[fusion-commits] r2226 - trunk/lib/OpenLayers
svn_fusion at osgeo.org
Fri Sep 10 14:35:41 EDT 2010
Author: madair
Date: 2010-09-10 18:35:41 +0000 (Fri, 10 Sep 2010)
New Revision: 2226
trunk/lib/OpenLayers/OpenLayers.js
closes #406: Update OpenLayers to v2.10
Modified: trunk/lib/OpenLayers/OpenLayers.js
--- trunk/lib/OpenLayers/OpenLayers.js 2010-09-10 17:12:53 UTC (rev 2225)
+++ trunk/lib/OpenLayers/OpenLayers.js 2010-09-10 18:35:41 UTC (rev 2226)
@@ -1,101 +1,102 @@
- OpenLayers.js -- OpenLayers Map Viewer Library
- Copyright 2005-2008 MetaCarta, Inc., released under the Clear BSD license.
- Please see http://svn.openlayers.org/trunk/openlayers/license.txt
- for the full text of the license.
- Includes compressed code under the following licenses:
- (For uncompressed versions of the code used please see the
- OpenLayers SVN repository: <http://openlayers.org/>)
-/* Contains portions of Prototype.js:
- * Prototype JavaScript framework, version 1.4.0
- * (c) 2005 Sam Stephenson <sam at conio.net>
- * Prototype is freely distributable under the terms of an MIT-style license.
- * For details, see the Prototype web site: http://prototype.conio.net/
-* Contains portions of Rico <http://openrico.org/>
-* Copyright 2005 Sabre Airline Solutions
-* Licensed under the Apache License, Version 2.0 (the "License"); you
-* may not use this file except in compliance with the License. You
-* may obtain a copy of the License at
-* http://www.apache.org/licenses/LICENSE-2.0
-* Unless required by applicable law or agreed to in writing, software
-* distributed under the License is distributed on an "AS IS" BASIS,
-* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
-* implied. See the License for the specific language governing
-* permissions and limitations under the License.
- * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
- * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Contains portions of Gears <http://code.google.com/apis/gears/>
- * Copyright 2007, Google Inc.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions are met:
- * 1. Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright notice,
- * this list of conditions and the following disclaimer in the documentation
- * and/or other materials provided with the distribution.
- * 3. Neither the name of Google Inc. nor the names of its contributors may be
- * used to endorse or promote products derived from this software without
- * specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
- * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
- * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
- * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
- * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
- * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
- * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
- * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- * Sets up google.gears.*, which is *the only* supported way to access Gears.
- * Circumvent this file at your own risk!
- * In the future, Gears may automatically define google.gears.* without this
- * file. Gears may use these objects to transparently fix bugs and compatibility
- * issues. Applications that use the code below will continue to work seamlessly
- * when that happens.
+ OpenLayers.js -- OpenLayers Map Viewer Library
+ Copyright 2005-2010 OpenLayers Contributors, released under the Clear BSD
+ license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
+ for the full text of the license.
+ Includes compressed code under the following licenses:
+ (For uncompressed versions of the code used please see the
+ OpenLayers SVN repository: <http://openlayers.org/>)
+/* Contains portions of Prototype.js:
+ * Prototype JavaScript framework, version 1.4.0
+ * (c) 2005 Sam Stephenson <sam at conio.net>
+ * Prototype is freely distributable under the terms of an MIT-style license.
+ * For details, see the Prototype web site: http://prototype.conio.net/
+* Contains portions of Rico <http://openrico.org/>
+* Copyright 2005 Sabre Airline Solutions
+* Licensed under the Apache License, Version 2.0 (the "License"); you
+* may not use this file except in compliance with the License. You
+* may obtain a copy of the License at
+* http://www.apache.org/licenses/LICENSE-2.0
+* Unless required by applicable law or agreed to in writing, software
+* distributed under the License is distributed on an "AS IS" BASIS,
+* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+* implied. See the License for the specific language governing
+* permissions and limitations under the License.
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Contains portions of Gears <http://code.google.com/apis/gears/>
+ * Copyright 2007, Google Inc.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * 3. Neither the name of Google Inc. nor the names of its contributors may be
+ * used to endorse or promote products derived from this software without
+ * specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
+ * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Sets up google.gears.*, which is *the only* supported way to access Gears.
+ * Circumvent this file at your own risk!
+ * In the future, Gears may automatically define google.gears.* without this
+ * file. Gears may use these objects to transparently fix bugs and compatibility
+ * issues. Applications that use the code below will continue to work seamlessly
+ * when that happens.
OpenLayers/SingleFile.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
- * license. See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+/* Copyright (c) 2006-2010 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
* full text of the license. */
var OpenLayers = {
@@ -107,8 +108,9 @@
OpenLayers.js
@@ -216,6 +218,7 @@
"OpenLayers/Layer/EventPane.js",
"OpenLayers/Layer/FixedZoomLevels.js",
"OpenLayers/Layer/Google.js",
+ "OpenLayers/Layer/Google/v3.js",
"OpenLayers/Layer/VirtualEarth.js",
"OpenLayers/Layer/Yahoo.js",
"OpenLayers/Layer/HTTPRequest.js",
@@ -233,6 +236,7 @@
"OpenLayers/Layer/WMS.js",
"OpenLayers/Layer/WMS/Untiled.js",
"OpenLayers/Layer/WMS/Post.js",
+ "OpenLayers/Layer/WMTS.js",
"OpenLayers/Layer/ArcIMS.js",
"OpenLayers/Layer/GeoRSS.js",
"OpenLayers/Layer/Boxes.js",
@@ -287,8 +291,10 @@
"OpenLayers/Control/NavigationHistory.js",
"OpenLayers/Control/Measure.js",
"OpenLayers/Control/WMSGetFeatureInfo.js",
+ "OpenLayers/Control/WMTSGetFeatureInfo.js",
"OpenLayers/Control/Graticule.js",
"OpenLayers/Control/TransformFeature.js",
+ "OpenLayers/Control/SLDSelect.js",
"OpenLayers/Geometry.js",
"OpenLayers/Geometry/Rectangle.js",
"OpenLayers/Geometry/Collection.js",
@@ -309,6 +315,7 @@
"OpenLayers/Layer/Vector.js",
"OpenLayers/Layer/Vector/RootContainer.js",
"OpenLayers/Strategy.js",
+ "OpenLayers/Strategy/Filter.js",
"OpenLayers/Strategy/Fixed.js",
"OpenLayers/Strategy/Cluster.js",
"OpenLayers/Strategy/Paging.js",
@@ -333,10 +340,12 @@
"OpenLayers/Layer/PointTrack.js",
"OpenLayers/Layer/GML.js",
"OpenLayers/Style.js",
+ "OpenLayers/Style2.js",
"OpenLayers/StyleMap.js",
"OpenLayers/Rule.js",
"OpenLayers/Format.js",
"OpenLayers/Format/XML.js",
+ "OpenLayers/Format/Context.js",
"OpenLayers/Format/ArcXML.js",
"OpenLayers/Format/ArcXML/Features.js",
"OpenLayers/Format/GML.js",
@@ -364,6 +373,9 @@
"OpenLayers/Format/SLD.js",
"OpenLayers/Format/SLD/v1.js",
"OpenLayers/Format/SLD/v1_0_0.js",
+ "OpenLayers/Format/OWSCommon/v1.js",
+ "OpenLayers/Format/OWSCommon/v1_0_0.js",
+ "OpenLayers/Format/OWSCommon/v1_1_0.js",
"OpenLayers/Format/CSWGetDomain.js",
"OpenLayers/Format/CSWGetDomain/v2_0_2.js",
"OpenLayers/Format/CSWGetRecords.js",
@@ -387,11 +399,14 @@
"OpenLayers/Format/WMSCapabilities/v1_3.js",
"OpenLayers/Format/WMSCapabilities/v1_3_0.js",
"OpenLayers/Format/WMSGetFeatureInfo.js",
- "OpenLayers/Format/OWSCommon/v1_1_0.js",
"OpenLayers/Format/SOSCapabilities.js",
"OpenLayers/Format/SOSCapabilities/v1_0_0.js",
"OpenLayers/Format/SOSGetObservation.js",
"OpenLayers/Format/SOSGetFeatureOfInterest.js",
+ "OpenLayers/Format/OWSContext.js",
+ "OpenLayers/Format/OWSContext/v0_3_1.js",
+ "OpenLayers/Format/WMTSCapabilities.js",
+ "OpenLayers/Format/WMTSCapabilities/v1_0_0.js",
"OpenLayers/Layer/WFS.js",
"OpenLayers/Control/GetFeature.js",
"OpenLayers/Control/MouseToolbar.js",
@@ -402,6 +417,12 @@
"OpenLayers/Control/ZoomOut.js",
"OpenLayers/Control/ZoomPanel.js",
"OpenLayers/Control/EditingToolbar.js",
+ "OpenLayers/Symbolizer.js",
+ "OpenLayers/Symbolizer/Point.js",
+ "OpenLayers/Symbolizer/Line.js",
+ "OpenLayers/Symbolizer/Polygon.js",
+ "OpenLayers/Symbolizer/Text.js",
+ "OpenLayers/Symbolizer/Raster.js",
"OpenLayers/Lang.js",
"OpenLayers/Lang/en.js"
); // etc.
@@ -434,13 +455,14 @@
* Constant: VERSION_NUMBER
-OpenLayers.VERSION_NUMBER="$Revision$";
+OpenLayers.VERSION_NUMBER="OpenLayers 2.10 -- $Revision$";
OpenLayers/Util.js
@@ -490,7 +512,7 @@
* Maintain existing definition of $.
if(typeof window.$ === "undefined") {
- window.$ = OpenLayers.Util.getElement;
+ //window.$ = OpenLayers.Util.getElement;
@@ -1333,22 +1355,45 @@
OpenLayers.Util.rad = function(x) {return x*Math.PI/180;};
- * Function: distVincenty
+ * Function: deg
+ * Parameters:
+ * x - {Float}
+ * Returns:
+ * {Float}
+OpenLayers.Util.deg = function(x) {return x*180/Math.PI;};
+ * Property: VincentyConstants
+ * {Object} Constants for Vincenty functions.
+OpenLayers.Util.VincentyConstants = {
+ a: 6378137,
+ b: 6356752.3142,
+ f: 1/298.257223563
+ * APIFunction: distVincenty
* Given two objects representing points with geographic coordinates, this
* calculates the distance between those points on the surface of an
* ellipsoid.
* Parameters:
* p1 - {<OpenLayers.LonLat>} (or any object with both .lat, .lon properties)
* p2 - {<OpenLayers.LonLat>} (or any object with both .lat, .lon properties)
* Returns:
* {Float} The distance (in km) between the two input points as measured on an
* ellipsoid. Note that the input point objects must be in geographic
* coordinates (decimal degrees) and the return distance is in kilometers.
-OpenLayers.Util.distVincenty=function(p1, p2) {
- var a = 6378137, b = 6356752.3142, f = 1/298.257223563;
+OpenLayers.Util.distVincenty = function(p1, p2) {
+ var ct = OpenLayers.Util.VincentyConstants;
+ var a = ct.a, b = ct.b, f = ct.f;
var L = OpenLayers.Util.rad(p2.lon - p1.lon);
var U1 = Math.atan((1-f) * Math.tan(OpenLayers.Util.rad(p1.lat)));
var U2 = Math.atan((1-f) * Math.tan(OpenLayers.Util.rad(p2.lat)));
@@ -1387,6 +1432,68 @@
+ * APIFunction: destinationVincenty
+ * Calculate destination point given start point lat/long (numeric degrees),
+ * bearing (numeric degrees) & distance (in m).
+ * Adapted from Chris Veness work, see
+ * http://www.movable-type.co.uk/scripts/latlong-vincenty-direct.html
+ * Parameters:
+ * lonlat - {<OpenLayers.LonLat>} (or any object with both .lat, .lon
+ * properties) The start point.
+ * brng - {Float} The bearing (degrees).
+ * distance - {Float} The ground distance (meters).
+ * Returns:
+ * {<OpenLayers.LonLat>} The destination point.
+OpenLayers.Util.destinationVincenty = function(lonlat, brng, dist) {
+ var u = OpenLayers.Util;
+ var ct = u.VincentyConstants;
+ var lon1 = lonlat.lon;
+ var lat1 = lonlat.lat;
+ var s = dist;
+ var alpha1 = u.rad(brng);
+ var sinAlpha1 = Math.sin(alpha1);
+ var cosAlpha1 = Math.cos(alpha1);
+ var tanU1 = (1-f) * Math.tan(u.rad(lat1));
+ var cosU1 = 1 / Math.sqrt((1 + tanU1*tanU1)), sinU1 = tanU1*cosU1;
+ var sigma1 = Math.atan2(tanU1, cosAlpha1);
+ var sinAlpha = cosU1 * sinAlpha1;
+ var cosSqAlpha = 1 - sinAlpha*sinAlpha;
+ var uSq = cosSqAlpha * (a*a - b*b) / (b*b);
+ var A = 1 + uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));
+ var B = uSq/1024 * (256+uSq*(-128+uSq*(74-47*uSq)));
+ var sigma = s / (b*A), sigmaP = 2*Math.PI;
+ while (Math.abs(sigma-sigmaP) > 1e-12) {
+ var cos2SigmaM = Math.cos(2*sigma1 + sigma);
+ var sinSigma = Math.sin(sigma);
+ var cosSigma = Math.cos(sigma);
+ var deltaSigma = B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)-
+ B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));
+ sigmaP = sigma;
+ sigma = s / (b*A) + deltaSigma;
+ var tmp = sinU1*sinSigma - cosU1*cosSigma*cosAlpha1;
+ var lat2 = Math.atan2(sinU1*cosSigma + cosU1*sinSigma*cosAlpha1,
+ (1-f)*Math.sqrt(sinAlpha*sinAlpha + tmp*tmp));
+ var lambda = Math.atan2(sinSigma*sinAlpha1, cosU1*cosSigma - sinU1*sinSigma*cosAlpha1);
+ var C = f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));
+ var L = lambda - (1-C) * f * sinAlpha *
+ (sigma + C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));
+ var revAz = Math.atan2(sinAlpha, -tmp); // final bearing
+ return new OpenLayers.LonLat(lon1+u.deg(L), u.deg(lat2));
* Function: getParameters
* Parse the parameters from a URL or from the current page itself into a
* JavaScript Object. Note that parameter values with commas are separated
@@ -2126,7 +2233,7 @@
if( coordinatedegrees < 10 ) {
coordinatedegrees = "0" + coordinatedegrees;
- var str = coordinatedegrees + " "; //get degree symbol here somehow for SVG/VML labelling
+ var str = coordinatedegrees + "\u00B0";
if (dmsOption.indexOf('dm') >= 0) {
if( coordinateminutes < 10 ) {
@@ -2154,8 +2261,9 @@
OpenLayers/Console.js
@@ -2403,8 +2511,9 @@
OpenLayers/BaseTypes.js
@@ -2924,7 +3033,7 @@
* Array.prototype.filter extension to the ECMA-262 standard. Where
* available, Array.prototype.filter will be used.
- * Based on well known example from http://developer.mozilla.org/en/docs/Core_JavaScript_1.5_Reference:Objects:Array:filter
+ * Based on well known example from http://developer.mozilla.org/en/Core_JavaScript_1.5_Reference/Global_Objects/Array/filter
* Parameters:
* array - {Array} The array to be filtered. This array is not mutated.
@@ -2964,12 +3073,133 @@
+ * Namespace: OpenLayers.Date
+ * Contains implementations of Date.parse and date.toISOString that match the
+ * ECMAScript 5 specification for parsing RFC 3339 dates.
+ * http://tools.ietf.org/html/rfc3339
+OpenLayers.Date = {
+ * APIMethod: toISOString
+ * Generates a string representing a date. The format of the string follows
+ * the profile of ISO 8601 for date and time on the Internet (see
+ * http://tools.ietf.org/html/rfc3339). If the toISOString method is
+ * available on the Date prototype, that is used. The toISOString
+ * method for Date instances is defined in ECMA-262.
+ * Parameters:
+ * date - {Date} A date object.
+ * Returns:
+ * {String} A string representing the date (e.g.
+ * "2010-08-07T16:58:23.123Z"). If the date does not have a valid time
+ * (i.e. isNaN(date.getTime())) this method returns the string "Invalid
+ * Date". The ECMA standard says the toISOString method should throw
+ * RangeError in this case, but Firefox returns a string instead. For
+ * best results, use isNaN(date.getTime()) to determine date validity
+ * before generating date strings.
+ toISOString: (function() {
+ if ("toISOString" in Date.prototype) {
+ return function(date) {
+ return date.toISOString();
+ } else {
+ function pad(num, len) {
+ var str = num + "";
+ while (str.length < len) {
+ str = "0" + str;
+ return str;
+ var str;
+ if (isNaN(date.getTime())) {
+ // ECMA-262 says throw RangeError, Firefox returns
+ // "Invalid Date"
+ str = "Invalid Date";
+ } else {
+ str =
+ date.getUTCFullYear() + "-" +
+ pad(date.getUTCMonth() + 1, 2) + "-" +
+ pad(date.getUTCDate(), 2) + "T" +
+ pad(date.getUTCHours(), 2) + ":" +
+ pad(date.getUTCMinutes(), 2) + ":" +
+ pad(date.getUTCSeconds(), 2) + "." +
+ pad(date.getUTCMilliseconds(), 3) + "Z";
+ return str;
+ * APIMethod: parse
+ * Generate a date object from a string. The format for the string follows
+ * http://tools.ietf.org/html/rfc3339). If the parse method on
+ * the Date constructor returns a valid date for the given string,
+ * that method is used.
