[fusion-commits] r2233 - sandbox/jxlib-3.0/lib
svn_fusion at osgeo.org
Wed Sep 22 15:14:57 EDT 2010
Author: madair
Date: 2010-09-22 19:14:57 +0000 (Wed, 22 Sep 2010)
New Revision: 2233
sandbox/jxlib-3.0/lib/ApplicationDefinition.js
convert numeric option values in AppDef to floats
Modified: sandbox/jxlib-3.0/lib/ApplicationDefinition.js
--- sandbox/jxlib-3.0/lib/ApplicationDefinition.js 2010-09-21 19:31:25 UTC (rev 2232)
+++ sandbox/jxlib-3.0/lib/ApplicationDefinition.js 2010-09-22 19:14:57 UTC (rev 2233)
@@ -1,1330 +1,1343 @@
- * Fusion.Lib.ApplicationDefinition
- * $Id$
- * Copyright (c) 2007, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
- * Class: Fusion.Lib.ApplicationDefinition
- * Utility class to parse an application definition
-Fusion.Lib.ApplicationDefinition = OpenLayers.Class({
- * Property: mapGroups
- * array of map groups, parsed from ApplicationDefinition. A MapGroup
- * consists of one or more Maps that can be combined into the same
- * OpenLayers Map object
- mapGroups: null,
- * Property: widgetSets
- * array of widget sets (each one corresponding to a map) parsed
- * from the ApplicationDefinition.
- widgetSets: null,
- * Property: {Object} oBroker
- * A Broker object that can communicate with a MapGuide instance
- * in the case we are running against a MapGuide server
- oBroker: null,
- * Property: {Array} searchDefinitions
- * An array of search definitions
- searchDefinitions: null,
- * Property: {Array} searchCategories
- * An array of search categories
- searchCategories: null,
- * Constructor: ApplicationDefinition
- * construct a new instance of the ApplicationDefinition object. While
- * not enforced, this is intended to be a singleton.
- * Parameter: sessionId
- * an optional session id to initialize the application with, passed to
- * the map widgets when they are created.
- initialize: function(sessionId) {
- //console.log('ApplicationDefinition initialize');
- this.sessionId = sessionId;
- this.oBroker = Fusion.getBroker();
- this.applicationDefinition = Fusion.getApplicationDefinitionURL();
- this.widgetSets = [];
- this.mapGroups = {};
- this.searchDefinitions = [];
- this.searchCategories = [];
- this.parse();
- * Function: parse
- * start parsing the ApplicationDefinition file. This happens
- * asynchronously since the ApplicationDefinition has to be
- * retrieved from the server or the MapGuide repository. When
- * parsing is complete, an APPLICATIONDEFINITION_PARSED event
- * will be emitted. This function returns true if parsing
- * will start, false if it will not (due to a missing
- * application definition for instance).
- parse : function() {
- if (this.applicationDefinition == '') {
- //TODO: emit an error
- return null;
- /* if the application definition is not in the mapguide server,
- just load the xml*/
- if ( (this.applicationDefinition.match('Library://') == null) &&
- (this.applicationDefinition.match('Session:') == null) ) {
- if (Fusion.appDefJson) {
- this.parseAppDef(Fusion.appDefJson);
- } else {
- Fusion.getXmlAsJson(this.applicationDefinition,
- OpenLayers.Function.bind(this.getAppDefCB, this));
- } else {
- //these need to be called via setTimeout so that the execution thread
- //is broken in IE and so that the ApplicationDefinition constructor
- //will return a valid object to Fusion in loadConfig before the loadState
- //gets incremented.
- if (!this.sessionId) {
- window.setTimeout(OpenLayers.Function.bind(this.createSessionThenGetAppDef,this),5);
- } else {
- window.setTimeout(OpenLayers.Function.bind(this.getAppDef,this),5);
- return true;
- createSessionThenGetAppDef: function() {
- var sl = Fusion.getScriptLanguage();
- var scriptURL = 'layers/' + 'MapGuide' + '/' + sl + '/CreateSession.' + sl;
- var options = {onSuccess: OpenLayers.Function.bind(this.createSessionThenGetAppDefCB, this)};
- Fusion.ajaxRequest(scriptURL, options);
- createSessionThenGetAppDefCB : function(xhr) {
- if (xhr && typeof(xhr) == "object" && xhr.responseText) {
- var o;
- eval("o="+xhr.responseText);
- this.sessionId = o.sessionId;
- Fusion.sessionId = this.sessionId;
- this.getAppDef();
- getAppDef: function(){
- var r = new Fusion.Lib.MGRequest.MGGetResourceContent(this.applicationDefinition);
- r.parameters.session = this.sessionId;
- r.parameters.format = 'application/json';
- this.oBroker.dispatchRequest(r,
- getAppDefCB: function(xhr) {
- var o;
- this.parseAppDef(o);
- Fusion.setLoadState(Fusion.LOAD_WIDGETS);
- * Function: parseAppDef
- * parse the ApplicationDefinition file into the appropriate Fusion objects
- * Parameter: {XmlHttpRequest} xhr
- * the XmlHttpRequest object
- parseAppDef: function(json) {
- var appDef = json.ApplicationDefinition;
- /* Set the application title */
- if (appDef.Title) {
- var title = appDef.Title[0];
- document.title = title;
- /* process Map nodes */
- if (appDef.MapSet) {
- var mapSet = appDef.MapSet[0];
- if (mapSet.MapGroup instanceof Array) {
- for (var i=0; i<mapSet.MapGroup.length; i++) {
- var mapGroup = new Fusion.Lib.ApplicationDefinition.MapGroup(mapSet.MapGroup[i]);
- this.mapGroups[mapGroup.mapId] = mapGroup;
- } else {
- Fusion.reportError(new Fusion.Error(Fusion.Error.FATAL,
- OpenLayers.i18n('appDefParseError')));
- /* process WIDGET sets */
- if (appDef.WidgetSet) {
- for (var i=0; i<appDef.WidgetSet.length; i++) {
- var widgetSet = new Fusion.Lib.ApplicationDefinition.WidgetSet(appDef.WidgetSet[i]);
- this.widgetSets.push(widgetSet);
- } else {
- OpenLayers.i18n('widgetSetParseError')));
- /* process extensions */
- if (appDef.Extension) {
- var extension = appDef.Extension[0];
- /* process search definitions */
- if (extension.SearchDefinitions instanceof Array) {
- var categories = extension.SearchDefinitions[0];
- if (categories.SearchCategory instanceof Array) {
- for (var i=0; i<categories.SearchCategory.length; i++) {
- var oCategory = {};
- var category = categories.SearchCategory[i];
- oCategory.id = category['@id'];
- oCategory.name = category['@name'];
- oCategory.layer = category.Layer ? category.Layer[0] : '';
- oCategory.searchDefinitions = [];
- this.searchCategories[oCategory.id] = oCategory;
- var defns = category.SearchDefinition;
- for (var k=0; k<defns.length; k++) {
- var defn = new Fusion.Lib.ApplicationDefinition.SearchDefinition(defns[k]);
- defn.category = oCategory;
- oCategory.searchDefinitions[defn.id] = defn;
- this.searchDefinitions[defn.id] = defn;
- * Function: create
- * Create the application definition. This actually triggers initializing
- * every widget and container.
- create: function() {
- for (var i=0; i<this.widgetSets.length; i++) {
- this.widgetSets[i].create(this);
- * Function: getMapByName
- * return a map widget with the given name
- * Parameter: {String} name
- * The map name to return
- * Returns: {Object} a map object or null if not found.
- getMapByName : function(name) {
- var map = null;
- map = this.widgetSets[i].getMapByName(name);
- if (map) {
- break;
- return map;
- * Function: getMapById
- * return a map widget with the given id
- * Parameter: {String} id
- * The map id to return. ID is distinct from map.name in that id is the
- * id of the HTML tag where the map widget is inserted.
- getMapById : function(id) {
- var map = null;
- map = this.widgetSets[i].mapWidget;
- if (map.mapId == id) {
- break;
- return map;
- * Function: getMapByIndice
- * return the map widget at the given index
- * Parameter: {String} indice
- * The map indice to return
- getMapByIndice : function(indice) {
- var map = null;
- if (this.widgetSets.length > indice) {
- map = this.widgetSets[indice].getMapWidget();
- return map;
- * Function: getMapGroup
- * return the specified map group from the application definition
- * Parameter: {String} mapgroup
- * The id of the MapGroup to return
- * Returns: {Object} a MapGroup appdef or null if not found.
- getMapGroup : function(mapGroupId) {
- return this.mapGroups[mapGroupId];
- * Function getWidgetsByType
- * returns an array of widgets by type.
