[fusion-commits] r2376 - trunk/layers/MapServer/php
svn_fusion at osgeo.org
Wed May 4 12:02:56 EDT 2011
Author: assefa
Date: 2011-05-04 09:02:55 -0700 (Wed, 04 May 2011)
New Revision: 2376
trunk/layers/MapServer/php/Query.php
Fix Raster query issue (#73)
Modified: trunk/layers/MapServer/php/Query.php
--- trunk/layers/MapServer/php/Query.php 2011-05-04 14:38:46 UTC (rev 2375)
+++ trunk/layers/MapServer/php/Query.php 2011-05-04 16:02:55 UTC (rev 2376)
@@ -108,6 +108,28 @@
$result->hasSelection = false;
$result->layers = array();
+/* Get the list of raster layers that are on. We will use it */
+/* when doing raster query. Turn them off here. Return them on */
+/* before the raster query. bug #73 */
+$aRasterLayerIndiceOn = array();
+$aRasterLayerIndiceDefault = array();
+for ($i=0; $i<$oMap->numlayers; $i++)
+ $oLayer = $oMap->GetLayer($i);
+ if($oLayer->type == MS_LAYER_RASTER)
+ if ($oLayer->status == MS_ON)
+ array_push($aRasterLayerIndiceOn, $i);
+ else if ($oLayer->status == MS_DEFAULT)
+ array_push($aRasterLayerIndiceDefault, $i);
+ $oLayer->set("status", MS_OFF);
if ($nLayers == 0) {
$nLayers = $oMap->numlayers;
$bAllLayers = true;
@@ -174,7 +196,23 @@
$result->queryFile = getSessionSavePath()."query.qy";
-/*raster query: limit the result to 100 if it is not already set in the map fle*/
+/* resttoe raster layer status #73 */
+for ($i=0; $i<count($aRasterLayerIndiceOn); $i++)
+ $oLayer = $oMap->getlayer($aRasterLayerIndiceOn[$i]);
+ $oLayer->set("status", MS_ON);
+for ($i=0; $i<count($aRasterLayerIndiceDefault); $i++)
+ $oLayer = $oMap->getlayer($aRasterLayerIndiceDefault[$i]);
+ $oLayer->set("status", MS_DEFAULT);
+/*raster query: limit the result to 100 if it is not already set in the map file*/
for ($i=0; $i<$nLayers; $i++) {
if (!$bAllLayers) {
$oLayer = $oMap->GetLayerByName($layers[$i]);
@@ -186,6 +224,7 @@
continue;
$aProcessings = $oLayer->getprocessing();
$nCount = count($aProcessings);
More information about the fusion-commits