+ * Parameters:
+ * str - {String} A string representing the date (e.g.
+ * "2010", "2010-08", "2010-08-07", "2010-08-07T16:58:23.123Z",
+ * "2010-08-07T11:58:23.123-06").
+ * Returns:
+ * {Date} A date object. If the string could not be parsed, an invalid
+ * date is returned (i.e. isNaN(date.getTime())).
+ parse: function(str) {
+ var date;
+ // first check if the native parse method can parse it
+ var elapsed = Date.parse(str);
+ if (!isNaN(elapsed)) {
+ date = new Date(elapsed);
+ } else {
+ var match = str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/);
+ var date;
+ if (match && (match[1] || match[7])) { // must have at least year or time
+ var year = parseInt(match[1], 10) || 0;
+ var month = (parseInt(match[2], 10) - 1) || 0;
+ var day = parseInt(match[3], 10) || 1;
+ date = new Date(Date.UTC(year, month, day));
+ // optional time
+ var type = match[7];
+ if (type) {
+ var hours = parseInt(match[4], 10);
+ var minutes = parseInt(match[5], 10);
+ var secFrac = parseFloat(match[6]);
+ var seconds = secFrac | 0;
+ var milliseconds = Math.round(1000 * (secFrac - seconds));
+ date.setUTCHours(hours, minutes, seconds, milliseconds);
+ // check offset
+ if (type !== "Z") {
+ var hoursOffset = parseInt(type, 10);
+ var minutesOffset = parseInt(match[8]) || 0;
+ var offset = -1000 * (60 * (hoursOffset * 60) + minutesOffset * 60);
+ date = new Date(date.getTime() + offset);
+ } else {
+ date = new Date("invalid");
+ return date;
OpenLayers/BaseTypes/Class.js
@@ -3005,30 +3235,31 @@
var extended = {};
- var parent, initialize;
+ var parent, initialize, Type;
for(var i=0, len=arguments.length; i<len; ++i) {
- if(typeof arguments[i] == "function") {
+ Type = arguments[i];
+ if(typeof Type == "function") {
// make the class passed as the first argument the superclass
if(i == 0 && len > 1) {
- initialize = arguments[i].prototype.initialize;
+ initialize = Type.prototype.initialize;
// replace the initialize method with an empty function,
// because we do not want to create a real instance here
- arguments[i].prototype.initialize = function() {};
+ Type.prototype.initialize = function() {};
// the line below makes sure that the new class has a
// superclass
- extended = new arguments[i];
+ extended = new Type();
// restore the original initialize method
if(initialize === undefined) {
- delete arguments[i].prototype.initialize;
+ delete Type.prototype.initialize;
} else {
- arguments[i].prototype.initialize = initialize;
+ Type.prototype.initialize = initialize;
// get the prototype of the superclass
- parent = arguments[i].prototype;
+ parent = Type.prototype;
} else {
// in this case we're extending with the prototype
- parent = arguments[i];
+ parent = Type;
OpenLayers.Util.extend(extended, parent);
@@ -3086,8 +3317,9 @@
OpenLayers/BaseTypes/Size.js
@@ -3174,8 +3406,9 @@
OpenLayers/BaseTypes/Bounds.js
@@ -3653,7 +3886,7 @@
* bounds - {<OpenLayers.Bounds>} The target bounds.
* partial - {Boolean} If any of the target corners is within this bounds
- * consider the bounds contained. Default is false. If true, the
+ * consider the bounds contained. Default is false. If false, the
* entire target bounds must be contained within this bounds.
* inclusive - {Boolean} Treat shared edges as contained. Default is
* true.
@@ -3858,8 +4091,9 @@
OpenLayers/BaseTypes/Element.js
@@ -3907,7 +4141,9 @@
hide: function() {
for (var i=0, len=arguments.length; i<len; i++) {
var element = OpenLayers.Util.getElement(arguments[i]);
- element.style.display = 'none';
+ if (element) {
+ element.style.display = 'none';
@@ -3921,7 +4157,9 @@
show: function() {
- element.style.display = '';
+ if (element) {
+ element.style.display = '';
@@ -4108,8 +4346,9 @@
OpenLayers/BaseTypes/LonLat.js
@@ -4202,7 +4441,8 @@
OpenLayers.Console.error(msg);
return null;
- return new OpenLayers.LonLat(this.lon + lon, this.lat + lat);
+ return new OpenLayers.LonLat(this.lon + OpenLayers.Util.toFloat(lon),
+ this.lat + OpenLayers.Util.toFloat(lat));
@@ -4294,15 +4534,15 @@
OpenLayers.LonLat.fromString = function(str) {
var pair = str.split(",");
- return new OpenLayers.LonLat(parseFloat(pair[0]),
- parseFloat(pair[1]));
+ return new OpenLayers.LonLat(pair[0], pair[1]);
OpenLayers/BaseTypes/Pixel.js
@@ -4429,11 +4669,11 @@
OpenLayers/Icon.js
* Class: OpenLayers.Icon
@@ -4660,8 +4900,9 @@
OpenLayers/Popup.js
@@ -5715,8 +5956,9 @@
OpenLayers/Protocol.js
@@ -5774,20 +6016,18 @@
* filter - {OpenLayers.Filter}
mergeWithDefaultFilter: function(filter) {
- if(filter) {
- if(this.defaultFilter) {
- filter = new OpenLayers.Filter.Logical({
- type: OpenLayers.Filter.Logical.AND,
- filters: [this.defaultFilter, filter]
+ var merged;
+ if (filter && this.defaultFilter) {
+ merged = new OpenLayers.Filter.Logical({
+ type: OpenLayers.Filter.Logical.AND,
+ filters: [this.defaultFilter, filter]
} else {
- filter = this.defaultFilter;
+ merged = filter || this.defaultFilter || undefined;
- return filter;
+ return merged;
* APIMethod: destroy
* Clean up the protocol.
@@ -5992,8 +6232,9 @@
OpenLayers/Renderer.js
@@ -6259,8 +6500,9 @@
features = [features];
for(var i=0, len=features.length; i<len; ++i) {
- this.eraseGeometry(features[i].geometry);
- this.removeText(features[i].id);
+ var feature = features[i];
+ this.eraseGeometry(feature.geometry, feature.id);
+ this.removeText(feature.id);
@@ -6271,8 +6513,9 @@
* Parameters:
* geometry - {<OpenLayers.Geometry>}
+ * featureId - {String}
- eraseGeometry: function(geometry) {},
+ eraseGeometry: function(geometry, featureId) {},
* Method: moveRoot
@@ -6297,15 +6540,67 @@
getRenderLayerId: function() {
return this.container.id;
+ * Method: applyDefaultSymbolizer
+ * Parameters:
+ * symbolizer - {Object}
+ * Returns:
+ * {Object}
+ applyDefaultSymbolizer: function(symbolizer) {
+ var result = OpenLayers.Util.extend({},
+ OpenLayers.Renderer.defaultSymbolizer);
+ if(symbolizer.stroke === false) {
+ delete result.strokeWidth;
+ delete result.strokeColor;
+ if(symbolizer.fill === false) {
+ delete result.fillColor;
+ OpenLayers.Util.extend(result, symbolizer);
+ return result;
CLASS_NAME: "OpenLayers.Renderer"
+ * Constant: OpenLayers.Renderer.defaultSymbolizer
+ * {Object} Properties from this symbolizer will be applied to symbolizers
+ * with missing properties. This can also be used to set a global
+ * symbolizer default in OpenLayers. To be SLD 1.x compliant, add the
+ * following code before rendering any vector features:
+ * (code)
+ * OpenLayers.Renderer.defaultSymbolizer = {
+ * fillColor: "#808080",
+ * fillOpacity: 1,
+ * strokeColor: "#000000",
+ * strokeOpacity: 1,
+ * strokeWidth: 1,
+ * pointRadius: 3,
+ * graphicName: "square"
+ * (end)
+OpenLayers.Renderer.defaultSymbolizer = {
+ fillColor: "#000000",
+ strokeColor: "#000000",
+ strokeWidth: 2,
+ fillOpacity: 1,
+ strokeOpacity: 1,
+ pointRadius: 0
@@ -6421,11 +6716,67 @@
CLASS_NAME: "OpenLayers.Strategy"
+ OpenLayers/Symbolizer.js
+ * full text of the license. */
+ * Class: OpenLayers.Symbolizer
+ * Base class representing a symbolizer used for feature rendering.
+OpenLayers.Symbolizer = OpenLayers.Class({
+ * APIProperty: zIndex
+ * {Number} The zIndex determines the rendering order for a symbolizer.
+ * Symbolizers with larger zIndex values are rendered over symbolizers
+ * with smaller zIndex values. Default is 0.
+ zIndex: 0,
+ * Constructor: OpenLayers.Symbolizer
+ * Instances of this class are not useful. See one of the subclasses.
+ * Parameters:
+ * config - {Object} An object containing properties to be set on the
+ * symbolizer. Any documented symbolizer property can be set at
+ * construction.
+ * Returns:
+ * A new symbolizer.
+ initialize: function(config) {
+ OpenLayers.Util.extend(this, config);
+ * APIMethod: clone
+ * Create a copy of this symbolizer.
+ * Returns a symbolizer of the same type with the same properties.
+ clone: function() {
+ var Type = eval(this.CLASS_NAME);
+ return new Type(OpenLayers.Util.extend({}, this));
+ CLASS_NAME: "OpenLayers.Symbolizer"
OpenLayers/Control.js
@@ -6502,9 +6853,9 @@
* Property: type
- * {OpenLayers.Control.TYPES} Controls can have a 'type'. The type
- * determines the type of interactions which are possible with them when
- * they are placed into a toolbar.
+ * {Number} Controls can have a 'type'. The type determines the type of
+ * interactions which are possible with them when they are placed in an
+ * <OpenLayers.Control.Panel>.
type: null,
@@ -6777,15 +7128,27 @@
CLASS_NAME: "OpenLayers.Control"
+ * Constant: OpenLayers.Control.TYPE_BUTTON
OpenLayers.Control.TYPE_BUTTON = 1;
+ * Constant: OpenLayers.Control.TYPE_TOGGLE
OpenLayers.Control.TYPE_TOGGLE = 2;
+ * Constant: OpenLayers.Control.TYPE_TOOL
OpenLayers.Control.TYPE_TOOL = 3;
OpenLayers/Lang.js
@@ -6920,8 +7283,9 @@
OpenLayers/Popup/Anchored.js
@@ -7107,10 +7471,10 @@
var size = this.size || this.contentSize;
var top = (this.relativePosition.charAt(0) == 't');
- newPx.y += (top) ? -size.h : this.anchor.size.h;
+ newPx.y += (top) ? -(size.h + this.anchor.size.h) : this.anchor.size.h;
var left = (this.relativePosition.charAt(1) == 'l');
- newPx.x += (left) ? -size.w : this.anchor.size.w;
+ newPx.x += (left) ? -(size.w + this.anchor.size.w) : this.anchor.size.w;
return newPx;
@@ -7121,8 +7485,9 @@
OpenLayers/Renderer/Canvas.js
@@ -7151,14 +7516,6 @@
features: null,
- * Property: geometryMap
- * {Object} Geometry -> Feature lookup table. Used by eraseGeometry to
- * lookup features to remove from our internal table (this.features)
- * when erasing geoms.
- geometryMap: null,
* Constructor: OpenLayers.Renderer.Canvas
* Parameters:
@@ -7170,7 +7527,6 @@
this.container.appendChild(this.root);
this.canvas = this.root.getContext("2d");
this.features = {};
- this.geometryMap = {};
@@ -7181,9 +7537,10 @@
* Parameters:
- this.eraseFeatures(this.features[this.geometryMap[geometry.id]][0]);
+ this.eraseFeatures(this.features[featureId][0]);
@@ -7241,20 +7598,10 @@
* style - {<Object>}
drawFeature: function(feature, style) {
- if(style == null) {
- style = feature.style;
- style = OpenLayers.Util.extend({
- 'fillColor': '#000000',
- 'strokeColor': '#000000',
- 'strokeWidth': 2,
- 'fillOpacity': 1,
- 'strokeOpacity': 1
- }, style);
+ style = style || feature.style;
+ style = this.applyDefaultSymbolizer(style);
this.features[feature.id] = [feature, style];
- if (feature.geometry) {
- this.geometryMap[feature.geometry.id] = feature.id;
this.redraw();
@@ -7278,7 +7625,7 @@
this.drawGeometry(geometry.components[i], style);
return;
switch (geometry.CLASS_NAME) {
case "OpenLayers.Geometry.Point":
this.drawPoint(geometry, style);
@@ -7307,7 +7654,6 @@
drawExternalGraphic: function(pt, style) {
var img = new Image();
- img.src = style.externalGraphic;
if(style.graphicTitle) {
img.title=style.graphicTitle;
@@ -7321,19 +7667,21 @@
style.graphicXOffset : -(0.5 * width);
var yOffset = (style.graphicYOffset != undefined) ?
style.graphicYOffset : -(0.5 * height);
- var opacity = style.graphicOpacity || style.fillOpacity;
var context = { img: img,
x: (pt[0]+xOffset),
y: (pt[1]+yOffset),
width: width,
height: height,
+ opacity: style.graphicOpacity || style.fillOpacity,
canvas: this.canvas };
img.onload = OpenLayers.Function.bind( function() {
+ this.canvas.globalAlpha = this.opacity;
this.canvas.drawImage(this.img, this.x,
this.y, this.width, this.height);
- }, context);
+ }, context);
+ img.src = style.externalGraphic;
@@ -7436,7 +7784,6 @@
if(style.stroke !== false) {
- var oldWidth = this.canvas.lineWidth;
this.setCanvasStyle("stroke", style);
this.canvas.beginPath();
var start = this.getLocalXY(geometry.components[0]);
@@ -7535,14 +7882,14 @@
var y = ((extent.top / resolution) - point.y / resolution);
return [x, y];
* Method: clear
* Clear all vectors from the renderer.
- * virtual function.
clear: function() {
this.canvas.clearRect(0, 0, this.root.width, this.root.height);
+ this.features = {};
@@ -7600,7 +7947,7 @@
redraw: function() {
if (!this.locked) {
- this.clear();
+ this.canvas.clearRect(0, 0, this.root.width, this.root.height);
var labelMap = [];
var feature, style;
for (var id in this.features) {
@@ -7614,7 +7961,7 @@
var item;
- for (var i=0; len=labelMap.length, i<len; ++i) {
+ for (var i=0, len=labelMap.length; i<len; ++i) {
item = labelMap[i];
this.drawText(item[0].geometry.getCentroid(), item[1]);
@@ -7636,8 +7983,9 @@
OpenLayers/Renderer/Elements.js
@@ -8033,18 +8381,6 @@
LABEL_ID_SUFFIX: "_label",
- * Property: minimumSymbolizer
- * {Object}
- minimumSymbolizer: {
- strokeLinecap: "round",
- strokeOpacity: 1,
- strokeDashstyle: "solid",
- fillOpacity: 1,
- pointRadius: 0
* Constructor: OpenLayers.Renderer.Elements
* Parameters:
@@ -8092,14 +8428,17 @@
* Remove all the elements from the root
clear: function() {
- if (this.vectorRoot) {
- while (this.vectorRoot.childNodes.length > 0) {
- this.vectorRoot.removeChild(this.vectorRoot.firstChild);
+ var child;
+ var root = this.vectorRoot;
+ if (root) {
+ while (child = root.firstChild) {
+ root.removeChild(child);
- if (this.textRoot) {
- while (this.textRoot.childNodes.length > 0) {
- this.textRoot.removeChild(this.textRoot.firstChild);
+ root = this.textRoot;
+ if (root) {
if (this.indexer) {
@@ -8190,6 +8529,7 @@
* the geometry could not be drawn, false otherwise
redrawNode: function(id, geometry, style, featureId) {
// Get the node if it's already on the map.
var node = this.nodeFactory(id, this.getNodeType(geometry, style));
@@ -8293,7 +8633,6 @@
drawGeometryNode: function(node, geometry, style) {
style = style || node._style;
- OpenLayers.Util.applyDefaults(style, this.minimumSymbolizer);
var options = {
'isFilled': style.fill === undefined ?
@@ -8505,14 +8844,15 @@
* Parameters:
if ((geometry.CLASS_NAME == "OpenLayers.Geometry.MultiPoint") ||
(geometry.CLASS_NAME == "OpenLayers.Geometry.MultiLineString") ||
(geometry.CLASS_NAME == "OpenLayers.Geometry.MultiPolygon") ||
(geometry.CLASS_NAME == "OpenLayers.Geometry.Collection")) {
for (var i=0, len=geometry.components.length; i<len; i++) {
- this.eraseGeometry(geometry.components[i]);
+ this.eraseGeometry(geometry.components[i], featureId);
} else {
var element = OpenLayers.Util.getElement(geometry.id);
@@ -8657,8 +8997,9 @@
@@ -8795,11 +9136,422 @@
CLASS_NAME: "OpenLayers.Strategy.Fixed"
+ OpenLayers/Symbolizer/Line.js
+ * @requires OpenLayers/Symbolizer.js
+ * Class: OpenLayers.Symbolizer.Line
+ * A symbolizer used to render line features.
+OpenLayers.Symbolizer.Line = OpenLayers.Class(OpenLayers.Symbolizer, {
+ * APIProperty: strokeColor
+ * {String} Color for line stroke. This is a RGB hex value (e.g. "#ff0000"
+ * for red).
