyMessage - sets the message of the waiter component when used
@@ -15919,6 +15984,10 @@
Extends: Jx.Object,
options: {
+ /* Option: id
+ * (optional) {String} an HTML ID to assign to the widget
+ id: null,
* Option: content
* content may be an HTML element reference, the id of an HTML element
@@ -15932,6 +16001,18 @@
contentURL: null,
+ * Option: loadOnDemand
+ * {boolean} ajax content will only be loaded if the action is requested
+ * (like loading the content into a tab when activated)
+ loadOnDemand : false,
+ * Option: cacheContent
+ * {boolean} determine whether the content should be loaded every time
+ * or if it's being cached
+ cacheContent : true,
* Option: template
* the default HTML structure of this widget. The default template
* is just a div with a class of jxWidget in the base class
@@ -15959,7 +16040,16 @@
className: 'jxIframeShim'
fx: true
+ * Option: deferRender
+ * Used to defer rendering of a widget to a later time. Useful when
+ * we need data or other information not at hand at the moment
+ * of Widget instantiation. If set to true, the user will need to call
+ * render() at some later time. The only drawback to doing so will be
+ * the loss of preRender and postRender events.
+ deferRender: false
@@ -16064,12 +16154,18 @@
url: this.options.contentURL,
method:'get',
evalScripts:true,
+ onRequest:(function() {
+ if(this.options.loadOnDemand) {
+ this.setBusy(true);
+ }).bind(this),
onSuccess:(function(html) {
element.innerHTML = html;
this.contentIsLoaded = true;
if (Jx.isAir){
$clear(this.reqTimeout);
+ this.setBusy(false);
this.fireEvent('contentLoaded', this);
}).bind(this),
onFailure: (function(){
@@ -16554,6 +16650,7 @@
cleanup: function(){
if ($defined(this.domObj)) {
+ this.domObj.eliminate('jxWidget');
this.domObj.destroy();
if ($defined(this.addable)) {
@@ -16572,6 +16669,14 @@
render: function() {
this.elements = this.processElements(this.options.template,
this.classes);
+ if ($defined(this.domObj)) {
+ if ( $defined(this.options.id)) {
+ this.domObj.set('id', this.options.id);
+ //TODO: Should we autogenerate an id when one is not provided? like so...
+ // this.domObj.set('id',this.generateId());
+ this.domObj.store('jxWidget', this);
@@ -16643,7 +16748,7 @@
opts.img = null;
opts.message = new Element('p',{
'class':'jxSpinnerMessage',
- html: '<span class="jxSpinnerImage"></span>'+MooTools.lang.get('Jx','widget').busyMessage
+ html: '<span class="jxSpinnerImage"></span>'+this.getText({set:'Jx',key:'widget',value:'busyMessage'})
opts = $merge(this.options.busyMask, opts);
@@ -16668,7 +16773,7 @@
* Parameters:
+ * lang - {string} the language being changed to or that had it's data set of
changeText: function (lang) {
@@ -16740,7 +16845,7 @@
-}// $Id: selection.js 762 2010-03-16 13:48:29Z pagameba $
+}// $Id: selection.js 840 2010-04-13 19:57:25Z pagameba $
* Class: Jx.Selection
@@ -16873,10 +16978,10 @@
if (this.selection.length > 1) {
this.unselect(this.selection[0]);
+ this.fireEvent(this.options.eventToFire.select, item);
} else {
this.unselect(item);
- this.fireEvent(this.options.eventToFire.select, item);
@@ -16893,7 +16998,7 @@
this.selection.length > this.options.minimumSelection) {
document.id(item).removeClass(this.options.selectClass);
this.selection.erase(item);
- this.fireEvent(this.options.eventToFire.unselect, item, this);
+ this.fireEvent(this.options.eventToFire.unselect, [item, this]);
@@ -16922,7 +17027,7 @@
isSelected: function(item) {
return this.selection.contains(item);
-});// $Id: list.js 762 2010-03-16 13:48:29Z pagameba $
+});// $Id: list.js 841 2010-04-15 14:16:06Z pagameba $
* Class: Jx.List
@@ -17088,7 +17193,7 @@
this.removeClass('jxPressed');
- click: function () {
+ click: function (e) {
if (target.selection &&
isEnabled(this) &&
isSelectable(this)) {
@@ -17106,6 +17211,14 @@
var itemTarget = item.retrieve('jxListTargetItem') || item;
target.fireEvent('unselect', itemTarget);
+ contextmenu: function(e) {
+ var cm = this.retrieve('jxContextMenu');
+ if (cm) {
+ cm.show(e);
+ this.removeClass(target.options.pressClass);
+ e.stop();
@@ -17160,6 +17273,9 @@
var target = el.retrieve('jxListTarget') || el;
if (target) {
target.store('jxListTargetItem', el);
+ target.addEvents({
+ contextmenu: this.bound.contextmenu
if (this.options.press && this.options.pressClass) {
target.addEvents({
mousedown: this.bound.mousedown,
@@ -17468,14 +17584,17 @@
sign: 'â¬'
'formatter.number': {
- decimalSeparator: '.',
- thousandsSeparator: ','
+ decimalSeparator: ',',
+ thousandsSeparator: '.'
splitter: {
barToolTip: 'Ziehen Sie diese Leiste um die GröÃe zu verändern'
+ panelset: {
+ barToolTip: 'Ziehen Sie diese Leiste um die GröÃe zu verändern'
panel: {
- collapseTooltip: 'Panel ein-/ausklappen', //colB
+ collapseTooltip: 'Panel ein-/ausklappen', //colB
collapseLabel: 'Einklappen', //colM
expandLabel: 'Ausklappen', //colM
maximizeTooltip: 'Panel maximieren',
@@ -17486,8 +17605,8 @@
closeLabel: 'SchlieÃen' //closeM
confirm: {
- affirmitiveLabel: 'Ja',
- negativeLabel: 'Nein'
+ affirmativeLabel: 'Ja',
+ negativeLabel: 'Nein'
dialog: {
label: 'Neues Fenster'
@@ -17495,9 +17614,6 @@
message: {
okButton: 'Ok'
- panelset: {
- barTooltip: 'Ziehen Sie diese Leiste um die GröÃe zu verändern'
prompt: {
okButton: 'Ok',
cancelButton: 'Abbrechen'
@@ -17506,15 +17622,88 @@
buttonText: 'Dateien hochladen'
'plugin.resize': {
- tooltip: 'Klicken um GröÃe zu verändern. Doppelklick für automatische GröÃe.'
+ tooltip: 'Klicken um GröÃe zu verändern. Doppelklick für automatische Anpassung.'
'plugin.editor': {
submitButton: 'Speichern',
-});// $Id: record.js 686 2010-02-01 05:45:28Z jonlb at comcast.net $
+});MooTools.lang.set('ru-RU-unicode', 'Jx', {
+ 'widget': {
+ busyMessage: 'ÐбÑабоÑка...'
+ 'colorpalette': {
+ alphaLabel: 'alpha (%)'
+ notice: {
+ closeTip: 'закÑÑÑÑ Ñ?Ñо Ñ?ообÑение'
+ progressbar: {
+ messageText: 'ÐагÑÑзка...',
+ progressText: '{progress} из {total}'
+ field: {
+ requiredText: '*'
+ file: {
+ browseLabel: 'ÐÑбÑаÑÑ...'
+ 'formatter.boolean': {
+ 'true': 'Ðа',
+ 'false': 'Ð?еÑ'
+ 'formatter.currency': {
+ sign: 'Ñ.'
+ 'formatter.number': {
+ thousandsSeparator: ' '
+ splitter: {
+ barToolTip: 'поÑÑ?ни, ÑÑÐ¾Ð±Ñ Ð¸Ð·Ð¼ÐµÐ½Ð¸ÑÑ ÑазмеÑ'
+ panelset: {
+ panel: {
+ collapseTooltip: 'СвеÑнÑÑÑ/РазвеÑнÑÑÑ ÐанелÑ',
+ collapseLabel: 'СвеÑнÑÑÑ',
+ expandLabel: 'РазвеÑнÑÑÑ',
+ maximizeTooltip: 'УвелиÑиÑÑ ÐанелÑ',
+ maximizeLabel: 'УвелиÑиÑÑ',
+ restoreTooltip: 'ÐоÑ?Ñ?ÑановиÑÑ ÐанелÑ',
+ restoreLabel: 'ÐоÑ?Ñ?ÑановиÑÑ',
+ closeTooltip: 'ÐакÑÑÑÑ ÐанелÑ',
+ closeLabel: 'ÐакÑÑÑÑ'
+ confirm: {
+ affirmativeLabel: 'Ðа',
+ negativeLabel: 'Ð?еÑ'
+ dialog: {
+ resizeToolTip: 'ÐзмениÑÑ ÑазмеÑ'
+ message: {
+ okButton: 'Ðк'
+ prompt: {
+ okButton: 'Ðк',
+ cancelButton: 'ÐÑмена'
+ upload: {
+ buttonText: 'ÐагÑÑзка Ñайла'
+ 'plugin.resize': {
+ tooltip: 'ÐоÑÑ?ни, ÑÑÐ¾Ð±Ñ Ð¸Ð·Ð¼ÐµÐ½Ð¸ÑÑ, двойной ÑелÑок длÑ? авÑо ÑазмеÑа.'
+ 'plugin.editor': {
+ submitButton: 'СоÑ
ÑаниÑÑ',
+});// $Id: record.js 834 2010-04-05 18:17:01Z jonlb at comcast.net $
- * Class: Jx.record
+ * Class: Jx.Record
* Extends: <Jx.Object>
@@ -17552,9 +17741,9 @@
* used to determine the state of this record. When not null (meaning no
* changes were made) this should be one of
- * - Jx.Store.Record.UPDATE
- * - Jx.Store.Record.DELETE
- * - Jx.Store.Record.INSERT
+ * - Jx.Record.UPDATE
+ * - Jx.Record.DELETE
+ * - Jx.Record.INSERT
state: null,
@@ -17721,7 +17910,7 @@
Jx.Record.UPDATE = 1;
Jx.Record.DELETE = 2;
-Jx.Record.INSERT = 3;// $Id: store.js 797 2010-03-26 20:23:32Z jonlb at comcast.net $
+Jx.Record.INSERT = 3;// $Id: store.js 898 2010-05-10 04:08:44Z jonlb at comcast.net $
* Class: Jx.Store
@@ -17733,8 +17922,7 @@
* For the most part the store is pretty "dumb" meaning it
* starts with very limited functionality. Actually, it can't
* even load data by itself. Instead, it needs to have protocols,
- * strategies, and a record class passed to it that it knows how to use
- * and can use it.
+ * strategies, and a record class passed to it that it can use.
* Example:
* (code)
@@ -17769,7 +17957,8 @@
* Option: protocol
* The protocol to use for communication in this store. The store
* itself doesn't actually use it but it is accessed by the strategies
- * to do their work. This option is required and the store won't work without it.
+ * to do their work. This option is required and the store won't work
+ * without it.
protocol: null,
@@ -17783,10 +17972,10 @@
strategies: null,
* Option: record
- * This is a Jx.Store.Record instance or one of its subclasses. This is the
- * class that will be used to hold each individual record in the store.
- * Don't pass in a instance of the class but rather the class name
- * itself. If none is passed in it will default to Jx.Store.Record
+ * This is a Jx.Store.Record instance or one of its subclasses. This is
+ * the class that will be used to hold each individual record in the
+ * store. Don't pass in a instance of the class but rather the class
+ * name itself. If none is passed in it will default to Jx.Record
record: null,
@@ -17810,7 +17999,7 @@
index : 0,
- * Property: id
+ * APIProperty: id
* The id of this store.
@@ -18104,9 +18293,7 @@
} else {
data = this.data;
- for (var i = 0, l = data.length; i < l; i++) {
- fn.call(bind, data[i], i, data);
+ data.each(fn, bind);
* APIMethod: get
@@ -18416,25 +18603,36 @@
* template - the template to fill
* columnsNeeded - the array of columns needed by this template. should be
* obtained by calling parseTemplate().
+ * obj - an object with some prefilled keys to use in substituting.
+ * Ones that are also in the store will be overwritten.
- fillTemplate: function (index, template, columnsNeeded) {
- index = $defined(index)? index : this.index;
+ fillTemplate: function (index, template, columnsNeeded, obj) {
+ var record = null;
+ if ($defined(index)) {
+ if (index instanceof Jx.Record) {
+ record = index;
+ } else {
+ record = this.getRecord(index);
+ } else {
+ record = this.getRecord(this.index);
//create the item
- var itemObj = {};
+ var itemObj = $defined(obj) ? obj : {};
columnsNeeded.each(function (col) {
- itemObj[col] = this.get(col, index);
+ itemObj[col] = record.get(col);
}, this);
return template.substitute(itemObj);
-});// $Id: compare.js 649 2009-11-30 22:19:48Z pagameba $
+});// $Id: compare.js 855 2010-04-20 06:04:53Z jonlb at comcast.net $
* Class: Jx.Compare
* Class that holds functions for doing comparison operations.
- * This class requires the clientside Date() extensions (deps/date.js).
+ * This class requires the mootools-more Date() extensions.
* notes:
* Each function that does a comparison returns
@@ -18495,7 +18693,14 @@
convert: function (val) {
if (Jx.type(val) === 'string') {
+ var neg = false;
+ if (val.substr(0,1) == '-') {
+ neg = true;
val = parseFloat(val.replace(/^[^\d\.]*([\d., ]+).*/g, "$1").replace(new RegExp("[^\\\d" + this.options.separator + "]", "g"), '').replace(/,/, '.')) || 0;
+ if (neg) {
+ val = val * -1;
return val || 0;
@@ -19085,7 +19290,7 @@
-// $Id: response.js 649 2009-11-30 22:19:48Z pagameba $
+// $Id: response.js 898 2010-05-10 04:08:44Z jonlb at comcast.net $
* Class: Jx.Store.Response
@@ -19100,10 +19305,10 @@
* This file is licensed under an MIT style license
Jx.Store.Response = new Class({
+ Family: 'Jx.Store.Response',
Extends: Jx.Object,
- Family: 'Jx.Store.Response',
* Property: code
* This is the success/failure code
@@ -19136,6 +19341,11 @@
request: null,
+ * Property: error
+ * the error data received from the called page if any.
+ error: null,
* APIMethod: success
* determines if this response represents a successful response
@@ -19230,14 +19440,14 @@
* that subclasses should implement.
abort: $empty
-});// $Id: protocol.local.js 649 2009-11-30 22:19:48Z pagameba $
+});// $Id: protocol.local.js 834 2010-04-05 18:17:01Z jonlb at comcast.net $
* Class: Jx.Store.Protocol.Local
* Extends: Jx.Store.Protocol
- * Based on the Protocol base class, the local protocol uses data that it is handed
- * upon instantiation to process requests.
+ * Based on the Protocol base class, the local protocol uses data that it is
+ * handed upon instantiation to process requests.
* Constructor Parameters:
* data - The data to use
@@ -19308,14 +19518,15 @@
- * The following methods are not implemented as they make no sense for a local protocol:
+ * The following methods are not implemented as they make no sense for a
+ * local protocol:
* - create
* - update
* - delete
* - commit
* - abort
-});// $Id: protocol.ajax.js 649 2009-11-30 22:19:48Z pagameba $
+});// $Id: protocol.ajax.js 898 2010-05-10 04:08:44Z jonlb at comcast.net $
* Class: Jx.Store.Protocol.Ajax
@@ -19350,9 +19561,9 @@
* Option: urls
* This is a hash of the urls to use for each method. If the rest
- * option is set to true the only one needed will be the urls.rest. These
- * can be overridden if needed by passing an options object into the
- * various methods with the appropriate urls.
+ * option is set to true the only one needed will be the urls.rest.
+ * These can be overridden if needed by passing an options object into
+ * the various methods with the appropriate urls.
urls: {
rest: null,
@@ -19371,8 +19582,6 @@
* Send a read request via AJAX
* Parameters:
- * page - the page requested
- * itemsPerPage - the number of items on the page
* options - the options to pass to the request.
read: function (options) {
@@ -19416,13 +19625,18 @@
var data = this.parser.parse(str);
if ($defined(data)) {
- if ($defined(data.data)) {
- response.data = data.data;
+ if ($defined(data.success) && data.success) {
+ if ($defined(data.data)) {
+ response.data = data.data;
+ if ($defined(data.meta)) {
+ response.meta = data.meta;
+ response.code = Jx.Store.Response.SUCCESS;
+ } else {
+ response.code = Jx.Store.Response.FAILURE;
+ response.error = $defined(data.error) ? data.error : null;
- if ($defined(data.meta)) {
- response.meta = data.meta;
- response.code = Jx.Store.Response.SUCCESS;
} else {
@@ -19437,7 +19651,7 @@
* options - options to pass to the request
insert: function (record, options) {
- if (!this.options.rest) {
+ if (this.options.rest) {
options = $merge({url: this.options.urls.rest},options);
} else {
options = $merge({url: this.options.urls.insert},options);
@@ -19504,7 +19718,9 @@
run: function (record, options, method) {
- this.options.requestOptions.data = this.parser.encode(record);
+ this.options.requestOptions.data = {
+ data: this.parser.encode(record)
var resp = new Jx.Store.Response();
resp.requestType = method;
@@ -19595,7 +19811,7 @@
return false;
-});// $Id: strategy.full.js 776 2010-03-22 14:35:16Z pagameba $
+});// $Id: strategy.full.js 898 2010-05-10 04:08:44Z jonlb at comcast.net $
* Class: Jx.Store.Strategy.Full
@@ -19671,7 +19887,7 @@
* Method: loadStore
- * Called as the event hanlder for the protocol's dataLoaded event. Checks
+ * Called as the event handler for the protocol's dataLoaded event. Checks
* the response for success and loads the data into the store if needed.
* Parameters:
@@ -19997,7 +20213,21 @@
getTotalCount: function () {
return this.totalItems;
+ * Class: Jx.Store.Strategy.Progressive
+ * Extends: <Jx.Store.Strategy.Paginate>
+ * Store strategy for progressively obtaining results in a store. You can
+ * continually call nextPage() to get the next page and the store will retain
+ * all current data. You can set a maximum number of records the store should
+ * hold and whether it should dropRecords when that max is hit.
+ * License:
+ * Copyright (c) 2010, Jon Bomgardner.
+ * This file is licensed under an MIT style license
Jx.Store.Strategy.Progressive = new Class({
Extends: Jx.Store.Strategy.Paginate,
@@ -20032,6 +20262,7 @@
loadedPages: 0,
* Property: loadAt
+ * Options are 'top' or 'bottom'. Defaults to 'bottom'.
loadAt: 'bottom',
@@ -20089,13 +20320,13 @@
* the store
* Parameters:
- * end - which end to load to. Either 'top' or 'bottom'.
+ * params - a hash of parameters to pass to the request if needed.
nextPage: function (params) {
if (!$defined(params)) {
params = {};
- if (this.options.dropPages && this.totalPages > this.startingPage + this.loadedPages) {
+ if (this.options.dropRecords && this.totalPages > this.startingPage + this.loadedPages) {
this.loadAt = 'bottom';
if (this.loadedPages >= this.maxPages) {
//drop records before getting more
@@ -20107,10 +20338,16 @@
this.page = this.startingPage + this.loadedPages + 1;
this.load($merge(this.params, params));
+ * APIMethod: previousPage
+ * Allows a caller to move back to the previous page.
+ * Parameters:
previousPage: function (params) {
- //if we're not dropping pages there's nothing todo
- if (!this.options.dropPages) {
+ //if we're not dropping pages there's nothing to do
+ if (!this.options.dropRecords) {
return;
@@ -20129,7 +20366,7 @@
-});// $Id: strategy.save.js 776 2010-03-22 14:35:16Z pagameba $
+});// $Id: strategy.save.js 898 2010-05-10 04:08:44Z jonlb at comcast.net $
* Class: Jx.Store.Strategy.Save
@@ -20151,7 +20388,7 @@
options: {
* Option: autoSave
- * Whether the strateggy should be watching the store to save changes
+ * Whether the strategy should be watching the store to save changes
* automatically. Set to True to watch events, set it to a number of
* milliseconds to have the strategy save every so many seconds
@@ -20227,7 +20464,7 @@
* record - The Jx.Record instance that was changed
* store - The instance of the store
- saveRecord: function (record, store) {
+ saveRecord: function (store, record) {
//determine the status and route based on that
if (!this.updating && $defined(record.state)) {
if (this.totalChanges === 0) {
@@ -20270,7 +20507,7 @@
records[Jx.Record.DELETE] = this.store.deleted;
records.flatten().each(function (record) {
- this.saveRecord(record);
+ this.saveRecord(null, record);
}, this);
@@ -20684,7 +20921,7 @@
return JSON.encode(data);
-});// $Id: button.js 808 2010-03-27 18:07:49Z pagameba $
+});// $Id: button.js 892 2010-05-06 21:06:26Z conrad.barthelmes $
* Class: Jx.Button
@@ -20752,11 +20989,6 @@
Extends: Jx.Widget,
options: {
- /* Option: id
- * optional. A string value to use as the ID of the button
- * container.
- id: '',
/* Option: image
* optional. A string value that is the url to load the image to
* display in this button. The default styles size this image to 16 x
@@ -20772,7 +21004,8 @@
tooltip: '',
/* Option: label
* optional, default is no label. A string value that is used as a
- * label on the button.
+ * label on the button. - use an object for localization: { set: 'Examples', key: 'lanKey', value: 'langValue' }
+ * see widget.js for details
label: '',
/* Option: toggle
@@ -20849,8 +21082,8 @@
var mouseDown;
this.domA.set({
href: this.options.href,
- title: this.options.tooltip,
- alt: this.options.tooltip
+ title: this.getText(this.options.tooltip),
+ alt: this.getText(this.options.tooltip)
this.domA.addEvents({
click: this.clicked.bindWithEvent(this),
@@ -20896,8 +21129,8 @@
if (this.domImg) {
if (this.options.image || !this.options.label) {
this.domImg.set({
if (this.options.image && this.options.image.indexOf(Jx.aPixel.src) == -1) {
this.domImg.setStyle('backgroundImage',"url("+this.options.image+")");
@@ -20913,7 +21146,7 @@
if (this.domLabel) {
if (this.options.label || this.domA.hasClass('jxDiscloser')) {
- this.domLabel.set('html',this.options.label);
+ this.setLabel(this.options.label);
} else {
//this.domLabel.removeClass('jx'+this.type+'Label');
this.domLabel.setStyle('display','none');
@@ -21037,7 +21270,7 @@
setLabel: function(label) {
this.options.label = label;
- this.domLabel.set('html', label);
+ this.domLabel.set('html', this.getText(label));
this.domLabel.setStyle('display', label || this.domA.hasClass('jxDiscloser') ? null : 'none');
@@ -21058,8 +21291,8 @@
setTooltip: function(tooltip) {
if (this.domA) {
this.domA.set({
- 'title':tooltip,
- 'alt':tooltip
+ 'title':this.getText(tooltip),
+ 'alt':this.getText(tooltip)
//need to account for the tooltip on the image as well
@@ -21069,8 +21302,8 @@
if ($defined(t)) {
//change it...
this.domImg.set({
- 'title':tooltip,
- 'alt':tooltip
@@ -21092,9 +21325,21 @@
if (this.domA) {
this.domA.blur();
+ * APIMethod: changeText
+ * updates the label of the button on langChange Event for
+ * Internationalization
+ changeText : function(lang) {
+ this.parent();
+ this.setTooltip(this.options.tooltip);
-// $Id: flyout.js 768 2010-03-18 16:22:50Z fred.warnock $
+// $Id: flyout.js 900 2010-05-10 16:04:57Z pagameba $
* Class: Jx.Button.Flyout
@@ -21162,7 +21407,21 @@
/* Option: contentTemplate
* the HTML structure of the flyout content area
- contentTemplate: '<div class="jxFlyout"><div class="jxFlyoutContent"></div></div>'
+ contentTemplate: '<div class="jxFlyout"><div class="jxFlyoutContent"></div></div>',
+ /* Option: position
+ * where to position the flyout, see Jx.Widget::position
+ * for details on how to specify this option
+ position: {
+ horizontal: ['left left', 'right right'],
+ vertical: ['bottom top', 'top bottom']
+ /* Option: positionElement
+ * the element to position the flyout relative to, by default
+ * it is the domObj of this button and should only be changed
+ * if you really know what you are doing
+ positionElement: null
@@ -21262,12 +21521,12 @@
this.showChrome(this.contentContainer);
- this.position(this.contentContainer, this.domObj, {
- horizontal: ['left left', 'right right'],
- vertical: ['bottom top', 'top bottom'],
- offsets: this.chromeOffsets
+ var rel = this.options.positionElement || this.domObj;
+ var pos = $merge(this.options.position, {
+ offsets: this.chromeOffsets
+ this.position(this.contentContainer, rel, pos);
/* we have to size the container for IE to render the chrome correctly
* there is some horrible peekaboo bug in IE 6
@@ -21319,611 +21578,8 @@
Jx.Button.Flyout.Stack[Jx.Button.Flyout.Stack.length - 1].hide();
-});// $Id: layout.js 718 2010-03-02 16:22:06Z pagameba $
+});// $Id: colorpalette.js 892 2010-05-06 21:06:26Z conrad.barthelmes $
- * Class: Jx.Layout
- * Extends: <Jx.Object>
- * Jx.Layout is used to provide more flexible layout options for applications
- * Jx.Layout wraps an existing DOM element (typically a div) and provides
- * extra functionality for sizing that element within its parent and sizing
- * elements contained within it that have a 'resize' function attached to them.
