[fusion-commits] r2481 - trunk/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Dec 6 09:24:01 EST 2011
Author: jng
Date: 2011-12-06 06:24:01 -0800 (Tue, 06 Dec 2011)
New Revision: 2481
   trunk/widgets/Legend.js
Partial fix for #500. Tiled layers no longer have checkboxes shown. However this fix is partial because tiled themed layers are represented as folder nodes, which I have yet to figure out how to turn off checkboxes for (if it is possible)
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js	2011-12-05 16:02:51 UTC (rev 2480)
+++ trunk/widgets/Legend.js	2011-12-06 14:24:01 UTC (rev 2481)
@@ -609,11 +609,11 @@
                     style.legendLabel = layer.legendLabel;
                 if (!layer.legend.treeItem) {
-                    layer.legend.treeItem = this.createTreeItem(layer, style, fScale, true);
+                    layer.legend.treeItem = this.createTreeItem(layer, style, fScale, !layer.isBaseMapLayer);
                     layer.parentGroup.legend.treeItem.add(layer.legend.treeItem);
                 } else if (layer.legend.treeItem instanceof Fusion.Widget.Legend.TreeFolder) {
                     this.clearTreeItem(layer);
                 } else {
                     if (range.styles.length > 0) {
@@ -636,7 +636,7 @@
                     layer.legend.treeItem = null;
             } else {
-              var newTreeItem = this.createTreeItem(layer, {legendLabel: layer.legendLabel}, null, true);
+              var newTreeItem = this.createTreeItem(layer, {legendLabel: layer.legendLabel}, null, !layer.isBaseMapLayer);
                 if (layer.legend.treeItem) {
                     layer.parentGroup.legend.treeItem.replace(newTreeItem, layer.legend.treeItem);
                     layer.legend.treeItem.finalize();
@@ -648,7 +648,8 @@
             layer.legend.treeItem.options.data = layer;
-            layer.legend.treeItem.check(layer.visible);
+            if (!layer.isBaseMapLayer) //Tiled layers don't have a checkbox so there's nothing to check
+                layer.legend.treeItem.check(layer.visible);
     getThemeExpandContextMenu: function(node) {
More information about the fusion-commits mailing list