+ strokeColor: null,
+ * APIProperty: strokeOpacity
+ * {Number} Stroke opacity (0-1).
+ strokeOpacity: null,
+ * APIProperty: strokeWidth
+ * {Number} Pixel stroke width.
+ strokeWidth: null,
+ * APIProperty: strokeLinecap
+ * {String} Stroke cap type ("butt", "round", or "square").
+ strokeLinecap: null,
+ * Property: strokeDashstyle
+ * {String} Stroke dash style according to the SLD spec. Note that the
+ * OpenLayers values for strokeDashstyle ("dot", "dash", "dashdot",
+ * "longdash", "longdashdot", or "solid") will not work in SLD, but
+ * most SLD patterns will render correctly in OpenLayers.
+ strokeDashstyle: null,
+ * Constructor: OpenLayers.Symbolizer.Line
+ * Create a symbolizer for rendering lines.
+ * Parameters:
+ * construction.
+ * Returns:
+ * A new line symbolizer.
+ OpenLayers.Symbolizer.prototype.initialize.apply(this, arguments);
+ CLASS_NAME: "OpenLayers.Symbolizer.Line"
+ OpenLayers/Symbolizer/Point.js
+ * Class: OpenLayers.Symbolizer.Point
+ * A symbolizer used to render point features.
+OpenLayers.Symbolizer.Point = OpenLayers.Class(OpenLayers.Symbolizer, {
+ * for red).
+ * APIProperty: fillColor
+ * {String} RGB hex fill color (e.g. "#ff0000" for red).
+ fillColor: null,
+ * APIProperty: fillOpacity
+ * {Number} Fill opacity (0-1).
+ fillOpacity: null,
+ * APIProperty: pointRadius
+ * {Number} Pixel point radius.
+ pointRadius: null,
+ * APIProperty: externalGraphic
+ * {String} Url to an external graphic that will be used for rendering
+ * points.
+ externalGraphic: null,
+ * APIProperty: graphicWidth
+ * {Number} Pixel width for sizing an external graphic.
+ graphicWidth: null,
+ * APIProperty: graphicHeight
+ * {Number} Pixel height for sizing an external graphic.
+ graphicHeight: null,
+ * APIProperty: graphicOpacity
+ * {Number} Opacity (0-1) for an external graphic.
+ graphicOpacity: null,
+ * APIProperty: graphicXOffset
+ * {Number} Pixel offset along the positive x axis for displacing an
+ * external graphic.
+ graphicXOffset: null,
+ * APIProperty: graphicYOffset
+ * {Number} Pixel offset along the positive y axis for displacing an
+ graphicYOffset: null,
+ * APIProperty: rotation
+ * {Number} The rotation of a graphic in the clockwise direction about its
+ * center point (or any point off center as specified by
+ * <graphicXOffset> and <graphicYOffset>).
+ rotation: null,
+ * APIProperty: graphicName
+ * {String} Named graphic to use when rendering points. Supported values
+ * include "circle", "square", "star", "x", "cross", and "triangle".
+ graphicName: null,
+ * Constructor: OpenLayers.Symbolizer.Point
+ * Create a symbolizer for rendering points.
+ * Parameters:
+ * construction.
+ * Returns:
+ * A new point symbolizer.
+ CLASS_NAME: "OpenLayers.Symbolizer.Point"
+ OpenLayers/Symbolizer/Polygon.js
+ * Class: OpenLayers.Symbolizer.Polygon
+OpenLayers.Symbolizer.Polygon = OpenLayers.Class(OpenLayers.Symbolizer, {
+ * for red).
+ fillColor: null,
+ * Constructor: OpenLayers.Symbolizer.Polygon
+ * Create a symbolizer for rendering polygons.
+ * Parameters:
+ * construction.
+ * Returns:
+ * A new polygon symbolizer.
+ CLASS_NAME: "OpenLayers.Symbolizer.Polygon"
+ OpenLayers/Symbolizer/Raster.js
+ * Class: OpenLayers.Symbolizer.Raster
+ * A symbolizer used to render raster images.
+OpenLayers.Symbolizer.Raster = OpenLayers.Class(OpenLayers.Symbolizer, {
+ * Constructor: OpenLayers.Symbolizer.Raster
+ * Create a symbolizer for rendering rasters.
+ * Parameters:
+ * construction.
+ * Returns:
+ * A new raster symbolizer.
+ CLASS_NAME: "OpenLayers.Symbolizer.Raster"
+ OpenLayers/Symbolizer/Text.js
+ * Class: OpenLayers.Symbolizer.Text
+ * A symbolizer used to render text labels for features.
+OpenLayers.Symbolizer.Text = OpenLayers.Class(OpenLayers.Symbolizer, {
+ * APIProperty: label
+ * {String} The text for the label.
+ label: null,
+ * APIProperty: fontFamily
+ * {String} The font family for the label.
+ fontFamily: null,
+ * APIProperty: fontSize
+ * {String} The font size for the label.
+ fontSize: null,
+ * APIProperty: fontWeight
+ * {String} The font weight for the label.
+ fontWeight: null,
+ * Property: fontStyle
+ * {String} The font style for the label.
+ fontStyle: null,
+ * Constructor: OpenLayers.Symbolizer.Text
+ * Create a symbolizer for rendering text labels.
+ * Parameters:
+ * construction.
+ * Returns:
+ * A new text symbolizer.
+ CLASS_NAME: "OpenLayers.Symbolizer.Text"
OpenLayers/Tween.js
@@ -8948,12 +9700,7 @@
if (this.time > this.duration) {
- if (this.callbacks && this.callbacks.done) {
- this.callbacks.done.call(this, this.finish);
- this.playing = false;
- window.clearInterval(this.interval);
- this.interval = null;
+ this.stop();
@@ -9124,8 +9871,9 @@
OpenLayers/Control/ArgParser.js
@@ -9293,8 +10041,9 @@
OpenLayers/Control/PanZoom.js
@@ -9542,9 +10291,10 @@
OpenLayers/Control/ScaleLine.js
-/* Copyright (c) 2006-2007 MetaCarta, Inc., published under a modified BSD license.
- * See http://svn.openlayers.org/trunk/openlayers/repository-license.txt
- * for the full text of the license. */
* @requires OpenLayers/Control.js
@@ -9608,7 +10358,10 @@
* APIProperty: geodesic
- * {Boolean} Use geodesic measurement. Default is false.
+ * {Boolean} Use geodesic measurement. Default is false. The recommended
+ * setting for maps in EPSG:4326 is false, and true EPSG:900913. If set to
+ * true, the scale will be calculated based on the horizontal size of the
+ * pixel in the center of the map viewport.
geodesic: false,
@@ -9709,7 +10462,8 @@
var maxSizeData = this.maxWidth * res * inches[curMapUnits];
var geodesicRatio = 1;
if(this.geodesic === true) {
- var maxSizeGeodesic = this.getGeodesicLength(this.maxWidth);
+ var maxSizeGeodesic = (this.map.getGeodesicPixelSize().w ||
+ 0.000001) * this.maxWidth;
var maxSizeKilometers = maxSizeData / inches["km"];
geodesicRatio = maxSizeGeodesic / maxSizeKilometers;
maxSizeData *= geodesicRatio;
@@ -9757,26 +10511,6 @@
- * Method: getGeodesicLength
- * Parameters:
- * pixels - {Number} the pixels to get the geodesic length in meters for.
- getGeodesicLength: function(pixels) {
- var map = this.map;
- var centerPx = map.getPixelFromLonLat(map.getCenter());
- var bottom = map.getLonLatFromPixel(centerPx.add(0, -pixels / 2));
- var top = map.getLonLatFromPixel(centerPx.add(0, pixels / 2));
- var source = map.getProjectionObject();
- var dest = new OpenLayers.Projection("EPSG:4326");
- if(!source.equals(dest)) {
- bottom.transform(source, dest);
- top.transform(source, dest);
- return OpenLayers.Util.distVincenty(bottom, top);
CLASS_NAME: "OpenLayers.Control.ScaleLine"
@@ -9784,8 +10518,9 @@
OpenLayers/Events.js
@@ -10642,8 +11377,9 @@
@@ -10768,10 +11504,6 @@
- * full text of the license. */
* @requires OpenLayers/Lang.js
@@ -10857,6 +11589,7 @@
'E': 'E',
'N': 'N',
'S': 'S',
+ 'graticule': 'Graticule',
// console message
'layerAlreadyAdded':
@@ -10891,18 +11624,21 @@
// console message
'pagePositionFailed':
"OpenLayers.Util.pagePosition failed: element with id ${elemId} may be misplaced.",
- 'end': '',
// console message
- 'filterEvaluateNotImplemented': "evaluate is not implemented for this filter type."
+ 'filterEvaluateNotImplemented': "evaluate is not implemented for this filter type.",
+ // **** end ****
+ 'end': ''
OpenLayers/Popup/AnchoredBubble.js
@@ -11094,9 +11830,10 @@
OpenLayers/Projection.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under a modified BSD license.
* @requires OpenLayers/Util.js
@@ -11275,8 +12012,9 @@
OpenLayers/Renderer/SVG.js
@@ -11550,7 +12288,7 @@
} else if (style.externalGraphic) {
pos = this.getPosition(node);
- if (style.graphicTitle) {
+ if (style.graphicTitle) {
node.setAttributeNS(null, "title", style.graphicTitle);
if (style.graphicWidth && style.graphicHeight) {
@@ -11625,7 +12363,7 @@
"rotate(" + rotation + " " + pos.x + " " +
pos.y + ")");
} else {
- var metrics = this.symbolMetrics[id]
+ var metrics = this.symbolMetrics[id];
node.firstChild.setAttributeNS(null, "transform",
"rotate(" + style.rotation + " " + metrics[1] +
" " + metrics[2] + ")");
@@ -11644,12 +12382,12 @@
node.setAttributeNS(null, "stroke", style.strokeColor);
node.setAttributeNS(null, "stroke-opacity", style.strokeOpacity);
node.setAttributeNS(null, "stroke-width", style.strokeWidth * widthFactor);
- node.setAttributeNS(null, "stroke-linecap", style.strokeLinecap);
+ node.setAttributeNS(null, "stroke-linecap", style.strokeLinecap || "round");
// Hard-coded linejoin for now, to make it look the same as in VML.
// There is no strokeLinejoin property yet for symbolizers.
node.setAttributeNS(null, "stroke-linejoin", "round");
- node.setAttributeNS(null, "stroke-dasharray", this.dashStyle(style,
- widthFactor));
+ style.strokeDashstyle && node.setAttributeNS(null,
+ "stroke-dasharray", this.dashStyle(style, widthFactor));
} else {
node.setAttributeNS(null, "stroke", "none");
@@ -11657,7 +12395,7 @@
if (style.pointerEvents) {
node.setAttributeNS(null, "pointer-events", style.pointerEvents);
if (style.cursor != null) {
node.setAttributeNS(null, "cursor", style.cursor);
@@ -12044,7 +12782,7 @@
var complete = true;
var len = components.length;
var strings = [];
- var str, component, j;
+ var str, component;
for(var i=0; i<len; i++) {
component = components[i];
renderCmp.push(component);
@@ -12183,7 +12921,6 @@
var symbol = OpenLayers.Renderer.symbol[graphicName];
if (!symbol) {
throw new Error(graphicName + ' is not a valid symbol name');
- return;
var symbolNode = this.nodeFactory(id, "symbol");
@@ -12192,7 +12929,7 @@
var symbolExtent = new OpenLayers.Bounds(
Number.MAX_VALUE, Number.MAX_VALUE, 0, 0);
- var points = "";
+ var points = [];
var x,y;
for (var i=0; i<symbol.length; i=i+2) {
x = symbol[i];
@@ -12201,10 +12938,10 @@
symbolExtent.bottom = Math.min(symbolExtent.bottom, y);
symbolExtent.right = Math.max(symbolExtent.right, x);
symbolExtent.top = Math.max(symbolExtent.top, y);
- points += " " + x + "," + y;
+ points.push(x, ",", y);
- node.setAttributeNS(null, "points", points);
+ node.setAttributeNS(null, "points", points.join(" "));
var width = symbolExtent.getWidth();
var height = symbolExtent.getHeight();
@@ -12274,8 +13011,9 @@
OpenLayers/Renderer/VML.js
@@ -12490,12 +13228,11 @@
setStyle: function(node, style, options, geometry) {
options = options || node._options;
- var widthFactor = 1;
var fillColor = style.fillColor;
if (node._geometryClass === "OpenLayers.Geometry.Point") {
node.title=style.graphicTitle;
var width = style.graphicWidth || style.graphicHeight;
@@ -12571,7 +13308,7 @@
// additional rendering for rotated graphics or symbols
var rotation = style.rotation;
- if (rotation !== node._rotation) {
+ if ((rotation !== undefined || node._rotation !== undefined)) {
node._rotation = rotation;
this.graphicRotate(node, xOffset, yOffset, style);
@@ -12586,26 +13323,27 @@
// stroke
- if (options.isStroked) {
- node.strokecolor = style.strokeColor;
- node.strokeweight = style.strokeWidth + "px";
- } else {
- node.stroked = false;
var strokes = node.getElementsByTagName("stroke");
var stroke = (strokes.length == 0) ? null : strokes[0];
if (!options.isStroked) {
+ node.stroked = false;
if (stroke) {
- node.removeChild(stroke);
+ stroke.on = false;
} else {
if (!stroke) {
stroke = this.createNode('olv:stroke', node.id + "_stroke");
node.appendChild(stroke);
+ stroke.on = true;
+ stroke.color = style.strokeColor;
+ stroke.weight = style.strokeWidth + "px";
stroke.opacity = style.strokeOpacity;
- stroke.endcap = !style.strokeLinecap || style.strokeLinecap == 'butt' ? 'flat' : style.strokeLinecap;
- stroke.dashstyle = this.dashStyle(style);
+ stroke.endcap = style.strokeLinecap == 'butt' ? 'flat' :
+ (style.strokeLinecap || 'round');
+ if (style.strokeDashstyle) {
+ stroke.dashstyle = this.dashStyle(style);
if (style.cursor != "inherit" && style.cursor != null) {
@@ -12636,7 +13374,6 @@
graphicRotate: function(node, xOffset, yOffset, style) {
var style = style || node._style;
- var options = node._options;
var rotation = style.rotation || 0;
var aspectRatio, size;
@@ -13123,10 +13860,13 @@
var align = style.labelAlign || "cm";
+ if (align.length == 1) {
+ align += "m";
var xshift = textbox.clientWidth *
- (OpenLayers.Renderer.VML.LABEL_SHIFT[align[0] || "c"]);
+ (OpenLayers.Renderer.VML.LABEL_SHIFT[align.substr(0,1)]);
var yshift = textbox.clientHeight *
- (OpenLayers.Renderer.VML.LABEL_SHIFT[align[1] || "m"]);
+ (OpenLayers.Renderer.VML.LABEL_SHIFT[align.substr(1,1)]);
label.style.left = parseInt(label.style.left)-xshift-1+"px";
label.style.top = parseInt(label.style.top)+yshift+"px";
@@ -13212,7 +13952,6 @@
if (!symbol) {
- return;
@@ -13275,8 +14014,9 @@
OpenLayers/Tile.js
@@ -13559,8 +14299,9 @@
@@ -13804,6 +14545,9 @@
createTextNode: function(text) {
var node;
+ if (typeof text !== "string") {
+ text = String(text);
if(this.xmldom) {
node = this.xmldom.createTextNode(text);
} else {
@@ -14129,9 +14873,6 @@
var value = options.value;
if(value != null) {
- if(typeof value == "boolean") {
- value = String(value);
node.appendChild(this.createTextNode(value));
return node;
@@ -14443,8 +15184,9 @@
OpenLayers/Handler.js
@@ -14536,7 +15278,8 @@
* Parameters:
* control - {<OpenLayers.Control>} The control that initialized this
* handler. The control is assumed to have a valid map property; that
- * map is used in the handler's own setMap method.
+ * map is used in the handler's own setMap method. If a map property
+ * is present in the options argument it will be used instead.
* callbacks - {Object} An object whose properties correspond to abstracted
* events or sequences of browser events. The values for these
* properties are functions defined by the control that get called by
@@ -14548,11 +15291,11 @@
OpenLayers.Util.extend(this, options);
this.control = control;
this.callbacks = callbacks;
- if (control.map) {
- this.setMap(control.map);
+ var map = this.map || control.map;
+ if (map) {
+ this.setMap(map);
- OpenLayers.Util.extend(this, options);
this.id = OpenLayers.Util.createUniqueID(this.CLASS_NAME + "_");
@@ -14732,8 +15475,9 @@
OpenLayers/Map.js
@@ -14806,15 +15550,9 @@
* - *move* triggered after each drag, pan, or zoom
* - *moveend* triggered after a drag, pan, or zoom completes
* - *zoomend* triggered after a zoom completes
- * - *addmarker* triggered after a marker has been added
- * - *removemarker* triggered after a marker has been removed
- * - *clearmarkers* triggered after markers have been cleared
* - *mouseover* triggered after mouseover the map
* - *mouseout* triggered after mouseout the map
* - *mousemove* triggered after mousemove the map
- * - *dragstart* Does not work. Register for movestart instead.
- * - *drag* Does not work. Register for move instead.
- * - *dragend* Does not work. Register for moveend instead.
* - *changebaselayer* triggered after the base layer changes
EVENT_TYPES: [
@@ -15381,8 +16119,9 @@
// make sure panning doesn't continue after destruction
- if(this.panTween && this.panTween.playing) {
+ if(this.panTween) {
this.panTween.stop();
+ this.panTween = null;
// map has been destroyed. dont do it again!