- * To create a Jx.Layout, pass the element or id plus an options object to
- * the constructor.
- * Example:
- * (code)
- * var myContainer = new Jx.Layout('myDiv', options);
- * (end)
- * Events:
- * sizeChange - fired when the size of the container changes
- * License:
- * Copyright (c) 2008, DM Solutions Group Inc.
- * This file is licensed under an MIT style license
-Jx.Layout = new Class({
- Family: 'Jx.Layout',
- Extends: Jx.Object,
- options: {
- /* Option: resizeWithWindow
- * boolean, automatically resize this layout when the window size
- * changes, even if the element is not a direct descendant of the
- * BODY. False by default.
- resizeWithWindow: false,
- /* Option: propagate
- * boolean, controls propogation of resize to child nodes.
- * True by default. If set to false, changes in size will not be
- * propogated to child nodes.
- propagate: true,
- /* Option: position
- * how to position the element, either 'absolute' or 'relative'.
- * The default (if not passed) is 'absolute'. When using
- * 'absolute' positioning, both the width and height are
- * controlled by Jx.Layout. If 'relative' positioning is used
- * then only the width is controlled, allowing the height to
- * be controlled by its content.
- position: 'absolute',
- /* Option: left
- * the distance (in pixels) to maintain the left edge of the element
- * from its parent element. The default value is 0. If this is set
- * to 'null', then the left edge can be any distance from its parent
- * based on other parameters.
- left: 0,
- /* Option: right
- * the distance (in pixels) to maintain the right edge of the element
- * to 'null', then the right edge can be any distance from its parent
- right: 0,
- /* Option: top
- * the distance (in pixels) to maintain the top edge of the element
- * to 'null', then the top edge can be any distance from its parent
- top: 0,
- /* Option: bottom
- * the distance (in pixels) to maintain the bottom edge of the element
- * to 'null', then the bottom edge can be any distance from its parent
- bottom: 0,
- /* Option: width
- * the width (in pixels) of the element. The default value is null.
- * If this is set to 'null', then the width can be any value based on
- * other parameters.
- width: null,
- /* Option: height
- * the height (in pixels) of the element. The default value is null.
- * If this is set to 'null', then the height can be any value based on
- height: null,
- /* Option: minWidth
- * the minimum width that the element can be sized to. The default
- * value is 0.
- minWidth: 0,
- /* Option: minHeight
- * the minimum height that the element can be sized to. The
- * default value is 0.
- minHeight: 0,
- /* Option: maxWidth
- * the maximum width that the element can be sized to. The default
- * value is -1, which means no maximum.
- maxWidth: -1,
- /* Option: maxHeight
- * the maximum height that the element can be sized to. The
- * default value is -1, which means no maximum.
- maxHeight: -1
- * Parameters:
- * domObj - {HTMLElement} element or id to apply the layout to
- * options - <Jx.Layout.Options>
- parameters: ['domObj','options'],
- * APIMethod: init
- * Create a new instance of Jx.Layout.
- init: function() {
- this.domObj = document.id(this.options.domObj);
- this.domObj.resize = this.resize.bind(this);
- this.domObj.setStyle('position', this.options.position);
- this.domObj.store('jxLayout', this);
- if (this.options.resizeWithWindow || document.body == this.domObj.parentNode) {
- window.addEvent('resize', this.windowResize.bindWithEvent(this));
- window.addEvent('load', this.windowResize.bind(this));
- //this.resize();
- * Method: windowResize
- * when the window is resized, any Jx.Layout controlled elements that are
- * direct children of the BODY element are resized
- windowResize: function() {
- this.resize();
- if (this.resizeTimer) {
- $clear(this.resizeTimer);
- this.resizeTimer = null;
- this.resizeTimer = this.resize.delay(50, this);
- * Method: resize
- * resize the element controlled by this Jx.Layout object.
- * Parameters:
- * options - new options to apply, see <Jx.Layout.Options>
- resize: function(options) {
- /* this looks like a really big function but actually not
- * much code gets executed in the two big if statements
- var needsResize = false;
- if (options) {
- for (var i in options) {
- //prevent forceResize: false from causing a resize
- if (i == 'forceResize') {
- continue;
- if (this.options[i] != options[i]) {
- needsResize = true;
- this.options[i] = options[i];
- if (options.forceResize) {
- if (!document.id(this.domObj.parentNode)) {
- return;
- var parentSize;
- if (this.domObj.parentNode.tagName == 'BODY') {
- parentSize = Jx.getPageDimensions();
- } else {
- parentSize = document.id(this.domObj.parentNode).getContentBoxSize();
- if (this.lastParentSize && !needsResize) {
- needsResize = (this.lastParentSize.width != parentSize.width ||
- this.lastParentSize.height != parentSize.height);
- } else {
- this.lastParentSize = parentSize;
- if (!needsResize) {
- return;
- var l, t, w, h;
- /* calculate left and width */
- if (this.options.left != null) {
- /* fixed left */
- l = this.options.left;
- if (this.options.right == null) {
- /* variable right */
- if (this.options.width == null) {
- /* variable right and width
- * set right to min, stretch width */
- w = parentSize.width - l;
- if (w < this.options.minWidth ) {
- w = this.options.minWidth;
- if (this.options.maxWidth >= 0 && w > this.options.maxWidth) {
- w = this.options.maxWidth;
- } else {
- /* variable right, fixed width
- * use width
- w = this.options.width;
- } else {
- /* fixed right */
- /* fixed right, variable width
- * stretch width
- w = parentSize.width - l - this.options.right;
- if (w < this.options.minWidth) {
- } else {
- /* fixed right, fixed width
- * respect left and width, allow right to stretch
- } else {
- /* variable left, width and right
- * set left, right to min, stretch width
- l = 0;
- w = parentSize.width;
- l = l + parseInt(w - this.options.maxWidth,10)/2;
- } else {
- /* variable left, fixed width, variable right
- * distribute space between left and right
- l = parseInt((parentSize.width - w)/2,10);
- if (l < 0) {
- l = 0;
- } else {
- if (this.options.width != null) {
- /* variable left, fixed width, fixed right
- * left is calculated directly
- l = parentSize.width - w - this.options.right;
- if (l < 0) {
- l = 0;
- } else {
- /* variable left and width, fixed right
- * set left to min value and stretch width
- l = 0;
- w = parentSize.width - this.options.right;
- l = w - this.options.maxWidth - this.options.right;
- /* calculate the top and height */
- if (this.options.top != null) {
- /* fixed top */
- t = this.options.top;
- if (this.options.bottom == null) {
- /* variable bottom */
- if (this.options.height == null) {
- /* variable bottom and height
- * set bottom to min, stretch height */
- h = parentSize.height - t;
- if (h < this.options.minHeight) {
- h = this.options.minHeight;
- if (this.options.maxHeight >= 0 && h > this.options.maxHeight) {
- h = this.options.maxHeight;
- } else {
- /* variable bottom, fixed height
- * stretch height
- h = this.options.height;
- t = h - this.options.maxHeight;
- } else {
- /* fixed bottom */
- /* fixed bottom, variable height
- * stretch height
- h = parentSize.height - t - this.options.bottom;
- } else {
- /* fixed bottom, fixed height
- * respect top and height, allow bottom to stretch
- } else {
- /* variable top, height and bottom
- * set top, bottom to min, stretch height
- t = 0;
- h = parentSize.height;
- t = parseInt((parentSize.height - this.options.maxHeight)/2,10);
- } else {
- /* variable top, fixed height, variable bottom
- * distribute space between top and bottom
- t = parseInt((parentSize.height - h)/2,10);
- if (t < 0) {
- t = 0;
- } else {
- if (this.options.height != null) {
- /* variable top, fixed height, fixed bottom
- * top is calculated directly
- t = parentSize.height - h - this.options.bottom;
- if (t < 0) {
- t = 0;
- } else {
- /* variable top and height, fixed bottom
- * set top to min value and stretch height
- t = 0;
- h = parentSize.height - this.options.bottom;
- t = parentSize.height - this.options.maxHeight - this.options.bottom;
- //TODO: check left, top, width, height against current styles
- // and only apply changes if they are not the same.
- /* apply the new sizes */
- var sizeOpts = {width: w};
- if (this.options.position == 'absolute') {
- var m = document.id(this.domObj.parentNode).measure(function(){
- return this.getSizes(['padding'],['left','top']).padding;
- this.domObj.setStyles({
- position: this.options.position,
- left: l+m.left,
- top: t+m.top
- sizeOpts.height = h;
- } else {
- if (this.options.height) {
- sizeOpts.height = this.options.height;
- this.domObj.setBorderBoxSize(sizeOpts);
- if (this.options.propagate) {
- // propogate changes to children
- var o = {forceResize: options ? options.forceResize : false};
- $A(this.domObj.childNodes).each(function(child){
- if (child.resize && child.getStyle('display') != 'none') {
- child.resize.delay(0,child,o);
- this.fireEvent('sizeChange',this);
-});// $Id: tab.js 762 2010-03-16 13:48:29Z pagameba $
- * Class: Jx.Button.Tab
- * Extends: <Jx.Button>
- * A single tab in a tab set. A tab has a label (displayed in the tab) and a
- * content area that is displayed when the tab is active. A tab has to be
- * added to both a <Jx.TabSet> (for the content) and <Jx.Toolbar> (for the
- * actual tab itself) in order to be useful. Alternately, you can use
- * a <Jx.TabBox> which combines both into a single control at the cost of
- * some flexibility in layout options.
- * A tab is a <Jx.ContentLoader> and you can specify the initial content of
- * the tab using any of the methods supported by
- * <Jx.ContentLoader::loadContent>. You can acccess the actual DOM element
- * that contains the content (if you want to dynamically insert content
- * for instance) via the <Jx.Tab::content> property.
- * A tab is a button of type *toggle* which means that it emits the *up*
- * and *down* events.
- * Example:
- * (code)
- * var tab1 = new Jx.Button.Tab({
- * label: 'tab 1',
- * content: 'content1',
- * onDown: function(tab) {
- * console.log('tab became active');
- * onUp: function(tab) {
- * console.log('tab became inactive');
- * (end)
- * License:
-Jx.Button.Tab = new Class({
- Family: 'Jx.Button.Tab',
- Extends: Jx.Button,
- * Property: content
- * {HTMLElement} The content area that is displayed when the tab is
- * active.
- content: null,
- options: {
- /* Option: toggleClass
- * the CSS class to use for the button, 'jxTabToggle' by default
- toggleClass: 'jxTabToggle',
- /* Option: pressedClass
- * the CSS class to use when the tab is pressed, 'jxTabPressed' by
- * default
- pressedClass: 'jxTabPressed',
- /* Option: activeClass
- * the CSS class to use when the tab is active, 'jxTabActive' by
- * default.
- activeClass: 'jxTabActive',
- /* Option: activeTabClass
- * the CSS class to use on the content area of the active tab,
- * 'tabContentActive' by default.
- activeTabClass: 'tabContentActive',
- /* Option: template
- * the HTML template for a tab
- template: '<span class="jxTabContainer"><a class="jxTab"><span class="jxTabContent"><img class="jxTabIcon"><span class="jxTabLabel"></span></span></a><a class="jxTabClose"></span>',
- /* Option: contentTemplate
- * the HTML template for a tab's content area
- contentTemplate: '<div class="tabContent"></div>',
- /* Option: close
- * {Boolean} can the tab be closed by the user? False by default.
- close: false,
- /* Option: shouldClose
- * {Mixed} when a tab is closeable, the shouldClose option is checked
- * first to see if the tab should close. You can provide a function
- * for this option that can be used to return a boolean value. This
- * is useful if your tab contains something the user can edit and you
- * want to see if they want to discard the changes before closing.
- * The default value is true, meaning the tab will close immediately.
- * (code)
- * new Jx.Tab({
- * label: 'test close',
- * close: true,
- * shouldClose: function() {
- * return window.confirm('Are you sure?');
- * (end)
- shouldClose: true
- * Property: classes
- * {<Hash>} a hash of object properties to CSS class names used to
- * automatically extract references to important DOM elements when
- * processing a widget template. This allows developers to provide custom
- * HTML structures without affecting the functionality of widgets.
- classes: new Hash({
- domObj: 'jxTabContainer',
- domA: 'jxTab',
- domImg: 'jxTabIcon',
- domLabel: 'jxTabLabel',
- domClose: 'jxTabClose',
- content: 'tabContent'
- * Method: render
- * Create a new instance of Jx.Button.Tab. Any layout options passed are used
- * to create a <Jx.Layout> for the tab content area.
- render : function( ) {
- this.options = $merge(this.options, {toggle:true});
- this.parent();
- this.domObj.store('jxTab', this);
- this.processElements(this.options.contentTemplate, this.classes);
- new Jx.Layout(this.content, this.options);
- this.loadContent(this.content);
- this.addEvent('down', function(){
- this.content.addClass(this.options.activeTabClass);
- }.bind(this));
- this.addEvent('up', function(){
- this.content.removeClass(this.options.activeTabClass);
- }.bind(this));
- //remove the close button if necessary
- if (this.domClose) {
- if (this.options.close) {
- this.domObj.addClass('jxTabClose');
- this.domClose.addEvent('click', (function(){
- var shouldClose = true;
- if ($defined(this.options.shouldClose)) {
- if (typeof this.options.shouldClose == 'function') {
- shouldClose = this.options.shouldClose();
- } else {
- shouldClose = this.options.shouldClose;
- if (shouldClose) {
- this.fireEvent('close');
- }).bind(this));
- } else {
- this.domClose.dispose();
- * APIMethod: clicked
- * triggered when the user clicks the button, processes the
- * actionPerformed event
- clicked : function(evt) {
- if (this.options.enabled) {
- this.setActive(true);
-});// $Id: colorpalette.js 776 2010-03-22 14:35:16Z pagameba $
* Class: Jx.ColorPalette
* Extends: <Jx.Widget>
@@ -22024,7 +21680,7 @@
top.adopt(this.colorInput);
- this.alphaLabel = new Element('label', {'class':'jxAlphaLabel', 'html':MooTools.lang.get('Jx','colorpalette').alphaLabel});
+ this.alphaLabel = new Element('label', {'class':'jxAlphaLabel', 'html':this.getText({set:'Jx',key:'colorpalette',value:'alphaLabel'}) });
top.adopt(this.alphaLabel);
this.alphaInput = new Element('input', {
@@ -22244,7 +21900,7 @@
this.parent();
if ($defined(this.alphaLabel)) {
- this.alphaLabel.set('html', MooTools.lang.get('Jx','colorpalette').alphaLabel);
+ this.alphaLabel.set('html', this.getText({set:'Jx',key:'colorpalette',value:'alphaLabel'}));
@@ -22453,7 +22109,7 @@
this.swatch.setStyles(styles);
-// $Id: menu.js 817 2010-03-30 12:13:04Z pagameba $
+// $Id: menu.js 908 2010-05-19 21:12:06Z conrad.barthelmes $
* Class: Jx.Menu
@@ -22477,6 +22133,7 @@
Jx.Menu = new Class({
Family: 'Jx.Menu',
Extends: Jx.Widget,
+ Binds: ['onMouseEnter','onMouseLeave','hide','keypressHandler'],
* Property: button
* {<Jx.Button>} The button that represents this menu in a toolbar and
@@ -22498,6 +22155,19 @@
parameters: ['buttonOptions', 'options'],
options: {
+ * Option: exposeOnHover
+ * {Boolean} default false, if set to true the menu will show
+ * when the mouse hovers over it rather than when it is clicked.
+ exposeOnHover: false,
+ * Option: hideDelay
+ * {Integer} default 0, if greater than 0, this is the number of
+ * milliseconds to delay before hiding a menu when the mouse leaves
+ * the menu button or list.
+ hideDelay: 0,
template: "<div class='jxMenuContainer'><ul class='jxMenu'></ul></div>",
buttonTemplate: '<span class="jxButtonContainer"><a class="jxButton jxButtonMenu jxDiscloser"><span class="jxButtonContent"><img class="jxButtonIcon" src="'+Jx.aPixel.src+'"><span class="jxButtonLabel"></span></span></a></span>',
position: {
@@ -22537,18 +22207,16 @@
onClick:this.show.bind(this)
- this.button.domA.addEvent('mouseover', this.onMouseOver.bindWithEvent(this));
+ this.button.domA.addEvent('mouseenter', this.onMouseEnter);
+ this.button.domA.addEvent('mouseleave', this.onMouseLeave);
this.domObj = this.button.domObj;
this.domObj.store('jxMenu', this);
+ this.subDomObj.addEvent('mouseenter', this.onMouseEnter);
+ this.subDomObj.addEvent('mouseleave', this.onMouseLeave);
- /* pre-bind the hide function for efficiency */
- this.bound = {
- mousedown: this.hide.bindWithEvent(this),
- keypress: this.keypressHandler.bindWithEvent(this)
if (this.options.parent) {
this.addTo(this.options.parent);
@@ -22622,13 +22290,37 @@
* Parameters:
* e - {Event} the mouse event
- onMouseOver: function(e) {
+ onMouseEnter: function(e) {
+ if (this.hideTimer) {
+ $clear(this.hideTimer);
+ this.hideTimer = null;
if (Jx.Menu.Menus[0] && Jx.Menu.Menus[0] != this) {
this.show({event:e});
+ } else if (this.options.exposeOnHover) {
+ if (Jx.Menu.Menus[0] && Jx.Menu.Menus[0] == this) {
+ Jx.Menu.Menus[0] = null;
+ this.show({event:e});
+ * Method: onMouseLeave
+ * Handle the user moving the mouse off this button or menu by
+ * starting the hide process if so configured.
+ * Parameters:
+ * e - {Event} the mouse event
+ onMouseLeave: function(e) {
+ if (this.options.hideDelay > 0) {
+ this.hideTimer = (function(){
+ this.deactivate();
+ }).delay(this.options.hideDelay, this);
* Method: eventInMenu
* determine if an event happened inside this menu or a sub menu
* of this menu.
@@ -22700,8 +22392,8 @@
this.button.domA.removeClass(this.button.options.activeClass);
this.list.each(function(item){item.retrieve('jxMenuItem').hide(e);});
- document.removeEvent('mousedown', this.bound.mousedown);
- document.removeEvent('keydown', this.bound.keypress);
+ document.removeEvent('mousedown', this.hide);
+ document.removeEvent('keydown', this.keypressHandler);
this.unstack(this.contentContainer);
this.contentContainer.dispose();
this.visibleItem = null;
@@ -22736,8 +22428,8 @@
- * but just in the menu/sub menu case - there is some horrible peekaboo
- * bug in IE related to ULs that we just couldn't figure out
+ * but just in the menu/sub menu case - there is some horrible
+ * peekaboo bug in IE related to ULs that we just couldn't figure out
this.contentContainer.setContentBoxSize(this.subDomObj.getMarginBoxSize());
@@ -22753,8 +22445,8 @@
/* fix bug in IE that closes the menu as it opens because of bubbling */
- document.addEvent('mousedown', this.bound.mousedown);
- document.addEvent('keydown', this.bound.keypress);
+ document.addEvent('mousedown', this.hide);
+ document.addEvent('keydown', this.keypressHandler);
this.fireEvent('show', this);
@@ -22875,6 +22567,11 @@
blur: function() {
this.button.blur();
+ changeText: function(lang) {
+ this.parent();
+ //this.render();
@@ -23002,7 +22699,7 @@
this.setActiveButton(button);
this.fireEvent('change', this);
-});// $Id: multi.js 762 2010-03-16 13:48:29Z pagameba $
+});// $Id: multi.js 900 2010-05-10 16:04:57Z pagameba $
* Class: Jx.Button.Multi
@@ -23079,7 +22776,8 @@
/* Option: template
* the button template for a multi button
- template: '<span class="jxButtonContainer"><a class="jxButton jxButtonMulti jxDiscloser"><span class="jxButtonContent"><img src="'+Jx.aPixel.src+'" class="jxButtonIcon"><span class="jxButtonLabel"></span></span></a><a class="jxButtonDisclose" href="javascript:void(0)"><img src="'+Jx.aPixel.src+'"></a></span>'
+ template: '<span class="jxButtonContainer"><a class="jxButton jxButtonMulti jxDiscloser"><span class="jxButtonContent"><img src="'+Jx.aPixel.src+'" class="jxButtonIcon"><span class="jxButtonLabel"></span></span></a><a class="jxButtonDisclose" href="javascript:void(0)"><img src="'+Jx.aPixel.src+'"></a></span>',
+ menuOptions: {}
@@ -23105,7 +22803,7 @@
this.parent();
this.buttons = [];
- this.menu = new Jx.Menu();
+ this.menu = new Jx.Menu({}, this.options.menuOptions);
this.menu.button = this;
this.buttonSet = new Jx.ButtonSet();
@@ -23143,8 +22841,8 @@
this.contentContainer.setStyle('visibility','');
- document.addEvent('keyup', this.bound.keypress);
+ document.addEvent('keyup', this.keypressHandler);
}).bindWithEvent(this.menu),
@@ -23437,218 +23135,439 @@
-// $Id: combo.js 826 2010-03-31 18:46:16Z pagameba $
+// $Id: layout.js 718 2010-03-02 16:22:06Z pagameba $
- * Class: Jx.Button.Combo
+ * Class: Jx.Layout
- * Extends: <Jx.Button.Multi>
+ * Extends: <Jx.Object>
- * A drop down list of selectable items. Items can be either a string, an image or both.
+ * Jx.Layout is used to provide more flexible layout options for applications
+ * Jx.Layout wraps an existing DOM element (typically a div) and provides
+ * extra functionality for sizing that element within its parent and sizing
+ * elements contained within it that have a 'resize' function attached to them.
+ * To create a Jx.Layout, pass the element or id plus an options object to
+ * the constructor.
* Example:
* (code)
- * new Jx.Button.Combo({
- * label: 'Choose a symbol',
- * items: [
- * {label: 'Star', image: 'images/swatches.png', imageClass: 'comboStar'},
- * {label: 'Square', image: 'images/swatches.png', imageClass: 'comboSquare'},
- * {label: 'Triangle', image: 'images/swatches.png', imageClass: 'comboTriangle'},
- * {label: 'Circle', image: 'images/swatches.png', imageClass: 'comboCircle'},
- * {label: 'Plus', image: 'images/swatches.png', imageClass: 'comboPlus'},
- * {label: 'Cross', image: 'images/swatches.png', imageClass: 'comboCross'}
- * onChange: function(combo) { alert('you selected ' + combo.getValue()) }
+ * var myContainer = new Jx.Layout('myDiv', options);
* (end)
* Events:
- * change - triggered when the user selects a new item from the list
+ * sizeChange - fired when the size of the container changes
* License:
-Jx.Button.Combo = new Class({
- Family: 'Jx.Button.Combo',
- ul : null,
- * Property: currentSelection
- * {Object} current selection in the list
- currentSelection : null,
+Jx.Layout = new Class({
+ Family: 'Jx.Layout',
+ Extends: Jx.Object,
options: {
- /* Option: label
- * string, default ''. The label to display next to the combo.
