[fusion-commits] r2340 - trunk/lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Mar 3 15:59:36 EST 2011
Author: madair
Date: 2011-03-03 12:59:36 -0800 (Thu, 03 Mar 2011)
New Revision: 2340
   trunk/lib/jxlib.uncompressed.js
fix for Jx.subMenu issue where the submenus being hidden before the click event can fire
Modified: trunk/lib/jxlib.uncompressed.js
--- trunk/lib/jxlib.uncompressed.js	2011-02-14 18:59:54 UTC (rev 2339)
+++ trunk/lib/jxlib.uncompressed.js	2011-03-03 20:59:36 UTC (rev 2340)
@@ -27,14561 +27,14561 @@
  * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
  * DEALINGS IN THE SOFTWARE.
+script: Core.js
+description: The core of MooTools, contains all the base functions and the Native and Hash implementations. Required by all the other scripts.
+license: MIT-style license.
+copyright: Copyright (c) 2006-2008 [Valerio Proietti](http://mad4milk.net/).
+authors: The MooTools production team (http://mootools.net/developers/)
+inspiration:
+- Class implementation inspired by [Base.js](http://dean.edwards.name/weblog/2006/03/base/) Copyright (c) 2006 Dean Edwards, [GNU Lesser General Public License](http://opensource.org/licenses/lgpl-license.php)
+- Some functionality inspired by [Prototype.js](http://prototypejs.org) Copyright (c) 2005-2007 Sam Stephenson, [MIT License](http://opensource.org/licenses/mit-license.php)
+provides: [MooTools, Native, Hash.base, Array.each, $util]
+var MooTools = {
+	'version': '1.2.5dev',
+	'build': '%build%'
+var Native = function(options){
+	options = options || {};
+	var name = options.name;
+	var legacy = options.legacy;
+	var protect = options.protect;
+	var methods = options.implement;
+	var generics = options.generics;
+	var initialize = options.initialize;
+	var afterImplement = options.afterImplement || function(){};
+	var object = initialize || legacy;
+	generics = generics !== false;
+	object.constructor = Native;
+	object.$family = {name: 'native'};
+	if (legacy && initialize) object.prototype = legacy.prototype;
+	object.prototype.constructor = object;
+	if (name){
+		var family = name.toLowerCase();
+		object.prototype.$family = {name: family};
+		Native.typize(object, family);
+	var add = function(obj, name, method, force){
+		if (!protect || force || !obj.prototype[name]) obj.prototype[name] = method;
+		if (generics) Native.genericize(obj, name, protect);
+		afterImplement.call(obj, name, method);
+		return obj;
+	object.alias = function(a1, a2, a3){
+		if (typeof a1 == 'string'){
+			var pa1 = this.prototype[a1];
+			if ((a1 = pa1)) return add(this, a2, a1, a3);
+		for (var a in a1) this.alias(a, a1[a], a2);
+		return this;
+	object.implement = function(a1, a2, a3){
+		if (typeof a1 == 'string') return add(this, a1, a2, a3);
+		for (var p in a1) add(this, p, a1[p], a2);
+		return this;
+	if (methods) object.implement(methods);
+	return object;
+Native.genericize = function(object, property, check){
+	if ((!check || !object[property]) && typeof object.prototype[property] == 'function') object[property] = function(){
+		var args = Array.prototype.slice.call(arguments);
+		return object.prototype[property].apply(args.shift(), args);
+Native.implement = function(objects, properties){
+	for (var i = 0, l = objects.length; i < l; i++) objects[i].implement(properties);
+Native.typize = function(object, family){
+	if (!object.type) object.type = function(item){
+		return ($type(item) === family);
+(function(){
+	var natives = {'Array': Array, 'Date': Date, 'Function': Function, 'Number': Number, 'RegExp': RegExp, 'String': String};
+	for (var n in natives) new Native({name: n, initialize: natives[n], protect: true});
+	var types = {'boolean': Boolean, 'native': Native, 'object': Object};
+	for (var t in types) Native.typize(types[t], t);
+	var generics = {
+		'Array': ["concat", "indexOf", "join", "lastIndexOf", "pop", "push", "reverse", "shift", "slice", "sort", "splice", "toString", "unshift", "valueOf"],
+		'String': ["charAt", "charCodeAt", "concat", "indexOf", "lastIndexOf", "match", "replace", "search", "slice", "split", "substr", "substring", "toLowerCase", "toUpperCase", "valueOf"]
+	for (var g in generics){
+		for (var i = generics[g].length; i--;) Native.genericize(natives[g], generics[g][i], true);
+var Hash = new Native({
+	name: 'Hash',
+	initialize: function(object){
+		if ($type(object) == 'hash') object = $unlink(object.getClean());
+		for (var key in object) this[key] = object[key];
+		return this;
+Hash.implement({
+	forEach: function(fn, bind){
+		for (var key in this){
+			if (this.hasOwnProperty(key)) fn.call(bind, this[key], key, this);
+	getClean: function(){
+		var clean = {};
+			if (this.hasOwnProperty(key)) clean[key] = this[key];
+		return clean;
+	getLength: function(){
+		var length = 0;
+			if (this.hasOwnProperty(key)) length++;
+		return length;
+Hash.alias('forEach', 'each');
+Array.implement({
+		for (var i = 0, l = this.length; i < l; i++) fn.call(bind, this[i], i, this);
+Array.alias('forEach', 'each');
+function $A(iterable){
+	if (iterable.item){
+		var l = iterable.length, array = new Array(l);
+		while (l--) array[l] = iterable[l];
+		return array;
+	return Array.prototype.slice.call(iterable);
+function $arguments(i){
+	return function(){
+		return arguments[i];
+function $chk(obj){
+	return !!(obj || obj === 0);
+function $clear(timer){
+	clearTimeout(timer);
+	clearInterval(timer);
+	return null;
+function $defined(obj){
+	return (obj != undefined);
+function $each(iterable, fn, bind){
+	var type = $type(iterable);
+	((type == 'arguments' || type == 'collection' || type == 'array') ? Array : Hash).each(iterable, fn, bind);
+function $empty(){};
+function $extend(original, extended){
+	for (var key in (extended || {})) original[key] = extended[key];
+	return original;
+function $H(object){
+	return new Hash(object);
+function $lambda(value){
+	return ($type(value) == 'function') ? value : function(){
+		return value;
+function $merge(){
+	var args = Array.slice(arguments);
+	args.unshift({});
+	return $mixin.apply(null, args);
+function $mixin(mix){
+	for (var i = 1, l = arguments.length; i < l; i++){
+		var object = arguments[i];
+		if ($type(object) != 'object') continue;
+		for (var key in object){
+			var op = object[key], mp = mix[key];
+			mix[key] = (mp && $type(op) == 'object' && $type(mp) == 'object') ? $mixin(mp, op) : $unlink(op);
+	return mix;
+function $pick(){
+	for (var i = 0, l = arguments.length; i < l; i++){
+		if (arguments[i] != undefined) return arguments[i];
+	return null;
+function $random(min, max){
+	return Math.floor(Math.random() * (max - min + 1) + min);
+function $splat(obj){
+	var type = $type(obj);
+	return (type) ? ((type != 'array' && type != 'arguments') ? [obj] : obj) : [];
+var $time = Date.now || function(){
+	return +new Date;
+function $try(){
+		try {
+			return arguments[i]();
+		} catch(e){}
+	return null;
+function $type(obj){
+	if (obj == undefined) return false;
+	if (obj.$family) return (obj.$family.name == 'number' && !isFinite(obj)) ? false : obj.$family.name;
+	if (obj.nodeName){
+		switch (obj.nodeType){
+			case 1: return 'element';
+			case 3: return (/\S/).test(obj.nodeValue) ? 'textnode' : 'whitespace';
+	} else if (typeof obj.length == 'number'){
+		if (obj.callee) return 'arguments';
+		else if (obj.item) return 'collection';
+	return typeof obj;
+function $unlink(object){
+	var unlinked;
+	switch ($type(object)){
+		case 'object':
+			unlinked = {};
+			for (var p in object) unlinked[p] = $unlink(object[p]);
+		break;
+		case 'hash':
+			unlinked = new Hash(object);
+		break;
+		case 'array':
+			unlinked = [];
+			for (var i = 0, l = object.length; i < l; i++) unlinked[i] = $unlink(object[i]);
+		break;
+		default: return object;
+	return unlinked;
+script: Browser.js
+description: The Browser Core. Contains Browser initialization, Window and Document, and the Browser Hash.
+requires:
+- /Native
+- /$util
+provides: [Browser, Window, Document, $exec]
+var Browser = $merge({
+	Engine: {name: 'unknown', version: 0},
+	Platform: {name: (window.orientation != undefined) ? 'ipod' : (navigator.platform.match(/mac|win|linux/i) || ['other'])[0].toLowerCase()},
+	Features: {xpath: !!(document.evaluate), air: !!(window.runtime), query: !!(document.querySelector)},
+	Plugins: {},
+	Engines: {
+		presto: function(){
+			return (!window.opera) ? false : ((arguments.callee.caller) ? 960 : ((document.getElementsByClassName) ? 950 : 925));
+		trident: function(){
+			return (!window.ActiveXObject) ? false : ((window.XMLHttpRequest) ? ((document.querySelectorAll) ? 6 : 5) : 4);
+		webkit: function(){
+			return (navigator.taintEnabled) ? false : ((Browser.Features.xpath) ? ((Browser.Features.query) ? 525 : 420) : 419);
+		gecko: function(){
+			return (!document.getBoxObjectFor && window.mozInnerScreenX == null) ? false : ((document.getElementsByClassName) ? 19 : 18);
+}, Browser || {});
+Browser.Platform[Browser.Platform.name] = true;
+Browser.detect = function(){
+	for (var engine in this.Engines){
+		var version = this.Engines[engine]();
+		if (version){
+			this.Engine = {name: engine, version: version};
+			this.Engine[engine] = this.Engine[engine + version] = true;
+			break;
+	return {name: engine, version: version};
+Browser.detect();
+Browser.Request = function(){
+	return $try(function(){
+		return new XMLHttpRequest();
+	}, function(){
+		return new ActiveXObject('MSXML2.XMLHTTP');
+	}, function(){
+		return new ActiveXObject('Microsoft.XMLHTTP');
+Browser.Features.xhr = !!(Browser.Request());
+Browser.Plugins.Flash = (function(){
+	var version = ($try(function(){
+		return navigator.plugins['Shockwave Flash'].description;
+	}, function(){
+		return new ActiveXObject('ShockwaveFlash.ShockwaveFlash').GetVariable('$version');
+	}) || '0 r0').match(/\d+/g);
+	return {version: parseInt(version[0] || 0 + '.' + version[1], 10) || 0, build: parseInt(version[2], 10) || 0};
+function $exec(text){
+	if (!text) return text;
+	if (window.execScript){
+		window.execScript(text);
+	} else {
+		var script = document.createElement('script');
+		script.setAttribute('type', 'text/javascript');
+		script[(Browser.Engine.webkit && Browser.Engine.version < 420) ? 'innerText' : 'text'] = text;
+		document.head.appendChild(script);
+		document.head.removeChild(script);
+	return text;
+Native.UID = 1;
+var $uid = (Browser.Engine.trident) ? function(item){
+	return (item.uid || (item.uid = [Native.UID++]))[0];
+} : function(item){
+	return item.uid || (item.uid = Native.UID++);
+var Window = new Native({
+	name: 'Window',
+	legacy: (Browser.Engine.trident) ? null: window.Window,
+	initialize: function(win){
+		$uid(win);
+		if (!win.Element){
+			win.Element = $empty;
+			if (Browser.Engine.webkit) win.document.createElement("iframe"); //fixes safari 2
+			win.Element.prototype = (Browser.Engine.webkit) ? window["[[DOMElement.prototype]]"] : {};
+		win.document.window = win;
+		return $extend(win, Window.Prototype);
+	afterImplement: function(property, value){
+		window[property] = Window.Prototype[property] = value;
+Window.Prototype = {$family: {name: 'window'}};
+new Window(window);
+var Document = new Native({
+	name: 'Document',
+	legacy: (Browser.Engine.trident) ? null: window.Document,
+	initialize: function(doc){
+		$uid(doc);
+		doc.head = doc.getElementsByTagName('head')[0];
+		doc.html = doc.getElementsByTagName('html')[0];
+		if (Browser.Engine.trident && Browser.Engine.version <= 4) $try(function(){
+			doc.execCommand("BackgroundImageCache", false, true);
+		if (Browser.Engine.trident) doc.window.attachEvent('onunload', function(){
+			doc.window.detachEvent('onunload', arguments.callee);
+			doc.head = doc.html = doc.window = null;
+		return $extend(doc, Document.Prototype);
+		document[property] = Document.Prototype[property] = value;
+Document.Prototype = {$family: {name: 'document'}};
+new Document(document);
+script: Array.js
+description: Contains Array Prototypes like each, contains, and erase.
+requires:
+- /$util
+- /Array.each
+provides: [Array]
+Array.implement({
+	every: function(fn, bind){
+		for (var i = 0, l = this.length; i < l; i++){
+			if (!fn.call(bind, this[i], i, this)) return false;
+		return true;
+	filter: function(fn, bind){
+		var results = [];
+			if (fn.call(bind, this[i], i, this)) results.push(this[i]);
+		return results;
+	clean: function(){
+		return this.filter($defined);
+	indexOf: function(item, from){
+		var len = this.length;
+		for (var i = (from < 0) ? Math.max(0, len + from) : from || 0; i < len; i++){
+			if (this[i] === item) return i;
+		return -1;
+	map: function(fn, bind){
+		var results = [];
+		for (var i = 0, l = this.length; i < l; i++) results[i] = fn.call(bind, this[i], i, this);
+		return results;
+	some: function(fn, bind){
+			if (fn.call(bind, this[i], i, this)) return true;
+		return false;
+	associate: function(keys){
+		var obj = {}, length = Math.min(this.length, keys.length);
+		for (var i = 0; i < length; i++) obj[keys[i]] = this[i];
+		return obj;
+	link: function(object){
+		var result = {};
+				if (object[key](this[i])){
+					result[key] = this[i];
+					delete object[key];
+					break;
+		return result;
+	contains: function(item, from){
+		return this.indexOf(item, from) != -1;
+	extend: function(array){
+		for (var i = 0, j = array.length; i < j; i++) this.push(array[i]);
+		return this;
+	getLast: function(){
+		return (this.length) ? this[this.length - 1] : null;
+	getRandom: function(){
+		return (this.length) ? this[$random(0, this.length - 1)] : null;
+	include: function(item){
+		if (!this.contains(item)) this.push(item);
+		return this;
+	combine: function(array){
+		for (var i = 0, l = array.length; i < l; i++) this.include(array[i]);
+		return this;
+	erase: function(item){
+		for (var i = this.length; i--; i){
+			if (this[i] === item) this.splice(i, 1);
+		return this;
+	empty: function(){
+		this.length = 0;
+		return this;
+	flatten: function(){
+		var array = [];
+			var type = $type(this[i]);
+			if (!type) continue;
+			array = array.concat((type == 'array' || type == 'collection' || type == 'arguments') ? Array.flatten(this[i]) : this[i]);
+		return array;
+	hexToRgb: function(array){
+		if (this.length != 3) return null;
+		var rgb = this.map(function(value){
+			if (value.length == 1) value += value;
+			return value.toInt(16);
+		return (array) ? rgb : 'rgb(' + rgb + ')';
+	rgbToHex: function(array){
+		if (this.length < 3) return null;
+		if (this.length == 4 && this[3] == 0 && !array) return 'transparent';
+		var hex = [];
+		for (var i = 0; i < 3; i++){
+			var bit = (this[i] - 0).toString(16);
+			hex.push((bit.length == 1) ? '0' + bit : bit);
+		return (array) ? hex : '#' + hex.join('');
+script: Function.js
+description: Contains Function Prototypes like create, bind, pass, and delay.
+requires:
+- /Native
+- /$util
+provides: [Function]
+Function.implement({
+	extend: function(properties){
+		for (var property in properties) this[property] = properties[property];
+		return this;
+	create: function(options){
+		var self = this;
+		return function(event){
+			var args = options.arguments;
+			args = (args != undefined) ? $splat(args) : Array.slice(arguments, (options.event) ? 1 : 0);
+			if (options.event) args = [event || window.event].extend(args);
+			var returns = function(){
+				return self.apply(options.bind || null, args);
+			if (options.delay) return setTimeout(returns, options.delay);
+			if (options.periodical) return setInterval(returns, options.periodical);
+			if (options.attempt) return $try(returns);
+			return returns();
+	run: function(args, bind){
+		return this.apply(bind, $splat(args));
+	pass: function(args, bind){
+		return this.create({bind: bind, arguments: args});
+	bind: function(bind, args){
+	bindWithEvent: function(bind, args){
+		return this.create({bind: bind, arguments: args, event: true});
+	attempt: function(args, bind){
+		return this.create({bind: bind, arguments: args, attempt: true})();
+	delay: function(delay, bind, args){
+		return this.create({bind: bind, arguments: args, delay: delay})();
+	periodical: function(periodical, bind, args){
+		return this.create({bind: bind, arguments: args, periodical: periodical})();
+script: Number.js
+description: Contains Number Prototypes like limit, round, times, and ceil.
+requires:
+- /Native
+- /$util
+provides: [Number]
+Number.implement({
+	limit: function(min, max){
+		return Math.min(max, Math.max(min, this));
+	round: function(precision){
+		precision = Math.pow(10, precision || 0);
+		return Math.round(this * precision) / precision;
+	times: function(fn, bind){
+		for (var i = 0; i < this; i++) fn.call(bind, i, this);
+	toFloat: function(){
+		return parseFloat(this);
+	toInt: function(base){
+		return parseInt(this, base || 10);
+Number.alias('times', 'each');
+(function(math){
+	var methods = {};
+	math.each(function(name){
+		if (!Number[name]) methods[name] = function(){
+			return Math[name].apply(null, [this].concat($A(arguments)));
+	Number.implement(methods);
+})(['abs', 'acos', 'asin', 'atan', 'atan2', 'ceil', 'cos', 'exp', 'floor', 'log', 'max', 'min', 'pow', 'sin', 'sqrt', 'tan']);
+script: String.js
+description: Contains String Prototypes like camelCase, capitalize, test, and toInt.
+requires:
+- /Native
+provides: [String]
+String.implement({
+	test: function(regex, params){
+		return ((typeof regex == 'string') ? new RegExp(regex, params) : regex).test(this);
+	contains: function(string, separator){
+		return (separator) ? (separator + this + separator).indexOf(separator + string + separator) > -1 : this.indexOf(string) > -1;
+	trim: function(){
+		return this.replace(/^\s+|\s+$/g, '');
+		return this.replace(/\s+/g, ' ').trim();
+	camelCase: function(){
+		return this.replace(/-\D/g, function(match){
+			return match.charAt(1).toUpperCase();
+	hyphenate: function(){
+		return this.replace(/[A-Z]/g, function(match){
+			return ('-' + match.charAt(0).toLowerCase());
+	capitalize: function(){
+		return this.replace(/\b[a-z]/g, function(match){
+			return match.toUpperCase();
+	escapeRegExp: function(){
+		return this.replace(/([-.*+?^${}()|[\]\/\\])/g, '\\$1');
+		var hex = this.match(/^#?(\w{1,2})(\w{1,2})(\w{1,2})$/);
+		return (hex) ? hex.slice(1).hexToRgb(array) : null;
+		var rgb = this.match(/\d{1,3}/g);
+		return (rgb) ? rgb.rgbToHex(array) : null;
+	stripScripts: function(option){
+		var scripts = '';
+		var text = this.replace(/<script[^>]*>([\s\S]*?)<\/script>/gi, function(){
+			scripts += arguments[1] + '\n';
+			return '';
+		if (option === true) $exec(scripts);
+		else if ($type(option) == 'function') option(scripts, text);
+		return text;
+	substitute: function(object, regexp){
+		return this.replace(regexp || (/\\?\{([^{}]+)\}/g), function(match, name){
+			if (match.charAt(0) == '\\') return match.slice(1);
+			return (object[name] != undefined) ? object[name] : '';
+script: Hash.js
+description: Contains Hash Prototypes. Provides a means for overcoming the JavaScript practical impossibility of extending native Objects.
+requires:
+- /Hash.base
+provides: [Hash]
+Hash.implement({
+	has: Object.prototype.hasOwnProperty,
+	keyOf: function(value){
+			if (this.hasOwnProperty(key) && this[key] === value) return key;
+		return null;
+	hasValue: function(value){
+		return (Hash.keyOf(this, value) !== null);
+		Hash.each(properties || {}, function(value, key){
+			Hash.set(this, key, value);
+		}, this);
+		return this;
+	combine: function(properties){
+			Hash.include(this, key, value);
+		}, this);
+		return this;
+	erase: function(key){
+		if (this.hasOwnProperty(key)) delete this[key];
+		return this;
+	get: function(key){
+		return (this.hasOwnProperty(key)) ? this[key] : null;
+	set: function(key, value){
+		if (!this[key] || this.hasOwnProperty(key)) this[key] = value;
+		return this;
+		Hash.each(this, function(value, key){
+			delete this[key];
+		}, this);
+		return this;
+	include: function(key, value){
+		if (this[key] == undefined) this[key] = value;
+		return this;
+		var results = new Hash;
+			results.set(key, fn.call(bind, value, key, this));
+		}, this);
+		return results;
+			if (fn.call(bind, value, key, this)) results.set(key, value);
+		}, this);
+		return results;
+			if (this.hasOwnProperty(key) && !fn.call(bind, this[key], key)) return false;
+		return true;
+			if (this.hasOwnProperty(key) && fn.call(bind, this[key], key)) return true;
+		return false;
+	getKeys: function(){
+		var keys = [];
+			keys.push(key);
+		return keys;
+	getValues: function(){
+		var values = [];
+		Hash.each(this, function(value){
+			values.push(value);
+		return values;
+	toQueryString: function(base){
+		var queryString = [];
+			if (base) key = base + '[' + key + ']';
+			var result;
+			switch ($type(value)){
+				case 'object': result = Hash.toQueryString(value, key); break;
+				case 'array':
+					var qs = {};
+					value.each(function(val, i){
+						qs[i] = val;
+					result = Hash.toQueryString(qs, key);
+				break;
+				default: result = key + '=' + encodeURIComponent(value);
+			if (value != undefined) queryString.push(result);
+		return queryString.join('&');
+Hash.alias({keyOf: 'indexOf', hasValue: 'contains'});
+script: Event.js
+description: Contains the Event Class, to make the event object cross-browser.
+requires:
+- /Window
+- /Document
+- /Hash
+- /Array
+- /Function
+- /String
+provides: [Event]
+var Event = new Native({
+	name: 'Event',
+	initialize: function(event, win){
+		win = win || window;
+		var doc = win.document;
+		event = event || win.event;
+		if (event.$extended) return event;
+		this.$extended = true;
+		var type = event.type;
+		var target = event.target || event.srcElement;
+		while (target && target.nodeType == 3) target = target.parentNode;
+		if (type.test(/key/)){
+			var code = event.which || event.keyCode;
+			var key = Event.Keys.keyOf(code);
+			if (type == 'keydown'){
+				var fKey = code - 111;
+				if (fKey > 0 && fKey < 13) key = 'f' + fKey;
+			key = key || String.fromCharCode(code).toLowerCase();
+		} else if (type.match(/(click|mouse|menu)/i)){
+			doc = (!doc.compatMode || doc.compatMode == 'CSS1Compat') ? doc.html : doc.body;
+			var page = {
+				x: event.pageX || event.clientX + doc.scrollLeft,
+				y: event.pageY || event.clientY + doc.scrollTop
+			var client = {
+				x: (event.pageX) ? event.pageX - win.pageXOffset : event.clientX,
+				y: (event.pageY) ? event.pageY - win.pageYOffset : event.clientY
+			if (type.match(/DOMMouseScroll|mousewheel/)){
+				var wheel = (event.wheelDelta) ? event.wheelDelta / 120 : -(event.detail || 0) / 3;
+			var rightClick = (event.which == 3) || (event.button == 2);
+			var related = null;
+			if (type.match(/over|out/)){
+				switch (type){
+					case 'mouseover': related = event.relatedTarget || event.fromElement; break;
+					case 'mouseout': related = event.relatedTarget || event.toElement;
+				if (!(function(){
+					while (related && related.nodeType == 3) related = related.parentNode;
+					return true;
+				}).create({attempt: Browser.Engine.gecko})()) related = false;
+		return $extend(this, {
+			event: event,
+			type: type,
+			page: page,
+			client: client,
+			rightClick: rightClick,
+			wheel: wheel,
+			relatedTarget: related,
+			target: target,
+			code: code,
+			key: key,
+			shift: event.shiftKey,
+			control: event.ctrlKey,
+			alt: event.altKey,
+			meta: event.metaKey
+Event.Keys = new Hash({
+	'enter': 13,
+	'up': 38,
+	'down': 40,
+	'left': 37,
+	'right': 39,
+	'esc': 27,
+	'space': 32,
+	'backspace': 8,
+	'tab': 9,
+	'delete': 46
+Event.implement({
+	stop: function(){
+		return this.stopPropagation().preventDefault();
+	stopPropagation: function(){
+		if (this.event.stopPropagation) this.event.stopPropagation();
+		else this.event.cancelBubble = true;
+		return this;
+	preventDefault: function(){
+		if (this.event.preventDefault) this.event.preventDefault();
+		else this.event.returnValue = false;
+		return this;
+script: Class.js
+description: Contains the Class Function for easily creating, extending, and implementing reusable Classes.
+requires:
+- /$util
+- /Native
+- /Array
+- /String
+- /Function
+- /Number
+- /Hash
+provides: [Class]
+function Class(params){
+	if (params instanceof Function) params = {initialize: params};
+	var newClass = function(){
+		Object.reset(this);
+		if (newClass._prototyping) return this;
+		this._current = $empty;
+		var value = (this.initialize) ? this.initialize.apply(this, arguments) : this;
+		delete this._current; delete this.caller;
+		return value;
+	}.extend(this);
+	newClass.implement(params);
+	newClass.constructor = Class;
+	newClass.prototype.constructor = newClass;
+	return newClass;
+Function.prototype.protect = function(){
+	this._protected = true;
+	return this;
+Object.reset = function(object, key){
+	if (key == null){
+		for (var p in object) Object.reset(object, p);
+		return object;
+	switch ($type(object[key])){
+		case 'object':
+			var F = function(){};
+			F.prototype = object[key];
+			var i = new F;
+			object[key] = Object.reset(i);
+		break;
+		case 'array': object[key] = $unlink(object[key]); break;
+	return object;
+new Native({name: 'Class', initialize: Class}).extend({
+	instantiate: function(F){
+		F._prototyping = true;
+		var proto = new F;
+		delete F._prototyping;
+		return proto;
+	wrap: function(self, key, method){
+		if (method._origin) method = method._origin;
+			if (method._protected && this._current == null) throw new Error('The method "' + key + '" cannot be called.');
+			var caller = this.caller, current = this._current;
+			this.caller = current; this._current = arguments.callee;
+			var result = method.apply(this, arguments);
+			this._current = current; this.caller = caller;
+			return result;
+		}.extend({_owner: self, _origin: method, _name: key});
+Class.implement({
+	implement: function(key, value){
+		if ($type(key) == 'object'){
+			for (var p in key) this.implement(p, key[p]);
+			return this;
+		var mutator = Class.Mutators[key];
+		if (mutator){
+			value = mutator.call(this, value);
+			if (value == null) return this;
+		var proto = this.prototype;
+			case 'function':
+				if (value._hidden) return this;
+				proto[key] = Class.wrap(this, key, value);
+			break;
+			case 'object':
+				var previous = proto[key];
+				if ($type(previous) == 'object') $mixin(previous, value);
+				else proto[key] = $unlink(value);
+			break;
+			case 'array':
+				proto[key] = $unlink(value);
+			break;
+			default: proto[key] = value;
+		return this;
+Class.Mutators = {
+	Extends: function(parent){
+		this.parent = parent;
+		this.prototype = Class.instantiate(parent);
+		this.implement('parent', function(){
+			var name = this.caller._name, previous = this.caller._owner.parent.prototype[name];
+			if (!previous) throw new Error('The method "' + name + '" has no parent.');
+			return previous.apply(this, arguments);
+		}.protect());
+	Implements: function(items){
+		$splat(items).each(function(item){
+			if (item instanceof Function) item = Class.instantiate(item);
+			this.implement(item);
+		}, this);
+script: Class.Extras.js
+description: Contains Utility Classes that can be implemented into your own Classes to ease the execution of many common tasks.
+requires:
+- /Class
+provides: [Chain, Events, Options]
+var Chain = new Class({
+	$chain: [],
+	chain: function(){
+		this.$chain.extend(Array.flatten(arguments));
+		return this;
+	callChain: function(){
+		return (this.$chain.length) ? this.$chain.shift().apply(this, arguments) : false;
+	clearChain: function(){
+		this.$chain.empty();
+		return this;
+var Events = new Class({
+	$events: {},
+	addEvent: function(type, fn, internal){
+		type = Events.removeOn(type);
+		if (fn != $empty){
+			this.$events[type] = this.$events[type] || [];
+			this.$events[type].include(fn);
+			if (internal) fn.internal = true;
+		return this;
+	addEvents: function(events){
+		for (var type in events) this.addEvent(type, events[type]);
+		return this;
+	fireEvent: function(type, args, delay){
+		if (!this.$events || !this.$events[type]) return this;
+		this.$events[type].each(function(fn){
+			fn.create({'bind': this, 'delay': delay, 'arguments': args})();
+		}, this);
+		return this;
+	removeEvent: function(type, fn){
+		if (!this.$events[type]) return this;
+		if (!fn.internal) this.$events[type].erase(fn);
+		return this;
+	removeEvents: function(events){
+		var type;
+		if ($type(events) == 'object'){
+			for (type in events) this.removeEvent(type, events[type]);
+			return this;
+		if (events) events = Events.removeOn(events);
+		for (type in this.$events){
+			if (events && events != type) continue;
+			var fns = this.$events[type];
+			for (var i = fns.length; i--; i) this.removeEvent(type, fns[i]);
+		return this;
+Events.removeOn = function(string){
+	return string.replace(/^on([A-Z])/, function(full, first){
+		return first.toLowerCase();
+var Options = new Class({
+	setOptions: function(){
+		this.options = $merge.run([this.options].extend(arguments));
+		if (!this.addEvent) return this;
+		for (var option in this.options){
+			if ($type(this.options[option]) != 'function' || !(/^on[A-Z]/).test(option)) continue;
+			this.addEvent(option, this.options[option]);
+			delete this.options[option];
+		return this;
+script: Element.js
+description: One of the most important items in MooTools. Contains the dollar function, the dollars function, and an handful of cross-browser, time-saver methods to let you easily work with HTML Elements.
+requires:
+- /Window
+- /Document
+- /Array
+- /String
+- /Function
+- /Number
+- /Hash
+provides: [Element, Elements, $, $$, Iframe]
+var Element = new Native({
+	name: 'Element',
+	legacy: window.Element,
+	initialize: function(tag, props){
+		var konstructor = Element.Constructors.get(tag);
+		if (konstructor) return konstructor(props);
+		if (typeof tag == 'string') return document.newElement(tag, props);
+		return document.id(tag).set(props);
+	afterImplement: function(key, value){
+		Element.Prototype[key] = value;
+		if (Array[key]) return;
+		Elements.implement(key, function(){
+			var items = [], elements = true;
+			for (var i = 0, j = this.length; i < j; i++){
+				var returns = this[i][key].apply(this[i], arguments);
+				items.push(returns);
+				if (elements) elements = ($type(returns) == 'element');
+			return (elements) ? new Elements(items) : items;
+Element.Prototype = {$family: {name: 'element'}};
+Element.Constructors = new Hash;
+var IFrame = new Native({
+	name: 'IFrame',
+	generics: false,
+	initialize: function(){
+		var params = Array.link(arguments, {properties: Object.type, iframe: $defined});
+		var props = params.properties || {};
+		var iframe = document.id(params.iframe);
+		var onload = props.onload || $empty;
+		delete props.onload;
+		props.id = props.name = $pick(props.id, props.name, iframe ? (iframe.id || iframe.name) : 'IFrame_' + $time());
+		iframe = new Element(iframe || 'iframe', props);
+		var onFrameLoad = function(){
+			var host = $try(function(){
+				return iframe.contentWindow.location.host;
+			if (!host || host == window.location.host){
+				var win = new Window(iframe.contentWindow);
+				new Document(iframe.contentWindow.document);
+				$extend(win.Element.prototype, Element.Prototype);
+			onload.call(iframe.contentWindow, iframe.contentWindow.document);
+		var contentWindow = $try(function(){
+			return iframe.contentWindow;
+		((contentWindow && contentWindow.document.body) || window.frames[props.id]) ? onFrameLoad() : iframe.addListener('load', onFrameLoad);
+		return iframe;
+var Elements = new Native({
+	initialize: function(elements, options){
+		options = $extend({ddup: true, cash: true}, options);
+		elements = elements || [];
+		if (options.ddup || options.cash){
+			var uniques = {}, returned = [];
+			for (var i = 0, l = elements.length; i < l; i++){
+				var el = document.id(elements[i], !options.cash);
+				if (options.ddup){
+					if (uniques[el.uid]) continue;
+					uniques[el.uid] = true;
+				if (el) returned.push(el);
+			elements = returned;
+		return (options.cash) ? $extend(elements, this) : elements;
+Elements.implement({
+	filter: function(filter, bind){
+		if (!filter) return this;
+		return new Elements(Array.filter(this, (typeof filter == 'string') ? function(item){
+			return item.match(filter);
+		} : filter, bind));
+Document.implement({
+	newElement: function(tag, props){
+		if (Browser.Engine.trident && props){
+			['name', 'type', 'checked'].each(function(attribute){
+				if (!props[attribute]) return;
+				tag += ' ' + attribute + '="' + props[attribute] + '"';
+				if (attribute != 'checked') delete props[attribute];
+			tag = '<' + tag + '>';
+		return document.id(this.createElement(tag)).set(props);
+	newTextNode: function(text){
+		return this.createTextNode(text);
+	getDocument: function(){
+		return this;
+	getWindow: function(){
+		return this.window;
+	id: (function(){
+		var types = {
+			string: function(id, nocash, doc){
+				id = doc.getElementById(id);
+				return (id) ? types.element(id, nocash) : null;
+			element: function(el, nocash){
+				$uid(el);
+				if (!nocash && !el.$family && !(/^object|embed$/i).test(el.tagName)){
+					var proto = Element.Prototype;
+					for (var p in proto) el[p] = proto[p];
+				return el;
+			object: function(obj, nocash, doc){
+				if (obj.toElement) return types.element(obj.toElement(doc), nocash);
+				return null;
+		types.textnode = types.whitespace = types.window = types.document = $arguments(0);
+		return function(el, nocash, doc){
+			if (el && el.$family && el.uid) return el;
+			var type = $type(el);
+			return (types[type]) ? types[type](el, nocash, doc || document) : null;
+if (window.$ == null) Window.implement({
+	$: function(el, nc){
+		return document.id(el, nc, this.document);
+Window.implement({
+	$$: function(selector){
+		if (arguments.length == 1 && typeof selector == 'string') return this.document.getElements(selector);
+		var elements = [];
+		var args = Array.flatten(arguments);
+		for (var i = 0, l = args.length; i < l; i++){
+			var item = args[i];
+			switch ($type(item)){
+				case 'element': elements.push(item); break;
+				case 'string': elements.extend(this.document.getElements(item, true));
+		return new Elements(elements);
+		return this.document;
+		return this;
+Native.implement([Element, Document], {
+	getElement: function(selector, nocash){
+		return document.id(this.getElements(selector, true)[0] || null, nocash);
+	getElements: function(tags, nocash){
+		tags = tags.split(',');
+		var ddup = (tags.length > 1);
+		tags.each(function(tag){
+			var partial = this.getElementsByTagName(tag.trim());
+			(ddup) ? elements.extend(partial) : elements = partial;
+		}, this);
+		return new Elements(elements, {ddup: ddup, cash: !nocash});
+(function(){
+var collected = {}, storage = {};
+var props = {input: 'checked', option: 'selected', textarea: (Browser.Engine.webkit && Browser.Engine.version < 420) ? 'innerHTML' : 'value'};
+var get = function(uid){
+	return (storage[uid] || (storage[uid] = {}));
+var clean = function(item, retain){
+	if (!item) return;
+	var uid = item.uid;
+	if (retain !== true) retain = false;
+	if (Browser.Engine.trident){
+		if (item.clearAttributes){
+			var clone = retain && item.cloneNode(false);
+			item.clearAttributes();
+			if (clone) item.mergeAttributes(clone);
+		} else if (item.removeEvents){
+			item.removeEvents();
+		if ((/object/i).test(item.tagName)){
+			for (var p in item){
+				if (typeof item[p] == 'function') item[p] = $empty;
+			Element.dispose(item);
+	if (!uid) return;
+	collected[uid] = storage[uid] = null;
+var purge = function(){
+	Hash.each(collected, clean);
+	if (Browser.Engine.trident) $A(document.getElementsByTagName('object')).each(clean);
+	if (window.CollectGarbage) CollectGarbage();
+	collected = storage = null;
+var walk = function(element, walk, start, match, all, nocash){
+	var el = element[start || walk];
+	while (el){
+		if (el.nodeType == 1 && (!match || Element.match(el, match))){
+			if (!all) return document.id(el, nocash);
+			elements.push(el);
+		el = el[walk];
+	return (all) ? new Elements(elements, {ddup: false, cash: !nocash}) : null;
+var attributes = {
+	'html': 'innerHTML',
+	'class': 'className',
+	'for': 'htmlFor',
+	'defaultValue': 'defaultValue',
+	'text': (Browser.Engine.trident || (Browser.Engine.webkit && Browser.Engine.version < 420)) ? 'innerText' : 'textContent'
+var bools = ['compact', 'nowrap', 'ismap', 'declare', 'noshade', 'checked', 'disabled', 'readonly', 'multiple', 'selected', 'noresize', 'defer'];
+var camels = ['value', 'type', 'defaultValue', 'accessKey', 'cellPadding', 'cellSpacing', 'colSpan', 'frameBorder', 'maxLength', 'readOnly', 'rowSpan', 'tabIndex', 'useMap'];
+bools = bools.associate(bools);
+Hash.extend(attributes, bools);
+Hash.extend(attributes, camels.associate(camels.map(String.toLowerCase)));
+var inserters = {
+	before: function(context, element){
+		if (element.parentNode) element.parentNode.insertBefore(context, element);
+	after: function(context, element){
+		if (!element.parentNode) return;
+		var next = element.nextSibling;
+		(next) ? element.parentNode.insertBefore(context, next) : element.parentNode.appendChild(context);
+	bottom: function(context, element){
+		element.appendChild(context);
+	top: function(context, element){
+		var first = element.firstChild;
+		(first) ? element.insertBefore(context, first) : element.appendChild(context);
+inserters.inside = inserters.bottom;
+Hash.each(inserters, function(inserter, where){
+	where = where.capitalize();
+	Element.implement('inject' + where, function(el){
+		inserter(this, document.id(el, true));
+		return this;
+	Element.implement('grab' + where, function(el){
+		inserter(document.id(el, true), this);
+		return this;
+Element.implement({
+	set: function(prop, value){
+		switch ($type(prop)){
+			case 'object':
+				for (var p in prop) this.set(p, prop[p]);
+				break;
+			case 'string':
+				var property = Element.Properties.get(prop);
+				(property && property.set) ? property.set.apply(this, Array.slice(arguments, 1)) : this.setProperty(prop, value);
+		return this;
+	get: function(prop){
+		return (property && property.get) ? property.get.apply(this, Array.slice(arguments, 1)) : this.getProperty(prop);
+	erase: function(prop){
+		(property && property.erase) ? property.erase.apply(this) : this.removeProperty(prop);
+		return this;
+	setProperty: function(attribute, value){
+		var key = attributes[attribute];
+		if (value == undefined) return this.removeProperty(attribute);
+		if (key && bools[attribute]) value = !!value;
+		(key) ? this[key] = value : this.setAttribute(attribute, '' + value);
+		return this;
+	setProperties: function(attributes){
+		for (var attribute in attributes) this.setProperty(attribute, attributes[attribute]);
+		return this;
+	getProperty: function(attribute){
+		var value = (key) ? this[key] : this.getAttribute(attribute, 2);
+		return (bools[attribute]) ? !!value : (key) ? value : value || null;
+	getProperties: function(){
+		var args = $A(arguments);
+		return args.map(this.getProperty, this).associate(args);
+	removeProperty: function(attribute){
+		(key) ? this[key] = (key && bools[attribute]) ? false : '' : this.removeAttribute(attribute);
+		return this;
+	removeProperties: function(){
+		Array.each(arguments, this.removeProperty, this);
+		return this;
+	hasClass: function(className){
+		return this.className.contains(className, ' ');
+	addClass: function(className){
+		if (!this.hasClass(className)) this.className = (this.className + ' ' + className).clean();
+		return this;
+	removeClass: function(className){
+		this.className = this.className.replace(new RegExp('(^|\\s)' + className + '(?:\\s|$)'), '$1');
+		return this;
+	toggleClass: function(className){
+		return this.hasClass(className) ? this.removeClass(className) : this.addClass(className);
+	adopt: function(){
+		Array.flatten(arguments).each(function(element){
+			element = document.id(element, true);
+			if (element) this.appendChild(element);
+		}, this);
+		return this;
+	appendText: function(text, where){
+		return this.grab(this.getDocument().newTextNode(text), where);
+	grab: function(el, where){
+		inserters[where || 'bottom'](document.id(el, true), this);
+		return this;
+	inject: function(el, where){
+		inserters[where || 'bottom'](this, document.id(el, true));
+		return this;
+	replaces: function(el){
+		el = document.id(el, true);
+		el.parentNode.replaceChild(this, el);
+		return this;
+	wraps: function(el, where){
+		return this.replaces(el).grab(el, where);
+	getPrevious: function(match, nocash){
+		return walk(this, 'previousSibling', null, match, false, nocash);
+	getAllPrevious: function(match, nocash){
+		return walk(this, 'previousSibling', null, match, true, nocash);
+	getNext: function(match, nocash){
+		return walk(this, 'nextSibling', null, match, false, nocash);
+	getAllNext: function(match, nocash){
+		return walk(this, 'nextSibling', null, match, true, nocash);
+	getFirst: function(match, nocash){
+		return walk(this, 'nextSibling', 'firstChild', match, false, nocash);
+	getLast: function(match, nocash){
+		return walk(this, 'previousSibling', 'lastChild', match, false, nocash);
+	getParent: function(match, nocash){
+		return walk(this, 'parentNode', null, match, false, nocash);
+	getParents: function(match, nocash){
+		return walk(this, 'parentNode', null, match, true, nocash);
+	getSiblings: function(match, nocash){
+		return this.getParent().getChildren(match, nocash).erase(this);
+	getChildren: function(match, nocash){
+		return walk(this, 'nextSibling', 'firstChild', match, true, nocash);
+		return this.ownerDocument.window;
+		return this.ownerDocument;
+	getElementById: function(id, nocash){
+		var el = this.ownerDocument.getElementById(id);
+		if (!el) return null;
+		for (var parent = el.parentNode; parent != this; parent = parent.parentNode){
+			if (!parent) return null;
+		return document.id(el, nocash);
+	getSelected: function(){
+		return new Elements($A(this.options).filter(function(option){
+			return option.selected;
+	getComputedStyle: function(property){
+		if (this.currentStyle) return this.currentStyle[property.camelCase()];
+		var computed = this.getDocument().defaultView.getComputedStyle(this, null);
+		return (computed) ? computed.getPropertyValue([property.hyphenate()]) : null;
+	toQueryString: function(){
+		this.getElements('input, select, textarea', true).each(function(el){
+			if (!el.name || el.disabled || el.type == 'submit' || el.type == 'reset' || el.type == 'file') return;
+			var value = (el.tagName.toLowerCase() == 'select') ? Element.getSelected(el).map(function(opt){
+				return opt.value;
+			}) : ((el.type == 'radio' || el.type == 'checkbox') && !el.checked) ? null : el.value;
+			$splat(value).each(function(val){
+				if (typeof val != 'undefined') queryString.push(el.name + '=' + encodeURIComponent(val));
+	clone: function(contents, keepid){
+		contents = contents !== false;
+		var clone = this.cloneNode(contents);
+		var clean = function(node, element){
+			if (!keepid) node.removeAttribute('id');
+				node.clearAttributes();
+				node.mergeAttributes(element);
+				node.removeAttribute('uid');
+				if (node.options){
+					var no = node.options, eo = element.options;
+					for (var j = no.length; j--;) no[j].selected = eo[j].selected;
+			var prop = props[element.tagName.toLowerCase()];
+			if (prop && element[prop]) node[prop] = element[prop];
+		if (contents){
+			var ce = clone.getElementsByTagName('*'), te = this.getElementsByTagName('*');
+			for (var i = ce.length; i--;) clean(ce[i], te[i]);
+		clean(clone, this);
+		return document.id(clone);
+	destroy: function(){
+		Element.empty(this);
+		Element.dispose(this);
+		clean(this, true);
+		return null;
+		$A(this.childNodes).each(function(node){
+			Element.destroy(node);
+		return this;
+	dispose: function(){
+		return (this.parentNode) ? this.parentNode.removeChild(this) : this;
+	hasChild: function(el){
+		if (!el) return false;
+		if (Browser.Engine.webkit && Browser.Engine.version < 420) return $A(this.getElementsByTagName(el.tagName)).contains(el);
+		return (this.contains) ? (this != el && this.contains(el)) : !!(this.compareDocumentPosition(el) & 16);
+	match: function(tag){
+		return (!tag || (tag == this) || (Element.get(this, 'tag') == tag));
+Native.implement([Element, Window, Document], {
+	addListener: function(type, fn){
+		if (type == 'unload'){
+			var old = fn, self = this;
+			fn = function(){
+				self.removeListener('unload', fn);
+				old();
+		} else {
+			collected[this.uid] = this;
+		if (this.addEventListener) this.addEventListener(type, fn, false);
+		else this.attachEvent('on' + type, fn);
+		return this;
+	removeListener: function(type, fn){
+		if (this.removeEventListener) this.removeEventListener(type, fn, false);
+		else this.detachEvent('on' + type, fn);
+		return this;
+	retrieve: function(property, dflt){
+		var storage = get(this.uid), prop = storage[property];
+		if (dflt != undefined && prop == undefined) prop = storage[property] = dflt;
+		return $pick(prop);
+	store: function(property, value){
+		var storage = get(this.uid);
+		storage[property] = value;
+		return this;
+	eliminate: function(property){
+		delete storage[property];
+		return this;
+window.addListener('unload', purge);
+Element.Properties = new Hash;
+Element.Properties.style = {
+	set: function(style){
+		this.style.cssText = style;
+	get: function(){
+		return this.style.cssText;
+	erase: function(){
+		this.style.cssText = '';
+Element.Properties.tag = {
+	get: function(){
+		return this.tagName.toLowerCase();
+Element.Properties.html = (function(){
+	var wrapper = document.createElement('div');
+	var translations = {
+		table: [1, '<table>', '</table>'],
+		select: [1, '<select>', '</select>'],
+		tbody: [2, '<table><tbody>', '</tbody></table>'],
+		tr: [3, '<table><tbody><tr>', '</tr></tbody></table>']
+	translations.thead = translations.tfoot = translations.tbody;
+	var html = {
+		set: function(){
+			var html = Array.flatten(arguments).join('');
+			var wrap = Browser.Engine.trident && translations[this.get('tag')];
+			if (wrap){
+				var first = wrapper;
+				first.innerHTML = wrap[1] + html + wrap[2];
+				for (var i = wrap[0]; i--;) first = first.firstChild;
+				this.empty().adopt(first.childNodes);
+			} else {
+				this.innerHTML = html;
+	html.erase = html.set;
+	return html;
+if (Browser.Engine.webkit && Browser.Engine.version < 420) Element.Properties.text = {
+	get: function(){
+		if (this.innerText) return this.innerText;
+		var temp = this.ownerDocument.newElement('div', {html: this.innerHTML}).inject(this.ownerDocument.body);
+		var text = temp.innerText;
+		temp.destroy();
+		return text;
+script: Element.Event.js
+description: Contains Element methods for dealing with events. This file also includes mouseenter and mouseleave custom Element Events.
+requires:
+- /Element
+- /Event
+provides: [Element.Event]
+Element.Properties.events = {set: function(events){
+	this.addEvents(events);
+	addEvent: function(type, fn){
+		var events = this.retrieve('events', {});
+		events[type] = events[type] || {'keys': [], 'values': []};
+		if (events[type].keys.contains(fn)) return this;
+		events[type].keys.push(fn);
+		var realType = type, custom = Element.Events.get(type), condition = fn, self = this;
+		if (custom){
+			if (custom.onAdd) custom.onAdd.call(this, fn);
+			if (custom.condition){
+				condition = function(event){
+					if (custom.condition.call(this, event)) return fn.call(this, event);
+					return true;
+			realType = custom.base || realType;
+		var defn = function(){
+			return fn.call(self);
+		var nativeEvent = Element.NativeEvents[realType];
+		if (nativeEvent){
+			if (nativeEvent == 2){
+				defn = function(event){
+					event = new Event(event, self.getWindow());
+					if (condition.call(self, event) === false) event.stop();
+			this.addListener(realType, defn);
+		events[type].values.push(defn);
+		return this;
+		var events = this.retrieve('events');
+		if (!events || !events[type]) return this;
+		var pos = events[type].keys.indexOf(fn);
+		if (pos == -1) return this;
+		events[type].keys.splice(pos, 1);
+		var value = events[type].values.splice(pos, 1)[0];
+		var custom = Element.Events.get(type);
+		if (custom){
+			if (custom.onRemove) custom.onRemove.call(this, fn);
+			type = custom.base || type;
+		return (Element.NativeEvents[type]) ? this.removeListener(type, value) : this;
+		for (var event in events) this.addEvent(event, events[event]);
+		return this;
+		var type;
+			return this;
+		var attached = this.retrieve('events');
+		if (!attached) return this;
+		if (!events){
+			for (type in attached) this.removeEvents(type);
+			this.eliminate('events');
+		} else if (attached[events]){
+			while (attached[events].keys[0]) this.removeEvent(events, attached[events].keys[0]);
+			attached[events] = null;
+		return this;
+		events[type].keys.each(function(fn){
+		}, this);
+		return this;
+	cloneEvents: function(from, type){
+		from = document.id(from);
+		var fevents = from.retrieve('events');
+		if (!fevents) return this;
+		if (!type){
+			for (var evType in fevents) this.cloneEvents(from, evType);
+		} else if (fevents[type]){
+			fevents[type].keys.each(function(fn){
+				this.addEvent(type, fn);
+			}, this);
+		return this;
+Element.NativeEvents = {
+	click: 2, dblclick: 2, mouseup: 2, mousedown: 2, contextmenu: 2, //mouse buttons
+	mousewheel: 2, DOMMouseScroll: 2, //mouse wheel
+	mouseover: 2, mouseout: 2, mousemove: 2, selectstart: 2, selectend: 2, //mouse movement
+	keydown: 2, keypress: 2, keyup: 2, //keyboard
+	focus: 2, blur: 2, change: 2, reset: 2, select: 2, submit: 2, //form elements
+	load: 1, unload: 1, beforeunload: 2, resize: 1, move: 1, DOMContentLoaded: 1, readystatechange: 1, //window
+	error: 1, abort: 1, scroll: 1 //misc
+(function(){
+var $check = function(event){
+	var related = event.relatedTarget;
+	if (related == undefined) return true;
+	if (related === false) return false;
+	return ($type(this) != 'document' && related != this && related.prefix != 'xul' && !this.hasChild(related));
+Element.Events = new Hash({
+	mouseenter: {
+		base: 'mouseover',
+		condition: $check
+	mouseleave: {
+		base: 'mouseout',
+		condition: $check
+	mousewheel: {
+		base: (Browser.Engine.gecko) ? 'DOMMouseScroll' : 'mousewheel'
+script: Element.Style.js
+description: Contains methods for interacting with the styles of Elements in a fashionable way.
+requires:
+- /Element
+provides: [Element.Style]
+Element.Properties.styles = {set: function(styles){
+	this.setStyles(styles);
+Element.Properties.opacity = {
+	set: function(opacity, novisibility){
+		if (!novisibility){
+			if (opacity == 0){
+				if (this.style.visibility != 'hidden') this.style.visibility = 'hidden';
+			} else {
+				if (this.style.visibility != 'visible') this.style.visibility = 'visible';
+		if (!this.currentStyle || !this.currentStyle.hasLayout) this.style.zoom = 1;
+		if (Browser.Engine.trident) this.style.filter = (opacity == 1) ? '' : 'alpha(opacity=' + opacity * 100 + ')';
+		this.style.opacity = opacity;
+		this.store('opacity', opacity);
+	get: function(){
+		return this.retrieve('opacity', 1);
+	setOpacity: function(value){
+		return this.set('opacity', value, true);
+	getOpacity: function(){
+		return this.get('opacity');
+	setStyle: function(property, value){
+		switch (property){
+			case 'opacity': return this.set('opacity', parseFloat(value));
+			case 'float': property = (Browser.Engine.trident) ? 'styleFloat' : 'cssFloat';
+		property = property.camelCase();
+		if ($type(value) != 'string'){
+			var map = (Element.Styles.get(property) || '@').split(' ');
+			value = $splat(value).map(function(val, i){
+				if (!map[i]) return '';
+				return ($type(val) == 'number') ? map[i].replace('@', Math.round(val)) : val;
+			}).join(' ');
+		} else if (value == String(Number(value))){
+			value = Math.round(value);
+		this.style[property] = value;
+		return this;
+	getStyle: function(property){
+			case 'opacity': return this.get('opacity');
+		var result = this.style[property];
+		if (!$chk(result)){
+			result = [];
+			for (var style in Element.ShortStyles){
+				if (property != style) continue;
+				for (var s in Element.ShortStyles[style]) result.push(this.getStyle(s));
+				return result.join(' ');
+			result = this.getComputedStyle(property);
+		if (result){
+			result = String(result);
+			var color = result.match(/rgba?\([\d\s,]+\)/);
+			if (color) result = result.replace(color[0], color[0].rgbToHex());
+		if (Browser.Engine.presto || (Browser.Engine.trident && !$chk(parseInt(result, 10)))){
+			if (property.test(/^(height|width)$/)){
+				var values = (property == 'width') ? ['left', 'right'] : ['top', 'bottom'], size = 0;
+				values.each(function(value){
+					size += this.getStyle('border-' + value + '-width').toInt() + this.getStyle('padding-' + value).toInt();
+				}, this);
+				return this['offset' + property.capitalize()] - size + 'px';
+			if ((Browser.Engine.presto) && String(result).test('px')) return result;
+			if (property.test(/(border(.+)Width|margin|padding)/)) return '0px';
+		return result;
+	setStyles: function(styles){
+		for (var style in styles) this.setStyle(style, styles[style]);
+		return this;
+	getStyles: function(){
+		var result = {};
+		Array.flatten(arguments).each(function(key){
+			result[key] = this.getStyle(key);
+		}, this);
+		return result;
+Element.Styles = new Hash({
+	left: '@px', top: '@px', bottom: '@px', right: '@px',
+	width: '@px', height: '@px', maxWidth: '@px', maxHeight: '@px', minWidth: '@px', minHeight: '@px',
+	backgroundColor: 'rgb(@, @, @)', backgroundPosition: '@px @px', color: 'rgb(@, @, @)',
+	fontSize: '@px', letterSpacing: '@px', lineHeight: '@px', clip: 'rect(@px @px @px @px)',
+	margin: '@px @px @px @px', padding: '@px @px @px @px', border: '@px @ rgb(@, @, @) @px @ rgb(@, @, @) @px @ rgb(@, @, @)',
+	borderWidth: '@px @px @px @px', borderStyle: '@ @ @ @', borderColor: 'rgb(@, @, @) rgb(@, @, @) rgb(@, @, @) rgb(@, @, @)',
+	zIndex: '@', 'zoom': '@', fontWeight: '@', textIndent: '@px', opacity: '@'
+Element.ShortStyles = {margin: {}, padding: {}, border: {}, borderWidth: {}, borderStyle: {}, borderColor: {}};
+['Top', 'Right', 'Bottom', 'Left'].each(function(direction){
+	var Short = Element.ShortStyles;
+	var All = Element.Styles;
+	['margin', 'padding'].each(function(style){
+		var sd = style + direction;
+		Short[style][sd] = All[sd] = '@px';
+	var bd = 'border' + direction;
+	Short.border[bd] = All[bd] = '@px @ rgb(@, @, @)';
+	var bdw = bd + 'Width', bds = bd + 'Style', bdc = bd + 'Color';
+	Short[bd] = {};
+	Short.borderWidth[bdw] = Short[bd][bdw] = All[bdw] = '@px';
+	Short.borderStyle[bds] = Short[bd][bds] = All[bds] = '@';
+	Short.borderColor[bdc] = Short[bd][bdc] = All[bdc] = 'rgb(@, @, @)';
+script: Element.Dimensions.js
+description: Contains methods to work with size, scroll, or positioning of Elements and the window object.
+credits:
+- Element positioning based on the [qooxdoo](http://qooxdoo.org/) code and smart browser fixes, [LGPL License](http://www.gnu.org/licenses/lgpl.html).
+- Viewport dimensions based on [YUI](http://developer.yahoo.com/yui/) code, [BSD License](http://developer.yahoo.com/yui/license.html).
+requires:
+- /Element
+provides: [Element.Dimensions]
+(function(){
+	scrollTo: function(x, y){
+		if (isBody(this)){
+			this.getWindow().scrollTo(x, y);
+		} else {
+			this.scrollLeft = x;
+			this.scrollTop = y;
+		return this;
+	getSize: function(){
+		if (isBody(this)) return this.getWindow().getSize();
+		return {x: this.offsetWidth, y: this.offsetHeight};
+	getScrollSize: function(){
+		if (isBody(this)) return this.getWindow().getScrollSize();
+		return {x: this.scrollWidth, y: this.scrollHeight};
+	getScroll: function(){
+		if (isBody(this)) return this.getWindow().getScroll();
+		return {x: this.scrollLeft, y: this.scrollTop};
+	getScrolls: function(){
+		var element = this, position = {x: 0, y: 0};
+		while (element && !isBody(element)){
+			position.x += element.scrollLeft;
+			position.y += element.scrollTop;
+			element = element.parentNode;
+		return position;
+	getOffsetParent: function(){
+		var element = this;
+		if (isBody(element)) return null;
+		if (!Browser.Engine.trident) return element.offsetParent;
+		while ((element = element.parentNode) && !isBody(element)){
+			if (styleString(element, 'position') != 'static') return element;
+		return null;
+	getOffsets: function(){
+		if (this.getBoundingClientRect){
+			var bound = this.getBoundingClientRect(),
+				html = document.id(this.getDocument().documentElement),
+				htmlScroll = html.getScroll(),
+				elemScrolls = this.getScrolls(),
+				elemScroll = this.getScroll(),
+				isFixed = (styleString(this, 'position') == 'fixed');
+			return {
+				x: bound.left.toInt() + elemScrolls.x - elemScroll.x + ((isFixed) ? 0 : htmlScroll.x) - html.clientLeft,
+				y: bound.top.toInt()  + elemScrolls.y - elemScroll.y + ((isFixed) ? 0 : htmlScroll.y) - html.clientTop
+		if (isBody(this)) return position;
+			position.x += element.offsetLeft;
+			position.y += element.offsetTop;
+			if (Browser.Engine.gecko){
+				if (!borderBox(element)){
+					position.x += leftBorder(element);
+					position.y += topBorder(element);
+				var parent = element.parentNode;
+				if (parent && styleString(parent, 'overflow') != 'visible'){
+					position.x += leftBorder(parent);
+					position.y += topBorder(parent);
+			} else if (element != this && Browser.Engine.webkit){
+			element = element.offsetParent;
+		if (Browser.Engine.gecko && !borderBox(this)){
+			position.x -= leftBorder(this);
+			position.y -= topBorder(this);
+		return position;
+	getPosition: function(relative){
+		if (isBody(this)) return {x: 0, y: 0};
+		var offset = this.getOffsets(),
+				scroll = this.getScrolls();
+		var position = {
+			x: offset.x - scroll.x,
+			y: offset.y - scroll.y
+		var relativePosition = (relative && (relative = document.id(relative))) ? relative.getPosition() : {x: 0, y: 0};
+		return {x: position.x - relativePosition.x, y: position.y - relativePosition.y};
+	getCoordinates: function(element){
+		if (isBody(this)) return this.getWindow().getCoordinates();
+		var position = this.getPosition(element),
+				size = this.getSize();
+		var obj = {
+			left: position.x,
+			top: position.y,
+			width: size.x,
+			height: size.y
+		obj.right = obj.left + obj.width;
+		obj.bottom = obj.top + obj.height;
+		return obj;
+	computePosition: function(obj){
+		return {
+			left: obj.x - styleNumber(this, 'margin-left'),
+			top: obj.y - styleNumber(this, 'margin-top')
+	setPosition: function(obj){
+		return this.setStyles(this.computePosition(obj));
+Native.implement([Document, Window], {
+		if (Browser.Engine.presto || Browser.Engine.webkit){
+			var win = this.getWindow();
+			return {x: win.innerWidth, y: win.innerHeight};
+		var doc = getCompatElement(this);
+		return {x: doc.clientWidth, y: doc.clientHeight};
+		var win = this.getWindow(), doc = getCompatElement(this);
+		return {x: win.pageXOffset || doc.scrollLeft, y: win.pageYOffset || doc.scrollTop};
+		var doc = getCompatElement(this), min = this.getSize();
+		return {x: Math.max(doc.scrollWidth, min.x), y: Math.max(doc.scrollHeight, min.y)};
+	getPosition: function(){
+		return {x: 0, y: 0};
+	getCoordinates: function(){
+		var size = this.getSize();
+		return {top: 0, left: 0, bottom: size.y, right: size.x, height: size.y, width: size.x};
+// private methods
+var styleString = Element.getComputedStyle;
+function styleNumber(element, style){
+	return styleString(element, style).toInt() || 0;
+function borderBox(element){
+	return styleString(element, '-moz-box-sizing') == 'border-box';
+function topBorder(element){
+	return styleNumber(element, 'border-top-width');
+function leftBorder(element){
+	return styleNumber(element, 'border-left-width');
+function isBody(element){
+	return (/^(?:body|html)$/i).test(element.tagName);
+function getCompatElement(element){
+	var doc = element.getDocument();
+	return (!doc.compatMode || doc.compatMode == 'CSS1Compat') ? doc.html : doc.body;
+//aliases
+Element.alias('setPosition', 'position'); //compatability
+Native.implement([Window, Document, Element], {
+	getHeight: function(){
+		return this.getSize().y;
+	getWidth: function(){
+		return this.getSize().x;
+	getScrollTop: function(){
+		return this.getScroll().y;
+	getScrollLeft: function(){
+		return this.getScroll().x;
+	getScrollHeight: function(){
+		return this.getScrollSize().y;
+	getScrollWidth: function(){
+		return this.getScrollSize().x;
+	getTop: function(){
+		return this.getPosition().y;
+	getLeft: function(){
+		return this.getPosition().x;
+script: Selectors.js
+description: Adds advanced CSS-style querying capabilities for targeting HTML Elements. Includes pseudo selectors.
+requires:
+- /Element
+provides: [Selectors]
+Native.implement([Document, Element], {
+	getElements: function(expression, nocash){
+		expression = expression.split(',');
+		var items, local = {};
+		for (var i = 0, l = expression.length; i < l; i++){
+			var selector = expression[i], elements = Selectors.Utils.search(this, selector, local);
+			if (i != 0 && elements.item) elements = $A(elements);
+			items = (i == 0) ? elements : (items.item) ? $A(items).concat(elements) : items.concat(elements);
+		return new Elements(items, {ddup: (expression.length > 1), cash: !nocash});
+	match: function(selector){
+		if (!selector || (selector == this)) return true;
+		var tagid = Selectors.Utils.parseTagAndID(selector);
+		var tag = tagid[0], id = tagid[1];
+		if (!Selectors.Filters.byID(this, id) || !Selectors.Filters.byTag(this, tag)) return false;
+		var parsed = Selectors.Utils.parseSelector(selector);
+		return (parsed) ? Selectors.Utils.filter(this, parsed, {}) : true;
+var Selectors = {Cache: {nth: {}, parsed: {}}};
+Selectors.RegExps = {
+	id: (/#([\w-]+)/),
+	tag: (/^(\w+|\*)/),
+	quick: (/^(\w+|\*)$/),
+	splitter: (/\s*([+>~\s])\s*([a-zA-Z#.*:\[])/g),
+	combined: (/\.([\w-]+)|\[(\w+)(?:([!*^$~|]?=)(["']?)([^\4]*?)\4)?\]|:([\w-]+)(?:\(["']?(.*?)?["']?\)|$)/g)
+Selectors.Utils = {
+	chk: function(item, uniques){
+		if (!uniques) return true;
+		var uid = $uid(item);
+		if (!uniques[uid]) return uniques[uid] = true;
+		return false;
+	parseNthArgument: function(argument){
+		if (Selectors.Cache.nth[argument]) return Selectors.Cache.nth[argument];
+		var parsed = argument.match(/^([+-]?\d*)?([a-z]+)?([+-]?\d*)?$/);
+		if (!parsed) return false;
+		var inta = parseInt(parsed[1], 10);
+		var a = (inta || inta === 0) ? inta : 1;
+		var special = parsed[2] || false;
+		var b = parseInt(parsed[3], 10) || 0;
+		if (a != 0){
+			b--;
+			while (b < 1) b += a;
+			while (b >= a) b -= a;
+		} else {
+			a = b;
+			special = 'index';
+		switch (special){
+			case 'n': parsed = {a: a, b: b, special: 'n'}; break;
+			case 'odd': parsed = {a: 2, b: 0, special: 'n'}; break;
+			case 'even': parsed = {a: 2, b: 1, special: 'n'}; break;
+			case 'first': parsed = {a: 0, special: 'index'}; break;
+			case 'last': parsed = {special: 'last-child'}; break;
+			case 'only': parsed = {special: 'only-child'}; break;
+			default: parsed = {a: (a - 1), special: 'index'};
+		return Selectors.Cache.nth[argument] = parsed;
+	parseSelector: function(selector){
+		if (Selectors.Cache.parsed[selector]) return Selectors.Cache.parsed[selector];
+		var m, parsed = {classes: [], pseudos: [], attributes: []};
+		while ((m = Selectors.RegExps.combined.exec(selector))){
+			var cn = m[1], an = m[2], ao = m[3], av = m[5], pn = m[6], pa = m[7];
+			if (cn){
+				parsed.classes.push(cn);
+			} else if (pn){
+				var parser = Selectors.Pseudo.get(pn);
+				if (parser) parsed.pseudos.push({parser: parser, argument: pa});
+				else parsed.attributes.push({name: pn, operator: '=', value: pa});
+			} else if (an){
+				parsed.attributes.push({name: an, operator: ao, value: av});
+		if (!parsed.classes.length) delete parsed.classes;
+		if (!parsed.attributes.length) delete parsed.attributes;
+		if (!parsed.pseudos.length) delete parsed.pseudos;
+		if (!parsed.classes && !parsed.attributes && !parsed.pseudos) parsed = null;
+		return Selectors.Cache.parsed[selector] = parsed;
+	parseTagAndID: function(selector){
+		var tag = selector.match(Selectors.RegExps.tag);
+		var id = selector.match(Selectors.RegExps.id);
+		return [(tag) ? tag[1] : '*', (id) ? id[1] : false];
+	filter: function(item, parsed, local){
+		var i;
+		if (parsed.classes){
+			for (i = parsed.classes.length; i--; i){
+				var cn = parsed.classes[i];
+				if (!Selectors.Filters.byClass(item, cn)) return false;
+		if (parsed.attributes){
+			for (i = parsed.attributes.length; i--; i){
+				var att = parsed.attributes[i];
+				if (!Selectors.Filters.byAttribute(item, att.name, att.operator, att.value)) return false;
+		if (parsed.pseudos){
+			for (i = parsed.pseudos.length; i--; i){
+				var psd = parsed.pseudos[i];
+				if (!Selectors.Filters.byPseudo(item, psd.parser, psd.argument, local)) return false;
+		return true;
+	getByTagAndID: function(ctx, tag, id){
+		if (id){
+			var item = (ctx.getElementById) ? ctx.getElementById(id, true) : Element.getElementById(ctx, id, true);
+			return (item && Selectors.Filters.byTag(item, tag)) ? [item] : [];
+		} else {
+			return ctx.getElementsByTagName(tag);
+	search: function(self, expression, local){
+		var splitters = [];
+		var selectors = expression.trim().replace(Selectors.RegExps.splitter, function(m0, m1, m2){
+			splitters.push(m1);
+			return ':)' + m2;
+		}).split(':)');
+		var items, filtered, item;
+		for (var i = 0, l = selectors.length; i < l; i++){
+			var selector = selectors[i];
+			if (i == 0 && Selectors.RegExps.quick.test(selector)){
+				items = self.getElementsByTagName(selector);
+				continue;
+			var splitter = splitters[i - 1];
+			if (i == 0){
+				items = Selectors.Utils.getByTagAndID(self, tag, id);
+			} else {
+				var uniques = {}, found = [];
+				for (var j = 0, k = items.length; j < k; j++) found = Selectors.Getters[splitter](found, items[j], tag, id, uniques);
+				items = found;
+			if (parsed){
+				filtered = [];
+				for (var m = 0, n = items.length; m < n; m++){
+					item = items[m];
+					if (Selectors.Utils.filter(item, parsed, local)) filtered.push(item);
+				items = filtered;
+		return items;
+Selectors.Getters = {
+	' ': function(found, self, tag, id, uniques){
+		var items = Selectors.Utils.getByTagAndID(self, tag, id);
+		for (var i = 0, l = items.length; i < l; i++){
+			var item = items[i];
+			if (Selectors.Utils.chk(item, uniques)) found.push(item);
+		return found;
+	'>': function(found, self, tag, id, uniques){
+		var children = Selectors.Utils.getByTagAndID(self, tag, id);
+		for (var i = 0, l = children.length; i < l; i++){
+			var child = children[i];
+			if (child.parentNode == self && Selectors.Utils.chk(child, uniques)) found.push(child);
+		return found;
+	'+': function(found, self, tag, id, uniques){
+		while ((self = self.nextSibling)){
+			if (self.nodeType == 1){
+				if (Selectors.Utils.chk(self, uniques) && Selectors.Filters.byTag(self, tag) && Selectors.Filters.byID(self, id)) found.push(self);
+				break;
+		return found;
+	'~': function(found, self, tag, id, uniques){
+				if (!Selectors.Utils.chk(self, uniques)) break;
+				if (Selectors.Filters.byTag(self, tag) && Selectors.Filters.byID(self, id)) found.push(self);
+		return found;
+Selectors.Filters = {
+	byTag: function(self, tag){
+		return (tag == '*' || (self.tagName && self.tagName.toLowerCase() == tag));
+	byID: function(self, id){
+		return (!id || (self.id && self.id == id));
+	byClass: function(self, klass){
+		return (self.className && self.className.contains && self.className.contains(klass, ' '));
+	byPseudo: function(self, parser, argument, local){
+		return parser.call(self, argument, local);
+	byAttribute: function(self, name, operator, value){
+		var result = Element.prototype.getProperty.call(self, name);
+		if (!result) return (operator == '!=');
+		if (!operator || value == undefined) return true;
+		switch (operator){
+			case '=': return (result == value);
+			case '*=': return (result.contains(value));
+			case '^=': return (result.substr(0, value.length) == value);
+			case '$=': return (result.substr(result.length - value.length) == value);
+			case '!=': return (result != value);
+			case '~=': return result.contains(value, ' ');
+			case '|=': return result.contains(value, '-');
+		return false;
+Selectors.Pseudo = new Hash({
+	// w3c pseudo selectors
+	checked: function(){
+		return this.checked;
+		return !(this.innerText || this.textContent || '').length;
+	not: function(selector){
+		return !Element.match(this, selector);
+	contains: function(text){
+		return (this.innerText || this.textContent || '').contains(text);
+	'first-child': function(){
+		return Selectors.Pseudo.index.call(this, 0);
+	'last-child': function(){
+		while ((element = element.nextSibling)){
+			if (element.nodeType == 1) return false;
+		return true;
+	'only-child': function(){
+		var prev = this;
+		while ((prev = prev.previousSibling)){
+			if (prev.nodeType == 1) return false;
+		var next = this;
+		while ((next = next.nextSibling)){
+			if (next.nodeType == 1) return false;
+		return true;
+	'nth-child': function(argument, local){
+		argument = (argument == undefined) ? 'n' : argument;
+		var parsed = Selectors.Utils.parseNthArgument(argument);
+		if (parsed.special != 'n') return Selectors.Pseudo[parsed.special].call(this, parsed.a, local);
+		var count = 0;
+		local.positions = local.positions || {};
+		var uid = $uid(this);
+		if (!local.positions[uid]){
+			var self = this;
+			while ((self = self.previousSibling)){
+				if (self.nodeType != 1) continue;
+				count ++;
+				var position = local.positions[$uid(self)];
+				if (position != undefined){
+					count = position + count;
+					break;
+			local.positions[uid] = count;
+		return (local.positions[uid] % parsed.a == parsed.b);
+	// custom pseudo selectors
+	index: function(index){
+		var element = this, count = 0;
+		while ((element = element.previousSibling)){
+			if (element.nodeType == 1 && ++count > index) return false;
+		return (count == index);
+	even: function(argument, local){
+		return Selectors.Pseudo['nth-child'].call(this, '2n+1', local);
+	odd: function(argument, local){
+		return Selectors.Pseudo['nth-child'].call(this, '2n', local);
+	selected: function(){
+		return this.selected;
+	enabled: function(){
+		return (this.disabled === false);
+script: DomReady.js
+description: Contains the custom event domready.
+license: MIT-style license.
+requires:
+- /Element.Event
+provides: [DomReady]
+Element.Events.domready = {
+	onAdd: function(fn){
+		if (Browser.loaded) fn.call(this);
+(function(){
+	var domready = function(){
+		if (Browser.loaded) return;
+		Browser.loaded = true;
+		window.fireEvent('domready');
+		document.fireEvent('domready');
+	window.addEvent('load', domready);
+		var temp = document.createElement('div');
+		(function(){
+			($try(function(){
+				temp.doScroll(); // Technique by Diego Perini
+				return document.id(temp).inject(document.body).set('html', 'temp').dispose();
+			})) ? domready() : arguments.callee.delay(50);
+	} else if (Browser.Engine.webkit && Browser.Engine.version < 525){
+		(function(){
+			(['loaded', 'complete'].contains(document.readyState)) ? domready() : arguments.callee.delay(50);
+	} else {
+		document.addEvent('DOMContentLoaded', domready);
+script: JSON.js
+description: JSON encoder and decoder.
+See Also: <http://www.json.org/>
+requires:
+- /Array
+- /String
+- /Number
+- /Function
+- /Hash
+provides: [JSON]
+var JSON = new Hash(this.JSON && {
+	stringify: JSON.stringify,
+	parse: JSON.parse
+}).extend({
+	$specialChars: {'\b': '\\b', '\t': '\\t', '\n': '\\n', '\f': '\\f', '\r': '\\r', '"' : '\\"', '\\': '\\\\'},
+	$replaceChars: function(chr){
+		return JSON.$specialChars[chr] || '\\u00' + Math.floor(chr.charCodeAt() / 16).toString(16) + (chr.charCodeAt() % 16).toString(16);
+	encode: function(obj){
+		switch ($type(obj)){
+			case 'string':
+				return '"' + obj.replace(/[\x00-\x1f\\"]/g, JSON.$replaceChars) + '"';
+			case 'array':
+				return '[' + String(obj.map(JSON.encode).clean()) + ']';
+			case 'object': case 'hash':
+				var string = [];
+				Hash.each(obj, function(value, key){
+					var json = JSON.encode(value);
+					if (json) string.push(JSON.encode(key) + ':' + json);
+				return '{' + string + '}';
+			case 'number': case 'boolean': return String(obj);
+			case false: return 'null';
+		return null;
+	decode: function(string, secure){
+		if ($type(string) != 'string' || !string.length) return null;
+		if (secure && !(/^[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t]*$/).test(string.replace(/\\./g, '@').replace(/"[^"\\\n\r]*"/g, ''))) return null;
+		return eval('(' + string + ')');
+Native.implement([Hash, Array, String, Number], {
+	toJSON: function(){
+		return JSON.encode(this);
+script: Cookie.js
+description: Class for creating, reading, and deleting browser Cookies.
+credits:
+- Based on the functions by Peter-Paul Koch (http://quirksmode.org).
+requires:
+- /Options
+provides: [Cookie]
+var Cookie = new Class({
+	Implements: Options,
+	options: {
+		path: false,
+		domain: false,
+		duration: false,
+		secure: false,
+		document: document
+	initialize: function(key, options){
+		this.key = key;
+		this.setOptions(options);
+	write: function(value){
+		value = encodeURIComponent(value);
+		if (this.options.domain) value += '; domain=' + this.options.domain;
+		if (this.options.path) value += '; path=' + this.options.path;
+		if (this.options.duration){
+			var date = new Date();
+			date.setTime(date.getTime() + this.options.duration * 24 * 60 * 60 * 1000);
+			value += '; expires=' + date.toGMTString();
+		if (this.options.secure) value += '; secure';
+		this.options.document.cookie = this.key + '=' + value;
+		return this;
+	read: function(){
+		var value = this.options.document.cookie.match('(?:^|;)\\s*' + this.key.escapeRegExp() + '=([^;]*)');
+		return (value) ? decodeURIComponent(value[1]) : null;
+		new Cookie(this.key, $merge(this.options, {duration: -1})).write('');
+		return this;
+Cookie.write = function(key, value, options){
+	return new Cookie(key, options).write(value);
+Cookie.read = function(key){
+	return new Cookie(key).read();
+Cookie.dispose = function(key, options){
+	return new Cookie(key, options).dispose();
+script: Swiff.js
+description: Wrapper for embedding SWF movies. Supports External Interface Communication.
+credits:
+- Flash detection & Internet Explorer + Flash Player 9 fix inspired by SWFObject.
+requires:
+- /Options
+- /$util
+provides: [Swiff]
+var Swiff = new Class({
+	Implements: [Options],
+	options: {
+		id: null,
+		height: 1,
+		width: 1,
+		container: null,
+		properties: {},
+		params: {
+			quality: 'high',
+			allowScriptAccess: 'always',
+			wMode: 'transparent',
+			swLiveConnect: true
+		callBacks: {},
+		vars: {}
+	toElement: function(){
+		return this.object;
+	initialize: function(path, options){
+		this.instance = 'Swiff_' + $time();
+		options = this.options;
+		var id = this.id = options.id || this.instance;
+		var container = document.id(options.container);
+		Swiff.CallBacks[this.instance] = {};
+		var params = options.params, vars = options.vars, callBacks = options.callBacks;
+		var properties = $extend({height: options.height, width: options.width}, options.properties);
+		var self = this;
+		for (var callBack in callBacks){
+			Swiff.CallBacks[this.instance][callBack] = (function(option){
+				return function(){
+					return option.apply(self.object, arguments);
+			})(callBacks[callBack]);
+			vars[callBack] = 'Swiff.CallBacks.' + this.instance + '.' + callBack;
+		params.flashVars = Hash.toQueryString(vars);
+			properties.classid = 'clsid:D27CDB6E-AE6D-11cf-96B8-444553540000';
+			params.movie = path;
+		} else {
+			properties.type = 'application/x-shockwave-flash';
+			properties.data = path;
+		var build = '<object id="' + id + '"';
+		for (var property in properties) build += ' ' + property + '="' + properties[property] + '"';
+		build += '>';
+		for (var param in params){
+			if (params[param]) build += '<param name="' + param + '" value="' + params[param] + '" />';
+		build += '</object>';
+		this.object = ((container) ? container.empty() : new Element('div')).set('html', build).firstChild;
+	replaces: function(element){
+		element.parentNode.replaceChild(this.toElement(), element);
+		return this;
+	inject: function(element){
+		document.id(element, true).appendChild(this.toElement());
+		return this;
+	remote: function(){
+		return Swiff.remote.apply(Swiff, [this.toElement()].extend(arguments));
+Swiff.CallBacks = {};
+Swiff.remote = function(obj, fn){
+	var rs = obj.CallFunction('<invoke name="' + fn + '" returntype="javascript">' + __flash__argumentsToXML(arguments, 2) + '</invoke>');
+	return eval(rs);
+script: Fx.js
+description: Contains the basic animation logic to be extended by all other Fx Classes.
+requires:
+- /Chain
+- /Events
+- /Options
+provides: [Fx]
+var Fx = new Class({
+	Implements: [Chain, Events, Options],
+	options: {
+		onStart: $empty,
+		onCancel: $empty,
+		onComplete: $empty,
+		fps: 50,
+		unit: false,
+		duration: 500,
+		link: 'ignore'
+	initialize: function(options){
+		this.subject = this.subject || this;
+		this.options.duration = Fx.Durations[this.options.duration] || this.options.duration.toInt();
+		var wait = this.options.wait;
+		if (wait === false) this.options.link = 'cancel';
+	getTransition: function(){
+		return function(p){
+			return -(Math.cos(Math.PI * p) - 1) / 2;
+	step: function(){
+		var time = $time();
+		if (time < this.time + this.options.duration){
+			var delta = this.transition((time - this.time) / this.options.duration);
+			this.set(this.compute(this.from, this.to, delta));
+		} else {
+			this.set(this.compute(this.from, this.to, 1));
+			this.complete();
+	set: function(now){
+		return now;
+	compute: function(from, to, delta){
+		return Fx.compute(from, to, delta);
+	check: function(){
+		if (!this.timer) return true;
+		switch (this.options.link){
+			case 'cancel': this.cancel(); return true;
+			case 'chain': this.chain(this.caller.bind(this, arguments)); return false;
+		return false;
+	start: function(from, to){
+		if (!this.check(from, to)) return this;
+		this.from = from;
+		this.to = to;
+		this.time = 0;
+		this.transition = this.getTransition();
+		this.startTimer();
+		this.onStart();
+		return this;
+	complete: function(){
+		if (this.stopTimer()) this.onComplete();
+		return this;
+	cancel: function(){
+		if (this.stopTimer()) this.onCancel();
+		return this;
+	onStart: function(){
+		this.fireEvent('start', this.subject);
+	onComplete: function(){
+		this.fireEvent('complete', this.subject);
+		if (!this.callChain()) this.fireEvent('chainComplete', this.subject);
+	onCancel: function(){
+		this.fireEvent('cancel', this.subject).clearChain();
+	pause: function(){
+		this.stopTimer();
+		return this;
+	resume: function(){
+		return this;
+	stopTimer: function(){
+		if (!this.timer) return false;
+		this.time = $time() - this.time;
+		this.timer = $clear(this.timer);
+		return true;
+	startTimer: function(){
+		if (this.timer) return false;
+		this.timer = this.step.periodical(Math.round(1000 / this.options.fps), this);
+		return true;
+Fx.compute = function(from, to, delta){
+	return (to - from) * delta + from;
+Fx.Durations = {'short': 250, 'normal': 500, 'long': 1000};
+script: Fx.CSS.js
+description: Contains the CSS animation logic. Used by Fx.Tween, Fx.Morph, Fx.Elements.
+requires:
+- /Fx
+- /Element.Style
+provides: [Fx.CSS]
+Fx.CSS = new Class({
+	Extends: Fx,
+	//prepares the base from/to object
+	prepare: function(element, property, values){
+		values = $splat(values);
+		var values1 = values[1];
+		if (!$chk(values1)){
+			values[1] = values[0];
+			values[0] = element.getStyle(property);
+		var parsed = values.map(this.parse);
+		return {from: parsed[0], to: parsed[1]};
+	//parses a value into an array
+	parse: function(value){
+		value = $lambda(value)();
+		value = (typeof value == 'string') ? value.split(' ') : $splat(value);
+		return value.map(function(val){
+			val = String(val);
+			var found = false;
+			Fx.CSS.Parsers.each(function(parser, key){
+				if (found) return;
+				var parsed = parser.parse(val);
+				if ($chk(parsed)) found = {value: parsed, parser: parser};
+			found = found || {value: val, parser: Fx.CSS.Parsers.String};
+			return found;
+	//computes by a from and to prepared objects, using their parsers.
+		var computed = [];
+		(Math.min(from.length, to.length)).times(function(i){
+			computed.push({value: from[i].parser.compute(from[i].value, to[i].value, delta), parser: from[i].parser});
+		computed.$family = {name: 'fx:css:value'};
+		return computed;
+	//serves the value as settable
+	serve: function(value, unit){
+		if ($type(value) != 'fx:css:value') value = this.parse(value);
+		var returned = [];
+		value.each(function(bit){
+			returned = returned.concat(bit.parser.serve(bit.value, unit));
+		return returned;
+	//renders the change to an element
+	render: function(element, property, value, unit){
+		element.setStyle(property, this.serve(value, unit));
+	//searches inside the page css to find the values for a selector
+	search: function(selector){
+		if (Fx.CSS.Cache[selector]) return Fx.CSS.Cache[selector];
+		var to = {};
+		Array.each(document.styleSheets, function(sheet, j){
+			var href = sheet.href;
+			if (href && href.contains('://') && !href.contains(document.domain)) return;
+			var rules = sheet.rules || sheet.cssRules;
+			Array.each(rules, function(rule, i){
+				if (!rule.style) return;
+				var selectorText = (rule.selectorText) ? rule.selectorText.replace(/^\w+/, function(m){
+					return m.toLowerCase();
+				}) : null;
+				if (!selectorText || !selectorText.test('^' + selector + '$')) return;
+				Element.Styles.each(function(value, style){
+					if (!rule.style[style] || Element.ShortStyles[style]) return;
+					value = String(rule.style[style]);
+					to[style] = (value.test(/^rgb/)) ? value.rgbToHex() : value;
+		return Fx.CSS.Cache[selector] = to;
+Fx.CSS.Cache = {};
+Fx.CSS.Parsers = new Hash({
+	Color: {
+			if (value.match(/^#[0-9a-f]{3,6}$/i)) return value.hexToRgb(true);
+			return ((value = value.match(/(\d+),\s*(\d+),\s*(\d+)/))) ? [value[1], value[2], value[3]] : false;
+			return from.map(function(value, i){
+				return Math.round(Fx.compute(from[i], to[i], delta));
+		serve: function(value){
+			return value.map(Number);
+	Number: {
+		parse: parseFloat,
+		compute: Fx.compute,
+			return (unit) ? value + unit : value;
+	String: {
+		parse: $lambda(false),
+		compute: $arguments(1),
+		serve: $arguments(0)
+script: Fx.Tween.js
+description: Formerly Fx.Style, effect to transition any CSS property for an element.
+requires:
+- /Fx.CSS
+provides: [Fx.Tween, Element.fade, Element.highlight]
+Fx.Tween = new Class({
+	Extends: Fx.CSS,
+	initialize: function(element, options){
+		this.element = this.subject = document.id(element);
+		this.parent(options);
+	set: function(property, now){
+		if (arguments.length == 1){
+			now = property;
+			property = this.property || this.options.property;
+		this.render(this.element, property, now, this.options.unit);
+		return this;
+	start: function(property, from, to){
+		if (!this.check(property, from, to)) return this;
+		this.property = this.options.property || args.shift();
+		var parsed = this.prepare(this.element, this.property, args);
+		return this.parent(parsed.from, parsed.to);
+Element.Properties.tween = {
+	set: function(options){
+		var tween = this.retrieve('tween');
+		if (tween) tween.cancel();
+		return this.eliminate('tween').store('tween:options', $extend({link: 'cancel'}, options));
+	get: function(options){
+		if (options || !this.retrieve('tween')){
+			if (options || !this.retrieve('tween:options')) this.set('tween', options);
+			this.store('tween', new Fx.Tween(this, this.retrieve('tween:options')));
+		return this.retrieve('tween');
+	tween: function(property, from, to){
+		this.get('tween').start(arguments);
+		return this;
+	fade: function(how){
+		var fade = this.get('tween'), o = 'opacity', toggle;
+		how = $pick(how, 'toggle');
+		switch (how){
+			case 'in': fade.start(o, 1); break;
+			case 'out': fade.start(o, 0); break;
+			case 'show': fade.set(o, 1); break;
+			case 'hide': fade.set(o, 0); break;
+			case 'toggle':
+				var flag = this.retrieve('fade:flag', this.get('opacity') == 1);
+				fade.start(o, (flag) ? 0 : 1);
+				this.store('fade:flag', !flag);
+				toggle = true;
+			break;
+			default: fade.start(o, arguments);
+		if (!toggle) this.eliminate('fade:flag');
+		return this;
+	highlight: function(start, end){
+		if (!end){
+			end = this.retrieve('highlight:original', this.getStyle('background-color'));
+			end = (end == 'transparent') ? '#fff' : end;
+		var tween = this.get('tween');
+		tween.start('background-color', start || '#ffff88', end).chain(function(){
+			this.setStyle('background-color', this.retrieve('highlight:original'));
+			tween.callChain();
+		}.bind(this));
+		return this;
+script: Fx.Morph.js
+description: Formerly Fx.Styles, effect to transition any number of CSS properties for an element using an object of rules, or CSS based selector rules.
+requires:
+- /Fx.CSS
+provides: [Fx.Morph]
+Fx.Morph = new Class({
+	Extends: Fx.CSS,
+		if (typeof now == 'string') now = this.search(now);
+		for (var p in now) this.render(this.element, p, now[p], this.options.unit);
+		return this;
+		var now = {};
+		for (var p in from) now[p] = this.parent(from[p], to[p], delta);
+		return now;
+	start: function(properties){
+		if (!this.check(properties)) return this;
+		if (typeof properties == 'string') properties = this.search(properties);
+		var from = {}, to = {};
+		for (var p in properties){
+			var parsed = this.prepare(this.element, p, properties[p]);
+			from[p] = parsed.from;
+			to[p] = parsed.to;
+		return this.parent(from, to);
+Element.Properties.morph = {
+		var morph = this.retrieve('morph');
+		if (morph) morph.cancel();
+		return this.eliminate('morph').store('morph:options', $extend({link: 'cancel'}, options));
+		if (options || !this.retrieve('morph')){
+			if (options || !this.retrieve('morph:options')) this.set('morph', options);
+			this.store('morph', new Fx.Morph(this, this.retrieve('morph:options')));
+		return this.retrieve('morph');
+	morph: function(props){
+		this.get('morph').start(props);
+		return this;
+script: Fx.Transitions.js
+description: Contains a set of advanced transitions to be used with any of the Fx Classes.
+credits:
+- Easing Equations by Robert Penner, <http://www.robertpenner.com/easing/>, modified and optimized to be used with MooTools.
+requires:
+- /Fx
+provides: [Fx.Transitions]
+Fx.implement({
+		var trans = this.options.transition || Fx.Transitions.Sine.easeInOut;
+		if (typeof trans == 'string'){
+			var data = trans.split(':');
+			trans = Fx.Transitions;
+			trans = trans[data[0]] || trans[data[0].capitalize()];
+			if (data[1]) trans = trans['ease' + data[1].capitalize() + (data[2] ? data[2].capitalize() : '')];
+		return trans;
+Fx.Transition = function(transition, params){
+	params = $splat(params);
+	return $extend(transition, {
+		easeIn: function(pos){
+			return transition(pos, params);
+		easeOut: function(pos){
+			return 1 - transition(1 - pos, params);
+		easeInOut: function(pos){
+			return (pos <= 0.5) ? transition(2 * pos, params) / 2 : (2 - transition(2 * (1 - pos), params)) / 2;
+Fx.Transitions = new Hash({
+	linear: $arguments(0)
+Fx.Transitions.extend = function(transitions){
+	for (var transition in transitions) Fx.Transitions[transition] = new Fx.Transition(transitions[transition]);
+Fx.Transitions.extend({
+	Pow: function(p, x){
+		return Math.pow(p, x[0] || 6);
+	Expo: function(p){
+		return Math.pow(2, 8 * (p - 1));
+	Circ: function(p){
+		return 1 - Math.sin(Math.acos(p));
+	Sine: function(p){
+		return 1 - Math.sin((1 - p) * Math.PI / 2);
+	Back: function(p, x){
+		x = x[0] || 1.618;
+		return Math.pow(p, 2) * ((x + 1) * p - x);
+	Bounce: function(p){
+		var value;
+		for (var a = 0, b = 1; 1; a += b, b /= 2){
+			if (p >= (7 - 4 * a) / 11){
+				value = b * b - Math.pow((11 - 6 * a - 11 * p) / 4, 2);
+				break;
+		return value;
+	Elastic: function(p, x){
+		return Math.pow(2, 10 * --p) * Math.cos(20 * p * Math.PI * (x[0] || 1) / 3);
+['Quad', 'Cubic', 'Quart', 'Quint'].each(function(transition, i){
+	Fx.Transitions[transition] = new Fx.Transition(function(p){
+		return Math.pow(p, [i + 2]);
+script: Request.js
+description: Powerful all purpose Request Class. Uses XMLHTTPRequest.
+requires:
+- /Element
+- /Chain
+- /Events
+- /Options
+- /Browser
+provides: [Request]
+var Request = new Class({
+	options: {/*
+		onRequest: $empty,
+		onCancel: $empty,
+		onSuccess: $empty,
+		onFailure: $empty,
+		onException: $empty,*/
+		url: '',
+		data: '',
+		headers: {
+			'X-Requested-With': 'XMLHttpRequest',
+			'Accept': 'text/javascript, text/html, application/xml, text/xml, */*'
+		async: true,
+		format: false,
+		method: 'post',
+		link: 'ignore',
+		isSuccess: null,
+		emulation: true,
+		urlEncoded: true,
+		encoding: 'utf-8',
+		evalScripts: false,
+		evalResponse: false,
+		noCache: false
+		this.xhr = new Browser.Request();
+		this.options.isSuccess = this.options.isSuccess || this.isSuccess;
+		this.headers = new Hash(this.options.headers);
+	onStateChange: function(){
+		if (this.xhr.readyState != 4 || !this.running) return;
+		this.running = false;
+		this.status = 0;
+		$try(function(){
+			this.status = this.xhr.status;
+		}.bind(this));
+		this.xhr.onreadystatechange = $empty;
+		if (this.options.isSuccess.call(this, this.status)){
+			this.response = {text: this.xhr.responseText, xml: this.xhr.responseXML};
+			this.success(this.response.text, this.response.xml);
+		} else {
+			this.response = {text: null, xml: null};
+			this.failure();
+	isSuccess: function(){
+		return ((this.status >= 200) && (this.status < 300));
+	processScripts: function(text){
+		if (this.options.evalResponse || (/(ecma|java)script/).test(this.getHeader('Content-type'))) return $exec(text);
+		return text.stripScripts(this.options.evalScripts);
+	success: function(text, xml){
+		this.onSuccess(this.processScripts(text), xml);
+	onSuccess: function(){
+		this.fireEvent('complete', arguments).fireEvent('success', arguments).callChain();
+	failure: function(){
+		this.onFailure();
+	onFailure: function(){
+		this.fireEvent('complete').fireEvent('failure', this.xhr);
+	setHeader: function(name, value){
+		this.headers.set(name, value);
+		return this;
+	getHeader: function(name){
+		return $try(function(){
+			return this.xhr.getResponseHeader(name);
+		}.bind(this));
+		if (!this.running) return true;
+		return false;
+	send: function(options){
+		if (!this.check(options)) return this;
+		this.running = true;
+		var type = $type(options);
+		if (type == 'string' || type == 'element') options = {data: options};
+		var old = this.options;
+		options = $extend({data: old.data, url: old.url, method: old.method}, options);
+		var data = options.data, url = String(options.url), method = options.method.toLowerCase();
+		switch ($type(data)){
+			case 'element': data = document.id(data).toQueryString(); break;
+			case 'object': case 'hash': data = Hash.toQueryString(data);
+		if (this.options.format){
+			var format = 'format=' + this.options.format;
+			data = (data) ? format + '&' + data : format;
+		if (this.options.emulation && !['get', 'post'].contains(method)){
+			var _method = '_method=' + method;
+			data = (data) ? _method + '&' + data : _method;
+			method = 'post';
+		if (this.options.urlEncoded && method == 'post'){
+			var encoding = (this.options.encoding) ? '; charset=' + this.options.encoding : '';
+			this.headers.set('Content-type', 'application/x-www-form-urlencoded' + encoding);
+		if (this.options.noCache){
+			var noCache = 'noCache=' + new Date().getTime();
+			data = (data) ? noCache + '&' + data : noCache;
+		var trimPosition = url.lastIndexOf('/');
+		if (trimPosition > -1 && (trimPosition = url.indexOf('#')) > -1) url = url.substr(0, trimPosition);
+		if (data && method == 'get'){
+			url = url + (url.contains('?') ? '&' : '?') + data;
+			data = null;
+		this.xhr.open(method.toUpperCase(), url, this.options.async);
+		this.xhr.onreadystatechange = this.onStateChange.bind(this);
+		this.headers.each(function(value, key){
+			try {
+				this.xhr.setRequestHeader(key, value);
+			} catch (e){
+				this.fireEvent('exception', [key, value]);
+		}, this);
+		this.fireEvent('request');
+		this.xhr.send(data);
+		if (!this.options.async) this.onStateChange();
+		return this;
+		if (!this.running) return this;
+		this.xhr.abort();
+		this.fireEvent('cancel');
+		return this;
+(function(){
+var methods = {};
+['get', 'post', 'put', 'delete', 'GET', 'POST', 'PUT', 'DELETE'].each(function(method){
+	methods[method] = function(){
+		var params = Array.link(arguments, {url: String.type, data: $defined});
+		return this.send($extend(params, {method: method}));
+Request.implement(methods);
+Element.Properties.send = {
+		var send = this.retrieve('send');
+		if (send) send.cancel();
+		return this.eliminate('send').store('send:options', $extend({
+			data: this, link: 'cancel', method: this.get('method') || 'post', url: this.get('action')
+		}, options));
+		if (options || !this.retrieve('send')){
+			if (options || !this.retrieve('send:options')) this.set('send', options);
+			this.store('send', new Request(this.retrieve('send:options')));
+		return this.retrieve('send');
+	send: function(url){
+		var sender = this.get('send');
+		sender.send({data: this, url: url || sender.options.url});
+		return this;
+script: Request.HTML.js
+description: Extends the basic Request Class with additional methods for interacting with HTML responses.
