[fusion-commits] r2235 - in sandbox/jxlib-3.0: layers layers/MapGuide layers/MapServer lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Sep 27 15:34:46 EDT 2010
Author: pagameba
Date: 2010-09-27 19:34:46 +0000 (Mon, 27 Sep 2010)
New Revision: 2235
   sandbox/jxlib-3.0/layers/Layers.js
   sandbox/jxlib-3.0/layers/MapGuide/MapGuide.js
   sandbox/jxlib-3.0/layers/MapServer/MapServer.js
   sandbox/jxlib-3.0/lib/Map.js
   sandbox/jxlib-3.0/lib/jxlib.uncompressed.js
adding indicator for whether layers support querying, updating jxlib
Modified: sandbox/jxlib-3.0/layers/Layers.js
--- sandbox/jxlib-3.0/layers/Layers.js	2010-09-24 18:32:16 UTC (rev 2234)
+++ sandbox/jxlib-3.0/layers/Layers.js	2010-09-27 19:34:46 UTC (rev 2235)
@@ -48,6 +48,9 @@
     noCache: false,
     _sMapTitle: null,
     _sMapname: null,
+    supports: {
+      query: false
     initialize: function(map, mapTag, isMapWidgetLayer) {
         // console.log('Fusion.Layers.initialize');
Modified: sandbox/jxlib-3.0/layers/MapGuide/MapGuide.js
--- sandbox/jxlib-3.0/layers/MapGuide/MapGuide.js	2010-09-24 18:32:16 UTC (rev 2234)
+++ sandbox/jxlib-3.0/layers/MapGuide/MapGuide.js	2010-09-27 19:34:46 UTC (rev 2235)
@@ -44,6 +44,9 @@
     selectionAsOverlay: true,
     useAsyncOverlay: false,
     defaultFormat: 'PNG',
+    supports: {
+      query: true
         // console.log('MapGuide.initialize');
Modified: sandbox/jxlib-3.0/layers/MapServer/MapServer.js
--- sandbox/jxlib-3.0/layers/MapServer/MapServer.js	2010-09-24 18:32:16 UTC (rev 2234)
+++ sandbox/jxlib-3.0/layers/MapServer/MapServer.js	2010-09-27 19:34:46 UTC (rev 2235)
@@ -47,6 +47,9 @@
     //the map file
     sMapFile: null,
+    supports: {
+      query: true
         //console.log('Fusion.Layers.MapServer.initialize');
Modified: sandbox/jxlib-3.0/lib/Map.js
--- sandbox/jxlib-3.0/lib/Map.js	2010-09-24 18:32:16 UTC (rev 2234)
+++ sandbox/jxlib-3.0/lib/Map.js	2010-09-27 19:34:46 UTC (rev 2235)
@@ -688,7 +688,8 @@
          this.oSelection = {};
          this.nSelectionMaps = 0;
          for (var i=0; i<this.aMaps.length; i++ ) {
-		     if(this.aMaps[i].layerType == "Google" || this.aMaps[i].layerType == "Yahoo" ||this.aMaps[i].layerType == "VirtualEarth" )
+           if (this.aMaps[i].supports.query)
+         // if(this.aMaps[i].layerType == "Google" || this.aMaps[i].layerType == "Yahoo" ||this.aMaps[i].layerType == "VirtualEarth" )
 			     continue;
              this.nSelectionMaps++;
              this.aMaps[i].getSelection(
Modified: sandbox/jxlib-3.0/lib/jxlib.uncompressed.js
--- sandbox/jxlib-3.0/lib/jxlib.uncompressed.js	2010-09-24 18:32:16 UTC (rev 2234)
+++ sandbox/jxlib-3.0/lib/jxlib.uncompressed.js	2010-09-27 19:34:46 UTC (rev 2235)
@@ -31989,7 +31989,7 @@
-// $Id: row.js 981 2010-09-13 12:18:35Z pagameba $
+// $Id: row.js 986 2010-09-15 19:01:47Z pagameba $
  * Class: Jx.Row
@@ -32125,7 +32125,8 @@
      * determines and returns the height of a row
     getHeight : function (row) {
-      var h = this.options.rowHeight;
+      var h = this.options.rowHeight,
+          rowEl;
       //this should eventually compute a height, however, we would need
       //a fixed width to do so reliably. For right now, we use a fixed height
       //for all rows.
@@ -32135,6 +32136,10 @@
         if (this.options.rowHeight == 'auto') {
           // this.calculateHeight(row);
           h = 20; // TODO calculate?