+ /* Option: resizeWithWindow
+ * boolean, automatically resize this layout when the window size
+ * changes, even if the element is not a direct descendant of the
+ * BODY. False by default.
- label: '',
+ resizeWithWindow: false,
+ /* Option: propagate
+ * boolean, controls propogation of resize to child nodes.
+ * True by default. If set to false, changes in size will not be
+ * propogated to child nodes.
- template: '<span class="jxButtonContainer"><a class="jxButton jxButtonCombo jxDiscloser"><span class="jxButtonContent"><img class="jxButtonIcon" src="'+Jx.aPixel.src+'"><span class="jxButtonLabel"></span></span></a></span>'
+ propagate: true,
+ * how to position the element, either 'absolute' or 'relative'.
+ * The default (if not passed) is 'absolute'. When using
+ * 'absolute' positioning, both the width and height are
+ * controlled by Jx.Layout. If 'relative' positioning is used
+ * then only the width is controlled, allowing the height to
+ * be controlled by its content.
+ position: 'absolute',
+ /* Option: left
+ * the distance (in pixels) to maintain the left edge of the element
+ * from its parent element. The default value is 0. If this is set
+ * to 'null', then the left edge can be any distance from its parent
+ * based on other parameters.
+ left: 0,
+ /* Option: right
+ * the distance (in pixels) to maintain the right edge of the element
+ * to 'null', then the right edge can be any distance from its parent
+ right: 0,
+ /* Option: top
+ * the distance (in pixels) to maintain the top edge of the element
+ * to 'null', then the top edge can be any distance from its parent
+ top: 0,
+ /* Option: bottom
+ * the distance (in pixels) to maintain the bottom edge of the element
+ * to 'null', then the bottom edge can be any distance from its parent
+ bottom: 0,
+ /* Option: width
+ * the width (in pixels) of the element. The default value is null.
+ * If this is set to 'null', then the width can be any value based on
+ * other parameters.
+ width: null,
+ /* Option: height
+ * the height (in pixels) of the element. The default value is null.
+ * If this is set to 'null', then the height can be any value based on
+ height: null,
+ /* Option: minWidth
+ * the minimum width that the element can be sized to. The default
+ * value is 0.
+ minWidth: 0,
+ /* Option: minHeight
+ * the minimum height that the element can be sized to. The
+ * default value is 0.
+ minHeight: 0,
+ /* Option: maxWidth
+ * the maximum width that the element can be sized to. The default
+ * value is -1, which means no maximum.
+ maxWidth: -1,
+ /* Option: maxHeight
+ * the maximum height that the element can be sized to. The
+ * default value is -1, which means no maximum.
+ maxHeight: -1
- * APIMethod: render
- * create a new instance of Jx.Combo
+ * Parameters:
+ * domObj - {HTMLElement} element or id to apply the layout to
+ * options - <Jx.Layout.Options>
- render: function() {
- this.parent();
+ parameters: ['domObj','options'],
- this.menu.button = this;
- this.buttonSet = new Jx.ButtonSet();
+ * APIMethod: init
+ * Create a new instance of Jx.Layout.
+ init: function() {
+ this.domObj = document.id(this.options.domObj);
+ this.domObj.resize = this.resize.bind(this);
+ this.domObj.setStyle('position', this.options.position);
+ this.domObj.store('jxLayout', this);
- this.buttonSet = new Jx.ButtonSet({
- onChange: (function(set) {
- var button = set.activeButton;
- var l = button.options.label;
- if (l == ' ') {
- l = '';
+ if (this.options.resizeWithWindow || document.body == this.domObj.parentNode) {
+ window.addEvent('resize', this.windowResize.bindWithEvent(this));
+ window.addEvent('load', this.windowResize.bind(this));
+ //this.resize();
+ * Method: windowResize
+ * when the window is resized, any Jx.Layout controlled elements that are
+ * direct children of the BODY element are resized
+ windowResize: function() {
+ this.resize();
+ if (this.resizeTimer) {
+ $clear(this.resizeTimer);
+ this.resizeTimer = null;
+ this.resizeTimer = this.resize.delay(50, this);
+ * Method: resize
+ * resize the element controlled by this Jx.Layout object.
+ * Parameters:
+ * options - new options to apply, see <Jx.Layout.Options>
+ resize: function(options) {
+ /* this looks like a really big function but actually not
+ * much code gets executed in the two big if statements
+ var needsResize = false;
+ if (options) {
+ for (var i in options) {
+ //prevent forceResize: false from causing a resize
+ if (i == 'forceResize') {
+ continue;
- this.setLabel(l);
- var img = button.options.image;
- if (img.indexOf('a_pixel') != -1) {
- img = '';
+ if (this.options[i] != options[i]) {
+ needsResize = true;
+ this.options[i] = options[i];
- this.setImage(img);
- if (this.options.imageClass && this.domImg) {
- this.domImg.removeClass(this.options.imageClass);
- if (button.options.imageClass && this.domImg) {
- this.options.imageClass = button.options.imageClass;
- this.domImg.addClass(button.options.imageClass);
- this.fireEvent('change', this);
- }).bind(this)
- if (this.options.items) {
- this.add(this.options.items);
- var button = this;
- this.addEvent('click', function(e) {
- if (this.list.count() === 0) {
- return;
- if (!button.options.enabled) {
- return;
+ if (options.forceResize) {
- this.contentContainer.setStyle('visibility','hidden');
- this.contentContainer.setStyle('display','block');
- document.id(document.body).adopt(this.contentContainer);
- /* we have to size the container for IE to render the chrome correctly
- this.contentContainer.setContentBoxSize(this.subDomObj.getMarginBoxSize());
+ if (!document.id(this.domObj.parentNode)) {
+ return;
- this.showChrome(this.contentContainer);
+ var parentSize;
+ if (this.domObj.parentNode.tagName == 'BODY') {
+ parentSize = Jx.getPageDimensions();
+ } else {
+ parentSize = document.id(this.domObj.parentNode).getContentBoxSize();
- this.position(this.contentContainer, this.button.domObj, {
- horizontal: ['right right'],
+ if (this.lastParentSize && !needsResize) {
+ needsResize = (this.lastParentSize.width != parentSize.width ||
+ this.lastParentSize.height != parentSize.height);
+ } else {
+ this.lastParentSize = parentSize;
- this.contentContainer.setStyle('visibility','');
+ if (!needsResize) {
+ return;
+ var l, t, w, h;
- this.fireEvent('show', this);
- }.bindWithEvent(this.menu));
+ /* calculate left and width */
+ if (this.options.left != null) {
+ /* fixed left */
+ l = this.options.left;
+ if (this.options.right == null) {
+ /* variable right */
+ if (this.options.width == null) {
+ /* variable right and width
+ * set right to min, stretch width */
+ w = parentSize.width - l;
+ if (w < this.options.minWidth ) {
+ w = this.options.minWidth;
+ if (this.options.maxWidth >= 0 && w > this.options.maxWidth) {
+ w = this.options.maxWidth;
+ } else {
+ /* variable right, fixed width
+ * use width
+ w = this.options.width;
+ } else {
+ /* fixed right */
+ /* fixed right, variable width
+ * stretch width
+ w = parentSize.width - l - this.options.right;
+ if (w < this.options.minWidth) {
+ } else {
+ /* fixed right, fixed width
+ * respect left and width, allow right to stretch
- this.menu.addEvents({
- 'show': (function() {
- }).bind(this),
- 'hide': (function() {
- this.setActive(false);
- }).bind(this)
+ } else {
+ /* variable left, width and right
+ * set left, right to min, stretch width
+ l = 0;
+ w = parentSize.width;
+ l = l + parseInt(w - this.options.maxWidth,10)/2;
+ } else {
+ /* variable left, fixed width, variable right
+ * distribute space between left and right
+ l = parseInt((parentSize.width - w)/2,10);
+ if (l < 0) {
+ l = 0;
+ } else {
+ if (this.options.width != null) {
+ /* variable left, fixed width, fixed right
+ * left is calculated directly
+ l = parentSize.width - w - this.options.right;
+ if (l < 0) {
+ l = 0;
+ } else {
+ /* variable left and width, fixed right
+ * set left to min value and stretch width
+ l = 0;
+ w = parentSize.width - this.options.right;
+ l = w - this.options.maxWidth - this.options.right;
+ /* calculate the top and height */
+ if (this.options.top != null) {
+ /* fixed top */
+ t = this.options.top;
+ if (this.options.bottom == null) {
+ /* variable bottom */
+ if (this.options.height == null) {
+ /* variable bottom and height
+ * set bottom to min, stretch height */
+ h = parentSize.height - t;
+ if (h < this.options.minHeight) {
+ h = this.options.minHeight;
+ if (this.options.maxHeight >= 0 && h > this.options.maxHeight) {
+ h = this.options.maxHeight;
+ } else {
+ /* variable bottom, fixed height
+ * stretch height
+ h = this.options.height;
+ t = h - this.options.maxHeight;
+ } else {
+ /* fixed bottom */
+ /* fixed bottom, variable height
+ * stretch height
+ h = parentSize.height - t - this.options.bottom;
+ } else {
+ /* fixed bottom, fixed height
+ * respect top and height, allow bottom to stretch
+ } else {
+ /* variable top, height and bottom
+ * set top, bottom to min, stretch height
+ t = 0;
+ h = parentSize.height;
+ t = parseInt((parentSize.height - this.options.maxHeight)/2,10);
+ } else {
+ /* variable top, fixed height, variable bottom
+ * distribute space between top and bottom
+ t = parseInt((parentSize.height - h)/2,10);
+ if (t < 0) {
+ t = 0;
+ } else {
+ if (this.options.height != null) {
+ /* variable top, fixed height, fixed bottom
+ * top is calculated directly
+ t = parentSize.height - h - this.options.bottom;
+ if (t < 0) {
+ t = 0;
+ } else {
+ /* variable top and height, fixed bottom
+ * set top to min value and stretch height
+ t = 0;
+ h = parentSize.height - this.options.bottom;
+ t = parentSize.height - this.options.maxHeight - this.options.bottom;
- * Method: valueChanged
- * invoked when the current value is changed
- valueChanged: function() {
+ //TODO: check left, top, width, height against current styles
+ // and only apply changes if they are not the same.
- * Method: getValue
- * returns the currently selected value
- getValue: function() {
- return this.options.label;
- setValue: function(value) {
- this.buttonSet.buttons.each(function(button){
- if (button.options.label === value) {
- button.setActive(true);
+ /* apply the new sizes */
+ var sizeOpts = {width: w};
+ if (this.options.position == 'absolute') {
+ var m = document.id(this.domObj.parentNode).measure(function(){
+ return this.getSizes(['padding'],['left','top']).padding;
+ this.domObj.setStyles({
+ position: this.options.position,
+ left: l+m.left,
+ top: t+m.top
+ sizeOpts.height = h;
+ } else {
+ if (this.options.height) {
+ sizeOpts.height = this.options.height;
- },this);
+ this.domObj.setBorderBoxSize(sizeOpts);
- * Method: onKeyPress
- * Handle the user pressing a key by looking for an ENTER key to set the
- * value.
- * Parameters:
- * e - {Event} the keypress event
- onKeyPress: function(e) {
- if (e.key == 'enter') {
- this.valueChanged();
+ if (this.options.propagate) {
+ // propogate changes to children
+ var o = {forceResize: options ? options.forceResize : false};
+ $A(this.domObj.childNodes).each(function(child){
+ if (child.resize && child.getStyle('display') != 'none') {
+ child.resize.delay(0,child,o);
- * Method: add
- * add a new item to the pick list
- * Parameters:
- * options - {Object} object with properties suitable to be passed to
- * a <Jx.Menu.Item.Options> object. More than one options object can be
- * passed, comma separated or in an array.
- add: function() {
- $A(arguments).flatten().each(function(opt) {
- var button = new Jx.Menu.Item($merge(opt,{
- toggle: true
- this.menu.add(button);
- this.buttonSet.add(button);
- }, this);
- * Method: remove
- * Remove the item at the given index. Not implemented.
- * Parameters:
- * idx - {Integer} the item to remove.
- remove: function(idx) {
- //TODO: implement remove?
- * APIMethod: empty
- * remove all items from the combo
- empty: function() {
- this.menu.empty();
- this.buttonSet.empty();
- this.setLabel('');
- this.setImage(Jx.aPixel.src);
+ this.fireEvent('sizeChange',this);
-});// $Id: toolbar.js 801 2010-03-27 15:04:05Z pagameba $
+});// $Id: toolbar.js 857 2010-04-20 12:12:11Z pagameba $
* Class: Jx.Toolbar
@@ -23737,6 +23656,14 @@
* things it contains. Default is false.
autoSize: false,
+ * Option: align
+ * Determines whether the toolbar is aligned left, center, or right.
+ * Mutually exclusive with the scroll option. If scroll is set to true
+ * this option does nothing. Default: 'left', valid values: 'left',
+ * 'center', or 'right'
+ align: 'left',
/* Option: scroll
* if true, the toolbar may scroll if the contents are wider than
* the size of the toolbar
@@ -23791,6 +23718,7 @@
parent: parent,
autoSize: this.options.autoSize,
+ align: this.options.align,
scroll: this.options.scroll
@@ -23939,9 +23867,12 @@
// }).delay(1,this);
this.fireEvent('update');
+ this.update();
-// $Id: container.js 826 2010-03-31 18:46:16Z pagameba $
+// $Id: container.js 903 2010-05-12 19:31:17Z jonlb at comcast.net $
* Class: Jx.Toolbar.Container
@@ -23998,6 +23929,14 @@
* Default is true.
scroll: true,
+ * Option: align
+ * Mutually exclusive with the scroll option. This option overrides
+ * scroll if set to something other than the default. Default: 'left',
+ * valid values are 'left','center', or 'right'
+ align: 'left',
template: "<div class='jxBarContainer'><div class='jxBarControls'></div></div>",
scrollerTemplate: "<div class='jxBarScroller'><div class='jxBarWrapper'></div></div>"
@@ -24031,9 +23970,11 @@
this.domObj.addEvent('sizeChange', this.update);
- if (this.options.scroll) {
+ if (!['center', 'right'].contains(this.options.align) && this.options.scroll) {
this.processElements(this.options.scrollerTemplate, this.classes);
this.domObj.grab(this.scroller, 'top');
+ } else {
+ this.domObj.addClass('jxToolbarAlign' + this.options.align.capitalize());
/* this allows toolbars to add themselves to this bar container
@@ -24087,6 +24028,11 @@
+ * APIMethod: update
+ * Updates the scroller enablement dependent on the total size of the
+ * toolbar(s).
update: function() {
if (['top', 'bottom'].contains(this.options.position)) {
@@ -24172,7 +24118,7 @@
- * Method: add
+ * APIMethod: add
* Add a toolbar to the container.
* Parameters:
@@ -24202,6 +24148,13 @@
return this;
+ * Method: scroll
+ * Does the work of scrolling the toolbar to a specific position.
+ * Parameters:
+ * direction - whether to scroll left or right
scroll: function(direction) {
if (this.updating) {
return
@@ -24257,6 +24210,13 @@
+ * Method: afterTweenRight
+ * Updates pointers to buttons after the toolbar scrolls right
+ * Parameters:
+ * currentButton - the button that was currently first before the scroll
afterTweenRight: function(currentButton) {
var np = this.getNextButton(currentButton);
if (!np) {
@@ -24268,7 +24228,14 @@
this.update();
+ * Method: afterTweenLeft
+ * Updates pointers to buttons after the toolbar scrolls left
+ * Parameters:
+ * previousButton - the button that was to the left of the first visible
+ * button.
afterTweenLeft: function(previousButton) {
this.scroller.store('buttonPointer', previousButton);
var pp = this.getPreviousButton(previousButton);
@@ -24279,10 +24246,8 @@
this.update();
- * Method: remove
+ * APIMethod: remove
* remove an item from a toolbar. If the item is not in this toolbar
* nothing happens
@@ -24302,7 +24267,7 @@
this.update();
- * Method: scrollIntoView
+ * APIMethod: scrollIntoView
* scrolls an item in one of the toolbars into the currently visible
* area of the container if it is not already fully visible
@@ -24377,7 +24342,13 @@
+ * Method: getPreviousButton
+ * Finds the button to the left of the first visible button
+ * Parameters:
+ * currentButton - the first visible button
getPreviousButton: function(currentButton) {
pp = currentButton.getPrevious();
if (!$defined(pp)) {
@@ -24389,7 +24360,13 @@
return pp;
+ * Method: getNextButton
+ * Finds the button to the right of the first visible button
+ * Parameters:
getNextButton: function(currentButton) {
np = currentButton.getNext();
if (!np) {
@@ -24444,7 +24421,7 @@
this.domObj.adopt(el);
-});// $Id: panel.js 770 2010-03-18 21:12:28Z jonlb at comcast.net $
+});// $Id: panel.js 892 2010-05-06 21:06:26Z conrad.barthelmes $
* Class: Jx.Panel
@@ -24500,10 +24477,6 @@
maximizeClass: 'jxPanelMaximize',
closeClass: 'jxPanelClose',
- /* Option: id
- * String, an id to assign to the panel's container
- id: '',
/* Option: label
* String, the title of the Jx Panel
@@ -24570,7 +24543,7 @@
this.domImg.setStyle('backgroundImage', 'url('+this.options.image+')');
if (this.options.label && this.domLabel) {
var tbDiv = new Element('div');
@@ -24594,7 +24567,7 @@
this.colB = new Jx.Button({
template: this.options.controlButtonTemplate,
image: Jx.aPixel.src,
- tooltip: MooTools.lang.get('Jx','panel').collapseTooltip,
+ tooltip: {set:'Jx',key:'panel',value:'collapseTooltip'},
onClick: function() {
that.toggleCollapse();
@@ -24602,10 +24575,10 @@
this.colB.domObj.addClass(this.options.collapseClass);
this.addEvents({
collapse: function() {
- this.colB.setTooltip(MooTools.lang.get('Jx','panel').expandTooltip);
+ this.colB.setTooltip({set:'Jx',key:'panel',value:'expandTooltip'});
}.bind(this),
expand: function() {
- this.colB.setTooltip(MooTools.lang.get('Jx','panel').collapseTooltip);
+ this.colB.setTooltip({set:'Jx',key:'panel',value:'collapseTooltip'});
}.bind(this)
this.toolbar.add(this.colB);
@@ -24617,10 +24590,10 @@
var item = this.colM
this.addEvents({
- this.colM.setLabel(MooTools.lang.get('Jx','panel').expandLabel);
+ this.colM.setLabel({set:'Jx',key:'panel',value:'expandLabel'});
}.bind(this),
- this.colM.setLabel(MooTools.lang.get('Jx','panel').collapseLabel);
+ this.colM.setLabel({set:'Jx',key:'panel',value:'collapseLabel'});
}.bind(this)
this.menu.add(item);
@@ -24631,7 +24604,7 @@
this.maxB = new Jx.Button({
- tooltip: MooTools.lang.get('Jx','panel').maximizeTooltip,
+ tooltip: {set:'Jx',key:'panel',value:'maximizeTooltip'},
that.maximize();
@@ -24639,10 +24612,10 @@
this.maxB.domObj.addClass(this.options.maximizeClass);
this.addEvents({
maximize: function() {
- this.maxB.setTooltip(MooTools.lang.get('Jx','panel').restoreTooltip);
+ this.maxB.setTooltip({set:'Jx',key:'panel',value:'restoreTooltip'});
}.bind(this),
restore: function() {
- this.maxB.setTooltip(MooTools.lang.get('Jx','panel').maximizeTooltip);
+ this.maxB.setTooltip({set:'Jx',key:'panel',value:'maximizeTooltip'});
}.bind(this)
this.toolbar.add(this.maxB);
@@ -24654,10 +24627,10 @@
this.addEvents({
- this.maxM.setLabel(MooTools.lang.get('Jx','panel').restoreLabel);
+ this.maxM.setLabel({set:'Jx',key:'panel',value:'maximizeLabel'});
}.bind(this),
- this.maxM.setLabel(MooTools.lang.get('Jx','panel').maximizeLabel);
+ this.maxM.setLabel({set:'Jx',key:'panel',value:'restoreLabel'});
}.bind(this)
this.menu.add(this.maxM);
@@ -24668,7 +24641,7 @@
this.closeB = new Jx.Button({
- tooltip: MooTools.lang.get('Jx','panel').closeTooltip,
+ tooltip: {set:'Jx',key:'panel',value:'closeTooltip'},
that.close();
@@ -24677,7 +24650,7 @@
this.toolbar.add(this.closeB);
if (this.menu) {
this.closeM = new Jx.Menu.Item({
- label: MooTools.lang.get('Jx','panel').closeLabel,
+ label: {set:'Jx',key:'panel',value:'closeLabel'},
that.close();
@@ -24837,7 +24810,7 @@
* s - {String} the new label
setLabel: function(s) {
- this.domLabel.set('html',s);
+ this.domLabel.set('html',this.getText(s));
* Method: getLabel
@@ -24970,27 +24943,32 @@
changeText: function (lang) {
this.parent(); //TODO: change this class so that we can access these properties without too much voodoo...
if($defined(this.closeB)) {
- this.closeB.setTooltip(MooTools.lang.get('Jx','panel').closeTooltip);
+ this.closeB.setTooltip({set:'Jx',key:'panel',value:'closeTooltip'});
if ($defined(this.closeM)) {
- this.closeM.setLabel(MooTools.lang.get('Jx','panel').closeLabel);
+ this.closeM.setLabel({set:'Jx',key:'panel',value:'closeLabel'});
if ($defined(this.maxB)) {
if ($defined(this.colB)) {
if ($defined(this.colM)) {
if (this.options.closed == true) {
} else {
+ if (this.options.label && this.domLabel) {
+ // TODO: is this the right method to call?
+ // if toolbars left/right are used and localized, they may change their size..
+ this.layoutContent();
-});// $Id: dialog.js 816 2010-03-30 11:57:09Z pagameba $
+});// $Id: dialog.js 894 2010-05-07 09:10:29Z conrad.barthelmes $
* Class: Jx.Dialog
@@ -25090,11 +25068,6 @@
* (optional) {String} the title of the dialog box.
label: '',
- /* Option: id
- * (optional) {String} an HTML ID to assign to the dialog, primarily
- * used for applying CSS styles to specific dialogs
- id: '',
/* Option: parent
* (optional) {HTMLElement} a reference to an HTML element that
* the dialog is to be contained by. The default value is for the dialog
@@ -25117,6 +25090,39 @@
* closeable by the user or not. Default is true.
close: true,
+ * Option: useKeyboard
+ * (optional) {Boolean} determines whether the Dialog listens to keyboard events globally
+ * Default is false
+ useKeyboard : false,
+ * Option: keys
+ * (optional) {Object} refers with the syntax for MooTools Keyboard Class
+ * to functions. Set key to false to disable it manually
+ keys: {
+ 'esc' : 'close'
+ * Option: keyboardMethods
+ * can be used to overwrite existing keyboard methods that are used inside
+ * this.options.keys - also possible to add new ones.