+requires:
+- /Request
+- /Element
+provides: [Request.HTML]
+Request.HTML = new Class({
+	Extends: Request,
+	options: {
+		update: false,
+		append: false,
+		evalScripts: true,
+		filter: false
+	processHTML: function(text){
+		var match = text.match(/<body[^>]*>([\s\S]*?)<\/body>/i);
+		text = (match) ? match[1] : text;
+		var container = new Element('div');
+			var root = '<root>' + text + '</root>', doc;
+				doc = new ActiveXObject('Microsoft.XMLDOM');
+				doc.async = false;
+				doc.loadXML(root);
+			} else {
+				doc = new DOMParser().parseFromString(root, 'text/xml');
+			root = doc.getElementsByTagName('root')[0];
+			if (!root) return null;
+			for (var i = 0, k = root.childNodes.length; i < k; i++){
+				var child = Element.clone(root.childNodes[i], true, true);
+				if (child) container.grab(child);
+			return container;
+		}) || container.set('html', text);
+	success: function(text){
+		var options = this.options, response = this.response;
+		response.html = text.stripScripts(function(script){
+			response.javascript = script;
+		var temp = this.processHTML(response.html);
+		response.tree = temp.childNodes;
+		response.elements = temp.getElements('*');
+		if (options.filter) response.tree = response.elements.filter(options.filter);
+		if (options.update) document.id(options.update).empty().set('html', response.html);
+		else if (options.append) document.id(options.append).adopt(temp.getChildren());
+		if (options.evalScripts) $exec(response.javascript);
+		this.onSuccess(response.tree, response.elements, response.html, response.javascript);
+Element.Properties.load = {
+		var load = this.retrieve('load');
+		if (load) load.cancel();
+		return this.eliminate('load').store('load:options', $extend({data: this, link: 'cancel', update: this, method: 'get'}, options));
+		if (options || ! this.retrieve('load')){
+			if (options || !this.retrieve('load:options')) this.set('load', options);
+			this.store('load', new Request.HTML(this.retrieve('load:options')));
+		return this.retrieve('load');
+	load: function(){
+		this.get('load').send(Array.link(arguments, {data: Object.type, url: String.type}));
+		return this;
+script: Request.JSON.js
+description: Extends the basic Request Class with additional methods for sending and receiving JSON data.
+requires:
+- /Request JSON
+Request.JSON = new Class({
+	Extends: Request,
+	options: {
+		secure: true
+		this.headers.extend({'Accept': 'application/json', 'X-Request': 'JSON'});
+		this.response.json = JSON.decode(text, this.options.secure);
+		this.onSuccess(this.response.json, text);
+script: More.js
+description: MooTools More
+authors:
+ - Guillermo Rauch
+ - Thomas Aylott
+ - Scott Kyle
+requires:
+ - core:1.2.4/MooTools
+provides: [MooTools.More]
+MooTools.More = {
+	'version': '1.2.4.4',
+	'build': '6f6057dc645fdb7547689183b2311063bd653ddf'
+script: MooTools.Lang.js
+description: Provides methods for localization.
+authors:
+ - Aaron Newton
+requires:
+ - core:1.2.4/Events
+ - /MooTools.More
+provides: [MooTools.Lang]
+(function(){
+	var data = {
+		language: 'en-US',
+		languages: {
+			'en-US': {}
+		cascades: ['en-US']
+	var cascaded;
+	MooTools.lang = new Events();
+	$extend(MooTools.lang, {
+		setLanguage: function(lang){
+			if (!data.languages[lang]) return this;
+			data.language = lang;
+			this.load();
+			this.fireEvent('langChange', lang);
+			return this;
+		load: function() {
+			var langs = this.cascade(this.getCurrentLanguage());
+			cascaded = {};
+			$each(langs, function(set, setName){
+				cascaded[setName] = this.lambda(set);
+			}, this);
+		getCurrentLanguage: function(){
+			return data.language;
+		addLanguage: function(lang){
+			data.languages[lang] = data.languages[lang] || {};
+			return this;
+		cascade: function(lang){
+			var cascades = (data.languages[lang] || {}).cascades || [];
+			cascades.combine(data.cascades);
+			cascades.erase(lang).push(lang);
+			var langs = cascades.map(function(lng){
+				return data.languages[lng];
+			}, this);
+			return $merge.apply(this, langs);
+		lambda: function(set) {
+			(set || {}).get = function(key, args){
+				return $lambda(set[key]).apply(this, $splat(args));
+			return set;
+		get: function(set, key, args){
+			if (cascaded && cascaded[set]) return (key ? cascaded[set].get(key, args) : cascaded[set]);
+		set: function(lang, set, members){
+			this.addLanguage(lang);
+			langData = data.languages[lang];
+			if (!langData[set]) langData[set] = {};
+			$extend(langData[set], members);
+			if (lang == this.getCurrentLanguage()){
+				this.load();
+			return this;
+		list: function(){
+			return Hash.getKeys(data.languages);
+script: Log.js
+description: Provides basic logging functionality for plugins to implement.
+authors:
+ - Guillermo Rauch
+ - Thomas Aylott
+ - Scott Kyle
+requires:
+ - core:1.2.4/Class
+ - /MooTools.More
+provides: [Log]
+(function(){
+var global = this;
+var log = function(){
+	if (global.console && console.log){
+		try {
+			console.log.apply(console, arguments);
+		} catch(e) {
+			console.log(Array.slice(arguments));
+	} else {
+		Log.logged.push(arguments);
+	return this;
+var disabled = function(){
+	this.logged.push(arguments);
+	return this;
+this.Log = new Class({
+	logged: [],
+	log: disabled,
+	resetLog: function(){
+		this.logged.empty();
+		return this;
+	enableLog: function(){
+		this.log = log;
+		this.logged.each(function(args){
+			this.log.apply(this, args);
+		}, this);
+		return this.resetLog();
+	disableLog: function(){
+		this.log = disabled;
+		return this;
+Log.extend(new Log).enableLog();
+// legacy
+Log.logger = function(){
+	return this.log.apply(this, arguments);
+script: Depender.js
+description: A stand alone dependency loader for the MooTools library.
+authors:
+ - Aaron Newton
+requires:
+ - core:1.2.4/Element.Events
+ - core:1.2.4/Request.JSON
+ - /MooTools.More
+ - /Log
+provides: Depender
+var Depender = {
+	options: {
+		onRequire: $empty(options),
+		onRequirementLoaded: $empty([scripts, options]),
+		onScriptLoaded: $empty({
+			script: script,
+			totalLoaded: percentOfTotalLoaded,
+			loaded: scriptsState
+		serial: false,
+		target: null,
+		noCache: false,
+		log: false,*/
+		loadedSources: [],
+		loadedScripts: ['Core', 'Browser', 'Array', 'String', 'Function', 'Number', 'Hash', 'Element', 'Event', 'Element.Event', 'Class', 'DomReady', 'Class.Extras', 'Request', 'JSON', 'Request.JSON', 'More', 'Depender', 'Log'],
+		useScriptInjection: true
+	loaded: [],
+	sources: {},
+	libs: {},
+	include: function(libs){
+		this.log('include: ', libs);
+		this.mapLoaded = false;
+		var loader = function(data){
+			this.libs = $merge(this.libs, data);
+			$each(this.libs, function(data, lib){
+				if (data.scripts) this.loadSource(lib, data.scripts);
+			}, this);
+		}.bind(this);
+		if ($type(libs) == 'string'){
+			this.log('fetching libs ', libs);
+			this.request(libs, loader);
+		} else {
+			loader(libs);
+		return this;
+	required: [],
+	require: function(options){
+		var loaded = function(){
+			var scripts = this.calculateDependencies(options.scripts);
+			if (options.sources){
+				options.sources.each(function(source){
+					scripts.combine(this.libs[source].files);
+				}, this);
+			if (options.serial) scripts.combine(this.getLoadedScripts());
+			options.scripts = scripts;
+			this.required.push(options);
+			this.fireEvent('require', options);
+			this.loadScripts(options.scripts);
+		if (this.mapLoaded) loaded.call(this);
+		else this.addEvent('mapLoaded', loaded.bind(this));
+		return this;
+	cleanDoubleSlash: function(str){
+		if (!str) return str;
+		var prefix = '';
+		if (str.test(/^http:\/\//)){
+			prefix = 'http://';
+			str = str.substring(7, str.length);
+		str = str.replace(/\/\//g, '/');
+		return prefix + str;
+	request: function(url, callback){
+		new Request.JSON({
+			url: url,
+			secure: false,
+			onSuccess: callback
+		}).send();
+	loadSource: function(lib, source){
+		if (this.libs[lib].files){
+			this.dataLoaded();
+			return;
+		this.log('loading source: ', source);
+		this.request(this.cleanDoubleSlash(source + '/scripts.json'), function(result){
+			this.log('loaded source: ', source);
+			this.libs[lib].files = result;
+		}.bind(this));
+	dataLoaded: function(){
+		var loaded = true;
+		$each(this.libs, function(v, k){
+			if (!this.libs[k].files) loaded = false;
+		}, this);
+		if (loaded){
+			this.mapTree();
+			this.mapLoaded = true;
+			this.calculateLoaded();
+			this.lastLoaded = this.getLoadedScripts().getLength();
+			this.fireEvent('mapLoaded');
+			this.removeEvents('mapLoaded');
+	calculateLoaded: function(){
+		var set = function(script){
+			this.scriptsState[script] = true;
+		}.bind(this);
+		if (this.options.loadedScripts) this.options.loadedScripts.each(set);
+		if (this.options.loadedSources){
+			this.options.loadedSources.each(function(lib){
+				$each(this.libs[lib].files, function(dir){
+					$each(dir, function(data, file){
+						set(file);
+					}, this);
+				}, this);
+			}, this);
+	deps: {},
+	pathMap: {},
+	mapTree: function(){
+		$each(this.libs, function(data, source){
+			$each(data.files, function(scripts, folder){
+				$each(scripts, function(details, script){
+					var path = source + ':' + folder + ':' + script;
+					if (this.deps[path]) return;
+					this.deps[path] = details.deps;
+					this.pathMap[script] = path;
+				}, this);
+			}, this);
+		}, this);
+	getDepsForScript: function(script){
+		return this.deps[this.pathMap[script]] || [];
+	calculateDependencies: function(scripts){
+		var reqs = [];
+		$splat(scripts).each(function(script){
+			if (script == 'None' || !script) return;
+			var deps = this.getDepsForScript(script);
+			if (!deps){
+				if (window.console && console.warn) console.warn('dependencies not mapped: script: %o, map: %o, :deps: %o', script, this.pathMap, this.deps);
+			} else {
+				deps.each(function(scr){
+					if (scr == script || scr == 'None' || !scr) return;
+					if (!reqs.contains(scr)) reqs.combine(this.calculateDependencies(scr));
+					reqs.include(scr);
+				}, this);
+			reqs.include(script);
+		}, this);
+		return reqs;
+	getPath: function(script){
+		try {
+			var chunks = this.pathMap[script].split(':');
+			var lib = this.libs[chunks[0]];
+			var dir = (lib.path || lib.scripts) + '/';
+			chunks.shift();
+			return this.cleanDoubleSlash(dir + chunks.join('/') + '.js');
+		} catch(e){
+			return script;
+	loadScripts: function(scripts){
+		scripts = scripts.filter(function(s){
+			if (!this.scriptsState[s] && s != 'None'){
+				this.scriptsState[s] = false;
+				return true;
+		}, this);
+		if (scripts.length){
+			scripts.each(function(scr){
+				this.loadScript(scr);
+			}, this);
+		} else {
+			this.check();
+	toLoad: [],
+	loadScript: function(script){
+		if (this.scriptsState[script] && this.toLoad.length){
+			this.loadScript(this.toLoad.shift());
+			return;
+		} else if (this.loading){
+			this.toLoad.push(script);
+			return;
+		var finish = function(){
+			this.loading = false;
+			this.scriptLoaded(script);
+			if (this.toLoad.length) this.loadScript(this.toLoad.shift());
+		}.bind(this);
+		var error = function(){
+			this.log('could not load: ', scriptPath);
+		}.bind(this);
+		this.loading = true;
+		var scriptPath = this.getPath(script);
+		if (this.options.useScriptInjection){
+			this.log('injecting script: ', scriptPath);
+				this.log('loaded script: ', scriptPath);
+				finish();
+			}.bind(this);
+			new Element('script', {
+				src: scriptPath + (this.options.noCache ? '?noCache=' + new Date().getTime() : ''),
+				events: {
+					load: loaded,
+					readystatechange: function(){
+						if (['loaded', 'complete'].contains(this.readyState)) loaded();
+					error: error
+			}).inject(this.options.target || document.head);
+		} else {
+			this.log('requesting script: ', scriptPath);
+			new Request({
+				url: scriptPath,
+				noCache: this.options.noCache,
+				onComplete: function(js){
+					$exec(js);
+					finish();
+				}.bind(this),
+				onFailure: error,
+				onException: error
+			}).send();
+	scriptsState: $H(),
+	getLoadedScripts: function(){
+		return this.scriptsState.filter(function(state){
+			return state;
+	scriptLoaded: function(script){
+		this.log('loaded script: ', script);
+		this.check();
+		var loaded = this.getLoadedScripts();
+		var loadedLength = loaded.getLength();
+		var toLoad = this.scriptsState.getLength();
+		this.fireEvent('scriptLoaded', {
+			script: script,
+			totalLoaded: (loadedLength / toLoad * 100).round(),
+			currentLoaded: ((loadedLength - this.lastLoaded) / (toLoad - this.lastLoaded) * 100).round(),
+			loaded: loaded
+		if (loadedLength == toLoad) this.lastLoaded = loadedLength;
+	lastLoaded: 0,
+		var incomplete = [];
+		this.required.each(function(required){
+			var loaded = [];
+			required.scripts.each(function(script){
+				if (this.scriptsState[script]) loaded.push(script);
+			}, this);
+			if (required.onStep){
+				required.onStep({
+					percent: loaded.length / required.scripts.length * 100,
+					scripts: loaded
+			if (required.scripts.length != loaded.length) return;
+			required.callback();
+			this.required.erase(required);
+			this.fireEvent('requirementLoaded', [loaded, required]);
+		}, this);
+$extend(Depender, new Events);
+$extend(Depender, new Options);
+$extend(Depender, new Log);
+Depender._setOptions = Depender.setOptions;
+Depender.setOptions = function(){
+	Depender._setOptions.apply(Depender, arguments);
+	if (this.options.log) Depender.enableLog();
+	return this;
+script: Class.Refactor.js
+description: Extends a class onto itself with new property, preserving any items attached to the class's namespace.
+authors:
+ - Aaron Newton
+requires:
+ - /MooTools.More
+provides: [Class.refactor]
+Class.refactor = function(original, refactors){
+	$each(refactors, function(item, name){
+		var origin = original.prototype[name];
+		if (origin && (origin = origin._origin) && typeof item == 'function') original.implement(name, function(){
+			var old = this.previous;
+			this.previous = origin;
+			var value = item.apply(this, arguments);
+			this.previous = old;
+			return value;
+		}); else original.implement(name, item);
+	return original;
+script: Class.Binds.js
+description: Automagically binds specified methods in a class to the instance of the class.
+authors:
+ - Aaron Newton
+requires:
+ - /MooTools.More
+provides: [Class.Binds]
+Class.Mutators.Binds = function(binds){
+    return binds;
+Class.Mutators.initialize = function(initialize){
+		$splat(this.Binds).each(function(name){
+			var original = this[name];
+			if (original) this[name] = original.bind(this);
+		}, this);
+		return initialize.apply(this, arguments);
+script: Class.Occlude.js
+description: Prevents a class from being applied to a DOM element twice.
+authors:
+ - Aaron Newton
+requires:
+ - core/1.2.4/Class
+ - /MooTools.More
+provides: [Class.Occlude]
+Class.Occlude = new Class({
+	occlude: function(property, element){
+		element = document.id(element || this.element);
+		var instance = element.retrieve(property || this.property);
+		if (instance && !$defined(this.occluded))
+			return this.occluded = instance;
+		this.occluded = false;
+		element.store(property || this.property, this);
+		return this.occluded;
+script: Chain.Wait.js
+description: value, Adds a method to inject pauses between chained events.
+authors:
+ - Aaron Newton
+requires:
+ - core:1.2.4/Chain
+ - core:1.2.4/Fx
+ - /MooTools.More
+provides: [Chain.Wait]
+(function(){
+	var wait = {
+		wait: function(duration){
+			return this.chain(function(){
+				this.callChain.delay($pick(duration, 500), this);
+			}.bind(this));
+	Chain.implement(wait);
+	if (window.Fx){
+		Fx.implement(wait);
+		['Css', 'Tween', 'Elements'].each(function(cls){
+			if (Fx[cls]) Fx[cls].implement(wait);
+	Element.implement({
+		chains: function(effects){
+			$splat($pick(effects, ['tween', 'morph', 'reveal'])).each(function(effect){
+				effect = this.get(effect);
+				if (!effect) return;
+				effect.setOptions({
+					link:'chain'
+			}, this);
+			return this;
+		pauseFx: function(duration, effect){
+			this.chains(effect).get($pick(effect, 'tween')).wait(duration);
+			return this;
+script: Array.Extras.js
+description: Extends the Array native object to include useful methods to work with arrays.
+authors:
+ - Christoph Pojer
+requires:
+ - core:1.2.4/Array
+provides: [Array.Extras]
+Array.implement({
+	min: function(){
+		return Math.min.apply(null, this);
+	max: function(){
+		return Math.max.apply(null, this);
+	average: function(){
+		return this.length ? this.sum() / this.length : 0;
+	sum: function(){
+		var result = 0, l = this.length;
+		if (l){
+			do {
+				result += this[--l];
+			} while (l);
+		return result;
+	unique: function(){
+		return [].combine(this);
+	shuffle: function(){
+		for (var i = this.length; i && --i;){
+			var temp = this[i], r = Math.floor(Math.random() * ( i + 1 ));
+			this[i] = this[r];
+			this[r] = temp;
+		return this;
+script: Date.English.US.js
+description: Date messages for US English.
+authors:
+ - Aaron Newton
+requires:
+ - /Lang
+ - /Date
+provides: [Date.English.US]
+MooTools.lang.set('en-US', 'Date', {
+	months: ['January', 'February', 'March', 'April', 'May', 'June', 'July', 'August', 'September', 'October', 'November', 'December'],
+	days: ['Sunday', 'Monday', 'Tuesday', 'Wednesday', 'Thursday', 'Friday', 'Saturday'],
+	//culture's date order: MM/DD/YYYY
+	dateOrder: ['month', 'date', 'year'],
+	shortDate: '%m/%d/%Y',
+	shortTime: '%I:%M%p',
+	AM: 'AM',
+	PM: 'PM',
+	/* Date.Extras */
+	ordinal: function(dayOfMonth){
+		//1st, 2nd, 3rd, etc.
+		return (dayOfMonth > 3 && dayOfMonth < 21) ? 'th' : ['th', 'st', 'nd', 'rd', 'th'][Math.min(dayOfMonth % 10, 4)];
+	lessThanMinuteAgo: 'less than a minute ago',
+	minuteAgo: 'about a minute ago',
+	minutesAgo: '{delta} minutes ago',
+	hourAgo: 'about an hour ago',
+	hoursAgo: 'about {delta} hours ago',
+	dayAgo: '1 day ago',
+	daysAgo: '{delta} days ago',
+	weekAgo: '1 week ago',
+	weeksAgo: '{delta} weeks ago',
+	monthAgo: '1 month ago',
+	monthsAgo: '{delta} months ago',
+	yearAgo: '1 year ago',
+	yearsAgo: '{delta} years ago',
+	lessThanMinuteUntil: 'less than a minute from now',
+	minuteUntil: 'about a minute from now',
+	minutesUntil: '{delta} minutes from now',
+	hourUntil: 'about an hour from now',
+	hoursUntil: 'about {delta} hours from now',
+	dayUntil: '1 day from now',
+	daysUntil: '{delta} days from now',
+	weekUntil: '1 week from now',
+	weeksUntil: '{delta} weeks from now',
+	monthUntil: '1 month from now',
+	monthsUntil: '{delta} months from now',
+	yearUntil: '1 year from now',
+	yearsUntil: '{delta} years from now'
+script: Date.js
+description: Extends the Date native object to include methods useful in managing dates.
+authors:
+ - Aaron Newton
+ - Nicholas Barthelemy - https://svn.nbarthelemy.com/date-js/
+ - Harald Kirshner - mail [at] digitarald.de; http://digitarald.de
+ - Scott Kyle - scott [at] appden.com; http://appden.com
+requires:
+ - core:1.2.4/String
+ - core:1.2.4/Number
+ - core:1.2.4/Lang
+ - core:1.2.4/Date.English.US
+ - /MooTools.More
+provides: [Date]
+(function(){
+var Date = this.Date;
+if (!Date.now) Date.now = $time;
+Date.Methods = {
+	ms: 'Milliseconds',
+	year: 'FullYear',
+	min: 'Minutes',
+	mo: 'Month',
+	sec: 'Seconds',
+	hr: 'Hours'
+['Date', 'Day', 'FullYear', 'Hours', 'Milliseconds', 'Minutes', 'Month', 'Seconds', 'Time', 'TimezoneOffset',
+	'Week', 'Timezone', 'GMTOffset', 'DayOfYear', 'LastMonth', 'LastDayOfMonth', 'UTCDate', 'UTCDay', 'UTCFullYear',
+	'AMPM', 'Ordinal', 'UTCHours', 'UTCMilliseconds', 'UTCMinutes', 'UTCMonth', 'UTCSeconds'].each(function(method){
+	Date.Methods[method.toLowerCase()] = method;
+var pad = function(what, length){
+	return new Array(length - String(what).length + 1).join('0') + what;
+Date.implement({
+	set: function(prop, value){
+		switch ($type(prop)){
+			case 'object':
+				for (var p in prop) this.set(p, prop[p]);
+				break;
+			case 'string':
+				prop = prop.toLowerCase();
+				var m = Date.Methods;
+				if (m[prop]) this['set' + m[prop]](value);
+		return this;
+	get: function(prop){
+		if (m[prop]) return this['get' + m[prop]]();
+		return null;
+	clone: function(){
+		return new Date(this.get('time'));
+	increment: function(interval, times){
+		interval = interval || 'day';
+		times = $pick(times, 1);
+		switch (interval){
+			case 'year':
+				return this.increment('month', times * 12);
+			case 'month':
+				var d = this.get('date');
+				this.set('date', 1).set('mo', this.get('mo') + times);
+				return this.set('date', d.min(this.get('lastdayofmonth')));
+			case 'week':
+				return this.increment('day', times * 7);
+			case 'day':
+				return this.set('date', this.get('date') + times);
+		if (!Date.units[interval]) throw new Error(interval + ' is not a supported interval');
+		return this.set('time', this.get('time') + times * Date.units[interval]());
+	decrement: function(interval, times){
+		return this.increment(interval, -1 * $pick(times, 1));
+	isLeapYear: function(){
+		return Date.isLeapYear(this.get('year'));
+	clearTime: function(){
+		return this.set({hr: 0, min: 0, sec: 0, ms: 0});
+	diff: function(date, resolution){
+		if ($type(date) == 'string') date = Date.parse(date);
+		return ((date - this) / Date.units[resolution || 'day'](3, 3)).toInt(); // non-leap year, 30-day month
+	getLastDayOfMonth: function(){
+		return Date.daysInMonth(this.get('mo'), this.get('year'));
+	getDayOfYear: function(){
+		return (Date.UTC(this.get('year'), this.get('mo'), this.get('date') + 1)
+			- Date.UTC(this.get('year'), 0, 1)) / Date.units.day();
+	getWeek: function(){
+		return (this.get('dayofyear') / 7).ceil();
+	getOrdinal: function(day){
+		return Date.getMsg('ordinal', day || this.get('date'));
+	getTimezone: function(){
+		return this.toString()
+			.replace(/^.*? ([A-Z]{3}).[0-9]{4}.*$/, '$1')
+			.replace(/^.*?\(([A-Z])[a-z]+ ([A-Z])[a-z]+ ([A-Z])[a-z]+\)$/, '$1$2$3');
+	getGMTOffset: function(){
+		var off = this.get('timezoneOffset');
+		return ((off > 0) ? '-' : '+') + pad((off.abs() / 60).floor(), 2) + pad(off % 60, 2);
+	setAMPM: function(ampm){
+		ampm = ampm.toUpperCase();
+		var hr = this.get('hr');
+		if (hr > 11 && ampm == 'AM') return this.decrement('hour', 12);
+		else if (hr < 12 && ampm == 'PM') return this.increment('hour', 12);
+		return this;
+	getAMPM: function(){
+		return (this.get('hr') < 12) ? 'AM' : 'PM';
+	parse: function(str){
+		this.set('time', Date.parse(str));
+		return this;
+	isValid: function(date) {
+		return !!(date || this).valueOf();
+	format: function(f){
+		if (!this.isValid()) return 'invalid date';
+		f = f || '%x %X';
+		f = formats[f.toLowerCase()] || f; // replace short-hand with actual format
+		var d = this;
+		return f.replace(/%([a-z%])/gi,
+			function($0, $1){
+				switch ($1){
+					case 'a': return Date.getMsg('days')[d.get('day')].substr(0, 3);
+					case 'A': return Date.getMsg('days')[d.get('day')];
+					case 'b': return Date.getMsg('months')[d.get('month')].substr(0, 3);
+					case 'B': return Date.getMsg('months')[d.get('month')];
+					case 'c': return d.toString();
+					case 'd': return pad(d.get('date'), 2);
+					case 'H': return pad(d.get('hr'), 2);
+					case 'I': return ((d.get('hr') % 12) || 12);
+					case 'j': return pad(d.get('dayofyear'), 3);
+					case 'm': return pad((d.get('mo') + 1), 2);
+					case 'M': return pad(d.get('min'), 2);
+					case 'o': return d.get('ordinal');
+					case 'p': return Date.getMsg(d.get('ampm'));
+					case 'S': return pad(d.get('seconds'), 2);
+					case 'U': return pad(d.get('week'), 2);
+					case 'w': return d.get('day');
+					case 'x': return d.format(Date.getMsg('shortDate'));
+					case 'X': return d.format(Date.getMsg('shortTime'));
+					case 'y': return d.get('year').toString().substr(2);
+					case 'Y': return d.get('year');
+					case 'T': return d.get('GMTOffset');
+					case 'Z': return d.get('Timezone');
+				return $1;
+	toISOString: function(){
+		return this.format('iso8601');
+Date.alias('toISOString', 'toJSON');
+Date.alias('diff', 'compare');
+Date.alias('format', 'strftime');
+var formats = {
+	db: '%Y-%m-%d %H:%M:%S',
+	compact: '%Y%m%dT%H%M%S',
+	iso8601: '%Y-%m-%dT%H:%M:%S%T',
+	rfc822: '%a, %d %b %Y %H:%M:%S %Z',
+	'short': '%d %b %H:%M',
+	'long': '%B %d, %Y %H:%M'
+var parsePatterns = [];
+var nativeParse = Date.parse;
+var parseWord = function(type, word, num){
+	var ret = -1;
+	var translated = Date.getMsg(type + 's');
+	switch ($type(word)){
+		case 'object':
+			ret = translated[word.get(type)];
+			break;
+		case 'number':
+			ret = translated[month - 1];
+			if (!ret) throw new Error('Invalid ' + type + ' index: ' + index);
+			break;
+		case 'string':
+			var match = translated.filter(function(name){
+				return this.test(name);
+			}, new RegExp('^' + word, 'i'));
+			if (!match.length)    throw new Error('Invalid ' + type + ' string');
+			if (match.length > 1) throw new Error('Ambiguous ' + type);
+			ret = match[0];
+	return (num) ? translated.indexOf(ret) : ret;
+Date.extend({
+	getMsg: function(key, args) {
+		return MooTools.lang.get('Date', key, args);
+	units: {
+		ms: $lambda(1),
+		second: $lambda(1000),
+		minute: $lambda(60000),
+		hour: $lambda(3600000),
+		day: $lambda(86400000),
+		week: $lambda(608400000),
+		month: function(month, year){
+			var d = new Date;
+			return Date.daysInMonth($pick(month, d.get('mo')), $pick(year, d.get('year'))) * 86400000;
+		year: function(year){
+			year = year || new Date().get('year');
+			return Date.isLeapYear(year) ? 31622400000 : 31536000000;
+	daysInMonth: function(month, year){
+		return [31, Date.isLeapYear(year) ? 29 : 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31][month];
+	isLeapYear: function(year){
+		return ((year % 4 === 0) && (year % 100 !== 0)) || (year % 400 === 0);
+	parse: function(from){
+		var t = $type(from);
+		if (t == 'number') return new Date(from);
+		if (t != 'string') return from;
+		from = from.clean();
+		if (!from.length) return null;
+		var parsed;
+		parsePatterns.some(function(pattern){
+			var bits = pattern.re.exec(from);
+			return (bits) ? (parsed = pattern.handler(bits)) : false;
+		return parsed || new Date(nativeParse(from));
+	parseDay: function(day, num){
+		return parseWord('day', day, num);
+	parseMonth: function(month, num){
+		return parseWord('month', month, num);
+	parseUTC: function(value){
+		var localDate = new Date(value);
+		var utcSeconds = Date.UTC(
+			localDate.get('year'),
+			localDate.get('mo'),
+			localDate.get('date'),
+			localDate.get('hr'),
+			localDate.get('min'),
+			localDate.get('sec')
+		return new Date(utcSeconds);
+	orderIndex: function(unit){
+		return Date.getMsg('dateOrder').indexOf(unit) + 1;
+	defineFormat: function(name, format){
+		formats[name] = format;
+	defineFormats: function(formats){
+		for (var name in formats) Date.defineFormat(name, formats[name]);
+	parsePatterns: parsePatterns, // this is deprecated
+	defineParser: function(pattern){
+		parsePatterns.push((pattern.re && pattern.handler) ? pattern : build(pattern));
+	defineParsers: function(){
+		Array.flatten(arguments).each(Date.defineParser);
+	define2DigitYearStart: function(year){
+		startYear = year % 100;
+		startCentury = year - startYear;
+var startCentury = 1900;
+var startYear = 70;
+var regexOf = function(type){
+	return new RegExp('(?:' + Date.getMsg(type).map(function(name){
+		return name.substr(0, 3);
+	}).join('|') + ')[a-z]*');
+var replacers = function(key){
+	switch(key){
+		case 'x': // iso8601 covers yyyy-mm-dd, so just check if month is first
+			return ((Date.orderIndex('month') == 1) ? '%m[.-/]%d' : '%d[.-/]%m') + '([.-/]%y)?';
+		case 'X':
+			return '%H([.:]%M)?([.:]%S([.:]%s)?)? ?%p? ?%T?';
+	return null;
+var keys = {
+	d: /[0-2]?[0-9]|3[01]/,
+	H: /[01]?[0-9]|2[0-3]/,
+	I: /0?[1-9]|1[0-2]/,
+	M: /[0-5]?\d/,
+	s: /\d+/,
+	o: /[a-z]*/,
+	p: /[ap]\.?m\.?/,
+	y: /\d{2}|\d{4}/,
+	Y: /\d{4}/,
+	T: /Z|[+-]\d{2}(?::?\d{2})?/
+keys.m = keys.I;
+keys.S = keys.M;
+var currentLanguage;
+var recompile = function(language){
+	currentLanguage = language;
+	keys.a = keys.A = regexOf('days');
+	keys.b = keys.B = regexOf('months');
+	parsePatterns.each(function(pattern, i){
+		if (pattern.format) parsePatterns[i] = build(pattern.format);
+var build = function(format){
+	if (!currentLanguage) return {format: format};
+	var parsed = [];
+	var re = (format.source || format) // allow format to be regex
+	 .replace(/%([a-z])/gi,
+		function($0, $1){
+			return replacers($1) || $0;
+	).replace(/\((?!\?)/g, '(?:') // make all groups non-capturing
+	 .replace(/ (?!\?|\*)/g, ',? ') // be forgiving with spaces and commas
+	 .replace(/%([a-z%])/gi,
+		function($0, $1){
+			var p = keys[$1];
+			if (!p) return $1;
+			parsed.push($1);
+			return '(' + p.source + ')';
+	).replace(/\[a-z\]/gi, '[a-z\\u00c0-\\uffff]'); // handle unicode words
+	return {
+		format: format,
+		re: new RegExp('^' + re + '$', 'i'),
+		handler: function(bits){
+			bits = bits.slice(1).associate(parsed);
+			var date = new Date().clearTime();
+			if ('d' in bits) handle.call(date, 'd', 1);
+			if ('m' in bits || 'b' in bits || 'B' in bits) handle.call(date, 'm', 1);
+			for (var key in bits) handle.call(date, key, bits[key]);
+			return date;
+var handle = function(key, value){
+	if (!value) return this;
+	switch(key){
+		case 'a': case 'A': return this.set('day', Date.parseDay(value, true));
+		case 'b': case 'B': return this.set('mo', Date.parseMonth(value, true));
+		case 'd': return this.set('date', value);
+		case 'H': case 'I': return this.set('hr', value);
+		case 'm': return this.set('mo', value - 1);
+		case 'M': return this.set('min', value);
+		case 'p': return this.set('ampm', value.replace(/\./g, ''));
+		case 'S': return this.set('sec', value);
+		case 's': return this.set('ms', ('0.' + value) * 1000);
+		case 'w': return this.set('day', value);
+		case 'Y': return this.set('year', value);
+		case 'y':
+			value = +value;
+			if (value < 100) value += startCentury + (value < startYear ? 100 : 0);
+			return this.set('year', value);
+		case 'T':
+			if (value == 'Z') value = '+00';
+			var offset = value.match(/([+-])(\d{2}):?(\d{2})?/);
+			offset = (offset[1] + '1') * (offset[2] * 60 + (+offset[3] || 0)) + this.getTimezoneOffset();
+			return this.set('time', this - offset * 60000);
+	return this;
+Date.defineParsers(
+	'%Y([-./]%m([-./]%d((T| )%X)?)?)?', // "1999-12-31", "1999-12-31 11:59pm", "1999-12-31 23:59:59", ISO8601
+	'%Y%m%d(T%H(%M%S?)?)?', // "19991231", "19991231T1159", compact
+	'%x( %X)?', // "12/31", "12.31.99", "12-31-1999", "12/31/2008 11:59 PM"
+	'%d%o( %b( %Y)?)?( %X)?', // "31st", "31st December", "31 Dec 1999", "31 Dec 1999 11:59pm"
+	'%b( %d%o)?( %Y)?( %X)?', // Same as above with month and day switched
+	'%Y %b( %d%o( %X)?)?', // Same as above with year coming first
+	'%o %b %d %X %T %Y' // "Thu Oct 22 08:11:23 +0000 2009"
+MooTools.lang.addEvent('langChange', function(language){
+	if (MooTools.lang.get('Date')) recompile(language);
+}).fireEvent('langChange', MooTools.lang.getCurrentLanguage());
+script: Date.Extras.js
+description: Extends the Date native object to include extra methods (on top of those in Date.js).
+authors:
+ - Aaron Newton
+ - Scott Kyle
+requires:
+ - /Date
+provides: [Date.Extras]
+Date.implement({
+	timeDiffInWords: function(relative_to){
+		return Date.distanceOfTimeInWords(this, relative_to || new Date);
+	timeDiff: function(to, joiner){
+		if (to == null) to = new Date;
+		var delta = ((to - this) / 1000).toInt();
+		if (!delta) return '0s';
+		var durations = {s: 60, m: 60, h: 24, d: 365, y: 0};
+		var duration, vals = [];
+		for (var step in durations){
+			if (!delta) break;
+			if ((duration = durations[step])){
+				vals.unshift((delta % duration) + step);
+				delta = (delta / duration).toInt();
+			} else {
+				vals.unshift(delta + step);
+		return vals.join(joiner || ':');
+Date.alias('timeDiffInWords', 'timeAgoInWords');
+Date.extend({
+	distanceOfTimeInWords: function(from, to){
+		return Date.getTimePhrase(((to - from) / 1000).toInt());
+	getTimePhrase: function(delta){
+		var suffix = (delta < 0) ? 'Until' : 'Ago';
+		if (delta < 0) delta *= -1;
+		var units = {
+			minute: 60,
+			hour: 60,
+			day: 24,
+			week: 7,
+			month: 52 / 12,
+			year: 12,
+			eon: Infinity
+		var msg = 'lessThanMinute';
+		for (var unit in units){
+			var interval = units[unit];
+			if (delta < 1.5 * interval){
+				if (delta > 0.75 * interval) msg = unit;
+				break;
+			delta /= interval;
+			msg = unit + 's';
+		return Date.getMsg(msg + suffix).substitute({delta: delta.round()});
+		// "today", "tomorrow", "yesterday"
+		re: /^(?:tod|tom|yes)/i,
+			var d = new Date().clearTime();
+			switch(bits[0]){
+				case 'tom': return d.increment();
+				case 'yes': return d.decrement();
+				default: 	return d;
+		// "next Wednesday", "last Thursday"
+		re: /^(next|last) ([a-z]+)$/i,
+			var day = d.getDay();
+			var newDay = Date.parseDay(bits[2], true);
+			var addDays = newDay - day;
+			if (newDay <= day) addDays += 7;
+			if (bits[1] == 'last') addDays -= 7;
+			return d.set('date', d.getDate() + addDays);
+script: Hash.Extras.js
+description: Extends the Hash native object to include getFromPath which allows a path notation to child elements.
+authors:
+ - Aaron Newton
+requires:
+ - core:1.2.4/Hash.base
+ - /MooTools.More
+provides: [Hash.Extras]
+Hash.implement({
+	getFromPath: function(notation){
+		var source = this.getClean();
+		notation.replace(/\[([^\]]+)\]|\.([^.[]+)|[^[.]+/g, function(match){
+			if (!source) return null;
+			var prop = arguments[2] || arguments[1] || arguments[0];
+			source = (prop in source) ? source[prop] : null;
+			return match;
+		return source;
+	cleanValues: function(method){
+		method = method || $defined;
+		this.each(function(v, k){
+			if (!method(v)) this.erase(k);
+		}, this);
+		return this;
+	run: function(){
+		var args = arguments;
+			if ($type(v) == 'function') v.run(args);
+script: String.Extras.js
+description: Extends the String native object to include methods useful in managing various kinds of strings (query strings, urls, html, etc).
+authors:
+ - Aaron Newton
+ - Guillermo Rauch
+requires:
+ - core:1.2.4/$util
+provides: [String.Extras]
+(function(){
+var special = ['À','à','Ã?','á','Â','â','Ã','ã','Ä','ä','Ã…','Ã¥','Ä‚','ă','Ä„','Ä…','Ć','ć','ÄŒ','Ä?','Ç','ç', 'ÄŽ','Ä?','Ä?','Ä‘', 'È','è','É','é','Ê','ê','Ë','ë','Äš','Ä›','Ę','Ä™', 'Äž','ÄŸ','ÃŒ','ì','Ã?','í','ÃŽ','î','Ã?','ï', 'Ĺ','ĺ','Ľ','ľ','Å?','Å‚', 'Ñ','ñ','Ň','ň','Ń','Å„','Ã’','ò','Ó','ó','Ô','ô','Õ','õ','Ö','ö','Ø','ø','Å‘','Ř','Å™','Å”','Å•','Å ','Å¡','Åž','ÅŸ','Åš','Å›', 'Ť','Å¥','Ť','Å¥','Å¢','Å£','Ù','ù','Ú','ú','Û','û','Ü','ü','Å®','ů', 'Ÿ','ÿ','ý','Ã?','Ž','ž','Ź','ź','Å»','ż', 'Þ','þ','Ã?','ð','ß','Å’','Å“','Æ','æ','µ'];
+var standard = ['A','a','A','a','A','a','A','a','Ae','ae','A','a','A','a','A','a','C','c','C','c','C','c','D','d','D','d', 'E','e','E','e','E','e','E','e','E','e','E','e','G','g','I','i','I','i','I','i','I','i','L','l','L','l','L','l', 'N','n','N','n','N','n', 'O','o','O','o','O','o','O','o','Oe','oe','O','o','o', 'R','r','R','r', 'S','s','S','s','S','s','T','t','T','t','T','t', 'U','u','U','u','U','u','Ue','ue','U','u','Y','y','Y','y','Z','z','Z','z','Z','z','TH','th','DH','dh','ss','OE','oe','AE','ae','u'];
+var tidymap = {
+	"[\xa0\u2002\u2003\u2009]": " ",
+	"\xb7": "*",
+	"[\u2018\u2019]": "'",
+	"[\u201c\u201d]": '"',
+	"\u2026": "...",
+	"\u2013": "-",
+	"\u2014": "--",
+	"\uFFFD": "&raquo;"
+var getRegForTag = function(tag, contents) {
+	tag = tag || '';
+	var regstr = contents ? "<" + tag + "[^>]*>([\\s\\S]*?)<\/" + tag + ">" : "<\/?" + tag + "([^>]+)?>";
+	reg = new RegExp(regstr, "gi");
+	return reg;
+String.implement({
+	standardize: function(){
+		var text = this;
+		special.each(function(ch, i){
+			text = text.replace(new RegExp(ch, 'g'), standard[i]);
+		return text;
+	repeat: function(times){
+		return new Array(times + 1).join(this);
+	pad: function(length, str, dir){
+		if (this.length >= length) return this;
+		var pad = (str == null ? ' ' : '' + str).repeat(length - this.length).substr(0, length - this.length);
+		if (!dir || dir == 'right') return this + pad;
+		if (dir == 'left') return pad + this;
+		return pad.substr(0, (pad.length / 2).floor()) + this + pad.substr(0, (pad.length / 2).ceil());
+	getTags: function(tag, contents){
+		return this.match(getRegForTag(tag, contents)) || [];
+	stripTags: function(tag, contents){
+		return this.replace(getRegForTag(tag, contents), '');
+	tidy: function(){
+		var txt = this.toString();
+		$each(tidymap, function(value, key){
+			txt = txt.replace(new RegExp(key, 'g'), value);
+		return txt;
+script: String.QueryString.js
+description: Methods for dealing with URI query strings.
+authors:
+ - Sebastian Markbåge, Aaron Newton, Lennart Pilon, Valerio Proietti
+requires:
+ - /MooTools.More
+provides: [String.QueryString]
+String.implement({
+	parseQueryString: function(){
+		var vars = this.split(/[&;]/), res = {};
+		if (vars.length) vars.each(function(val){
+			var index = val.indexOf('='),
+				keys = index < 0 ? [''] : val.substr(0, index).match(/[^\]\[]+/g),
+				value = decodeURIComponent(val.substr(index + 1)),
+				obj = res;
+			keys.each(function(key, i){
+				var current = obj[key];
+				if(i < keys.length - 1)
+					obj = obj[key] = current || {};
+				else if($type(current) == 'array')
+					current.push(value);
+				else
+					obj[key] = $defined(current) ? [current, value] : value;
+		return res;
+	cleanQueryString: function(method){
+		return this.split('&').filter(function(val){
+			key = index < 0 ? '' : val.substr(0, index),
+			value = val.substr(index + 1);
+			return method ? method.run([key, value]) : $chk(value);
+		}).join('&');
+script: URI.js
+description: Provides methods useful in managing the window location and uris.
+authors:
+ - Aaron Newton
+requires:
+ - core:1.2.4/Selectors
+ - /String.QueryString
+provides: URI
+var URI = new Class({
+	options: {
+		/*base: false*/
+	regex: /^(?:(\w+):)?(?:\/\/(?:(?:([^:@\/]*):?([^:@\/]*))?@)?([^:\/?#]*)(?::(\d*))?)?(\.\.?$|(?:[^?#\/]*\/)*)([^?#]*)(?:\?([^#]*))?(?:#(.*))?/,
+	parts: ['scheme', 'user', 'password', 'host', 'port', 'directory', 'file', 'query', 'fragment'],
+	schemes: {http: 80, https: 443, ftp: 21, rtsp: 554, mms: 1755, file: 0},
+	initialize: function(uri, options){
+		var base = this.options.base || URI.base;
+		if(!uri) uri = base;
+		if (uri && uri.parsed) this.parsed = $unlink(uri.parsed);
+		else this.set('value', uri.href || uri.toString(), base ? new URI(base) : false);
+	parse: function(value, base){
+		var bits = value.match(this.regex);
+		if (!bits) return false;
+		bits.shift();
+		return this.merge(bits.associate(this.parts), base);
+	merge: function(bits, base){
+		if ((!bits || !bits.scheme) && (!base || !base.scheme)) return false;
+		if (base){
+			this.parts.every(function(part){
+				if (bits[part]) return false;
+				bits[part] = base[part] || '';
+				return true;
+		bits.port = bits.port || this.schemes[bits.scheme.toLowerCase()];
+		bits.directory = bits.directory ? this.parseDirectory(bits.directory, base ? base.directory : '') : '/';
+		return bits;
+	parseDirectory: function(directory, baseDirectory) {
+		directory = (directory.substr(0, 1) == '/' ? '' : (baseDirectory || '/')) + directory;
+		if (!directory.test(URI.regs.directoryDot)) return directory;
+		var result = [];
+		directory.replace(URI.regs.endSlash, '').split('/').each(function(dir){
+			if (dir == '..' && result.length > 0) result.pop();
+			else if (dir != '.') result.push(dir);
+		return result.join('/') + '/';
+	combine: function(bits){
+		return bits.value || bits.scheme + '://' +
+			(bits.user ? bits.user + (bits.password ? ':' + bits.password : '') + '@' : '') +
+			(bits.host || '') + (bits.port && bits.port != this.schemes[bits.scheme] ? ':' + bits.port : '') +
+			(bits.directory || '/') + (bits.file || '') +
+			(bits.query ? '?' + bits.query : '') +
+			(bits.fragment ? '#' + bits.fragment : '');
+	set: function(part, value, base){
+		if (part == 'value'){
+			var scheme = value.match(URI.regs.scheme);
+			if (scheme) scheme = scheme[1];
+			if (scheme && !$defined(this.schemes[scheme.toLowerCase()])) this.parsed = { scheme: scheme, value: value };
+			else this.parsed = this.parse(value, (base || this).parsed) || (scheme ? { scheme: scheme, value: value } : { value: value });
+		} else if (part == 'data') {
+			this.setData(value);
+		} else {
+			this.parsed[part] = value;
+		return this;
+	get: function(part, base){
+		switch(part){
+			case 'value': return this.combine(this.parsed, base ? base.parsed : false);
+			case 'data' : return this.getData();
+		return this.parsed[part] || '';
+	go: function(){
+		document.location.href = this.toString();
+	toURI: function(){
+		return this;
+	getData: function(key, part){
+		var qs = this.get(part || 'query');
+		if (!$chk(qs)) return key ? null : {};
+		var obj = qs.parseQueryString();
+		return key ? obj[key] : obj;
+	setData: function(values, merge, part){
+		if (typeof values == 'string'){
+			data = this.getData();
+			data[arguments[0]] = arguments[1];
+			values = data;
+		} else if (merge) {
+			values = $merge(this.getData(), values);
+		return this.set(part || 'query', Hash.toQueryString(values));
+	clearData: function(part){
+		return this.set(part || 'query', '');
+URI.prototype.toString = URI.prototype.valueOf = function(){
+	return this.get('value');
+URI.regs = {
+	endSlash: /\/$/,
+	scheme: /^(\w+):/,
+	directoryDot: /\.\/|\.$/
+URI.base = new URI(document.getElements('base[href]', true).getLast(), {base: document.location});
+String.implement({
+	toURI: function(options){
+		return new URI(this, options);
+script: URI.Relative.js
+description: Extends the URI class to add methods for computing relative and absolute urls.
+license: MIT-style license
+authors:
+requires:
+ - /Class.refactor
+ - /URI
+provides: [URI.Relative]
+URI = Class.refactor(URI, {
+	combine: function(bits, base){
+		if (!base || bits.scheme != base.scheme || bits.host != base.host || bits.port != base.port)
+			return this.previous.apply(this, arguments);
+		var end = bits.file + (bits.query ? '?' + bits.query : '') + (bits.fragment ? '#' + bits.fragment : '');
+		if (!base.directory) return (bits.directory || (bits.file ? '' : './')) + end;
+		var baseDir = base.directory.split('/'),
+			relDir = bits.directory.split('/'),
+			path = '',
+			offset;
+		var i = 0;
+		for(offset = 0; offset < baseDir.length && offset < relDir.length && baseDir[offset] == relDir[offset]; offset++);
+		for(i = 0; i < baseDir.length - offset - 1; i++) path += '../';
+		for(i = offset; i < relDir.length - 1; i++) path += relDir[i] + '/';
+		return (path || (bits.file ? '' : './')) + end;
+	toAbsolute: function(base){
+		base = new URI(base);
+		if (base) base.set('directory', '').set('file', '');
+		return this.toRelative(base);
+	toRelative: function(base){
+		return this.get('value', new URI(base));
+script: Element.Forms.js
+description: Extends the Element native object to include methods useful in managing inputs.
+authors:
+ - Aaron Newton
+requires:
+ - /MooTools.More
+provides: [Element.Forms]
+Element.implement({
+	tidy: function(){
+		this.set('value', this.get('value').tidy());
+	getTextInRange: function(start, end){
+		return this.get('value').substring(start, end);
+	getSelectedText: function(){
+		if (this.setSelectionRange) return this.getTextInRange(this.getSelectionStart(), this.getSelectionEnd());
+		return document.selection.createRange().text;
+	getSelectedRange: function() {
+		if ($defined(this.selectionStart)) return {start: this.selectionStart, end: this.selectionEnd};
+		var pos = {start: 0, end: 0};
+		var range = this.getDocument().selection.createRange();
+		if (!range || range.parentElement() != this) return pos;
+		var dup = range.duplicate();
+		if (this.type == 'text') {
+			pos.start = 0 - dup.moveStart('character', -100000);
+			pos.end = pos.start + range.text.length;
+		} else {
+			var value = this.get('value');
+			var offset = value.length;
+			dup.moveToElementText(this);
+			dup.setEndPoint('StartToEnd', range);
+			if(dup.text.length) offset -= value.match(/[\n\r]*$/)[0].length;
+			pos.end = offset - dup.text.length;
+			dup.setEndPoint('StartToStart', range);
+			pos.start = offset - dup.text.length;
+		return pos;
+	getSelectionStart: function(){
+		return this.getSelectedRange().start;
+	getSelectionEnd: function(){
+		return this.getSelectedRange().end;
+	setCaretPosition: function(pos){
+		if (pos == 'end') pos = this.get('value').length;
+		this.selectRange(pos, pos);
+		return this;
+	getCaretPosition: function(){
+	selectRange: function(start, end){
+		if (this.setSelectionRange) {
+			this.focus();
+			this.setSelectionRange(start, end);
+		} else {
+			var diff = value.substr(start, end - start).replace(/\r/g, '').length;
+			start = value.substr(0, start).replace(/\r/g, '').length;
+			var range = this.createTextRange();
+			range.collapse(true);
+			range.moveEnd('character', start + diff);
+			range.moveStart('character', start);
+			range.select();
+		return this;
+	insertAtCursor: function(value, select){
+		var pos = this.getSelectedRange();
+		var text = this.get('value');
+		this.set('value', text.substring(0, pos.start) + value + text.substring(pos.end, text.length));
+		if ($pick(select, true)) this.selectRange(pos.start, pos.start + value.length);
+		else this.setCaretPosition(pos.start + value.length);
+		return this;
+	insertAroundCursor: function(options, select){
+			before: '',
+			defaultMiddle: '',
+			after: ''
+		}, options);
+		var value = this.getSelectedText() || options.defaultMiddle;
+		if (pos.start == pos.end){
+			this.set('value', text.substring(0, pos.start) + options.before + value + options.after + text.substring(pos.end, text.length));
+			this.selectRange(pos.start + options.before.length, pos.end + options.before.length + value.length);
+		} else {
+			var current = text.substring(pos.start, pos.end);
+			this.set('value', text.substring(0, pos.start) + options.before + current + options.after + text.substring(pos.end, text.length));
+			var selStart = pos.start + options.before.length;
+			if ($pick(select, true)) this.selectRange(selStart, selStart + current.length);
+			else this.setCaretPosition(selStart + text.length);
+		return this;
+script: Elements.From.js
+description: Returns a collection of elements from a string of html.
+authors:
+ - Aaron Newton
+requires:
+ - /MooTools.More
+provides: [Elements.from]
+Elements.from = function(text, excludeScripts){
+	if ($pick(excludeScripts, true)) text = text.stripScripts();
+	var container, match = text.match(/^\s*<(t[dhr]|tbody|tfoot|thead)/i);
+	if (match){
+		container = new Element('table');
+		var tag = match[1].toLowerCase();
+		if (['td', 'th', 'tr'].contains(tag)){
+			container = new Element('tbody').inject(container);
+			if (tag != 'tr') container = new Element('tr').inject(container);
+	return (container || new Element('div')).set('html', text).getChildren();
+script: Element.Delegation.js
+description: Extends the Element native object to include the delegate method for more efficient event management.
+credits:
+ - "Event checking based on the work of Daniel Steigerwald. License: MIT-style license.	Copyright: Copyright (c) 2008 Daniel Steigerwald, daniel.steigerwald.cz"
+authors:
+ - Aaron Newton
+ - Daniel Steigerwald
+requires:
+ - /MooTools.More
+provides: [Element.Delegation]
+(function(addEvent, removeEvent){
+	var match = /(.*?):relay\(([^)]+)\)$/,
+		combinators = /[+>~\s]/,
+		splitType = function(type){
+			var bits = type.match(match);
+			return !bits ? {event: type} : {
+				event: bits[1],
+				selector: bits[2]
+		check = function(e, selector){
+			var t = e.target;
+			if (combinators.test(selector = selector.trim())){
+				var els = this.getElements(selector);
+				for (var i = els.length; i--; ){
+					var el = els[i];
+					if (t == el || el.hasChild(t)) return el;
+			} else {
+				for ( ; t && t != this; t = t.parentNode){
+					if (Element.match(t, selector)) return document.id(t);
+			return null;
+		addEvent: function(type, fn){
+			var splitted = splitType(type);
+			if (splitted.selector){
+				var monitors = this.retrieve('$moo:delegateMonitors', {});
+				if (!monitors[type]){
+					var monitor = function(e){
+						var el = check.call(this, e, splitted.selector);
+						if (el) this.fireEvent(type, [e, el], 0, el);
+					}.bind(this);
+					monitors[type] = monitor;
+					addEvent.call(this, splitted.event, monitor);
+			return addEvent.apply(this, arguments);
+		removeEvent: function(type, fn){
+				var events = this.retrieve('events');
+				if (!events || !events[type] || (fn && !events[type].keys.contains(fn))) return this;
+				if (fn) removeEvent.apply(this, [type, fn]);
+				else removeEvent.apply(this, type);
+				events = this.retrieve('events');
+				if (events && events[type] && events[type].keys.length == 0){
+					removeEvent.apply(this, [splitted.event, monitors[type]]);
+					delete monitors[type];
+				return this;
+			return removeEvent.apply(this, arguments);
+		fireEvent: function(type, args, delay, bind){
+			if (!events || !events[type]) return this;
+			events[type].keys.each(function(fn){
+				fn.create({bind: bind || this, delay: delay, arguments: args})();
+			}, this);
+			return this;
+})(Element.prototype.addEvent, Element.prototype.removeEvent);/*
+script: Element.Measure.js
+description: Extends the Element native object to include methods useful in measuring dimensions.
+credits: "Element.measure / .expose methods by Daniel Steigerwald License: MIT-style license. Copyright: Copyright (c) 2008 Daniel Steigerwald, daniel.steigerwald.cz"
+authors:
+ - Aaron Newton
+requires:
+ - core:1.2.4/Element.Style
+ - core:1.2.4/Element.Dimensions
+ - /MooTools.More
+provides: [Element.Measure]
+	measure: function(fn){
+		var vis = function(el) {
+			return !!(!el || el.offsetHeight || el.offsetWidth);
+		if (vis(this)) return fn.apply(this);
+		var parent = this.getParent(),
+			restorers = [],
+			toMeasure = [];
+		while (!vis(parent) && parent != document.body) {
+			toMeasure.push(parent.expose());
+			parent = parent.getParent();
+		var restore = this.expose();
+		var result = fn.apply(this);
+		restore();
+		toMeasure.each(function(restore){
+			restore();
+		return result;
+	expose: function(){
+		if (this.getStyle('display') != 'none') return $empty;
+		var before = this.style.cssText;
+		this.setStyles({
+			display: 'block',
+			position: 'absolute',
+			visibility: 'hidden'
+		return function(){
+			this.style.cssText = before;
+		}.bind(this);
+	getDimensions: function(options){
+		options = $merge({computeSize: false},options);
+		var dim = {};
+		var getSize = function(el, options){
+			return (options.computeSize)?el.getComputedSize(options):el.getSize();
+		var parent = this.getParent('body');
+		if (parent && this.getStyle('display') == 'none'){
+			dim = this.measure(function(){
+				return getSize(this, options);
+		} else if (parent){
+			try { //safari sometimes crashes here, so catch it
+				dim = getSize(this, options);
+			}catch(e){}
+		} else {
+			dim = {x: 0, y: 0};
+		return $chk(dim.x) ? $extend(dim, {width: dim.x, height: dim.y}) : $extend(dim, {x: dim.width, y: dim.height});
+	getComputedSize: function(options){
+			styles: ['padding','border'],
+			plains: {
+				height: ['top','bottom'],
+				width: ['left','right']
+			mode: 'both'
+		}, options);
+		var size = {width: 0,height: 0};
+		switch (options.mode){
+			case 'vertical':
+				delete size.width;
+				delete options.plains.width;
+				break;
+			case 'horizontal':
+				delete size.height;
+				delete options.plains.height;
+				break;
+		var getStyles = [];
+		//this function might be useful in other places; perhaps it should be outside this function?
+		$each(options.plains, function(plain, key){
+			plain.each(function(edge){
+				options.styles.each(function(style){
+					getStyles.push((style == 'border') ? style + '-' + edge + '-' + 'width' : style + '-' + edge);
+		var styles = {};
+		getStyles.each(function(style){ styles[style] = this.getComputedStyle(style); }, this);
+		var subtracted = [];
+		$each(options.plains, function(plain, key){ //keys: width, height, plains: ['left', 'right'], ['top','bottom']
+			var capitalized = key.capitalize();
+			size['total' + capitalized] = size['computed' + capitalized] = 0;
+			plain.each(function(edge){ //top, left, right, bottom
+				size['computed' + edge.capitalize()] = 0;
+				getStyles.each(function(style, i){ //padding, border, etc.
+					//'padding-left'.test('left') size['totalWidth'] = size['width'] + [padding-left]
+					if (style.test(edge)){
+						styles[style] = styles[style].toInt() || 0; //styles['padding-left'] = 5;
+						size['total' + capitalized] = size['total' + capitalized] + styles[style];
+						size['computed' + edge.capitalize()] = size['computed' + edge.capitalize()] + styles[style];
+					//if width != width (so, padding-left, for instance), then subtract that from the total
+					if (style.test(edge) && key != style &&
+						(style.test('border') || style.test('padding')) && !subtracted.contains(style)){
+						subtracted.push(style);
+						size['computed' + capitalized] = size['computed' + capitalized]-styles[style];
+		['Width', 'Height'].each(function(value){
+			var lower = value.toLowerCase();
+			if(!$chk(size[lower])) return;
+			size[lower] = size[lower] + this['offset' + value] + size['computed' + value];
+			size['total' + value] = size[lower] + size['total' + value];
+			delete size['computed' + value];
+		}, this);
+		return $extend(styles, size);
+script: Element.Pin.js
+description: Extends the Element native object to include the pin method useful for fixed positioning for elements.
+authors:
+ - Aaron Newton
+requires:
+ - /MooTools.More
+provides: [Element.Pin]
+(function(){
+	var supportsPositionFixed = false;
+	window.addEvent('domready', function(){
+		var test = new Element('div').setStyles({
+			position: 'fixed',
+			top: 0,
+			right: 0
+		}).inject(document.body);
+		supportsPositionFixed = (test.offsetTop === 0);
+		test.dispose();
+		pin: function(enable){
+			if (this.getStyle('display') == 'none') return null;
+			var p,
+					scroll = window.getScroll();
+			if (enable !== false){
+				p = this.getPosition();
+				if (!this.retrieve('pinned')){
+					var pos = {
+						top: p.y - scroll.y,
+						left: p.x - scroll.x
+					if (supportsPositionFixed){
+						this.setStyle('position', 'fixed').setStyles(pos);
+					} else {
+						this.store('pinnedByJS', true);
+						this.setStyles({
+							top: p.y,
+							left: p.x
+						}).addClass('isPinned');
+						this.store('scrollFixer', (function(){
+							if (this.retrieve('pinned'))
+								var scroll = window.getScroll();
+								this.setStyles({
+									top: pos.top.toInt() + scroll.y,
+									left: pos.left.toInt() + scroll.x
+						}).bind(this));
+						window.addEvent('scroll', this.retrieve('scrollFixer'));
+					this.store('pinned', true);
+			} else {
+				var op;
+				if (!Browser.Engine.trident){
+					var parent = this.getParent();
+					op = (parent.getComputedStyle('position') != 'static' ? parent : parent.getOffsetParent());
+				p = this.getPosition(op);
+				this.store('pinned', false);
+				var reposition;
+				if (supportsPositionFixed && !this.retrieve('pinnedByJS')){
+					reposition = {
+						top: p.y + scroll.y,
+						left: p.x + scroll.x
+				} else {
+					this.store('pinnedByJS', false);
+					window.removeEvent('scroll', this.retrieve('scrollFixer'));
+					reposition = {
+						top: p.y,
+						left: p.x
+				this.setStyles($merge(reposition, {position: 'absolute'})).removeClass('isPinned');
+			return this;
+		unpin: function(){
+			return this.pin(false);
+		togglepin: function(){
+			this.pin(!this.retrieve('pinned'));
+script: Element.Position.js
+description: Extends the Element native object to include methods useful positioning elements relative to others.
+authors:
+ - Aaron Newton
+requires:
+ - /Element.Measure
+provides: [Elements.Position]
+(function(){
+var original = Element.prototype.position;
+	position: function(options){
+		//call original position if the options are x/y values
+		if (options && ($defined(options.x) || $defined(options.y))) return original ? original.apply(this, arguments) : this;
+		$each(options||{}, function(v, k){ if (!$defined(v)) delete options[k]; });
+			// minimum: { x: 0, y: 0 },
+			// maximum: { x: 0, y: 0},
+			relativeTo: document.body,
+			position: {
+				x: 'center', //left, center, right
+				y: 'center' //top, center, bottom
+			edge: false,
+			offset: {x: 0, y: 0},
+			returnPos: false,
+			relFixedPosition: false,
+			ignoreMargins: false,
+			ignoreScroll: false,
+			allowNegative: false
+		}, options);
+		//compute the offset of the parent positioned element if this element is in one
+		var parentOffset = {x: 0, y: 0},
+				parentPositioned = false;
+		/* dollar around getOffsetParent should not be necessary, but as it does not return
+		 * a mootools extended element in IE, an error occurs on the call to expose. See:
+		 * http://mootools.lighthouseapp.com/projects/2706/tickets/333-element-getoffsetparent-inconsistency-between-ie-and-other-browsers */
+		var offsetParent = this.measure(function(){
+			return document.id(this.getOffsetParent());
+		if (offsetParent && offsetParent != this.getDocument().body){
+			parentOffset = offsetParent.measure(function(){
+				return this.getPosition();
+			parentPositioned = offsetParent != document.id(options.relativeTo);
+			options.offset.x = options.offset.x - parentOffset.x;
+			options.offset.y = options.offset.y - parentOffset.y;
+		//upperRight, bottomRight, centerRight, upperLeft, bottomLeft, centerLeft
+		//topRight, topLeft, centerTop, centerBottom, center
+		var fixValue = function(option){
+			if ($type(option) != 'string') return option;
+			option = option.toLowerCase();
+			var val = {};
+			if (option.test('left')) val.x = 'left';
+			else if (option.test('right')) val.x = 'right';
+			else val.x = 'center';
+			if (option.test('upper') || option.test('top')) val.y = 'top';
+			else if (option.test('bottom')) val.y = 'bottom';
+			else val.y = 'center';
+			return val;
+		options.edge = fixValue(options.edge);
+		options.position = fixValue(options.position);
+		if (!options.edge){
+			if (options.position.x == 'center' && options.position.y == 'center') options.edge = {x:'center', y:'center'};
+			else options.edge = {x:'left', y:'top'};
+		this.setStyle('position', 'absolute');
+		var rel = document.id(options.relativeTo) || document.body,
+				calc = rel == document.body ? window.getScroll() : rel.getPosition(),
+				top = calc.y, left = calc.x;
+		var dim = this.getDimensions({computeSize: true, styles:['padding', 'border','margin']});
+		var pos = {},
+				prefY = options.offset.y,
+				prefX = options.offset.x,
+				winSize = window.getSize();
+		switch(options.position.x){
+			case 'left':
+				pos.x = left + prefX;
+				break;
+			case 'right':
+				pos.x = left + prefX + rel.offsetWidth;
+				break;
+			default: //center
+				pos.x = left + ((rel == document.body ? winSize.x : rel.offsetWidth)/2) + prefX;
+				break;
+		switch(options.position.y){
+			case 'top':
+				pos.y = top + prefY;
+				break;
+			case 'bottom':
+				pos.y = top + prefY + rel.offsetHeight;
+				break;
+			default: //center
+				pos.y = top + ((rel == document.body ? winSize.y : rel.offsetHeight)/2) + prefY;
+				break;
+		if (options.edge){
+			var edgeOffset = {};
+			switch(options.edge.x){
+				case 'left':
+					edgeOffset.x = 0;
+					break;
+				case 'right':
+					edgeOffset.x = -dim.x-dim.computedRight-dim.computedLeft;
+					break;
+				default: //center
+					edgeOffset.x = -(dim.totalWidth/2);
+					break;
+			switch(options.edge.y){
+				case 'top':
+					edgeOffset.y = 0;
+					break;
+				case 'bottom':
+					edgeOffset.y = -dim.y-dim.computedTop-dim.computedBottom;
+					break;
+				default: //center
+					edgeOffset.y = -(dim.totalHeight/2);
+					break;
+			pos.x += edgeOffset.x;
+			pos.y += edgeOffset.y;
+		pos = {
+			left: ((pos.x >= 0 || parentPositioned || options.allowNegative) ? pos.x : 0).toInt(),
+			top: ((pos.y >= 0 || parentPositioned || options.allowNegative) ? pos.y : 0).toInt()
+		var xy = {left: 'x', top: 'y'};
+		['minimum', 'maximum'].each(function(minmax) {
+			['left', 'top'].each(function(lr) {
+				var val = options[minmax] ? options[minmax][xy[lr]] : null;
+				if (val != null && pos[lr] < val) pos[lr] = val;
+		if (rel.getStyle('position') == 'fixed' || options.relFixedPosition){
+			var winScroll = window.getScroll();
+			pos.top+= winScroll.y;
+			pos.left+= winScroll.x;
+		if (options.ignoreScroll) {
+			var relScroll = rel.getScroll();
+			pos.top-= relScroll.y;
+			pos.left-= relScroll.x;
+		if (options.ignoreMargins) {
+			pos.left += (
+				options.edge.x == 'right' ? dim['margin-right'] :
+				options.edge.x == 'center' ? -dim['margin-left'] + ((dim['margin-right'] + dim['margin-left'])/2) :
+					- dim['margin-left']
+			pos.top += (
+				options.edge.y == 'bottom' ? dim['margin-bottom'] :
+				options.edge.y == 'center' ? -dim['margin-top'] + ((dim['margin-bottom'] + dim['margin-top'])/2) :
+					- dim['margin-top']
+		pos.left = Math.ceil(pos.left);
+		pos.top = Math.ceil(pos.top);
+		if (options.returnPos) return pos;
+		else this.setStyles(pos);
+		return this;
+script: Element.Shortcuts.js
+description: Extends the Element native object to include some shortcut methods.
+authors:
+ - Aaron Newton
+requires:
+ - /MooTools.More
+provides: [Element.Shortcuts]
+	isDisplayed: function(){
+		return this.getStyle('display') != 'none';
+	isVisible: function(){
+		var w = this.offsetWidth,
+			h = this.offsetHeight;
+		return (w == 0 && h == 0) ? false : (w > 0 && h > 0) ? true : this.isDisplayed();
+	toggle: function(){
+		return this[this.isDisplayed() ? 'hide' : 'show']();
+	hide: function(){
+		var d;
+		try {
+			//IE fails here if the element is not in the dom
+			d = this.getStyle('display');
+		} catch(e){}
+		return this.store('originalDisplay', d || '').setStyle('display', 'none');
+	show: function(display){
+		display = display || this.retrieve('originalDisplay') || 'block';
+		return this.setStyle('display', (display == 'none') ? 'block' : display);
+	swapClass: function(remove, add){
+		return this.removeClass(remove).addClass(add);
+script: IframeShim.js
+description: Defines IframeShim, a class for obscuring select lists and flash objects in IE.
+authors:
+ - Aaron Newton
+requires:
+ - core:1.2.4/Options Events
+ - /Element.Position
+ - /Class.Occlude
+provides: [IframeShim]
+var IframeShim = new Class({
+	Implements: [Options, Events, Class.Occlude],
+	options: {
+		className: 'iframeShim',
+		src: 'javascript:false;document.write("");',
+		display: false,
+		zIndex: null,
+		margin: 0,
+		browsers: (Browser.Engine.trident4 || (Browser.Engine.gecko && !Browser.Engine.gecko19 && Browser.Platform.mac))
+	property: 'IframeShim',
+	initialize: function(element, options){
+		this.element = document.id(element);
+		if (this.occlude()) return this.occluded;
+		this.setOptions(options);
+		this.makeShim();
+		return this;
+	makeShim: function(){
+		if(this.options.browsers){
+			var zIndex = this.element.getStyle('zIndex').toInt();
+			if (!zIndex){
+				zIndex = 1;
+				var pos = this.element.getStyle('position');
+				if (pos == 'static' || !pos) this.element.setStyle('position', 'relative');
+				this.element.setStyle('zIndex', zIndex);
+			zIndex = ($chk(this.options.zIndex) && zIndex > this.options.zIndex) ? this.options.zIndex : zIndex - 1;
+			if (zIndex < 0) zIndex = 1;
+			this.shim = new Element('iframe', {
+				src: this.options.src,
+				scrolling: 'no',
+				frameborder: 0,
+				styles: {
+					zIndex: zIndex,
+					border: 'none',
+					filter: 'progid:DXImageTransform.Microsoft.Alpha(style=0,opacity=0)'
+				'class': this.options.className
+			}).store('IframeShim', this);
+			var inject = (function(){
+				this.shim.inject(this.element, 'after');
+				this[this.options.display ? 'show' : 'hide']();
+				this.fireEvent('inject');
+			}).bind(this);
+			if (!IframeShim.ready) window.addEvent('load', inject);
+			else inject();
+		} else {
+			this.position = this.hide = this.show = this.dispose = $lambda(this);
+	position: function(){
+		if (!IframeShim.ready || !this.shim) return this;
+		var size = this.element.measure(function(){
+			return this.getSize();
+		if (this.options.margin != undefined){
+			size.x = size.x - (this.options.margin * 2);
+			size.y = size.y - (this.options.margin * 2);
+			this.options.offset.x += this.options.margin;
+			this.options.offset.y += this.options.margin;
+		this.shim.set({width: size.x, height: size.y}).position({
+			relativeTo: this.element,
+			offset: this.options.offset
+		return this;
+	hide: function(){
+		if (this.shim) this.shim.setStyle('display', 'none');
+		return this;
+	show: function(){
+		if (this.shim) this.shim.setStyle('display', 'block');
+		return this.position();
+	dispose: function(){
+		if (this.shim) this.shim.dispose();
+		return this;
+	destroy: function(){
+		if (this.shim) this.shim.destroy();
+		return this;
+window.addEvent('load', function(){
+	IframeShim.ready = true;
+script: Mask.js
+description: Creates a mask element to cover another.
+authors:
+ - Aaron Newton
+requires:
+ - core:1.2.4/Events
+ - /Class.Binds
+ - /IframeShim
+provides: [Mask]
+var Mask = new Class({
+	Implements: [Options, Events],
+	Binds: ['position'],
+	options: {
+		// onShow: $empty,
+		// onHide: $empty,
+		// onDestroy: $empty,
+		// onClick: $empty,
+		//inject: {
+		//  where: 'after',
+		//  target: null,
+		// hideOnClick: false,
+		// id: null,
+		// destroyOnHide: false,
+		style: {},
+		'class': 'mask',
+		maskMargins: false,
+		useIframeShim: true,
+		iframeShimOptions: {}
+	initialize: function(target, options){
+		this.target = document.id(target) || document.id(document.body);
+		this.target.store('Mask', this);
+		this.render();
+		this.inject();
+	render: function() {
+		this.element = new Element('div', {
+			'class': this.options['class'],
+			id: this.options.id || 'mask-' + $time(),
+			styles: $merge(this.options.style, {
+				display: 'none'
+			events: {
+				click: function(){
+					this.fireEvent('click');
+					if (this.options.hideOnClick) this.hide();
+				}.bind(this)
+		this.hidden = true;
+	toElement: function(){
+		return this.element;
+	inject: function(target, where){
+		where = where || this.options.inject ? this.options.inject.where : '' || this.target == document.body ? 'inside' : 'after';
+		target = target || this.options.inject ? this.options.inject.target : '' || this.target;
+		this.element.inject(target, where);
+		if (this.options.useIframeShim) {
+			this.shim = new IframeShim(this.element, this.options.iframeShimOptions);
+			this.addEvents({
+				show: this.shim.show.bind(this.shim),
+				hide: this.shim.hide.bind(this.shim),
+				destroy: this.shim.destroy.bind(this.shim)
+		this.resize(this.options.width, this.options.height);
+		this.element.position({
+			relativeTo: this.target,
+			position: 'topLeft',
+			ignoreMargins: !this.options.maskMargins,
+			ignoreScroll: this.target == document.body
+		return this;
+	resize: function(x, y){
+		var opt = {
+			styles: ['padding', 'border']
+		if (this.options.maskMargins) opt.styles.push('margin');
+		var dim = this.target.getComputedSize(opt);
+		if (this.target == document.body) {
+			var win = window.getSize();
+			if (dim.totalHeight < win.y) dim.totalHeight = win.y;
+			if (dim.totalWidth < win.x) dim.totalWidth = win.x;
+		this.element.setStyles({
+			width: $pick(x, dim.totalWidth, dim.x),
+			height: $pick(y, dim.totalHeight, dim.y)
+		return this;
+	show: function(){
+		if (!this.hidden) return this;
+		window.addEvent('resize', this.position);
+		this.position();
+		this.showMask.apply(this, arguments);
+		return this;
+	showMask: function(){
+		this.element.setStyle('display', 'block');
+		this.hidden = false;
+		this.fireEvent('show');
+	hide: function(){
+		if (this.hidden) return this;
+		window.removeEvent('resize', this.position);
+		this.hideMask.apply(this, arguments);
+		if (this.options.destroyOnHide) return this.destroy();
+		return this;
+	hideMask: function(){
+		this.element.setStyle('display', 'none');
+		this.fireEvent('hide');
+		this[this.hidden ? 'show' : 'hide']();
+		this.hide();
+		this.element.destroy();
+		this.fireEvent('destroy');
+		this.target.eliminate('mask');
+Element.Properties.mask = {
+	set: function(options){
+		var mask = this.retrieve('mask');
+		return this.eliminate('mask').store('mask:options', options);
+	get: function(options){
+		if (options || !this.retrieve('mask')){
+			if (this.retrieve('mask')) this.retrieve('mask').destroy();
+			if (options || !this.retrieve('mask:options')) this.set('mask', options);
+			this.store('mask', new Mask(this, this.retrieve('mask:options')));
+		return this.retrieve('mask');
+	mask: function(options){
+		this.get('mask', options).show();
+		return this;
+	unmask: function(){
+		this.get('mask').hide();
+		return this;
+script: Spinner.js
+description: Adds a semi-transparent overlay over a dom element with a spinnin ajax icon.
+authors:
+ - Aaron Newton
+requires:
+ - core:1.2.4/Fx.Tween
+ - /Class.refactor
+ - /Mask
+provides: [Spinner]
+var Spinner = new Class({
+	Extends: Mask,
+	options: {
+		/*message: false,*/
+		'class':'spinner',
+		containerPosition: {},
+		content: {
+			'class':'spinner-content'
+		messageContainer: {
+			'class':'spinner-msg'
+		img: {
+			'class':'spinner-img'
+		fxOptions: {
+			link: 'chain'
+	initialize: function(){
+		this.parent.apply(this, arguments);
+		this.target.store('spinner', this);
+		//add this to events for when noFx is true; parent methods handle hide/show
+		var deactivate = function(){ this.active = false; }.bind(this);
+		this.addEvents({
+			hide: deactivate,
+			show: deactivate
+	render: function(){
+		this.parent();
+		this.element.set('id', this.options.id || 'spinner-'+$time());
+		this.content = document.id(this.options.content) || new Element('div', this.options.content);
+		this.content.inject(this.element);
+		if (this.options.message) {
+			this.msg = document.id(this.options.message) || new Element('p', this.options.messageContainer).appendText(this.options.message);
+			this.msg.inject(this.content);
+		if (this.options.img) {
+			this.img = document.id(this.options.img) || new Element('div', this.options.img);
+			this.img.inject(this.content);
+		this.element.set('tween', this.options.fxOptions);
+	show: function(noFx){
+		if (this.active) return this.chain(this.show.bind(this));
+		if (!this.hidden) {
+			this.callChain.delay(20, this);
+			return this;
+		this.active = true;
+		return this.parent(noFx);
+	showMask: function(noFx){
+		var pos = function(){
+			this.content.position($merge({
+			}, this.options.containerPosition));
+		}.bind(this);
+		if (noFx) {
+			this.parent();
+			pos();
+		} else {
+				display: 'block',
+				opacity: 0
+			}).tween('opacity', this.options.style.opacity || 0.9);
+			pos();
+			this.callChain();
+	hide: function(noFx){
+		if (this.active) return this.chain(this.hide.bind(this));
+		if (this.hidden) {
+			return this;
+	hideMask: function(noFx){
+		if (noFx) return this.parent();
+		this.element.tween('opacity', 0).get('tween').chain(function(){
+			this.callChain();
+		}.bind(this));
+		this.content.destroy();
+		this.parent();
+		this.target.eliminate('spinner');
+Spinner.implement(new Chain);
+if (window.Request) {
+	Request = Class.refactor(Request, {
+		options: {
+			useSpinner: false,
+			spinnerOptions: {},
+			spinnerTarget: false
+		initialize: function(options){
+			this._send = this.send;
+			this.send = function(options){
+				if (this.spinner) this.spinner.chain(this._send.bind(this, options)).show();
+				else this._send(options);
+				return this;
+			this.previous(options);
+			var update = document.id(this.options.spinnerTarget) || document.id(this.options.update);
+			if (this.options.useSpinner && update) {
+				this.spinner = update.get('spinner', this.options.spinnerOptions);
+				['onComplete', 'onException', 'onCancel'].each(function(event){
+					this.addEvent(event, this.spinner.hide.bind(this.spinner));
+				}, this);
+		getSpinner: function(){
+			return this.spinner;
+Element.Properties.spinner = {
+		var spinner = this.retrieve('spinner');
+		return this.eliminate('spinner').store('spinner:options', options);
+		if (options || !this.retrieve('spinner')){
+			if (this.retrieve('spinner')) this.retrieve('spinner').destroy();
+			if (options || !this.retrieve('spinner:options')) this.set('spinner', options);
+			new Spinner(this, this.retrieve('spinner:options'));
+		return this.retrieve('spinner');
+	spin: function(options){
+		this.get('spinner', options).show();
+		return this;
+	unspin: function(){
+		var opt = Array.link(arguments, {options: Object.type, callback: Function.type});
+		this.get('spinner', opt.options).hide(opt.callback);
+		return this;
+script: Form.Request.js
+description: Handles the basic functionality of submitting a form and updating a dom element with the result.
+authors:
+ - Aaron Newton
+requires:
+ - core:1.2.4/Element.Event
+ - core:1.2.4/Request.HTML
+ - /Class.Binds
+ - /Class.Occlude
+ - /Spinner
+provides: [Form.Request]
+if (!window.Form) window.Form = {};
+(function(){
+	Form.Request = new Class({
+		Binds: ['onSubmit', 'onFormValidate'],
+		options: {
+			//onFailure: $empty,
+			//onSuccess: #empty, //aliased to onComplete,
+			//onSend: $empty
+			requestOptions: {
+				evalScripts: true,
+				useSpinner: true,
+				emulation: false,
+				link: 'ignore'
+			extraData: {},
+			resetForm: true
+		property: 'form.request',
+		initialize: function(form, update, options) {
+			this.element = document.id(form);
+			this.update = document.id(update);
+			this.makeRequest();
+			if (this.options.resetForm) {
+				this.request.addEvent('success', function(){
+					$try(function(){ this.element.reset(); }.bind(this));
+					if (window.OverText) OverText.update();
+				}.bind(this));
+			this.attach();
+		toElement: function() {
+		makeRequest: function(){
+			this.request = new Request.HTML($merge({
+					update: this.update,
+					emulation: false,
+					spinnerTarget: this.element,
+					method: this.element.get('method') || 'post'
+			}, this.options.requestOptions)).addEvents({
+				success: function(text, xml){
+					['complete', 'success'].each(function(evt){
+						this.fireEvent(evt, [this.update, text, xml]);
+					}, this);
+				}.bind(this),
+				failure: function(xhr){
+					this.fireEvent('complete').fireEvent('failure', xhr);
+				}.bind(this),
+				exception: function(){
+					this.fireEvent('failure', xhr);
+				}.bind(this)
+		attach: function(attach){
+			attach = $pick(attach, true);
+			method = attach ? 'addEvent' : 'removeEvent';
+			var fv = this.element.retrieve('validator');
+			if (fv) fv[method]('onFormValidate', this.onFormValidate);
+			if (!fv || !attach) this.element[method]('submit', this.onSubmit);
+		detach: function(){
+			this.attach(false);
+		//public method
+		enable: function(){
+			this.attach();
+		//public method
+		disable: function(){
+			this.detach();
+		onFormValidate: function(valid, form, e) {
+			if (valid || (fv && !fv.options.stopOnFailure)) {
+				if (e && e.stop) e.stop();
+				this.send();
+		onSubmit: function(e){
+			if (this.element.retrieve('validator')) {
+				//form validator was created after Form.Request
+				this.detach();
+				return;
+			e.stop();
+			this.send();
+		send: function(){
+			var str = this.element.toQueryString().trim();
+			var data = $H(this.options.extraData).toQueryString();
+			if (str) str += "&" + data;
+			else str = data;
+			this.fireEvent('send', [this.element, str.parseQueryString()]);
+			this.request.send({data: str, url: this.element.get("action")});
+			return this;
+	Element.Properties.formRequest = {
+		set: function(){
+			var opt = Array.link(arguments, {options: Object.type, update: Element.type, updateId: String.type});
+			var update = opt.update || opt.updateId;
+			var updater = this.retrieve('form.request');
+			if (update) {
+				if (updater) updater.update = document.id(update);
+				this.store('form.request:update', update);
+			if (opt.options) {
+				if (updater) updater.setOptions(opt.options);
+				this.store('form.request:options', opt.options);
+			return this;
+		get: function(){
+			if (opt.options || update || !this.retrieve('form.request')){
+				if (opt.options || !this.retrieve('form.request:options')) this.set('form.request', opt.options);
+				if (update) this.set('form.request', update);
+				this.store('form.request', new Form.Request(this, this.retrieve('form.request:update'), this.retrieve('form.request:options')));
+			return this.retrieve('form.request');
+		formUpdate: function(update, options){
+			this.get('form.request', update, options).send();
+			return this;
+script: Fx.Reveal.js
+description: Defines Fx.Reveal, a class that shows and hides elements with a transition.
+authors:
+ - Aaron Newton
+requires:
+ - core:1.2.4/Fx.Morph
+ - /Element.Shortcuts
+provides: [Fx.Reveal]
+Fx.Reveal = new Class({
+	Extends: Fx.Morph,
+	options: {/*
+		onShow: $empty(thisElement),
+		onHide: $empty(thisElement),
+		onComplete: $empty(thisElement),
+		heightOverride: null,
+		widthOverride: null, */
+		link: 'cancel',
+		styles: ['padding', 'border', 'margin'],
+		transitionOpacity: !Browser.Engine.trident4,
+		mode: 'vertical',
+		display: 'block',
+		hideInputs: Browser.Engine.trident ? 'select, input, textarea, object, embed' : false
+	dissolve: function(){
+		try {
+			if (!this.hiding && !this.showing){
+				if (this.element.getStyle('display') != 'none'){
+					this.hiding = true;
+					this.showing = false;
+					this.cssText = this.element.style.cssText;
+					var startStyles = this.element.getComputedSize({
+						styles: this.options.styles,
+						mode: this.options.mode
+					this.element.setStyle('display', this.options.display);
+					if (this.options.transitionOpacity) startStyles.opacity = 1;
+					var zero = {};
+					$each(startStyles, function(style, name){
+						zero[name] = [style, 0];
+					}, this);
+					this.element.setStyle('overflow', 'hidden');
+					var hideThese = this.options.hideInputs ? this.element.getElements(this.options.hideInputs) : null;
+					this.$chain.unshift(function(){
+						if (this.hidden){
+							this.hiding = false;
+								startStyles[name] = style;
+							}, this);
+							this.element.style.cssText = this.cssText;
+							if (hideThese) hideThese.setStyle('visibility', 'visible');
+						this.fireEvent('hide', this.element);
+						this.callChain();
+					}.bind(this));
+					if (hideThese) hideThese.setStyle('visibility', 'hidden');
+					this.start(zero);
+				} else {
+					this.callChain.delay(10, this);
+					this.fireEvent('complete', this.element);
+			} else if (this.options.link == 'chain'){
+				this.chain(this.dissolve.bind(this));
+			} else if (this.options.link == 'cancel' && !this.hiding){
+				this.cancel();
+				this.dissolve();
+		} catch(e){
+		return this;
+	reveal: function(){
+		try {
+			if (!this.showing && !this.hiding){
+				if (this.element.getStyle('display') == 'none' ||
+					 this.element.getStyle('visiblity') == 'hidden' ||
+					 this.element.getStyle('opacity') == 0){
+					this.showing = true;
+					this.hiding = this.hidden =  false;
+					var startStyles;
+					//toggle display, but hide it
+					this.element.measure(function(){
+						//create the styles for the opened/visible state
+						startStyles = this.element.getComputedSize({
+					}.bind(this));
+					//if we're overridding height/width
+					if ($chk(this.options.heightOverride)) startStyles.height = this.options.heightOverride.toInt();
+					if ($chk(this.options.widthOverride)) startStyles.width = this.options.widthOverride.toInt();
+					if (this.options.transitionOpacity) {
+						this.element.setStyle('opacity', 0);
+						startStyles.opacity = 1;
+					//create the zero state for the beginning of the transition
+					var zero = {
+						height: 0,
+						display: this.options.display
+					$each(startStyles, function(style, name){ zero[name] = 0; });
+					//set to zero
+					this.element.setStyles($merge(zero, {overflow: 'hidden'}));
+					//hide inputs
+					//start the effect
+					this.start(startStyles);
+						if (!this.hidden) this.showing = false;
+						this.callChain();
+						this.fireEvent('show', this.element);
+					}.bind(this));
+				} else {
+					this.callChain();
+				this.chain(this.reveal.bind(this));
+			} else if (this.options.link == 'cancel' && !this.showing){
+				this.cancel();
+				this.reveal();
+		} catch(e){
+				display: this.options.display,
+				visiblity: 'visible',
+				opacity: 1
+		return this;
+			this.reveal();
+		} else {
+			this.dissolve();
+		return this;
+	cancel: function(){
+		this.hidding = false;
+Element.Properties.reveal = {
+		var reveal = this.retrieve('reveal');
+		if (reveal) reveal.cancel();
+		return this.eliminate('reveal').store('reveal:options', options);
+		if (options || !this.retrieve('reveal')){
+			if (options || !this.retrieve('reveal:options')) this.set('reveal', options);
+			this.store('reveal', new Fx.Reveal(this, this.retrieve('reveal:options')));
+		return this.retrieve('reveal');
+Element.Properties.dissolve = Element.Properties.reveal;
+	reveal: function(options){
+		this.get('reveal', options).reveal();
+		return this;
+	dissolve: function(options){
+		this.get('reveal', options).dissolve();
+		return this;
+	nix: function(){
+		var params = Array.link(arguments, {destroy: Boolean.type, options: Object.type});
+		this.get('reveal', params.options).dissolve().chain(function(){
+			this[params.destroy ? 'destroy' : 'dispose']();
+		}.bind(this));
+		return this;
+	wink: function(){
+		var params = Array.link(arguments, {duration: Number.type, options: Object.type});
+		var reveal = this.get('reveal', params.options);
+		reveal.reveal().chain(function(){
+			(function(){
+				reveal.dissolve();
+			}).delay(params.duration || 2000);
+script: Form.Request.Append.js
+description: Handles the basic functionality of submitting a form and updating a dom element with the result. The result is appended to the DOM element instead of replacing its contents.
+authors:
+ - Aaron Newton
+requires:
+ - /Form.Request
+ - /Fx.Reveal
+ - /Elements.from
+provides: [Form.Request.Append]
+Form.Request.Append = new Class({
+	Extends: Form.Request,
+	options: {
+		//onBeforeEffect: $empty,
+		useReveal: true,
+		revealOptions: {},
+		inject: 'bottom'
+				url: this.element.get('action'),
+				method: this.element.get('method') || 'post',
+			}, this.options.requestOptions, {
+				evalScripts: false
+		).addEvents({
+			success: function(tree, elements, html, javascript){
+				var container;
+				var kids = Elements.from(html);
+				if (kids.length == 1) {
+					container = kids[0];
+				} else {
+					 container = new Element('div', {
+						styles: {
+							display: 'none'
+					}).adopt(kids);
+				container.inject(this.update, this.options.inject);
+				if (this.options.requestOptions.evalScripts) $exec(javascript);
+				this.fireEvent('beforeEffect', container);
+				var finish = function(){
+					this.fireEvent('success', [container, this.update, tree, elements, html, javascript]);
+				}.bind(this);
+				if (this.options.useReveal) {
+					container.get('reveal', this.options.revealOptions).chain(finish);
+					container.reveal();
+				} else {
+					finish();
+			}.bind(this),
+			}.bind(this)
+script: Form.Validator.English.js
+description: Form Validator messages for English.
+authors:
+ - Aaron Newton
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.English]
+MooTools.lang.set('en-US', 'Form.Validator', {
+	required:'This field is required.',
+	minLength:'Please enter at least {minLength} characters (you entered {length} characters).',
+	maxLength:'Please enter no more than {maxLength} characters (you entered {length} characters).',
+	integer:'Please enter an integer in this field. Numbers with decimals (e.g. 1.25) are not permitted.',
+	numeric:'Please enter only numeric values in this field (i.e. "1" or "1.1" or "-1" or "-1.1").',
+	digits:'Please use numbers and punctuation only in this field (for example, a phone number with dashes or dots is permitted).',
+	alpha:'Please use letters only (a-z) with in this field. No spaces or other characters are allowed.',
+	alphanum:'Please use only letters (a-z) or numbers (0-9) only in this field. No spaces or other characters are allowed.',
+	dateSuchAs:'Please enter a valid date such as {date}',
+	dateInFormatMDY:'Please enter a valid date such as MM/DD/YYYY (i.e. "12/31/1999")',
+	email:'Please enter a valid email address. For example "fred at domain.com".',
+	url:'Please enter a valid URL such as http://www.google.com.',
+	currencyDollar:'Please enter a valid $ amount. For example $100.00 .',
+	oneRequired:'Please enter something for at least one of these inputs.',
+	errorPrefix: 'Error: ',
+	warningPrefix: 'Warning: ',
+	//Form.Validator.Extras
+	noSpace: 'There can be no spaces in this input.',
+	reqChkByNode: 'No items are selected.',
+	requiredChk: 'This field is required.',
+	reqChkByName: 'Please select a {label}.',
+	match: 'This field needs to match the {matchName} field',
+	startDate: 'the start date',
+	endDate: 'the end date',
+	currendDate: 'the current date',
+	afterDate: 'The date should be the same or after {label}.',
+	beforeDate: 'The date should be the same or before {label}.',
+	startMonth: 'Please select a start month',
+	sameMonth: 'These two dates must be in the same month - you must change one or the other.',
+	creditcard: 'The credit card number entered is invalid. Please check the number and try again. {length} digits entered.'
+script: Form.Validator.js
+description: A css-class based form validation system.
