[fusion-commits] r2390 - in trunk: layers/MapServer
layers/MapServer/php lib widgets
svn_fusion at osgeo.org
Tue May 31 16:32:54 EDT 2011
Author: madair
Date: 2011-05-31 13:32:54 -0700 (Tue, 31 May 2011)
New Revision: 2390
Added:
trunk/layers/MapServer/php/SaveSession.php
trunk/widgets/SaveSession.js
trunk/layers/MapServer/MapServer.js
trunk/layers/MapServer/php/RestoreState.php
trunk/lib/Map.js
re #457: implementation of the SaveSession widget pulled from the ext/packs svn
Modified: trunk/layers/MapServer/MapServer.js
--- trunk/layers/MapServer/MapServer.js 2011-05-31 07:22:37 UTC (rev 2389)
+++ trunk/layers/MapServer/MapServer.js 2011-05-31 20:32:54 UTC (rev 2390)
@@ -176,6 +176,10 @@
maxX: parseFloat(a[2]),
maxY: parseFloat(a[3])
+ if (this.oRestoredState.queryfile && this.oRestoredState.queryfile.length>0) {
+ this.bSelectionOn = true;
+ this._sQueryfile = this.oRestoredState.queryfile;
// done with session create, fire the event.
this.triggerEvent(Fusion.Event.MAP_SESSION_CREATED);
@@ -316,6 +320,9 @@
map: this._sMapFile,
map_imagetype: this._sImageType
+ if (this.hasSelection()) {
+ params.queryfile = this._sQueryfile;
OpenLayers.Util.extend(params, this.mapTag.layerParams);
//remove this layer if it was already loaded
Modified: trunk/layers/MapServer/php/RestoreState.php
--- trunk/layers/MapServer/php/RestoreState.php 2011-05-31 07:22:37 UTC (rev 2389)
+++ trunk/layers/MapServer/php/RestoreState.php 2011-05-31 20:32:54 UTC (rev 2390)
@@ -35,6 +35,7 @@
$oReturn->extents = $aData["_afCurrentExtents"];
$oReturn->vislayers = $aData["aVisibleLayers"];
$oReturn->sessionname = $aData["sessionName"];
+ $oReturn->queryfile = $aData["queryfile"];
$oReturn->loadmap = $szDestination."/".$oReturn->mapname.'.map';
$oMap = ms_newMapObj($oReturn->loadmap);
@@ -89,6 +90,14 @@
if($oLayer){
$oLayer->set("connection", $szDestination."/features.gml");
+ @$oLayer = $oMap->getLayerByName("LWEGML-Circle");
+ if($oLayer){
+ $oLayer->set("connection", $szDestination."/features.gml");
+ @$oLayer = $oMap->getLayerByName("LWEGML-Rectangle");
+ if($oLayer){
function readSessionSaveControlFile($szFileName){
Added: trunk/layers/MapServer/php/SaveSession.php
--- trunk/layers/MapServer/php/SaveSession.php (rev 0)
+++ trunk/layers/MapServer/php/SaveSession.php 2011-05-31 20:32:54 UTC (rev 2390)
@@ -0,0 +1,321 @@
+<?php
+ini_set("memory_limit","64M");
+ _____________________________________________________________________________
+ | sessionSave.php
+ | @project WCS-NAECPA
+ | @revision $Id: SaveSession.php 443 2011-03-31 20:10:33Z pdeschamps $
+ | @purpose Save map session
+ | @author Paul Deschamps (pdeschamps at dmsolutions.ca)
+ | @copyright
+ | <b>Copyright (c) 2001-2006 DM Solutions Group Inc.</b>
+ | Permission is hereby granted, free of charge, to any person obtaining a
+ | copy of this software and associated documentation files (the "Software"),
+ | to deal in the Software without restriction, including without limitation
+ | the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ | and/or sell copies of the Software, and to permit persons to whom the
+ | Software is furnished to do so, subject to the following conditions:
+ | The above copyright notice and this permission notice shall be included
+ | in all copies or substantial portions of the Software.
+ | THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ | IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ | FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ | THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ | LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ | FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHERf
+ | DEALINGS IN THE SOFTWARE.
