[fusion-commits] r2420 - in trunk: layers/MapGuide lib
svn_fusion at osgeo.org
Tue Aug 9 21:09:04 EDT 2011
Author: liuar
Date: 2011-08-09 18:09:04 -0700 (Tue, 09 Aug 2011)
New Revision: 2420
trunk/layers/MapGuide/MapGuide.js
trunk/lib/MGBroker.js
Fix ticket http://trac.osgeo.org/fusion/ticket/473
query() ignores the options.filter parameter
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2011-08-09 06:22:51 UTC (rev 2419)
+++ trunk/layers/MapGuide/MapGuide.js 2011-08-10 01:09:04 UTC (rev 2420)
@@ -1024,12 +1024,17 @@
maxFeatures = -1;
+ if(option.filter == null)
+ option.filter = '';
var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures(this.getSessionID(),
this._sMapname,
options.geometry,
maxFeatures,
persist,
options.selectionType || this.selectionType,
+ options.filter,
options.layers,
layerAttributeFilter);
var callback = (options.extendSelection == true) ? OpenLayers.Function.bind(this.processAndMergeFeatureInfo, this) : OpenLayers.Function.bind(this.processFeatureInfo, this);
@@ -1109,6 +1114,7 @@
var maxFeatures = 1;
var persist = 0;
var selection = 'INTERSECTS';
+ var filter = '';
var layerNames = '';
var layerAttributeFilter = 3;
var sep = '';
@@ -1119,7 +1125,7 @@
this._sMapname,
sGeometry,
- maxFeatures, persist, selection, layerNames,
+ maxFeatures, persist, selection, filter, layerNames,
var callback = OpenLayers.Function.bind(this.crtlClickDisplay, this);
Fusion.oBroker.dispatchRequest(r, OpenLayers.Function.bind(Fusion.xml2json, this, callback));
@@ -1232,6 +1238,7 @@
var persist = 0;
+ var filter = '';
// only select visible layers with maptips defined (1+4)
var layerAttributeFilter = 5;
//TODO: possibly make the layer names configurable?
@@ -1239,7 +1246,7 @@
this._sMapname,
sGeometry,
Modified: trunk/lib/MGBroker.js
--- trunk/lib/MGBroker.js 2011-08-09 06:22:51 UTC (rev 2419)
+++ trunk/lib/MGBroker.js 2011-08-10 01:09:04 UTC (rev 2420)
@@ -567,13 +567,14 @@
* @param maxFeatures {integer} number of maximum results (-1 to indicate no maximum)
* @param selectionPersist {boolean} save the selection (valid values are 0 and 1)
* @param selectionVariant {String} indicates the spatial operation. Valid values are 'INTERSECTS', ...
+ * @param featureFilter {String} filter crieteria to be applied for selection.
* @param layerNames {String} comma separated list of layer names to include in the query
* @param layerAttributeFilter {integer} bitmask determining layer selection behaviour (1=visible layers,
* 2=selectable layers, 4=layers with tooltips)
* @return {Object} an instance of Fusion.Lib.MGRequest.MGQueryMapFeatures
- initialize : function( sessionId, mapName, geometry, maxFeatures, persist, selectionVariant, layerNames, layerAttributeFilter )
+ initialize : function( sessionId, mapName, geometry, maxFeatures, persist, selectionVariant, featureFilter, layerNames, layerAttributeFilter )
this.initializeRequest();
this.setParams( {
@@ -584,6 +585,7 @@
maxFeatures: maxFeatures,
persist: persist,
selectionVariant: selectionVariant,
+ featureFilter: featureFilter,
layerNames: layerNames,
layerAttributeFilter: layerAttributeFilter
More information about the fusion-commits