+authors:
+ - Aaron Newton
+requires:
+ - core:1.2.4/JSON
+ - /Lang
+ - /Class.Binds
+ - /Date Element.Forms
+ - /Form.Validator.English
+provides: [Form.Validator, InputValidator, FormValidator.BaseValidators]
+var InputValidator = new Class({
+	Implements: [Options],
+	options: {
+		errorMsg: 'Validation failed.',
+		test: function(field){return true;}
+	initialize: function(className, options){
+		this.className = className;
+	test: function(field, props){
+		if (document.id(field)) return this.options.test(document.id(field), props||this.getProps(field));
+		else return false;
+	getError: function(field, props){
+		var err = this.options.errorMsg;
+		if ($type(err) == 'function') err = err(document.id(field), props||this.getProps(field));
+		return err;
+	getProps: function(field){
+		if (!document.id(field)) return {};
+		return field.get('validatorProps');
+Element.Properties.validatorProps = {
+	set: function(props){
+		return this.eliminate('validatorProps').store('validatorProps', props);
+	get: function(props){
+		if (props) this.set(props);
+		if (this.retrieve('validatorProps')) return this.retrieve('validatorProps');
+		if (this.getProperty('validatorProps')){
+			try {
+				this.store('validatorProps', JSON.decode(this.getProperty('validatorProps')));
+			}catch(e){
+				return {};
+		} else {
+			var vals = this.get('class').split(' ').filter(function(cls){
+				return cls.test(':');
+			if (!vals.length){
+				this.store('validatorProps', {});
+			} else {
+				props = {};
+				vals.each(function(cls){
+					var split = cls.split(':');
+					if (split[1]) {
+						try {
+							props[split[0]] = JSON.decode(split[1]);
+						} catch(e) {}
+				this.store('validatorProps', props);
+		return this.retrieve('validatorProps');
+Form.Validator = new Class({
+	Implements:[Options, Events],
+	Binds: ['onSubmit'],
+	options: {/*
+		onFormValidate: $empty(isValid, form, event),
+		onElementValidate: $empty(isValid, field, className, warn),
+		onElementPass: $empty(field),
+		onElementFail: $empty(field, validatorsFailed) */
+		fieldSelectors: 'input, select, textarea',
+		ignoreHidden: true,
+		ignoreDisabled: true,
+		useTitles: false,
+		evaluateOnSubmit: true,
+		evaluateFieldsOnBlur: true,
+		evaluateFieldsOnChange: true,
+		serial: true,
+		stopOnFailure: true,
+		warningPrefix: function(){
+			return Form.Validator.getMsg('warningPrefix') || 'Warning: ';
+		errorPrefix: function(){
+			return Form.Validator.getMsg('errorPrefix') || 'Error: ';
+	initialize: function(form, options){
+		this.element.store('validator', this);
+		this.warningPrefix = $lambda(this.options.warningPrefix)();
+		this.errorPrefix = $lambda(this.options.errorPrefix)();
+		if (this.options.evaluateOnSubmit) this.element.addEvent('submit', this.onSubmit);
+		if (this.options.evaluateFieldsOnBlur || this.options.evaluateFieldsOnChange) this.watchFields(this.getFields());
+	getFields: function(){
+		return (this.fields = this.element.getElements(this.options.fieldSelectors));
+	watchFields: function(fields){
+		fields.each(function(el){
+			if (this.options.evaluateFieldsOnBlur)
+				el.addEvent('blur', this.validationMonitor.pass([el, false], this));
+			if (this.options.evaluateFieldsOnChange)
+				el.addEvent('change', this.validationMonitor.pass([el, true], this));
+		}, this);
+	validationMonitor: function(){
+		$clear(this.timer);
+		this.timer = this.validateField.delay(50, this, arguments);
+	onSubmit: function(event){
+		if (!this.validate(event) && event) event.preventDefault();
+		else this.reset();
+	reset: function(){
+		this.getFields().each(this.resetField, this);
+		return this;
+	validate: function(event){
+		var result = this.getFields().map(function(field){
+			return this.validateField(field, true);
+		}, this).every(function(v){ return v;});
+		this.fireEvent('formValidate', [result, this.element, event]);
+		if (this.options.stopOnFailure && !result && event) event.preventDefault();
+		return result;
+	validateField: function(field, force){
+		if (this.paused) return true;
+		field = document.id(field);
+		var passed = !field.hasClass('validation-failed');
+		var failed, warned;
+		if (this.options.serial && !force){
+			failed = this.element.getElement('.validation-failed');
+			warned = this.element.getElement('.warning');
+		if (field && (!failed || force || field.hasClass('validation-failed') || (failed && !this.options.serial))){
+			var validators = field.className.split(' ').some(function(cn){
+				return this.getValidator(cn);
+			}, this);
+			var validatorsFailed = [];
+			field.className.split(' ').each(function(className){
+				if (className && !this.test(className, field)) validatorsFailed.include(className);
+			}, this);
+			passed = validatorsFailed.length === 0;
+			if (validators && !field.hasClass('warnOnly')){
+				if (passed){
+					field.addClass('validation-passed').removeClass('validation-failed');
+					this.fireEvent('elementPass', field);
+				} else {
+					field.addClass('validation-failed').removeClass('validation-passed');
+					this.fireEvent('elementFail', [field, validatorsFailed]);
+			if (!warned){
+				var warnings = field.className.split(' ').some(function(cn){
+					if (cn.test('^warn-') || field.hasClass('warnOnly'))
+						return this.getValidator(cn.replace(/^warn-/,''));
+					else return null;
+				}, this);
+				field.removeClass('warning');
+				var warnResult = field.className.split(' ').map(function(cn){
+						return this.test(cn.replace(/^warn-/,''), field, true);
+					else return null;
+				}, this);
+		return passed;
+	test: function(className, field, warn){
+		if((this.options.ignoreHidden && !field.isVisible()) || (this.options.ignoreDisabled && field.get('disabled'))) return true;
+		var validator = this.getValidator(className);
+		if (field.hasClass('ignoreValidation')) return true;
+		warn = $pick(warn, false);
+		if (field.hasClass('warnOnly')) warn = true;
+		var isValid = validator ? validator.test(field) : true;
+		if (validator && field.isVisible()) this.fireEvent('elementValidate', [isValid, field, className, warn]);
+		if (warn) return true;
+		return isValid;
+	resetField: function(field){
+		if (field){
+				if (className.test('^warn-')) className = className.replace(/^warn-/, '');
+				field.removeClass('validation-failed');
+				field.removeClass('validation-passed');
+			}, this);
+		return this;
+	stop: function(){
+		this.paused = true;
+		return this;
+	start: function(){
+		this.paused = false;
+		return this;
+	ignoreField: function(field, warn){
+		if (field){
+			this.enforceField(field);
+			if (warn) field.addClass('warnOnly');
+			else field.addClass('ignoreValidation');
+		return this;
+	enforceField: function(field){
+		if (field) field.removeClass('warnOnly').removeClass('ignoreValidation');
+		return this;
+Form.Validator.getMsg = function(key){
+	return MooTools.lang.get('Form.Validator', key);
+Form.Validator.adders = {
+	validators:{},
+	add : function(className, options){
+		this.validators[className] = new InputValidator(className, options);
+		//if this is a class (this method is used by instances of Form.Validator and the Form.Validator namespace)
+		//extend these validators into it
+		//this allows validators to be global and/or per instance
+		if (!this.initialize){
+			this.implement({
+				validators: this.validators
+	addAllThese : function(validators){
+		$A(validators).each(function(validator){
+			this.add(validator[0], validator[1]);
+		}, this);
+	getValidator: function(className){
+		return this.validators[className.split(':')[0]];
+$extend(Form.Validator, Form.Validator.adders);
+Form.Validator.implement(Form.Validator.adders);
+Form.Validator.add('IsEmpty', {
+	errorMsg: false,
+	test: function(element){
+		if (element.type == 'select-one' || element.type == 'select')
+			return !(element.selectedIndex >= 0 && element.options[element.selectedIndex].value != '');
+		else
+			return ((element.get('value') == null) || (element.get('value').length == 0));
+Form.Validator.addAllThese([
+	['required', {
+		errorMsg: function(){
+			return Form.Validator.getMsg('required');
+			return !Form.Validator.getValidator('IsEmpty').test(element);
+	['minLength', {
+		errorMsg: function(element, props){
+			if ($type(props.minLength))
+				return Form.Validator.getMsg('minLength').substitute({minLength:props.minLength,length:element.get('value').length });
+			else return '';
+		test: function(element, props){
+			if ($type(props.minLength)) return (element.get('value').length >= $pick(props.minLength, 0));
+			else return true;
+	['maxLength', {
+			//props is {maxLength:10}
+			if ($type(props.maxLength))
+				return Form.Validator.getMsg('maxLength').substitute({maxLength:props.maxLength,length:element.get('value').length });
+			else return '';
+			//if the value is <= than the maxLength value, element passes test
+			return (element.get('value').length <= $pick(props.maxLength, 10000));
+	['validate-integer', {
+		errorMsg: Form.Validator.getMsg.pass('integer'),
+			return Form.Validator.getValidator('IsEmpty').test(element) || (/^(-?[1-9]\d*|0)$/).test(element.get('value'));
+	['validate-numeric', {
+		errorMsg: Form.Validator.getMsg.pass('numeric'),
+				(/^-?(?:0$0(?=\d*\.)|[1-9]|0)\d*(\.\d+)?$/).test(element.get('value'));
+	['validate-digits', {
+		errorMsg: Form.Validator.getMsg.pass('digits'),
+			return Form.Validator.getValidator('IsEmpty').test(element) || (/^[\d() .:\-\+#]+$/.test(element.get('value')));
+	['validate-alpha', {
+		errorMsg: Form.Validator.getMsg.pass('alpha'),
+			return Form.Validator.getValidator('IsEmpty').test(element) ||  (/^[a-zA-Z]+$/).test(element.get('value'));
+	['validate-alphanum', {
+		errorMsg: Form.Validator.getMsg.pass('alphanum'),
+			return Form.Validator.getValidator('IsEmpty').test(element) || !(/\W/).test(element.get('value'));
+	['validate-date', {
+			if (Date.parse){
+				var format = props.dateFormat || '%x';
+				return Form.Validator.getMsg('dateSuchAs').substitute({date: new Date().format(format)});
+			} else {
+				return Form.Validator.getMsg('dateInFormatMDY');
+			if (Form.Validator.getValidator('IsEmpty').test(element)) return true;
+			var d;
+			if (Date.parse){
+				d = Date.parse(element.get('value'));
+				var formatted = d.format(format);
+				if (formatted != 'invalid date') element.set('value', formatted);
+				return !isNaN(d);
+			} else {
+				var regex = /^(\d{2})\/(\d{2})\/(\d{4})$/;
+				if (!regex.test(element.get('value'))) return false;
+				d = new Date(element.get('value').replace(regex, '$1/$2/$3'));
+				return (parseInt(RegExp.$1, 10) == (1 + d.getMonth())) &&
+					(parseInt(RegExp.$2, 10) == d.getDate()) &&
+					(parseInt(RegExp.$3, 10) == d.getFullYear());
+	['validate-email', {
+		errorMsg: Form.Validator.getMsg.pass('email'),
+			return Form.Validator.getValidator('IsEmpty').test(element) || (/^[A-Z0-9._%+-]+@[A-Z0-9.-]+\.[A-Z]{2,4}$/i).test(element.get('value'));
+	['validate-url', {
+		errorMsg: Form.Validator.getMsg.pass('url'),
+			return Form.Validator.getValidator('IsEmpty').test(element) || (/^(https?|ftp|rmtp|mms):\/\/(([A-Z0-9][A-Z0-9_-]*)(\.[A-Z0-9][A-Z0-9_-]*)+)(:(\d+))?\/?/i).test(element.get('value'));
+	['validate-currency-dollar', {
+		errorMsg: Form.Validator.getMsg.pass('currencyDollar'),
+			// [$]1[##][,###]+[.##]
+			// [$]1###+[.##]
+			// [$]0.##
+			return Form.Validator.getValidator('IsEmpty').test(element) ||  (/^\$?\-?([1-9]{1}[0-9]{0,2}(\,[0-9]{3})*(\.[0-9]{0,2})?|[1-9]{1}\d*(\.[0-9]{0,2})?|0(\.[0-9]{0,2})?|(\.[0-9]{1,2})?)$/).test(element.get('value'));
+	['validate-one-required', {
+		errorMsg: Form.Validator.getMsg.pass('oneRequired'),
+			var p = document.id(props['validate-one-required']) || element.getParent();
+			return p.getElements('input').some(function(el){
+				if (['checkbox', 'radio'].contains(el.get('type'))) return el.get('checked');
+				return el.get('value');
+Element.Properties.validator = {
+		var validator = this.retrieve('validator');
+		if (validator) validator.setOptions(options);
+		return this.store('validator:options');
+		if (options || !this.retrieve('validator')){
+			if (options || !this.retrieve('validator:options')) this.set('validator', options);
+			this.store('validator', new Form.Validator(this, this.retrieve('validator:options')));
+		return this.retrieve('validator');
+	validate: function(options){
+		this.set('validator', options);
+		return this.get('validator', options).validate();
+//legacy
+var FormValidator = Form.Validator;/*
+script: Form.Validator.Inline.js
+description: Extends Form.Validator to add inline messages.
+authors:
+ - Aaron Newton
+requires:
+ - /Form.Validator
+provides: [Form.Validator.Inline]
+Form.Validator.Inline = new Class({
+	Extends: Form.Validator,
+	options: {
+		scrollToErrorsOnSubmit: true,
+		scrollFxOptions: {
+			transition: 'quad:out',
+			offset: {
+				y: -20
+		this.parent(form, options);
+		this.addEvent('onElementValidate', function(isValid, field, className, warn){
+			if (!isValid && validator.getError(field)){
+				if (warn) field.addClass('warning');
+				var advice = this.makeAdvice(className, field, validator.getError(field), warn);
+				this.insertAdvice(advice, field);
+				this.showAdvice(className, field);
+			} else {
+				this.hideAdvice(className, field);
+	makeAdvice: function(className, field, error, warn){
+		var errorMsg = (warn)?this.warningPrefix:this.errorPrefix;
+			errorMsg += (this.options.useTitles) ? field.title || error:error;
+		var cssClass = (warn) ? 'warning-advice' : 'validation-advice';
+		var advice = this.getAdvice(className, field);
+		if(advice) {
+			advice = advice.set('html', errorMsg);
+		} else {
+			advice = new Element('div', {
+				html: errorMsg,
+				styles: { display: 'none' },
+				id: 'advice-' + className + '-' + this.getFieldId(field)
+			}).addClass(cssClass);
+		field.store('advice-' + className, advice);
+		return advice;
+	getFieldId : function(field){
+		return field.id ? field.id : field.id = 'input_' + field.name;
+	showAdvice: function(className, field){
+		if (advice && !field.retrieve(this.getPropName(className))
+				&& (advice.getStyle('display') == 'none'
+				|| advice.getStyle('visiblity') == 'hidden'
+				|| advice.getStyle('opacity') == 0)){
+			field.store(this.getPropName(className), true);
+			if (advice.reveal) advice.reveal();
+			else advice.setStyle('display', 'block');
+	hideAdvice: function(className, field){
+		if (advice && field.retrieve(this.getPropName(className))){
+			field.store(this.getPropName(className), false);
+			//if Fx.Reveal.js is present, transition the advice out
+			if (advice.dissolve) advice.dissolve();
+			else advice.setStyle('display', 'none');
+	getPropName: function(className){
+		return 'advice' + className;
+		if (!field) return this;
+		this.parent(field);
+		}, this);
+		return this;
+	getAllAdviceMessages: function(field, force){
+		var advice = [];
+		if (field.hasClass('ignoreValidation') && !force) return advice;
+			var warner = cn.test('^warn-') || field.hasClass('warnOnly');
+			if (warner) cn = cn.replace(/^warn-/, '');
+			var validator = this.getValidator(cn);
+			if (!validator) return;
+			advice.push({
+				message: validator.getError(field),
+				warnOnly: warner,
+				passed: validator.test(),
+				validator: validator
+		}, this);
+		return advice;
+	getAdvice: function(className, field){
+		return field.retrieve('advice-' + className);
+	insertAdvice: function(advice, field){
+		//Check for error position prop
+		var props = field.get('validatorProps');
+		//Build advice
+		if (!props.msgPos || !document.id(props.msgPos)){
+			if(field.type.toLowerCase() == 'radio') field.getParent().adopt(advice);
+			else advice.inject(document.id(field), 'after');
+		} else {
+			document.id(props.msgPos).grab(advice);
+		var result = this.parent(field, force);
+		if (this.options.scrollToErrorsOnSubmit && !result){
+			var failed = document.id(this).getElement('.validation-failed');
+			var par = document.id(this).getParent();
+			while (par != document.body && par.getScrollSize().y == par.getSize().y){
+				par = par.getParent();
+			var fx = par.retrieve('fvScroller');
+			if (!fx && window.Fx && Fx.Scroll){
+				fx = new Fx.Scroll(par, this.options.scrollFxOptions);
+				par.store('fvScroller', fx);
+			if (failed){
+				if (fx) fx.toElement(failed);
+				else par.scrollTo(par.getScroll().x, failed.getPosition(par).y - 20);
+		return result;
+script: Form.Validator.Extras.js
+description: Additional validators for the Form.Validator class.
+authors:
+ - Aaron Newton
+requires:
+ - /Form.Validator
+provides: [Form.Validator.Extras]
+	['validate-enforce-oncheck', {
+			if (element.checked){
+				var fv = element.getParent('form').retrieve('validator');
+				if (!fv) return true;
+				(props.toEnforce || document.id(props.enforceChildrenOf).getElements('input, select, textarea')).map(function(item){
+					fv.enforceField(item);
+			return true;
+	['validate-ignore-oncheck', {
+				(props.toIgnore || document.id(props.ignoreChildrenOf).getElements('input, select, textarea')).each(function(item){
+					fv.ignoreField(item);
+					fv.resetField(item);
+			return true;
+	['validate-nospace', {
+			return Form.Validator.getMsg('noSpace');
+			return !element.get('value').test(/\s/);
+	['validate-toggle-oncheck', {
+			var eleArr = props.toToggle || document.id(props.toToggleChildrenOf).getElements('input, select, textarea');
+			if (!element.checked){
+				eleArr.each(function(item){
+			} else {
+			return true;
+	['validate-reqchk-bynode', {
+			return Form.Validator.getMsg('reqChkByNode');
+			return (document.id(props.nodeId).getElements(props.selector || 'input[type=checkbox], input[type=radio]')).some(function(item){
+				return item.checked;
+	['validate-required-check', {
+			return props.useTitle ? element.get('title') : Form.Validator.getMsg('requiredChk');
+			return !!element.checked;
+	['validate-reqchk-byname', {
+			return Form.Validator.getMsg('reqChkByName').substitute({label: props.label || element.get('type')});
+			var grpName = props.groupName || element.get('name');
+			var oneCheckedItem = $$(document.getElementsByName(grpName)).some(function(item, index){
+			if (oneCheckedItem && fv) fv.resetField(element);
+			return oneCheckedItem;
+	['validate-match', {
+			return Form.Validator.getMsg('match').substitute({matchName: props.matchName || document.id(props.matchInput).get('name')});
+			var eleVal = element.get('value');
+			var matchVal = document.id(props.matchInput) && document.id(props.matchInput).get('value');
+			return eleVal && matchVal ? eleVal == matchVal : true;
+	['validate-after-date', {
+			return Form.Validator.getMsg('afterDate').substitute({
+				label: props.afterLabel || (props.afterElement ? Form.Validator.getMsg('startDate') : Form.Validator.getMsg('currentDate'))
+			var start = document.id(props.afterElement) ? Date.parse(document.id(props.afterElement).get('value')) : new Date();
+			var end = Date.parse(element.get('value'));
+			return end && start ? end >= start : true;
+	['validate-before-date', {
+			return Form.Validator.getMsg('beforeDate').substitute({
+				label: props.beforeLabel || (props.beforeElement ? Form.Validator.getMsg('endDate') : Form.Validator.getMsg('currentDate'))
+			var start = Date.parse(element.get('value'));
+			var end = document.id(props.beforeElement) ? Date.parse(document.id(props.beforeElement).get('value')) : new Date();
+	['validate-custom-required', {
+			return element.get('value') != props.emptyValue;
+	['validate-same-month', {
+			var startMo = document.id(props.sameMonthAs) && document.id(props.sameMonthAs).get('value');
+			if (eleVal != '') return Form.Validator.getMsg(startMo ? 'sameMonth' : 'startMonth');
+			var d1 = Date.parse(element.get('value'));
+			var d2 = Date.parse(document.id(props.sameMonthAs) && document.id(props.sameMonthAs).get('value'));
+			return d1 && d2 ? d1.format('%B') == d2.format('%B') : true;
+	['validate-cc-num', {
+		errorMsg: function(element){
+			var ccNum = element.get('value').replace(/[^0-9]/g, '');
+			return Form.Validator.getMsg('creditcard').substitute({length: ccNum.length});
+			// required is a different test
+			if (Form.Validator.getValidator('IsEmpty').test(element)) { return true; }
+			// Clean number value
+			var ccNum = element.get('value');
+			ccNum = ccNum.replace(/[^0-9]/g, '');
+			var valid_type = false;
+			if (ccNum.test(/^4[0-9]{12}([0-9]{3})?$/)) valid_type = 'Visa';
+			else if (ccNum.test(/^5[1-5]([0-9]{14})$/)) valid_type = 'Master Card';
+			else if (ccNum.test(/^3[47][0-9]{13}$/)) valid_type = 'American Express';
+			else if (ccNum.test(/^6011[0-9]{12}$/)) valid_type = 'Discover';
+			if (valid_type) {
+				var sum = 0;
+				var cur = 0;
+				for(var i=ccNum.length-1; i>=0; --i) {
+					cur = ccNum.charAt(i).toInt();
+					if (cur == 0) { continue; }
+					if ((ccNum.length-i) % 2 == 0) { cur += cur; }
+					if (cur > 9) { cur = cur.toString().charAt(0).toInt() + cur.toString().charAt(1).toInt(); }
+					sum += cur;
+				if ((sum % 10) == 0) { return true; }
+			var chunks = '';
+			while (ccNum != '') {
+				chunks += ' ' + ccNum.substr(0,4);
+				ccNum = ccNum.substr(4);
+			element.getParent('form').retrieve('validator').ignoreField(element);
+			element.set('value', chunks.clean());
+			element.getParent('form').retrieve('validator').enforceField(element);
+			return false;
+script: OverText.js
+description: Shows text over an input that disappears when the user clicks into it. The text remains hidden if the user adds a value.
+license: MIT-style license
+authors:
+ - Aaron Newton
+requires:
+ - /Class.Binds
+ - /Class.Occlude
+provides: [OverText]
+var OverText = new Class({
+	Binds: ['reposition', 'assert', 'focus', 'hide'],
+	options: {/*
+		textOverride: null,
+		onFocus: $empty()
+		onTextHide: $empty(textEl, inputEl),
+		onTextShow: $empty(textEl, inputEl), */
+		element: 'label',
+		positionOptions: {
+			position: 'upperLeft',
+			edge: 'upperLeft',
+			offset: {
+				x: 4,
+				y: 2
+		poll: false,
+		pollInterval: 250,
+		wrap: false
+	property: 'OverText',
+		this.attach(this.element);
+		OverText.instances.push(this);
+		if (this.options.poll) this.poll();
+		return this;
+	attach: function(){
+		var val = this.options.textOverride || this.element.get('alt') || this.element.get('title');
+		if (!val) return;
+		this.text = new Element(this.options.element, {
+			'class': 'overTxtLabel',
+			styles: {
+				lineHeight: 'normal',
+				cursor: 'text'
+			html: val,
+			events: {
+				click: this.hide.pass(this.options.element == 'label', this)
+		}).inject(this.element, 'after');
+		if (this.options.element == 'label') {
+			if (!this.element.get('id')) this.element.set('id', 'input_' + new Date().getTime());
+			this.text.set('for', this.element.get('id'));
+		if (this.options.wrap) {
+			this.textHolder = new Element('div', {
+				styles: {
+					position: 'relative'
+				'class':'overTxtWrapper'
+			}).adopt(this.text).inject(this.element, 'before');
+		this.element.addEvents({
+			focus: this.focus,
+			blur: this.assert,
+			change: this.assert
+		}).store('OverTextDiv', this.text);
+		window.addEvent('resize', this.reposition.bind(this));
+		this.assert(true);
+		this.reposition();
+	wrap: function(){
+	startPolling: function(){
+		this.pollingPaused = false;
+		return this.poll();
+	poll: function(stop){
+		//start immediately
+		//pause on focus
+		//resumeon blur
+		if (this.poller && !stop) return this;
+		var test = function(){
+			if (!this.pollingPaused) this.assert(true);
+		}.bind(this);
+		if (stop) $clear(this.poller);
+		else this.poller = test.periodical(this.options.pollInterval, this);
+		return this;
+	stopPolling: function(){
+		this.pollingPaused = true;
+		return this.poll(true);
+	focus: function(){
+		if (this.text && (!this.text.isDisplayed() || this.element.get('disabled'))) return;
+		this.hide();
+	hide: function(suppressFocus, force){
+		if (this.text && (this.text.isDisplayed() && (!this.element.get('disabled') || force))){
+			this.text.hide();
+			this.fireEvent('textHide', [this.text, this.element]);
+			if (!suppressFocus){
+				try {
+					this.element.fireEvent('focus');
+					this.element.focus();
+				} catch(e){} //IE barfs if you call focus on hidden elements
+		return this;
+	show: function(){
+		if (this.text && !this.text.isDisplayed()){
+			this.text.show();
+			this.fireEvent('textShow', [this.text, this.element]);
+		return this;
+	assert: function(suppressFocus){
+		this[this.test() ? 'show' : 'hide'](suppressFocus);
+	test: function(){
+		var v = this.element.get('value');
+		return !v;
+	reposition: function(){
+		if (!this.element.isVisible()) return this.stopPolling().hide();
+		if (this.text && this.test()) this.text.position($merge(this.options.positionOptions, {relativeTo: this.element}));
+		return this;
+OverText.instances = [];
+$extend(OverText, {
+	each: function(fn) {
+		return OverText.instances.map(function(ot, i){
+			if (ot.element && ot.text) return fn.apply(OverText, [ot, i]);
+			return null; //the input or the text was destroyed
+	update: function(){
+		return OverText.each(function(ot){
+			return ot.reposition();
+	hideAll: function(){
+			return ot.hide(true, true);
+	showAll: function(){
+		return OverText.each(function(ot) {
+			return ot.show();
+if (window.Fx && Fx.Reveal) {
+	Fx.Reveal.implement({
+		hideInputs: Browser.Engine.trident ? 'select, input, textarea, object, embed, .overTxtLabel' : false
+script: Fx.Elements.js
+description: Effect to change any number of CSS properties of any number of Elements.
+authors:
+ - Valerio Proietti
+requires:
+ - core:1.2.4/Fx.CSS
+ - /MooTools.More
+provides: [Fx.Elements]
+Fx.Elements = new Class({
+	Extends: Fx.CSS,
+	initialize: function(elements, options){
+		this.elements = this.subject = $$(elements);
+		this.parent(options);
+	compute: function(from, to, delta){
+		var now = {};
+		for (var i in from){
+			var iFrom = from[i], iTo = to[i], iNow = now[i] = {};
+			for (var p in iFrom) iNow[p] = this.parent(iFrom[p], iTo[p], delta);
+		return now;
+	set: function(now){
+		for (var i in now){
+			var iNow = now[i];
+			for (var p in iNow) this.render(this.elements[i], p, iNow[p], this.options.unit);
+		return this;
+	start: function(obj){
+		if (!this.check(obj)) return this;
+		var from = {}, to = {};
+		for (var i in obj){
+			var iProps = obj[i], iFrom = from[i] = {}, iTo = to[i] = {};
+			for (var p in iProps){
+				var parsed = this.prepare(this.elements[i], p, iProps[p]);
+				iFrom[p] = parsed.from;
+				iTo[p] = parsed.to;
+		return this.parent(from, to);
+script: Fx.Accordion.js
+description: An Fx.Elements extension which allows you to easily create accordion type controls.
+authors:
+requires:
+ - /Fx.Elements
+provides: [Fx.Accordion]
+Fx.Accordion = new Class({
+	Extends: Fx.Elements,
+	options: {/*
+		onActive: $empty(toggler, section),
+		onBackground: $empty(toggler, section),
+		fixedHeight: false,
+		fixedWidth: false,
+		display: 0,
+		show: false,
+		height: true,
+		width: false,
+		opacity: true,
+		alwaysHide: false,
+		trigger: 'click',
+		initialDisplayFx: true,
+		returnHeightToAuto: true
+			'container': Element.type, //deprecated
+			'options': Object.type,
+			'togglers': $defined,
+			'elements': $defined
+		this.parent(params.elements, params.options);
+		this.togglers = $$(params.togglers);
+		this.previous = -1;
+		this.internalChain = new Chain();
+		if (this.options.alwaysHide) this.options.wait = true;
+		if ($chk(this.options.show)){
+			this.options.display = false;
+			this.previous = this.options.show;
+		if (this.options.start){
+			this.options.show = false;
+		this.effects = {};
+		if (this.options.opacity) this.effects.opacity = 'fullOpacity';
+		if (this.options.width) this.effects.width = this.options.fixedWidth ? 'fullWidth' : 'offsetWidth';
+		if (this.options.height) this.effects.height = this.options.fixedHeight ? 'fullHeight' : 'scrollHeight';
+		for (var i = 0, l = this.togglers.length; i < l; i++) this.addSection(this.togglers[i], this.elements[i]);
+		this.elements.each(function(el, i){
+			if (this.options.show === i){
+				this.fireEvent('active', [this.togglers[i], el]);
+			} else {
+				for (var fx in this.effects) el.setStyle(fx, 0);
+		}, this);
+		if ($chk(this.options.display) || this.options.initialDisplayFx === false) this.display(this.options.display, this.options.initialDisplayFx);
+		if (this.options.fixedHeight !== false) this.options.returnHeightToAuto = false;
+		this.addEvent('complete', this.internalChain.callChain.bind(this.internalChain));
+	addSection: function(toggler, element){
+		toggler = document.id(toggler);
+		element = document.id(element);
+		var test = this.togglers.contains(toggler);
+		this.togglers.include(toggler);
+		this.elements.include(element);
+		var idx = this.togglers.indexOf(toggler);
+		var displayer = this.display.bind(this, idx);
+		toggler.store('accordion:display', displayer);
+		toggler.addEvent(this.options.trigger, displayer);
+		if (this.options.height) element.setStyles({'padding-top': 0, 'border-top': 'none', 'padding-bottom': 0, 'border-bottom': 'none'});
+		if (this.options.width) element.setStyles({'padding-left': 0, 'border-left': 'none', 'padding-right': 0, 'border-right': 'none'});
+		element.fullOpacity = 1;
+		if (this.options.fixedWidth) element.fullWidth = this.options.fixedWidth;
+		if (this.options.fixedHeight) element.fullHeight = this.options.fixedHeight;
+		element.setStyle('overflow', 'hidden');
+		if (!test){
+			for (var fx in this.effects) element.setStyle(fx, 0);
+		return this;
+		this.togglers.each(function(toggler) {
+			toggler.removeEvent(this.options.trigger, toggler.retrieve('accordion:display'));
+		}, this);
+	display: function(index, useFx){
+		if (!this.check(index, useFx)) return this;
+		useFx = $pick(useFx, true);
+		if (this.options.returnHeightToAuto){
+			var prev = this.elements[this.previous];
+			if (prev && !this.selfHidden){
+				for (var fx in this.effects){
+					prev.setStyle(fx, prev[this.effects[fx]]);
+		index = ($type(index) == 'element') ? this.elements.indexOf(index) : index;
+		if ((this.timer && this.options.wait) || (index === this.previous && !this.options.alwaysHide)) return this;
+		this.previous = index;
+		var obj = {};
+			obj[i] = {};
+			var hide;
+			if (i != index){
+				hide = true;
+			} else if (this.options.alwaysHide && ((el.offsetHeight > 0 && this.options.height) || el.offsetWidth > 0 && this.options.width)){
+				hide = true;
+				this.selfHidden = true;
+			this.fireEvent(hide ? 'background' : 'active', [this.togglers[i], el]);
+			for (var fx in this.effects) obj[i][fx] = hide ? 0 : el[this.effects[fx]];
+		}, this);
+		this.internalChain.chain(function(){
+			if (this.options.returnHeightToAuto && !this.selfHidden){
+				var el = this.elements[index];
+				if (el) el.setStyle('height', 'auto');
+		}.bind(this));
+		return useFx ? this.start(obj) : this.set(obj);
+	Compatibility with 1.2.0
+var Accordion = new Class({
+	Extends: Fx.Accordion,
+		var params = Array.link(arguments, {'container': Element.type});
+		this.container = params.container;
+	addSection: function(toggler, element, pos){
+		var len = this.togglers.length;
+		if (len && (!test || pos)){
+			pos = $pick(pos, len - 1);
+			toggler.inject(this.togglers[pos], 'before');
+			element.inject(toggler, 'after');
+		} else if (this.container && !test){
+			toggler.inject(this.container);
+			element.inject(this.container);
+		return this.parent.apply(this, arguments);
+script: Fx.Move.js
+description: Defines Fx.Move, a class that works with Element.Position.js to transition an element from one location to another.
+authors:
+ - Aaron Newton
+requires:
+provides: [Fx.Move]
+Fx.Move = new Class({
+	options: {
+		position: 'center',
+		edge: false,
+	start: function(destination){
+		return this.parent(this.element.position($merge(this.options, destination, {returnPos: true})));
+Element.Properties.move = {
+		var morph = this.retrieve('move');
+		if (morph) morph.cancel();
+		return this.eliminate('move').store('move:options', $extend({link: 'cancel'}, options));
+		if (options || !this.retrieve('move')){
+			if (options || !this.retrieve('move:options')) this.set('move', options);
+			this.store('move', new Fx.Move(this, this.retrieve('move:options')));
+		return this.retrieve('move');
+Element.implement({
+	move: function(options){
+		this.get('move').start(options);
+		return this;
+script: Fx.Scroll.js
+description: Effect to smoothly scroll any element, including the window.
+authors:
+requires:
+ - core:1.2.4/Fx
+ - core:1.2.4/Element.Dimensions
+ - /MooTools.More
+provides: [Fx.Scroll]
+Fx.Scroll = new Class({
+	Extends: Fx,
+	options: {
+		wheelStops: true
+		this.element = this.subject = document.id(element);
+		var cancel = this.cancel.bind(this, false);
+		if ($type(this.element) != 'element') this.element = document.id(this.element.getDocument().body);
+		var stopper = this.element;
+		if (this.options.wheelStops){
+			this.addEvent('start', function(){
+				stopper.addEvent('mousewheel', cancel);
+			}, true);
+			this.addEvent('complete', function(){
+				stopper.removeEvent('mousewheel', cancel);
+			}, true);
+	set: function(){
+		var now = Array.flatten(arguments);
+		if (Browser.Engine.gecko) now = [Math.round(now[0]), Math.round(now[1])];
+		this.element.scrollTo(now[0], now[1]);
+		return [0, 1].map(function(i){
+			return Fx.compute(from[i], to[i], delta);
+	start: function(x, y){
+		if (!this.check(x, y)) return this;
+		var scrollSize = this.element.getScrollSize(),
+			scroll = this.element.getScroll(),
+			values = {x: x, y: y};
+		for (var z in values){
+			var max = scrollSize[z];
+			if ($chk(values[z])) values[z] = ($type(values[z]) == 'number') ? values[z] : max;
+			else values[z] = scroll[z];
+			values[z] += this.options.offset[z];
+		return this.parent([scroll.x, scroll.y], [values.x, values.y]);
+	toTop: function(){
+		return this.start(false, 0);
+	toLeft: function(){
+		return this.start(0, false);
+	toRight: function(){
+		return this.start('right', false);
+	toBottom: function(){
+		return this.start(false, 'bottom');
+	toElement: function(el){
+		var position = document.id(el).getPosition(this.element);
+		return this.start(position.x, position.y);
+	scrollIntoView: function(el, axes, offset){
+		axes = axes ? $splat(axes) : ['x','y'];
+		var to = {};
+		el = document.id(el);
+		var pos = el.getPosition(this.element);
+		var size = el.getSize();
+		var scroll = this.element.getScroll();
+		var containerSize = this.element.getSize();
+		var edge = {
+			x: pos.x + size.x,
+			y: pos.y + size.y
+		['x','y'].each(function(axis) {
+			if (axes.contains(axis)) {
+				if (edge[axis] > scroll[axis] + containerSize[axis]) to[axis] = edge[axis] - containerSize[axis];
+				if (pos[axis] < scroll[axis]) to[axis] = pos[axis];
+			if (to[axis] == null) to[axis] = scroll[axis];
+			if (offset && offset[axis]) to[axis] = to[axis] + offset[axis];
+		}, this);
+		if (to.x != scroll.x || to.y != scroll.y) this.start(to.x, to.y);
+		return this;
+	scrollToCenter: function(el, axes, offset){
+		axes = axes ? $splat(axes) : ['x', 'y'];
+		el = $(el);
+		var to = {},
+			pos = el.getPosition(this.element),
+			size = el.getSize(),
+			containerSize = this.element.getSize(),
+			edge = {
+				y: pos.y + size.y
+		['x','y'].each(function(axis){
+			if(axes.contains(axis)){
+				to[axis] = pos[axis] - (containerSize[axis] - size[axis])/2;
+			if(to[axis] == null) to[axis] = scroll[axis];
+			if(offset && offset[axis]) to[axis] = to[axis] + offset[axis];
+		}, this);
+		return this;
+script: Fx.Slide.js
+description: Effect to slide an element in and out of view.
+authors:
+requires:
+ - core:1.2.4/Fx Element.Style
+ - /MooTools.More
+provides: [Fx.Slide]
+Fx.Slide = new Class({
+	Extends: Fx,
+	options: {
+		mode: 'vertical',
+		wrapper: false,
+		hideOverflow: true
+			this.open = (this.wrapper['offset' + this.layout.capitalize()] != 0);
+			if (this.open) this.wrapper.setStyle('height', '');
+			if (this.open && Browser.Engine.webkit419) this.element.dispose().inject(this.wrapper);
+		}, true);
+		var wrapper = this.element.retrieve('wrapper');
+		var styles = this.element.getStyles('margin', 'position', 'overflow');
+		if (this.options.hideOverflow) styles = $extend(styles, {overflow: 'hidden'});
+		if (this.options.wrapper) wrapper = document.id(this.options.wrapper).setStyles(styles);
+		this.wrapper = wrapper || new Element('div', {
+			styles: styles
+		}).wraps(this.element);
+		this.element.store('wrapper', this.wrapper).setStyle('margin', 0);
+		this.now = [];
+		this.open = true;
+	vertical: function(){
+		this.margin = 'margin-top';
+		this.layout = 'height';
+		this.offset = this.element.offsetHeight;
+	horizontal: function(){
+		this.margin = 'margin-left';
+		this.layout = 'width';
+		this.offset = this.element.offsetWidth;
+		this.element.setStyle(this.margin, now[0]);
+		this.wrapper.setStyle(this.layout, now[1]);
+		return this;
+	start: function(how, mode){
+		if (!this.check(how, mode)) return this;
+		this[mode || this.options.mode]();
+		var margin = this.element.getStyle(this.margin).toInt();
+		var layout = this.wrapper.getStyle(this.layout).toInt();
+		var caseIn = [[margin, layout], [0, this.offset]];
+		var caseOut = [[margin, layout], [-this.offset, 0]];
+		var start;
+		switch (how){
+			case 'in': start = caseIn; break;
+			case 'out': start = caseOut; break;
+			case 'toggle': start = (layout == 0) ? caseIn : caseOut;
+		return this.parent(start[0], start[1]);
+	slideIn: function(mode){
+		return this.start('in', mode);
+	slideOut: function(mode){
+		return this.start('out', mode);
+	hide: function(mode){
+		this.open = false;
+		return this.set([-this.offset, 0]);
+	show: function(mode){
+		this.open = true;
+		return this.set([0, this.offset]);
+	toggle: function(mode){
+		return this.start('toggle', mode);
+Element.Properties.slide = {
+		var slide = this.retrieve('slide');
+		if (slide) slide.cancel();
+		return this.eliminate('slide').store('slide:options', $extend({link: 'cancel'}, options));
+		if (options || !this.retrieve('slide')){
+			if (options || !this.retrieve('slide:options')) this.set('slide', options);
+			this.store('slide', new Fx.Slide(this, this.retrieve('slide:options')));
+		return this.retrieve('slide');
+	slide: function(how, mode){
+		how = how || 'toggle';
+		var slide = this.get('slide'), toggle;
+		switch (how){
+			case 'hide': slide.hide(mode); break;
+			case 'show': slide.show(mode); break;
+			case 'toggle':
+				var flag = this.retrieve('slide:flag', slide.open);
+				slide[flag ? 'slideOut' : 'slideIn'](mode);
+				this.store('slide:flag', !flag);
+				toggle = true;
+			break;
+			default: slide.start(how, mode);
+		if (!toggle) this.eliminate('slide:flag');
+		return this;
+script: Fx.SmoothScroll.js
+description: Class for creating a smooth scrolling effect to all internal links on the page.
+authors:
+requires:
+ - core:1.2.4/Selectors
+ - /Fx.Scroll
+provides: [Fx.SmoothScroll]
+var SmoothScroll = Fx.SmoothScroll = new Class({
+	Extends: Fx.Scroll,
+	initialize: function(options, context){
+		context = context || document;
+		this.doc = context.getDocument();
+		var win = context.getWindow();
+		this.parent(this.doc, options);
+		this.links = $$(this.options.links || this.doc.links);
+		var location = win.location.href.match(/^[^#]*/)[0] + '#';
+		this.links.each(function(link){
+			if (link.href.indexOf(location) != 0) {return;}
+			var anchor = link.href.substr(location.length);
+			if (anchor) this.useLink(link, anchor);
+		}, this);
+		if (!Browser.Engine.webkit419) {
+				win.location.hash = this.anchor;
+			}, true);
+	useLink: function(link, anchor){
+		var el;
+		link.addEvent('click', function(event){
+			if (el !== false && !el) el = document.id(anchor) || this.doc.getElement('a[name=' + anchor + ']');
+			if (el) {
+				event.preventDefault();
+				this.anchor = anchor;
+				this.toElement(el).chain(function(){
+					this.fireEvent('scrolledTo', [link, el]);
+				}.bind(this));
+				link.blur();
+		}.bind(this));
+script: Fx.Sort.js
+description: Defines Fx.Sort, a class that reorders lists with a transition.
+authors:
+ - Aaron Newton
+requires:
+ - /Fx.Elements
+ - /Element.Measure
+provides: [Fx.Sort]
+Fx.Sort = new Class({
+	options: {
+		mode: 'vertical'
+		this.parent(elements, options);
+		this.elements.each(function(el){
+			if (el.getStyle('position') == 'static') el.setStyle('position', 'relative');
+		this.setDefaultOrder();
+	setDefaultOrder: function(){
+		this.currentOrder = this.elements.map(function(el, index){
+			return index;
+	sort: function(newOrder){
+		if ($type(newOrder) != 'array') return false;
+		var top = 0,
+			left = 0,
+			next = {},
+			zero = {},
+			vert = this.options.mode == 'vertical';
+		var current = this.elements.map(function(el, index){
+			var size = el.getComputedSize({styles: ['border', 'padding', 'margin']});
+			var val;
+			if (vert){
+				val = {
+					top: top,
+					margin: size['margin-top'],
+					height: size.totalHeight
+				top += val.height - size['margin-top'];
+			} else {
+				val = {
+					left: left,
+					margin: size['margin-left'],
+					width: size.totalWidth
+				left += val.width;
+			var plain = vert ? 'top' : 'left';
+			zero[index] = {};
+			var start = el.getStyle(plain).toInt();
+			zero[index][plain] = start || 0;
+			return val;
+		}, this);
+		this.set(zero);
+		newOrder = newOrder.map(function(i){ return i.toInt(); });
+		if (newOrder.length != this.elements.length){
+			this.currentOrder.each(function(index){
+				if (!newOrder.contains(index)) newOrder.push(index);
+			if (newOrder.length > this.elements.length)
+				newOrder.splice(this.elements.length-1, newOrder.length - this.elements.length);
+		var margin = top = left = 0;
+		newOrder.each(function(item, index){
+			var newPos = {};
+			if (vert){
+				newPos.top = top - current[item].top - margin;
+				top += current[item].height;
+			} else {
+				newPos.left = left - current[item].left;
+				left += current[item].width;
+			margin = margin + current[item].margin;
+			next[item]=newPos;
+		}, this);
+		var mapped = {};
+		$A(newOrder).sort().each(function(index){
+			mapped[index] = next[index];
+		this.start(mapped);
+		this.currentOrder = newOrder;
+		return this;
+	rearrangeDOM: function(newOrder){
+		newOrder = newOrder || this.currentOrder;
+		var parent = this.elements[0].getParent();
+		var rearranged = [];
+		this.elements.setStyle('opacity', 0);
+		//move each element and store the new default order
+		newOrder.each(function(index){
+			rearranged.push(this.elements[index].inject(parent).setStyles({
+				top: 0,
+				left: 0
+		}, this);
+		this.elements.setStyle('opacity', 1);
+		this.elements = $$(rearranged);
+		return this;
+	getDefaultOrder: function(){
+		return this.elements.map(function(el, index){
+			return index;
+	forward: function(){
+		return this.sort(this.getDefaultOrder());
+	backward: function(){
+		return this.sort(this.getDefaultOrder().reverse());
+	reverse: function(){
+		return this.sort(this.currentOrder.reverse());
+	sortByElements: function(elements){
+		return this.sort(elements.map(function(el){
+			return this.elements.indexOf(el);
+		}, this));
+	swap: function(one, two){
+		if ($type(one) == 'element') one = this.elements.indexOf(one);
+		if ($type(two) == 'element') two = this.elements.indexOf(two);
+		var newOrder = $A(this.currentOrder);
+		newOrder[this.currentOrder.indexOf(one)] = two;
+		newOrder[this.currentOrder.indexOf(two)] = one;
+		return this.sort(newOrder);
+script: Drag.js
+description: The base Drag Class. Can be used to drag and resize Elements using mouse events.
+authors:
+ - Tom Occhinno
+ - Jan Kassens
+requires:
+ - core:1.2.4/Events
+ - core:1.2.4/Options
+ - core:1.2.4/Element.Style
+ - /MooTools.More
+provides: [Drag]
+var Drag = new Class({
+	Implements: [Events, Options],
+	options: {/*
+		onBeforeStart: $empty(thisElement),
+		onStart: $empty(thisElement, event),
+		onSnap: $empty(thisElement)
+		onDrag: $empty(thisElement, event),
+		onCancel: $empty(thisElement),
+		onComplete: $empty(thisElement, event),*/
+		snap: 6,
+		unit: 'px',
+		grid: false,
+		style: true,
+		limit: false,
+		handle: false,
+		invert: false,
+		preventDefault: false,
+		stopPropagation: false,
+		modifiers: {x: 'left', y: 'top'}
+		var params = Array.link(arguments, {'options': Object.type, 'element': $defined});
+		this.element = document.id(params.element);
+		this.document = this.element.getDocument();
+		this.setOptions(params.options || {});
+		var htype = $type(this.options.handle);
+		this.handles = ((htype == 'array' || htype == 'collection') ? $$(this.options.handle) : document.id(this.options.handle)) || this.element;
+		this.mouse = {'now': {}, 'pos': {}};
+		this.value = {'start': {}, 'now': {}};
+		this.selection = (Browser.Engine.trident) ? 'selectstart' : 'mousedown';
+		this.bound = {
+			start: this.start.bind(this),
+			check: this.check.bind(this),
+			drag: this.drag.bind(this),
+			stop: this.stop.bind(this),
+			cancel: this.cancel.bind(this),
+			eventStop: $lambda(false)
+		this.attach();
+		this.handles.addEvent('mousedown', this.bound.start);
+		return this;
+		this.handles.removeEvent('mousedown', this.bound.start);
+		return this;
+	start: function(event){
+		if (event.rightClick) return;
+		if (this.options.preventDefault) event.preventDefault();
+		if (this.options.stopPropagation) event.stopPropagation();
+		this.mouse.start = event.page;
+		this.fireEvent('beforeStart', this.element);
+		var limit = this.options.limit;
+		this.limit = {x: [], y: []};
+		for (var z in this.options.modifiers){
+			if (!this.options.modifiers[z]) continue;
+			if (this.options.style) this.value.now[z] = this.element.getStyle(this.options.modifiers[z]).toInt();
+			else this.value.now[z] = this.element[this.options.modifiers[z]];
+			if (this.options.invert) this.value.now[z] *= -1;
+			this.mouse.pos[z] = event.page[z] - this.value.now[z];
+			if (limit && limit[z]){
+				for (var i = 2; i--; i){
+					if ($chk(limit[z][i])) this.limit[z][i] = $lambda(limit[z][i])();
+		if ($type(this.options.grid) == 'number') this.options.grid = {x: this.options.grid, y: this.options.grid};
+		this.document.addEvents({mousemove: this.bound.check, mouseup: this.bound.cancel});
+		this.document.addEvent(this.selection, this.bound.eventStop);
+	check: function(event){
+		var distance = Math.round(Math.sqrt(Math.pow(event.page.x - this.mouse.start.x, 2) + Math.pow(event.page.y - this.mouse.start.y, 2)));
+		if (distance > this.options.snap){
+			this.cancel();
+				mousemove: this.bound.drag,
+				mouseup: this.bound.stop
+			this.fireEvent('start', [this.element, event]).fireEvent('snap', this.element);
+	drag: function(event){
+		this.mouse.now = event.page;
+			this.value.now[z] = this.mouse.now[z] - this.mouse.pos[z];
+			if (this.options.limit && this.limit[z]){
+				if ($chk(this.limit[z][1]) && (this.value.now[z] > this.limit[z][1])){
+					this.value.now[z] = this.limit[z][1];
+				} else if ($chk(this.limit[z][0]) && (this.value.now[z] < this.limit[z][0])){
+					this.value.now[z] = this.limit[z][0];
+			if (this.options.grid[z]) this.value.now[z] -= ((this.value.now[z] - (this.limit[z][0]||0)) % this.options.grid[z]);
+			if (this.options.style) {
+				this.element.setStyle(this.options.modifiers[z], this.value.now[z] + this.options.unit);
+			} else {
+				this.element[this.options.modifiers[z]] = this.value.now[z];
+		this.fireEvent('drag', [this.element, event]);
+	cancel: function(event){
+		this.document.removeEvent('mousemove', this.bound.check);
+		this.document.removeEvent('mouseup', this.bound.cancel);
+		if (event){
+			this.document.removeEvent(this.selection, this.bound.eventStop);
+			this.fireEvent('cancel', this.element);
+	stop: function(event){
+		this.document.removeEvent('mousemove', this.bound.drag);
+		this.document.removeEvent('mouseup', this.bound.stop);
+		if (event) this.fireEvent('complete', [this.element, event]);
+	makeResizable: function(options){
+		var drag = new Drag(this, $merge({modifiers: {x: 'width', y: 'height'}}, options));
+		this.store('resizer', drag);
+		return drag.addEvent('drag', function(){
+			this.fireEvent('resize', drag);
+		}.bind(this));
+script: Drag.Move.js
+description: A Drag extension that provides support for the constraining of draggables to containers and droppables.
+authors:
+ - Tom Occhinno
+ - Jan Kassens
+ - Aaron Newton
+ - Scott Kyle
+requires:
+ - /Drag
+provides: [Drag.Move]
+Drag.Move = new Class({
+	Extends: Drag,
+	options: {/*
+		onEnter: $empty(thisElement, overed),
+		onLeave: $empty(thisElement, overed),
+		onDrop: $empty(thisElement, overed, event),*/
+		droppables: [],
+		container: false,
+		precalculate: false,
+		includeMargins: true,
+		checkDroppables: true
+	initialize: function(element, options){
+		this.parent(element, options);
+		element = this.element;
+		this.droppables = $$(this.options.droppables);
+		this.container = document.id(this.options.container);
+		if (this.container && $type(this.container) != 'element')
+			this.container = document.id(this.container.getDocument().body);
+		var styles = element.getStyles('left', 'top', 'position');
+		if (styles.left == 'auto' || styles.top == 'auto')
+			element.setPosition(element.getPosition(element.getOffsetParent()));
+		if (styles.position == 'static')
+			element.setStyle('position', 'absolute');
+		this.addEvent('start', this.checkDroppables, true);
+		this.overed = null;
+		if (this.container) this.options.limit = this.calculateLimit();
+		if (this.options.precalculate){
+			this.positions = this.droppables.map(function(el){
+				return el.getCoordinates();
+		this.parent(event);
+	calculateLimit: function(){
+		var offsetParent = this.element.getOffsetParent(),
+			containerCoordinates = this.container.getCoordinates(offsetParent),
+			containerBorder = {},
+			elementMargin = {},
+			elementBorder = {},
+			containerMargin = {},
+			offsetParentPadding = {};
+		['top', 'right', 'bottom', 'left'].each(function(pad){
+			containerBorder[pad] = this.container.getStyle('border-' + pad).toInt();
+			elementBorder[pad] = this.element.getStyle('border-' + pad).toInt();
+			elementMargin[pad] = this.element.getStyle('margin-' + pad).toInt();
+			containerMargin[pad] = this.container.getStyle('margin-' + pad).toInt();
+			offsetParentPadding[pad] = offsetParent.getStyle('padding-' + pad).toInt();
+		}, this);
+		var width = this.element.offsetWidth + elementMargin.left + elementMargin.right,
+			height = this.element.offsetHeight + elementMargin.top + elementMargin.bottom,
+			left = 0,
+			top = 0,
+			right = containerCoordinates.right - containerBorder.right - width,
+			bottom = containerCoordinates.bottom - containerBorder.bottom - height;
+		if (this.options.includeMargins){
+			left += elementMargin.left;
+			top += elementMargin.top;
+		} else {
+			right += elementMargin.right;
+			bottom += elementMargin.bottom;
+		if (this.element.getStyle('position') == 'relative'){
+			var coords = this.element.getCoordinates(offsetParent);
+			coords.left -= this.element.getStyle('left').toInt();
+			coords.top -= this.element.getStyle('top').toInt();
+			left += containerBorder.left - coords.left;
+			top += containerBorder.top - coords.top;
+			right += elementMargin.left - coords.left;
+			bottom += elementMargin.top - coords.top;
+			if (this.container != offsetParent){
+				left += containerMargin.left + offsetParentPadding.left;
+				top += (Browser.Engine.trident4 ? 0 : containerMargin.top) + offsetParentPadding.top;
+		} else {
+			left -= elementMargin.left;
+			top -= elementMargin.top;
+			if (this.container == offsetParent){
+				right -= containerBorder.left;
+				bottom -= containerBorder.top;
+			} else {
+				left += containerCoordinates.left + containerBorder.left;
+				top += containerCoordinates.top + containerBorder.top;
+		return {
+			x: [left, right],
+			y: [top, bottom]
+	checkAgainst: function(el, i){
+		el = (this.positions) ? this.positions[i] : el.getCoordinates();
+		var now = this.mouse.now;
+		return (now.x > el.left && now.x < el.right && now.y < el.bottom && now.y > el.top);
+	checkDroppables: function(){
+		var overed = this.droppables.filter(this.checkAgainst, this).getLast();
+		if (this.overed != overed){
+			if (this.overed) this.fireEvent('leave', [this.element, this.overed]);
+			if (overed) this.fireEvent('enter', [this.element, overed]);
+			this.overed = overed;
+		if (this.options.checkDroppables && this.droppables.length) this.checkDroppables();
+		this.checkDroppables();
+		this.fireEvent('drop', [this.element, this.overed, event]);
+		return this.parent(event);
+	makeDraggable: function(options){
+		var drag = new Drag.Move(this, options);
+		this.store('dragger', drag);
+		return drag;
+script: Slider.js
+description: Class for creating horizontal and vertical slider controls.
+authors:
+requires:
+ - /Class.Binds
+ - /Drag
+ - /Element.Dimensions
+provides: [Slider]
+var Slider = new Class({
+	Binds: ['clickedElement', 'draggedKnob', 'scrolledElement'],
+	options: {/*
+		onTick: $empty(intPosition),
+		onChange: $empty(intStep),
+		onComplete: $empty(strStep),*/
+		onTick: function(position){
+			if (this.options.snap) position = this.toPosition(this.step);
+			this.knob.setStyle(this.property, position);
+		initialStep: 0,
+		snap: false,
+		offset: 0,
+		range: false,
+		wheel: false,
+		steps: 100,
+		mode: 'horizontal'
+	initialize: function(element, knob, options){
+		this.setOptions(options);
+		this.element = document.id(element);
+		this.knob = document.id(knob);
+		this.previousChange = this.previousEnd = this.step = -1;
+		var offset, limit = {}, modifiers = {'x': false, 'y': false};
+		switch (this.options.mode){
+			case 'vertical':
+				this.axis = 'y';
+				this.property = 'top';
+				offset = 'offsetHeight';
+				break;
+			case 'horizontal':
+				this.axis = 'x';
+				this.property = 'left';
+				offset = 'offsetWidth';
+		this.full = this.element.measure(function(){
+			this.half = this.knob[offset] / 2;
+			return this.element[offset] - this.knob[offset] + (this.options.offset * 2);
+		}.bind(this));
+		this.min = $chk(this.options.range[0]) ? this.options.range[0] : 0;
+		this.max = $chk(this.options.range[1]) ? this.options.range[1] : this.options.steps;
+		this.range = this.max - this.min;
+		this.steps = this.options.steps || this.full;
+		this.stepSize = Math.abs(this.range) / this.steps;
+		this.stepWidth = this.stepSize * this.full / Math.abs(this.range) ;
+		this.knob.setStyle('position', 'relative').setStyle(this.property, this.options.initialStep ? this.toPosition(this.options.initialStep) : - this.options.offset);
+		modifiers[this.axis] = this.property;
+		limit[this.axis] = [- this.options.offset, this.full - this.options.offset];
+		var dragOptions = {
+			snap: 0,
+			limit: limit,
+			modifiers: modifiers,
+			onDrag: this.draggedKnob,
+			onStart: this.draggedKnob,
+			onBeforeStart: (function(){
+				this.isDragging = true;
+			}).bind(this),
+			onCancel: function() {
+				this.isDragging = false;
+			}.bind(this),
+			onComplete: function(){
+				this.draggedKnob();
+				this.end();
+			}.bind(this)
+		if (this.options.snap){
+			dragOptions.grid = Math.ceil(this.stepWidth);
+			dragOptions.limit[this.axis][1] = this.full;
+		this.drag = new Drag(this.knob, dragOptions);
+		this.attach();
+		this.element.addEvent('mousedown', this.clickedElement);
+		if (this.options.wheel) this.element.addEvent('mousewheel', this.scrolledElement);
+		this.drag.attach();
+		return this;
+	detach: function(){
+		this.element.removeEvent('mousedown', this.clickedElement);
+		this.element.removeEvent('mousewheel', this.scrolledElement);
+		this.drag.detach();
+		return this;
+	set: function(step){
+		if (!((this.range > 0) ^ (step < this.min))) step = this.min;
+		if (!((this.range > 0) ^ (step > this.max))) step = this.max;
+		this.step = Math.round(step);
+		this.checkStep();
+		this.fireEvent('tick', this.toPosition(this.step));
+		this.end();
+		return this;
+	clickedElement: function(event){
+		if (this.isDragging || event.target == this.knob) return;
+		var dir = this.range < 0 ? -1 : 1;
+		var position = event.page[this.axis] - this.element.getPosition()[this.axis] - this.half;
+		position = position.limit(-this.options.offset, this.full -this.options.offset);
+		this.step = Math.round(this.min + dir * this.toStep(position));
+		this.checkStep();
+		this.fireEvent('tick', position);
+		this.end();
+	scrolledElement: function(event){
+		var mode = (this.options.mode == 'horizontal') ? (event.wheel < 0) : (event.wheel > 0);
+		this.set(mode ? this.step - this.stepSize : this.step + this.stepSize);
+		event.stop();
+	draggedKnob: function(){
+		var position = this.drag.value.now[this.axis];
+		this.checkStep();
+	checkStep: function(){
+		if (this.previousChange != this.step){
+			this.previousChange = this.step;
+			this.fireEvent('change', this.step);
+	end: function(){
+		if (this.previousEnd !== this.step){
+			this.previousEnd = this.step;
+			this.fireEvent('complete', this.step + '');
+	toStep: function(position){
+		var step = (position + this.options.offset) * this.stepSize / this.full * this.steps;
+		return this.options.steps ? Math.round(step -= step % this.stepSize) : step;
+	toPosition: function(step){
+		return (this.full * Math.abs(this.min - step)) / (this.steps * this.stepSize) - this.options.offset;
+script: Sortables.js
+description: Class for creating a drag and drop sorting interface for lists of items.
+authors:
+ - Tom Occhino
+requires:
+ - /Drag.Move
+provides: [Slider]
+var Sortables = new Class({
+	options: {/*
+		onSort: $empty(element, clone),
+		onStart: $empty(element, clone),
+		onComplete: $empty(element),*/
+		snap: 4,
+		opacity: 1,
+		clone: false,
+		revert: false,
+		handle: false,
+		constrain: false
+	initialize: function(lists, options){
+		this.elements = [];
+		this.lists = [];
+		this.idle = true;
+		this.addLists($$(document.id(lists) || lists));
+		if (!this.options.clone) this.options.revert = false;
+		if (this.options.revert) this.effect = new Fx.Morph(null, $merge({duration: 250, link: 'cancel'}, this.options.revert));
+		this.addLists(this.lists);
+		return this;
+		this.lists = this.removeLists(this.lists);
+		return this;
+	addItems: function(){
+		Array.flatten(arguments).each(function(element){
+			this.elements.push(element);
+			var start = element.retrieve('sortables:start', this.start.bindWithEvent(this, element));
+			(this.options.handle ? element.getElement(this.options.handle) || element : element).addEvent('mousedown', start);
+		}, this);
+		return this;
+	addLists: function(){
+		Array.flatten(arguments).each(function(list){
+			this.lists.push(list);
+			this.addItems(list.getChildren());
+		}, this);
+		return this;
+	removeItems: function(){
+		return $$(Array.flatten(arguments).map(function(element){
+			this.elements.erase(element);
+			var start = element.retrieve('sortables:start');
+			(this.options.handle ? element.getElement(this.options.handle) || element : element).removeEvent('mousedown', start);
+			return element;
+		}, this));
+	removeLists: function(){
+		return $$(Array.flatten(arguments).map(function(list){
+			this.lists.erase(list);
+			this.removeItems(list.getChildren());
+			return list;
+		}, this));
+	getClone: function(event, element){
+		if (!this.options.clone) return new Element('div').inject(document.body);
+		if ($type(this.options.clone) == 'function') return this.options.clone.call(this, event, element, this.list);
+		var clone = element.clone(true).setStyles({
+			margin: '0px',
+			position: 'absolute',
+			visibility: 'hidden',
+			'width': element.getStyle('width')
+		//prevent the duplicated radio inputs from unchecking the real one
+		if (clone.get('html').test('radio')) {
+			clone.getElements('input[type=radio]').each(function(input, i) {
+				input.set('name', 'clone_' + i);
+		return clone.inject(this.list).setPosition(element.getPosition(element.getOffsetParent()));
+	getDroppables: function(){
+		var droppables = this.list.getChildren();
+		if (!this.options.constrain) droppables = this.lists.concat(droppables).erase(this.list);
+		return droppables.erase(this.clone).erase(this.element);
+	insert: function(dragging, element){
+		var where = 'inside';
+		if (this.lists.contains(element)){
+			this.list = element;
+			this.drag.droppables = this.getDroppables();
+		} else {
+			where = this.element.getAllPrevious().contains(element) ? 'before' : 'after';
+		this.element.inject(element, where);
+		this.fireEvent('sort', [this.element, this.clone]);
+	start: function(event, element){
+		if (!this.idle) return;
+		this.idle = false;
+		this.element = element;
+		this.opacity = element.get('opacity');
+		this.list = element.getParent();
+		this.clone = this.getClone(event, element);
+		this.drag = new Drag.Move(this.clone, {
+			snap: this.options.snap,
+			container: this.options.constrain && this.element.getParent(),
+			droppables: this.getDroppables(),
+			onSnap: function(){
+				event.stop();
+				this.clone.setStyle('visibility', 'visible');
+				this.element.set('opacity', this.options.opacity || 0);
+				this.fireEvent('start', [this.element, this.clone]);
+			}.bind(this),
+			onEnter: this.insert.bind(this),
+			onCancel: this.reset.bind(this),
+			onComplete: this.end.bind(this)
+		this.clone.inject(this.element, 'before');
+		this.drag.start(event);
+	end: function(){
+		this.element.set('opacity', this.opacity);
+		if (this.effect){
+			var dim = this.element.getStyles('width', 'height');
+			var pos = this.clone.computePosition(this.element.getPosition(this.clone.offsetParent));
+			this.effect.element = this.clone;
+			this.effect.start({
+				top: pos.top,
+				left: pos.left,
+				width: dim.width,
+				height: dim.height,
+				opacity: 0.25
+			}).chain(this.reset.bind(this));
+		} else {
+			this.reset();
+		this.idle = true;
+		this.clone.destroy();
+		this.fireEvent('complete', this.element);
+	serialize: function(){
+		var params = Array.link(arguments, {modifier: Function.type, index: $defined});
+		var serial = this.lists.map(function(list){
+			return list.getChildren().map(params.modifier || function(element){
+				return element.get('id');
+			}, this);
+		}, this);
+		var index = params.index;
+		if (this.lists.length == 1) index = 0;
+		return $chk(index) && index >= 0 && index < this.lists.length ? serial[index] : serial;
+script: Request.JSONP.js
+description: Defines Request.JSONP, a class for cross domain javascript via script injection.
+authors:
+ - Aaron Newton
+ - Guillermo Rauch
+requires:
+ - core:1.2.4/Request
+ - /Log
+provides: [Request.JSONP]
+Request.JSONP = new Class({
+	Implements: [Chain, Events, Options, Log],
+	options: {/*
+		onRetry: $empty(intRetries),
+		onRequest: $empty(scriptElement),
+		onComplete: $empty(data),
+		onSuccess: $empty(data),
+		onCancel: $empty(),
+		log: false,
+		url: '',
+		data: {},
+		retries: 0,
+		timeout: 0,
+		link: 'ignore',
+		callbackKey: 'callback',
+		injectScript: document.head
+	initialize: function(options){
+		if (this.options.log) this.enableLog();
+		this.running = false;
+		this.requests = 0;
+		this.triesRemaining = [];
+	check: function(){
+		if (!this.running) return true;
+		switch (this.options.link){
+			case 'cancel': this.cancel(); return true;
+			case 'chain': this.chain(this.caller.bind(this, arguments)); return false;
+		return false;
+	send: function(options){
+		if (!$chk(arguments[1]) && !this.check(options)) return this;
+		var type = $type(options),
+				old = this.options,
+				index = $chk(arguments[1]) ? arguments[1] : this.requests++;
+		if (type == 'string' || type == 'element') options = {data: options};
+		options = $extend({data: old.data, url: old.url}, options);
+		if (!$chk(this.triesRemaining[index])) this.triesRemaining[index] = this.options.retries;
+		var remaining = this.triesRemaining[index];
+		(function(){
+			var script = this.getScript(options);
+			this.log('JSONP retrieving script with url: ' + script.get('src'));
+			this.fireEvent('request', script);
+			this.running = true;
+			(function(){
+				if (remaining){
+					this.triesRemaining[index] = remaining - 1;
+					if (script){
+						script.destroy();
+						this.send(options, index).fireEvent('retry', this.triesRemaining[index]);
+				} else if(script && this.options.timeout){
+					script.destroy();
+					this.cancel().fireEvent('failure');
+			}).delay(this.options.timeout, this);
+		}).delay(Browser.Engine.trident ? 50 : 0, this);
+		return this;
+	cancel: function(){
+		if (!this.running) return this;
+		this.fireEvent('cancel');
+		return this;
+	getScript: function(options){
+		var index = Request.JSONP.counter,
+				data;
+		Request.JSONP.counter++;
+		switch ($type(options.data)){
+			case 'element': data = document.id(options.data).toQueryString(); break;
+			case 'object': case 'hash': data = Hash.toQueryString(options.data);
+		var src = options.url +
+			 (options.url.test('\\?') ? '&' :'?') +
+			 (options.callbackKey || this.options.callbackKey) +
+			 '=Request.JSONP.request_map.request_'+ index +
+			 (data ? '&' + data : '');
+		if (src.length > 2083) this.log('JSONP '+ src +' will fail in Internet Explorer, which enforces a 2083 bytes length limit on URIs');
+		var script = new Element('script', {type: 'text/javascript', src: src});
+		Request.JSONP.request_map['request_' + index] = function(){ this.success(arguments, script); }.bind(this);
+		return script.inject(this.options.injectScript);
+	success: function(args, script){
+		if (script) script.destroy();
+		this.log('JSONP successfully retrieved: ', args);
+		this.fireEvent('complete', args).fireEvent('success', args).callChain();
+Request.JSONP.counter = 0;
+Request.JSONP.request_map = {};/*
+script: Request.Queue.js
+description: Controls several instances of Request and its variants to run only one request at a time.
+authors:
+ - Aaron Newton
+requires:
+ - /Log
+provides: [Request.Queue]
+Request.Queue = new Class({
+	Implements: [Options, Events],
+	Binds: ['attach', 'request', 'complete', 'cancel', 'success', 'failure', 'exception'],
+	options: {/*
+		onRequest: $empty(argsPassedToOnRequest),
+		onSuccess: $empty(argsPassedToOnSuccess),
+		onComplete: $empty(argsPassedToOnComplete),
+		onCancel: $empty(argsPassedToOnCancel),
+		onException: $empty(argsPassedToOnException),
+		onFailure: $empty(argsPassedToOnFailure),
+		onEnd: $empty,
+		stopOnFailure: true,
+		autoAdvance: true,
+		concurrent: 1,
+		requests: {}
+		if(options){
+			var requests = options.requests;
+			delete options.requests;
+		this.requests = new Hash;
+		this.queue = [];
+		this.reqBinders = {};
+		if(requests) this.addRequests(requests);
+	addRequest: function(name, request){
+		this.requests.set(name, request);
+		this.attach(name, request);
+		return this;
+	addRequests: function(obj){
+		$each(obj, function(req, name){
+			this.addRequest(name, req);
+		}, this);
+		return this;
+	getName: function(req){
+		return this.requests.keyOf(req);
+	attach: function(name, req){
+		if (req._groupSend) return this;
+		['request', 'complete', 'cancel', 'success', 'failure', 'exception'].each(function(evt){
+			if(!this.reqBinders[name]) this.reqBinders[name] = {};
+			this.reqBinders[name][evt] = function(){
+				this['on' + evt.capitalize()].apply(this, [name, req].extend(arguments));
+			}.bind(this);
+			req.addEvent(evt, this.reqBinders[name][evt]);
+		}, this);
+		req._groupSend = req.send;
+		req.send = function(options){
+			this.send(name, options);
+			return req;
+		}.bind(this);
+		return this;
+	removeRequest: function(req){
+		var name = $type(req) == 'object' ? this.getName(req) : req;
+		if (!name && $type(name) != 'string') return this;
+		req = this.requests.get(name);
+		if (!req) return this;
+			req.removeEvent(evt, this.reqBinders[name][evt]);
+		}, this);
+		req.send = req._groupSend;
+		delete req._groupSend;
+		return this;
+	getRunning: function(){
+		return this.requests.filter(function(r){
+			return r.running;
+	isRunning: function(){
+		return !!(this.getRunning().getKeys().length);
+	send: function(name, options){
+		var q = function(){
+			this.requests.get(name)._groupSend(options);
+			this.queue.erase(q);
+		}.bind(this);
+		q.name = name;
+		if (this.getRunning().getKeys().length >= this.options.concurrent || (this.error && this.options.stopOnFailure)) this.queue.push(q);
+		else q();
+		return this;
+	hasNext: function(name){
+		return (!name) ? !!this.queue.length : !!this.queue.filter(function(q){ return q.name == name; }).length;
+	resume: function(){
+		this.error = false;
+		(this.options.concurrent - this.getRunning().getKeys().length).times(this.runNext, this);
+		return this;
+	runNext: function(name){
+		if (!this.queue.length) return this;
+		if (!name){
+			this.queue[0]();
+		} else {
+			var found;
+			this.queue.each(function(q){
+				if (!found && q.name == name){
+					found = true;
+					q();
+		return this;
+	runAll: function() {
+		this.queue.each(function(q) {
+			q();
+		return this;
+	clear: function(name){
+		if (!name){
+			this.queue.empty();
+		} else {
+			this.queue = this.queue.map(function(q){
+				if (q.name != name) return q;
+				else return false;
+			}).filter(function(q){ return q; });
+		return this;
+	cancel: function(name){
+		this.requests.get(name).cancel();
+		return this;
+	onRequest: function(){
+		this.fireEvent('request', arguments);
+		this.fireEvent('complete', arguments);
+		if (!this.queue.length) this.fireEvent('end');
+	onCancel: function(){
+		if (this.options.autoAdvance && !this.error) this.runNext();
+		this.fireEvent('cancel', arguments);
+	onSuccess: function(){
+		this.fireEvent('success', arguments);
+	onFailure: function(){
+		this.error = true;
+		if (!this.options.stopOnFailure && this.options.autoAdvance) this.runNext();
+		this.fireEvent('failure', arguments);
+	onException: function(){
+		this.fireEvent('exception', arguments);
+script: Request.Periodical.js
+description: Requests the same URL to pull data from a server but increases the intervals if no data is returned to reduce the load
+authors:
+ - Christoph Pojer
+requires:
+ - /MooTools.More
+provides: [Request.Periodical]
+Request.implement({
+	options: {
+		initialDelay: 5000,
+		delay: 5000,
+		limit: 60000
+	startTimer: function(data){
+		var fn = function(){
+			if (!this.running) this.send({data: data});
+		this.timer = fn.delay(this.options.initialDelay, this);
+		this.lastDelay = this.options.initialDelay;
+		this.completeCheck = function(response){
+			$clear(this.timer);
+			this.lastDelay = (response) ? this.options.delay : (this.lastDelay + this.options.delay).min(this.options.limit);
+			this.timer = fn.delay(this.lastDelay, this);
+		return this.addEvent('complete', this.completeCheck);
+	stopTimer: function(){
+		return this.removeEvent('complete', this.completeCheck);
+script: Assets.js
+description: Provides methods to dynamically load JavaScript, CSS, and Image files into the document.
+authors:
+requires:
+ - core:1.2.4/Element.Event
+ - /MooTools.More
+provides: [Assets]
+var Asset = {
+	javascript: function(source, properties){
+		properties = $extend({
+			onload: $empty,
+			document: document,
+			check: $lambda(true)
+		}, properties);
+		if (properties.onLoad) properties.onload = properties.onLoad;
+		var script = new Element('script', {src: source, type: 'text/javascript'});
+		var load = properties.onload.bind(script),
+			check = properties.check,
+			doc = properties.document;
+		delete properties.onload;
+		delete properties.check;
+		delete properties.document;
+		script.addEvents({
+			load: load,
+			readystatechange: function(){
+				if (['loaded', 'complete'].contains(this.readyState)) load();
+		}).set(properties);
+		if (Browser.Engine.webkit419) var checker = (function(){
+			if (!$try(check)) return;
+			$clear(checker);
+			load();
+		}).periodical(50);
+		return script.inject(doc.head);
+	css: function(source, properties){
+		return new Element('link', $merge({
+			rel: 'stylesheet',
+			media: 'screen',
+			type: 'text/css',
+			href: source
+		}, properties)).inject(document.head);
+	image: function(source, properties){
+		properties = $merge({
+			onload: $empty,
+			onabort: $empty,
+			onerror: $empty
+		}, properties);
+		var image = new Image();
+		var element = document.id(image) || new Element('img');
+		['load', 'abort', 'error'].each(function(name){
+			var type = 'on' + name;
+			var cap = name.capitalize();
+			if (properties['on' + cap]) properties[type] = properties['on' + cap];
+			var event = properties[type];
+			delete properties[type];
+			image[type] = function(){
+				if (!image) return;
+				if (!element.parentNode){
+					element.width = image.width;
+					element.height = image.height;
+				image = image.onload = image.onabort = image.onerror = null;
+				event.delay(1, element, element);
+				element.fireEvent(name, element, 1);
+		image.src = element.src = source;
+		if (image && image.complete) image.onload.delay(1);
+		return element.set(properties);
+	images: function(sources, options){
+		options = $merge({
+			onComplete: $empty,
+			onProgress: $empty,
+			onError: $empty,
+			properties: {}
+		}, options);
+		sources = $splat(sources);
+		var images = [];
+		var counter = 0;
+		return new Elements(sources.map(function(source){
+			return Asset.image(source, $extend(options.properties, {
+				onload: function(){
+					options.onProgress.call(this, counter, sources.indexOf(source));
+					counter++;
+					if (counter == sources.length) options.onComplete();
+				onerror: function(){
+					options.onError.call(this, counter, sources.indexOf(source));
+					counter++;
+script: Color.js
+description: Class for creating and manipulating colors in JavaScript. Supports HSB -> RGB Conversions and vice versa.
+authors:
+requires:
+ - core:1.2.4/Array
+ - core:1.2.4/String
+ - core:1.2.4/Number
+ - core:1.2.4/Hash
+ - core:1.2.4/Function
+ - core:1.2.4/$util
+provides: [Color]
+var Color = new Native({
+	initialize: function(color, type){
+		if (arguments.length >= 3){
+			type = 'rgb'; color = Array.slice(arguments, 0, 3);
+		} else if (typeof color == 'string'){
+			if (color.match(/rgb/)) color = color.rgbToHex().hexToRgb(true);
+			else if (color.match(/hsb/)) color = color.hsbToRgb();
+			else color = color.hexToRgb(true);
+		type = type || 'rgb';
+		switch (type){
+			case 'hsb':
+				var old = color;
+				color = color.hsbToRgb();
+				color.hsb = old;
+			break;
+			case 'hex': color = color.hexToRgb(true); break;
+		color.rgb = color.slice(0, 3);
+		color.hsb = color.hsb || color.rgbToHsb();
+		color.hex = color.rgbToHex();
+		return $extend(color, this);
+Color.implement({
+	mix: function(){
+		var colors = Array.slice(arguments);
+		var alpha = ($type(colors.getLast()) == 'number') ? colors.pop() : 50;
+		var rgb = this.slice();
+		colors.each(function(color){
+			color = new Color(color);
+			for (var i = 0; i < 3; i++) rgb[i] = Math.round((rgb[i] / 100 * (100 - alpha)) + (color[i] / 100 * alpha));
+		return new Color(rgb, 'rgb');
+	invert: function(){
+		return new Color(this.map(function(value){
+			return 255 - value;
+	setHue: function(value){
+		return new Color([value, this.hsb[1], this.hsb[2]], 'hsb');
+	setSaturation: function(percent){
+		return new Color([this.hsb[0], percent, this.hsb[2]], 'hsb');
+	setBrightness: function(percent){
+		return new Color([this.hsb[0], this.hsb[1], percent], 'hsb');
+var $RGB = function(r, g, b){
+	return new Color([r, g, b], 'rgb');
+var $HSB = function(h, s, b){
+	return new Color([h, s, b], 'hsb');
+var $HEX = function(hex){
+	return new Color(hex, 'hex');
+Array.implement({
+	rgbToHsb: function(){
+		var red = this[0],
+				green = this[1],
+				blue = this[2],
+				hue = 0;
+		var max = Math.max(red, green, blue),
+				min = Math.min(red, green, blue);
+		var delta = max - min;
+		var brightness = max / 255,
+				saturation = (max != 0) ? delta / max : 0;
+		if(saturation != 0) {
+			var rr = (max - red) / delta;
+			var gr = (max - green) / delta;
+			var br = (max - blue) / delta;
+			if (red == max) hue = br - gr;
+			else if (green == max) hue = 2 + rr - br;
+			else hue = 4 + gr - rr;
+			hue /= 6;
+			if (hue < 0) hue++;
+		return [Math.round(hue * 360), Math.round(saturation * 100), Math.round(brightness * 100)];
+	hsbToRgb: function(){
+		var br = Math.round(this[2] / 100 * 255);
+		if (this[1] == 0){
+			return [br, br, br];
+		} else {
+			var hue = this[0] % 360;
+			var f = hue % 60;
+			var p = Math.round((this[2] * (100 - this[1])) / 10000 * 255);
+			var q = Math.round((this[2] * (6000 - this[1] * f)) / 600000 * 255);
+			var t = Math.round((this[2] * (6000 - this[1] * (60 - f))) / 600000 * 255);
+			switch (Math.floor(hue / 60)){
+				case 0: return [br, t, p];
+				case 1: return [q, br, p];
+				case 2: return [p, br, t];
+				case 3: return [p, q, br];
+				case 4: return [t, p, br];
+				case 5: return [br, p, q];
+		return false;
+String.implement({
+		var rgb = this.match(/\d{1,3}/g);
+		return (rgb) ? rgb.rgbToHsb() : null;
+		var hsb = this.match(/\d{1,3}/g);
+		return (hsb) ? hsb.hsbToRgb() : null;
+script: Group.js
+description: Class for monitoring collections of events
+authors:
+requires:
+ - /MooTools.More
+provides: [Group]
+var Group = new Class({
+	initialize: function(){
+		this.instances = Array.flatten(arguments);
+		this.events = {};
+		this.checker = {};
+	addEvent: function(type, fn){
+		this.checker[type] = this.checker[type] || {};
+		this.events[type] = this.events[type] || [];
+		if (this.events[type].contains(fn)) return false;
+		else this.events[type].push(fn);
+		this.instances.each(function(instance, i){
+			instance.addEvent(type, this.check.bind(this, [type, instance, i]));
+		}, this);
+		return this;
+	check: function(type, instance, i){
+		this.checker[type][i] = true;
+		var every = this.instances.every(function(current, j){
+			return this.checker[type][j] || false;
+		}, this);
+		if (!every) return;
+		this.checker[type] = {};
+		this.events[type].each(function(event){
+			event.call(this, this.instances, instance);
+		}, this);
+script: Hash.Cookie.js
+description: Class for creating, reading, and deleting Cookies in JSON format.
+authors:
+ - Aaron Newton
+requires:
+ - core:1.2.4/Cookie
+ - core:1.2.4/JSON
+ - /MooTools.More
+provides: [Hash.Cookie]
+Hash.Cookie = new Class({
+	Extends: Cookie,
+	options: {
+		autoSave: true
+	initialize: function(name, options){
+		this.parent(name, options);
+		this.load();
+	save: function(){
+		var value = JSON.encode(this.hash);
+		if (!value || value.length > 4096) return false; //cookie would be truncated!
+		if (value == '{}') this.dispose();
+		else this.write(value);
+		return true;
+	load: function(){
+		this.hash = new Hash(JSON.decode(this.read(), true));
+		return this;
+Hash.each(Hash.prototype, function(method, name){
+	if (typeof method == 'function') Hash.Cookie.implement(name, function(){
+		var value = method.apply(this.hash, arguments);
+		if (this.options.autoSave) this.save();
+		return value;
+script: HtmlTable.js
+description: Builds table elements with methods to add rows.
+authors:
+ - Aaron Newton
+requires:
+ - /Class.Occlude
+provides: [HtmlTable]
+var HtmlTable = new Class({
+	Implements: [Options, Events, Class.Occlude],
+	options: {
+		properties: {
+			cellpadding: 0,
+			cellspacing: 0,
+			border: 0
+		rows: [],
+		headers: [],
+		footers: []
+	property: 'HtmlTable',
+		var params = Array.link(arguments, {options: Object.type, table: Element.type});
+		this.setOptions(params.options);
+		this.element = params.table || new Element('table', this.options.properties);
+		if (this.occlude()) return this.occluded;
+		this.build();
+	build: function(){
+		this.element.store('HtmlTable', this);
+		this.body = document.id(this.element.tBodies[0]) || new Element('tbody').inject(this.element);
+		$$(this.body.rows);
+		if (this.options.headers.length) this.setHeaders(this.options.headers);
+		else this.thead = document.id(this.element.tHead);
+		if (this.thead) this.head = document.id(this.thead.rows[0]);
+		if (this.options.footers.length) this.setFooters(this.options.footers);
+		this.tfoot = document.id(this.element.tFoot);
+		if (this.tfoot) this.foot = document.id(this.thead.rows[0]);
+		this.options.rows.each(function(row){
+			this.push(row);
+		}, this);
+		['adopt', 'inject', 'wraps', 'grab', 'replaces', 'dispose'].each(function(method){
+				this[method] = this.element[method].bind(this.element);
+		}, this);
+	toElement: function(){
+		return this.element;
+	empty: function(){
+		this.body.empty();
+		return this;
+	set: function(what, items) {
+		var target = (what == 'headers') ? 'tHead' : 'tFoot';
+		this[target.toLowerCase()] = (document.id(this.element[target]) || new Element(target.toLowerCase()).inject(this.element, 'top')).empty();
+		var data = this.push(items, {}, this[target.toLowerCase()], what == 'headers' ? 'th' : 'td');
+		if (what == 'headers') this.head = document.id(this.thead.rows[0]);
+		else this.foot = document.id(this.thead.rows[0]);
+		return data;
+	setHeaders: function(headers){
+		this.set('headers', headers);
+		return this;
+	setFooters: function(footers){
+		this.set('footers', footers);
+		return this;
+	push: function(row, rowProperties, target, tag){
+		var tds = row.map(function(data){
+			var td = new Element(tag || 'td', data.properties),
+				type = data.content || data || '',
+				element = document.id(type);
+			if($type(type) != 'string' && element) td.adopt(element);
+			else td.set('html', type);
+			return td;
+		return {
+			tr: new Element('tr', rowProperties).inject(target || this.body).adopt(tds),
+			tds: tds
+script: HtmlTable.Zebra.js
+description: Builds a stripy table with methods to add rows.
+authors:
+ - Harald Kirschner
+ - Aaron Newton
+requires:
+ - /HtmlTable
+ - /Class.refactor
+provides: [HtmlTable.Zebra]
+HtmlTable = Class.refactor(HtmlTable, {
+	options: {
+		classZebra: 'table-tr-odd',
+		zebra: true
+		this.previous.apply(this, arguments);
+		if (this.occluded) return this.occluded;
+		if (this.options.zebra) this.updateZebras();
+	updateZebras: function(){
+		Array.each(this.body.rows, this.zebra, this);
+	zebra: function(row, i){
+		return row[((i % 2) ? 'remove' : 'add')+'Class'](this.options.classZebra);
+	push: function(){
+		var pushed = this.previous.apply(this, arguments);
+		return pushed;
+script: HtmlTable.Sort.js
+description: Builds a stripy, sortable table with methods to add rows.
+authors:
+ - Aaron Newton
+requires:
+ - core:1.2.4/Hash
+ - /HtmlTable
+ - /Class.refactor
+ - /Element.Delegation
+ - /Date
+provides: [HtmlTable.Sort]
+	options: {/*
+		onSort: $empty, */
+		sortIndex: 0,
+		sortReverse: false,
+		parsers: [],
+		defaultParser: 'string',
+		classSortable: 'table-sortable',
+		classHeadSort: 'table-th-sort',
+		classHeadSortRev: 'table-th-sort-rev',
+		classNoSort: 'table-th-nosort',
+		classGroupHead: 'table-tr-group-head',
+		classGroup: 'table-tr-group',
+		classCellSort: 'table-td-sort',
+		classSortSpan: 'table-th-sort-span',
+		sortable: false
+	initialize: function () {
+		this.sorted = {index: null, dir: 1};
+		this.bound = {
+			headClick: this.headClick.bind(this)
+		this.sortSpans = new Elements();
+		if (this.options.sortable) {
+			this.enableSort();
+			if (this.options.sortIndex != null) this.sort(this.options.sortIndex, this.options.sortReverse);
+	attachSorts: function(attach){
+		this.element.removeEvents('click:relay(th)');
+		this.element[$pick(attach, true) ? 'addEvent' : 'removeEvent']('click:relay(th)', this.bound.headClick);
+	setHeaders: function(){
+		if (this.sortEnabled) this.detectParsers();
+	detectParsers: function(force){
+		if (!this.head) return;
+		var parsers = this.options.parsers,
+				rows = this.body.rows;
+		// auto-detect
+		this.parsers = $$(this.head.cells).map(function(cell, index) {
+			if (!force && (cell.hasClass(this.options.classNoSort) || cell.retrieve('htmltable-parser'))) return cell.retrieve('htmltable-parser');
+			var thDiv = new Element('div');
+			$each(cell.childNodes, function(node) {
+				thDiv.adopt(node);
+			thDiv.inject(cell);
+			var sortSpan = new Element('span', {'html': '&#160;', 'class': this.options.classSortSpan}).inject(thDiv, 'top');
+			this.sortSpans.push(sortSpan);
+			var parser = parsers[index],
+					cancel;
+			switch ($type(parser)) {
+				case 'function': parser = {convert: parser}; cancel = true; break;
+				case 'string': parser = parser; cancel = true; break;
+			if (!cancel) {
+				HtmlTable.Parsers.some(function(current) {
+					var match = current.match;
+					if (!match) return false;
+					for (var i = 0, j = rows.length; i < j; i++) {
+						var text = $(rows[i].cells[index]).get('html').clean();
+						if (text && match.test(text)) {
+							parser = current;
+							return true;
+			if (!parser) parser = this.options.defaultParser;
+			cell.store('htmltable-parser', parser);
+			return parser;
+		}, this);
+	headClick: function(event, el) {
+		console.log(el);
+		if (!this.head || el.hasClass(this.options.classNoSort)) return;
+		var index = Array.indexOf(this.head.cells, el);
+		this.sort(index);
+		return false;
+	sort: function(index, reverse, pre) {
+		pre = !!(pre);
+		var classCellSort = this.options.classCellSort;
+		var classGroup = this.options.classGroup,
+				classGroupHead = this.options.classGroupHead;
+		if (!pre) {
+			if (index != null) {
+				if (this.sorted.index == index) {
+					this.sorted.reverse = !(this.sorted.reverse);
+				} else {
+					if (this.sorted.index != null) {
+						this.sorted.reverse = false;
+						this.head.cells[this.sorted.index].removeClass(this.options.classHeadSort).removeClass(this.options.classHeadSortRev);
+					} else {
+						this.sorted.reverse = true;
+					this.sorted.index = index;
+			} else {
+				index = this.sorted.index;
+			if (reverse != null) this.sorted.reverse = reverse;
+			var head = document.id(this.head.cells[index]);
+			if (head) {
+				head.addClass(this.options.classHeadSort);
+				if (this.sorted.reverse) head.addClass(this.options.classHeadSortRev);
+				else head.removeClass(this.options.classHeadSortRev);
+			this.body.getElements('td').removeClass(this.options.classCellSort);
+		var parser = this.parsers[index];
+		if ($type(parser) == 'string') parser = HtmlTable.Parsers.get(parser);
+		if (!parser) return;
+		if (!Browser.Engine.trident) {
+			var rel = this.body.getParent();
+			this.body.dispose();
+		var data = Array.map(this.body.rows, function(row, i) {
+			var value = parser.convert.call(document.id(row.cells[index]));
+			return {
+				position: i,
+				value: value,
+				toString:  function() {
+					return value.toString();
+		}, this);
+		data.reverse(true);
+		data.sort(function(a, b){
+			if (a.value === b.value) return 0;
+			return a.value > b.value ? 1 : -1;
+		if (!this.sorted.reverse) data.reverse(true);
+		var i = data.length, body = this.body;
+		var j, position, entry, group;
+		while (i) {
+			var item = data[--i];
+			position = item.position;
+			var row = body.rows[position];
+			if (row.disabled) continue;
+			if (!pre) {
+				if (group === item.value) {
+					row.removeClass(classGroupHead).addClass(classGroup);
+				} else {
+					group = item.value;
+					row.removeClass(classGroup).addClass(classGroupHead);
+				if (this.zebra) this.zebra(row, i);
+				row.cells[index].addClass(classCellSort);
+			body.appendChild(row);
+			for (j = 0; j < i; j++) {
+				if (data[j].position > position) data[j].position--;
+		data = null;
+		if (rel) rel.grab(body);
+		return this.fireEvent('sort', [body, index]);
+	reSort: function(){
+		if (this.sortEnabled) this.sort.call(this, this.sorted.index, this.sorted.reverse);
+		return this;
+	enableSort: function(){
+		this.element.addClass(this.options.classSortable);
+		this.attachSorts(true);
+		this.detectParsers();
+		this.sortEnabled = true;
+		return this;
+	disableSort: function(){
+		this.element.removeClass(this.options.classSortable);
+		this.attachSorts(false);
+		this.sortSpans.each(function(span) { span.destroy(); });
+		this.sortSpans.empty();
+		this.sortEnabled = false;
+		return this;
+HtmlTable.Parsers = new Hash({
+	'date': {
+		match: /^\d{2}[-\/ ]\d{2}[-\/ ]\d{2,4}$/,
+		convert: function() {
+			return Date.parse(this.get('text')).format('db');
+		type: 'date'
+	'input-checked': {
+		match: / type="(radio|checkbox)" /,
+			return this.getElement('input').checked;
+	'input-value': {
+		match: /<input/,
+			return this.getElement('input').value;
+	'number': {
+		match: /^\d+[^\d.,]*$/,
+			return this.get('text').toInt();
+		number: true
+	'numberLax': {
+		match: /^[^\d]+\d+$/,
+			return this.get('text').replace(/[^-?^0-9]/, '').toInt();
+		number: true
+	'float': {
+		match: /^[\d]+\.[\d]+/,
+			return this.get('text').replace(/[^-?^\d.]/, '').toFloat();
+		number: true
+	'floatLax': {
+		match: /^[^\d]+[\d]+\.[\d]+$/,
+			return this.get('text').replace(/[^-?^\d.]/, '');
+		number: true
+	'string': {
+		match: null,
+			return this.get('text');
+	'title': {
+		match: null,
+			return this.title;
+script: Keyboard.js
+description: KeyboardEvents used to intercept events on a class for keyboard and format modifiers in a specific order so as to make alt+shift+c the same as shift+alt+c.
+license: MIT-style license
+authors:
+ - Perrin Westrich
+ - Aaron Newton
+ - Scott Kyle
+requires:
+ - /Log
+provides: [Keyboard]
+(function(){
+	var Keyboard = this.Keyboard = new Class({
+		Extends: Events,
+		Implements: [Options, Log],
+		options: {
+			onActivate: $empty,
+			onDeactivate: $empty,
+			defaultEventType: 'keydown',
+			active: false,
+			events: {},
+			nonParsedEvents: ['activate', 'deactivate', 'onactivate', 'ondeactivate', 'changed', 'onchanged']
+			this.setup();
+		setup: function(){
+			this.addEvents(this.options.events);
+			//if this is the root manager, nothing manages it
+			if (Keyboard.manager && !this.manager) Keyboard.manager.manage(this);
+			if (this.options.active) this.activate();
+		handle: function(event, type){
+			//Keyboard.stop(event) prevents key propagation
+			if (event.preventKeyboardPropagation) return;
+			var bubbles = !!this.manager;
+			if (bubbles && this.activeKB){
+				this.activeKB.handle(event, type);
+			this.fireEvent(type, event);
+			if (!bubbles && this.activeKB) this.activeKB.handle(event, type);
+		addEvent: function(type, fn, internal){
+			return this.parent(Keyboard.parse(type, this.options.defaultEventType, this.options.nonParsedEvents), fn, internal);
+		removeEvent: function(type, fn){
+			return this.parent(Keyboard.parse(type, this.options.defaultEventType, this.options.nonParsedEvents), fn);
+		toggleActive: function(){
+			return this[this.active ? 'deactivate' : 'activate']();
+		activate: function(instance){
+			if (instance) {
+				//if we're stealing focus, store the last keyboard to have it so the relenquish command works
+				if (instance != this.activeKB) this.previous = this.activeKB;
+				//if we're enabling a child, assign it so that events are now passed to it
+				this.activeKB = instance.fireEvent('activate');
+				Keyboard.manager.fireEvent('changed');
+			} else if (this.manager) {
+				//else we're enabling ourselves, we must ask our parent to do it for us
+				this.manager.activate(this);
+			return this;
+		deactivate: function(instance){
+			if (instance) {
+				if(instance === this.activeKB) {
+					this.activeKB = null;
+					instance.fireEvent('deactivate');
+			else if (this.manager) {
+				this.manager.deactivate(this);
+			return this;
+		relenquish: function(){
+			if (this.previous) this.activate(this.previous);
+		//management logic
+		manage: function(instance){
+			if (instance.manager) instance.manager.drop(instance);
+			this.instances.push(instance);
+			instance.manager = this;
+			if (!this.activeKB) this.activate(instance);
+			else this._disable(instance);
+		_disable: function(instance){
+			if (this.activeKB == instance) this.activeKB = null;
+		drop: function(instance){
+			this._disable(instance);
+			this.instances.erase(instance);
+		instances: [],
+		trace: function(){
+			Keyboard.trace(this);
+		each: function(fn){
+			Keyboard.each(this, fn);
+	var parsed = {};
+	var modifiers = ['shift', 'control', 'alt', 'meta'];
+	var regex = /^(?:shift|control|ctrl|alt|meta)$/;
+	Keyboard.parse = function(type, eventType, ignore){
+		if (ignore && ignore.contains(type.toLowerCase())) return type;
+		type = type.toLowerCase().replace(/^(keyup|keydown):/, function($0, $1){
+			eventType = $1;
+			return '';
+		if (!parsed[type]){
+			var key, mods = {};
+			type.split('+').each(function(part){
+				if (regex.test(part)) mods[part] = true;
+				else key = part;
+			mods.control = mods.control || mods.ctrl; // allow both control and ctrl
+			var keys = [];
+			modifiers.each(function(mod){
+				if (mods[mod]) keys.push(mod);
+			if (key) keys.push(key);
+			parsed[type] = keys.join('+');
+		return eventType + ':' + parsed[type];
+	Keyboard.each = function(keyboard, fn){
+		var current = keyboard || Keyboard.manager;
+		while (current){
+			fn.run(current);
+			current = current.activeKB;
+	Keyboard.stop = function(event){
+		event.preventKeyboardPropagation = true;
+	Keyboard.manager = new Keyboard({
+		active: true
+	Keyboard.trace = function(keyboard){
+		keyboard = keyboard || Keyboard.manager;
+		keyboard.enableLog();
+		keyboard.log('the following items have focus: ');
+		Keyboard.each(keyboard, function(current){
+			keyboard.log(document.id(current.widget) || current.wiget || current);
+	var handler = function(event){
+		var keys = [];
+			if (event[mod]) keys.push(mod);
+		if (!regex.test(event.key)) keys.push(event.key);
+		Keyboard.manager.handle(event, event.type + ':' + keys.join('+'));
+	document.addEvents({
+		'keyup': handler,
+		'keydown': handler
+	Event.Keys.extend({
+		'shift': 16,
+		'control': 17,
+		'alt': 18,
+		'capslock': 20,
+		'pageup': 33,
+		'pagedown': 34,
+		'end': 35,
+		'home': 36,
+		'numlock': 144,
+		'scrolllock': 145,
+		';': 186,
+		'=': 187,
+		',': 188,
+		'-': Browser.Engine.Gecko ? 109 : 189,
+		'.': 190,
+		'/': 191,
+		'`': 192,
+		'[': 219,
+		'\\': 220,
+		']': 221,
+		"'": 222
+script: HtmlTable.Select.js
+description: Builds a stripy, sortable table with methods to add rows. Rows can be selected with the mouse or keyboard navigation.
