[fusion-commits] r2429 - in trunk/widgets: . QuickPlot widgetinfo
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Sep 26 12:07:59 EDT 2011
Author: jng
Date: 2011-09-26 09:07:59 -0700 (Mon, 26 Sep 2011)
New Revision: 2429
   trunk/widgets/QuickPlot.js
   trunk/widgets/QuickPlot/GeneratePicture.php
   trunk/widgets/QuickPlot/PreviewDialog.js
   trunk/widgets/QuickPlot/QuickPlotPanel.js
   trunk/widgets/QuickPlot/QuickPlotPanel.templ
   trunk/widgets/QuickPlot/QuickPlotPreview.js
   trunk/widgets/QuickPlot/QuickPlotPreviewInner.php
   trunk/widgets/QuickPlot/QuickPlotPreviewInner.templ
   trunk/widgets/widgetinfo/quickplot.xml
#460: Port over enhanced QuickPlot functionality from my github fork. A summary of the changes:
 1. Expose a whole lot of new widget extension options. See updated quickplot.xml for more details
   * RememberPlotOptions - Indicates whether to persist the current QuickPlot settings
   * ShowCoordinateLabels - Indicates whether to show the coordinate labels in the preview dialog
   * ShowSubTitle - Indicates whether to show the sub title in the preview dialog
   * DefaultDpi - The default DPI to use for plotting
   * PaperListEntry - Each entry specified will form the set of paper lists that will override the default list in the UI. If empty, the default list will be used
   * ScaleListEntry - Each entry specified will form the set of scale lists that will override the default list in the UI. If empty, the default list will be used
   * Disclaimer - The legal disclaimer text to show in the preview dialog and final printout
 2. Fix some defects and shortcomings in the QuickPlot widget
   * Allow the preview dialog to be displayed and closed multiple times
   * If any exceptions are caught in GeneratePicture.php, render the exception text out as an image
Modified: trunk/widgets/QuickPlot/GeneratePicture.php
--- trunk/widgets/QuickPlot/GeneratePicture.php	2011-09-26 12:44:33 UTC (rev 2428)
+++ trunk/widgets/QuickPlot/GeneratePicture.php	2011-09-26 16:07:59 UTC (rev 2429)
@@ -20,15 +20,21 @@
         GetParameters();
         GenerateMap($printSize);
-    catch (MgException $e)
-        header ("Content-type: text/html");
-        echo "ERROR: " . $e->GetExceptionMessage() . "<br>";
-        echo $e->GetStackTrace() . "<br>";
+    catch (MgException $e) {
+        $msg = "last error";
+        $msg .= "\nERROR: " . $e->GetExceptionMessage() . "\n";
+        $msg .= $e->GetDetails() . "\n";
+        $msg .= $e->GetStackTrace() . "\n";
+        RenderTextToImage($msg);
+    catch (Exception $ex) {
+        $msg = $ex->GetMessage();
 <?php
     function GetParameters()
         global $sessionID, $mapName, $printDpi, $rotation, $paperSize, $captureBox, $printSize, $scaleDenominator, $normalizedCapture;
Modified: trunk/widgets/QuickPlot/PreviewDialog.js
--- trunk/widgets/QuickPlot/PreviewDialog.js	2011-09-26 12:44:33 UTC (rev 2428)
+++ trunk/widgets/QuickPlot/PreviewDialog.js	2011-09-26 16:07:59 UTC (rev 2429)
@@ -221,6 +221,39 @@
     previewInnerLoaded: function()
+        //HACK: There is some state within these labels that gets invalidated in subsequent
+        //previews (ie. You click "Generate" on the Quick Plot panel multiple times without cancelling out the dialog).
