[fusion-commits] r2534 - trunk/lib
svn_fusion at osgeo.org
Mon Apr 30 15:56:16 EDT 2012
Author: madair
Date: 2012-04-30 12:56:16 -0700 (Mon, 30 Apr 2012)
New Revision: 2534
trunk/lib/IE9patch.js
fix an error where extra attributes passed in with the tag
Modified: trunk/lib/IE9patch.js
--- trunk/lib/IE9patch.js 2012-04-23 06:43:43 UTC (rev 2533)
+++ trunk/lib/IE9patch.js 2012-04-30 19:56:16 UTC (rev 2534)
@@ -1,5 +1,9 @@
document.newElement = function(tag, props) {
var createdElement;
+ var temp = tag.split(' ').shift();//error in IE if tag has extra attributes listed
+ //just strip off the tag name, properties should
+ //set through the props argument
if (Browser.Engine.trident && props){
['name', 'type', 'checked'].each(function(attribute){
if (!props[attribute]) return;
@@ -13,12 +17,12 @@
createdElement = this.createElement(replaceTag);
catch (e) {
- createdElement = this.createElement(tag);
+ createdElement = this.createElement(temp);
else {
- return document.id(this.createElement(tag)).set(props);
\ No newline at end of file
+ return document.id(this.createElement(temp)).set(props);
More information about the fusion-commits