+          rowEl = this.grid.gridTableBody.rows[row]
+          if (rowEl) {
+            h = rowEl.getContentBoxSize().height;
         } else if (Jx.type(this.options.rowHeight) !== 'number') {
@@ -32337,7 +32342,7 @@
-// $Id: grid.js 982 2010-09-15 13:49:13Z pagameba $
+// $Id: grid.js 989 2010-09-15 20:27:48Z pagameba $
  * Class: Jx.Grid
@@ -32387,7 +32392,7 @@
 Jx.Grid = new Class({
   Family : 'Jx.Grid',
   Extends: Jx.Widget,
-  Binds: ['storeLoaded', 'clickColumnHeader', 'moveColumnHeader', 'clickRowHeader', 'moveRowHeader', 'clickCell', 'moveCell', 'leaveGrid', 'resize', 'drawStore', 'scroll', 'addRow', 'removeRow', 'removeRows', 'updateRow'],
+  Binds: ['storeLoaded', 'clickColumnHeader', 'moveColumnHeader', 'clickRowHeader', 'moveRowHeader', 'clickCell', 'dblclickCell', 'moveCell', 'leaveGrid', 'resize', 'drawStore', 'scroll', 'addRow', 'removeRow', 'removeRows', 'updateRow'],
    * Property: pluginNamespace
@@ -32522,15 +32527,12 @@
       'gridRowLeave': false,
       'gridRowClick': false,
       'gridCellClick': false,
+      'gridCellDblClick': false,
       'gridCellEnter': false,
       'gridCellLeave': false,
       'gridMouseLeave': false
-    if (options.parent) {
-      this.addTo(options.parent);
     this.parent();
@@ -32578,6 +32580,10 @@
           this.gridObj.addEvent('click', this.clickCell);
           this.hooks.set('gridCellClick', true);
           break;
+        case 'gridCellDblClick':
+          this.gridObj.addEvent('dblclick', this.dblclickCell);
+          this.hooks.set('gridCellDblClick', true);
+          break;
         case 'gridMouseLeave':
           this.rowObj.addEvent('mouseleave', this.leaveGrid);
           this.colObj.addEvent('mouseleave', this.leaveGrid);
@@ -32606,6 +32612,10 @@
    * Create the grid for the current model
   render: function() {
+    if (this.domObj) {
+      this.redraw();
+      return;
     this.parent();
     var store = this.store;
@@ -32649,6 +32659,7 @@
     if (document.id(this.options.parent)) {
       this.addTo(this.options.parent);
+      this.resize();
@@ -32730,7 +32741,12 @@
   storeLoaded: function(store) {
-    var template = '',
+    this.redraw();
+  redraw: function() {
+    var store = this.store,
+        template = '',
         tr,
         columns = [],
         useRowHeaders = this.row.useHeaders();
@@ -32787,6 +32803,13 @@
     if (this.columns.useHeaders()) {
       tr = new Element('tr');
       this.columns.getHeaders(tr);
+      tr.adopt(new Element('th', {
+        'class': 'jxGridColHead',
+        'html': '&nbsp',
+        styles: {
+          width: 1000
       this.colObj.getElement('thead').empty().adopt(tr);
     this.columns.calculateWidths();
@@ -32876,15 +32899,27 @@
    * that is handled by the render() method
   drawStore: function() {
+    var useHeaders = this.row.useHeaders(),
+        blank;
     this.domObj.resize();
     this.gridTableBody.empty();
-    if (this.row.useHeaders()) {
+    if (useHeaders) {
       this.rowTableBody.empty();
     this.store.each(function(record,index) {
       this.store.index = index;
       this.drawRow(record, index);
     }, this);
+    if (useHeaders) {
+      blank = new Element('tr', {
+        styles: { height: 1000 }
+      blank.adopt(new Element('th', {
+        'class':'jxGridRowHead',
+        html: '&nbsp'
+      this.rowTableBody.adopt(blank);
@@ -32953,9 +32988,6 @@
       if (row.options.headerColumn && renderer.domInsert) {
         th.adopt(rowHeaderColumn.getHTML());
-      if (autoRowHeight) {
-        th.setStyle('height', tr.childNodes[0].getContentBoxSize().height);
       rh = new Element('tr').adopt(th);
       if (position == 'replace' && index < rowBody.childNodes.length) {
         rh.inject(rowBody.childNodes[index], 'after');
@@ -32963,6 +32995,10 @@
       } else {
         rh.inject(rowBody, position);
+      if (autoRowHeight) {
+        // th.setBorderBoxSize({height: tr.childNodes[0].getBorderBoxSize().height});
+        rh.setBorderBoxSize({height: tr.getBorderBoxSize().height});
@@ -33047,6 +33083,18 @@
+   * Method: dblclickCell
+   * handle doubleclicks on cells in the grid
+  clickCell: function(e) {
+    var target = e.target;
+    if (target.getParent('tbody')) {
+      target = target.tagName == 'TD' ? target : target.getParent('td');
+      this.fireEvent('gridCellDblClick', target);
    * Method: moveCell
    * handle the mouse moving over cells in the grid
@@ -33507,7 +33555,7 @@
-// $Id: grid.selector.js 982 2010-09-15 13:49:13Z pagameba $
+// $Id: grid.selector.js 987 2010-09-15 19:18:57Z pagameba $
  * Class: Jx.Plugin.Grid.Selector
@@ -33530,7 +33578,7 @@
-    Binds: ['select','checkSelection','checkAll','afterGridRender','onCellClick'],