+        //So detect this invalid state and remove these labels, forcing a rebuild
+        if (this.topLeftXYLabel)
+            var tlDoc = this.topLeftXYLabel.getDocument();
+            if (tlDoc.defaultView == null)
+                this.topLeftXYLabel.parentNode.removeChild(this.topLeftXYLabel);
+                this.topLeftXYLabel = null;
+        if (this.bottomRightXYLabel)
+            var brDoc = this.bottomRightXYLabel.getDocument();
+            if (brDoc.defaultView == null)
+                this.bottomRightXYLabel.parentNode.removeChild(this.bottomRightXYLabel);
+                this.bottomRightXYLabel = null;
+        if (this.printLabel)
+            var prDoc = this.printLabel.getDocument();
+            if (prDoc.defaultView == null)
+                this.printLabel.parentNode.removeChild(this.printLabel);
+                this.printLabel = null;
         this.previewInnerIsLoaded = true;
         if (this.resizeIsPending)
@@ -269,19 +302,22 @@
         this.printStyle.style.width  = realWidth + "px";
         this.printStyle.style.height = realHeight + "px";
-        // Create the coordinates labels
-        if (!this.topLeftXYLabel)
+        var showLabels = (this.params.showCoordinateLabels == true);
+        if (showLabels)
-            this.topLeftXYLabel = this.createCoordinateLabel(this.pictureContainer, this.captureInfo.topLeftCs.x, this.captureInfo.topLeftCs.y, "TopLeftXYLabel");
-            this.topLeftXYLabel.setOpacity(0);
+            // Create the coordinates labels
+            if (!this.topLeftXYLabel)
+                this.topLeftXYLabel = this.createCoordinateLabel(this.pictureContainer, this.captureInfo.topLeftCs.x, this.captureInfo.topLeftCs.y, "TopLeftXYLabel");
+                this.topLeftXYLabel.setOpacity(0);
+            if (!this.bottomRightXYLabel)
+                this.bottomRightXYLabel = this.createCoordinateLabel(this.pictureContainer, this.captureInfo.bottomRightCs.x, this.captureInfo.bottomRightCs.y, "BottomRightXYLabel");
+                this.bottomRightXYLabel.setOpacity(0);
-        if (!this.bottomRightXYLabel)
-            this.bottomRightXYLabel = this.createCoordinateLabel(this.pictureContainer, this.captureInfo.bottomRightCs.x, this.captureInfo.bottomRightCs.y, "BottomRightXYLabel");
-            this.bottomRightXYLabel.setOpacity(0);
         if (!this.printLabel)
             this.printLabel = this.createCoordinateLabel(this.pictureContainer, this.captureInfo.bottomRightCs.x, this.captureInfo.bottomRightCs.y, "PrintLabel");
@@ -290,19 +326,25 @@
         // Set the correct positions for the labels
         var pos    = this.getContentPosition(this.pictureContainer);
         var picDim = this.pictureContainer.getContentBoxSize();
-        this.topLeftXYLabel.style.left     = pos.left + this.csLabelOffset + "px";
-        this.topLeftXYLabel.style.top      = pos.top + this.csLabelOffset + "px";
-        var labelDim = this.bottomRightXYLabel.getMarginBoxSize();
-        this.bottomRightXYLabel.className  = "ScreenOnly";
-        this.bottomRightXYLabel.style.left = pos.left + picDim.width - this.csLabelOffset - labelDim.width + "px";
-        this.bottomRightXYLabel.style.top  = pos.top + picDim.height - this.csLabelOffset - labelDim.height + "px";
+        var labelDim = null;
+        if (showLabels) {
+            this.topLeftXYLabel.style.left     = pos.left + this.csLabelOffset + "px";
+            this.topLeftXYLabel.style.top      = pos.top + this.csLabelOffset + "px";
+            labelDim = this.bottomRightXYLabel.getMarginBoxSize();
+            this.bottomRightXYLabel.className  = "ScreenOnly";
+            this.bottomRightXYLabel.style.left = pos.left + picDim.width - this.csLabelOffset - labelDim.width + "px";
+            this.bottomRightXYLabel.style.top  = pos.top + picDim.height - this.csLabelOffset - labelDim.height + "px";
+            this.topLeftXYLabel.fade(1);
+            this.bottomRightXYLabel.fade(1);
         labelDim = this.printLabel.getMarginBoxSize();
         this.printLabel.className          = "PrintOnly";
         this.printLabel.style.left         = pos.left + realWidth - this.csLabelOffset - labelDim.width + "px";
         this.printLabel.style.top          = pos.top + realHeight - this.csLabelOffset - labelDim.height + "px";
-        this.topLeftXYLabel.fade(1);
-        this.bottomRightXYLabel.fade(1);
         // Enable the print button
         this.printButton.disabled  = false;
         this.cancelButton.disabled = false;
Modified: trunk/widgets/QuickPlot/QuickPlotPanel.js
--- trunk/widgets/QuickPlot/QuickPlotPanel.js	2011-09-26 12:44:33 UTC (rev 2428)
+++ trunk/widgets/QuickPlot/QuickPlotPanel.js	2011-09-26 16:07:59 UTC (rev 2429)
@@ -2,29 +2,95 @@
  * Copyright (C) 2010 Autodesk, Inc. All rights reserved.