- * Parameter: {String} type
- * the type of widget to get references to
- * Returns: {Array} an array of widgets, which may be empty
- getWidgetsByType: function(type) {
- var widgets = [];
- widgets = widgets.concat(this.widgetSets[i].getWidgetsByType(type));
- return widgets;
- * Class: Fusion.Lib.ApplicationDefinition.MapGroup
- * Holds an internal representation of MapGroup objects as defined in the AppDef
-Fusion.Lib.ApplicationDefinition.MapGroup = OpenLayers.Class({
- initialView: null,
- maps: null,
- initialize: function(jsonNode) {
- this.mapId = jsonNode['@id'][0];
- this.maps = [];
- /* parse InitialView */
- if (jsonNode.InitialView) {
- var iv = jsonNode.InitialView[0];
- if (iv.CenterX && iv.CenterY && iv.Scale) {
- this.setInitialView({x:parseFloat(iv.CenterX[0]),
- y:parseFloat(iv.CenterY[0]),
- scale:parseFloat(iv.Scale[0])});
- } else if (iv.MinX && iv.MinY && iv.MaxX && iv.MaxY) {
- this.setInitialView({minX:parseFloat(iv.MinX[0]),
- minY:parseFloat(iv.MinY[0]),
- maxX:parseFloat(iv.MaxX[0]),
- maxY:parseFloat(iv.MaxY[0])});
- } else {
- //TODO: emit warning that the initial view was incomplete
- /* parse maps */
- if (jsonNode.Map instanceof Array) {
- for (var i=0; i<jsonNode.Map.length; i++) {
- var map = new Fusion.Lib.ApplicationDefinition.Map(jsonNode.Map[i]);
- var links = {groups:[], layers:[]};
- var mapEvents = {layerEvents:{},groupEvents:{}};
- if (jsonNode.Map[i].Extension) {
- var extension = jsonNode.Map[i].Extension[0];
- if (extension.Links) {
- /* process Groups */
- if (extension.Links[0].Group instanceof Array) {
- for (var j=0; j<extension.Links[0].Group.length; j++) {
- var group = extension.Links[0].Group[j];
- links.groups.push({name:group.Name[0],url:group.Url[0]});
- if (extension.Links[0].Layer instanceof Array) {
- for (var j=0; j<extension.Links[0].Layer.length; j++) {
- var layer = extension.Links[0].Layer[j];
- links.layers.push({name:layer.Name[0],url:layer.Url[0]});
- /* process layer events */
- //TODO: Should this be called MapEvents?
- if (extension.MapEvents) {
- if (extension.MapEvents[0].Layer instanceof Array) {
- for (var j=0; j<extension.MapEvents[0].Layer.length; j++) {
- var layer = extension.MapEvents[0].Layer[j];
- var layerObj = {};
- layerObj.name = layer.Name[0];
- layerObj.onEnable = [];
- if (layer.OnEnable instanceof Array) {
- layerObj.onEnable = this.parseMapEventSubBlock(layer.OnEnable[0]);
- layerObj.onDisable = [];
- if (layer.OnDisable instanceof Array) {
- layerObj.onDisable = this.parseMapEventSubBlock(layer.OnDisable[0]);
- mapEvents.layerEvents[layerObj.name] = layerObj;
- if (extension.MapEvents[0].Group instanceof Array) {
- for (var j=0; j<extension.MapEvents[0].Group.length; j++) {
- var group = extension.MapEvents[0].Group[j];
- var groupObj = {};
- groupObj.name = group.Name[0];
- groupObj.onEnable = [];
- groupObj.onEnable = this.parseMapEventSubBlock(group.OnEnable[0]);
- groupObj.onDisable = [];
- groupObj.onDisable = this.parseMapEventSubBlock(group.OnDisable[0]);
- mapEvents.groupEvents[groupObj.name] = groupObj;
- map.mapInfo = {links: links, mapEvents: mapEvents};
- this.maps.push(map);
- } else {
- //TODO: do we need a warning that there are no layers in this map?
- parseMapEventSubBlock: function(block) {
- var a = [];
- if (block.Layer && block.Layer instanceof Array) {
- for (var i=0; i<block.Layer.length; i++) {
- var layer = block.Layer[i];
- a.push({type: 'layer', name:layer.Name[0], enable: layer.Enable[0] == 'true' ? true : false});
- if (block.Group && block.Group instanceof Array) {
- for (var i=0; i<block.Group.length; i++) {
- var group = block.Group[i];
- a.push({type: 'group', name:group.Name[0], enable: group.Enable[0] == 'true' ? true : false});
- return a;
- getInitialView: function() {
- return this.initialView;
- setInitialView: function(view) {
- this.initialView = view;
- * Holds an internal representation of Map objects as defined in the AppDef
-Fusion.Lib.ApplicationDefinition.Map = OpenLayers.Class({
- type: null,
- singleTile: false,
- extension: null,
- /* TODO: type can be any supported OpenLayers type */
- this.type = jsonNode.Type[0];
- if (jsonNode.SingleTile) {
- var b = jsonNode.SingleTile[0].toLowerCase();
- this.singleTile = (b == "true") ? true : false;
- if (jsonNode.Extension) {
- this.extension = jsonNode.Extension[0];
- } else {
- this.extension = {};
- this.resourceId = this.extension.ResourceId ? this.extension.ResourceId[0] : '';
- var tagOptions = this.extension.Options;
- this.layerOptions = {};
- if (tagOptions && tagOptions[0]) {
- for (var key in tagOptions[0]) {
- this.layerOptions[key] = tagOptions[0][key][0];
- if (this.layerOptions[key].toLowerCase() == 'true') {
- this.layerOptions[key] = true;
- } else if (this.layerOptions[key].toLowerCase() == 'false') {
- this.layerOptions[key] = false;
- if (key == 'maxExtent' || key == 'minExtent') {
- this.layerOptions[key] = OpenLayers.Bounds.fromString(this.layerOptions[key]);
- if (key == 'resolutions' || key == 'scales') {
- this.layerOptions[key] = this.layerOptions[key].split(',');
- var tagParams = this.extension.Parameters;
- this.layerParams = {};
- if (tagParams && tagParams[0]) {
- for (var key in tagParams[0]) {
- this.layerParams[key] = tagParams[0][key][0];
- //projection info from the extension
- //this.layerOptions.projection = "EPSG:4326"; //default to WGS84 lat long
- if (this.extension.ProjectionCode) {
- this.layerOptions.projection = this.extension.ProjectionCode[0];
- if (this.extension.ProjectionDef) {
- var projDef = this.extension.ProjectionDef[0];
- if (!this.layerOptions.projection) {
- this.layerOptions.projection = "APP-DEF-PROJ";
- Proj4js.defs[this.layerOptions.projection] = projDef;
- this.layerOptions.projection = "EPSG:4326";
- switch (this.type) {
- case 'MapGuide':
- case 'MapServer':
- if ( !Fusion.Layers[this.type] ) {
- Fusion.require('layers/' + this.type + '/' + this.type + '.js');
- break;
- case "Google":
- case "Yahoo":
- case "VirtualEarth":
- this.layerOptions.isBaseLayer = true;
- this.layerOptions.sphericalMercator = true;
- this.layerOptions.displayProjection = "EPSG:4326";
- //no break here continue below to set EPSG:3785 as projCode
- default:
- if (this.layerOptions.sphericalMercator) {
- this.layerOptions.projection = "EPSG:900913"; //commercial map layer projection spherical mercator
- } else {
- this.layerOptions.projection = "EPSG:4326"; //WGS84 lat long
- if ( !Fusion.Layers.Generic ) {
- Fusion.require('layers/Generic/Generic.js');
- break;
- * Class: Fusion.Lib.ApplicationDefinition.WidgetSet
- * Holds an internal representation of WidgetSet objects as defined in the AppDef
-Fusion.Lib.ApplicationDefinition.WidgetSet = OpenLayers.Class({
- containers: null,
- containersByName: null,
- widgetTags: null,
- widgetTagsByName: null,
- widgetInstances: null,
- mapWidget: null,
- mapId: null,
- this.containers = [];
- this.widgetTags = [];
- this.widgetInstances = [];
- this.widgetTagsByName = {};
- this.containersByName = {};
- /* process map widgets */
- if (jsonNode.MapWidget) {
- for (var i=0; i<jsonNode.MapWidget.length; i++) {
- var widget = new Fusion.Lib.ApplicationDefinition.Widget(jsonNode.MapWidget[i]);
- widget.widgetSet = this;
- this.mapWidgetTag = widget;
- this.mapId = jsonNode.MapWidget[i].MapId[0];
- /* process widgets */
- if (jsonNode.Widget) {
- for (var i=0; i<jsonNode.Widget.length; i++) {
- var widget = new Fusion.Lib.ApplicationDefinition.Widget(jsonNode.Widget[i]);
- this.widgetTags.push(widget);
- this.widgetTagsByName[widget.name] = widget;
- /* process containers */
- if (jsonNode.Container) {
- for (var i=0; i<jsonNode.Container.length; i++) {
- var container = new Fusion.Lib.ApplicationDefinition.Container(jsonNode.Container[i]);
- this.containers.push(container);
- this.containersByName[container.name] = container;
- * Function: addWidgetInstance
- * keep track of live widgets created in this widgetSet
- * Parameter: {<Fusion.Widget>} widget
- * the widget to add
- addWidgetInstance: function(widget) {
- this.widgetInstances.push(widget);
- * Function: getMapWidget
- * return the map widget for this widget set
- * Returns: {<Fusion.Lib.Map>} a map widget or null
- getMapWidget: function() {
- return this.mapWidget;
- * create all the things required by this widgetSet, including
- * containers and widgets.
