[fusion-commits] r2252 - in trunk: . lib/OpenLayers
svn_fusion at osgeo.org
Tue Oct 19 13:44:10 EDT 2010
Author: madair
Date: 2010-10-19 10:44:10 -0700 (Tue, 19 Oct 2010)
New Revision: 2252
trunk/fusion.cfg
trunk/lib/OpenLayers/OpenLayers.js
adding format version files for WFS capabilities
Modified: trunk/fusion.cfg
--- trunk/fusion.cfg 2010-10-19 14:48:02 UTC (rev 2251)
+++ trunk/fusion.cfg 2010-10-19 17:44:10 UTC (rev 2252)
@@ -45,6 +45,9 @@
OpenLayers/Format/GML/v2.js
OpenLayers/Format/GML/v3.js
OpenLayers/Format/WFSCapabilities.js
+OpenLayers/Format/WFSCapabilities/v1.js
+OpenLayers/Format/WFSCapabilities/v1_0_0.js
+OpenLayers/Format/WFSCapabilities/v1_1_0.js
OpenLayers/Format/WFSDescribeFeatureType.js
OpenLayers/Handler/Box.js
OpenLayers/Handler/Click.js
Modified: trunk/lib/OpenLayers/OpenLayers.js
--- trunk/lib/OpenLayers/OpenLayers.js 2010-10-19 14:48:02 UTC (rev 2251)
+++ trunk/lib/OpenLayers/OpenLayers.js 2010-10-19 17:44:10 UTC (rev 2252)
@@ -25001,6 +25001,136 @@
+ OpenLayers/Format/WFSCapabilities/v1.js
+/* Copyright (c) 2006-2010 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Format/WFSCapabilities.js
+ * Class: OpenLayers.Format.WFSCapabilities.v1
+ * Abstract class not to be instantiated directly.
+ * Inherits from:
+ * - <OpenLayers.Format.XML>
+OpenLayers.Format.WFSCapabilities.v1 = OpenLayers.Class(
+ OpenLayers.Format.WFSCapabilities, {
+ * Constructor: OpenLayers.Format.WFSCapabilities.v1_1
+ * Create an instance of one of the subclasses.
+ * Parameters:
+ * options - {Object} An optional object whose properties will be set on
+ * this instance.
+ initialize: function(options) {
+ OpenLayers.Format.XML.prototype.initialize.apply(this, [options]);
+ this.options = options;
+ * APIMethod: read
+ * Read capabilities data from a string, and return a list of layers.
+ * Parameters:
+ * data - {String} or {DOMElement} data to read/parse.
+ * Returns:
+ * {Array} List of named layers.
+ read: function(data) {
+ if(typeof data == "string") {
+ data = OpenLayers.Format.XML.prototype.read.apply(this, [data]);
+ var capabilities = {};
+ var root = data.documentElement;
+ this.runChildNodes(capabilities, root);
+ return capabilities;
+ * Method: runChildNodes
+ runChildNodes: function(obj, node) {
+ var children = node.childNodes;
+ var childNode, processor;
+ for(var i=0; i<children.length; ++i) {
+ childNode = children[i];
+ if(childNode.nodeType == 1) {
+ processor = this["read_cap_" + childNode.nodeName];
+ if(processor) {
+ processor.apply(this, [obj, childNode]);
+ * Method: read_cap_FeatureTypeList
+ read_cap_FeatureTypeList: function(request, node) {
+ var featureTypeList = {
+ featureTypes: []
+ this.runChildNodes(featureTypeList, node);
+ request.featureTypeList = featureTypeList;
+ read_cap_FeatureType: function(featureTypeList, node, parentLayer) {
+ var featureType = {};
+ this.runChildNodes(featureType, node);
+ featureTypeList.featureTypes.push(featureType);
+ * Method: read_cap_Name
+ read_cap_Name: function(obj, node) {
+ var name = this.getChildValue(node);
+ if(name) {
+ var parts = name.split(":");
+ obj.name = parts.pop();
+ if(parts.length > 0) {
+ obj.featureNS = this.lookupNamespaceURI(node, parts[0]);
+ * Method: read_cap_Title
+ read_cap_Title: function(obj, node) {
+ var title = this.getChildValue(node);
+ if(title) {
+ obj.title = title;
+ * Method: read_cap_Abstract
+ read_cap_Abstract: function(obj, node) {
+ var abst = this.getChildValue(node);
+ if(abst) {
+ obj["abstract"] = abst;
+ CLASS_NAME: "OpenLayers.Format.WFSCapabilities.v1"
@@ -27571,6 +27701,207 @@
CLASS_NAME: "OpenLayers.Control.ZoomBox"
+ OpenLayers/Format/WFSCapabilities/v1_0_0.js
+ * @requires OpenLayers/Format/WFSCapabilities/v1.js
+ * Class: OpenLayers.Format.WFSCapabilities/v1_0_0
+ * Read WMS Capabilities version 1.0.0.