+authors:
+ - Aaron Newton
+requires:
+ - /Keyboard
+ - /HtmlTable
+ - /Class.refactor
+provides: [HtmlTable.Select]
+	options: {
+		/*onRowFocus: $empty,
+		onRowUnfocus: $empty,*/
+		useKeyboard: true,
+		classRowSelected: 'table-tr-selected',
+		classRowHovered: 'table-tr-hovered',
+		classSelectable: 'table-selectable',
+		allowMultiSelect: true,
+		selectable: false
+		this.selectedRows = new Elements();
+		this.bound = {
+			mouseleave: this.mouseleave.bind(this),
+			focusRow: this.focusRow.bind(this)
+		if (this.options.selectable) this.enableSelect();
+	enableSelect: function(){
+		this.selectEnabled = true;
+		this.attachSelects();
+		this.element.addClass(this.options.classSelectable);
+	disableSelect: function(){
+		this.selectEnabled = false;
+		this.attach(false);
+		this.element.removeClass(this.options.classSelectable);
+	attachSelects: function(attach){
+		attach = $pick(attach, true);
+		var method = attach ? 'addEvents' : 'removeEvents';
+		this.element[method]({
+			mouseleave: this.bound.mouseleave
+		this.body[method]({
+			'click:relay(tr)': this.bound.focusRow
+		if (this.options.useKeyboard || this.keyboard){
+			if (!this.keyboard) this.keyboard = new Keyboard({
+				events: {
+					down: function(e) {
+						e.preventDefault();
+						this.shiftFocus(1);
+					}.bind(this),
+					up: function(e) {
+						this.shiftFocus(-1);
+					}.bind(this),
+					enter: function(e) {
+						if (this.hover) this.focusRow(this.hover);
+					}.bind(this)
+				active: true
+			this.keyboard[attach ? 'activate' : 'deactivate']();
+		this.updateSelects();
+	mouseleave: function(){
+		if (this.hover) this.leaveRow(this.hover);
+	focus: function(){
+		if (this.keyboard) this.keyboard.activate();
+	blur: function(){
+		if (this.keyboard) this.keyboard.deactivate();
+	push: function(){
+		var ret = this.previous.apply(this, arguments);
+		return ret;
+	updateSelects: function(){
+		Array.each(this.body.rows, function(row){
+			var binders = row.retrieve('binders');
+			if ((binders && this.selectEnabled) || (!binders && !this.selectEnabled)) return;
+			if (!binders){
+				binders = {
+					mouseenter: this.enterRow.bind(this, [row]),
+					mouseleave: this.leaveRow.bind(this, [row])
+				row.store('binders', binders).addEvents(binders);
+			} else {
+				row.removeEvents(binders);
+		}, this);
+	enterRow: function(row){
+		if (this.hover) this.hover = this.leaveRow(this.hover);
+		this.hover = row.addClass(this.options.classRowHovered);
+	shiftFocus: function(offset){
+		if (!this.hover) return this.enterRow(this.body.rows[0]);
+		var to = Array.indexOf(this.body.rows, this.hover) + offset;
+		if (to < 0) to = 0;
+		if (to >= this.body.rows.length) to = this.body.rows.length - 1;
+		if (this.hover == this.body.rows[to]) return this;
+		this.enterRow(this.body.rows[to]);
+	leaveRow: function(row){
+		row.removeClass(this.options.classRowHovered);
+	focusRow: function(){
+		var row = arguments[1] || arguments[0]; //delegation passes the event first
+		if (!this.body.getChildren().contains(row)) return;
+		var unfocus = function(row){
+			this.selectedRows.erase(row);
+			row.removeClass(this.options.classRowSelected);
+			this.fireEvent('rowUnfocus', [row, this.selectedRows]);
+		}.bind(this);
+		if (!this.options.allowMultiSelect) this.selectedRows.each(unfocus);
+		if (!this.selectedRows.contains(row)) {
+			this.selectedRows.push(row);
+			row.addClass(this.options.classRowSelected);
+			this.fireEvent('rowFocus', [row, this.selectedRows]);
+		} else {
+			unfocus(row);
+		return false;
+	selectAll: function(status){
+		status = $pick(status, true);
+		if (!this.options.allowMultiSelect && status) return;
+		if (!status) this.selectedRows.removeClass(this.options.classRowSelected).empty();
+		else this.selectedRows.combine(this.body.rows).addClass(this.options.classRowSelected);
+		return this;
+	selectNone: function(){
+		return this.selectAll(false);
+description: Enhances Keyboard by adding the ability to name and describe keyboard shortcuts, and the ability to grab shortcuts by name and bind the shortcut to different keys.
+authors:
+ - Perrin Westrich
+requires:
+ - /Keyboard.Extras
+provides: [Keyboard.Extras]
+Keyboard.prototype.options.nonParsedEvents.combine(['rebound', 'onrebound']);
+Keyboard.implement({
+		shortcut should be in the format of:
+			'keys': 'shift+s', // the default to add as an event.
+			'description': 'blah blah blah', // a brief description of the functionality.
+			'handler': function(){} // the event handler to run when keys are pressed.
+	addShortcut: function(name, shortcut) {
+		this.shortcuts = this.shortcuts || [];
+		this.shortcutIndex = this.shortcutIndex || {};
+		shortcut.getKeyboard = $lambda(this);
+		shortcut.name = name;
+		this.shortcutIndex[name] = shortcut;
+		this.shortcuts.push(shortcut);
+		if(shortcut.keys) this.addEvent(shortcut.keys, shortcut.handler);
+		return this;
+	addShortcuts: function(obj){
+		for(var name in obj) this.addShortcut(name, obj[name]);
+		return this;
+	getShortcuts: function(){
+		return this.shortcuts || [];
+	getShortcut: function(name){
+		return (this.shortcutIndex || {})[name];
+Keyboard.rebind = function(newKeys, shortcuts){
+	$splat(shortcuts).each(function(shortcut){
+		shortcut.getKeyboard().removeEvent(shortcut.keys, shortcut.handler);
+		shortcut.getKeyboard().addEvent(newKeys, shortcut.handler);
+		shortcut.keys = newKeys;
+		shortcut.getKeyboard().fireEvent('rebound');
+Keyboard.getActiveShortcuts = function(keyboard) {
+	var activeKBS = [], activeSCS = [];
+	Keyboard.each(keyboard, [].push.bind(activeKBS));
+	activeKBS.each(function(kb){ activeSCS.extend(kb.getShortcuts()); });
+	return activeSCS;
+Keyboard.getShortcut = function(name, keyboard, opts){
+	opts = opts || {};
+	var shortcuts = opts.many ? [] : null,
+		set = opts.many ? function(kb){
+				var shortcut = kb.getShortcut(name);
+				if(shortcut) shortcuts.push(shortcut);
+			} : function(kb) {
+				if(!shortcuts) shortcuts = kb.getShortcut(name);
+	Keyboard.each(keyboard, set);
+	return shortcuts;
+Keyboard.getShortcuts = function(name, keyboard) {
+	return Keyboard.getShortcut(name, keyboard, { many: true });
+script: Scroller.js
+description: Class which scrolls the contents of any Element (including the window) when the mouse reaches the Element's boundaries.
+authors:
+ - Valerio Proietti
+requires:
+ - core:1.2.4/Element.Dimensions
+provides: [Scroller]
+var Scroller = new Class({
+	options: {
+		area: 20,
+		velocity: 1,
+		onChange: function(x, y){
+			this.element.scrollTo(x, y);
+		fps: 50
+		this.docBody = document.id(this.element.getDocument().body);
+		this.listener = ($type(this.element) != 'element') ?  this.docBody : this.element;
+		this.timer = null;
+		this.bound = {
+			attach: this.attach.bind(this),
+			detach: this.detach.bind(this),
+			getCoords: this.getCoords.bind(this)
+	start: function(){
+		this.listener.addEvents({
+			mouseover: this.bound.attach,
+			mouseout: this.bound.detach
+	stop: function(){
+		this.listener.removeEvents({
+		this.detach();
+		this.timer = $clear(this.timer);
+	attach: function(){
+		this.listener.addEvent('mousemove', this.bound.getCoords);
+		this.listener.removeEvent('mousemove', this.bound.getCoords);
+	getCoords: function(event){
+		this.page = (this.listener.get('tag') == 'body') ? event.client : event.page;
+		if (!this.timer) this.timer = this.scroll.periodical(Math.round(1000 / this.options.fps), this);
+	scroll: function(){
+		var size = this.element.getSize(),
+			scroll = this.element.getScroll(),
+			pos = this.element != this.docBody ? this.element.getOffsets() : {x: 0, y:0},
+			scrollSize = this.element.getScrollSize(),
+			change = {x: 0, y: 0};
+		for (var z in this.page){
+			if (this.page[z] < (this.options.area + pos[z]) && scroll[z] != 0) {
+				change[z] = (this.page[z] - this.options.area - pos[z]) * this.options.velocity;
+			} else if (this.page[z] + this.options.area > (size[z] + pos[z]) && scroll[z] + size[z] != scrollSize[z]) {
+				change[z] = (this.page[z] - size[z] + this.options.area - pos[z]) * this.options.velocity;
+		if (change.y || change.x) this.fireEvent('change', [scroll.x + change.x, scroll.y + change.y]);
+script: Tips.js
+description: Class for creating nice tips that follow the mouse cursor when hovering an element.
+authors:
+ - Christoph Pojer
+requires:
+ - /MooTools.More
+provides: [Tips]
+(function(){
+var read = function(option, element){
+	return (option) ? ($type(option) == 'function' ? option(element) : element.get(option)) : '';
+this.Tips = new Class({
+	options: {
+		onAttach: $empty(element),
+		onDetach: $empty(element),
+		onShow: function(){
+			this.tip.setStyle('display', 'block');
+		onHide: function(){
+			this.tip.setStyle('display', 'none');
+		title: 'title',
+		text: function(element){
+			return element.get('rel') || element.get('href');
+		showDelay: 100,
+		hideDelay: 100,
+		className: 'tip-wrap',
+		offset: {x: 16, y: 16},
+		windowPadding: {x:0, y:0},
+		fixed: false
+		var params = Array.link(arguments, {options: Object.type, elements: $defined});
+		if (params.elements) this.attach(params.elements);
+		this.container = new Element('div', {'class': 'tip'});
+		if (this.tip) return this.tip;
+		return this.tip = new Element('div', {
+			'class': this.options.className,
+			styles: {
+				top: 0,
+				left: 0
+		}).adopt(
+			new Element('div', {'class': 'tip-top'}),
+			this.container,
+			new Element('div', {'class': 'tip-bottom'})
+		).inject(document.body);
+	attach: function(elements){
+		$$(elements).each(function(element){
+			var title = read(this.options.title, element),
+				text = read(this.options.text, element);
+			element.erase('title').store('tip:native', title).retrieve('tip:title', title);
+			element.retrieve('tip:text', text);
+			this.fireEvent('attach', [element]);
+			var events = ['enter', 'leave'];
+			if (!this.options.fixed) events.push('move');
+			events.each(function(value){
+				var event = element.retrieve('tip:' + value);
+				if (!event) event = this['element' + value.capitalize()].bindWithEvent(this, element);
+				element.store('tip:' + value, event).addEvent('mouse' + value, event);
+			}, this);
+		}, this);
+		return this;
+	detach: function(elements){
+			['enter', 'leave', 'move'].each(function(value){
+				element.removeEvent('mouse' + value, element.retrieve('tip:' + value)).eliminate('tip:' + value);
+			this.fireEvent('detach', [element]);
+			if (this.options.title == 'title'){ // This is necessary to check if we can revert the title
+				var original = element.retrieve('tip:native');
+				if (original) element.set('title', original);
+		}, this);
+		return this;
+	elementEnter: function(event, element){
+		this.container.empty();
+		['title', 'text'].each(function(value){
+			var content = element.retrieve('tip:' + value);
+			if (content) this.fill(new Element('div', {'class': 'tip-' + value}).inject(this.container), content);
+		}, this);
+		this.timer = (function(){
+			this.show(this, element);
+			this.position((this.options.fixed) ? {page: element.getPosition()} : event);
+		}).delay(this.options.showDelay, this);
+	elementLeave: function(event, element){
+		this.timer = this.hide.delay(this.options.hideDelay, this, element);
+		this.fireForParent(event, element);
+	fireForParent: function(event, element){
+		element = element.getParent();
+		if (!element || element == document.body) return;
+		if (element.retrieve('tip:enter')) element.fireEvent('mouseenter', event);
+		else this.fireForParent(event, element);
+	elementMove: function(event, element){
+		this.position(event);
+	position: function(event){
+		if (!this.tip) document.id(this);
+		var size = window.getSize(), scroll = window.getScroll(),
+			tip = {x: this.tip.offsetWidth, y: this.tip.offsetHeight},
+			props = {x: 'left', y: 'top'},
+			obj = {};
+		for (var z in props){
+			obj[props[z]] = event.page[z] + this.options.offset[z];
+			if ((obj[props[z]] + tip[z] - scroll[z]) > size[z] - this.options.windowPadding[z]) obj[props[z]] = event.page[z] - this.options.offset[z] - tip[z];
+		this.tip.setStyles(obj);
+	fill: function(element, contents){
+		if(typeof contents == 'string') element.set('html', contents);
+		else element.adopt(contents);
+	show: function(element){
+		this.fireEvent('show', [this.tip, element]);
+	hide: function(element){
+		this.fireEvent('hide', [this.tip, element]);
+script: Date.Catalan.js
+description: Date messages for Catalan.
+authors:
+ - Alfons Sanchez
+requires:
+ - /Lang
+ - /Date
+provides: [Date.Catalan]
+MooTools.lang.set('ca-CA', 'Date', {
+	months: ['Gener', 'Febrer', 'Març', 'Abril', 'Maig', 'Juny', 'Juli', 'Agost', 'Setembre', 'Octubre', 'Novembre', 'Desembre'],
+	days: ['Diumenge', 'Dilluns', 'Dimarts', 'Dimecres', 'Dijous', 'Divendres', 'Dissabte'],
+	//culture's date order: MM/DD/YYYY
+	dateOrder: ['date', 'month', 'year'],
+	shortDate: '%d/%m/%Y',
+	shortTime: '%H:%M',
+	AM: 'AM',
+	PM: 'PM',
+	/* Date.Extras */
+	ordinal: '',
+	lessThanMinuteAgo: 'fa menys d`un minut',
+	minuteAgo: 'fa un minut',
+	minutesAgo: 'fa {delta} minuts',
+	hourAgo: 'fa un hora',
+	hoursAgo: 'fa unes {delta} hores',
+	dayAgo: 'fa un dia',
+	daysAgo: 'fa {delta} dies',
+	lessThanMinuteUntil: 'menys d`un minut des d`ara',
+	minuteUntil: 'un minut des d`ara',
+	minutesUntil: '{delta} minuts des d`ara',
+	hourUntil: 'un hora des d`ara',
+	hoursUntil: 'unes {delta} hores des d`ara',
+	dayUntil: '1 dia des d`ara',
+	daysUntil: '{delta} dies des d`ara'
+script: Date.Czech.js
+description: Date messages for Czech.
+authors:
+ - Jan Černý chemiX
+requires:
+ - /Lang
+ - /Date
+provides: [Date.Czech]
+MooTools.lang.set('cs-CZ', 'Date', {
+	months: ['Leden', 'Únor', 'Březen', 'Duben', 'Květen', 'Červen', 'Červenec', 'Srpen', 'Září', 'Říjen', 'Listopad', 'Prosinec'],
+	days: ['Neděle', 'Pondělí', 'Úterý', 'Středa', 'Čtvrtek', 'Pátek', 'Sobota'],
+	AM: 'dop.',
+	PM: 'odp.',
+	/* Date.Extras */
+	ordinal: function(dayOfMonth){
+		return '.';
+    // TODO : in examples use and fix it
+	lessThanMinuteAgo: 'méně než minutou',
+	minuteAgo: 'přibližně před minutou',
+	minutesAgo: 'před {delta} minutami',
+	hourAgo: 'přibližně před hodinou',
+	hoursAgo: 'před {delta} hodinami',
+	dayAgo: 'před dnem',
+	daysAgo: 'před {delta} dni',
+	lessThanMinuteUntil: 'před méně než minutou',
+	minuteUntil: 'asi před minutou',
+	minutesUntil: ' asi před {delta} minutami',
+	hourUntil: 'asi před hodinou',
+	hoursUntil: 'před {delta} hodinami',
+	dayUntil: 'před dnem',
+	daysUntil: 'před {delta} dni',
+	weekUntil: 'před týdnem',
+	weeksUntil: 'před {delta} týdny',
+	monthUntil: 'před měsícem',
+	monthsUntil: 'před {delta} měsíci',
+	yearUntil: 'před rokem',
+	yearsUntil: 'před {delta} lety'
+script: Date.Danish.js
+description: Date messages for Danish.
+authors:
+ - Martin Overgaard
+ - Henrik Hansen
+requires:
+ - /Lang
+ - /Date
+provides: [Date.Danish]
+MooTools.lang.set('da-DK', 'Date', {
+	months: ['Januar', 'Februa', 'Marts', 'April', 'Maj', 'Juni', 'Juli', 'August', 'September', 'Oktober', 'November', 'December'],
+	days: ['Søndag', 'Mandag', 'Tirsdag', 'Onsdag', 'Torsdag', 'Fredag', 'Lørdag'],
+	//culture's date order: DD/MM/YYYY
+	AM: 'AM',
+	PM: 'PM',
+	shortDate: '%d-%m-%Y',
+	/* Date.Extras */
+	  //1st, 2nd, 3rd, etc.
+	  return (dayOfMonth > 3 && dayOfMonth < 21) ? 'th' : ['th', 'st', 'nd', 'rd', 'th'][Math.min(dayOfMonth % 10, 4)];
+	lessThanMinuteAgo: 'mindre end et minut siden',
+	minuteAgo: 'omkring et minut siden',
+	minutesAgo: '{delta} minutter siden',
+	hourAgo: 'omkring en time siden',
+	hoursAgo: 'omkring {delta} timer siden',
+	dayAgo: '1 dag siden',
+	daysAgo: '{delta} dage siden',
+	weekAgo: '1 uge siden',
+	weeksAgo: '{delta} uger siden',
+	monthAgo: '1 måned siden',
+	monthsAgo: '{delta} måneder siden',
+	yearthAgo: '1 år siden',
+	yearsAgo: '{delta} år siden',
+	lessThanMinuteUntil: 'mindre end et minut fra nu',
+	minuteUntil: 'omkring et minut fra nu',
+	minutesUntil: '{delta} minutter fra nu',
+	hourUntil: 'omkring en time fra nu',
+	hoursUntil: 'omkring {delta} timer fra nu',
+	dayUntil: '1 dag fra nu',
+	daysUntil: '{delta} dage fra nu',
+	weekUntil: '1 uge fra nu',
+	weeksUntil: '{delta} uger fra nu',
+	monthUntil: '1 måned fra nu',
+	monthsUntil: '{delta} måneder fra nu',
+	yearUntil: '1 år fra nu',
+	yearsUntil: '{delta} år fra nu'
+script: Date.Dutch.js
+description: Date messages in Dutch.
+authors:
+ - Lennart Pilon
+requires:
+ - /Lang
+ - /Date
+provides: [Date.Dutch]
+MooTools.lang.set('nl-NL', 'Date', {
+	months: ['Januari', 'Februari', 'Maart', 'April', 'Mei', 'Juni', 'Juli', 'Augustus', 'September', 'Oktober', 'November', 'December'],
+	days: ['Zondag', 'Maandag', 'Dinsdag', 'Woensdag', 'Donderdag', 'Vrijdag', 'Zaterdag'],
+	AM: 'AM',
+	PM: 'PM',
+	/* Date.Extras */
+	ordinal: 'e',
+	lessThanMinuteAgo: 'minder dan een minuut geleden',
+	minuteAgo: 'ongeveer een minuut geleden',
+	minutesAgo: 'minuten geleden',
+	hourAgo: 'ongeveer een uur geleden',
+	hoursAgo: 'ongeveer {delta} uur geleden',
+	dayAgo: '{delta} dag geleden',
+	daysAgo: 'dagen geleden',
+	weekAgo: 'een week geleden',
+	weeksAgo: '{delta} weken geleden',
+	monthAgo: 'een maand geleden',
+	monthsAgo: '{delta} maanden geleden',
+	yearAgo: 'een jaar geleden',
+	yearsAgo: '{delta} jaar geleden',
+	lessThanMinuteUntil: 'minder dan een minuut vanaf nu',
+	minuteUntil: 'ongeveer een minuut vanaf nu',
+	minutesUntil: '{delta} minuten vanaf nu',
+	hourUntil: 'ongeveer een uur vanaf nu',
+	hoursUntil: 'ongeveer {delta} uur vanaf nu',
+	dayUntil: '1 dag vanaf nu',
+	daysUntil: '{delta} dagen vanaf nu',
+	yearthAgo: 'een jaar geleden',
+	weekUntil: 'over een week',
+	weeksUntil: 'over {delta} weken',
+	monthUntil: 'over een maand',
+	monthsUntil: 'over {delta} maanden',
+	yearUntil: 'over een jaar',
+	yearsUntil: 'over {delta} jaar'
+script: Date.English.GB.js
+description: Date messages for British English.
+authors:
+ - Aaron Newton
+requires:
+ - /Lang
+ - /Date
+provides: [Date.English.GB]
+MooTools.lang.set('en-GB', 'Date', {
+}).set('cascade', ['en-US']);/*
+script: Date.Estonian.js
+description: Date messages for Estonian.
+authors:
+ - Kevin Valdek
+requires:
+ - /Lang
+ - /Date
+provides: [Date.Estonian]
+MooTools.lang.set('et-EE', 'Date', {
+	months: ['jaanuar', 'veebruar', 'märts', 'aprill', 'mai', 'juuni', 'juuli', 'august', 'september', 'oktoober', 'november', 'detsember'],
+	days: ['pühapäev', 'esmaspäev', 'teisipäev', 'kolmapäev', 'neljapäev', 'reede', 'laupäev'],
+	//culture's date order: MM.DD.YYYY
+	dateOrder: ['month', 'date', 'year'],
+	AM: 'AM',
+	PM: 'PM',
+	shortDate: '%m.%d.%Y',
+	/* Date.Extras */
+	ordinal: '',
+	lessThanMinuteAgo: 'vähem kui minut aega tagasi',
+	minuteAgo: 'umbes minut aega tagasi',
+	minutesAgo: '{delta} minutit tagasi',
+	hourAgo: 'umbes tund aega tagasi',
+	hoursAgo: 'umbes {delta} tundi tagasi',
+	dayAgo: '1 päev tagasi',
+	daysAgo: '{delta} päeva tagasi',
+	weekAgo: '1 nädal tagasi',
+	weeksAgo: '{delta} nädalat tagasi',
+	monthAgo: '1 kuu tagasi',
+	monthsAgo: '{delta} kuud tagasi',
+	yearAgo: '1 aasta tagasi',
+	yearsAgo: '{delta} aastat tagasi',
+	lessThanMinuteUntil: 'vähem kui minuti aja pärast',
+	minuteUntil: 'umbes minuti aja pärast',
+	minutesUntil: '{delta} minuti pärast',
+	hourUntil: 'umbes tunni aja pärast',
+	hoursUntil: 'umbes {delta} tunni pärast',
+	dayUntil: '1 päeva pärast',
+	daysUntil: '{delta} päeva pärast',
+	weekUntil: '1 nädala pärast',
+	weeksUntil: '{delta} nädala pärast',
+	monthUntil: '1 kuu pärast',
+	monthsUntil: '{delta} kuu pärast',
+	yearUntil: '1 aasta pärast',
+	yearsUntil: '{delta} aasta pärast'
+script: Date.German.js
+description: Date messages for German.
+authors:
+ - Christoph Pojer
+ - Frank Rossi
+ - Ulrich Petri
+ - Fabian Beiner
+requires:
+ - /Lang
+ - /Date
+provides: [Date.German]
+MooTools.lang.set('de-DE', 'Date', {
+	months: ['Januar', 'Februar', 'M&auml;rz', 'April', 'Mai', 'Juni', 'Juli', 'August', 'September', 'Oktober', 'November', 'Dezember'],
+	days: ['Sonntag', 'Montag', 'Dienstag', 'Mittwoch', 'Donnerstag', 'Freitag', 'Samstag'],
+	dateOrder: [ 'date', 'month', 'year', '.'],
+	AM: 'vormittags',
+	PM: 'nachmittags',
+	shortDate: '%d.%m.%Y',
+	/* Date.Extras */
+	ordinal: '.',
+	lessThanMinuteAgo: 'Vor weniger als einer Minute',
+	minuteAgo: 'Vor einer Minute',
+	minutesAgo: 'Vor {delta} Minuten',
+	hourAgo: 'Vor einer Stunde',
+	hoursAgo: 'Vor {delta} Stunden',
+	dayAgo: 'Vor einem Tag',
+	daysAgo: 'Vor {delta} Tagen',
+	weekAgo: 'Vor einer Woche',
+	weeksAgo: 'Vor {delta} Wochen',
+	monthAgo: 'Vor einem Monat',
+	monthsAgo: 'Vor {delta} Monaten',
+	yearAgo: 'Vor einem Jahr',
+	yearsAgo: 'Vor {delta} Jahren',
+	lessThanMinuteUntil: 'In weniger als einer Minute',
+	minuteUntil: 'In einer Minute',
+	minutesUntil: 'In {delta} Minuten',
+	hourUntil: 'In ca. einer Stunde',
+	hoursUntil: 'In ca. {delta} Stunden',
+	dayUntil: 'In einem Tag',
+	daysUntil: 'In {delta} Tagen',
+	weekUntil: 'In einer Woche',
+	weeksUntil: 'In {delta} Wochen',
+	monthUntil: 'In einem Monat',
+	monthsUntil: 'In {delta} Monaten',
+	yearUntil: 'In einem Jahr',
+	yearsUntil: 'In {delta} Jahren'
+script: Date.German.CH.js
+description: Date messages for German (Switzerland).
+authors:
+ - Michael van der Weg
+requires:
+ - /Lang
+ - /Date.German
+provides: [Date.German.CH]
+MooTools.lang.set('de-CH', 'cascade', ['de-DE']);/*
+script: Date.French.js
+description: Date messages in French.
+authors:
+ - Nicolas Sorosac
+ - Antoine Abt
+requires:
+ - /Lang
+ - /Date
+provides: [Date.French]
+MooTools.lang.set('fr-FR', 'Date', {
+	months: ['janvier', 'f&eacute;vrier', 'mars', 'avril', 'mai', 'juin', 'juillet', 'ao&ucirc;t', 'septembre', 'octobre', 'novembre', 'd&eacute;cembre'],
+	days: ['dimanche', 'lundi', 'mardi', 'mercredi', 'jeudi', 'vendredi', 'samedi'],
+	AM: 'AM',
+	PM: 'PM',
+	/* Date.Extras */
+	getOrdinal: function(dayOfMonth){
+	  return (dayOfMonth > 1) ? '' : 'er';
+	lessThanMinuteAgo: 'il y a moins d\'une minute',
+	minuteAgo: 'il y a une minute',
+	minutesAgo: 'il y a {delta} minutes',
+	hourAgo: 'il y a une heure',
+	hoursAgo: 'il y a {delta} heures',
+	dayAgo: 'il y a un jour',
+	daysAgo: 'il y a {delta} jours',
+	weekAgo: 'il y a une semaine',
+	weeksAgo: 'il y a {delta} semaines',
+	monthAgo: 'il y a 1 mois',
+	monthsAgo: 'il y a {delta} mois',
+	yearthAgo: 'il y a 1 an',
+	yearsAgo: 'il y a {delta} ans',
+	lessThanMinuteUntil: 'dans moins d\'une minute',
+	minuteUntil: 'dans une minute',
+	minutesUntil: 'dans {delta} minutes',
+	hourUntil: 'dans une heure',
+	hoursUntil: 'dans {delta} heures',
+	dayUntil: 'dans un jour',
+	daysUntil: 'dans {delta} jours',
+	weekUntil: 'dans 1 semaine',
+	weeksUntil: 'dans {delta} semaines',
+	monthUntil: 'dans 1 mois',
+	monthsUntil: 'dans {delta} mois',
+	yearUntil: 'dans 1 an',
+	yearsUntil: 'dans {delta} ans'
+script: Date.Italian.js
+description: Date messages for Italian.
+license: MIT-style license.
+authors:
+ - Andrea Novero
+requires:
+ - /Lang
+ - /Date
+provides: [Date.Italian]
+MooTools.lang.set('it-IT', 'Date', {
+	months: ['Gennaio', 'Febbraio', 'Marzo', 'Aprile', 'Maggio', 'Giugno', 'Luglio', 'Agosto', 'Settembre', 'Ottobre', 'Novembre', 'Dicembre'],
+	days: ['Domenica', 'Luned&igrave;', 'Marted&igrave;', 'Mercoled&igrave;', 'Gioved&igrave;', 'Venerd&igrave;', 'Sabato'],
+	AM: 'AM',
+	PM: 'PM',
+	shortTime: '%H.%M',
+	/* Date.Extras */
+	ordinal: '&ordm;',
+	lessThanMinuteAgo: 'meno di un minuto fa',
+	minuteAgo: 'circa un minuto fa',
+	minutesAgo: 'circa {delta} minuti fa',
+	hourAgo: 'circa un\'ora fa',
+	hoursAgo: 'circa {delta} ore fa',
+	dayAgo: 'circa 1 giorno fa',
+	daysAgo: 'circa {delta} giorni fa',
+	lessThanMinuteUntil: 'tra meno di un minuto',
+	minuteUntil: 'tra circa un minuto',
+	minutesUntil: 'tra circa {delta} minuti',
+	hourUntil: 'tra circa un\'ora',
+	hoursUntil: 'tra circa {delta} ore',
+	dayUntil: 'tra circa un giorno',
+	daysUntil: 'tra circa {delta} giorni'
+script: Date.Norwegian.js
+description: Date messages in Norwegian.
+authors:
+ - Espen 'Rexxars' Hovlandsdal
+requires:
+ - /Lang
+ - /Date
+provides: [Date.Norwegian]
+MooTools.lang.set('no-NO', 'Date', {
+	lessThanMinuteAgo: 'kortere enn et minutt siden',
+	minuteAgo: 'omtrent et minutt siden',
+	hourAgo: 'omtrent en time siden',
+	hoursAgo: 'omtrent {delta} timer siden',
+	dayAgo: '{delta} dag siden',
+	daysAgo: '{delta} dager siden'
+script: Date.Polish.js
+description: Date messages for Polish.
+authors:
+ - Oskar Krawczyk
+requires:
+ - /Lang
+ - /Date
+provides: [Date.Polish]
+MooTools.lang.set('pl-PL', 'Date', {
+	months: ['Styczeń', 'Luty', 'Marzec', 'Kwiecień', 'Maj', 'Czerwiec', 'Lipiec', 'Sierpień', 'Wrzesień', 'Październik', 'Listopad', 'Grudzień'],
+	days: ['Niedziela', 'Poniedziałek', 'Wtorek', 'Środa', 'Czwartek', 'Piątek', 'Sobota'],
+	dateOrder: ['year', 'month', 'date'],
+	AM: 'nad ranem',
+	PM: 'po południu',
+	shortDate: '%Y-%m-%d',
+	/* Date.Extras */
+		return (dayOfMonth > 3 && dayOfMonth < 21) ? 'ty' : ['ty', 'szy', 'gi', 'ci', 'ty'][Math.min(dayOfMonth % 10, 4)];
+	lessThanMinuteAgo: 'mniej niż minute temu',
+	minuteAgo: 'około minutę temu',
+	minutesAgo: '{delta} minut temu',
+	hourAgo: 'około godzinę temu',
+	hoursAgo: 'około {delta} godzin temu',
+	dayAgo: 'Wczoraj',
+	daysAgo: '{delta} dni temu',
+	lessThanMinuteUntil: 'za niecałą minutę',
+	minuteUntil: 'za około minutę',
+	minutesUntil: 'za {delta} minut',
+	hourUntil: 'za około godzinę',
+	hoursUntil: 'za około {delta} godzin',
+	dayUntil: 'za 1 dzień',
+	daysUntil: 'za {delta} dni'
+script: Date.Portuguese.BR.js
+description: Date messages in Portuguese-BR (Brazil).
+authors:
+ - Fabio Miranda Costa
+requires:
+ - /Lang
+ - /Date
+provides: [Date.Portuguese.BR]
+MooTools.lang.set('pt-BR', 'Date', {
+	months: ['Janeiro', 'Fevereiro', 'Março', 'Abril', 'Maio', 'Junho', 'Julho', 'Agosto', 'Setembro', 'Outubro', 'Novembro', 'Dezembro'],
+	days: ['Domingo', 'Segunda-feira', 'Terça-feira', 'Quarta-feira', 'Quinta-feira', 'Sexta-feira', 'Sábado'],
+	/* Date.Extras */
+		//1º, 2º, 3º, etc.
+    	return '&ordm;';
+	lessThanMinuteAgo: 'há menos de um minuto',
+	minuteAgo: 'há cerca de um minuto',
+	minutesAgo: 'há {delta} minutos',
+	hourAgo: 'há cerca de uma hora',
+	hoursAgo: 'há cerca de {delta} horas',
+	dayAgo: 'há um dia',
+	daysAgo: 'há {delta} dias',
+    weekAgo: 'há uma semana',
+	weeksAgo: 'há {delta} semanas',
+	monthAgo: 'há um mês',
+	monthsAgo: 'há {delta} meses',
+	yearAgo: 'há um ano',
+	yearsAgo: 'há {delta} anos',
+	lessThanMinuteUntil: 'em menos de um minuto',
+	minuteUntil: 'em um minuto',
+	minutesUntil: 'em {delta} minutos',
+	hourUntil: 'em uma hora',
+	hoursUntil: 'em {delta} horas',
+	dayUntil: 'em um dia',
+	daysUntil: 'em {delta} dias',
+	weekUntil: 'em uma semana',
+	weeksUntil: 'em {delta} semanas',
+	monthUntil: 'em um mês',
+	monthsUntil: 'em {delta} meses',
+	yearUntil: 'em um ano',
+	yearsUntil: 'em {delta} anos'
+Script: Date.Russian.js
+	Date messages for Russian.
+	License:
+		MIT-style license.
+	Authors:
+		Evstigneev Pavel
+MooTools.lang.set('ru-RU-unicode', 'Date', {
+	months: ['Январь', 'Февраль', 'Март', 'Ð?прель', 'Май', 'Июнь', 'Июль', 'Ð?вгуÑ?Ñ‚', 'СентÑ?брь', 'ОктÑ?брь', 'Ð?оÑ?брь', 'Декабрь'],
+	days: ['ВоÑ?креÑ?енье', 'Понедельник', 'Вторник', 'Среда', 'Четверг', 'ПÑ?тница', 'Суббота'],
+	AM: 'AM',
+	PM: 'PM',
+   *  Russian language pluralization rules, taken from CLDR project, http://unicode.org/cldr/
+   *  one -> n mod 10 is 1 and n mod 100 is not 11;
+   *  few -> n mod 10 in 2..4 and n mod 100 not in 12..14;
+   *  many -> n mod 10 is 0 or n mod 10 in 5..9 or n mod 100 in 11..14;
+   *  other -> everything else (example 3.14)
+  pluralize: function (n, one, few, many, other) {
+    var modulo10 = n % 10
+    var modulo100 = n % 100
+    if (modulo10 == 1 && modulo100 != 11) {
+      return one;
+    } else if ((modulo10 == 2 || modulo10 == 3 || modulo10 == 4) && !(modulo100 == 12 || modulo100 == 13 || modulo100 == 14)) {
+      return few;
+    } else if (modulo10 == 0 || (modulo10 == 5 || modulo10 == 6 || modulo10 == 7 || modulo10 == 8 || modulo10 == 9) || (modulo100 == 11 || modulo100 == 12 || modulo100 == 13 || modulo100 == 14)) {
+      return many;
+    } else {
+      return other;
+	/* Date.Extras */
+	ordinal: '',
+	lessThanMinuteAgo: 'меньше минуты назад',
+	minuteAgo: 'минута назад',
+	minutesAgo: function (delta) { return  '{delta} ' + this.pluralize(delta, 'минута', 'минуты', 'минут') + ' назад'},
+	hourAgo: 'чаÑ? назад',
+	hoursAgo: function (delta) { return  '{delta} ' + this.pluralize(delta, 'чаÑ?', 'чаÑ?а', 'чаÑ?ов') + ' назад'},
+	dayAgo: 'вчера',
+	daysAgo: function (delta) { return '{delta} ' + this.pluralize(delta, 'день', 'днÑ?', 'дней') + ' назад' },
+	lessThanMinuteUntil: 'меньше минуты назад',
+	minuteUntil: 'через минуту',
+	minutesUntil: function (delta) { return  'через {delta} ' + this.pluralize(delta, 'чаÑ?', 'чаÑ?а', 'чаÑ?ов') + ''},
+	hourUntil: 'через чаÑ?',
+	hoursUntil: function (delta) { return  'через {delta} ' + this.pluralize(delta, 'чаÑ?', 'чаÑ?а', 'чаÑ?ов') + ''},
+	dayUntil: 'завтра',
+	daysUntil: function (delta) { return 'через {delta} ' + this.pluralize(delta, 'день', 'днÑ?', 'дней') + '' }
+script: Date.Spanish.US.js
+description: Date messages for Spanish.
+authors:
+ - Ãlfons Sanchez
+requires:
+ - /Lang
+ - /Date
+provides: [Date.Spanish]
+MooTools.lang.set('es-ES', 'Date', {
+	months: ['Enero', 'Febrero', 'Marzo', 'Abril', 'Mayo', 'Junio', 'Julio', 'Agosto', 'Septiembre', 'Octubre', 'Noviembre', 'Diciembre'],
+	days: ['Domingo', 'Lunes', 'Martes', 'Miércoles', 'Jueves', 'Viernes', 'Sábado'],
+	AM: 'AM',
+	PM: 'PM',
+	/* Date.Extras */
+	ordinal: '',
+	lessThanMinuteAgo: 'hace menos de un minuto',
+	minuteAgo: 'hace un minuto',
+	minutesAgo: 'hace {delta} minutos',
+	hourAgo: 'hace una hora',
+	hoursAgo: 'hace unas {delta} horas',
+	dayAgo: 'hace un día',
+	daysAgo: 'hace {delta} días',
+	weekAgo: 'hace una semana',
+	weeksAgo: 'hace unas {delta} semanas',
+	monthAgo: 'hace un mes',
+	monthsAgo: 'hace {delta} meses',
+	yearAgo: 'hace un año',
+	yearsAgo: 'hace {delta} años',
+	lessThanMinuteUntil: 'menos de un minuto desde ahora',
+	minuteUntil: 'un minuto desde ahora',
+	minutesUntil: '{delta} minutos desde ahora',
+	hourUntil: 'una hora desde ahora',
+	hoursUntil: 'unas {delta} horas desde ahora',
+	dayUntil: 'un día desde ahora',
+	daysUntil: '{delta} días desde ahora',
+	weekUntil: 'una semana desde ahora',
+	weeksUntil: 'unas {delta} semanas desde ahora',
+	monthUntil: 'un mes desde ahora',
+	monthsUntil: '{delta} meses desde ahora',
+	yearUntil: 'un año desde ahora',
+	yearsUntil: '{delta} años desde ahora'
+script: Date.Swedish.js
+description: Date messages for Swedish (SE).
+authors:
+ - Martin Lundgren
+requires:
+ - /Lang
+ - /Date
+provides: [Date.Swedish]
+MooTools.lang.set('sv-SE', 'Date', {
+	months: ['januari', 'februari', 'mars', 'april', 'maj', 'juni', 'juli', 'augusti', 'september', 'oktober', 'november', 'december'],
+	days: ['söndag', 'måndag', 'tisdag', 'onsdag', 'torsdag', 'fredag', 'lördag'],
+	// culture's date order: YYYY-MM-DD
+	AM: '',
+	PM: '',
+	/* Date.Extras */
+		// Not used in Swedish
+		return '';
+	lessThanMinuteAgo: 'mindre än en minut sedan',
+	minuteAgo: 'ungefär en minut sedan',
+	minutesAgo: '{delta} minuter sedan',
+	hourAgo: 'ungefär en timme sedan',
+	hoursAgo: 'ungefär {delta} timmar sedan',
+	dayAgo: '1 dag sedan',
+	daysAgo: '{delta} dagar sedan',
+	lessThanMinuteUntil: 'mindre än en minut sedan',
+	minuteUntil: 'ungefär en minut sedan',
+	minutesUntil: '{delta} minuter sedan',
+	hourUntil: 'ungefär en timme sedan',
+	hoursUntil: 'ungefär {delta} timmar sedan',
+	dayUntil: '1 dag sedan',
+	daysUntil: '{delta} dagar sedan'
+script: Date.Ukrainian.js
+description: Date messages for Ukrainian.
+authors:
+ - Slik
+requires:
+ - /Lang
+ - /Date
+provides: [Date.Ukrainian]
+(function(){
+	var pluralize = function(n, one, few, many, other){
+		var d = (n / 10).toInt();
+		var z = n % 10;
+		var s = (n / 100).toInt();
+		if(d == 1 && n > 10) return many;
+		if(z == 1) return one;
+		if(z > 0 && z < 5) return few;
+		return many;
+	MooTools.lang.set('uk-UA', 'Date', {
+			months: ['Січень', 'Лютий', 'Березень', 'Квітень', 'Травень', 'Червень', 'Липень', 'Серпень', 'ВереÑ?ень', 'Жовтень', 'ЛиÑ?топад', 'Грудень'],
+			days: ['Ð?еділÑ?', 'Понеділок', 'Вівторок', 'Середа', 'Четвер', 'П\'Ñ?тницÑ?', 'Субота'],
+			AM: 'до полуднÑ?',
+			PM: 'по полудню',
+			/* Date.Extras */
+			ordinal: '',
+			lessThanMinuteAgo: 'меньше хвилини тому',
+			minuteAgo: 'хвилину тому',
+			minutesAgo: function (delta){
+				return '{delta} ' + pluralize(delta, 'хвилину', 'хвилини', 'хвилин') + ' тому';
+			hourAgo: 'годину тому',
+			hoursAgo: function (delta){
+				return '{delta} ' + pluralize(delta, 'годину', 'години', 'годин') + ' тому';
+			dayAgo: 'вчора',
+			daysAgo: function (delta){
+				return '{delta} ' + pluralize(delta, 'день', 'днÑ?', 'днів') + ' тому';
+			weekAgo: 'тиждень тому',
+			weeksAgo: function (delta){
+				return '{delta} ' + pluralize(delta, 'тиждень', 'тижні', 'тижнів') + ' тому';
+			monthAgo: 'міÑ?Ñ?ць тому',
+			monthsAgo: function (delta){
+				return '{delta} ' + pluralize(delta, 'міÑ?Ñ?ць', 'міÑ?Ñ?ці', 'міÑ?Ñ?ців') + ' тому';
+			yearAgo: 'рік тому',
+			yearsAgo: function (delta){
+				return '{delta} ' + pluralize(delta, 'рік', 'роки', 'років') + ' тому';
+			lessThanMinuteUntil: 'за мить',
+			minuteUntil: 'через хвилину',
+			minutesUntil: function (delta){
+				return 'через {delta} ' + pluralize(delta, 'хвилину', 'хвилини', 'хвилин');
+			hourUntil: 'через годину',
+			hoursUntil: function (delta){
+				return 'через {delta} ' + pluralize(delta, 'годину', 'години', 'годин');
+			daysUntil: function (delta){
+				return 'через {delta} ' + pluralize(delta, 'день', 'днÑ?', 'днів');
+			weekUntil: 'через тиждень',
+			weeksUntil: function (delta){
+				return 'через {delta} ' + pluralize(delta, 'тиждень', 'тижні', 'тижнів');
+			monthUntil: 'через міÑ?Ñ?ць',
+			monthesUntil: function (delta){
+				return 'через {delta} ' + pluralize(delta, 'міÑ?Ñ?ць', 'міÑ?Ñ?ці', 'міÑ?Ñ?ців');
+			yearUntil: 'через рік',
+			yearsUntil: function (delta){
+				return 'через {delta} ' + pluralize(delta, 'рік', 'роки', 'років');
+script: Form.Validator.Arabic.js
+description: Form.Validator messages in Arabic.
+authors:
+ - Chafik Barbar
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.Arabic]
+MooTools.lang.set('ar', 'Form.Validator', {
+	required:'هذا الحقل مطلوب.',
+	minLength:'رجاءً إدخال {minLength}  أحرÙ? على الأقل (تم إدخال {length} أحرÙ?).',
+	maxLength:'الرجاء عدم إدخال أكثر من {maxLength} أحرÙ? (تم إدخال {length} أحرÙ?).',
+	integer:'الرجاء إدخال عدد صحيح Ù?ÙŠ هذا الحقل. أي رقم ذو كسر عشري أو مئوي (مثال 1.25 ) غير مسموح.',
+	numeric:'الرجاء إدخال قيم رقمية Ù?ÙŠ هذا الحقل (مثال "1" أو "1.1" أو "-1" أو "-1.1").',
+	digits:'الرجاء أستخدام قيم رقمية وعلامات ترقيمية Ù?قط Ù?ÙŠ هذا الحقل (مثال, رقم هاتÙ? مع نقطة أو شحطة)',
+	alpha:'الرجاء أستخدام أحرÙ? Ù?قط (ا-ÙŠ) Ù?ÙŠ هذا الحقل. أي Ù?راغات أو علامات غير مسموحة.',
+	alphanum:'الرجاء أستخدام أحرÙ? Ù?قط (ا-ÙŠ) أو أرقام (0-9) Ù?قط Ù?ÙŠ هذا الحقل. أي Ù?راغات أو علامات غير مسموحة.',
+	dateSuchAs:'الرجاء إدخال تاريخ صحيح كالتالي {date}',
+	dateInFormatMDY:'الرجاء إدخال تاريخ صحيح (مثال, 31-12-1999)',
+	email:'الرجاء إدخال بريد إلكتروني صحيح.',
+	url:'الرجاء إدخال عنوان إلكتروني صحيح مثل http://www.google.com',
+	currencyDollar:'الرجاء إدخال قيمة $ صحيحة.  مثال, 100.00$',
+	oneRequired:'الرجاء إدخال قيمة Ù?ÙŠ أحد هذه الحقول على الأقل.',
+	errorPrefix: 'خطأ: ',
+	warningPrefix: 'تحذير: '
+}).set('ar', 'Date', {
+	dateOrder: ['date', 'month', 'year', '/']
+script: Form.Validator.Catalan.js
+authors:
+ - Miquel Hudin
+ - Alfons Sanchez
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.Catalan]
+MooTools.lang.set('ca-CA', 'Form.Validator', {
+	required:'Aquest camp es obligatori.',
+	minLength:'Per favor introdueix al menys {minLength} caracters (has introduit {length} caracters).',
+	maxLength:'Per favor introdueix no mes de {maxLength} caracters (has introduit {length} caracters).',
+	integer:'Per favor introdueix un nombre enter en aquest camp. Nombres amb decimals (p.e. 1,25) no estan permesos.',
+	numeric:'Per favor introdueix sols valors numerics en aquest camp (p.e. "1" o "1,1" o "-1" o "-1,1").',
+	digits:'Per favor usa sols numeros i puntuacio en aquest camp (per exemple, un nombre de telefon amb guions i punts no esta permes).',
+	alpha:'Per favor utilitza lletres nomes (a-z) en aquest camp. No s´admiteixen espais ni altres caracters.',
+	alphanum:'Per favor, utilitza nomes lletres (a-z) o numeros (0-9) en aquest camp. No s´admiteixen espais ni altres caracters.',
+	dateSuchAs:'Per favor introdueix una data valida com {date}',
+	dateInFormatMDY:'Per favor introdueix una data valida com DD/MM/YYYY (p.e. "31/12/1999")',
+	email:'Per favor, introdueix una adreça de correu electronic valida. Per exemple,  "fred at domain.com".',
+	url:'Per favor introdueix una URL valida com http://www.google.com.',
+	currencyDollar:'Per favor introdueix una quantitat valida de €. Per exemple €100,00 .',
+	oneRequired:'Per favor introdueix alguna cosa per al menys una d´aquestes entrades.',
+	errorPrefix: 'Error: ',
+	warningPrefix: 'Avis: ',
+	//Form.Validator.Extras
+	noSpace: 'No poden haver espais en aquesta entrada.',
+	reqChkByNode: 'No hi han elements seleccionats.',
+	requiredChk: 'Aquest camp es obligatori.',
+	reqChkByName: 'Per favor selecciona una {label}.',
+	match: 'Aquest camp necessita coincidir amb el camp {matchName}',
+	startDate: 'la data de inici',
+	endDate: 'la data de fi',
+	currendDate: 'la data actual',
+	afterDate: 'La data deu ser igual o posterior a {label}.',
+	beforeDate: 'La data deu ser igual o anterior a {label}.',
+	startMonth: 'Per favor selecciona un mes d´orige',
+	sameMonth: 'Aquestes dos dates deuen estar dins del mateix mes - deus canviar una o altra.'
+script: Form.Validator.Czech.js
+description: Form Validator messages for Czech.
+authors:
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.Czech]
+MooTools.lang.set('cs-CZ', 'Form.Validator', {
+	required:'Tato položka je povinná.',
+	minLength:'Zadejte prosím alespoň {minLength} znaků (napsáno {length} znaků).',
+	maxLength:'Zadejte prosím méně než {maxLength} znaků (nápsáno {length} znaků).',
+	integer:'Zadejte prosím celé Ä?íslo. Desetinná Ä?ísla (napÅ™. 1.25) nejsou povolena.',
+	numeric:'Zadejte jen Ä?íselné hodnoty  (tj. "1" nebo "1.1" nebo "-1" nebo "-1.1").',
+	digits:'Zadejte prosím pouze Ä?ísla a interpunkÄ?ní znaménka(například telefonní Ä?íslo s pomlÄ?kami nebo teÄ?kami je povoleno).',
+	alpha:'Zadejte prosím pouze písmena (a-z). Mezery nebo jiné znaky nejsou povoleny.',
+	alphanum:'Zadejte prosím pouze písmena (a-z) nebo Ä?íslice (0-9). Mezery nebo jiné znaky nejsou povoleny.',
+	dateSuchAs:'Zadejte prosím platné datum jako {date}',
+	dateInFormatMDY:'Zadejte prosím platné datum jako MM / DD / RRRR (tj. "12/31/1999")',
+	email:'Zadejte prosím platnou e-mailovou adresu. Například "fred at domain.com".',
+	url:'Zadejte prosím platnou URL adresu jako http://www.google.com.',
+	currencyDollar:'Zadejte prosím platnou Ä?ástku. Například $100.00.',
+	oneRequired:'Zadejte prosím alespoň jednu hodnotu pro tyto položky.',
+	errorPrefix: 'Chyba: ',
+	warningPrefix: 'Upozornění: ',
+	noSpace: 'V této položce nejsou povoleny mezery',
+	reqChkByNode: 'Nejsou vybrány žádné položky.',
+	requiredChk: 'Tato položka je vyžadována.',
+	reqChkByName: 'Prosím vyberte {label}.',
+	match: 'Tato položka se musí shodovat s položkou {matchName}',
+	startDate: 'datum zahájení',
+	endDate: 'datum ukonÄ?ení',
+	currendDate: 'aktuální datum',
+	afterDate: 'Datum by mělo být stejné nebo větší než {label}.',
+	beforeDate: 'Datum by mělo být stejné nebo menší než {label}.',
+	startMonth: 'Vyberte poÄ?áteÄ?ní mÄ›síc.',
+	sameMonth: 'Tyto dva datumy musí být ve stejném měsíci - změňte jeden z nich.',
+    creditcard: 'Zadané Ä?íslo kreditní karty je neplatné. Prosím opravte ho. Bylo zadáno {length} Ä?ísel.'
+script: Form.Validator.Chinese.js
+description: Form.Validator messages in chinese (both simplified and traditional).
+authors:
+ - 陈桂军 - guidy <at> ixuer [dot] net
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.Chinese]
+In Chinese:
+需�指出的是:
+简体中文适用于中国大陆,
+�体中文适用于香港�澳门和�湾�。
+简体中文和�体中文在字体和语法上有很多的��之处。
+我�以确�简体中文语言包的准确性,
+但对于�体中文,我�以��用户�以准确的�解,但无法��语�符�他们的阅读习惯。
+如果您�能确认的�,�以�使用简体中文语言包,因为它是最通用的。
+In English:
+It should be noted that:
+Simplified  Chinese apply to mainland Chinese,
+Traditional Chinese apply to Hong Kong, Macao and Taiwan Province.
+There are a lot of different from Simplified  Chinese and Traditional Chinese , Contains font and syntax .
+I can assure Simplified Chinese language pack accuracy .
+For Traditional Chinese, I can only guarantee that users can understand, but not necessarily in line with their reading habits.
+If you are unsure, you can only use the simplified Chinese language pack, as it is the most common.
+// Simplified Chinese
+MooTools.lang.set('zhs-CN', 'Form.Validator', {
+	required:'这是必填项。',
+	minLength:'请至少输入 {minLength} 个字符 (已输入 {length} 个)。',
+	maxLength:'最多�能输入 {maxLength} 个字符 (已输入 {length} 个)。',
+	integer:'请输入一个整数,�能包��数点。例如:"1", "200"。',
+	numeric:'请输入一个数字,例如:"1", "1.1", "-1", "-1.1"。',
+	digits:'这里�能接�数字和标点的输入,标点�以是:"(", ")", ".", ":", "-", "+", "#"和空格。',
+	alpha:'请输入 A-Z 的 26 个字�,�能包�空格或任何其他字符。',
+	alphanum:'请输入 A-Z 的 26 个字�或 0-9 的 10 个数字,�能包�空格或任何其他字符。',
+	dateSuchAs:'请输入�法的日期格�,如:{date}。',
+	dateInFormatMDY:'请输入�法的日期格�,例如:MM/DD/YYYY ("12/31/1999")。',
+	email:'请输入�法的电�信箱地�,例如:"fred at domain.com"。',
+	url:'请输入�法的 Url 地�,例如:http://www.google.com。',
+	currencyDollar:'请输入�法的货�符�,例如:¥',
+	oneRequired:'请至少选择一项。',
+	errorPrefix: '错误:',
+	warningPrefix: '警告:'
+// Traditional Chinese
+MooTools.lang.set('zht-CN', 'Form.Validator', {
+	required:'這是必填項。',
+	minLength:'請至少�入 {minLength} 個字符(已�入 {length} 個)。',
+	maxLength:'最多�能�入 {maxLength} 個字符(已�入 {length} 個)。',
+	integer:'請�入一個整數,�能包��數點。例如:"1", "200"。',
+	numeric:'請�入一個數字,例如:"1", "1.1", "-1", "-1.1"。',
+	digits:'這裡�能接�數字和標點的�入,標點�以是:"(", ")", ".", ":", "-", "+", "#"和空格。',
+	alpha:'請�入 A-Z 的 26 個字�,�能包�空格或任何其他字符。',
+	alphanum:'請�入 A-Z 的 26 個字�或 0-9 的 10 個數字,�能包�空格或任何其他字符。',
+	dateSuchAs:'請�入�法的日期格�,如:{date}。',
+	dateInFormatMDY:'請�入�法的日期格�,例如:MM/DD/YYYY ("12/31/1999")。',
+	email:'請�入�法的電�信箱地�,例如:"fred at domain.com"。',
+	url:'請�入�法的 Url 地�,例如:http://www.google.com。',
+	currencyYuan:'請�入�法的貨幣符號,例如:¥',
+	oneRequired:'請至少�擇一項。',
+	errorPrefix: '錯誤:',
+Form.Validator.add('validate-currency-yuan', {
+	errorMsg: function(){
+		return Form.Validator.getMsg('currencyYuan');
+	test: function(element) {
+		// [ï¿¥]1[##][,###]+[.##]
+		// [ï¿¥]1###+[.##]
+		// [ï¿¥]0.##
+		// [ï¿¥].##
+		return Form.Validator.getValidator('IsEmpty').test(element) ||  (/^ï¿¥?\-?([1-9]{1}[0-9]{0,2}(\,[0-9]{3})*(\.[0-9]{0,2})?|[1-9]{1}\d*(\.[0-9]{0,2})?|0(\.[0-9]{0,2})?|(\.[0-9]{1,2})?)$/).test(element.get('value'));
+script: Form.Validator.Dutch.js
+description: Form.Validator messages in Dutch.
+authors:
+ - Lennart Pilon
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.Dutch]
+MooTools.lang.set('nl-NL', 'Form.Validator', {
+	required:'Dit veld is verplicht.',
+	minLength:'Vul minimaal {minLength} karakters in (je hebt {length} karakters ingevoerd).',
+	maxLength:'Vul niet meer dan {maxLength} karakters in (je hebt {length} karakters ingevoerd).',
+	integer:'Vul een getal in. Getallen met decimalen (bijvoorbeeld 1,25) zijn niet toegestaan.',
+	numeric:'Vul alleen numerieke waarden in (bijvoorbeeld. "1" of "1.1" of "-1" of "-1.1").',
+	digits:'Vul alleen nummers en leestekens in (bijvoorbeeld een telefoonnummer met een streepje).',
+	alpha:'Vul alleen letters in (a-z). Spaties en andere karakters zijn niet toegestaan.',
+	alphanum:'Vul alleen letters in (a-z) of nummers (0-9). Spaties en andere karakters zijn niet toegestaan.',
+	dateSuchAs:'Vul een geldige datum in, zoals {date}',
+	dateInFormatMDY:'Vul een geldige datum, in het formaat MM/DD/YYYY (bijvoorbeeld "12/31/1999")',
+	email:'Vul een geldig e-mailadres in. Bijvoorbeeld "fred at domein.nl".',
+	url:'Vul een geldige URL in, zoals http://www.google.nl.',
+	currencyDollar:'Vul een geldig $ bedrag in. Bijvoorbeeld $100.00 .',
+	oneRequired:'Vul iets in bij minimaal een van de invoervelden.',
+	warningPrefix: 'Waarschuwing: ',
+	errorPrefix: 'Fout: '
+script: Form.Validator.Estonian.js
+authors:
+ - Kevin Valdek
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.Estonian]
+MooTools.lang.set('et-EE', 'Form.Validator', {
+	required:'Väli peab olema täidetud.',
+	minLength:'Palun sisestage vähemalt {minLength} tähte (te sisestasite {length} tähte).',
+	maxLength:'Palun ärge sisestage rohkem kui {maxLength} tähte (te sisestasite {length} tähte).',
+	integer:'Palun sisestage väljale täisarv. Kümnendarvud (näiteks 1.25) ei ole lubatud.',
+	numeric:'Palun sisestage ainult numbreid väljale (näiteks "1", "1.1", "-1" või "-1.1").',
+	digits:'Palun kasutage ainult numbreid ja kirjavahemärke (telefoninumbri sisestamisel on lubatud kasutada kriipse ja punkte).',
+	alpha:'Palun kasutage ainult tähti (a-z). Tühikud ja teised sümbolid on keelatud.',
+	alphanum:'Palun kasutage ainult tähti (a-z) või numbreid (0-9). Tühikud ja teised sümbolid on keelatud.',
+	dateSuchAs:'Palun sisestage kehtiv kuupäev kujul {date}',
+	dateInFormatMDY:'Palun sisestage kehtiv kuupäev kujul MM.DD.YYYY (näiteks: "12.31.1999").',
+	email:'Palun sisestage kehtiv e-maili aadress (näiteks: "fred at domain.com").',
+	url:'Palun sisestage kehtiv URL (näiteks: http://www.google.com).',
+	currencyDollar:'Palun sisestage kehtiv $ summa (näiteks: $100.00).',
+	oneRequired:'Palun sisestage midagi vähemalt ühele antud väljadest.',
+	errorPrefix: 'Viga: ',
+	warningPrefix: 'Hoiatus: ',
+	noSpace: 'Väli ei tohi sisaldada tühikuid.',
+	reqChkByNode: 'Ükski väljadest pole valitud.',
+	requiredChk: 'Välja täitmine on vajalik.',
+	reqChkByName: 'Palun valige üks {label}.',
+	match: 'Väli peab sobima {matchName} väljaga',
+	startDate: 'algkuupäev',
+	endDate: 'lõppkuupäev',
+	currendDate: 'praegune kuupäev',
+	afterDate: 'Kuupäev peab olema võrdne või pärast {label}.',
+	beforeDate: 'Kuupäev peab olema võrdne või enne {label}.',
+	startMonth: 'Palun valige algkuupäev.',
+	sameMonth: 'Antud kaks kuupäeva peavad olema samas kuus - peate muutma ühte kuupäeva.'
+script: Form.Validator.German.js
+authors:
+ - Frank Rossi
+ - Ulrich Petri
+ - Fabian Beiner
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.German]
+MooTools.lang.set('de-DE', 'Form.Validator', {
+	required: 'Dieses Eingabefeld muss ausgef&uuml;llt werden.',
+	minLength: 'Geben Sie bitte mindestens {minLength} Zeichen ein (Sie haben nur {length} Zeichen eingegeben).',
+	maxLength: 'Geben Sie bitte nicht mehr als {maxLength} Zeichen ein (Sie haben {length} Zeichen eingegeben).',
+	integer: 'Geben Sie in diesem Eingabefeld bitte eine ganze Zahl ein. Dezimalzahlen (z.B. &quot;1.25&quot;) sind nicht erlaubt.',
+	numeric: 'Geben Sie in diesem Eingabefeld bitte nur Zahlenwerte (z.B. &quot;1&quot;, &quot;1.1&quot;, &quot;-1&quot; oder &quot;-1.1&quot;) ein.',
+	digits: 'Geben Sie in diesem Eingabefeld bitte nur Zahlen und Satzzeichen ein (z.B. eine Telefonnummer mit Bindestrichen und Punkten ist erlaubt).',
+	alpha: 'Geben Sie in diesem Eingabefeld bitte nur Buchstaben (a-z) ein. Leerzeichen und andere Zeichen sind nicht erlaubt.',
+	alphanum: 'Geben Sie in diesem Eingabefeld bitte nur Buchstaben (a-z) und Zahlen (0-9) ein. Leerzeichen oder andere Zeichen sind nicht erlaubt.',
+	dateSuchAs: 'Geben Sie bitte ein g&uuml;ltiges Datum ein (z.B. &quot;{date}&quot;).',
+	dateInFormatMDY: 'Geben Sie bitte ein g&uuml;ltiges Datum im Format TT.MM.JJJJ ein (z.B. &quot;31.12.1999&quot;).',
+	email: 'Geben Sie bitte eine g&uuml;ltige E-Mail-Adresse ein (z.B. &quot;max at mustermann.de&quot;).',
+	url: 'Geben Sie bitte eine g&uuml;ltige URL ein (z.B. &quot;http://www.google.de&quot;).',
+	currencyDollar: 'Geben Sie bitte einen g&uuml;ltigen Betrag in EURO ein (z.B. 100.00&#8364;).',
+	oneRequired: 'Bitte f&uuml;llen Sie mindestens ein Eingabefeld aus.',
+	errorPrefix: 'Fehler: ',
+	warningPrefix: 'Warnung: ',
+	noSpace: 'Es darf kein Leerzeichen in diesem Eingabefeld sein.',
+	reqChkByNode: 'Es wurden keine Elemente gew&auml;hlt.',
+	requiredChk: 'Dieses Feld muss ausgef&uuml;llt werden.',
+	reqChkByName: 'Bitte w&auml;hlen Sie ein {label}.',
+	match: 'Dieses Eingabefeld muss mit dem {matchName} Eingabefeld &uuml;bereinstimmen.',
+	startDate: 'Das Anfangsdatum',
+	endDate: 'Das Enddatum',
+	currendDate: 'Das aktuelle Datum',
+	afterDate: 'Das Datum sollte zur gleichen Zeit oder sp&auml;ter sein als {label}.',
+	beforeDate: 'Das Datum sollte zur gleichen Zeit oder fr&uuml;her sein als {label}.',
+	startMonth: 'W&auml;hlen Sie bitte einen Anfangsmonat',
+	sameMonth: 'Diese zwei Datumsangaben m&uuml;ssen im selben Monat sein - Sie m&uuml;ssen eines von beiden ver&auml;ndern.',
+	creditcard: 'Die eingegebene Kreditkartennummer ist ung&uuml;ltig. Bitte &uuml;berpr&uuml;fen Sie diese und versuchen Sie es erneut. {length} Zahlen eingegeben.'
+script: Form.Validator.German.CH.js
+authors:
+requires:
+ - /Lang
+ - /Form.Validator.German
+provides: [Form.Validator.German.CH]
+MooTools.lang.set('de-CH', 'Form.Validator', {
+  required:'Dieses Feld ist obligatorisch.',
+  minLength:'Geben Sie bitte mindestens {minLength} Zeichen ein (Sie haben {length} Zeichen eingegeben).',
+  maxLength:'Bitte geben Sie nicht mehr als {maxLength} Zeichen ein (Sie haben {length} Zeichen eingegeben).',
+  integer:'Geben Sie bitte eine ganze Zahl ein. Dezimalzahlen (z.B. 1.25) sind nicht erlaubt.',
+  numeric:'Geben Sie bitte nur Zahlenwerte in dieses Eingabefeld ein (z.B. &quot;1&quot;, &quot;1.1&quot;, &quot;-1&quot; oder &quot;-1.1&quot;).',
+  digits:'Benutzen Sie bitte nur Zahlen und Satzzeichen in diesem Eingabefeld (erlaubt ist z.B. eine Telefonnummer mit Bindestrichen und Punkten).',
+  alpha:'Benutzen Sie bitte nur Buchstaben (a-z) in diesem Feld. Leerzeichen und andere Zeichen sind nicht erlaubt.',
+  alphanum:'Benutzen Sie bitte nur Buchstaben (a-z) und Zahlen (0-9) in diesem Eingabefeld. Leerzeichen und andere Zeichen sind nicht erlaubt.',
+  dateSuchAs:'Geben Sie bitte ein g&uuml;ltiges Datum ein. Wie zum Beispiel {date}',
+  dateInFormatMDY:'Geben Sie bitte ein g&uuml;ltiges Datum ein. Wie zum Beispiel TT.MM.JJJJ (z.B. &quot;31.12.1999&quot;)',
+  email:'Geben Sie bitte eine g&uuml;ltige E-Mail Adresse ein. Wie zum Beispiel &quot;maria at bernasconi.ch&quot;.',
+  url:'Geben Sie bitte eine g&uuml;ltige URL ein. Wie zum Beispiel http://www.google.ch.',
+  currencyDollar:'Geben Sie bitte einen g&uuml;ltigen Betrag in Schweizer Franken ein. Wie zum Beispiel 100.00 CHF .',
+  oneRequired:'Machen Sie f&uuml;r mindestens eines der Eingabefelder einen Eintrag.',
+  noSpace: 'In diesem Eingabefeld darf kein Leerzeichen sein.',
+  requiredChk: 'Dieses Feld ist obligatorisch.',
+  match: 'Dieses Eingabefeld muss mit dem Feld {matchName} &uuml;bereinstimmen.',
+  afterDate: 'Das Datum sollte zur gleichen Zeit oder sp&auml;ter sein {label}.',
+  beforeDate: 'Das Datum sollte zur gleichen Zeit oder fr&uuml;her sein {label}.',
+  sameMonth: 'Diese zwei Datumsangaben m&uuml;ssen im selben Monat sein - Sie m&uuml;ssen eine von beiden ver&auml;ndern.'
+script: Form.Validator.French.js
+description: Form.Validator messages in French.
+authors:
+ - Miquel Hudin
+ - Nicolas Sorosac <nicolas <dot> sorosac <at> gmail <dot> com>
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.French]
+MooTools.lang.set('fr-FR', 'Form.Validator', {
+  required:'Ce champ est obligatoire.',
+  minLength:'Veuillez saisir un minimum de {minLength} caract&egrave;re(s) (vous avez saisi {length} caract&egrave;re(s)).',
+  maxLength:'Veuillez saisir un maximum de {maxLength} caract&egrave;re(s) (vous avez saisi {length} caract&egrave;re(s)).',
+  integer:'Veuillez saisir un nombre entier dans ce champ. Les nombres d&eacute;cimaux (ex : "1,25") ne sont pas autoris&eacute;s.',
+  numeric:'Veuillez saisir uniquement des chiffres dans ce champ (ex : "1" ou "1,1" ou "-1" ou "-1,1").',
+  digits:'Veuillez saisir uniquement des chiffres et des signes de ponctuation dans ce champ (ex : un num&eacute;ro de t&eacute;l&eacute;phone avec des traits d\'union est autoris&eacute;).',
+  alpha:'Veuillez saisir uniquement des lettres (a-z) dans ce champ. Les espaces ou autres caract&egrave;res ne sont pas autoris&eacute;s.',
+  alphanum:'Veuillez saisir uniquement des lettres (a-z) ou des chiffres (0-9) dans ce champ. Les espaces ou autres caract&egrave;res ne sont pas autoris&eacute;s.',
+  dateSuchAs:'Veuillez saisir une date correcte comme {date}',
+  dateInFormatMDY:'Veuillez saisir une date correcte, au format JJ/MM/AAAA (ex : "31/11/1999").',
+  email:'Veuillez saisir une adresse de courrier &eacute;lectronique. Par example "fred at domaine.com".',
+  url:'Veuillez saisir une URL, comme http://www.google.com.',
+  currencyDollar:'Veuillez saisir une quantit&eacute; correcte. Par example 100,00&euro;.',
+  oneRequired:'Veuillez s&eacute;lectionner au moins une de ces options.',
+  errorPrefix: 'Erreur : ',
+  warningPrefix: 'Attention : ',
+  noSpace: 'Ce champ n\'accepte pas les espaces.',
+  reqChkByNode: 'Aucun &eacute;l&eacute;ment n\'est s&eacute;lectionn&eacute;.',
+  requiredChk: 'Ce champ est obligatoire.',
+  reqChkByName: 'Veuillez s&eacute;lectionner un(e) {label}.',
+  match: 'Ce champ doit correspondre avec le champ {matchName}.',
+  startDate: 'date de d&eacute;but',
+  endDate: 'date de fin',
+  currendDate: 'date actuelle',
+  afterDate: 'La date doit &ecirc;tre identique ou post&eacute;rieure &agrave; {label}.',
+  beforeDate: 'La date doit &ecirc;tre identique ou ant&eacute;rieure &agrave; {label}.',
+  startMonth: 'Veuillez s&eacute;lectionner un mois de d&eacute;but.',
+  sameMonth: 'Ces deux dates doivent &ecirc;tre dans le m&ecirc;me mois - vous devez en modifier une.'
+script: Form.Validator.Italian.js
+description: Form.Validator messages in Italian.
+authors:
+ - Leonardo Laureti
+ - Andrea Novero
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.Italian]
+MooTools.lang.set('it-IT', 'Form.Validator', {
+	required:'Il campo &egrave; obbligatorio.',
+	minLength:'Inserire almeno {minLength} caratteri (ne sono stati inseriti {length}).',
+	maxLength:'Inserire al massimo {maxLength} caratteri (ne sono stati inseriti {length}).',
+	integer:'Inserire un numero intero. Non sono consentiti decimali (es.: 1.25).',
+	numeric:'Inserire solo valori numerici (es.: "1" oppure "1.1" oppure "-1" oppure "-1.1").',
+	digits:'Inserire solo numeri e caratteri di punteggiatura. Per esempio &egrave; consentito un numero telefonico con trattini o punti.',
+	alpha:'Inserire solo lettere (a-z). Non sono consentiti spazi o altri caratteri.',
+	alphanum:'Inserire solo lettere (a-z) o numeri (0-9). Non sono consentiti spazi o altri caratteri.',
+	dateSuchAs:'Inserire una data valida del tipo {date}',
+	dateInFormatMDY:'Inserire una data valida nel formato MM/GG/AAAA (es.: "12/31/1999")',
+	email:'Inserire un indirizzo email valido. Per esempio "nome at dominio.com".',
+	url:'Inserire un indirizzo valido. Per esempio "http://www.dominio.com".',
+	currencyDollar:'Inserire un importo valido. Per esempio "$100.00".',
+	oneRequired:'Completare almeno uno dei campi richiesti.',
+	errorPrefix: 'Errore: ',
+	warningPrefix: 'Attenzione: ',
+	noSpace: 'Non sono consentiti spazi.',
+	reqChkByNode: 'Nessuna voce selezionata.',
+	requiredChk: 'Il campo &egrave; obbligatorio.',
+	reqChkByName: 'Selezionare un(a) {label}.',
+	match: 'Il valore deve corrispondere al campo {matchName}',
+	startDate: 'data d\'inizio',
+	endDate: 'data di fine',
+	currendDate: 'data attuale',
+	afterDate: 'La data deve corrispondere o essere successiva al {label}.',
+	beforeDate: 'La data deve corrispondere o essere precedente al {label}.',
+	startMonth: 'Selezionare un mese d\'inizio',
+	sameMonth: 'Le due date devono essere dello stesso mese - occorre modificarne una.'
+script: Form.Validator.Norwegian.js
+description: Form.Validator messages in Norwegian.
+authors:
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.Norwegian]
+MooTools.lang.set('no-NO', 'Form.Validator', {
+   required:'Dette feltet er påkrevd.',
+   minLength:'Vennligst skriv inn minst {minLength} tegn (du skrev {length} tegn).',
+   maxLength:'Vennligst skriv inn maksimalt {maxLength} tegn (du skrev {length} tegn).',
+   integer:'Vennligst skriv inn et tall i dette feltet. Tall med desimaler (for eksempel 1,25) er ikke tillat.',
+   numeric:'Vennligst skriv inn kun numeriske verdier i dette feltet (for eksempel "1", "1.1", "-1" eller "-1.1").',
+   digits:'Vennligst bruk kun nummer og skilletegn i dette feltet.',
+   alpha:'Vennligst bruk kun bokstaver (a-z) i dette feltet. Ingen mellomrom eller andre tegn er tillat.',
+   alphanum:'Vennligst bruk kun bokstaver (a-z) eller nummer (0-9) i dette feltet. Ingen mellomrom eller andre tegn er tillat.',
+   dateSuchAs:'Vennligst skriv inn en gyldig dato, som {date}',
+   dateInFormatMDY:'Vennligst skriv inn en gyldig dato, i formatet MM/DD/YYYY (for eksempel "12/31/1999")',
+   email:'Vennligst skriv inn en gyldig epost-adresse. For eksempel "espen at domene.no".',
+   url:'Vennligst skriv inn en gyldig URL, for eksempel http://www.google.no.',
+   currencyDollar:'Vennligst fyll ut et gyldig $ beløp. For eksempel $100.00 .',
+   oneRequired:'Vennligst fyll ut noe i minst ett av disse feltene.',
+   errorPrefix: 'Feil: ',
+   warningPrefix: 'Advarsel: '
+script: Form.Validator.Polish.js
+authors:
+ - Oskar Krawczyk
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.Polish]
+MooTools.lang.set('pl-PL', 'Form.Validator', {
+	required:'To pole jest wymagane.',
+	minLength:'Wymagane jest przynajmniej {minLength} znaków (wpisanych zostało tylko {length}).',
+	maxLength:'Dozwolone jest nie więcej niż {maxLength} znaków (wpisanych zostało {length})',
+	integer:'To pole wymaga liczb całych. Liczby dziesiętne (np. 1.25) są niedozwolone.',
+	numeric:'Prosimy używać tylko numerycznych wartości w tym polu (np. "1", "1.1", "-1" lub "-1.1").',
+	digits:'Prosimy używać liczb oraz zankow punktuacyjnych w typ polu (dla przykładu, przy numerze telefonu myślniki i kropki są dozwolone).',
+	alpha:'Prosimy używać tylko liter (a-z) w tym polu. Spacje oraz inne znaki są niedozwolone.',
+	alphanum:'Prosimy używać tylko liter (a-z) lub liczb (0-9) w tym polu. Spacje oraz inne znaki są niedozwolone.',
+	dateSuchAs:'Prosimy podać prawidłową datę w formacie: {date}',
+	dateInFormatMDY:'Prosimy podać poprawną date w formacie DD.MM.RRRR (i.e. "12.01.2009")',
+	email:'Prosimy podać prawidłowy adres e-mail, np. "jan at domena.pl".',
+	url:'Prosimy podać prawidłowy adres URL, np. http://www.google.pl.',
+	currencyDollar:'Prosimy podać prawidłową sumę w PLN. Dla przykładu: 100.00 PLN.',
+	oneRequired:'Prosimy wypełnić chociaż jedno z pól.',
+	errorPrefix: 'Błąd: ',
+	warningPrefix: 'Uwaga: ',
+	noSpace: 'W tym polu nie mogą znajdować się spacje.',
+	reqChkByNode: 'Brak zaznaczonych elementów.',
+	requiredChk: 'To pole jest wymagane.',
+	reqChkByName: 'Prosimy wybrać z {label}.',
+	match: 'To pole musi być takie samo jak {matchName}',
+	startDate: 'data poczÄ…tkowa',
+	endDate: 'data końcowa',
+	currendDate: 'aktualna data',
+	afterDate: 'Podana data poinna być taka sama lub po {label}.',
+	beforeDate: 'Podana data poinna być taka sama lub przed {label}.',
+	startMonth: 'Prosimy wybrać początkowy miesiąc.',
+	sameMonth: 'Te dwie daty muszą być w zakresie tego samego miesiąca - wymagana jest zmiana któregoś z pól.'
+script: Form.Validator.Portuguese.js
+description: Form.Validator messages in Portuguese.
+authors:
+ - Miquel Hudin
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.Portuguese]
+MooTools.lang.set('pt-PT', 'Form.Validator', {
+	required:'Este campo é necessário.',
+	minLength:'Digite pelo menos{minLength} caracteres (comprimento {length} caracteres).',
+	maxLength:'Não insira mais de {maxLength} caracteres (comprimento {length} caracteres).',
+	integer:'Digite um número inteiro neste domínio. Com números decimais (por exemplo, 1,25), não são permitidas.',
+	numeric:'Digite apenas valores numéricos neste domínio (p.ex., "1" ou "1.1" ou "-1" ou "-1,1").',
+	digits:'Por favor, use números e pontuação apenas neste campo (p.ex., um número de telefone com traços ou pontos é permitida).',
+	alpha:'Por favor use somente letras (a-z), com nesta área. Não utilize espaços nem outros caracteres são permitidos.',
+	alphanum:'Use somente letras (a-z) ou números (0-9) neste campo. Não utilize espaços nem outros caracteres são permitidos.',
+	dateSuchAs:'Digite uma data válida, como {date}',
+	dateInFormatMDY:'Digite uma data válida, como DD/MM/YYYY (p.ex. "31/12/1999")',
+	email:'Digite um endereço de email válido. Por exemplo "fred at domain.com".',
+	url:'Digite uma URL válida, como http://www.google.com.',
+	currencyDollar:'Digite um valor válido $. Por exemplo $ 100,00. ',
+	oneRequired:'Digite algo para pelo menos um desses insumos.',
+	errorPrefix: 'Erro: ',
+	warningPrefix: 'Aviso: '
+}).set('pt-PT', 'Date', {
+script: Form.Validator.Portuguese.BR.js
+description: Form.Validator messages in Portuguese-BR.
+authors:
+ - Fábio Miranda Costa
+requires:
+ - /Lang
+ - /Form.Validator.Portuguese
+provides: [Form.Validator.Portuguese.BR]
+MooTools.lang.set('pt-BR', 'Form.Validator', {
+	required: 'Este campo é obrigatório.',
+	minLength: 'Digite pelo menos {minLength} caracteres (tamanho atual: {length}).',
+	maxLength: 'Não digite mais de {maxLength} caracteres (tamanho atual: {length}).',
+	integer: 'Por favor digite apenas um número inteiro neste campo. Não são permitidos números decimais (por exemplo, 1,25).',
+	numeric: 'Por favor digite apenas valores numéricos neste campo (por exemplo, "1" ou "1.1" ou "-1" ou "-1,1").',
+	digits: 'Por favor use apenas números e pontuação neste campo (por exemplo, um número de telefone com traços ou pontos é permitido).',
+	alpha: 'Por favor use somente letras (a-z). Espaço e outros caracteres não são permitidos.',
+	alphanum: 'Use somente letras (a-z) ou números (0-9) neste campo. Espaço e outros caracteres não são permitidos.',
+	dateSuchAs: 'Digite uma data válida, como {date}',
+	dateInFormatMDY: 'Digite uma data válida, como DD/MM/YYYY (por exemplo, "31/12/1999")',
+	email: 'Digite um endereço de email válido. Por exemplo "nome at dominio.com".',
+	url: 'Digite uma URL válida. Exemplo: http://www.google.com.',
+	currencyDollar: 'Digite um valor em dinheiro válido. Exemplo: R$100,00 .',
+	oneRequired: 'Digite algo para pelo menos um desses campos.',
+	warningPrefix: 'Aviso: ',
+	noSpace: 'Não é possível digitar espaços neste campo.',
+	reqChkByNode: 'Não foi selecionado nenhum item.',
+	requiredChk: 'Este campo é obrigatório.',
+	reqChkByName: 'Por favor digite um {label}.',
+	match: 'Este campo deve ser igual ao campo {matchName}.',
+	startDate: 'a data inicial',
+	endDate: 'a data final',
+	currendDate: 'a data atual',
+	afterDate: 'A data deve ser igual ou posterior a {label}.',
+	beforeDate: 'A data deve ser igual ou anterior a {label}.',
+	startMonth: 'Por favor selecione uma data inicial.',
+	sameMonth: 'Estas duas datas devem ter o mesmo mês - você deve modificar uma das duas.',
+	creditcard: 'O número do cartão de crédito informado é inválido. Por favor verifique o valor e tente novamente. {length} números informados.'
+script: Form.Validator.Russian.js
+description: Form.Validator messages in Russian (utf-8 and cp1251).
+authors:
+ - Chernodarov Egor
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.Russian]
+MooTools.lang.set('ru-RU-unicode', 'Form.Validator', {
+	required:'Это поле обÑ?зательно к заполнению.',
+	minLength:'ПожалуйÑ?та, введите хотÑ? бы {minLength} Ñ?имволов (Ð’Ñ‹ ввели {length}).',
+	maxLength:'ПожалуйÑ?та, введите не больше {maxLength} Ñ?имволов (Ð’Ñ‹ ввели {length}).',
+	integer:'ПожалуйÑ?та, введите в Ñ?то поле чиÑ?ло. Дробные чиÑ?ла (например 1.25) тут не разрешены.',
+	numeric:'ПожалуйÑ?та, введите в Ñ?то поле чиÑ?ло (например "1" или "1.1", или "-1", или "-1.1").',
+	digits:'Ð’ Ñ?том поле Ð’Ñ‹ можете иÑ?пользовать только цифры и знаки пунктуации (например, телефонный номер Ñ?о знаками дефиÑ?а или Ñ? точками).',
+	alpha:'Ð’ Ñ?том поле можно иÑ?пользовать только латинÑ?кие буквы (a-z). Пробелы и другие Ñ?имволы запрещены.',
+	alphanum:'Ð’ Ñ?том поле можно иÑ?пользовать только латинÑ?кие буквы (a-z) и цифры (0-9). Пробелы и другие Ñ?имволы запрещены.',
+	dateSuchAs:'ПожалуйÑ?та, введите корректную дату {date}',
+	dateInFormatMDY:'ПожалуйÑ?та, введите дату в формате ММ/ДД/ГГГГ (например "12/31/1999")',
+	email:'ПожалуйÑ?та, введите корректный емейл-адреÑ?. ДлÑ? примера "fred at domain.com".',
+	url:'ПожалуйÑ?та, введите правильную Ñ?Ñ?ылку вида http://www.google.com.',
+	currencyDollar:'ПожалуйÑ?та, введите Ñ?умму в долларах. Ð?апример: $100.00 .',
+	oneRequired:'ПожалуйÑ?та, выберите хоть что-нибудь в одном из Ñ?тих полей.',
+	errorPrefix: 'Ошибка: ',
+	warningPrefix: 'Внимание: '
+//translation in windows-1251 codepage
+MooTools.lang.set('ru-RU', 'Form.Validator', {
+	required:'�òî ïîëå îáÿçàòåëüíî ê çàïîëíåíèþ.',
+	minLength:'�îæàëóéñòà, ââåäèòå õîòÿ áû {minLength} ñèìâîëîâ (Âû ââåëè {length}).',
+	maxLength:'�îæàëóéñòà, ââåäèòå íå áîëüøå {maxLength} ñèìâîëîâ (Âû ââåëè {length}).',
+	integer:'�îæàëóéñòà, ââåäèòå â ýòî ïîëå ÷èñëî. Äðîáíûå ÷èñëà (íàïðèìåð 1.25) òóò íå ðàçðåøåíû.',
+	numeric:'�îæàëóéñòà, ââåäèòå â ýòî ïîëå ÷èñëî (íàïðèìåð "1" èëè "1.1", èëè "-1", èëè "-1.1").',
+	digits:' ýòîì ïîëå Âû ìîæåòå èñïîëüçîâàòü òîëüêî öèôðû è çíàêè ïóíêòóàöèè (íàïðèìåð, òåëåôîííûé íîìåð ñî çíàêàìè äåôèñà èëè ñ òî÷êàìè).',
+	alpha:' ýòîì ïîëå ìîæíî èñïîëüçîâàòü òîëüêî ëàòèíñêèå áóêâû (a-z). �ðîáåëû è äðóãèå ñèìâîëû çàïðåùåíû.',
+	alphanum:' ýòîì ïîëå ìîæíî èñïîëüçîâàòü òîëüêî ëàòèíñêèå áóêâû (a-z) è öèôðû (0-9). �ðîáåëû è äðóãèå ñèìâîëû çàïðåùåíû.',
+	dateSuchAs:'�îæàëóéñòà, ââåäèòå êîððåêòíóþ äàòó {date}',
+	dateInFormatMDY:'�îæàëóéñòà, ââåäèòå äàòó â ôîðìàòå ÌÌ/ÄÄ/ÃÃÃà (íàïðèìåð "12/31/1999")',
+	email:'�îæàëóéñòà, ââåäèòå êîððåêòíûé åìåéë-àäðåñ. Äëÿ ïðèìåðà "fred at domain.com".',
+	url:'�îæàëóéñòà, ââåäèòå ïðàâèëüíóþ ññûëêó âèäà http://www.google.com.',
+	currencyDollar:'�îæàëóéñòà, ââåäèòå ñóììó â äîëëàðàõ. �àïðèìåð: $100.00 .',
+	oneRequired:'�îæàëóéñòà, âûáåðèòå õîòü ÷òî-íèáóäü â îäíîì èç ýòèõ ïîëåé.',
+	errorPrefix: 'Îøèáêà: ',
+	warningPrefix: 'Âíèìàíèå: '
+script: Form.Validator.Spanish.js
+authors:
+ - Ãlfons Sanchez
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.Spanish]
+MooTools.lang.set('es-ES', 'Form.Validator', {
+	required:'Este campo es obligatorio.',
+	minLength:'Por favor introduce al menos {minLength} caracteres (has introducido {length} caracteres).',
+	maxLength:'Por favor introduce no m&aacute;s de {maxLength} caracteres (has introducido {length} caracteres).',
+	integer:'Por favor introduce un n&uacute;mero entero en este campo. N&uacute;meros con decimales (p.e. 1,25) no se permiten.',
+	numeric:'Por favor introduce solo valores num&eacute;ricos en este campo (p.e. "1" o "1,1" o "-1" o "-1,1").',
+	digits:'Por favor usa solo n&uacute;meros y puntuaci&oacute;n en este campo (por ejemplo, un n&uacute;mero de tel&eacute;fono con guiones y puntos no esta permitido).',
+	alpha:'Por favor usa letras solo (a-z) en este campo. No se admiten espacios ni otros caracteres.',
+	alphanum:'Por favor, usa solo letras (a-z) o n&uacute;meros (0-9) en este campo. No se admiten espacios ni otros caracteres.',
+	dateSuchAs:'Por favor introduce una fecha v&aacute;lida como {date}',
+	dateInFormatMDY:'Por favor introduce una fecha v&aacute;lida como DD/MM/YYYY (p.e. "31/12/1999")',
+	email:'Por favor, introduce una direcci&oacute;n de email v&aacute;lida. Por ejemplo,  "fred at domain.com".',
+	url:'Por favor introduce una URL v&aacute;lida como http://www.google.com.',
+	currencyDollar:'Por favor introduce una cantidad v&aacute;lida de €. Por ejemplo €100,00 .',
+	oneRequired:'Por favor introduce algo para por lo menos una de estas entradas.',
+	noSpace: 'No pueden haber espacios en esta entrada.',
+	reqChkByNode: 'No hay elementos seleccionados.',
+	requiredChk: 'Este campo es obligatorio.',
+	reqChkByName: 'Por favor selecciona una {label}.',
+	match: 'Este campo necesita coincidir con el campo {matchName}',
+	startDate: 'la fecha de inicio',
+	endDate: 'la fecha de fin',
+	currendDate: 'la fecha actual',
+	afterDate: 'La fecha debe ser igual o posterior a {label}.',
+	beforeDate: 'La fecha debe ser igual o anterior a {label}.',
+	startMonth: 'Por favor selecciona un mes de origen',
+	sameMonth: 'Estas dos fechas deben estar en el mismo mes - debes cambiar una u otra.'
+script: Form.Validator.Swedish.js
+description: Date messages for Swedish.
+authors:
+ - Martin Lundgren
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.Swedish]
+MooTools.lang.set('sv-SE', 'Form.Validator', {
+	required:'Fältet är obligatoriskt.',
+	minLength:'Ange minst {minLength} tecken (du angav {length} tecken).',
+	maxLength:'Ange högst {maxLength} tecken (du angav {length} tecken). ',
+	integer:'Ange ett heltal i fältet. Tal med decimaler (t.ex. 1,25) är inte tillåtna.',
+	numeric:'Ange endast numeriska värden i detta fält (t.ex. "1" eller "1.1" eller "-1" eller "-1,1").',
+	digits:'Använd endast siffror och skiljetecken i detta fält (till exempel ett telefonnummer med bindestreck tillåtet).',
+	alpha:'Använd endast bokstäver (a-ö) i detta fält. Inga mellanslag eller andra tecken är tillåtna.',
+	alphanum:'Använd endast bokstäver (a-ö) och siffror (0-9) i detta fält. Inga mellanslag eller andra tecken är tillåtna.',
+	dateSuchAs:'Ange ett giltigt datum som t.ex. {date}',
+	dateInFormatMDY:'Ange ett giltigt datum som t.ex. YYYY-MM-DD (i.e. "1999-12-31")',
+	email:'Ange en giltig e-postadress. Till exempel "erik at domain.com".',
+	url:'Ange en giltig webbadress som http://www.google.com.',
+	currencyDollar:'Ange en giltig belopp. Exempelvis 100,00.',
+	oneRequired:'Vänligen ange minst ett av dessa alternativ.',
+	errorPrefix: 'Fel: ',
+	warningPrefix: 'Varning: ',
+	noSpace: 'Det får inte finnas några mellanslag i detta fält.',
+	reqChkByNode: 'Inga objekt är valda.',
+	requiredChk: 'Detta är ett obligatoriskt fält.',
+	reqChkByName: 'Välj en {label}.',
+	match: 'Detta fält måste matcha {matchName}',
+	startDate: 'startdatumet',
+	endDate: 'slutdatum',
+	currendDate: 'dagens datum',
+	afterDate: 'Datumet bör vara samma eller senare än {label}.',
+	beforeDate: 'Datumet bör vara samma eller tidigare än {label}.',
+	startMonth: 'Välj en start månad',
+	sameMonth: 'Dessa två datum måste vara i samma månad - du måste ändra det ena eller det andra.'
+script: Form.Validator.Ukrainian.js
+description: Form.Validator messages in Ukrainian (utf-8).
+authors:
+ - Slik
+requires:
+ - /Lang
+ - /Form.Validator
+provides: [Form.Validator.Ukrainian]
+MooTools.lang.set('uk-UA', 'Form.Validator', {
+	required:'Це поле повинне бути заповненим.',
+	minLength:'Введіть хоча б {minLength} Ñ?имволів (Ви ввели {length}).',
+	maxLength:'КількіÑ?ть Ñ?имволів не може бути більше {maxLength} (Ви ввели {length}).',
+	integer:'Введіть в це поле чиÑ?ло. Дробові чиÑ?ла (наприклад 1.25) не дозволені.',
+	numeric:'Введіть в це поле чиÑ?ло (наприклад "1" або "1.1", або "-1", або "-1.1").',
+	digits:'Ð’ цьому полі ви можете викориÑ?товувати лише цифри Ñ– знаки пунктіації (наприклад, телефонний номер з знаками дефізу або з крапками).',
+	alpha:'Ð’ цьому полі можна викориÑ?товувати лише латинÑ?ькі літери (a-z). Пробіли Ñ– інші Ñ?имволи заборонені.',
+	alphanum:'Ð’ цьому полі можна викориÑ?товувати лише латинÑ?ькі літери (a-z) Ñ– цифри (0-9). Пробіли Ñ– інші Ñ?имволи заборонені.',
+	dateSuchAs:'Введіть коректну дату {date}.',
+	dateInFormatMDY:'Введіть дату в форматі ММ/ДД/РРРР (наприклад "12/31/2009").',
+	email:'Введіть коректну адреÑ?у електронної пошти (наприклад "name at domain.com").',
+	url:'Введіть коректне інтернет-поÑ?иланнÑ? (наприклад http://www.google.com).',
+	currencyDollar:'Введіть Ñ?уму в доларах (наприклад "$100.00").',
+	oneRequired:'Заповніть одне з полів.',
+	errorPrefix: 'Помилка: ',
+	warningPrefix: 'Увага: '
-script: Core.js
-description: The core of MooTools, contains all the base functions and the Native and Hash implementations. Required by all the other scripts.
-license: MIT-style license.
-copyright: Copyright (c) 2006-2008 [Valerio Proietti](http://mad4milk.net/).