- * Parameter: {<Fusion.Lib.ApplicationDefinition>}
- * the application definition that this widgetSet is part of
- create: function(appDef) {
- //allow over-ride of mapId via URL parameter
- var mapGroup = null;
- var paramMapId = Fusion.getQueryParam('mapid');
- if (paramMapId.length>0) {
- mapGroup = appDef.getMapGroup(paramMapId);
- if (mapGroup) {
- this.mapId = paramMapId;
- } else {
- Fusion.reportError(new Fusion.Error(Fusion.Error.WARNING,
- "can't find MapGroup: " + paramMapId + ' - reverting to default map'));
- if (!mapGroup) {
- mapGroup = appDef.getMapGroup(this.mapId);
- //create the Map widget for this WidgetSet
- this.mapWidget = new Fusion.Widget.Map(this.mapWidgetTag,mapGroup,this);
- this.mapWidget.setMenu();
- $(this.mapWidgetTag.name).widget = this.mapWidget;
- //create all the other widgets for the widget set
- for (var i=0; i<this.widgetTags.length; i++) {
- this.widgetTags[i].create(this);
- //create all the containers for the widget set
- for (var i=0; i<this.containers.length; i++) {
- this.containers[i].create(this);
- * return the map widget from this widget set if the map's name
- * matches the requested name, or null.
- * The map name to check
- * Returns: {Object} a map object or null.
- var map = null;
- if (this.mapWidget.getMapName() == name) {
- map = this.mapWidget;
- return map;
- var widgets = [];
- for (var i=0; i<this.widgetInstances.length; i++) {
- if (this.widgetInstances[i].type == type) {
- widgets.push(this.widgetInstances[i]);
- return widgets;
- getWidgetByName: function(name) {
- return this.widgetTagsByName[name];
- getContainerByName: function(name) {
- return this.containersByName[name];
- * Class: Fusion.Lib.ApplicationDefinition.Container
- * Holds an internal representation of Container objects as defined in the AppDef
-Fusion.Lib.ApplicationDefinition.Container = OpenLayers.Class({
- name: null,
- type: null,
- validPositions: ['top', 'left', 'bottom', 'right'],
- position: 'top',
- items: null,
- this.name = jsonNode.Name[0];
- var position = jsonNode.Position ? jsonNode.Position[0].toLowerCase() : this.position;
- for (var i=0; i<this.validPositions.length; i++) {
- if (this.validPositions[i] == position) {
- this.position = position;
- break;
- this.items = [];
- if (jsonNode.Item) {
- for (var i=0; i<jsonNode.Item.length; i++) {
- var item = new Fusion.Lib.ApplicationDefinition.Item(jsonNode.Item[i]);
- this.items.push(item);
- } else {
- //TODO: is this a problem if there are no items?
- create: function(widgetSet) {
- var container;
- if (this.type == 'Toolbar' || this.type == 'Statusbar') {
- if ($(this.name)) {
- if ($(this.name).retrieve('jxToolbar')) {
- container = $(this.name).retrieve('jxToolbar');
- } else {
- container = new Jx.Toolbar({parent: this.name, position: this.position, scroll:false});
- $(this.name).container = container;
- this.createWidgets(widgetSet, container);
- } else if (this.type == 'Splitterbar') {
- container = new Jx.Splitter(this.name, {splitInto: this.items.length});
- for (var i=0; i<this.items.length; i++) {
- container.elements[i].id = this.name + '_' + i;
- if (container && container.domObj.jxLayout) {
- container.domObj.jxLayout.resize({forceResize: true});
- createWidgets: function(widgetSet, container) {
- this.items[i].create(widgetSet, container, this.name + '_' + i);
- * Holds an internal representation of Widget objects as defined in the AppDef
-Fusion.Lib.ApplicationDefinition.Widget = OpenLayers.Class({
- name: null,
- type: null,
- statusText: null,
- imageUrl: null,
- imageClass: null,
- tooltip: null,
- label: null,
- disabled: null,
- extension: null,
- if (jsonNode) {
- this.name = jsonNode.Name ? jsonNode.Name[0] : '';
- this.statusText = jsonNode.StatusText ? jsonNode.StatusText[0] : '';
- this.statusText = OpenLayers.i18n(this.statusText);
- //TODO: this may be an extension
- this.location = jsonNode.Location ? jsonNode.Location[0] : 'widgets/';
- if (this.location.slice(-1) != '/') {
- this.location += '/';
- this.imageUrl = jsonNode.ImageUrl ? jsonNode.ImageUrl[0] : '';
- this.imageClass = jsonNode.ImageClass ? jsonNode.ImageClass[0] : '';
- this.tooltip = jsonNode.Tooltip ? jsonNode.Tooltip[0] : '';
- this.tooltip = OpenLayers.i18n(this.tooltip);
- this.label = jsonNode.Label ? jsonNode.Label[0] : '';
- this.label = OpenLayers.i18n(this.label);
- this.disabled = jsonNode.Disabled ? (jsonNode.Disabled[0].toLowerCase() == 'true' ? true : false) : false;
- //console.log('Widget: ' + this.type + ', ' + this.name + ', ' + this.description);
- } else {
- //require the widget code
- if ( !Fusion.Widget[this.type] ) {
- Fusion.require(this.location + this.type + '.js');
- if (this.widgetSet) {
- return this.widgetSet.getMapWidget();
- } else {
- return null;
- * creates a new instance of the widget, optionally using a
- * different name during instantiation to accomodate
- * containers
- * Parameter: name
- * An optional name to use for the widget, overrides the
- * original name temporarily if passed.
- * Returns: an instance of the widget represented by this
- * object.
