[fusion-commits] r2386 - in trunk/layers/MapServer: . php
svn_fusion at osgeo.org
Fri May 27 15:11:57 EDT 2011
Author: madair
Date: 2011-05-27 12:11:57 -0700 (Fri, 27 May 2011)
New Revision: 2386
trunk/layers/MapServer/MapServer.js
trunk/layers/MapServer/php/LoadMap.php
re #452: only clear the session selection_array on LoadMap, not reloadMap
Modified: trunk/layers/MapServer/MapServer.js
--- trunk/layers/MapServer/MapServer.js 2011-05-27 10:57:43 UTC (rev 2385)
+++ trunk/layers/MapServer/MapServer.js 2011-05-27 19:11:57 UTC (rev 2386)
@@ -165,13 +165,18 @@
restoreStateCB: function(oResponse){
- if(oResponse.error){
+ if(oResponse.error) {
Fusion.reportError(new Fusion.Error(Fusion.Error.WARNING, "Error Restoring Map State - "+oResponse.error));
+ } else {
+ this.oRestoredState = oResponse;
+ var a = this.oRestoredState.extents.split(',');
+ this.mapWidget.mapGroup.initialView = {
+ minX: parseFloat(a[0]),
+ minY: parseFloat(a[1]),
+ maxX: parseFloat(a[2]),
+ maxY: parseFloat(a[3])
- else
- this.oRestoredState = oResponse;
// done with session create, fire the event.
this.triggerEvent(Fusion.Event.MAP_SESSION_CREATED);
@@ -353,7 +358,8 @@
var params = {
'mapname': this._sMapname,
- 'session': this.getSessionID()
+ 'session': this.getSessionID(),
+ 'reload': true
if (this.mapMetadataKeys) {
params.map_metadata = this.mapMetadataKeys;
Modified: trunk/layers/MapServer/php/LoadMap.php
--- trunk/layers/MapServer/php/LoadMap.php 2011-05-27 10:57:43 UTC (rev 2385)
+++ trunk/layers/MapServer/php/LoadMap.php 2011-05-27 19:11:57 UTC (rev 2386)
@@ -41,7 +41,9 @@
$moveToSession = true;
$modifyPaths = false;
-unset($_SESSION['selection_array']);
+if (!isset($_REQUEST['reload'])) {
+ unset($_SESSION['selection_array']);
TODO make it possible to specify only a relative path
@@ -434,6 +436,8 @@
//allow for nested groups using a "parentGroup" piece of metadata
//nesting of groups is accomplished by using the | as a separator
+ //this value becomes the groups uniqueId because groups with the
+ //same name can have diffferent parents.
$parentStr = $layer->getMetaData('parentGroup');
$nestedParents = array();
if (strlen($parentStr)>0) {
@@ -443,13 +447,10 @@
array_push($nestedParents, $layer->group);
$layerObj->parentGroup = implode("|",$nestedParents);
- //echo "/*";
- //print_r($nestedParents);
while (count($nestedParents)>0) {
$alreadyListed = false;
$parentId = implode("|",$nestedParents);
$parent = array_pop($nestedParents);
- //echo "-testing:".$parent." from:".$parentId."\n";
foreach($mapObj->groups as $pGroup) {
if ($pGroup->uniqueId == $parentId) {
$alreadyListed = true;
@@ -460,21 +461,9 @@
array_push($mapObj->groups, getGroupObject($layer, $parentId));
- //echo "*/";
array_push($mapObj->layers, $layerObj);
- $aGroups = $oMap->getAllGroupNames();
- if (is_array($aGroups)) {
- foreach($aGroups as $groupName) {
- $aLayerIndexes = $oMap->getLayersIndexByGroup($groupName);
- if (count($aLayerIndexes) > 0) {
- array_push($mapObj->groups, getGroupObject($oMap->getLayer($aLayerIndexes[0])));
echo var2json($mapObj);
@@ -504,28 +493,6 @@
return $group;
-function getParentGroupObject($layer,$groupName,$parent) {
- $parentGroup = $layer->getMetaData('parentGroup');
- $group = NULL;
- $group->groupName = $groupName;
- $ll = $layer->getMetaData('parentGroupLegendLabel');
- $group->legendLabel = $ll != '' ? $ll : $group->groupName;
- $group->uniqueId = $group->groupName;
- $b = $layer->getMetaData('groupDisplayInLegend');
- $group->displayInLegend = ($b == 'false') ? false : true;
- $b = $layer->getMetaData('groupExpandInLegend');
- $group->expandInLegend = ($b == 'false') ? false : true;
- $group->layerGroupType = '';
- /* maybe do some parsing of the metadata to get parents of paretns? */
- $group->parentUniqueId = $parentGroup;
- $group->parent = $parent;
- $b = $layer->getMetaData('groupVisible');
- $group->visible = ($b == 'false') ? false : true;
- $group->actuallyVisible = $layer->isVisible();
- return $group;
function GetMetersPerUnit($unit)
if ($unit == MS_INCHES)
More information about the fusion-commits