@@ -17021,6 +17760,39 @@
px.y = Math.round(px.y);
return px;
+ * Method: getGeodesicPixelSize
+ * Parameters:
+ * px - {<OpenLayers.Pixel>} The pixel to get the geodesic length for. If
+ * not provided, the center pixel of the map viewport will be used.
+ * Returns:
+ * {<OpenLayers.Size>} The geodesic size of the pixel in kilometers.
+ getGeodesicPixelSize: function(px) {
+ var lonlat = px ? this.getLonLatFromPixel(px) : (this.getCenter() ||
+ new OpenLayers.LonLat(0, 0));
+ var res = this.getResolution();
+ var left = lonlat.add(-res / 2, 0);
+ var right = lonlat.add(res / 2, 0);
+ var bottom = lonlat.add(0, -res / 2);
+ var top = lonlat.add(0, res / 2);
+ var dest = new OpenLayers.Projection("EPSG:4326");
+ var source = this.getProjectionObject() || dest;
+ if(!source.equals(dest)) {
+ left.transform(source, dest);
+ right.transform(source, dest);
+ bottom.transform(source, dest);
+ top.transform(source, dest);
+ return new OpenLayers.Size(
+ OpenLayers.Util.distVincenty(left, right),
+ OpenLayers.Util.distVincenty(bottom, top)
@@ -17124,8 +17896,9 @@
OpenLayers/Marker.js
@@ -17147,9 +17920,9 @@
* var markers = new OpenLayers.Layer.Markers( "Markers" );
* map.addLayer(markers);
- * var size = new OpenLayers.Size(10,17);
+ * var size = new OpenLayers.Size(21,25);
* var offset = new OpenLayers.Pixel(-(size.w/2), -size.h);
- * var icon = new OpenLayers.Icon('http://boston.openguides.org/markers/AQUA.png',size,offset);
+ * var icon = new OpenLayers.Icon('http://www.openlayers.org/dev/img/marker.png', size, offset);
* markers.addMarker(new OpenLayers.Marker(new OpenLayers.LonLat(0,0),icon));
* markers.addMarker(new OpenLayers.Marker(new OpenLayers.LonLat(0,0),icon.clone()));
@@ -17369,8 +18142,9 @@
OpenLayers/Request.js
@@ -17539,7 +18313,9 @@
request.send(config.data);
} else {
window.setTimeout(function(){
- request.send(config.data);
+ if (request._aborted !== true) {
+ request.send(config.data);
}, 0);
return request;
@@ -17728,8 +18504,9 @@
OpenLayers/Tile/Image.js
@@ -17913,7 +18690,8 @@
var drawTile = OpenLayers.Tile.prototype.draw.apply(this, arguments);
- if (OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS, this.layer.transitionEffect) != -1) {
+ if ((OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS, this.layer.transitionEffect) != -1) ||
+ this.layer.singleTile) {
if (drawTile) {
//we use a clone of this tile to create a double buffer for visual
//continuity. The backBufferTile is used to create transition
@@ -18047,9 +18825,9 @@
positionImage: function() {
// if the this layer doesn't exist at the point the image is
// returned, do not attempt to use it for size computation
- if ( this.layer == null )
+ if (this.layer === null) {
return;
// position the frame
OpenLayers.Util.modifyDOMElement(this.frame,
null, this.position, this.size);
@@ -18308,8 +19086,9 @@
OpenLayers/Control/OverviewMap.js
@@ -18431,6 +19210,12 @@
resolutionFactor: 1,
+ * APIProperty: maximized
+ * {Boolean} Start as maximized (visible). Defaults to false.
+ maximized: false,
* Constructor: OpenLayers.Control.OverviewMap
* Create a new overview map
@@ -18598,7 +19383,10 @@
this.map.events.register('moveend', this, this.update);
+ if (this.maximized) {
+ this.maximizeControl();
return this.div;
@@ -19022,8 +19810,9 @@
OpenLayers/Feature.js
@@ -19252,9 +20041,10 @@
OpenLayers/Handler/Click.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the clear BSD license.
- * See http://svn.openlayers.org/trunk/openlayers/license.txt
* @requires OpenLayers/Handler.js
@@ -19580,8 +20370,9 @@
OpenLayers/Handler/Drag.js
@@ -19782,8 +20573,8 @@
if(!this.oldOnselectstart) {
this.oldOnselectstart = (document.onselectstart) ? document.onselectstart : OpenLayers.Function.True;
- document.onselectstart = OpenLayers.Function.False;
+ document.onselectstart = OpenLayers.Function.False;
propagate = !this.stopDown;
} else {
@@ -20003,8 +20794,9 @@
OpenLayers/Handler/Feature.js
@@ -20394,9 +21186,10 @@
OpenLayers/Handler/Hover.js
@@ -20580,8 +21373,9 @@
OpenLayers/Handler/MouseWheel.js
@@ -20866,8 +21660,9 @@
OpenLayers/Layer.js
@@ -20950,8 +21745,20 @@
EVENT_TYPES: ["loadstart", "loadend", "loadcancel", "visibilitychanged",
"move", "moveend"],
+ * Constant: RESOLUTION_PROPERTIES
+ * {Array} The properties that are used for calculating resolutions
+ * information.
+ RESOLUTION_PROPERTIES: [
+ 'scales', 'resolutions',
+ 'maxScale', 'minScale',
+ 'maxResolution', 'minResolution',
+ 'numZoomLevels', 'maxZoomLevel'
* APIProperty: events
* {<OpenLayers.Events>}
@@ -21168,6 +21975,13 @@
* transitionEffect values.
SUPPORTED_TRANSITIONS: ['resize'],
+ * Property: metadata
+ * {Object} This object can be used to store additional information on a
+ * layer object.
+ metadata: {},
* Constructor: OpenLayers.Layer
@@ -21305,18 +22119,46 @@
* newOptions - {Object}
addOptions: function (newOptions) {
if (this.options == null) {
this.options = {};
// update our copy for clone
OpenLayers.Util.extend(this.options, newOptions);
// add new options to this
OpenLayers.Util.extend(this, newOptions);
+ // make sure this.projection references a projection object
+ if(typeof this.projection == "string") {
+ this.projection = new OpenLayers.Projection(this.projection);
+ // get the units from the projection, if we have a projection
+ // and it it has units
+ if(this.projection && this.projection.getUnits()) {
+ this.units = this.projection.getUnits();
+ // re-initialize resolutions if necessary, i.e. if any of the
+ // properties of the "properties" array defined below is set
+ // in the new options
+ if(this.map) {
+ var properties = this.RESOLUTION_PROPERTIES.concat(
+ ["projection", "units", "minExtent", "maxExtent"]
+ for(var o in newOptions) {
+ if(newOptions.hasOwnProperty(o) &&
+ OpenLayers.Util.indexOf(properties, o) >= 0) {
+ this.initResolutions();
+ break;
* APIMethod: onMapResize
* This function can be implemented by subclasses
@@ -21390,12 +22232,13 @@
// grab some essential layer data from the map if it hasn't already
// been set
this.maxExtent = this.maxExtent || this.map.maxExtent;
+ this.minExtent = this.minExtent || this.map.minExtent;
this.projection = this.projection || this.map.projection;
- if (this.projection && typeof this.projection == "string") {
+ if (typeof this.projection == "string") {
// Check the projection to see if we can get units -- if not, refer
// to properties.
this.units = this.projection.getUnits() ||
@@ -21595,184 +22438,242 @@
initResolutions: function() {
- // These are the relevant options which are used for calculating
- // resolutions information.
+ // ok we want resolutions, here's our strategy:
- var props = new Array(
- 'projection', 'units',
- 'scales', 'resolutions',
- 'maxScale', 'minScale',
- 'maxResolution', 'minResolution',
- 'minExtent', 'maxExtent',
- 'numZoomLevels', 'maxZoomLevel'
+ // 1. if resolutions are defined in the layer config, use them
+ // 2. else, if scales are defined in the layer config then derive
+ // resolutions from these scales
+ // 3. else, attempt to calculate resolutions from maxResolution,
+ // minResolution, numZoomLevels, maxZoomLevel set in the
+ // layer config
+ // 4. if we still don't have resolutions, and if resolutions
+ // are defined in the same, use them
+ // 5. else, if scales are defined in the map then derive
+ // 6. else, attempt to calculate resolutions from maxResolution,
+ // map
+ // 7. hope for the best!
- //these are the properties which do *not* imply that user wishes
- // this layer to be scale-dependant
- var notScaleProps = ['projection', 'units'];
+ var i, len;
+ var props = {}, alwaysInRange = true;
- //should the layer be scale-dependant? default is false -- this will
- // only be set true if we find that the user has specified a property
- // from the 'props' array that is not in 'notScaleProps'
- var useInRange = false;
- // First we create a new object where we will store all of the
- // resolution-related properties that we find in either the layer's
- // 'options' array or from the map.
- var confProps = {};
- for(var i=0, len=props.length; i<len; i++) {
- var property = props[i];
- // If the layer had one of these properties set *and* it is
- // a scale property (is not a non-scale property), then we assume
- // the user did intend to use scale-dependant display (useInRange).
- if (this.options[property] &&
- OpenLayers.Util.indexOf(notScaleProps, property) == -1) {
- useInRange = true;
+ // get resolution data from layer config
+ // (we also set alwaysInRange in the layer as appropriate)
+ for(i=0, len=this.RESOLUTION_PROPERTIES.length; i<len; i++) {
+ var p = this.RESOLUTION_PROPERTIES[i];
+ props[p] = this.options[p];
+ if(alwaysInRange && this.options[p]) {
+ alwaysInRange = false;
- confProps[property] = this.options[property] || this.map[property];
+ if(this.alwaysInRange == null) {
+ this.alwaysInRange = alwaysInRange;
- //only automatically set 'alwaysInRange' if the user hasn't already
- // set it (to true or false, since the default is null). If user did
- // not intend to use scale-dependant display then we set they layer
- // as alwaysInRange. This means calculateInRange() will always return
- // true and the layer will never be turned off due to scale changes.
- if (this.alwaysInRange == null) {
- this.alwaysInRange = !useInRange;
+ // if we don't have resolutions then attempt to derive them from scales
+ if(props.resolutions == null) {
+ props.resolutions = this.resolutionsFromScales(props.scales);
- // Do not use the scales array set at the map level if
- // either minScale or maxScale or both are set at the
- // layer level
- if ((this.options.minScale != null ||
- this.options.maxScale != null) &&
- this.options.scales == null) {
+ // if we still don't have resolutions then attempt to calculate them
+ props.resolutions = this.calculateResolutions(props);
- confProps.scales = null;
+ // if we couldn't calculate resolutions then we look at we have
+ // in the map
+ props[p] = this.options[p] != null ?
+ this.options[p] : this.map[p];
- // Do not use the resolutions array set at the map level if
- // either minResolution or maxResolution or both are set at the
- // layer level
- if ((this.options.minResolution != null ||
- this.options.maxResolution != null) &&
- this.options.resolutions == null) {
- confProps.resolutions = null;
+ // ok, we new need to set properties in the instance
+ // get maxResolution from the config if it's defined there
+ var maxResolution;
+ if(this.options.maxResolution &&
+ this.options.maxResolution !== "auto") {
+ maxResolution = this.options.maxResolution;
+ if(this.options.minScale) {
+ maxResolution = OpenLayers.Util.getResolutionFromScale(
+ this.options.minScale, this.units);
- // If numZoomLevels hasn't been set and the maxZoomLevel *has*,
- // then use maxZoomLevel to calculate numZoomLevels
- if ( (!confProps.numZoomLevels) && (confProps.maxZoomLevel) ) {
- confProps.numZoomLevels = confProps.maxZoomLevel + 1;
+ // get minResolution from the config if it's defined there
+ var minResolution;
+ if(this.options.minResolution &&
+ this.options.minResolution !== "auto") {
+ minResolution = this.options.minResolution;
+ if(this.options.maxScale) {
+ minResolution = OpenLayers.Util.getResolutionFromScale(
+ this.options.maxScale, this.units);
- // First off, we take whatever hodge-podge of values we have and
- // calculate/distill them down into a resolutions[] array
- if ((confProps.scales != null) || (confProps.resolutions != null)) {
- //preset levels
- if (confProps.scales != null) {
- confProps.resolutions = [];
- for(var i=0, len=confProps.scales.length; i<len; i++) {
- var scale = confProps.scales[i];
- confProps.resolutions[i] =
- OpenLayers.Util.getResolutionFromScale(scale,
- confProps.units);
+ if(props.resolutions) {
+ //sort resolutions array descendingly
+ props.resolutions.sort(function(a, b) {
+ return (b - a);
+ // if we still don't have a maxResolution get it from the
+ // resolutions array
+ if(!maxResolution) {
+ maxResolution = props.resolutions[0];
- confProps.numZoomLevels = confProps.resolutions.length;
- } else {
- //maxResolution and numZoomLevels based calculation
+ // if we still don't have a minResolution get it from the
+ if(!minResolution) {
+ var lastIdx = props.resolutions.length - 1;
+ minResolution = props.resolutions[lastIdx];
- // determine maxResolution
- if (confProps.minScale) {
- confProps.maxResolution =
- OpenLayers.Util.getResolutionFromScale(confProps.minScale,
- confProps.units);
- } else if (confProps.maxResolution == "auto") {
- var viewSize = this.map.getSize();
- var wRes = confProps.maxExtent.getWidth() / viewSize.w;
- var hRes = confProps.maxExtent.getHeight()/ viewSize.h;
- confProps.maxResolution = Math.max(wRes, hRes);
+ this.resolutions = props.resolutions;
+ if(this.resolutions) {
+ len = this.resolutions.length;
+ this.scales = new Array(len);
+ for(i=0; i<len; i++) {
+ this.scales[i] = OpenLayers.Util.getScaleFromResolution(
+ this.resolutions[i], this.units);
+ this.numZoomLevels = len;
+ this.minResolution = minResolution;
+ if(minResolution) {
+ this.maxScale = OpenLayers.Util.getScaleFromResolution(
+ minResolution, this.units);
+ this.maxResolution = maxResolution;
+ if(maxResolution) {
+ this.minScale = OpenLayers.Util.getScaleFromResolution(
+ maxResolution, this.units);
- // determine minResolution
- if (confProps.maxScale != null) {
- confProps.minResolution =
- OpenLayers.Util.getResolutionFromScale(confProps.maxScale,
- confProps.units);
- } else if ( (confProps.minResolution == "auto") &&
- (confProps.minExtent != null) ) {
- var wRes = confProps.minExtent.getWidth() / viewSize.w;
- var hRes = confProps.minExtent.getHeight()/ viewSize.h;
- confProps.minResolution = Math.max(wRes, hRes);
+ * Method: resolutionsFromScales
+ * Derive resolutions from scales.
+ * Parameters:
+ * scales - {Array(Number)} Scales
+ * Returns
+ * {Array(Number)} Resolutions
+ resolutionsFromScales: function(scales) {
+ if(scales == null) {
+ return;
+ var resolutions, i, len;
+ len = scales.length;
+ resolutions = new Array(len);
+ resolutions[i] = OpenLayers.Util.getResolutionFromScale(
+ scales[i], this.units);
+ return resolutions;
- // determine numZoomLevels if not already set on the layer
- // this gives numZoomLevels assuming approximately base 2 scaling
- if (confProps.minResolution != null &&
- this.options.numZoomLevels == undefined) {
- var ratio = confProps.maxResolution / confProps.minResolution;
- Math.floor(Math.log(ratio) / Math.log(2)) + 1;
+ * Method: calculateResolutions
+ * Calculate resolutions based on the provided properties.
+ * Parameters:
+ * props - {Object} Properties
+ * Return:
+ * {Array({Number})} Array of resolutions.
+ calculateResolutions: function(props) {
+ // determine maxResolution
+ var maxResolution = props.maxResolution;
+ if(props.minScale != null) {
+ maxResolution =
+ OpenLayers.Util.getResolutionFromScale(props.minScale,
+ this.units);
+ } else if(maxResolution == "auto" && this.maxExtent != null) {
+ var viewSize = this.map.getSize();
+ var wRes = this.maxExtent.getWidth() / viewSize.w;
+ var hRes = this.maxExtent.getHeight() / viewSize.h;
+ maxResolution = Math.max(wRes, hRes);
+ // determine minResolution
+ var minResolution = props.minResolution;
+ if(props.maxScale != null) {
+ minResolution =
+ OpenLayers.Util.getResolutionFromScale(props.maxScale,
+ this.units);
+ } else if(props.minResolution == "auto" && this.minExtent != null) {
+ var wRes = this.minExtent.getWidth() / viewSize.w;
+ var hRes = this.minExtent.getHeight()/ viewSize.h;
+ minResolution = Math.max(wRes, hRes);
+ // determine numZoomLevels
+ var maxZoomLevel = props.maxZoomLevel;
+ var numZoomLevels = props.numZoomLevels;
+ if(typeof minResolution === "number" &&
+ typeof maxResolution === "number" && numZoomLevels === undefined) {
+ var ratio = maxResolution / minResolution;
+ numZoomLevels = Math.floor(Math.log(ratio) / Math.log(2)) + 1;
+ } else if(numZoomLevels === undefined && maxZoomLevel != null) {
+ numZoomLevels = maxZoomLevel + 1;
+ // are we able to calculate resolutions?