- create: function(widgetSet, widgetName) {
- var widget = null;
- this.widgetSet = widgetSet;
- var oldName = this.name;
- if (typeof widgetName == 'undefined') {
- widgetName = this.name;
- /* create the widget if the name is not null and the name
- * is either an empty string (in the case of buttons in menus)
- * or something exists in the dom with the right id
- if (widgetName != null && (widgetName == '' || $(widgetName) != null)) {
- this.name = widgetName;
- widget = eval("new Fusion.Widget."+this.type+"(this)");
- widgetSet.addWidgetInstance(widget);
- widget.id = this.name;
- $(this.name).widget = widget;
- if (widget.uiClass) {
- widget.setUiObject(new widget.uiClass({
- label: this.label,
- image: this.imageUrl,
- imageClass: this.imageClass,
- toggle: this.isExclusive
- if (widget.uiObj.addTo) {
- widget.uiObj.addTo($(this.name));
- if (widget.uiObj.setEnabled) {
- widget.uiObj.setEnabled(widget.isEnabled());
- widget.registerForEvent(Fusion.Event.WIDGET_STATE_CHANGED, function() {
- this.name = oldName;
- return widget;
- * Class: Fusion.Lib.ApplicationDefinition.Item
- * Holds an internal representation of Menu Item objects as defined in the AppDef
-Fusion.Lib.ApplicationDefinition.Item = OpenLayers.Class({
- uniqueId: [0],
- type: null,
- this.type = jsonNode.Function[0];
- switch(this.type) {
- case 'Widget':
- this.widgetName = jsonNode.Widget[0];
- break;
- case 'Flyout':
- this.flyout = new Fusion.Lib.ApplicationDefinition.Flyout(jsonNode);
- break;
- case 'Multi':
- this.multi = new Fusion.Lib.ApplicationDefinition.Multi(jsonNode);
- break;
- case 'Separator':
- break;
- create: function(widgetSet, container, idx) {
- case 'Widget':
- var widgetTag = widgetSet.getWidgetByName(this.widgetName);
- if (widgetTag) {
- var name = 'FusionItem'+this.uniqueId[0];
- this.uniqueId[0]++;
- if (container instanceof Jx.Toolbar) {
- var widget = widgetTag.create(widgetSet, '');
- if (!widget.uiClass) {
- widget.uiClass = Jx.Toolbar.Item;
- widget.setUiObject(new widget.uiClass());
- } else if (widget.uiClass == Jx.Button || widget.uiClass == Jx.Button.Color || widget.uiClass == Jx.Menu || widget.uiClass == Jx.Button.Flyout) {
- label: widgetTag.label,
- image: widgetTag.imageUrl,
- imageClass: widgetTag.imageClass,
- toggle: widget.isExclusive
- container.add(widget.uiObj);
- } else if (container instanceof Jx.Splitter) {
- var widget = widgetTag.create(widgetSet, idx);
- } else if (container instanceof Jx.Menu ||
- container instanceof Jx.Menu.Context ||
- container instanceof Jx.Menu.SubMenu) {
- if (!widget.uiClass || widget.uiClass == Jx.Button) {
- widget.uiClass = Jx.Menu.Item;
- } else if (widget.uiClass == Jx.Menu) {
- widget.uiClass = Jx.Menu.SubMenu;
- } else if (container instanceof Jx.Button.Multi) {
- widget.uiClass = Jx.Button;
- var b = !container.buttons.some(function(w) {
- return !w.isEnabled();
- container.setEnabled(b);
- } else {
- "can't find widget: " + this.widgetName));
- break;
- case 'Flyout':
- /* create a menu */
- var menu;
- var opt = {
- label: this.flyout.label,
- tooltip: this.flyout.tooltip,
- image: this.flyout.imageUrl,
- imageClass: this.flyout.imageClass
- menu = new Jx.Menu(opt);
- menu = new Jx.Menu.SubMenu(opt);
- container.add(menu);
- this.flyout.create(widgetSet, menu);
- break;
- case 'Multi':
- var multi;
- var opt = {
- label: this.multi.label,
- tooltip: this.multi.tooltip,
- image: this.multi.imageUrl,
- imageClass: this.multi.imageClass
- multi = new Jx.Button.Multi(opt);
- container.add(multi);
- this.multi.create(widgetSet, multi);
- break;
- case 'Separator':
- container.add(new Jx.Toolbar.Separator());
- } else if (container instanceof( Jx.Menu) ||
- container instanceof(Jx.Menu.SubMenu) ||
- container instanceof(Jx.Menu.Context)) {
- container.add(new Jx.Menu.Separator());
- break;
- * Class: Fusion.Lib.ApplicationDefinition.Flyout
- * Holds an internal representation of Flyout objects as defined in the AppDef
-Fusion.Lib.ApplicationDefinition.Flyout = OpenLayers.Class({
- label: null,
- tooltip: null,
- description: null,
- imageUrl: null,
- items: null,
- this.description = jsonNode.Description ? jsonNode.Description[0] : '';
- this.items = [];
- if (jsonNode.Item instanceof Array) {
- this.items.push(new Fusion.Lib.ApplicationDefinition.Item(jsonNode.Item[i]));
- create: function(widgetSet, menu) {
- this.items[i].create(widgetSet, menu);
- * Class: Fusion.Lib.ApplicationDefinition.Multi
- * Holds an internal representation of Multi objects as defined in the AppDef
-Fusion.Lib.ApplicationDefinition.Multi = OpenLayers.Class({
- label: null,
- tooltip: null,
- imageUrl: null,
- items: null,
- this.items = [];
- create: function(widgetSet, multi) {
- this.items[i].create(widgetSet, multi);
- * Class: Fusion.Lib.ApplicationDefinition.SearchDefinition
- * Holds an internal representation of SearchDefinition objects as defined in the AppDef
-Fusion.Lib.ApplicationDefinition.SearchDefinition = OpenLayers.Class({
- id: null,
- name: null,
- category: null,
- parameters: null,
- join: null,
- rule: null,
- initialize: function(json) {
- this.id = json['@id'];
- this.name = json['@name'];
- if (json.Join instanceof Array) {
- this.join = new Fusion.Lib.ApplicationDefinition.SearchJoin(json.Join[0]);
- this.parameters = [];
- if (json.Parameter instanceof Array) {
- for (var i=0; i<json.Parameter.length; i++) {
- this.parameters.push(json.Parameter[i]['@name']);
- this.reports = [];
- if (json.Report instanceof Array) {
- for (var i=0; i<json.Report.length; i++) {
- var label = json.Report[i].Label[0]
- var link = json.Report[i].Link[0]
- this.reports.push({'label':label, 'link':link});
- var rule;
- if (json.SearchAnd instanceof Array) {
- this.rule = new Fusion.Lib.ApplicationDefinition.SearchRule('AND');
- rule = json.SearchAnd[0];
- } else if (json.SearchOr instanceof Array) {
- this.rule = new Fusion.Lib.ApplicationDefinition.SearchRule('OR');
- rule = json.SearchOr[0];
- if (rule && rule.SearchCondition instanceof Array) {
- for (var i=0; i<rule.SearchCondition.length; i++) {
- this.rule.add(new Fusion.Lib.ApplicationDefinition.SearchCondition(rule.SearchCondition[i]));
- getJoinUrl: function(params) {
- if (this.join) {
- return '&joinlayer='+this.join.layer+'&joinpk='+this.join.primaryKey+'&joinfk='+this.join.foreignKey;
- } else {
- return '';
- getFilterUrl: function(params) {
- return '&filter='+encodeURIComponent(this.rule.toString(params));
- * Class: Fusion.Lib.ApplicationDefinition.SearchJoin
- * Holds an internal representation of SearchJoin objects as defined in the AppDef
-Fusion.Lib.ApplicationDefinition.SearchJoin = OpenLayers.Class({
- layer: null,
- primaryKey: null,
- foreignKey: null,
- this.layer = json.Layer ? json.Layer[0] : '';
- this.primaryKey = json.PrimaryKey ? json.PrimaryKey[0] : '';
- this.foreignKey = json.ForeignKey ? json.ForeignKey[0] : '';
- * Class: Fusion.Lib.ApplicationDefinition.SearchRule
- * Holds an internal representation of SearchRule objects as defined in the AppDef
-Fusion.Lib.ApplicationDefinition.SearchRule = OpenLayers.Class({
- type: null,
- conditions: null,
- initialize: function(type) {
- this.type = type;
- this.conditions = [];
- add: function(condition) {
- this.conditions.push(condition);
- remove: function(condition) {
- for (var i=0; i<this.conditions.length; i++) {
- if (this.conditions[i] == condition) {
- this.conditions.splice(i, 1);
- break;
- toString: function(params) {
- var conditions = [];
- this.conditions[i].setParams(params);
- var c = this.conditions[i].toString();
- if (c != '') {
- conditions.push(c);
- return '(' + conditions.join(') ' + this.type + ' (') + ')';
- * Class: Fusion.Lib.ApplicationDefinition.SearchCondition
- * Holds an internal representation of SearchCondition objects as defined in the AppDef
-Fusion.Lib.ApplicationDefinition.SearchCondition = OpenLayers.Class({
- column: null,
- operator: null,
- parameter: null,
- quote: null,
- value: null,
- operators: {eq:'=', like:'like', lt:'<', lte:'<=', gt:'>', gte:'>=', neq:'<>'},
- includeIfEmpty: false,
- this.column = json.Column[0];
- this.operator = this.operators[json.Operator[0].toLowerCase()];
- this.parameter = json.Parameter[0];
- this.quote = json['@quote'] ? json['@quote'] : '';
- this.wildcard = json['@wildcard'] ? json['@wildcard'] : 'both';
- this.caseSensitive = true;
- if (json['@caseSensitive'] && json['@caseSensitive'] == 'false') {
- this.caseSensitive = false;
- setParams: function(p) {
- if (p[this.parameter]) {
- this.value = p[this.parameter];
- } else {
- this.value = '';
- toString: function() {
- var value = this.value ? this.value : '';
- if (value == '' && !this.includeIfEmpty) {
- return '';
- var upper = '';
- if (!this.caseSensitive) {
- value = value.toUpperCase();
- upper = 'Upper';
- var prewildcard = '';
- var postwildcard = '';
- if (this.operator == 'like') {
- if (this.wildcard == 'before' || this.wildcard == 'both') {
- prewildcard = '*';
- if (this.wildcard == 'after' || this.wildcard == 'both') {
- postwildcard = '*';
- var wildcard = this.operator == 'like' ? '*' : '';
- return upper + '('+this.column + ') ' + this.operator + ' ' + this.quote + prewildcard + value + postwildcard + this.quote;
+ * Fusion.Lib.ApplicationDefinition
+ * $Id$
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Class: Fusion.Lib.ApplicationDefinition
+ * Utility class to parse an application definition
+Fusion.Lib.ApplicationDefinition = OpenLayers.Class({
+ * Property: mapGroups
+ * array of map groups, parsed from ApplicationDefinition. A MapGroup
+ * consists of one or more Maps that can be combined into the same
+ * OpenLayers Map object
+ mapGroups: null,
+ * Property: widgetSets
+ * array of widget sets (each one corresponding to a map) parsed
+ * from the ApplicationDefinition.
