[fusion-commits] r2474 - in trunk: lib widgets
svn_fusion at osgeo.org
Thu Dec 1 05:04:17 EST 2011
Author: liuar
Date: 2011-12-01 02:04:17 -0800 (Thu, 01 Dec 2011)
New Revision: 2474
trunk/lib/Widget.js
trunk/widgets/TaskPane.js
on behalf of libr(Bruce li)
Issues:
The 'go to previous task executed' button does not work well.
Reason:
The function of loading task panel of specified widget was called more than once, which call themselves because of incorrect logic.
Modified: trunk/lib/Widget.js
--- trunk/lib/Widget.js 2011-12-01 05:44:31 UTC (rev 2473)
+++ trunk/lib/Widget.js 2011-12-01 10:04:17 UTC (rev 2474)
@@ -119,9 +119,11 @@
if (uiObj.addEvents) {
if (Fusion.Widget.uiInstances[this.type][0].uiObj &&
Fusion.Widget.uiInstances[this.type][0].uiObj.options.active &&
- Fusion.Widget.uiInstances[this.type][0].shouldActivateWith(this) &&
- uiObj.setActive) {
- uiObj.setActive(true);
+ Fusion.Widget.uiInstances[this.type][0].shouldActivateWith(this)) {
+ uiObj.options.active = true;
+ if (uiObj.domA) {
+ uiObj.domA.addClass('jx' + uiObj.options.type + 'Active');
uiObj.addEvents({
@@ -132,9 +134,11 @@
var instances = Fusion.Widget.uiInstances[this.type];
for (var i=0; i<instances.length; i++) {
var instance = instances[i];
- if (instance.shouldActivateWith(this) &&
- instance.uiObj && instance.uiObj.setActive) {
- instance.uiObj.setActive(false);
+ if (instance.shouldActivateWith(this) && instance.uiObj) {
+ instance.uiObj.options.active = false;
+ if (instance.uiObj.domA) {
+ instance.uiObj.domA.removeClass('jx' + instance.uiObj.options.type + 'Active');
this.deactivate();
@@ -143,9 +147,11 @@
- instance.uiObj.setActive(true);
+ instance.uiObj.options.active = true;
+ instance.uiObj.domA.addClass('jx' + instance.uiObj.options.type + 'Active');
this.activate();
Modified: trunk/widgets/TaskPane.js
--- trunk/widgets/TaskPane.js 2011-12-01 05:44:31 UTC (rev 2473)
+++ trunk/widgets/TaskPane.js 2011-12-01 10:04:17 UTC (rev 2474)
@@ -157,7 +157,7 @@
setInitialContent: function(url) {
this.aExecutedTasks = [];
- this.nCurrentTask = 0;
+ this.nCurrentTask = -1;
this.setContent(url);
More information about the fusion-commits