+ * Functions are bound to the dialog when using 'this'
+ * example:
+ * keys : {
+ * 'alt+enter' : 'maximizeDialog'
+ * keyboardMethods: {
+ * 'maximizeDialog' : function(ev){
+ * ev.preventDefault();
+ * this.maximize();
+ keyboardMethods : {},
collapsedClass: 'jxDialogMin',
collapseClass: 'jxDialogCollapse',
menuClass: 'jxDialogMenu',
@@ -25135,6 +25141,11 @@
content: 'jxDialogContent'
+ * MooTools Keyboard class for Events (mostly used in Dialog.Confirm, Prompt or Message)
+ * But also optional here with esc to close
+ keyboard : null,
* APIMethod: render
* renders Jx.Dialog
@@ -25195,7 +25206,7 @@
if (this.options.resize && typeof Drag != 'undefined') {
this.resizeHandle = new Element('div', {
'class':'jxDialogResize',
- title: MooTools.lang.get('Jx','panel').resizeTooltip,
+ title: this.getText({set:'Jx',key:'panel',value:'resizeTooltip'}),
styles: {
'display':this.options.closed?'none':'block'
@@ -25240,6 +25251,9 @@
this.domObj.addEvent('mousedown', (function(){
this.stack();
}).bind(this));
+ // initialize keyboard class
+ this.initializeKeyboard();
@@ -25449,7 +25463,9 @@
Jx.Stack.unstack(this.options.parent.get('mask').element);
this.options.parent.unmask();
+ if(this.options.useKeyboard && this.keyboard != null) {
+ this.keyboard.deactivate();
* Method: openURL
@@ -25489,6 +25505,9 @@
} else {
this.addEvent('contentLoaded', this.openOnLoaded);
+ this.keyboard.activate();
* Method: close
@@ -25512,22 +25531,65 @@
return !((this.domObj.getStyle('display') === 'none') || (this.domObj.getStyle('visibility') === 'hidden'));
- createText: function (lang) {
+ changeText: function (lang) {
this.parent();
if ($defined(this.maxM)) {
if (this.maximize) {
+ this.maxM.setLabel(this.getText({set:'Jx',key:'panel',value:'restoreLabel'}));
} else {
+ this.maxM.setLabel(this.getText({set:'Jx',key:'panel',value:'maximizeLabel'}));
if ($defined(this.resizeHandle)) {
- this.resizeHandle.set('title', MooTools.lang.get('Jx','dialog').resizeTooltip);
+ this.resizeHandle.set('title', this.getText({set:'Jx',key:'dialog',value:'resizeTooltip'}));
+ this.toggleCollapse(false);
+ initializeKeyboard: function() {
+ if(this.options.useKeyboard) {
+ var self = this;
+ this.keyboardEvents = {};
+ this.keyboardMethods = {
+ close : function(ev) {ev.preventDefault();self.close()}
+ this.keyboard = new Keyboard({
+ events: this.getKeyboardEvents()
+ * Method: getKeyboardMethods
+ * used by this and all child classes to have methods listen to keyboard events,
+ * returned object will be parsed to the events object of a MooTools Keyboard instance
+ * @return Object
+ getKeyboardEvents : function() {
+ var self = this;
+ for(var i in this.options.keys) {
+ // only add a reference once, otherwise keyboard events will be fired twice in subclasses
+ if(!$defined(this.keyboardEvents[i])) {
+ if($defined(this.keyboardMethods[this.options.keys[i]])) {
+ this.keyboardEvents[i] = this.keyboardMethods[this.options.keys[i]];
+ }else if($defined(this.options.keyboardMethods[this.options.keys[i]])){
+ this.keyboardEvents[i] = this.options.keyboardMethods[this.options.keys[i]].bind(self);
+ }else if(Jx.type(this.options.keys[i]) == 'function') {
+ this.keyboardEvents[i] = this.options.keys[i].bind(self);
+ }else{
+ // allow disabling of special keys by setting them to false or null with having a warning
+ if(this.options.keyboardMethods[this.options.keys[i]] != false) {
+ $defined(console) ? console.warn("keyboard method %o not defined for %o", this.options.keys[i], this) : false;
+ return this.keyboardEvents;
-// $Id: splitter.js 826 2010-03-31 18:46:16Z pagameba $
+// $Id: splitter.js 892 2010-05-06 21:06:26Z conrad.barthelmes $
* Class: Jx.Splitter
@@ -25774,7 +25836,7 @@
prepareBar: function() {
var o = new Element('div', {
'class': 'jxSplitBar'+this.options.layout.capitalize(),
- 'title': MooTools.lang.get('Jx','panel').barTooltip
+ 'title': this.getText({set:'Jx',key:'splitter',value:'barToolTip'})
return o;
@@ -26269,14 +26331,13 @@
this.parent();
this.bars.each(function(bar){
- document.id(bar).set('title', MooTools.lang.get('Jx','splitter').title);
- },this);
+ document.id(bar).set('title', this.getText({set:'Jx',key:'splitter',value:'barToolTip'}));
+ },this);
-});// $Id: panelset.js 770 2010-03-18 21:12:28Z jonlb at comcast.net $
+});// $Id: panelset.js 895 2010-05-07 19:05:19Z conrad.barthelmes $
* Class: Jx.PanelSet
@@ -26374,7 +26435,7 @@
prepareBar: (function(i) {
var bar = new Element('div', {
'class': 'jxPanelBar',
- 'title': MooTools.lang.get('Jx','panelset').barTooltip
+ 'title': this.getText({set:'Jx',key:'panelset',value:'barToolTip'})
var panel = this.panels[i];
@@ -26510,7 +26571,7 @@
this.parent();
//barTooltip is handled by the splitter's createText() function
-});// $Id: message.js 826 2010-03-31 18:46:16Z pagameba $
+});// $Id: message.js 892 2010-05-06 21:06:26Z conrad.barthelmes $
* Class: Jx.Dialog.Message
@@ -26561,7 +26622,11 @@
* Option: collapse
* by default, message dialogs are not collapsible
- collapse: false
+ collapse: false,
+ useKeyboard : true,
+ keys : {
+ 'enter' : 'ok'
* Method: render
@@ -26571,22 +26636,38 @@
//create content to be added
this.buttons = new Jx.Toolbar({position: 'bottom',scroll:false});
this.ok = new Jx.Button({
- label: MooTools.lang.get('Jx','message').okButton,
+ label: this.getText({set:'Jx',key:'message',value:'okButton'}),
onClick: this.onOk
this.buttons.add(this.ok);
this.options.toolbars = [this.buttons];
- if (Jx.type(this.options.message) === 'string') {
+ var type = Jx.type(this.options.message);
+ if (type === 'string' || type == 'object' || type == 'element') {
this.question = new Element('div', {
- 'class': 'jxMessage',
- html: this.options.message
+ 'class': 'jxMessage'
+ switch(type) {
+ case 'string':
+ case 'object':
+ this.question.set('html', this.getText(this.options.message));
+ break;
+ case 'element':
+ this.options.message.inject(this.question);
+ break;
} else {
this.question = this.options.question;
document.id(this.question).addClass('jxMessage');
this.options.content = this.question;
+ var self = this;
+ this.options.keyboardMethods.ok = function(ev) { ev.preventDefault(); self.close(); }
this.parent();
+ this.keyboard.addEvents(this.getKeyboardEvents());
* Method: onOk
@@ -26607,7 +26688,7 @@
setMessage: function(message) {
this.options.message = message;
if ($defined(this.question)) {
- this.question.set('html',message);
+ this.question.set('html',this.getText(message));
@@ -26615,14 +26696,17 @@
* Method: createText
* handle change in language
this.parent();
if ($defined(this.ok)) {
- this.ok.setLabel(MooTools.lang.get('Jx','message').okButton);
+ this.ok.setLabel({set:'Jx',key:'message',value:'okButton'});
+ if(Jx.type(this.options.message) === 'object') {
-// $Id: confirm.js 826 2010-03-31 18:46:16Z pagameba $
+// $Id: confirm.js 895 2010-05-07 19:05:19Z conrad.barthelmes $
* Class: Jx.Dialog.Confirm
@@ -26653,6 +26737,11 @@
* Jx.Dialog option defaults
+ keys : {
+ 'esc' : 'cancel',
+ 'enter' : 'ok'
width: 300,
height: 150,
close: false,
@@ -26660,6 +26749,10 @@
collapse: false
+ * Reference to MooTools keyboards Class for handling keypress events like Enter or ESC
+ keyboard : null,
* APIMethod: render
* creates the dialog
@@ -26667,28 +26760,49 @@
//turn scrolling off as confirm only has 2 buttons.
this.buttons = new Jx.Toolbar({position: 'bottom',scroll: false});
+ // COMMENT: returning boolean would be more what people expect instead of a localized label of a button?
- label: MooTools.lang.get('Jx','confirm').affirmitiveLabel,
- onClick: this.onClick.bind(this, MooTools.lang.get('Jx','confirm').affirmitiveLabel)
+ label: this.getText({set:'Jx',key:'confirm',value:'affirmativeLabel'}),
+ onClick: this.onClick.bind(this, true)
this.cancel = new Jx.Button({
- label: MooTools.lang.get('Jx','confirm').negativeLabel,
- onClick: this.onClick.bind(this, MooTools.lang.get('Jx','confirm').negativeLabel)
+ label: this.getText({set:'Jx',key:'confirm',value:'negativeLabel'}),
+ onClick: this.onClick.bind(this, false)
this.buttons.add(this.ok, this.cancel);
- if (Jx.type(this.options.question) === 'string') {
+ var type = Jx.type(this.options.question);
+ if (type === 'string' || type === 'object' || type == 'element'){
- 'class': 'jxConfirmQuestion',
- html: this.options.question
+ 'class': 'jxConfirmQuestion'
+ switch(type) {
+ case 'string':
+ case 'object':
+ this.question.set('html', this.getText(this.options.question));
+ break;
+ case 'element':
+ this.options.question.inject(this.question);
+ break;
} else {
document.id(this.question).addClass('jxConfirmQuestion');
+ // add default key functions
+ var self = this;
+ this.options.keyboardMethods.ok = function(ev) { ev.preventDefault(); self.onClick(true); }
+ this.options.keyboardMethods.cancel = function(ev) { ev.preventDefault(); self.onClick(false); }
this.parent();
+ // add new ones
* Method: onClick
@@ -26701,19 +26815,20 @@
this.fireEvent('close', [this, value]);
this.parent();
- this.ok.setLabel(MooTools.lang.get('Jx','confirm').affirmitiveLabel);
+ this.ok.setLabel({set:'Jx',key:'confirm',value:'affirmativeLabel'});
if ($defined(this.cancel)) {
- this.cancel.setLabel(MooTools.lang.get('Jx','confirm').negativeLabel);
+ this.cancel.setLabel({set:'Jx',key:'confirm',value:'negativeLabel'});
+ if(Jx.type(this.options.question) === 'object') {
-});// $Id: tooltip.js 776 2010-03-22 14:35:16Z pagameba $
+});// $Id: tooltip.js 835 2010-04-07 22:59:37Z conrad.barthelmes $
* Class: Jx.Tooltip
@@ -26796,8 +26911,8 @@
}).inject(document.body);
- if (Jx.type(this.options.tip) === 'string') {
- this.domObj.set('html', this.options.tip);
+ if (Jx.type(this.options.tip) === 'string' || Jx.type(this.options.tip) == 'object') {
+ this.domObj.set('html', this.getText(this.options.tip));
} else {
this.domObj.grab(this.options.tip);
@@ -26891,15 +27006,417 @@
this.destroy();
-// $Id: field.js 823 2010-03-31 12:18:00Z pagameba $
+// $Id: fieldset.js 867 2010-04-23 15:54:04Z conrad.barthelmes $
+ * Class: Jx.Fieldset
+ * Extends: <Jx.Widget>
+ * This class represents a fieldset. It can be used to group fields together.
+ * Example:
+ * (code)
+ * (end)
+ * License:
+ * Copyright (c) 2009, Jon Bomgardner.
+ * This file is licensed under an MIT style license
+Jx.Fieldset = new Class({
+ Family: 'Jx.Fieldset',
+ Extends : Jx.Widget,
+ options : {
+ * Option: legend
+ * The text for the legend of a fieldset. Default is null
+ * or no legend.
+ legend : null,
+ * Option: id
+ * The id to assign to this element
+ id : null,
+ * Option: fieldsetClass
+ * A CSS class to assign to the fieldset. Useful for custom styling of
+ * the element
+ fieldsetClass : null,
+ * Option: legendClass
+ * A CSS class to assign to the legend. Useful for custom styling of
+ * the element
+ legendClass : null,
+ * Option: template
+ * a template for how this element should be rendered
+ template : '<fieldset class="jxFieldset"><legend><span class="jxFieldsetLegend"></span></legend></fieldset>',
+ * Option: form
+ * The <Jx.Form> that this fieldset should be added to
+ form : null
+ classes: new Hash({
+ domObj: 'jxFieldset',
+ legend: 'jxFieldsetLegend'
+ * Property: legend
+ * a holder for the legend Element
+ legend : null,
+ * APIMethod: render
+ * Creates a fieldset.
+ render : function () {
+ this.parent();
+ this.id = this.options.id;
+ if ($defined(this.options.form)
+ && this.options.form instanceof Jx.Form) {
+ this.form = this.options.form;
+ //FIELDSET
+ if (this.domObj) {
+ if ($defined(this.options.id)) {
+ this.domObj.set('id', this.options.id);
+ if ($defined(this.options.fieldsetClass)) {
+ this.domObj.addClass(this.options.fieldsetClass);
+ if (this.legend) {
+ if ($defined(this.options.legend)) {
+ this.legend.set('html', this.getText(this.options.legend));
+ if ($defined(this.options.legendClass)) {
+ this.legend.addClass(this.options.legendClass);
+ } else {
+ this.legend.destroy();
+ * APIMethod: add
+ * Adds fields to this fieldset
+ * Parameters:
+ * pass as many fields to this method as you like. They should be
+ * <Jx.Field> objects
+ add : function () {
+ var field;
+ for (var x = 0; x < arguments.length; x++) {
+ field = arguments[x];
+ //add form to the field and field to the form if not already there
+ if ($defined(field.jxFamily) && !$defined(field.form) && $defined(this.form)) {
+ field.form = this.form;
+ this.form.addField(field);
+ this.domObj.grab(field);
+ return this;
+ * APIMethod: addTo
+ addTo: function(what) {
+ if (what instanceof Jx.Form) {
+ this.form = what;
+ } else if (what instanceof Jx.Fieldset) {
+ this.form = what.form;
+ return this.parent(what);
+// $Id: form.js 901 2010-05-10 19:33:28Z jonlb at comcast.net $
+ * Class: Jx.Form
+ * A class that represents an HTML form. You add fields using either
+ * Jx.Form.add() or by using the field's .addTo() method. You can get all form
+ * values or set them using this class. It also handles validation of fields
+ * through the use of a plugin (Jx.Plugin.Form.Validator).
+ * Example:
+ * (code)
+ * (end)
+ * License:
+Jx.Form = new Class({
+ Family: 'Jx.Form',
+ Extends: Jx.Widget,
+ options: {
+ * Option: method
+ * the method used to submit the form
+ method: 'post',
+ * Option: action
+ * where to submit it to
+ action: '',
+ * Option: fileUpload
+ * whether this form handles file uploads or not.
+ fileUpload: false,
+ * Option: formClass
+ formClass: null,
+ * Option: name
+ * the name property for the form
+ name: '',
+ * Option: acceptCharset
+ * the character encoding to be used. Defaults to utf-8.
+ acceptCharset: 'utf-8',
+ template: '<form class="jxForm"></form>'
+ * Property: defaultAction
+ * the default field to activate if the user hits the enter key in this
+ * form. Set by specifying default: true as an option to a field. Will
+ * only work if the default is a Jx button field or an input of a type
+ * that is a button
+ defaultAction: null,
+ * Property: fields
+ * An array of all of the single fields (not contained in a fieldset) for
+ * this form
+ fields : null,
+ * Property: pluginNamespace
+ * required variable for plugins
+ pluginNamespace: 'Form',
+ classes: $H({
+ domObj: 'jxForm'
+ this.parent();
+ this.fields = new Hash();
+ * Constructs the form but does not add it to anything to be shown. The
+ * caller should use form.addTo() to add the form to the DOM.
+ this.parent();
+ //create the form first
+ this.domObj.set({
+ 'method' : this.options.method,
+ 'action' : this.options.action,
+ 'name' : this.options.name,
+ 'accept-charset': this.options.acceptCharset,
+ events: {
+ keypress: function(e) {
+ if (e.key == 'enter' &&
+ e.target.tagName != "TEXTAREA" &&
+ this.defaultAction &&
+ this.defaultAction.click) {
+ document.id(this.defaultAction).focus();
+ this.defaultAction.click();
+ e.stop();
+ }.bind(this)
+ if (this.options.fileUpload) {
+ this.domObj.set('enctype', 'multipart/form-data');
+ if ($defined(this.options.formClass)) {
+ this.domObj.addClass(this.options.formClass);
+ * APIMethod: addField
+ * Adds a <Jx.Field> subclass to this form's fields hash
+ * Parameters:
+ * field - <Jx.Field> to add
+ addField : function (field) {
+ this.fields.set(field.id, field);
+ if (field.options.defaultAction) {
+ this.defaultAction = field;
+ * Method: isValid
+ * Determines if the form passes validation
+ * Parameters:
+ * evt - the MooTools event object
+ isValid : function (evt) {
+ return true;
+ * APIMethod: getValues
+ * Gets the values of all the fields in the form as a Hash object. This
+ * uses the mootools function Element.toQueryString to get the values and
+ * will either return the values as a querystring or as an object (using
+ * mootools-more's String.parseQueryString method).
+ * Parameters:
+ * asQueryString - {boolean} indicates whether to return the value as a
+ * query string or an object.
+ getValues : function (asQueryString) {
+ var queryString = this.domObj.toQueryString();
+ if ($defined(asQueryString) && asQueryString) {
+ return queryString;
+ } else {
+ return queryString.parseQueryString();
+ * APIMethod: setValues
+ * Used to set values on the form
+ * Parameters:
+ * values - A Hash of values to set keyed by field name.
+ setValues : function (values) {
+ if (Jx.type(values) === 'object') {
+ values = new Hash(values);
+ this.fields.each(function (item) {
+ item.setValue(values.get(item.name));
+ }, this);
+ * APIMethod: add
+ * Parameters:
+ * Pass as many parameters as you like. However, they should all be
+ * <Jx.Field> objects.
+ var field;
+ if (field instanceof Jx.Field && !$defined(field.form)) {
+ field.form = this;
+ this.addField(field);
+ } else if (field instanceof Jx.Fieldset && !$defined(field.form)) {
+ return this;
+ * APIMethod: reset
+ * Resets all fields back to their original value
+ reset : function () {
+ this.fields.each(function (field, name) {
+ field.reset();
+ }, this);
+ this.fireEvent('reset',this);
+ * APIMethod: getFieldsByName
+ * Allows retrieving a field from a form by the name of the field (NOT the
+ * ID).
+ * Parameters:
+ * name - {string} the name of the field to find
+ getFieldsByName: function (name) {
+ var fields = [];
+ this.fields.each(function(val, id){
+ if (val.name === name) {
+ fields.push(val);
+ },this);
+ return fields;
+ * Returns a Jx.Field object by its ID.
+ * Parameters:
+ * id - {string} the id of the field to find.
+ getField: function (id) {
+ if (this.fields.has(id)) {
+ return this.fields.get(id);
+ return null;
+ * APIMethod: setBusy
+ * Sets the busy state of the Form and all of it's fields.
+ * Parameters:
+ * state - {boolean} indicated whether the form is busy or not.
+ setBusy: function(state) {
+ if (this.busy == state) {
+ return;
+ this.parent(state);
+ this.fields.each(function(field) {
+ field.setBusy(state, true);
+// $Id: field.js 901 2010-05-10 19:33:28Z jonlb at comcast.net $
* Class: Jx.Field
* This class is the base class for all form fields.
- * The class will also allow for displaying error messages generated by
- * form validation.
* Example:
@@ -26918,6 +27435,7 @@
Family: 'Jx.Field',
pluginNamespace: 'Field',
+ Binds: ['changeText'],
options : {
@@ -26988,7 +27506,9 @@
* Option: required
* Whether the field is required. Setting this to true will trigger
* the addition of a "required" validator class and the form
- * will not submit until it is filled in and validates.
+ * will not submit until it is filled in and validates provided
+ * that the plugin Jx.Plugin.Field.Validator has been added to this
+ * field.
required : false,
@@ -27090,27 +27610,7 @@
- // LABEL
- if (this.label) {
- if ($defined(this.options.labelClass)) {
- this.label.addClass(this.options.labelClass);
- if ($defined(this.options.label)) {
- this.label.set('html', this.options.label
- + this.options.labelSeparator);
- this.label.set('for', this.id);
- if (this.options.required) {
- this.requiredText = new Element('em', {
- 'html' : MooTools.lang.get('Jx','field').requiredText,
- 'class' : 'required'
- this.requiredText.inject(this.label);
// FIELD
if (this.field) {
if ($defined(this.options.fieldClass)) {
@@ -27143,8 +27643,37 @@
this.field.store('field', this);
+ // add click event to label to set the focus to the field
+ // COMMENT: tried it without a function using addEvent('click', this.field.focus.bind(this)) but crashed in IE
+ if(this.label) {
+ this.label.addEvent('click', function() {
+ this.field.focus();
+ }.bind(this));
+ // LABEL
+ if (this.label) {
+ if ($defined(this.options.labelClass)) {
+ this.label.addClass(this.options.labelClass);
+ if ($defined(this.options.label)) {
+ this.label.set('html', this.getText(this.options.label)
+ + this.options.labelSeparator);
+ this.label.set('for', this.id);
+ if (this.options.required) {
+ this.requiredText = new Element('em', {
+ 'html' : this.getText({set:'Jx',key:'field',value:'requiredText'}),
+ 'class' : 'required'
+ this.requiredText.inject(this.label);
// TAG
if (this.tag) {
if ($defined(this.options.tagClass)) {
@@ -27189,7 +27718,7 @@
* original options
- this.field.set('value', this.options.value);
+ this.setValue(this.options.value);
this.fireEvent('reset', this);
@@ -27211,13 +27740,19 @@
* APIMethod: addTo
+ * Overrides default Jx.Widget AddTo() so that we can call .add() if
+ * adding to a Jx.Form or Jx.Fieldset object.
+ * Parameters:
+ * what - the element or object to add this field to.
+ * where - where in the object to place it. Not valid if adding to Jx.Form
+ * or Jx.Fieldset.
- addTo: function(what) {
+ addTo: function(what, where) {
if (what instanceof Jx.Fieldset || what instanceof Jx.Form) {
what.add(this);
} else {
- this.parent(what);
+ this.parent(what, where);
return this;
@@ -27232,11 +27767,21 @@
* translations changed.
- this.parent();
- if ($defined(this.requiredText)) {
- this.requiredText.set('html',MooTools.lang.get('Jx','field').requiredText);
+ this.parent();
+ if ($defined(this.options.label) && this.label) {
+ this.label.set('html', this.getText(this.options.label) + this.options.labelSeparator);
+ if(this.options.required) {
+ if ($defined(this.requiredText)) {
+ this.requiredText.set('html',this.getText({set:'Jx',key:'field',value:'requiredText'}));
onFocus: function() {
this.fireEvent('focus', this);
@@ -27315,7 +27860,7 @@
-});// $Id: prompt.js 785 2010-03-25 19:19:21Z jonlb at comcast.net $
+});// $Id: prompt.js 892 2010-05-06 21:06:26Z conrad.barthelmes $
* Class: Jx.Dialog.Prompt
@@ -27345,17 +27890,37 @@
prompt: '',
* Option: startingValue
- * The startingvalue to place in the text box
+ * The startingvalue to place in the input field
startingValue: '',
+ * Option: fieldOptions,
+ * Object with various
+ fieldOptions: {
+ type : 'Text',
+ options: {},
+ validate : true,
+ validatorOptions: {
+ validators: ['required'],
+ validateOnBlur: true,
+ validateOnChange : false
+ showErrorMsg : true
width: 400,
height: 200,
close: true,
resize: true,
- collapse: false
+ collapse: false,
+ keys : {
+ 'esc' : 'cancel',
+ 'enter' : 'ok'
* APIMethod: render
@@ -27365,47 +27930,84 @@
- label: MooTools.lang.get('Jx','prompt').okButton,
- onClick: this.onClick.bind(this, 'Ok')
+ label: this.getText({set:'Jx',key:'prompt',value:'okButton'}),
- label: MooTools.lang.get('Jx','prompt').cancelButton,
- onClick: this.onClick.bind(this,'Cancel')
+ label: this.getText({set:'Jx',key:'prompt',value:'cancelButton'}),
+ var fOpts = this.options.fieldOptions;
+ fOpts.options.label = this.getText(this.options.prompt);
+ fOpts.options.value = this.options.startingValue;
+ fOpts.options.containerClass = 'jxPrompt';
+ if(Jx.type(fOpts.type) === 'string' && $defined(Jx.Field[fOpts.type.capitalize()])) {
+ this.field = new Jx.Field[fOpts.type.capitalize()](fOpts.options);
+ }else if(Jx.type(fOpts.type) === 'Jx.Object'){
+ this.field = fOpts.type;
+ }else{
+ // warning and fallback?