+ if(typeof numZoomLevels !== "number" || numZoomLevels <= 0 ||
+ (typeof maxResolution !== "number" &&
+ typeof minResolution !== "number")) {
+ return;
+ // now we have numZoomLevels and at least one of maxResolution
+ // or minResolution, we can populate the resolutions array
+ var resolutions = new Array(numZoomLevels);
+ var base = 2;
+ if(typeof minResolution == "number" &&
+ typeof maxResolution == "number") {
+ // if maxResolution and minResolution are set, we calculate
+ // the base for exponential scaling that starts at
+ // maxResolution and ends at minResolution in numZoomLevels
+ // steps.
+ base = Math.pow(
+ (maxResolution / minResolution),
+ (1 / (numZoomLevels - 1))
+ var i;
+ if(typeof maxResolution === "number") {
+ for(i=0; i<numZoomLevels; i++) {
+ resolutions[i] = maxResolution / Math.pow(base, i);
- // now we have numZoomLevels and maxResolution,
- // we can populate the resolutions array
- confProps.resolutions = new Array(confProps.numZoomLevels);
- var base = 2;
- if(typeof confProps.minResolution == "number" &&
- confProps.numZoomLevels > 1) {
- * If maxResolution and minResolution are set (or related
- * scale properties), we calculate the base for exponential
- * scaling that starts at maxResolution and ends at
- * minResolution in numZoomLevels steps.
- base = Math.pow(
- (confProps.maxResolution / confProps.minResolution),
- (1 / (confProps.numZoomLevels - 1))
+ } else {
+ resolutions[numZoomLevels - 1 - i] =
+ minResolution * Math.pow(base, i);
- for (var i=0; i < confProps.numZoomLevels; i++) {
- var res = confProps.maxResolution / Math.pow(base, i);
- confProps.resolutions[i] = res;
- //sort resolutions array ascendingly
- confProps.resolutions.sort( function(a, b) { return(b-a); } );
- // now set our newly calculated values back to the layer
- // Note: We specifically do *not* set them to layer.options, which we
- // will preserve as it was when we added this layer to the map.
- // this way cloned layers reset themselves to new map div
- // dimensions)
- this.resolutions = confProps.resolutions;
- this.maxResolution = confProps.resolutions[0];
- var lastIndex = confProps.resolutions.length - 1;
- this.minResolution = confProps.resolutions[lastIndex];
- this.scales = [];
- for(var i=0, len=confProps.resolutions.length; i<len; i++) {
- this.scales[i] =
- OpenLayers.Util.getScaleFromResolution(confProps.resolutions[i],
- confProps.units);
- this.minScale = this.scales[0];
- this.maxScale = this.scales[this.scales.length - 1];
- this.numZoomLevels = confProps.numZoomLevels;
@@ -22067,8 +22968,9 @@
OpenLayers/Marker/Box.js
@@ -22190,7 +23092,7 @@
OpenLayers/Request/XMLHttpRequest.js
-// Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+// XMLHttpRequest.js Copyright (C) 2010 Sergey Ilinsky (http://www.ilinsky.com)
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
@@ -22215,11 +23117,13 @@
// Define on browser type
var bGecko = !!window.controllers,
- bIE = window.document.all && !window.opera;
+ bIE = window.document.all && !window.opera,
+ bIE7 = bIE && window.navigator.userAgent.match(/MSIE ([\.0-9]+)/) && RegExp.$1 == 7;
// Constructor
function cXMLHttpRequest() {
- this._object = oXMLHttpRequest ? new oXMLHttpRequest : new window.ActiveXObject('Microsoft.XMLHTTP');
+ this._object = oXMLHttpRequest && !bIE7 ? new oXMLHttpRequest : new window.ActiveXObject("Microsoft.XMLHTTP");
+ this._listeners = [];
// BUGFIX: Firefox with Firebug installed would break pages if not executed
@@ -22235,10 +23139,10 @@
// Public Properties
cXMLHttpRequest.prototype.readyState = cXMLHttpRequest.UNSENT;
- cXMLHttpRequest.prototype.responseText = "";
+ cXMLHttpRequest.prototype.responseText = '';
cXMLHttpRequest.prototype.responseXML = null;
cXMLHttpRequest.prototype.status = 0;
- cXMLHttpRequest.prototype.statusText = "";
+ cXMLHttpRequest.prototype.statusText = '';
// Instance-level Events Handlers
cXMLHttpRequest.prototype.onreadystatechange = null;
@@ -22251,24 +23155,50 @@
// Public Methods
cXMLHttpRequest.prototype.open = function(sMethod, sUrl, bAsync, sUser, sPassword) {
+ // Delete headers, required when object is reused
+ delete this._headers;
+ // When bAsync parameter value is omitted, use true as default
+ if (arguments.length < 3)
+ bAsync = true;
// Save async parameter for fixing Gecko bug with missing readystatechange in synchronous requests
this._async = bAsync;
// Set the onreadystatechange handler
var oRequest = this,
- nState = this.readyState;
+ nState = this.readyState,
+ fOnUnload;
// BUGFIX: IE - memory leak on page unload (inter-page leak)
- if (bIE) {
- var fOnUnload = function() {
- if (oRequest._object.readyState != cXMLHttpRequest.DONE)
+ if (bIE && bAsync) {
+ fOnUnload = function() {
+ if (nState != cXMLHttpRequest.DONE) {
fCleanTransport(oRequest);
+ // Safe to abort here since onreadystatechange handler removed
+ oRequest.abort();
- if (bAsync)
window.attachEvent("onunload", fOnUnload);
+ // Add method sniffer
+ if (cXMLHttpRequest.onopen)
+ cXMLHttpRequest.onopen.apply(this, arguments);
+ if (arguments.length > 4)
+ this._object.open(sMethod, sUrl, bAsync, sUser, sPassword);
+ else
+ if (arguments.length > 3)
+ this._object.open(sMethod, sUrl, bAsync, sUser);
+ else
+ this._object.open(sMethod, sUrl, bAsync);
+ if (!bGecko && !bIE) {
+ this.readyState = cXMLHttpRequest.OPENED;
+ fReadyStateChange(this);
this._object.onreadystatechange = function() {
if (bGecko && !bAsync)
return;
@@ -22279,7 +23209,7 @@
fSynchronizeValues(oRequest);
- // BUGFIX: Firefox fires unneccesary DONE when aborting
+ // BUGFIX: Firefox fires unnecessary DONE when aborting
if (oRequest._aborted) {
// Reset readyState to UNSENT
oRequest.readyState = cXMLHttpRequest.UNSENT;
@@ -22302,7 +23232,14 @@
cXMLHttpRequest.call(oRequest);
// Re-send request
+ if (sUser) {
+ if (sPassword)
oRequest._object.open(sMethod, sUrl, bAsync, sUser, sPassword);
+ else
+ oRequest._object.open(sMethod, sUrl, bAsync, sUser);
+ else
+ oRequest._object.open(sMethod, sUrl, bAsync);
oRequest._object.setRequestHeader("If-Modified-Since", oRequest._cached.getResponseHeader("Last-Modified") || new window.Date(0));
// Copy headers set
if (oRequest._headers)
@@ -22346,7 +23283,7 @@
oRequest._object.send(null);
- // Return now - wait untill re-sent request is finished
+ // Return now - wait until re-sent request is finished
return;
@@ -22360,19 +23297,6 @@
fReadyStateChange(oRequest);
nState = oRequest.readyState;
- // Add method sniffer
- if (cXMLHttpRequest.onopen)
- cXMLHttpRequest.onopen.apply(this, arguments);
- this._object.open(sMethod, sUrl, bAsync, sUser, sPassword);
- // BUGFIX: Gecko - missing readystatechange calls in synchronous requests
- if (!bAsync && bGecko) {
- this.readyState = cXMLHttpRequest.OPENED;
- fReadyStateChange(this);
cXMLHttpRequest.prototype.send = function(vData) {
@@ -22413,7 +23337,7 @@
if (cXMLHttpRequest.onabort)
cXMLHttpRequest.onabort.apply(this, arguments);
- // BUGFIX: Gecko - unneccesary DONE when aborting
+ // BUGFIX: Gecko - unnecessary DONE when aborting
if (this.readyState > cXMLHttpRequest.UNSENT)
this._aborted = true;
@@ -22436,34 +23360,86 @@
return this._object.setRequestHeader(sName, sValue);
+ // EventTarget interface implementation
+ cXMLHttpRequest.prototype.addEventListener = function(sName, fHandler, bUseCapture) {
+ for (var nIndex = 0, oListener; oListener = this._listeners[nIndex]; nIndex++)
+ if (oListener[0] == sName && oListener[1] == fHandler && oListener[2] == bUseCapture)
+ return;
+ // Add listener
+ this._listeners.push([sName, fHandler, bUseCapture]);
+ cXMLHttpRequest.prototype.removeEventListener = function(sName, fHandler, bUseCapture) {
+ break;
+ // Remove listener
+ if (oListener)
+ this._listeners.splice(nIndex, 1);
+ cXMLHttpRequest.prototype.dispatchEvent = function(oEvent) {
+ var oEventPseudo = {
+ 'type': oEvent.type,
+ 'target': this,
+ 'currentTarget':this,
+ 'eventPhase': 2,
+ 'bubbles': oEvent.bubbles,
+ 'cancelable': oEvent.cancelable,
+ 'timeStamp': oEvent.timeStamp,
+ 'stopPropagation': function() {}, // There is no flow
+ 'preventDefault': function() {}, // There is no default action
+ 'initEvent': function() {} // Original event object should be initialized
+ // Execute onreadystatechange
+ if (oEventPseudo.type == "readystatechange" && this.onreadystatechange)
+ (this.onreadystatechange.handleEvent || this.onreadystatechange).apply(this, [oEventPseudo]);
+ // Execute listeners
+ if (oListener[0] == oEventPseudo.type && !oListener[2])
+ (oListener[1].handleEvent || oListener[1]).apply(this, [oEventPseudo]);
cXMLHttpRequest.prototype.toString = function() {
return '[' + "object" + ' ' + "XMLHttpRequest" + ']';
cXMLHttpRequest.toString = function() {
return '[' + "XMLHttpRequest" + ']';
// Helper function
function fReadyStateChange(oRequest) {
- // Execute onreadystatechange
- if (oRequest.onreadystatechange)
- oRequest.onreadystatechange.apply(oRequest);
// Sniffing code
if (cXMLHttpRequest.onreadystatechange)
cXMLHttpRequest.onreadystatechange.apply(oRequest);
+ // Fake event
+ oRequest.dispatchEvent({
+ 'type': "readystatechange",
+ 'bubbles': false,
+ 'cancelable': false,
+ 'timeStamp': new Date + 0
function fGetDocument(oRequest) {
- var oDocument = oRequest.responseXML;
+ var oDocument = oRequest.responseXML,
+ sResponse = oRequest.responseText;
// Try parsing responseText
- if (bIE && oDocument && !oDocument.documentElement && oRequest.getResponseHeader("Content-Type").match(/[^\/]+\/[^\+]+\+xml/)) {
- oDocument = new ActiveXObject('Microsoft.XMLDOM');
- oDocument.loadXML(oRequest.responseText);
+ if (bIE && sResponse && oDocument && !oDocument.documentElement && oRequest.getResponseHeader("Content-Type").match(/[^\/]+\/[^\+]+\+xml/)) {
+ oDocument = new window.ActiveXObject("Microsoft.XMLDOM");
+ oDocument.async = false;
+ oDocument.validateOnParse = false;
+ oDocument.loadXML(sResponse);
// Check if there is no error in document
if (oDocument)
- if ((bIE && oDocument.parseError != 0) || (oDocument.documentElement && oDocument.documentElement.tagName == "parsererror"))
+ if ((bIE && oDocument.parseError != 0) || !oDocument.documentElement || (oDocument.documentElement && oDocument.documentElement.tagName == "parsererror"))
return null;
return oDocument;
@@ -22478,9 +23454,6 @@
function fCleanTransport(oRequest) {
// BUGFIX: IE - memory leak (on-page leak)
oRequest._object.onreadystatechange = new window.Function;
- // Delete private properties
- delete oRequest._headers;
// Internet Explorer 5.0 (missing apply)
@@ -22507,8 +23480,9 @@
OpenLayers/Ajax.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
- * license. See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+/* Copyright (c) 2006-2010 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
@@ -23188,8 +24162,9 @@
OpenLayers/Control/DragPan.js
@@ -23285,8 +24260,9 @@
OpenLayers/Feature/Vector.js
// TRASH THIS
@@ -23329,8 +24305,8 @@
* APIProperty: attributes
- * {Object} This object holds arbitrary properties that describe the
- * feature.
+ * {Object} This object holds arbitrary, serializable properties that
+ * describe the feature.
attributes: null,
@@ -23742,8 +24718,9 @@
OpenLayers/Handler/Box.js
@@ -23805,6 +24782,17 @@
+ * Method: destroy
+ destroy: function() {
+ if (this.dragHandler) {
+ this.dragHandler.destroy();
+ this.dragHandler = null;
+ OpenLayers.Handler.prototype.destroy.apply(this, arguments);
* Method: setMap
setMap: function (map) {
@@ -23955,8 +24943,9 @@
OpenLayers/Handler/RegularPolygon.js
@@ -24013,6 +25002,12 @@
snapToggle: 'shiftKey',
+ * Property: layerOptions
+ * {Object} Any optional properties to be set on the sketch layer.
+ layerOptions: null,
* APIProperty: persist
* {Boolean} Leave the feature rendered until clear is called. Default
* is false. If set to true, the feature remains rendered until
@@ -24087,11 +25082,13 @@
* cancel callback will receive a geometry.
initialize: function(control, callbacks, options) {
- this.style = OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'], {});
+ if(!(options && options.layerOptions && options.layerOptions.styleMap)) {
+ this.style = OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'], {});
OpenLayers.Handler.prototype.initialize.apply(this,
[control, callbacks, options]);
- this.options = (options) ? options : new Object();
+ this.options = (options) ? options : {};
@@ -24116,14 +25113,14 @@
var activated = false;
if(OpenLayers.Handler.prototype.activate.apply(this, arguments)) {
// create temporary vector layer for rendering geometry sketch
- var options = {
+ var options = OpenLayers.Util.extend({
displayInLayerSwitcher: false,
// indicate that the temp vector layer will never be out of range
// without this, resolution properties must be specified at the
// map-level for this temporary layer to init its resolutions
// correctly
calculateInRange: OpenLayers.Function.True
+ }, this.layerOptions);
this.layer = new OpenLayers.Layer.Vector(this.CLASS_NAME, options);
this.map.addLayer(this.layer);
activated = true;
@@ -24275,7 +25272,7 @@
* Modify the polygon geometry in place.
modifyGeometry: function() {
- var angle, dx, dy, point;
+ var angle, point;
var ring = this.feature.geometry.components[0];
// if the number of sides ever changes, create a new geometry
if(ring.components.length != (this.sides + 1)) {
@@ -24336,8 +25333,10 @@
* is true).
clear: function() {
- this.layer.renderer.clear();
- this.layer.destroyFeatures();
+ if (this.layer) {
+ this.layer.renderer.clear();
+ this.layer.destroyFeatures();
@@ -24369,8 +25368,9 @@
OpenLayers/Layer/EventPane.js
@@ -24790,8 +25790,9 @@
OpenLayers/Layer/FixedZoomLevels.js
@@ -25108,8 +26109,9 @@
OpenLayers/Layer/HTTPRequest.js
@@ -25341,8 +26343,9 @@
OpenLayers/Layer/Markers.js
@@ -25531,6 +26534,11 @@
OpenLayers/Layer/SphericalMercator.js
* @requires OpenLayers/Layer.js
* @requires OpenLayers/Projection.js
@@ -25583,6 +26591,38 @@
return extent;
+ * Method: getLonLatFromViewPortPx
+ * Get a map location from a pixel location
+ * Parameters:
+ * viewPortPx - {<OpenLayers.Pixel>}
+ * Returns:
+ * {<OpenLayers.LonLat>} An OpenLayers.LonLat which is the passed-in view
+ * port OpenLayers.Pixel, translated into lon/lat by map lib
+ * If the map lib is not loaded or not centered, returns null
+ getLonLatFromViewPortPx: function (viewPortPx) {
+ return OpenLayers.Layer.prototype.getLonLatFromViewPortPx.apply(this, arguments);
+ * Method: getViewPortPxFromLonLat
+ * Get a pixel location from a map location
+ * Parameters:
+ * lonlat - {<OpenLayers.LonLat>}
+ * Returns:
+ * {<OpenLayers.Pixel>} An OpenLayers.Pixel which is the passed-in
+ * OpenLayers.LonLat, translated into view port pixels by map lib
+ * If map lib is not loaded or not centered, returns null
+ getViewPortPxFromLonLat: function (lonlat) {
+ return OpenLayers.Layer.prototype.getViewPortPxFromLonLat.apply(this, arguments);
* Method: initMercatorParameters
* Set up the mercator parameters on the layer: resolutions,
@@ -25596,7 +26636,7 @@
this.RESOLUTIONS[zoom] = maxResolution / Math.pow(2, zoom);
this.units = "m";
- this.projection = "EPSG:900913";
+ this.projection = this.projection || "EPSG:900913";
@@ -25694,8 +26734,9 @@
OpenLayers/Control/DrawFeature.js
@@ -25823,8 +26864,9 @@
OpenLayers/Control/Measure.js
@@ -26004,12 +27046,15 @@
* geometry - {<OpenLayers.Geometry>} The sketch geometry.
measurePartial: function(point, geometry) {
- this.delayedTrigger = window.setTimeout(
- OpenLayers.Function.bind(function() {
- this.measure(geometry, "measurepartial");
- }, this),
- this.partialDelay
+ if (geometry.getLength() > 0) {
+ geometry = geometry.clone();
+ this.delayedTrigger = window.setTimeout(
+ OpenLayers.Function.bind(function() {
+ this.measure(geometry, "measurepartial");
+ }, this),
+ this.partialDelay
@@ -26144,8 +27189,9 @@
OpenLayers/Control/ZoomBox.js
@@ -26242,8 +27288,9 @@
OpenLayers/Format/WKT.js
@@ -26395,7 +27442,9 @@
'multipoint': function(multipoint) {
var array = [];
for(var i=0, len=multipoint.components.length; i<len; ++i) {
- array.push(this.extract.point.apply(this, [multipoint.components[i]]));
+ array.push('(' +
+ this.extract.point.apply(this, [multipoint.components[i]]) +
return array.join(',');
@@ -26488,10 +27537,12 @@
* @private
'multipoint': function(str) {
- var points = OpenLayers.String.trim(str).split(',');
+ var point;
+ var points = OpenLayers.String.trim(str).split(this.regExes.parenComma);
var components = [];
for(var i=0, len=points.length; i<len; ++i) {
- components.push(this.parse.point.apply(this, [points[i]]).geometry);
+ point = points[i].replace(this.regExes.trimParens, '$1');
+ components.push(this.parse.point.apply(this, [point]).geometry);
return new OpenLayers.Feature.Vector(
new OpenLayers.Geometry.MultiPoint(components)
@@ -26599,8 +27650,9 @@
OpenLayers/Layer/Google.js
@@ -26608,7 +27660,6 @@
* @requires OpenLayers/Layer/SphericalMercator.js
* @requires OpenLayers/Layer/EventPane.js
* @requires OpenLayers/Layer/FixedZoomLevels.js
- * @requires OpenLayers/Console.js
@@ -26672,6 +27723,14 @@
type: null,
+ * APIProperty: wrapDateLine
+ * {Boolean} Allow user to pan forever east/west. Default is true.
