[fusion-commits] r2165 - sandbox/jxlib-3.0/widgets
svn_fusion at osgeo.org
Tue May 25 10:59:53 EDT 2010
Author: madair
Date: 2010-05-25 10:59:52 -0400 (Tue, 25 May 2010)
New Revision: 2165
sandbox/jxlib-3.0/widgets/Legend.js
changes to work with mem leak fixes in JxLib
Modified: sandbox/jxlib-3.0/widgets/Legend.js
--- sandbox/jxlib-3.0/widgets/Legend.js 2010-05-20 20:41:30 UTC (rev 2164)
+++ sandbox/jxlib-3.0/widgets/Legend.js 2010-05-25 14:59:52 UTC (rev 2165)
@@ -260,7 +260,7 @@
this.selection = new Jx.Selection({
onSelect: function(item) {
var treeItem = item.retrieve('jxTreeItem');
- var data = treeItem.options.data
+ var data = treeItem.options.data;
if (data instanceof Fusion.Layers.Group) {
this.getMap().setActiveLayer(null);
} else {
@@ -287,21 +287,21 @@
// console.log('showing root folder');
var opt = {
label: OpenLayers.i18n('defaultMapTitle'),
- open: true,
- contextMenu: this.getContextMenu()
+ // contextMenu: this.getContextMenu(),
+ open: true
this.oRoot = new Jx.TreeFolder(opt);
this.oTree.add(this.oRoot);
- this.oRoot.options.contextMenu.add([
- new Jx.Menu.Item({
- label: OpenLayers.i18n('collapse'),
- onClick: OpenLayers.Function.bind(this.collapseBranch, this, this.oRoot)
- label: OpenLayers.i18n('expand'),
- onClick: OpenLayers.Function.bind(this.expandBranch, this, this.oRoot)
+ // this.oRoot.options.contextMenu.add([
+ // new Jx.Menu.Item({
+ // label: OpenLayers.i18n('collapse'),
+ // onClick: OpenLayers.Function.bind(this.collapseBranch, this, this.oRoot)
+ // label: OpenLayers.i18n('expand'),
+ // onClick: OpenLayers.Function.bind(this.expandBranch, this, this.oRoot)
this.extentsChangedWatcher = this.update.bind(this);
@@ -439,22 +439,22 @@
var opt = {
label: group.legendLabel,
open: group.expandInLegend,
- contextMenu: this.getContextMenu(),
checked: group.visible
var treeItem = new Fusion.Widget.Legend.TreeFolder(opt);
treeItem.options.data = group;
group.legend.treeItem = treeItem;
- treeItem.options.contextMenu.add(
- onClick: OpenLayers.Function.bind(this.collapseBranch, this, treeItem)
- onClick: OpenLayers.Function.bind(this.expandBranch, this, treeItem)
+ // treeItem.options.contextMenu.add(
+ // onClick: OpenLayers.Function.bind(this.collapseBranch, this, treeItem)
+ // onClick: OpenLayers.Function.bind(this.expandBranch, this, treeItem)
folder.add(treeItem);
@@ -513,9 +513,33 @@
* remove the dom objects representing the legend layers and groups
clear: function() {
+ console.log('clear legend');
+ var map = this.getMap();
+ for (var i=0; i<map.layerRoot.groups.length; i++) {
+ this.clearGroup(map.layerRoot.groups[i]);
+ for (var i=0; i<map.layerRoot.layers.length; i++) {
+ if (map.layerRoot.layers[i].legend) {
+ map.layerRoot.layers[i].legend.treeItem = null;
+ map.layerRoot.layers[i].legend.checkbox = null;
+ map.layerRoot.layers[i].legend.currentRange = null;
this.oRoot.empty();
+ clearGroup: function(group) {
+ for (var i=0; i<group.groups.length; i++) {
+ this.clearGroup(group.groups[i]);
+ for (var i=0; i<group.layers.length; i++) {
+ if (group.layers[i].legend) {
+ group.layers[i].legend.treeItem = null;
+ group.layers[i].legend.currentRange = null;
updateGroupLayers: function(group, fScale) {
this.updateGroupLayers(group.groups[i], fScale);
