[fusion-commits] r2451 - in trunk: lib widgets
svn_fusion at osgeo.org
Tue Nov 8 16:06:19 EST 2011
Author: madair
Date: 2011-11-08 13:06:19 -0800 (Tue, 08 Nov 2011)
New Revision: 2451
trunk/lib/Widget.js
trunk/widgets/Measure.js
trunk/widgets/Select.js
trunk/widgets/SelectPolygon.js
trunk/widgets/Zoom.js
re #480: make sure that widgets each have a unique ID so that it is easier to identify specific instances of a qidget for the 'shouldActivateWith' function. (Multiple widgets of same type that include a path handler is the problem.)
Modified: trunk/lib/Widget.js
--- trunk/lib/Widget.js 2011-11-08 20:17:34 UTC (rev 2450)
+++ trunk/lib/Widget.js 2011-11-08 21:06:19 UTC (rev 2451)
@@ -46,6 +46,7 @@
group: null,
domObj: null,
uiClass: null,
+ widgetUniqueId: null,
* initialize the widget
@@ -79,6 +80,7 @@
//check to see if this widget is associated with a specific Map
var json = widgetTag.extension;
this.widgetLayerId = json.WidgetLayerId ? json.WidgetLayerId[0] : null;
+ this.widgetUniqueId = OpenLayers.Util.createUniqueID("FusionWidget_");
this.initializeWidget(widgetTag);
Modified: trunk/widgets/Measure.js
--- trunk/widgets/Measure.js 2011-11-08 20:17:34 UTC (rev 2450)
+++ trunk/widgets/Measure.js 2011-11-08 21:06:19 UTC (rev 2451)
@@ -238,11 +238,12 @@
shouldActivateWith: function(widget) {
- return (widget instanceof Fusion.Widget.Measure &&
- widget.measureType == this.measureType);
+ return (widget instanceof Fusion.Widget.SelectPolygon &&
+ widget.widgetUniqueId == this.widgetUniqueId);
measure: function(stats) {
this.hasMeasure = true;
/* rebuild distance markers */
Modified: trunk/widgets/Select.js
--- trunk/widgets/Select.js 2011-11-08 20:17:34 UTC (rev 2450)
+++ trunk/widgets/Select.js 2011-11-08 21:06:19 UTC (rev 2451)
@@ -84,10 +84,11 @@
- return (widget instanceof Fusion.Widget.Select &&
- widget.bActiveOnly == this.bActiveOnly);
enable: function() {
if (this.bActiveOnly) {
var layer = this.getMap().getActiveLayer();
Modified: trunk/widgets/SelectPolygon.js
--- trunk/widgets/SelectPolygon.js 2011-11-08 20:17:34 UTC (rev 2450)
+++ trunk/widgets/SelectPolygon.js 2011-11-08 21:06:19 UTC (rev 2451)
@@ -63,6 +63,12 @@
mapWidget.handlers.push(this.handler);
+ shouldActivateWith: function(widget) {
* activate the widget (listen to mouse events and change cursor)
* This function should be defined for all functions that register
@@ -110,6 +116,7 @@
this.getMap().query(options);
+ return false;
setParameter: function(param, value) {
Modified: trunk/widgets/Zoom.js
--- trunk/widgets/Zoom.js 2011-11-08 20:17:34 UTC (rev 2450)
+++ trunk/widgets/Zoom.js 2011-11-08 21:06:19 UTC (rev 2451)
@@ -66,10 +66,9 @@
- return (widget instanceof Fusion.Widget.Zoom &&
- widget.zoomIn == this.zoomIn &&
- widget.factor == this.factor &&
- widget.tolerance == this.tolerance);
More information about the fusion-commits
