[fusion-commits] r2335 - trunk/lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Feb 7 14:03:14 EST 2011
Author: assefa
Date: 2011-02-07 11:03:14 -0800 (Mon, 07 Feb 2011)
New Revision: 2335
   trunk/lib/ApplicationDefinition.js
   trunk/lib/Map.js
Correct restrictedExtent
Modified: trunk/lib/ApplicationDefinition.js
--- trunk/lib/ApplicationDefinition.js	2011-02-07 16:26:48 UTC (rev 2334)
+++ trunk/lib/ApplicationDefinition.js	2011-02-07 19:03:14 UTC (rev 2335)
@@ -518,7 +518,7 @@
                 this.layerOptions[key] = val;
-            if (key == 'maxExtent' || key == 'minExtent') {
+            if (key == 'maxExtent' || key == 'minExtent' || key == 'restrictedExtent') {
               this.layerOptions[key] = OpenLayers.Bounds.fromString(this.layerOptions[key]);
             if (key == 'resolutions' || key == 'scales') {
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js	2011-02-07 16:26:48 UTC (rev 2334)
+++ trunk/lib/Map.js	2011-02-07 19:03:14 UTC (rev 2335)
@@ -526,36 +526,39 @@
      * Return: none
-    addMap: function(map) {
+    addMap: function(currentmap) {
-        if (map.mapTag.layerOptions.maxExtent) {
-          this.maxExtent.extend(map.mapTag.layerOptions.maxExtent);
+        if (currentmap.mapTag.layerOptions.maxExtent) {
+          this.maxExtent.extend(currentmap.mapTag.layerOptions.maxExtent);
           this.oMapOL.setOptions({maxExtent: this.maxExtent});
+        if (currentmap.mapTag.layerOptions.restrictedExtent) {
+          this.oMapOL.setOptions({restrictedExtent: currentmap.mapTag.layerOptions.restrictedExtent});
         //if bRestrictExtent is null, use the default OL behaviour with somewhat restricted map navigation
         //if bRestrictExtent is set to true, map navigation is limited to the map extent
         //if bRestrictExtent is set to false, map navigation is not restricted at all
         if (this.bRestrictExtent != null) {
           if (this.bRestrictExtent) {
-            this.oMapOL.restrictedExtent = map.mapTag.layerOptions.maxExtent;
+            this.oMapOL.restrictedExtent = currentmap.mapTag.layerOptions.maxExtent;
           } else {
             this.oMapOL.restrictedExtent = false;
-        this.oMapOL.addLayer(map.oLayerOL);
-        if (map.oLayerOL.isBaseLayer) {
-          this.projection = map.projection;
-          this.units = map.units;
+        this.oMapOL.addLayer(currentmap.oLayerOL);
+        if (currentmap.oLayerOL.isBaseLayer) {
+          this.projection = currentmap.projection;
+          this.units = currentmap.units;
-                  units: map.units,
+                  units: currentmap.units,
                   projection: this.projection
-        map.registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
+        currentmap.registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
                 OpenLayers.Function.bind(this.selectionHandler, this));
-        map.registerForEvent(Fusion.Event.MAP_SELECTION_ON,
+        currentmap.registerForEvent(Fusion.Event.MAP_SELECTION_ON,
More information about the fusion-commits mailing list