+function panelLoaded()
+    var widget = getParent().Fusion.getWidgetsByType("QuickPlot")[0];
+    if (widget.paperList.length > 0)
+        var list = document.getElementById("PaperList");
+        list.options.length = 0;
+        for (var i = 0; i < widget.paperList.length; i++) {
+            var elOpt = document.createElement("option");
+            elOpt.text = widget.paperList[i].name;
+            elOpt.value = widget.paperList[i].size;
+            try {
+                list.add(elOpt, null);
+            catch (ex) {
+                list.add(elOpt); //IE
+    if (widget.scaleList.length > 0)
+        var list = document.getElementById("ScalingList");
+        for (var i = 0; i < widget.scaleList.length; i++) {
+            elOpt.text = widget.scaleList[i].name;
+            elOpt.value = widget.scaleList[i].scale;
+            try {
+            catch (ex) {
+    restoreUI();
 function restoreUI()
     setAdvancedOptionsUI(false);
-    // Read the last used options
-    lastPaperSize = getParent().Cookie.read("QuickPlotLastUsedPaperSize");
-    lastScale     = getParent().Cookie.read("QuickPlotLastUsedScaling");
-    lastDPI       = getParent().Cookie.read("QuickPlotLastUsedDPI");
-    if (lastPaperSize != null)
+    if (widget.persistPlotOptions)
-        document.getElementById("PaperList").value   = lastPaperSize;
+        // Read the last used options
+        lastPaperSize = getParent().Cookie.read("QuickPlotLastUsedPaperSize");
+        lastScale     = getParent().Cookie.read("QuickPlotLastUsedScaling");
+        lastDPI       = getParent().Cookie.read("QuickPlotLastUsedDPI");
+        if (lastPaperSize != null)
+            document.getElementById("PaperList").value   = lastPaperSize;
+        if (lastScale != null)
+            document.getElementById("ScalingList").value = lastScale;
+        if (lastDPI != null)
+            document.getElementById("DPIList").value     = lastDPI;
-    if (lastScale != null)
+    if (widget.defaultDpi)
-        document.getElementById("ScalingList").value = lastScale;
+        document.getElementById("DPICtrl").style.display = "none";
+        document.getElementById("DPILabel").style.display = "none";
+    else
+        document.getElementById("DPICtrl").style.display = "block";
+        document.getElementById("DPILabel").style.display = "block";
-    if (lastDPI != null)
+    if (widget.showSubTitle)
-        document.getElementById("DPIList").value     = lastDPI;
+        document.getElementById("SubTitleCtrl").style.display = "block";
+        document.getElementById("SubTitleLabel").style.display = "block";
+    else
+        document.getElementById("SubTitleCtrl").style.display = "none";
+        document.getElementById("SubTitleLabel").style.display = "none";
 function setAdvancedOptionsUI(enabled)
@@ -65,11 +131,15 @@
     var form = document.getElementById("Form1");
     form.target = windowName;
-    // Save the advanced options to a cookie
-    var cookieDuration = 365;
-    getParent().Cookie.write("QuickPlotLastUsedPaperSize", document.getElementById("PaperList").value, {duration:cookieDuration});
-    getParent().Cookie.write("QuickPlotLastUsedScaling", document.getElementById("ScalingList").value, {duration:cookieDuration});
-    getParent().Cookie.write("QuickPlotLastUsedDPI", document.getElementById("DPIList").value, {duration:cookieDuration});
+    if (widget.persistPlotOptions) {
+        // Save the advanced options to a cookie
+        var cookieDuration = 365;
+        getParent().Cookie.write("QuickPlotLastUsedPaperSize", document.getElementById("PaperList").value, {duration:cookieDuration});