+ widgetSets: null,
+ * Property: {Object} oBroker
+ * A Broker object that can communicate with a MapGuide instance
+ * in the case we are running against a MapGuide server
+ oBroker: null,
+ * Property: {Array} searchDefinitions
+ * An array of search definitions
+ searchDefinitions: null,
+ * Property: {Array} searchCategories
+ * An array of search categories
+ searchCategories: null,
+ * Constructor: ApplicationDefinition
+ * construct a new instance of the ApplicationDefinition object. While
+ * not enforced, this is intended to be a singleton.
+ * Parameter: sessionId
+ * an optional session id to initialize the application with, passed to
+ * the map widgets when they are created.
+ initialize: function(sessionId) {
+ //console.log('ApplicationDefinition initialize');
+ this.sessionId = sessionId;
+ this.oBroker = Fusion.getBroker();
+ this.applicationDefinition = Fusion.getApplicationDefinitionURL();
+ this.widgetSets = [];
+ this.mapGroups = {};
+ this.searchDefinitions = [];
+ this.searchCategories = [];
+ this.parse();
+ * Function: parse
+ * start parsing the ApplicationDefinition file. This happens
+ * asynchronously since the ApplicationDefinition has to be
+ * retrieved from the server or the MapGuide repository. When
+ * parsing is complete, an APPLICATIONDEFINITION_PARSED event
+ * will be emitted. This function returns true if parsing
+ * will start, false if it will not (due to a missing
+ * application definition for instance).
+ parse : function() {
+ if (this.applicationDefinition == '') {
+ //TODO: emit an error
+ return null;
+ /* if the application definition is not in the mapguide server,
+ just load the xml*/
+ if ( (this.applicationDefinition.match('Library://') == null) &&
+ (this.applicationDefinition.match('Session:') == null) ) {
+ if (Fusion.appDefJson) {
+ this.parseAppDef(Fusion.appDefJson);
+ } else {
+ Fusion.getXmlAsJson(this.applicationDefinition,
+ OpenLayers.Function.bind(this.getAppDefCB, this));
+ } else {
+ //these need to be called via setTimeout so that the execution thread
+ //is broken in IE and so that the ApplicationDefinition constructor
+ //will return a valid object to Fusion in loadConfig before the loadState
+ //gets incremented.
+ if (!this.sessionId) {
+ window.setTimeout(OpenLayers.Function.bind(this.createSessionThenGetAppDef,this),5);
+ } else {
+ window.setTimeout(OpenLayers.Function.bind(this.getAppDef,this),5);
+ return true;
+ createSessionThenGetAppDef: function() {
+ var sl = Fusion.getScriptLanguage();
+ var scriptURL = 'layers/' + 'MapGuide' + '/' + sl + '/CreateSession.' + sl;
+ var options = {onSuccess: OpenLayers.Function.bind(this.createSessionThenGetAppDefCB, this)};
+ Fusion.ajaxRequest(scriptURL, options);
+ createSessionThenGetAppDefCB : function(xhr) {
+ if (xhr && typeof(xhr) == "object" && xhr.responseText) {
+ var o;
+ eval("o="+xhr.responseText);
+ this.sessionId = o.sessionId;
+ Fusion.sessionId = this.sessionId;
+ this.getAppDef();
+ getAppDef: function(){
+ var r = new Fusion.Lib.MGRequest.MGGetResourceContent(this.applicationDefinition);
+ r.parameters.session = this.sessionId;
+ r.parameters.format = 'application/json';
+ this.oBroker.dispatchRequest(r,
+ getAppDefCB: function(xhr) {
+ var o;
+ this.parseAppDef(o);
+ Fusion.setLoadState(Fusion.LOAD_WIDGETS);
+ * Function: parseAppDef
+ * parse the ApplicationDefinition file into the appropriate Fusion objects
+ * Parameter: {XmlHttpRequest} xhr
+ * the XmlHttpRequest object
+ parseAppDef: function(json) {
+ var appDef = json.ApplicationDefinition;
+ /* Set the application title */
+ if (appDef.Title) {
+ var title = appDef.Title[0];
+ document.title = title;
+ /* process Map nodes */
+ if (appDef.MapSet) {
+ var mapSet = appDef.MapSet[0];
+ if (mapSet.MapGroup instanceof Array) {
+ for (var i=0; i<mapSet.MapGroup.length; i++) {
+ var mapGroup = new Fusion.Lib.ApplicationDefinition.MapGroup(mapSet.MapGroup[i]);
+ this.mapGroups[mapGroup.mapId] = mapGroup;
+ } else {
+ Fusion.reportError(new Fusion.Error(Fusion.Error.FATAL,
+ OpenLayers.i18n('appDefParseError')));
+ /* process WIDGET sets */
+ if (appDef.WidgetSet) {
+ for (var i=0; i<appDef.WidgetSet.length; i++) {
+ var widgetSet = new Fusion.Lib.ApplicationDefinition.WidgetSet(appDef.WidgetSet[i]);
+ this.widgetSets.push(widgetSet);
+ } else {
+ OpenLayers.i18n('widgetSetParseError')));
+ /* process extensions */
+ if (appDef.Extension) {
+ var extension = appDef.Extension[0];
+ /* process search definitions */
+ if (extension.SearchDefinitions instanceof Array) {
+ var categories = extension.SearchDefinitions[0];
+ if (categories.SearchCategory instanceof Array) {
+ for (var i=0; i<categories.SearchCategory.length; i++) {
+ var oCategory = {};
+ var category = categories.SearchCategory[i];
+ oCategory.id = category['@id'];
+ oCategory.name = category['@name'];
+ oCategory.layer = category.Layer ? category.Layer[0] : '';
+ oCategory.searchDefinitions = [];
+ this.searchCategories[oCategory.id] = oCategory;
+ var defns = category.SearchDefinition;
+ for (var k=0; k<defns.length; k++) {
+ var defn = new Fusion.Lib.ApplicationDefinition.SearchDefinition(defns[k]);
+ defn.category = oCategory;
+ oCategory.searchDefinitions[defn.id] = defn;
+ this.searchDefinitions[defn.id] = defn;
+ * Function: create
+ * Create the application definition. This actually triggers initializing
+ * every widget and container.
+ create: function() {
+ for (var i=0; i<this.widgetSets.length; i++) {
+ this.widgetSets[i].create(this);
+ * Function: getMapByName
+ * return a map widget with the given name
+ * Parameter: {String} name
+ * The map name to return
+ * Returns: {Object} a map object or null if not found.
+ getMapByName : function(name) {
+ var map = null;
+ map = this.widgetSets[i].getMapByName(name);
+ if (map) {
+ break;
+ return map;
+ * Function: getMapById
+ * return a map widget with the given id
+ * Parameter: {String} id
+ * The map id to return. ID is distinct from map.name in that id is the
+ * id of the HTML tag where the map widget is inserted.
+ getMapById : function(id) {
+ var map = null;
+ map = this.widgetSets[i].mapWidget;
+ if (map.mapId == id) {
+ break;
+ return map;
+ * Function: getMapByIndice
+ * return the map widget at the given index
+ * Parameter: {String} indice
+ * The map indice to return
+ getMapByIndice : function(indice) {
+ var map = null;
+ if (this.widgetSets.length > indice) {
+ map = this.widgetSets[indice].getMapWidget();
+ return map;
+ * Function: getMapGroup
+ * return the specified map group from the application definition
+ * Parameter: {String} mapgroup
+ * The id of the MapGroup to return
+ * Returns: {Object} a MapGroup appdef or null if not found.
+ getMapGroup : function(mapGroupId) {
+ return this.mapGroups[mapGroupId];
+ * Function getWidgetsByType
+ * returns an array of widgets by type.