-authors: The MooTools production team (http://mootools.net/developers/)
-inspiration:
-- Class implementation inspired by [Base.js](http://dean.edwards.name/weblog/2006/03/base/) Copyright (c) 2006 Dean Edwards, [GNU Lesser General Public License](http://opensource.org/licenses/lgpl-license.php)
-- Some functionality inspired by [Prototype.js](http://prototypejs.org) Copyright (c) 2005-2007 Sam Stephenson, [MIT License](http://opensource.org/licenses/mit-license.php)
-provides: [MooTools, Native, Hash.base, Array.each, $util]
-var MooTools = {
-	'version': '1.2.5dev',
-	'build': '%build%'
-var Native = function(options){
-	options = options || {};
-	var name = options.name;
-	var legacy = options.legacy;
-	var protect = options.protect;
-	var methods = options.implement;
-	var generics = options.generics;
-	var initialize = options.initialize;
-	var afterImplement = options.afterImplement || function(){};
-	var object = initialize || legacy;
-	generics = generics !== false;
-	object.constructor = Native;
-	object.$family = {name: 'native'};
-	if (legacy && initialize) object.prototype = legacy.prototype;
-	object.prototype.constructor = object;
-	if (name){
-		var family = name.toLowerCase();
-		object.prototype.$family = {name: family};
-		Native.typize(object, family);
-	var add = function(obj, name, method, force){
-		if (!protect || force || !obj.prototype[name]) obj.prototype[name] = method;
-		if (generics) Native.genericize(obj, name, protect);
-		afterImplement.call(obj, name, method);
-		return obj;
-	object.alias = function(a1, a2, a3){
-		if (typeof a1 == 'string'){
-			var pa1 = this.prototype[a1];
-			if ((a1 = pa1)) return add(this, a2, a1, a3);
-		for (var a in a1) this.alias(a, a1[a], a2);
-		return this;
-	object.implement = function(a1, a2, a3){
-		if (typeof a1 == 'string') return add(this, a1, a2, a3);
-		for (var p in a1) add(this, p, a1[p], a2);
-		return this;
-	if (methods) object.implement(methods);
-	return object;
-Native.genericize = function(object, property, check){
-	if ((!check || !object[property]) && typeof object.prototype[property] == 'function') object[property] = function(){
-		var args = Array.prototype.slice.call(arguments);
-		return object.prototype[property].apply(args.shift(), args);
-Native.implement = function(objects, properties){
-	for (var i = 0, l = objects.length; i < l; i++) objects[i].implement(properties);
-Native.typize = function(object, family){
-	if (!object.type) object.type = function(item){
-		return ($type(item) === family);
-(function(){
-	var natives = {'Array': Array, 'Date': Date, 'Function': Function, 'Number': Number, 'RegExp': RegExp, 'String': String};
-	for (var n in natives) new Native({name: n, initialize: natives[n], protect: true});
-	var types = {'boolean': Boolean, 'native': Native, 'object': Object};
-	for (var t in types) Native.typize(types[t], t);
-	var generics = {
-		'Array': ["concat", "indexOf", "join", "lastIndexOf", "pop", "push", "reverse", "shift", "slice", "sort", "splice", "toString", "unshift", "valueOf"],
-		'String': ["charAt", "charCodeAt", "concat", "indexOf", "lastIndexOf", "match", "replace", "search", "slice", "split", "substr", "substring", "toLowerCase", "toUpperCase", "valueOf"]
-	for (var g in generics){
-		for (var i = generics[g].length; i--;) Native.genericize(natives[g], generics[g][i], true);
-var Hash = new Native({
-	name: 'Hash',
-	initialize: function(object){
-		if ($type(object) == 'hash') object = $unlink(object.getClean());
-		for (var key in object) this[key] = object[key];
-		return this;
-Hash.implement({
-	forEach: function(fn, bind){
-		for (var key in this){
-			if (this.hasOwnProperty(key)) fn.call(bind, this[key], key, this);
-	getClean: function(){
-		var clean = {};
-			if (this.hasOwnProperty(key)) clean[key] = this[key];
-		return clean;
-	getLength: function(){
-		var length = 0;
-			if (this.hasOwnProperty(key)) length++;
-		return length;
-Hash.alias('forEach', 'each');
-Array.implement({
-		for (var i = 0, l = this.length; i < l; i++) fn.call(bind, this[i], i, this);
-Array.alias('forEach', 'each');
-function $A(iterable){
-	if (iterable.item){
-		var l = iterable.length, array = new Array(l);
-		while (l--) array[l] = iterable[l];
-		return array;
-	return Array.prototype.slice.call(iterable);
-function $arguments(i){
-	return function(){
-		return arguments[i];
-function $chk(obj){
-	return !!(obj || obj === 0);
-function $clear(timer){
-	clearTimeout(timer);
-	clearInterval(timer);
-	return null;
-function $defined(obj){
-	return (obj != undefined);
-function $each(iterable, fn, bind){
-	var type = $type(iterable);
-	((type == 'arguments' || type == 'collection' || type == 'array') ? Array : Hash).each(iterable, fn, bind);
-function $empty(){};
-function $extend(original, extended){
-	for (var key in (extended || {})) original[key] = extended[key];
-	return original;
-function $H(object){
-	return new Hash(object);
-function $lambda(value){
-	return ($type(value) == 'function') ? value : function(){
-		return value;
-function $merge(){
-	var args = Array.slice(arguments);
-	args.unshift({});
-	return $mixin.apply(null, args);
-function $mixin(mix){
-	for (var i = 1, l = arguments.length; i < l; i++){
-		var object = arguments[i];
-		if ($type(object) != 'object') continue;
-		for (var key in object){
-			var op = object[key], mp = mix[key];
-			mix[key] = (mp && $type(op) == 'object' && $type(mp) == 'object') ? $mixin(mp, op) : $unlink(op);
-	return mix;
-function $pick(){
-	for (var i = 0, l = arguments.length; i < l; i++){
-		if (arguments[i] != undefined) return arguments[i];
-	return null;
-function $random(min, max){
-	return Math.floor(Math.random() * (max - min + 1) + min);
-function $splat(obj){
-	var type = $type(obj);
-	return (type) ? ((type != 'array' && type != 'arguments') ? [obj] : obj) : [];
-var $time = Date.now || function(){
-	return +new Date;
-function $try(){
-		try {
-			return arguments[i]();
-		} catch(e){}
-	return null;
-function $type(obj){
-	if (obj == undefined) return false;
-	if (obj.$family) return (obj.$family.name == 'number' && !isFinite(obj)) ? false : obj.$family.name;
-	if (obj.nodeName){
-		switch (obj.nodeType){
-			case 1: return 'element';
-			case 3: return (/\S/).test(obj.nodeValue) ? 'textnode' : 'whitespace';
-	} else if (typeof obj.length == 'number'){
-		if (obj.callee) return 'arguments';
-		else if (obj.item) return 'collection';
-	return typeof obj;
-function $unlink(object){
-	var unlinked;
-	switch ($type(object)){
-		case 'object':
-			unlinked = {};
-			for (var p in object) unlinked[p] = $unlink(object[p]);
-		break;
-		case 'hash':
-			unlinked = new Hash(object);
-		break;
-		case 'array':
-			unlinked = [];
-			for (var i = 0, l = object.length; i < l; i++) unlinked[i] = $unlink(object[i]);
-		break;
-		default: return object;
-	return unlinked;
-script: Browser.js
-description: The Browser Core. Contains Browser initialization, Window and Document, and the Browser Hash.
-requires:
-- /Native
-- /$util
-provides: [Browser, Window, Document, $exec]
-var Browser = $merge({
-	Engine: {name: 'unknown', version: 0},
-	Platform: {name: (window.orientation != undefined) ? 'ipod' : (navigator.platform.match(/mac|win|linux/i) || ['other'])[0].toLowerCase()},
-	Features: {xpath: !!(document.evaluate), air: !!(window.runtime), query: !!(document.querySelector)},
-	Plugins: {},
-	Engines: {
-		presto: function(){
-			return (!window.opera) ? false : ((arguments.callee.caller) ? 960 : ((document.getElementsByClassName) ? 950 : 925));
-		trident: function(){
-			return (!window.ActiveXObject) ? false : ((window.XMLHttpRequest) ? ((document.querySelectorAll) ? 6 : 5) : 4);
-		webkit: function(){
-			return (navigator.taintEnabled) ? false : ((Browser.Features.xpath) ? ((Browser.Features.query) ? 525 : 420) : 419);
-		gecko: function(){
-			return (!document.getBoxObjectFor && window.mozInnerScreenX == null) ? false : ((document.getElementsByClassName) ? 19 : 18);
-}, Browser || {});
-Browser.Platform[Browser.Platform.name] = true;
-Browser.detect = function(){
-	for (var engine in this.Engines){
-		var version = this.Engines[engine]();
-		if (version){
-			this.Engine = {name: engine, version: version};
-			this.Engine[engine] = this.Engine[engine + version] = true;
-			break;
-	return {name: engine, version: version};
-Browser.detect();
-Browser.Request = function(){
-	return $try(function(){
-		return new XMLHttpRequest();
-	}, function(){
-		return new ActiveXObject('MSXML2.XMLHTTP');
-	}, function(){
-		return new ActiveXObject('Microsoft.XMLHTTP');
-Browser.Features.xhr = !!(Browser.Request());
-Browser.Plugins.Flash = (function(){
-	var version = ($try(function(){
-		return navigator.plugins['Shockwave Flash'].description;
-	}, function(){
-		return new ActiveXObject('ShockwaveFlash.ShockwaveFlash').GetVariable('$version');
-	}) || '0 r0').match(/\d+/g);
-	return {version: parseInt(version[0] || 0 + '.' + version[1], 10) || 0, build: parseInt(version[2], 10) || 0};
-function $exec(text){
-	if (!text) return text;
-	if (window.execScript){
-		window.execScript(text);
-	} else {
-		var script = document.createElement('script');
-		script.setAttribute('type', 'text/javascript');
-		script[(Browser.Engine.webkit && Browser.Engine.version < 420) ? 'innerText' : 'text'] = text;
-		document.head.appendChild(script);
-		document.head.removeChild(script);
-	return text;
-Native.UID = 1;
-var $uid = (Browser.Engine.trident) ? function(item){
-	return (item.uid || (item.uid = [Native.UID++]))[0];
-} : function(item){
-	return item.uid || (item.uid = Native.UID++);
-var Window = new Native({
-	name: 'Window',
-	legacy: (Browser.Engine.trident) ? null: window.Window,
-	initialize: function(win){
-		$uid(win);
-		if (!win.Element){
-			win.Element = $empty;
-			if (Browser.Engine.webkit) win.document.createElement("iframe"); //fixes safari 2
-			win.Element.prototype = (Browser.Engine.webkit) ? window["[[DOMElement.prototype]]"] : {};
-		win.document.window = win;
-		return $extend(win, Window.Prototype);
-	afterImplement: function(property, value){
-		window[property] = Window.Prototype[property] = value;
-Window.Prototype = {$family: {name: 'window'}};
-new Window(window);
-var Document = new Native({
-	name: 'Document',
-	legacy: (Browser.Engine.trident) ? null: window.Document,
-	initialize: function(doc){
-		$uid(doc);
-		doc.head = doc.getElementsByTagName('head')[0];
-		doc.html = doc.getElementsByTagName('html')[0];
-		if (Browser.Engine.trident && Browser.Engine.version <= 4) $try(function(){
-			doc.execCommand("BackgroundImageCache", false, true);
-		if (Browser.Engine.trident) doc.window.attachEvent('onunload', function(){
-			doc.window.detachEvent('onunload', arguments.callee);
-			doc.head = doc.html = doc.window = null;
-		return $extend(doc, Document.Prototype);
-		document[property] = Document.Prototype[property] = value;
-Document.Prototype = {$family: {name: 'document'}};
-new Document(document);
-script: Array.js
-description: Contains Array Prototypes like each, contains, and erase.
-requires:
-- /$util
-- /Array.each
-provides: [Array]
-Array.implement({
-	every: function(fn, bind){
-		for (var i = 0, l = this.length; i < l; i++){
-			if (!fn.call(bind, this[i], i, this)) return false;
-		return true;
-	filter: function(fn, bind){
-		var results = [];
-			if (fn.call(bind, this[i], i, this)) results.push(this[i]);
-		return results;
-	clean: function(){
-		return this.filter($defined);
-	indexOf: function(item, from){
-		var len = this.length;
-		for (var i = (from < 0) ? Math.max(0, len + from) : from || 0; i < len; i++){
-			if (this[i] === item) return i;
-		return -1;
-	map: function(fn, bind){
-		var results = [];
-		for (var i = 0, l = this.length; i < l; i++) results[i] = fn.call(bind, this[i], i, this);
-		return results;
-	some: function(fn, bind){
-			if (fn.call(bind, this[i], i, this)) return true;
-		return false;
-	associate: function(keys){
-		var obj = {}, length = Math.min(this.length, keys.length);
-		for (var i = 0; i < length; i++) obj[keys[i]] = this[i];
-		return obj;
-	link: function(object){
-		var result = {};
-				if (object[key](this[i])){
-					result[key] = this[i];
-					delete object[key];
-					break;
-		return result;
-	contains: function(item, from){
-		return this.indexOf(item, from) != -1;
-	extend: function(array){
-		for (var i = 0, j = array.length; i < j; i++) this.push(array[i]);
-		return this;
-	getLast: function(){
-		return (this.length) ? this[this.length - 1] : null;
-	getRandom: function(){
-		return (this.length) ? this[$random(0, this.length - 1)] : null;
-	include: function(item){
-		if (!this.contains(item)) this.push(item);
-		return this;
-	combine: function(array){
-		for (var i = 0, l = array.length; i < l; i++) this.include(array[i]);
-		return this;
-	erase: function(item){
-		for (var i = this.length; i--; i){
-			if (this[i] === item) this.splice(i, 1);
-		return this;
-	empty: function(){
-		this.length = 0;
-		return this;
-	flatten: function(){
-		var array = [];
-			var type = $type(this[i]);
-			if (!type) continue;
-			array = array.concat((type == 'array' || type == 'collection' || type == 'arguments') ? Array.flatten(this[i]) : this[i]);
-		return array;
-	hexToRgb: function(array){
-		if (this.length != 3) return null;
-		var rgb = this.map(function(value){
-			if (value.length == 1) value += value;
-			return value.toInt(16);
-		return (array) ? rgb : 'rgb(' + rgb + ')';
-	rgbToHex: function(array){
-		if (this.length < 3) return null;
-		if (this.length == 4 && this[3] == 0 && !array) return 'transparent';
-		var hex = [];
-		for (var i = 0; i < 3; i++){
-			var bit = (this[i] - 0).toString(16);
-			hex.push((bit.length == 1) ? '0' + bit : bit);
-		return (array) ? hex : '#' + hex.join('');
-script: Function.js
-description: Contains Function Prototypes like create, bind, pass, and delay.
-requires:
-- /Native
-- /$util
-provides: [Function]
-Function.implement({
-	extend: function(properties){
-		for (var property in properties) this[property] = properties[property];
-		return this;
-	create: function(options){
-		var self = this;
-		return function(event){
-			var args = options.arguments;
-			args = (args != undefined) ? $splat(args) : Array.slice(arguments, (options.event) ? 1 : 0);
-			if (options.event) args = [event || window.event].extend(args);
-			var returns = function(){
-				return self.apply(options.bind || null, args);
-			if (options.delay) return setTimeout(returns, options.delay);
-			if (options.periodical) return setInterval(returns, options.periodical);
-			if (options.attempt) return $try(returns);
-			return returns();
-	run: function(args, bind){
-		return this.apply(bind, $splat(args));
-	pass: function(args, bind){
-		return this.create({bind: bind, arguments: args});
-	bind: function(bind, args){
-	bindWithEvent: function(bind, args){
-		return this.create({bind: bind, arguments: args, event: true});
-	attempt: function(args, bind){
-		return this.create({bind: bind, arguments: args, attempt: true})();
-	delay: function(delay, bind, args){
-		return this.create({bind: bind, arguments: args, delay: delay})();
-	periodical: function(periodical, bind, args){
-		return this.create({bind: bind, arguments: args, periodical: periodical})();
-script: Number.js
-description: Contains Number Prototypes like limit, round, times, and ceil.
-requires:
-- /Native
-- /$util
-provides: [Number]
-Number.implement({
-	limit: function(min, max){
-		return Math.min(max, Math.max(min, this));
-	round: function(precision){
-		precision = Math.pow(10, precision || 0);
-		return Math.round(this * precision) / precision;
-	times: function(fn, bind){
-		for (var i = 0; i < this; i++) fn.call(bind, i, this);
-	toFloat: function(){
-		return parseFloat(this);
-	toInt: function(base){
-		return parseInt(this, base || 10);
-Number.alias('times', 'each');
-(function(math){
-	var methods = {};
-	math.each(function(name){
-		if (!Number[name]) methods[name] = function(){
-			return Math[name].apply(null, [this].concat($A(arguments)));
-	Number.implement(methods);
-})(['abs', 'acos', 'asin', 'atan', 'atan2', 'ceil', 'cos', 'exp', 'floor', 'log', 'max', 'min', 'pow', 'sin', 'sqrt', 'tan']);
-script: String.js
-description: Contains String Prototypes like camelCase, capitalize, test, and toInt.
-requires:
-- /Native
-provides: [String]
-String.implement({
-	test: function(regex, params){
-		return ((typeof regex == 'string') ? new RegExp(regex, params) : regex).test(this);
-	contains: function(string, separator){
-		return (separator) ? (separator + this + separator).indexOf(separator + string + separator) > -1 : this.indexOf(string) > -1;
-	trim: function(){
-		return this.replace(/^\s+|\s+$/g, '');
-		return this.replace(/\s+/g, ' ').trim();
-	camelCase: function(){
-		return this.replace(/-\D/g, function(match){
-			return match.charAt(1).toUpperCase();
-	hyphenate: function(){
-		return this.replace(/[A-Z]/g, function(match){
-			return ('-' + match.charAt(0).toLowerCase());
-	capitalize: function(){
-		return this.replace(/\b[a-z]/g, function(match){
-			return match.toUpperCase();
-	escapeRegExp: function(){
-		return this.replace(/([-.*+?^${}()|[\]\/\\])/g, '\\$1');
-		var hex = this.match(/^#?(\w{1,2})(\w{1,2})(\w{1,2})$/);
-		return (hex) ? hex.slice(1).hexToRgb(array) : null;
-		var rgb = this.match(/\d{1,3}/g);
-		return (rgb) ? rgb.rgbToHex(array) : null;
-	stripScripts: function(option){
-		var scripts = '';
-		var text = this.replace(/<script[^>]*>([\s\S]*?)<\/script>/gi, function(){
-			scripts += arguments[1] + '\n';
-			return '';
-		if (option === true) $exec(scripts);
-		else if ($type(option) == 'function') option(scripts, text);
-		return text;
-	substitute: function(object, regexp){
-		return this.replace(regexp || (/\\?\{([^{}]+)\}/g), function(match, name){
-			if (match.charAt(0) == '\\') return match.slice(1);
-			return (object[name] != undefined) ? object[name] : '';
-script: Hash.js
-description: Contains Hash Prototypes. Provides a means for overcoming the JavaScript practical impossibility of extending native Objects.
-requires:
-- /Hash.base
-provides: [Hash]
-Hash.implement({
-	has: Object.prototype.hasOwnProperty,
-	keyOf: function(value){
-			if (this.hasOwnProperty(key) && this[key] === value) return key;
-		return null;
-	hasValue: function(value){
-		return (Hash.keyOf(this, value) !== null);
-		Hash.each(properties || {}, function(value, key){
-			Hash.set(this, key, value);
-		}, this);
-		return this;
-	combine: function(properties){
-			Hash.include(this, key, value);
-		}, this);
-		return this;
-	erase: function(key){
-		if (this.hasOwnProperty(key)) delete this[key];
-		return this;
-	get: function(key){
-		return (this.hasOwnProperty(key)) ? this[key] : null;
-	set: function(key, value){
-		if (!this[key] || this.hasOwnProperty(key)) this[key] = value;
-		return this;
-		Hash.each(this, function(value, key){
-			delete this[key];
-		}, this);
-		return this;
-	include: function(key, value){
-		if (this[key] == undefined) this[key] = value;
-		return this;
-		var results = new Hash;
-			results.set(key, fn.call(bind, value, key, this));
-		}, this);
-		return results;
-			if (fn.call(bind, value, key, this)) results.set(key, value);
-		}, this);
-		return results;
-			if (this.hasOwnProperty(key) && !fn.call(bind, this[key], key)) return false;
-		return true;
-			if (this.hasOwnProperty(key) && fn.call(bind, this[key], key)) return true;
-		return false;
-	getKeys: function(){
-		var keys = [];
-			keys.push(key);
-		return keys;
-	getValues: function(){
-		var values = [];
-		Hash.each(this, function(value){
-			values.push(value);
-		return values;
-	toQueryString: function(base){
-		var queryString = [];
-			if (base) key = base + '[' + key + ']';
-			var result;
-			switch ($type(value)){
-				case 'object': result = Hash.toQueryString(value, key); break;
-				case 'array':
-					var qs = {};
-					value.each(function(val, i){
-						qs[i] = val;
-					result = Hash.toQueryString(qs, key);
-				break;
-				default: result = key + '=' + encodeURIComponent(value);
-			if (value != undefined) queryString.push(result);
-		return queryString.join('&');
-Hash.alias({keyOf: 'indexOf', hasValue: 'contains'});
-script: Event.js
-description: Contains the Event Class, to make the event object cross-browser.
-requires:
-- /Window
-- /Document
-- /Hash
-- /Array
-- /Function
-- /String
-provides: [Event]
-var Event = new Native({
-	name: 'Event',
-	initialize: function(event, win){
-		win = win || window;
-		var doc = win.document;
-		event = event || win.event;
-		if (event.$extended) return event;
-		this.$extended = true;
-		var type = event.type;
-		var target = event.target || event.srcElement;
-		while (target && target.nodeType == 3) target = target.parentNode;
-		if (type.test(/key/)){
-			var code = event.which || event.keyCode;
-			var key = Event.Keys.keyOf(code);
-			if (type == 'keydown'){
-				var fKey = code - 111;
-				if (fKey > 0 && fKey < 13) key = 'f' + fKey;
-			key = key || String.fromCharCode(code).toLowerCase();
-		} else if (type.match(/(click|mouse|menu)/i)){
-			doc = (!doc.compatMode || doc.compatMode == 'CSS1Compat') ? doc.html : doc.body;
-			var page = {
-				x: event.pageX || event.clientX + doc.scrollLeft,
-				y: event.pageY || event.clientY + doc.scrollTop
-			var client = {
-				x: (event.pageX) ? event.pageX - win.pageXOffset : event.clientX,
-				y: (event.pageY) ? event.pageY - win.pageYOffset : event.clientY
-			if (type.match(/DOMMouseScroll|mousewheel/)){
-				var wheel = (event.wheelDelta) ? event.wheelDelta / 120 : -(event.detail || 0) / 3;
-			var rightClick = (event.which == 3) || (event.button == 2);
-			var related = null;
-			if (type.match(/over|out/)){
-				switch (type){
-					case 'mouseover': related = event.relatedTarget || event.fromElement; break;
-					case 'mouseout': related = event.relatedTarget || event.toElement;
-				if (!(function(){
-					while (related && related.nodeType == 3) related = related.parentNode;
-					return true;
-				}).create({attempt: Browser.Engine.gecko})()) related = false;
-		return $extend(this, {
-			event: event,
-			type: type,
-			page: page,
-			client: client,
-			rightClick: rightClick,
-			wheel: wheel,
-			relatedTarget: related,
-			target: target,
-			code: code,
-			key: key,
-			shift: event.shiftKey,
-			control: event.ctrlKey,
-			alt: event.altKey,
-			meta: event.metaKey
-Event.Keys = new Hash({
-	'enter': 13,
-	'up': 38,
-	'down': 40,
-	'left': 37,
-	'right': 39,
-	'esc': 27,
-	'space': 32,
-	'backspace': 8,
-	'tab': 9,
-	'delete': 46
-Event.implement({
-	stop: function(){
-		return this.stopPropagation().preventDefault();
-	stopPropagation: function(){
-		if (this.event.stopPropagation) this.event.stopPropagation();
-		else this.event.cancelBubble = true;
-		return this;
-	preventDefault: function(){
-		if (this.event.preventDefault) this.event.preventDefault();
-		else this.event.returnValue = false;
-		return this;
-script: Class.js
-description: Contains the Class Function for easily creating, extending, and implementing reusable Classes.
-requires:
-- /$util
-- /Native
-- /Array
-- /String
-- /Function
-- /Number
-- /Hash
-provides: [Class]
-function Class(params){
-	if (params instanceof Function) params = {initialize: params};
-	var newClass = function(){
-		Object.reset(this);
-		if (newClass._prototyping) return this;
-		this._current = $empty;
-		var value = (this.initialize) ? this.initialize.apply(this, arguments) : this;
-		delete this._current; delete this.caller;
-		return value;
-	}.extend(this);
-	newClass.implement(params);
-	newClass.constructor = Class;
-	newClass.prototype.constructor = newClass;
-	return newClass;
-Function.prototype.protect = function(){
-	this._protected = true;
-	return this;
-Object.reset = function(object, key){
-	if (key == null){
-		for (var p in object) Object.reset(object, p);
-		return object;
-	switch ($type(object[key])){
-		case 'object':
-			var F = function(){};
-			F.prototype = object[key];
-			var i = new F;
-			object[key] = Object.reset(i);
-		break;
-		case 'array': object[key] = $unlink(object[key]); break;
-	return object;
-new Native({name: 'Class', initialize: Class}).extend({
-	instantiate: function(F){
-		F._prototyping = true;
-		var proto = new F;
-		delete F._prototyping;
-		return proto;
-	wrap: function(self, key, method){
-		if (method._origin) method = method._origin;
-			if (method._protected && this._current == null) throw new Error('The method "' + key + '" cannot be called.');
-			var caller = this.caller, current = this._current;
-			this.caller = current; this._current = arguments.callee;
-			var result = method.apply(this, arguments);
-			this._current = current; this.caller = caller;
-			return result;
-		}.extend({_owner: self, _origin: method, _name: key});
-Class.implement({
-	implement: function(key, value){
-		if ($type(key) == 'object'){
-			for (var p in key) this.implement(p, key[p]);
-			return this;
-		var mutator = Class.Mutators[key];
-		if (mutator){
-			value = mutator.call(this, value);
-			if (value == null) return this;
-		var proto = this.prototype;
-			case 'function':
-				if (value._hidden) return this;
-				proto[key] = Class.wrap(this, key, value);
-			break;
-			case 'object':
-				var previous = proto[key];
-				if ($type(previous) == 'object') $mixin(previous, value);
-				else proto[key] = $unlink(value);
-			break;
-			case 'array':
-				proto[key] = $unlink(value);
-			break;
-			default: proto[key] = value;
-		return this;
-Class.Mutators = {
-	Extends: function(parent){
-		this.parent = parent;
-		this.prototype = Class.instantiate(parent);
-		this.implement('parent', function(){
-			var name = this.caller._name, previous = this.caller._owner.parent.prototype[name];
-			if (!previous) throw new Error('The method "' + name + '" has no parent.');
-			return previous.apply(this, arguments);
-		}.protect());
-	Implements: function(items){
-		$splat(items).each(function(item){
-			if (item instanceof Function) item = Class.instantiate(item);
-			this.implement(item);
-		}, this);
-script: Class.Extras.js
-description: Contains Utility Classes that can be implemented into your own Classes to ease the execution of many common tasks.
-requires:
-- /Class
-provides: [Chain, Events, Options]
-var Chain = new Class({
-	$chain: [],
-	chain: function(){
-		this.$chain.extend(Array.flatten(arguments));
-		return this;
-	callChain: function(){
-		return (this.$chain.length) ? this.$chain.shift().apply(this, arguments) : false;
-	clearChain: function(){
-		this.$chain.empty();
-		return this;
-var Events = new Class({
-	$events: {},
-	addEvent: function(type, fn, internal){
-		type = Events.removeOn(type);
-		if (fn != $empty){
-			this.$events[type] = this.$events[type] || [];
-			this.$events[type].include(fn);
-			if (internal) fn.internal = true;
-		return this;
-	addEvents: function(events){
-		for (var type in events) this.addEvent(type, events[type]);
-		return this;
-	fireEvent: function(type, args, delay){
-		if (!this.$events || !this.$events[type]) return this;
-		this.$events[type].each(function(fn){
-			fn.create({'bind': this, 'delay': delay, 'arguments': args})();
-		}, this);
-		return this;
-	removeEvent: function(type, fn){
-		if (!this.$events[type]) return this;
-		if (!fn.internal) this.$events[type].erase(fn);
-		return this;
-	removeEvents: function(events){
-		var type;
-		if ($type(events) == 'object'){
-			for (type in events) this.removeEvent(type, events[type]);
-			return this;
-		if (events) events = Events.removeOn(events);
-		for (type in this.$events){
-			if (events && events != type) continue;
-			var fns = this.$events[type];
-			for (var i = fns.length; i--; i) this.removeEvent(type, fns[i]);
-		return this;
-Events.removeOn = function(string){
-	return string.replace(/^on([A-Z])/, function(full, first){
-		return first.toLowerCase();
-var Options = new Class({
-	setOptions: function(){
-		this.options = $merge.run([this.options].extend(arguments));
-		if (!this.addEvent) return this;
-		for (var option in this.options){
-			if ($type(this.options[option]) != 'function' || !(/^on[A-Z]/).test(option)) continue;
-			this.addEvent(option, this.options[option]);
-			delete this.options[option];
-		return this;
-script: Element.js
-description: One of the most important items in MooTools. Contains the dollar function, the dollars function, and an handful of cross-browser, time-saver methods to let you easily work with HTML Elements.
-requires:
-- /Window
-- /Document
-- /Array
-- /String
-- /Function
-- /Number
-- /Hash
-provides: [Element, Elements, $, $$, Iframe]
-var Element = new Native({
-	name: 'Element',
-	legacy: window.Element,
-	initialize: function(tag, props){
-		var konstructor = Element.Constructors.get(tag);
-		if (konstructor) return konstructor(props);
-		if (typeof tag == 'string') return document.newElement(tag, props);
-		return document.id(tag).set(props);
-	afterImplement: function(key, value){
-		Element.Prototype[key] = value;
-		if (Array[key]) return;
-		Elements.implement(key, function(){
-			var items = [], elements = true;
-			for (var i = 0, j = this.length; i < j; i++){
-				var returns = this[i][key].apply(this[i], arguments);
-				items.push(returns);
-				if (elements) elements = ($type(returns) == 'element');
-			return (elements) ? new Elements(items) : items;
-Element.Prototype = {$family: {name: 'element'}};
-Element.Constructors = new Hash;
-var IFrame = new Native({
-	name: 'IFrame',
-	generics: false,
-	initialize: function(){
-		var params = Array.link(arguments, {properties: Object.type, iframe: $defined});
-		var props = params.properties || {};
-		var iframe = document.id(params.iframe);
-		var onload = props.onload || $empty;
-		delete props.onload;
-		props.id = props.name = $pick(props.id, props.name, iframe ? (iframe.id || iframe.name) : 'IFrame_' + $time());
-		iframe = new Element(iframe || 'iframe', props);
-		var onFrameLoad = function(){
-			var host = $try(function(){
-				return iframe.contentWindow.location.host;
-			if (!host || host == window.location.host){
-				var win = new Window(iframe.contentWindow);
-				new Document(iframe.contentWindow.document);
-				$extend(win.Element.prototype, Element.Prototype);
-			onload.call(iframe.contentWindow, iframe.contentWindow.document);
-		var contentWindow = $try(function(){
-			return iframe.contentWindow;
-		((contentWindow && contentWindow.document.body) || window.frames[props.id]) ? onFrameLoad() : iframe.addListener('load', onFrameLoad);
-		return iframe;
-var Elements = new Native({
-	initialize: function(elements, options){
-		options = $extend({ddup: true, cash: true}, options);
-		elements = elements || [];
-		if (options.ddup || options.cash){
-			var uniques = {}, returned = [];
-			for (var i = 0, l = elements.length; i < l; i++){
-				var el = document.id(elements[i], !options.cash);
-				if (options.ddup){
-					if (uniques[el.uid]) continue;
-					uniques[el.uid] = true;
-				if (el) returned.push(el);
-			elements = returned;
-		return (options.cash) ? $extend(elements, this) : elements;
-Elements.implement({
-	filter: function(filter, bind){
-		if (!filter) return this;
-		return new Elements(Array.filter(this, (typeof filter == 'string') ? function(item){
-			return item.match(filter);
-		} : filter, bind));
-Document.implement({
-	newElement: function(tag, props){
-		if (Browser.Engine.trident && props){
-			['name', 'type', 'checked'].each(function(attribute){
-				if (!props[attribute]) return;
-				tag += ' ' + attribute + '="' + props[attribute] + '"';
-				if (attribute != 'checked') delete props[attribute];
-			tag = '<' + tag + '>';
-		return document.id(this.createElement(tag)).set(props);
-	newTextNode: function(text){
-		return this.createTextNode(text);
-	getDocument: function(){
-		return this;
-	getWindow: function(){
-		return this.window;
-	id: (function(){
-		var types = {
-			string: function(id, nocash, doc){
-				id = doc.getElementById(id);
-				return (id) ? types.element(id, nocash) : null;
-			element: function(el, nocash){
-				$uid(el);
-				if (!nocash && !el.$family && !(/^object|embed$/i).test(el.tagName)){
-					var proto = Element.Prototype;
-					for (var p in proto) el[p] = proto[p];
-				return el;
-			object: function(obj, nocash, doc){
-				if (obj.toElement) return types.element(obj.toElement(doc), nocash);
-				return null;
-		types.textnode = types.whitespace = types.window = types.document = $arguments(0);
-		return function(el, nocash, doc){
-			if (el && el.$family && el.uid) return el;
-			var type = $type(el);
-			return (types[type]) ? types[type](el, nocash, doc || document) : null;
-if (window.$ == null) Window.implement({
-	$: function(el, nc){
-		return document.id(el, nc, this.document);
-Window.implement({
-	$$: function(selector){
-		if (arguments.length == 1 && typeof selector == 'string') return this.document.getElements(selector);
-		var elements = [];
-		var args = Array.flatten(arguments);
-		for (var i = 0, l = args.length; i < l; i++){
-			var item = args[i];
-			switch ($type(item)){
-				case 'element': elements.push(item); break;
-				case 'string': elements.extend(this.document.getElements(item, true));
-		return new Elements(elements);
-		return this.document;
-		return this;
-Native.implement([Element, Document], {
-	getElement: function(selector, nocash){
-		return document.id(this.getElements(selector, true)[0] || null, nocash);
-	getElements: function(tags, nocash){
-		tags = tags.split(',');
-		var ddup = (tags.length > 1);
-		tags.each(function(tag){
-			var partial = this.getElementsByTagName(tag.trim());
-			(ddup) ? elements.extend(partial) : elements = partial;
-		}, this);
-		return new Elements(elements, {ddup: ddup, cash: !nocash});
-(function(){
-var collected = {}, storage = {};
-var props = {input: 'checked', option: 'selected', textarea: (Browser.Engine.webkit && Browser.Engine.version < 420) ? 'innerHTML' : 'value'};
-var get = function(uid){
-	return (storage[uid] || (storage[uid] = {}));
-var clean = function(item, retain){
-	if (!item) return;
-	var uid = item.uid;
-	if (retain !== true) retain = false;
-	if (Browser.Engine.trident){
-		if (item.clearAttributes){
-			var clone = retain && item.cloneNode(false);
-			item.clearAttributes();
-			if (clone) item.mergeAttributes(clone);
-		} else if (item.removeEvents){
-			item.removeEvents();
-		if ((/object/i).test(item.tagName)){
-			for (var p in item){
-				if (typeof item[p] == 'function') item[p] = $empty;
-			Element.dispose(item);
-	if (!uid) return;
-	collected[uid] = storage[uid] = null;
-var purge = function(){
-	Hash.each(collected, clean);
-	if (Browser.Engine.trident) $A(document.getElementsByTagName('object')).each(clean);
-	if (window.CollectGarbage) CollectGarbage();
-	collected = storage = null;
-var walk = function(element, walk, start, match, all, nocash){
-	var el = element[start || walk];
-	while (el){
-		if (el.nodeType == 1 && (!match || Element.match(el, match))){
-			if (!all) return document.id(el, nocash);
-			elements.push(el);
-		el = el[walk];
-	return (all) ? new Elements(elements, {ddup: false, cash: !nocash}) : null;
-var attributes = {
-	'html': 'innerHTML',
-	'class': 'className',
-	'for': 'htmlFor',
-	'defaultValue': 'defaultValue',
-	'text': (Browser.Engine.trident || (Browser.Engine.webkit && Browser.Engine.version < 420)) ? 'innerText' : 'textContent'
-var bools = ['compact', 'nowrap', 'ismap', 'declare', 'noshade', 'checked', 'disabled', 'readonly', 'multiple', 'selected', 'noresize', 'defer'];
-var camels = ['value', 'type', 'defaultValue', 'accessKey', 'cellPadding', 'cellSpacing', 'colSpan', 'frameBorder', 'maxLength', 'readOnly', 'rowSpan', 'tabIndex', 'useMap'];
-bools = bools.associate(bools);
-Hash.extend(attributes, bools);
-Hash.extend(attributes, camels.associate(camels.map(String.toLowerCase)));
-var inserters = {
-	before: function(context, element){
-		if (element.parentNode) element.parentNode.insertBefore(context, element);
-	after: function(context, element){
-		if (!element.parentNode) return;
-		var next = element.nextSibling;
-		(next) ? element.parentNode.insertBefore(context, next) : element.parentNode.appendChild(context);
-	bottom: function(context, element){
-		element.appendChild(context);
-	top: function(context, element){
-		var first = element.firstChild;
-		(first) ? element.insertBefore(context, first) : element.appendChild(context);
-inserters.inside = inserters.bottom;
-Hash.each(inserters, function(inserter, where){
-	where = where.capitalize();
-	Element.implement('inject' + where, function(el){
-		inserter(this, document.id(el, true));
-		return this;
-	Element.implement('grab' + where, function(el){
-		inserter(document.id(el, true), this);
-		return this;
-Element.implement({
-	set: function(prop, value){
-		switch ($type(prop)){
-			case 'object':
-				for (var p in prop) this.set(p, prop[p]);
-				break;
-			case 'string':
-				var property = Element.Properties.get(prop);
-				(property && property.set) ? property.set.apply(this, Array.slice(arguments, 1)) : this.setProperty(prop, value);
-		return this;
-	get: function(prop){
-		return (property && property.get) ? property.get.apply(this, Array.slice(arguments, 1)) : this.getProperty(prop);
-	erase: function(prop){
-		(property && property.erase) ? property.erase.apply(this) : this.removeProperty(prop);
-		return this;
-	setProperty: function(attribute, value){
-		var key = attributes[attribute];
-		if (value == undefined) return this.removeProperty(attribute);
-		if (key && bools[attribute]) value = !!value;
-		(key) ? this[key] = value : this.setAttribute(attribute, '' + value);
-		return this;
-	setProperties: function(attributes){
-		for (var attribute in attributes) this.setProperty(attribute, attributes[attribute]);
-		return this;
-	getProperty: function(attribute){
-		var value = (key) ? this[key] : this.getAttribute(attribute, 2);
-		return (bools[attribute]) ? !!value : (key) ? value : value || null;
-	getProperties: function(){
-		var args = $A(arguments);
-		return args.map(this.getProperty, this).associate(args);
-	removeProperty: function(attribute){
-		(key) ? this[key] = (key && bools[attribute]) ? false : '' : this.removeAttribute(attribute);
-		return this;
-	removeProperties: function(){
-		Array.each(arguments, this.removeProperty, this);
-		return this;
-	hasClass: function(className){
-		return this.className.contains(className, ' ');
-	addClass: function(className){
-		if (!this.hasClass(className)) this.className = (this.className + ' ' + className).clean();
-		return this;
-	removeClass: function(className){
-		this.className = this.className.replace(new RegExp('(^|\\s)' + className + '(?:\\s|$)'), '$1');
-		return this;
-	toggleClass: function(className){
-		return this.hasClass(className) ? this.removeClass(className) : this.addClass(className);
-	adopt: function(){
-		Array.flatten(arguments).each(function(element){
-			element = document.id(element, true);
-			if (element) this.appendChild(element);
-		}, this);
-		return this;
-	appendText: function(text, where){
-		return this.grab(this.getDocument().newTextNode(text), where);
-	grab: function(el, where){
-		inserters[where || 'bottom'](document.id(el, true), this);
-		return this;
-	inject: function(el, where){
-		inserters[where || 'bottom'](this, document.id(el, true));
-		return this;
-	replaces: function(el){
-		el = document.id(el, true);
-		el.parentNode.replaceChild(this, el);
-		return this;
-	wraps: function(el, where){
-		return this.replaces(el).grab(el, where);
-	getPrevious: function(match, nocash){
-		return walk(this, 'previousSibling', null, match, false, nocash);
-	getAllPrevious: function(match, nocash){
-		return walk(this, 'previousSibling', null, match, true, nocash);
-	getNext: function(match, nocash){
-		return walk(this, 'nextSibling', null, match, false, nocash);
-	getAllNext: function(match, nocash){
-		return walk(this, 'nextSibling', null, match, true, nocash);
-	getFirst: function(match, nocash){
-		return walk(this, 'nextSibling', 'firstChild', match, false, nocash);
-	getLast: function(match, nocash){
-		return walk(this, 'previousSibling', 'lastChild', match, false, nocash);
-	getParent: function(match, nocash){
-		return walk(this, 'parentNode', null, match, false, nocash);
-	getParents: function(match, nocash){
-		return walk(this, 'parentNode', null, match, true, nocash);
-	getSiblings: function(match, nocash){
-		return this.getParent().getChildren(match, nocash).erase(this);
-	getChildren: function(match, nocash){
-		return walk(this, 'nextSibling', 'firstChild', match, true, nocash);
-		return this.ownerDocument.window;
-		return this.ownerDocument;
-	getElementById: function(id, nocash){
-		var el = this.ownerDocument.getElementById(id);
-		if (!el) return null;
-		for (var parent = el.parentNode; parent != this; parent = parent.parentNode){
-			if (!parent) return null;
-		return document.id(el, nocash);
-	getSelected: function(){
-		return new Elements($A(this.options).filter(function(option){
-			return option.selected;
-	getComputedStyle: function(property){
-		if (this.currentStyle) return this.currentStyle[property.camelCase()];
-		var computed = this.getDocument().defaultView.getComputedStyle(this, null);
-		return (computed) ? computed.getPropertyValue([property.hyphenate()]) : null;
-	toQueryString: function(){
-		this.getElements('input, select, textarea', true).each(function(el){
-			if (!el.name || el.disabled || el.type == 'submit' || el.type == 'reset' || el.type == 'file') return;
-			var value = (el.tagName.toLowerCase() == 'select') ? Element.getSelected(el).map(function(opt){
-				return opt.value;
-			}) : ((el.type == 'radio' || el.type == 'checkbox') && !el.checked) ? null : el.value;
-			$splat(value).each(function(val){
-				if (typeof val != 'undefined') queryString.push(el.name + '=' + encodeURIComponent(val));
-	clone: function(contents, keepid){
-		contents = contents !== false;
-		var clone = this.cloneNode(contents);
-		var clean = function(node, element){
-			if (!keepid) node.removeAttribute('id');
-				node.clearAttributes();
-				node.mergeAttributes(element);
-				node.removeAttribute('uid');
-				if (node.options){
-					var no = node.options, eo = element.options;
-					for (var j = no.length; j--;) no[j].selected = eo[j].selected;
-			var prop = props[element.tagName.toLowerCase()];
-			if (prop && element[prop]) node[prop] = element[prop];
-		if (contents){
-			var ce = clone.getElementsByTagName('*'), te = this.getElementsByTagName('*');
-			for (var i = ce.length; i--;) clean(ce[i], te[i]);
-		clean(clone, this);
-		return document.id(clone);
-	destroy: function(){
-		Element.empty(this);
-		Element.dispose(this);
-		clean(this, true);
-		return null;
-		$A(this.childNodes).each(function(node){
-			Element.destroy(node);
-		return this;
-	dispose: function(){
-		return (this.parentNode) ? this.parentNode.removeChild(this) : this;
-	hasChild: function(el){
-		if (!el) return false;
-		if (Browser.Engine.webkit && Browser.Engine.version < 420) return $A(this.getElementsByTagName(el.tagName)).contains(el);
-		return (this.contains) ? (this != el && this.contains(el)) : !!(this.compareDocumentPosition(el) & 16);
-	match: function(tag){
-		return (!tag || (tag == this) || (Element.get(this, 'tag') == tag));
-Native.implement([Element, Window, Document], {
-	addListener: function(type, fn){
-		if (type == 'unload'){
-			var old = fn, self = this;
-			fn = function(){
-				self.removeListener('unload', fn);
-				old();
-		} else {
-			collected[this.uid] = this;
-		if (this.addEventListener) this.addEventListener(type, fn, false);
-		else this.attachEvent('on' + type, fn);
-		return this;
-	removeListener: function(type, fn){
-		if (this.removeEventListener) this.removeEventListener(type, fn, false);
-		else this.detachEvent('on' + type, fn);
-		return this;
-	retrieve: function(property, dflt){
-		var storage = get(this.uid), prop = storage[property];
-		if (dflt != undefined && prop == undefined) prop = storage[property] = dflt;
-		return $pick(prop);
-	store: function(property, value){
-		var storage = get(this.uid);
-		storage[property] = value;
-		return this;
-	eliminate: function(property){
-		delete storage[property];
-		return this;
-window.addListener('unload', purge);
-Element.Properties = new Hash;
-Element.Properties.style = {
-	set: function(style){
-		this.style.cssText = style;
-	get: function(){
-		return this.style.cssText;
-	erase: function(){
-		this.style.cssText = '';
-Element.Properties.tag = {
-	get: function(){
-		return this.tagName.toLowerCase();
-Element.Properties.html = (function(){
-	var wrapper = document.createElement('div');
-	var translations = {
-		table: [1, '<table>', '</table>'],
-		select: [1, '<select>', '</select>'],
-		tbody: [2, '<table><tbody>', '</tbody></table>'],
-		tr: [3, '<table><tbody><tr>', '</tr></tbody></table>']
-	translations.thead = translations.tfoot = translations.tbody;
-	var html = {
-		set: function(){
-			var html = Array.flatten(arguments).join('');
-			var wrap = Browser.Engine.trident && translations[this.get('tag')];
-			if (wrap){
-				var first = wrapper;
-				first.innerHTML = wrap[1] + html + wrap[2];
-				for (var i = wrap[0]; i--;) first = first.firstChild;
-				this.empty().adopt(first.childNodes);
-			} else {
-				this.innerHTML = html;
-	html.erase = html.set;
-	return html;
-if (Browser.Engine.webkit && Browser.Engine.version < 420) Element.Properties.text = {
-	get: function(){
-		if (this.innerText) return this.innerText;
-		var temp = this.ownerDocument.newElement('div', {html: this.innerHTML}).inject(this.ownerDocument.body);
-		var text = temp.innerText;
-		temp.destroy();
-		return text;
-script: Element.Event.js
-description: Contains Element methods for dealing with events. This file also includes mouseenter and mouseleave custom Element Events.
-requires:
-- /Element
-- /Event
-provides: [Element.Event]
-Element.Properties.events = {set: function(events){
-	this.addEvents(events);
-	addEvent: function(type, fn){
-		var events = this.retrieve('events', {});
-		events[type] = events[type] || {'keys': [], 'values': []};
-		if (events[type].keys.contains(fn)) return this;
-		events[type].keys.push(fn);
-		var realType = type, custom = Element.Events.get(type), condition = fn, self = this;
-		if (custom){
-			if (custom.onAdd) custom.onAdd.call(this, fn);
-			if (custom.condition){
-				condition = function(event){
-					if (custom.condition.call(this, event)) return fn.call(this, event);
-					return true;
-			realType = custom.base || realType;
-		var defn = function(){
-			return fn.call(self);
-		var nativeEvent = Element.NativeEvents[realType];
-		if (nativeEvent){
-			if (nativeEvent == 2){
-				defn = function(event){
-					event = new Event(event, self.getWindow());
-					if (condition.call(self, event) === false) event.stop();
-			this.addListener(realType, defn);
-		events[type].values.push(defn);
-		return this;
-		var events = this.retrieve('events');
-		if (!events || !events[type]) return this;
-		var pos = events[type].keys.indexOf(fn);
-		if (pos == -1) return this;
-		events[type].keys.splice(pos, 1);
-		var value = events[type].values.splice(pos, 1)[0];
-		var custom = Element.Events.get(type);
-		if (custom){
-			if (custom.onRemove) custom.onRemove.call(this, fn);
-			type = custom.base || type;
-		return (Element.NativeEvents[type]) ? this.removeListener(type, value) : this;
-		for (var event in events) this.addEvent(event, events[event]);
-		return this;
-		var type;
-			return this;
-		var attached = this.retrieve('events');
-		if (!attached) return this;
-		if (!events){
-			for (type in attached) this.removeEvents(type);
-			this.eliminate('events');
-		} else if (attached[events]){
-			while (attached[events].keys[0]) this.removeEvent(events, attached[events].keys[0]);
-			attached[events] = null;
-		return this;
-		events[type].keys.each(function(fn){
-		}, this);
-		return this;
-	cloneEvents: function(from, type){
-		from = document.id(from);
-		var fevents = from.retrieve('events');
-		if (!fevents) return this;
-		if (!type){
-			for (var evType in fevents) this.cloneEvents(from, evType);
-		} else if (fevents[type]){
-			fevents[type].keys.each(function(fn){
-				this.addEvent(type, fn);
-			}, this);
-		return this;
-Element.NativeEvents = {
-	click: 2, dblclick: 2, mouseup: 2, mousedown: 2, contextmenu: 2, //mouse buttons
-	mousewheel: 2, DOMMouseScroll: 2, //mouse wheel
-	mouseover: 2, mouseout: 2, mousemove: 2, selectstart: 2, selectend: 2, //mouse movement
-	keydown: 2, keypress: 2, keyup: 2, //keyboard
-	focus: 2, blur: 2, change: 2, reset: 2, select: 2, submit: 2, //form elements
-	load: 1, unload: 1, beforeunload: 2, resize: 1, move: 1, DOMContentLoaded: 1, readystatechange: 1, //window
-	error: 1, abort: 1, scroll: 1 //misc
-(function(){
-var $check = function(event){
-	var related = event.relatedTarget;
-	if (related == undefined) return true;
-	if (related === false) return false;
-	return ($type(this) != 'document' && related != this && related.prefix != 'xul' && !this.hasChild(related));
-Element.Events = new Hash({
-	mouseenter: {
-		base: 'mouseover',
-		condition: $check
-	mouseleave: {
-		base: 'mouseout',
-		condition: $check
-	mousewheel: {
-		base: (Browser.Engine.gecko) ? 'DOMMouseScroll' : 'mousewheel'
-script: Element.Style.js
-description: Contains methods for interacting with the styles of Elements in a fashionable way.
-requires:
-- /Element
-provides: [Element.Style]
-Element.Properties.styles = {set: function(styles){
-	this.setStyles(styles);
-Element.Properties.opacity = {
-	set: function(opacity, novisibility){
-		if (!novisibility){
-			if (opacity == 0){
-				if (this.style.visibility != 'hidden') this.style.visibility = 'hidden';
-			} else {
-				if (this.style.visibility != 'visible') this.style.visibility = 'visible';
-		if (!this.currentStyle || !this.currentStyle.hasLayout) this.style.zoom = 1;
-		if (Browser.Engine.trident) this.style.filter = (opacity == 1) ? '' : 'alpha(opacity=' + opacity * 100 + ')';
-		this.style.opacity = opacity;
-		this.store('opacity', opacity);
-	get: function(){
-		return this.retrieve('opacity', 1);
-	setOpacity: function(value){
-		return this.set('opacity', value, true);
-	getOpacity: function(){
-		return this.get('opacity');
-	setStyle: function(property, value){
-		switch (property){
-			case 'opacity': return this.set('opacity', parseFloat(value));
-			case 'float': property = (Browser.Engine.trident) ? 'styleFloat' : 'cssFloat';
-		property = property.camelCase();
-		if ($type(value) != 'string'){
-			var map = (Element.Styles.get(property) || '@').split(' ');
-			value = $splat(value).map(function(val, i){
-				if (!map[i]) return '';
-				return ($type(val) == 'number') ? map[i].replace('@', Math.round(val)) : val;
-			}).join(' ');
-		} else if (value == String(Number(value))){
-			value = Math.round(value);
-		this.style[property] = value;
-		return this;
-	getStyle: function(property){
-			case 'opacity': return this.get('opacity');
-		var result = this.style[property];
-		if (!$chk(result)){
-			result = [];
-			for (var style in Element.ShortStyles){
-				if (property != style) continue;
-				for (var s in Element.ShortStyles[style]) result.push(this.getStyle(s));
-				return result.join(' ');
-			result = this.getComputedStyle(property);
-		if (result){
-			result = String(result);
-			var color = result.match(/rgba?\([\d\s,]+\)/);
-			if (color) result = result.replace(color[0], color[0].rgbToHex());
-		if (Browser.Engine.presto || (Browser.Engine.trident && !$chk(parseInt(result, 10)))){
-			if (property.test(/^(height|width)$/)){
-				var values = (property == 'width') ? ['left', 'right'] : ['top', 'bottom'], size = 0;
-				values.each(function(value){
-					size += this.getStyle('border-' + value + '-width').toInt() + this.getStyle('padding-' + value).toInt();
-				}, this);
-				return this['offset' + property.capitalize()] - size + 'px';
-			if ((Browser.Engine.presto) && String(result).test('px')) return result;
-			if (property.test(/(border(.+)Width|margin|padding)/)) return '0px';
-		return result;
-	setStyles: function(styles){
-		for (var style in styles) this.setStyle(style, styles[style]);
-		return this;
-	getStyles: function(){
-		var result = {};
-		Array.flatten(arguments).each(function(key){
-			result[key] = this.getStyle(key);
-		}, this);
-		return result;
-Element.Styles = new Hash({
-	left: '@px', top: '@px', bottom: '@px', right: '@px',
-	width: '@px', height: '@px', maxWidth: '@px', maxHeight: '@px', minWidth: '@px', minHeight: '@px',
-	backgroundColor: 'rgb(@, @, @)', backgroundPosition: '@px @px', color: 'rgb(@, @, @)',
-	fontSize: '@px', letterSpacing: '@px', lineHeight: '@px', clip: 'rect(@px @px @px @px)',
-	margin: '@px @px @px @px', padding: '@px @px @px @px', border: '@px @ rgb(@, @, @) @px @ rgb(@, @, @) @px @ rgb(@, @, @)',
-	borderWidth: '@px @px @px @px', borderStyle: '@ @ @ @', borderColor: 'rgb(@, @, @) rgb(@, @, @) rgb(@, @, @) rgb(@, @, @)',
-	zIndex: '@', 'zoom': '@', fontWeight: '@', textIndent: '@px', opacity: '@'
-Element.ShortStyles = {margin: {}, padding: {}, border: {}, borderWidth: {}, borderStyle: {}, borderColor: {}};
-['Top', 'Right', 'Bottom', 'Left'].each(function(direction){
-	var Short = Element.ShortStyles;
-	var All = Element.Styles;
-	['margin', 'padding'].each(function(style){
-		var sd = style + direction;
-		Short[style][sd] = All[sd] = '@px';
-	var bd = 'border' + direction;
-	Short.border[bd] = All[bd] = '@px @ rgb(@, @, @)';
-	var bdw = bd + 'Width', bds = bd + 'Style', bdc = bd + 'Color';
-	Short[bd] = {};
-	Short.borderWidth[bdw] = Short[bd][bdw] = All[bdw] = '@px';
-	Short.borderStyle[bds] = Short[bd][bds] = All[bds] = '@';
-	Short.borderColor[bdc] = Short[bd][bdc] = All[bdc] = 'rgb(@, @, @)';
-script: Element.Dimensions.js
-description: Contains methods to work with size, scroll, or positioning of Elements and the window object.
-credits:
-- Element positioning based on the [qooxdoo](http://qooxdoo.org/) code and smart browser fixes, [LGPL License](http://www.gnu.org/licenses/lgpl.html).
-- Viewport dimensions based on [YUI](http://developer.yahoo.com/yui/) code, [BSD License](http://developer.yahoo.com/yui/license.html).
-requires:
-- /Element
-provides: [Element.Dimensions]
-(function(){
-	scrollTo: function(x, y){
-		if (isBody(this)){
-			this.getWindow().scrollTo(x, y);
-		} else {
-			this.scrollLeft = x;
-			this.scrollTop = y;
-		return this;
-	getSize: function(){
-		if (isBody(this)) return this.getWindow().getSize();
-		return {x: this.offsetWidth, y: this.offsetHeight};
-	getScrollSize: function(){
-		if (isBody(this)) return this.getWindow().getScrollSize();
-		return {x: this.scrollWidth, y: this.scrollHeight};
-	getScroll: function(){
-		if (isBody(this)) return this.getWindow().getScroll();
-		return {x: this.scrollLeft, y: this.scrollTop};
-	getScrolls: function(){
-		var element = this, position = {x: 0, y: 0};
-		while (element && !isBody(element)){
-			position.x += element.scrollLeft;
-			position.y += element.scrollTop;
-			element = element.parentNode;
-		return position;
-	getOffsetParent: function(){
-		var element = this;
-		if (isBody(element)) return null;
-		if (!Browser.Engine.trident) return element.offsetParent;
-		while ((element = element.parentNode) && !isBody(element)){
-			if (styleString(element, 'position') != 'static') return element;
-		return null;
-	getOffsets: function(){
-		if (this.getBoundingClientRect){
-			var bound = this.getBoundingClientRect(),
-				html = document.id(this.getDocument().documentElement),
-				htmlScroll = html.getScroll(),
-				elemScrolls = this.getScrolls(),
-				elemScroll = this.getScroll(),
-				isFixed = (styleString(this, 'position') == 'fixed');
-			return {
-				x: bound.left.toInt() + elemScrolls.x - elemScroll.x + ((isFixed) ? 0 : htmlScroll.x) - html.clientLeft,
-				y: bound.top.toInt()  + elemScrolls.y - elemScroll.y + ((isFixed) ? 0 : htmlScroll.y) - html.clientTop
-		if (isBody(this)) return position;
-			position.x += element.offsetLeft;
-			position.y += element.offsetTop;
-			if (Browser.Engine.gecko){
-				if (!borderBox(element)){
-					position.x += leftBorder(element);
-					position.y += topBorder(element);
-				var parent = element.parentNode;
-				if (parent && styleString(parent, 'overflow') != 'visible'){
-					position.x += leftBorder(parent);
-					position.y += topBorder(parent);
-			} else if (element != this && Browser.Engine.webkit){
-			element = element.offsetParent;
-		if (Browser.Engine.gecko && !borderBox(this)){
-			position.x -= leftBorder(this);
-			position.y -= topBorder(this);
-		return position;
-	getPosition: function(relative){
-		if (isBody(this)) return {x: 0, y: 0};
-		var offset = this.getOffsets(),
-				scroll = this.getScrolls();
-		var position = {
-			x: offset.x - scroll.x,
-			y: offset.y - scroll.y
-		var relativePosition = (relative && (relative = document.id(relative))) ? relative.getPosition() : {x: 0, y: 0};
-		return {x: position.x - relativePosition.x, y: position.y - relativePosition.y};
-	getCoordinates: function(element){
-		if (isBody(this)) return this.getWindow().getCoordinates();
-		var position = this.getPosition(element),
-				size = this.getSize();
-		var obj = {
-			left: position.x,
-			top: position.y,
-			width: size.x,
-			height: size.y
-		obj.right = obj.left + obj.width;
-		obj.bottom = obj.top + obj.height;
-		return obj;
-	computePosition: function(obj){
-		return {
-			left: obj.x - styleNumber(this, 'margin-left'),
-			top: obj.y - styleNumber(this, 'margin-top')
-	setPosition: function(obj){
-		return this.setStyles(this.computePosition(obj));
-Native.implement([Document, Window], {
-		if (Browser.Engine.presto || Browser.Engine.webkit){
-			var win = this.getWindow();
-			return {x: win.innerWidth, y: win.innerHeight};
-		var doc = getCompatElement(this);
-		return {x: doc.clientWidth, y: doc.clientHeight};
-		var win = this.getWindow(), doc = getCompatElement(this);
-		return {x: win.pageXOffset || doc.scrollLeft, y: win.pageYOffset || doc.scrollTop};
-		var doc = getCompatElement(this), min = this.getSize();
-		return {x: Math.max(doc.scrollWidth, min.x), y: Math.max(doc.scrollHeight, min.y)};
-	getPosition: function(){
-		return {x: 0, y: 0};
-	getCoordinates: function(){
-		var size = this.getSize();
-		return {top: 0, left: 0, bottom: size.y, right: size.x, height: size.y, width: size.x};
-// private methods
-var styleString = Element.getComputedStyle;
-function styleNumber(element, style){
-	return styleString(element, style).toInt() || 0;
-function borderBox(element){
-	return styleString(element, '-moz-box-sizing') == 'border-box';
-function topBorder(element){
-	return styleNumber(element, 'border-top-width');
-function leftBorder(element){
-	return styleNumber(element, 'border-left-width');
-function isBody(element){
-	return (/^(?:body|html)$/i).test(element.tagName);
-function getCompatElement(element){
-	var doc = element.getDocument();
-	return (!doc.compatMode || doc.compatMode == 'CSS1Compat') ? doc.html : doc.body;
-//aliases
-Element.alias('setPosition', 'position'); //compatability
-Native.implement([Window, Document, Element], {
-	getHeight: function(){
-		return this.getSize().y;
-	getWidth: function(){
-		return this.getSize().x;
-	getScrollTop: function(){
-		return this.getScroll().y;
-	getScrollLeft: function(){
-		return this.getScroll().x;
-	getScrollHeight: function(){
-		return this.getScrollSize().y;
-	getScrollWidth: function(){
-		return this.getScrollSize().x;
-	getTop: function(){
-		return this.getPosition().y;
-	getLeft: function(){
-		return this.getPosition().x;
-script: Selectors.js
-description: Adds advanced CSS-style querying capabilities for targeting HTML Elements. Includes pseudo selectors.
-requires:
-- /Element
-provides: [Selectors]
-Native.implement([Document, Element], {
-	getElements: function(expression, nocash){
-		expression = expression.split(',');
-		var items, local = {};
-		for (var i = 0, l = expression.length; i < l; i++){
-			var selector = expression[i], elements = Selectors.Utils.search(this, selector, local);
-			if (i != 0 && elements.item) elements = $A(elements);
-			items = (i == 0) ? elements : (items.item) ? $A(items).concat(elements) : items.concat(elements);
-		return new Elements(items, {ddup: (expression.length > 1), cash: !nocash});
-	match: function(selector){
-		if (!selector || (selector == this)) return true;
-		var tagid = Selectors.Utils.parseTagAndID(selector);
-		var tag = tagid[0], id = tagid[1];
-		if (!Selectors.Filters.byID(this, id) || !Selectors.Filters.byTag(this, tag)) return false;
-		var parsed = Selectors.Utils.parseSelector(selector);
-		return (parsed) ? Selectors.Utils.filter(this, parsed, {}) : true;
-var Selectors = {Cache: {nth: {}, parsed: {}}};
-Selectors.RegExps = {
-	id: (/#([\w-]+)/),
-	tag: (/^(\w+|\*)/),
-	quick: (/^(\w+|\*)$/),
-	splitter: (/\s*([+>~\s])\s*([a-zA-Z#.*:\[])/g),
-	combined: (/\.([\w-]+)|\[(\w+)(?:([!*^$~|]?=)(["']?)([^\4]*?)\4)?\]|:([\w-]+)(?:\(["']?(.*?)?["']?\)|$)/g)
-Selectors.Utils = {
-	chk: function(item, uniques){
-		if (!uniques) return true;
-		var uid = $uid(item);
-		if (!uniques[uid]) return uniques[uid] = true;
-		return false;
-	parseNthArgument: function(argument){
-		if (Selectors.Cache.nth[argument]) return Selectors.Cache.nth[argument];
-		var parsed = argument.match(/^([+-]?\d*)?([a-z]+)?([+-]?\d*)?$/);
-		if (!parsed) return false;
-		var inta = parseInt(parsed[1], 10);
-		var a = (inta || inta === 0) ? inta : 1;
-		var special = parsed[2] || false;
-		var b = parseInt(parsed[3], 10) || 0;
-		if (a != 0){
-			b--;
-			while (b < 1) b += a;
-			while (b >= a) b -= a;
-		} else {
-			a = b;
-			special = 'index';
-		switch (special){
-			case 'n': parsed = {a: a, b: b, special: 'n'}; break;
-			case 'odd': parsed = {a: 2, b: 0, special: 'n'}; break;
-			case 'even': parsed = {a: 2, b: 1, special: 'n'}; break;
-			case 'first': parsed = {a: 0, special: 'index'}; break;
-			case 'last': parsed = {special: 'last-child'}; break;
-			case 'only': parsed = {special: 'only-child'}; break;
-			default: parsed = {a: (a - 1), special: 'index'};
-		return Selectors.Cache.nth[argument] = parsed;
-	parseSelector: function(selector){
-		if (Selectors.Cache.parsed[selector]) return Selectors.Cache.parsed[selector];
-		var m, parsed = {classes: [], pseudos: [], attributes: []};
-		while ((m = Selectors.RegExps.combined.exec(selector))){
-			var cn = m[1], an = m[2], ao = m[3], av = m[5], pn = m[6], pa = m[7];
-			if (cn){
-				parsed.classes.push(cn);
-			} else if (pn){
-				var parser = Selectors.Pseudo.get(pn);
-				if (parser) parsed.pseudos.push({parser: parser, argument: pa});
-				else parsed.attributes.push({name: pn, operator: '=', value: pa});
-			} else if (an){
-				parsed.attributes.push({name: an, operator: ao, value: av});
-		if (!parsed.classes.length) delete parsed.classes;
-		if (!parsed.attributes.length) delete parsed.attributes;
-		if (!parsed.pseudos.length) delete parsed.pseudos;
-		if (!parsed.classes && !parsed.attributes && !parsed.pseudos) parsed = null;
-		return Selectors.Cache.parsed[selector] = parsed;
-	parseTagAndID: function(selector){
-		var tag = selector.match(Selectors.RegExps.tag);
-		var id = selector.match(Selectors.RegExps.id);
-		return [(tag) ? tag[1] : '*', (id) ? id[1] : false];
-	filter: function(item, parsed, local){
-		var i;
-		if (parsed.classes){
-			for (i = parsed.classes.length; i--; i){
-				var cn = parsed.classes[i];
-				if (!Selectors.Filters.byClass(item, cn)) return false;
-		if (parsed.attributes){
-			for (i = parsed.attributes.length; i--; i){
-				var att = parsed.attributes[i];
-				if (!Selectors.Filters.byAttribute(item, att.name, att.operator, att.value)) return false;
-		if (parsed.pseudos){
-			for (i = parsed.pseudos.length; i--; i){
-				var psd = parsed.pseudos[i];
-				if (!Selectors.Filters.byPseudo(item, psd.parser, psd.argument, local)) return false;
-		return true;
-	getByTagAndID: function(ctx, tag, id){
-		if (id){
-			var item = (ctx.getElementById) ? ctx.getElementById(id, true) : Element.getElementById(ctx, id, true);
-			return (item && Selectors.Filters.byTag(item, tag)) ? [item] : [];
-		} else {
-			return ctx.getElementsByTagName(tag);
-	search: function(self, expression, local){
-		var splitters = [];
-		var selectors = expression.trim().replace(Selectors.RegExps.splitter, function(m0, m1, m2){
-			splitters.push(m1);
-			return ':)' + m2;
-		}).split(':)');
-		var items, filtered, item;
-		for (var i = 0, l = selectors.length; i < l; i++){
-			var selector = selectors[i];
-			if (i == 0 && Selectors.RegExps.quick.test(selector)){
-				items = self.getElementsByTagName(selector);
-				continue;
-			var splitter = splitters[i - 1];
-			if (i == 0){
-				items = Selectors.Utils.getByTagAndID(self, tag, id);
-			} else {
-				var uniques = {}, found = [];
-				for (var j = 0, k = items.length; j < k; j++) found = Selectors.Getters[splitter](found, items[j], tag, id, uniques);
-				items = found;
-			if (parsed){
-				filtered = [];
-				for (var m = 0, n = items.length; m < n; m++){
-					item = items[m];
-					if (Selectors.Utils.filter(item, parsed, local)) filtered.push(item);
-				items = filtered;
-		return items;
-Selectors.Getters = {
-	' ': function(found, self, tag, id, uniques){
-		var items = Selectors.Utils.getByTagAndID(self, tag, id);
-		for (var i = 0, l = items.length; i < l; i++){
-			var item = items[i];
-			if (Selectors.Utils.chk(item, uniques)) found.push(item);
-		return found;
-	'>': function(found, self, tag, id, uniques){
-		var children = Selectors.Utils.getByTagAndID(self, tag, id);
-		for (var i = 0, l = children.length; i < l; i++){
-			var child = children[i];
-			if (child.parentNode == self && Selectors.Utils.chk(child, uniques)) found.push(child);
-		return found;
-	'+': function(found, self, tag, id, uniques){
-		while ((self = self.nextSibling)){
-			if (self.nodeType == 1){
-				if (Selectors.Utils.chk(self, uniques) && Selectors.Filters.byTag(self, tag) && Selectors.Filters.byID(self, id)) found.push(self);
-				break;
-		return found;
-	'~': function(found, self, tag, id, uniques){
-				if (!Selectors.Utils.chk(self, uniques)) break;
-				if (Selectors.Filters.byTag(self, tag) && Selectors.Filters.byID(self, id)) found.push(self);
-		return found;
-Selectors.Filters = {
-	byTag: function(self, tag){
-		return (tag == '*' || (self.tagName && self.tagName.toLowerCase() == tag));
-	byID: function(self, id){
-		return (!id || (self.id && self.id == id));
-	byClass: function(self, klass){
-		return (self.className && self.className.contains && self.className.contains(klass, ' '));
-	byPseudo: function(self, parser, argument, local){
-		return parser.call(self, argument, local);
-	byAttribute: function(self, name, operator, value){
-		var result = Element.prototype.getProperty.call(self, name);
-		if (!result) return (operator == '!=');
-		if (!operator || value == undefined) return true;
-		switch (operator){
-			case '=': return (result == value);
-			case '*=': return (result.contains(value));
-			case '^=': return (result.substr(0, value.length) == value);
-			case '$=': return (result.substr(result.length - value.length) == value);
-			case '!=': return (result != value);
-			case '~=': return result.contains(value, ' ');
-			case '|=': return result.contains(value, '-');
-		return false;
-Selectors.Pseudo = new Hash({
-	// w3c pseudo selectors
-	checked: function(){
-		return this.checked;
-		return !(this.innerText || this.textContent || '').length;
-	not: function(selector){
-		return !Element.match(this, selector);
-	contains: function(text){
-		return (this.innerText || this.textContent || '').contains(text);
-	'first-child': function(){
-		return Selectors.Pseudo.index.call(this, 0);
-	'last-child': function(){
-		while ((element = element.nextSibling)){
-			if (element.nodeType == 1) return false;
-		return true;
-	'only-child': function(){
-		var prev = this;
-		while ((prev = prev.previousSibling)){
-			if (prev.nodeType == 1) return false;
-		var next = this;
-		while ((next = next.nextSibling)){
-			if (next.nodeType == 1) return false;
-		return true;
-	'nth-child': function(argument, local){
-		argument = (argument == undefined) ? 'n' : argument;
-		var parsed = Selectors.Utils.parseNthArgument(argument);
-		if (parsed.special != 'n') return Selectors.Pseudo[parsed.special].call(this, parsed.a, local);
-		var count = 0;
-		local.positions = local.positions || {};
-		var uid = $uid(this);
-		if (!local.positions[uid]){
-			var self = this;
-			while ((self = self.previousSibling)){
-				if (self.nodeType != 1) continue;
-				count ++;
-				var position = local.positions[$uid(self)];
-				if (position != undefined){
-					count = position + count;
-					break;
-			local.positions[uid] = count;
-		return (local.positions[uid] % parsed.a == parsed.b);
-	// custom pseudo selectors
-	index: function(index){
-		var element = this, count = 0;
-		while ((element = element.previousSibling)){
-			if (element.nodeType == 1 && ++count > index) return false;
-		return (count == index);
-	even: function(argument, local){
-		return Selectors.Pseudo['nth-child'].call(this, '2n+1', local);
-	odd: function(argument, local){
-		return Selectors.Pseudo['nth-child'].call(this, '2n', local);
-	selected: function(){
-		return this.selected;
-	enabled: function(){
-		return (this.disabled === false);
-script: DomReady.js
-description: Contains the custom event domready.
-license: MIT-style license.
-requires:
-- /Element.Event
-provides: [DomReady]
-Element.Events.domready = {
-	onAdd: function(fn){
-		if (Browser.loaded) fn.call(this);
-(function(){
-	var domready = function(){
-		if (Browser.loaded) return;
-		Browser.loaded = true;
-		window.fireEvent('domready');
-		document.fireEvent('domready');
-	window.addEvent('load', domready);
-		var temp = document.createElement('div');
-		(function(){
-			($try(function(){
-				temp.doScroll(); // Technique by Diego Perini
-				return document.id(temp).inject(document.body).set('html', 'temp').dispose();
-			})) ? domready() : arguments.callee.delay(50);
-	} else if (Browser.Engine.webkit && Browser.Engine.version < 525){
-		(function(){
-			(['loaded', 'complete'].contains(document.readyState)) ? domready() : arguments.callee.delay(50);
-	} else {
-		document.addEvent('DOMContentLoaded', domready);
-script: JSON.js
-description: JSON encoder and decoder.
-See Also: <http://www.json.org/>
-requires:
-- /Array
-- /String
-- /Number
-- /Function
-- /Hash
-provides: [JSON]
-var JSON = new Hash(this.JSON && {
-	stringify: JSON.stringify,
-	parse: JSON.parse
-}).extend({
-	$specialChars: {'\b': '\\b', '\t': '\\t', '\n': '\\n', '\f': '\\f', '\r': '\\r', '"' : '\\"', '\\': '\\\\'},
-	$replaceChars: function(chr){
-		return JSON.$specialChars[chr] || '\\u00' + Math.floor(chr.charCodeAt() / 16).toString(16) + (chr.charCodeAt() % 16).toString(16);
-	encode: function(obj){
-		switch ($type(obj)){
-			case 'string':
-				return '"' + obj.replace(/[\x00-\x1f\\"]/g, JSON.$replaceChars) + '"';
-			case 'array':
-				return '[' + String(obj.map(JSON.encode).clean()) + ']';
-			case 'object': case 'hash':
-				var string = [];
-				Hash.each(obj, function(value, key){
-					var json = JSON.encode(value);
-					if (json) string.push(JSON.encode(key) + ':' + json);
-				return '{' + string + '}';
-			case 'number': case 'boolean': return String(obj);
-			case false: return 'null';
-		return null;
-	decode: function(string, secure){
-		if ($type(string) != 'string' || !string.length) return null;
-		if (secure && !(/^[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t]*$/).test(string.replace(/\\./g, '@').replace(/"[^"\\\n\r]*"/g, ''))) return null;
-		return eval('(' + string + ')');
-Native.implement([Hash, Array, String, Number], {
-	toJSON: function(){
-		return JSON.encode(this);
-script: Cookie.js
-description: Class for creating, reading, and deleting browser Cookies.
-credits:
-- Based on the functions by Peter-Paul Koch (http://quirksmode.org).
-requires:
-- /Options
-provides: [Cookie]
-var Cookie = new Class({
-	Implements: Options,
-	options: {
-		path: false,
-		domain: false,
-		duration: false,
-		secure: false,
-		document: document
-	initialize: function(key, options){
-		this.key = key;
-		this.setOptions(options);
-	write: function(value){
-		value = encodeURIComponent(value);
-		if (this.options.domain) value += '; domain=' + this.options.domain;
-		if (this.options.path) value += '; path=' + this.options.path;
-		if (this.options.duration){
-			var date = new Date();
-			date.setTime(date.getTime() + this.options.duration * 24 * 60 * 60 * 1000);
-			value += '; expires=' + date.toGMTString();
-		if (this.options.secure) value += '; secure';
-		this.options.document.cookie = this.key + '=' + value;
-		return this;
-	read: function(){
-		var value = this.options.document.cookie.match('(?:^|;)\\s*' + this.key.escapeRegExp() + '=([^;]*)');
-		return (value) ? decodeURIComponent(value[1]) : null;
-		new Cookie(this.key, $merge(this.options, {duration: -1})).write('');
-		return this;
-Cookie.write = function(key, value, options){
-	return new Cookie(key, options).write(value);
-Cookie.read = function(key){
-	return new Cookie(key).read();
-Cookie.dispose = function(key, options){
-	return new Cookie(key, options).dispose();
-script: Swiff.js
-description: Wrapper for embedding SWF movies. Supports External Interface Communication.
-credits:
-- Flash detection & Internet Explorer + Flash Player 9 fix inspired by SWFObject.
-requires:
-- /Options
-- /$util
-provides: [Swiff]
-var Swiff = new Class({
-	Implements: [Options],
-	options: {
-		id: null,
-		height: 1,
-		width: 1,
-		container: null,
-		properties: {},
-		params: {
-			quality: 'high',
-			allowScriptAccess: 'always',
-			wMode: 'transparent',
-			swLiveConnect: true
-		callBacks: {},
-		vars: {}
-	toElement: function(){
-		return this.object;
-	initialize: function(path, options){
-		this.instance = 'Swiff_' + $time();
-		options = this.options;
-		var id = this.id = options.id || this.instance;
-		var container = document.id(options.container);
-		Swiff.CallBacks[this.instance] = {};
-		var params = options.params, vars = options.vars, callBacks = options.callBacks;
-		var properties = $extend({height: options.height, width: options.width}, options.properties);
-		var self = this;
-		for (var callBack in callBacks){
-			Swiff.CallBacks[this.instance][callBack] = (function(option){
-				return function(){
-					return option.apply(self.object, arguments);
-			})(callBacks[callBack]);
-			vars[callBack] = 'Swiff.CallBacks.' + this.instance + '.' + callBack;
-		params.flashVars = Hash.toQueryString(vars);
-			properties.classid = 'clsid:D27CDB6E-AE6D-11cf-96B8-444553540000';
-			params.movie = path;
-		} else {
-			properties.type = 'application/x-shockwave-flash';
-			properties.data = path;
-		var build = '<object id="' + id + '"';
-		for (var property in properties) build += ' ' + property + '="' + properties[property] + '"';
-		build += '>';
-		for (var param in params){
-			if (params[param]) build += '<param name="' + param + '" value="' + params[param] + '" />';
-		build += '</object>';
-		this.object = ((container) ? container.empty() : new Element('div')).set('html', build).firstChild;
-	replaces: function(element){
-		element.parentNode.replaceChild(this.toElement(), element);
-		return this;
-	inject: function(element){
-		document.id(element, true).appendChild(this.toElement());
-		return this;
-	remote: function(){
-		return Swiff.remote.apply(Swiff, [this.toElement()].extend(arguments));
-Swiff.CallBacks = {};
-Swiff.remote = function(obj, fn){
-	var rs = obj.CallFunction('<invoke name="' + fn + '" returntype="javascript">' + __flash__argumentsToXML(arguments, 2) + '</invoke>');
-	return eval(rs);
-script: Fx.js
-description: Contains the basic animation logic to be extended by all other Fx Classes.
-requires:
-- /Chain
-- /Events
-- /Options
-provides: [Fx]
-var Fx = new Class({
-	Implements: [Chain, Events, Options],
-	options: {
-		onStart: $empty,
-		onCancel: $empty,
-		onComplete: $empty,
-		fps: 50,
-		unit: false,
-		duration: 500,
-		link: 'ignore'
-	initialize: function(options){
-		this.subject = this.subject || this;
-		this.options.duration = Fx.Durations[this.options.duration] || this.options.duration.toInt();
-		var wait = this.options.wait;
-		if (wait === false) this.options.link = 'cancel';
-	getTransition: function(){
-		return function(p){
-			return -(Math.cos(Math.PI * p) - 1) / 2;
-	step: function(){
-		var time = $time();
-		if (time < this.time + this.options.duration){
-			var delta = this.transition((time - this.time) / this.options.duration);
-			this.set(this.compute(this.from, this.to, delta));
-		} else {
-			this.set(this.compute(this.from, this.to, 1));
-			this.complete();
-	set: function(now){
-		return now;
-	compute: function(from, to, delta){
-		return Fx.compute(from, to, delta);
-	check: function(){
-		if (!this.timer) return true;
-		switch (this.options.link){
-			case 'cancel': this.cancel(); return true;
-			case 'chain': this.chain(this.caller.bind(this, arguments)); return false;
-		return false;
-	start: function(from, to){
-		if (!this.check(from, to)) return this;
-		this.from = from;
-		this.to = to;
-		this.time = 0;
-		this.transition = this.getTransition();
-		this.startTimer();
-		this.onStart();
-		return this;
-	complete: function(){
-		if (this.stopTimer()) this.onComplete();
-		return this;
-	cancel: function(){
-		if (this.stopTimer()) this.onCancel();
-		return this;
-	onStart: function(){
-		this.fireEvent('start', this.subject);
-	onComplete: function(){
-		this.fireEvent('complete', this.subject);
-		if (!this.callChain()) this.fireEvent('chainComplete', this.subject);
-	onCancel: function(){
-		this.fireEvent('cancel', this.subject).clearChain();
-	pause: function(){
-		this.stopTimer();
-		return this;
-	resume: function(){
-		return this;
-	stopTimer: function(){
-		if (!this.timer) return false;
-		this.time = $time() - this.time;
-		this.timer = $clear(this.timer);
-		return true;
-	startTimer: function(){
-		if (this.timer) return false;
-		this.timer = this.step.periodical(Math.round(1000 / this.options.fps), this);
-		return true;
-Fx.compute = function(from, to, delta){
-	return (to - from) * delta + from;
-Fx.Durations = {'short': 250, 'normal': 500, 'long': 1000};
-script: Fx.CSS.js
-description: Contains the CSS animation logic. Used by Fx.Tween, Fx.Morph, Fx.Elements.
-requires:
-- /Fx
-- /Element.Style
-provides: [Fx.CSS]
-Fx.CSS = new Class({
-	Extends: Fx,
-	//prepares the base from/to object
-	prepare: function(element, property, values){
-		values = $splat(values);
-		var values1 = values[1];
-		if (!$chk(values1)){
-			values[1] = values[0];
-			values[0] = element.getStyle(property);
-		var parsed = values.map(this.parse);
-		return {from: parsed[0], to: parsed[1]};
-	//parses a value into an array
-	parse: function(value){
-		value = $lambda(value)();
-		value = (typeof value == 'string') ? value.split(' ') : $splat(value);
-		return value.map(function(val){
-			val = String(val);
-			var found = false;
-			Fx.CSS.Parsers.each(function(parser, key){
-				if (found) return;
-				var parsed = parser.parse(val);
-				if ($chk(parsed)) found = {value: parsed, parser: parser};
-			found = found || {value: val, parser: Fx.CSS.Parsers.String};
-			return found;
-	//computes by a from and to prepared objects, using their parsers.
-		var computed = [];
-		(Math.min(from.length, to.length)).times(function(i){
-			computed.push({value: from[i].parser.compute(from[i].value, to[i].value, delta), parser: from[i].parser});
-		computed.$family = {name: 'fx:css:value'};
-		return computed;
-	//serves the value as settable
-	serve: function(value, unit){
-		if ($type(value) != 'fx:css:value') value = this.parse(value);
-		var returned = [];
-		value.each(function(bit){
-			returned = returned.concat(bit.parser.serve(bit.value, unit));
-		return returned;
-	//renders the change to an element
-	render: function(element, property, value, unit){
-		element.setStyle(property, this.serve(value, unit));
-	//searches inside the page css to find the values for a selector
-	search: function(selector){
-		if (Fx.CSS.Cache[selector]) return Fx.CSS.Cache[selector];
-		var to = {};
-		Array.each(document.styleSheets, function(sheet, j){
-			var href = sheet.href;
-			if (href && href.contains('://') && !href.contains(document.domain)) return;
-			var rules = sheet.rules || sheet.cssRules;
-			Array.each(rules, function(rule, i){
-				if (!rule.style) return;
-				var selectorText = (rule.selectorText) ? rule.selectorText.replace(/^\w+/, function(m){
-					return m.toLowerCase();
-				}) : null;
-				if (!selectorText || !selectorText.test('^' + selector + '$')) return;
-				Element.Styles.each(function(value, style){
-					if (!rule.style[style] || Element.ShortStyles[style]) return;
-					value = String(rule.style[style]);
-					to[style] = (value.test(/^rgb/)) ? value.rgbToHex() : value;
-		return Fx.CSS.Cache[selector] = to;
-Fx.CSS.Cache = {};
-Fx.CSS.Parsers = new Hash({
-	Color: {
-			if (value.match(/^#[0-9a-f]{3,6}$/i)) return value.hexToRgb(true);
-			return ((value = value.match(/(\d+),\s*(\d+),\s*(\d+)/))) ? [value[1], value[2], value[3]] : false;
-			return from.map(function(value, i){
-				return Math.round(Fx.compute(from[i], to[i], delta));
-		serve: function(value){
-			return value.map(Number);
-	Number: {
-		parse: parseFloat,
-		compute: Fx.compute,
-			return (unit) ? value + unit : value;
-	String: {
-		parse: $lambda(false),
-		compute: $arguments(1),
-		serve: $arguments(0)
-script: Fx.Tween.js
-description: Formerly Fx.Style, effect to transition any CSS property for an element.
-requires:
-- /Fx.CSS
-provides: [Fx.Tween, Element.fade, Element.highlight]
-Fx.Tween = new Class({
-	Extends: Fx.CSS,
-	initialize: function(element, options){
-		this.element = this.subject = document.id(element);
-		this.parent(options);
-	set: function(property, now){
-		if (arguments.length == 1){
-			now = property;
-			property = this.property || this.options.property;
-		this.render(this.element, property, now, this.options.unit);
-		return this;
-	start: function(property, from, to){
-		if (!this.check(property, from, to)) return this;
-		this.property = this.options.property || args.shift();
-		var parsed = this.prepare(this.element, this.property, args);
-		return this.parent(parsed.from, parsed.to);
-Element.Properties.tween = {
-	set: function(options){
-		var tween = this.retrieve('tween');
-		if (tween) tween.cancel();
-		return this.eliminate('tween').store('tween:options', $extend({link: 'cancel'}, options));
-	get: function(options){
-		if (options || !this.retrieve('tween')){
-			if (options || !this.retrieve('tween:options')) this.set('tween', options);
-			this.store('tween', new Fx.Tween(this, this.retrieve('tween:options')));
-		return this.retrieve('tween');
-	tween: function(property, from, to){
-		this.get('tween').start(arguments);
-		return this;
-	fade: function(how){
-		var fade = this.get('tween'), o = 'opacity', toggle;
-		how = $pick(how, 'toggle');
-		switch (how){
-			case 'in': fade.start(o, 1); break;
-			case 'out': fade.start(o, 0); break;
-			case 'show': fade.set(o, 1); break;
-			case 'hide': fade.set(o, 0); break;
-			case 'toggle':
-				var flag = this.retrieve('fade:flag', this.get('opacity') == 1);
-				fade.start(o, (flag) ? 0 : 1);
-				this.store('fade:flag', !flag);
-				toggle = true;
-			break;
-			default: fade.start(o, arguments);
-		if (!toggle) this.eliminate('fade:flag');
-		return this;
-	highlight: function(start, end){
-		if (!end){
-			end = this.retrieve('highlight:original', this.getStyle('background-color'));
-			end = (end == 'transparent') ? '#fff' : end;
-		var tween = this.get('tween');
-		tween.start('background-color', start || '#ffff88', end).chain(function(){
-			this.setStyle('background-color', this.retrieve('highlight:original'));
-			tween.callChain();
-		}.bind(this));
-		return this;
-script: Fx.Morph.js
-description: Formerly Fx.Styles, effect to transition any number of CSS properties for an element using an object of rules, or CSS based selector rules.
-requires:
-- /Fx.CSS
-provides: [Fx.Morph]
-Fx.Morph = new Class({
-	Extends: Fx.CSS,
-		if (typeof now == 'string') now = this.search(now);
-		for (var p in now) this.render(this.element, p, now[p], this.options.unit);
-		return this;
-		var now = {};
-		for (var p in from) now[p] = this.parent(from[p], to[p], delta);
-		return now;
-	start: function(properties){
-		if (!this.check(properties)) return this;
-		if (typeof properties == 'string') properties = this.search(properties);
-		var from = {}, to = {};
-		for (var p in properties){
-			var parsed = this.prepare(this.element, p, properties[p]);
-			from[p] = parsed.from;
-			to[p] = parsed.to;
-		return this.parent(from, to);
-Element.Properties.morph = {
-		var morph = this.retrieve('morph');
-		if (morph) morph.cancel();
-		return this.eliminate('morph').store('morph:options', $extend({link: 'cancel'}, options));
-		if (options || !this.retrieve('morph')){
-			if (options || !this.retrieve('morph:options')) this.set('morph', options);
-			this.store('morph', new Fx.Morph(this, this.retrieve('morph:options')));
-		return this.retrieve('morph');
-	morph: function(props){
-		this.get('morph').start(props);
-		return this;
-script: Fx.Transitions.js
-description: Contains a set of advanced transitions to be used with any of the Fx Classes.
-credits:
-- Easing Equations by Robert Penner, <http://www.robertpenner.com/easing/>, modified and optimized to be used with MooTools.
-requires:
-- /Fx
-provides: [Fx.Transitions]
-Fx.implement({
-		var trans = this.options.transition || Fx.Transitions.Sine.easeInOut;
-		if (typeof trans == 'string'){
-			var data = trans.split(':');
-			trans = Fx.Transitions;
-			trans = trans[data[0]] || trans[data[0].capitalize()];
-			if (data[1]) trans = trans['ease' + data[1].capitalize() + (data[2] ? data[2].capitalize() : '')];
-		return trans;
-Fx.Transition = function(transition, params){
-	params = $splat(params);
-	return $extend(transition, {
-		easeIn: function(pos){
-			return transition(pos, params);
-		easeOut: function(pos){
-			return 1 - transition(1 - pos, params);
-		easeInOut: function(pos){
-			return (pos <= 0.5) ? transition(2 * pos, params) / 2 : (2 - transition(2 * (1 - pos), params)) / 2;
-Fx.Transitions = new Hash({
-	linear: $arguments(0)
-Fx.Transitions.extend = function(transitions){
-	for (var transition in transitions) Fx.Transitions[transition] = new Fx.Transition(transitions[transition]);
-Fx.Transitions.extend({
-	Pow: function(p, x){
-		return Math.pow(p, x[0] || 6);
-	Expo: function(p){
-		return Math.pow(2, 8 * (p - 1));
-	Circ: function(p){
-		return 1 - Math.sin(Math.acos(p));
-	Sine: function(p){
-		return 1 - Math.sin((1 - p) * Math.PI / 2);
-	Back: function(p, x){
-		x = x[0] || 1.618;
-		return Math.pow(p, 2) * ((x + 1) * p - x);
-	Bounce: function(p){
-		var value;
-		for (var a = 0, b = 1; 1; a += b, b /= 2){
-			if (p >= (7 - 4 * a) / 11){
-				value = b * b - Math.pow((11 - 6 * a - 11 * p) / 4, 2);
-				break;
-		return value;
-	Elastic: function(p, x){
-		return Math.pow(2, 10 * --p) * Math.cos(20 * p * Math.PI * (x[0] || 1) / 3);
-['Quad', 'Cubic', 'Quart', 'Quint'].each(function(transition, i){
-	Fx.Transitions[transition] = new Fx.Transition(function(p){
-		return Math.pow(p, [i + 2]);
-script: Request.js
-description: Powerful all purpose Request Class. Uses XMLHTTPRequest.
-requires:
-- /Element
-- /Chain
-- /Events
-- /Options
-- /Browser
-provides: [Request]
-var Request = new Class({
-	options: {/*
-		onRequest: $empty,
-		onCancel: $empty,
-		onSuccess: $empty,
-		onFailure: $empty,
-		onException: $empty,*/
-		url: '',
-		data: '',
-		headers: {
-			'X-Requested-With': 'XMLHttpRequest',
-			'Accept': 'text/javascript, text/html, application/xml, text/xml, */*'
-		async: true,
-		format: false,
-		method: 'post',
-		link: 'ignore',
-		isSuccess: null,
-		emulation: true,
-		urlEncoded: true,
-		encoding: 'utf-8',
-		evalScripts: false,
-		evalResponse: false,
-		noCache: false
-		this.xhr = new Browser.Request();
-		this.options.isSuccess = this.options.isSuccess || this.isSuccess;
-		this.headers = new Hash(this.options.headers);
-	onStateChange: function(){
-		if (this.xhr.readyState != 4 || !this.running) return;
-		this.running = false;
-		this.status = 0;
-		$try(function(){
-			this.status = this.xhr.status;
-		}.bind(this));
-		this.xhr.onreadystatechange = $empty;
-		if (this.options.isSuccess.call(this, this.status)){
-			this.response = {text: this.xhr.responseText, xml: this.xhr.responseXML};
-			this.success(this.response.text, this.response.xml);
-		} else {
-			this.response = {text: null, xml: null};
-			this.failure();
-	isSuccess: function(){
-		return ((this.status >= 200) && (this.status < 300));
-	processScripts: function(text){
-		if (this.options.evalResponse || (/(ecma|java)script/).test(this.getHeader('Content-type'))) return $exec(text);
-		return text.stripScripts(this.options.evalScripts);
-	success: function(text, xml){
-		this.onSuccess(this.processScripts(text), xml);
-	onSuccess: function(){
-		this.fireEvent('complete', arguments).fireEvent('success', arguments).callChain();
-	failure: function(){
-		this.onFailure();
-	onFailure: function(){
-		this.fireEvent('complete').fireEvent('failure', this.xhr);
-	setHeader: function(name, value){
-		this.headers.set(name, value);
-		return this;
-	getHeader: function(name){
-		return $try(function(){
-			return this.xhr.getResponseHeader(name);
-		}.bind(this));
-		if (!this.running) return true;
-		return false;
-	send: function(options){
-		if (!this.check(options)) return this;
-		this.running = true;
-		var type = $type(options);
-		if (type == 'string' || type == 'element') options = {data: options};
-		var old = this.options;
-		options = $extend({data: old.data, url: old.url, method: old.method}, options);
-		var data = options.data, url = String(options.url), method = options.method.toLowerCase();
-		switch ($type(data)){
-			case 'element': data = document.id(data).toQueryString(); break;
-			case 'object': case 'hash': data = Hash.toQueryString(data);
-		if (this.options.format){
-			var format = 'format=' + this.options.format;
-			data = (data) ? format + '&' + data : format;
-		if (this.options.emulation && !['get', 'post'].contains(method)){
-			var _method = '_method=' + method;
-			data = (data) ? _method + '&' + data : _method;
-			method = 'post';
-		if (this.options.urlEncoded && method == 'post'){
-			var encoding = (this.options.encoding) ? '; charset=' + this.options.encoding : '';
-			this.headers.set('Content-type', 'application/x-www-form-urlencoded' + encoding);
-		if (this.options.noCache){
-			var noCache = 'noCache=' + new Date().getTime();
-			data = (data) ? noCache + '&' + data : noCache;
-		var trimPosition = url.lastIndexOf('/');
-		if (trimPosition > -1 && (trimPosition = url.indexOf('#')) > -1) url = url.substr(0, trimPosition);
-		if (data && method == 'get'){
-			url = url + (url.contains('?') ? '&' : '?') + data;
-			data = null;
-		this.xhr.open(method.toUpperCase(), url, this.options.async);
-		this.xhr.onreadystatechange = this.onStateChange.bind(this);
-		this.headers.each(function(value, key){
-			try {
-				this.xhr.setRequestHeader(key, value);
-			} catch (e){
-				this.fireEvent('exception', [key, value]);
-		}, this);
-		this.fireEvent('request');
-		this.xhr.send(data);
-		if (!this.options.async) this.onStateChange();
-		return this;
-		if (!this.running) return this;
-		this.xhr.abort();
-		this.fireEvent('cancel');
-		return this;
-(function(){
-var methods = {};
-['get', 'post', 'put', 'delete', 'GET', 'POST', 'PUT', 'DELETE'].each(function(method){
-	methods[method] = function(){
-		var params = Array.link(arguments, {url: String.type, data: $defined});
-		return this.send($extend(params, {method: method}));
-Request.implement(methods);
-Element.Properties.send = {
-		var send = this.retrieve('send');
-		if (send) send.cancel();
-		return this.eliminate('send').store('send:options', $extend({
-			data: this, link: 'cancel', method: this.get('method') || 'post', url: this.get('action')
-		}, options));
-		if (options || !this.retrieve('send')){
-			if (options || !this.retrieve('send:options')) this.set('send', options);
-			this.store('send', new Request(this.retrieve('send:options')));
-		return this.retrieve('send');
-	send: function(url){
-		var sender = this.get('send');
-		sender.send({data: this, url: url || sender.options.url});
-		return this;
-script: Request.HTML.js
-description: Extends the basic Request Class with additional methods for interacting with HTML responses.
-requires:
-- /Request
-- /Element
-provides: [Request.HTML]
-Request.HTML = new Class({
-	Extends: Request,
-	options: {
-		update: false,
-		append: false,
-		evalScripts: true,
-		filter: false
-	processHTML: function(text){
-		var match = text.match(/<body[^>]*>([\s\S]*?)<\/body>/i);
-		text = (match) ? match[1] : text;
-		var container = new Element('div');
-			var root = '<root>' + text + '</root>', doc;
-				doc = new ActiveXObject('Microsoft.XMLDOM');
-				doc.async = false;
-				doc.loadXML(root);
-			} else {
-				doc = new DOMParser().parseFromString(root, 'text/xml');
-			root = doc.getElementsByTagName('root')[0];
-			if (!root) return null;
-			for (var i = 0, k = root.childNodes.length; i < k; i++){
-				var child = Element.clone(root.childNodes[i], true, true);
-				if (child) container.grab(child);
-			return container;
-		}) || container.set('html', text);
-	success: function(text){
-		var options = this.options, response = this.response;
-		response.html = text.stripScripts(function(script){
-			response.javascript = script;
-		var temp = this.processHTML(response.html);
-		response.tree = temp.childNodes;
-		response.elements = temp.getElements('*');
-		if (options.filter) response.tree = response.elements.filter(options.filter);
-		if (options.update) document.id(options.update).empty().set('html', response.html);
-		else if (options.append) document.id(options.append).adopt(temp.getChildren());
-		if (options.evalScripts) $exec(response.javascript);
-		this.onSuccess(response.tree, response.elements, response.html, response.javascript);
-Element.Properties.load = {
-		var load = this.retrieve('load');
-		if (load) load.cancel();
-		return this.eliminate('load').store('load:options', $extend({data: this, link: 'cancel', update: this, method: 'get'}, options));
-		if (options || ! this.retrieve('load')){
-			if (options || !this.retrieve('load:options')) this.set('load', options);
-			this.store('load', new Request.HTML(this.retrieve('load:options')));
-		return this.retrieve('load');
-	load: function(){
-		this.get('load').send(Array.link(arguments, {data: Object.type, url: String.type}));
-		return this;
-script: Request.JSON.js
-description: Extends the basic Request Class with additional methods for sending and receiving JSON data.