+        getParent().Cookie.write("QuickPlotLastUsedScaling", document.getElementById("ScalingList").value, {duration:cookieDuration});
+        getParent().Cookie.write("QuickPlotLastUsedDPI", document.getElementById("DPIList").value, {duration:cookieDuration});
     form.submit();
@@ -121,6 +191,7 @@
     else
         var map        = getParent().Fusion.getWidgetById("Map");
         var paperSize  = getPaperSize();
         var viewerSize = map.getCurrentExtents().getSize();
         var factor     = map.getMetersPerUnit();
@@ -132,7 +203,8 @@
         else
             scale = viewerSize.w * factor * 1000 / paperSize.w;
+        scale = map.getScale();
     scale = parseInt(scale);
@@ -145,7 +217,11 @@
 function getPrintDpi()
-    return document.getElementById("DPIList").value;
+        return widget.defaultDpi;
+    else
+        return document.getElementById("DPIList").value;
 function drawCaptureBox()
Modified: trunk/widgets/QuickPlot/QuickPlotPanel.templ
--- trunk/widgets/QuickPlot/QuickPlotPanel.templ	2011-09-26 12:44:33 UTC (rev 2428)
+++ trunk/widgets/QuickPlot/QuickPlotPanel.templ	2011-09-26 16:07:59 UTC (rev 2429)
@@ -75,7 +75,7 @@
 <script language="javascript" type="text/javascript" src="%sQuickPlotPanel.js"></script>
 </head>
-<body onload="restoreUI()">
+<body onload="panelLoaded()">
     <form id="Form1" name="Form1" method="post" action="QuickPlotPreviewInner.php">
         <div class="Title FixWidth">__#QUICKPLOT_HEADER#__</div>
         <div class="Label ">__#QUICKPLOT_TITLE#__</div>
@@ -84,8 +84,8 @@
         </div>
         <div class="HPlaceholder5px"></div>
-        <div class="Label">__#QUICKPLOT_SUBTITLE#__</div>
-        <div class="Ctrl">
+        <div class="Label" id="SubTitleLabel">__#QUICKPLOT_SUBTITLE#__</div>
+        <div class="Ctrl" id="SubTitleCtrl">
             <input type="text" class="FixWidth" name="{field:sub_title}" maxLength=100"/>
         </div>
@@ -128,8 +128,8 @@
                 <option value="5000">1 : 5000</option>
             </select>
         </div>
-        <div class="Label">__#QUICKPLOT_DPI#__</div>
+        <div class="Label" id="DPILabel">__#QUICKPLOT_DPI#__</div>
+        <div class="Ctrl" id="DPICtrl">
                 The pre-defined print DPI.
                 We can change the html code to extend the pre-defined values
Modified: trunk/widgets/QuickPlot/QuickPlotPreview.js
--- trunk/widgets/QuickPlot/QuickPlotPreview.js	2011-09-26 12:44:33 UTC (rev 2428)
+++ trunk/widgets/QuickPlot/QuickPlotPreview.js	2011-09-26 16:07:59 UTC (rev 2429)
@@ -6,7 +6,10 @@
     if (parent.Fusion)
-        parent.Fusion.getWidgetsByType("QuickPlot")[0].previewInnerLoaded();
+        var widget = parent.Fusion.getWidgetsByType("QuickPlot")[0];
+        var disclaimer = widget.disclaimer;
+        document.getElementById("legalNotice").innerHTML = disclaimer;
+        widget.previewInnerLoaded();
Modified: trunk/widgets/QuickPlot/QuickPlotPreviewInner.php
--- trunk/widgets/QuickPlot/QuickPlotPreviewInner.php	2011-09-26 12:44:33 UTC (rev 2428)
+++ trunk/widgets/QuickPlot/QuickPlotPreviewInner.php	2011-09-26 16:07:59 UTC (rev 2429)
@@ -2,7 +2,7 @@
     $fusionMGpath = '../../layers/MapGuide/php/';
     include $fusionMGpath . 'Common.php';
     $locale = GetDefaultLocale();
     $scaleDenominator;
     $annotations;
@@ -28,7 +28,7 @@
         $templ = preg_replace($pattern, $date, $templ);
-    $jsPath    = "";
+    $jsPath = "";
     print sprintf($templ, $jsPath);
Modified: trunk/widgets/QuickPlot/QuickPlotPreviewInner.templ
--- trunk/widgets/QuickPlot/QuickPlotPreviewInner.templ	2011-09-26 12:44:33 UTC (rev 2428)
+++ trunk/widgets/QuickPlot/QuickPlotPreviewInner.templ	2011-09-26 16:07:59 UTC (rev 2429)