+ |_____________________________________________________________________________
+//dl('zip.so');
+ /* set up the session */
+include(dirname(__FILE__).'/Common.php');
+include('../../../common/php/Utilities.php');
+//header('Content-type: application/json');
+//header('X-JSON: true');
+if (!isset($mapName)) {
+ die("{'error':'mapname not set'}");
+isset($_POST["session"])?$szSessionID = $_POST["session"]:$szSessionID = NULL ;
+isset($_REQUEST["layers"])?$szLayers = $_REQUEST["layers"]:$szLayers = NULL ;
+isset($_REQUEST["extents"])?$szExtents = $_REQUEST["extents"]:$szExtents = NULL ;
+isset($_REQUEST["queryfile"])?$szQueryFile = $_REQUEST["queryfile"]:$szQueryFile = NULL ;
+if (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
+ $oReturn = NULL;
+ $oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
+ $oReturn->sessionKey = generateKey(7);
+ $szStoreSessionPath = $_SESSION['fusionConfig']->mapserver->mapRestoreState;
+ $szFilePhpSession = $_SESSION['fusionConfig']->mapserver->mapRestoreStateSession;
+ $szZipFilename = $szStoreSessionPath."/ss_".$oReturn->sessionKey.".zip";
+ $szSourceDir = $szFilePhpSession."/sess_".$szSessionID."/";
+ // check to see if the file exists already it's a 1: 3,521,614,606,208 chance but not impossible :)
+ if(file_exists($szZipFilename)){
+ while(file_exists($szZipFilename) === TRUE){
+ $oReturn = NULL;
+ $szZipFilename = $szStoreSessionPath.$oReturn->sessionKey.".zip";
+ // data for the session Save File
+ $aData["mapname"] = $mapName;
+ $aData["sessionKey"] = $oReturn->sessionKey;
+ $aData["_afCurrentExtents"] = $szExtents;
+ $aData["aVisibleLayers"] = $szLayers;
+ $aData["queryfile"] = $szQueryFile;
+ // set the visable state in the session mapfile
+ turnOnVisableLayersInMapFile($oMap);
+ // save the map
+ $oMap->save($_SESSION['maps'][$mapName]);
+ // create the session save file
+ writeSessionSaveControlFile($aData,$szSourceDir."/");
+ // create a new zip.
+ $zip = new ZipArchive;
+ if ($zip->open($szZipFilename, ZIPARCHIVE::CREATE)!==TRUE) {
+ exit("{'error':'Can not create archive'}");
+ } else {
+ make_archive( $szSourceDir , &$zip, $extdir="");
+ $zip->close();
+ echo var2json($oReturn);
+ $handle = fopen($szStoreSessionPath.$oReturn->sessionKey.".dat", "w+");
+ fwrite($handle, serialize($aData));
+ fclose($handle);
+ //$result = new SavedSession($oReturn->sessionKey, true);
+function writeSessionSaveControlFile($aData,$szPath){
+ $handle = fopen($szPath."sessionInfo.txt", "w+");
+ $szOutput = "";
+ fclose($handle);
+function readSessionSaveControlFile($szFileName){
+ $handle = @fopen($szFileName, "r");
+ if($handle) {
+ $szData = fread($handle, filesize($szFileName));
+ fclose($handle);
+ return unserialize($szData);
+function turnOnVisableLayersInMapFile($oMap){
+ global $szLayers;
+ // trun off all layers except ones hidden from legend.
+ for ($i=0;$i<$oMap->numlayers;$i++){
+ $oLayer=$oMap->GetLayer($i);
+ // check to see that the layer is displayed in the legend
+ $bDisplayInLegend = $oLayer->getmetadata('displayInLegend');
+ if($bDisplayInLegend == false) {
+ $oLayer->set("status", MS_ON);
+ } else {
+ $oLayer->set("status", MS_OFF);
+ $aLayers = @split(',',$szLayers);
+ // cycle thru map layers
+ //cycle thru visable layers from app.