-requires:
-- /Request JSON
-Request.JSON = new Class({
-	Extends: Request,
-	options: {
-		secure: true
-		this.headers.extend({'Accept': 'application/json', 'X-Request': 'JSON'});
-		this.response.json = JSON.decode(text, this.options.secure);
-		this.onSuccess(this.response.json, text);
-script: More.js
-description: MooTools More
-authors:
- - Guillermo Rauch
- - Thomas Aylott
- - Scott Kyle
-requires:
- - core:1.2.4/MooTools
-provides: [MooTools.More]
-MooTools.More = {
-	'version': '1.2.4.4',
-	'build': '6f6057dc645fdb7547689183b2311063bd653ddf'
-script: MooTools.Lang.js
-description: Provides methods for localization.
-authors:
- - Aaron Newton
-requires:
- - core:1.2.4/Events
- - /MooTools.More
-provides: [MooTools.Lang]
-(function(){
-	var data = {
-		language: 'en-US',
-		languages: {
-			'en-US': {}
-		cascades: ['en-US']
-	var cascaded;
-	MooTools.lang = new Events();
-	$extend(MooTools.lang, {
-		setLanguage: function(lang){
-			if (!data.languages[lang]) return this;
-			data.language = lang;
-			this.load();
-			this.fireEvent('langChange', lang);
-			return this;
-		load: function() {
-			var langs = this.cascade(this.getCurrentLanguage());
-			cascaded = {};
-			$each(langs, function(set, setName){
-				cascaded[setName] = this.lambda(set);
-			}, this);
-		getCurrentLanguage: function(){
-			return data.language;
-		addLanguage: function(lang){
-			data.languages[lang] = data.languages[lang] || {};
-			return this;
-		cascade: function(lang){
-			var cascades = (data.languages[lang] || {}).cascades || [];
-			cascades.combine(data.cascades);
-			cascades.erase(lang).push(lang);
-			var langs = cascades.map(function(lng){
-				return data.languages[lng];
-			}, this);
-			return $merge.apply(this, langs);
-		lambda: function(set) {
-			(set || {}).get = function(key, args){
-				return $lambda(set[key]).apply(this, $splat(args));
-			return set;
-		get: function(set, key, args){
-			if (cascaded && cascaded[set]) return (key ? cascaded[set].get(key, args) : cascaded[set]);
-		set: function(lang, set, members){
-			this.addLanguage(lang);
-			langData = data.languages[lang];
-			if (!langData[set]) langData[set] = {};
-			$extend(langData[set], members);
-			if (lang == this.getCurrentLanguage()){
-				this.load();
-			return this;
-		list: function(){
-			return Hash.getKeys(data.languages);
-script: Log.js
-description: Provides basic logging functionality for plugins to implement.
-authors:
- - Guillermo Rauch
- - Thomas Aylott
- - Scott Kyle
-requires:
- - core:1.2.4/Class
- - /MooTools.More
-provides: [Log]
-(function(){
-var global = this;
-var log = function(){
-	if (global.console && console.log){
-		try {
-			console.log.apply(console, arguments);
-		} catch(e) {
-			console.log(Array.slice(arguments));
-	} else {
-		Log.logged.push(arguments);
-	return this;
-var disabled = function(){
-	this.logged.push(arguments);
-	return this;
-this.Log = new Class({
-	logged: [],
-	log: disabled,
-	resetLog: function(){
-		this.logged.empty();
-		return this;
-	enableLog: function(){
-		this.log = log;
-		this.logged.each(function(args){
-			this.log.apply(this, args);
-		}, this);
-		return this.resetLog();
-	disableLog: function(){
-		this.log = disabled;
-		return this;
-Log.extend(new Log).enableLog();
-// legacy
-Log.logger = function(){
-	return this.log.apply(this, arguments);
-script: Depender.js
-description: A stand alone dependency loader for the MooTools library.
-authors:
- - Aaron Newton
-requires:
- - core:1.2.4/Element.Events
- - core:1.2.4/Request.JSON
- - /MooTools.More
- - /Log
-provides: Depender
-var Depender = {
-	options: {
-		onRequire: $empty(options),
-		onRequirementLoaded: $empty([scripts, options]),
-		onScriptLoaded: $empty({
-			script: script,
-			totalLoaded: percentOfTotalLoaded,
-			loaded: scriptsState
-		serial: false,
-		target: null,
-		noCache: false,
-		log: false,*/
-		loadedSources: [],
-		loadedScripts: ['Core', 'Browser', 'Array', 'String', 'Function', 'Number', 'Hash', 'Element', 'Event', 'Element.Event', 'Class', 'DomReady', 'Class.Extras', 'Request', 'JSON', 'Request.JSON', 'More', 'Depender', 'Log'],
-		useScriptInjection: true
-	loaded: [],
-	sources: {},
-	libs: {},
-	include: function(libs){
-		this.log('include: ', libs);
-		this.mapLoaded = false;
-		var loader = function(data){
-			this.libs = $merge(this.libs, data);
-			$each(this.libs, function(data, lib){
-				if (data.scripts) this.loadSource(lib, data.scripts);
-			}, this);
-		}.bind(this);
-		if ($type(libs) == 'string'){
-			this.log('fetching libs ', libs);
-			this.request(libs, loader);
-		} else {
-			loader(libs);
-		return this;
-	required: [],
-	require: function(options){
-		var loaded = function(){
-			var scripts = this.calculateDependencies(options.scripts);
-			if (options.sources){
-				options.sources.each(function(source){
-					scripts.combine(this.libs[source].files);
-				}, this);
-			if (options.serial) scripts.combine(this.getLoadedScripts());
-			options.scripts = scripts;
-			this.required.push(options);
-			this.fireEvent('require', options);
-			this.loadScripts(options.scripts);
-		if (this.mapLoaded) loaded.call(this);
-		else this.addEvent('mapLoaded', loaded.bind(this));
-		return this;
-	cleanDoubleSlash: function(str){
-		if (!str) return str;
-		var prefix = '';
-		if (str.test(/^http:\/\//)){
-			prefix = 'http://';
-			str = str.substring(7, str.length);
-		str = str.replace(/\/\//g, '/');
-		return prefix + str;
-	request: function(url, callback){
-		new Request.JSON({
-			url: url,
-			secure: false,
-			onSuccess: callback
-		}).send();
-	loadSource: function(lib, source){
-		if (this.libs[lib].files){
-			this.dataLoaded();
-			return;
-		this.log('loading source: ', source);
-		this.request(this.cleanDoubleSlash(source + '/scripts.json'), function(result){
-			this.log('loaded source: ', source);
-			this.libs[lib].files = result;
-		}.bind(this));
-	dataLoaded: function(){
-		var loaded = true;
-		$each(this.libs, function(v, k){
-			if (!this.libs[k].files) loaded = false;
-		}, this);
-		if (loaded){
-			this.mapTree();
-			this.mapLoaded = true;
-			this.calculateLoaded();
-			this.lastLoaded = this.getLoadedScripts().getLength();
-			this.fireEvent('mapLoaded');
-			this.removeEvents('mapLoaded');
-	calculateLoaded: function(){
-		var set = function(script){
-			this.scriptsState[script] = true;
-		}.bind(this);
-		if (this.options.loadedScripts) this.options.loadedScripts.each(set);
-		if (this.options.loadedSources){
-			this.options.loadedSources.each(function(lib){
-				$each(this.libs[lib].files, function(dir){
-					$each(dir, function(data, file){
-						set(file);
-					}, this);
-				}, this);
-			}, this);
-	deps: {},
-	pathMap: {},
-	mapTree: function(){
-		$each(this.libs, function(data, source){
-			$each(data.files, function(scripts, folder){
-				$each(scripts, function(details, script){
-					var path = source + ':' + folder + ':' + script;
-					if (this.deps[path]) return;
-					this.deps[path] = details.deps;
-					this.pathMap[script] = path;
-				}, this);
-			}, this);
-		}, this);
-	getDepsForScript: function(script){
-		return this.deps[this.pathMap[script]] || [];
-	calculateDependencies: function(scripts){
-		var reqs = [];
-		$splat(scripts).each(function(script){
-			if (script == 'None' || !script) return;
-			var deps = this.getDepsForScript(script);
-			if (!deps){
-				if (window.console && console.warn) console.warn('dependencies not mapped: script: %o, map: %o, :deps: %o', script, this.pathMap, this.deps);
-			} else {
-				deps.each(function(scr){
-					if (scr == script || scr == 'None' || !scr) return;
-					if (!reqs.contains(scr)) reqs.combine(this.calculateDependencies(scr));
-					reqs.include(scr);
-				}, this);
-			reqs.include(script);
-		}, this);
-		return reqs;
-	getPath: function(script){
-		try {
-			var chunks = this.pathMap[script].split(':');
-			var lib = this.libs[chunks[0]];
-			var dir = (lib.path || lib.scripts) + '/';
-			chunks.shift();
-			return this.cleanDoubleSlash(dir + chunks.join('/') + '.js');
-		} catch(e){
-			return script;
-	loadScripts: function(scripts){
-		scripts = scripts.filter(function(s){
-			if (!this.scriptsState[s] && s != 'None'){
-				this.scriptsState[s] = false;
-				return true;
-		}, this);
-		if (scripts.length){
-			scripts.each(function(scr){
-				this.loadScript(scr);
-			}, this);
-		} else {
-			this.check();
-	toLoad: [],
-	loadScript: function(script){
-		if (this.scriptsState[script] && this.toLoad.length){
-			this.loadScript(this.toLoad.shift());
-			return;
-		} else if (this.loading){
-			this.toLoad.push(script);
-			return;
-		var finish = function(){
-			this.loading = false;
-			this.scriptLoaded(script);
-			if (this.toLoad.length) this.loadScript(this.toLoad.shift());
-		}.bind(this);
-		var error = function(){
-			this.log('could not load: ', scriptPath);
-		}.bind(this);
-		this.loading = true;
-		var scriptPath = this.getPath(script);
-		if (this.options.useScriptInjection){
-			this.log('injecting script: ', scriptPath);
-				this.log('loaded script: ', scriptPath);
-				finish();
-			}.bind(this);
-			new Element('script', {
-				src: scriptPath + (this.options.noCache ? '?noCache=' + new Date().getTime() : ''),
-				events: {
-					load: loaded,
-					readystatechange: function(){
-						if (['loaded', 'complete'].contains(this.readyState)) loaded();
-					error: error
-			}).inject(this.options.target || document.head);
-		} else {
-			this.log('requesting script: ', scriptPath);
-			new Request({
-				url: scriptPath,
-				noCache: this.options.noCache,
-				onComplete: function(js){
-					$exec(js);
-					finish();
-				}.bind(this),
-				onFailure: error,
-				onException: error
-			}).send();
-	scriptsState: $H(),
-	getLoadedScripts: function(){
-		return this.scriptsState.filter(function(state){
-			return state;
-	scriptLoaded: function(script){
-		this.log('loaded script: ', script);
-		this.check();
-		var loaded = this.getLoadedScripts();
-		var loadedLength = loaded.getLength();
-		var toLoad = this.scriptsState.getLength();
-		this.fireEvent('scriptLoaded', {
-			script: script,
-			totalLoaded: (loadedLength / toLoad * 100).round(),
-			currentLoaded: ((loadedLength - this.lastLoaded) / (toLoad - this.lastLoaded) * 100).round(),
-			loaded: loaded
-		if (loadedLength == toLoad) this.lastLoaded = loadedLength;
-	lastLoaded: 0,
-		var incomplete = [];
-		this.required.each(function(required){
-			var loaded = [];
-			required.scripts.each(function(script){
-				if (this.scriptsState[script]) loaded.push(script);
-			}, this);
-			if (required.onStep){
-				required.onStep({
-					percent: loaded.length / required.scripts.length * 100,
-					scripts: loaded
-			if (required.scripts.length != loaded.length) return;
-			required.callback();
-			this.required.erase(required);
-			this.fireEvent('requirementLoaded', [loaded, required]);
-		}, this);
-$extend(Depender, new Events);
-$extend(Depender, new Options);
-$extend(Depender, new Log);
-Depender._setOptions = Depender.setOptions;
-Depender.setOptions = function(){
-	Depender._setOptions.apply(Depender, arguments);
-	if (this.options.log) Depender.enableLog();
-	return this;
-script: Class.Refactor.js
-description: Extends a class onto itself with new property, preserving any items attached to the class's namespace.
-authors:
- - Aaron Newton
-requires:
- - /MooTools.More
-provides: [Class.refactor]
-Class.refactor = function(original, refactors){
-	$each(refactors, function(item, name){
-		var origin = original.prototype[name];
-		if (origin && (origin = origin._origin) && typeof item == 'function') original.implement(name, function(){
-			var old = this.previous;
-			this.previous = origin;
-			var value = item.apply(this, arguments);
-			this.previous = old;
-			return value;
-		}); else original.implement(name, item);
-	return original;
-script: Class.Binds.js
-description: Automagically binds specified methods in a class to the instance of the class.
-authors:
- - Aaron Newton
-requires:
- - /MooTools.More
-provides: [Class.Binds]
-Class.Mutators.Binds = function(binds){
-    return binds;
-Class.Mutators.initialize = function(initialize){
-		$splat(this.Binds).each(function(name){
-			var original = this[name];
-			if (original) this[name] = original.bind(this);
-		}, this);
-		return initialize.apply(this, arguments);
-script: Class.Occlude.js
-description: Prevents a class from being applied to a DOM element twice.
-authors:
- - Aaron Newton
-requires:
- - core/1.2.4/Class
- - /MooTools.More
-provides: [Class.Occlude]
-Class.Occlude = new Class({
-	occlude: function(property, element){
-		element = document.id(element || this.element);
-		var instance = element.retrieve(property || this.property);
-		if (instance && !$defined(this.occluded))
-			return this.occluded = instance;
-		this.occluded = false;
-		element.store(property || this.property, this);
-		return this.occluded;
-script: Chain.Wait.js
-description: value, Adds a method to inject pauses between chained events.
-authors:
- - Aaron Newton
-requires:
- - core:1.2.4/Chain
- - core:1.2.4/Fx
- - /MooTools.More
-provides: [Chain.Wait]
-(function(){
-	var wait = {
-		wait: function(duration){
-			return this.chain(function(){
-				this.callChain.delay($pick(duration, 500), this);
-			}.bind(this));
-	Chain.implement(wait);
-	if (window.Fx){
-		Fx.implement(wait);
-		['Css', 'Tween', 'Elements'].each(function(cls){
-			if (Fx[cls]) Fx[cls].implement(wait);
-	Element.implement({
-		chains: function(effects){
-			$splat($pick(effects, ['tween', 'morph', 'reveal'])).each(function(effect){
-				effect = this.get(effect);
-				if (!effect) return;
-				effect.setOptions({
-					link:'chain'
-			}, this);
-			return this;
-		pauseFx: function(duration, effect){
-			this.chains(effect).get($pick(effect, 'tween')).wait(duration);
-			return this;
-script: Array.Extras.js
-description: Extends the Array native object to include useful methods to work with arrays.
-authors:
- - Christoph Pojer
-requires:
- - core:1.2.4/Array
-provides: [Array.Extras]
-Array.implement({
-	min: function(){
-		return Math.min.apply(null, this);
-	max: function(){
-		return Math.max.apply(null, this);
-	average: function(){
-		return this.length ? this.sum() / this.length : 0;
-	sum: function(){
-		var result = 0, l = this.length;
-		if (l){
-			do {
-				result += this[--l];
-			} while (l);
-		return result;
-	unique: function(){
-		return [].combine(this);
-	shuffle: function(){
-		for (var i = this.length; i && --i;){
-			var temp = this[i], r = Math.floor(Math.random() * ( i + 1 ));
-			this[i] = this[r];
-			this[r] = temp;
-		return this;
-script: Date.English.US.js
-description: Date messages for US English.
-authors:
- - Aaron Newton
-requires:
- - /Lang
- - /Date
-provides: [Date.English.US]
-MooTools.lang.set('en-US', 'Date', {
-	months: ['January', 'February', 'March', 'April', 'May', 'June', 'July', 'August', 'September', 'October', 'November', 'December'],
-	days: ['Sunday', 'Monday', 'Tuesday', 'Wednesday', 'Thursday', 'Friday', 'Saturday'],
-	//culture's date order: MM/DD/YYYY
-	dateOrder: ['month', 'date', 'year'],
-	shortDate: '%m/%d/%Y',
-	shortTime: '%I:%M%p',
-	AM: 'AM',
-	PM: 'PM',
-	/* Date.Extras */
-	ordinal: function(dayOfMonth){
-		//1st, 2nd, 3rd, etc.
-		return (dayOfMonth > 3 && dayOfMonth < 21) ? 'th' : ['th', 'st', 'nd', 'rd', 'th'][Math.min(dayOfMonth % 10, 4)];
-	lessThanMinuteAgo: 'less than a minute ago',
-	minuteAgo: 'about a minute ago',
-	minutesAgo: '{delta} minutes ago',
-	hourAgo: 'about an hour ago',
-	hoursAgo: 'about {delta} hours ago',
-	dayAgo: '1 day ago',
-	daysAgo: '{delta} days ago',
-	weekAgo: '1 week ago',
-	weeksAgo: '{delta} weeks ago',
-	monthAgo: '1 month ago',
-	monthsAgo: '{delta} months ago',
-	yearAgo: '1 year ago',
-	yearsAgo: '{delta} years ago',
-	lessThanMinuteUntil: 'less than a minute from now',
-	minuteUntil: 'about a minute from now',
-	minutesUntil: '{delta} minutes from now',
-	hourUntil: 'about an hour from now',
-	hoursUntil: 'about {delta} hours from now',
-	dayUntil: '1 day from now',
-	daysUntil: '{delta} days from now',
-	weekUntil: '1 week from now',
-	weeksUntil: '{delta} weeks from now',
-	monthUntil: '1 month from now',
-	monthsUntil: '{delta} months from now',
-	yearUntil: '1 year from now',
-	yearsUntil: '{delta} years from now'
-script: Date.js
-description: Extends the Date native object to include methods useful in managing dates.
-authors:
- - Aaron Newton
- - Nicholas Barthelemy - https://svn.nbarthelemy.com/date-js/
- - Harald Kirshner - mail [at] digitarald.de; http://digitarald.de
- - Scott Kyle - scott [at] appden.com; http://appden.com
-requires:
- - core:1.2.4/String
- - core:1.2.4/Number
- - core:1.2.4/Lang
- - core:1.2.4/Date.English.US
- - /MooTools.More
-provides: [Date]
-(function(){
-var Date = this.Date;
-if (!Date.now) Date.now = $time;
-Date.Methods = {
-	ms: 'Milliseconds',
-	year: 'FullYear',
-	min: 'Minutes',
-	mo: 'Month',
-	sec: 'Seconds',
-	hr: 'Hours'
-['Date', 'Day', 'FullYear', 'Hours', 'Milliseconds', 'Minutes', 'Month', 'Seconds', 'Time', 'TimezoneOffset',
-	'Week', 'Timezone', 'GMTOffset', 'DayOfYear', 'LastMonth', 'LastDayOfMonth', 'UTCDate', 'UTCDay', 'UTCFullYear',
-	'AMPM', 'Ordinal', 'UTCHours', 'UTCMilliseconds', 'UTCMinutes', 'UTCMonth', 'UTCSeconds'].each(function(method){
-	Date.Methods[method.toLowerCase()] = method;
-var pad = function(what, length){
-	return new Array(length - String(what).length + 1).join('0') + what;
-Date.implement({
-	set: function(prop, value){
-		switch ($type(prop)){
-			case 'object':
-				for (var p in prop) this.set(p, prop[p]);
-				break;
-			case 'string':
-				prop = prop.toLowerCase();
-				var m = Date.Methods;
-				if (m[prop]) this['set' + m[prop]](value);
-		return this;
-	get: function(prop){
-		if (m[prop]) return this['get' + m[prop]]();
-		return null;
-	clone: function(){
-		return new Date(this.get('time'));
-	increment: function(interval, times){
-		interval = interval || 'day';
-		times = $pick(times, 1);
-		switch (interval){
-			case 'year':
-				return this.increment('month', times * 12);
-			case 'month':
-				var d = this.get('date');
-				this.set('date', 1).set('mo', this.get('mo') + times);
-				return this.set('date', d.min(this.get('lastdayofmonth')));
-			case 'week':
-				return this.increment('day', times * 7);
-			case 'day':
-				return this.set('date', this.get('date') + times);
-		if (!Date.units[interval]) throw new Error(interval + ' is not a supported interval');
-		return this.set('time', this.get('time') + times * Date.units[interval]());
-	decrement: function(interval, times){
-		return this.increment(interval, -1 * $pick(times, 1));
-	isLeapYear: function(){
-		return Date.isLeapYear(this.get('year'));
-	clearTime: function(){
-		return this.set({hr: 0, min: 0, sec: 0, ms: 0});
-	diff: function(date, resolution){
-		if ($type(date) == 'string') date = Date.parse(date);
-		return ((date - this) / Date.units[resolution || 'day'](3, 3)).toInt(); // non-leap year, 30-day month
-	getLastDayOfMonth: function(){
-		return Date.daysInMonth(this.get('mo'), this.get('year'));
-	getDayOfYear: function(){
-		return (Date.UTC(this.get('year'), this.get('mo'), this.get('date') + 1)
-			- Date.UTC(this.get('year'), 0, 1)) / Date.units.day();
-	getWeek: function(){
-		return (this.get('dayofyear') / 7).ceil();
-	getOrdinal: function(day){
-		return Date.getMsg('ordinal', day || this.get('date'));
-	getTimezone: function(){
-		return this.toString()
-			.replace(/^.*? ([A-Z]{3}).[0-9]{4}.*$/, '$1')
-			.replace(/^.*?\(([A-Z])[a-z]+ ([A-Z])[a-z]+ ([A-Z])[a-z]+\)$/, '$1$2$3');
-	getGMTOffset: function(){
-		var off = this.get('timezoneOffset');
-		return ((off > 0) ? '-' : '+') + pad((off.abs() / 60).floor(), 2) + pad(off % 60, 2);
-	setAMPM: function(ampm){
-		ampm = ampm.toUpperCase();
-		var hr = this.get('hr');
-		if (hr > 11 && ampm == 'AM') return this.decrement('hour', 12);
-		else if (hr < 12 && ampm == 'PM') return this.increment('hour', 12);
-		return this;
-	getAMPM: function(){
-		return (this.get('hr') < 12) ? 'AM' : 'PM';
-	parse: function(str){
-		this.set('time', Date.parse(str));
-		return this;
-	isValid: function(date) {
-		return !!(date || this).valueOf();
-	format: function(f){
-		if (!this.isValid()) return 'invalid date';
-		f = f || '%x %X';
-		f = formats[f.toLowerCase()] || f; // replace short-hand with actual format
-		var d = this;
-		return f.replace(/%([a-z%])/gi,
-			function($0, $1){
-				switch ($1){
-					case 'a': return Date.getMsg('days')[d.get('day')].substr(0, 3);
-					case 'A': return Date.getMsg('days')[d.get('day')];
-					case 'b': return Date.getMsg('months')[d.get('month')].substr(0, 3);
-					case 'B': return Date.getMsg('months')[d.get('month')];
-					case 'c': return d.toString();
-					case 'd': return pad(d.get('date'), 2);
-					case 'H': return pad(d.get('hr'), 2);
-					case 'I': return ((d.get('hr') % 12) || 12);
-					case 'j': return pad(d.get('dayofyear'), 3);
-					case 'm': return pad((d.get('mo') + 1), 2);
-					case 'M': return pad(d.get('min'), 2);
-					case 'o': return d.get('ordinal');
-					case 'p': return Date.getMsg(d.get('ampm'));
-					case 'S': return pad(d.get('seconds'), 2);
-					case 'U': return pad(d.get('week'), 2);
-					case 'w': return d.get('day');
-					case 'x': return d.format(Date.getMsg('shortDate'));
-					case 'X': return d.format(Date.getMsg('shortTime'));
-					case 'y': return d.get('year').toString().substr(2);
-					case 'Y': return d.get('year');
-					case 'T': return d.get('GMTOffset');
-					case 'Z': return d.get('Timezone');
-				return $1;
-	toISOString: function(){
-		return this.format('iso8601');
-Date.alias('toISOString', 'toJSON');
-Date.alias('diff', 'compare');
-Date.alias('format', 'strftime');
-var formats = {
-	db: '%Y-%m-%d %H:%M:%S',
-	compact: '%Y%m%dT%H%M%S',
-	iso8601: '%Y-%m-%dT%H:%M:%S%T',
-	rfc822: '%a, %d %b %Y %H:%M:%S %Z',
-	'short': '%d %b %H:%M',
-	'long': '%B %d, %Y %H:%M'
-var parsePatterns = [];
-var nativeParse = Date.parse;
-var parseWord = function(type, word, num){
-	var ret = -1;
-	var translated = Date.getMsg(type + 's');
-	switch ($type(word)){
-		case 'object':
-			ret = translated[word.get(type)];
-			break;
-		case 'number':
-			ret = translated[month - 1];
-			if (!ret) throw new Error('Invalid ' + type + ' index: ' + index);
-			break;
-		case 'string':
-			var match = translated.filter(function(name){
-				return this.test(name);
-			}, new RegExp('^' + word, 'i'));
-			if (!match.length)    throw new Error('Invalid ' + type + ' string');
-			if (match.length > 1) throw new Error('Ambiguous ' + type);
-			ret = match[0];
-	return (num) ? translated.indexOf(ret) : ret;
-Date.extend({
-	getMsg: function(key, args) {
-		return MooTools.lang.get('Date', key, args);
-	units: {
-		ms: $lambda(1),
-		second: $lambda(1000),
-		minute: $lambda(60000),
-		hour: $lambda(3600000),
-		day: $lambda(86400000),
-		week: $lambda(608400000),
-		month: function(month, year){
-			var d = new Date;
-			return Date.daysInMonth($pick(month, d.get('mo')), $pick(year, d.get('year'))) * 86400000;
-		year: function(year){
-			year = year || new Date().get('year');
-			return Date.isLeapYear(year) ? 31622400000 : 31536000000;
-	daysInMonth: function(month, year){
-		return [31, Date.isLeapYear(year) ? 29 : 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31][month];
-	isLeapYear: function(year){
-		return ((year % 4 === 0) && (year % 100 !== 0)) || (year % 400 === 0);
-	parse: function(from){
-		var t = $type(from);
-		if (t == 'number') return new Date(from);
-		if (t != 'string') return from;
-		from = from.clean();
-		if (!from.length) return null;
-		var parsed;
-		parsePatterns.some(function(pattern){
-			var bits = pattern.re.exec(from);
-			return (bits) ? (parsed = pattern.handler(bits)) : false;
-		return parsed || new Date(nativeParse(from));
-	parseDay: function(day, num){
-		return parseWord('day', day, num);
-	parseMonth: function(month, num){
-		return parseWord('month', month, num);
-	parseUTC: function(value){
-		var localDate = new Date(value);
-		var utcSeconds = Date.UTC(
-			localDate.get('year'),
-			localDate.get('mo'),
-			localDate.get('date'),
-			localDate.get('hr'),
-			localDate.get('min'),
-			localDate.get('sec')
-		return new Date(utcSeconds);
-	orderIndex: function(unit){
-		return Date.getMsg('dateOrder').indexOf(unit) + 1;
-	defineFormat: function(name, format){
-		formats[name] = format;
-	defineFormats: function(formats){
-		for (var name in formats) Date.defineFormat(name, formats[name]);
-	parsePatterns: parsePatterns, // this is deprecated
-	defineParser: function(pattern){
-		parsePatterns.push((pattern.re && pattern.handler) ? pattern : build(pattern));
-	defineParsers: function(){
-		Array.flatten(arguments).each(Date.defineParser);
-	define2DigitYearStart: function(year){
-		startYear = year % 100;
-		startCentury = year - startYear;
-var startCentury = 1900;
-var startYear = 70;
-var regexOf = function(type){
-	return new RegExp('(?:' + Date.getMsg(type).map(function(name){
-		return name.substr(0, 3);
-	}).join('|') + ')[a-z]*');
-var replacers = function(key){
-	switch(key){
-		case 'x': // iso8601 covers yyyy-mm-dd, so just check if month is first
-			return ((Date.orderIndex('month') == 1) ? '%m[.-/]%d' : '%d[.-/]%m') + '([.-/]%y)?';
-		case 'X':
-			return '%H([.:]%M)?([.:]%S([.:]%s)?)? ?%p? ?%T?';
-	return null;
-var keys = {
-	d: /[0-2]?[0-9]|3[01]/,
-	H: /[01]?[0-9]|2[0-3]/,
-	I: /0?[1-9]|1[0-2]/,
-	M: /[0-5]?\d/,
-	s: /\d+/,
-	o: /[a-z]*/,
-	p: /[ap]\.?m\.?/,
-	y: /\d{2}|\d{4}/,
-	Y: /\d{4}/,
-	T: /Z|[+-]\d{2}(?::?\d{2})?/
-keys.m = keys.I;
-keys.S = keys.M;
-var currentLanguage;
-var recompile = function(language){
-	currentLanguage = language;
-	keys.a = keys.A = regexOf('days');
-	keys.b = keys.B = regexOf('months');
-	parsePatterns.each(function(pattern, i){
-		if (pattern.format) parsePatterns[i] = build(pattern.format);
-var build = function(format){
-	if (!currentLanguage) return {format: format};
-	var parsed = [];
-	var re = (format.source || format) // allow format to be regex
-	 .replace(/%([a-z])/gi,
-		function($0, $1){
-			return replacers($1) || $0;
-	).replace(/\((?!\?)/g, '(?:') // make all groups non-capturing
-	 .replace(/ (?!\?|\*)/g, ',? ') // be forgiving with spaces and commas
-	 .replace(/%([a-z%])/gi,
-		function($0, $1){
-			var p = keys[$1];
-			if (!p) return $1;
-			parsed.push($1);
-			return '(' + p.source + ')';
-	).replace(/\[a-z\]/gi, '[a-z\\u00c0-\\uffff]'); // handle unicode words
-	return {
-		format: format,
-		re: new RegExp('^' + re + '$', 'i'),
-		handler: function(bits){
-			bits = bits.slice(1).associate(parsed);
-			var date = new Date().clearTime();
-			if ('d' in bits) handle.call(date, 'd', 1);
-			if ('m' in bits || 'b' in bits || 'B' in bits) handle.call(date, 'm', 1);
-			for (var key in bits) handle.call(date, key, bits[key]);
-			return date;
-var handle = function(key, value){
-	if (!value) return this;
-	switch(key){
-		case 'a': case 'A': return this.set('day', Date.parseDay(value, true));
-		case 'b': case 'B': return this.set('mo', Date.parseMonth(value, true));
-		case 'd': return this.set('date', value);
-		case 'H': case 'I': return this.set('hr', value);
-		case 'm': return this.set('mo', value - 1);
-		case 'M': return this.set('min', value);
-		case 'p': return this.set('ampm', value.replace(/\./g, ''));
-		case 'S': return this.set('sec', value);
-		case 's': return this.set('ms', ('0.' + value) * 1000);
-		case 'w': return this.set('day', value);
-		case 'Y': return this.set('year', value);
-		case 'y':
-			value = +value;
-			if (value < 100) value += startCentury + (value < startYear ? 100 : 0);
-			return this.set('year', value);
-		case 'T':
-			if (value == 'Z') value = '+00';
-			var offset = value.match(/([+-])(\d{2}):?(\d{2})?/);
-			offset = (offset[1] + '1') * (offset[2] * 60 + (+offset[3] || 0)) + this.getTimezoneOffset();
-			return this.set('time', this - offset * 60000);
-	return this;
-Date.defineParsers(
-	'%Y([-./]%m([-./]%d((T| )%X)?)?)?', // "1999-12-31", "1999-12-31 11:59pm", "1999-12-31 23:59:59", ISO8601
-	'%Y%m%d(T%H(%M%S?)?)?', // "19991231", "19991231T1159", compact
-	'%x( %X)?', // "12/31", "12.31.99", "12-31-1999", "12/31/2008 11:59 PM"
-	'%d%o( %b( %Y)?)?( %X)?', // "31st", "31st December", "31 Dec 1999", "31 Dec 1999 11:59pm"
-	'%b( %d%o)?( %Y)?( %X)?', // Same as above with month and day switched
-	'%Y %b( %d%o( %X)?)?', // Same as above with year coming first
-	'%o %b %d %X %T %Y' // "Thu Oct 22 08:11:23 +0000 2009"
-MooTools.lang.addEvent('langChange', function(language){
-	if (MooTools.lang.get('Date')) recompile(language);
-}).fireEvent('langChange', MooTools.lang.getCurrentLanguage());
-script: Date.Extras.js
-description: Extends the Date native object to include extra methods (on top of those in Date.js).
-authors:
- - Aaron Newton
- - Scott Kyle
-requires:
- - /Date
-provides: [Date.Extras]
-Date.implement({
-	timeDiffInWords: function(relative_to){
-		return Date.distanceOfTimeInWords(this, relative_to || new Date);
-	timeDiff: function(to, joiner){
-		if (to == null) to = new Date;
-		var delta = ((to - this) / 1000).toInt();
-		if (!delta) return '0s';
-		var durations = {s: 60, m: 60, h: 24, d: 365, y: 0};
-		var duration, vals = [];
-		for (var step in durations){
-			if (!delta) break;
-			if ((duration = durations[step])){
-				vals.unshift((delta % duration) + step);
-				delta = (delta / duration).toInt();
-			} else {
-				vals.unshift(delta + step);
-		return vals.join(joiner || ':');
-Date.alias('timeDiffInWords', 'timeAgoInWords');
-Date.extend({
-	distanceOfTimeInWords: function(from, to){
-		return Date.getTimePhrase(((to - from) / 1000).toInt());
-	getTimePhrase: function(delta){
-		var suffix = (delta < 0) ? 'Until' : 'Ago';
-		if (delta < 0) delta *= -1;
-		var units = {
-			minute: 60,
-			hour: 60,
-			day: 24,
-			week: 7,
-			month: 52 / 12,
-			year: 12,
-			eon: Infinity
-		var msg = 'lessThanMinute';
-		for (var unit in units){
-			var interval = units[unit];
-			if (delta < 1.5 * interval){
-				if (delta > 0.75 * interval) msg = unit;
-				break;
-			delta /= interval;
-			msg = unit + 's';
-		return Date.getMsg(msg + suffix).substitute({delta: delta.round()});
-		// "today", "tomorrow", "yesterday"
-		re: /^(?:tod|tom|yes)/i,
-			var d = new Date().clearTime();
-			switch(bits[0]){
-				case 'tom': return d.increment();
-				case 'yes': return d.decrement();
-				default: 	return d;
-		// "next Wednesday", "last Thursday"
-		re: /^(next|last) ([a-z]+)$/i,
-			var day = d.getDay();
-			var newDay = Date.parseDay(bits[2], true);
-			var addDays = newDay - day;
-			if (newDay <= day) addDays += 7;
-			if (bits[1] == 'last') addDays -= 7;
-			return d.set('date', d.getDate() + addDays);
-script: Hash.Extras.js
-description: Extends the Hash native object to include getFromPath which allows a path notation to child elements.
-authors:
- - Aaron Newton
-requires:
- - core:1.2.4/Hash.base
- - /MooTools.More
-provides: [Hash.Extras]
-Hash.implement({
-	getFromPath: function(notation){
-		var source = this.getClean();
-		notation.replace(/\[([^\]]+)\]|\.([^.[]+)|[^[.]+/g, function(match){
-			if (!source) return null;
-			var prop = arguments[2] || arguments[1] || arguments[0];
-			source = (prop in source) ? source[prop] : null;
-			return match;
-		return source;
-	cleanValues: function(method){
-		method = method || $defined;
-		this.each(function(v, k){
-			if (!method(v)) this.erase(k);
-		}, this);
-		return this;
-	run: function(){
-		var args = arguments;
-			if ($type(v) == 'function') v.run(args);
-script: String.Extras.js
-description: Extends the String native object to include methods useful in managing various kinds of strings (query strings, urls, html, etc).
-authors:
- - Aaron Newton
- - Guillermo Rauch
-requires:
- - core:1.2.4/$util
-provides: [String.Extras]
-(function(){
-var special = ['À','à','�?','á','Â','â','Ã','ã','Ä','ä','Å','å','Ă','ă','Ą','ą','Ć','ć','Č','�?','Ç','ç', 'Ď','�?','�?','đ', 'È','è','É','é','Ê','ê','Ë','ë','Ě','ě','Ę','ę', 'Ğ','ğ','Ì','ì','�?','í','Î','î','�?','ï', 'Ĺ','ĺ','Ľ','ľ','�?','ł', 'Ñ','ñ','Ň','ň','Ń','ń','Ò','ò','Ó','ó','Ô','ô','Õ','õ','Ö','ö','Ø','ø','ő','Ř','ř','Ŕ','ŕ','Š','š','Ş','ş','Ś','ś', 'Ť','ť','Ť','ť','Ţ','ţ','Ù','ù','Ú','ú','Û','û','Ü','ü','Ů','ů', 'Ÿ','ÿ','ý','�?','Ž','ž','Ź','ź','Ż','ż', 'Þ','þ','�?','ð','ß','Œ','œ','Æ','æ','µ'];
-var standard = ['A','a','A','a','A','a','A','a','Ae','ae','A','a','A','a','A','a','C','c','C','c','C','c','D','d','D','d', 'E','e','E','e','E','e','E','e','E','e','E','e','G','g','I','i','I','i','I','i','I','i','L','l','L','l','L','l', 'N','n','N','n','N','n', 'O','o','O','o','O','o','O','o','Oe','oe','O','o','o', 'R','r','R','r', 'S','s','S','s','S','s','T','t','T','t','T','t', 'U','u','U','u','U','u','Ue','ue','U','u','Y','y','Y','y','Z','z','Z','z','Z','z','TH','th','DH','dh','ss','OE','oe','AE','ae','u'];
-var tidymap = {
-	"[\xa0\u2002\u2003\u2009]": " ",
-	"\xb7": "*",
-	"[\u2018\u2019]": "'",
-	"[\u201c\u201d]": '"',
-	"\u2026": "...",
-	"\u2013": "-",
-	"\u2014": "--",
-	"\uFFFD": "&raquo;"
-var getRegForTag = function(tag, contents) {
-	tag = tag || '';
-	var regstr = contents ? "<" + tag + "[^>]*>([\\s\\S]*?)<\/" + tag + ">" : "<\/?" + tag + "([^>]+)?>";
-	reg = new RegExp(regstr, "gi");
-	return reg;
-String.implement({
-	standardize: function(){
-		var text = this;
-		special.each(function(ch, i){
-			text = text.replace(new RegExp(ch, 'g'), standard[i]);
-		return text;
-	repeat: function(times){
-		return new Array(times + 1).join(this);
-	pad: function(length, str, dir){
-		if (this.length >= length) return this;
-		var pad = (str == null ? ' ' : '' + str).repeat(length - this.length).substr(0, length - this.length);
-		if (!dir || dir == 'right') return this + pad;
-		if (dir == 'left') return pad + this;
-		return pad.substr(0, (pad.length / 2).floor()) + this + pad.substr(0, (pad.length / 2).ceil());
-	getTags: function(tag, contents){
-		return this.match(getRegForTag(tag, contents)) || [];
-	stripTags: function(tag, contents){
-		return this.replace(getRegForTag(tag, contents), '');
-	tidy: function(){
-		var txt = this.toString();
-		$each(tidymap, function(value, key){
-			txt = txt.replace(new RegExp(key, 'g'), value);
-		return txt;
-script: String.QueryString.js
-description: Methods for dealing with URI query strings.
-authors:
- - Sebastian Markbåge, Aaron Newton, Lennart Pilon, Valerio Proietti
-requires:
- - /MooTools.More
-provides: [String.QueryString]
-String.implement({
-	parseQueryString: function(){
-		var vars = this.split(/[&;]/), res = {};
-		if (vars.length) vars.each(function(val){
-			var index = val.indexOf('='),
-				keys = index < 0 ? [''] : val.substr(0, index).match(/[^\]\[]+/g),
-				value = decodeURIComponent(val.substr(index + 1)),
-				obj = res;
-			keys.each(function(key, i){
-				var current = obj[key];
-				if(i < keys.length - 1)
-					obj = obj[key] = current || {};
-				else if($type(current) == 'array')
-					current.push(value);
-				else
-					obj[key] = $defined(current) ? [current, value] : value;
-		return res;
-	cleanQueryString: function(method){
-		return this.split('&').filter(function(val){
-			key = index < 0 ? '' : val.substr(0, index),
-			value = val.substr(index + 1);
-			return method ? method.run([key, value]) : $chk(value);
-		}).join('&');
-script: URI.js
-description: Provides methods useful in managing the window location and uris.
-authors:
- - Sebastian Markb�ge
- - Aaron Newton
-requires:
- - core:1.2.4/Selectors
- - /String.QueryString
-provides: URI
-var URI = new Class({
-	options: {
-		/*base: false*/
-	regex: /^(?:(\w+):)?(?:\/\/(?:(?:([^:@\/]*):?([^:@\/]*))?@)?([^:\/?#]*)(?::(\d*))?)?(\.\.?$|(?:[^?#\/]*\/)*)([^?#]*)(?:\?([^#]*))?(?:#(.*))?/,
-	parts: ['scheme', 'user', 'password', 'host', 'port', 'directory', 'file', 'query', 'fragment'],
-	schemes: {http: 80, https: 443, ftp: 21, rtsp: 554, mms: 1755, file: 0},
-	initialize: function(uri, options){
-		var base = this.options.base || URI.base;
-		if(!uri) uri = base;
-		if (uri && uri.parsed) this.parsed = $unlink(uri.parsed);
-		else this.set('value', uri.href || uri.toString(), base ? new URI(base) : false);
-	parse: function(value, base){
-		var bits = value.match(this.regex);
-		if (!bits) return false;
-		bits.shift();
-		return this.merge(bits.associate(this.parts), base);
-	merge: function(bits, base){
-		if ((!bits || !bits.scheme) && (!base || !base.scheme)) return false;
-		if (base){
-			this.parts.every(function(part){
-				if (bits[part]) return false;
-				bits[part] = base[part] || '';
-				return true;
-		bits.port = bits.port || this.schemes[bits.scheme.toLowerCase()];
-		bits.directory = bits.directory ? this.parseDirectory(bits.directory, base ? base.directory : '') : '/';
-		return bits;
-	parseDirectory: function(directory, baseDirectory) {
-		directory = (directory.substr(0, 1) == '/' ? '' : (baseDirectory || '/')) + directory;
-		if (!directory.test(URI.regs.directoryDot)) return directory;
-		var result = [];
-		directory.replace(URI.regs.endSlash, '').split('/').each(function(dir){
-			if (dir == '..' && result.length > 0) result.pop();
-			else if (dir != '.') result.push(dir);
-		return result.join('/') + '/';
-	combine: function(bits){
-		return bits.value || bits.scheme + '://' +
-			(bits.user ? bits.user + (bits.password ? ':' + bits.password : '') + '@' : '') +
-			(bits.host || '') + (bits.port && bits.port != this.schemes[bits.scheme] ? ':' + bits.port : '') +
-			(bits.directory || '/') + (bits.file || '') +
-			(bits.query ? '?' + bits.query : '') +
-			(bits.fragment ? '#' + bits.fragment : '');
-	set: function(part, value, base){
-		if (part == 'value'){
-			var scheme = value.match(URI.regs.scheme);
-			if (scheme) scheme = scheme[1];
-			if (scheme && !$defined(this.schemes[scheme.toLowerCase()])) this.parsed = { scheme: scheme, value: value };
-			else this.parsed = this.parse(value, (base || this).parsed) || (scheme ? { scheme: scheme, value: value } : { value: value });
-		} else if (part == 'data') {
-			this.setData(value);
-		} else {
-			this.parsed[part] = value;
-		return this;
-	get: function(part, base){
-		switch(part){
-			case 'value': return this.combine(this.parsed, base ? base.parsed : false);
-			case 'data' : return this.getData();
-		return this.parsed[part] || '';
-	go: function(){
-		document.location.href = this.toString();
-	toURI: function(){
-		return this;
-	getData: function(key, part){
-		var qs = this.get(part || 'query');
-		if (!$chk(qs)) return key ? null : {};
-		var obj = qs.parseQueryString();
-		return key ? obj[key] : obj;
-	setData: function(values, merge, part){
-		if (typeof values == 'string'){
-			data = this.getData();
-			data[arguments[0]] = arguments[1];
-			values = data;
-		} else if (merge) {
-			values = $merge(this.getData(), values);
-		return this.set(part || 'query', Hash.toQueryString(values));
-	clearData: function(part){
-		return this.set(part || 'query', '');
-URI.prototype.toString = URI.prototype.valueOf = function(){
-	return this.get('value');
-URI.regs = {
-	endSlash: /\/$/,
-	scheme: /^(\w+):/,
-	directoryDot: /\.\/|\.$/
-URI.base = new URI(document.getElements('base[href]', true).getLast(), {base: document.location});
-String.implement({
-	toURI: function(options){
-		return new URI(this, options);
-script: URI.Relative.js
-description: Extends the URI class to add methods for computing relative and absolute urls.
-license: MIT-style license
-authors:
-requires:
- - /Class.refactor
- - /URI
-provides: [URI.Relative]
-URI = Class.refactor(URI, {
-	combine: function(bits, base){
-		if (!base || bits.scheme != base.scheme || bits.host != base.host || bits.port != base.port)
-			return this.previous.apply(this, arguments);
-		var end = bits.file + (bits.query ? '?' + bits.query : '') + (bits.fragment ? '#' + bits.fragment : '');
-		if (!base.directory) return (bits.directory || (bits.file ? '' : './')) + end;
-		var baseDir = base.directory.split('/'),
-			relDir = bits.directory.split('/'),
-			path = '',
-			offset;
-		var i = 0;
-		for(offset = 0; offset < baseDir.length && offset < relDir.length && baseDir[offset] == relDir[offset]; offset++);
-		for(i = 0; i < baseDir.length - offset - 1; i++) path += '../';
-		for(i = offset; i < relDir.length - 1; i++) path += relDir[i] + '/';
-		return (path || (bits.file ? '' : './')) + end;
-	toAbsolute: function(base){
-		base = new URI(base);
-		if (base) base.set('directory', '').set('file', '');
-		return this.toRelative(base);
-	toRelative: function(base){
-		return this.get('value', new URI(base));
-script: Element.Forms.js
-description: Extends the Element native object to include methods useful in managing inputs.
-authors:
- - Aaron Newton
-requires:
- - /MooTools.More
-provides: [Element.Forms]
-Element.implement({
-	tidy: function(){
-		this.set('value', this.get('value').tidy());
-	getTextInRange: function(start, end){
-		return this.get('value').substring(start, end);
-	getSelectedText: function(){
-		if (this.setSelectionRange) return this.getTextInRange(this.getSelectionStart(), this.getSelectionEnd());
-		return document.selection.createRange().text;
-	getSelectedRange: function() {
-		if ($defined(this.selectionStart)) return {start: this.selectionStart, end: this.selectionEnd};
-		var pos = {start: 0, end: 0};
-		var range = this.getDocument().selection.createRange();
-		if (!range || range.parentElement() != this) return pos;
-		var dup = range.duplicate();
-		if (this.type == 'text') {
-			pos.start = 0 - dup.moveStart('character', -100000);
-			pos.end = pos.start + range.text.length;
-		} else {
-			var value = this.get('value');
-			var offset = value.length;
-			dup.moveToElementText(this);
-			dup.setEndPoint('StartToEnd', range);
-			if(dup.text.length) offset -= value.match(/[\n\r]*$/)[0].length;
-			pos.end = offset - dup.text.length;
-			dup.setEndPoint('StartToStart', range);
-			pos.start = offset - dup.text.length;
-		return pos;
-	getSelectionStart: function(){
-		return this.getSelectedRange().start;
-	getSelectionEnd: function(){
-		return this.getSelectedRange().end;
-	setCaretPosition: function(pos){
-		if (pos == 'end') pos = this.get('value').length;
-		this.selectRange(pos, pos);
-		return this;
-	getCaretPosition: function(){
-	selectRange: function(start, end){
-		if (this.setSelectionRange) {
-			this.focus();
-			this.setSelectionRange(start, end);
-		} else {
-			var diff = value.substr(start, end - start).replace(/\r/g, '').length;
-			start = value.substr(0, start).replace(/\r/g, '').length;
-			var range = this.createTextRange();
-			range.collapse(true);
-			range.moveEnd('character', start + diff);
-			range.moveStart('character', start);
-			range.select();
-		return this;
-	insertAtCursor: function(value, select){
-		var pos = this.getSelectedRange();
-		var text = this.get('value');
-		this.set('value', text.substring(0, pos.start) + value + text.substring(pos.end, text.length));
-		if ($pick(select, true)) this.selectRange(pos.start, pos.start + value.length);
-		else this.setCaretPosition(pos.start + value.length);
-		return this;
-	insertAroundCursor: function(options, select){
-			before: '',
-			defaultMiddle: '',
-			after: ''
-		}, options);
-		var value = this.getSelectedText() || options.defaultMiddle;
-		if (pos.start == pos.end){
-			this.set('value', text.substring(0, pos.start) + options.before + value + options.after + text.substring(pos.end, text.length));
-			this.selectRange(pos.start + options.before.length, pos.end + options.before.length + value.length);
-		} else {
-			var current = text.substring(pos.start, pos.end);
-			this.set('value', text.substring(0, pos.start) + options.before + current + options.after + text.substring(pos.end, text.length));
-			var selStart = pos.start + options.before.length;
-			if ($pick(select, true)) this.selectRange(selStart, selStart + current.length);
-			else this.setCaretPosition(selStart + text.length);
-		return this;
-script: Elements.From.js
-description: Returns a collection of elements from a string of html.
-authors:
- - Aaron Newton
-requires:
- - /MooTools.More
-provides: [Elements.from]
-Elements.from = function(text, excludeScripts){
-	if ($pick(excludeScripts, true)) text = text.stripScripts();
-	var container, match = text.match(/^\s*<(t[dhr]|tbody|tfoot|thead)/i);
-	if (match){
-		container = new Element('table');
-		var tag = match[1].toLowerCase();
-		if (['td', 'th', 'tr'].contains(tag)){
-			container = new Element('tbody').inject(container);
-			if (tag != 'tr') container = new Element('tr').inject(container);
-	return (container || new Element('div')).set('html', text).getChildren();
-script: Element.Delegation.js
-description: Extends the Element native object to include the delegate method for more efficient event management.
-credits:
- - "Event checking based on the work of Daniel Steigerwald. License: MIT-style license.	Copyright: Copyright (c) 2008 Daniel Steigerwald, daniel.steigerwald.cz"
-authors:
- - Aaron Newton
- - Daniel Steigerwald
-requires:
- - /MooTools.More
-provides: [Element.Delegation]
-(function(addEvent, removeEvent){
-	var match = /(.*?):relay\(([^)]+)\)$/,
-		combinators = /[+>~\s]/,
-		splitType = function(type){
-			var bits = type.match(match);
-			return !bits ? {event: type} : {
-				event: bits[1],
-				selector: bits[2]
-		check = function(e, selector){
-			var t = e.target;
-			if (combinators.test(selector = selector.trim())){
-				var els = this.getElements(selector);
-				for (var i = els.length; i--; ){
-					var el = els[i];
-					if (t == el || el.hasChild(t)) return el;
-			} else {
-				for ( ; t && t != this; t = t.parentNode){
-					if (Element.match(t, selector)) return document.id(t);
-			return null;
-		addEvent: function(type, fn){
-			var splitted = splitType(type);
-			if (splitted.selector){
-				var monitors = this.retrieve('$moo:delegateMonitors', {});
-				if (!monitors[type]){
-					var monitor = function(e){
-						var el = check.call(this, e, splitted.selector);
-						if (el) this.fireEvent(type, [e, el], 0, el);
-					}.bind(this);
-					monitors[type] = monitor;
-					addEvent.call(this, splitted.event, monitor);
-			return addEvent.apply(this, arguments);
-		removeEvent: function(type, fn){
-				var events = this.retrieve('events');
-				if (!events || !events[type] || (fn && !events[type].keys.contains(fn))) return this;
-				if (fn) removeEvent.apply(this, [type, fn]);
-				else removeEvent.apply(this, type);
-				events = this.retrieve('events');
-				if (events && events[type] && events[type].keys.length == 0){
-					removeEvent.apply(this, [splitted.event, monitors[type]]);
-					delete monitors[type];
-				return this;
-			return removeEvent.apply(this, arguments);
-		fireEvent: function(type, args, delay, bind){
-			if (!events || !events[type]) return this;
-			events[type].keys.each(function(fn){
-				fn.create({bind: bind || this, delay: delay, arguments: args})();
-			}, this);
-			return this;
-})(Element.prototype.addEvent, Element.prototype.removeEvent);/*
-script: Element.Measure.js
-description: Extends the Element native object to include methods useful in measuring dimensions.
-credits: "Element.measure / .expose methods by Daniel Steigerwald License: MIT-style license. Copyright: Copyright (c) 2008 Daniel Steigerwald, daniel.steigerwald.cz"
-authors:
- - Aaron Newton
-requires:
- - core:1.2.4/Element.Style
- - core:1.2.4/Element.Dimensions
- - /MooTools.More
-provides: [Element.Measure]
-	measure: function(fn){
-		var vis = function(el) {
-			return !!(!el || el.offsetHeight || el.offsetWidth);
-		if (vis(this)) return fn.apply(this);
-		var parent = this.getParent(),
-			restorers = [],
-			toMeasure = [];
-		while (!vis(parent) && parent != document.body) {
-			toMeasure.push(parent.expose());
-			parent = parent.getParent();
-		var restore = this.expose();
-		var result = fn.apply(this);
-		restore();
-		toMeasure.each(function(restore){
-			restore();
-		return result;
-	expose: function(){
-		if (this.getStyle('display') != 'none') return $empty;
-		var before = this.style.cssText;
-		this.setStyles({
-			display: 'block',
-			position: 'absolute',
-			visibility: 'hidden'
-		return function(){
-			this.style.cssText = before;
-		}.bind(this);
-	getDimensions: function(options){
-		options = $merge({computeSize: false},options);
-		var dim = {};
-		var getSize = function(el, options){
-			return (options.computeSize)?el.getComputedSize(options):el.getSize();
-		var parent = this.getParent('body');
-		if (parent && this.getStyle('display') == 'none'){
-			dim = this.measure(function(){
-				return getSize(this, options);
-		} else if (parent){
-			try { //safari sometimes crashes here, so catch it
-				dim = getSize(this, options);
-			}catch(e){}
-		} else {
-			dim = {x: 0, y: 0};
-		return $chk(dim.x) ? $extend(dim, {width: dim.x, height: dim.y}) : $extend(dim, {x: dim.width, y: dim.height});
-	getComputedSize: function(options){
-			styles: ['padding','border'],
-			plains: {
-				height: ['top','bottom'],
-				width: ['left','right']
-			mode: 'both'
-		}, options);
-		var size = {width: 0,height: 0};
-		switch (options.mode){
-			case 'vertical':
-				delete size.width;
-				delete options.plains.width;
-				break;
-			case 'horizontal':
-				delete size.height;
-				delete options.plains.height;
-				break;
-		var getStyles = [];
-		//this function might be useful in other places; perhaps it should be outside this function?
-		$each(options.plains, function(plain, key){
-			plain.each(function(edge){
-				options.styles.each(function(style){
-					getStyles.push((style == 'border') ? style + '-' + edge + '-' + 'width' : style + '-' + edge);
-		var styles = {};
-		getStyles.each(function(style){ styles[style] = this.getComputedStyle(style); }, this);
-		var subtracted = [];
-		$each(options.plains, function(plain, key){ //keys: width, height, plains: ['left', 'right'], ['top','bottom']
-			var capitalized = key.capitalize();
-			size['total' + capitalized] = size['computed' + capitalized] = 0;
-			plain.each(function(edge){ //top, left, right, bottom
-				size['computed' + edge.capitalize()] = 0;
-				getStyles.each(function(style, i){ //padding, border, etc.
-					//'padding-left'.test('left') size['totalWidth'] = size['width'] + [padding-left]
-					if (style.test(edge)){
-						styles[style] = styles[style].toInt() || 0; //styles['padding-left'] = 5;
-						size['total' + capitalized] = size['total' + capitalized] + styles[style];
-						size['computed' + edge.capitalize()] = size['computed' + edge.capitalize()] + styles[style];
-					//if width != width (so, padding-left, for instance), then subtract that from the total
-					if (style.test(edge) && key != style &&
-						(style.test('border') || style.test('padding')) && !subtracted.contains(style)){
-						subtracted.push(style);
-						size['computed' + capitalized] = size['computed' + capitalized]-styles[style];
-		['Width', 'Height'].each(function(value){
-			var lower = value.toLowerCase();
-			if(!$chk(size[lower])) return;
-			size[lower] = size[lower] + this['offset' + value] + size['computed' + value];
-			size['total' + value] = size[lower] + size['total' + value];
-			delete size['computed' + value];
-		}, this);
-		return $extend(styles, size);
-script: Element.Pin.js
-description: Extends the Element native object to include the pin method useful for fixed positioning for elements.
-authors:
- - Aaron Newton
-requires:
- - /MooTools.More
-provides: [Element.Pin]
-(function(){
-	var supportsPositionFixed = false;
-	window.addEvent('domready', function(){
-		var test = new Element('div').setStyles({
-			position: 'fixed',
-			top: 0,
-			right: 0
-		}).inject(document.body);
-		supportsPositionFixed = (test.offsetTop === 0);
-		test.dispose();
-		pin: function(enable){
-			if (this.getStyle('display') == 'none') return null;
-			var p,
-					scroll = window.getScroll();
-			if (enable !== false){
-				p = this.getPosition();
-				if (!this.retrieve('pinned')){
-					var pos = {
-						top: p.y - scroll.y,
-						left: p.x - scroll.x
-					if (supportsPositionFixed){
-						this.setStyle('position', 'fixed').setStyles(pos);
-					} else {
-						this.store('pinnedByJS', true);
-						this.setStyles({
-							top: p.y,
-							left: p.x
-						}).addClass('isPinned');
-						this.store('scrollFixer', (function(){
-							if (this.retrieve('pinned'))
-								var scroll = window.getScroll();
-								this.setStyles({
-									top: pos.top.toInt() + scroll.y,
-									left: pos.left.toInt() + scroll.x
-						}).bind(this));
-						window.addEvent('scroll', this.retrieve('scrollFixer'));
-					this.store('pinned', true);
-			} else {
-				var op;
-				if (!Browser.Engine.trident){
-					var parent = this.getParent();
-					op = (parent.getComputedStyle('position') != 'static' ? parent : parent.getOffsetParent());
-				p = this.getPosition(op);
-				this.store('pinned', false);
-				var reposition;
-				if (supportsPositionFixed && !this.retrieve('pinnedByJS')){
-					reposition = {
-						top: p.y + scroll.y,
-						left: p.x + scroll.x
-				} else {
-					this.store('pinnedByJS', false);
-					window.removeEvent('scroll', this.retrieve('scrollFixer'));
-					reposition = {
-						top: p.y,
-						left: p.x
-				this.setStyles($merge(reposition, {position: 'absolute'})).removeClass('isPinned');
-			return this;
-		unpin: function(){
-			return this.pin(false);
-		togglepin: function(){
-			this.pin(!this.retrieve('pinned'));
-script: Element.Position.js
-description: Extends the Element native object to include methods useful positioning elements relative to others.
-authors:
- - Aaron Newton
-requires:
- - /Element.Measure
-provides: [Elements.Position]
-(function(){
-var original = Element.prototype.position;
-	position: function(options){
-		//call original position if the options are x/y values
-		if (options && ($defined(options.x) || $defined(options.y))) return original ? original.apply(this, arguments) : this;
-		$each(options||{}, function(v, k){ if (!$defined(v)) delete options[k]; });
-			// minimum: { x: 0, y: 0 },
-			// maximum: { x: 0, y: 0},
-			relativeTo: document.body,
-			position: {
-				x: 'center', //left, center, right
-				y: 'center' //top, center, bottom
-			edge: false,
-			offset: {x: 0, y: 0},
-			returnPos: false,
-			relFixedPosition: false,
-			ignoreMargins: false,
-			ignoreScroll: false,
-			allowNegative: false
-		}, options);
-		//compute the offset of the parent positioned element if this element is in one
-		var parentOffset = {x: 0, y: 0},
-				parentPositioned = false;
-		/* dollar around getOffsetParent should not be necessary, but as it does not return
-		 * a mootools extended element in IE, an error occurs on the call to expose. See:
-		 * http://mootools.lighthouseapp.com/projects/2706/tickets/333-element-getoffsetparent-inconsistency-between-ie-and-other-browsers */
-		var offsetParent = this.measure(function(){
-			return document.id(this.getOffsetParent());
-		if (offsetParent && offsetParent != this.getDocument().body){
-			parentOffset = offsetParent.measure(function(){
-				return this.getPosition();
-			parentPositioned = offsetParent != document.id(options.relativeTo);
-			options.offset.x = options.offset.x - parentOffset.x;
-			options.offset.y = options.offset.y - parentOffset.y;
-		//upperRight, bottomRight, centerRight, upperLeft, bottomLeft, centerLeft
-		//topRight, topLeft, centerTop, centerBottom, center
-		var fixValue = function(option){
-			if ($type(option) != 'string') return option;
-			option = option.toLowerCase();
-			var val = {};
-			if (option.test('left')) val.x = 'left';
-			else if (option.test('right')) val.x = 'right';
-			else val.x = 'center';
-			if (option.test('upper') || option.test('top')) val.y = 'top';
-			else if (option.test('bottom')) val.y = 'bottom';
-			else val.y = 'center';
-			return val;
-		options.edge = fixValue(options.edge);
-		options.position = fixValue(options.position);
-		if (!options.edge){
-			if (options.position.x == 'center' && options.position.y == 'center') options.edge = {x:'center', y:'center'};
-			else options.edge = {x:'left', y:'top'};
-		this.setStyle('position', 'absolute');
-		var rel = document.id(options.relativeTo) || document.body,
-				calc = rel == document.body ? window.getScroll() : rel.getPosition(),
-				top = calc.y, left = calc.x;
-		var dim = this.getDimensions({computeSize: true, styles:['padding', 'border','margin']});
-		var pos = {},
-				prefY = options.offset.y,
-				prefX = options.offset.x,
-				winSize = window.getSize();
-		switch(options.position.x){
-			case 'left':
-				pos.x = left + prefX;
-				break;
-			case 'right':
-				pos.x = left + prefX + rel.offsetWidth;
-				break;
-			default: //center
-				pos.x = left + ((rel == document.body ? winSize.x : rel.offsetWidth)/2) + prefX;
-				break;
-		switch(options.position.y){
-			case 'top':
-				pos.y = top + prefY;
-				break;
-			case 'bottom':
-				pos.y = top + prefY + rel.offsetHeight;
-				break;
-			default: //center
-				pos.y = top + ((rel == document.body ? winSize.y : rel.offsetHeight)/2) + prefY;
-				break;
-		if (options.edge){
-			var edgeOffset = {};
-			switch(options.edge.x){
-				case 'left':
-					edgeOffset.x = 0;
-					break;
-				case 'right':
-					edgeOffset.x = -dim.x-dim.computedRight-dim.computedLeft;
-					break;
-				default: //center
-					edgeOffset.x = -(dim.totalWidth/2);
-					break;
-			switch(options.edge.y){
-				case 'top':
-					edgeOffset.y = 0;
-					break;
-				case 'bottom':
-					edgeOffset.y = -dim.y-dim.computedTop-dim.computedBottom;
-					break;
-				default: //center
-					edgeOffset.y = -(dim.totalHeight/2);
-					break;
-			pos.x += edgeOffset.x;
-			pos.y += edgeOffset.y;
-		pos = {
-			left: ((pos.x >= 0 || parentPositioned || options.allowNegative) ? pos.x : 0).toInt(),
-			top: ((pos.y >= 0 || parentPositioned || options.allowNegative) ? pos.y : 0).toInt()
-		var xy = {left: 'x', top: 'y'};
-		['minimum', 'maximum'].each(function(minmax) {
-			['left', 'top'].each(function(lr) {
-				var val = options[minmax] ? options[minmax][xy[lr]] : null;
-				if (val != null && pos[lr] < val) pos[lr] = val;
-		if (rel.getStyle('position') == 'fixed' || options.relFixedPosition){
-			var winScroll = window.getScroll();
-			pos.top+= winScroll.y;
-			pos.left+= winScroll.x;
-		if (options.ignoreScroll) {
-			var relScroll = rel.getScroll();
-			pos.top-= relScroll.y;
-			pos.left-= relScroll.x;
-		if (options.ignoreMargins) {
-			pos.left += (
-				options.edge.x == 'right' ? dim['margin-right'] :
-				options.edge.x == 'center' ? -dim['margin-left'] + ((dim['margin-right'] + dim['margin-left'])/2) :
-					- dim['margin-left']
-			pos.top += (
-				options.edge.y == 'bottom' ? dim['margin-bottom'] :
-				options.edge.y == 'center' ? -dim['margin-top'] + ((dim['margin-bottom'] + dim['margin-top'])/2) :
-					- dim['margin-top']
-		pos.left = Math.ceil(pos.left);
-		pos.top = Math.ceil(pos.top);
-		if (options.returnPos) return pos;
-		else this.setStyles(pos);
-		return this;
-script: Element.Shortcuts.js
-description: Extends the Element native object to include some shortcut methods.
-authors:
- - Aaron Newton
-requires:
- - /MooTools.More
-provides: [Element.Shortcuts]
-	isDisplayed: function(){
-		return this.getStyle('display') != 'none';
-	isVisible: function(){
-		var w = this.offsetWidth,
-			h = this.offsetHeight;
-		return (w == 0 && h == 0) ? false : (w > 0 && h > 0) ? true : this.isDisplayed();
-	toggle: function(){
-		return this[this.isDisplayed() ? 'hide' : 'show']();
-	hide: function(){
-		var d;
-		try {
-			//IE fails here if the element is not in the dom
-			d = this.getStyle('display');
-		} catch(e){}
-		return this.store('originalDisplay', d || '').setStyle('display', 'none');
-	show: function(display){
-		display = display || this.retrieve('originalDisplay') || 'block';
-		return this.setStyle('display', (display == 'none') ? 'block' : display);
-	swapClass: function(remove, add){
-		return this.removeClass(remove).addClass(add);
-script: IframeShim.js
-description: Defines IframeShim, a class for obscuring select lists and flash objects in IE.
-authors:
- - Aaron Newton
-requires:
- - core:1.2.4/Options Events
- - /Element.Position
- - /Class.Occlude
-provides: [IframeShim]
-var IframeShim = new Class({
-	Implements: [Options, Events, Class.Occlude],
-	options: {
-		className: 'iframeShim',
-		src: 'javascript:false;document.write("");',
-		display: false,
-		zIndex: null,
-		margin: 0,
-		browsers: (Browser.Engine.trident4 || (Browser.Engine.gecko && !Browser.Engine.gecko19 && Browser.Platform.mac))
-	property: 'IframeShim',
-	initialize: function(element, options){
-		this.element = document.id(element);
-		if (this.occlude()) return this.occluded;
-		this.setOptions(options);
-		this.makeShim();
-		return this;
-	makeShim: function(){
-		if(this.options.browsers){
-			var zIndex = this.element.getStyle('zIndex').toInt();
-			if (!zIndex){
-				zIndex = 1;
-				var pos = this.element.getStyle('position');
-				if (pos == 'static' || !pos) this.element.setStyle('position', 'relative');
-				this.element.setStyle('zIndex', zIndex);
-			zIndex = ($chk(this.options.zIndex) && zIndex > this.options.zIndex) ? this.options.zIndex : zIndex - 1;
-			if (zIndex < 0) zIndex = 1;
-			this.shim = new Element('iframe', {
-				src: this.options.src,
-				scrolling: 'no',
-				frameborder: 0,
-				styles: {
-					zIndex: zIndex,
-					border: 'none',
-					filter: 'progid:DXImageTransform.Microsoft.Alpha(style=0,opacity=0)'
-				'class': this.options.className
-			}).store('IframeShim', this);
-			var inject = (function(){
-				this.shim.inject(this.element, 'after');
-				this[this.options.display ? 'show' : 'hide']();
-				this.fireEvent('inject');
-			}).bind(this);
-			if (!IframeShim.ready) window.addEvent('load', inject);
-			else inject();
-		} else {
-			this.position = this.hide = this.show = this.dispose = $lambda(this);
-	position: function(){
-		if (!IframeShim.ready || !this.shim) return this;
-		var size = this.element.measure(function(){
-			return this.getSize();
-		if (this.options.margin != undefined){
-			size.x = size.x - (this.options.margin * 2);
-			size.y = size.y - (this.options.margin * 2);
-			this.options.offset.x += this.options.margin;
-			this.options.offset.y += this.options.margin;
-		this.shim.set({width: size.x, height: size.y}).position({
-			relativeTo: this.element,
-			offset: this.options.offset
-		return this;
-	hide: function(){
-		if (this.shim) this.shim.setStyle('display', 'none');
-		return this;
-	show: function(){
-		if (this.shim) this.shim.setStyle('display', 'block');
-		return this.position();
-	dispose: function(){
-		if (this.shim) this.shim.dispose();
-		return this;
-	destroy: function(){
-		if (this.shim) this.shim.destroy();
-		return this;
-window.addEvent('load', function(){
-	IframeShim.ready = true;
-script: Mask.js
-description: Creates a mask element to cover another.
-authors:
- - Aaron Newton
-requires:
- - core:1.2.4/Events
- - /Class.Binds
- - /IframeShim
-provides: [Mask]
-var Mask = new Class({
-	Implements: [Options, Events],
-	Binds: ['position'],
-	options: {
-		// onShow: $empty,
-		// onHide: $empty,
-		// onDestroy: $empty,
-		// onClick: $empty,
-		//inject: {
-		//  where: 'after',
-		//  target: null,
-		// hideOnClick: false,
-		// id: null,
-		// destroyOnHide: false,
-		style: {},
-		'class': 'mask',
-		maskMargins: false,
-		useIframeShim: true,
-		iframeShimOptions: {}
-	initialize: function(target, options){
-		this.target = document.id(target) || document.id(document.body);
-		this.target.store('Mask', this);
-		this.render();
-		this.inject();
-	render: function() {
-		this.element = new Element('div', {
-			'class': this.options['class'],
-			id: this.options.id || 'mask-' + $time(),
-			styles: $merge(this.options.style, {
-				display: 'none'
-			events: {
-				click: function(){
-					this.fireEvent('click');
-					if (this.options.hideOnClick) this.hide();
-				}.bind(this)
-		this.hidden = true;
-	toElement: function(){
-		return this.element;
-	inject: function(target, where){
-		where = where || this.options.inject ? this.options.inject.where : '' || this.target == document.body ? 'inside' : 'after';
-		target = target || this.options.inject ? this.options.inject.target : '' || this.target;
-		this.element.inject(target, where);
-		if (this.options.useIframeShim) {
-			this.shim = new IframeShim(this.element, this.options.iframeShimOptions);
-			this.addEvents({
-				show: this.shim.show.bind(this.shim),
-				hide: this.shim.hide.bind(this.shim),
-				destroy: this.shim.destroy.bind(this.shim)
-		this.resize(this.options.width, this.options.height);
-		this.element.position({
-			relativeTo: this.target,
-			position: 'topLeft',
-			ignoreMargins: !this.options.maskMargins,
-			ignoreScroll: this.target == document.body
-		return this;
-	resize: function(x, y){
-		var opt = {
-			styles: ['padding', 'border']
-		if (this.options.maskMargins) opt.styles.push('margin');
-		var dim = this.target.getComputedSize(opt);
-		if (this.target == document.body) {
-			var win = window.getSize();
-			if (dim.totalHeight < win.y) dim.totalHeight = win.y;
-			if (dim.totalWidth < win.x) dim.totalWidth = win.x;
-		this.element.setStyles({
-			width: $pick(x, dim.totalWidth, dim.x),
-			height: $pick(y, dim.totalHeight, dim.y)
-		return this;
-	show: function(){
-		if (!this.hidden) return this;
-		window.addEvent('resize', this.position);
-		this.position();
-		this.showMask.apply(this, arguments);
-		return this;
-	showMask: function(){
-		this.element.setStyle('display', 'block');
-		this.hidden = false;
-		this.fireEvent('show');
-	hide: function(){
-		if (this.hidden) return this;
-		window.removeEvent('resize', this.position);
-		this.hideMask.apply(this, arguments);
-		if (this.options.destroyOnHide) return this.destroy();
-		return this;
-	hideMask: function(){
-		this.element.setStyle('display', 'none');
-		this.fireEvent('hide');
-		this[this.hidden ? 'show' : 'hide']();
-		this.hide();
-		this.element.destroy();
-		this.fireEvent('destroy');
-		this.target.eliminate('mask');
-Element.Properties.mask = {
-	set: function(options){
-		var mask = this.retrieve('mask');
-		return this.eliminate('mask').store('mask:options', options);
-	get: function(options){
-		if (options || !this.retrieve('mask')){
-			if (this.retrieve('mask')) this.retrieve('mask').destroy();
-			if (options || !this.retrieve('mask:options')) this.set('mask', options);
-			this.store('mask', new Mask(this, this.retrieve('mask:options')));
-		return this.retrieve('mask');
-	mask: function(options){
-		this.get('mask', options).show();
-		return this;
-	unmask: function(){
-		this.get('mask').hide();
-		return this;
-script: Spinner.js
-description: Adds a semi-transparent overlay over a dom element with a spinnin ajax icon.
-authors:
- - Aaron Newton
-requires:
- - core:1.2.4/Fx.Tween
- - /Class.refactor
- - /Mask
-provides: [Spinner]
-var Spinner = new Class({
-	Extends: Mask,
-	options: {
-		/*message: false,*/
-		'class':'spinner',
-		containerPosition: {},
-		content: {
-			'class':'spinner-content'
-		messageContainer: {
-			'class':'spinner-msg'
-		img: {
-			'class':'spinner-img'
-		fxOptions: {
-			link: 'chain'
-	initialize: function(){
-		this.parent.apply(this, arguments);
-		this.target.store('spinner', this);
-		//add this to events for when noFx is true; parent methods handle hide/show
-		var deactivate = function(){ this.active = false; }.bind(this);
-		this.addEvents({
-			hide: deactivate,
-			show: deactivate
-	render: function(){
-		this.parent();
-		this.element.set('id', this.options.id || 'spinner-'+$time());
-		this.content = document.id(this.options.content) || new Element('div', this.options.content);
-		this.content.inject(this.element);
-		if (this.options.message) {
-			this.msg = document.id(this.options.message) || new Element('p', this.options.messageContainer).appendText(this.options.message);
-			this.msg.inject(this.content);
-		if (this.options.img) {
-			this.img = document.id(this.options.img) || new Element('div', this.options.img);
-			this.img.inject(this.content);
-		this.element.set('tween', this.options.fxOptions);
-	show: function(noFx){
-		if (this.active) return this.chain(this.show.bind(this));
-		if (!this.hidden) {
-			this.callChain.delay(20, this);
-			return this;
-		this.active = true;
-		return this.parent(noFx);
-	showMask: function(noFx){
-		var pos = function(){
-			this.content.position($merge({
-			}, this.options.containerPosition));
-		}.bind(this);
-		if (noFx) {
-			this.parent();
-			pos();
-		} else {
-				display: 'block',
-				opacity: 0
-			}).tween('opacity', this.options.style.opacity || 0.9);
-			pos();
-			this.callChain();
-	hide: function(noFx){
-		if (this.active) return this.chain(this.hide.bind(this));
-		if (this.hidden) {
-			return this;
-	hideMask: function(noFx){
-		if (noFx) return this.parent();
-		this.element.tween('opacity', 0).get('tween').chain(function(){
-			this.callChain();
-		}.bind(this));
-		this.content.destroy();
-		this.parent();
-		this.target.eliminate('spinner');
-Spinner.implement(new Chain);
-if (window.Request) {
-	Request = Class.refactor(Request, {
-		options: {
-			useSpinner: false,
-			spinnerOptions: {},
-			spinnerTarget: false
-		initialize: function(options){
-			this._send = this.send;
-			this.send = function(options){
-				if (this.spinner) this.spinner.chain(this._send.bind(this, options)).show();
-				else this._send(options);
-				return this;
-			this.previous(options);
-			var update = document.id(this.options.spinnerTarget) || document.id(this.options.update);
-			if (this.options.useSpinner && update) {
-				this.spinner = update.get('spinner', this.options.spinnerOptions);
-				['onComplete', 'onException', 'onCancel'].each(function(event){
-					this.addEvent(event, this.spinner.hide.bind(this.spinner));
-				}, this);
-		getSpinner: function(){
-			return this.spinner;
-Element.Properties.spinner = {
-		var spinner = this.retrieve('spinner');
-		return this.eliminate('spinner').store('spinner:options', options);
-		if (options || !this.retrieve('spinner')){
-			if (this.retrieve('spinner')) this.retrieve('spinner').destroy();
-			if (options || !this.retrieve('spinner:options')) this.set('spinner', options);
-			new Spinner(this, this.retrieve('spinner:options'));
-		return this.retrieve('spinner');
-	spin: function(options){
-		this.get('spinner', options).show();
-		return this;
-	unspin: function(){
-		var opt = Array.link(arguments, {options: Object.type, callback: Function.type});
-		this.get('spinner', opt.options).hide(opt.callback);
-		return this;
-script: Form.Request.js
-description: Handles the basic functionality of submitting a form and updating a dom element with the result.
-authors:
- - Aaron Newton
-requires:
- - core:1.2.4/Element.Event
- - core:1.2.4/Request.HTML
- - /Class.Binds
- - /Class.Occlude
- - /Spinner
-provides: [Form.Request]
-if (!window.Form) window.Form = {};
-(function(){
-	Form.Request = new Class({
-		Binds: ['onSubmit', 'onFormValidate'],
-		options: {
-			//onFailure: $empty,
-			//onSuccess: #empty, //aliased to onComplete,
-			//onSend: $empty
-			requestOptions: {
-				evalScripts: true,
-				useSpinner: true,
-				emulation: false,
-				link: 'ignore'
-			extraData: {},
-			resetForm: true
-		property: 'form.request',
-		initialize: function(form, update, options) {
-			this.element = document.id(form);
-			this.update = document.id(update);
-			this.makeRequest();
-			if (this.options.resetForm) {
-				this.request.addEvent('success', function(){
-					$try(function(){ this.element.reset(); }.bind(this));
-					if (window.OverText) OverText.update();
-				}.bind(this));
-			this.attach();
-		toElement: function() {
-		makeRequest: function(){
-			this.request = new Request.HTML($merge({
-					update: this.update,
-					emulation: false,
-					spinnerTarget: this.element,
-					method: this.element.get('method') || 'post'
-			}, this.options.requestOptions)).addEvents({
-				success: function(text, xml){
-					['complete', 'success'].each(function(evt){
-						this.fireEvent(evt, [this.update, text, xml]);
-					}, this);
-				}.bind(this),
-				failure: function(xhr){
-					this.fireEvent('complete').fireEvent('failure', xhr);
-				}.bind(this),
-				exception: function(){
-					this.fireEvent('failure', xhr);
-				}.bind(this)
-		attach: function(attach){
-			attach = $pick(attach, true);
-			method = attach ? 'addEvent' : 'removeEvent';
-			var fv = this.element.retrieve('validator');
-			if (fv) fv[method]('onFormValidate', this.onFormValidate);
-			if (!fv || !attach) this.element[method]('submit', this.onSubmit);
-		detach: function(){
-			this.attach(false);
-		//public method
-		enable: function(){
-			this.attach();
-		//public method
-		disable: function(){
-			this.detach();
-		onFormValidate: function(valid, form, e) {
-			if (valid || (fv && !fv.options.stopOnFailure)) {
-				if (e && e.stop) e.stop();
-				this.send();
-		onSubmit: function(e){
-			if (this.element.retrieve('validator')) {
-				//form validator was created after Form.Request
-				this.detach();
-				return;
-			e.stop();
-			this.send();
-		send: function(){
-			var str = this.element.toQueryString().trim();
-			var data = $H(this.options.extraData).toQueryString();
-			if (str) str += "&" + data;
-			else str = data;
-			this.fireEvent('send', [this.element, str.parseQueryString()]);
-			this.request.send({data: str, url: this.element.get("action")});
-			return this;
-	Element.Properties.formRequest = {
-		set: function(){
-			var opt = Array.link(arguments, {options: Object.type, update: Element.type, updateId: String.type});
-			var update = opt.update || opt.updateId;
-			var updater = this.retrieve('form.request');
-			if (update) {
-				if (updater) updater.update = document.id(update);
-				this.store('form.request:update', update);
-			if (opt.options) {
-				if (updater) updater.setOptions(opt.options);
-				this.store('form.request:options', opt.options);
-			return this;
-		get: function(){
-			if (opt.options || update || !this.retrieve('form.request')){
-				if (opt.options || !this.retrieve('form.request:options')) this.set('form.request', opt.options);
-				if (update) this.set('form.request', update);
-				this.store('form.request', new Form.Request(this, this.retrieve('form.request:update'), this.retrieve('form.request:options')));
-			return this.retrieve('form.request');
-		formUpdate: function(update, options){
-			this.get('form.request', update, options).send();
-			return this;
-script: Fx.Reveal.js
-description: Defines Fx.Reveal, a class that shows and hides elements with a transition.
-authors:
- - Aaron Newton
-requires:
- - core:1.2.4/Fx.Morph
- - /Element.Shortcuts
-provides: [Fx.Reveal]
-Fx.Reveal = new Class({
-	Extends: Fx.Morph,
-	options: {/*
-		onShow: $empty(thisElement),
-		onHide: $empty(thisElement),
-		onComplete: $empty(thisElement),
-		heightOverride: null,
-		widthOverride: null, */
-		link: 'cancel',
-		styles: ['padding', 'border', 'margin'],
-		transitionOpacity: !Browser.Engine.trident4,
-		mode: 'vertical',
-		display: 'block',
-		hideInputs: Browser.Engine.trident ? 'select, input, textarea, object, embed' : false
-	dissolve: function(){
-		try {
-			if (!this.hiding && !this.showing){
-				if (this.element.getStyle('display') != 'none'){
-					this.hiding = true;
-					this.showing = false;
-					this.cssText = this.element.style.cssText;
-					var startStyles = this.element.getComputedSize({
-						styles: this.options.styles,
-						mode: this.options.mode
-					this.element.setStyle('display', this.options.display);
-					if (this.options.transitionOpacity) startStyles.opacity = 1;
-					var zero = {};
-					$each(startStyles, function(style, name){
-						zero[name] = [style, 0];
-					}, this);
-					this.element.setStyle('overflow', 'hidden');
-					var hideThese = this.options.hideInputs ? this.element.getElements(this.options.hideInputs) : null;
-					this.$chain.unshift(function(){
-						if (this.hidden){
-							this.hiding = false;
-								startStyles[name] = style;
-							}, this);
-							this.element.style.cssText = this.cssText;
-							if (hideThese) hideThese.setStyle('visibility', 'visible');
-						this.fireEvent('hide', this.element);
-						this.callChain();
-					}.bind(this));
-					if (hideThese) hideThese.setStyle('visibility', 'hidden');
-					this.start(zero);
-				} else {
-					this.callChain.delay(10, this);
-					this.fireEvent('complete', this.element);
-			} else if (this.options.link == 'chain'){
-				this.chain(this.dissolve.bind(this));
-			} else if (this.options.link == 'cancel' && !this.hiding){
-				this.cancel();
-				this.dissolve();
-		} catch(e){
-		return this;
-	reveal: function(){
-		try {
-			if (!this.showing && !this.hiding){
-				if (this.element.getStyle('display') == 'none' ||
-					 this.element.getStyle('visiblity') == 'hidden' ||
-					 this.element.getStyle('opacity') == 0){
-					this.showing = true;
-					this.hiding = this.hidden =  false;
-					var startStyles;
-					//toggle display, but hide it
-					this.element.measure(function(){
-						//create the styles for the opened/visible state
-						startStyles = this.element.getComputedSize({
-					}.bind(this));
-					//if we're overridding height/width
-					if ($chk(this.options.heightOverride)) startStyles.height = this.options.heightOverride.toInt();
-					if ($chk(this.options.widthOverride)) startStyles.width = this.options.widthOverride.toInt();
-					if (this.options.transitionOpacity) {
-						this.element.setStyle('opacity', 0);
-						startStyles.opacity = 1;
-					//create the zero state for the beginning of the transition
-					var zero = {
-						height: 0,
-						display: this.options.display
-					$each(startStyles, function(style, name){ zero[name] = 0; });
-					//set to zero
-					this.element.setStyles($merge(zero, {overflow: 'hidden'}));
-					//hide inputs
-					//start the effect
-					this.start(startStyles);
-						if (!this.hidden) this.showing = false;
-						this.callChain();
-						this.fireEvent('show', this.element);
-					}.bind(this));
-				} else {
-					this.callChain();
-				this.chain(this.reveal.bind(this));
-			} else if (this.options.link == 'cancel' && !this.showing){
-				this.cancel();
-				this.reveal();
-		} catch(e){
-				display: this.options.display,
-				visiblity: 'visible',
-				opacity: 1
-		return this;
-			this.reveal();
-		} else {
-			this.dissolve();
-		return this;
-	cancel: function(){
-		this.hidding = false;
-Element.Properties.reveal = {
-		var reveal = this.retrieve('reveal');
-		if (reveal) reveal.cancel();
-		return this.eliminate('reveal').store('reveal:options', options);
-		if (options || !this.retrieve('reveal')){
-			if (options || !this.retrieve('reveal:options')) this.set('reveal', options);
-			this.store('reveal', new Fx.Reveal(this, this.retrieve('reveal:options')));
-		return this.retrieve('reveal');
-Element.Properties.dissolve = Element.Properties.reveal;
-	reveal: function(options){
-		this.get('reveal', options).reveal();
-		return this;
-	dissolve: function(options){
-		this.get('reveal', options).dissolve();
-		return this;
-	nix: function(){
-		var params = Array.link(arguments, {destroy: Boolean.type, options: Object.type});
-		this.get('reveal', params.options).dissolve().chain(function(){
-			this[params.destroy ? 'destroy' : 'dispose']();
-		}.bind(this));
-		return this;
-	wink: function(){
-		var params = Array.link(arguments, {duration: Number.type, options: Object.type});
-		var reveal = this.get('reveal', params.options);
-		reveal.reveal().chain(function(){
-			(function(){
-				reveal.dissolve();
-			}).delay(params.duration || 2000);
-script: Form.Request.Append.js
-description: Handles the basic functionality of submitting a form and updating a dom element with the result. The result is appended to the DOM element instead of replacing its contents.
-authors:
- - Aaron Newton
-requires:
- - /Form.Request
- - /Fx.Reveal
- - /Elements.from
-provides: [Form.Request.Append]
-Form.Request.Append = new Class({
-	Extends: Form.Request,
-	options: {
-		//onBeforeEffect: $empty,
-		useReveal: true,
-		revealOptions: {},
-		inject: 'bottom'
-				url: this.element.get('action'),
-				method: this.element.get('method') || 'post',
-			}, this.options.requestOptions, {
-				evalScripts: false
-		).addEvents({
-			success: function(tree, elements, html, javascript){
-				var container;
-				var kids = Elements.from(html);
-				if (kids.length == 1) {
-					container = kids[0];
-				} else {
-					 container = new Element('div', {
-						styles: {
-							display: 'none'
-					}).adopt(kids);
-				container.inject(this.update, this.options.inject);
-				if (this.options.requestOptions.evalScripts) $exec(javascript);
-				this.fireEvent('beforeEffect', container);
-				var finish = function(){
-					this.fireEvent('success', [container, this.update, tree, elements, html, javascript]);
-				}.bind(this);
-				if (this.options.useReveal) {
-					container.get('reveal', this.options.revealOptions).chain(finish);
-					container.reveal();
-				} else {
-					finish();
-			}.bind(this),
-			}.bind(this)
-script: Form.Validator.English.js
-description: Form Validator messages for English.
-authors:
- - Aaron Newton
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.English]
-MooTools.lang.set('en-US', 'Form.Validator', {
-	required:'This field is required.',
-	minLength:'Please enter at least {minLength} characters (you entered {length} characters).',
-	maxLength:'Please enter no more than {maxLength} characters (you entered {length} characters).',
-	integer:'Please enter an integer in this field. Numbers with decimals (e.g. 1.25) are not permitted.',
-	numeric:'Please enter only numeric values in this field (i.e. "1" or "1.1" or "-1" or "-1.1").',
-	digits:'Please use numbers and punctuation only in this field (for example, a phone number with dashes or dots is permitted).',
-	alpha:'Please use letters only (a-z) with in this field. No spaces or other characters are allowed.',
-	alphanum:'Please use only letters (a-z) or numbers (0-9) only in this field. No spaces or other characters are allowed.',
-	dateSuchAs:'Please enter a valid date such as {date}',
-	dateInFormatMDY:'Please enter a valid date such as MM/DD/YYYY (i.e. "12/31/1999")',
-	email:'Please enter a valid email address. For example "fred at domain.com".',
-	url:'Please enter a valid URL such as http://www.google.com.',
-	currencyDollar:'Please enter a valid $ amount. For example $100.00 .',
-	oneRequired:'Please enter something for at least one of these inputs.',
-	errorPrefix: 'Error: ',
-	warningPrefix: 'Warning: ',
-	//Form.Validator.Extras
-	noSpace: 'There can be no spaces in this input.',
-	reqChkByNode: 'No items are selected.',
-	requiredChk: 'This field is required.',
-	reqChkByName: 'Please select a {label}.',
-	match: 'This field needs to match the {matchName} field',
-	startDate: 'the start date',
-	endDate: 'the end date',
-	currendDate: 'the current date',
-	afterDate: 'The date should be the same or after {label}.',
-	beforeDate: 'The date should be the same or before {label}.',
-	startMonth: 'Please select a start month',
-	sameMonth: 'These two dates must be in the same month - you must change one or the other.',
-	creditcard: 'The credit card number entered is invalid. Please check the number and try again. {length} digits entered.'
-script: Form.Validator.js
-description: A css-class based form validation system.
