[fusion-commits] r2288 - trunk/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Nov 24 14:31:55 EST 2010
Author: madair
Date: 2010-11-24 11:31:55 -0800 (Wed, 24 Nov 2010)
New Revision: 2288
   trunk/widgets/Legend.js
re #416: adding alt and title attributes to legend labels
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js	2010-11-24 03:18:32 UTC (rev 2287)
+++ trunk/widgets/Legend.js	2010-11-24 19:31:55 UTC (rev 2288)
@@ -762,7 +762,7 @@
 Fusion.Widget.Legend.TreeItem = new Class({
     Extends: Jx.TreeItem,
     options: {
-        template: '<li class="jxTreeContainer jxTreeLeaf"><img class="jxTreeImage" src="'+Jx.aPixel.src+'" alt="" title=""><span class="fusionLegendCheckboxContainer"><input type="checkbox" class="fusionLegendCheckboxInput"></span><a class="fusionLayerInfo" target="_blank"><img class="fusionLayerInfoIcon" src="'+Jx.aPixel.src+'"></a><a class="jxTreeItem fusionCheckboxItem" href="javascript:void(0);"><img class="jxTreeIcon" src="'+Jx.aPixel.src+'" alt="" title=""><span class="jxTreeLabel"></span></a></li>'
+        template: '<li class="jxTreeContainer jxTreeLeaf"><img class="jxTreeImage" src="'+Jx.aPixel.src+'" alt="" title=""><span class="fusionLegendCheckboxContainer"><input type="checkbox" class="fusionLegendCheckboxInput"></span><a class="fusionLayerInfo" target="_blank"><img class="fusionLayerInfoIcon" src="'+Jx.aPixel.src+'"></a><a class="jxTreeItem fusionCheckboxItem" href="javascript:void(0);"><img class="jxTreeIcon" src="'+Jx.aPixel.src+'" alt="" title=""><span class="jxTreeLabel" alt="" title=""></span></a></li>'
     classes: new Hash({
         domObj: 'jxTreeContainer',
@@ -794,6 +794,8 @@
     render: function() {
         this.parent();
+        this.domLabel.set('alt', this.options.label);
+        this.domLabel.set('title', this.options.label);
         if (this.checkbox) {
             if ($defined(this.options.checked)) {
                 this.check(this.options.checked);
@@ -841,7 +843,7 @@
 Fusion.Widget.Legend.TreeFolder = new Class({
     Extends: Jx.TreeFolder,
     options: {
-        template: '<li class="jxTreeContainer jxTreeBranch"><img class="jxTreeImage" src="'+Jx.aPixel.src+'" alt="" title=""><span class="fusionLegendCheckboxContainer"><input type="checkbox" class="fusionLegendCheckboxInput"></span><a class="jxTreeItem fusionCheckboxItem" href="javascript:void(0);"><img class="jxTreeIcon" src="'+Jx.aPixel.src+'" alt="" title=""><span class="jxTreeLabel"></span></a><a class="fusionGroupInfo"><img class="fusionGroupInfoIcon" src="'+Jx.aPixel.src+'"></a><a class="fusionLayerInfo"><img class="fusionLayerInfoIcon" src="'+Jx.aPixel.src+'"></a><ul class="jxTree"></ul></li>'
+        template: '<li class="jxTreeContainer jxTreeBranch"><img class="jxTreeImage" src="'+Jx.aPixel.src+'" alt="" title=""><span class="fusionLegendCheckboxContainer"><input type="checkbox" class="fusionLegendCheckboxInput"></span><a class="jxTreeItem fusionCheckboxItem" href="javascript:void(0);"><img class="jxTreeIcon" src="'+Jx.aPixel.src+'" alt="" title=""><span class="jxTreeLabel" alt="" title=""></span></a><a class="fusionGroupInfo"><img class="fusionGroupInfoIcon" src="'+Jx.aPixel.src+'"></a><a class="fusionLayerInfo"><img class="fusionLayerInfoIcon" src="'+Jx.aPixel.src+'"></a><ul class="jxTree"></ul></li>'
     classes: new Hash({
@@ -877,6 +879,8 @@
         this.parent();
More information about the fusion-commits mailing list
