[fusion-commits] r2446 - trunk/widgets/Theme
svn_fusion at osgeo.org
Thu Nov 3 16:03:13 EDT 2011
Author: madair
Date: 2011-11-03 13:03:13 -0700 (Thu, 03 Nov 2011)
New Revision: 2446
trunk/widgets/Theme/thememain.php
closes #259: adjusting how the Fusion window is retrieved
Modified: trunk/widgets/Theme/thememain.php
--- trunk/widgets/Theme/thememain.php 2011-11-02 17:31:57 UTC (rev 2445)
+++ trunk/widgets/Theme/thememain.php 2011-11-03 20:03:13 UTC (rev 2446)
@@ -358,12 +358,29 @@
document.getElementById("busyImg").src = NOT_BUSY_IMAGE;
themeReqHandler = null;
- var map = parent.Fusion.getMapByName(mapName);
+ var fWin = GetFusionWindow().Fusion;
+ var map = fWin.getWidgetById('Map');
map.reloadMap();
+ /* locate the Fusion window */
+ function GetFusionWindow() {
+ var curWindow = window;
+ while (!curWindow.Fusion) {
+ if (curWindow.parent && curWindow != curWindow.parent) {
+ curWindow = curWindow.parent;
+ } else if(curWindow.opener) {
+ curWindow = curWindow.opener;
+ } else {
+ alert('Could not find Fusion instance');
+ break;
+ return curWindow;
function OnLoad()
OnLayerChange();
More information about the fusion-commits
