[fusion-commits] r2229 - sandbox/jxlib-3.0/lib
svn_fusion at osgeo.org
Wed Sep 15 10:14:28 EDT 2010
Author: pagameba
Date: 2010-09-15 14:14:28 +0000 (Wed, 15 Sep 2010)
New Revision: 2229
sandbox/jxlib-3.0/lib/jxlib.uncompressed.js
fixing a few jxlib issues with the grid (it renders in firefox now).
Modified: sandbox/jxlib-3.0/lib/jxlib.uncompressed.js
--- sandbox/jxlib-3.0/lib/jxlib.uncompressed.js 2010-09-13 12:47:18 UTC (rev 2228)
+++ sandbox/jxlib-3.0/lib/jxlib.uncompressed.js 2010-09-15 14:14:28 UTC (rev 2229)
@@ -31525,7 +31525,7 @@
-// $Id: columns.js 981 2010-09-13 12:18:35Z pagameba $
+// $Id: columns.js 982 2010-09-15 13:49:13Z pagameba $
* Class: Jx.Columns
@@ -31749,7 +31749,7 @@
if (this.useHeaders()) {
this.columns.each(function(col, idx) {
if (!col.isHidden() && col != rhc) {
- var classes = ['jxGridColHead', 'jxGridCol'+idx, 'jxGridCol'+col.options.name],
+ var classes = ['jxGridColHead', 'jxGridCol'+idx, 'jxCol-'+col.options.name, 'jxColHead-'+col.options.name],
th;
if (col.isEditable()) { classes.push('jxColEditable'); }
if (col.isResizable()) { classes.push('jxColResizable'); }
@@ -31791,7 +31791,7 @@
rhc = grid.row.useHeaders() ?
this.getByName(row.options.headerColumn) : null,
domInserts = [],
- i;
+ i = 0;
this.columns.each(function(column, index) {
if (!column.isHidden() && column != rhc) {
if (column.options.renderer && column.options.renderer.domInsert) {
@@ -32337,7 +32337,7 @@
-// $Id: grid.js 981 2010-09-13 12:18:35Z pagameba $
+// $Id: grid.js 982 2010-09-15 13:49:13Z pagameba $
* Class: Jx.Grid
@@ -32535,10 +32535,8 @@
wantEvent: function(eventName) {
- console.log('wantEvent ' + eventName);
var hook = this.hooks.get(eventName);
if (hook === false) {
- console.log('hooking event ' + eventName);
switch(eventName) {
case 'gridColumnEnter':
case 'gridColumnLeave':
@@ -32591,8 +32589,6 @@
default:
break;
- } else {
- console.log('event is already hooked');
@@ -32625,8 +32621,8 @@
store.addEvent('storeColumnChanged', this.updateRow);
store.addEvent('storeRecordRemoved', this.removeRow);
store.addEvent('storeMultipleRecordsRemoved', this.removeRows);
- if (this.store.loaded) {
- this.storeLoaded();
+ if (store.loaded) {
+ this.storeLoaded(store);
if (!this.columns.useHeaders()) {
@@ -32650,6 +32646,10 @@
this.wantEvent(key);
}, this);
+ if (document.id(this.options.parent)) {
+ this.addTo(this.options.parent);
@@ -32729,7 +32729,7 @@
return this.store;
- storeLoaded: function(store, response) {
+ storeLoaded: function(store) {
var template = '',
tr,
columns = [],
@@ -32876,16 +32876,15 @@
* that is handled by the render() method
drawStore: function() {
- console.profile();
this.domObj.resize();
this.gridTableBody.empty();
if (this.row.useHeaders()) {
this.rowTableBody.empty();
this.store.each(function(record,index) {
+ this.store.index = index;
this.drawRow(record, index);
}, this);
- console.profileEnd();
@@ -32903,6 +32902,7 @@
var columns = this.columns,
body = this.gridTableBody,
row = this.row,
+ store = this.store,
rowHeaders = row.useHeaders(),
autoRowHeight = row.options.rowHeight == 'auto',
rowBody = this.rowTableBody,
@@ -32919,13 +32919,13 @@
position = 'bottom';
tr = row.getGridRowElement(index, '');
- columns.getRow(tr, record);
if (position == 'replace' && index < body.childNodes.length) {
tr.inject(body.childNodes[index], 'after');
body.childNodes[index].dispose();
} else {
tr.inject(body, position);
+ columns.getRow(tr, record);
if (rowHeaders) {
if (row.options.headerColumn) {
rowHeaderColumn = columns.getByName(row.options.headerColumn);
@@ -33507,7 +33507,7 @@
-// $Id: grid.selector.js 981 2010-09-13 12:18:35Z pagameba $
+// $Id: grid.selector.js 982 2010-09-15 13:49:13Z pagameba $
* Class: Jx.Plugin.Grid.Selector
@@ -33563,7 +33563,12 @@
* Option: checkAsHeader
* Determines if the check column is the header of the rows
- checkAsHeader: false
+ checkAsHeader: false,
+ * Option: sortableColumn
+ * Determines if the check column is sortable
+ sortableColumn: false
domInsert: true,
@@ -33622,7 +33627,8 @@
renderMode: 'fixed',
width: 20,
renderer: null,
- name: 'selection'
+ name: 'selection',
+ isSortable: this.options.sortableColumn || false
}, grid);
this.checkColumn.options.renderer = this;
grid.columns.columns.reverse();
@@ -34390,7 +34396,7 @@
-// $Id: grid.sorter.js 981 2010-09-13 12:18:35Z pagameba $
+// $Id: grid.sorter.js 982 2010-09-15 13:49:13Z pagameba $
* Class: Jx.Plugin.Grid.Sorter
More information about the fusion-commits