-authors:
- - Aaron Newton
-requires:
- - core:1.2.4/JSON
- - /Lang
- - /Class.Binds
- - /Date Element.Forms
- - /Form.Validator.English
-provides: [Form.Validator, InputValidator, FormValidator.BaseValidators]
-var InputValidator = new Class({
-	Implements: [Options],
-	options: {
-		errorMsg: 'Validation failed.',
-		test: function(field){return true;}
-	initialize: function(className, options){
-		this.className = className;
-	test: function(field, props){
-		if (document.id(field)) return this.options.test(document.id(field), props||this.getProps(field));
-		else return false;
-	getError: function(field, props){
-		var err = this.options.errorMsg;
-		if ($type(err) == 'function') err = err(document.id(field), props||this.getProps(field));
-		return err;
-	getProps: function(field){
-		if (!document.id(field)) return {};
-		return field.get('validatorProps');
-Element.Properties.validatorProps = {
-	set: function(props){
-		return this.eliminate('validatorProps').store('validatorProps', props);
-	get: function(props){
-		if (props) this.set(props);
-		if (this.retrieve('validatorProps')) return this.retrieve('validatorProps');
-		if (this.getProperty('validatorProps')){
-			try {
-				this.store('validatorProps', JSON.decode(this.getProperty('validatorProps')));
-			}catch(e){
-				return {};
-		} else {
-			var vals = this.get('class').split(' ').filter(function(cls){
-				return cls.test(':');
-			if (!vals.length){
-				this.store('validatorProps', {});
-			} else {
-				props = {};
-				vals.each(function(cls){
-					var split = cls.split(':');
-					if (split[1]) {
-						try {
-							props[split[0]] = JSON.decode(split[1]);
-						} catch(e) {}
-				this.store('validatorProps', props);
-		return this.retrieve('validatorProps');
-Form.Validator = new Class({
-	Implements:[Options, Events],
-	Binds: ['onSubmit'],
-	options: {/*
-		onFormValidate: $empty(isValid, form, event),
-		onElementValidate: $empty(isValid, field, className, warn),
-		onElementPass: $empty(field),
-		onElementFail: $empty(field, validatorsFailed) */
-		fieldSelectors: 'input, select, textarea',
-		ignoreHidden: true,
-		ignoreDisabled: true,
-		useTitles: false,
-		evaluateOnSubmit: true,
-		evaluateFieldsOnBlur: true,
-		evaluateFieldsOnChange: true,
-		serial: true,
-		stopOnFailure: true,
-		warningPrefix: function(){
-			return Form.Validator.getMsg('warningPrefix') || 'Warning: ';
-		errorPrefix: function(){
-			return Form.Validator.getMsg('errorPrefix') || 'Error: ';
-	initialize: function(form, options){
-		this.element.store('validator', this);
-		this.warningPrefix = $lambda(this.options.warningPrefix)();
-		this.errorPrefix = $lambda(this.options.errorPrefix)();
-		if (this.options.evaluateOnSubmit) this.element.addEvent('submit', this.onSubmit);
-		if (this.options.evaluateFieldsOnBlur || this.options.evaluateFieldsOnChange) this.watchFields(this.getFields());
-	getFields: function(){
-		return (this.fields = this.element.getElements(this.options.fieldSelectors));
-	watchFields: function(fields){
-		fields.each(function(el){
-			if (this.options.evaluateFieldsOnBlur)
-				el.addEvent('blur', this.validationMonitor.pass([el, false], this));
-			if (this.options.evaluateFieldsOnChange)
-				el.addEvent('change', this.validationMonitor.pass([el, true], this));
-		}, this);
-	validationMonitor: function(){
-		$clear(this.timer);
-		this.timer = this.validateField.delay(50, this, arguments);
-	onSubmit: function(event){
-		if (!this.validate(event) && event) event.preventDefault();
-		else this.reset();
-	reset: function(){
-		this.getFields().each(this.resetField, this);
-		return this;
-	validate: function(event){
-		var result = this.getFields().map(function(field){
-			return this.validateField(field, true);
-		}, this).every(function(v){ return v;});
-		this.fireEvent('formValidate', [result, this.element, event]);
-		if (this.options.stopOnFailure && !result && event) event.preventDefault();
-		return result;
-	validateField: function(field, force){
-		if (this.paused) return true;
-		field = document.id(field);
-		var passed = !field.hasClass('validation-failed');
-		var failed, warned;
-		if (this.options.serial && !force){
-			failed = this.element.getElement('.validation-failed');
-			warned = this.element.getElement('.warning');
-		if (field && (!failed || force || field.hasClass('validation-failed') || (failed && !this.options.serial))){
-			var validators = field.className.split(' ').some(function(cn){
-				return this.getValidator(cn);
-			}, this);
-			var validatorsFailed = [];
-			field.className.split(' ').each(function(className){
-				if (className && !this.test(className, field)) validatorsFailed.include(className);
-			}, this);
-			passed = validatorsFailed.length === 0;
-			if (validators && !field.hasClass('warnOnly')){
-				if (passed){
-					field.addClass('validation-passed').removeClass('validation-failed');
-					this.fireEvent('elementPass', field);
-				} else {
-					field.addClass('validation-failed').removeClass('validation-passed');
-					this.fireEvent('elementFail', [field, validatorsFailed]);
-			if (!warned){
-				var warnings = field.className.split(' ').some(function(cn){
-					if (cn.test('^warn-') || field.hasClass('warnOnly'))
-						return this.getValidator(cn.replace(/^warn-/,''));
-					else return null;
-				}, this);
-				field.removeClass('warning');
-				var warnResult = field.className.split(' ').map(function(cn){
-						return this.test(cn.replace(/^warn-/,''), field, true);
-					else return null;
-				}, this);
-		return passed;
-	test: function(className, field, warn){
-		if((this.options.ignoreHidden && !field.isVisible()) || (this.options.ignoreDisabled && field.get('disabled'))) return true;
-		var validator = this.getValidator(className);
-		if (field.hasClass('ignoreValidation')) return true;
-		warn = $pick(warn, false);
-		if (field.hasClass('warnOnly')) warn = true;
-		var isValid = validator ? validator.test(field) : true;
-		if (validator && field.isVisible()) this.fireEvent('elementValidate', [isValid, field, className, warn]);
-		if (warn) return true;
-		return isValid;
-	resetField: function(field){
-		if (field){
-				if (className.test('^warn-')) className = className.replace(/^warn-/, '');
-				field.removeClass('validation-failed');
-				field.removeClass('validation-passed');
-			}, this);
-		return this;
-	stop: function(){
-		this.paused = true;
-		return this;
-	start: function(){
-		this.paused = false;
-		return this;
-	ignoreField: function(field, warn){
-		if (field){
-			this.enforceField(field);
-			if (warn) field.addClass('warnOnly');
-			else field.addClass('ignoreValidation');
-		return this;
-	enforceField: function(field){
-		if (field) field.removeClass('warnOnly').removeClass('ignoreValidation');
-		return this;
-Form.Validator.getMsg = function(key){
-	return MooTools.lang.get('Form.Validator', key);
-Form.Validator.adders = {
-	validators:{},
-	add : function(className, options){
-		this.validators[className] = new InputValidator(className, options);
-		//if this is a class (this method is used by instances of Form.Validator and the Form.Validator namespace)
-		//extend these validators into it
-		//this allows validators to be global and/or per instance
-		if (!this.initialize){
-			this.implement({
-				validators: this.validators
-	addAllThese : function(validators){
-		$A(validators).each(function(validator){
-			this.add(validator[0], validator[1]);
-		}, this);
-	getValidator: function(className){
-		return this.validators[className.split(':')[0]];
-$extend(Form.Validator, Form.Validator.adders);
-Form.Validator.implement(Form.Validator.adders);
-Form.Validator.add('IsEmpty', {
-	errorMsg: false,
-	test: function(element){
-		if (element.type == 'select-one' || element.type == 'select')
-			return !(element.selectedIndex >= 0 && element.options[element.selectedIndex].value != '');
-		else
-			return ((element.get('value') == null) || (element.get('value').length == 0));
-Form.Validator.addAllThese([
-	['required', {
-		errorMsg: function(){
-			return Form.Validator.getMsg('required');
-			return !Form.Validator.getValidator('IsEmpty').test(element);
-	['minLength', {
-		errorMsg: function(element, props){
-			if ($type(props.minLength))
-				return Form.Validator.getMsg('minLength').substitute({minLength:props.minLength,length:element.get('value').length });
-			else return '';
-		test: function(element, props){
-			if ($type(props.minLength)) return (element.get('value').length >= $pick(props.minLength, 0));
-			else return true;
-	['maxLength', {
-			//props is {maxLength:10}
-			if ($type(props.maxLength))
-				return Form.Validator.getMsg('maxLength').substitute({maxLength:props.maxLength,length:element.get('value').length });
-			else return '';
-			//if the value is <= than the maxLength value, element passes test
-			return (element.get('value').length <= $pick(props.maxLength, 10000));
-	['validate-integer', {
-		errorMsg: Form.Validator.getMsg.pass('integer'),
-			return Form.Validator.getValidator('IsEmpty').test(element) || (/^(-?[1-9]\d*|0)$/).test(element.get('value'));
-	['validate-numeric', {
-		errorMsg: Form.Validator.getMsg.pass('numeric'),
-				(/^-?(?:0$0(?=\d*\.)|[1-9]|0)\d*(\.\d+)?$/).test(element.get('value'));
-	['validate-digits', {
-		errorMsg: Form.Validator.getMsg.pass('digits'),
-			return Form.Validator.getValidator('IsEmpty').test(element) || (/^[\d() .:\-\+#]+$/.test(element.get('value')));
-	['validate-alpha', {
-		errorMsg: Form.Validator.getMsg.pass('alpha'),
-			return Form.Validator.getValidator('IsEmpty').test(element) ||  (/^[a-zA-Z]+$/).test(element.get('value'));
-	['validate-alphanum', {
-		errorMsg: Form.Validator.getMsg.pass('alphanum'),
-			return Form.Validator.getValidator('IsEmpty').test(element) || !(/\W/).test(element.get('value'));
-	['validate-date', {
-			if (Date.parse){
-				var format = props.dateFormat || '%x';
-				return Form.Validator.getMsg('dateSuchAs').substitute({date: new Date().format(format)});
-			} else {
-				return Form.Validator.getMsg('dateInFormatMDY');
-			if (Form.Validator.getValidator('IsEmpty').test(element)) return true;
-			var d;
-			if (Date.parse){
-				d = Date.parse(element.get('value'));
-				var formatted = d.format(format);
-				if (formatted != 'invalid date') element.set('value', formatted);
-				return !isNaN(d);
-			} else {
-				var regex = /^(\d{2})\/(\d{2})\/(\d{4})$/;
-				if (!regex.test(element.get('value'))) return false;
-				d = new Date(element.get('value').replace(regex, '$1/$2/$3'));
-				return (parseInt(RegExp.$1, 10) == (1 + d.getMonth())) &&
-					(parseInt(RegExp.$2, 10) == d.getDate()) &&
-					(parseInt(RegExp.$3, 10) == d.getFullYear());
-	['validate-email', {
-		errorMsg: Form.Validator.getMsg.pass('email'),
-			return Form.Validator.getValidator('IsEmpty').test(element) || (/^[A-Z0-9._%+-]+@[A-Z0-9.-]+\.[A-Z]{2,4}$/i).test(element.get('value'));
-	['validate-url', {
-		errorMsg: Form.Validator.getMsg.pass('url'),
-			return Form.Validator.getValidator('IsEmpty').test(element) || (/^(https?|ftp|rmtp|mms):\/\/(([A-Z0-9][A-Z0-9_-]*)(\.[A-Z0-9][A-Z0-9_-]*)+)(:(\d+))?\/?/i).test(element.get('value'));
-	['validate-currency-dollar', {
-		errorMsg: Form.Validator.getMsg.pass('currencyDollar'),
-			// [$]1[##][,###]+[.##]
-			// [$]1###+[.##]
-			// [$]0.##
-			return Form.Validator.getValidator('IsEmpty').test(element) ||  (/^\$?\-?([1-9]{1}[0-9]{0,2}(\,[0-9]{3})*(\.[0-9]{0,2})?|[1-9]{1}\d*(\.[0-9]{0,2})?|0(\.[0-9]{0,2})?|(\.[0-9]{1,2})?)$/).test(element.get('value'));
-	['validate-one-required', {
-		errorMsg: Form.Validator.getMsg.pass('oneRequired'),
-			var p = document.id(props['validate-one-required']) || element.getParent();
-			return p.getElements('input').some(function(el){
-				if (['checkbox', 'radio'].contains(el.get('type'))) return el.get('checked');
-				return el.get('value');
-Element.Properties.validator = {
-		var validator = this.retrieve('validator');
-		if (validator) validator.setOptions(options);
-		return this.store('validator:options');
-		if (options || !this.retrieve('validator')){
-			if (options || !this.retrieve('validator:options')) this.set('validator', options);
-			this.store('validator', new Form.Validator(this, this.retrieve('validator:options')));
-		return this.retrieve('validator');
-	validate: function(options){
-		this.set('validator', options);
-		return this.get('validator', options).validate();
-//legacy
-var FormValidator = Form.Validator;/*
-script: Form.Validator.Inline.js
-description: Extends Form.Validator to add inline messages.
-authors:
- - Aaron Newton
-requires:
- - /Form.Validator
-provides: [Form.Validator.Inline]
-Form.Validator.Inline = new Class({
-	Extends: Form.Validator,
-	options: {
-		scrollToErrorsOnSubmit: true,
-		scrollFxOptions: {
-			transition: 'quad:out',
-			offset: {
-				y: -20
-		this.parent(form, options);
-		this.addEvent('onElementValidate', function(isValid, field, className, warn){
-			if (!isValid && validator.getError(field)){
-				if (warn) field.addClass('warning');
-				var advice = this.makeAdvice(className, field, validator.getError(field), warn);
-				this.insertAdvice(advice, field);
-				this.showAdvice(className, field);
-			} else {
-				this.hideAdvice(className, field);
-	makeAdvice: function(className, field, error, warn){
-		var errorMsg = (warn)?this.warningPrefix:this.errorPrefix;
-			errorMsg += (this.options.useTitles) ? field.title || error:error;
-		var cssClass = (warn) ? 'warning-advice' : 'validation-advice';
-		var advice = this.getAdvice(className, field);
-		if(advice) {
-			advice = advice.set('html', errorMsg);
-		} else {
-			advice = new Element('div', {
-				html: errorMsg,
-				styles: { display: 'none' },
-				id: 'advice-' + className + '-' + this.getFieldId(field)
-			}).addClass(cssClass);
-		field.store('advice-' + className, advice);
-		return advice;
-	getFieldId : function(field){
-		return field.id ? field.id : field.id = 'input_' + field.name;
-	showAdvice: function(className, field){
-		if (advice && !field.retrieve(this.getPropName(className))
-				&& (advice.getStyle('display') == 'none'
-				|| advice.getStyle('visiblity') == 'hidden'
-				|| advice.getStyle('opacity') == 0)){
-			field.store(this.getPropName(className), true);
-			if (advice.reveal) advice.reveal();
-			else advice.setStyle('display', 'block');
-	hideAdvice: function(className, field){
-		if (advice && field.retrieve(this.getPropName(className))){
-			field.store(this.getPropName(className), false);
-			//if Fx.Reveal.js is present, transition the advice out
-			if (advice.dissolve) advice.dissolve();
-			else advice.setStyle('display', 'none');
-	getPropName: function(className){
-		return 'advice' + className;
-		if (!field) return this;
-		this.parent(field);
-		}, this);
-		return this;
-	getAllAdviceMessages: function(field, force){
-		var advice = [];
-		if (field.hasClass('ignoreValidation') && !force) return advice;
-			var warner = cn.test('^warn-') || field.hasClass('warnOnly');
-			if (warner) cn = cn.replace(/^warn-/, '');
-			var validator = this.getValidator(cn);
-			if (!validator) return;
-			advice.push({
-				message: validator.getError(field),
-				warnOnly: warner,
-				passed: validator.test(),
-				validator: validator
-		}, this);
-		return advice;
-	getAdvice: function(className, field){
-		return field.retrieve('advice-' + className);
-	insertAdvice: function(advice, field){
-		//Check for error position prop
-		var props = field.get('validatorProps');
-		//Build advice
-		if (!props.msgPos || !document.id(props.msgPos)){
-			if(field.type.toLowerCase() == 'radio') field.getParent().adopt(advice);
-			else advice.inject(document.id(field), 'after');
-		} else {
-			document.id(props.msgPos).grab(advice);
-		var result = this.parent(field, force);
-		if (this.options.scrollToErrorsOnSubmit && !result){
-			var failed = document.id(this).getElement('.validation-failed');
-			var par = document.id(this).getParent();
-			while (par != document.body && par.getScrollSize().y == par.getSize().y){
-				par = par.getParent();
-			var fx = par.retrieve('fvScroller');
-			if (!fx && window.Fx && Fx.Scroll){
-				fx = new Fx.Scroll(par, this.options.scrollFxOptions);
-				par.store('fvScroller', fx);
-			if (failed){
-				if (fx) fx.toElement(failed);
-				else par.scrollTo(par.getScroll().x, failed.getPosition(par).y - 20);
-		return result;
-script: Form.Validator.Extras.js
-description: Additional validators for the Form.Validator class.
-authors:
- - Aaron Newton
-requires:
- - /Form.Validator
-provides: [Form.Validator.Extras]
-	['validate-enforce-oncheck', {
-			if (element.checked){
-				var fv = element.getParent('form').retrieve('validator');
-				if (!fv) return true;
-				(props.toEnforce || document.id(props.enforceChildrenOf).getElements('input, select, textarea')).map(function(item){
-					fv.enforceField(item);
-			return true;
-	['validate-ignore-oncheck', {
-				(props.toIgnore || document.id(props.ignoreChildrenOf).getElements('input, select, textarea')).each(function(item){
-					fv.ignoreField(item);
-					fv.resetField(item);
-			return true;
-	['validate-nospace', {
-			return Form.Validator.getMsg('noSpace');
-			return !element.get('value').test(/\s/);
-	['validate-toggle-oncheck', {
-			var eleArr = props.toToggle || document.id(props.toToggleChildrenOf).getElements('input, select, textarea');
-			if (!element.checked){
-				eleArr.each(function(item){
-			} else {
-			return true;
-	['validate-reqchk-bynode', {
-			return Form.Validator.getMsg('reqChkByNode');
-			return (document.id(props.nodeId).getElements(props.selector || 'input[type=checkbox], input[type=radio]')).some(function(item){
-				return item.checked;
-	['validate-required-check', {
-			return props.useTitle ? element.get('title') : Form.Validator.getMsg('requiredChk');
-			return !!element.checked;
-	['validate-reqchk-byname', {
-			return Form.Validator.getMsg('reqChkByName').substitute({label: props.label || element.get('type')});
-			var grpName = props.groupName || element.get('name');
-			var oneCheckedItem = $$(document.getElementsByName(grpName)).some(function(item, index){
-			if (oneCheckedItem && fv) fv.resetField(element);
-			return oneCheckedItem;
-	['validate-match', {
-			return Form.Validator.getMsg('match').substitute({matchName: props.matchName || document.id(props.matchInput).get('name')});
-			var eleVal = element.get('value');
-			var matchVal = document.id(props.matchInput) && document.id(props.matchInput).get('value');
-			return eleVal && matchVal ? eleVal == matchVal : true;
-	['validate-after-date', {
-			return Form.Validator.getMsg('afterDate').substitute({
-				label: props.afterLabel || (props.afterElement ? Form.Validator.getMsg('startDate') : Form.Validator.getMsg('currentDate'))
-			var start = document.id(props.afterElement) ? Date.parse(document.id(props.afterElement).get('value')) : new Date();
-			var end = Date.parse(element.get('value'));
-			return end && start ? end >= start : true;
-	['validate-before-date', {
-			return Form.Validator.getMsg('beforeDate').substitute({
-				label: props.beforeLabel || (props.beforeElement ? Form.Validator.getMsg('endDate') : Form.Validator.getMsg('currentDate'))
-			var start = Date.parse(element.get('value'));
-			var end = document.id(props.beforeElement) ? Date.parse(document.id(props.beforeElement).get('value')) : new Date();
-	['validate-custom-required', {
-			return element.get('value') != props.emptyValue;
-	['validate-same-month', {
-			var startMo = document.id(props.sameMonthAs) && document.id(props.sameMonthAs).get('value');
-			if (eleVal != '') return Form.Validator.getMsg(startMo ? 'sameMonth' : 'startMonth');
-			var d1 = Date.parse(element.get('value'));
-			var d2 = Date.parse(document.id(props.sameMonthAs) && document.id(props.sameMonthAs).get('value'));
-			return d1 && d2 ? d1.format('%B') == d2.format('%B') : true;
-	['validate-cc-num', {
-		errorMsg: function(element){
-			var ccNum = element.get('value').replace(/[^0-9]/g, '');
-			return Form.Validator.getMsg('creditcard').substitute({length: ccNum.length});
-			// required is a different test
-			if (Form.Validator.getValidator('IsEmpty').test(element)) { return true; }
-			// Clean number value
-			var ccNum = element.get('value');
-			ccNum = ccNum.replace(/[^0-9]/g, '');
-			var valid_type = false;
-			if (ccNum.test(/^4[0-9]{12}([0-9]{3})?$/)) valid_type = 'Visa';
-			else if (ccNum.test(/^5[1-5]([0-9]{14})$/)) valid_type = 'Master Card';
-			else if (ccNum.test(/^3[47][0-9]{13}$/)) valid_type = 'American Express';
-			else if (ccNum.test(/^6011[0-9]{12}$/)) valid_type = 'Discover';
-			if (valid_type) {
-				var sum = 0;
-				var cur = 0;
-				for(var i=ccNum.length-1; i>=0; --i) {
-					cur = ccNum.charAt(i).toInt();
-					if (cur == 0) { continue; }
-					if ((ccNum.length-i) % 2 == 0) { cur += cur; }
-					if (cur > 9) { cur = cur.toString().charAt(0).toInt() + cur.toString().charAt(1).toInt(); }
-					sum += cur;
-				if ((sum % 10) == 0) { return true; }
-			var chunks = '';
-			while (ccNum != '') {
-				chunks += ' ' + ccNum.substr(0,4);
-				ccNum = ccNum.substr(4);
-			element.getParent('form').retrieve('validator').ignoreField(element);
-			element.set('value', chunks.clean());
-			element.getParent('form').retrieve('validator').enforceField(element);
-			return false;
-script: OverText.js
-description: Shows text over an input that disappears when the user clicks into it. The text remains hidden if the user adds a value.
-license: MIT-style license
-authors:
- - Aaron Newton
-requires:
- - /Class.Binds
- - /Class.Occlude
-provides: [OverText]
-var OverText = new Class({
-	Binds: ['reposition', 'assert', 'focus', 'hide'],
-	options: {/*
-		textOverride: null,
-		onFocus: $empty()
-		onTextHide: $empty(textEl, inputEl),
-		onTextShow: $empty(textEl, inputEl), */
-		element: 'label',
-		positionOptions: {
-			position: 'upperLeft',
-			edge: 'upperLeft',
-			offset: {
-				x: 4,
-				y: 2
-		poll: false,
-		pollInterval: 250,
-		wrap: false
-	property: 'OverText',
-		this.attach(this.element);
-		OverText.instances.push(this);
-		if (this.options.poll) this.poll();
-		return this;
-	attach: function(){
-		var val = this.options.textOverride || this.element.get('alt') || this.element.get('title');
-		if (!val) return;
-		this.text = new Element(this.options.element, {
-			'class': 'overTxtLabel',
-			styles: {
-				lineHeight: 'normal',
-				cursor: 'text'
-			html: val,
-			events: {
-				click: this.hide.pass(this.options.element == 'label', this)
-		}).inject(this.element, 'after');
-		if (this.options.element == 'label') {
-			if (!this.element.get('id')) this.element.set('id', 'input_' + new Date().getTime());
-			this.text.set('for', this.element.get('id'));
-		if (this.options.wrap) {
-			this.textHolder = new Element('div', {
-				styles: {
-					position: 'relative'
-				'class':'overTxtWrapper'
-			}).adopt(this.text).inject(this.element, 'before');
-		this.element.addEvents({
-			focus: this.focus,
-			blur: this.assert,
-			change: this.assert
-		}).store('OverTextDiv', this.text);
-		window.addEvent('resize', this.reposition.bind(this));
-		this.assert(true);
-		this.reposition();
-	wrap: function(){
-	startPolling: function(){
-		this.pollingPaused = false;
-		return this.poll();
-	poll: function(stop){
-		//start immediately
-		//pause on focus
-		//resumeon blur
-		if (this.poller && !stop) return this;
-		var test = function(){
-			if (!this.pollingPaused) this.assert(true);
-		}.bind(this);
-		if (stop) $clear(this.poller);
-		else this.poller = test.periodical(this.options.pollInterval, this);
-		return this;
-	stopPolling: function(){
-		this.pollingPaused = true;
-		return this.poll(true);
-	focus: function(){
-		if (this.text && (!this.text.isDisplayed() || this.element.get('disabled'))) return;
-		this.hide();
-	hide: function(suppressFocus, force){
-		if (this.text && (this.text.isDisplayed() && (!this.element.get('disabled') || force))){
-			this.text.hide();
-			this.fireEvent('textHide', [this.text, this.element]);
-			if (!suppressFocus){
-				try {
-					this.element.fireEvent('focus');
-					this.element.focus();
-				} catch(e){} //IE barfs if you call focus on hidden elements
-		return this;
-	show: function(){
-		if (this.text && !this.text.isDisplayed()){
-			this.text.show();
-			this.fireEvent('textShow', [this.text, this.element]);
-		return this;
-	assert: function(suppressFocus){
-		this[this.test() ? 'show' : 'hide'](suppressFocus);
-	test: function(){
-		var v = this.element.get('value');
-		return !v;
-	reposition: function(){
-		if (!this.element.isVisible()) return this.stopPolling().hide();
-		if (this.text && this.test()) this.text.position($merge(this.options.positionOptions, {relativeTo: this.element}));
-		return this;
-OverText.instances = [];
-$extend(OverText, {
-	each: function(fn) {
-		return OverText.instances.map(function(ot, i){
-			if (ot.element && ot.text) return fn.apply(OverText, [ot, i]);
-			return null; //the input or the text was destroyed
-	update: function(){
-		return OverText.each(function(ot){
-			return ot.reposition();
-	hideAll: function(){
-			return ot.hide(true, true);
-	showAll: function(){
-		return OverText.each(function(ot) {
-			return ot.show();
-if (window.Fx && Fx.Reveal) {
-	Fx.Reveal.implement({
-		hideInputs: Browser.Engine.trident ? 'select, input, textarea, object, embed, .overTxtLabel' : false
-script: Fx.Elements.js
-description: Effect to change any number of CSS properties of any number of Elements.
-authors:
- - Valerio Proietti
-requires:
- - core:1.2.4/Fx.CSS
- - /MooTools.More
-provides: [Fx.Elements]
-Fx.Elements = new Class({
-	Extends: Fx.CSS,
-	initialize: function(elements, options){
-		this.elements = this.subject = $$(elements);
-		this.parent(options);
-	compute: function(from, to, delta){
-		var now = {};
-		for (var i in from){
-			var iFrom = from[i], iTo = to[i], iNow = now[i] = {};
-			for (var p in iFrom) iNow[p] = this.parent(iFrom[p], iTo[p], delta);
-		return now;
-	set: function(now){
-		for (var i in now){
-			var iNow = now[i];
-			for (var p in iNow) this.render(this.elements[i], p, iNow[p], this.options.unit);
-		return this;
-	start: function(obj){
-		if (!this.check(obj)) return this;
-		var from = {}, to = {};
-		for (var i in obj){
-			var iProps = obj[i], iFrom = from[i] = {}, iTo = to[i] = {};
-			for (var p in iProps){
-				var parsed = this.prepare(this.elements[i], p, iProps[p]);
-				iFrom[p] = parsed.from;
-				iTo[p] = parsed.to;
-		return this.parent(from, to);
-script: Fx.Accordion.js
-description: An Fx.Elements extension which allows you to easily create accordion type controls.
-authors:
-requires:
- - /Fx.Elements
-provides: [Fx.Accordion]
-Fx.Accordion = new Class({
-	Extends: Fx.Elements,
-	options: {/*
-		onActive: $empty(toggler, section),
-		onBackground: $empty(toggler, section),
-		fixedHeight: false,
-		fixedWidth: false,
-		display: 0,
-		show: false,
-		height: true,
-		width: false,
-		opacity: true,
-		alwaysHide: false,
-		trigger: 'click',
-		initialDisplayFx: true,
-		returnHeightToAuto: true
-			'container': Element.type, //deprecated
-			'options': Object.type,
-			'togglers': $defined,
-			'elements': $defined
-		this.parent(params.elements, params.options);
-		this.togglers = $$(params.togglers);
-		this.previous = -1;
-		this.internalChain = new Chain();
-		if (this.options.alwaysHide) this.options.wait = true;
-		if ($chk(this.options.show)){
-			this.options.display = false;
-			this.previous = this.options.show;
-		if (this.options.start){
-			this.options.show = false;
-		this.effects = {};
-		if (this.options.opacity) this.effects.opacity = 'fullOpacity';
-		if (this.options.width) this.effects.width = this.options.fixedWidth ? 'fullWidth' : 'offsetWidth';
-		if (this.options.height) this.effects.height = this.options.fixedHeight ? 'fullHeight' : 'scrollHeight';
-		for (var i = 0, l = this.togglers.length; i < l; i++) this.addSection(this.togglers[i], this.elements[i]);
-		this.elements.each(function(el, i){
-			if (this.options.show === i){
-				this.fireEvent('active', [this.togglers[i], el]);
-			} else {
-				for (var fx in this.effects) el.setStyle(fx, 0);
-		}, this);
-		if ($chk(this.options.display) || this.options.initialDisplayFx === false) this.display(this.options.display, this.options.initialDisplayFx);
-		if (this.options.fixedHeight !== false) this.options.returnHeightToAuto = false;
-		this.addEvent('complete', this.internalChain.callChain.bind(this.internalChain));
-	addSection: function(toggler, element){
-		toggler = document.id(toggler);
-		element = document.id(element);
-		var test = this.togglers.contains(toggler);
-		this.togglers.include(toggler);
-		this.elements.include(element);
-		var idx = this.togglers.indexOf(toggler);
-		var displayer = this.display.bind(this, idx);
-		toggler.store('accordion:display', displayer);
-		toggler.addEvent(this.options.trigger, displayer);
-		if (this.options.height) element.setStyles({'padding-top': 0, 'border-top': 'none', 'padding-bottom': 0, 'border-bottom': 'none'});
-		if (this.options.width) element.setStyles({'padding-left': 0, 'border-left': 'none', 'padding-right': 0, 'border-right': 'none'});
-		element.fullOpacity = 1;
-		if (this.options.fixedWidth) element.fullWidth = this.options.fixedWidth;
-		if (this.options.fixedHeight) element.fullHeight = this.options.fixedHeight;
-		element.setStyle('overflow', 'hidden');
-		if (!test){
-			for (var fx in this.effects) element.setStyle(fx, 0);
-		return this;
-		this.togglers.each(function(toggler) {
-			toggler.removeEvent(this.options.trigger, toggler.retrieve('accordion:display'));
-		}, this);
-	display: function(index, useFx){
-		if (!this.check(index, useFx)) return this;
-		useFx = $pick(useFx, true);
-		if (this.options.returnHeightToAuto){
-			var prev = this.elements[this.previous];
-			if (prev && !this.selfHidden){
-				for (var fx in this.effects){
-					prev.setStyle(fx, prev[this.effects[fx]]);
-		index = ($type(index) == 'element') ? this.elements.indexOf(index) : index;
-		if ((this.timer && this.options.wait) || (index === this.previous && !this.options.alwaysHide)) return this;
-		this.previous = index;
-		var obj = {};
-			obj[i] = {};
-			var hide;
-			if (i != index){
-				hide = true;
-			} else if (this.options.alwaysHide && ((el.offsetHeight > 0 && this.options.height) || el.offsetWidth > 0 && this.options.width)){
-				hide = true;
-				this.selfHidden = true;
-			this.fireEvent(hide ? 'background' : 'active', [this.togglers[i], el]);
-			for (var fx in this.effects) obj[i][fx] = hide ? 0 : el[this.effects[fx]];
-		}, this);
-		this.internalChain.chain(function(){
-			if (this.options.returnHeightToAuto && !this.selfHidden){
-				var el = this.elements[index];
-				if (el) el.setStyle('height', 'auto');
-		}.bind(this));
-		return useFx ? this.start(obj) : this.set(obj);
-	Compatibility with 1.2.0
-var Accordion = new Class({
-	Extends: Fx.Accordion,
-		var params = Array.link(arguments, {'container': Element.type});
-		this.container = params.container;
-	addSection: function(toggler, element, pos){
-		var len = this.togglers.length;
-		if (len && (!test || pos)){
-			pos = $pick(pos, len - 1);
-			toggler.inject(this.togglers[pos], 'before');
-			element.inject(toggler, 'after');
-		} else if (this.container && !test){
-			toggler.inject(this.container);
-			element.inject(this.container);
-		return this.parent.apply(this, arguments);
-script: Fx.Move.js
-description: Defines Fx.Move, a class that works with Element.Position.js to transition an element from one location to another.
-authors:
- - Aaron Newton
-requires:
-provides: [Fx.Move]
-Fx.Move = new Class({
-	options: {
-		position: 'center',
-		edge: false,
-	start: function(destination){
-		return this.parent(this.element.position($merge(this.options, destination, {returnPos: true})));
-Element.Properties.move = {
-		var morph = this.retrieve('move');
-		if (morph) morph.cancel();
-		return this.eliminate('move').store('move:options', $extend({link: 'cancel'}, options));
-		if (options || !this.retrieve('move')){
-			if (options || !this.retrieve('move:options')) this.set('move', options);
-			this.store('move', new Fx.Move(this, this.retrieve('move:options')));
-		return this.retrieve('move');
-Element.implement({
-	move: function(options){
-		this.get('move').start(options);
-		return this;
-script: Fx.Scroll.js
-description: Effect to smoothly scroll any element, including the window.
-authors:
-requires:
- - core:1.2.4/Fx
- - core:1.2.4/Element.Dimensions
- - /MooTools.More
-provides: [Fx.Scroll]
-Fx.Scroll = new Class({
-	Extends: Fx,
-	options: {
-		wheelStops: true
-		this.element = this.subject = document.id(element);
-		var cancel = this.cancel.bind(this, false);
-		if ($type(this.element) != 'element') this.element = document.id(this.element.getDocument().body);
-		var stopper = this.element;
-		if (this.options.wheelStops){
-			this.addEvent('start', function(){
-				stopper.addEvent('mousewheel', cancel);
-			}, true);
-			this.addEvent('complete', function(){
-				stopper.removeEvent('mousewheel', cancel);
-			}, true);
-	set: function(){
-		var now = Array.flatten(arguments);
-		if (Browser.Engine.gecko) now = [Math.round(now[0]), Math.round(now[1])];
-		this.element.scrollTo(now[0], now[1]);
-		return [0, 1].map(function(i){
-			return Fx.compute(from[i], to[i], delta);
-	start: function(x, y){
-		if (!this.check(x, y)) return this;
-		var scrollSize = this.element.getScrollSize(),
-			scroll = this.element.getScroll(),
-			values = {x: x, y: y};
-		for (var z in values){
-			var max = scrollSize[z];
-			if ($chk(values[z])) values[z] = ($type(values[z]) == 'number') ? values[z] : max;
-			else values[z] = scroll[z];
-			values[z] += this.options.offset[z];
-		return this.parent([scroll.x, scroll.y], [values.x, values.y]);
-	toTop: function(){
-		return this.start(false, 0);
-	toLeft: function(){
-		return this.start(0, false);
-	toRight: function(){
-		return this.start('right', false);
-	toBottom: function(){
-		return this.start(false, 'bottom');
-	toElement: function(el){
-		var position = document.id(el).getPosition(this.element);
-		return this.start(position.x, position.y);
-	scrollIntoView: function(el, axes, offset){
-		axes = axes ? $splat(axes) : ['x','y'];
-		var to = {};
-		el = document.id(el);
-		var pos = el.getPosition(this.element);
-		var size = el.getSize();
-		var scroll = this.element.getScroll();
-		var containerSize = this.element.getSize();
-		var edge = {
-			x: pos.x + size.x,
-			y: pos.y + size.y
-		['x','y'].each(function(axis) {
-			if (axes.contains(axis)) {
-				if (edge[axis] > scroll[axis] + containerSize[axis]) to[axis] = edge[axis] - containerSize[axis];
-				if (pos[axis] < scroll[axis]) to[axis] = pos[axis];
-			if (to[axis] == null) to[axis] = scroll[axis];
-			if (offset && offset[axis]) to[axis] = to[axis] + offset[axis];
-		}, this);
-		if (to.x != scroll.x || to.y != scroll.y) this.start(to.x, to.y);
-		return this;
-	scrollToCenter: function(el, axes, offset){
-		axes = axes ? $splat(axes) : ['x', 'y'];
-		el = $(el);
-		var to = {},
-			pos = el.getPosition(this.element),
-			size = el.getSize(),
-			containerSize = this.element.getSize(),
-			edge = {
-				y: pos.y + size.y
-		['x','y'].each(function(axis){
-			if(axes.contains(axis)){
-				to[axis] = pos[axis] - (containerSize[axis] - size[axis])/2;
-			if(to[axis] == null) to[axis] = scroll[axis];
-			if(offset && offset[axis]) to[axis] = to[axis] + offset[axis];
-		}, this);
-		return this;
-script: Fx.Slide.js
-description: Effect to slide an element in and out of view.
-authors:
-requires:
- - core:1.2.4/Fx Element.Style
- - /MooTools.More
-provides: [Fx.Slide]
-Fx.Slide = new Class({
-	Extends: Fx,
-	options: {
-		mode: 'vertical',
-		wrapper: false,
-		hideOverflow: true
-			this.open = (this.wrapper['offset' + this.layout.capitalize()] != 0);
-			if (this.open) this.wrapper.setStyle('height', '');
-			if (this.open && Browser.Engine.webkit419) this.element.dispose().inject(this.wrapper);
-		}, true);
-		var wrapper = this.element.retrieve('wrapper');
-		var styles = this.element.getStyles('margin', 'position', 'overflow');
-		if (this.options.hideOverflow) styles = $extend(styles, {overflow: 'hidden'});
-		if (this.options.wrapper) wrapper = document.id(this.options.wrapper).setStyles(styles);
-		this.wrapper = wrapper || new Element('div', {
-			styles: styles
-		}).wraps(this.element);
-		this.element.store('wrapper', this.wrapper).setStyle('margin', 0);
-		this.now = [];
-		this.open = true;
-	vertical: function(){
-		this.margin = 'margin-top';
-		this.layout = 'height';
-		this.offset = this.element.offsetHeight;
-	horizontal: function(){
-		this.margin = 'margin-left';
-		this.layout = 'width';
-		this.offset = this.element.offsetWidth;
-		this.element.setStyle(this.margin, now[0]);
-		this.wrapper.setStyle(this.layout, now[1]);
-		return this;
-	start: function(how, mode){
-		if (!this.check(how, mode)) return this;
-		this[mode || this.options.mode]();
-		var margin = this.element.getStyle(this.margin).toInt();
-		var layout = this.wrapper.getStyle(this.layout).toInt();
-		var caseIn = [[margin, layout], [0, this.offset]];
-		var caseOut = [[margin, layout], [-this.offset, 0]];
-		var start;
-		switch (how){
-			case 'in': start = caseIn; break;
-			case 'out': start = caseOut; break;
-			case 'toggle': start = (layout == 0) ? caseIn : caseOut;
-		return this.parent(start[0], start[1]);
-	slideIn: function(mode){
-		return this.start('in', mode);
-	slideOut: function(mode){
-		return this.start('out', mode);
-	hide: function(mode){
-		this.open = false;
-		return this.set([-this.offset, 0]);
-	show: function(mode){
-		this.open = true;
-		return this.set([0, this.offset]);
-	toggle: function(mode){
-		return this.start('toggle', mode);
-Element.Properties.slide = {
-		var slide = this.retrieve('slide');
-		if (slide) slide.cancel();
-		return this.eliminate('slide').store('slide:options', $extend({link: 'cancel'}, options));
-		if (options || !this.retrieve('slide')){
-			if (options || !this.retrieve('slide:options')) this.set('slide', options);
-			this.store('slide', new Fx.Slide(this, this.retrieve('slide:options')));
-		return this.retrieve('slide');
-	slide: function(how, mode){
-		how = how || 'toggle';
-		var slide = this.get('slide'), toggle;
-		switch (how){
-			case 'hide': slide.hide(mode); break;
-			case 'show': slide.show(mode); break;
-			case 'toggle':
-				var flag = this.retrieve('slide:flag', slide.open);
-				slide[flag ? 'slideOut' : 'slideIn'](mode);
-				this.store('slide:flag', !flag);
-				toggle = true;
-			break;
-			default: slide.start(how, mode);
-		if (!toggle) this.eliminate('slide:flag');
-		return this;
-script: Fx.SmoothScroll.js
-description: Class for creating a smooth scrolling effect to all internal links on the page.
-authors:
-requires:
- - core:1.2.4/Selectors
- - /Fx.Scroll
-provides: [Fx.SmoothScroll]
-var SmoothScroll = Fx.SmoothScroll = new Class({
-	Extends: Fx.Scroll,
-	initialize: function(options, context){
-		context = context || document;
-		this.doc = context.getDocument();
-		var win = context.getWindow();
-		this.parent(this.doc, options);
-		this.links = $$(this.options.links || this.doc.links);
-		var location = win.location.href.match(/^[^#]*/)[0] + '#';
-		this.links.each(function(link){
-			if (link.href.indexOf(location) != 0) {return;}
-			var anchor = link.href.substr(location.length);
-			if (anchor) this.useLink(link, anchor);
-		}, this);
-		if (!Browser.Engine.webkit419) {
-				win.location.hash = this.anchor;
-			}, true);
-	useLink: function(link, anchor){
-		var el;
-		link.addEvent('click', function(event){
-			if (el !== false && !el) el = document.id(anchor) || this.doc.getElement('a[name=' + anchor + ']');
-			if (el) {
-				event.preventDefault();
-				this.anchor = anchor;
-				this.toElement(el).chain(function(){
-					this.fireEvent('scrolledTo', [link, el]);
-				}.bind(this));
-				link.blur();
-		}.bind(this));
-script: Fx.Sort.js
-description: Defines Fx.Sort, a class that reorders lists with a transition.
-authors:
- - Aaron Newton
-requires:
- - /Fx.Elements
- - /Element.Measure
-provides: [Fx.Sort]
-Fx.Sort = new Class({
-	options: {
-		mode: 'vertical'
-		this.parent(elements, options);
-		this.elements.each(function(el){
-			if (el.getStyle('position') == 'static') el.setStyle('position', 'relative');
-		this.setDefaultOrder();
-	setDefaultOrder: function(){
-		this.currentOrder = this.elements.map(function(el, index){
-			return index;
-	sort: function(newOrder){
-		if ($type(newOrder) != 'array') return false;
-		var top = 0,
-			left = 0,
-			next = {},
-			zero = {},
-			vert = this.options.mode == 'vertical';
-		var current = this.elements.map(function(el, index){
-			var size = el.getComputedSize({styles: ['border', 'padding', 'margin']});
-			var val;
-			if (vert){
-				val = {
-					top: top,
-					margin: size['margin-top'],
-					height: size.totalHeight
-				top += val.height - size['margin-top'];
-			} else {
-				val = {
-					left: left,
-					margin: size['margin-left'],
-					width: size.totalWidth
-				left += val.width;
-			var plain = vert ? 'top' : 'left';
-			zero[index] = {};
-			var start = el.getStyle(plain).toInt();
-			zero[index][plain] = start || 0;
-			return val;
-		}, this);
-		this.set(zero);
-		newOrder = newOrder.map(function(i){ return i.toInt(); });
-		if (newOrder.length != this.elements.length){
-			this.currentOrder.each(function(index){
-				if (!newOrder.contains(index)) newOrder.push(index);
-			if (newOrder.length > this.elements.length)
-				newOrder.splice(this.elements.length-1, newOrder.length - this.elements.length);
-		var margin = top = left = 0;
-		newOrder.each(function(item, index){
-			var newPos = {};
-			if (vert){
-				newPos.top = top - current[item].top - margin;
-				top += current[item].height;
-			} else {
-				newPos.left = left - current[item].left;
-				left += current[item].width;
-			margin = margin + current[item].margin;
-			next[item]=newPos;
-		}, this);
-		var mapped = {};
-		$A(newOrder).sort().each(function(index){
-			mapped[index] = next[index];
-		this.start(mapped);
-		this.currentOrder = newOrder;
-		return this;
-	rearrangeDOM: function(newOrder){
-		newOrder = newOrder || this.currentOrder;
-		var parent = this.elements[0].getParent();
-		var rearranged = [];
-		this.elements.setStyle('opacity', 0);
-		//move each element and store the new default order
-		newOrder.each(function(index){
-			rearranged.push(this.elements[index].inject(parent).setStyles({
-				top: 0,
-				left: 0
-		}, this);
-		this.elements.setStyle('opacity', 1);
-		this.elements = $$(rearranged);
-		return this;
-	getDefaultOrder: function(){
-		return this.elements.map(function(el, index){
-			return index;
-	forward: function(){
-		return this.sort(this.getDefaultOrder());
-	backward: function(){
-		return this.sort(this.getDefaultOrder().reverse());
-	reverse: function(){
-		return this.sort(this.currentOrder.reverse());
-	sortByElements: function(elements){
-		return this.sort(elements.map(function(el){
-			return this.elements.indexOf(el);
-		}, this));
-	swap: function(one, two){
-		if ($type(one) == 'element') one = this.elements.indexOf(one);
-		if ($type(two) == 'element') two = this.elements.indexOf(two);
-		var newOrder = $A(this.currentOrder);
-		newOrder[this.currentOrder.indexOf(one)] = two;
-		newOrder[this.currentOrder.indexOf(two)] = one;
-		return this.sort(newOrder);
-script: Drag.js
-description: The base Drag Class. Can be used to drag and resize Elements using mouse events.
-authors:
- - Tom Occhinno
- - Jan Kassens
-requires:
- - core:1.2.4/Events
- - core:1.2.4/Options
- - core:1.2.4/Element.Style
- - /MooTools.More
-provides: [Drag]
-var Drag = new Class({
-	Implements: [Events, Options],
-	options: {/*
-		onBeforeStart: $empty(thisElement),
-		onStart: $empty(thisElement, event),
-		onSnap: $empty(thisElement)
-		onDrag: $empty(thisElement, event),
-		onCancel: $empty(thisElement),
-		onComplete: $empty(thisElement, event),*/
-		snap: 6,
-		unit: 'px',
-		grid: false,
-		style: true,
-		limit: false,
-		handle: false,
-		invert: false,
-		preventDefault: false,
-		stopPropagation: false,
-		modifiers: {x: 'left', y: 'top'}
-		var params = Array.link(arguments, {'options': Object.type, 'element': $defined});
-		this.element = document.id(params.element);
-		this.document = this.element.getDocument();
-		this.setOptions(params.options || {});
-		var htype = $type(this.options.handle);
-		this.handles = ((htype == 'array' || htype == 'collection') ? $$(this.options.handle) : document.id(this.options.handle)) || this.element;
-		this.mouse = {'now': {}, 'pos': {}};
-		this.value = {'start': {}, 'now': {}};
-		this.selection = (Browser.Engine.trident) ? 'selectstart' : 'mousedown';
-		this.bound = {
-			start: this.start.bind(this),
-			check: this.check.bind(this),
-			drag: this.drag.bind(this),
-			stop: this.stop.bind(this),
-			cancel: this.cancel.bind(this),
-			eventStop: $lambda(false)
-		this.attach();
-		this.handles.addEvent('mousedown', this.bound.start);
-		return this;
-		this.handles.removeEvent('mousedown', this.bound.start);
-		return this;
-	start: function(event){
-		if (event.rightClick) return;
-		if (this.options.preventDefault) event.preventDefault();
-		if (this.options.stopPropagation) event.stopPropagation();
-		this.mouse.start = event.page;
-		this.fireEvent('beforeStart', this.element);
-		var limit = this.options.limit;
-		this.limit = {x: [], y: []};
-		for (var z in this.options.modifiers){
-			if (!this.options.modifiers[z]) continue;
-			if (this.options.style) this.value.now[z] = this.element.getStyle(this.options.modifiers[z]).toInt();
-			else this.value.now[z] = this.element[this.options.modifiers[z]];
-			if (this.options.invert) this.value.now[z] *= -1;
-			this.mouse.pos[z] = event.page[z] - this.value.now[z];
-			if (limit && limit[z]){
-				for (var i = 2; i--; i){
-					if ($chk(limit[z][i])) this.limit[z][i] = $lambda(limit[z][i])();
-		if ($type(this.options.grid) == 'number') this.options.grid = {x: this.options.grid, y: this.options.grid};
-		this.document.addEvents({mousemove: this.bound.check, mouseup: this.bound.cancel});
-		this.document.addEvent(this.selection, this.bound.eventStop);
-	check: function(event){
-		var distance = Math.round(Math.sqrt(Math.pow(event.page.x - this.mouse.start.x, 2) + Math.pow(event.page.y - this.mouse.start.y, 2)));
-		if (distance > this.options.snap){
-			this.cancel();
-				mousemove: this.bound.drag,
-				mouseup: this.bound.stop
-			this.fireEvent('start', [this.element, event]).fireEvent('snap', this.element);
-	drag: function(event){
-		this.mouse.now = event.page;
-			this.value.now[z] = this.mouse.now[z] - this.mouse.pos[z];
-			if (this.options.limit && this.limit[z]){
-				if ($chk(this.limit[z][1]) && (this.value.now[z] > this.limit[z][1])){
-					this.value.now[z] = this.limit[z][1];
-				} else if ($chk(this.limit[z][0]) && (this.value.now[z] < this.limit[z][0])){
-					this.value.now[z] = this.limit[z][0];
-			if (this.options.grid[z]) this.value.now[z] -= ((this.value.now[z] - (this.limit[z][0]||0)) % this.options.grid[z]);
-			if (this.options.style) {
-				this.element.setStyle(this.options.modifiers[z], this.value.now[z] + this.options.unit);
-			} else {
-				this.element[this.options.modifiers[z]] = this.value.now[z];
-		this.fireEvent('drag', [this.element, event]);
-	cancel: function(event){
-		this.document.removeEvent('mousemove', this.bound.check);
-		this.document.removeEvent('mouseup', this.bound.cancel);
-		if (event){
-			this.document.removeEvent(this.selection, this.bound.eventStop);
-			this.fireEvent('cancel', this.element);
-	stop: function(event){
-		this.document.removeEvent('mousemove', this.bound.drag);
-		this.document.removeEvent('mouseup', this.bound.stop);
-		if (event) this.fireEvent('complete', [this.element, event]);
-	makeResizable: function(options){
-		var drag = new Drag(this, $merge({modifiers: {x: 'width', y: 'height'}}, options));
-		this.store('resizer', drag);
-		return drag.addEvent('drag', function(){
-			this.fireEvent('resize', drag);
-		}.bind(this));
-script: Drag.Move.js
-description: A Drag extension that provides support for the constraining of draggables to containers and droppables.
-authors:
- - Tom Occhinno
- - Jan Kassens
- - Aaron Newton
- - Scott Kyle
-requires:
- - /Drag
-provides: [Drag.Move]
-Drag.Move = new Class({
-	Extends: Drag,
-	options: {/*
-		onEnter: $empty(thisElement, overed),
-		onLeave: $empty(thisElement, overed),
-		onDrop: $empty(thisElement, overed, event),*/
-		droppables: [],
-		container: false,
-		precalculate: false,
-		includeMargins: true,
-		checkDroppables: true
-	initialize: function(element, options){
-		this.parent(element, options);
-		element = this.element;
-		this.droppables = $$(this.options.droppables);
-		this.container = document.id(this.options.container);
-		if (this.container && $type(this.container) != 'element')
-			this.container = document.id(this.container.getDocument().body);
-		var styles = element.getStyles('left', 'top', 'position');
-		if (styles.left == 'auto' || styles.top == 'auto')
-			element.setPosition(element.getPosition(element.getOffsetParent()));
-		if (styles.position == 'static')
-			element.setStyle('position', 'absolute');
-		this.addEvent('start', this.checkDroppables, true);
-		this.overed = null;
-		if (this.container) this.options.limit = this.calculateLimit();
-		if (this.options.precalculate){
-			this.positions = this.droppables.map(function(el){
-				return el.getCoordinates();
-		this.parent(event);
-	calculateLimit: function(){
-		var offsetParent = this.element.getOffsetParent(),
-			containerCoordinates = this.container.getCoordinates(offsetParent),
-			containerBorder = {},
-			elementMargin = {},
-			elementBorder = {},
-			containerMargin = {},
-			offsetParentPadding = {};
-		['top', 'right', 'bottom', 'left'].each(function(pad){
-			containerBorder[pad] = this.container.getStyle('border-' + pad).toInt();
-			elementBorder[pad] = this.element.getStyle('border-' + pad).toInt();
-			elementMargin[pad] = this.element.getStyle('margin-' + pad).toInt();
-			containerMargin[pad] = this.container.getStyle('margin-' + pad).toInt();
-			offsetParentPadding[pad] = offsetParent.getStyle('padding-' + pad).toInt();
-		}, this);
-		var width = this.element.offsetWidth + elementMargin.left + elementMargin.right,
-			height = this.element.offsetHeight + elementMargin.top + elementMargin.bottom,
-			left = 0,
-			top = 0,
-			right = containerCoordinates.right - containerBorder.right - width,
-			bottom = containerCoordinates.bottom - containerBorder.bottom - height;
-		if (this.options.includeMargins){
-			left += elementMargin.left;
-			top += elementMargin.top;
-		} else {
-			right += elementMargin.right;
-			bottom += elementMargin.bottom;
-		if (this.element.getStyle('position') == 'relative'){
-			var coords = this.element.getCoordinates(offsetParent);
-			coords.left -= this.element.getStyle('left').toInt();
-			coords.top -= this.element.getStyle('top').toInt();
-			left += containerBorder.left - coords.left;
-			top += containerBorder.top - coords.top;
-			right += elementMargin.left - coords.left;
-			bottom += elementMargin.top - coords.top;
-			if (this.container != offsetParent){
-				left += containerMargin.left + offsetParentPadding.left;
-				top += (Browser.Engine.trident4 ? 0 : containerMargin.top) + offsetParentPadding.top;
-		} else {
-			left -= elementMargin.left;
-			top -= elementMargin.top;
-			if (this.container == offsetParent){
-				right -= containerBorder.left;
-				bottom -= containerBorder.top;
-			} else {
-				left += containerCoordinates.left + containerBorder.left;
-				top += containerCoordinates.top + containerBorder.top;
-		return {
-			x: [left, right],
-			y: [top, bottom]
-	checkAgainst: function(el, i){
-		el = (this.positions) ? this.positions[i] : el.getCoordinates();
-		var now = this.mouse.now;
-		return (now.x > el.left && now.x < el.right && now.y < el.bottom && now.y > el.top);
-	checkDroppables: function(){
-		var overed = this.droppables.filter(this.checkAgainst, this).getLast();
-		if (this.overed != overed){
-			if (this.overed) this.fireEvent('leave', [this.element, this.overed]);
-			if (overed) this.fireEvent('enter', [this.element, overed]);
-			this.overed = overed;
-		if (this.options.checkDroppables && this.droppables.length) this.checkDroppables();
-		this.checkDroppables();
-		this.fireEvent('drop', [this.element, this.overed, event]);
-		return this.parent(event);
-	makeDraggable: function(options){
-		var drag = new Drag.Move(this, options);
-		this.store('dragger', drag);
-		return drag;
-script: Slider.js
-description: Class for creating horizontal and vertical slider controls.
-authors:
-requires:
- - /Class.Binds
- - /Drag
- - /Element.Dimensions
-provides: [Slider]
-var Slider = new Class({
-	Binds: ['clickedElement', 'draggedKnob', 'scrolledElement'],
-	options: {/*
-		onTick: $empty(intPosition),
-		onChange: $empty(intStep),
-		onComplete: $empty(strStep),*/
-		onTick: function(position){
-			if (this.options.snap) position = this.toPosition(this.step);
-			this.knob.setStyle(this.property, position);
-		initialStep: 0,
-		snap: false,
-		offset: 0,
-		range: false,
-		wheel: false,
-		steps: 100,
-		mode: 'horizontal'
-	initialize: function(element, knob, options){
-		this.setOptions(options);
-		this.element = document.id(element);
-		this.knob = document.id(knob);
-		this.previousChange = this.previousEnd = this.step = -1;
-		var offset, limit = {}, modifiers = {'x': false, 'y': false};
-		switch (this.options.mode){
-			case 'vertical':
-				this.axis = 'y';
-				this.property = 'top';
-				offset = 'offsetHeight';
-				break;
-			case 'horizontal':
-				this.axis = 'x';
-				this.property = 'left';
-				offset = 'offsetWidth';
-		this.full = this.element.measure(function(){
-			this.half = this.knob[offset] / 2;
-			return this.element[offset] - this.knob[offset] + (this.options.offset * 2);
-		}.bind(this));
-		this.min = $chk(this.options.range[0]) ? this.options.range[0] : 0;
-		this.max = $chk(this.options.range[1]) ? this.options.range[1] : this.options.steps;
-		this.range = this.max - this.min;
-		this.steps = this.options.steps || this.full;
-		this.stepSize = Math.abs(this.range) / this.steps;
-		this.stepWidth = this.stepSize * this.full / Math.abs(this.range) ;
-		this.knob.setStyle('position', 'relative').setStyle(this.property, this.options.initialStep ? this.toPosition(this.options.initialStep) : - this.options.offset);
-		modifiers[this.axis] = this.property;
-		limit[this.axis] = [- this.options.offset, this.full - this.options.offset];
-		var dragOptions = {
-			snap: 0,
-			limit: limit,
-			modifiers: modifiers,
-			onDrag: this.draggedKnob,
-			onStart: this.draggedKnob,
-			onBeforeStart: (function(){
-				this.isDragging = true;
-			}).bind(this),
-			onCancel: function() {
-				this.isDragging = false;
-			}.bind(this),
-			onComplete: function(){
-				this.draggedKnob();
-				this.end();
-			}.bind(this)
-		if (this.options.snap){
-			dragOptions.grid = Math.ceil(this.stepWidth);
-			dragOptions.limit[this.axis][1] = this.full;
-		this.drag = new Drag(this.knob, dragOptions);
-		this.attach();
-		this.element.addEvent('mousedown', this.clickedElement);
-		if (this.options.wheel) this.element.addEvent('mousewheel', this.scrolledElement);
-		this.drag.attach();
-		return this;
-	detach: function(){
-		this.element.removeEvent('mousedown', this.clickedElement);
-		this.element.removeEvent('mousewheel', this.scrolledElement);
-		this.drag.detach();
-		return this;
-	set: function(step){
-		if (!((this.range > 0) ^ (step < this.min))) step = this.min;
-		if (!((this.range > 0) ^ (step > this.max))) step = this.max;
-		this.step = Math.round(step);
-		this.checkStep();
-		this.fireEvent('tick', this.toPosition(this.step));
-		this.end();
-		return this;
-	clickedElement: function(event){
-		if (this.isDragging || event.target == this.knob) return;
-		var dir = this.range < 0 ? -1 : 1;
-		var position = event.page[this.axis] - this.element.getPosition()[this.axis] - this.half;
-		position = position.limit(-this.options.offset, this.full -this.options.offset);
-		this.step = Math.round(this.min + dir * this.toStep(position));
-		this.checkStep();
-		this.fireEvent('tick', position);
-		this.end();
-	scrolledElement: function(event){
-		var mode = (this.options.mode == 'horizontal') ? (event.wheel < 0) : (event.wheel > 0);
-		this.set(mode ? this.step - this.stepSize : this.step + this.stepSize);
-		event.stop();
-	draggedKnob: function(){
-		var position = this.drag.value.now[this.axis];
-		this.checkStep();
-	checkStep: function(){
-		if (this.previousChange != this.step){
-			this.previousChange = this.step;
-			this.fireEvent('change', this.step);
-	end: function(){
-		if (this.previousEnd !== this.step){
-			this.previousEnd = this.step;
-			this.fireEvent('complete', this.step + '');
-	toStep: function(position){
-		var step = (position + this.options.offset) * this.stepSize / this.full * this.steps;
-		return this.options.steps ? Math.round(step -= step % this.stepSize) : step;
-	toPosition: function(step){
-		return (this.full * Math.abs(this.min - step)) / (this.steps * this.stepSize) - this.options.offset;
-script: Sortables.js
-description: Class for creating a drag and drop sorting interface for lists of items.
-authors:
- - Tom Occhino
-requires:
- - /Drag.Move
-provides: [Slider]
-var Sortables = new Class({
-	options: {/*
-		onSort: $empty(element, clone),
-		onStart: $empty(element, clone),
-		onComplete: $empty(element),*/
-		snap: 4,
-		opacity: 1,
-		clone: false,
-		revert: false,
-		handle: false,
-		constrain: false
-	initialize: function(lists, options){
-		this.elements = [];
-		this.lists = [];
-		this.idle = true;
-		this.addLists($$(document.id(lists) || lists));
-		if (!this.options.clone) this.options.revert = false;
-		if (this.options.revert) this.effect = new Fx.Morph(null, $merge({duration: 250, link: 'cancel'}, this.options.revert));
-		this.addLists(this.lists);
-		return this;
-		this.lists = this.removeLists(this.lists);
-		return this;
-	addItems: function(){
-		Array.flatten(arguments).each(function(element){
-			this.elements.push(element);
-			var start = element.retrieve('sortables:start', this.start.bindWithEvent(this, element));
-			(this.options.handle ? element.getElement(this.options.handle) || element : element).addEvent('mousedown', start);
-		}, this);
-		return this;
-	addLists: function(){
-		Array.flatten(arguments).each(function(list){
-			this.lists.push(list);
-			this.addItems(list.getChildren());
-		}, this);
-		return this;
-	removeItems: function(){
-		return $$(Array.flatten(arguments).map(function(element){
-			this.elements.erase(element);
-			var start = element.retrieve('sortables:start');
-			(this.options.handle ? element.getElement(this.options.handle) || element : element).removeEvent('mousedown', start);
-			return element;
-		}, this));
-	removeLists: function(){
-		return $$(Array.flatten(arguments).map(function(list){
-			this.lists.erase(list);
-			this.removeItems(list.getChildren());
-			return list;
-		}, this));
-	getClone: function(event, element){
-		if (!this.options.clone) return new Element('div').inject(document.body);
-		if ($type(this.options.clone) == 'function') return this.options.clone.call(this, event, element, this.list);
-		var clone = element.clone(true).setStyles({
-			margin: '0px',
-			position: 'absolute',
-			visibility: 'hidden',
-			'width': element.getStyle('width')
-		//prevent the duplicated radio inputs from unchecking the real one
-		if (clone.get('html').test('radio')) {
-			clone.getElements('input[type=radio]').each(function(input, i) {
-				input.set('name', 'clone_' + i);
-		return clone.inject(this.list).setPosition(element.getPosition(element.getOffsetParent()));
-	getDroppables: function(){
-		var droppables = this.list.getChildren();
-		if (!this.options.constrain) droppables = this.lists.concat(droppables).erase(this.list);
-		return droppables.erase(this.clone).erase(this.element);
-	insert: function(dragging, element){
-		var where = 'inside';
-		if (this.lists.contains(element)){
-			this.list = element;
-			this.drag.droppables = this.getDroppables();
-		} else {
-			where = this.element.getAllPrevious().contains(element) ? 'before' : 'after';
-		this.element.inject(element, where);
-		this.fireEvent('sort', [this.element, this.clone]);
-	start: function(event, element){
-		if (!this.idle) return;
-		this.idle = false;
-		this.element = element;
-		this.opacity = element.get('opacity');
-		this.list = element.getParent();
-		this.clone = this.getClone(event, element);
-		this.drag = new Drag.Move(this.clone, {
-			snap: this.options.snap,
-			container: this.options.constrain && this.element.getParent(),
-			droppables: this.getDroppables(),
-			onSnap: function(){
-				event.stop();
-				this.clone.setStyle('visibility', 'visible');
-				this.element.set('opacity', this.options.opacity || 0);
-				this.fireEvent('start', [this.element, this.clone]);
-			}.bind(this),
-			onEnter: this.insert.bind(this),
-			onCancel: this.reset.bind(this),
-			onComplete: this.end.bind(this)
-		this.clone.inject(this.element, 'before');
-		this.drag.start(event);
-	end: function(){
-		this.element.set('opacity', this.opacity);
-		if (this.effect){
-			var dim = this.element.getStyles('width', 'height');
-			var pos = this.clone.computePosition(this.element.getPosition(this.clone.offsetParent));
-			this.effect.element = this.clone;
-			this.effect.start({
-				top: pos.top,
-				left: pos.left,
-				width: dim.width,
-				height: dim.height,
-				opacity: 0.25
-			}).chain(this.reset.bind(this));
-		} else {
-			this.reset();
-		this.idle = true;
-		this.clone.destroy();
-		this.fireEvent('complete', this.element);
-	serialize: function(){
-		var params = Array.link(arguments, {modifier: Function.type, index: $defined});
-		var serial = this.lists.map(function(list){
-			return list.getChildren().map(params.modifier || function(element){
-				return element.get('id');
-			}, this);
-		}, this);
-		var index = params.index;
-		if (this.lists.length == 1) index = 0;
-		return $chk(index) && index >= 0 && index < this.lists.length ? serial[index] : serial;
-script: Request.JSONP.js
-description: Defines Request.JSONP, a class for cross domain javascript via script injection.
-authors:
- - Aaron Newton
- - Guillermo Rauch
-requires:
- - core:1.2.4/Request
- - /Log
-provides: [Request.JSONP]
-Request.JSONP = new Class({
-	Implements: [Chain, Events, Options, Log],
-	options: {/*
-		onRetry: $empty(intRetries),
-		onRequest: $empty(scriptElement),
-		onComplete: $empty(data),
-		onSuccess: $empty(data),
-		onCancel: $empty(),
-		log: false,
-		url: '',
-		data: {},
-		retries: 0,
-		timeout: 0,
-		link: 'ignore',
-		callbackKey: 'callback',
-		injectScript: document.head
-	initialize: function(options){
-		if (this.options.log) this.enableLog();
-		this.running = false;
-		this.requests = 0;
-		this.triesRemaining = [];
-	check: function(){
-		if (!this.running) return true;
-		switch (this.options.link){
-			case 'cancel': this.cancel(); return true;
-			case 'chain': this.chain(this.caller.bind(this, arguments)); return false;
-		return false;
-	send: function(options){
-		if (!$chk(arguments[1]) && !this.check(options)) return this;
-		var type = $type(options),
-				old = this.options,
-				index = $chk(arguments[1]) ? arguments[1] : this.requests++;
-		if (type == 'string' || type == 'element') options = {data: options};
-		options = $extend({data: old.data, url: old.url}, options);
-		if (!$chk(this.triesRemaining[index])) this.triesRemaining[index] = this.options.retries;
-		var remaining = this.triesRemaining[index];
-		(function(){
-			var script = this.getScript(options);
-			this.log('JSONP retrieving script with url: ' + script.get('src'));
-			this.fireEvent('request', script);
-			this.running = true;
-			(function(){
-				if (remaining){
-					this.triesRemaining[index] = remaining - 1;
-					if (script){
-						script.destroy();
-						this.send(options, index).fireEvent('retry', this.triesRemaining[index]);
-				} else if(script && this.options.timeout){
-					script.destroy();
-					this.cancel().fireEvent('failure');
-			}).delay(this.options.timeout, this);
-		}).delay(Browser.Engine.trident ? 50 : 0, this);
-		return this;
-	cancel: function(){
-		if (!this.running) return this;
-		this.fireEvent('cancel');
-		return this;
-	getScript: function(options){
-		var index = Request.JSONP.counter,
-				data;
-		Request.JSONP.counter++;
-		switch ($type(options.data)){
-			case 'element': data = document.id(options.data).toQueryString(); break;
-			case 'object': case 'hash': data = Hash.toQueryString(options.data);
-		var src = options.url +
-			 (options.url.test('\\?') ? '&' :'?') +
-			 (options.callbackKey || this.options.callbackKey) +
-			 '=Request.JSONP.request_map.request_'+ index +
-			 (data ? '&' + data : '');
-		if (src.length > 2083) this.log('JSONP '+ src +' will fail in Internet Explorer, which enforces a 2083 bytes length limit on URIs');
-		var script = new Element('script', {type: 'text/javascript', src: src});
-		Request.JSONP.request_map['request_' + index] = function(){ this.success(arguments, script); }.bind(this);
-		return script.inject(this.options.injectScript);
-	success: function(args, script){
-		if (script) script.destroy();
-		this.log('JSONP successfully retrieved: ', args);
-		this.fireEvent('complete', args).fireEvent('success', args).callChain();
-Request.JSONP.counter = 0;
-Request.JSONP.request_map = {};/*
-script: Request.Queue.js
-description: Controls several instances of Request and its variants to run only one request at a time.
-authors:
- - Aaron Newton
-requires:
- - /Log
-provides: [Request.Queue]
-Request.Queue = new Class({
-	Implements: [Options, Events],
-	Binds: ['attach', 'request', 'complete', 'cancel', 'success', 'failure', 'exception'],
-	options: {/*
-		onRequest: $empty(argsPassedToOnRequest),
-		onSuccess: $empty(argsPassedToOnSuccess),
-		onComplete: $empty(argsPassedToOnComplete),
-		onCancel: $empty(argsPassedToOnCancel),
-		onException: $empty(argsPassedToOnException),
-		onFailure: $empty(argsPassedToOnFailure),
-		onEnd: $empty,
-		stopOnFailure: true,
-		autoAdvance: true,
-		concurrent: 1,
-		requests: {}
-		if(options){
-			var requests = options.requests;
-			delete options.requests;
-		this.requests = new Hash;
-		this.queue = [];
-		this.reqBinders = {};
-		if(requests) this.addRequests(requests);
-	addRequest: function(name, request){
-		this.requests.set(name, request);
-		this.attach(name, request);
-		return this;
-	addRequests: function(obj){
-		$each(obj, function(req, name){
-			this.addRequest(name, req);
-		}, this);
-		return this;
-	getName: function(req){
-		return this.requests.keyOf(req);
-	attach: function(name, req){
-		if (req._groupSend) return this;
-		['request', 'complete', 'cancel', 'success', 'failure', 'exception'].each(function(evt){
-			if(!this.reqBinders[name]) this.reqBinders[name] = {};
-			this.reqBinders[name][evt] = function(){
-				this['on' + evt.capitalize()].apply(this, [name, req].extend(arguments));
-			}.bind(this);
-			req.addEvent(evt, this.reqBinders[name][evt]);
-		}, this);
-		req._groupSend = req.send;
-		req.send = function(options){
-			this.send(name, options);
-			return req;
-		}.bind(this);
-		return this;
-	removeRequest: function(req){
-		var name = $type(req) == 'object' ? this.getName(req) : req;
-		if (!name && $type(name) != 'string') return this;
-		req = this.requests.get(name);
-		if (!req) return this;
-			req.removeEvent(evt, this.reqBinders[name][evt]);
-		}, this);
-		req.send = req._groupSend;
-		delete req._groupSend;
-		return this;
-	getRunning: function(){
-		return this.requests.filter(function(r){
-			return r.running;
-	isRunning: function(){
-		return !!(this.getRunning().getKeys().length);
-	send: function(name, options){
-		var q = function(){
-			this.requests.get(name)._groupSend(options);
-			this.queue.erase(q);
-		}.bind(this);
-		q.name = name;
-		if (this.getRunning().getKeys().length >= this.options.concurrent || (this.error && this.options.stopOnFailure)) this.queue.push(q);
-		else q();
-		return this;
-	hasNext: function(name){
-		return (!name) ? !!this.queue.length : !!this.queue.filter(function(q){ return q.name == name; }).length;
-	resume: function(){
-		this.error = false;
-		(this.options.concurrent - this.getRunning().getKeys().length).times(this.runNext, this);
-		return this;
-	runNext: function(name){
-		if (!this.queue.length) return this;
-		if (!name){
-			this.queue[0]();
-		} else {
-			var found;
-			this.queue.each(function(q){
-				if (!found && q.name == name){
-					found = true;
-					q();
-		return this;
-	runAll: function() {
-		this.queue.each(function(q) {
-			q();
-		return this;
-	clear: function(name){
-		if (!name){
-			this.queue.empty();
-		} else {
-			this.queue = this.queue.map(function(q){
-				if (q.name != name) return q;
-				else return false;
-			}).filter(function(q){ return q; });
-		return this;
-	cancel: function(name){
-		this.requests.get(name).cancel();
-		return this;
-	onRequest: function(){
-		this.fireEvent('request', arguments);
-		this.fireEvent('complete', arguments);
-		if (!this.queue.length) this.fireEvent('end');
-	onCancel: function(){
-		if (this.options.autoAdvance && !this.error) this.runNext();
-		this.fireEvent('cancel', arguments);
-	onSuccess: function(){
-		this.fireEvent('success', arguments);
-	onFailure: function(){
-		this.error = true;
-		if (!this.options.stopOnFailure && this.options.autoAdvance) this.runNext();
-		this.fireEvent('failure', arguments);
-	onException: function(){
-		this.fireEvent('exception', arguments);
-script: Request.Periodical.js
-description: Requests the same URL to pull data from a server but increases the intervals if no data is returned to reduce the load
-authors:
- - Christoph Pojer
-requires:
- - /MooTools.More
-provides: [Request.Periodical]
-Request.implement({
-	options: {
-		initialDelay: 5000,
-		delay: 5000,
-		limit: 60000
-	startTimer: function(data){
-		var fn = function(){
-			if (!this.running) this.send({data: data});
-		this.timer = fn.delay(this.options.initialDelay, this);
-		this.lastDelay = this.options.initialDelay;
-		this.completeCheck = function(response){
-			$clear(this.timer);
-			this.lastDelay = (response) ? this.options.delay : (this.lastDelay + this.options.delay).min(this.options.limit);
-			this.timer = fn.delay(this.lastDelay, this);
-		return this.addEvent('complete', this.completeCheck);
-	stopTimer: function(){
-		return this.removeEvent('complete', this.completeCheck);
-script: Assets.js
-description: Provides methods to dynamically load JavaScript, CSS, and Image files into the document.
-authors:
-requires:
- - core:1.2.4/Element.Event
- - /MooTools.More
-provides: [Assets]
-var Asset = {
-	javascript: function(source, properties){
-		properties = $extend({
-			onload: $empty,
-			document: document,
-			check: $lambda(true)
-		}, properties);
-		if (properties.onLoad) properties.onload = properties.onLoad;
-		var script = new Element('script', {src: source, type: 'text/javascript'});
-		var load = properties.onload.bind(script),
-			check = properties.check,
-			doc = properties.document;
-		delete properties.onload;
-		delete properties.check;
-		delete properties.document;
-		script.addEvents({
-			load: load,
-			readystatechange: function(){
-				if (['loaded', 'complete'].contains(this.readyState)) load();
-		}).set(properties);
-		if (Browser.Engine.webkit419) var checker = (function(){
-			if (!$try(check)) return;
-			$clear(checker);
-			load();
-		}).periodical(50);
-		return script.inject(doc.head);
-	css: function(source, properties){
-		return new Element('link', $merge({
-			rel: 'stylesheet',
-			media: 'screen',
-			type: 'text/css',
-			href: source
-		}, properties)).inject(document.head);
-	image: function(source, properties){
-		properties = $merge({
-			onload: $empty,
-			onabort: $empty,
-			onerror: $empty
-		}, properties);
-		var image = new Image();
-		var element = document.id(image) || new Element('img');
-		['load', 'abort', 'error'].each(function(name){
-			var type = 'on' + name;
-			var cap = name.capitalize();
-			if (properties['on' + cap]) properties[type] = properties['on' + cap];
-			var event = properties[type];
-			delete properties[type];
-			image[type] = function(){
-				if (!image) return;
-				if (!element.parentNode){
-					element.width = image.width;
-					element.height = image.height;
-				image = image.onload = image.onabort = image.onerror = null;
-				event.delay(1, element, element);
-				element.fireEvent(name, element, 1);
-		image.src = element.src = source;
-		if (image && image.complete) image.onload.delay(1);
-		return element.set(properties);
-	images: function(sources, options){
-		options = $merge({
-			onComplete: $empty,
-			onProgress: $empty,
-			onError: $empty,
-			properties: {}
-		}, options);
-		sources = $splat(sources);
-		var images = [];
-		var counter = 0;
-		return new Elements(sources.map(function(source){
-			return Asset.image(source, $extend(options.properties, {
-				onload: function(){
-					options.onProgress.call(this, counter, sources.indexOf(source));
-					counter++;
-					if (counter == sources.length) options.onComplete();
-				onerror: function(){
-					options.onError.call(this, counter, sources.indexOf(source));
-					counter++;
-script: Color.js
-description: Class for creating and manipulating colors in JavaScript. Supports HSB -> RGB Conversions and vice versa.
-authors:
-requires:
- - core:1.2.4/Array
- - core:1.2.4/String
- - core:1.2.4/Number
- - core:1.2.4/Hash
- - core:1.2.4/Function
- - core:1.2.4/$util
-provides: [Color]
-var Color = new Native({
-	initialize: function(color, type){
-		if (arguments.length >= 3){
-			type = 'rgb'; color = Array.slice(arguments, 0, 3);
-		} else if (typeof color == 'string'){
-			if (color.match(/rgb/)) color = color.rgbToHex().hexToRgb(true);
-			else if (color.match(/hsb/)) color = color.hsbToRgb();
-			else color = color.hexToRgb(true);
-		type = type || 'rgb';
-		switch (type){
-			case 'hsb':
-				var old = color;
-				color = color.hsbToRgb();
-				color.hsb = old;
-			break;
-			case 'hex': color = color.hexToRgb(true); break;
-		color.rgb = color.slice(0, 3);
-		color.hsb = color.hsb || color.rgbToHsb();
-		color.hex = color.rgbToHex();
-		return $extend(color, this);
-Color.implement({
-	mix: function(){
-		var colors = Array.slice(arguments);
-		var alpha = ($type(colors.getLast()) == 'number') ? colors.pop() : 50;
-		var rgb = this.slice();
-		colors.each(function(color){
-			color = new Color(color);
-			for (var i = 0; i < 3; i++) rgb[i] = Math.round((rgb[i] / 100 * (100 - alpha)) + (color[i] / 100 * alpha));
-		return new Color(rgb, 'rgb');
-	invert: function(){
-		return new Color(this.map(function(value){
-			return 255 - value;
-	setHue: function(value){
-		return new Color([value, this.hsb[1], this.hsb[2]], 'hsb');
-	setSaturation: function(percent){
-		return new Color([this.hsb[0], percent, this.hsb[2]], 'hsb');
-	setBrightness: function(percent){
-		return new Color([this.hsb[0], this.hsb[1], percent], 'hsb');
-var $RGB = function(r, g, b){
-	return new Color([r, g, b], 'rgb');
-var $HSB = function(h, s, b){
-	return new Color([h, s, b], 'hsb');
-var $HEX = function(hex){
-	return new Color(hex, 'hex');
-Array.implement({
-	rgbToHsb: function(){
-		var red = this[0],
-				green = this[1],
-				blue = this[2],
-				hue = 0;
-		var max = Math.max(red, green, blue),
-				min = Math.min(red, green, blue);
-		var delta = max - min;
-		var brightness = max / 255,
-				saturation = (max != 0) ? delta / max : 0;
-		if(saturation != 0) {
-			var rr = (max - red) / delta;
-			var gr = (max - green) / delta;
-			var br = (max - blue) / delta;
-			if (red == max) hue = br - gr;
-			else if (green == max) hue = 2 + rr - br;
-			else hue = 4 + gr - rr;
-			hue /= 6;
-			if (hue < 0) hue++;
-		return [Math.round(hue * 360), Math.round(saturation * 100), Math.round(brightness * 100)];
-	hsbToRgb: function(){
-		var br = Math.round(this[2] / 100 * 255);
-		if (this[1] == 0){
-			return [br, br, br];
-		} else {
-			var hue = this[0] % 360;
-			var f = hue % 60;
-			var p = Math.round((this[2] * (100 - this[1])) / 10000 * 255);
-			var q = Math.round((this[2] * (6000 - this[1] * f)) / 600000 * 255);
-			var t = Math.round((this[2] * (6000 - this[1] * (60 - f))) / 600000 * 255);
-			switch (Math.floor(hue / 60)){
-				case 0: return [br, t, p];
-				case 1: return [q, br, p];
-				case 2: return [p, br, t];
-				case 3: return [p, q, br];
-				case 4: return [t, p, br];
-				case 5: return [br, p, q];
-		return false;
-String.implement({
-		var rgb = this.match(/\d{1,3}/g);
-		return (rgb) ? rgb.rgbToHsb() : null;
-		var hsb = this.match(/\d{1,3}/g);
-		return (hsb) ? hsb.hsbToRgb() : null;
-script: Group.js
-description: Class for monitoring collections of events
-authors:
-requires:
- - /MooTools.More
-provides: [Group]
-var Group = new Class({
-	initialize: function(){
-		this.instances = Array.flatten(arguments);
-		this.events = {};
-		this.checker = {};
-	addEvent: function(type, fn){
-		this.checker[type] = this.checker[type] || {};
-		this.events[type] = this.events[type] || [];
-		if (this.events[type].contains(fn)) return false;
-		else this.events[type].push(fn);
-		this.instances.each(function(instance, i){
-			instance.addEvent(type, this.check.bind(this, [type, instance, i]));
-		}, this);
-		return this;
-	check: function(type, instance, i){
-		this.checker[type][i] = true;
-		var every = this.instances.every(function(current, j){
-			return this.checker[type][j] || false;
-		}, this);
-		if (!every) return;
-		this.checker[type] = {};
-		this.events[type].each(function(event){
-			event.call(this, this.instances, instance);
-		}, this);
-script: Hash.Cookie.js
-description: Class for creating, reading, and deleting Cookies in JSON format.
-authors:
- - Aaron Newton
-requires:
- - core:1.2.4/Cookie
- - core:1.2.4/JSON
- - /MooTools.More
-provides: [Hash.Cookie]
-Hash.Cookie = new Class({
-	Extends: Cookie,
-	options: {
-		autoSave: true
-	initialize: function(name, options){
-		this.parent(name, options);
-		this.load();
-	save: function(){
-		var value = JSON.encode(this.hash);
-		if (!value || value.length > 4096) return false; //cookie would be truncated!
-		if (value == '{}') this.dispose();
-		else this.write(value);
-		return true;
-	load: function(){
-		this.hash = new Hash(JSON.decode(this.read(), true));
-		return this;
-Hash.each(Hash.prototype, function(method, name){
-	if (typeof method == 'function') Hash.Cookie.implement(name, function(){
-		var value = method.apply(this.hash, arguments);
-		if (this.options.autoSave) this.save();
-		return value;
-script: HtmlTable.js
-description: Builds table elements with methods to add rows.
-authors:
- - Aaron Newton
-requires:
- - /Class.Occlude
-provides: [HtmlTable]
-var HtmlTable = new Class({
-	Implements: [Options, Events, Class.Occlude],
-	options: {
-		properties: {
-			cellpadding: 0,
-			cellspacing: 0,
-			border: 0
-		rows: [],
-		headers: [],
-		footers: []
-	property: 'HtmlTable',
-		var params = Array.link(arguments, {options: Object.type, table: Element.type});
-		this.setOptions(params.options);
-		this.element = params.table || new Element('table', this.options.properties);
-		if (this.occlude()) return this.occluded;
-		this.build();
-	build: function(){
-		this.element.store('HtmlTable', this);
-		this.body = document.id(this.element.tBodies[0]) || new Element('tbody').inject(this.element);
-		$$(this.body.rows);
-		if (this.options.headers.length) this.setHeaders(this.options.headers);
-		else this.thead = document.id(this.element.tHead);
-		if (this.thead) this.head = document.id(this.thead.rows[0]);
-		if (this.options.footers.length) this.setFooters(this.options.footers);
-		this.tfoot = document.id(this.element.tFoot);
-		if (this.tfoot) this.foot = document.id(this.thead.rows[0]);
-		this.options.rows.each(function(row){
-			this.push(row);
-		}, this);
-		['adopt', 'inject', 'wraps', 'grab', 'replaces', 'dispose'].each(function(method){
-				this[method] = this.element[method].bind(this.element);
-		}, this);
-	toElement: function(){
-		return this.element;
-	empty: function(){
-		this.body.empty();
-		return this;
-	set: function(what, items) {
-		var target = (what == 'headers') ? 'tHead' : 'tFoot';
-		this[target.toLowerCase()] = (document.id(this.element[target]) || new Element(target.toLowerCase()).inject(this.element, 'top')).empty();
-		var data = this.push(items, {}, this[target.toLowerCase()], what == 'headers' ? 'th' : 'td');
-		if (what == 'headers') this.head = document.id(this.thead.rows[0]);
-		else this.foot = document.id(this.thead.rows[0]);
-		return data;
-	setHeaders: function(headers){
-		this.set('headers', headers);
-		return this;
-	setFooters: function(footers){
-		this.set('footers', footers);
-		return this;
-	push: function(row, rowProperties, target, tag){
-		var tds = row.map(function(data){
-			var td = new Element(tag || 'td', data.properties),
-				type = data.content || data || '',
-				element = document.id(type);
-			if($type(type) != 'string' && element) td.adopt(element);
-			else td.set('html', type);
-			return td;
-		return {
-			tr: new Element('tr', rowProperties).inject(target || this.body).adopt(tds),
-			tds: tds
-script: HtmlTable.Zebra.js
-description: Builds a stripy table with methods to add rows.
-authors:
- - Harald Kirschner
- - Aaron Newton
-requires:
- - /HtmlTable
- - /Class.refactor
-provides: [HtmlTable.Zebra]
-HtmlTable = Class.refactor(HtmlTable, {
-	options: {
-		classZebra: 'table-tr-odd',
-		zebra: true
-		this.previous.apply(this, arguments);
-		if (this.occluded) return this.occluded;
-		if (this.options.zebra) this.updateZebras();
-	updateZebras: function(){
-		Array.each(this.body.rows, this.zebra, this);
-	zebra: function(row, i){
-		return row[((i % 2) ? 'remove' : 'add')+'Class'](this.options.classZebra);
-	push: function(){
-		var pushed = this.previous.apply(this, arguments);
-		return pushed;
-script: HtmlTable.Sort.js
-description: Builds a stripy, sortable table with methods to add rows.
-authors:
- - Aaron Newton
-requires:
- - core:1.2.4/Hash
- - /HtmlTable
- - /Class.refactor
- - /Element.Delegation
- - /Date
-provides: [HtmlTable.Sort]
-	options: {/*
-		onSort: $empty, */
-		sortIndex: 0,
-		sortReverse: false,
-		parsers: [],
-		defaultParser: 'string',
-		classSortable: 'table-sortable',
-		classHeadSort: 'table-th-sort',
-		classHeadSortRev: 'table-th-sort-rev',
-		classNoSort: 'table-th-nosort',
-		classGroupHead: 'table-tr-group-head',
-		classGroup: 'table-tr-group',
-		classCellSort: 'table-td-sort',
-		classSortSpan: 'table-th-sort-span',
-		sortable: false
-	initialize: function () {
-		this.sorted = {index: null, dir: 1};
-		this.bound = {
-			headClick: this.headClick.bind(this)
-		this.sortSpans = new Elements();
-		if (this.options.sortable) {
-			this.enableSort();
-			if (this.options.sortIndex != null) this.sort(this.options.sortIndex, this.options.sortReverse);
-	attachSorts: function(attach){
-		this.element.removeEvents('click:relay(th)');
-		this.element[$pick(attach, true) ? 'addEvent' : 'removeEvent']('click:relay(th)', this.bound.headClick);
-	setHeaders: function(){
-		if (this.sortEnabled) this.detectParsers();
-	detectParsers: function(force){
-		if (!this.head) return;
-		var parsers = this.options.parsers,
-				rows = this.body.rows;
-		// auto-detect
-		this.parsers = $$(this.head.cells).map(function(cell, index) {
-			if (!force && (cell.hasClass(this.options.classNoSort) || cell.retrieve('htmltable-parser'))) return cell.retrieve('htmltable-parser');
-			var thDiv = new Element('div');
-			$each(cell.childNodes, function(node) {
-				thDiv.adopt(node);
-			thDiv.inject(cell);
-			var sortSpan = new Element('span', {'html': '&#160;', 'class': this.options.classSortSpan}).inject(thDiv, 'top');
-			this.sortSpans.push(sortSpan);
-			var parser = parsers[index],
-					cancel;
-			switch ($type(parser)) {
-				case 'function': parser = {convert: parser}; cancel = true; break;
-				case 'string': parser = parser; cancel = true; break;
-			if (!cancel) {
-				HtmlTable.Parsers.some(function(current) {
-					var match = current.match;
-					if (!match) return false;
-					for (var i = 0, j = rows.length; i < j; i++) {
-						var text = $(rows[i].cells[index]).get('html').clean();
-						if (text && match.test(text)) {
-							parser = current;
-							return true;
-			if (!parser) parser = this.options.defaultParser;
-			cell.store('htmltable-parser', parser);
-			return parser;
-		}, this);
-	headClick: function(event, el) {
-		console.log(el);
-		if (!this.head || el.hasClass(this.options.classNoSort)) return;
-		var index = Array.indexOf(this.head.cells, el);
-		this.sort(index);
-		return false;
-	sort: function(index, reverse, pre) {
-		pre = !!(pre);
-		var classCellSort = this.options.classCellSort;
-		var classGroup = this.options.classGroup,
-				classGroupHead = this.options.classGroupHead;
-		if (!pre) {
-			if (index != null) {
-				if (this.sorted.index == index) {
-					this.sorted.reverse = !(this.sorted.reverse);
-				} else {
-					if (this.sorted.index != null) {
-						this.sorted.reverse = false;
-						this.head.cells[this.sorted.index].removeClass(this.options.classHeadSort).removeClass(this.options.classHeadSortRev);
-					} else {
-						this.sorted.reverse = true;
-					this.sorted.index = index;
-			} else {
-				index = this.sorted.index;
-			if (reverse != null) this.sorted.reverse = reverse;
-			var head = document.id(this.head.cells[index]);
-			if (head) {
-				head.addClass(this.options.classHeadSort);
-				if (this.sorted.reverse) head.addClass(this.options.classHeadSortRev);
-				else head.removeClass(this.options.classHeadSortRev);
-			this.body.getElements('td').removeClass(this.options.classCellSort);
-		var parser = this.parsers[index];
-		if ($type(parser) == 'string') parser = HtmlTable.Parsers.get(parser);
-		if (!parser) return;
-		if (!Browser.Engine.trident) {
-			var rel = this.body.getParent();
-			this.body.dispose();
-		var data = Array.map(this.body.rows, function(row, i) {
-			var value = parser.convert.call(document.id(row.cells[index]));
-			return {
-				position: i,
-				value: value,
-				toString:  function() {
-					return value.toString();
-		}, this);
-		data.reverse(true);
-		data.sort(function(a, b){
-			if (a.value === b.value) return 0;
-			return a.value > b.value ? 1 : -1;
-		if (!this.sorted.reverse) data.reverse(true);
-		var i = data.length, body = this.body;
-		var j, position, entry, group;
-		while (i) {
-			var item = data[--i];
-			position = item.position;
-			var row = body.rows[position];
-			if (row.disabled) continue;
-			if (!pre) {
-				if (group === item.value) {
-					row.removeClass(classGroupHead).addClass(classGroup);
-				} else {
-					group = item.value;
-					row.removeClass(classGroup).addClass(classGroupHead);
-				if (this.zebra) this.zebra(row, i);
-				row.cells[index].addClass(classCellSort);
-			body.appendChild(row);
-			for (j = 0; j < i; j++) {
-				if (data[j].position > position) data[j].position--;
-		data = null;
-		if (rel) rel.grab(body);
-		return this.fireEvent('sort', [body, index]);
-	reSort: function(){
-		if (this.sortEnabled) this.sort.call(this, this.sorted.index, this.sorted.reverse);
-		return this;
-	enableSort: function(){
-		this.element.addClass(this.options.classSortable);
-		this.attachSorts(true);
-		this.detectParsers();
-		this.sortEnabled = true;
-		return this;
-	disableSort: function(){
-		this.element.removeClass(this.options.classSortable);
-		this.attachSorts(false);
-		this.sortSpans.each(function(span) { span.destroy(); });
-		this.sortSpans.empty();
-		this.sortEnabled = false;
-		return this;
-HtmlTable.Parsers = new Hash({
-	'date': {
-		match: /^\d{2}[-\/ ]\d{2}[-\/ ]\d{2,4}$/,
-		convert: function() {
-			return Date.parse(this.get('text')).format('db');
-		type: 'date'
-	'input-checked': {
-		match: / type="(radio|checkbox)" /,
-			return this.getElement('input').checked;
-	'input-value': {
-		match: /<input/,
-			return this.getElement('input').value;
-	'number': {
-		match: /^\d+[^\d.,]*$/,
-			return this.get('text').toInt();
-		number: true
-	'numberLax': {
-		match: /^[^\d]+\d+$/,
-			return this.get('text').replace(/[^-?^0-9]/, '').toInt();
-		number: true
-	'float': {
-		match: /^[\d]+\.[\d]+/,
-			return this.get('text').replace(/[^-?^\d.]/, '').toFloat();
-		number: true
-	'floatLax': {
-		match: /^[^\d]+[\d]+\.[\d]+$/,
-			return this.get('text').replace(/[^-?^\d.]/, '');
-		number: true
-	'string': {
-		match: null,
-			return this.get('text');
-	'title': {
-		match: null,
-			return this.title;
-script: Keyboard.js
-description: KeyboardEvents used to intercept events on a class for keyboard and format modifiers in a specific order so as to make alt+shift+c the same as shift+alt+c.
-license: MIT-style license
-authors:
- - Perrin Westrich
- - Aaron Newton
- - Scott Kyle
-requires:
- - /Log
-provides: [Keyboard]
-(function(){
-	var Keyboard = this.Keyboard = new Class({
-		Extends: Events,
-		Implements: [Options, Log],
-		options: {
-			onActivate: $empty,
-			onDeactivate: $empty,
-			defaultEventType: 'keydown',
-			active: false,
-			events: {},
-			nonParsedEvents: ['activate', 'deactivate', 'onactivate', 'ondeactivate', 'changed', 'onchanged']
-			this.setup();
-		setup: function(){
-			this.addEvents(this.options.events);
-			//if this is the root manager, nothing manages it
-			if (Keyboard.manager && !this.manager) Keyboard.manager.manage(this);
-			if (this.options.active) this.activate();
-		handle: function(event, type){
-			//Keyboard.stop(event) prevents key propagation
-			if (event.preventKeyboardPropagation) return;
-			var bubbles = !!this.manager;
-			if (bubbles && this.activeKB){
-				this.activeKB.handle(event, type);
-			this.fireEvent(type, event);
-			if (!bubbles && this.activeKB) this.activeKB.handle(event, type);
-		addEvent: function(type, fn, internal){
-			return this.parent(Keyboard.parse(type, this.options.defaultEventType, this.options.nonParsedEvents), fn, internal);
-		removeEvent: function(type, fn){
-			return this.parent(Keyboard.parse(type, this.options.defaultEventType, this.options.nonParsedEvents), fn);
-		toggleActive: function(){
-			return this[this.active ? 'deactivate' : 'activate']();
-		activate: function(instance){
-			if (instance) {
-				//if we're stealing focus, store the last keyboard to have it so the relenquish command works
-				if (instance != this.activeKB) this.previous = this.activeKB;
-				//if we're enabling a child, assign it so that events are now passed to it
-				this.activeKB = instance.fireEvent('activate');
-				Keyboard.manager.fireEvent('changed');
-			} else if (this.manager) {
-				//else we're enabling ourselves, we must ask our parent to do it for us
-				this.manager.activate(this);
-			return this;
-		deactivate: function(instance){
-			if (instance) {
-				if(instance === this.activeKB) {
-					this.activeKB = null;
-					instance.fireEvent('deactivate');
-			else if (this.manager) {
-				this.manager.deactivate(this);
-			return this;
-		relenquish: function(){
-			if (this.previous) this.activate(this.previous);
-		//management logic
-		manage: function(instance){
-			if (instance.manager) instance.manager.drop(instance);
-			this.instances.push(instance);
-			instance.manager = this;
-			if (!this.activeKB) this.activate(instance);
-			else this._disable(instance);
-		_disable: function(instance){
-			if (this.activeKB == instance) this.activeKB = null;
-		drop: function(instance){
-			this._disable(instance);
-			this.instances.erase(instance);
-		instances: [],
-		trace: function(){
-			Keyboard.trace(this);
-		each: function(fn){
-			Keyboard.each(this, fn);
-	var parsed = {};
-	var modifiers = ['shift', 'control', 'alt', 'meta'];
-	var regex = /^(?:shift|control|ctrl|alt|meta)$/;
-	Keyboard.parse = function(type, eventType, ignore){
-		if (ignore && ignore.contains(type.toLowerCase())) return type;
-		type = type.toLowerCase().replace(/^(keyup|keydown):/, function($0, $1){
-			eventType = $1;
-			return '';
-		if (!parsed[type]){
-			var key, mods = {};
-			type.split('+').each(function(part){
-				if (regex.test(part)) mods[part] = true;
-				else key = part;
-			mods.control = mods.control || mods.ctrl; // allow both control and ctrl
-			var keys = [];
-			modifiers.each(function(mod){
-				if (mods[mod]) keys.push(mod);
-			if (key) keys.push(key);
-			parsed[type] = keys.join('+');
-		return eventType + ':' + parsed[type];
-	Keyboard.each = function(keyboard, fn){
-		var current = keyboard || Keyboard.manager;
-		while (current){
-			fn.run(current);
-			current = current.activeKB;
-	Keyboard.stop = function(event){
-		event.preventKeyboardPropagation = true;
-	Keyboard.manager = new Keyboard({
-		active: true
-	Keyboard.trace = function(keyboard){
-		keyboard = keyboard || Keyboard.manager;
-		keyboard.enableLog();
-		keyboard.log('the following items have focus: ');
-		Keyboard.each(keyboard, function(current){
-			keyboard.log(document.id(current.widget) || current.wiget || current);
-	var handler = function(event){
-		var keys = [];
-			if (event[mod]) keys.push(mod);
-		if (!regex.test(event.key)) keys.push(event.key);
-		Keyboard.manager.handle(event, event.type + ':' + keys.join('+'));
-	document.addEvents({
-		'keyup': handler,
-		'keydown': handler
-	Event.Keys.extend({
-		'shift': 16,
-		'control': 17,
-		'alt': 18,
-		'capslock': 20,
-		'pageup': 33,
-		'pagedown': 34,
-		'end': 35,
-		'home': 36,
-		'numlock': 144,
-		'scrolllock': 145,
-		';': 186,
-		'=': 187,
-		',': 188,
-		'-': Browser.Engine.Gecko ? 109 : 189,
-		'.': 190,
-		'/': 191,
-		'`': 192,
-		'[': 219,
-		'\\': 220,
-		']': 221,
-		"'": 222
-script: HtmlTable.Select.js
-description: Builds a stripy, sortable table with methods to add rows. Rows can be selected with the mouse or keyboard navigation.
-authors:
- - Aaron Newton
-requires:
- - /Keyboard
- - /HtmlTable
- - /Class.refactor
-provides: [HtmlTable.Select]
-	options: {
-		/*onRowFocus: $empty,
-		onRowUnfocus: $empty,*/
-		useKeyboard: true,
-		classRowSelected: 'table-tr-selected',
-		classRowHovered: 'table-tr-hovered',
-		classSelectable: 'table-selectable',
-		allowMultiSelect: true,
-		selectable: false
-		this.selectedRows = new Elements();
-		this.bound = {
-			mouseleave: this.mouseleave.bind(this),
-			focusRow: this.focusRow.bind(this)
-		if (this.options.selectable) this.enableSelect();
-	enableSelect: function(){
-		this.selectEnabled = true;
-		this.attachSelects();
-		this.element.addClass(this.options.classSelectable);
-	disableSelect: function(){
-		this.selectEnabled = false;
-		this.attach(false);
-		this.element.removeClass(this.options.classSelectable);
-	attachSelects: function(attach){
-		attach = $pick(attach, true);
-		var method = attach ? 'addEvents' : 'removeEvents';
-		this.element[method]({
-			mouseleave: this.bound.mouseleave
-		this.body[method]({
-			'click:relay(tr)': this.bound.focusRow
-		if (this.options.useKeyboard || this.keyboard){
-			if (!this.keyboard) this.keyboard = new Keyboard({
-				events: {
-					down: function(e) {
-						e.preventDefault();
-						this.shiftFocus(1);
-					}.bind(this),
-					up: function(e) {
-						this.shiftFocus(-1);
-					}.bind(this),
-					enter: function(e) {
-						if (this.hover) this.focusRow(this.hover);
-					}.bind(this)
-				active: true
-			this.keyboard[attach ? 'activate' : 'deactivate']();
-		this.updateSelects();
-	mouseleave: function(){
-		if (this.hover) this.leaveRow(this.hover);
-	focus: function(){
-		if (this.keyboard) this.keyboard.activate();
-	blur: function(){
-		if (this.keyboard) this.keyboard.deactivate();
-	push: function(){
-		var ret = this.previous.apply(this, arguments);
-		return ret;
-	updateSelects: function(){
-		Array.each(this.body.rows, function(row){
-			var binders = row.retrieve('binders');
-			if ((binders && this.selectEnabled) || (!binders && !this.selectEnabled)) return;
-			if (!binders){
-				binders = {
-					mouseenter: this.enterRow.bind(this, [row]),
-					mouseleave: this.leaveRow.bind(this, [row])
-				row.store('binders', binders).addEvents(binders);
-			} else {
-				row.removeEvents(binders);
-		}, this);
-	enterRow: function(row){
-		if (this.hover) this.hover = this.leaveRow(this.hover);
-		this.hover = row.addClass(this.options.classRowHovered);
-	shiftFocus: function(offset){
-		if (!this.hover) return this.enterRow(this.body.rows[0]);
-		var to = Array.indexOf(this.body.rows, this.hover) + offset;
-		if (to < 0) to = 0;
-		if (to >= this.body.rows.length) to = this.body.rows.length - 1;
-		if (this.hover == this.body.rows[to]) return this;
-		this.enterRow(this.body.rows[to]);
-	leaveRow: function(row){
-		row.removeClass(this.options.classRowHovered);
-	focusRow: function(){
-		var row = arguments[1] || arguments[0]; //delegation passes the event first
-		if (!this.body.getChildren().contains(row)) return;
-		var unfocus = function(row){
-			this.selectedRows.erase(row);
-			row.removeClass(this.options.classRowSelected);
-			this.fireEvent('rowUnfocus', [row, this.selectedRows]);
-		}.bind(this);
-		if (!this.options.allowMultiSelect) this.selectedRows.each(unfocus);
-		if (!this.selectedRows.contains(row)) {
-			this.selectedRows.push(row);
-			row.addClass(this.options.classRowSelected);
-			this.fireEvent('rowFocus', [row, this.selectedRows]);
-		} else {
-			unfocus(row);
-		return false;
-	selectAll: function(status){
-		status = $pick(status, true);
-		if (!this.options.allowMultiSelect && status) return;
-		if (!status) this.selectedRows.removeClass(this.options.classRowSelected).empty();
-		else this.selectedRows.combine(this.body.rows).addClass(this.options.classRowSelected);
-		return this;
-	selectNone: function(){
-		return this.selectAll(false);
-description: Enhances Keyboard by adding the ability to name and describe keyboard shortcuts, and the ability to grab shortcuts by name and bind the shortcut to different keys.
