[fusion-commits] r2442 - trunk/widgets/Theme/templates
svn_fusion at osgeo.org
Wed Oct 26 02:57:04 EDT 2011
Author: liuar
Date: 2011-10-25 23:57:04 -0700 (Tue, 25 Oct 2011)
New Revision: 2442
Added:
trunk/widgets/Theme/templates/arearuletemplate-2.4.0-Enhanced.xml
trunk/widgets/Theme/templates/arearuletemplate-2.4.0.xml
Upgrade LayerDeninition version in Theme templates
Added: trunk/widgets/Theme/templates/arearuletemplate-2.4.0-Enhanced.xml
--- trunk/widgets/Theme/templates/arearuletemplate-2.4.0-Enhanced.xml (rev 0)
+++ trunk/widgets/Theme/templates/arearuletemplate-2.4.0-Enhanced.xml 2011-10-26 06:57:04 UTC (rev 2442)
@@ -0,0 +1,85 @@
+<CompositeRule>
+ <LegendLabel>%s</LegendLabel>
+ <Filter>%s</Filter>
+ <CompositeSymbolization>
+ <SymbolInstance>
+ <SimpleSymbolDefinition>
+ <Name>Solid Fill</Name>
+ <Description>Default Area Symbol</Description>
+ <Graphics>
+ <Path>
+ <Geometry>M 0.0,0.0 h 100.0 v 100.0 h -100.0 z</Geometry>
+ <FillColor>%s</FillColor>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ <RepeatX>100.0</RepeatX>
+ <RepeatY>100.0</RepeatY>
+ </AreaUsage>
+ <ParameterDefinition>
+ <Parameter>
+ <Identifier>FILLCOLOR</Identifier>
+ <DefaultValue>0xffbfbfbf</DefaultValue>
+ <DisplayName>&Fill Color</DisplayName>
+ <Description>Fill Color</Description>
+ <DataType>FillColor</DataType>
+ </Parameter>
+ </ParameterDefinition>
+ </SimpleSymbolDefinition>
+ <ParameterOverrides>
+ <Override>
+ <SymbolName>Solid Fill</SymbolName>
+ <ParameterIdentifier>FILLCOLOR</ParameterIdentifier>
+ <ParameterValue>0xffbfbfbf</ParameterValue>
+ </Override>
+ </ParameterOverrides>
+ <GeometryContext>Polygon</GeometryContext>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Name>Solid Line</Name>
+ <Description>Default Line Symbol</Description>
+ <Graphics>
+ <Path>
+ <Geometry>M 0.0,0.0 L 1.0,0.0</Geometry>
+ <LineColor>%s</LineColor>
+ <LineWeight>0.0</LineWeight>
+ <LineWeightScalable>false</LineWeightScalable>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ <Repeat>1.0</Repeat>
+ </LineUsage>
+ <Parameter>
+ <Identifier>LINECOLOR</Identifier>
+ <DefaultValue>0xff000000</DefaultValue>
+ <DisplayName>Line &Color</DisplayName>
+ <Description>Line Color</Description>
+ <DataType>LineColor</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>LINEWEIGHT</Identifier>
+ <DefaultValue>0.0</DefaultValue>
+ <DisplayName>Line &Thickness</DisplayName>
+ <Description>Line Thickness</Description>
+ <DataType>LineWeight</DataType>
+ </Parameter>
+ <Override>
+ <SymbolName>Solid Line</SymbolName>
+ <ParameterIdentifier>LINECOLOR</ParameterIdentifier>
+ <ParameterValue>0xff000000</ParameterValue>
+ </Override>
+ <Override>
+ <ParameterIdentifier>LINEWEIGHT</ParameterIdentifier>
+ <ParameterValue>0.0</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ </CompositeSymbolization>
+</CompositeRule>
\ No newline at end of file
Added: trunk/widgets/Theme/templates/arearuletemplate-2.4.0.xml
--- trunk/widgets/Theme/templates/arearuletemplate-2.4.0.xml (rev 0)
+++ trunk/widgets/Theme/templates/arearuletemplate-2.4.0.xml 2011-10-26 06:57:04 UTC (rev 2442)
@@ -0,0 +1,18 @@
+<AreaRule>
+ <AreaSymbolization2D>
+ <Fill>
+ <FillPattern>Solid</FillPattern>
+ <ForegroundColor>%s</ForegroundColor>
+ <BackgroundColor>FF000000</BackgroundColor>
+ </Fill>
+ <Stroke>
+ <LineStyle>Solid</LineStyle>
+ <Thickness>0</Thickness>
+ <Color>%s</Color>
+ <Unit>Inches</Unit>
+ <SizeContext>DeviceUnits</SizeContext>
+ </Stroke>
+ </AreaSymbolization2D>
+</AreaRule>
More information about the fusion-commits