+    Binds: ['select','checkSelection','checkAll','afterGridRender','onCellClick', 'sort'],
     options : {
@@ -33628,7 +33676,8 @@
             width: 20,
             renderer: null,
-            isSortable: this.options.sortableColumn || false
+            isSortable: options.sortableColumn || false,
+            sort: options.sortableColumn ? this.sort : null
           }, grid);
           this.checkColumn.options.renderer = this;
           grid.columns.columns.reverse();
@@ -33731,7 +33780,7 @@
      * opt - the option to turn off. One of 'cell', 'column', or 'row'
     deactivate: function (opt) {
-        var gridTableRows = this.grid.gridTable.rows,
+        var gridTableRows = this.grid.gridTableBody.rows,
             selected = this.selected,
             i;
         this.options[opt] = false;
@@ -33945,7 +33994,7 @@
      * col - {Integer} the column to select
     selectColumn: function (col) {
-        var gridTable = this.grid.gridTable,
+        var gridTable = this.grid.gridTableBody,
             cols = this.selected.get('columns'),
             m = '',
             i;
@@ -34067,6 +34116,63 @@
         }, this);
+    sort: function(dir) {
+      var grid = this.grid,
+          store = grid.store,
+          data = store.data,
+          gridTableBody= grid.gridTableBody,
+          gridParent = gridTableBody.getParent(),
+          useHeaders = grid.row.useHeaders(),
+          rowTableBody = grid.rowTableBody,
+          rowParent = rowTableBody.getParent(),
+          selected = this.selected.rows;
+      // sorting only works for rows and when more than zero are selected
+      // in fact it is probably only useful if multiple selections are also enabled
+      // but that is not a hard rule for this method
+      if (!this.options.row || selected.length == 0) {
+        console.log('not sorting by selection, nothing to sort');
+        return;
+      store.each(function(record, index) {
+        record.dom = {
+          cell: gridTableBody.childNodes[index],
+          row: useHeaders ? rowTableBody.childNodes[index] : null
+      gridTableBody.dispose();
+      if (useHeaders) {
+        rowTableBody.dispose();
+      selected.sort(function(a,b) {
+        return a.retrieve('jxRowData').row - b.retrieve('jxRowData').row;
+      }).each(function(row) {
+        console.log('moving row ' + row.retrieve('jxRowData').row + ' to beginning of array');
+        data.unshift(data.splice(row.retrieve('jxRowData').row,1)[0]);
+      if (dir == 'desc') {
+        data.reverse();
+        record.dom.cell.inject(gridTableBody);
+        record.dom.cell.store('jxRowData', {row: index});
+        if (useHeaders) {
+          record.dom.row.inject(rowTableBody);
+      if (gridParent) {
+        gridParent.adopt(gridTableBody);
+      if (useHeaders && rowParent) {
+        rowParent.adopt(rowTableBody);
@@ -34500,8 +34606,8 @@
         data = el.retrieve('jxCellData'),
         dir = 'asc',
         opt = this.options;
-    if (sorter && $defined(data.column) && data.column.isSortable()) {
+    if ($defined(data.column) && data.column.isSortable()){
       if (el.hasClass(opt.ascendingClass)) {
         el.removeClass(opt.ascendingClass).addClass(opt.descendingClass);
         dir = 'desc';
@@ -34514,34 +34620,40 @@
         current.removeClass(opt.ascendingClass).removeClass(opt.descendingClass);
       this.current = el;
-      gridTableBody.dispose();
-      if (useHeaders) {
-        rowTableBody.dispose();
-      store.each(function(record, index) {
-        record.dom = {
-          cell: gridTableBody.childNodes[index],
-          row: useHeaders ? rowTableBody.childNodes[index] : null
-      // store.removeEvent('storeSortFinished', grid.drawStore);
-      sorter.sort(data.column.name, null, dir);
-      // store.addEvent('storeSortFinished', grid.drawStore);
-        record.dom.cell.inject(gridTableBody);
-        if (useHeaders) {
-          record.dom.row.inject(rowTableBody);
+      if ($defined(data.column.options.sort) && Jx.type(data.column.options.sort) == 'function') {
+        data.column.options.sort(dir);
+      } else {
+        if (sorter) {
+          if (useHeaders) {
+            record.dom = {
+          // store.removeEvent('storeSortFinished', grid.drawStore);
+          sorter.sort(data.column.name, null, dir);
+          // store.addEvent('storeSortFinished', grid.drawStore);
+            if (useHeaders) {
+          if (gridParent) {
-      if (gridParent) {
-        gridParent.adopt(gridTableBody);
-      if (useHeaders && rowParent) {
-        rowParent.adopt(rowTableBody);
More information about the fusion-commits mailing list