+ window.console ? console.warn("Field type does not exist %o, using Jx.Field.Text", fOpts.type) : false;
+ this.field = new Jx.Field.Text(fOpts.options);
+ if(this.options.fieldOptions.validate) {
+ this.validator = new Jx.Plugin.Field.Validator(this.options.fieldOptions.validatorOptions);
+ this.validator.attach(this.field);
+ this.options.content = document.id(this.field);
- this.field = new Jx.Field.Text({
- label: this.options.prompt,
- value: this.options.startingValue,
- containerClass: 'jxPrompt'
- this.options.content = document.id(this.field);
+ var self = this;
this.parent();
* Method: onClick
* Called when the OK button is clicked. Closes the dialog.
onClick: function (value) {
- this.isOpening = false;
- this.hide();
- this.fireEvent('close', [this, value, this.field.getValue()]);
+ if(value && $defined(this.validator)) {
+ if(this.validator.isValid()) {
+ this.isOpening = false;
+ this.hide();
+ this.fireEvent('close', [this, value, this.field.getValue()]);
+ }else{
+ //this.options.content.adopt(this.validator.getError());
+ this.field.field.focus.delay(50, this.field.field);
+ //todo: show error messages ?
+ }else{
+ this.hide();
this.parent();
- this.ok.setLabel(MooTools.lang.get('Jx','prompt').okButton);
+ this.ok.setLabel({set:'Jx',key:'prompt',value:'okButton'});
- this.cancel.setLabel(MooTools.lang.get('Jx','prompt').cancelButton);
+ this.cancel.setLabel({set:'Jx',key:'prompt',value:'cancelButton'});
+ this.field.label.set('html', this.getText(this.options.prompt));
-// $Id: dataview.js 686 2010-02-01 05:45:28Z jonlb at comcast.net $
+// $Id: dataview.js 902 2010-05-12 17:27:42Z jonlb at comcast.net $
* Class: Jx.Panel.DataView
@@ -27506,9 +28108,9 @@
this.bound.update = this.update.bind(this);
//listen for data updates
- this.options.data.addEvent('loadFinished', this.bound.update);
- this.options.data.addEvent('sortFinished', this.bound.update);
- this.options.data.addEvent('loadError', this.bound.update);
+ this.options.data.addEvent('storeDataLoaded', this.bound.update);
+ this.options.data.addEvent('storeSortFinished', this.bound.update);
+ this.options.data.addEvent('storeDataLoadFailed', this.bound.update);
if (this.options.data.loaded) {
this.update();
@@ -27837,290 +28439,165 @@
-// $Id: hidden.js 649 2009-11-30 22:19:48Z pagameba $
+// $Id: listitem.js 649 2009-11-30 22:19:48Z pagameba $
- * Class: Jx.Field.Hidden
+ * Class: Jx.ListItem
- * Extends: <Jx.Field>
- * This class represents a hidden input field.
+ * Events:
- * Example:
- * (code)
- * (end)
* License:
- * Copyright (c) 2009, Jon Bomgardner.
+ * Copyright (c) 2009, DM Solutions Group.
-Jx.Field.Hidden = new Class({
+Jx.ListItem = new Class({
+ Family: 'Jx.ListItem',
- Extends: Jx.Field,
options: {
- * Option: template
- * The template used to render this field
- template: '<span class="jxInputContainer"><input class="jxInputHidden" type="hidden" name="{name}"/></span>'
+ enabled: true,
+ template: '<li class="jxListItemContainer jxListItem"></li>'
+ domObj: 'jxListItemContainer',
+ domContent: 'jxListItem'
- * Property: type
- * The type of this field
- type: 'Hidden'
+ render: function () {
+ this.parent();
+ this.domContent.store('jxListItem', this);
+ this.domObj.store('jxListTarget', this.domContent);
+ this.loadContent(this.domContent);
+ enable: function(state) {
-// $Id: form.js 823 2010-03-31 12:18:00Z pagameba $
+});// $Id: listview.js 898 2010-05-10 04:08:44Z jonlb at comcast.net $
- * Class: Jx.Form
+ * Class: Jx.ListView
- * A class that represents an HTML form. You add fields using either Jx.Form.add()
- * or by using the field's .addTo() method. You can get all form values or set them
- * using this class. It also handles validation of fields.
+ * Events:
- * Example:
- * (code)
- * (end)
* License:
-Jx.Form = new Class({
- Family: 'Jx.Form',
+Jx.ListView = new Class({
+ Family: 'Jx.Widget',
Extends: Jx.Widget,
+ pluginNamespace: 'ListView',
options: {
+ template: '<ul class="jxListView jxList"></ul>',
- * Option: method
- * the method used to submit the form
+ * Option: listOptions
+ * control the behaviour of the list, see <Jx.List>
- method: 'post',
- * Option: action
- * where to submit it to
- action: '',
- * Option: fileUpload
- * whether this form handles file uploads or not.
- fileUpload: false,
- * Option: id
- * the id of this form
- id: null,
- * Option: formClass
- formClass: null,
- * Option: name
- * the name property for the form
- name: '',
- * Option: acceptCharset
- * the character encoding to be used. Defaults to utf-8.
- acceptCharset: 'utf-8'
+ listOptions: {
+ hover: true,
+ press: true,
+ select: true
- * Property: defaultAction
- * the default field to activate if the user hits the enter key in this
- * form. Set by specifying default: true as an option to a field. Will
- * only work if the default is a Jx button field or an input of a type
- * that is a button
- defaultAction: null,
+ domObj: 'jxListView',
+ listObj: 'jxList'
- * Property: fields
- * An array of all of the single fields (not contained in a fieldset) for this form
- fields : null,
- * Property: pluginNamespace
- * required variable for plugins
- pluginNamespace: 'Form',
- init: function() {
- this.parent();
- this.fields = new Hash();
* APIMethod: render
- * Constructs the form but does not add it to anything to be shown. The caller
- * should use form.addTo() to add the form to the DOM.
- render : function () {
- //create the form first
- this.domObj = new Element('form', {
- 'method' : this.options.method,
- 'action' : this.options.action,
- 'class' : 'jxForm',
- 'name' : this.options.name,
- 'accept-charset': this.options.acceptCharset,
- events: {
- keypress: function(e) {
- if (e.key == 'enter' &&
- e.target.tagName != "TEXTAREA" &&
- this.defaultAction &&
- this.defaultAction.click) {
- document.id(this.defaultAction).focus();
- this.defaultAction.click();
- e.stop();
- }.bind(this)
+ this.parent();
- if (this.options.fileUpload) {
- this.domObj.set('enctype', 'multipart/form-data');
+ if (this.options.selection) {
+ this.selection = this.options.selection;
+ } else if (this.options.select) {
+ this.selection = new Jx.Selection(this.options);
+ this.ownsSelection = true;
- if ($defined(this.options.id)) {
- this.domObj.set('id', this.options.id);
- if ($defined(this.options.formClass)) {
- this.domObj.addClass(this.options.formClass);
+ this.list = new Jx.List(this.listObj, this.options.listOptions, this.selection);
- * APIMethod: addField
- * Adds a <Jx.Field> subclass to this form's fields hash
- * Parameters:
- * field - <Jx.Field> to add
- addField : function (field) {
- this.fields.set(field.id, field);
- if (field.options.defaultAction) {
- this.defaultAction = field;
+ cleanup: function() {
+ if (this.ownsSelection) {
+ this.selection.destroy();
+ this.list.destroy();
- * Method: isValid
- * Determines if the form passes validation
- * Parameters:
- * evt - the MooTools event object
- isValid : function (evt) {
- return true;
+ add: function(item, where) {
+ this.list.add(item, where);
+ return this;
- * APIMethod: getValues
- * Gets the values of all the fields in the form as a Hash object. This
- * uses the mootools function Element.toQueryString to get the values and
- * will either return the values as a querystring or as an object (using
- * mootools-more's String.parseQueryString method).
- * Parameters:
- * asQueryString - {boolean} indicates whether to return the value as a
- * query string or an object.
- getValues : function (asQueryString) {
- var queryString = this.domObj.toQueryString();
- if ($defined(asQueryString) && asQueryString) {
- return queryString;
- } else {
- return queryString.parseQueryString();
+ remove: function(item) {
+ this.list.remove(item);
+ return this;
- * APIMethod: setValues
- * Used to set values on the form
- * Parameters:
- * values - A Hash of values to set keyed by field name.
- setValues : function (values) {
- //TODO: This may have to change with change to getValues().
- if (Jx.type(values) === 'object') {
- values = new Hash(values);
- this.fields.each(function (item) {
- item.setValue(values.get(item.name));
- }, this);
+ replace: function(item, withItem) {
+ this.list.replace(item, withItem);
+ return this;
- * APIMethod: add
- * Parameters:
- * Pass as many parameters as you like. However, they should all be
- * <Jx.Field> objects.
- add : function () {
- var field;
- for (var x = 0; x < arguments.length; x++) {
- field = arguments[x];
- //add form to the field and field to the form if not already there
- if (field instanceof Jx.Field && !$defined(field.form)) {
- field.form = this;
- this.addField(field);
- } else if (field instanceof Jx.Fieldset && !$defined(field.form)) {
- this.domObj.grab(field);
+ empty: function () {
+ this.list.empty();
return this;
+});// $Id: hidden.js 649 2009-11-30 22:19:48Z pagameba $
+ * Class: Jx.Field.Hidden
+ * Extends: <Jx.Field>
+ * This class represents a hidden input field.
+ * Example:
+ * (code)
+ * (end)
+ * License:
+Jx.Field.Hidden = new Class({
+ Extends: Jx.Field,
+ options: {
+ * The template used to render this field
+ template: '<span class="jxInputContainer"><input class="jxInputHidden" type="hidden" name="{name}"/></span>'
- * APIMethod: reset
+ * Property: type
+ * The type of this field
- reset : function () {
- this.fields.each(function (field, name) {
- field.reset();
- }, this);
- this.fireEvent('reset',this);
+ type: 'Hidden'
- getFieldsByName: function (name) {
- var fields = [];
- this.fields.each(function(val, id){
- if (val.name === name) {
- fields.push(val);
- },this);
- return fields;
- getField: function (id) {
- if (this.fields.has(id)) {
- return this.fields.get(id);
- return null;
- setBusy: function(state) {
- if (this.busy == state) {
- return;
- this.parent(state);
- this.fields.each(function(field) {
- field.setBusy(state, true);
* Class: Jx.Field.File
@@ -28203,12 +28680,23 @@
debug: false,
+ * Option: mode
+ * determines whether this file field acts in single upload mode or
+ * multiple file upload mode. The multiple upload mode was done to work with
+ * Jx.Panel.FileUpload. When in multiple mode, this field will remove the actual
+ * file control after a file is selected, fires an event to signify the selection but will
+ * hold on to the files until told to upload them. Obviously 'multiple' mode isn't designed
+ * to be used when the control is outside of the Upload Panel (unless the user designs
+ * their own upload panel around it).
+ mode: 'single',
* Events
- onUploadBegin: $empty,
- onUploadComplete: $empty,
- onUploadProgress: $empty,
- onUploadError: $empty,
+ onFileUploadBegin: $empty,
+ onFileUploadComplete: $empty,
+ onFileUploadProgress: $empty,
+ onFileUploadError: $empty,
onFileSelected: $empty
@@ -28218,6 +28706,31 @@
type: 'File',
+ * Property: forms
+ * holds all form references when we're in multiple mode
+ forms: null,
+ init: function () {
+ this.parent();
+ this.forms = new Hash();
+ //create the iframe
+ //we use the same iFrame for each so we don't have to recreate it each time
+ this.setupIframe = true;
+ this.iframe = new IFrame(null, {
+ styles: {
+ 'display':'none',
+ 'visibility':'hidden'
+ name : this.generateId()
+ this.iframe.inject(document.body);
+ this.iframe.addEvent('load', this.processIFrameUpload.bind(this));
* APIMethod: render
* renders the file input
@@ -28238,16 +28751,15 @@
template : '<span class="jxInputContainer"><input class="jxInputText" type="text" /></span>'
this.browseButton = new Jx.Button({
- label: MooTools.lang.get('Jx','file').browseLabel
+ label: this.getText({set:'Jx',key:'file',value:'browseLabel'})
this.fake.adopt(this.text, this.browseButton);
this.field.grab(this.fake, 'after');
this.field.addEvents({
change : this.copyValue.bind(this),
- mouseout : this.copyValue.bind(this),
+ //mouseout : this.copyValue.bind(this),
mouseenter : this.mouseEnter.bind(this),
mouseleave : this.mouseLeave.bind(this)
@@ -28259,9 +28771,19 @@
* the mouse moves out of it to copy the value into the "fake" text box.
copyValue: function () {
- if (this.field.value !== '' && (this.text.field.value !== this.field.value)) {
+ if (this.options.mode=='single' && this.field.value !== '' && (this.text.field.value !== this.field.value)) {
this.text.field.value = this.field.value;
this.fireEvent('fileSelected', this);
+ if (this.options.autoUpload) {
+ this.uploadSingle();
+ } else if (this.options.mode=='multiple') {
+ var filename = this.field.value;
+ var form = this.prepForm();
+ this.forms.set(filename, form);
+ this.text.setValue('');
+ //fire the selected event.
+ this.fireEvent('fileSelected', filename);
@@ -28280,38 +28802,62 @@
mouseLeave: function () {
this.browseButton.domA.removeClass('jxButtonPressed');
- * APIMethod: upload
- * Call this to upload the file to the server
- upload: function () {
- this.fireEvent('uploadBegin', this);
- //create the iframe
- this.iframe = new IFrame(null, {
- styles: {
- display: 'none'
- name : this.generateId()
- this.iframe.inject(document.body);
+ prepForm: function () {
//load in the form
- this.form = new Jx.Form({
+ var form = new Jx.Form({
action : this.options.handlerUrl,
fileUpload: true
- //iframeBody.grab(this.form);
+ //move the form input into it (cloneNode)
+ var parent = document.id(this.field.getParent());
+ var sibling = document.id(this.field).getPrevious();
+ var clone = this.field.clone().cloneEvents(this.field);
+ document.id(form).grab(this.field);
+ // tried clone.replaces(this.field) but it didn't seem to work
+ if (sibling) {
+ clone.inject(sibling, 'after');
+ } else if (parent) {
+ clone.inject(parent, 'top');
+ this.field = clone;
+ this.mouseLeave();
+ return form;
+ upload: function () {
+ //do we have files to upload?
+ if (this.forms.getLength() > 0) {
+ var keys = this.forms.getKeys();
+ this.currentKey = keys[0];
+ var form = this.forms.get(this.currentKey);
+ this.forms.erase(this.currentKey);
+ this.uploadSingle(form);
+ } else {
+ //fire finished event...
+ this.fireEvent('allUploadsComplete', this);
+ * APIMethod: uploadSingle
+ * Call this to upload the file to the server
+ uploadSingle: function (form) {
+ this.form = $defined(form) ? form : this.prepForm();
+ this.fireEvent('fileUploadBegin', [this.currentKey, this]);
document.id(this.form).set('target', this.iframe.get('name')).setStyles({
visibility: 'hidden',
display: 'none'
- //move the form input into it (cloneNode)
- document.id(this.form).grab(this.field.cloneNode(true));
//if polling the server we need an APC_UPLOAD_PROGRESS id.
//get it from the server.
if (this.options.progress) {
@@ -28345,9 +28891,7 @@
id.addTo(this.form, 'top');
- this.iframe.addEvent('load', this.processIFrameUpload.bind(this));
//submit the form
document.id(this.form).submit();
//begin polling if needed
@@ -28380,16 +28924,12 @@
processProgress: function (data) {
if ($defined(data)) {
- this.fireEvent('uploadProgress', [data, this]);
+ this.fireEvent('fileUploadProgress', [data, this.currentKey, this]);
if (data.current < data.total) {
this.polling = true;
this.pollUpload();
} else {
this.polling = false;
- if (this.done) {
- this.uploadCleanUp();
- this.fireEvent('uploadComplete', [this.doneData, this]);
@@ -28398,7 +28938,7 @@
* called if there is a problem getting progress on the upload
uploadFailure: function (xhr) {
- this.fireEvent('uploadProgressError', this);
+ this.fireEvent('fileUploadProgressError', [this, xhr]);
* Method: processIFrameUpload
@@ -28408,18 +28948,26 @@
processIFrameUpload: function () {
//the body text should be a JSON structure
//get the body
- var iframeBody = this.iframe.contentDocument.defaultView.document.body.innerHTML;
+ if (!this.setupIframe) {
+ var iframeBody = this.iframe.contentDocument.defaultView.document.body.innerHTML;
- var data = JSON.decode(iframeBody);
- if ($defined(data.success) && data.success) {
- this.done = true;
- this.doneData = data;
- if (!this.polling) {
+ var data = JSON.decode(iframeBody);
+ if ($defined(data.success) && data.success) {
+ this.done = true;
+ this.doneData = data;
- this.fireEvent('uploadComplete', [data, this]);
+ this.fireEvent('fileUploadComplete', [data, this.currentKey, this]);
+ } else {
+ this.fireEvent('fileUploadError', [data , this.currentKey, this]);
+ if (this.options.mode == 'multiple') {
+ this.upload();
+ } else {
} else {
- this.fireEvent('uploadError', [data , this]);
+ this.setupIframe = false;
@@ -28430,25 +28978,23 @@
uploadCleanUp: function () {
if (!this.options.debug) {
this.form.destroy();
- this.iframe.destroy();
+ if (this.options.mode == 'single') {
+ this.iframe.destroy();
- * APIMethod: getFileName
- * Allows caller to get the filename of the file we're uploading
+ * Removes a file from the hash of forms to upload.
+ * Parameters:
+ * filename - the filename indicating which file to remove.
- getFileName: function () {
- var fn = this.field.get('value');
- return fn.slice(fn.lastIndexOf('/') + 1);
+ remove: function (filename) {
+ if (this.forms.has(filename)) {
+ this.forms.erase(filename);
- * Method: getExt
- * Returns the 3-letter extension of this file.
- getExt: function () {
- var fn = this.getFileName();
- return fn.slice(fn.length - 3);
* APIMethod: changeText
@@ -28462,7 +29008,7 @@
this.parent();
if ($defined(this.browseButton)) {
- this.browseButton.setLabel( MooTools.lang.get('Jx','file').browseLabel);
+ this.browseButton.setLabel( this.getText({set:'Jx',key:'file',value:'browseLabel'}) );
@@ -28495,7 +29041,9 @@
* MooTools.lang keys:
* - progressbar.messageText
* - progressbar.progressText
+ * Copyright (c) 2010 by Jonathan Bomgardner
+ * Licensed under an mit-style license
Jx.Progressbar = new Class({
Family: 'Jx.Progressbar',
@@ -28505,21 +29053,17 @@
onUpdate: $empty,
onComplete: $empty,
- * Option: bar
- * an object that gives options for the bar itself. Specifically,
- * the width and height of the bar. You can set either to 'auto' to
- * have the bar calculate its own width.
- bar: {
- width: 'auto',
- height: 20
* Option: parent
* The element to put this progressbar into
parent: null,
+ * Option: progressText
+ * Text to show while processing, uses
+ * {progress} von {total}
+ progressText : null,
* Option: template
* The template used to create the progressbar
@@ -28560,57 +29104,31 @@
this.domObj.addClass('jxProgressStarting');
+ //we need to know the width of the bar
+ this.width = document.id(this.domObj).getContentBoxSize().width;
- //determine width of progressbar
- if (this.options.bar.width === 'auto') {
- //get width of container
- this.options.bar.width = this.domObj.getStyle('width').toInt();
- //determine height
- if (this.options.bar.height === 'auto') {
- this.options.bar.height = this.domObj.getStyle('height').toInt() - 4;
//Message
if (this.message) {
if ($defined(MooTools.lang.get('Jx','progressbar').messageText)) {
- this.message.set('html', MooTools.lang.get('Jx','progressbar').messageText);
+ this.message.set('html', this.getText({set:'Jx',key:'progressbar',value:'messageText'}));
} else {
this.message.destroy();
- //bar container itself
- if (this.container) {
- this.container.setStyles({
- 'position': 'relative',
- 'width': this.options.bar.width
- //'height' : this.options.bar.height + 4
- //Outline
- if (this.outline) {
- this.outline.setStyles({
//Fill
if (this.fill) {
this.fill.setStyles({
'width': 0
//TODO: check for {progress} and {total} in progressText
var obj = {};
- var progressText = MooTools.lang.get('Jx','progressbar').progressText;
+ var progressText = this.options.progressText == null ?
+ this.getText({set:'Jx',key:'progressbar',value:'progressText'}) :
+ this.getText(this.options.progressText);
if (progressText.contains('{progress}')) {
obj.progress = 0;
@@ -28640,12 +29158,14 @@
this.domObj.removeClass('jxProgressStarting').addClass('jxProgressWorking');
- var newWidth = (progress * this.options.bar.width) / total;
+ var newWidth = (progress * this.width) / total;
//update bar width
this.text.get('tween', {property:'width', onComplete: function() {
var obj = {};
obj.progress = progress;
@@ -28681,12 +29201,12 @@
this.parent();
if (this.message) {
- this.message.set('html',MooTools.lang.get('Jx','progressbar').messageText);
+ this.message.set('html',this.getText({set:'Jx',key:'progressbar',value:'messageText'}));
//progress text will update on next update.
-});// $Id: upload.js 826 2010-03-31 18:46:16Z pagameba $
+});// $Id: upload.js 892 2010-05-06 21:06:26Z conrad.barthelmes $
* Class: Jx.Panel.FileUpload
@@ -28705,7 +29225,9 @@
Jx.Panel.FileUpload = new Class({
+ Family: 'Jx.Panel.FileUpload',
Extends: Jx.Panel,
+ Binds: ['moveToQueue','fileUploadBegin', 'fileUploadComplete','allUploadsComplete', 'fileUploadProgressError,', 'fileUploadError', 'fileUploadProgress'],
options: {
@@ -28719,6 +29241,15 @@
handlerUrl: '',
progressUrl: ''
+ progressOptions: {
+ template: "<li class='jxListItemContainer jxProgressBar-container' id='{id}'><div class='jxProgressBar'><div class='jxProgressBar-outline'></div><div class='jxProgressBar-fill'></div><div class='jxProgressBar-text'></div></div></li>",
+ containerClass: 'progress-container',
+ messageText: null,
+ messageClass: 'progress-message',
+ progressText: 'Uploading {filename}',
+ progressClass: 'progress-bar'
* Option: onFileComplete
* An event handler that is called when a file has been uploaded
@@ -28752,6 +29283,8 @@
* An array holding Jx.Field.File elements that are to be uploaded
fileQueue: [],
+ listTemplate: "<li class='jxListItemContainer' id='{id}'><a class='jxListItem' href='javascript:void(0);'><span class='itemLabel jxUploadFileName'>{name}</span><span class='jxUploadFileDelete' title='Remove this file from the queue.'></span></a></li>",
* Method: render
* Sets up the upload panel.