+ * Parameter: {String} type
+ * the type of widget to get references to
+ * Returns: {Array} an array of widgets, which may be empty
+ getWidgetsByType: function(type) {
+ var widgets = [];
+ widgets = widgets.concat(this.widgetSets[i].getWidgetsByType(type));
+ return widgets;
+ * Class: Fusion.Lib.ApplicationDefinition.MapGroup
+ * Holds an internal representation of MapGroup objects as defined in the AppDef
+Fusion.Lib.ApplicationDefinition.MapGroup = OpenLayers.Class({
+ initialView: null,
+ maps: null,
+ initialize: function(jsonNode) {
+ this.mapId = jsonNode['@id'][0];
+ this.maps = [];
+ /* parse InitialView */
+ if (jsonNode.InitialView) {
+ var iv = jsonNode.InitialView[0];
+ if (iv.CenterX && iv.CenterY && iv.Scale) {
+ this.setInitialView({x:parseFloat(iv.CenterX[0]),
+ y:parseFloat(iv.CenterY[0]),
+ scale:parseFloat(iv.Scale[0])});
+ } else if (iv.MinX && iv.MinY && iv.MaxX && iv.MaxY) {
+ this.setInitialView({minX:parseFloat(iv.MinX[0]),
+ minY:parseFloat(iv.MinY[0]),
+ maxX:parseFloat(iv.MaxX[0]),
+ maxY:parseFloat(iv.MaxY[0])});
+ } else {
+ //TODO: emit warning that the initial view was incomplete
+ /* parse maps */
+ if (jsonNode.Map instanceof Array) {
+ for (var i=0; i<jsonNode.Map.length; i++) {
+ var map = new Fusion.Lib.ApplicationDefinition.Map(jsonNode.Map[i]);
+ var links = {groups:[], layers:[]};
+ var mapEvents = {layerEvents:{},groupEvents:{}};
+ if (jsonNode.Map[i].Extension) {
+ var extension = jsonNode.Map[i].Extension[0];
+ if (extension.Links) {
+ /* process Groups */
+ if (extension.Links[0].Group instanceof Array) {
+ for (var j=0; j<extension.Links[0].Group.length; j++) {
+ var group = extension.Links[0].Group[j];
+ links.groups.push({name:group.Name[0],url:group.Url[0]});
+ if (extension.Links[0].Layer instanceof Array) {
+ for (var j=0; j<extension.Links[0].Layer.length; j++) {
+ var layer = extension.Links[0].Layer[j];
+ links.layers.push({name:layer.Name[0],url:layer.Url[0]});
+ /* process layer events */
+ //TODO: Should this be called MapEvents?
+ if (extension.MapEvents) {
+ if (extension.MapEvents[0].Layer instanceof Array) {
+ for (var j=0; j<extension.MapEvents[0].Layer.length; j++) {
+ var layer = extension.MapEvents[0].Layer[j];
+ var layerObj = {};
+ layerObj.name = layer.Name[0];
+ layerObj.onEnable = [];
+ if (layer.OnEnable instanceof Array) {
+ layerObj.onEnable = this.parseMapEventSubBlock(layer.OnEnable[0]);
+ layerObj.onDisable = [];
+ if (layer.OnDisable instanceof Array) {
+ layerObj.onDisable = this.parseMapEventSubBlock(layer.OnDisable[0]);
+ mapEvents.layerEvents[layerObj.name] = layerObj;
+ if (extension.MapEvents[0].Group instanceof Array) {
+ for (var j=0; j<extension.MapEvents[0].Group.length; j++) {
+ var group = extension.MapEvents[0].Group[j];
+ var groupObj = {};
+ groupObj.name = group.Name[0];
+ groupObj.onEnable = [];
+ groupObj.onEnable = this.parseMapEventSubBlock(group.OnEnable[0]);
+ groupObj.onDisable = [];
+ groupObj.onDisable = this.parseMapEventSubBlock(group.OnDisable[0]);
+ mapEvents.groupEvents[groupObj.name] = groupObj;
+ map.mapInfo = {links: links, mapEvents: mapEvents};
+ this.maps.push(map);
+ } else {
+ //TODO: do we need a warning that there are no layers in this map?
+ parseMapEventSubBlock: function(block) {
+ var a = [];
+ if (block.Layer && block.Layer instanceof Array) {
+ for (var i=0; i<block.Layer.length; i++) {
+ var layer = block.Layer[i];
+ a.push({type: 'layer', name:layer.Name[0], enable: layer.Enable[0] == 'true' ? true : false});
+ if (block.Group && block.Group instanceof Array) {
+ for (var i=0; i<block.Group.length; i++) {
+ var group = block.Group[i];
+ a.push({type: 'group', name:group.Name[0], enable: group.Enable[0] == 'true' ? true : false});
+ return a;
+ getInitialView: function() {
+ return this.initialView;
+ setInitialView: function(view) {
+ this.initialView = view;
+ * Holds an internal representation of Map objects as defined in the AppDef
+Fusion.Lib.ApplicationDefinition.Map = OpenLayers.Class({
+ type: null,
+ singleTile: false,
+ extension: null,
+ /* TODO: type can be any supported OpenLayers type */
+ this.type = jsonNode.Type[0];
+ if (jsonNode.SingleTile) {
+ var b = jsonNode.SingleTile[0].toLowerCase();
+ this.singleTile = (b == "true") ? true : false;
+ if (jsonNode.Extension) {
+ this.extension = jsonNode.Extension[0];
+ } else {
+ this.extension = {};
+ this.resourceId = this.extension.ResourceId ? this.extension.ResourceId[0] : '';
+ var tagOptions = this.extension.Options;
+ this.layerOptions = {};
+ if (tagOptions && tagOptions[0]) {
+ for (var key in tagOptions[0]) {
+ var val = tagOptions[0][key][0];
+ if (val.toFloat().toString() == val) {
+ this.layerOptions[key] = val.toFloat();
+ } else {
+ if (val.toLowerCase() == 'true') {
+ this.layerOptions[key] = true;
+ } else if (val.toLowerCase() == 'false') {
+ this.layerOptions[key] = false;
+ } else {
+ this.layerOptions[key] = val;
+ if (key == 'maxExtent' || key == 'minExtent') {
+ this.layerOptions[key] = OpenLayers.Bounds.fromString(this.layerOptions[key]);
+ if (key == 'resolutions' || key == 'scales') {
+ this.layerOptions[key] = this.layerOptions[key].split(',');
+ for (var i=0; i<this.layerOptions[key].length; i++) {
+ this.layerOptions[key][i] = this.layerOptions[key][i].toFloat();
+ var tagParams = this.extension.Parameters;
+ this.layerParams = {};
+ if (tagParams && tagParams[0]) {
+ for (var key in tagParams[0]) {
+ var val = tagParams[0][key][0];
+ val = val.toFloat();
+ this.layerParams[key] = val;
+ //projection info from the extension
+ //this.layerOptions.projection = "EPSG:4326"; //default to WGS84 lat long
+ if (this.extension.ProjectionCode) {
+ this.layerOptions.projection = this.extension.ProjectionCode[0];
+ if (this.extension.ProjectionDef) {
+ var projDef = this.extension.ProjectionDef[0];
+ if (!this.layerOptions.projection) {
+ this.layerOptions.projection = "APP-DEF-PROJ";
+ Proj4js.defs[this.layerOptions.projection] = projDef;
+ this.layerOptions.projection = "EPSG:4326";
+ switch (this.type) {
+ case 'MapGuide':
+ case 'MapServer':
+ if ( !Fusion.Layers[this.type] ) {
+ Fusion.require('layers/' + this.type + '/' + this.type + '.js');
+ break;
+ case "Google":
+ case "Yahoo":
+ case "VirtualEarth":
+ this.layerOptions.isBaseLayer = true;
+ this.layerOptions.sphericalMercator = true;
+ this.layerOptions.displayProjection = "EPSG:4326";
+ //no break here continue below to set EPSG:3785 as projCode
+ default:
+ if (this.layerOptions.sphericalMercator) {
+ this.layerOptions.projection = "EPSG:900913"; //commercial map layer projection spherical mercator
+ } else {
+ this.layerOptions.projection = "EPSG:4326"; //WGS84 lat long
+ if ( !Fusion.Layers.Generic ) {
+ Fusion.require('layers/Generic/Generic.js');
+ break;
+ * Class: Fusion.Lib.ApplicationDefinition.WidgetSet
+ * Holds an internal representation of WidgetSet objects as defined in the AppDef
+Fusion.Lib.ApplicationDefinition.WidgetSet = OpenLayers.Class({
+ containers: null,
+ containersByName: null,
+ widgetTags: null,
+ widgetTagsByName: null,
+ widgetInstances: null,
+ mapWidget: null,
+ mapId: null,
+ this.containers = [];
+ this.widgetTags = [];
+ this.widgetInstances = [];
+ this.widgetTagsByName = {};
+ this.containersByName = {};
+ /* process map widgets */
+ if (jsonNode.MapWidget) {
+ for (var i=0; i<jsonNode.MapWidget.length; i++) {
+ var widget = new Fusion.Lib.ApplicationDefinition.Widget(jsonNode.MapWidget[i]);
+ widget.widgetSet = this;
+ this.mapWidgetTag = widget;
+ this.mapId = jsonNode.MapWidget[i].MapId[0];
+ /* process widgets */
+ if (jsonNode.Widget) {
+ for (var i=0; i<jsonNode.Widget.length; i++) {
+ var widget = new Fusion.Lib.ApplicationDefinition.Widget(jsonNode.Widget[i]);
+ this.widgetTags.push(widget);
+ this.widgetTagsByName[widget.name] = widget;
+ /* process containers */
+ if (jsonNode.Container) {
+ for (var i=0; i<jsonNode.Container.length; i++) {
+ var container = new Fusion.Lib.ApplicationDefinition.Container(jsonNode.Container[i]);
+ this.containers.push(container);
+ this.containersByName[container.name] = container;
+ * Function: addWidgetInstance
+ * keep track of live widgets created in this widgetSet
+ * Parameter: {<Fusion.Widget>} widget
+ * the widget to add
+ addWidgetInstance: function(widget) {
+ this.widgetInstances.push(widget);
+ * Function: getMapWidget
+ * return the map widget for this widget set
+ * Returns: {<Fusion.Lib.Map>} a map widget or null
+ getMapWidget: function() {
+ return this.mapWidget;
+ * create all the things required by this widgetSet, including
+ * containers and widgets.