@@ -74,7 +74,7 @@
     <td><table width="100%%" border="0" cellspacing="0" cellpadding="0">
         <tr>
           <!-- Legal notice. Just replace it with the necessary statement -->
-          <td style="width:100%%" class="LegalNotice">The materials available at this web site are for informational purposes only and do not constitute a legal document.</td>
+          <td style="width:100%%" class="LegalNotice" id="legalNotice">}</td>
           <td style="white-space:nowrap"><input type="button" id="PrintButton" class="Button" onClick="printIt()" value="__#QUICKPLOT_PRINT#__" /><input type="button" id="CancelButton" class="Button" onClick="cancelPreview()" value="__#QUICKPLOT_CANCEL#__" />
           </td>
         </tr>
Modified: trunk/widgets/QuickPlot.js
--- trunk/widgets/QuickPlot.js	2011-09-26 12:44:33 UTC (rev 2428)
+++ trunk/widgets/QuickPlot.js	2011-09-26 16:07:59 UTC (rev 2429)
@@ -17,17 +17,96 @@
     uiClass: Jx.Button,
     sFeatures : 'menubar=no,location=no,resizable=no,status=no',
     options : {},
+    //The legal disclaimer text to display in the preview and final printout
+    disclaimer: "",
+    //The default DPI to use, if specified will hide the DPI field on the QuickPlot UI and override
+    //whatever DPI value is being used for plotting
+    defaultDpi: null,
+    //A custom paper size list. If specified, will override the default list in the QuickPlot UI
+    paperList: null,
+    //A custom scale list. If specified, will override the default list in the QuickPlot UI
+    scaleList: null,
+    //Indicates whether to show the coordinate labels in the QuickPlot preview dialog
+    showCoordinatesInPreview: true,
+    //Indicates whether to show the sub title in the QuickPlot UI and preview dialog
+    showSubTitle: true,
+    //Indicates whether cookies will be used to persist QuickPlot UI options
+    persistPlotOptions: false,
     initializeWidget: function(widgetTag)
         this.mapCapturer = new OpenLayers.Control.MapCapturer(this.getMap());
         this.getMap().oMapOL.addControl(this.mapCapturer);
-        var json                     = widgetTag.extension;
+        var json = widgetTag.extension;
         this.sTarget  = json.Target ? json.Target[0] : "PrintPanelWindow";
         this.sBaseUrl = Fusion.getFusionURL() + 'widgets/QuickPlot/QuickPlotPanel.php';
+        if (json.DefaultDpi) {
+            this.defaultDpi = parseInt(json.DefaultDpi[0]);
+        <PaperListEntry>
+          <Name>Letter</Name>
+          <Value>279.4,215.9</Value>
+        </PaperListEntry>
+        <PaperListEntry>
+          <Name>A4</Name>
+          <Value>297.0,210.0</Value>
+        </PaperListEntry>
+        this.paperList = [];
+        if (json.PaperListEntry) {
+            for (var i=0; i<json.PaperListEntry.length; i++)
+                var p = json.PaperListEntry[i];
+                var name = p.Name[0];
+                var size = p.Value[0];
+                this.paperList.push({ name: name, size: size });
+        <ScaleListEntry>
+          <Name>1:2500</Name>
+          <Value>2500</Value>
+        </ScaleListEntry>
+        <ScaleListEntry>
+          <Name>1:5000</Name>
+          <Value>5000</Value>
+        </ScaleListEntry>
+        this.scaleList = [];
+        if (json.ScaleListEntry) {
+            for (var i=0; i<json.ScaleListEntry.length; i++)
+                var p = json.ScaleListEntry[i];
+                var scale = p.Value[0];
+                this.scaleList.push({ name: name, scale: scale });
+        if (json.ShowSubTitle) {
+            this.showSubTitle = (json.ShowSubTitle[0] == 'true');
+        if (json.ShowCoordinateLabels) {