@@ -28777,25 +29310,21 @@
this.fileOpt = this.options.file;
this.fileOpt.template = '<div class="jxInputContainer jxFileInputs"><input class="jxInputFile" type="file" name={name} /></div>';
- this.currentFile = new Jx.Field.File(this.fileOpt);
- this.currentFile.addEvent('fileSelected', this.moveToQueue.bind(this));
- this.currentFile.addTo(this.domObjA);
+ this.file = new Jx.Field.File(this.fileOpt);
+ this.file.addEvent('fileSelected', this.moveToQueue);
+ this.file.addTo(this.domObjA);
- //now the 'queue' listing with delete button
+ this.listView = new Jx.ListView({
+ template: '<ul class="jxListView jxList jxUploadQueue"></ul>'
+ }).addTo(this.domObjA);
- this.queueDiv = new Element('div', {
- 'class': 'jxUploadQueue'
- //make the queueDiv a list
- this.list = new Jx.List(this.queueDiv, {
- hover: true
- this.queueDiv.inject(this.domObjA);
+ //this is the upload button at the bottom of the panel.
this.uploadBtn = new Jx.Button({
- label : MooTools.lang.get('Jx','upload').buttonText,
+ label : this.getText({set:'Jx',key:'upload',value:'buttonText'}),
onClick: this.upload.bind(this)
- var tlb = new Jx.Toolbar({position: 'bottom'}).add(this.uploadBtn);
+ var tlb = new Jx.Toolbar({position: 'bottom', scroll: false}).add(this.uploadBtn);
this.uploadBtn.setEnabled(false);
this.options.toolbars = [tlb];
//then pass it on to the Panel constructor
@@ -28807,32 +29336,22 @@
* Called by Jx.Field.File's fileSelected event. Moves the selected file
* into the upload queue.
- moveToQueue: function (file) {
- var cf = this.currentFile;
- var name = cf.getFileName();
+ moveToQueue: function (filename) {
+ var theTemplate = new String(this.listTemplate).substitute({
+ name: filename,
+ id: filename
+ var item = new Jx.ListItem({template:theTemplate, enabled: true});
- this.fileQueue.push(this.currentFile);
+ $(item).getElement('.jxUploadFileDelete').addEvent('click', function(){
+ this.listView.remove(item);
+ this.file.remove(filename);
+ if (this.listView.list.count() == 0) {
+ this.uploadBtn.setEnabled(false);
+ }.bind(this));
+ this.listView.add(item);
- document.id(this.currentFile).replaces(document.id(cf));
- //add to queue div
- cf.queuedDiv = new Element('div', {id : name});
- var s = new Element('span', {
- html : name,
- 'class' : 'jxUploadFileName'
- var del = new Element('span', {
- 'class' : 'jxUploadFileDelete',
- title : 'Remove from queue'
- del.addEvent('click', this.removeFromQueue.bind(this, cf));
- cf.queuedDiv.adopt(s, del);
- this.list.add(cf.queuedDiv);
- //cf.queuedDiv.inject(this.queueDiv);
if (!this.uploadBtn.isEnabled()) {
this.uploadBtn.setEnabled(true);
@@ -28843,43 +29362,46 @@
* Called when the user clicks the upload button. Runs the upload process.
- var file = this.fileQueue.shift();
- file.addEvent('uploadComplete', this.fileUploadComplete.bind(this));
- file.addEvent('uploadError', this.fileUploadError.bind(this));
+ this.file.addEvents({
+ 'fileUploadBegin': this.fileUploadBegin ,
+ 'fileUploadComplete': this.fileUploadComplete,
+ 'allUploadsComplete': this.allUploadsComplete,
+ 'fileUploadError': this.fileUploadError,
+ 'fileUploadProgress': this.fileUploadProgress,
+ 'fileUploadProgressError': this.fileUploadError
+ this.file.upload();
+ fileUploadBegin: function (filename) {
if (this.options.file.progress) {
- file.addEvent('uploadProgress', this.fileUploadProgress.bind(this));
//progressbar
//setup options
// TODO: should (at least some of) these options be available to
// the developer?
- var options = {
- containerClass: 'progress-container',
- messageText: null,
- messageClass: 'progress-message',
- progressText: 'uploading ' + file.getFileName(),
- progressClass: 'progress-bar',
- bar: {
- width: file.queuedDiv.getStyle('width').toInt(),
- height: file.queuedDiv.getFirst().getStyle('height').toInt()
- var pb = new Jx.Progressbar(options);
- file.pb = pb;
- $(pb).replaces(file.queuedDiv);
+ var options = $merge({},this.options.progressOptions);
+ options.progressText = options.progressText.substitute({filename: filename});
+ options.template = options.template.substitute({id: filename});
+ this.pb = new Jx.Progressbar(options);
+ var item = document.id(filename);
+ this.oldContents = item;
+ this.listView.replace(item,$(this.pb));
} else {
- file.queuedDiv.getLast().removeClass('jxUploadFileDelete').addClass('jxUploadFileProgress');
+ var icon = document.id(filename).getElement('.jxUploadFileDelete')
+ icon.addClass('jxUploadFileProgress').set('title','File Uploading...');
- file.upload();
* Method: fileUploadComplete
- * Called when a single file is uploaded completely (called by
- * Jx.Field.File's uploadComplete event).
+ * Called when a single file is uploaded completely .
* Parameters:
* data - the data returned from the event
- * file - the file we're tracking
+ * filename - the filename of the file we're tracking
fileUploadComplete: function (data, file) {
if ($defined(data.success) && data.success ){
@@ -28896,15 +29418,18 @@
* data - the data passed back from the server, if any.
- fileUploadError: function (data, file) {
- var icon = file.queuedDiv.getLast();
+ fileUploadError: function (data, filename) {
+ if (this.options.file.progress) {
+ //show this old contents...
+ this.listView.replace(document.id(filename),this.oldContents);
+ var icon = document.id(filename).getElement('.jxUploadFileDelete');
icon.erase('title');
if (icon.hasClass('jxUploadFileProgress')) {
icon.removeClass('jxUploadFileProgress').addClass('jxUploadFileError');
} else {
- //queued div is hidden, show it
- file.queuedDiv.replaces(file.pb);
- icon.removeClass('jxUploadFileDelete').addClass('jxUploadFileError');
+ icon.addClass('jxUploadFileError');
if ($defined(data.error) && $defined(data.error.message)) {
var tt = new Jx.Tooltip(icon, data.error.message, {
@@ -28919,35 +29444,23 @@
* Parameters:
- removeUploadedFile: function (file) {
+ removeUploadedFile: function (filename) {
if (this.options.removeOnComplete) {
- if ($defined(file.pb)) {
- file.pb.destroy();
- this.list.remove(file.queuedDiv);
- //file.queuedDiv.dispose();
- var name = file.getFileName();
- this.fileQueue.erase(name);
+ this.listView.remove(document.id(filename));
} else {
- var l = file.queuedDiv.getLast();
+ var l = document.id(filename).getElement('.jxUploadFileDelete');
if (l.hasClass('jxUploadFileDelete')) {
- l.removeClass('jxUploadFileDelete').addClass('jxUploadFileComplete');
+ l.addClass('jxUploadFileComplete');
} else if (l.hasClass('jxUploadFileProgress')) {
l.removeClass('jxUploadFileProgress').addClass('jxUploadFileComplete');
- this.fireEvent('fileComplete', file);
- if (this.fileQueue.length > 0) {
- this.upload();
- } else {
- this.fireEvent('complete');
+ this.fireEvent('fileUploadComplete', filename);
* Method: fileUploadProgress
@@ -28955,154 +29468,33 @@
* in the file. Only used if we're tracking progress.
fileUploadProgress: function (data, file) {
- file.pb.update(data.total, data.current);
+ if (this.options.progress) {
+ this.pb.update(data.total, data.current);
- * Method: removeFromQueue
- * Called when the delete icon is clicked for an individual file. It
- * removes the file from the queue, disposes of it, and does NOT upload
- * the file to the server.
- * Pparameters:
- * file - the file we're getting rid of.
+ * Method: allUploadCompleted
+ * Called when the Jx.Field.File completes uploading
+ * all files. Sets upload button to disabled and fires the allUploadCompleted
+ * event.
- removeFromQueue: function (file) {
- //TODO: Should prompt the user to be sure - use Jx.Dialog.Confirm?
- //document.id(name).destroy();
- this.fileQueue = this.fileQueue.erase(file);
- if (this.fileQueue.length === 0) {
- this.uploadBtn.setEnabled(false);
+ allUploadsComplete: function () {
+ this.fireEvent('allUploadsCompleted',this);
this.parent();
if ($defined(this.uploadBtn)) {
- this.uploadBtn.setLabel(MooTools.lang.get('Jx','upload').buttonText);
+ this.uploadBtn.setLabel({set:'Jx',key:'upload',value:'buttonText'});
-// $Id: listitem.js 649 2009-11-30 22:19:48Z pagameba $
+// $Id: column.js 878 2010-04-25 22:07:31Z jonlb at comcast.net $
- * Class: Jx.ListItem
- * Extends: <Jx.Widget>
- * Events:
- * License:
- * Copyright (c) 2009, DM Solutions Group.
- * This file is licensed under an MIT style license
-Jx.ListItem = new Class({
- Family: 'Jx.ListItem',
- Extends: Jx.Widget,
- options: {
- enabled: true,
- template: '<li class="jxListItemContainer jxListItem"></li>'
- classes: new Hash({
- domObj: 'jxListItemContainer',
- domContent: 'jxListItem'
- * APIMethod: render
- render: function () {
- this.parent();
- this.domContent.store('jxListItem', this);
- this.domObj.store('jxListTarget', this.domContent);
- this.loadContent(this.domContent);
- enable: function(state) {
-});// $Id: listview.js 649 2009-11-30 22:19:48Z pagameba $
- * Class: Jx.ListView
- * Events:
- * License:
-Jx.ListView = new Class({
- Family: 'Jx.Widget',
- options: {
- template: '<ul class="jxListView jxList"></ul>',
- * Option: listOptions
- * control the behaviour of the list, see <Jx.List>
- listOptions: {
- hover: true,
- press: true,
- select: true
- domObj: 'jxListView',
- listObj: 'jxList'
- this.parent();
- if (this.options.selection) {
- this.selection = this.options.selection;
- } else if (this.options.select) {
- this.selection = new Jx.Selection(this.options);
- this.ownsSelection = true;
- this.list = new Jx.List(this.listObj, this.options.listOptions, this.selection);
- cleanup: function() {
- if (this.ownsSelection) {
- this.selection.destroy();
- this.list.destroy();
- add: function(item, where) {
- this.list.add(item, where);
- return this;
- remove: function(item) {
- this.list.remove(item);
- return this;
- replace: function(item, withItem) {
- this.list.replace(item, withItem);
- return this;
-});// $Id: column.js 826 2010-03-31 18:46:16Z pagameba $
* Class: Jx.Column
* Extends: <Jx.Object>
@@ -29253,13 +29645,21 @@
return this.domObj;
- setWidth: function(newWidth) {
- var delta = this.cellWidth - this.width;
- this.width = parseInt(newWidth,10);
- this.cellWidth = this.width + delta;
- this.options.width = newWidth;
- if (this.rule && parseInt(newWidth,10) >= 0) {
- this.rule.style.width = parseInt(newWidth,10) + "px";
+ setWidth: function(newWidth, asCellWidth) {
+ asCellWidth = $defined(asCellWidth) ? asCellWidth : false;
+ var delta = this.cellWidth - this.width;
+ if (!asCellWidth) {
+ this.width = parseInt(newWidth,10);
+ this.cellWidth = this.width + delta;
+ this.options.width = newWidth;
+ } else {
+ this.width = parseInt(newWidth,10) - delta;
+ this.cellWidth = newWidth;
+ this.options.width = this.width;
+ if (this.rule && parseInt(this.width,10) >= 0) {
+ this.rule.style.width = parseInt(this.width,10) + "px";
if (this.cellRule && parseInt(this.cellWidth,10) >= 0) {
this.cellRule.style.width = parseInt(this.cellWidth,10) + "px";
@@ -29427,6 +29827,14 @@
return this.options.isHidden;
+ * APIMethod: isAttached
+ * returns whether this column is attached to a store.
+ isAttached: function () {
+ return this.options.renderer.attached;
* APIMethod: getHTML
* calls render method of the renderer object passed in.
@@ -29435,7 +29843,7 @@
return document.id(this.options.renderer);
-});// $Id: columns.js 818 2010-03-30 12:45:20Z pagameba $
+});// $Id: columns.js 886 2010-04-29 23:07:02Z jonlb at comcast.net $
* Class: Jx.Columns
@@ -29481,6 +29889,11 @@
columns : [],
parameters: ['options','grid'],
+ * Property: hasExpandable
+ hasExpandable: null,
* APIMethod: init
@@ -29493,6 +29906,8 @@
this.grid = this.options.grid;
+ this.hasExpandable = false;
this.options.columns.each(function (col) {
//check the column to see if it's a Jx.Grid.Column or an object
if (col instanceof Jx.Column) {
@@ -29500,6 +29915,10 @@
} else if (Jx.type(col) === "object") {
this.columns.push(new Jx.Column(col,this.grid));
+ var c = this.columns[this.columns.length - 1 ];
+ if (c.options.renderMode === 'expand') {
+ this.hasExpandable = true;
}, this);
@@ -29640,7 +30059,11 @@
list.add(this.getColumnCell(col, idx));
}, this);
- list.add(new Element('td'));
+ if (!this.hasExpandable) {
+ list.add(new Element('td',{
+ 'class': 'jxGridCellUnattached'
* APIMethod: getColumnCell
@@ -29667,6 +30090,9 @@
if (col.isSortable()) {
td.addClass('jxColSortable');
+ if (!col.isAttached()) {
+ td.addClass('jxGridCellUnattached');
td.store('jxCellData',{
col: col,
@@ -29705,7 +30131,7 @@
if (!col.isHidden() && !(col.name == this.grid.row.options.headerColumn)) {
- totalWidth += Jx.getNumber(col.getWidth());
+ totalWidth += Jx.getNumber(col.getCellWidth());
if (rowHeader) {
rowHeaderWidth = col.getWidth();
@@ -29719,19 +30145,29 @@
//now figure the expand column
if ($defined(expand)) {
// var leftOverSpace = gridSize.width - totalWidth + rowHeaderWidth;
- var leftOverSpace = gridSize.width - totalWidth;
+ var leftOverSpace = gridSize.width - totalWidth
+ //account for right borders in firefox...
+ if (Browser.Engine.gecko) {
+ leftOverSpace -= this.getColumnCount(true);
+ } else {
+ // -2 is for the right hand border on the cell and the table for all other browsers
+ leftOverSpace -= 2;
if (leftOverSpace >= expand.options.width) {
+ //in order for this to be set properly the cellWidth must be the
+ //leftover space. we need to figure out the delta value and
+ //subtract it from the leftover width
expand.options.width = leftOverSpace;
expand.calculateWidth();
- expand.setWidth(leftOverSpace);
+ expand.setWidth(leftOverSpace, true);
totalWidth += leftOverSpace;
} else {
expand.setWidth(expand.options.width);
} //else {
- this.grid.gridTable.setContentBoxSize({'width': totalWidth - rowHeaderWidth});
- this.grid.colTable.setContentBoxSize({'width': totalWidth - rowHeaderWidth});
+ this.grid.gridTable.setContentBoxSize({'width': totalWidth});
+ this.grid.colTable.setContentBoxSize({'width': totalWidth});
@@ -29766,8 +30202,17 @@
* APIMethod: getColumnCount
* returns the number of columns in this model (including hidden).
- getColumnCount : function () {
- return this.columns.length;
+ getColumnCount : function (noHidden) {
+ noHidden = $defined(noHidden) ? false : true;
+ var total = this.columns.length;
+ if (noHidden) {
+ this.columns.each(function(col){
+ if (col.isHidden()) {
+ total -= 1;
+ },this);
+ return total;
* APIMethod: getIndexFromGrid
@@ -29801,7 +30246,7 @@
-// $Id: row.js 809 2010-03-28 04:15:14Z jonlb at comcast.net $
+// $Id: row.js 887 2010-04-30 12:46:38Z pagameba $
* Class: Jx.Row
@@ -29980,7 +30425,7 @@
createRules: function(styleSheet, scope) {
this.grid.gridTableBody.getChildren().each(function(row, idx) {
- var selector = scope+' .jxGridRow'+idx;
+ var selector = scope+' .jxGridRow'+idx + ', ' + scope + ' .jxGridRow'+idx+' .jxGridCellContent';
var rule = Jx.Styles.insertCssRule(selector, '', styleSheet);
this.rules.set('jxGridRow'+idx, rule);
rule.style.height = this.heights[idx] + "px";
@@ -29989,10 +30434,23 @@
selector += " th";
var thRule = Jx.Styles.insertCssRule(selector, '', styleSheet);
thRule.style.height = this.heights[idx] + "px";
+ this.rules.set('th_jxGridRow'+idx, thRule);
}, this);
+ updateRules: function() {
+ this.grid.gridTableBody.getChildren().each(function(row, idx) {
+ var h = this.heights[idx] + "px";
+ this.rules.get('jxGridRow'+idx).style.height = h;
+ if (Browser.Engine.webkit) {
+ this.rules.get('th_jxGridRow'+idx).style.height = h;
+ }, this);
* APIMethod: useHeaders
* determines and returns whether row headers should be used
@@ -30095,7 +30553,7 @@
-Jx.Plugin.Grid = {};// $Id: grid.js 826 2010-03-31 18:46:16Z pagameba $
+Jx.Plugin.Grid = {};// $Id: grid.js 897 2010-05-07 20:03:33Z conrad.barthelmes $
* Class: Jx.Grid
@@ -30262,8 +30720,6 @@
this.row = new Jx.Row({grid: this});
//initialize the grid
this.domObj = new Element('div', {'class':this.uniqueId});
var l = new Jx.Layout(this.domObj, {
@@ -30368,17 +30824,7 @@
var size = this.domObj.getContentBoxSize();
- //sum all of the column widths except the hidden columns and the header column
- var w = size.width - rowWidth - 1;
- var totalCols = 0;
- this.columns.columns.each(function (col) {
- if (col.options.modelField !== this.row.getRowHeaderField()
- && !col.isHidden()) {
- totalCols += col.getWidth();
- }, this);
/* -1 because of the right/bottom borders */
this.rowColObj.setStyles({
@@ -30408,6 +30854,25 @@
+ resizeRowsCols: function (mode) {
+ mode = $defined(mode) ? mode : 'all';
+ if (mode === 'all' || mode === 'columns') {
+ Jx.Styles.removeStyleSheet(this.styleSheet + "Columns");
+ Jx.Styles.enableStyleSheet(this.styleSheet + "Columns");
+ this.columns.calculateWidths();
+ this.columns.createRules(this.styleSheet + "Columns", "."+this.uniqueId);
+ if (mode === 'all' || mode === 'rows') {
+ Jx.Styles.removeStyleSheet(this.styleSheet + "Rows");
+ Jx.Styles.enableStyleSheet(this.styleSheet + "Rows");
+ this.row.calculateHeights();
+ this.row.createRules(this.styleSheet + "Rows", "."+this.uniqueId);
* APIMethod: setModel
* set the model for the grid to display. If a model is attached to the grid
@@ -30560,13 +31025,9 @@
this.domObj.resize();
+ this.resizeRowsCols();
this.resize();
- this.columns.calculateWidths();
- Jx.Styles.enableStyleSheet(this.styleSheet);
- this.columns.createRules(this.styleSheet, "."+this.uniqueId);
- this.row.calculateHeights();
- this.row.createRules(this.styleSheet, "."+this.uniqueId);
this.fireEvent('doneCreateGrid', this);
} else {
this.model.load();
@@ -30696,6 +31157,15 @@
onMouseLeave: function (cell, list) {
this.fireEvent('gridCellLeave', [cell,list,this]);
+ changeText : function(lang) {
+ this.parent();
+ this.resize();
+ this.render();
@@ -30722,6 +31192,13 @@
template: '<span class="jxGridCellContent"></span>'
+ * APIProperty: attached
+ * tells whether this renderer is used in attached mode
+ * or not. Should be set by renderers that get a reference to
+ * the store.
+ attached: null,
classes: $H({
domObj: 'jxGridCellContent'
@@ -30731,6 +31208,7 @@
init: function () {
this.parent();
+ this.attached = false;
@@ -30804,6 +31282,10 @@
&& !(this.options.formatter instanceof Jx.Formatter)) {
var t = Jx.type(this.options.formatter);
if (t === 'object') {
+ // allow users to leave the options object blank
+ if(!$defined(this.options.formatter.options)) {
+ this.options.formatter.options = {}
this.options.formatter = new Jx.Formatter[this.options.formatter.name](
this.options.formatter.options);
@@ -30814,6 +31296,7 @@
this.parent();
this.store = column.grid.getModel();
+ this.attached = true;
if ($defined(this.options.textTemplate)) {
this.columnsNeeded = this.store.parseTemplate(this.options.textTemplate);
@@ -30825,23 +31308,25 @@
var text = '';
- text = this.store.fillTemplate(null,this.options.textTemplate,this.columnsNeeded);
+ if (!$defined(this.columnsNeeded) || (Jx.type(this.columnsNeeded) === 'array' && this.columnsNeeded.length === 0)) {
+ this.columnsNeeded = this.store.parseTemplate(this.options.textTemplate);
+ text = this.store.fillTemplate(null,this.options.textTemplate,this.columnsNeeded);
- if ($defined(this.options.formatter)) {
- text = this.options.formatter.format(text);
+ if ($defined(this.options.formatter)) {
+ text = this.options.formatter.format(text);
+ this.domObj.set('html',text);
+ if ($defined(this.options.css) && Jx.type(this.options.css) === 'function') {
+ this.domObj.addClass(this.options.css.run(text));
+ } else if ($defined(this.options.css) && Jx.type(this.options.css) === 'string'){
+ this.domObj.addClass(this.options.css);
- this.domObj.set('html',text);
- if ($defined(this.options.css) && Jx.type(this.options.css) === 'function') {
- this.domObj.addClass(this.options.css.run(text));
- } else if ($defined(this.options.css) && Jx.type(this.options.css) === 'string'){
- this.domObj.addClass(this.options.css);
* Class: Jx.Grid.Renderer.CheckBox
* Renders a checkbox into the cell. Allows options for connecting the cell
@@ -30893,6 +31378,7 @@
if (this.options.useStore) {
this.store = this.column.grid.getModel();
@@ -30922,47 +31408,47 @@
- * Class: Jx.Grid.Renderer.Button
- * Renders a <Jx.Button> into the cell. You can add s many buttons as you'd like per column by passing button configs
- * in as an array option to options.buttonOptions
- * Extends: <Jx.Grid.Renderer>
-Jx.Grid.Renderer.Button = new Class({
- Family: 'Jx.Grid.Renderer.Button',
- Extends: Jx.Grid.Renderer,
- Binds: [],
- options: {
- template: '<span class="buttons"></span>',
- * Option: buttonOptions
- * an array of option configurations for <Jx.Button>
- buttonOptions: null
- classes: $H({
- domObj: 'buttons'
- init: function () {
- this.parent();
- this.parent();
- $A(this.options.buttonOptions).each(function(opts){
- var button = new Jx.Button(opts);
- this.domObj.grab(document.id(button));
- },this);
+ * Class: Jx.Grid.Renderer.Button
+ * Renders a <Jx.Button> into the cell. You can add s many buttons as you'd like per column by passing button configs
+ * in as an array option to options.buttonOptions
+ * Extends: <Jx.Grid.Renderer>
+Jx.Grid.Renderer.Button = new Class({
+ Family: 'Jx.Grid.Renderer.Button',
+ Extends: Jx.Grid.Renderer,
+ Binds: [],
+ options: {
+ template: '<span class="buttons"></span>',
+ * Option: buttonOptions
+ * an array of option configurations for <Jx.Button>
+ buttonOptions: null
+ classes: $H({
+ domObj: 'buttons'
+ this.parent();
+ this.parent();
+ $A(this.options.buttonOptions).each(function(opts){
+ var button = new Jx.Button(opts);
+ this.domObj.grab(document.id(button));
+ },this);
});// $Id: grid.selector.js 826 2010-03-31 18:46:16Z pagameba $
* Class: Jx.Plugin.Selector
@@ -31821,7 +32307,7 @@
th.addClass('jxGridColumnSorted' + this.direction.capitalize());
-// $Id: grid.resize.js 796 2010-03-26 19:56:43Z pagameba $
+// $Id: grid.resize.js 892 2010-05-06 21:06:26Z conrad.barthelmes $
* Class: Jx.Plugin.Resize
@@ -31853,9 +32339,9 @@
* Option: tooltip
* the tooltip to display for the draggable portion of the
- * cell header
+ * cell header, localized with MooTools.lang.get('Jx','plugin.resize').tooltip for default
- tooltip: MooTools.lang.get('Jx','plugin.resize').tooltip
+ tooltip: ''
* Property: els
@@ -31938,10 +32424,10 @@
col.domObj) {
var el = new Element('div', {
'class':'jxGridColumnResize',
- title: this.options.tooltip,
+ title: this.options.tooltip == '' ? this.getText({set:'Jx',key:'plugin.resize',value:'tooltip'}) : this.getText(this.options.tooltip),
events: {
dblclick: function() {
- col.options.renderMode = 'fixed';
+ col.options.renderMode = 'fit';
col.options.width = 'auto';
col.setWidth(col.getWidth(true));
@@ -31975,6 +32461,7 @@
onComplete: function(el) {
el.setStyle('left', null);
+ col.grid.resizeRowsCols("rows");
@@ -31987,15 +32474,15 @@
* Method: createText
* respond to a language change by updating the tooltip
- createText: function (lang) {
+ changeText: function (lang) {
this.parent();
- var txt = MooTools.lang.get('Jx','plugin.resize').tooltip;
+ var txt = this.options.tooltip == '' ? this.getText({set:'Jx',key:'plugin.resize',value:'tooltip'}) : this.getText(this.options.tooltip);
['column','row'].each(function(option) {
this.els[option].each(function(el) { el.set('title',txt); } );
}, this);
-// $Id: grid.editor.js 822 2010-03-31 11:28:31Z conrad.barthelmes $
+// $Id: grid.editor.js 892 2010-05-06 21:06:26Z conrad.barthelmes $
* Class: Jx.Plugin.Editor
@@ -32159,6 +32646,14 @@
keyboardMethods : {},
+ * Option: keypressLoop
+ * loop through the grid when pressing TAB (or some other method that uses
+ * this.getNextCellInRow() or this.getPrevCellInRow()). If set to false,
+ * the input field/popup will not start at the opposite site of the grid
+ * Defaults to true
+ keypressLoop : true,
* Option: linkClickListener
* disables all click events on links that are formatted with Jx.Formatter.Uri
* - otherwise the link will open directly instead of open the input editor)
@@ -32302,8 +32797,10 @@
keyboardEvents[i] = this.keyboardMethods[this.options.keys[i]];
}else if($defined(this.options.keyboardMethods[this.options.keys[i]])){
keyboardEvents[i] = this.options.keyboardMethods[this.options.keys[i]].bind(self);
+ }else if(Jx.type(this.options.keys[i]) == 'function') {
+ keyboardEvents[i] = this.options.keys[i].bind(self);
}else{
- $defined(console) ? console.log("keyboard method %o not defined", this.options.keys[i]) : false;
+ $defined(console) ? console.warn("keyboard method %o not defined", this.options.keys[i]) : false;
@@ -32427,7 +32924,7 @@
break;
case 'Select':
// find out which visible value fits to the value inside <option>{value}</option> and set it to selected
- var oldValue = this.activeCell.oldValue.toString()
+ var oldValue = this.activeCell.oldValue.toString();
function setCombos(opts, oldValue) {
for(var i = 0, j = opts.length; i < j; i++) {
if(opts[i].value == oldValue) {
@@ -32590,12 +33087,19 @@
* the row could probably be highlighted as well?