@@ -615,23 +639,23 @@
var opt = {
label: layer.legendLabel == '' ? ' ' : layer.legendLabel,
isOpen: layer.expandInLegend,
image: this.imgLayerThemeIcon,
selectable: !layer.metadata.jxUnselectable || (layer.metadata.jxUnselectable && layer.metadata.jxUnselectable != 'true')
var folder = new Fusion.Widget.Legend.TreeFolder(opt);
var img = folder.elements.get('jxTreeIcon');
img.style.backgroundPosition = '0px 0px';
- folder.options.contextMenu.add([
- onClick: OpenLayers.Function.bind(this.collapseBranch, this, folder)
- onClick: OpenLayers.Function.bind(this.expandBranch, this, folder)
+ // folder.options.contextMenu.add([
+ // onClick: OpenLayers.Function.bind(this.collapseBranch, this, folder)
+ // onClick: OpenLayers.Function.bind(this.expandBranch, this, folder)
var layerInfo = layer.oMap.getLayerInfoUrl(layer.layerName);
if (layerInfo) {
@@ -668,7 +692,7 @@
var item;
if (checkbox) {
- opt.contextMenu = this.getContextMenu();
+ // opt.contextMenu = this.getContextMenu();
item = new Fusion.Widget.Legend.TreeItem(opt);
/* only need to add layer info if it has a check box too */
@@ -720,7 +744,7 @@
clearTreeItem: function(layer) {
if (layer.legend.treeItem && layer.legend.treeItem.owner) {
layer.legend.treeItem.owner.remove(layer.legend.treeItem);
- layer.legend.treeItem.finalize();
+ // layer.legend.treeItem.finalize();
layer.legend.treeItem.destroy();
layer.legend.treeItem = null;
@@ -741,32 +765,51 @@
checkbox: 'fusionLegendCheckboxInput',
layerInfo: 'fusionLayerInfo',
layerInfoIcon: 'fusionLayerInfoIcon'
+ init: function() {
+ this.bound.onClick = function(e){
+ if (this.options.data) {
+ if (e.target.checked && this.options.data.show) {
+ this.options.data.show();
+ } else if (!e.target.checked && this.options.data.hide) {
+ this.options.data.hide();
+ }.bind(this);
+ this.bound.enabled = function() {
+ this.checkbox.disabled = false;
+ }.bind(this);
+ this.bound.disabled = function() {
+ this.checkbox.disabled = true;
+ }.bind(this);
+ this.parent();
render: function() {
this.parent();
if (this.checkbox) {
if ($defined(this.options.checked)) {
this.check(this.options.checked);
- this.checkbox.addEvent('click', function(e){
- if (this.options.data) {
- if (e.target.checked && this.options.data.show) {
- this.options.data.show();
- } else if (!e.target.checked && this.options.data.hide) {
- this.options.data.hide();
- }.bind(this));
+ this.checkbox.addEvent('click', this.bound.onClick);
this.addEvents({
- enabled: function() {
- this.checkbox.disabled = false;
- disabled: function() {
- this.checkbox.disabled = true;
+ enabled: this.bound.enabled,
+ disabled: this.bound.disabled
+ cleanup: function() {
+ this.removeEvents({
+ if (this.checkbox) {
+ this.checkbox.removeEvent('click', this.bound.onClick);
+ this.bound.onClick = null;
+ this.bound.enabled = null;
+ this.bound.disabled = null;
+ this.parent();
check: function(state) {
this.checkbox.set('checked', state);
@@ -805,6 +848,24 @@
groupInfo: 'fusionGroupInfo',
groupInfoIcon: 'fusionGroupInfoIcon'
+ }.bind(this);
+ }.bind(this);
+ }.bind(this);
+ this.parent();
this.parent();
@@ -812,25 +873,26 @@
- }.bind(this));
this.addEvents({
+ this.parent();
More information about the fusion-commits