+ * Inherits from:
+ * - <OpenLayers.Format.WFSCapabilities>
+OpenLayers.Format.WFSCapabilities.v1_0_0 = OpenLayers.Class(
+ OpenLayers.Format.WFSCapabilities.v1, {
+ * Constructor: OpenLayers.Format.WFSCapabilities.v1_0_0
+ * Create a new parser for WFS capabilities version 1.0.0.
+ * Parameters:
+ * this instance.
+ OpenLayers.Format.WFSCapabilities.v1.prototype.initialize.apply(
+ this, [options]
+ * Method: read_cap_Service
+ read_cap_Service: function(capabilities, node) {
+ var service = {};
+ this.runChildNodes(service, node);
+ capabilities.service = service;
+ * Method: read_cap_Fees
+ read_cap_Fees: function(service, node) {
+ var fees = this.getChildValue(node);
+ if (fees && fees.toLowerCase() != "none") {
+ service.fees = fees;
+ * Method: read_cap_AccessConstraints
+ read_cap_AccessConstraints: function(service, node) {
+ var constraints = this.getChildValue(node);
+ if (constraints && constraints.toLowerCase() != "none") {
+ service.accessConstraints = constraints;
+ * Method: read_cap_OnlineResource
+ read_cap_OnlineResource: function(service, node) {
+ var onlineResource = this.getChildValue(node);
+ if (onlineResource && onlineResource.toLowerCase() != "none") {
+ service.onlineResource = onlineResource;
+ * Method: read_cap_Keywords
+ read_cap_Keywords: function(service, node) {
+ var keywords = this.getChildValue(node);
+ if (keywords && keywords.toLowerCase() != "none") {
+ service.keywords = keywords.split(', ');
+ * Method: read_cap_Capability
+ read_cap_Capability: function(capabilities, node) {
+ var capability = {};
+ this.runChildNodes(capability, node);
+ capabilities.capability = capability;
+ * Method: read_cap_Request
+ read_cap_Request: function(obj, node) {
+ var request = {};
+ this.runChildNodes(request, node);
+ obj.request = request;
+ * Method: read_cap_GetFeature
+ read_cap_GetFeature: function(request, node) {
+ var getfeature = {
+ href: {}, // DCPType
+ formats: [] // ResultFormat
+ this.runChildNodes(getfeature, node);
+ request.getfeature = getfeature;
+ * Method: read_cap_ResultFormat
+ read_cap_ResultFormat: function(obj, node) {
+ var childNode;
+ for(var i=0; i<children.length; i++) {
+ obj.formats.push(childNode.nodeName);
+ * Method: read_cap_DCPType
+ read_cap_DCPType: function(obj, node) {
+ this.runChildNodes(obj, node);
+ * Method: read_cap_HTTP
+ read_cap_HTTP: function(obj, node) {
+ this.runChildNodes(obj.href, node);
+ read_cap_Get: function(obj, node) {
+ obj.get = node.getAttribute("onlineResource");
+ * Method: read_cap_Post
+ read_cap_Post: function(obj, node) {
+ obj.post = node.getAttribute("onlineResource");
+ CLASS_NAME: "OpenLayers.Format.WFSCapabilities.v1_0_0"
+ OpenLayers/Format/WFSCapabilities/v1_1_0.js
+ * Class: OpenLayers.Format.WFSCapabilities/v1_1_0
+ * Read WFS Capabilities version 1.1.0.
+ * Inherits from:
+OpenLayers.Format.WFSCapabilities.v1_1_0 = OpenLayers.Class(
+ * Constructor: OpenLayers.Format.WFSCapabilities.v1_1_0
+ * Create a new parser for WFS capabilities version 1.1.0.
+ * Parameters:
+ * this instance.
+ this, [options]
+ CLASS_NAME: "OpenLayers.Format.WFSCapabilities.v1_1_0"
OpenLayers/Format/WKT.js
More information about the fusion-commits