+ * Setting this to false only restricts panning if
+ * <sphericalMercator> is true.
+ wrapDateLine: true,
* APIProperty: sphericalMercator
* {Boolean} Should the map act as a mercator-projected map? This will
* cause all interactions with the map to be in the actual map
@@ -26681,24 +27740,11 @@
sphericalMercator: false,
- * Property: dragObject
- * {GDraggableObject} Since 2.93, Google has exposed the ability to get
- * the maps GDraggableObject. We can now use this for smooth panning
+ * Property: version
+ * {Number} The version of the Google Maps API
- dragObject: null,
+ version: null,
- * Property: termsOfUse
- * {DOMElement} Div for Google's copyright and terms of use link
- termsOfUse: null,
- * Property: poweredBy
- * {DOMElement} Div for Google's powered by logo and link
- poweredBy: null,
* Constructor: OpenLayers.Layer.Google
@@ -26708,16 +27754,34 @@
* on the layer.
initialize: function(name, options) {
- OpenLayers.Layer.EventPane.prototype.initialize.apply(this, arguments);
+ options = options || {};
+ if(!options.version) {
+ options.version = typeof GMap2 === "function" ? "2" : "3";
+ var mixin = OpenLayers.Layer.Google["v" +
+ options.version.replace(/\./g, "_")];
+ if (mixin) {
+ OpenLayers.Util.applyDefaults(options, mixin);
+ } else {
+ throw "Unsupported Google Maps API version: " + options.version;
+ OpenLayers.Util.applyDefaults(options, mixin.DEFAULTS);
+ if (options.maxExtent) {
+ options.maxExtent = options.maxExtent.clone();
+ OpenLayers.Layer.EventPane.prototype.initialize.apply(this,
+ [name, options]);
OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,
- arguments);
- this.addContainerPxFunction();
+ [name, options]);
if (this.sphericalMercator) {
OpenLayers.Util.extend(this, OpenLayers.Layer.SphericalMercator);
this.initMercatorParameters();
* Method: clone
* Create a clone of this layer
@@ -26736,118 +27800,8 @@
this.name, this.getOptions()
- * Method: loadMapObject
- * Load the GMap and register appropriate event listeners. If we can't
- * load GMap2, then display a warning message.
- loadMapObject:function() {
- if (!this.type) {
- this.type = G_NORMAL_MAP;
- var mapObject, termsOfUse, poweredBy;
- var cache = OpenLayers.Layer.Google.cache[this.map.id];
- if (cache) {
- // there are already Google layers added to this map
- mapObject = cache.mapObject;
- termsOfUse = cache.termsOfUse;
- poweredBy = cache.poweredBy;
- // increment the layer count
- ++cache.count;
- } else {
- // this is the first Google layer for this map
- var container = this.map.viewPortDiv;
- var div = document.createElement("div");
- div.id = this.map.id + "_GMap2Container";
- div.style.position = "absolute";
- div.style.width = "100%";
- div.style.height = "100%";
- container.appendChild(div);
- // create GMap and shuffle elements
- try {
- mapObject = new GMap2(div);
- // move the ToS and branding stuff up to the container div
- termsOfUse = div.lastChild;
- container.appendChild(termsOfUse);
- termsOfUse.style.zIndex = "1100";
- termsOfUse.style.right = "";
- termsOfUse.style.bottom = "";
- termsOfUse.className = "olLayerGoogleCopyright";
- poweredBy = div.lastChild;
- container.appendChild(poweredBy);
- poweredBy.style.zIndex = "1100";
- poweredBy.style.right = "";
- poweredBy.style.bottom = "";
- poweredBy.className = "olLayerGooglePoweredBy gmnoprint";
- } catch (e) {
- OpenLayers.Console.error(e);
- return;
- // cache elements for use by any other google layers added to
- // this same map
- OpenLayers.Layer.Google.cache[this.map.id] = {
- mapObject: mapObject,
- termsOfUse: termsOfUse,
- poweredBy: poweredBy,
- count: 1
- this.mapObject = mapObject;
- this.termsOfUse = termsOfUse;
- this.poweredBy = poweredBy;
- // ensure this layer type is one of the mapObject types
- if (OpenLayers.Util.indexOf(this.mapObject.getMapTypes(),
- this.type) === -1) {
- this.mapObject.addMapType(this.type);
- //since v 2.93 getDragObject is now available.
- if(typeof mapObject.getDragObject == "function") {
- this.dragObject = mapObject.getDragObject();
- } else {
- this.dragPanMapObject = null;
- if(this.isBaseLayer === false) {
- this.setGMapVisibility(this.div.style.display !== "none");
- * APIMethod: onMapResize
- onMapResize: function() {
- // workaround for resizing of invisible or not yet fully loaded layers
- // where GMap2.checkResize() does not work. We need to load the GMap
- // for the old div size, then checkResize(), and then call
- // layer.moveTo() to trigger GMap.setCenter() (which will finish
- // the GMap initialization).
- if(this.visibility && this.mapObject.isLoaded()) {
- this.mapObject.checkResize();
- } else {
- if(!this._resized) {
- var layer = this;
- var handle = GEvent.addListener(this.mapObject, "load", function() {
- GEvent.removeListener(handle);
- delete layer._resized;
- layer.mapObject.checkResize();
- layer.moveTo(layer.map.getCenter(), layer.map.getZoom());
- this._resized = true;
* APIMethod: setVisibility
* Set the visibility flag for the layer and hide/show & redraw
* accordingly. Fire event unless otherwise specified
@@ -26863,51 +27817,42 @@
* visible - {Boolean} Display the layer (if in range)
setVisibility: function(visible) {
- this.setGMapVisibility(visible);
// sharing a map container, opacity has to be set per layer
var opacity = this.opacity == null ? 1 : this.opacity;
OpenLayers.Layer.EventPane.prototype.setVisibility.apply(this, arguments);
this.setOpacity(opacity);
- * Method: setGMapVisibility
- * Display the GMap container and associated elements.
+ * APIMethod: display
+ * Hide or show the Layer
* Parameters:
- * visible - {Boolean} Display the GMap elements.
+ * display - {Boolean}
- setGMapVisibility: function(visible) {
- if (cache) {
- var container = this.mapObject.getContainer();
- if (visible === true) {
- this.mapObject.setMapType(this.type);
- container.style.display = "";
- this.termsOfUse.style.left = "";
- this.termsOfUse.style.display = "";
- this.poweredBy.style.display = "";
- cache.displayed = this.id;
- } else {
- if (cache.displayed === this.id) {
- delete cache.displayed;
- if (!cache.displayed) {
- container.style.display = "none";
- this.termsOfUse.style.display = "none";
- // move ToU far to the left in addition to setting display
- // to "none", because at the end of the GMap2 load
- // sequence, display: none will be unset and ToU would be
- // visible after loading a map with a google layer that is
- // initially hidden.
- this.termsOfUse.style.left = "-9999px";
- this.poweredBy.style.display = "none";
+ display: function(visible) {
+ if (!this._dragging) {
+ this.setGMapVisibility(visible);
+ OpenLayers.Layer.EventPane.prototype.display.apply(this, arguments);
+ * Method: moveTo
+ * Parameters:
+ * bound - {<OpenLayers.Bounds>}
+ * zoomChanged - {Boolean} Tells when zoom has changed, as layers have to
+ * do some init work in that case.
+ * dragging - {Boolean}
+ moveTo: function(bounds, zoomChanged, dragging) {
+ this._dragging = dragging;
+ OpenLayers.Layer.EventPane.prototype.moveTo.apply(this, arguments);
+ delete this._dragging;
* APIMethod: setOpacity
* Sets the opacity for the entire layer (all images)
@@ -26927,7 +27872,7 @@
// Though this layer's opacity may not change, we're sharing a container
// and need to update the opacity for the entire container.
if (this.getVisibility()) {
+ var container = this.getMapContainer();
container, null, null, null, null, null, null, opacity
@@ -26948,7 +27893,7 @@
this.setGMapVisibility(false);
if (cache && cache.count <= 1) {
- this.removeGMapElements(false);
+ this.removeGMapElements();
OpenLayers.Layer.EventPane.prototype.destroy.apply(this, arguments);
@@ -26963,7 +27908,7 @@
if (cache) {
// remove shared elements from dom
- var container = this.mapObject && this.mapObject.getContainer();
+ var container = this.mapObject && this.getMapContainer();
if (container && container.parentNode) {
container.parentNode.removeChild(container);
@@ -27009,33 +27954,6 @@
OpenLayers.Layer.EventPane.prototype.removeMap.apply(this, arguments);
- * APIMethod: getZoomForExtent
- * Parameters:
- * bounds - {<OpenLayers.Bounds>}
- * Returns:
- * {Integer} Corresponding zoom level for a specified Bounds.
- * If mapObject is not loaded or not centered, returns null
- getZoomForExtent: function (bounds) {
- var zoom = null;
- if (this.mapObject != null) {
- var moBounds = this.getMapObjectBoundsFromOLBounds(bounds);
- var moZoom = this.getMapObjectZoomFromMapObjectBounds(moBounds);
- //make sure zoom is within bounds
- var moZoom = Math.min(Math.max(moZoom, this.minZoomLevel),
- this.maxZoomLevel);
- zoom = this.getOLZoomFromMapObjectZoom(moZoom);
- return zoom;
// TRANSLATION: MapObject Bounds <-> OpenLayers.Bounds
@@ -27071,7 +27989,313 @@
return olBounds;
+ * APIMethod: getWarningHTML
+ * Returns:
+ * {String} String with information on why layer is broken, how to get
+ * it working.
+ getWarningHTML:function() {
+ return OpenLayers.i18n("googleWarning");
+ * MapObject Interface Controls *
+ // Get&Set Center, Zoom
+ * APIMethod: getMapObjectCenter
+ * Returns:
+ * {Object} The mapObject's current center in Map Object format
+ getMapObjectCenter: function() {
+ return this.mapObject.getCenter();
+ * APIMethod: getMapObjectZoom
+ * Returns:
+ * {Integer} The mapObject's current zoom, in Map Object format
+ getMapObjectZoom: function() {
+ return this.mapObject.getZoom();
+ * MapObject Primitives *
+ // LonLat
+ * APIMethod: getLongitudeFromMapObjectLonLat
+ * Parameters:
+ * moLonLat - {Object} MapObject LonLat format
+ * Returns:
+ * {Float} Longitude of the given MapObject LonLat
+ getLongitudeFromMapObjectLonLat: function(moLonLat) {
+ return this.sphericalMercator ?
+ this.forwardMercator(moLonLat.lng(), moLonLat.lat()).lon :
+ moLonLat.lng();
+ * APIMethod: getLatitudeFromMapObjectLonLat
+ * Parameters:
+ * Returns:
+ * {Float} Latitude of the given MapObject LonLat
+ getLatitudeFromMapObjectLonLat: function(moLonLat) {
+ var lat = this.sphericalMercator ?
+ this.forwardMercator(moLonLat.lng(), moLonLat.lat()).lat :
+ moLonLat.lat();
+ return lat;
+ // Pixel
+ * APIMethod: getXFromMapObjectPixel
+ * Parameters:
+ * moPixel - {Object} MapObject Pixel format
+ * Returns:
+ * {Integer} X value of the MapObject Pixel
+ getXFromMapObjectPixel: function(moPixel) {
+ return moPixel.x;
+ * APIMethod: getYFromMapObjectPixel
+ * Parameters:
+ * Returns:
+ * {Integer} Y value of the MapObject Pixel
+ getYFromMapObjectPixel: function(moPixel) {
+ return moPixel.y;
+ CLASS_NAME: "OpenLayers.Layer.Google"
+ * Property: OpenLayers.Layer.Google.cache
+ * {Object} Cache for elements that should only be created once per map.
+OpenLayers.Layer.Google.cache = {};
+ * Constant: OpenLayers.Layer.Google.v2
+ * Mixin providing functionality specific to the Google Maps API v2.
+OpenLayers.Layer.Google.v2 = {
+ * Property: termsOfUse
+ * {DOMElement} Div for Google's copyright and terms of use link
+ termsOfUse: null,
+ * Property: poweredBy
+ * {DOMElement} Div for Google's powered by logo and link
+ poweredBy: null,
+ * Property: dragObject
+ * {GDraggableObject} Since 2.93, Google has exposed the ability to get
+ * the maps GDraggableObject. We can now use this for smooth panning
+ dragObject: null,
+ * Method: loadMapObject
+ * Load the GMap and register appropriate event listeners. If we can't
+ * load GMap2, then display a warning message.
+ loadMapObject:function() {
+ if (!this.type) {
+ this.type = G_NORMAL_MAP;
+ var mapObject, termsOfUse, poweredBy;
+ var cache = OpenLayers.Layer.Google.cache[this.map.id];
+ if (cache) {
+ // there are already Google layers added to this map
+ mapObject = cache.mapObject;
+ termsOfUse = cache.termsOfUse;
+ poweredBy = cache.poweredBy;
+ // increment the layer count
+ ++cache.count;
+ } else {
+ // this is the first Google layer for this map
+ var container = this.map.viewPortDiv;
+ var div = document.createElement("div");
+ div.id = this.map.id + "_GMap2Container";
+ div.style.position = "absolute";
+ div.style.width = "100%";
+ div.style.height = "100%";
+ container.appendChild(div);
+ // create GMap and shuffle elements
+ try {
+ mapObject = new GMap2(div);
+ // move the ToS and branding stuff up to the container div
+ termsOfUse = div.lastChild;
+ container.appendChild(termsOfUse);
+ termsOfUse.style.zIndex = "1100";
+ termsOfUse.style.right = "";
+ termsOfUse.style.bottom = "";
+ termsOfUse.className = "olLayerGoogleCopyright";
+ poweredBy = div.lastChild;
+ container.appendChild(poweredBy);
+ poweredBy.style.zIndex = "1100";
+ poweredBy.style.right = "";
+ poweredBy.style.bottom = "";
+ poweredBy.className = "olLayerGooglePoweredBy gmnoprint";
+ } catch (e) {
+ throw(e);
+ // cache elements for use by any other google layers added to
+ // this same map
+ OpenLayers.Layer.Google.cache[this.map.id] = {
+ mapObject: mapObject,
+ termsOfUse: termsOfUse,
+ poweredBy: poweredBy,
+ count: 1
+ this.mapObject = mapObject;
+ this.termsOfUse = termsOfUse;
+ this.poweredBy = poweredBy;
+ // ensure this layer type is one of the mapObject types
+ if (OpenLayers.Util.indexOf(this.mapObject.getMapTypes(),
+ this.type) === -1) {
+ this.mapObject.addMapType(this.type);
+ //since v 2.93 getDragObject is now available.
+ if(typeof mapObject.getDragObject == "function") {
+ this.dragObject = mapObject.getDragObject();
+ } else {
+ this.dragPanMapObject = null;
+ if(this.isBaseLayer === false) {
+ this.setGMapVisibility(this.div.style.display !== "none");
+ * APIMethod: onMapResize
+ onMapResize: function() {
+ // workaround for resizing of invisible or not yet fully loaded layers
+ // where GMap2.checkResize() does not work. We need to load the GMap
+ // for the old div size, then checkResize(), and then call
+ // layer.moveTo() to trigger GMap.setCenter() (which will finish
+ // the GMap initialization).
