[fusion-commits] r2171 - sandbox/jxlib-3.0/widgets
svn_fusion at osgeo.org
Fri May 28 11:49:59 EDT 2010
Author: madair
Date: 2010-05-28 11:49:44 -0400 (Fri, 28 May 2010)
New Revision: 2171
sandbox/jxlib-3.0/widgets/SelectAttribute.js
fix error with IE 7 add options to a Select
Modified: sandbox/jxlib-3.0/widgets/SelectAttribute.js
--- sandbox/jxlib-3.0/widgets/SelectAttribute.js 2010-05-28 14:48:54 UTC (rev 2170)
+++ sandbox/jxlib-3.0/widgets/SelectAttribute.js 2010-05-28 15:49:44 UTC (rev 2171)
@@ -69,11 +69,11 @@
//this.layerList.empty();
this.layerList.innerHTML = '';
var map = this.getMap().aMaps[0];
- this.layerList.add(new Option('--select--',''),null);
+ this.layerList.add(new Option('--select--',''),0);
for (var i=0; i<map.aLayers.length; ++i) {
var layer = map.aLayers[i];
if (layer.selectable) {
- this.layerList.add(new Option(layer.legendLabel,layer.layerName),null);
+ this.layerList.add(new Option(layer.legendLabel,layer.layerName),0);
this.layerList.onchange = OpenLayers.Function.bind(this.activateLayer, this);
@@ -108,7 +108,7 @@
var attrs = this.attrs[layer].propertyvalues;
var props = this.attrs[layer].propertynames;
for (var i=0; i<attrs.length; ++i) {
- this.propsList.add(new Option(attrs[i],props[i]),null);
+ this.propsList.add(new Option(attrs[i],props[i]),i);
@@ -142,13 +142,13 @@
this.operatorList = document.createElement('select');
this.operatorList.className = 'operatorSelector';
- this.operatorList.add(new Option("=","eq",true),null);
- this.operatorList.add(new Option("like","like"),null);
- this.operatorList.add(new Option(">","gt"),null);
- this.operatorList.add(new Option("<","lt"),null);
- this.operatorList.add(new Option("<=","le"),null);
- this.operatorList.add(new Option(">=","ge"),null);
- this.operatorList.add(new Option("!=","ne"),null);
+ this.operatorList.add(new Option("=","eq",true),0);
+ this.operatorList.add(new Option("like","like"),0);
+ this.operatorList.add(new Option(">","gt"),0);
+ this.operatorList.add(new Option("<","lt"),0);
+ this.operatorList.add(new Option("<=","le"),0);
+ this.operatorList.add(new Option(">=","ge"),0);
+ this.operatorList.add(new Option("!=","ne"),0);
this.attrRow.appendChild(this.operatorList);
this.attrValue = document.createElement('input');
More information about the fusion-commits
