[fusion-commits] r2177 - sandbox/jxlib-3.0/widgets
svn_fusion at osgeo.org
Mon May 31 16:18:33 EDT 2010
Author: madair
Date: 2010-05-31 16:18:33 -0400 (Mon, 31 May 2010)
New Revision: 2177
sandbox/jxlib-3.0/widgets/MapMenu.js
adding an option to MapMenu.js to allow a map to load at it's max extent setting the initialView to null this time
Modified: sandbox/jxlib-3.0/widgets/MapMenu.js
--- sandbox/jxlib-3.0/widgets/MapMenu.js 2010-05-31 19:56:10 UTC (rev 2176)
+++ sandbox/jxlib-3.0/widgets/MapMenu.js 2010-05-31 20:18:33 UTC (rev 2177)
@@ -103,9 +103,9 @@
processMSMapMenu: function(r) {
if (r.status == 200) {
var o;
- eval("o="+r.responseText);
- //var testData = '{"success":true,"errorMessages":[],"values":[{"sPath":"/ms4w/apps/gmap/cap/HamiltonLowIncome.map","sPermissions":"2","sResourceId":"/Hamilton/Hamilton Low Income","sMapResource":"/Hamilton/hamilton_low_income"},{"sPath":"/mnt/FGS_ENVIRONS/fgs-cap/apps/platform/data/home/root/Canada1.map","sPermissions":"2","sResourceId":"/Canada/Canada1","sMapResource":"/Canada/Canada"}],"request":"listpublishedmaps","version":1}';
- //eval("o="+testData);
+ //eval("o="+r.responseText);
+ var testData = '{"success":true,"errorMessages":[],"values":[{"sPath":"/ms4w/apps/gmap/cap/HamiltonLowIncome.map","sPermissions":"2","sResourceId":"/Hamilton/Hamilton Low Income","sMapResource":"/Hamilton/hamilton_low_income"},{"sPath":"/mnt/FGS_ENVIRONS/fgs-cap/apps/platform/data/home/root/Canada1.map","sPermissions":"2","sResourceId":"/Canada/Canada1","sMapResource":"/Canada/Canada"}],"request":"listpublishedmaps","version":1}';
+ eval("o="+testData);
this.menus = {};
var list = o.values;
if (o.values) {
@@ -223,9 +223,10 @@
//change the map, preserving current extents
switchMap: function(data) {
- var ce = this.getMap().getCurrentExtents();
- var dest = null;
+ data.initialView = null;
if (!this.loadMaxExtent) {
+ var ce = this.getMap().getCurrentExtents();
+ var dest = null;
for (var i=0; i<data.maps.length; ++i) {
if (data.maps[i].layerOptions && data.maps[i].layerOptions.projection) {
dest = new OpenLayers.Projection(data.maps[i].layerOptions.projection);
@@ -238,13 +239,13 @@
dest = new OpenLayers.Projection("EPSG:4326");
ce = ce.transform(this.oMap.oMapOL.getProjectionObject(), dest);
- data.initialView = {minX:ce.left,
+ data.initialView = {minX:ce.left,
minY:ce.bottom,
maxX:ce.right,
maxY:ce.top,
projection: dest
this.getMap().loadMapGroup(data);
More information about the fusion-commits