+ for($j=0;$j<count($aLayers);$j++){
+ // found app == map layer
+ if($aLayers[$j] == $oLayer->name){
+function make_archive( $dir , &$zip, $extdir="")
+if (is_dir($dir)) {
+ if ($dh = opendir($dir)) {
+ while (($file = readdir($dh)) !== false ) {
+ if( $file != "." && $file != ".." )
+ if( is_dir( $dir . $file ) )
+ $zip->addFile($dir.$file,$extdir.$file);
+ //echo "<br>add:".$dir.$file;
+ make_archive($dir.$file."/" , $zip, $extdir.$file."/");
+ else
+ closedir($dh);
+return true;
+function unzip($src_file, $dest_dir=false, $create_zip_name_dir=true, $overwrite=true)
+ if(function_exists("zip_open"))
+ if(!is_resource(zip_open($src_file)))
+ $src_file=dirname($_SERVER['SCRIPT_FILENAME'])."/".$src_file;
+ if (is_resource($zip = zip_open($src_file)))
+ $splitter = ($create_zip_name_dir === true) ? "." : "/";
+ if ($dest_dir === false) $dest_dir = substr($src_file, 0, strrpos($src_file, $splitter))."/";
+ // Create the directories to the destination dir if they don't already exist
+ create_dirs($dest_dir);
+ // For every file in the zip-packet
+ while ($zip_entry = zip_read($zip))
+ // Now we're going to create the directories in the destination directories
+ // If the file is not in the root dir
+ $pos_last_slash = strrpos(zip_entry_name($zip_entry), "/");
+ if ($pos_last_slash !== false)
+ // Create the directory where the zip-entry should be saved (with a "/" at the end)
+ create_dirs($dest_dir.substr(zip_entry_name($zip_entry), 0, $pos_last_slash+1));
+ // Open the entry
+ if (zip_entry_open($zip,$zip_entry,"r"))
+ // The name of the file to save on the disk
+ $file_name = $dest_dir.zip_entry_name($zip_entry);
+ // Check if the files should be overwritten or not
+ if ($overwrite === true || $overwrite === false && !is_file($file_name))
+ // Get the content of the zip entry
+ $fstream = zip_entry_read($zip_entry, zip_entry_filesize($zip_entry));
+ if(!is_dir($file_name))
+ file_put_contents($file_name, $fstream );
+ // Set the rights
+ if(file_exists($file_name))
+ chmod($file_name, 0777);
+ //echo "<span style=\"color:#1da319;\">file saved: </span>".$file_name."<br />";
+ else
+ //echo "<span style=\"color:red;\">file not found: </span>".$file_name."<br />";
+ // Close the entry
+ zip_entry_close($zip_entry);
+ // Close the zip-file
+ zip_close($zip);
+ else
+ return false;
+ return true;
+ else
+ if(version_compare(phpversion(), "5.2.0", "<"))
+ $infoVersion="(use PHP 5.2.0 or later)";
+ echo "You need to install/enable the php_zip.dll extension $infoVersion";
+function create_dirs($path)
+ if (!is_dir($path))
+ $directory_path = "";
+ $directories = explode("/",$path);
+ array_pop($directories);
+ foreach($directories as $directory)
+ $directory_path .= $directory."/";
+ if (!is_dir($directory_path))
+ mkdir($directory_path);
+ chmod($directory_path, 0777);
+function generateKey($iLength = 7){
+ a character length of 7 = 3,521,614,606,208 possiblities.
+ $aKeyParts = array("a","A","b","B","c","C","d","D","e","E","f","F","g","G","h","H","i","I","j","J","k","K","l","L","m","M","n","N","o","O","p","P","q","Q","r","R","s","S","t","T","u","U","v","V","w","W","x","X","y","Y","z","Z","0","1","2","3","4","5","6","7","8","9");
+ $szReturn = "";
+ for($i=0;$i<$iLength;$i++){
+ $szReturn = $szReturn.$aKeyParts[rand(0,count($aKeyParts)-1)];
+ return $szReturn;
+function generateFileName(){
+ $bSuccess = FALSE;
+ $i=0;
+ // there is a possibility that this could loop indefinately if the paths are set incorrectly so we'll add a count so it doesn't hang indefinately
+ while($bSuccess === FALSE || $i == 100){
+ $oReturn = NULL;
+ $oReturn->keygen = generateKey(7);
+ $oReturn->filename = STORED_SESSION_PATH."/ss_".$oReturn->keygen.".zip";
+ if(!file_exists($oReturn->filename)){
+ $bSuccess = TRUE;
+ $i++;
+ if($i == 100){
+ die("{error: 'There is an issue with the paths set in SaveSessionConfig file.'}");
+ return $oReturn;
\ No newline at end of file
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js 2011-05-31 07:22:37 UTC (rev 2389)
+++ trunk/lib/Map.js 2011-05-31 20:32:54 UTC (rev 2390)
@@ -338,22 +338,9 @@
if (this.aMaps.length == 1) {
this.oMapOL.setBaseLayer(this.aMaps[0].oLayerOL);
- Are we restoring a saved map state?