+ * Parameter: {<Fusion.Lib.ApplicationDefinition>}
+ * the application definition that this widgetSet is part of
+ create: function(appDef) {
+ //allow over-ride of mapId via URL parameter
+ var mapGroup = null;
+ var paramMapId = Fusion.getQueryParam('mapid');
+ if (paramMapId.length>0) {
+ mapGroup = appDef.getMapGroup(paramMapId);
+ if (mapGroup) {
+ this.mapId = paramMapId;
+ } else {
+ Fusion.reportError(new Fusion.Error(Fusion.Error.WARNING,
+ "can't find MapGroup: " + paramMapId + ' - reverting to default map'));
+ if (!mapGroup) {
+ mapGroup = appDef.getMapGroup(this.mapId);
+ //create the Map widget for this WidgetSet
+ this.mapWidget = new Fusion.Widget.Map(this.mapWidgetTag,mapGroup,this);
+ this.mapWidget.setMenu();
+ $(this.mapWidgetTag.name).widget = this.mapWidget;
+ //create all the other widgets for the widget set
+ for (var i=0; i<this.widgetTags.length; i++) {
+ this.widgetTags[i].create(this);
+ //create all the containers for the widget set
+ for (var i=0; i<this.containers.length; i++) {
+ this.containers[i].create(this);
+ * return the map widget from this widget set if the map's name
+ * matches the requested name, or null.
+ * The map name to check
+ * Returns: {Object} a map object or null.
+ var map = null;
+ if (this.mapWidget.getMapName() == name) {
+ map = this.mapWidget;
+ return map;
+ var widgets = [];
+ for (var i=0; i<this.widgetInstances.length; i++) {
+ if (this.widgetInstances[i].type == type) {
+ widgets.push(this.widgetInstances[i]);
+ return widgets;
+ getWidgetByName: function(name) {
+ return this.widgetTagsByName[name];
+ getContainerByName: function(name) {
+ return this.containersByName[name];
+ * Class: Fusion.Lib.ApplicationDefinition.Container
+ * Holds an internal representation of Container objects as defined in the AppDef
+Fusion.Lib.ApplicationDefinition.Container = OpenLayers.Class({
+ name: null,
+ type: null,
+ validPositions: ['top', 'left', 'bottom', 'right'],
+ position: 'top',
+ items: null,
+ this.name = jsonNode.Name[0];
+ var position = jsonNode.Position ? jsonNode.Position[0].toLowerCase() : this.position;
+ for (var i=0; i<this.validPositions.length; i++) {
+ if (this.validPositions[i] == position) {
+ this.position = position;
+ break;
+ this.items = [];
+ if (jsonNode.Item) {
+ for (var i=0; i<jsonNode.Item.length; i++) {
+ var item = new Fusion.Lib.ApplicationDefinition.Item(jsonNode.Item[i]);
+ this.items.push(item);
+ } else {
+ //TODO: is this a problem if there are no items?
+ create: function(widgetSet) {
+ var container;
+ if (this.type == 'Toolbar' || this.type == 'Statusbar') {
+ if ($(this.name)) {
+ if ($(this.name).retrieve('jxToolbar')) {
+ container = $(this.name).retrieve('jxToolbar');
+ } else {
+ container = new Jx.Toolbar({parent: this.name, position: this.position, scroll:false});
+ $(this.name).container = container;
+ this.createWidgets(widgetSet, container);
+ } else if (this.type == 'Splitterbar') {
+ container = new Jx.Splitter(this.name, {splitInto: this.items.length});
+ for (var i=0; i<this.items.length; i++) {
+ container.elements[i].id = this.name + '_' + i;
+ if (container && container.domObj.jxLayout) {
+ container.domObj.jxLayout.resize({forceResize: true});
+ createWidgets: function(widgetSet, container) {
+ this.items[i].create(widgetSet, container, this.name + '_' + i);
+ * Holds an internal representation of Widget objects as defined in the AppDef
+Fusion.Lib.ApplicationDefinition.Widget = OpenLayers.Class({
+ name: null,
+ type: null,
+ statusText: null,
+ location: null,
+ imageUrl: null,
+ imageClass: null,
+ tooltip: null,
+ label: null,
+ disabled: null,
+ extension: null,
+ if (jsonNode) {
+ this.name = jsonNode.Name ? jsonNode.Name[0] : '';
+ this.statusText = jsonNode.StatusText ? jsonNode.StatusText[0] : '';
+ this.statusText = OpenLayers.i18n(this.statusText);
+ //TODO: this may be an extension
+ this.location = jsonNode.Location ? jsonNode.Location[0] : 'widgets/';
+ if (this.location.slice(-1) != '/') {
+ this.location += '/';
+ this.imageUrl = jsonNode.ImageUrl ? jsonNode.ImageUrl[0] : '';
+ this.imageClass = jsonNode.ImageClass ? jsonNode.ImageClass[0] : '';
+ this.tooltip = jsonNode.Tooltip ? jsonNode.Tooltip[0] : '';
+ this.tooltip = OpenLayers.i18n(this.tooltip);
+ this.label = jsonNode.Label ? jsonNode.Label[0] : '';
+ this.label = OpenLayers.i18n(this.label);
+ this.disabled = jsonNode.Disabled ? (jsonNode.Disabled[0].toLowerCase() == 'true' ? true : false) : false;
+ //console.log('Widget: ' + this.type + ', ' + this.name + ', ' + this.description);
+ } else {
+ //require the widget code
+ if ( !Fusion.Widget[this.type] ) {
+ Fusion.require(this.location + this.type + '.js');
+ if (this.widgetSet) {
+ return this.widgetSet.getMapWidget();
+ } else {
+ return null;
+ * creates a new instance of the widget, optionally using a
+ * different name during instantiation to accomodate
+ * containers
+ * Parameter: name
+ * An optional name to use for the widget, overrides the
+ * original name temporarily if passed.
+ * Returns: an instance of the widget represented by this
+ * object.