-authors:
- - Perrin Westrich
-requires:
- - /Keyboard.Extras
-provides: [Keyboard.Extras]
-Keyboard.prototype.options.nonParsedEvents.combine(['rebound', 'onrebound']);
-Keyboard.implement({
-		shortcut should be in the format of:
-			'keys': 'shift+s', // the default to add as an event.
-			'description': 'blah blah blah', // a brief description of the functionality.
-			'handler': function(){} // the event handler to run when keys are pressed.
-	addShortcut: function(name, shortcut) {
-		this.shortcuts = this.shortcuts || [];
-		this.shortcutIndex = this.shortcutIndex || {};
-		shortcut.getKeyboard = $lambda(this);
-		shortcut.name = name;
-		this.shortcutIndex[name] = shortcut;
-		this.shortcuts.push(shortcut);
-		if(shortcut.keys) this.addEvent(shortcut.keys, shortcut.handler);
-		return this;
-	addShortcuts: function(obj){
-		for(var name in obj) this.addShortcut(name, obj[name]);
-		return this;
-	getShortcuts: function(){
-		return this.shortcuts || [];
-	getShortcut: function(name){
-		return (this.shortcutIndex || {})[name];
-Keyboard.rebind = function(newKeys, shortcuts){
-	$splat(shortcuts).each(function(shortcut){
-		shortcut.getKeyboard().removeEvent(shortcut.keys, shortcut.handler);
-		shortcut.getKeyboard().addEvent(newKeys, shortcut.handler);
-		shortcut.keys = newKeys;
-		shortcut.getKeyboard().fireEvent('rebound');
-Keyboard.getActiveShortcuts = function(keyboard) {
-	var activeKBS = [], activeSCS = [];
-	Keyboard.each(keyboard, [].push.bind(activeKBS));
-	activeKBS.each(function(kb){ activeSCS.extend(kb.getShortcuts()); });
-	return activeSCS;
-Keyboard.getShortcut = function(name, keyboard, opts){
-	opts = opts || {};
-	var shortcuts = opts.many ? [] : null,
-		set = opts.many ? function(kb){
-				var shortcut = kb.getShortcut(name);
-				if(shortcut) shortcuts.push(shortcut);
-			} : function(kb) {
-				if(!shortcuts) shortcuts = kb.getShortcut(name);
-	Keyboard.each(keyboard, set);
-	return shortcuts;
-Keyboard.getShortcuts = function(name, keyboard) {
-	return Keyboard.getShortcut(name, keyboard, { many: true });
-script: Scroller.js
-description: Class which scrolls the contents of any Element (including the window) when the mouse reaches the Element's boundaries.
-authors:
- - Valerio Proietti
-requires:
- - core:1.2.4/Element.Dimensions
-provides: [Scroller]
-var Scroller = new Class({
-	options: {
-		area: 20,
-		velocity: 1,
-		onChange: function(x, y){
-			this.element.scrollTo(x, y);
-		fps: 50
-		this.docBody = document.id(this.element.getDocument().body);
-		this.listener = ($type(this.element) != 'element') ?  this.docBody : this.element;
-		this.timer = null;
-		this.bound = {
-			attach: this.attach.bind(this),
-			detach: this.detach.bind(this),
-			getCoords: this.getCoords.bind(this)
-	start: function(){
-		this.listener.addEvents({
-			mouseover: this.bound.attach,
-			mouseout: this.bound.detach
-	stop: function(){
-		this.listener.removeEvents({
-		this.detach();
-		this.timer = $clear(this.timer);
-	attach: function(){
-		this.listener.addEvent('mousemove', this.bound.getCoords);
-		this.listener.removeEvent('mousemove', this.bound.getCoords);
-	getCoords: function(event){
-		this.page = (this.listener.get('tag') == 'body') ? event.client : event.page;
-		if (!this.timer) this.timer = this.scroll.periodical(Math.round(1000 / this.options.fps), this);
-	scroll: function(){
-		var size = this.element.getSize(),
-			scroll = this.element.getScroll(),
-			pos = this.element != this.docBody ? this.element.getOffsets() : {x: 0, y:0},
-			scrollSize = this.element.getScrollSize(),
-			change = {x: 0, y: 0};
-		for (var z in this.page){
-			if (this.page[z] < (this.options.area + pos[z]) && scroll[z] != 0) {
-				change[z] = (this.page[z] - this.options.area - pos[z]) * this.options.velocity;
-			} else if (this.page[z] + this.options.area > (size[z] + pos[z]) && scroll[z] + size[z] != scrollSize[z]) {
-				change[z] = (this.page[z] - size[z] + this.options.area - pos[z]) * this.options.velocity;
-		if (change.y || change.x) this.fireEvent('change', [scroll.x + change.x, scroll.y + change.y]);
-script: Tips.js
-description: Class for creating nice tips that follow the mouse cursor when hovering an element.
-authors:
- - Christoph Pojer
-requires:
- - /MooTools.More
-provides: [Tips]
-(function(){
-var read = function(option, element){
-	return (option) ? ($type(option) == 'function' ? option(element) : element.get(option)) : '';
-this.Tips = new Class({
-	options: {
-		onAttach: $empty(element),
-		onDetach: $empty(element),
-		onShow: function(){
-			this.tip.setStyle('display', 'block');
-		onHide: function(){
-			this.tip.setStyle('display', 'none');
-		title: 'title',
-		text: function(element){
-			return element.get('rel') || element.get('href');
-		showDelay: 100,
-		hideDelay: 100,
-		className: 'tip-wrap',
-		offset: {x: 16, y: 16},
-		windowPadding: {x:0, y:0},
-		fixed: false
-		var params = Array.link(arguments, {options: Object.type, elements: $defined});
-		if (params.elements) this.attach(params.elements);
-		this.container = new Element('div', {'class': 'tip'});
-		if (this.tip) return this.tip;
-		return this.tip = new Element('div', {
-			'class': this.options.className,
-			styles: {
-				top: 0,
-				left: 0
-		}).adopt(
-			new Element('div', {'class': 'tip-top'}),
-			this.container,
-			new Element('div', {'class': 'tip-bottom'})
-		).inject(document.body);
-	attach: function(elements){
-		$$(elements).each(function(element){
-			var title = read(this.options.title, element),
-				text = read(this.options.text, element);
-			element.erase('title').store('tip:native', title).retrieve('tip:title', title);
-			element.retrieve('tip:text', text);
-			this.fireEvent('attach', [element]);
-			var events = ['enter', 'leave'];
-			if (!this.options.fixed) events.push('move');
-			events.each(function(value){
-				var event = element.retrieve('tip:' + value);
-				if (!event) event = this['element' + value.capitalize()].bindWithEvent(this, element);
-				element.store('tip:' + value, event).addEvent('mouse' + value, event);
-			}, this);
-		}, this);
-		return this;
-	detach: function(elements){
-			['enter', 'leave', 'move'].each(function(value){
-				element.removeEvent('mouse' + value, element.retrieve('tip:' + value)).eliminate('tip:' + value);
-			this.fireEvent('detach', [element]);
-			if (this.options.title == 'title'){ // This is necessary to check if we can revert the title
-				var original = element.retrieve('tip:native');
-				if (original) element.set('title', original);
-		}, this);
-		return this;
-	elementEnter: function(event, element){
-		this.container.empty();
-		['title', 'text'].each(function(value){
-			var content = element.retrieve('tip:' + value);
-			if (content) this.fill(new Element('div', {'class': 'tip-' + value}).inject(this.container), content);
-		}, this);
-		this.timer = (function(){
-			this.show(this, element);
-			this.position((this.options.fixed) ? {page: element.getPosition()} : event);
-		}).delay(this.options.showDelay, this);
-	elementLeave: function(event, element){
-		this.timer = this.hide.delay(this.options.hideDelay, this, element);
-		this.fireForParent(event, element);
-	fireForParent: function(event, element){
-		element = element.getParent();
-		if (!element || element == document.body) return;
-		if (element.retrieve('tip:enter')) element.fireEvent('mouseenter', event);
-		else this.fireForParent(event, element);
-	elementMove: function(event, element){
-		this.position(event);
-	position: function(event){
-		if (!this.tip) document.id(this);
-		var size = window.getSize(), scroll = window.getScroll(),
-			tip = {x: this.tip.offsetWidth, y: this.tip.offsetHeight},
-			props = {x: 'left', y: 'top'},
-			obj = {};
-		for (var z in props){
-			obj[props[z]] = event.page[z] + this.options.offset[z];
-			if ((obj[props[z]] + tip[z] - scroll[z]) > size[z] - this.options.windowPadding[z]) obj[props[z]] = event.page[z] - this.options.offset[z] - tip[z];
-		this.tip.setStyles(obj);
-	fill: function(element, contents){
-		if(typeof contents == 'string') element.set('html', contents);
-		else element.adopt(contents);
-	show: function(element){
-		this.fireEvent('show', [this.tip, element]);
-	hide: function(element){
-		this.fireEvent('hide', [this.tip, element]);
-script: Date.Catalan.js
-description: Date messages for Catalan.
-authors:
- - Alfons Sanchez
-requires:
- - /Lang
- - /Date
-provides: [Date.Catalan]
-MooTools.lang.set('ca-CA', 'Date', {
-	months: ['Gener', 'Febrer', 'Març', 'Abril', 'Maig', 'Juny', 'Juli', 'Agost', 'Setembre', 'Octubre', 'Novembre', 'Desembre'],
-	days: ['Diumenge', 'Dilluns', 'Dimarts', 'Dimecres', 'Dijous', 'Divendres', 'Dissabte'],
-	//culture's date order: MM/DD/YYYY
-	dateOrder: ['date', 'month', 'year'],
-	shortDate: '%d/%m/%Y',
-	shortTime: '%H:%M',
-	AM: 'AM',
-	PM: 'PM',
-	/* Date.Extras */
-	ordinal: '',
-	lessThanMinuteAgo: 'fa menys d`un minut',
-	minuteAgo: 'fa un minut',
-	minutesAgo: 'fa {delta} minuts',
-	hourAgo: 'fa un hora',
-	hoursAgo: 'fa unes {delta} hores',
-	dayAgo: 'fa un dia',
-	daysAgo: 'fa {delta} dies',
-	lessThanMinuteUntil: 'menys d`un minut des d`ara',
-	minuteUntil: 'un minut des d`ara',
-	minutesUntil: '{delta} minuts des d`ara',
-	hourUntil: 'un hora des d`ara',
-	hoursUntil: 'unes {delta} hores des d`ara',
-	dayUntil: '1 dia des d`ara',
-	daysUntil: '{delta} dies des d`ara'
-script: Date.Czech.js
-description: Date messages for Czech.
-authors:
- - Jan Černý chemiX
-requires:
- - /Lang
- - /Date
-provides: [Date.Czech]
-MooTools.lang.set('cs-CZ', 'Date', {
-	months: ['Leden', 'Únor', 'Březen', 'Duben', 'Květen', 'Červen', 'Červenec', 'Srpen', 'Září', 'Říjen', 'Listopad', 'Prosinec'],
-	days: ['Neděle', 'Pondělí', 'Úterý', 'Středa', 'Čtvrtek', 'Pátek', 'Sobota'],
-	AM: 'dop.',
-	PM: 'odp.',
-	/* Date.Extras */
-	ordinal: function(dayOfMonth){
-		return '.';
-    // TODO : in examples use and fix it
-	lessThanMinuteAgo: 'méně než minutou',
-	minuteAgo: 'přibližně před minutou',
-	minutesAgo: 'před {delta} minutami',
-	hourAgo: 'přibližně před hodinou',
-	hoursAgo: 'před {delta} hodinami',
-	dayAgo: 'před dnem',
-	daysAgo: 'před {delta} dni',
-	lessThanMinuteUntil: 'před méně než minutou',
-	minuteUntil: 'asi před minutou',
-	minutesUntil: ' asi před {delta} minutami',
-	hourUntil: 'asi před hodinou',
-	hoursUntil: 'před {delta} hodinami',
-	dayUntil: 'před dnem',
-	daysUntil: 'před {delta} dni',
-	weekUntil: 'před týdnem',
-	weeksUntil: 'před {delta} týdny',
-	monthUntil: 'před měsícem',
-	monthsUntil: 'před {delta} měsíci',
-	yearUntil: 'před rokem',
-	yearsUntil: 'před {delta} lety'
-script: Date.Danish.js
-description: Date messages for Danish.
-authors:
- - Martin Overgaard
- - Henrik Hansen
-requires:
- - /Lang
- - /Date
-provides: [Date.Danish]
-MooTools.lang.set('da-DK', 'Date', {
-	months: ['Januar', 'Februa', 'Marts', 'April', 'Maj', 'Juni', 'Juli', 'August', 'September', 'Oktober', 'November', 'December'],
-	days: ['Søndag', 'Mandag', 'Tirsdag', 'Onsdag', 'Torsdag', 'Fredag', 'Lørdag'],
-	//culture's date order: DD/MM/YYYY
-	AM: 'AM',
-	PM: 'PM',
-	shortDate: '%d-%m-%Y',
-	/* Date.Extras */
-	  //1st, 2nd, 3rd, etc.
-	  return (dayOfMonth > 3 && dayOfMonth < 21) ? 'th' : ['th', 'st', 'nd', 'rd', 'th'][Math.min(dayOfMonth % 10, 4)];
-	lessThanMinuteAgo: 'mindre end et minut siden',
-	minuteAgo: 'omkring et minut siden',
-	minutesAgo: '{delta} minutter siden',
-	hourAgo: 'omkring en time siden',
-	hoursAgo: 'omkring {delta} timer siden',
-	dayAgo: '1 dag siden',
-	daysAgo: '{delta} dage siden',
-	weekAgo: '1 uge siden',
-	weeksAgo: '{delta} uger siden',
-	monthAgo: '1 måned siden',
-	monthsAgo: '{delta} måneder siden',
-	yearthAgo: '1 år siden',
-	yearsAgo: '{delta} år siden',
-	lessThanMinuteUntil: 'mindre end et minut fra nu',
-	minuteUntil: 'omkring et minut fra nu',
-	minutesUntil: '{delta} minutter fra nu',
-	hourUntil: 'omkring en time fra nu',
-	hoursUntil: 'omkring {delta} timer fra nu',
-	dayUntil: '1 dag fra nu',
-	daysUntil: '{delta} dage fra nu',
-	weekUntil: '1 uge fra nu',
-	weeksUntil: '{delta} uger fra nu',
-	monthUntil: '1 måned fra nu',
-	monthsUntil: '{delta} måneder fra nu',
-	yearUntil: '1 år fra nu',
-	yearsUntil: '{delta} år fra nu'
-script: Date.Dutch.js
-description: Date messages in Dutch.
-authors:
- - Lennart Pilon
-requires:
- - /Lang
- - /Date
-provides: [Date.Dutch]
-MooTools.lang.set('nl-NL', 'Date', {
-	months: ['Januari', 'Februari', 'Maart', 'April', 'Mei', 'Juni', 'Juli', 'Augustus', 'September', 'Oktober', 'November', 'December'],
-	days: ['Zondag', 'Maandag', 'Dinsdag', 'Woensdag', 'Donderdag', 'Vrijdag', 'Zaterdag'],
-	AM: 'AM',
-	PM: 'PM',
-	/* Date.Extras */
-	ordinal: 'e',
-	lessThanMinuteAgo: 'minder dan een minuut geleden',
-	minuteAgo: 'ongeveer een minuut geleden',
-	minutesAgo: 'minuten geleden',
-	hourAgo: 'ongeveer een uur geleden',
-	hoursAgo: 'ongeveer {delta} uur geleden',
-	dayAgo: '{delta} dag geleden',
-	daysAgo: 'dagen geleden',
-	weekAgo: 'een week geleden',
-	weeksAgo: '{delta} weken geleden',
-	monthAgo: 'een maand geleden',
-	monthsAgo: '{delta} maanden geleden',
-	yearAgo: 'een jaar geleden',
-	yearsAgo: '{delta} jaar geleden',
-	lessThanMinuteUntil: 'minder dan een minuut vanaf nu',
-	minuteUntil: 'ongeveer een minuut vanaf nu',
-	minutesUntil: '{delta} minuten vanaf nu',
-	hourUntil: 'ongeveer een uur vanaf nu',
-	hoursUntil: 'ongeveer {delta} uur vanaf nu',
-	dayUntil: '1 dag vanaf nu',
-	daysUntil: '{delta} dagen vanaf nu',
-	yearthAgo: 'een jaar geleden',
-	weekUntil: 'over een week',
-	weeksUntil: 'over {delta} weken',
-	monthUntil: 'over een maand',
-	monthsUntil: 'over {delta} maanden',
-	yearUntil: 'over een jaar',
-	yearsUntil: 'over {delta} jaar'
-script: Date.English.GB.js
-description: Date messages for British English.
-authors:
- - Aaron Newton
-requires:
- - /Lang
- - /Date
-provides: [Date.English.GB]
-MooTools.lang.set('en-GB', 'Date', {
-}).set('cascade', ['en-US']);/*
-script: Date.Estonian.js
-description: Date messages for Estonian.
-authors:
- - Kevin Valdek
-requires:
- - /Lang
- - /Date
-provides: [Date.Estonian]
-MooTools.lang.set('et-EE', 'Date', {
-	months: ['jaanuar', 'veebruar', 'märts', 'aprill', 'mai', 'juuni', 'juuli', 'august', 'september', 'oktoober', 'november', 'detsember'],
-	days: ['pühapäev', 'esmaspäev', 'teisipäev', 'kolmapäev', 'neljapäev', 'reede', 'laupäev'],
-	//culture's date order: MM.DD.YYYY
-	dateOrder: ['month', 'date', 'year'],
-	AM: 'AM',
-	PM: 'PM',
-	shortDate: '%m.%d.%Y',
-	/* Date.Extras */
-	ordinal: '',
-	lessThanMinuteAgo: 'vähem kui minut aega tagasi',
-	minuteAgo: 'umbes minut aega tagasi',
-	minutesAgo: '{delta} minutit tagasi',
-	hourAgo: 'umbes tund aega tagasi',
-	hoursAgo: 'umbes {delta} tundi tagasi',
-	dayAgo: '1 päev tagasi',
-	daysAgo: '{delta} päeva tagasi',
-	weekAgo: '1 nädal tagasi',
-	weeksAgo: '{delta} nädalat tagasi',
-	monthAgo: '1 kuu tagasi',
-	monthsAgo: '{delta} kuud tagasi',
-	yearAgo: '1 aasta tagasi',
-	yearsAgo: '{delta} aastat tagasi',
-	lessThanMinuteUntil: 'vähem kui minuti aja pärast',
-	minuteUntil: 'umbes minuti aja pärast',
-	minutesUntil: '{delta} minuti pärast',
-	hourUntil: 'umbes tunni aja pärast',
-	hoursUntil: 'umbes {delta} tunni pärast',
-	dayUntil: '1 päeva pärast',
-	daysUntil: '{delta} päeva pärast',
-	weekUntil: '1 nädala pärast',
-	weeksUntil: '{delta} nädala pärast',
-	monthUntil: '1 kuu pärast',
-	monthsUntil: '{delta} kuu pärast',
-	yearUntil: '1 aasta pärast',
-	yearsUntil: '{delta} aasta pärast'
-script: Date.German.js
-description: Date messages for German.
-authors:
- - Christoph Pojer
- - Frank Rossi
- - Ulrich Petri
- - Fabian Beiner
-requires:
- - /Lang
- - /Date
-provides: [Date.German]
-MooTools.lang.set('de-DE', 'Date', {
-	months: ['Januar', 'Februar', 'M&auml;rz', 'April', 'Mai', 'Juni', 'Juli', 'August', 'September', 'Oktober', 'November', 'Dezember'],
-	days: ['Sonntag', 'Montag', 'Dienstag', 'Mittwoch', 'Donnerstag', 'Freitag', 'Samstag'],
-	dateOrder: [ 'date', 'month', 'year', '.'],
-	AM: 'vormittags',
-	PM: 'nachmittags',
-	shortDate: '%d.%m.%Y',
-	/* Date.Extras */
-	ordinal: '.',
-	lessThanMinuteAgo: 'Vor weniger als einer Minute',
-	minuteAgo: 'Vor einer Minute',
-	minutesAgo: 'Vor {delta} Minuten',
-	hourAgo: 'Vor einer Stunde',
-	hoursAgo: 'Vor {delta} Stunden',
-	dayAgo: 'Vor einem Tag',
-	daysAgo: 'Vor {delta} Tagen',
-	weekAgo: 'Vor einer Woche',
-	weeksAgo: 'Vor {delta} Wochen',
-	monthAgo: 'Vor einem Monat',
-	monthsAgo: 'Vor {delta} Monaten',
-	yearAgo: 'Vor einem Jahr',
-	yearsAgo: 'Vor {delta} Jahren',
-	lessThanMinuteUntil: 'In weniger als einer Minute',
-	minuteUntil: 'In einer Minute',
-	minutesUntil: 'In {delta} Minuten',
-	hourUntil: 'In ca. einer Stunde',
-	hoursUntil: 'In ca. {delta} Stunden',
-	dayUntil: 'In einem Tag',
-	daysUntil: 'In {delta} Tagen',
-	weekUntil: 'In einer Woche',
-	weeksUntil: 'In {delta} Wochen',
-	monthUntil: 'In einem Monat',
-	monthsUntil: 'In {delta} Monaten',
-	yearUntil: 'In einem Jahr',
-	yearsUntil: 'In {delta} Jahren'
-script: Date.German.CH.js
-description: Date messages for German (Switzerland).
-authors:
- - Michael van der Weg
-requires:
- - /Lang
- - /Date.German
-provides: [Date.German.CH]
-MooTools.lang.set('de-CH', 'cascade', ['de-DE']);/*
-script: Date.French.js
-description: Date messages in French.
-authors:
- - Nicolas Sorosac
- - Antoine Abt
-requires:
- - /Lang
- - /Date
-provides: [Date.French]
-MooTools.lang.set('fr-FR', 'Date', {
-	months: ['janvier', 'f&eacute;vrier', 'mars', 'avril', 'mai', 'juin', 'juillet', 'ao&ucirc;t', 'septembre', 'octobre', 'novembre', 'd&eacute;cembre'],
-	days: ['dimanche', 'lundi', 'mardi', 'mercredi', 'jeudi', 'vendredi', 'samedi'],
-	AM: 'AM',
-	PM: 'PM',
-	/* Date.Extras */
-	getOrdinal: function(dayOfMonth){
-	  return (dayOfMonth > 1) ? '' : 'er';
-	lessThanMinuteAgo: 'il y a moins d\'une minute',
-	minuteAgo: 'il y a une minute',
-	minutesAgo: 'il y a {delta} minutes',
-	hourAgo: 'il y a une heure',
-	hoursAgo: 'il y a {delta} heures',
-	dayAgo: 'il y a un jour',
-	daysAgo: 'il y a {delta} jours',
-	weekAgo: 'il y a une semaine',
-	weeksAgo: 'il y a {delta} semaines',
-	monthAgo: 'il y a 1 mois',
-	monthsAgo: 'il y a {delta} mois',
-	yearthAgo: 'il y a 1 an',
-	yearsAgo: 'il y a {delta} ans',
-	lessThanMinuteUntil: 'dans moins d\'une minute',
-	minuteUntil: 'dans une minute',
-	minutesUntil: 'dans {delta} minutes',
-	hourUntil: 'dans une heure',
-	hoursUntil: 'dans {delta} heures',
-	dayUntil: 'dans un jour',
-	daysUntil: 'dans {delta} jours',
-	weekUntil: 'dans 1 semaine',
-	weeksUntil: 'dans {delta} semaines',
-	monthUntil: 'dans 1 mois',
-	monthsUntil: 'dans {delta} mois',
-	yearUntil: 'dans 1 an',
-	yearsUntil: 'dans {delta} ans'
-script: Date.Italian.js
-description: Date messages for Italian.
-license: MIT-style license.
-authors:
- - Andrea Novero
-requires:
- - /Lang
- - /Date
-provides: [Date.Italian]
-MooTools.lang.set('it-IT', 'Date', {
-	months: ['Gennaio', 'Febbraio', 'Marzo', 'Aprile', 'Maggio', 'Giugno', 'Luglio', 'Agosto', 'Settembre', 'Ottobre', 'Novembre', 'Dicembre'],
-	days: ['Domenica', 'Luned&igrave;', 'Marted&igrave;', 'Mercoled&igrave;', 'Gioved&igrave;', 'Venerd&igrave;', 'Sabato'],
-	AM: 'AM',
-	PM: 'PM',
-	shortTime: '%H.%M',
-	/* Date.Extras */
-	ordinal: '&ordm;',
-	lessThanMinuteAgo: 'meno di un minuto fa',
-	minuteAgo: 'circa un minuto fa',
-	minutesAgo: 'circa {delta} minuti fa',
-	hourAgo: 'circa un\'ora fa',
-	hoursAgo: 'circa {delta} ore fa',
-	dayAgo: 'circa 1 giorno fa',
-	daysAgo: 'circa {delta} giorni fa',
-	lessThanMinuteUntil: 'tra meno di un minuto',
-	minuteUntil: 'tra circa un minuto',
-	minutesUntil: 'tra circa {delta} minuti',
-	hourUntil: 'tra circa un\'ora',
-	hoursUntil: 'tra circa {delta} ore',
-	dayUntil: 'tra circa un giorno',
-	daysUntil: 'tra circa {delta} giorni'
-script: Date.Norwegian.js
-description: Date messages in Norwegian.
-authors:
- - Espen 'Rexxars' Hovlandsdal
-requires:
- - /Lang
- - /Date
-provides: [Date.Norwegian]
-MooTools.lang.set('no-NO', 'Date', {
-	lessThanMinuteAgo: 'kortere enn et minutt siden',
-	minuteAgo: 'omtrent et minutt siden',
-	hourAgo: 'omtrent en time siden',
-	hoursAgo: 'omtrent {delta} timer siden',
-	dayAgo: '{delta} dag siden',
-	daysAgo: '{delta} dager siden'
-script: Date.Polish.js
-description: Date messages for Polish.
-authors:
- - Oskar Krawczyk
-requires:
- - /Lang
- - /Date
-provides: [Date.Polish]
-MooTools.lang.set('pl-PL', 'Date', {
-	months: ['Styczeń', 'Luty', 'Marzec', 'Kwiecień', 'Maj', 'Czerwiec', 'Lipiec', 'Sierpień', 'Wrzesień', 'Październik', 'Listopad', 'Grudzień'],
-	days: ['Niedziela', 'Poniedziałek', 'Wtorek', 'Środa', 'Czwartek', 'Piątek', 'Sobota'],
-	dateOrder: ['year', 'month', 'date'],
-	AM: 'nad ranem',
-	PM: 'po południu',
-	shortDate: '%Y-%m-%d',
-	/* Date.Extras */
-		return (dayOfMonth > 3 && dayOfMonth < 21) ? 'ty' : ['ty', 'szy', 'gi', 'ci', 'ty'][Math.min(dayOfMonth % 10, 4)];
-	lessThanMinuteAgo: 'mniej niż minute temu',
-	minuteAgo: 'około minutę temu',
-	minutesAgo: '{delta} minut temu',
-	hourAgo: 'około godzinę temu',
-	hoursAgo: 'około {delta} godzin temu',
-	dayAgo: 'Wczoraj',
-	daysAgo: '{delta} dni temu',
-	lessThanMinuteUntil: 'za niecałą minutę',
-	minuteUntil: 'za około minutę',
-	minutesUntil: 'za {delta} minut',
-	hourUntil: 'za około godzinę',
-	hoursUntil: 'za około {delta} godzin',
-	dayUntil: 'za 1 dzień',
-	daysUntil: 'za {delta} dni'
-script: Date.Portuguese.BR.js
-description: Date messages in Portuguese-BR (Brazil).
-authors:
- - Fabio Miranda Costa
-requires:
- - /Lang
- - /Date
-provides: [Date.Portuguese.BR]
-MooTools.lang.set('pt-BR', 'Date', {
-	months: ['Janeiro', 'Fevereiro', 'Março', 'Abril', 'Maio', 'Junho', 'Julho', 'Agosto', 'Setembro', 'Outubro', 'Novembro', 'Dezembro'],
-	days: ['Domingo', 'Segunda-feira', 'Terça-feira', 'Quarta-feira', 'Quinta-feira', 'Sexta-feira', 'Sábado'],
-	/* Date.Extras */
-		//1º, 2º, 3º, etc.
-    	return '&ordm;';
-	lessThanMinuteAgo: 'há menos de um minuto',
-	minuteAgo: 'há cerca de um minuto',
-	minutesAgo: 'há {delta} minutos',
-	hourAgo: 'há cerca de uma hora',
-	hoursAgo: 'há cerca de {delta} horas',
-	dayAgo: 'há um dia',
-	daysAgo: 'há {delta} dias',
-    weekAgo: 'há uma semana',
-	weeksAgo: 'há {delta} semanas',
-	monthAgo: 'há um mês',
-	monthsAgo: 'há {delta} meses',
-	yearAgo: 'há um ano',
-	yearsAgo: 'há {delta} anos',
-	lessThanMinuteUntil: 'em menos de um minuto',
-	minuteUntil: 'em um minuto',
-	minutesUntil: 'em {delta} minutos',
-	hourUntil: 'em uma hora',
-	hoursUntil: 'em {delta} horas',
-	dayUntil: 'em um dia',
-	daysUntil: 'em {delta} dias',
-	weekUntil: 'em uma semana',
-	weeksUntil: 'em {delta} semanas',
-	monthUntil: 'em um mês',
-	monthsUntil: 'em {delta} meses',
-	yearUntil: 'em um ano',
-	yearsUntil: 'em {delta} anos'
-Script: Date.Russian.js
-	Date messages for Russian.
-	License:
-		MIT-style license.
-	Authors:
-		Evstigneev Pavel
-MooTools.lang.set('ru-RU-unicode', 'Date', {
-	months: ['Январь', 'Февраль', 'Март', '�?прель', 'Май', 'Июнь', 'Июль', '�?вгу�?т', 'Сент�?брь', 'Окт�?брь', '�?о�?брь', 'Декабрь'],
-	days: ['Во�?кре�?енье', 'Понедельник', 'Вторник', 'Среда', 'Четверг', 'П�?тница', 'Суббота'],
-	AM: 'AM',
-	PM: 'PM',
-   *  Russian language pluralization rules, taken from CLDR project, http://unicode.org/cldr/
-   *  one -> n mod 10 is 1 and n mod 100 is not 11;
-   *  few -> n mod 10 in 2..4 and n mod 100 not in 12..14;
-   *  many -> n mod 10 is 0 or n mod 10 in 5..9 or n mod 100 in 11..14;
-   *  other -> everything else (example 3.14)
-  pluralize: function (n, one, few, many, other) {
-    var modulo10 = n % 10
-    var modulo100 = n % 100
-    if (modulo10 == 1 && modulo100 != 11) {
-      return one;
-    } else if ((modulo10 == 2 || modulo10 == 3 || modulo10 == 4) && !(modulo100 == 12 || modulo100 == 13 || modulo100 == 14)) {
-      return few;
-    } else if (modulo10 == 0 || (modulo10 == 5 || modulo10 == 6 || modulo10 == 7 || modulo10 == 8 || modulo10 == 9) || (modulo100 == 11 || modulo100 == 12 || modulo100 == 13 || modulo100 == 14)) {
-      return many;
-    } else {
-      return other;
-	/* Date.Extras */
-	ordinal: '',
-	lessThanMinuteAgo: 'меньше минуты назад',
-	minuteAgo: 'минута назад',
-	minutesAgo: function (delta) { return  '{delta} ' + this.pluralize(delta, 'минута', 'минуты', 'минут') + ' назад'},
-	hourAgo: 'ча�? назад',
-	hoursAgo: function (delta) { return  '{delta} ' + this.pluralize(delta, 'ча�?', 'ча�?а', 'ча�?ов') + ' назад'},
-	dayAgo: 'вчера',
-	daysAgo: function (delta) { return '{delta} ' + this.pluralize(delta, 'день', 'дн�?', 'дней') + ' назад' },
-	lessThanMinuteUntil: 'меньше минуты назад',
-	minuteUntil: 'через минуту',
-	minutesUntil: function (delta) { return  'через {delta} ' + this.pluralize(delta, 'ча�?', 'ча�?а', 'ча�?ов') + ''},
-	hourUntil: 'через ча�?',
-	hoursUntil: function (delta) { return  'через {delta} ' + this.pluralize(delta, 'ча�?', 'ча�?а', 'ча�?ов') + ''},
-	dayUntil: 'завтра',
-	daysUntil: function (delta) { return 'через {delta} ' + this.pluralize(delta, 'день', 'дн�?', 'дней') + '' }
-script: Date.Spanish.US.js
-description: Date messages for Spanish.
-authors:
- - Ãlfons Sanchez
-requires:
- - /Lang
- - /Date
-provides: [Date.Spanish]
-MooTools.lang.set('es-ES', 'Date', {
-	months: ['Enero', 'Febrero', 'Marzo', 'Abril', 'Mayo', 'Junio', 'Julio', 'Agosto', 'Septiembre', 'Octubre', 'Noviembre', 'Diciembre'],
-	days: ['Domingo', 'Lunes', 'Martes', 'Miércoles', 'Jueves', 'Viernes', 'Sábado'],
-	AM: 'AM',
-	PM: 'PM',
-	/* Date.Extras */
-	ordinal: '',
-	lessThanMinuteAgo: 'hace menos de un minuto',
-	minuteAgo: 'hace un minuto',
-	minutesAgo: 'hace {delta} minutos',
-	hourAgo: 'hace una hora',
-	hoursAgo: 'hace unas {delta} horas',
-	dayAgo: 'hace un día',
-	daysAgo: 'hace {delta} días',
-	weekAgo: 'hace una semana',
-	weeksAgo: 'hace unas {delta} semanas',
-	monthAgo: 'hace un mes',
-	monthsAgo: 'hace {delta} meses',
-	yearAgo: 'hace un año',
-	yearsAgo: 'hace {delta} años',
-	lessThanMinuteUntil: 'menos de un minuto desde ahora',
-	minuteUntil: 'un minuto desde ahora',
-	minutesUntil: '{delta} minutos desde ahora',
-	hourUntil: 'una hora desde ahora',
-	hoursUntil: 'unas {delta} horas desde ahora',
-	dayUntil: 'un día desde ahora',
-	daysUntil: '{delta} días desde ahora',
-	weekUntil: 'una semana desde ahora',
-	weeksUntil: 'unas {delta} semanas desde ahora',
-	monthUntil: 'un mes desde ahora',
-	monthsUntil: '{delta} meses desde ahora',
-	yearUntil: 'un año desde ahora',
-	yearsUntil: '{delta} años desde ahora'
-script: Date.Swedish.js
-description: Date messages for Swedish (SE).
-authors:
- - Martin Lundgren
-requires:
- - /Lang
- - /Date
-provides: [Date.Swedish]
-MooTools.lang.set('sv-SE', 'Date', {
-	months: ['januari', 'februari', 'mars', 'april', 'maj', 'juni', 'juli', 'augusti', 'september', 'oktober', 'november', 'december'],
-	days: ['söndag', 'måndag', 'tisdag', 'onsdag', 'torsdag', 'fredag', 'lördag'],
-	// culture's date order: YYYY-MM-DD
-	AM: '',
-	PM: '',
-	/* Date.Extras */
-		// Not used in Swedish
-		return '';
-	lessThanMinuteAgo: 'mindre än en minut sedan',
-	minuteAgo: 'ungefär en minut sedan',
-	minutesAgo: '{delta} minuter sedan',
-	hourAgo: 'ungefär en timme sedan',
-	hoursAgo: 'ungefär {delta} timmar sedan',
-	dayAgo: '1 dag sedan',
-	daysAgo: '{delta} dagar sedan',
-	lessThanMinuteUntil: 'mindre än en minut sedan',
-	minuteUntil: 'ungefär en minut sedan',
-	minutesUntil: '{delta} minuter sedan',
-	hourUntil: 'ungefär en timme sedan',
-	hoursUntil: 'ungefär {delta} timmar sedan',
-	dayUntil: '1 dag sedan',
-	daysUntil: '{delta} dagar sedan'
-script: Date.Ukrainian.js
-description: Date messages for Ukrainian.
-authors:
- - Slik
-requires:
- - /Lang
- - /Date
-provides: [Date.Ukrainian]
-(function(){
-	var pluralize = function(n, one, few, many, other){
-		var d = (n / 10).toInt();
-		var z = n % 10;
-		var s = (n / 100).toInt();
-		if(d == 1 && n > 10) return many;
-		if(z == 1) return one;
-		if(z > 0 && z < 5) return few;
-		return many;
-	MooTools.lang.set('uk-UA', 'Date', {
-			months: ['Січень', 'Лютий', 'Березень', 'Квітень', 'Травень', 'Червень', 'Липень', 'Серпень', 'Вере�?ень', 'Жовтень', 'Ли�?топад', 'Грудень'],
-			days: ['�?еділ�?', 'Понеділок', 'Вівторок', 'Середа', 'Четвер', 'П\'�?тниц�?', 'Субота'],
-			AM: 'до полудн�?',
-			PM: 'по полудню',
-			/* Date.Extras */
-			ordinal: '',
-			lessThanMinuteAgo: 'меньше хвилини тому',
-			minuteAgo: 'хвилину тому',
-			minutesAgo: function (delta){
-				return '{delta} ' + pluralize(delta, 'хвилину', 'хвилини', 'хвилин') + ' тому';
-			hourAgo: 'годину тому',
-			hoursAgo: function (delta){
-				return '{delta} ' + pluralize(delta, 'годину', 'години', 'годин') + ' тому';
-			dayAgo: 'вчора',
-			daysAgo: function (delta){
-				return '{delta} ' + pluralize(delta, 'день', 'дн�?', 'днів') + ' тому';
-			weekAgo: 'тиждень тому',
-			weeksAgo: function (delta){
-				return '{delta} ' + pluralize(delta, 'тиждень', 'тижні', 'тижнів') + ' тому';
-			monthAgo: 'мі�?�?ць тому',
-			monthsAgo: function (delta){
-				return '{delta} ' + pluralize(delta, 'мі�?�?ць', 'мі�?�?ці', 'мі�?�?ців') + ' тому';
-			yearAgo: 'рік тому',
-			yearsAgo: function (delta){
-				return '{delta} ' + pluralize(delta, 'рік', 'роки', 'років') + ' тому';
-			lessThanMinuteUntil: 'за мить',
-			minuteUntil: 'через хвилину',
-			minutesUntil: function (delta){
-				return 'через {delta} ' + pluralize(delta, 'хвилину', 'хвилини', 'хвилин');
-			hourUntil: 'через годину',
-			hoursUntil: function (delta){
-				return 'через {delta} ' + pluralize(delta, 'годину', 'години', 'годин');
-			daysUntil: function (delta){
-				return 'через {delta} ' + pluralize(delta, 'день', 'дн�?', 'днів');
-			weekUntil: 'через тиждень',
-			weeksUntil: function (delta){
-				return 'через {delta} ' + pluralize(delta, 'тиждень', 'тижні', 'тижнів');
-			monthUntil: 'через мі�?�?ць',
-			monthesUntil: function (delta){
-				return 'через {delta} ' + pluralize(delta, 'мі�?�?ць', 'мі�?�?ці', 'мі�?�?ців');
-			yearUntil: 'через рік',
-			yearsUntil: function (delta){
-				return 'через {delta} ' + pluralize(delta, 'рік', 'роки', 'років');
-script: Form.Validator.Arabic.js
-description: Form.Validator messages in Arabic.
-authors:
- - Chafik Barbar
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.Arabic]
-MooTools.lang.set('ar', 'Form.Validator', {
-	required:'هذا الحقل مطلوب.',
-	minLength:'رجاءً إدخال {minLength}  أحر�? على الأقل (تم إدخال {length} أحر�?).',
-	maxLength:'الرجاء عدم إدخال أكثر من {maxLength} أحر�? (تم إدخال {length} أحر�?).',
-	integer:'الرجاء إدخال عدد صحيح �?ي هذا الحقل. أي رقم ذو كسر عشري أو مئوي (مثال 1.25 ) غير مسموح.',
-	numeric:'الرجاء إدخال قيم رقمية �?ي هذا الحقل (مثال "1" أو "1.1" أو "-1" أو "-1.1").',
-	digits:'الرجاء أستخدام قيم رقمية وعلامات ترقيمية �?قط �?ي هذا الحقل (مثال, رقم هات�? مع نقطة أو شحطة)',
-	alpha:'الرجاء أستخدام أحر�? �?قط (ا-ي) �?ي هذا الحقل. أي �?راغات أو علامات غير مسموحة.',
-	alphanum:'الرجاء أستخدام أحر�? �?قط (ا-ي) أو أرقام (0-9) �?قط �?ي هذا الحقل. أي �?راغات أو علامات غير مسموحة.',
-	dateSuchAs:'الرجاء إدخال تاريخ صحيح كالتالي {date}',
-	dateInFormatMDY:'الرجاء إدخال تاريخ صحيح (مثال, 31-12-1999)',
-	email:'الرجاء إدخال بريد إلكتروني صحيح.',
-	url:'الرجاء إدخال عنوان إلكتروني صحيح مثل http://www.google.com',
-	currencyDollar:'الرجاء إدخال قيمة $ صحيحة.  مثال, 100.00$',
-	oneRequired:'الرجاء إدخال قيمة �?ي أحد هذه الحقول على الأقل.',
-	errorPrefix: 'خطأ: ',
-	warningPrefix: 'تحذير: '
-}).set('ar', 'Date', {
-	dateOrder: ['date', 'month', 'year', '/']
-script: Form.Validator.Catalan.js
-authors:
- - Miquel Hudin
- - Alfons Sanchez
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.Catalan]
-MooTools.lang.set('ca-CA', 'Form.Validator', {
-	required:'Aquest camp es obligatori.',
-	minLength:'Per favor introdueix al menys {minLength} caracters (has introduit {length} caracters).',
-	maxLength:'Per favor introdueix no mes de {maxLength} caracters (has introduit {length} caracters).',
-	integer:'Per favor introdueix un nombre enter en aquest camp. Nombres amb decimals (p.e. 1,25) no estan permesos.',
-	numeric:'Per favor introdueix sols valors numerics en aquest camp (p.e. "1" o "1,1" o "-1" o "-1,1").',
-	digits:'Per favor usa sols numeros i puntuacio en aquest camp (per exemple, un nombre de telefon amb guions i punts no esta permes).',
-	alpha:'Per favor utilitza lletres nomes (a-z) en aquest camp. No s´admiteixen espais ni altres caracters.',
-	alphanum:'Per favor, utilitza nomes lletres (a-z) o numeros (0-9) en aquest camp. No s´admiteixen espais ni altres caracters.',
-	dateSuchAs:'Per favor introdueix una data valida com {date}',
-	dateInFormatMDY:'Per favor introdueix una data valida com DD/MM/YYYY (p.e. "31/12/1999")',
-	email:'Per favor, introdueix una adreça de correu electronic valida. Per exemple,  "fred at domain.com".',
-	url:'Per favor introdueix una URL valida com http://www.google.com.',
-	currencyDollar:'Per favor introdueix una quantitat valida de €. Per exemple €100,00 .',
-	oneRequired:'Per favor introdueix alguna cosa per al menys una d´aquestes entrades.',
-	errorPrefix: 'Error: ',
-	warningPrefix: 'Avis: ',
-	//Form.Validator.Extras
-	noSpace: 'No poden haver espais en aquesta entrada.',
-	reqChkByNode: 'No hi han elements seleccionats.',
-	requiredChk: 'Aquest camp es obligatori.',
-	reqChkByName: 'Per favor selecciona una {label}.',
-	match: 'Aquest camp necessita coincidir amb el camp {matchName}',
-	startDate: 'la data de inici',
-	endDate: 'la data de fi',
-	currendDate: 'la data actual',
-	afterDate: 'La data deu ser igual o posterior a {label}.',
-	beforeDate: 'La data deu ser igual o anterior a {label}.',
-	startMonth: 'Per favor selecciona un mes d´orige',
-	sameMonth: 'Aquestes dos dates deuen estar dins del mateix mes - deus canviar una o altra.'
-script: Form.Validator.Czech.js
-description: Form Validator messages for Czech.
-authors:
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.Czech]
-MooTools.lang.set('cs-CZ', 'Form.Validator', {
-	required:'Tato položka je povinná.',
-	minLength:'Zadejte prosím alespoň {minLength} znaků (napsáno {length} znaků).',
-	maxLength:'Zadejte prosím méně než {maxLength} znaků (nápsáno {length} znaků).',
-	integer:'Zadejte prosím celé �?íslo. Desetinná �?ísla (např. 1.25) nejsou povolena.',
-	numeric:'Zadejte jen �?íselné hodnoty  (tj. "1" nebo "1.1" nebo "-1" nebo "-1.1").',
-	digits:'Zadejte prosím pouze �?ísla a interpunk�?ní znaménka(například telefonní �?íslo s poml�?kami nebo te�?kami je povoleno).',
-	alpha:'Zadejte prosím pouze písmena (a-z). Mezery nebo jiné znaky nejsou povoleny.',
-	alphanum:'Zadejte prosím pouze písmena (a-z) nebo �?íslice (0-9). Mezery nebo jiné znaky nejsou povoleny.',
-	dateSuchAs:'Zadejte prosím platné datum jako {date}',
-	dateInFormatMDY:'Zadejte prosím platné datum jako MM / DD / RRRR (tj. "12/31/1999")',
-	email:'Zadejte prosím platnou e-mailovou adresu. Například "fred at domain.com".',
-	url:'Zadejte prosím platnou URL adresu jako http://www.google.com.',
-	currencyDollar:'Zadejte prosím platnou �?ástku. Například $100.00.',
-	oneRequired:'Zadejte prosím alespoň jednu hodnotu pro tyto položky.',
-	errorPrefix: 'Chyba: ',
-	warningPrefix: 'Upozornění: ',
-	noSpace: 'V této položce nejsou povoleny mezery',
-	reqChkByNode: 'Nejsou vybrány žádné položky.',
-	requiredChk: 'Tato položka je vyžadována.',
-	reqChkByName: 'Prosím vyberte {label}.',
-	match: 'Tato položka se musí shodovat s položkou {matchName}',
-	startDate: 'datum zahájení',
-	endDate: 'datum ukon�?ení',
-	currendDate: 'aktuální datum',
-	afterDate: 'Datum by mělo být stejné nebo větší než {label}.',
-	beforeDate: 'Datum by mělo být stejné nebo menší než {label}.',
-	startMonth: 'Vyberte po�?áte�?ní měsíc.',
-	sameMonth: 'Tyto dva datumy musí být ve stejném měsíci - změňte jeden z nich.',
-    creditcard: 'Zadané �?íslo kreditní karty je neplatné. Prosím opravte ho. Bylo zadáno {length} �?ísel.'
-script: Form.Validator.Chinese.js
-description: Form.Validator messages in chinese (both simplified and traditional).
-authors:
- - 陈桂军 - guidy <at> ixuer [dot] net
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.Chinese]
-In Chinese:
-需�?指出的是:
-简体中文适用于中国大陆,
-�?体中文适用于香港�?澳门和�?�湾�?。
-简体中文和�?体中文在字体和语法上有很多的�?�?�之处。
-我�?�以确�?简体中文语言包的准确性,
-但对于�?体中文,我�?�以�?�?用户�?�以准确的�?�解,但无法�?�?语�?�符�?�他们的阅读习惯。
-如果您�?能确认的�?,�?�以�?�使用简体中文语言包,因为它是最通用的。
-In English:
-It should be noted that:
-Simplified  Chinese apply to mainland Chinese,
-Traditional Chinese apply to Hong Kong, Macao and Taiwan Province.
-There are a lot of different from Simplified  Chinese and Traditional Chinese , Contains font and syntax .
-I can assure Simplified Chinese language pack accuracy .
-For Traditional Chinese, I can only guarantee that users can understand, but not necessarily in line with their reading habits.
-If you are unsure, you can only use the simplified Chinese language pack, as it is the most common.
-// Simplified Chinese
-MooTools.lang.set('zhs-CN', 'Form.Validator', {
-	required:'这是必填项。',
-	minLength:'请至少输入 {minLength} 个字符 (已输入 {length} 个)。',
-	maxLength:'最多�?�能输入 {maxLength} 个字符 (已输入 {length} 个)。',
-	integer:'请输入一个整数,�?能包�?��?数点。例如:"1", "200"。',
-	numeric:'请输入一个数字,例如:"1", "1.1", "-1", "-1.1"。',
-	digits:'这里�?�能接�?�数字和标点的输入,标点�?�以是:"(", ")", ".", ":", "-", "+", "#"和空格。',
-	alpha:'请输入 A-Z 的 26 个字�?,�?能包�?�空格或任何其他字符。',
-	alphanum:'请输入 A-Z 的 26 个字�?或 0-9 的 10 个数字,�?能包�?�空格或任何其他字符。',
-	dateSuchAs:'请输入�?�法的日期格�?,如:{date}。',
-	dateInFormatMDY:'请输入�?�法的日期格�?,例如:MM/DD/YYYY ("12/31/1999")。',
-	email:'请输入�?�法的电�?信箱地�?�,例如:"fred at domain.com"。',
-	url:'请输入�?�法的 Url 地�?�,例如:http://www.google.com。',
-	currencyDollar:'请输入�?�法的货�?符�?�,例如:¥',
-	oneRequired:'请至少选择一项。',
-	errorPrefix: '错误:',
-	warningPrefix: '警告:'
-// Traditional Chinese
-MooTools.lang.set('zht-CN', 'Form.Validator', {
-	required:'這是必填項。',
-	minLength:'請至少�?�入 {minLength} 個字符(已�?�入 {length} 個)。',
-	maxLength:'最多�?�能�?�入 {maxLength} 個字符(已�?�入 {length} 個)。',
-	integer:'請�?�入一個整數,�?能包�?��?數點。例如:"1", "200"。',
-	numeric:'請�?�入一個數字,例如:"1", "1.1", "-1", "-1.1"。',
-	digits:'這裡�?�能接�?�數字和標點的�?�入,標點�?�以是:"(", ")", ".", ":", "-", "+", "#"和空格。',
-	alpha:'請�?�入 A-Z 的 26 個字�?,�?能包�?�空格或任何其他字符。',
-	alphanum:'請�?�入 A-Z 的 26 個字�?或 0-9 的 10 個數字,�?能包�?�空格或任何其他字符。',
-	dateSuchAs:'請�?�入�?�法的日期格�?,如:{date}。',
-	dateInFormatMDY:'請�?�入�?�法的日期格�?,例如:MM/DD/YYYY ("12/31/1999")。',
-	email:'請�?�入�?�法的電�?信箱地�?�,例如:"fred at domain.com"。',
-	url:'請�?�入�?�法的 Url 地�?�,例如:http://www.google.com。',
-	currencyYuan:'請�?�入�?�法的貨幣符號,例如:¥',
-	oneRequired:'請至少�?�擇一項。',
-	errorPrefix: '錯誤:',
-Form.Validator.add('validate-currency-yuan', {
-	errorMsg: function(){
-		return Form.Validator.getMsg('currencyYuan');
-	test: function(element) {
-		// [ï¿¥]1[##][,###]+[.##]
-		// [ï¿¥]1###+[.##]
-		// [ï¿¥]0.##
-		// [ï¿¥].##
-		return Form.Validator.getValidator('IsEmpty').test(element) ||  (/^ï¿¥?\-?([1-9]{1}[0-9]{0,2}(\,[0-9]{3})*(\.[0-9]{0,2})?|[1-9]{1}\d*(\.[0-9]{0,2})?|0(\.[0-9]{0,2})?|(\.[0-9]{1,2})?)$/).test(element.get('value'));
-script: Form.Validator.Dutch.js
-description: Form.Validator messages in Dutch.
-authors:
- - Lennart Pilon
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.Dutch]
-MooTools.lang.set('nl-NL', 'Form.Validator', {
-	required:'Dit veld is verplicht.',
-	minLength:'Vul minimaal {minLength} karakters in (je hebt {length} karakters ingevoerd).',
-	maxLength:'Vul niet meer dan {maxLength} karakters in (je hebt {length} karakters ingevoerd).',
-	integer:'Vul een getal in. Getallen met decimalen (bijvoorbeeld 1,25) zijn niet toegestaan.',
-	numeric:'Vul alleen numerieke waarden in (bijvoorbeeld. "1" of "1.1" of "-1" of "-1.1").',
-	digits:'Vul alleen nummers en leestekens in (bijvoorbeeld een telefoonnummer met een streepje).',
-	alpha:'Vul alleen letters in (a-z). Spaties en andere karakters zijn niet toegestaan.',
-	alphanum:'Vul alleen letters in (a-z) of nummers (0-9). Spaties en andere karakters zijn niet toegestaan.',
-	dateSuchAs:'Vul een geldige datum in, zoals {date}',
-	dateInFormatMDY:'Vul een geldige datum, in het formaat MM/DD/YYYY (bijvoorbeeld "12/31/1999")',
-	email:'Vul een geldig e-mailadres in. Bijvoorbeeld "fred at domein.nl".',
-	url:'Vul een geldige URL in, zoals http://www.google.nl.',
-	currencyDollar:'Vul een geldig $ bedrag in. Bijvoorbeeld $100.00 .',
-	oneRequired:'Vul iets in bij minimaal een van de invoervelden.',
-	warningPrefix: 'Waarschuwing: ',
-	errorPrefix: 'Fout: '
-script: Form.Validator.Estonian.js
-authors:
- - Kevin Valdek
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.Estonian]
-MooTools.lang.set('et-EE', 'Form.Validator', {
-	required:'Väli peab olema täidetud.',
-	minLength:'Palun sisestage vähemalt {minLength} tähte (te sisestasite {length} tähte).',
-	maxLength:'Palun ärge sisestage rohkem kui {maxLength} tähte (te sisestasite {length} tähte).',
-	integer:'Palun sisestage väljale täisarv. Kümnendarvud (näiteks 1.25) ei ole lubatud.',
-	numeric:'Palun sisestage ainult numbreid väljale (näiteks "1", "1.1", "-1" või "-1.1").',
-	digits:'Palun kasutage ainult numbreid ja kirjavahemärke (telefoninumbri sisestamisel on lubatud kasutada kriipse ja punkte).',
-	alpha:'Palun kasutage ainult tähti (a-z). Tühikud ja teised sümbolid on keelatud.',
-	alphanum:'Palun kasutage ainult tähti (a-z) või numbreid (0-9). Tühikud ja teised sümbolid on keelatud.',
-	dateSuchAs:'Palun sisestage kehtiv kuupäev kujul {date}',
-	dateInFormatMDY:'Palun sisestage kehtiv kuupäev kujul MM.DD.YYYY (näiteks: "12.31.1999").',
-	email:'Palun sisestage kehtiv e-maili aadress (näiteks: "fred at domain.com").',
-	url:'Palun sisestage kehtiv URL (näiteks: http://www.google.com).',
-	currencyDollar:'Palun sisestage kehtiv $ summa (näiteks: $100.00).',
-	oneRequired:'Palun sisestage midagi vähemalt ühele antud väljadest.',
-	errorPrefix: 'Viga: ',
-	warningPrefix: 'Hoiatus: ',
-	noSpace: 'Väli ei tohi sisaldada tühikuid.',
-	reqChkByNode: 'Ükski väljadest pole valitud.',
-	requiredChk: 'Välja täitmine on vajalik.',
-	reqChkByName: 'Palun valige üks {label}.',
-	match: 'Väli peab sobima {matchName} väljaga',
-	startDate: 'algkuupäev',
-	endDate: 'lõppkuupäev',
-	currendDate: 'praegune kuupäev',
-	afterDate: 'Kuupäev peab olema võrdne või pärast {label}.',
-	beforeDate: 'Kuupäev peab olema võrdne või enne {label}.',
-	startMonth: 'Palun valige algkuupäev.',
-	sameMonth: 'Antud kaks kuupäeva peavad olema samas kuus - peate muutma ühte kuupäeva.'
-script: Form.Validator.German.js
-authors:
- - Frank Rossi
- - Ulrich Petri
- - Fabian Beiner
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.German]
-MooTools.lang.set('de-DE', 'Form.Validator', {
-	required: 'Dieses Eingabefeld muss ausgef&uuml;llt werden.',
-	minLength: 'Geben Sie bitte mindestens {minLength} Zeichen ein (Sie haben nur {length} Zeichen eingegeben).',
-	maxLength: 'Geben Sie bitte nicht mehr als {maxLength} Zeichen ein (Sie haben {length} Zeichen eingegeben).',
-	integer: 'Geben Sie in diesem Eingabefeld bitte eine ganze Zahl ein. Dezimalzahlen (z.B. &quot;1.25&quot;) sind nicht erlaubt.',
-	numeric: 'Geben Sie in diesem Eingabefeld bitte nur Zahlenwerte (z.B. &quot;1&quot;, &quot;1.1&quot;, &quot;-1&quot; oder &quot;-1.1&quot;) ein.',
-	digits: 'Geben Sie in diesem Eingabefeld bitte nur Zahlen und Satzzeichen ein (z.B. eine Telefonnummer mit Bindestrichen und Punkten ist erlaubt).',
-	alpha: 'Geben Sie in diesem Eingabefeld bitte nur Buchstaben (a-z) ein. Leerzeichen und andere Zeichen sind nicht erlaubt.',
-	alphanum: 'Geben Sie in diesem Eingabefeld bitte nur Buchstaben (a-z) und Zahlen (0-9) ein. Leerzeichen oder andere Zeichen sind nicht erlaubt.',
-	dateSuchAs: 'Geben Sie bitte ein g&uuml;ltiges Datum ein (z.B. &quot;{date}&quot;).',
-	dateInFormatMDY: 'Geben Sie bitte ein g&uuml;ltiges Datum im Format TT.MM.JJJJ ein (z.B. &quot;31.12.1999&quot;).',
-	email: 'Geben Sie bitte eine g&uuml;ltige E-Mail-Adresse ein (z.B. &quot;max at mustermann.de&quot;).',
-	url: 'Geben Sie bitte eine g&uuml;ltige URL ein (z.B. &quot;http://www.google.de&quot;).',
-	currencyDollar: 'Geben Sie bitte einen g&uuml;ltigen Betrag in EURO ein (z.B. 100.00&#8364;).',
-	oneRequired: 'Bitte f&uuml;llen Sie mindestens ein Eingabefeld aus.',
-	errorPrefix: 'Fehler: ',
-	warningPrefix: 'Warnung: ',
-	noSpace: 'Es darf kein Leerzeichen in diesem Eingabefeld sein.',
-	reqChkByNode: 'Es wurden keine Elemente gew&auml;hlt.',
-	requiredChk: 'Dieses Feld muss ausgef&uuml;llt werden.',
-	reqChkByName: 'Bitte w&auml;hlen Sie ein {label}.',
-	match: 'Dieses Eingabefeld muss mit dem {matchName} Eingabefeld &uuml;bereinstimmen.',
-	startDate: 'Das Anfangsdatum',
-	endDate: 'Das Enddatum',
-	currendDate: 'Das aktuelle Datum',
-	afterDate: 'Das Datum sollte zur gleichen Zeit oder sp&auml;ter sein als {label}.',
-	beforeDate: 'Das Datum sollte zur gleichen Zeit oder fr&uuml;her sein als {label}.',
-	startMonth: 'W&auml;hlen Sie bitte einen Anfangsmonat',
-	sameMonth: 'Diese zwei Datumsangaben m&uuml;ssen im selben Monat sein - Sie m&uuml;ssen eines von beiden ver&auml;ndern.',
-	creditcard: 'Die eingegebene Kreditkartennummer ist ung&uuml;ltig. Bitte &uuml;berpr&uuml;fen Sie diese und versuchen Sie es erneut. {length} Zahlen eingegeben.'
-script: Form.Validator.German.CH.js
-authors:
-requires:
- - /Lang
- - /Form.Validator.German
-provides: [Form.Validator.German.CH]
-MooTools.lang.set('de-CH', 'Form.Validator', {
-  required:'Dieses Feld ist obligatorisch.',
-  minLength:'Geben Sie bitte mindestens {minLength} Zeichen ein (Sie haben {length} Zeichen eingegeben).',
-  maxLength:'Bitte geben Sie nicht mehr als {maxLength} Zeichen ein (Sie haben {length} Zeichen eingegeben).',
-  integer:'Geben Sie bitte eine ganze Zahl ein. Dezimalzahlen (z.B. 1.25) sind nicht erlaubt.',
-  numeric:'Geben Sie bitte nur Zahlenwerte in dieses Eingabefeld ein (z.B. &quot;1&quot;, &quot;1.1&quot;, &quot;-1&quot; oder &quot;-1.1&quot;).',
-  digits:'Benutzen Sie bitte nur Zahlen und Satzzeichen in diesem Eingabefeld (erlaubt ist z.B. eine Telefonnummer mit Bindestrichen und Punkten).',
-  alpha:'Benutzen Sie bitte nur Buchstaben (a-z) in diesem Feld. Leerzeichen und andere Zeichen sind nicht erlaubt.',
-  alphanum:'Benutzen Sie bitte nur Buchstaben (a-z) und Zahlen (0-9) in diesem Eingabefeld. Leerzeichen und andere Zeichen sind nicht erlaubt.',
-  dateSuchAs:'Geben Sie bitte ein g&uuml;ltiges Datum ein. Wie zum Beispiel {date}',
-  dateInFormatMDY:'Geben Sie bitte ein g&uuml;ltiges Datum ein. Wie zum Beispiel TT.MM.JJJJ (z.B. &quot;31.12.1999&quot;)',
-  email:'Geben Sie bitte eine g&uuml;ltige E-Mail Adresse ein. Wie zum Beispiel &quot;maria at bernasconi.ch&quot;.',
-  url:'Geben Sie bitte eine g&uuml;ltige URL ein. Wie zum Beispiel http://www.google.ch.',
-  currencyDollar:'Geben Sie bitte einen g&uuml;ltigen Betrag in Schweizer Franken ein. Wie zum Beispiel 100.00 CHF .',
-  oneRequired:'Machen Sie f&uuml;r mindestens eines der Eingabefelder einen Eintrag.',
-  noSpace: 'In diesem Eingabefeld darf kein Leerzeichen sein.',
-  requiredChk: 'Dieses Feld ist obligatorisch.',
-  match: 'Dieses Eingabefeld muss mit dem Feld {matchName} &uuml;bereinstimmen.',
-  afterDate: 'Das Datum sollte zur gleichen Zeit oder sp&auml;ter sein {label}.',
-  beforeDate: 'Das Datum sollte zur gleichen Zeit oder fr&uuml;her sein {label}.',
-  sameMonth: 'Diese zwei Datumsangaben m&uuml;ssen im selben Monat sein - Sie m&uuml;ssen eine von beiden ver&auml;ndern.'
-script: Form.Validator.French.js
-description: Form.Validator messages in French.
-authors:
- - Miquel Hudin
- - Nicolas Sorosac <nicolas <dot> sorosac <at> gmail <dot> com>
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.French]
-MooTools.lang.set('fr-FR', 'Form.Validator', {
-  required:'Ce champ est obligatoire.',
-  minLength:'Veuillez saisir un minimum de {minLength} caract&egrave;re(s) (vous avez saisi {length} caract&egrave;re(s)).',
-  maxLength:'Veuillez saisir un maximum de {maxLength} caract&egrave;re(s) (vous avez saisi {length} caract&egrave;re(s)).',
-  integer:'Veuillez saisir un nombre entier dans ce champ. Les nombres d&eacute;cimaux (ex : "1,25") ne sont pas autoris&eacute;s.',
-  numeric:'Veuillez saisir uniquement des chiffres dans ce champ (ex : "1" ou "1,1" ou "-1" ou "-1,1").',
-  digits:'Veuillez saisir uniquement des chiffres et des signes de ponctuation dans ce champ (ex : un num&eacute;ro de t&eacute;l&eacute;phone avec des traits d\'union est autoris&eacute;).',
-  alpha:'Veuillez saisir uniquement des lettres (a-z) dans ce champ. Les espaces ou autres caract&egrave;res ne sont pas autoris&eacute;s.',
-  alphanum:'Veuillez saisir uniquement des lettres (a-z) ou des chiffres (0-9) dans ce champ. Les espaces ou autres caract&egrave;res ne sont pas autoris&eacute;s.',
-  dateSuchAs:'Veuillez saisir une date correcte comme {date}',
-  dateInFormatMDY:'Veuillez saisir une date correcte, au format JJ/MM/AAAA (ex : "31/11/1999").',
-  email:'Veuillez saisir une adresse de courrier &eacute;lectronique. Par example "fred at domaine.com".',
-  url:'Veuillez saisir une URL, comme http://www.google.com.',
-  currencyDollar:'Veuillez saisir une quantit&eacute; correcte. Par example 100,00&euro;.',
-  oneRequired:'Veuillez s&eacute;lectionner au moins une de ces options.',
-  errorPrefix: 'Erreur : ',
-  warningPrefix: 'Attention : ',
-  noSpace: 'Ce champ n\'accepte pas les espaces.',
-  reqChkByNode: 'Aucun &eacute;l&eacute;ment n\'est s&eacute;lectionn&eacute;.',
-  requiredChk: 'Ce champ est obligatoire.',
-  reqChkByName: 'Veuillez s&eacute;lectionner un(e) {label}.',
-  match: 'Ce champ doit correspondre avec le champ {matchName}.',
-  startDate: 'date de d&eacute;but',
-  endDate: 'date de fin',
-  currendDate: 'date actuelle',
-  afterDate: 'La date doit &ecirc;tre identique ou post&eacute;rieure &agrave; {label}.',
-  beforeDate: 'La date doit &ecirc;tre identique ou ant&eacute;rieure &agrave; {label}.',
-  startMonth: 'Veuillez s&eacute;lectionner un mois de d&eacute;but.',
-  sameMonth: 'Ces deux dates doivent &ecirc;tre dans le m&ecirc;me mois - vous devez en modifier une.'
-script: Form.Validator.Italian.js
-description: Form.Validator messages in Italian.
-authors:
- - Leonardo Laureti
- - Andrea Novero
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.Italian]
-MooTools.lang.set('it-IT', 'Form.Validator', {
-	required:'Il campo &egrave; obbligatorio.',
-	minLength:'Inserire almeno {minLength} caratteri (ne sono stati inseriti {length}).',
-	maxLength:'Inserire al massimo {maxLength} caratteri (ne sono stati inseriti {length}).',
-	integer:'Inserire un numero intero. Non sono consentiti decimali (es.: 1.25).',
-	numeric:'Inserire solo valori numerici (es.: "1" oppure "1.1" oppure "-1" oppure "-1.1").',
-	digits:'Inserire solo numeri e caratteri di punteggiatura. Per esempio &egrave; consentito un numero telefonico con trattini o punti.',
-	alpha:'Inserire solo lettere (a-z). Non sono consentiti spazi o altri caratteri.',
-	alphanum:'Inserire solo lettere (a-z) o numeri (0-9). Non sono consentiti spazi o altri caratteri.',
-	dateSuchAs:'Inserire una data valida del tipo {date}',
-	dateInFormatMDY:'Inserire una data valida nel formato MM/GG/AAAA (es.: "12/31/1999")',
-	email:'Inserire un indirizzo email valido. Per esempio "nome at dominio.com".',
-	url:'Inserire un indirizzo valido. Per esempio "http://www.dominio.com".',
-	currencyDollar:'Inserire un importo valido. Per esempio "$100.00".',
-	oneRequired:'Completare almeno uno dei campi richiesti.',
-	errorPrefix: 'Errore: ',
-	warningPrefix: 'Attenzione: ',
-	noSpace: 'Non sono consentiti spazi.',
-	reqChkByNode: 'Nessuna voce selezionata.',
-	requiredChk: 'Il campo &egrave; obbligatorio.',
-	reqChkByName: 'Selezionare un(a) {label}.',
-	match: 'Il valore deve corrispondere al campo {matchName}',
-	startDate: 'data d\'inizio',
-	endDate: 'data di fine',
-	currendDate: 'data attuale',
-	afterDate: 'La data deve corrispondere o essere successiva al {label}.',
-	beforeDate: 'La data deve corrispondere o essere precedente al {label}.',
-	startMonth: 'Selezionare un mese d\'inizio',
-	sameMonth: 'Le due date devono essere dello stesso mese - occorre modificarne una.'
-script: Form.Validator.Norwegian.js
-description: Form.Validator messages in Norwegian.
-authors:
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.Norwegian]
-MooTools.lang.set('no-NO', 'Form.Validator', {
-   required:'Dette feltet er påkrevd.',
-   minLength:'Vennligst skriv inn minst {minLength} tegn (du skrev {length} tegn).',
-   maxLength:'Vennligst skriv inn maksimalt {maxLength} tegn (du skrev {length} tegn).',
-   integer:'Vennligst skriv inn et tall i dette feltet. Tall med desimaler (for eksempel 1,25) er ikke tillat.',
-   numeric:'Vennligst skriv inn kun numeriske verdier i dette feltet (for eksempel "1", "1.1", "-1" eller "-1.1").',
-   digits:'Vennligst bruk kun nummer og skilletegn i dette feltet.',
-   alpha:'Vennligst bruk kun bokstaver (a-z) i dette feltet. Ingen mellomrom eller andre tegn er tillat.',
-   alphanum:'Vennligst bruk kun bokstaver (a-z) eller nummer (0-9) i dette feltet. Ingen mellomrom eller andre tegn er tillat.',
-   dateSuchAs:'Vennligst skriv inn en gyldig dato, som {date}',
-   dateInFormatMDY:'Vennligst skriv inn en gyldig dato, i formatet MM/DD/YYYY (for eksempel "12/31/1999")',
-   email:'Vennligst skriv inn en gyldig epost-adresse. For eksempel "espen at domene.no".',
-   url:'Vennligst skriv inn en gyldig URL, for eksempel http://www.google.no.',
-   currencyDollar:'Vennligst fyll ut et gyldig $ beløp. For eksempel $100.00 .',
-   oneRequired:'Vennligst fyll ut noe i minst ett av disse feltene.',
-   errorPrefix: 'Feil: ',
-   warningPrefix: 'Advarsel: '
-script: Form.Validator.Polish.js
-authors:
- - Oskar Krawczyk
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.Polish]
-MooTools.lang.set('pl-PL', 'Form.Validator', {
-	required:'To pole jest wymagane.',
-	minLength:'Wymagane jest przynajmniej {minLength} znaków (wpisanych zostało tylko {length}).',
-	maxLength:'Dozwolone jest nie więcej niż {maxLength} znaków (wpisanych zostało {length})',
-	integer:'To pole wymaga liczb całych. Liczby dziesiętne (np. 1.25) są niedozwolone.',
-	numeric:'Prosimy używać tylko numerycznych wartości w tym polu (np. "1", "1.1", "-1" lub "-1.1").',
-	digits:'Prosimy używać liczb oraz zankow punktuacyjnych w typ polu (dla przykładu, przy numerze telefonu myślniki i kropki są dozwolone).',
-	alpha:'Prosimy używać tylko liter (a-z) w tym polu. Spacje oraz inne znaki są niedozwolone.',
-	alphanum:'Prosimy używać tylko liter (a-z) lub liczb (0-9) w tym polu. Spacje oraz inne znaki są niedozwolone.',
-	dateSuchAs:'Prosimy podać prawidłową datę w formacie: {date}',
-	dateInFormatMDY:'Prosimy podać poprawną date w formacie DD.MM.RRRR (i.e. "12.01.2009")',
-	email:'Prosimy podać prawidłowy adres e-mail, np. "jan at domena.pl".',
-	url:'Prosimy podać prawidłowy adres URL, np. http://www.google.pl.',
-	currencyDollar:'Prosimy podać prawidłową sumę w PLN. Dla przykładu: 100.00 PLN.',
-	oneRequired:'Prosimy wypełnić chociaż jedno z pól.',
-	errorPrefix: 'Błąd: ',
-	warningPrefix: 'Uwaga: ',
-	noSpace: 'W tym polu nie mogą znajdować się spacje.',
-	reqChkByNode: 'Brak zaznaczonych elementów.',
-	requiredChk: 'To pole jest wymagane.',
-	reqChkByName: 'Prosimy wybrać z {label}.',
-	match: 'To pole musi być takie samo jak {matchName}',
-	startDate: 'data poczÄ…tkowa',
-	endDate: 'data końcowa',
-	currendDate: 'aktualna data',
-	afterDate: 'Podana data poinna być taka sama lub po {label}.',
-	beforeDate: 'Podana data poinna być taka sama lub przed {label}.',
-	startMonth: 'Prosimy wybrać początkowy miesiąc.',
-	sameMonth: 'Te dwie daty muszą być w zakresie tego samego miesiąca - wymagana jest zmiana któregoś z pól.'
-script: Form.Validator.Portuguese.js
-description: Form.Validator messages in Portuguese.
-authors:
- - Miquel Hudin
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.Portuguese]
-MooTools.lang.set('pt-PT', 'Form.Validator', {
-	required:'Este campo é necessário.',
-	minLength:'Digite pelo menos{minLength} caracteres (comprimento {length} caracteres).',
-	maxLength:'Não insira mais de {maxLength} caracteres (comprimento {length} caracteres).',
-	integer:'Digite um número inteiro neste domínio. Com números decimais (por exemplo, 1,25), não são permitidas.',
-	numeric:'Digite apenas valores numéricos neste domínio (p.ex., "1" ou "1.1" ou "-1" ou "-1,1").',
-	digits:'Por favor, use números e pontuação apenas neste campo (p.ex., um número de telefone com traços ou pontos é permitida).',
-	alpha:'Por favor use somente letras (a-z), com nesta área. Não utilize espaços nem outros caracteres são permitidos.',
-	alphanum:'Use somente letras (a-z) ou números (0-9) neste campo. Não utilize espaços nem outros caracteres são permitidos.',
-	dateSuchAs:'Digite uma data válida, como {date}',
-	dateInFormatMDY:'Digite uma data válida, como DD/MM/YYYY (p.ex. "31/12/1999")',
-	email:'Digite um endereço de email válido. Por exemplo "fred at domain.com".',
-	url:'Digite uma URL válida, como http://www.google.com.',
-	currencyDollar:'Digite um valor válido $. Por exemplo $ 100,00. ',
-	oneRequired:'Digite algo para pelo menos um desses insumos.',
-	errorPrefix: 'Erro: ',
-	warningPrefix: 'Aviso: '
-}).set('pt-PT', 'Date', {
-script: Form.Validator.Portuguese.BR.js
-description: Form.Validator messages in Portuguese-BR.
-authors:
- - Fábio Miranda Costa
-requires:
- - /Lang
- - /Form.Validator.Portuguese
-provides: [Form.Validator.Portuguese.BR]
-MooTools.lang.set('pt-BR', 'Form.Validator', {
-	required: 'Este campo é obrigatório.',
-	minLength: 'Digite pelo menos {minLength} caracteres (tamanho atual: {length}).',
-	maxLength: 'Não digite mais de {maxLength} caracteres (tamanho atual: {length}).',
-	integer: 'Por favor digite apenas um número inteiro neste campo. Não são permitidos números decimais (por exemplo, 1,25).',
-	numeric: 'Por favor digite apenas valores numéricos neste campo (por exemplo, "1" ou "1.1" ou "-1" ou "-1,1").',
-	digits: 'Por favor use apenas números e pontuação neste campo (por exemplo, um número de telefone com traços ou pontos é permitido).',
-	alpha: 'Por favor use somente letras (a-z). Espaço e outros caracteres não são permitidos.',
-	alphanum: 'Use somente letras (a-z) ou números (0-9) neste campo. Espaço e outros caracteres não são permitidos.',
-	dateSuchAs: 'Digite uma data válida, como {date}',
-	dateInFormatMDY: 'Digite uma data válida, como DD/MM/YYYY (por exemplo, "31/12/1999")',
-	email: 'Digite um endereço de email válido. Por exemplo "nome at dominio.com".',
-	url: 'Digite uma URL válida. Exemplo: http://www.google.com.',
-	currencyDollar: 'Digite um valor em dinheiro válido. Exemplo: R$100,00 .',
-	oneRequired: 'Digite algo para pelo menos um desses campos.',
-	warningPrefix: 'Aviso: ',
-	noSpace: 'Não é possível digitar espaços neste campo.',
-	reqChkByNode: 'Não foi selecionado nenhum item.',
-	requiredChk: 'Este campo é obrigatório.',
-	reqChkByName: 'Por favor digite um {label}.',
-	match: 'Este campo deve ser igual ao campo {matchName}.',
-	startDate: 'a data inicial',
-	endDate: 'a data final',
-	currendDate: 'a data atual',
-	afterDate: 'A data deve ser igual ou posterior a {label}.',
-	beforeDate: 'A data deve ser igual ou anterior a {label}.',
-	startMonth: 'Por favor selecione uma data inicial.',
-	sameMonth: 'Estas duas datas devem ter o mesmo mês - você deve modificar uma das duas.',
-	creditcard: 'O número do cartão de crédito informado é inválido. Por favor verifique o valor e tente novamente. {length} números informados.'
-script: Form.Validator.Russian.js
-description: Form.Validator messages in Russian (utf-8 and cp1251).
-authors:
- - Chernodarov Egor
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.Russian]
-MooTools.lang.set('ru-RU-unicode', 'Form.Validator', {
-	required:'Это поле об�?зательно к заполнению.',
-	minLength:'Пожалуй�?та, введите хот�? бы {minLength} �?имволов (Вы ввели {length}).',
-	maxLength:'Пожалуй�?та, введите не больше {maxLength} �?имволов (Вы ввели {length}).',
-	integer:'Пожалуй�?та, введите в �?то поле чи�?ло. Дробные чи�?ла (например 1.25) тут не разрешены.',
-	numeric:'Пожалуй�?та, введите в �?то поле чи�?ло (например "1" или "1.1", или "-1", или "-1.1").',
-	digits:'В �?том поле Вы можете и�?пользовать только цифры и знаки пунктуации (например, телефонный номер �?о знаками дефи�?а или �? точками).',
-	alpha:'В �?том поле можно и�?пользовать только латин�?кие буквы (a-z). Пробелы и другие �?имволы запрещены.',
-	alphanum:'В �?том поле можно и�?пользовать только латин�?кие буквы (a-z) и цифры (0-9). Пробелы и другие �?имволы запрещены.',
-	dateSuchAs:'Пожалуй�?та, введите корректную дату {date}',
-	dateInFormatMDY:'Пожалуй�?та, введите дату в формате ММ/ДД/ГГГГ (например "12/31/1999")',
-	email:'Пожалуй�?та, введите корректный емейл-адре�?. Дл�? примера "fred at domain.com".',
-	url:'Пожалуй�?та, введите правильную �?�?ылку вида http://www.google.com.',
-	currencyDollar:'Пожалуй�?та, введите �?умму в долларах. �?апример: $100.00 .',
-	oneRequired:'Пожалуй�?та, выберите хоть что-нибудь в одном из �?тих полей.',
-	errorPrefix: 'Ошибка: ',
-	warningPrefix: 'Внимание: '
-//translation in windows-1251 codepage
-MooTools.lang.set('ru-RU', 'Form.Validator', {
-	required:'�?òî ïîëå îáÿçàòåëüíî ê çàïîëíåíèþ.',
-	minLength:'�?îæàëóéñòà, ââåäèòå õîòÿ áû {minLength} ñèìâîëîâ (Âû ââåëè {length}).',
-	maxLength:'�?îæàëóéñòà, ââåäèòå íå áîëüøå {maxLength} ñèìâîëîâ (Âû ââåëè {length}).',
-	integer:'�?îæàëóéñòà, ââåäèòå â ýòî ïîëå ÷èñëî. Äðîáíûå ÷èñëà (íàïðèìåð 1.25) òóò íå ðàçðåøåíû.',
-	numeric:'�?îæàëóéñòà, ââåäèòå â ýòî ïîëå ÷èñëî (íàïðèìåð "1" èëè "1.1", èëè "-1", èëè "-1.1").',
-	digits:' ýòîì ïîëå Âû ìîæåòå èñïîëüçîâàòü òîëüêî öèôðû è çíàêè ïóíêòóàöèè (íàïðèìåð, òåëåôîííûé íîìåð ñî çíàêàìè äåôèñà èëè ñ òî÷êàìè).',
-	alpha:'Â ýòîì ïîëå ìîæíî èñïîëüçîâàòü òîëüêî ëàòèíñêèå áóêâû (a-z). �?ðîáåëû è äðóãèå ñèìâîëû çàïðåùåíû.',
-	alphanum:'Â ýòîì ïîëå ìîæíî èñïîëüçîâàòü òîëüêî ëàòèíñêèå áóêâû (a-z) è öèôðû (0-9). �?ðîáåëû è äðóãèå ñèìâîëû çàïðåùåíû.',
-	dateSuchAs:'�?îæàëóéñòà, ââåäèòå êîððåêòíóþ äàòó {date}',
-	dateInFormatMDY:'�?îæàëóéñòà, ââåäèòå äàòó â ôîðìàòå ÌÌ/ÄÄ/ÃÃÃÃ (íàïðèìåð "12/31/1999")',
-	email:'�?îæàëóéñòà, ââåäèòå êîððåêòíûé åìåéë-àäðåñ. Äëÿ ïðèìåðà "fred at domain.com".',
-	url:'�?îæàëóéñòà, ââåäèòå ïðàâèëüíóþ ññûëêó âèäà http://www.google.com.',
-	currencyDollar:'�?îæàëóéñòà, ââåäèòå ñóììó â äîëëàðàõ. �?àïðèìåð: $100.00 .',
-	oneRequired:'�?îæàëóéñòà, âûáåðèòå õîòü ÷òî-íèáóäü â îäíîì èç ýòèõ ïîëåé.',
-	errorPrefix: 'Îøèáêà: ',
-	warningPrefix: 'Âíèìàíèå: '
-script: Form.Validator.Spanish.js
-authors:
- - Ãlfons Sanchez
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.Spanish]
-MooTools.lang.set('es-ES', 'Form.Validator', {
-	required:'Este campo es obligatorio.',
-	minLength:'Por favor introduce al menos {minLength} caracteres (has introducido {length} caracteres).',
-	maxLength:'Por favor introduce no m&aacute;s de {maxLength} caracteres (has introducido {length} caracteres).',
-	integer:'Por favor introduce un n&uacute;mero entero en este campo. N&uacute;meros con decimales (p.e. 1,25) no se permiten.',
-	numeric:'Por favor introduce solo valores num&eacute;ricos en este campo (p.e. "1" o "1,1" o "-1" o "-1,1").',
-	digits:'Por favor usa solo n&uacute;meros y puntuaci&oacute;n en este campo (por ejemplo, un n&uacute;mero de tel&eacute;fono con guiones y puntos no esta permitido).',
-	alpha:'Por favor usa letras solo (a-z) en este campo. No se admiten espacios ni otros caracteres.',
-	alphanum:'Por favor, usa solo letras (a-z) o n&uacute;meros (0-9) en este campo. No se admiten espacios ni otros caracteres.',
-	dateSuchAs:'Por favor introduce una fecha v&aacute;lida como {date}',
-	dateInFormatMDY:'Por favor introduce una fecha v&aacute;lida como DD/MM/YYYY (p.e. "31/12/1999")',
-	email:'Por favor, introduce una direcci&oacute;n de email v&aacute;lida. Por ejemplo,  "fred at domain.com".',
-	url:'Por favor introduce una URL v&aacute;lida como http://www.google.com.',
-	currencyDollar:'Por favor introduce una cantidad v&aacute;lida de €. Por ejemplo €100,00 .',
-	oneRequired:'Por favor introduce algo para por lo menos una de estas entradas.',
-	noSpace: 'No pueden haber espacios en esta entrada.',
-	reqChkByNode: 'No hay elementos seleccionados.',
-	requiredChk: 'Este campo es obligatorio.',
-	reqChkByName: 'Por favor selecciona una {label}.',
-	match: 'Este campo necesita coincidir con el campo {matchName}',
-	startDate: 'la fecha de inicio',
-	endDate: 'la fecha de fin',
-	currendDate: 'la fecha actual',
-	afterDate: 'La fecha debe ser igual o posterior a {label}.',
-	beforeDate: 'La fecha debe ser igual o anterior a {label}.',
-	startMonth: 'Por favor selecciona un mes de origen',
-	sameMonth: 'Estas dos fechas deben estar en el mismo mes - debes cambiar una u otra.'
-script: Form.Validator.Swedish.js
-description: Date messages for Swedish.
-authors:
- - Martin Lundgren
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.Swedish]
-MooTools.lang.set('sv-SE', 'Form.Validator', {
-	required:'Fältet är obligatoriskt.',
-	minLength:'Ange minst {minLength} tecken (du angav {length} tecken).',
-	maxLength:'Ange högst {maxLength} tecken (du angav {length} tecken). ',
-	integer:'Ange ett heltal i fältet. Tal med decimaler (t.ex. 1,25) är inte tillåtna.',
-	numeric:'Ange endast numeriska värden i detta fält (t.ex. "1" eller "1.1" eller "-1" eller "-1,1").',
-	digits:'Använd endast siffror och skiljetecken i detta fält (till exempel ett telefonnummer med bindestreck tillåtet).',
-	alpha:'Använd endast bokstäver (a-ö) i detta fält. Inga mellanslag eller andra tecken är tillåtna.',
-	alphanum:'Använd endast bokstäver (a-ö) och siffror (0-9) i detta fält. Inga mellanslag eller andra tecken är tillåtna.',
-	dateSuchAs:'Ange ett giltigt datum som t.ex. {date}',
-	dateInFormatMDY:'Ange ett giltigt datum som t.ex. YYYY-MM-DD (i.e. "1999-12-31")',
-	email:'Ange en giltig e-postadress. Till exempel "erik at domain.com".',
-	url:'Ange en giltig webbadress som http://www.google.com.',
-	currencyDollar:'Ange en giltig belopp. Exempelvis 100,00.',
-	oneRequired:'Vänligen ange minst ett av dessa alternativ.',
-	errorPrefix: 'Fel: ',
-	warningPrefix: 'Varning: ',
-	noSpace: 'Det får inte finnas några mellanslag i detta fält.',
-	reqChkByNode: 'Inga objekt är valda.',
-	requiredChk: 'Detta är ett obligatoriskt fält.',
-	reqChkByName: 'Välj en {label}.',
-	match: 'Detta fält måste matcha {matchName}',
-	startDate: 'startdatumet',
-	endDate: 'slutdatum',
-	currendDate: 'dagens datum',
-	afterDate: 'Datumet bör vara samma eller senare än {label}.',
-	beforeDate: 'Datumet bör vara samma eller tidigare än {label}.',
-	startMonth: 'Välj en start månad',
-	sameMonth: 'Dessa två datum måste vara i samma månad - du måste ändra det ena eller det andra.'
-script: Form.Validator.Ukrainian.js
-description: Form.Validator messages in Ukrainian (utf-8).
-authors:
- - Slik
-requires:
- - /Lang
- - /Form.Validator
-provides: [Form.Validator.Ukrainian]
-MooTools.lang.set('uk-UA', 'Form.Validator', {
-	required:'Це поле повинне бути заповненим.',
-	minLength:'Введіть хоча б {minLength} �?имволів (Ви ввели {length}).',
-	maxLength:'Кількі�?ть �?имволів не може бути більше {maxLength} (Ви ввели {length}).',
-	integer:'Введіть в це поле чи�?ло. Дробові чи�?ла (наприклад 1.25) не дозволені.',
-	numeric:'Введіть в це поле чи�?ло (наприклад "1" або "1.1", або "-1", або "-1.1").',
-	digits:'В цьому полі ви можете викори�?товувати лише цифри і знаки пунктіації (наприклад, телефонний номер з знаками дефізу або з крапками).',
-	alpha:'В цьому полі можна викори�?товувати лише латин�?ькі літери (a-z). Пробіли і інші �?имволи заборонені.',
-	alphanum:'В цьому полі можна викори�?товувати лише латин�?ькі літери (a-z) і цифри (0-9). Пробіли і інші �?имволи заборонені.',
-	dateSuchAs:'Введіть коректну дату {date}.',
-	dateInFormatMDY:'Введіть дату в форматі ММ/ДД/РРРР (наприклад "12/31/2009").',
-	email:'Введіть коректну адре�?у електронної пошти (наприклад "name at domain.com").',
-	url:'Введіть коректне інтернет-по�?иланн�? (наприклад http://www.google.com).',
-	currencyDollar:'Введіть �?уму в доларах (наприклад "$100.00").',
-	oneRequired:'Заповніть одне з полів.',
-	errorPrefix: 'Помилка: ',
-	warningPrefix: 'Увага: '
 description: Jx namespace with methods and classes common to most Jx widgets
@@ -15230,10 +15230,10 @@
             } else {
                 if ($defined(size.width) && size.width >= 0) {
-                  this.setStyle('width', size.width);
+                  this.setStyle('width', width);
                 if ($defined(size.height) && size.height >= 0) {
-                  this.setStyle('height', size.height);
+                  this.setStyle('height', height);
@@ -15368,7 +15368,7 @@
             if (i == -1) {
                 rule = this.insertCssRule(selector, '', styleSheetName);
             } else {
-                if (Browser.Engine.name === 'trident') {
+                if (Browser.Engine.trident) {
                     rule = ss.sheet.rules[i];
                 } else {
                     rule = ss.sheet.cssRules[i];
@@ -15400,7 +15400,7 @@
             rule,
             text = selector + " {" + declaration + "}",
             index;
             if (declaration == '') {
                 //IE requires SOME text for the declaration. Passing '{}' will
                 //create an empty rule.
@@ -17914,98 +17914,98 @@
     submitButton: 'Speichern',
     cancelButton: 'Abbrechen'
+name: Locale.Russian
+description: Default translations of text strings used in JX for Russia (Russia) (ru-RU)
+license: MIT-style license.
+requires:
+ - More/Lang
+provides: [Locale.Russian]
+MooTools.lang.set('ru-RU-unicode', 'Jx', {
+	'widget': {
+		busyMessage: 'Обработка...'
+	'colorpalette': {
+		alphaLabel: 'alpha (%)'
+	notice: {
+		closeTip: 'закрыть Ñ?то Ñ?ообщение'
+	progressbar: {
+		messageText: 'Загрузка...',
+		progressText: '{progress} из {total}'
+	field: {
+		requiredText: '*'
+	file: {
+		browseLabel: 'Выбрать...'
+	'formatter.boolean': {
+		'true': 'Да',
+		'false': 'Ð?ет'
+	'formatter.currency': {
+		sign: 'Ñ€.'
+	'formatter.number': {
+		decimalSeparator: ',',
+    thousandsSeparator: ' '
+	splitter: {
+		barToolTip: 'потÑ?ни, чтобы изменить размер'
+	panelset: {
+	panel: {
+		collapseTooltip: 'Свернуть/Развернуть Панель',
+    collapseLabel: 'Свернуть',
+    expandLabel: 'Развернуть',
+    maximizeTooltip: 'Увеличить Панель',
+    maximizeLabel: 'Увеличить',
+    restoreTooltip: 'ВоÑ?Ñ?тановить Панель',
+    restoreLabel: 'ВоÑ?Ñ?тановить',
+    closeTooltip: 'Закрыть Панель',
+    closeLabel: 'Закрыть'
+	confirm: {
+		affirmativeLabel: 'Да',
+    negativeLabel: 'Ð?ет'
+	dialog: {
+		resizeToolTip: 'Изменить размер'
+	message: {
+		okButton: 'Ок'
+	prompt: {
+		okButton: 'Ок',
+		cancelButton: 'Отмена'
+	upload: {
+		buttonText: 'Загрузка файла'
+	'plugin.resize': {
+	  tooltip: 'ПотÑ?ни, чтобы изменить, двойной щелчок длÑ? авто размера.'
+  'plugin.editor': {
+    submitButton: 'Сохранить',
-name: Locale.Russian
-description: Default translations of text strings used in JX for Russia (Russia) (ru-RU)
-requires:
- - More/Lang
-provides: [Locale.Russian]
-MooTools.lang.set('ru-RU-unicode', 'Jx', {
-	'widget': {
-		busyMessage: 'Обработка...'
-	'colorpalette': {
-		alphaLabel: 'alpha (%)'
-	notice: {
-		closeTip: 'закрыть �?то �?ообщение'
-	progressbar: {
-		messageText: 'Загрузка...',
-		progressText: '{progress} из {total}'
-	field: {
-		requiredText: '*'
-	file: {
-		browseLabel: 'Выбрать...'
-	'formatter.boolean': {
-		'true': 'Да',
-		'false': '�?ет'
-	'formatter.currency': {
-		sign: 'Ñ€.'
-	'formatter.number': {
-		decimalSeparator: ',',
-    thousandsSeparator: ' '
-	splitter: {
-		barToolTip: 'пот�?ни, чтобы изменить размер'
-	panelset: {
-	panel: {
-		collapseTooltip: 'Свернуть/Развернуть Панель',
-    collapseLabel: 'Свернуть',
-    expandLabel: 'Развернуть',
-    maximizeTooltip: 'Увеличить Панель',
-    maximizeLabel: 'Увеличить',
-    restoreTooltip: 'Во�?�?тановить Панель',
-    restoreLabel: 'Во�?�?тановить',
-    closeTooltip: 'Закрыть Панель',
-    closeLabel: 'Закрыть'
-	confirm: {
-		affirmativeLabel: 'Да',
-    negativeLabel: '�?ет'
-	dialog: {
-		resizeToolTip: 'Изменить размер'
-	message: {
-		okButton: 'Ок'
-	prompt: {
-		okButton: 'Ок',
-		cancelButton: 'Отмена'
-	upload: {
-		buttonText: 'Загрузка файла'
-	'plugin.resize': {
-	  tooltip: 'Пот�?ни, чтобы изменить, двойной щелчок дл�? авто размера.'
-  'plugin.editor': {
-    submitButton: 'Сохранить',
 description: The basic record implementation. A store uses records to handle and manipulate data.
@@ -23030,7 +23030,7 @@
-// $Id: menu.js 966 2010-07-20 13:31:16Z pagameba $
+// $Id: menu.js 1012 2011-03-03 20:37:26Z pagameba $
  * Class: Jx.Menu
@@ -23145,7 +23145,8 @@
         this.subDomObj.addEvent('mouseenter', this.bound.mouseenter);
         this.subDomObj.addEvent('mouseleave', this.bound.mouseleave);
+        this.subDomObj.store('jxSubMenu', this);
         if (this.options.parent) {
             this.addTo(this.options.parent);
@@ -23308,10 +23309,13 @@
             target.descendantOf(this.subDomObj)) {
             return true;
         } else {
-            var ul = target.findElement('ul');
+            var ul = target.getParent('ul');
             if (ul) {
                 var sm = ul.retrieve('jxSubMenu');
                 if (sm) {
+                    if (sm.eventInMenu(e)) {
+                      return true;
                     var owner = sm.owner;
                     while (owner) {
                         if (owner == this) {
@@ -37136,32 +37140,32 @@
-name: Jx.Plugin.ToolbarContainer
-description: Namespace for Jx.Toolbar.Container
-requires:
- - Jx.Plugin
-provides: [Jx.Plugin.ToolbarContainer]
- * Class: Jx.Plugin.Toolbar
- * Toolbar plugin namespace
- * License:
- * Copyright (c) 2009, Jon Bomgardner.
- * This file is licensed under an MIT style license
+name: Jx.Plugin.ToolbarContainer
+description: Namespace for Jx.Toolbar.Container
+requires:
+ - Jx.Plugin
+provides: [Jx.Plugin.ToolbarContainer]
+ * Class: Jx.Plugin.Toolbar
+ * Toolbar plugin namespace
+ * License:
+ * Copyright (c) 2009, Jon Bomgardner.
+ * This file is licensed under an MIT style license
 Jx.Plugin.ToolbarContainer = {};/*
@@ -38111,7 +38115,7 @@
-// $Id: submenu.js 960 2010-06-06 22:23:16Z jonlb at comcast.net $
+// $Id: submenu.js 1012 2011-03-03 20:37:26Z pagameba $
  * Class: Jx.Menu.SubMenu
@@ -38194,6 +38198,7 @@
     setOwner: function(obj) {
         this.owner = obj;
+        this.menu.owner = obj;
      * Method: show
@@ -40102,7 +40107,7 @@
       if (this.tree) {
         this.tree.setDirty(true);
More information about the fusion-commits mailing list
