[fusion-commits] r2262 - in branches/fusion-2.2/layers/MapServer: .
php
svn_fusion at osgeo.org
Tue Oct 26 15:44:21 EDT 2010
Author: madair
Date: 2010-10-26 12:44:21 -0700 (Tue, 26 Oct 2010)
New Revision: 2262
branches/fusion-2.2/layers/MapServer/MapServer.js
branches/fusion-2.2/layers/MapServer/php/Query.php
re #410: only pass layers if QueryActiveLayer is set to true; otherwise do the queryByShape action through the map object
Modified: branches/fusion-2.2/layers/MapServer/MapServer.js
--- branches/fusion-2.2/layers/MapServer/MapServer.js 2010-10-26 14:15:22 UTC (rev 2261)
+++ branches/fusion-2.2/layers/MapServer/MapServer.js 2010-10-26 19:44:21 UTC (rev 2262)
@@ -826,7 +826,7 @@
var layers = options.layers || '';
/* if no layes are given, query only visible layers. This is ususally the most common case*/
if (layers == '') {
- layers = this.aVisibleLayers.join(',');
+ //layers = this.aVisibleLayers.join(',');
var zoomTo = options.zoomTo || false;
var sl = Fusion.getScriptLanguage();
Modified: branches/fusion-2.2/layers/MapServer/php/Query.php
--- branches/fusion-2.2/layers/MapServer/php/Query.php 2010-10-26 14:15:22 UTC (rev 2261)
+++ branches/fusion-2.2/layers/MapServer/php/Query.php 2010-10-26 19:44:21 UTC (rev 2262)
@@ -34,6 +34,9 @@
include ("Utilities.php");
include('../../../common/php/Utilities.php');
+header('Content-type: application/json');
+header('X-JSON: true');
/* the name of the layer in the map to query */
if ($_REQUEST['layers'] != '') {
$layers = explode(',',$_REQUEST['layers']);
@@ -54,8 +57,9 @@
$variant = 'inside';
-/* a filter expression to apply, in the form of an FDO SQL statement */
-$filter = isset($_REQUEST['filter']) ? str_replace(array('*', '"'), array('%', "'"),html_entity_decode(urldecode( $_REQUEST['filter']))) : false;
+/* a filter expression to apply, in the form of an MapServer expression statement */
+$filter = isset($_REQUEST['filter']) ? html_entity_decode(urldecode( $_REQUEST['filter'])) : false;
+$filterItem = isset($_REQUEST['filterItem']) ? html_entity_decode(urldecode( $_REQUEST['filterItem'])) : false;
//echo "<!-- filter: $filter -->\n";
/* a spatial filter in the form on a WKT geometry */
$spatialFilter = (isset($_REQUEST['spatialfilter']) && $_REQUEST['spatialfilter'] != '') ? urldecode($_REQUEST['spatialfilter']) : false;
@@ -74,7 +78,7 @@
$versArray = explode(" ",$msVersion);
$versNumber = $versArray[2];
$versParts = explode(".", $versNumber);
-$queryTemplate = "query.qry";
+$queryTemplate = "query.qy";
//convert to an integer value to make the comparison easier
$versValue = $versParts[0]*100 + $versParts[1]*10 + $versParts[2];
if ($versValue >= 522) {
@@ -91,7 +95,7 @@
$bExtendSelection = isset($_REQUEST['extendselection']) && strcasecmp($_REQUEST['extendselection'], 'true') == 0;
if ($bExtendSelection) {
//TODO figure out how to load an existing selection here
- $oMap->loadquery(getSessionSavePath()."query.qry");
+ $oMap->loadquery(getSessionSavePath()."query.qy");
$bComputedProperties = isset($_REQUEST['computed']) && strcasecmp($_REQUEST['computed'], 'true') == 0;
@@ -99,14 +103,78 @@
$bAllLayers = false;
$nLayers = count($layers);
$nSelections = 0;
+$result = NULL;
+$result->hasSelection = false;
+$result->layers = array();
if ($nLayers == 0) {
$nLayers = $oMap->numlayers;
$bAllLayers = true;
+ if ($spatialFilter !== false ) {
+ if (@$oMap->queryByShape($oSpatialFilter) == MS_SUCCESS) {
+ $result->hasSelection = true;
+} else {
+ for ($i=0; $i<$nLayers; $i++) {
+ if (!$bAllLayers) {