if(this.options.cellChangeFx.use) {
+ var highlighter = new Fx.Tween(this.activeCell.cell, {
+ duration: 250,
+ onComplete: function(ev) {
+ this.element.removeProperty('style');
+ var currentCellBg = this.activeCell.cell.getStyle('background-color');
+ currentCellBg = currentCellBg == 'transparent' ? '#fff' : currentCellBg;
if(newValue.data != null && newValue.error == false) {
- this.activeCell.cell.highlight(this.options.cellChangeFx.success);
+ highlighter.start('background-color',this.options.cellChangeFx.success, currentCellBg);
}else if(newValue.error){
- this.activeCell.cell.highlight(this.options.cellChangeFx.error);
+ highlighter.start('background-color',this.options.cellChangeFx.error, currentCellBg);
- //this.activeCell.cell.removeProperty('style').delay(250, this.activeCell.cell);
// check for error and keep input field alive
@@ -32777,14 +33281,18 @@
// check if buttons are needed, innerWrapper exists and no buttons already exist
if(this.options.popup.useButtons && this.popup.innerWrapper != null && this.popup.button.submit == null) {
button.submit = new Jx.Button({
- label : this.options.popup.button.submit.label.length == 0 ? MooTools.lang.get('Jx','plugin.editor').submitButton : this.options.popup.button.submit.label,
+ label : this.options.popup.button.submit.label.length == 0 ?
+ this.getText({set:'Jx',key:'plugin.editor',value:'submitButton'}) :
+ this.getText(this.options.popup.button.submit.label),
image : this.options.popup.button.submit.image,
onClick: function() {
self.deactivate(true);
}).addTo(this.popup.innerWrapper);
button.cancel = new Jx.Button({
- label : this.options.popup.button.cancel.label.length == 0 ? MooTools.lang.get('Jx','plugin.editor').cancelButton : this.options.popup.button.cancel.label,
+ label : this.options.popup.button.cancel.label.length == 0 ?
+ this.getText({set:'Jx',key:'plugin.editor',value:'cancelButton'}) :
+ this.getText(this.options.popup.button.cancel.label),
image : this.options.popup.button.cancel.image,
self.deactivate(false);
@@ -32859,7 +33367,7 @@
if(this.activeCell.cell != null) {
var nextCell = true, nextRow = true,
sumCols = this.grid.columns.columns.length,
- jxCellClass = 'td.jxGridCell';
+ jxCellClass = 'td.jxGridCell:not(.jxGridCellUnattached)';
var i = 0;
do {
nextCell = i > 0 ? nextCell.getNext(jxCellClass) : this.activeCell.cell.getNext(jxCellClass);
@@ -32867,8 +33375,10 @@
if(nextCell == null) {
nextRow = this.activeCell.cell.getParent('tr').getNext();
// check if this was the last row in the table
- if(nextRow == null) {
+ if(nextRow == null && this.options.keypressLoop) {
nextRow = this.activeCell.cell.getParent('tbody').getFirst();
+ }else if(nextRow == null && !this.options.keypressLoop){
+ return;
nextCell = nextRow.getFirst(jxCellClass);
@@ -32902,16 +33412,17 @@
var prevCell, prevRow, i = 0,
do {
prevCell = i > 0 ? prevCell.getPrevious(jxCellClass) : this.activeCell.cell.getPrevious(jxCellClass);
// check if cell is still in row, otherwise returns null
if(prevCell == null) {
prevRow = this.activeCell.cell.getParent('tr').getPrevious();
- if(prevRow == null) {
- // @todo this does not always work when shift+tab is hold pressed (out of grid error)
+ if(prevRow == null && this.options.keypressLoop) {
prevRow = this.activeCell.cell.getParent('tbody').getLast();
+ }else if(prevRow == null && !this.options.keypressLoop) {
+ return;
prevCell = prevRow.getLast(jxCellClass);
@@ -33067,7 +33578,8 @@
* Method: addFormatterUriClickListener
* looks up for Jx.Formatter.Uri columns to disable the link and open the
- * inline editor instead. set option linkClickListener to false to disable this
+ * inline editor instead when CTRL is NOT pressed.
+ * set option linkClickListener to false to disable this
addFormatterUriClickListener : function() {
@@ -33713,16 +34225,16 @@
- * Class: Jx.Plugin.Toolbar
- * Toolbar plugin namespace
- * License:
+ * Class: Jx.Plugin.Toolbar
+ * Toolbar plugin namespace
+ * License:
+ * Copyright (c) 2009, Jon Bomgardner.
+ * This file is licensed under an MIT style license
Jx.Plugin.ToolbarContainer = {};/**
* Class: Jx.Plugin.ToolbarContainer.TabMenu
@@ -33800,7 +34312,7 @@
addButton: function (item) {
var tab;
- tab = (item instanceof Jx.Button.Tab) ? item : document.id(item).getFirst().retrieve('jxTab');
+ tab = (item instanceof Jx.Tab) ? item : document.id(item).getFirst().retrieve('jxTab');
var l = tab.getLabel();
@@ -33808,10 +34320,14 @@
l = '';
var mi = new Jx.Menu.Item({
- label: tab.getLabel(),
+ label: l,
image: tab.options.image,
- tab.setActive(true);
+ if (tab.isActive()) {
+ this.container.scrollIntoView(tab);
+ } else {
+ tab.setActive(true);
}.bind(this)
@@ -33823,62 +34339,82 @@
this.menu.add([mi]);
- * Class: Jx.Adaptor
- * Base class for all adaptor implementations. Provides a place to locate all
- * common code and the Jx.Adaptor namespace. Since it extends <Jx.Plugin> all
- * adaptors will be able to be used as plugins for their respective classes.
- * Also as such, they must have the attach() and detach() methods.
- * Adaptors are specifically used to conform a <Jx.Store> to any one of
- * the different widgets (i.e. Jx.Tree, Jx.ListView, etc...) that could
- * benefit from integration with the store. This approach was taken to minimize
- * data access code in the widgets themselves. Widgets should have no idea where
- * the data/items come from so that they will be usable in the broadest number
- * of situations.
-Jx.Adaptor = new Class({
- Family: 'Jx.Adaptor',
- Extends: Jx.Plugin,
- name: 'Jx.Adaptor',
- options: {
- template: '',
- useTemplate: true,
- store: null
- columnsNeeded: null,
- this.parent();
- this.store = this.options.store;
- if (this.options.useTemplate) {
- this.columnsNeeded = this.store.parseTemplate(this.options.template);
- attach: function (widget) {
- this.parent(widget);
- this.widget = widget;
- detach: function () {
- this.parent();
+ * Class: Jx.Adaptor
+ * Base class for all adaptor implementations. Provides a place to locate all
+ * common code and the Jx.Adaptor namespace. Since it extends <Jx.Plugin> all
+ * adaptors will be able to be used as plugins for their respective classes.
+ * Also as such, they must have the attach() and detach() methods.
+ * Adaptors are specifically used to conform a <Jx.Store> to any one of
+ * the different widgets (i.e. Jx.Tree, Jx.ListView, etc...) that could
+ * benefit from integration with the store. This approach was taken to minimize
+ * data access code in the widgets themselves. Widgets should have no idea where
+ * the data/items come from so that they will be usable in the broadest number
+ * of situations.
+ * Copyright 2010 by Jonathan Bomgardner
+ * License: mit-style
+Jx.Adaptor = new Class({
+ Family: 'Jx.Adaptor',
+ Extends: Jx.Plugin,
+ name: 'Jx.Adaptor',
+ options: {
+ * Option: template
+ * The text template to use in creating the items for this adaptor
+ template: '',
+ * Option: useTemplate
+ * Whether or not to use the text template above. Defaults to true.
+ useTemplate: true,
+ * Option: store
+ * The store to use with the adaptor.
+ store: null
+ * Property: columnsNeeded
+ * Will hold an array of the column names needed for processing the
+ * template
+ columnsNeeded: null,
+ this.parent();
+ this.store = this.options.store;
+ if (this.options.useTemplate && $defined(this.store.getColumns())) {
+ this.columnsNeeded = this.store.parseTemplate(this.options.template);
+ attach: function (widget) {
+ this.parent(widget);
+ this.widget = widget;
+ detach: function () {
+ this.parent();
* Class: Jx.Adaptor.Tree
* This base class is used to change a store (a flat list of records) into the
* data structure needed for a Jx.Tree. It will have 2 subclasses:
- * <Jx.Adapter.Tree.Mptt> and <Jx.Adapter.Tree.Parent>
+ * <Jx.Adapter.Tree.Mptt> and <Jx.Adapter.Tree.Parent>.
Jx.Adaptor.Tree = new Class({
@@ -33889,26 +34425,48 @@
options: {
- * Option: useAjax
- * Determines if this adapter should use ajax to request data on the
- * fly.
+ * Option: monitorFolders
+ * Determines if this adapter should use monitor the TreeFolder items in
+ * order to request any items they should contain if they are empty.
monitorFolders: false,
+ * Option: startingNodeKey
+ * The store primary key to use as the node that we're requesting.
+ * Initially set to -1 to indicate that we're request the first set of
+ * data
startingNodeKey: -1,
- folderOptions: {
- image: null,
- imageClass: null
- itemOptions: {
- image: null,
- imageClass: null
+ * Option: folderOptions
+ * A Hash containing the options for <Jx.TreeFolder>. Defaults to null.
+ folderOptions: null,
+ * Option: itemOptions
+ * A Hash containing the options for <Jx.TreeItem>. Defaults to null.
+ itemOptions: null
+ * Property: folders
+ * A Hash containing all of the <Jx.TreeFolders> in this tree.
folders: new Hash(),
+ * Property: currentRecord
+ * An integer indicating the last position we were at in the store. Used to
+ * allow the adaptor to pick up rendering items after we request additional
+ * data.
currentRecord: -1,
+ * APIMethod: attach
+ * Attaches this adaptor to a specific tree instance.
+ * Parameters:
+ * tree - an instance of <Jx.Tree>
attach: function (tree) {
this.parent(tree);
@@ -33934,12 +34492,18 @@
+ * APIMethod: detach
+ * removes this adaptor from the current tree.
this.parent();
this.store.removeEvent('storeDataLoaded', this.fill);
+ * APIMethod: firstLoad
+ * Method used to start the first store load.
firstLoad: function () {
//initial store load
this.busy = 'tree';
@@ -33999,7 +34563,11 @@
this.currentRecord = l;
+ * Method: checkFolder
+ * Called by the disclose event of the tree to determine if we need to
+ * request additional items for a branch of the tree.
checkFolder: function (folder) {
var items = folder.items();
if (!$defined(items) || items.length === 0) {
@@ -34014,12 +34582,25 @@
+ * Method: hasChildren
+ * Virtual method to be overridden by sublcasses. Determines if a specific
+ * node has any children.
hasChildren: $empty,
+ * Method: hasParent
+ * node has a parent node.
hasParent: $empty,
+ * Method: getParentIndex
+ * Virtual method to be overridden by sublcasses. Determines the store index
+ * of the parent node.
+ getParentIndex: $empty
- getParentIndex: function(){}
@@ -34033,7 +34614,10 @@
* if useAjax option is set to true then this adapter will send an Ajax request
* to the server, through the store's strategy (should be Jx.Store.Strategy.Progressive)
- * to request additional nodes.
+ * to request additional nodes.
Jx.Adaptor.Tree.Mptt = new Class({
@@ -34099,15 +34683,19 @@
* Class: Jx.Adapter.Tree.Parent
* This class adapts a table adhering to the classic Parent-style "tree table".
- * Basically, the store needs to have a column that will indicate each the
+ * Basically, the store needs to have a column that will indicate the
* parent of each row. The root(s) of the tree should be indicated by a "-1"
* in this column. The name of the "parent" column is configurable in the
* options.
- * if useAjax option is set to true then this adapter will send an Ajax request
- * to the server, through the store's strategy (should be Jx.Store.Strategy.Progressive)
- * to request additional nodes. Also, a column indicating whether this is a folder needs
- * to be set as there is no way to tell if a node has children without it.
+ * if the monitorFolders option is set to true then this adapter will send
+ * an Ajax request to the server, through the store's strategy (should be
+ * Jx.Store.Strategy.Progressive) to request additional nodes. Also, a column
+ * indicating whether this is a folder needs to be set as there is no way to
+ * tell if a node has children without it.
Jx.Adaptor.Tree.Parent = new Class({
@@ -34156,7 +34744,108 @@
var pk = this.store.get(this.options.parentColumn, index);
return this.store.findByColumn('primaryKey', pk);
-});// $Id: context.js 663 2009-12-08 07:08:21Z jonlb at comcast.net $
+ * Class: Jx.Adaptor.Combo
+ * The namespace for all combo adaptors
+Jx.Adaptor.Combo = {}
+Jx.Adaptor.Combo.Fill = new Class({
+ Family: 'Jx.Adaptor.Combo.Fill',
+ Extends: Jx.Adaptor,
+ name: 'combo.fill',
+ Binds: ['fill'],
+ * Note: option.template is used for constructing the text for the label
+ options: {
+ * Option: imagePathColumn
+ * points to a store column that holds the image information
+ * for the combo items.
+ imagePathColumn: null,
+ * Option: imageClassColumn
+ * Points to a store column that holds the image class
+ * information for the combo items
+ imageClassColumn: null,
+ * Option: selectedFn
+ * This should be a function that could be run to determine if
+ * an item should be selected. It will get passed the current store
+ * record as the only parameter. It should return either true or false.
+ selectedFn: null,
+ * Option: noRepeats
+ * This option allows you to use any store even if it has duplicate
+ * values in it. With this option set to true the adaptor will keep
+ * track of all of teh labels it adds and will not add anything that's
+ * a duplicate.
+ noRepeats: false
+ labels: null,
+ this.parent();
+ if (this.options.noRepeat) {
+ this.labels = [];
+ attach: function (combo) {
+ this.parent(combo);
+ this.store.addEvent('storeDataLoaded', this.fill);
+ if (this.store.loaded) {
+ this.fill();
+ this.parent();
+ this.store.removeEvent('storeDataLoaded', this.fill);
+ fill: function () {
+ //empty the combo
+ this.widget.empty();
+ //reset the store and cycle through creating the objects
+ //to pass to combo.add()
+ this.store.first();
+ var items = [];
+ this.store.each(function(record){
+ var template = this.store.fillTemplate(record,this.options.template,this.columnsNeeded);
+ if (!this.options.noRepeat || (this.options.noRepeat && !this.labels.contains(template))) {
+ var selected = false;
+ if ($type(this.options.selectedFn) == 'function') {
+ selected = this.options.selectedFn.run(record);
+ var obj = {
+ label: template,
+ image: record.get(this.options.imagePathColumn),
+ imageClass: record.get(this.options.imageClassColumn),
+ selected: selected
+ items.push(obj);
+ this.labels.push(template);
+ },this);
+ //pass all of the objects at once
+ this.widget.add(items);
+});// $Id: context.js 844 2010-04-15 15:42:05Z pagameba $
* Class: Jx.Menu.Context
@@ -34205,6 +34894,8 @@
if (this.list.count() ==0) {
return;
+ this.target = e.target;
this.contentContainer.setStyle('visibility','hidden');
this.contentContainer.setStyle('display','block');
@@ -34224,8 +34915,8 @@
this.contentContainer.setStyle('visibility','');
this.showChrome(this.contentContainer);
- document.addEvent('mousedown', this.bound.mousedown);
- document.addEvent('keyup', this.bound.keypress);
+ document.addEvent('mousedown', this.hide);
+ document.addEvent('keyup', this.keypressHandler);
e.stop();
@@ -34635,17 +35326,225 @@
-});// $Id: tabset.js 825 2010-03-31 18:35:28Z pagameba $
+});// $Id: tab.js 865 2010-04-23 14:09:28Z fred.warnock $
+ * Class: Jx.Tab
+ * Extends: <Jx.Button>
+ * A single tab in a tab set. A tab has a label (displayed in the tab) and a
+ * content area that is displayed when the tab is active. A tab has to be
+ * added to both a <Jx.TabSet> (for the content) and <Jx.Toolbar> (for the
+ * actual tab itself) in order to be useful. Alternately, you can use
+ * a <Jx.TabBox> which combines both into a single control at the cost of
+ * some flexibility in layout options.
+ * A tab is a <Jx.ContentLoader> and you can specify the initial content of
+ * the tab using any of the methods supported by
+ * <Jx.ContentLoader::loadContent>. You can acccess the actual DOM element
+ * that contains the content (if you want to dynamically insert content
+ * for instance) via the <Jx.Tab::content> property.
+ * A tab is a button of type *toggle* which means that it emits the *up*
+ * and *down* events.
+ * Example:
+ * (code)
+ * var tab1 = new Jx.Tab({
+ * label: 'tab 1',
+ * content: 'content1',
+ * onDown: function(tab) {
+ * console.log('tab became active');
+ * onUp: function(tab) {
+ * console.log('tab became inactive');
+ * (end)
+ * License:
+ * Copyright (c) 2008, DM Solutions Group Inc.
+Jx.Tab = new Class({
+ Family: 'Jx.Tab',
+ Extends: Jx.Button,
+ * Property: content
+ * {HTMLElement} The content area that is displayed when the tab is
+ * active.
+ content: null,
+ options: {
+ /* Option: toggleClass
+ * the CSS class to use for the button, 'jxTabToggle' by default
+ toggleClass: 'jxTabToggle',
+ /* Option: pressedClass
+ * the CSS class to use when the tab is pressed, 'jxTabPressed' by
+ * default
+ pressedClass: 'jxTabPressed',
+ /* Option: activeClass
+ * the CSS class to use when the tab is active, 'jxTabActive' by
+ * default.
+ activeClass: 'jxTabActive',
+ /* Option: activeTabClass
+ * the CSS class to use on the content area of the active tab,
+ * 'tabContentActive' by default.
+ activeTabClass: 'tabContentActive',
+ /* Option: template
+ * the HTML template for a tab
+ template: '<span class="jxTabContainer"><a class="jxTab"><span class="jxTabContent"><img class="jxTabIcon" src="'+Jx.aPixel.src+'"><span class="jxTabLabel"></span></span></a><a class="jxTabClose"></span>',
+ /* Option: contentTemplate
+ * the HTML template for a tab's content area
+ contentTemplate: '<div class="tabContent"></div>',
+ /* Option: close
+ * {Boolean} can the tab be closed by the user? False by default.
+ close: false,
+ /* Option: shouldClose
+ * {Mixed} when a tab is closeable, the shouldClose option is checked
+ * first to see if the tab should close. You can provide a function
+ * for this option that can be used to return a boolean value. This
+ * is useful if your tab contains something the user can edit and you
+ * want to see if they want to discard the changes before closing.
+ * The default value is true, meaning the tab will close immediately.
+ * (code)
+ * new Jx.Tab({
+ * label: 'test close',
+ * close: true,
+ * shouldClose: function() {
+ * return window.confirm('Are you sure?');
+ * (end)
+ shouldClose: true
+ * Property: classes
+ * {<Hash>} a hash of object properties to CSS class names used to
+ * automatically extract references to important DOM elements when
+ * processing a widget template. This allows developers to provide custom
+ * HTML structures without affecting the functionality of widgets.
+ classes: new Hash({
+ domObj: 'jxTabContainer',
+ domA: 'jxTab',
+ domImg: 'jxTabIcon',
+ domLabel: 'jxTabLabel',
+ domClose: 'jxTabClose',
+ content: 'tabContent'
+ * Method: render
+ * Create a new instance of Jx.Tab. Any layout options passed are used
+ * to create a <Jx.Layout> for the tab content area.