+ if(this.visibility && this.mapObject.isLoaded()) {
+ this.mapObject.checkResize();
+ } else {
+ if(!this._resized) {
+ var layer = this;
+ var handle = GEvent.addListener(this.mapObject, "load", function() {
+ GEvent.removeListener(handle);
+ delete layer._resized;
+ layer.mapObject.checkResize();
+ layer.moveTo(layer.map.getCenter(), layer.map.getZoom());
+ this._resized = true;
+ * Method: setGMapVisibility
+ * Display the GMap container and associated elements.
+ * Parameters:
+ * visible - {Boolean} Display the GMap elements.
+ setGMapVisibility: function(visible) {
+ if (cache) {
+ var container = this.mapObject.getContainer();
+ if (visible === true) {
+ this.mapObject.setMapType(this.type);
+ container.style.display = "";
+ this.termsOfUse.style.left = "";
+ this.termsOfUse.style.display = "";
+ this.poweredBy.style.display = "";
+ cache.displayed = this.id;
+ } else {
+ if (cache.displayed === this.id) {
+ delete cache.displayed;
+ if (!cache.displayed) {
+ container.style.display = "none";
+ this.termsOfUse.style.display = "none";
+ // move ToU far to the left in addition to setting display
+ // to "none", because at the end of the GMap2 load
+ // sequence, display: none will be unset and ToU would be
+ // visible after loading a map with a google layer that is
+ // initially hidden.
+ this.termsOfUse.style.left = "-9999px";
+ this.poweredBy.style.display = "none";
+ * Method: getMapContainer
+ * Returns:
+ * {DOMElement} the GMap container's div
+ getMapContainer: function() {
+ return this.mapObject.getContainer();
+ // TRANSLATION: MapObject Bounds <-> OpenLayers.Bounds
* APIMethod: getMapObjectBoundsFromOLBounds
* Parameters:
@@ -27096,49 +28320,7 @@
return moBounds;
- * Method: addContainerPxFunction
- * Hack-on function because GMAPS does not give it to us
- * Parameters:
- * gLatLng - {GLatLng}
- * Returns:
- * {GPoint} A GPoint specifying gLatLng translated into "Container" coords
- addContainerPxFunction: function() {
- if ( (typeof GMap2 != "undefined") &&
- !GMap2.prototype.fromLatLngToContainerPixel) {
- GMap2.prototype.fromLatLngToContainerPixel = function(gLatLng) {
- // first we translate into "DivPixel"
- var gPoint = this.fromLatLngToDivPixel(gLatLng);
- // locate the sliding "Div" div
- var div = this.getContainer().firstChild.firstChild;
- // adjust by the offset of "Div" and voila!
- gPoint.x += div.offsetLeft;
- gPoint.y += div.offsetTop;
- return gPoint;
- * APIMethod: getWarningHTML
- * Returns:
- * {String} String with information on why layer is broken, how to get
- * it working.
- getWarningHTML:function() {
- return OpenLayers.i18n("googleWarning");
@@ -27171,27 +28353,7 @@
this.dragObject.moveBy(new GSize(-dX, dY));
- * APIMethod: getMapObjectCenter
- * Returns:
- * {Object} The mapObject's current center in Map Object format
- getMapObjectCenter: function() {
- return this.mapObject.getCenter();
- * APIMethod: getMapObjectZoom
- * Returns:
- * {Integer} The mapObject's current zoom, in Map Object format
- getMapObjectZoom: function() {
- return this.mapObject.getZoom();
// LonLat - Pixel Translation
@@ -27246,37 +28408,6 @@
// LonLat
- * APIMethod: getLongitudeFromMapObjectLonLat
- * Parameters:
- * moLonLat - {Object} MapObject LonLat format
- * Returns:
- * {Float} Longitude of the given MapObject LonLat
- getLongitudeFromMapObjectLonLat: function(moLonLat) {
- return this.sphericalMercator ?
- this.forwardMercator(moLonLat.lng(), moLonLat.lat()).lon :
- moLonLat.lng();
- * APIMethod: getLatitudeFromMapObjectLonLat
- * Parameters:
- * Returns:
- * {Float} Latitude of the given MapObject LonLat
- getLatitudeFromMapObjectLonLat: function(moLonLat) {
- var lat = this.sphericalMercator ?
- this.forwardMercator(moLonLat.lng(), moLonLat.lat()).lat :
- moLonLat.lat();
- return lat;
* APIMethod: getMapObjectLonLatFromLonLat
* Parameters:
@@ -27300,32 +28431,6 @@
// Pixel
- * APIMethod: getXFromMapObjectPixel
- * Parameters:
- * moPixel - {Object} MapObject Pixel format
- * Returns:
- * {Integer} X value of the MapObject Pixel
- getXFromMapObjectPixel: function(moPixel) {
- return moPixel.x;
- * APIMethod: getYFromMapObjectPixel
- * Parameters:
- * Returns:
- * {Integer} Y value of the MapObject Pixel
- getYFromMapObjectPixel: function(moPixel) {
- return moPixel.y;
* APIMethod: getMapObjectPixelFromXY
* Parameters:
@@ -27337,22 +28442,16 @@
getMapObjectPixelFromXY: function(x, y) {
return new GPoint(x, y);
- CLASS_NAME: "OpenLayers.Layer.Google"
- * Property: OpenLayers.Layer.Google.cache
- * {Object} Cache for elements that should only be created once per map.
-OpenLayers.Layer.Google.cache = {};
OpenLayers/Layer/Grid.js
* full text of the license. */
@@ -27560,7 +28659,7 @@
setTileSize: function(size) {
if (this.singleTile) {
- size = this.map.getSize().clone();
+ size = this.map.getSize();
size.h = parseInt(size.h * this.ratio);
size.w = parseInt(size.w * this.ratio);
@@ -27707,7 +28806,7 @@
var minCols = Math.ceil(viewSize.w/this.tileSize.w) +
Math.max(1, 2 * this.buffer);
- var extent = this.maxExtent;
+ var extent = this.getMaxExtent();
var resolution = this.map.getResolution();
var tileLayout = this.calculateGridLayout(bounds, extent, resolution);
@@ -27782,6 +28881,18 @@
//now actually draw the tiles
this.spiralTileLoad();
+ * Method: getMaxExtent
+ * Get this layer's maximum extent. (Implemented as a getter for
+ * potential specific implementations in sub-classes.)
+ * Returns:
+ * {OpenLayers.Bounds}
+ getMaxExtent: function() {
+ return this.maxExtent;
* Method: spiralTileLoad
@@ -28097,8 +29208,9 @@
OpenLayers/Layer/VirtualEarth.js
@@ -28165,6 +29277,14 @@
type: null,
@@ -28225,8 +29345,6 @@
this.mapObject.AttachEvent("onmousedown", OpenLayers.Function.True);
} catch (e) { }
- this.mapObject.AttachEvent("onresize",
- OpenLayers.Function.bindAsEventListener(this.redrawDependentLayers, this));
this.mapObject.HideDashboard();
if(typeof this.mapObject.SetAnimationEnabled == "function") {
this.mapObject.SetAnimationEnabled(this.animationEnabled);
@@ -28245,20 +29363,6 @@
- * Method: redrawDependentLayers
- redrawDependentLayers: function(event) {
- if(this.isBaseLayer) {
- for(var i=0, len=this.map.layers.length; i<len; i++) {
- var otherLayer = this.map.layers[i];
- if (otherLayer != this) {
- otherLayer.redraw();
* Method: onMapResize
@@ -28476,8 +29580,9 @@
OpenLayers/Layer/Yahoo.js
@@ -28542,6 +29647,14 @@
type: null,
* cause all interactions with the map to be in the actual map projection,
@@ -28901,9 +30014,10 @@
OpenLayers/Style.js
- * full text of the license. */
+ * full text of the license. */
@@ -28919,6 +30033,12 @@
OpenLayers.Style = OpenLayers.Class({
+ * Property: id
+ * {String} A unique id for this session.
+ id: null,
* APIProperty: name
* {String}
@@ -29022,6 +30142,7 @@
this.setDefaultStyle(style ||
OpenLayers.Feature.Vector.style["default"]);
+ this.id = OpenLayers.Util.createUniqueID(this.CLASS_NAME + "_");
@@ -29236,7 +30357,7 @@
* rules - {Array(<OpenLayers.Rule>)}
addRules: function(rules) {
- this.rules = this.rules.concat(rules);
+ Array.prototype.push.apply(this.rules, rules);
this.propertyStyles = this.findPropertyStyles();
@@ -29272,6 +30393,29 @@
+ * APIMethod: clone
+ * Clones this style.
+ * Returns:
+ * {<OpenLayers.Style>} Clone of this style.
+ clone: function() {
+ var options = OpenLayers.Util.extend({}, this);
+ // clone rules
+ if(this.rules) {
+ options.rules = [];
+ for(var i=0, len=this.rules.length; i<len; ++i) {
+ options.rules.push(this.rules[i].clone());
+ // clone context
+ options.context = this.context && OpenLayers.Util.extend({}, this.context);
+ //clone default style
+ var defaultStyle = OpenLayers.Util.extend({}, this.defaultStyle);
+ return new OpenLayers.Style(defaultStyle, options);
CLASS_NAME: "OpenLayers.Style"
@@ -29311,13 +30455,15 @@
* {Array} prefixes of the sld symbolizers. These are the
* same as the main geometry types
-OpenLayers.Style.SYMBOLIZER_PREFIXES = ['Point', 'Line', 'Polygon', 'Text'];
+OpenLayers.Style.SYMBOLIZER_PREFIXES = ['Point', 'Line', 'Polygon', 'Text',
+ 'Raster'];
OpenLayers/Control/Navigation.js
@@ -29622,9 +30768,10 @@
OpenLayers/Filter.js
-/* Copyright (c) 2006 MetaCarta, Inc., published under a modified BSD license.
- * See http://svn.openlayers.org/trunk/openlayers/repository-license.txt
- * for the full text of the license. */
@@ -29666,7 +30813,8 @@
* subclasses.
* Parameters:
- * context - {Object} Context to use in evaluating the filter.
+ * context - {Object} Context to use in evaluating the filter. If a vector
+ * feature is provided, the feature.attributes will be used as context.
* Returns:
* {Boolean} The filter applies.
@@ -29692,8 +30840,9 @@
OpenLayers/Geometry.js
@@ -30151,8 +31300,9 @@
OpenLayers/Layer/MapGuide.js
- * licence. See http://svn.openlayers.org/trunk/openlayers/license.txt for the
@@ -30506,7 +31656,7 @@
allParams = OpenLayers.Util.extend(allParams, newParams);
// ignore parameters that are already in the url search string
var urlParams = OpenLayers.Util.upperCaseObject(
- OpenLayers.Util.getArgs(url));
+ OpenLayers.Util.getParameters(url));
for(var key in allParams) {
if(key.toUpperCase() in urlParams) {
delete allParams[key];
@@ -30643,8 +31793,9 @@
OpenLayers/Layer/MapServer.js
@@ -30845,8 +31996,9 @@
OpenLayers/Layer/WMS.js
@@ -30913,11 +32065,11 @@
* Property: yx
- * {Array} Array of strings with the EPSG codes for which the axis order
- * is to be reversed (yx instead of xy, LatLon instead of LonLat). This
- * is only relevant for WMS versions >= 1.3.0.
+ * {Object} Keys in this object are EPSG codes for which the axis order
+ * is to be reversed (yx instead of xy, LatLon instead of LonLat), with
+ * true as value. This is only relevant for WMS versions >= 1.3.0.
- yx: ['EPSG:4326'],
+ yx: {'EPSG:4326': true},
* Constructor: OpenLayers.Layer.WMS
@@ -30942,6 +32094,9 @@
var newArguments = [];
//uppercase params
params = OpenLayers.Util.upperCaseObject(params);
+ if (parseFloat(params.VERSION) >= 1.3 && !params.EXCEPTIONS) {
+ params.EXCEPTIONS = "INIMAGE";
newArguments.push(name, url, params, options);
OpenLayers.Layer.Grid.prototype.initialize.apply(this, newArguments);
@@ -31013,8 +32168,7 @@
reverseAxisOrder: function() {
return (parseFloat(this.params.VERSION) >= 1.3 &&
- OpenLayers.Util.indexOf(this.yx,
- this.map.getProjectionObject().getCode()) !== -1)
+ !!this.yx[this.map.getProjectionObject().getCode()]);
@@ -31111,17 +32265,223 @@
CLASS_NAME: "OpenLayers.Layer.WMS"
+ OpenLayers/Layer/XYZ.js
+ * @requires OpenLayers/Layer/Grid.js
+ * @requires OpenLayers/Tile/Image.js
+ * Class: OpenLayers.Layer.XYZ
+ * The XYZ class is designed to make it easier for people who have tiles
+ * arranged by a standard XYZ grid.
+ * Inherits from:
+ * - <OpenLayers.Layer.Grid>
+OpenLayers.Layer.XYZ = OpenLayers.Class(OpenLayers.Layer.Grid, {
+ * APIProperty: isBaseLayer
+ * Default is true, as this is designed to be a base tile source.
+ isBaseLayer: true,
+ * APIProperty: sphericalMecator
+ * Whether the tile extents should be set to the defaults for
+ * spherical mercator. Useful for things like OpenStreetMap.
+ * Default is false, except for the OSM subclass.
+ sphericalMercator: false,
+ * APIProperty: zoomOffset
+ * {Number} If your cache has more zoom levels than you want to provide
+ * access to with this layer, supply a zoomOffset. This zoom offset
+ * is added to the current map zoom level to determine the level
+ * for a requested tile. For example, if you supply a zoomOffset
+ * of 3, when the map is at the zoom 0, tiles will be requested from
+ * level 3 of your cache. Default is 0 (assumes cache level and map
+ * zoom are equivalent).
+ zoomOffset: 0,
+ * Constructor: OpenLayers.Layer.XYZ
+ * Parameters:
+ * name - {String}
+ * url - {String}
+ * options - {Object} Hashtable of extra options to tag onto the layer
+ initialize: function(name, url, options) {
+ if (options && options.sphericalMercator || this.sphericalMercator) {
+ options = OpenLayers.Util.extend({
+ maxExtent: new OpenLayers.Bounds(
+ -128 * 156543.0339,
+ 128 * 156543.0339,
+ 128 * 156543.0339
+ maxResolution: 156543.0339,
+ numZoomLevels: 19,
+ units: "m",
+ projection: "EPSG:900913"
+ }, options);
+ url = url || this.url;
+ name = name || this.name;
+ var newArguments = [name, url, {}, options];
+ OpenLayers.Layer.Grid.prototype.initialize.apply(this, newArguments);
+ * Create a clone of this layer
+ * Parameters:
+ * obj - {Object} Is this ever used?
+ * Returns:
+ * {<OpenLayers.Layer.XYZ>} An exact clone of this OpenLayers.Layer.XYZ
+ clone: function (obj) {
+ if (obj == null) {
+ obj = new OpenLayers.Layer.XYZ(this.name,
+ this.url,
+ this.getOptions());
+ //get all additions from superclasses
+ obj = OpenLayers.Layer.Grid.prototype.clone.apply(this, [obj]);
+ return obj;
+ * Method: getUrl
+ * Parameters:
+ * bounds - {<OpenLayers.Bounds>}
+ * Returns:
+ * {String} A string with the layer's url and parameters and also the
+ * passed-in bounds and appropriate tile size specified as
+ * parameters
+ getURL: function (bounds) {
+ var res = this.map.getResolution();
+ var x = Math.round((bounds.left - this.maxExtent.left)
+ / (res * this.tileSize.w));
+ var y = Math.round((this.maxExtent.top - bounds.top)
+ / (res * this.tileSize.h));
+ var z = this.map.getZoom() + this.zoomOffset;
+ var url = this.url;
+ var s = '' + x + y + z;
+ if (url instanceof Array)
+ url = this.selectUrl(s, url);
+ var path = OpenLayers.String.format(url, {'x': x, 'y': y, 'z': z});
+ return path;
+ * Method: addTile
+ * addTile creates a tile, initializes it, and adds it to the layer div.
+ * Parameters:
+ * position - {<OpenLayers.Pixel>}
+ * Returns:
+ * {<OpenLayers.Tile.Image>} The added OpenLayers.Tile.Image
+ addTile:function(bounds,position) {
+ return new OpenLayers.Tile.Image(this, position, bounds,
+ null, this.tileSize);
+ /* APIMethod: setMap
+ * When the layer is added to a map, then we can fetch our origin
+ * (if we don't have one.)
+ * Parameters:
+ * map - {<OpenLayers.Map>}
+ setMap: function(map) {
+ OpenLayers.Layer.Grid.prototype.setMap.apply(this, arguments);
+ if (!this.tileOrigin) {
+ this.tileOrigin = new OpenLayers.LonLat(this.maxExtent.left,
+ this.maxExtent.bottom);
+ CLASS_NAME: "OpenLayers.Layer.XYZ"
+ * Class: OpenLayers.Layer.OSM
+ * A class to access OpenStreetMap tiles. By default, uses the OpenStreetMap
+ * hosted tile.openstreetmap.org 'Mapnik' tileset. If you wish to use
+ * tiles at home / osmarender layer instead, you can pass a layer like:
+ * (code)
+ * new OpenLayers.Layer.OSM("t at h",
+ * "http://tah.openstreetmap.org/Tiles/tile/${z}/${x}/${y}.png");
+ * (end)
+ * This layer defaults to Spherical Mercator.