+ $oLayer = $oMap->GetLayerByName($layers[$i]);
+ } else {
+ $oLayer = $oMap->GetLayer($i);
+ $oLayer->set('tolerance', 0);
+ if ($oLayer->type == MS_LAYER_RASTER || $oLayer->type == MS_LAYER_QUERY ||
+ $oLayer->type == MS_LAYER_CIRCLE || $oLayer->type == MS_LAYER_CHART) {
+ continue;
+ if (@$oLayer->queryByShape($oSpatialFilter) == MS_SUCCESS) {
+ $layerName = $oLayer->name;
+ array_push($result->layers, $layerName);
+ $result->$layerName->featureCount = $oLayer->getNumResults();
+ //TODO: dump out the extents of the selection
+ if ($filter !== false ) {
+ if ($oLayer->connectiontype == MS_POSTGIS && $filterItem != '') {
+ $f = $filter;
+ $filter = $filterItem . ' IN (' . $filter . ')';
+ if (@$oLayer->queryByAttributes($filterItem,$filter,MS_MULTIPLE) == MS_SUCCESS) {
+ //if (@$oLayer->queryByAttributes($filterItem,'([REG_CODE] eq 61)',MS_MULTIPLE) == MS_SUCCESS) {
+ //if (@$oLayer->queryByAttributes('NAME_E','/.*Buffalo.*/gi',MS_MULTIPLE) == MS_SUCCESS) {
+ $filter = $f;
+ if ($bExtendSelection) {
+ } else {
+if ($bExtendSelection) {
-$result = NULL;
-$result->hasSelection = false;
-$result->layers = array();
+/* Save the query file here before doing any raster queries */
+if ($result->hasSelection) {
+ $oMap->savequery(getSessionSavePath()."query.qy");
+ $result->queryFile = getSessionSavePath()."query.qy";
+/*raster query: limit the result to 100 if it is not already set in the map fle*/
if (!$bAllLayers) {
@@ -114,13 +182,40 @@
- if ($oLayer->type == MS_LAYER_RASTER || $oLayer->type == MS_LAYER_QUERY ||
- $oLayer->type == MS_LAYER_CIRCLE || $oLayer->type == MS_LAYER_CHART) {
+ if ($oLayer->type != MS_LAYER_RASTER)
continue;
+ $aProcessings = $oLayer->getprocessing();
+ $nCount = count($aProcessings);
+ $bRasterMaxSet = 0;
+ for ($i=0;$i<$nCount; $i++)
+ $aKeyVal = explode("=", $aProcessings[$i]);
+ if (count($aKeyVal) == 2 &&
+ strcasecmp(trim($aKeyVal[0]), "RASTER_QUERY_MAX_RESULT") == 0)
+ $bRasterMaxSet = 1;
+ break;
- if (@$oLayer->queryByShape($oSpatialFilter) == MS_SUCCESS) {
+ if (!$bRasterMaxSet)
+ $oLayer->setprocessing("RASTER_QUERY_MAX_RESULT=100");
+ /*are we doing a point query? In that case maxfeatures was set to 1*/
+ /*this is not ideal but It is better to use querybypoint when we do point query and
+ a query by shape when we do other type of queries*/
+ if (isset($_REQUEST['maxfeatures']) && $_REQUEST['maxfeatures'] == '1')
+ $oCenterPoint = ms_newpointobj();
+ $oPoint = $oSpatialFilter->getCentroid();
+ $status = $oLayer->queryByPoint($oPoint, MS_SINGLE, -1);
+ else
+ $status = @$oLayer->queryByShape($oSpatialFilter);
+ if ($status == MS_SUCCESS) {
@@ -132,15 +227,8 @@
} else {
-if ($bExtendSelection) {
-header('Content-type: application/json');
-header('X-JSON: true');
- $oMap->savequery(getSessionSavePath()."query.qry");
- $result->queryFile = getSessionSavePath()."query.qry";
/*holds selection array*/
$properties = NULL;
$properties->layers = array();
@@ -168,7 +256,8 @@
$properties->$layerName->propertyvalues = array();
$properties->$layerName->propertytypes = array();
$properties->$layerName->values = array();
+ $aQueryItems = array();
$properties->$layerName->metadatanames= array();
array_push($properties->$layerName->metadatanames, 'dimension');
array_push($properties->$layerName->metadatanames, 'bbox');
@@ -199,7 +288,7 @@
$token = strtok($tokenSeparator);
// checking if metadata "query_exclude_items" is set
$metadataItems = $oLayer->getMetaData('query_exclude_items');
if ($metadataItems != "") {
More information about the fusion-commits
