[fusion-commits] r2416 - trunk/widgets/QuickPlot
svn_fusion at osgeo.org
Wed Jul 27 21:52:20 EDT 2011
Author: liuar
Date: 2011-07-27 18:52:20 -0700 (Wed, 27 Jul 2011)
New Revision: 2416
trunk/widgets/QuickPlot/GeneratePicture.php
For ticket 1757: http://trac.osgeo.org/mapguide/ticket/1757
Modified: trunk/widgets/QuickPlot/GeneratePicture.php
--- trunk/widgets/QuickPlot/GeneratePicture.php 2011-07-26 19:50:52 UTC (rev 2415)
+++ trunk/widgets/QuickPlot/GeneratePicture.php 2011-07-28 01:52:20 UTC (rev 2416)
@@ -13,8 +13,8 @@
$captureBox;
$normalizedCapture;
$printSize;
- $paperSize;
+ $paperSize;
GetParameters();
GenerateMap($printSize);
@@ -32,13 +32,13 @@
// Not necessary to validate the parameters
$sessionID = $args["session_id"];
$mapName = $args["map_name"];
- $rotation = floatval($args["rotation"]);
+ $rotation = ParseLocaleDouble($args["rotation"]);
$printDpi = intval($args["print_dpi"]);
$scaleDenominator = intval($args["scale_denominator"]);
$array = explode(",", $args["paper_size"]);
- $paperSize = new Size(floatval($array[0]), floatval($array[1]));
+ $paperSize = new Size(ParseLocaleDouble($array[0]), ParseLocaleDouble($array[1]));
$printSize = new Size($paperSize->width / 25.4 * $printDpi, $paperSize->height / 25.4 * $printDpi);
$array = explode(",", $args["box"]);
@@ -56,11 +56,11 @@
for ($index = 0; $index < count($coordinates); ++$index)
- $coordinate = $geometryFactory->CreateCoordinateXY(floatval($coordinates[$index]), floatval($coordinates[++$index]));
+ $coordinate = $geometryFactory->CreateCoordinateXY(ParseLocaleDouble($coordinates[$index]), ParseLocaleDouble($coordinates[++$index]));
$coordinateCollection->Add($coordinate);
- $coordinateCollection->Add($geometryFactory->CreateCoordinateXY(floatval($coordinates[0]), floatval($coordinates[1])));
+ $coordinateCollection->Add($geometryFactory->CreateCoordinateXY(ParseLocaleDouble($coordinates[0]), ParseLocaleDouble($coordinates[1])));
$linearRingCollection = $geometryFactory->CreateLinearRing($coordinateCollection);
$captureBox = $geometryFactory->CreatePolygon($linearRingCollection, null);
@@ -100,7 +100,7 @@
$mapAgent .= "s";
// Get the correct port number
- $mapAgent .= "://127.0.0.1:" . $_SERVER["SERVER_PORT"];
+ $mapAgent .= "://127.0.0.1:" . $_SERVER["SERVER_PORT"];
// Get the correct virtual directory
$mapAgent .= substr($_SERVER["REQUEST_URI"], 0, strpos($_SERVER["REQUEST_URI"], "/", 1));
$mapAgent .="/mapagent/mapagent.fcgi?VERSION=1.0.0&OPERATION=GETMAPIMAGE" .
@@ -130,7 +130,7 @@
header ("Content-type: image/png");
imagepng($croppedImg);
- imagedestroy($croppedImg);
+ imagedestroy($croppedImg);
function DrawNorthArrow($map)
@@ -165,6 +165,13 @@
// Free the north arrow image
imagedestroy($rotatedNa);
+ function ParseLocaleDouble($stringValue)
+ $lc = localeconv();
+ $result = str_replace(".", $lc["decimal_point"], $stringValue);
+ return doubleval($result);
<?php
More information about the fusion-commits