+ render : function( ) {
+ this.options = $merge(this.options, {toggle:true});
+ this.parent();
+ this.domObj.store('jxTab', this);
+ this.processElements(this.options.contentTemplate, this.classes);
+ new Jx.Layout(this.content, this.options);
+ if(!this.options.loadOnDemand) {
+ this.loadContent(this.content);
+ this.addEvent('down', function(){
+ this.content.addClass(this.options.activeTabClass);
+ }.bind(this));
+ this.addEvent('up', function(){
+ this.content.removeClass(this.options.activeTabClass);
+ }.bind(this));
+ //remove the close button if necessary
+ if (this.domClose) {
+ if (this.options.close) {
+ this.domObj.addClass('jxTabClose');
+ this.domClose.addEvent('click', (function(){
+ var shouldClose = true;
+ if ($defined(this.options.shouldClose)) {
+ if (typeof this.options.shouldClose == 'function') {
+ shouldClose = this.options.shouldClose();
+ } else {
+ shouldClose = this.options.shouldClose;
+ if (shouldClose) {
+ this.fireEvent('close');
+ }).bind(this));
+ } else {
+ this.domClose.dispose();
+ * APIMethod: clicked
+ * triggered when the user clicks the button, processes the
+ * actionPerformed event
+ clicked : function(evt) {
+ if(this.options.enabled) {
+ if((!this.contentIsLoaded && this.options.loadOnDemand) ||
+ this.contentIsLoaded && !this.options.cacheContent ) {
+ this.addEvent('contentLoaded', function(ev) {
+ this.setBusy(false);
+ this.setActive(true);
+ }.bind(this));
+ }else{
+ if(this.contentIsLoaded && this.options.cacheContent) {
+ }else if(this.options.loadOnDemand || !this.options.cacheContent){
+ //this.setBusy(false);
+ }.bind(this));
+ }else{
+/* keep the old location temporarily */
+Jx.Button.Tab = new Class({
+ Extends: Jx.Tab,
+ init: function() {
+ if (console.warn) {
+ console.warn('WARNING: Jx.Button.Tab has been renamed to Jx.Tab');
+ } else {
+ console.log('WARNING: Jx.Button.Tab has been renamed to Jx.Tab');
+ this.parent();
+});// $Id: tabset.js 848 2010-04-16 12:43:31Z pagameba $
* Class: Jx.TabSet
- * A TabSet manages a set of <Jx.Button.Tab> content areas by ensuring that only one
+ * A TabSet manages a set of <Jx.Tab> content areas by ensuring that only one
* of the content areas is visible (i.e. the active tab). TabSet does not
- * manage the actual tabs. The instances of <Jx.Button.Tab> that are to be managed
+ * manage the actual tabs. The instances of <Jx.Tab> that are to be managed
* as a set have to be added to both a TabSet and a <Jx.Toolbar>. The content
- * areas of the <Jx.Button.Tab>s are sized to fit the content area that the TabSet
+ * areas of the <Jx.Tab>s are sized to fit the content area that the TabSet
* is managing.
* Example:
@@ -34653,10 +35552,10 @@
* var tabBar = new Jx.Toolbar('tabBar');
* var tabSet = new Jx.TabSet('tabArea');
- * var tab1 = new Jx.Button.Tab('tab 1', {contentID: 'content1'});
- * var tab2 = new Jx.Button.Tab('tab 2', {contentID: 'content2'});
- * var tab3 = new Jx.Button.Tab('tab 3', {contentID: 'content3'});
- * var tab4 = new Jx.Button.Tab('tab 4', {contentURL: 'test_content.html'});
+ * var tab1 = new Jx.Tab('tab 1', {contentID: 'content1'});
+ * var tab2 = new Jx.Tab('tab 2', {contentID: 'content2'});
+ * var tab3 = new Jx.Tab('tab 3', {contentID: 'content3'});
+ * var tab4 = new Jx.Tab('tab 4', {contentURL: 'test_content.html'});
* tabSet.add(t1, t2, t3, t4);
* tabBar.add(t1, t2, t3, t4);
@@ -34719,7 +35618,7 @@
* Method: add
- * Add one or more <Jx.Button.Tab>s to the TabSet.
+ * Add one or more <Jx.Tab>s to the TabSet.
* Parameters:
* tab - {<Jx.Tab>} an instance of <Jx.Tab> to add to the tab set. More
@@ -34727,7 +35626,7 @@
add: function() {
$A(arguments).flatten().each(function(tab) {
- if (tab instanceof Jx.Button.Tab) {
+ if (tab instanceof Jx.Tab) {
tab.addEvent('down',this.setActiveTabFn);
tab.tabSet = this;
this.domObj.appendChild(tab.content);
@@ -34749,7 +35648,7 @@
* tab - {<Jx.Tab>} the tab to remove.
remove: function(tab) {
- if (tab instanceof Jx.Button.Tab && this.tabs.indexOf(tab) != -1) {
+ if (tab instanceof Jx.Tab && this.tabs.indexOf(tab) != -1) {
this.tabs.erase(tab);
if (this.activeTab == tab) {
if (this.tabs.length) {
@@ -34765,7 +35664,7 @@
* Set the active tab to the one passed to this method
* Parameters:
- * tab - {<Jx.Button.Tab>} the tab to make active.
+ * tab - {<Jx.Tab>} the tab to make active.
setActiveTab: function(tab) {
if (this.activeTab && this.activeTab != tab) {
@@ -34962,7 +35861,7 @@
this.domObj.appendChild(this.domSpan);
-// $Id: tree.js 755 2010-03-15 03:09:37Z jonlb at comcast.net $
+// $Id: tree.js 910 2010-05-20 17:24:49Z pagameba $
* Class: Jx.Tree
@@ -35003,6 +35902,7 @@
* items added to the tree.
list: null,
+ dirty: true,
* APIProperty: domObj
* {HTMLElement} the DOM element that contains the visual representation
@@ -35074,6 +35974,13 @@
this.addTo(this.options.parent);
+ setDirty: function(state) {
+ this.dirty = state;
+ if (state && this.owner && this.owner.setDirty) {
+ this.owner.setDirty(state);
* APIMethod: add
@@ -35101,6 +36008,7 @@
item.setSelection(this.selection);
item.owner = this;
this.list.add(item, position);
+ this.setDirty(true);
return this;
@@ -35120,6 +36028,7 @@
item.owner = null;
item.setSelection(null);
return this;
@@ -35139,6 +36048,7 @@
withItem.setSelection(this.selection);
return this;
@@ -35152,7 +36062,9 @@
this.domObj.dispose();
+ this.setDirty(false);
* Method: update
* Update the CSS of the Tree's DOM element in case it has changed
@@ -35162,7 +36074,6 @@
* shouldDescend - {Boolean} propagate changes to child nodes?
update: function(shouldDescend, isLast) {
if ($defined(isLast)) {
if (isLast) {
this.domObj.removeClass('jxTreeNest');
@@ -35180,6 +36091,7 @@
item.retrieve('jxTreeItem').update(lastItem);
@@ -35206,6 +36118,7 @@
this.remove(item.retrieve('jxTreeItem'));
}, this);
@@ -35269,7 +36182,7 @@
-// $Id: treeitem.js 755 2010-03-15 03:09:37Z jonlb at comcast.net $
+// $Id: treeitem.js 910 2010-05-20 17:24:49Z pagameba $
* Class: Jx.TreeItem
@@ -35362,7 +36275,9 @@
this.domObj = this.elements.get('jxTreeContainer');
this.domObj.store('jxTreeItem', this);
this.domA.store('jxTreeItem', this);
+ if (this.options.contextMenu) {
+ this.domA.store('jxContextMenu', this.options.contextMenu);
/* the target for jxPressed, jxSelected, jxHover classes */
this.domObj.store('jxListTarget', this.domA);
@@ -35389,15 +36304,14 @@
if (this.options.label && this.domLabel) {
- this.domLabel.set('html',this.options.label);
+ this.setLabel(this.options.label);
if (this.domA) {
this.domA.addEvents({
click: this.click.bind(this),
dblclick: this.dblclick.bind(this),
- drag: function(e) { e.stop(); },
- contextmenu: function(e) { e.stop(); }
+ drag: function(e) { e.stop(); }
if (typeof Drag != 'undefined') {
new Drag(this.domA, {
@@ -35410,6 +36324,13 @@
this.enable(this.options.enabled, true);
* Method: finalize
* Clean up the TreeItem and remove all DOM references
@@ -35459,7 +36380,7 @@
select: function() {
if (this.selection && this.options.enabled) {
- this.selection.select(document.id(this));
+ this.selection.select(this.domA);
@@ -35481,7 +36402,8 @@
setLabel: function(label) {
this.options.label = label;
if (this.domLabel) {
- this.domLabel.set('html',label);
+ this.domLabel.set('html',this.getText(label));
@@ -35489,11 +36411,13 @@
if (this.domIcon && $defined(url)) {
this.options.image = url;
this.domIcon.setStyle('backgroundImage', 'url('+this.options.image+')');
if (this.domIcon && $defined(imageClass)) {
this.domIcon.removeClass(this.options.imageClass);
this.options.imageClass = imageClass;
this.domIcon.addClass(imageClass);
enable: function(state, force) {
@@ -35553,9 +36477,13 @@
this.domImg.removeClass(this.options.busyClass);
+ this.parent();
-// $Id: treefolder.js 626 2009-11-20 13:22:22Z pagameba $
+// $Id: treefolder.js 910 2010-05-20 17:24:49Z pagameba $
* Class: Jx.TreeFolder
@@ -35582,7 +36510,7 @@
* {<Jx.Tree>} a Jx.Tree instance for managing the folder contents
tree : null,
options: {
/* Option: open
* is the folder open? false by default.
@@ -35720,21 +36648,24 @@
update: function(shouldDescend,isLast) {
/* avoid update if not attached to tree yet */
if (!this.domObj.parentNode) return;
+ if (this.tree.dirty) {
+ if (!$defined(isLast)) {
+ isLast = this.domObj.hasClass('jxTreeBranchLastOpen') ||
+ this.domObj.hasClass('jxTreeBranchLastClosed');
- if (!$defined(isLast)) {
- isLast = this.domObj.hasClass('jxTreeBranchLastOpen') ||
- this.domObj.hasClass('jxTreeBranchLastClosed');
+ ['jxTreeBranchOpen','jxTreeBranchLastOpen','jxTreeBranchClosed',
+ 'jxTreeBranchLastClosed'].each(function(c){
+ this.removeClass(c);
+ }, this.domObj);
+ var c = 'jxTreeBranch';
+ c += isLast ? 'Last' : '';
+ c += this.options.open ? 'Open' : 'Closed';
+ this.domObj.addClass(c);
- ['jxTreeBranchOpen','jxTreeBranchLastOpen','jxTreeBranchClosed',
- 'jxTreeBranchLastClosed'].each(function(c){
- this.removeClass(c);
- }.bind(this.domObj));
- var c = 'jxTreeBranch';
- c += isLast ? 'Last' : '';
- c += this.options.open ? 'Open' : 'Closed';
- this.domObj.addClass(c);
this.tree.update(shouldDescend, isLast);
@@ -35764,6 +36695,7 @@
expand : function() {
this.options.open = true;
document.id(this.tree).setStyle('display', 'block');
this.update(true);
this.fireEvent('disclosed', this);
return this;
@@ -35778,6 +36710,7 @@
collapse : function() {
this.options.open = false;
document.id(this.tree).setStyle('display', 'none');
this.update(true);
return this;
@@ -35946,7 +36879,7 @@
set: function(value) {
this.slider.set(value);
-});// $Id: notice.js 776 2010-03-22 14:35:16Z pagameba $
+});// $Id: notice.js 892 2010-05-06 21:06:26Z conrad.barthelmes $
* Class: Jx.Notice
@@ -36055,6 +36988,12 @@
document.id(this).dispose();
if (onComplete) onComplete();
+ this.parent();
+ //this.render();
+ //this.processElements(this.options.template, this.classes);
@@ -36479,7 +37418,7 @@
* the needed formatting functionality.
format: $empty
-});// $Id: number.js 770 2010-03-18 21:12:28Z jonlb at comcast.net $
+});// $Id: number.js 892 2010-05-06 21:06:26Z conrad.barthelmes $
* Class: Jx.Formatter.Number
@@ -36567,11 +37506,11 @@
for (var i = 0; i < l; i++) {
ret = ret + main.charAt(i);
if (i === left - 1 && i !== l - 1) {
- ret = ret + MooTools.lang.get('Jx','formatter.number').thousandsSeparator;
+ ret = ret + this.getText({set:'Jx',key:'formatter.number',value:'thousandsSeparator'});
} else if (i >= left) {
j++;
if (j === 3 && i !== l - 1) {
j = 0;
@@ -36582,7 +37521,7 @@
if (dec) {
- ret = ret + MooTools.lang.get('Jx','formatter.number').decimalSeparator + parts[1];
+ ret = ret + this.getText({set:'Jx',key:'formatter.number',value:'decimalSeparator'}) + parts[1];
if (neg && this.options.useParens) {
ret = "(" + ret + ")";
@@ -36605,7 +37544,7 @@
this.parent();
-});// $Id: currency.js 770 2010-03-18 21:12:28Z jonlb at comcast.net $
+});// $Id: currency.js 908 2010-05-19 21:12:06Z conrad.barthelmes $
* Class: Jx.Formatter.Currency
@@ -36644,7 +37583,6 @@
this.options.precision = 2;
value = this.parent(value);
//check for negative
var neg = false;
if (value.contains('(') || value.contains('-')) {
@@ -36653,11 +37591,10 @@
var ret;
if (neg && !this.options.useParens) {
- ret = "-" + MooTools.lang.get('Jx','formatter.currency').sign + value.substring(1, value.length);
+ ret = "-" + this.getText({set:'Jx',key:'formatter.currency',value:'sign'}) + value.substring(1, value.length);
} else {
- ret = MooTools.lang.get('Jx','formatter.currency').sign + value;
+ ret = this.getText({set:'Jx',key:'formatter.currency',value:'sign'}) + value;
return ret;
@@ -36781,7 +37718,7 @@
return this.options.format.substitute(uriContent);
-});// $Id: boolean.js 770 2010-03-18 21:12:28Z jonlb at comcast.net $
+});// $Id: boolean.js 892 2010-05-06 21:06:26Z conrad.barthelmes $
* Class: Jx.Formatter.Boolean
@@ -36836,7 +37773,7 @@
default:
b = true;
- return b ? MooTools.lang.get('Jx','formatter.boolean')['true'] : MooTools.lang.get('Jx','formatter.boolean')['false'];
+ return b ? this.getText({set:'Jx',key:'formatter.boolean',value:'true'}) : this.getText({set:'Jx',key:'formatter.boolean',value:'false'});
@@ -36922,148 +37859,8 @@
ret = ret + v.substring(0, 3) + sep + v.substring(3);
return ret;
-});// $Id: fieldset.js 701 2010-02-25 15:39:38Z pagameba $
+});// $Id: checkbox.js 859 2010-04-20 21:34:00Z jonlb at comcast.net $
- * Class: Jx.Fieldset
- * This class represents a fieldset. It can be used to group fields together.
- * Example:
- * (code)
- * (end)
- * License:
- * Copyright (c) 2009, Jon Bomgardner.
-Jx.Fieldset = new Class({
- Family: 'Jx.Fieldset',
- Extends : Jx.Widget,
- options : {
- * Option: legend
- * The text for the legend of a fieldset. Default is null
- * or no legend.
- legend : null,
- * Option: id
- * The id to assign to this element
- id : null,
- * Option: fieldsetClass
- * A CSS class to assign to the fieldset. Useful for custom styling of
- * the element
- fieldsetClass : null,
- * Option: legendClass
- * A CSS class to assign to the legend. Useful for custom styling of
- * the element
- legendClass : null,
- * Option: template
- * a template for how this element should be rendered
- template : '<fieldset class="jxFieldset"><legend><span class="jxFieldsetLegend"></span></legend></fieldset>',
- * Option: form
- * The <Jx.Form> that this fieldset should be added to
- form : null
- domObj: 'jxFieldset',
- legend: 'jxFieldsetLegend'
- * Property: legend
- * a holder for the legend Element
- legend : null,
- * Creates a fieldset.
- render : function () {
- this.parent();
- this.id = this.options.id;
- if ($defined(this.options.form)
- && this.options.form instanceof Jx.Form) {
- this.form = this.options.form;
- //FIELDSET
- if (this.domObj) {
- if ($defined(this.options.id)) {
- this.domObj.set('id', this.options.id);
- if ($defined(this.options.fieldsetClass)) {
- this.domObj.addClass(this.options.fieldsetClass);
- if (this.legend) {
- if ($defined(this.options.legend)) {
- this.legend.set('html', this.options.legend);
- if ($defined(this.options.legendClass)) {
- this.legend.addClass(this.options.legendClass);
- } else {
- this.legend.destroy();
- * APIMethod: add
- * Adds fields to this fieldset
- * Parameters:
- * pass as many fields to this method as you like. They should be
- * <Jx.Field> objects
- add : function () {
- var field;
- for (var x = 0; x < arguments.length; x++) {
- field = arguments[x];
- //add form to the field and field to the form if not already there
- if ($defined(field.jxFamily) && !$defined(field.form) && $defined(this.form)) {
- field.form = this.form;
- this.form.addField(field);
- this.domObj.grab(field);
- return this;
- * APIMethod: addTo
- addTo: function(what) {
- if (what instanceof Jx.Form) {
- this.form = what;
- } else if (what instanceof Jx.Fieldset) {
- this.form = what.form;
- return this.parent(what);
-// $Id: checkbox.js 826 2010-03-31 18:46:16Z pagameba $
* Class: Jx.Field.Check
* Extends: <Jx.Field>
@@ -37134,6 +37931,13 @@
this.field.set("defaultChecked", "checked");
+ // add click event to the label to toggle the checkbox
+ if(this.label) {
+ this.label.addEvent('click', function(ev) {
+ this.setValue(this.getValue() != null ? false : true)
+ }.bind(this));
@@ -37178,10 +37982,14 @@
} else {
this.field.erase('checked');
+ getChecked: function () {
+ return this.field.get("checked");
-// $Id: radio.js 826 2010-03-31 18:46:16Z pagameba $
+// $Id: radio.js 888 2010-05-04 20:01:16Z conrad.barthelmes $
* Class: Jx.Field.Radio
@@ -37252,6 +38060,12 @@
+ // add click event to toggle the radio buttons
+ this.field.checked ? this.setValue(false) : this.setValue(true);
+ }.bind(this));
@@ -37302,7 +38116,7 @@
-// $Id: select.js 681 2010-01-15 05:45:28Z jonlb at comcast.net $
+// $Id: select.js 836 2010-04-12 13:41:45Z pagameba $
* Class: Jx.Field.Select
@@ -37338,18 +38152,33 @@
options: {
+ * Option: multiple
+ * {Boolean} optional, defaults to false. If true, then the select
+ * will support multi-select
+ mulitple: false,
+ * Option: size
+ * {Integer} optional, defaults to 1. If set, then this specifies
+ * the number of rows of the select that are visible
+ size: 1,
* Option: comboOpts
- * Optional, defaults to null. if not null, this should be an array of objects
- * formated like [{value:'', selected: true|false, text:''},...]
+ * Optional, defaults to null. if not null, this should be an array of
+ * objects formated like [{value:'', selected: true|false,
+ * text:''},...]
comboOpts: null,
* Option: optGroups
- * Optional, defaults to null. if not null this should be an array of objects
- * defining option groups for this select. The comboOpts and optGroups options
- * are mutually exclusive. optGroups will always be shown if defined.
+ * Optional, defaults to null. if not null this should be an array of
+ * objects defining option groups for this select. The comboOpts and
+ * optGroups options are mutually exclusive. optGroups will always be
+ * shown if defined.
- * define them like [{name: '', options: [{value:'', selected: '', text: ''}...]},...]
+ * define them like [{name: '', options: [{value:'', selected: '',
+ * text: ''}...]},...]
optGroups: null,
@@ -37371,6 +38200,12 @@
this.parent();
this.field.addEvent('change', function() {this.fireEvent('change', this);}.bind(this));
+ if ($defined(this.options.multiple)) {
+ this.field.set('multiple', this.options.multiple);
+ if ($defined(this.options.size)) {
+ this.field.set('size', this.options.size);
if ($defined(this.options.optGroups)) {
this.options.optGroups.each(function(group){
var gr = new Element('optGroup');
@@ -37624,7 +38459,7 @@
click: function() {
this.button.clicked();
-});// $Id: jxcombo.js 826 2010-03-31 18:46:16Z pagameba $
+});// $Id: jxcombo.js 900 2010-05-10 16:04:57Z pagameba $
* Class: Jx.Field.Combo
@@ -37646,6 +38481,7 @@
Jx.Field.Combo = new Class({
Family: 'Jx.Field.Combo',
Extends: Jx.Field,
+ pluginNamespace: 'Combo',
options: {
buttonTemplate: '<a class="jxButtonContainer jxButton" href="javascript:void(0);"><img class="jxButtonIcon" src="'+Jx.aPixel.src+'"></a>',
@@ -37689,20 +38525,15 @@
if (img.indexOf('a_pixel') != -1) {
img = '';
- this.setImage(img);
- if (this.options.imageClass && this.icon) {
- this.icon.removeClass(this.options.imageClass);
- if (button.options.imageClass && this.icon) {
- this.options.imageClass = button.options.imageClass;
- this.icon.addClass(button.options.imageClass);
+ this.setImage(img, button.options.imageClass);
}).bind(this)
if (this.options.items) {
this.add(this.options.items);
+ var that = this;
button.addEvent('click', function(e) {
if (this.list.count() === 0) {
return;
@@ -37721,16 +38552,16 @@
- this.position(this.contentContainer, this.button.domObj, {
- horizontal: ['right right'],
+ this.position(this.contentContainer, that.field, {
+ horizontal: ['left left', 'right right'],
vertical: ['bottom top', 'top bottom'],
offsets: this.chromeOffsets
this.fireEvent('show', this);
}.bindWithEvent(this.menu));
@@ -37745,19 +38576,32 @@
this.addEvent('change', function(){
- console.log('on change detected');
+ window.console ? console.log('on change detected') : false;
if ($defined(this.field)) {
- this.field.value = label;
+ this.field.value = this.getText(label);
- setImage: function(url) {
+ setImage: function(url, imageClass) {
if ($defined(this.icon)) {
this.icon.setStyle('background-image', 'url('+url+')');
+ this.icon.setStyle('background-repeat', 'no-repeat');
+ if (this.options.imageClass) {
+ this.icon.removeClass(this.options.imageClass);
+ if (imageClass) {
+ this.options.imageClass = imageClass;
+ this.icon.addClass(imageClass);
+ this.icon.setStyle('background-position','');
+ } else {
+ this.options.imageClass = null;
+ this.icon.setStyle('background-position','center center');
if (!url) {
this.wrapper.addClass('jxInputIconHidden');
@@ -37774,19 +38618,10 @@
- * Method: getValue
- * returns the currently selected value
- getValue: function() {
- return this.options.label;
setValue: function(value) {
+ this.field.set('value', value);
this.buttonSet.buttons.each(function(button){
- if (button.options.label === value) {
- button.setActive(true);
+ button.setActive(button.options.label === value);
},this);
@@ -37887,13 +38722,7 @@
type: 'Password'
- * To change this template, choose Tools | Templates
- * and open the template in the editor.
* Class: Jx.Field.Color
@@ -37902,13 +38731,13 @@
* to have a Colorpicker with an input field.
* License:
- * Copyright (c) 2010, Conrad Barthelmes.
+ * Copyright (c) 2010, Paul Spener, Fred Warnock, Conrad Barthelmes
Jx.Field.Color = new Class({
Extends: Jx.Field,
- Binds: ['changed','hide','keyup'],
+ Binds: ['changed','hide','keyup','changeText'],
type: 'Color',
options: {
@@ -37958,6 +38787,7 @@
this.button = new Jx.Button.Flyout({
template: this.options.buttonTemplate,
imageClass: 'jxInputRevealerIcon',
+ positionElement: this.field,
onBeforeOpen: function() {
if (Jx.Field.Color.ColorPalette.currentButton) {
Jx.Field.Color.ColorPalette.currentButton.hide();
@@ -38019,6 +38849,12 @@
this.icon.setStyle('background-color', this.options.color);
//this.addEvent('change', self.changed);
+ * Method: onKeyUp
+ * listens to the keyup event and validates the input for a hex color
onKeyUp : function(ev) {
var color = this.getValue();
if (color.substring(0,1) == '#') {
@@ -38045,5 +38881,8 @@
this.button.hide();
Jx.Field.Color.ColorPalette.currentButton = null;
+ changeText: function(lang) {
+ this.parent();
More information about the fusion-commits
