[fusion-commits] r2465 - trunk/widgets
svn_fusion at osgeo.org
Mon Nov 21 21:54:26 EST 2011
Author: liuar
Date: 2011-11-21 18:54:26 -0800 (Mon, 21 Nov 2011)
New Revision: 2465
trunk/widgets/CursorPosition.js
Fix ticket #467 Display units as degrees shows incorrect x/y values in Fusion.
Modified: trunk/widgets/CursorPosition.js
--- trunk/widgets/CursorPosition.js 2011-11-21 17:06:46 UTC (rev 2464)
+++ trunk/widgets/CursorPosition.js 2011-11-22 02:54:26 UTC (rev 2465)
@@ -104,39 +104,53 @@
formatHTML: function(p) {
- if (!this.displayProjection) {
- /* old code for converting between units */
- if (this.units != Fusion.UNKNOWN) {
- var convFactor = this.getMap().getMetersPerUnit();
- p.lon = Fusion.fromMeter(this.units, p.lon * convFactor);
- p.lat = Fusion.fromMeter(this.units, p.lat * convFactor);
- if (this.precision >= 0) {
- var factor = Math.pow(10,this.precision);
- p.lon = Math.round(p.lon * factor)/factor;
- p.lat = Math.round(p.lat * factor)/factor;
- var unitAbbr = Fusion.unitAbbr(this.units);
- var innerHTML = this.template.replace('{x}',p.lon.toFixed(this.precision));
- innerHTML = innerHTML.replace('{y}',p.lat.toFixed(this.precision));
- innerHTML = innerHTML.replace('{units}', unitAbbr).replace('{units}', unitAbbr);
- return innerHTML;
+ if (!this.displayProjection) {
+ var mapProj = this.getMap().projection;
+ var mapUnit = mapProj.getUnits();
+ // convertion from linear units to degree unit.
+ if(this.units == Fusion.DEGREES && mapUnit != 'dd' && mapUnit != 'degrees' ) {
+ // coordinate transformation from map CS to EPSG:4326.
+ var dest = new OpenLayers.Projection("GEOGCS[\"LL84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137.000,298.25722293]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.01745329251994]]");
+ p = p.transform(this.getMap().projection, dest);
+ //else
+ // TODO: convertion from degree unit to linear units
+ /* old code for converting between units */
+ else if (this.units != Fusion.UNKNOWN) {
+ var convFactor = this.getMap().getMetersPerUnit();
+ p.lon = Fusion.fromMeter(this.units, p.lon * convFactor);
+ p.lat = Fusion.fromMeter(this.units, p.lat * convFactor);
+ if (this.precision >= 0) {
+ var factor = Math.pow(10,this.precision);
+ p.lon = Math.round(p.lon * factor)/factor;
+ p.lat = Math.round(p.lat * factor)/factor;
+ var unitAbbr = Fusion.unitAbbr(this.units);
+ var innerHTML = this.template.replace('{x}',p.lon.toFixed(this.precision));
+ innerHTML = innerHTML.replace('{y}',p.lat.toFixed(this.precision));
+ innerHTML = innerHTML.replace('{units}', unitAbbr).replace('{units}', unitAbbr);
+ return innerHTML;
setUnits: function() {
- if (this.units == Fusion.UNKNOWN) {
- this.setParameter('Units',this.getMap().getUnits());
+ if (this.units == Fusion.UNKNOWN) {
+ this.setParameter('Units',this.getMap().getUnits());
setParameter: function(param, value) {
if (param == 'Units') {
- var unitName = value;
- if (this.displayProjection) {
- unitName = this.displayProjection.getUnits();
+ var unitName = value;
+ if (this.displayProjection) {
+ unitName = this.displayProjection.getUnits();
this.units = Fusion.unitFromName(unitName);
More information about the fusion-commits