+ * Inherits from:
+ * - <OpenLayers.Layer.XYZ>
+OpenLayers.Layer.OSM = OpenLayers.Class(OpenLayers.Layer.XYZ, {
+ name: "OpenStreetMap",
+ attribution: "Data CC-By-SA by <a href='http://openstreetmap.org/'>OpenStreetMap</a>",
+ sphericalMercator: true,
+ url: 'http://tile.openstreetmap.org/${z}/${x}/${y}.png',
+ clone: function(obj) {
+ obj = new OpenLayers.Layer.OSM(
+ this.name, this.url, this.getOptions());
+ obj = OpenLayers.Layer.XYZ.prototype.clone.apply(this, [obj]);
+ return obj;
+ CLASS_NAME: "OpenLayers.Layer.OSM"
OpenLayers/Rule.js
* @requires OpenLayers/Util.js
* @requires OpenLayers/Style.js
+ * @requires OpenLayers/Symbolizer/Point.js
+ * @requires OpenLayers/Symbolizer/Line.js
+ * @requires OpenLayers/Symbolizer/Polygon.js
+ * @requires OpenLayers/Symbolizer/Text.js
+ * @requires OpenLayers/Symbolizer/Raster.js
@@ -31140,7 +32500,7 @@
* APIProperty: name
* {String} name of this rule
- name: 'default',
+ name: null,
* Property: title
@@ -31190,6 +32550,17 @@
symbolizer: null,
+ * Property: symbolizers
+ * {Array} Collection of symbolizers associated with this rule. If
+ * provided at construction, the symbolizers array has precedence
+ * over the deprecated symbolizer property. Note that multiple
+ * symbolizers are not currently supported by the vector renderers.
+ * Rules with multiple symbolizers are currently only useful for
+ * maintaining elements in an SLD document.
+ symbolizers: null,
* APIProperty: minScaleDenominator
* {Number} or {String} minimum scale at which to draw the feature.
* In the case of a String, this can be a combination of text and
@@ -31219,6 +32590,9 @@
initialize: function(options) {
this.symbolizer = {};
OpenLayers.Util.extend(this, options);
+ if (this.symbolizers) {
+ delete this.symbolizer;
@@ -31231,6 +32605,7 @@
this.symbolizer[i] = null;
this.symbolizer = null;
+ delete this.symbolizers;
@@ -31303,16 +32678,26 @@
clone: function() {
- // clone symbolizer
- options.symbolizer = {};
- for(var key in this.symbolizer) {
- value = this.symbolizer[key];
- type = typeof value;
- if(type === "object") {
- options.symbolizer[key] = OpenLayers.Util.extend({}, value);
- } else if(type === "string") {
- options.symbolizer[key] = value;
+ // clone symbolizers
+ var len = this.symbolizers.length;
+ options.symbolizers = new Array(len);
+ for (var i=0; i<len; ++i) {
+ options.symbolizers[i] = this.symbolizers[i].clone();
+ } else {
+ options.symbolizer = {};
+ var value, type;
+ for(var key in this.symbolizer) {
+ value = this.symbolizer[key];
+ type = typeof value;
+ if(type === "object") {
+ options.symbolizer[key] = OpenLayers.Util.extend({}, value);
+ } else if(type === "string") {
+ options.symbolizer[key] = value;
// clone filter
options.filter = this.filter && this.filter.clone();
@@ -31327,8 +32712,9 @@
OpenLayers/StyleMap.js
@@ -31490,9 +32876,10 @@
OpenLayers/Filter/Comparison.js
* @requires OpenLayers/Filter.js
@@ -31585,20 +32972,23 @@
* APIMethod: evaluate
- * Evaluates this filter in a specific context. Should be implemented by
- * subclasses.
+ * Evaluates this filter in a specific context.
* Parameters:
* Returns:
evaluate: function(context) {
+ if (context instanceof OpenLayers.Feature.Vector) {
+ context = context.attributes;
var result = false;
+ var got = context[this.property];
switch(this.type) {
case OpenLayers.Filter.Comparison.EQUAL_TO:
- var got = context[this.property];
var exp = this.value;
if(!this.matchCase &&
typeof got == "string" && typeof exp == "string") {
@@ -31608,7 +32998,6 @@
break;
case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:
@@ -31618,24 +33007,24 @@
break;
case OpenLayers.Filter.Comparison.LESS_THAN:
- result = context[this.property] < this.value;
+ result = got < this.value;
break;
case OpenLayers.Filter.Comparison.GREATER_THAN:
- result = context[this.property] > this.value;
+ result = got > this.value;
break;
case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:
- result = context[this.property] <= this.value;
+ result = got <= this.value;
break;
case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:
- result = context[this.property] >= this.value;
+ result = got >= this.value;
break;
case OpenLayers.Filter.Comparison.BETWEEN:
- result = (context[this.property] >= this.lowerBoundary) &&
- (context[this.property] <= this.upperBoundary);
+ result = (got >= this.lowerBoundary) &&
+ (got <= this.upperBoundary);
break;
case OpenLayers.Filter.Comparison.LIKE:
var regexp = new RegExp(this.value, "gi");
- result = regexp.test(context[this.property]);
+ result = regexp.test(got);
break;
return result;
@@ -31749,9 +33138,10 @@
OpenLayers/Filter/Logical.js
@@ -31809,11 +33199,12 @@
- * subclasses.
* Parameters:
+ * context - {Object} Context to use in evaluating the filter. A vector
+ * feature may also be provided to evaluate feature attributes in
+ * comparison filters or geometries in spatial filters.
* Returns:
@@ -31870,9 +33261,10 @@
OpenLayers/Filter/Spatial.js
@@ -32001,8 +33393,9 @@
OpenLayers/Geometry/Collection.js
@@ -32066,6 +33459,7 @@
destroy: function () {
this.components.length = 0;
this.components = null;
+ OpenLayers.Geometry.prototype.destroy.apply(this, arguments);
@@ -32263,22 +33657,67 @@
* APIMethod: getCentroid
+ * Compute the centroid for this geometry collection.
+ * Parameters:
+ * weighted - {Boolean} Perform the getCentroid computation recursively,
+ * returning an area weighted average of all geometries in this collection.
* Returns:
* {<OpenLayers.Geometry.Point>} The centroid of the collection
- getCentroid: function() {
- return this.components.length && this.components[0].getCentroid();
- var centroid;
- for (var i=0, len=this.components.length; i<len; i++) {
- if (!centroid) {
- centroid = this.components[i].getCentroid();
- } else {
- centroid.resize(this.components[i].getCentroid(), 0.5);
+ getCentroid: function(weighted) {
+ if (!weighted) {
+ return this.components.length && this.components[0].getCentroid();
+ var len = this.components.length;
+ if (!len) {
+ return false;
+ var areas = [];
+ var centroids = [];
+ var areaSum = 0;
+ var minArea = Number.MAX_VALUE;
+ var component;
+ component = this.components[i];
+ var area = component.getArea();
+ var centroid = component.getCentroid(true);
+ if (isNaN(area) || isNaN(centroid.x) || isNaN(centroid.y)) {
+ continue;
+ areas.push(area);
+ areaSum += area;
+ minArea = (area < minArea && area > 0) ? area : minArea;
+ centroids.push(centroid);
- return centroid;
+ len = areas.length;
+ if (areaSum === 0) {
+ // all the components in this collection have 0 area
+ // probably a collection of points -- weight all the points the same
+ areas[i] = 1;
+ areaSum = areas.length;
+ } else {
+ // normalize all the areas where the smallest area will get
+ // a value of 1
+ areas[i] /= minArea;
+ areaSum /= minArea;
+ var xSum = 0, ySum = 0, centroid, area;
+ centroid = centroids[i];
+ area = areas[i];
+ xSum += centroid.x * area;
+ ySum += centroid.y * area;
+ return new OpenLayers.Geometry.Point(xSum/areaSum, ySum/areaSum);
@@ -32504,8 +33943,9 @@
OpenLayers/Geometry/Point.js
@@ -32790,8 +34230,9 @@
OpenLayers/Layer/Vector.js
@@ -32846,6 +34287,9 @@
* beforefeatureremoved - Triggered before a feature is removed. Listeners
* will receive an object with a *feature* property referencing the
* feature to be removed.
+ * beforefeaturesremoved - Triggered before multiple features are removed.
+ * Listeners will receive an object with a *features* property
+ * referencing the features to be removed.
* featureremoved - Triggerd after a feature is removed. The event
* object passed to listeners will have a *feature* property with a
* reference to the removed feature.
@@ -32889,8 +34333,8 @@
* for a new set of features.
EVENT_TYPES: ["beforefeatureadded", "beforefeaturesadded",
- "featureadded", "featuresadded",
- "beforefeatureremoved", "featureremoved", "featuresremoved",
+ "featureadded", "featuresadded", "beforefeatureremoved",
+ "beforefeaturesremoved", "featureremoved", "featuresremoved",
"beforefeatureselected", "featureselected", "featureunselected",
"beforefeaturemodified", "featuremodified", "afterfeaturemodified",
"vertexmodified", "sketchstarted", "sketchmodified",
@@ -33146,10 +34590,12 @@
assignRenderer: function() {
for (var i=0, len=this.renderers.length; i<len; i++) {
- var rendererClass = OpenLayers.Renderer[this.renderers[i]];
- if (rendererClass && rendererClass.prototype.supported()) {
- this.renderer = new rendererClass(this.div,
- this.rendererOptions);
+ var rendererClass = this.renderers[i];
+ var renderer = (typeof rendererClass == "function") ?
+ rendererClass :
+ OpenLayers.Renderer[rendererClass];
+ if (renderer && renderer.prototype.supported()) {
+ this.renderer = new renderer(this.div, this.rendererOptions);
break;
@@ -33213,6 +34659,7 @@
removeMap: function(map) {
+ this.drawn = false;
if(this.strategies) {
var strategy, i, len;
for(i=0, len=this.strategies.length; i<len; i++) {
@@ -33330,7 +34777,9 @@
features = event.features;
+ // Track successfully added features for featuresadded event, since
+ // beforefeatureadded can veto single features.
+ var featuresAdded = [];
for (var i=0, len=features.length; i<len; i++) {
if (i != (features.length - 1)) {
this.renderer.locked = true;
@@ -33346,8 +34795,6 @@
throw throwStr;
- this.features.push(feature);
//give feature reference to its layer
feature.layer = this;
@@ -33363,6 +34810,8 @@
this.preFeatureInsert(feature);
+ featuresAdded.push(feature);
+ this.features.push(feature);
this.drawFeature(feature);
if (notify) {
@@ -33374,7 +34823,7 @@
if(notify) {
- this.events.triggerEvent("featuresadded", {features: features});
+ this.events.triggerEvent("featuresadded", {features: featuresAdded});
@@ -33400,14 +34849,23 @@
if(!features || features.length === 0) {
return;
+ if (features === this.features) {
+ return this.removeAllFeatures(options);
if (!(features instanceof Array)) {
features = [features];
- if (features === this.features || features === this.selectedFeatures) {
+ if (features === this.selectedFeatures) {
features = features.slice();
var notify = !options || !options.silent;
+ if (notify) {
+ "beforefeaturesremoved", {features: features}
for (var i = features.length - 1; i >= 0; i--) {
// We remain locked so long as we're not at 0
@@ -33458,6 +34916,49 @@
this.events.triggerEvent("featuresremoved", {features: features});
+ * APIMethod: removeAllFeatures
+ * Remove all features from the layer.
+ * Parameters:
+ * options - {Object} Optional properties for changing behavior of the
+ * removal.
+ * Valid options:
+ * silent - {Boolean} Supress event triggering. Default is false.
+ removeAllFeatures: function(options) {
+ var notify = !options || !options.silent;
+ var features = this.features;
+ if (notify) {
+ var feature;
+ for (var i = features.length-1; i >= 0; i--) {
+ feature = features[i];
+ if (notify) {
+ this.events.triggerEvent("beforefeatureremoved", {
+ feature: feature
+ feature.layer = null;
+ if (notify) {
+ this.events.triggerEvent("featureremoved", {
+ feature: feature
+ this.renderer.clear();
+ this.features = [];
+ this.unrenderedFeatures = {};
+ this.selectedFeatures = [];
+ if (notify) {
+ this.events.triggerEvent("featuresremoved", {features: features});
* APIMethod: destroyFeatures
@@ -33499,7 +35000,7 @@
* Parameters:
* feature - {<OpenLayers.Feature.Vector>}
- * style - {Object} Symbolizer hash or {String} renderIntent
+ * style - {String | Object} Named render intent or full symbolizer object.
drawFeature: function(feature, style) {
// don't try to draw the feature with the renderer if the layer is not
@@ -33555,31 +35056,62 @@
var featureId = this.renderer.getFeatureIdFromEvent(evt);
return this.getFeatureById(featureId);
- * APIMethod: getFeatureById
- * Given a feature id, return the feature if it exists in the features array
+ * APIMethod: getFeatureBy
+ * Given a property value, return the feature if it exists in the features array
* Parameters:
- * featureId - {String}
+ * property - {String}
+ * value - {String}
* Returns:
* {<OpenLayers.Feature.Vector>} A feature corresponding to the given
- * featureId
+ * property value or null if there is no such feature.
- getFeatureById: function(featureId) {
+ getFeatureBy: function(property, value) {
//TBD - would it be more efficient to use a hash for this.features?
var feature = null;
for(var i=0, len=this.features.length; i<len; ++i) {
- if(this.features[i].id == featureId) {
+ if(this.features[i][property] == value) {
feature = this.features[i];
break;
return feature;
+ * APIMethod: getFeatureById
+ * Given a feature id, return the feature if it exists in the features array
+ * Parameters:
+ * featureId - {String}
+ * Returns:
+ * {<OpenLayers.Feature.Vector>} A feature corresponding to the given
+ * featureId or null if there is no such feature.
+ getFeatureById: function(featureId) {
+ return this.getFeatureBy('id', featureId);
+ * APIMethod: getFeatureByFid
+ * Given a feature fid, return the feature if it exists in the features array
+ * Parameters:
+ * featureFid - {String}
+ * Returns:
+ * featureFid or null if there is no such feature.
+ getFeatureByFid: function(featureFid) {
+ return this.getFeatureBy('fid', featureFid);
* Unselect the selected features
* i.e. clears the featureSelection array
* change the style back
@@ -33649,8 +35181,9 @@
OpenLayers/Geometry/MultiPoint.js
@@ -33722,8 +35255,9 @@
OpenLayers/Handler/Point.js
@@ -34098,8 +35632,9 @@
OpenLayers/Protocol/HTTP.js
@@ -34108,6 +35643,7 @@
* @requires OpenLayers/Filter/Spatial.js
* @requires OpenLayers/Filter/Comparison.js
* @requires OpenLayers/Filter/Logical.js
+ * @requires OpenLayers/Request/XMLHttpRequest.js
@@ -34755,8 +36291,9 @@
OpenLayers/Geometry/Curve.js
@@ -34851,8 +36388,9 @@
OpenLayers/Geometry/LineString.js
@@ -35406,8 +36944,9 @@
OpenLayers/Geometry/LinearRing.js
@@ -35826,8 +37365,9 @@
OpenLayers/Geometry/MultiLineString.js
@@ -36091,8 +37631,9 @@
OpenLayers/Handler/Path.js
@@ -36396,8 +37937,9 @@
OpenLayers/Geometry/Polygon.js
@@ -36658,8 +38200,9 @@
OpenLayers/Geometry/MultiPolygon.js
@@ -36707,8 +38250,9 @@
OpenLayers/Handler/Polygon.js
@@ -36854,8 +38398,9 @@
OpenLayers/Format/GML.js
@@ -36996,7 +38541,9 @@
// only accept one geometry per feature - look for highest "order"
var order = ["MultiPolygon", "Polygon",
"MultiLineString", "LineString",
- "MultiPoint", "Point", "Envelope", "Box"];
+ "MultiPoint", "Point", "Envelope"];
+ // FIXME: In case we parse a feature with no geometry, but boundedBy an Envelope,
+ // this code creates a geometry derived from the Envelope. This is not correct.
var type, nodeList, geometry, parser;
for(var i=0; i<order.length; ++i) {
type = order[i];
@@ -37018,6 +38565,21 @@
break;
+ var bounds;
+ var boxNodes = this.getElementsByTagNameNS(node, this.gmlns, "Box");
+ for(i=0; i<boxNodes.length; ++i) {
+ var boxNode = boxNodes[i];
+ var box = this.parseGeometry["box"].apply(this, [boxNode]);
+ var parentNode = boxNode.parentNode;
+ var parentName = parentNode.localName ||
+ parentNode.nodeName.split(":").pop();
+ if(parentName === "boundedBy") {
+ bounds = box;
+ } else {
+ geometry = box.toGeometry();
// construct feature (optionally with attributes)
var attributes;
@@ -37025,6 +38587,7 @@
attributes = this.parseAttributes(node);
var feature = new OpenLayers.Feature.Vector(geometry, attributes);
+ feature.bounds = bounds;
feature.gml = {
featureType: node.firstChild.nodeName.split(":")[1],
@@ -37032,14 +38595,6 @@
featureNSPrefix: node.firstChild.prefix
- var boundedByNodes = this.getElementsByTagNameNS(node, this.gmlns, 'boundedBy');
- if (boundedByNodes.length === 1) {
- parser = this.parseGeometry['box'];
- if (parser) {
- feature.bounds = parser.apply(this, [boundedByNodes[0]]);
// assign fid - this can come from a "fid" or "id" attribute
var childNode = node.firstChild;
var fid;
@@ -37771,8 +39326,9 @@
OpenLayers/Format/GML/Base.js
@@ -38352,8 +39908,9 @@
OpenLayers/Format/GML/v2.js
@@ -38548,8 +40105,9 @@
OpenLayers/Format/GML/v3.js
More information about the fusion-commits