+            this.showCoordinatesInPreview = (json.ShowCoordinateLabels[0] == 'true');
+        if (json.RememberPlotOptions) {
+            this.persistPlotOptions = (json.RememberPlotOptions[0] == 'true');
+        if (json.Disclaimer) {
+            this.disclaimer = json.Disclaimer[0];
         this.additionalParameters = [];
         if (json.AdditionalParameter)
@@ -117,6 +196,8 @@
         var normalizedCapture = this.mapCapturer.getNormalizedCapture();
         var vertices = capture.geometry.getVertices();
         this.options.printDpi = printDpi;
+        this.options.showCoordinateLabels = this.showCoordinatesInPreview;
+        this.options.showSubTitle = this.showSubTitle;
         var options = {mapInfo : {sessionID : map.getSessionID(), name : map.getMapName()},
                        captureInfo : {topLeftCs : {x : vertices[3].x, y : vertices[3].y},
                                      bottomRightCs : {x : vertices[1].x, y : vertices[1].y},
Modified: trunk/widgets/widgetinfo/quickplot.xml
--- trunk/widgets/widgetinfo/quickplot.xml	2011-09-26 12:44:33 UTC (rev 2428)
+++ trunk/widgets/widgetinfo/quickplot.xml	2011-09-26 16:07:59 UTC (rev 2429)
@@ -16,4 +16,60 @@
         <DefaultValue>TaskPane</DefaultValue>
         <IsMandatory>true</IsMandatory>
     </Parameter>
+    <Parameter>
+        <Name>RememberPlotOptions</Name>
+        <Description>Indicates whether to persist the current QuickPlot UI settings to a cookie. If empty or false, these settings will not be saved</Description>
+        <Type>boolean</Type>
+        <Label>RememberPlotOptions</Label>
+        <DefaultValue>false</DefaultValue>
+        <IsMandatory>false</IsMandatory>
+    </Parameter>
+    <Parameter>
+        <Name>ShowCoordinateLabels</Name>
+        <Description>Indicates whether to show the coordinate labels in the QuickPlot preview dialog. If empty, will default to true</Description>
+        <Label>ShowCoordinateLabels</Label>
+        <DefaultValue>true</DefaultValue>
+    </Parameter>
+    <Parameter>
+        <Name>ShowSubTitle</Name>
+        <Description>Indicates whether to show the sub title in the QuickPlot UI and preview dialog. If empty, will default to true</Description>
+        <Label>ShowSubTitle</Label>
+    </Parameter>
+    <Parameter>
+        <Name>DefaultDpi</Name>
+        <Description>Indicates the default DPI to use for plotting. If specified, this will hide the DPI field in the QuickPlot UI and will override whatever DPI is used.</Description>
+        <Type>integer</Type>
+        <Label>DefaultDpi</Label>
+        <DefaultValue>96</DefaultValue>
+    </Parameter>
+    <Parameter>
+        <Name>PaperListEntry</Name>
+        <Description>Indicates a list of name/value pairs that will override the paper size list in the QuickPlot UI if specified.</Description>
+        <Type>xml</Type>
+        <Label>PaperListEntry</Label>
+        <DefaultValue></DefaultValue>
+    </Parameter>
+    <Parameter>
+        <Name>ScaleListEntry</Name>
+        <Description>Indicates a list of name/value pairs that will override the scale list in the QuickPlot UI if specified.</Description>
+        <Type>xml</Type>
+        <Label>ScaleListEntry</Label>
+    </Parameter>
+    <Parameter>
+        <Name>Disclaimer</Name>
+        <Description>The legal disclaimer text to show in the preview dialog and final printout</Description>
+        <Type>string</Type>
+        <Label>Disclaimer</Label>
+        <DefaultValue>The materials available at this web site are for informational purposes only and do not constitute a legal document.</DefaultValue>
+    </Parameter>
 </WidgetInfo>
More information about the fusion-commits mailing list
