[fusion-commits] r2440 - trunk/widgets/Query/classes
svn_fusion at osgeo.org
Mon Oct 24 21:02:03 EDT 2011
Author: jng
Date: 2011-10-24 18:02:03 -0700 (Mon, 24 Oct 2011)
New Revision: 2440
trunk/widgets/Query/classes/query.php
Fix query widget not being able to query data stores that do not have spatial contexts correctly set up. Patch provided by Adam Jamison
Modified: trunk/widgets/Query/classes/query.php
--- trunk/widgets/Query/classes/query.php 2011-10-21 19:35:22 UTC (rev 2439)
+++ trunk/widgets/Query/classes/query.php 2011-10-25 01:02:03 UTC (rev 2440)
@@ -283,7 +283,8 @@
if ($this->args['USESPATIALFILTER'] == 'true')
$polygon = $this->CreatePolygonFromGeomText($this->args['GEOMTEXT']);
- $polygon = $polygon->Transform($csInverseTransform);
+ if ($csInverseTransform)
+ $polygon = $polygon->Transform($csInverseTransform);
$queryOptions->SetSpatialFilter($featureGeometry, $polygon, MgFeatureSpatialOperations::Intersects);
@@ -298,7 +299,8 @@
$byteReader = $featureReader->GetGeometry($featureGeometry);
$geometry = $geometryReaderWriter->Read($byteReader);
$centerPoint = $geometry->GetCentroid();
- $centerPoint = $centerPoint->Transform($csTransform);
+ if ($csTransform)
+ $centerPoint = $centerPoint->Transform($csTransform);
$idList = $this->GetFeatureIdList($map, $layer, $featureReader);
More information about the fusion-commits