- if(this.aMaps[0].bRestoreMapState && this.aMaps[0].bRestoreMapState === true && typeof(this.aMaps[0].oRestoredState.extents) !=="undefined"){
- var a = this.aMaps[0].oRestoredState.extents.split(',');
- a[0] = parseFloat(a[0]);
- a[1] = parseFloat(a[1]);
- a[2] = parseFloat(a[2]);
- a[3] = parseFloat(a[3]);
- this.setExtents(new OpenLayers.Bounds(a[0], a[1], a[2], a[3]));
- else
var initialExtent = this.setInitialExtents();
this.setExtents(initialExtent);
this.triggerEvent(Fusion.Event.MAP_LOADED, mapTag);
Added: trunk/widgets/SaveSession.js
--- trunk/widgets/SaveSession.js (rev 0)
+++ trunk/widgets/SaveSession.js 2011-05-31 20:32:54 UTC (rev 2390)
@@ -0,0 +1,160 @@
+ * Fusion.Widget.SaveSession
+ * $Id: SaveSession.js 455 2011-05-17 17:24:43Z madair $
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Class: Fusion.Widget.SaveSession
+ * A Widget that saves the session folder and returns an unique id
+Fusion.Event.SAVE_SESSION_FINISHED = Fusion.Event.lastEventId++;
+Fusion.Widget.SaveSession = OpenLayers.Class(Fusion.Widget, {
+ oSessionName: null,
+ oInputURL: null,
+ oSaveSessionLink: null,
+ oSaveSessionShare: null,
+ oEmail: null,
+ oFacebook: null,
+ oTwitter: null,
+ oDialog: null,
+ bDrawn: false,
+ initializeWidget: function(widgetTag){
+ var arch = this.getMapLayer().arch;
+ var lang = Fusion.getScriptLanguage();
+ this.script = 'layers/' + arch + '/' + lang + '/SaveSession.' + lang;
+ this.getMap().registerEventID(Fusion.Event.SAVE_SESSION_FINISHED);
+ this.oDialog = new Jx.Dialog({
+ id: 'saveSessionDialog',
+ label: 'Save Session',
+ modal: false,
+ resize: true,
+ width:400,
+ height:200
+ activate: function(){
+ this.oDialog.open();
+ this.drawSaving();
+ this.save();
+ drawSaving: function() {
+ this.oDialog.content.empty();
+ var info = document.createElement('div');
+ info.innerHTML = "Saving session, please wait...";
+ info.addClass('sheetTip');
+ this.oDialog.content.adopt(info);
+ drawForm: function() {
+ this.form = new Jx.Form({
+ name: 'testForm',
+ formClass: 'jxFormInline'
+ }).addTo(this.oDialog.content);
+ var fieldSet2 = new Jx.Fieldset({
+ legend: 'Session URL',
+ id: 'FieldSet2',
+ fieldsetClass: 'jxFormInline'
+ }).addTo(this.form);
+ this.oInputURL = new Jx.Field.Text({
+ id: 'sessionUrl',
+ name: 'sessionUrl',
+ label: 'URL'
+ }).addTo(fieldSet2);
+ info.innerHTML = "Copy and paste the URL above to restore this session";
+ save: function(){
+ var that = this;
+ var mapWidget = this.getMap();
+ var mapLayer = this.getMapLayer();
+ var aMapExtents = [];
+ aMapExtents[0] = parseFloat(mapWidget._oCurrentExtents.left);
+ aMapExtents[1] = parseFloat(mapWidget._oCurrentExtents.bottom);
+ aMapExtents[2] = parseFloat(mapWidget._oCurrentExtents.right);
+ aMapExtents[3] = parseFloat(mapWidget._oCurrentExtents.top);
+ var params = {
+ parameters: OpenLayers.Util.getParameterString({
+ command: 'save',
+ extents: aMapExtents,
+ layers: mapLayer.aVisibleLayers,
+ session: mapLayer.getSessionID(),
+ mapname: mapLayer.getMapName()
+ onComplete: function(xhr) {
+ var o;
+ eval('o='+xhr.responseText);
+ that.saveCallBack(o);
+ if (mapLayer.hasSelection()) {
+ params.parameters += "&queryfile=" + mapLayer._sQueryfile;
+ Fusion.ajaxRequest(this.script,params);
+ saveCallBack: function(oKey){
+ if(oKey.error){
+ alert(oKey.error);
+ if(oKey.sessionKey){
+ this.drawForm();
+ var restoreURI = new URI(window.location.href);
+ restoreURI.setData({restoreState:oKey.sessionKey},true,'query');
+ this.oInputURL.setValue(restoreURI.toString());
+ this.oFacebook.href = "http://www.facebook.com/share.php?u="+escape(this.oInputURL.value)+"&t="+escape(this.oSessionName.value);
+ this.oFacebook.target = "_blank";
+ this.oTwitter.href = "http://twitter.com/home?status="+escape(this.oSessionName.value)+" :"+escape(this.oInputURL.value);
+ this.oTwitter.target = "_blank";
+ this.oEmail.href="mailto:?subject="+this.oSessionName.value+"&body="+escape("Here is a link to a map that I found interesting ")+this.oInputURL.value;
+ //mailto:you at yourdomain.com?subject=Your Subject&body=Message for the body.
+ this.showDiv(this.oSaveSessionShare);
+ //this.showDiv(this.oSaveSessionLink);
+ this.oInputURL.field.focus();
+ this.oInputURL.field.select();
More information about the fusion-commits
