[fusion-commits] r2320 - sandbox/adsk/2.3r/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Jan 18 00:16:25 EST 2011
Author: liuar
Date: 2011-01-17 21:16:25 -0800 (Mon, 17 Jan 2011)
New Revision: 2320
   sandbox/adsk/2.3r/widgets/Legend.js
Fix ticket #425 ("Stop Running this Script" with Fusion & IE when too many items in legend) in adsk branch
Modified: sandbox/adsk/2.3r/widgets/Legend.js
--- sandbox/adsk/2.3r/widgets/Legend.js	2011-01-17 20:15:35 UTC (rev 2319)
+++ sandbox/adsk/2.3r/widgets/Legend.js	2011-01-18 05:16:25 UTC (rev 2320)
@@ -563,6 +563,31 @@
             this.updateLayer(group.layers[i], fScale);
+    // RepeatingOperation and createAndAppendTreeItem are help methods
+    // to prevent 'Stop running this script' message in IE
+    RepeatingOperation: function(op, maxCount, yieldEveryIteration) {
+        var index = 0;
+        var count = 0;
+        this.step = function(instance, layer, range, scale, bCheckBox) {
+            while(count < maxCount) {
+                count++;
+                if (++index >= yieldEveryIteration) {
+                    index = 0;
+                    setTimeout(function() { op(instance, layer, range.styles[count], scale, bCheckBox); }, 1, [])
+                    return;
+                op(instance, layer, range.styles[count], scale, bCheckBox);
+    createAndAppendTreeItem: function(instance, layer, style, scale, bCheckBox){
+        var item = instance.createTreeItem(layer, style, scale, bCheckBox);
+        layer.legend.treeItem.append(item);
     updateLayer: function(layer, fScale) {
         var checkbox = layer.isBaseMapLayer ? false : this.bIncludeVisToggle;
@@ -598,10 +623,22 @@
                         layer.legend.treeItem.remove(layer.legend.treeItem.nodes[0]);
-                for (var i=0; i<range.styles.length; i++) {
-                    var item = this.createTreeItem(layer, range.styles[i], fScale, false);
-                    layer.legend.treeItem.append(item);
+                // for (var i=0; i<range.styles.length; i++) {
+                    // var item = this.createTreeItem(layer, range.styles[i], fScale, false);
+                    // layer.legend.treeItem.append(item);
+                var agent = navigator.userAgent.toLowerCase();
+                var msie = agent.indexOf("msie") != -1;
+                if(msie && range.styles.length > 0) {
+                    var ro = new this.RepeatingOperation(this.createAndAppendTreeItem, range.styles.length, 10);
+                    ro.step(this, layer, range, fScale, false);
+                else {
+                    for (var i=0; i<range.styles.length; i++) {
+                        var item = this.createTreeItem(layer, range.styles[i], fScale, false);
             } else {
                 var style = range.styles[0];
More information about the fusion-commits mailing list