+ create: function(widgetSet, widgetName) {
+ var widget = null;
+ this.widgetSet = widgetSet;
+ var oldName = this.name;
+ if (typeof widgetName == 'undefined') {
+ widgetName = this.name;
+ /* create the widget if the name is not null and the name
+ * is either an empty string (in the case of buttons in menus)
+ * or something exists in the dom with the right id
+ if (widgetName != null && (widgetName == '' || $(widgetName) != null)) {
+ this.name = widgetName;
+ widget = eval("new Fusion.Widget."+this.type+"(this)");
+ widgetSet.addWidgetInstance(widget);
+ widget.id = this.name;
+ $(this.name).widget = widget;
+ if (widget.uiClass) {
+ widget.setUiObject(new widget.uiClass({
+ label: this.label,
+ image: this.imageUrl,
+ imageClass: this.imageClass,
+ toggle: this.isExclusive
+ if (widget.uiObj.addTo) {
+ widget.uiObj.addTo($(this.name));
+ if (widget.uiObj.setEnabled) {
+ widget.uiObj.setEnabled(widget.isEnabled());
+ widget.registerForEvent(Fusion.Event.WIDGET_STATE_CHANGED, function() {
+ this.name = oldName;
+ return widget;
+ * Class: Fusion.Lib.ApplicationDefinition.Item
+ * Holds an internal representation of Menu Item objects as defined in the AppDef
+Fusion.Lib.ApplicationDefinition.Item = OpenLayers.Class({
+ uniqueId: [0],
+ type: null,
+ this.type = jsonNode.Function[0];
+ switch(this.type) {
+ case 'Widget':
+ this.widgetName = jsonNode.Widget[0];
+ break;
+ case 'Flyout':
+ this.flyout = new Fusion.Lib.ApplicationDefinition.Flyout(jsonNode);
+ break;
+ case 'Multi':
+ this.multi = new Fusion.Lib.ApplicationDefinition.Multi(jsonNode);
+ break;
+ case 'Separator':
+ break;
+ create: function(widgetSet, container, idx) {
+ case 'Widget':
+ var widgetTag = widgetSet.getWidgetByName(this.widgetName);
+ if (widgetTag) {
+ var name = 'FusionItem'+this.uniqueId[0];
+ this.uniqueId[0]++;
+ if (container instanceof Jx.Toolbar) {
+ var widget = widgetTag.create(widgetSet, '');
+ if (!widget.uiClass) {
+ widget.uiClass = Jx.Toolbar.Item;
+ widget.setUiObject(new widget.uiClass());
+ } else if (widget.uiClass == Jx.Button || widget.uiClass == Jx.Button.Color || widget.uiClass == Jx.Menu || widget.uiClass == Jx.Button.Flyout) {
+ label: widgetTag.label,
+ image: widgetTag.imageUrl,
+ imageClass: widgetTag.imageClass,
+ toggle: widget.isExclusive
+ container.add(widget.uiObj);
+ } else if (container instanceof Jx.Splitter) {
+ var widget = widgetTag.create(widgetSet, idx);
+ } else if (container instanceof Jx.Menu ||
+ container instanceof Jx.Menu.Context ||
+ container instanceof Jx.Menu.SubMenu) {
+ if (!widget.uiClass || widget.uiClass == Jx.Button) {
+ widget.uiClass = Jx.Menu.Item;
+ } else if (widget.uiClass == Jx.Menu) {
+ widget.uiClass = Jx.Menu.SubMenu;
+ } else if (container instanceof Jx.Button.Multi) {
+ widget.uiClass = Jx.Button;
+ var b = !container.buttons.some(function(w) {
+ return !w.isEnabled();
+ container.setEnabled(b);
+ } else {
+ "can't find widget: " + this.widgetName));
+ break;
+ case 'Flyout':
+ /* create a menu */
+ var menu;
+ var opt = {
+ label: this.flyout.label,
+ tooltip: this.flyout.tooltip,
+ image: this.flyout.imageUrl,
+ imageClass: this.flyout.imageClass
+ menu = new Jx.Menu(opt);
+ menu = new Jx.Menu.SubMenu(opt);
+ container.add(menu);
+ this.flyout.create(widgetSet, menu);
+ break;
+ case 'Multi':
+ var multi;
+ var opt = {
+ label: this.multi.label,
+ tooltip: this.multi.tooltip,
+ image: this.multi.imageUrl,
+ imageClass: this.multi.imageClass
+ multi = new Jx.Button.Multi(opt);
+ container.add(multi);
+ this.multi.create(widgetSet, multi);
+ break;
+ case 'Separator':
+ container.add(new Jx.Toolbar.Separator());
+ } else if (container instanceof( Jx.Menu) ||
+ container instanceof(Jx.Menu.SubMenu) ||
+ container instanceof(Jx.Menu.Context)) {
+ container.add(new Jx.Menu.Separator());
+ break;
+ * Class: Fusion.Lib.ApplicationDefinition.Flyout
+ * Holds an internal representation of Flyout objects as defined in the AppDef
+Fusion.Lib.ApplicationDefinition.Flyout = OpenLayers.Class({
+ label: null,
+ tooltip: null,
+ description: null,
+ imageUrl: null,
+ items: null,
+ this.description = jsonNode.Description ? jsonNode.Description[0] : '';
+ this.items = [];
+ if (jsonNode.Item instanceof Array) {
+ this.items.push(new Fusion.Lib.ApplicationDefinition.Item(jsonNode.Item[i]));
+ create: function(widgetSet, menu) {
+ this.items[i].create(widgetSet, menu);
+ * Class: Fusion.Lib.ApplicationDefinition.Multi
+ * Holds an internal representation of Multi objects as defined in the AppDef
+Fusion.Lib.ApplicationDefinition.Multi = OpenLayers.Class({
+ label: null,
+ tooltip: null,
+ imageUrl: null,
+ items: null,
+ this.items = [];
+ create: function(widgetSet, multi) {
+ this.items[i].create(widgetSet, multi);
+ * Class: Fusion.Lib.ApplicationDefinition.SearchDefinition
+ * Holds an internal representation of SearchDefinition objects as defined in the AppDef
+Fusion.Lib.ApplicationDefinition.SearchDefinition = OpenLayers.Class({
+ id: null,
+ name: null,
+ category: null,
+ parameters: null,
+ join: null,
+ rule: null,
+ initialize: function(json) {
+ this.id = json['@id'];
+ this.name = json['@name'];
+ if (json.Join instanceof Array) {
+ this.join = new Fusion.Lib.ApplicationDefinition.SearchJoin(json.Join[0]);
+ this.parameters = [];
+ if (json.Parameter instanceof Array) {
+ for (var i=0; i<json.Parameter.length; i++) {
+ this.parameters.push(json.Parameter[i]['@name']);
+ this.reports = [];
+ if (json.Report instanceof Array) {
+ for (var i=0; i<json.Report.length; i++) {
+ var label = json.Report[i].Label[0]
+ var link = json.Report[i].Link[0]
+ this.reports.push({'label':label, 'link':link});
+ var rule;
+ if (json.SearchAnd instanceof Array) {
+ this.rule = new Fusion.Lib.ApplicationDefinition.SearchRule('AND');
+ rule = json.SearchAnd[0];
+ } else if (json.SearchOr instanceof Array) {
+ this.rule = new Fusion.Lib.ApplicationDefinition.SearchRule('OR');
+ rule = json.SearchOr[0];
+ if (rule && rule.SearchCondition instanceof Array) {
+ for (var i=0; i<rule.SearchCondition.length; i++) {
+ this.rule.add(new Fusion.Lib.ApplicationDefinition.SearchCondition(rule.SearchCondition[i]));
+ getJoinUrl: function(params) {
+ if (this.join) {
+ return '&joinlayer='+this.join.layer+'&joinpk='+this.join.primaryKey+'&joinfk='+this.join.foreignKey;
+ } else {
+ return '';
+ getFilterUrl: function(params) {
+ return '&filter='+encodeURIComponent(this.rule.toString(params));
+ * Class: Fusion.Lib.ApplicationDefinition.SearchJoin
+ * Holds an internal representation of SearchJoin objects as defined in the AppDef
+Fusion.Lib.ApplicationDefinition.SearchJoin = OpenLayers.Class({
+ layer: null,
+ primaryKey: null,
+ foreignKey: null,
+ this.layer = json.Layer ? json.Layer[0] : '';
+ this.primaryKey = json.PrimaryKey ? json.PrimaryKey[0] : '';
+ this.foreignKey = json.ForeignKey ? json.ForeignKey[0] : '';
+ * Class: Fusion.Lib.ApplicationDefinition.SearchRule
+ * Holds an internal representation of SearchRule objects as defined in the AppDef
+Fusion.Lib.ApplicationDefinition.SearchRule = OpenLayers.Class({
+ type: null,
+ conditions: null,
+ initialize: function(type) {
+ this.type = type;
+ this.conditions = [];
+ add: function(condition) {
+ this.conditions.push(condition);
+ remove: function(condition) {
+ for (var i=0; i<this.conditions.length; i++) {
+ if (this.conditions[i] == condition) {
+ this.conditions.splice(i, 1);
+ break;
+ toString: function(params) {
+ var conditions = [];
+ this.conditions[i].setParams(params);
+ var c = this.conditions[i].toString();
+ if (c != '') {
+ conditions.push(c);
+ return '(' + conditions.join(') ' + this.type + ' (') + ')';
+ * Class: Fusion.Lib.ApplicationDefinition.SearchCondition
+ * Holds an internal representation of SearchCondition objects as defined in the AppDef
+Fusion.Lib.ApplicationDefinition.SearchCondition = OpenLayers.Class({
+ column: null,
+ operator: null,
+ parameter: null,
+ quote: null,
+ value: null,
+ operators: {eq:'=', like:'like', lt:'<', lte:'<=', gt:'>', gte:'>=', neq:'<>'},
+ includeIfEmpty: false,
+ this.column = json.Column[0];
+ this.operator = this.operators[json.Operator[0].toLowerCase()];
+ this.parameter = json.Parameter[0];
+ this.quote = json['@quote'] ? json['@quote'] : '';
+ this.wildcard = json['@wildcard'] ? json['@wildcard'] : 'both';
+ this.caseSensitive = true;
+ if (json['@caseSensitive'] && json['@caseSensitive'] == 'false') {
+ this.caseSensitive = false;
+ setParams: function(p) {
+ if (p[this.parameter]) {
+ this.value = p[this.parameter];
+ } else {
+ this.value = '';
+ toString: function() {
+ var value = this.value ? this.value : '';
+ if (value == '' && !this.includeIfEmpty) {
+ return '';
+ var upper = '';
+ if (!this.caseSensitive) {
+ value = value.toUpperCase();
+ upper = 'Upper';
+ var prewildcard = '';
+ var postwildcard = '';
+ if (this.operator == 'like') {
+ if (this.wildcard == 'before' || this.wildcard == 'both') {
+ prewildcard = '*';
+ if (this.wildcard == 'after' || this.wildcard == 'both') {
+ postwildcard = '*';
+ var wildcard = this.operator == 'like' ? '*' : '';
+ return upper + '('+this.column + ') ' + this.operator + ' ' + this.quote + prewildcard + value + postwildcard + this.quote;
More information about the fusion-commits
