[fusion-commits] r2393 - branches/fusion-2.2
svn_fusion at osgeo.org
Wed Jun 1 10:52:35 EDT 2011
Author: madair
Date: 2011-06-01 07:52:35 -0700 (Wed, 01 Jun 2011)
New Revision: 2393
Removed:
branches/fusion-2.2/OL-MGOS-useOverlay.patch
removing file added accidentally
Deleted: branches/fusion-2.2/OL-MGOS-useOverlay.patch
--- branches/fusion-2.2/OL-MGOS-useOverlay.patch 2011-06-01 14:39:15 UTC (rev 2392)
+++ branches/fusion-2.2/OL-MGOS-useOverlay.patch 2011-06-01 14:52:35 UTC (rev 2393)
@@ -1,37 +0,0 @@
-Index: lib/OpenLayers/Layer/MapGuide.js
---- lib/OpenLayers/Layer/MapGuide.js (revision 8066)
-+++ lib/OpenLayers/Layer/MapGuide.js (working copy)
-@@ -24,6 +24,13 @@
- isBaseLayer: true,
-+ * APIProperty: useOverlay
-+ * {Boolean} flag to indicate if the layer should be retrieved using
-+ * GETMAPIMAGE (default) or using GETDYNAMICOVERLAY requests.
-+ useOverlay: false,
- * APIProperty: singleTile
- * {Boolean} use tile server or request single tile image. Note that using
- * singleTile *and* isBaseLayer false is *not recommend*: it uses synchronous
-@@ -127,6 +134,9 @@
- this.params,
- this.SINGLE_TILE_PARAMS
-+ if (options.useOverlay!=null) {
-+ this.useOverlay = options.useOverlay;
- } else {
- //initialize for tiled layers
-@@ -202,7 +212,7 @@
- params.setviewcentery = center.lat;
- params.setviewscale = this.map.getScale();
-- if (!this.isBaseLayer) {
-+ if (this.useOverlay) {
- // in this case the main image operation is remapped to this
- this.params.operation = "GETDYNAMICMAPOVERLAYIMAGE";
More information about the fusion-commits
